[petsc-users] -snes_mf_operator yields "No support for this operation for this object type" in TS codes?
Ed Bueler elbueler at alaska.edu
Sun Apr 2 20:06:46 CDT 2017
Dear PETSc --
I have a TS-using and DMDA-using code in which I want to set a RHSJacobian
which is only approximate.  (The Jacobian uses first-order upwinding MOL
while the RHSFunction uses a flux-limited MOL.)  While it works with the
analytical Jacobian, and -snes_fd, and -snes_fd_color, and -snes_mf, I get
a "No support ..." message for -snes_mf_operator.
It suffices to show the problem with
src/ts/examples/tutorials/ex2.c
(Note ex2.c does not use DMDA so ..._color is not available for ex2.c.)
Error as follows:
~/petsc/src/ts/examples/tutorials[master*]$ ./ex2 -ts_dt 0.001
-ts_final_time 0.001 -snes_monitor
    0 SNES Function norm 1.059316422854e+01
    1 SNES Function norm 1.035505461114e-05
    2 SNES Function norm 5.498223366328e-12
-ts_final_time 0.001 -snes_monitor -snes_fd
    1 SNES Function norm 1.208245988550e-05
    2 SNES Function norm 6.022374930788e-12
-ts_final_time 0.001 -snes_monitor -snes_mf
    1 SNES Function norm 6.136984336801e-05
    2 SNES Function norm 5.355730806625e-10
-ts_final_time 0.001 -snes_monitor -snes_mf_operator
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Mat type mffd
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3426-g0c7851c  GIT
Date: 2017-04-01 18:40:06 -0600
[0]PETSC ERROR: ./ex2 on a linux-c-dbg named ed-lemur by ed Sun Apr  2
17:02:47 2017
[0]PETSC ERROR: Configure options --download-mpich --with-debugging=1
[0]PETSC ERROR: #1 MatZeroEntries() line 5471 in
/home/ed/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 TSComputeIJacobian() line 965 in
/home/ed/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: #3 SNESTSFormJacobian_Theta() line 515 in
/home/ed/petsc/src/ts/impls/implicit/theta/theta.c
[0]PETSC ERROR: #4 SNESTSFormJacobian() line 5078 in
[0]PETSC ERROR: #5 SNESComputeJacobian() line 2276 in
/home/ed/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: #6 SNESSolve_NEWTONLS() line 222 in
/home/ed/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #7 SNESSolve() line 3967 in
[0]PETSC ERROR: #8 TS_SNESSolve() line 171 in
[0]PETSC ERROR: #9 TSStep_Theta() line 211 in
[0]PETSC ERROR: #10 TSStep() line 3843 in
[0]PETSC ERROR: #11 TSSolve() line 4088 in
[0]PETSC ERROR: #12 main() line 194 in
/home/ed/petsc/src/ts/examples/tutorials/ex2.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -snes_mf_operator
[0]PETSC ERROR: -snes_monitor
[0]PETSC ERROR: -ts_dt 0.001
[0]PETSC ERROR: -ts_final_time 0.001
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
[unset]: aborting job:
Is this intended or a bug?  If it is intended, what is the issue?
I am using current master branch (commit
0c7851c55cba8e40da5083f79ba1ff846acd45b2).
Thanks for your help and awesome library!
Ed
Ed Bueler
Dept of Math and Stat and Geophysical Institute
University of Alaska Fairbanks
Fairbanks, AK 99775-6660
301C Chapman
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170402/a635077e/attachment.html>
