[petsc-users] how to use petsc4py with mpi subcommunicators?
Rodrigo Felicio Rodrigo.Felicio at iongeo.com
Wed Apr 12 12:10:14 CDT 2017
Going over my older codes I found out that I have already tried the approach of splitting PETSc.COMM_WORLD, but whenever I try to create a matrix using a subcommuicator, the program fails. For example, executing the following python code attached to this msg,  I get the following output
time mpirun -n 5 python another_split_ex.py
petsc rank=2, petsc size=5
petsc rank=3, petsc size=5
petsc rank=0, petsc size=5
petsc rank=1, petsc size=5
petsc rank=4, petsc size=5
number of subcomms = 2
sub rank 0/3, color:0
sub rank 0/2, color:1
sub rank 1/3, color:0
sub rank 1/2, color:1
sub rank 2/3, color:0
creating A in subcomm 1= 2, 1
creating A in subcomm 1= 2, 0
Traceback (most recent call last):
  File "another_split_ex.py", line 43, in <module>
    A = PETSc.Mat().createDense([n,n], comm=subcomm)
  File "PETSc/Mat.pyx", line 390, in petsc4py.PETSc.Mat.createDense (src/petsc4py.PETSc.c:113792)
  File "PETSc/petscmat.pxi", line 602, in petsc4py.PETSc.Mat_Create (src/petsc4py.PETSc.c:25274)
  File "PETSc/petscsys.pxi", line 104, in petsc4py.PETSc.Sys_Layout (src/petsc4py.PETSc.c:13666)
petsc4py.PETSc.Error: petsc4py.PETSc.Errorerror code 608517
[1] PetscSplitOwnership() line 86 in ~/mylocal/petsc/src/sys/utils/psplit.c
: error code 134826245
[3] PetscSplitOwnership() line 86 in ~/mylocal/petsc/src/sys/utils/psplit.c
Checking the traceback, all I can say is that when the subcommunicator object reaches psplit.c code it gets somehow corrupted, because PetscSplitOwnership() fails to retrieve the size of the subcommunicator ... :-(
regards
Rodrigo
This email and any files transmitted with it are confidential and are intended solely for the use of the individual or entity to whom they are addressed. If you are not the original recipient or the person responsible for delivering the email to the intended recipient, be advised that you have received this email in error, and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited. If you received this email in error, please immediately notify the sender and delete the original.
Type: text/x-python
Desc: another_split_ex.py
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170412/425c6686/attachment.py>
