[petsc-users] EPSViewer in SLEPc
Jose E. Roman jroman at dsic.upv.es
Fri Apr 7 05:41:44 CDT 2017
I have pushed a commit that should avoid this problem.
Jose
> El 6 abr 2017, a las 22:27, Kong, Fande <fande.kong at inl.gov> escribió:
> Hi All,
> The EPSViewer in SLEPc looks weird. I do not understand the viewer logic. For example there is a piece of code in SLEPc (at line 225 of epsview.c):
>     if (!ispower) {
>       if (!eps->ds) { ierr = EPSGetDS(eps,&eps->ds);CHKERRQ(ierr); }
>       ierr = DSView(eps->ds,viewer);CHKERRQ(ierr);
> If eps->ds is NULL, why we are going to create a new one? I just want to view this object. If it is NULL, you should just show me that this object is empty. You could print out: ds: null.
> If a user wants to develop a new EPS solver, and then register the new EPS to SLEPc. But the user does not want to use DS, and DSView will show some error messages:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Requested matrix was not created in this DS
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.5, unknown
> [0]PETSC ERROR: ../../../moose_test-opt on a arch-darwin-c-debug named FN604208 by kongf Thu Apr  6 14:22:14 2017
> [0]PETSC ERROR: #1 DSViewMat() line 149 in /slepc/src/sys/classes/ds/interface/dspriv.c
> [0]PETSC ERROR: #2 DSView_NHEP() line 47 in/slepc/src/sys/classes/ds/impls/nhep/dsnhep.c
> [0]PETSC ERROR: #3 DSView() line 772 in/slepc/src/sys/classes/ds/interface/dsbasic.c
> [0]PETSC ERROR: #4 EPSView() line 227 in /slepc/src/eps/interface/epsview.c
> [0]PETSC ERROR: #5 PetscObjectView() line 106 in/petsc/src/sys/objects/destroy.c
> [0]PETSC ERROR: #6 PetscObjectViewFromOptions() line 2808 in /petsc/src/sys/objects/options.c
> [0]PETSC ERROR: #7 EPSSolve() line 159 in /slepc/src/eps/interface/epssolve.c
> Fande,
