[petsc-users] [3.7.5] strange config error on macOS with XCode 8.3 and Clang 8.1.0
Unal sospinar at unal.edu.co
Sun Apr 2 06:43:19 CDT 2017
In my experience, each time you update Xcode, you also have to update the Command Line Tools (https://developer.apple.com/downloads/index.action?=command%20line%20tools <https://developer.apple.com/downloads/index.action?=command%20line%20tools>), and reinstall everything again in the right order; in my case, I have to reinstall Fortran, MPI, HDF5 and PETSc. When one doesn't do it in the right order, it appears problems like what you reported.
Santiago
> On 29 Mar 2017, at 07:26, Denis Davydov <davydden at gmail.com> wrote:
> Thanks Barry, I can confirm that an adaptation of your patch to 3.7.5 allows to compile PETSc.
> Regads,
> Denis.
>> On 29 Mar 2017, at 06:23, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> I have added the commit https://bitbucket.org/petsc/petsc/commits/4f290403fdd060d09d5cb07345cbfd52670e3cbc  to the maint, master and next branch that allows ./configure to to go through in this situation.  If the change does not break other tests it will be included in the next patch release.
>>  Thanks for reporting the problem,
>>    Barry
>> This patch does not directly deal with the problem (which i don't understand but seems to be an Apple Xcode problem) but works around the problem on my machine.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170402/69f69e46/attachment.html>
