[petsc-users] Correlation between da_refine and pg_mg_levels
Jed Brown jed at jedbrown.org
Mon Apr 3 06:11:38 CDT 2017
Justin Chang <jychang48 at gmail.com> writes:
> So if I begin with a 128x128x8 grid on 1032 procs, it works fine for the
> first two levels of da_refine. However, on the third level I get this error:
> Level 3 domain size (m)    1e+04 x    1e+04 x    1e+03, num elements 1024 x
> 1024 x 57 (59768832), size (m) 9.76562 x 9.76562 x 17.8571
> Level 2 domain size (m)    1e+04 x    1e+04 x    1e+03, num elements 512 x
> 512 x 29 (7602176), size (m) 19.5312 x 19.5312 x 35.7143
> Level 1 domain size (m)    1e+04 x    1e+04 x    1e+03, num elements 256 x
> 256 x 15 (983040), size (m) 39.0625 x 39.0625 x 71.4286
> Level 0 domain size (m)    1e+04 x    1e+04 x    1e+03, num elements 128 x
> 128 x 8 (131072), size (m) 78.125 x 78.125 x 142.857
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at iteration 0
Building with debugging and adding -fp_trap to get a stack trace would
be really useful.  Or reproducing at smaller scale.
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
> trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3418-ge372536  GIT
> Date: 2017-03-30 13:35:15 -0500
> [0]PETSC ERROR: /scratch2/scratchdirs/jychang/Icesheet/./ex48edison on a
> arch-edison-c-opt named nid00865 by jychang Sun Apr  2 21:44:44 2017
> [0]PETSC ERROR: Configure options --download-fblaslapack --with-cc=cc
> --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0
> --with-debugging=0 --with-fc=ftn --with-fortranlib-autodetect=0
> --with-mpiexec=srun --with-64-bit-indices=1 COPTFLAGS=-O3 CXXOPTFLAGS=-O3
> FOPTFLAGS=-O3 PETSC_ARCH=arch-edison-c-opt
> [0]PETSC ERROR: #1 KSPSolve_Chebyshev() line 380 in
> /global/u1/j/jychang/Software/petsc/src/ksp/ksp/impls/cheby/cheby.c
> [0]PETSC ERROR: #2 KSPSolve() line 655 in /global/u1/j/jychang/Software/
> petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #3 PCMGMCycle_Private() line 19 in
> /global/u1/j/jychang/Software/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #4 PCMGMCycle_Private() line 53 in
> [0]PETSC ERROR: #5 PCApply_MG() line 331 in /global/u1/j/jychang/Software/
> [0]PETSC ERROR: #6 PCApply() line 458 in /global/u1/j/jychang/Software/
> petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #7 KSP_PCApply() line 251 in /global/homes/j/jychang/
> Software/petsc/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #8 KSPInitialResidual() line 67 in
> /global/u1/j/jychang/Software/petsc/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #9 KSPSolve_GMRES() line 233 in
> /global/u1/j/jychang/Software/petsc/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #10 KSPSolve() line 655 in /global/u1/j/jychang/Software/
> [0]PETSC ERROR: #11 SNESSolve_NEWTONLS() line 224 in
> /global/u1/j/jychang/Software/petsc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #12 SNESSolve() line 3967 in /global/u1/j/jychang/Software/
> petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #13 main() line 1548 in /scratch2/scratchdirs/jychang/
> Icesheet/ex48.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -M 128
> [0]PETSC ERROR: -N 128
> [0]PETSC ERROR: -P 8
> [0]PETSC ERROR: -da_refine 3
> [0]PETSC ERROR: -mg_coarse_pc_type gamg
> [0]PETSC ERROR: -pc_mg_levels 4
> [0]PETSC ERROR: -pc_type mg
> [0]PETSC ERROR: -thi_mat_type baij
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> If I changed the coarse grid to 129x129x8, no error whatsoever for up to 4
> levels of refinement.
> However, I am having trouble getting this started up on Cori's KNL...
> I am using a coarse grid 136x136x8 across 1088 cores, and slurm is simply
> cancelling the job. No other PETSc error was given. This is literally what
> my log files say:
> Level 1 domain size (m)    1e+04 x    1e+04 x    1e+03, num elements 272 x
> 272 x 15 (1109760), size (m) 36.7647 x 36.7647 x 71.4286
> Level 0 domain size (m)    1e+04 x    1e+04 x    1e+03, num elements 136 x
> 136 x 8 (147968), size (m) 73.5294 x 73.5294 x 142.857
Why are levels 1 and 0 printed above, then 2,1,0 below.
> makefile:25: recipe for target 'runcori' failed
What is this makefile message doing?
> Level 2 domain size (m)    1e+04 x    1e+04 x    1e+03, num elements 544 x
> 544 x 29 (8582144), size (m) 18.3824 x 18.3824 x 35.7143
> srun: error: nid04139: task 480: Killed
> srun: Terminating job step 4387719.0
> srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
> slurmstepd: error: *** STEP 4387719.0 ON nid03873 CANCELLED AT
> 2017-04-02T22:21:21 ***
> srun: error: nid03960: task 202: Killed
> srun: error: nid04005: task 339: Killed
> srun: error: nid03873: task 32: Killed
> srun: error: nid03960: task 203: Killed
> srun: error: nid03873: task 3: Killed
> srun: error: nid03960: task 199: Killed
> srun: error: nid04004: task 264: Killed
> srun: error: nid04141: task 660: Killed
> srun: error: nid04139: task 539: Killed
> srun: error: nid03873: task 63: Killed
> srun: error: nid03960: task 170: Killed
> srun: error: nid08164: task 821: Killed
> srun: error: nid04139: task 507: Killed
> srun: error: nid04005: task 299: Killed
> srun: error: nid03960: tasks 136-169,171-198,200-201: Killed
> srun: error: nid04005: task 310: Killed
> srun: error: nid08166: task 1008: Killed
> srun: error: nid04141: task 671: Killed
> srun: error: nid03873: task 18: Killed
> srun: error: nid04139: tasks 476-479,481-506,508-538,540-543: Killed
> srun: error: nid04005: tasks 272-298,300-309,311-338: Killed
> srun: error: nid04140: tasks 544-611: Killed
> srun: error: nid04142: tasks 680-747: Killed
> srun: error: nid04138: tasks 408-475: Killed
> srun: error: nid04006: tasks 340-407: Killed
> srun: error: nid08163: tasks 748-815: Killed
> srun: error: nid08166: tasks 952-1007,1009-1019: Killed
> srun: error: nid03873: tasks 0-2,4-17,19-31,33-62,64-67: Killed
> srun: error: nid08165: tasks 884-951: Killed
> srun: error: nid03883: tasks 68-135: Killed
> srun: error: nid08164: tasks 816-820,822-883: Killed
> srun: error: nid08167: tasks 1020-1087: Killed
> srun: error: nid04141: tasks 612-659,661-670,672-679: Killed
> srun: error: nid04004: tasks 204-263,265-271: Killed
> make: [runcori] Error 137 (ignored)
> [257]PETSC ERROR:
> [257]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> batch system) has told this process to end
> [257]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [257]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [257]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [257]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
> and run
> [257]PETSC ERROR: to get more information on the crash.
> [878]PETSC ERROR:
> [878]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> [878]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [878]PETSC ERROR: or see
> [878]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [878]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
> and run
> [878]PETSC ERROR: to get more information on the crash.
> [clipped]
> my job script for KNL looks like this:
> #!/bin/bash
> #SBATCH -N 16
> #SBATCH -C knl,quad,cache
> #SBATCH -p regular
> #SBATCH -J knl1024
> #SBATCH -L SCRATCH
> #SBATCH -o knl1088.o%j
> #SBATCH -e knl1088.e%j
> #SBATCH --mail-type=ALL
> #SBATCH --mail-user=jychang48 at gmail.com
> #SBATCH -t 00:20:00
> srun -n 1088 -c 4 --cpu_bind=cores ./ex48 ....
> Any ideas why this is happening? Or do I need to contact the NERSC folks?
> Thanks,
> Justin
> On Sun, Apr 2, 2017 at 2:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Apr 2, 2017 at 2:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > On Apr 2, 2017, at 9:25 AM, Justin Chang <jychang48 at gmail.com> wrote:
>>> > Thanks guys,
>>> > So I want to run SNES ex48 across 1032 processes on Edison, but I keep
>>> getting segmentation violations. These are the parameters I am trying:
>>> > srun -n 1032 -c 2 ./ex48 -M 80 -N 80 -P 9 -da_refine 1 -pc_type mg
>>> -thi_mat_type baij -mg_coarse_pc_type gamg
>>> > The above works perfectly fine if I used 96 processes. I also tried to
>>> use a finer coarse mesh on 1032 but the error persists.
>>> > Any ideas why this is happening? What are the ideal parameters to use
>>> if I want to use 1k+ cores?
>>>    Hmm, one should never get segmentation violations. You should only get
>>> not completely useful error messages about incompatible sizes etc. Send an
>>> example of the segmentation violations. (I sure hope you are checking the
>>> error return codes for all functions?).
>> He is just running SNES ex48.
>>   Matt
>>>   Barry
>>> > Thanks,
>>> > Justin
>>> > On Fri, Mar 31, 2017 at 12:47 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> > >> Yeah based on my experiments it seems setting pc_mg_levels to
>>> $DAREFINE + 1
>>> > >> has decent performance.
>>> > >> 1) is there ever a case where you'd want $MGLEVELS <= $DAREFINE? In
>>> some of
>>> > >> the PETSc tutorial slides (e.g., http://www.mcs.anl.gov/
>>> > >> petsc/documentation/tutorials/TutorialCEMRACS2016.pdf on slide
>>> 203/227)
>>> > >> they say to use $MGLEVELS = 4 and $DAREFINE = 5, but when I ran
>>> this, it
>>> > >> was almost twice as slow as if $MGLEVELS >= $DAREFINE
>>> > > Smaller coarse grids are generally more scalable -- when the problem
>>> > > data is distributed, multigrid is a good solution algorithm.  But if
>>> > > multigrid stops being effective because it is not preserving
>>> sufficient
>>> > > coarse grid accuracy (e.g., for transport-dominated problems in
>>> > > complicated domains) then you might want to stop early and use a more
>>> > > robust method (like direct solves).
>>> > Basically for symmetric positive definite operators you can make the
>>> coarse problem as small as you like (even 1 point) in theory. For
>>> indefinite and non-symmetric problems the theory says the "coarse grid must
>>> be sufficiently fine" (loosely speaking the coarse grid has to resolve the
>>> eigenmodes for the eigenvalues to the left of the x = 0).
>>> > https://www.jstor.org/stable/2158375?seq=1#page_scan_tab_contents
>> experiments lead.
>> -- Norbert Wiener
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170403/23a0d1d3/attachment-0001.pgp>
