[petsc-users] Slepc JD and GD converge to wrong eigenpair
Tue Apr 4 06:40:39 CDT 2017
On Tue, Apr 4, 2017 at 2:20 AM, Toon Weyens <toon.weyens at gmail.com> wrote:
> Dear Jose and Matthew,
> Thank you so much for the effort!
> I still don't manage to converge using the range interval technique to
> filter out the positive eigenvalues, but using shift-invert combined with a
> target eigenvalue does true miracles. I get extremely fast convergence.
> The truth of the matter is that we are mainly interested in negative
> eigenvalues (unstable modes), and from physical considerations they are
> more or less situated in -0.2<lambda<0 in the normalized quantities that we
> use. So we will just use guesses.
> Thank you so much again!
> Also, I have finally managed to run streams (the cluster is quite full
> atm). These are the outputs:
1) This shows you have a bad process mapping. You could get much more
speedup for 1-4 procs by properly mapping processes to cores, perhaps with
numactl.
2) Essentially 3 processes can saturate your memory bandwidth, so I would
not expect much gain from using more than 4.
     Matt
> 1 processes
> Number of MPI processes 1 Processor names  c04b27
> Triad:        12352.0825   Rate (MB/s)
> 2 processes
> Number of MPI processes 2 Processor names  c04b27 c04b27
> Triad:        18968.0226   Rate (MB/s)
> 3 processes
> Number of MPI processes 3 Processor names  c04b27 c04b27 c04b27
> Triad:        21106.8580   Rate (MB/s)
> 4 processes
> Number of MPI processes 4 Processor names  c04b27 c04b27 c04b27 c04b27
> Triad:        21655.5885   Rate (MB/s)
> 5 processes
> Number of MPI processes 5 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27
> Triad:        21627.5559   Rate (MB/s)
> 6 processes
> Number of MPI processes 6 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27
> Triad:        21394.9620   Rate (MB/s)
> 7 processes
> Number of MPI processes 7 Processor names  c04b27 c04b27 c04b27 c04b27
> Triad:        24952.7076   Rate (MB/s)
> 8 processes
> Number of MPI processes 8 Processor names  c04b27 c04b27 c04b27 c04b27
> Triad:        28357.1062   Rate (MB/s)
> 9 processes
> Number of MPI processes 9 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        31720.4545   Rate (MB/s)
> 10 processes
> Number of MPI processes 10 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        35198.7412   Rate (MB/s)
> 11 processes
> Number of MPI processes 11 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        38616.0615   Rate (MB/s)
> 12 processes
> Number of MPI processes 12 Processor names  c04b27 c04b27 c04b27 c04b27
> c04b27 c04b27 c04b27 c04b27 c04b27 c04b27 c04b27 c04b27
> Triad:        41939.3994   Rate (MB/s)
> I attach a figure.
> Thanks again!
> On Mon, Apr 3, 2017 at 8:29 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
>> > El 1 abr 2017, a las 0:01, Toon Weyens <toon.weyens at gmail.com>
>> escribió:
>> > Dear jose,
>> > I have saved the matrices in Matlab format and am sending them to you
>> using pCloud. If you want another format, please tell me. Please also note
>> that they are about 1.4GB each.
>> > I also attach a typical output of eps_view and log_view in output.txt,
>> for 8 processes.
>> > Thanks so much for helping me out! I think Petsc and Slepc are amazing
>> inventions that really have saved me many months of work!
>> > Regards
>> I played a little bit with your matrices.
>> With Krylov-Schur I can solve the problem quite easily. Note that in
>> generalized eigenvalue problems it is always better to use STSINVERT
>> because you have to invert a matrix anyway. So instead of setting
>> which=smallest_real, use shift-and-invert with a target that is close to
>> the wanted eigenvalue. For instance, with target=-0.005 I get convergence
>> with just one iteration:
>> $ ./ex7 -f1 A.bin -f2 B.bin -st_ksp_type preonly -st_pc_type lu
>> -st_pc_factor_mat_solver_package mumps -eps_tol 1e-5 -st_type sinvert
>> -eps_target -0.005
>> Generalized eigenproblem stored in file.
>>  Reading COMPLEX matrices from binary files...
>>  Number of iterations of the method: 1
>>  Number of linear iterations of the method: 16
>>  Solution method: krylovschur
>>  Number of requested eigenvalues: 1
>>  Stopping condition: tol=1e-05, maxit=7500
>>  Linear eigensolve converged (1 eigenpair) due to CONVERGED_TOL;
>> iterations 1
>>             k             ||Ax-kBx||/||kx||
>>   -0.004809-0.000000i       8.82085e-05
>> Of course, you don't know a priori where your eigenvalue is.
>> Alternatively, you can set the target at 0 and get rid of positive
>> eigenvalues with a region filtering. For instance:
>> -eps_target 0 -rg_type interval -rg_interval_endpoints -1,0,-.05,.05
>> -eps_nev 2
>>  Number of iterations of the method: 8
>>  Number of linear iterations of the method: 74
>>  Number of requested eigenvalues: 2
>>  Stopping condition: tol=1e-05, maxit=7058
>>  Linear eigensolve converged (2 eigenpairs) due to CONVERGED_TOL;
>> iterations 8
>>             k             ||Ax-kBx||/||kx||
>>   -0.000392-0.000000i            2636.4
>>   -0.004809+0.000000i            318441
>> In this case, the residuals seem very bad. But this is due to the fact
>> that your matrices have huge norms. Adding the option -eps_error_backward
>> ::ascii_info_detail  will show residuals relative to the matrix norms:
>>             k                 eta(x,k)
>>   -0.000392-0.000000i       3.78647e-11
>>   -0.004809+0.000000i       5.61419e-08
>> Regarding the GD solver, I am also getting the correct solution. I don't
>> know why you are not getting convergence to the wanted eigenvalue:
>> -st_pc_factor_mat_solver_package mumps -eps_tol 1e-5 -eps_smallest_real
>> -eps_ncv 32 -eps_type gd
>>  Number of iterations of the method: 132
>>  Number of linear iterations of the method: 0
>>  Solution method: gd
>>  Stopping condition: tol=1e-05, maxit=120000
>> iterations 132
>>             k             ||Ax-kBx||/||kx||
>>   -0.004809+0.000000i       2.16223e-05
>> Again, it is much better to use a target instead of smallest_real:
>> -st_pc_factor_mat_solver_package mumps -eps_tol 1e-5 -eps_type gd
>> -eps_target -0.005
>>  Number of iterations of the method: 23
>>  Solution method: gd
>> iterations 23
>>             k             ||Ax-kBx||/||kx||
>>   -0.004809-0.000000i       2.06572e-05
>> Jose
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170404/49e9d30c/attachment.html>
