[petsc-users] Partitioning does not work
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Tue Apr 18 07:02:27 CDT 2017
> On 15 Apr 2017, at 22:31, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   The DMPlex experts and point you in the correct direction.
>> On Apr 15, 2017, at 4:28 PM, Orxan Shibliyev <orxan.shibli at gmail.com> wrote:
>> About partitioning of DMPlex, manual says that,
>> In exactly the same way as MatPartitioning and MatOrdering, we encode the results of a partition or order in an IS. However, the graph we are dealing with now is not the adjacency graph of the problem Jacobian, but the mesh itself.
>> I could not find a function related to partitioning to feed in DM object. I know how to partition with adjacency matrix but not with DM. Would you refer me to an example in which DMPlex is partitioned or to a proper function?
You want DMPlexDistribute.  See, for example snes/examples/tutorials/ex12.c, which solves Poisson with simplicial elements.
Lawrence
