[petsc-users] Correlation between da_refine and pg_mg_levels
Jed Brown jed at jedbrown.org
Mon Apr 3 06:23:18 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
> I can't think why it would fail there, but DMDA really likes old numbers of
> vertices, because it wants
> to take every other point, 129 seems good. I will see if I can reproduce
> once I get a chance.
This problem uses periodic boundary conditions so even is right, but
Justin only defines the coarsest grid and uses -da_refine so it should
actually be irrelevant.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170403/8043810d/attachment-0001.pgp>
