[petsc-users] Solving NON-Diagonally dominant sparse system
Dave May dave.mayhem23 at gmail.com
Tue Apr 11 01:27:09 CDT 2017
On Tue, 11 Apr 2017 at 07:28, Kaushik Kulkarni <kaushikggg at gmail.com> wrote:
> A strange behavior I am observing is:
> Problem: I have to solve A*x=rhs, and currently I am currently trying to
> solve for a system where I know the exact solution. I have initialized the
> exact solution in the Vec x_exact.
> MatMult(A, x_exact, dummy);// Storing the value of A*x_exact in dummy
> VecAXPY(dummy, -1.0, rhs); // dummy = dummy -rhs
> VecNorm(dummy, NORM_INFINITY, &norm_val); // norm_val = ||dummy||, which
> gives us the residual norm
> PetscPrintf(PETSC_COMM_SELF, "Norm = %f\n", norm_val); // Printing the
> norm.
> // Starting with the linear solver
> KSPCreate(PETSC_COMM_SELF, &ksp);
> KSPSetOperators(ksp, A, A);
> KSPSetFromOptions(ksp);
> KSPSolve(ksp,rhs,x_exact); // Solving the system A*x= rhs, with the given
> initial input x_exact. So the result will also be stored in x_exact
> On running with -pc_type lu -pc_factor_mat_solver_package superlu
> -ksp_monitor I get the following output:
> Norm = 0.000000
>   0 KSP Residual norm 4.371606462669e+04
>   1 KSP Residual norm 5.850058113796e+02
>   2 KSP Residual norm 5.832677911508e+02
>   3 KSP Residual norm 1.987386549571e+02
>   4 KSP Residual norm 1.220006530614e+02
The default KSP is left preconditioned GMRES. Hence the above iterates
report the preconditioned residual. If your operator is singular, and LU
generated garbage, the preconditioned residual can be very different to the
true residual.
To see the true residual, use
-ksp_monitor_true_residual
Alternatively, use a right preconditioned KSP method, e.g.
-ksp_type fgmres
(or -ksp_type gcr)
With these methods, you will see the true residual with just -ksp_monitor
Thanks
  Dave
> Since the initial guess is the exact solution should'nt the first residual
> itself be zero and converge in one iteration.
> Thanks,
> Kaushik
> On Tue, Apr 11, 2017 at 10:08 AM, Kaushik Kulkarni <kaushikggg at gmail.com>
> wrote:
> Thank you for the inputs.
> I tried Barry' s suggestion to use SuperLU, but the solution does not
> converge and on doing -ksp_monitor -ksp_converged_reason. I get the
> following error:-
> 240 KSP Residual norm 1.722571678777e+07
> Linear solve did not converge due to DIVERGED_DTOL iterations 240
> For some reason it is diverging, although I am sure that for the given
> system a unique solution exists.
> Thanks,
> Kaushik
> On Tue, Apr 11, 2017 at 1:04 AM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> If you need to use SuperLU_DIST, the pivoting is done statically, using
> maximum weighted matching, so the small diagonals are usually taken care as
> well. It is not as good as partial pivoting, but works most of the time.
> Sherry
> On Mon, Apr 10, 2017 at 12:07 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    I would suggest using ./configure --download-superlu and then when
> running the program -pc_type lu -pc_factor_mat_solver_package superlu
>    Note that this is SuperLU, it is not SuperLU_DIST.  Superlu uses
> partial pivoting for numerical stability so should be able to handle the
> small or zero diagonal entries.
>     Barry
> > On Apr 10, 2017, at 1:17 PM, Kaushik Kulkarni <kaushikggg at gmail.com>
> wrote:
> > Hello,
> > I am trying to solve a 2500x2500 sparse matrix. To get an idea about the
> matrix structure I have added a file matrix.log which contains the output
> of MatView() and also the output of Matview_draw in the image file.
> > From the matrix structure it can be seen that Jacobi iteration won't
> work and some of the diagonal entries being very low(of the order of 1E-16)
> LU factorization would also fail.
> > C​an someone please suggest what all could I try next, in order to make
> the solution converge?
> > Thanks,
> > Kaushik
> > Kaushik Kulkarni
> > Fourth Year Undergraduate
> > Department of Mechanical Engineering
> > Indian Institute of Technology Bombay
> > Mumbai, India
> > https://kaushikcfd.github.io/About/
> > +91-9967687150
> > <matrix.log><matrix_pattern.png>
> Kaushik Kulkarni
> Mumbai, India
> +91-9967687150
> Kaushik Kulkarni
> Mumbai, India
> +91-9967687150
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170411/6b692489/attachment-0001.html>
