[petsc-users] status of "make install" ?
Tue Apr 11 10:31:05 CDT 2017
It supports 2 modes:
1. inplace [default]:
./configure && make
2. prefix
./configure --prefix=/prefix/location && make && make install
So to use 'make install' - you need to run configure with the correct prefix option.
Satish
On Tue, 11 Apr 2017, Joachim Wuttke wrote:
> Does PETSc support the usual installation command sequence
> configure; make; make install?
> The installation web page does not mention "make install".
> The Makefile generated by configure does contain a target "install".
> However, "make install" does not work; it yields the error message
>   "Incorrect prefix usage. Specified destDir same as current
>   PETSC_DIR/PETSC_ARCH"
