[petsc-users] FindPETSc.cmake expects petscvariables in wrong location
Tue Apr 11 11:27:05 CDT 2017
On Tue, 11 Apr 2017, Satish Balay wrote:
> On Tue, 11 Apr 2017, Joachim Wuttke wrote:
> > > you need to give me details on how you installed petsc. [say make.log]
> > tar zxvf petsc-3.7.5.tar.gz
> > cd petsc-3.7.5
> > ./configure --with-shared-libraries PETSC_DIR=/usr/local/src/petsc-3.7.5
> > PETSC_ARCH=linux-amd64 --with-mpi-dir=/usr/lib/x86_64-linux-gnu/openmpi
> > make MAKE_NP=7 PETSC_DIR=/usr/local/src/petsc-3.7.5 PETSC_ARCH=linux-amd64 all
> So you are not using prefix install - so would require to use 'PETSC_DIR=/usr/local/src/petsc-3.7.5 PETSC_ARCH=linux-amd64' with FindPETSc.cmake
> Wrt your previous note:
> However, in the current source archive, it is located in
>   ${PETSC_DIR}/lib/petsc/conf/petscvariables,
> and the default install procedure does not copy it to ${PETSC_ARCH}.
> Thre is also be
> ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/petscvariables - that
> FindPETSc.cmake should find
> If it doesn't work - send the relavent cmake logs - and Jed might
> provide better debug instructions.
Also - please confirm if 'make test' was successful for your build.
> Satish
