[petsc-users] odd behavior when using lapack's dgeev with petsc
Manav Bhatia bhatiamanav at gmail.com
Fri Apr 7 13:46:13 CDT 2017
   I have compile petsc on my Ubuntu machine (also Mac OS 10.12 separately) to link to the system lapack and blas libraries (shown below).
   I have created an interface class to dgeev in lapack to calculate the eigenvalues of a matrix.
   My application code links to multiple libraries: libMesh, petsc, slepc, hdf5, etc.
   If I test my interface inside this application code, I get junk results.
   However, on the same machine, if I use the interface in a separate main() function without linking to any of the libraries except lapack and blas, then I get expected results.
   Also, this problem does not show up on Mac.
   I am not sure what could be causing this and don’t quite know where to start. Could Petsc have anything to do with this?
   Any insight would be greatly appreciated.
Manav
manav at manav1:~/test$ ldd /opt/local/lib/libpetsc.so
	linux-vdso.so.1 =>  (0x00007fff3e7a8000)
	libsuperlu_dist.so.5 => /opt/local/lib/libsuperlu_dist.so.5 (0x00007f721fbd1000)
	libparmetis.so => /opt/local/lib/libparmetis.so (0x00007f721f990000)
	libmetis.so => /opt/local/lib/libmetis.so (0x00007f721f718000)
	libsuperlu.so.5 => /opt/local/lib/libsuperlu.so.5 (0x00007f721f4a7000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f721f124000)
	liblapack.so.3 => /usr/lib/liblapack.so.3 (0x00007f721e92c000)
	libblas.so.3 => /usr/lib/libblas.so.3 (0x00007f721e6bd000)
	libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f721e382000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f721e079000)
	libmpi_mpifh.so.12 => /usr/lib/libmpi_mpifh.so.12 (0x00007f721de20000)
	libgfortran.so.3 => /usr/lib/x86_64-linux-gnu/libgfortran.so.3 (0x00007f721daf4000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f721d8f0000)
	libmpi.so.12 => /usr/lib/libmpi.so.12 (0x00007f721d61a000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f721d403000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f721d1e6000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f721ce1d000)
	/lib64/ld-linux-x86-64.so.2 (0x000055d739f1b000)
	libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f721cbcf000)
	libopen-pal.so.13 => /usr/lib/libopen-pal.so.13 (0x00007f721c932000)
	libquadmath.so.0 => /usr/lib/x86_64-linux-gnu/libquadmath.so.0 (0x00007f721c6f2000)
	libibverbs.so.1 => /usr/lib/libibverbs.so.1 (0x00007f721c4e3000)
	libopen-rte.so.12 => /usr/lib/libopen-rte.so.12 (0x00007f721c269000)
	libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f721c064000)
	libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f721be5e000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f721bc56000)
	libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f721ba52000)
	libhwloc.so.5 => /usr/lib/x86_64-linux-gnu/libhwloc.so.5 (0x00007f721b818000)
	libnuma.so.1 => /usr/lib/x86_64-linux-gnu/libnuma.so.1 (0x00007f721b60c000)
	libltdl.so.7 => /usr/lib/x86_64-linux-gnu/libltdl.so.7 (0x00007f721b402000)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170407/fdb9fe65/attachment.html>
