[petsc-users] Configuring PETSc for KNL
Thu Apr 6 06:25:31 CDT 2017
On Wed, Apr 5, 2017 at 10:26 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Wed, Apr 5, 2017 at 12:23 PM, Justin Chang <jychang48 at gmail.com>
> wrote:
> >> I simply ran these KNL simulations in flat mode with the following
> options:
> >> srun -n 64 -c 4 --cpu_bind=cores numactl -p 1 ./ex48 ....
> >> Basically I told it that MCDRAM usage in NUMA domain 1 is preferred. I
> >> followed the last example: http://www.nersc.gov/users/
> >> computational-systems/cori/configuration/knl-processor-modes/
> > Right. I think, from the prior discussion, that -m 1 causes the run to
> fail
> > if you spill out of MCDRAM. I think that is usually
> > what we want since it makes things easier to interpret and running MKL
> from
> > DRAM is like towing your McLaren with
> > your Toyota.
> I'm not sure whether getting the Intel acronyms mixed up (KNL vs MKL)
> makes the quote above better or worse.
Too cryptic. Are you saying that this cannot be what is happening? How
would you explain
the drop off in performance?
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170406/f05b9189/attachment.html>
