[petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
Barletta, Ivano ibarletta at inogs.it
Thu Apr 13 10:56:07 CDT 2017
I'm interested in this topic as well
Thanks
Ivano
2017-04-11 16:21 GMT+02:00 Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com>
> Hello,
> I’m trying to use DMPlexCreateFromCellListParallel to create a DM from an
> already partitioned mesh,
> It requires an array of numVertices*spaceDim numbers, but how should one
> order the coordinates of the vertices?
> we only pass the global vertex numbers using ‘const int cells[]’ to define
> the cell-connectivity, so passing the vertex coordinates in local ordering
> wouldn’t make sense?
> If it needs to be in global ordering, should I sort the global index of
> the node numbers owned by each rank (as they wont be continuous).
> Thank you
> Hassan Raiesi,
> Bombardier Aerospace
> www.bombardier.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170413/05482917/attachment-0001.html>
