[petsc-users] GAMG for the unsymmetrical matrix
Kong, Fande fande.kong at inl.gov
Thu Apr 6 09:39:31 CDT 2017
Thanks, Mark and Barry,
It works pretty wells in terms of the number of linear iterations (using
"-pc_gamg_sym_graph true"), but it is horrible in the compute time. I am
using the two-level method via "-pc_mg_levels 2". The reason why the
compute time is larger than other preconditioning options is that a matrix
free method is used in the fine level and in my particular problem the
function evaluation is expensive.
I am using "-snes_mf_operator 1" to turn on the Jacobian-free Newton, but I
do not think I want to make the preconditioning part matrix-free.  Do you
guys know how to turn off the matrix-free method for GAMG?
Here is the detailed solver:
*SNES Object: 384 MPI processes  type: newtonls  maximum iterations=200,
maximum function evaluations=10000  tolerances: relative=1e-08,
absolute=1e-08, solution=1e-50  total number of linear solver
iterations=20  total number of function evaluations=166  norm schedule
ALWAYS  SNESLineSearch Object:   384 MPI processes    type: bt
interpolation: cubic      alpha=1.000000e-04    maxstep=1.000000e+08,
minlambda=1.000000e-12    tolerances: relative=1.000000e-08,
absolute=1.000000e-15, lambda=1.000000e-08    maximum iterations=40  KSP
Object:   384 MPI processes    type: gmres      GMRES: restart=100, using
Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative
refinement      GMRES: happy breakdown tolerance 1e-30    maximum
iterations=100, initial guess is zero    tolerances:  relative=0.001,
absolute=1e-50, divergence=10000.    right preconditioning    using
UNPRECONDITIONED norm type for convergence test  PC Object:   384 MPI
processes    type: gamg      MG: type is MULTIPLICATIVE, levels=2
cycles=v        Cycles per PCApply=1        Using Galerkin computed coarse
grid matrices        GAMG specific options          Threshold for dropping
small values from graph 0.          AGG specific options
Symmetric graph true    Coarse grid solver -- level
-------------------------------      KSP Object:      (mg_coarse_)
384 MPI processes        type: preonly        maximum iterations=10000,
initial guess is zero        tolerances:  relative=1e-05, absolute=1e-50,
divergence=10000.        left preconditioning        using NONE norm type
for convergence test      PC Object:      (mg_coarse_)       384 MPI
processes        type: bjacobi          block Jacobi: number of blocks =
384          Local solve is same for all blocks, in the following KSP and
PC objects:        KSP Object:        (mg_coarse_sub_)         1 MPI
processes          type: preonly          maximum iterations=1, initial
type for convergence test        PC Object:        (mg_coarse_sub_)
1 MPI processes          type: lu            LU: out-of-place
factorization            tolerance for zero pivot 2.22045e-14
using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
matrix ordering: nd            factor fill ratio given 5., needed
1.31367              Factored matrix follows:                Mat
Object:                 1 MPI processes                  type:
seqaij                  rows=37, cols=37                  package used to
perform factorization: petsc                  total: nonzeros=913,
allocated nonzeros=913                  total number of mallocs used during
MatSetValues calls =0                    not using I-node routines
linear system matrix = precond matrix:          Mat Object:           1 MPI
processes            type: seqaij            rows=37, cols=37
total: nonzeros=695, allocated nonzeros=695            total number of
mallocs used during MatSetValues calls =0              not using I-node
routines        linear system matrix = precond matrix:        Mat
Object:         384 MPI processes          type: mpiaij
rows=18145, cols=18145          total: nonzeros=1709115, allocated
nonzeros=1709115          total number of mallocs used during MatSetValues
calls =0            not using I-node (on process 0) routines    Down solver
(pre-smoother) on level 1 -------------------------------      KSP
Object:      (mg_levels_1_)       384 MPI processes        type:
chebyshev          Chebyshev: eigenvalue estimates:  min = 0.133339, max =
1.46673          Chebyshev: eigenvalues estimated using gmres with
translations  [0. 0.1; 0. 1.1]          KSP Object:
(mg_levels_1_esteig_)           384 MPI processes            type:
gmres              GMRES: restart=30, using Classical (unmodified)
Gram-Schmidt Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30            maximum iterations=10,
initial guess is zero            tolerances:  relative=1e-12,
absolute=1e-50, divergence=10000.            left
preconditioning            using PRECONDITIONED norm type for convergence
test        maximum iterations=2        tolerances:  relative=1e-05,
absolute=1e-50, divergence=10000.        left preconditioning        using
nonzero initial guess        using NONE norm type for convergence test
PC Object:      (mg_levels_1_)       384 MPI processes        type:
sor          SOR: type = local_symmetric, iterations = 1, local iterations
= 1, omega = 1.        linear system matrix followed by preconditioner
matrix:        Mat Object:         384 MPI processes          type:
mffd          rows=3020875, cols=3020875            Matrix-free
approximation:              err=1.49012e-08 (relative error in function
evaluation)              Using wp compute h routine                  Does
not compute normU        Mat Object:        ()         384 MPI
processes          type: mpiaij          rows=3020875,
cols=3020875          total: nonzeros=215671710, allocated
nonzeros=241731750          total number of mallocs used during
MatSetValues calls =0            not using I-node (on process 0)
routines    Up solver (post-smoother) same as down solver (pre-smoother)
linear system matrix followed by preconditioner matrix:    Mat Object:
384 MPI processes      type: mffd      rows=3020875, cols=3020875
Matrix-free approximation:          err=1.49012e-08 (relative error in
function evaluation)          Using wp compute h routine              Does
not compute normU    Mat Object:    ()     384 MPI processes      type:
mpiaij      rows=3020875, cols=3020875      total: nonzeros=215671710,
allocated nonzeros=241731750      total number of mallocs used during
MatSetValues calls =0        not using I-node (on process 0) routines*
Fande,
On Thu, Apr 6, 2017 at 8:27 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Tue, Apr 4, 2017 at 10:10 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> Does this mean that GAMG works for the symmetrical matrix only?
> >   No, it means that for non symmetric nonzero structure you need the
> extra flag. So use the extra flag. The reason we don't always use the flag
> is because it adds extra cost and isn't needed if the matrix already has a
> symmetric nonzero structure.
> BTW, if you have symmetric non-zero structure you can just set
> -pc_gamg_threshold -1.0', note the "or" in the message.
> If you want to mess with the threshold then you need to use the
> symmetrized flag.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170406/dd55487e/attachment.html>
