[petsc-users] petsc4py & GPU
Fri Apr 21 10:08:04 CDT 2017
On Fri, Apr 21, 2017 at 9:27 AM, Damian Kaliszan <damian at man.poznan.pl>
wrote:
> Hi Francesco, Matthew, Lisandro,
> Thank you a lot, it works:)
> However the next problem I'm facing is:
> -  I'm trying to run run a problem (Ax=b) with the size of A (equals to
> 3375x3375) using PBS on 10 nodes, each node has 2
> GPU  cards  with 2GB each.
> - 'qstat' shows these nodes are allocated, job
> is running
> - I use ksp/gmres
> - the error I get is as follows:
> =>> PBS: job killed: mem job total 5994876 kb exceeded limit 2048000 kb
You exceeded a memory limit. This should be mailed to your cluster admin
who can tell
you how to schedule it appropriately.
    Matt
> [0]PETSC ERROR: ------------------------------
> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> batch system) has told this process to end
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] VecNorm_MPICUDA line 34 /home/users/damiank/petsc_
> bitbucket/src/vec/vec/impls/mpi/mpicuda/mpicuda.cu
> [0]PETSC ERROR: [0] VecNorm line 217 /home/users/damiank/petsc_
> bitbucket/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: [0] VecNormalize line 317 /home/users/damiank/petsc_
> [0]PETSC ERROR: [0] KSPInitialResidual line 42 /home/users/damiank/petsc_
> bitbucket/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: [0] KSP_PCApplyBAorAB line 277 /home/users/damiank/petsc_
> bitbucket/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: [0] KSPGMRESCycle line 122 /home/users/damiank/petsc_
> bitbucket/src/ksp/ksp/impls/gmres/gmres.c
> - 'A' matrix is loaded in the following way (so as 'b' vector):
>  viewer = petsc4py.PETSc.Viewer().createBinary(A, 'r')
> A = PETSc.Mat().create(comm=MPI.COMM_WORLD)
> A.setType(PETSc.Mat.Type.MPIAIJCUSPARSE)
> A.load(viewer)
> - Do you know what is going wrong?
> Best,
> Damian
> W liście datowanym 20 kwietnia 2017 (19:15:33) napisano:
> > Hi Damian,
> > You can use the "parse_known_args" method of the ArgumentParser
> > class; it will create a Namespace with the args you defined and
> > return the uknown ones  as a list of strings you can pass to
> petsc4py.init.
> > See:
> > https://docs.python.org/3.6/library/argparse.html
> > section 16.4.5.7.
> > I used it successfully in the past. Hope this helps.
> > Best,
> > Francesco Caimmi
> > Laboratorio di Ingegneria dei Polimeri
> > http://www.chem.polimi.it/polyenglab/
> > Politecnico di Milano - Dipartimento di Chimica,
> > Materiali e Ingegneria Chimica “Giulio Natta”
> > P.zza Leonardo da Vinci, 32
> > I-20133 Milano
> > Tel. +39.02.2399.4711
> > Fax +39.02.7063.8173
> > francesco.caimmi at polimi.it
> > Skype: fmglcaimmi
> > ________________________________________
> > From: petsc-users-bounces at mcs.anl.gov
> > <petsc-users-bounces at mcs.anl.gov> on behalf of Damian Kaliszan <
> > Sent: Thursday, April 20, 2017 6:26 PM
> > To: Lisandro Dalcin
> > Cc: PETSc
> > Subject: Re: [petsc-users] petsc4py & GPU
> > Hi,
> > There might be the problem because I'm using ArgumentParser class
> > to catch complex command line arguments. In this case is there any
> > chance to make both to cooperate or the only solution is to pass
> > everything through argument to init method of petsc4py?
> > Best,
> > Damian
> > W dniu 20 kwi 2017, o 17:37, użytkownik Lisandro Dalcin
> > <dalcinl at gmail.com<mailto:dalcinl at gmail.com>> napisał:
> > On 20 April 2017 at 17:09, Damian Kaliszan
> > <damian at man.poznan.pl<mailto:damian at man.poznan.pl>> wrote:
> > Thank you for reply:) Sorry for maybe stupid question in the scope of
> setting petsc(4py) options.
> > Should the following calls (somewhere before creating matrix & vectors):
> > PETSc.Options().setValue("ksp_view", "")
> > PETSc.Options().setValue("log_view", "")
> > Unfortunately, no. There are a few options (-log_view ?) that you
> > should set before calling PetscInitialize() (which happens
> > automatically at import time), otherwise things do not work as
> > expected. To pass things from the command line and set them before
> > PetscInitialize() the usual idiom is:
> > import sys, petsc4py
> > petsc4py.init(sys.argv)
> > from petsc4py import PETSc
> > Lisandro Dalcin
> > Research Scientist
> > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > Extreme Computing Research Center (ECRC)
> > King Abdullah University of Science and Technology (KAUST)
> > http://ecrc.kaust.edu.sa/
> > 4700 King Abdullah University of Science and Technology
> > al-Khawarizmi Bldg (Bldg 1), Office # 0109
> > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > http://www.kaust.edu.sa
> > Office Phone: +966 12 808-0459
> Damian Kaliszan
> Poznan Supercomputing and Networking Center
> HPC and Data Centres Technologies
> ul. Jana Pawła II 10
> 61-139 Poznan
> POLAND
> phone (+48 61) 858 5109
> e-mail damian at man.poznan.pl
>  www - http://www.man.poznan.pl/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170421/852ac094/attachment.html>
