[petsc-users] Configuring PETSc for KNL
    Zhang, Hong
    hongzhang at anl.gov
    Mon Apr  3 14:24:41 CDT 2017
On Apr 3, 2017, at 1:44 PM, Justin Chang <jychang48 at gmail.com<mailto:jychang48 at gmail.com>> wrote:
Richard,
This is what my job script looks like:
#!/bin/bash
#SBATCH -N 16
#SBATCH -C knl,quad,flat
#SBATCH -p regular
#SBATCH -J knlflat1024
#SBATCH -L SCRATCH
#SBATCH -o knlflat1024.o%j
#SBATCH --mail-type=ALL
#SBATCH --mail-user=jychang48 at gmail.com<mailto:jychang48 at gmail.com>
#SBATCH -t 00:20:00
#run the application:
cd $SCRATCH/Icesheet
sbcast --compress=lz4 ./ex48cori /tmp/ex48cori
srun -n 1024 -c 4 --cpu_bind=cores numactl -p 1 /tmp/ex48cori -M 128 -N 128 -P 16 -thi_mat_type baij -pc_type mg -mg_coarse_pc_type gamg -da_refine 1
Maybe it is a typo. It should be numactl -m 1.
According to the NERSC info pages, they say to add the "numactl" if using flat mode. Previously I tried cache mode but the performance seems to be unaffected.
Using cache mode should give similar performance as using flat mode with the numactl option. But both approaches should be significant faster than using flat mode without the numactl option. I usually see over 3X speedup. You can also do such comparison to see if the high-bandwidth memory is working properly.
I also comparerd 256 haswell nodes vs 256 KNL nodes and haswell is nearly 4-5x faster. Though I suspect this drastic change has much to do with the initial coarse grid size now being extremely small.
I'll give the COPTFLAGS a try and see what happens
Make sure to use --with-memalign=64 for data alignment when configuring PETSc.
The option -xMIC-AVX512 would improve the vectorization performance. But it may cause problems for the MPIBAIJ format for some unknown reason. MPIAIJ should work fine with this option.
Hong (Mr.)
Justin
On Mon, Apr 3, 2017 at 1:36 PM, Richard Mills <richardtmills at gmail.com<mailto:richardtmills at gmail.com>> wrote:
Hi Justin,
How is the MCDRAM (on-package "high-bandwidth memory") configured for your KNL runs?  And if it is in "flat" mode, what are you doing to ensure that you use the MCDRAM?  Doing this wrong seems to be one of the most common reasons for unexpected poor performance on KNL.
I'm not that familiar with the environment on Cori, but I think that if you are building for KNL, you should add "-xMIC-AVX512" to your compiler flags to explicitly instruct the compiler to use the AVX512 instruction set.  I usually use something along the lines of
  'COPTFLAGS=-g -O3 -fp-model fast -xMIC-AVX512'
(The "-g" just adds symbols, which make the output from performance profiling tools much more useful.)
That said, I think that if you are comparing 1024 Haswell cores vs. 1024 KNL cores (so double the number of Haswell nodes), I'm not surprised that the simulations are almost twice as fast using the Haswell nodes.  Keep in mind that individual KNL cores are much less powerful than an individual Haswell node.  You are also using roughly twice the power footprint (dual socket Haswell node should be roughly equivalent to a KNL node, I believe).  How do things look on when you compare equal nodes?
Cheers,
Richard
On Mon, Apr 3, 2017 at 11:13 AM, Justin Chang <jychang48 at gmail.com<mailto:jychang48 at gmail.com>> wrote:
Hi all,
On NERSC's Cori I have the following configure options for PETSc:
./configure --download-fblaslapack --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0 --with-debugging=0 --with-fc=ftn --with-fortranlib-autodetect=0 --with-mpiexec=srun --with-64-bit-indices=1 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-cori-opt
Where I swapped out the default Intel programming environment with that of Cray (e.g., 'module switch PrgEnv-intel/6.0.3 PrgEnv-cray/6.0.3'). I want to document the performance difference between Cori's Haswell and KNL processors.
When I run a PETSc example like SNES ex48 on 1024 cores (32 Haswell and 16 KNL nodes), the simulations are almost twice as fast on Haswell nodes. Which leads me to suspect that I am not doing something right for KNL. Does anyone know what are some "optimal" configure options for running PETSc on KNL?
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170403/3674866c/attachment.html>
