[petsc-users] memory usage for dense vs sparse matrices
D D driver.dan12 at yahoo.com
Mon Apr 24 11:53:11 CDT 2017
Hmm, you are right. The case I did here is much more in line with our use case matrix sizes. Hmm. I need to do further experiments.
me at blah:~/src$ ./ex8 -n_row 200 -n_col 40000 -sparsity 0.03 -mat_type mpiaij
Initialize
Got options
Create and assemble matrix
Assembled
Peak RSS 19 Mb
me at blah:~/src$ ./ex8 -n_row 200 -n_col 40000 -sparsity 0.03 -mat_type mpidense
Initialize
Got options
Assembled
Peak RSS 80 Mb
Thank you, Andrew McRae and Zhang Hong.
    On Monday, April 24, 2017 12:45 PM, Andrew McRae <A.T.T.McRae at bath.ac.uk> wrote:
 This matrix is 2000 x 200?  That's tiny.  Even a 2000-by-200 dense matrix takes only (2000*200 entries)*(8 bytes per entry) to store, or about 3 MB.  The sparse version might take 150KB.  The 'peak RSS' differs by 2MB, so this seems consistent.
Try a 20,000 x 20,000 dense and sparse matrix, by which time the memory usage will be dominated by the matrix storage.
On 24 April 2017 at 17:24, D D <driver.dan12 at yahoo.com> wrote:
Unless, of course, my assumption is incorrect. But why should my assumption be incorrect?
I think I'm constructing my sparse matrix properly by calling MatSetFromOptions. The loop from line 52 - 57 in example1.cpp may be incorrect.
How do you think I should measure the effect of the size of the sparse vs dense matrix structure to make sure I'm effectively using the PETSc sparse matrix structure in my example code?
On Monday, April 24, 2017 12:10 PM, D D <driver.dan12 at yahoo.com> wrote:
You are correct, and that is why I'm using the peak RSS. The total memory should be lower to reflect the sparse versus dense structure.
On Monday, April 24, 2017 11:28 AM, "Zhang, Hong" <hongzhang at anl.gov> wrote:
The peak RSS does not tell you how much memory the matrix takes. It may include many things such as the binary, the libraries linked to it, and stack and heap memory.
Hong (Mr.)
On Apr 24, 2017, at 9:46 AM, D D <driver.dan12 at yahoo.com> wrote:
Hello,
I see memory usage that confuses me:
me at blah:src$ ./example1 -n_row 200 -n_col 2000 -sparsity 0.03 -mat_type mpidenseInitialize
Got options
Assembled
Peak RSS 21 Mb
me at blah:~/src$ ./example1 -n_row 200 -n_col 2000 -sparsity 0.03 -mat_type mpiaij
Initialize
Got options
Assembled
Peak RSS 19 Mb
I put my example code on Github so I can more effectively communicate my question. And here is my question: why does the program as written use so much memory for the sparse case - matrix type mpiaij? Note that I'm creating a random dense matrix with at most 3% non-zero entries since this is my use case.
I have read the relevant portions of the user's manual and searched for answers. Have I missed a resource that can answer my question?
dtsmith2001/hpc
dtsmith2001/hpc
hpc - High Performance Computing Explorations using PETSc and SLEPc |  |
Dale
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170424/329f1031/attachment.html>
