[petsc-users] Question about PETScSF usage in DMNetwork/DMPlex
Adrian Maldonado
dmaldona at hawk.iit.edu
Mon Sep 19 14:21:12 CDT 2016
Ok, got it!
Thanks
On Mon, Sep 19, 2016 at 6:25 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 16, 2016 at 11:36 AM, Adrian Maldonado <dmaldona at hawk.iit.edu>
> wrote:
>> Hi,
>> I am trying to understand some of the data structures DMPlex/DMNetwork
>> creates and the relationship among them.
>> As an example, I have an small test circuit (/src/ksp/ksp/examples/tutoria
>> ls/network/ex1.c).
>> This is a graph that consists on 6 edges and 4 vertices, each one of
>> those having one degree of freedom. When ran with two processors, each
>> rank will own 3 edges. Rank 0 will own one vertex (3 ghost) and Rank 1 will
>> own 3 vertices.
>> These are some data structures for this problem. I am getting these data
>> structures inside DMNetworkDistribute
>> <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMNetworkDistribute.html>
>> DM Object: Parallel Mesh 2 MPI processes
>> type: plex
>> Parallel Mesh in 1 dimensions:
>> 0-cells: 4 3
>> 1-cells: 3 3
>> Labels:
>> depth: 2 strata of sizes (4, 3)
>> This, as I understand, is printing a tree with all the vertices and
>> edges in each processor (owned and ghost).
>> PetscSection Object: 2 MPI processes
>> type not yet set
>> Process 0:
>> ( 0) dim 1 offset 0
>> ( 1) dim 1 offset 1
>> ( 2) dim 1 offset 2
>> ( 3) dim 1 offset 3
>> ( 4) dim -2 offset -8
>> ( 5) dim -2 offset -9
>> ( 6) dim -2 offset -10
>> Process 1:
>> ( 0) dim 1 offset 4
>> ( 1) dim 1 offset 5
>> ( 2) dim 1 offset 6
>> ( 3) dim 1 offset 7
>> ( 4) dim 1 offset 8
>> ( 5) dim 1 offset 9
>> This is a global PETSc section that gives me the global numbering for the
>> owned points and (garbage?) negative values for ghost.
>> Until here everything is good. But then I print the PetscSF that is
>> created by 'DMPlexDistribute'. This I do not understand:
> 1) You are looking at the MigrationSF, not the eventual PointSF or
> OffsetSF from the DM. You need
> DMGetDefaultSF or DMGetPointSF
> for those.
> 2) Notice that edges 0,1,3 are sent to proc 0, and edges 2,4,5 are sent to
> proc 1.
> Matt
>> PetscSF Object: Migration SF 2 MPI processes
>> type: basic
>> sort=rank-order
>> [0] Number of roots=10, leaves=7, remote ranks=1
>> [0] 0 <- (0,0)
>> [0] 1 <- (0,1)
>> [0] 2 <- (0,3)
>> [0] 3 <- (0,6)
>> [0] 4 <- (0,7)
>> [0] 5 <- (0,8)
>> [0] 6 <- (0,9)
>> [1] Number of roots=0, leaves=6, remote ranks=1
>> [1] 0 <- (0,2)
>> [1] 1 <- (0,4)
>> [1] 2 <- (0,5)
>> [1] 3 <- (0,7)
>> [1] 4 <- (0,8)
>> [1] 5 <- (0,9)
>> [0] Roots referenced by my leaves, by rank
>> [0] 0: 7 edges
>> [0] 0 <- 0
>> [0] 1 <- 1
>> [0] 2 <- 3
>> [0] 3 <- 6
>> [0] 4 <- 7
>> [0] 5 <- 8
>> [0] 6 <- 9
>> [1] Roots referenced by my leaves, by rank
>> [1] 0: 6 edges
>> [1] 0 <- 2
>> [1] 1 <- 4
>> [1] 2 <- 5
>> [1] 3 <- 7
>> [1] 4 <- 8
>> [1] 5 <- 9
>> I understand that SF is a data structure that saves references to pieces
>> of data that are now owned by the process (https://arxiv.org/pdf/1506.06
>> 194v1.pdf, page 4).
>> Since the only ghost nodes appear in rank 0 (three ghost vertices) I
>> would expect something like:
>> *rank 0:*
>> 4 - (1, 3) (to read: point 4 is owned by rank 1 and is rank's 1 point
>> 3)
>> etc...
>> *rank 1:*
>> nothing
>> Is my intuition correct? If so, what does the star forest that I get from
>> DMPlexDistribute mean? I am printing the wrong thing?
>> Thank you
>> D. Adrian Maldonado, PhD Candidate
>> Electrical & Computer Engineering Dept.
>> Illinois Institute of Technology
>> 3301 S. Dearborn Street, Chicago, IL 60616
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160919/bdcbbf3f/attachment.html>
