[petsc-users] Configure takes very long
Hom Nath Gharti hng.email at gmail.com
Wed Apr 26 11:27:06 CDT 2017
Yes, I am compiling on a cluster. Thanks for the advice!
On Wed, Apr 26, 2017 at 12:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Great! Glad it work.
> With Intel MPI - I normally use mpiexec.hydra. However you must be
> using a cluster - and presumably 'srun' is the way to scedule mpi jobs
> on it.
> Satish
> On Wed, 26 Apr 2017, Hom Nath Gharti wrote:
>> Yes indeed! Thanks a lot, Satish! I am using intel MPI. Now I replace
>> mipexec with srun, and it configures quickly.
>> Hom Nath
>> On Wed, Apr 26, 2017 at 11:38 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > Perhaps mpiexec is hanging.
>> > What MPI are you using? Are you able to manually run jobs with
>> > mpiexec?
>> > Satish
>> >> Dear all,
>> >> With version > 3.7.4, I notice that the configure takes very long
>> >> about 24 hours!
>> >> Configure process hangs at the line:
>> >> TESTING: configureMPIEXEC from
>> >> config.packages.MPI(config/BuildSystem/config/packages/MPI.py:143)
>> >> Following is my configure command:
>> >> ./configure -with-blas-lapack-dir=/opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/lib/intel64
>> >> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
>> >> --with-mpiexec=mpiexec --with-debugging=1 --download-scalapack
>> >> --download-mumps --download-pastix --download-superlu
>> >> --download-superlu_dist --download-metis --download-parmetis
>> >> --download-ptscotch --download-hypre
>> >>              Configuring PETSc to compile on your system
>> >> Am I doing something wrong?
>> >> Thanks,
>> >> Hom Nath
