[petsc-users] Installation question
Wed Apr 19 13:02:20 CDT 2017
Sorry - should have mentioned:
do 'rm -rf arch-linux-cxx-opt' and rerun configure again.
The mpich install from previous build [that is currently in arch-linux-cxx-opt/]
is conflicting with --with-mpi-dir=/app1/centos6.3/gnu/mvapich2-1.9/
Satish
On Wed, 19 Apr 2017, Pham Pham wrote:
> I reconfigured PETSs with installed MPI, however, I got serous error:
> **************************ERROR*************************************
>   Error during compile, check arch-linux-cxx-opt/lib/petsc/conf/make.log
>   Send it and arch-linux-cxx-opt/lib/petsc/conf/configure.log to
> petsc-maint at mcs.anl.gov
> Please explain what is happening?
> Thank you very much.
> On Wed, Apr 19, 2017 at 11:43 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Presumably your cluster already has a recommended MPI to use [which is
> > already installed. So you should use that - instead of
> > --download-mpich=1
> > Satish
> > > Hi,
> > > I just installed petsc-3.7.5 into my university cluster. When evaluating
> > > the computer system, PETSc reports "It appears you have 1 node(s)", I
> > donot
> > > understand this, since the system is a multinodes system. Could you
> > please
> > > explain this to me?
> > > S.
> > > Output:
> > > Now to evaluate the computer systems you plan use - do:
> > > make PETSC_DIR=/home/svu/mpepvs/petsc/petsc-3.7.5
> > > PETSC_ARCH=arch-linux-cxx-opt streams
> > > [mpepvs at atlas7-c10 petsc-3.7.5]$ make
> > > streams
> > > cd src/benchmarks/streams; /usr/bin/gmake  --no-print-directory
> > > streams
> > > /home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/bin/mpicxx -o
> > > MPIVersion.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
> > > -Wno-unknown-pragmas -fvisibility=hidden -g -O
> > > -I/home/svu/mpepvs/petsc/petsc-3.7.5/include
> > > -I/home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/include
> > > `pwd`/MPIVersion.c
> > > Running streams with
> > > '/home/svu/mpepvs/petsc/petsc-3.7.5/arch-linux-cxx-opt/bin/mpiexec '
> > using
> > > 'NPMAX=12'
> > > Number of MPI processes 1 Processor names  atlas7-c10
> > > Triad:         9137.5025   Rate (MB/s)
> > > Number of MPI processes 2 Processor names  atlas7-c10 atlas7-c10
> > > Triad:         9707.2815   Rate (MB/s)
> > > Number of MPI processes 3 Processor names  atlas7-c10 atlas7-c10
> > atlas7-c10
> > > Triad:        13559.5275   Rate (MB/s)
> > > Number of MPI processes 4 Processor names  atlas7-c10 atlas7-c10
> > atlas7-c10
> > > atlas7-c10
> > > Triad:        14193.0597   Rate (MB/s)
> > > Number of MPI processes 5 Processor names  atlas7-c10 atlas7-c10
> > atlas7-c10
> > > Triad:        14492.9234   Rate (MB/s)
> > > Number of MPI processes 6 Processor names  atlas7-c10 atlas7-c10
> > atlas7-c10
> > > atlas7-c10 atlas7-c10 atlas7-c10
> > > Triad:        15476.5912   Rate (MB/s)
> > > Number of MPI processes 7 Processor names  atlas7-c10 atlas7-c10
> > atlas7-c10
> > > atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10
> > > Triad:        15148.7388   Rate (MB/s)
> > > Number of MPI processes 8 Processor names  atlas7-c10 atlas7-c10
> > atlas7-c10
> > > atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10
> > > Triad:        15799.1290   Rate (MB/s)
> > > Number of MPI processes 9 Processor names  atlas7-c10 atlas7-c10
> > atlas7-c10
> > > atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10 atlas7-c10
> > > Triad:        15671.3104   Rate (MB/s)
> > > Number of MPI processes 10 Processor names  atlas7-c10 atlas7-c10
> > > Triad:        15601.4754   Rate (MB/s)
> > > Number of MPI processes 11 Processor names  atlas7-c10 atlas7-c10
> > > Triad:        15434.5790   Rate (MB/s)
> > > Number of MPI processes 12 Processor names  atlas7-c10 atlas7-c10
> > > Triad:        15134.1263   Rate (MB/s)
> > > np  speedup
> > > 1 1.0
> > > 2 1.06
> > > 3 1.48
> > > 4 1.55
> > > 5 1.59
> > > 6 1.69
> > > 7 1.66
> > > 8 1.73
> > > 9 1.72
> > > 10 1.71
> > > 11 1.69
> > > 12 1.66
> > > Estimation of possible speedup of MPI programs based on Streams
> > benchmark.
> > > Unable to plot speedup to a file
> > > Unable to open matplotlib to plot speedup
