[petsc-users] GAMG for the unsymmetrical matrix
Kong, Fande fande.kong at inl.gov
Mon Apr 10 11:17:23 CDT 2017
On Sun, Apr 9, 2017 at 6:04 AM, Mark Adams <mfadams at lbl.gov> wrote:
> You seem to have two levels here and 3M eqs on the fine grid and 37 on
> the coarse grid.
37 is on the sub domain.
 rows=18145, cols=18145 on the entire coarse grid.
> I don't understand that.
> You are also calling the AMG setup a lot, but not spending much time
> in it. Try running with -info and grep on "GAMG".
> On Fri, Apr 7, 2017 at 5:29 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Thanks, Barry.
> > It works.
> > GAMG is three times better than ASM in terms of the number of linear
> > iterations, but it is five times slower than ASM. Any suggestions to
> improve
> > the performance of GAMG? Log files are attached.
> > Fande,
> > On Thu, Apr 6, 2017 at 3:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> > On Apr 6, 2017, at 9:39 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> >> > Thanks, Mark and Barry,
> >> > It works pretty wells in terms of the number of linear iterations
> (using
> >> > "-pc_gamg_sym_graph true"), but it is horrible in the compute time. I
> am
> >> > using the two-level method via "-pc_mg_levels 2". The reason why the
> compute
> >> > time is larger than other preconditioning options is that a matrix
> free
> >> > method is used in the fine level and in my particular problem the
> function
> >> > evaluation is expensive.
> >> > I am using "-snes_mf_operator 1" to turn on the Jacobian-free Newton,
> >> > but I do not think I want to make the preconditioning part
> matrix-free.  Do
> >> > you guys know how to turn off the matrix-free method for GAMG?
> >>    -pc_use_amat false
> >> > Here is the detailed solver:
> >> > SNES Object: 384 MPI processes
> >> >   type: newtonls
> >> >   maximum iterations=200, maximum function evaluations=10000
> >> >   tolerances: relative=1e-08, absolute=1e-08, solution=1e-50
> >> >   total number of linear solver iterations=20
> >> >   total number of function evaluations=166
> >> >   norm schedule ALWAYS
> >> >   SNESLineSearch Object:   384 MPI processes
> >> >     type: bt
> >> >       interpolation: cubic
> >> >       alpha=1.000000e-04
> >> >     maxstep=1.000000e+08, minlambda=1.000000e-12
> >> >     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> >> > lambda=1.000000e-08
> >> >     maximum iterations=40
> >> >   KSP Object:   384 MPI processes
> >> >     type: gmres
> >> >       GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
> >> > Orthogonalization with no iterative refinement
> >> >       GMRES: happy breakdown tolerance 1e-30
> >> >     maximum iterations=100, initial guess is zero
> >> >     tolerances:  relative=0.001, absolute=1e-50, divergence=10000.
> >> >     right preconditioning
> >> >     using UNPRECONDITIONED norm type for convergence test
> >> >   PC Object:   384 MPI processes
> >> >     type: gamg
> >> >       MG: type is MULTIPLICATIVE, levels=2 cycles=v
> >> >         Cycles per PCApply=1
> >> >         Using Galerkin computed coarse grid matrices
> >> >         GAMG specific options
> >> >           Threshold for dropping small values from graph 0.
> >> >           AGG specific options
> >> >             Symmetric graph true
> >> >     Coarse grid solver -- level -------------------------------
> >> >       KSP Object:      (mg_coarse_)       384 MPI processes
> >> >         type: preonly
> >> >         maximum iterations=10000, initial guess is zero
> >> >         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >> >         left preconditioning
> >> >         using NONE norm type for convergence test
> >> >       PC Object:      (mg_coarse_)       384 MPI processes
> >> >         type: bjacobi
> >> >           block Jacobi: number of blocks = 384
> >> >           Local solve is same for all blocks, in the following KSP and
> >> > PC objects:
> >> >         KSP Object:        (mg_coarse_sub_)         1 MPI processes
> >> >           type: preonly
> >> >           maximum iterations=1, initial guess is zero
> divergence=10000.
> >> >         PC Object:        (mg_coarse_sub_)         1 MPI processes
> >> >           type: lu
> >> >             LU: out-of-place factorization
> >> >             tolerance for zero pivot 2.22045e-14
> >> >             using diagonal shift on blocks to prevent zero pivot
> >> > [INBLOCKS]
> >> >             matrix ordering: nd
> >> >             factor fill ratio given 5., needed 1.31367
> >> >               Factored matrix follows:
> >> >                 Mat Object:                 1 MPI processes
> >> >                   type: seqaij
> >> >                   rows=37, cols=37
> >> >                   package used to perform factorization: petsc
> >> >                   total: nonzeros=913, allocated nonzeros=913
> >> >                   total number of mallocs used during MatSetValues
> calls
> >> > =0
> >> >                     not using I-node routines
> >> >           linear system matrix = precond matrix:
> >> >             type: seqaij
> >> >             rows=37, cols=37
> >> >             total: nonzeros=695, allocated nonzeros=695
> >> >             total number of mallocs used during MatSetValues calls =0
> >> >         Mat Object:         384 MPI processes
> >> >           type: mpiaij
> >> >           total: nonzeros=1709115, allocated nonzeros=1709115
> >> >             not using I-node (on process 0) routines
> >> >     Down solver (pre-smoother) on level 1
> >> >       KSP Object:      (mg_levels_1_)       384 MPI processes
> >> >         type: chebyshev
> >> >           Chebyshev: eigenvalue estimates:  min = 0.133339, max =
> >> > 1.46673
> >> >           Chebyshev: eigenvalues estimated using gmres with
> translations
> >> > [0. 0.1; 0. 1.1]
> >> >           KSP Object:          (mg_levels_1_esteig_)           384 MPI
> >> > processes
> >> >             type: gmres
> >> >               GMRES: restart=30, using Classical (unmodified)
> >> > Gram-Schmidt Orthogonalization with no iterative refinement
> >> >             maximum iterations=10, initial guess is zero
> >> >             tolerances:  relative=1e-12, absolute=1e-50,
> >> > divergence=10000.
> >> >             using PRECONDITIONED norm type for convergence test
> >> >         using nonzero initial guess
> >> >       PC Object:      (mg_levels_1_)       384 MPI processes
> >> >         type: sor
> >> >           SOR: type = local_symmetric, iterations = 1, local
> iterations
> >> > = 1, omega = 1.
> >> >         linear system matrix followed by preconditioner matrix:
> >> >           type: mffd
> >> >           rows=3020875, cols=3020875
> >> >             Matrix-free approximation:
> >> >               err=1.49012e-08 (relative error in function evaluation)
> >> >               Using wp compute h routine
> >> >                   Does not compute normU
> >> >         Mat Object:        ()         384 MPI processes
> >> >           type: mpiaij
> >> >           total: nonzeros=215671710, allocated nonzeros=241731750
> >> >     Up solver (post-smoother) same as down solver (pre-smoother)
> >> >       type: mffd
> >> >       type: mpiaij
> >> > Fande,
> >> > On Thu, Apr 6, 2017 at 8:27 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >> > On Tue, Apr 4, 2017 at 10:10 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >> > >> Does this mean that GAMG works for the symmetrical matrix only?
> >> > >   No, it means that for non symmetric nonzero structure you need the
> >> > > extra flag. So use the extra flag. The reason we don't always use
> the flag
> >> > > is because it adds extra cost and isn't needed if the matrix
> already has a
> >> > > symmetric nonzero structure.
> >> > BTW, if you have symmetric non-zero structure you can just set
> >> > -pc_gamg_threshold -1.0', note the "or" in the message.
> >> > If you want to mess with the threshold then you need to use the
> >> > symmetrized flag.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170410/faa9e8ed/attachment.html>
