[petsc-users] Configuring PETSc for KNL
Jed Brown jed at jedbrown.org
Wed Apr 5 07:54:19 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
> On Wed, Apr 5, 2017 at 12:12 AM, Richard Mills <richardtmills at gmail.com>
> wrote:
>> On Tue, Apr 4, 2017 at 9:10 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> >    These results seem reasonable to me.
>>> >    What makes you think that KNL should be doing better than it does in
>>> comparison to Haswell?
>>> >    The entire reason for the existence of KNL is that it is a way for
>>> >    Intel to be able to "compete" with Nvidia GPUs for numerics and
>>> >    data processing, for example in the financial industry. By
>>> >    "compete" I mean convince gullible purchasing agents for large
>>> >    companies to purchase Intel KNL systems instead of Nvidia GPU
>>> >    systems. There is nothing in the hardware specifications of KNL
>>> >    that would indicate that it should work better on this type of
>>> >    problem than Haswell, in fact the specifications indicate that the
>>> >    Haskell should perform better
>>> Boom!  Time to rewrite PETSc in Haskell!
>> Yeah, forget this debate about using C++!
> I think what Jed means is Time to write a Haskell program to Write PETSc.
Free your points and your mind will follow.
https://wiki.haskell.org/Pointfree
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170405/fb55013f/attachment.pgp>
