[petsc-users] petsc 3.7.4 with superlu_dist install problem
Klaij, Christiaan C.Klaij at marin.nl
Wed Oct 26 03:43:21 CDT 2016
Satish,
I'm having a similar problem with SuperLU_DIST, attached is the
configure.log. I've noticed that the extraction of the tarball
works fine, yet it gives the "unable to download" message:
          Checking for a functional SuperLU_DIST
                  Looking for SUPERLU_DIST at git.superlu_dist, hg.superlu_dist or a directory starting with superlu_dist
                  Could not locate an existing copy of SUPERLU_DIST:
                    ['metis-5.1.0-p3', 'parmetis-4.0.3-p3']
                  Downloading SuperLU_DIST
                          Trying to download file:///projects/developers/cklaij/ReFRESCO/Dev/trunk/Libs/src/superlu_dist_5.1.2.tar.gz for SUPERLU_DIST
                    Downloading file:///projects/developers/cklaij/ReFRESCO/Dev/trunk/Libs/src/superlu_dist_5.1.2.tar.gz to /projects/developers/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.4-dbg/linux_64bit/externalpackages/_d_superlu_dist_5.1.2.tar.gz
                    Extracting /projects/developers/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.4-dbg/linux_64bit/externalpackages/_d_superlu_dist_5.1.2.tar.gz
Executing: cd /projects/developers/cklaij/ReFRESCO/Dev/trunk/Libs/build/petsc/3.7.4-dbg/linux_64bit/externalpackages; chmod -R a+r SuperLU_DIST_5.1.2;find  SuperLU_DIST_5.1.2 -type d -name "*" -exec chmod a+rx {} \;
                      ['metis-5.1.0-p3', 'parmetis-4.0.3-p3', 'SuperLU_DIST_5.1.2']
                  ERROR: Failed to download SUPERLU_DIST
Chris
dr. ir. Christiaan Klaij  | CFD Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/SSSRIMARIN-seminar-November-2-Shanghai.htm
Type: text/x-log
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161026/96c348c8/attachment-0001.bin>
