[petsc-users] Use previous solution when encountering "DIVERGED_LINE_SEARCH"
Justin Chang jychang48 at gmail.com
Wed Nov 30 21:23:27 CST 2016
Also, -snes_stol does not seem to work for vinewtonrsls?
On Wed, Nov 30, 2016 at 8:54 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Generally speaking, yes. But this is VIRS where I am enforcing maximum
> principles. From what I have seen, the residual typically exhibit this
> behavior if there are very few violations in the first place.
> How would I "terminate on stagnation"?
> On Wed, Nov 30, 2016 at 8:48 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Nov 30, 2016 at 8:38 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> By manually terminating I meant setting -snes_max_it to 5 if I know DIVERGED_LINE_SEARCH
>>> occurs after 6 iterations. In a transient simulation I cannot do this
>> Let me elaborate. I mean that using DIVERGED_LINE_SEARCH as an indication
>> of convergence is dicey. It may be that in the problem
>> you looked at this was true, but I see no reason to believe its true in
>> general. Why does your residual quit decreasing?
>>   Thanks,
>>      Matt
>>> On Wed, Nov 30, 2016 at 8:35 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Nov 30, 2016 at 8:27 PM, Justin Chang <jychang48 at gmail.com>
>>>> wrote:
>>>>> Hi all,
>>>>> I am running some transient simulations using SNESVINEWTONRSLS. At
>>>>> certain timesteps, I get a "DIVERGED_LINE_SEARCH" which essentially
>>>>> "resets" my solution to zero and messes everything up. I notice that this
>>>>> happens when the SNES Function norm no longer decreases, and if I were to
>>>>> manually terminate the solver right before the final iteration I get the
>>>>> answer I want.
>>>> Yes, its possible, however isn't that a dangerous way to terminate?
>>>> Couldn't you terminate on stagnation?
>>>>   Thanks,
>>>>      Matt
>>>>> Is there a way to "detect" this error and use the solution from the
>>>>> previous non-failing iteration? Setting a fixed maximum iteration doesn't
>>>>> seem reasonble because every time level will require different numbers of
>>>>> iterations to converge.
>>>>> Thanks,
>>>>> Justin
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161130/99556850/attachment.html>
