[petsc-users] Configure takes very long
Wed Apr 26 10:38:06 CDT 2017
Perhaps mpiexec is hanging.
What MPI are you using? Are you able to manually run jobs with
mpiexec?
Satish
On Wed, 26 Apr 2017, Hom Nath Gharti wrote:
> Dear all,
> With version > 3.7.4, I notice that the configure takes very long
> about 24 hours!
> Configure process hangs at the line:
> TESTING: configureMPIEXEC from
> config.packages.MPI(config/BuildSystem/config/packages/MPI.py:143)
> Following is my configure command:
> ./configure -with-blas-lapack-dir=/opt/intel/compilers_and_libraries_2017.2.174/linux/mkl/lib/intel64
> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> --with-mpiexec=mpiexec --with-debugging=1 --download-scalapack
> --download-mumps --download-pastix --download-superlu
> --download-superlu_dist --download-metis --download-parmetis
> --download-ptscotch --download-hypre
>              Configuring PETSc to compile on your system
> Am I doing something wrong?
> Thanks,
> Hom Nath
