[petsc-users] Slepc JD and GD converge to wrong eigenpair
Toon Weyens toon.weyens at gmail.com
Tue Apr 4 07:34:38 CDT 2017
Ah ok. When I find the time I will have a look into mapping processes to
cores. I guess it is possible using the torque scheduler.
Thank you!
On Tue, Apr 4, 2017 at 2:00 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 4, 2017 at 6:58 AM, Toon Weyens <toon.weyens at gmail.com> wrote:
> Dear Matthew,
> Thanks for your answer, but this is something I do not really know much
> about... The node I used has 12 cores and about 24GB of RAM.
> But for these test cases, isn't the distribution of memory over cores
> handled automatically by SLEPC?
> No. Its handled by MPI, which just passes that job off to the OS, which
> does a crap job.
>    Matt
> Regards
> On Tue, Apr 4, 2017 at 1:40 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 4, 2017 at 2:20 AM, Toon Weyens <toon.weyens at gmail.com> wrote:
> Dear Jose and Matthew,
> Thank you so much for the effort!
> I still don't manage to converge using the range interval technique to
> filter out the positive eigenvalues, but using shift-invert combined with a
> target eigenvalue does true miracles. I get extremely fast convergence.
> The truth of the matter is that we are mainly interested in negative
> eigenvalues (unstable modes), and from physical considerations they are
> more or less situated in -0.2<lambda<0 in the normalized quantities that we
> use. So we will just use guesses.
> Thank you so much again!
> Also, I have finally managed to run streams (the cluster is quite full
> atm). These are the outputs:
> 1) This shows you have a bad process mapping. You could get much more
> speedup for 1-4 procs by properly mapping processes to cores, perhaps with
> numactl.
> 2) Essentially 3 processes can saturate your memory bandwidth, so I would
> not expect much gain from using more than 4.
>   Thanks,
>      Matt
> 1 processes
> Number of MPI processes 1 Processor names  c04b27
> Triad:        12352.0825   Rate (MB/s)
> 2 processes
> Number of MPI processes 2 Processor names  c04b27 c04b27
> Triad:        18968.0226   Rate (MB/s)
> 3 processes
> Number of MPI processes 3 Processor names  c04b27 c04b27 c04b27
> Triad:        21106.8580   Rate (MB/s)
> 4 processes
> Number of MPI processes 4 Processor names  c04b27 c04b27 c04b27 c04b27
> Triad:        21655.5885   Rate (MB/s)
> 5 processes
> Number of MPI processes 5 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27
> Triad:        21627.5559   Rate (MB/s)
> 6 processes
> Number of MPI processes 6 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27
> Triad:        21394.9620   Rate (MB/s)
> 7 processes
> Number of MPI processes 7 Processor names  c04b27 c04b27 c04b27 c04b27
> Triad:        24952.7076   Rate (MB/s)
> 8 processes
> Number of MPI processes 8 Processor names  c04b27 c04b27 c04b27 c04b27
> Triad:        28357.1062   Rate (MB/s)
> 9 processes
> Number of MPI processes 9 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        31720.4545   Rate (MB/s)
> 10 processes
> Number of MPI processes 10 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        35198.7412   Rate (MB/s)
> 11 processes
> Number of MPI processes 11 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        38616.0615   Rate (MB/s)
> 12 processes
> Number of MPI processes 12 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        41939.3994   Rate (MB/s)
> I attach a figure.
> Thanks again!
> On Mon, Apr 3, 2017 at 8:29 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > El 1 abr 2017, a las 0:01, Toon Weyens <toon.weyens at gmail.com> escribió:
> > Dear jose,
> > I have saved the matrices in Matlab format and am sending them to you
> using pCloud. If you want another format, please tell me. Please also note
> that they are about 1.4GB each.
> > I also attach a typical output of eps_view and log_view in output.txt,
> for 8 processes.
> > Thanks so much for helping me out! I think Petsc and Slepc are amazing
> inventions that really have saved me many months of work!
> > Regards
> I played a little bit with your matrices.
> With Krylov-Schur I can solve the problem quite easily. Note that in
> generalized eigenvalue problems it is always better to use STSINVERT
> because you have to invert a matrix anyway. So instead of setting
> which=smallest_real, use shift-and-invert with a target that is close to
> the wanted eigenvalue. For instance, with target=-0.005 I get convergence
> with just one iteration:
> $ ./ex7 -f1 A.bin -f2 B.bin -st_ksp_type preonly -st_pc_type lu
> -st_pc_factor_mat_solver_package mumps -eps_tol 1e-5 -st_type sinvert
> -eps_target -0.005
> Generalized eigenproblem stored in file.
>  Reading COMPLEX matrices from binary files...
>  Number of iterations of the method: 1
>  Number of linear iterations of the method: 16
>  Solution method: krylovschur
>  Number of requested eigenvalues: 1
>  Stopping condition: tol=1e-05, maxit=7500
>  Linear eigensolve converged (1 eigenpair) due to CONVERGED_TOL;
> iterations 1
>             k             ||Ax-kBx||/||kx||
>   -0.004809-0.000000i       8.82085e-05
> Of course, you don't know a priori where your eigenvalue is.
> Alternatively, you can set the target at 0 and get rid of positive
> eigenvalues with a region filtering. For instance:
> -eps_target 0 -rg_type interval -rg_interval_endpoints -1,0,-.05,.05
> -eps_nev 2
>  Number of iterations of the method: 8
>  Number of linear iterations of the method: 74
>  Number of requested eigenvalues: 2
>  Stopping condition: tol=1e-05, maxit=7058
>  Linear eigensolve converged (2 eigenpairs) due to CONVERGED_TOL;
> iterations 8
>             k             ||Ax-kBx||/||kx||
>   -0.000392-0.000000i            2636.4
>   -0.004809+0.000000i            318441
> In this case, the residuals seem very bad. But this is due to the fact
> that your matrices have huge norms. Adding the option -eps_error_backward
> ::ascii_info_detail  will show residuals relative to the matrix norms:
>             k                 eta(x,k)
>   -0.000392-0.000000i       3.78647e-11
>   -0.004809+0.000000i       5.61419e-08
> Regarding the GD solver, I am also getting the correct solution. I don't
> know why you are not getting convergence to the wanted eigenvalue:
> -st_pc_factor_mat_solver_package mumps -eps_tol 1e-5 -eps_smallest_real
> -eps_ncv 32 -eps_type gd
>  Number of iterations of the method: 132
>  Number of linear iterations of the method: 0
>  Solution method: gd
>  Stopping condition: tol=1e-05, maxit=120000
> iterations 132
>             k             ||Ax-kBx||/||kx||
>   -0.004809+0.000000i       2.16223e-05
> Again, it is much better to use a target instead of smallest_real:
> -st_pc_factor_mat_solver_package mumps -eps_tol 1e-5 -eps_type gd
> -eps_target -0.005
>  Number of iterations of the method: 23
>  Solution method: gd
> iterations 23
>             k             ||Ax-kBx||/||kx||
>   -0.004809-0.000000i       2.06572e-05
> Jose
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170404/49ca6828/attachment-0001.html>
