[petsc-users] how to use petsc4py with mpi subcommunicators?
Rodrigo Felicio Rodrigo.Felicio at iongeo.com
Wed Apr 12 09:30:56 CDT 2017
Thanks Jed and Gaetan.
I will try that approach of splitting PETSc.COMM_WORLD,  but I still need to load mpi4py (probably after PETSc), because PETSc.Comm is very limited, i.e., it does not have the split function, for example. My goal is to be able to set different matrices and vectors for each subcommunicator, and I am guessing that I can create them using something like PETSc.Mat().createAij(comm=subcomm)
Kind regards
Rodrigo
This email and any files transmitted with it are confidential and are intended solely for the use of the individual or entity to whom they are addressed. If you are not the original recipient or the person responsible for delivering the email to the intended recipient, be advised that you have received this email in error, and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited. If you received this email in error, please immediately notify the sender and delete the original.
