[petsc-users] Petsc with Windows
Mohammad Mirzadeh mirzadeh at gmail.com
Wed Nov 30 02:00:02 CST 2016
May I propose docker as an alternative approach? https://www.docker.com
There are already petsc images and creating your own environment is not
that hard. As a bonus you get a cross platform solution ... unless your
application is windows specific in which case docker might not be the best
way to go.
On Wed, Nov 30, 2016 at 1:45 AM Jed Brown <jed at jedbrown.org> wrote:
> Elaine Tang <lingdeer at gmail.com> writes:
> > I am developing some software on windows that would like to utilize petsc
> > library. Currently I have petsc library configured on cygwin on my
> windows
> > machine.
> This is probably a better choice than Cygwin going forward.
> https://msdn.microsoft.com/en-us/commandline/wsl/about
> I don't know to what extent PETSc users have experimented with this
> feature, but it should make it easier to build and distribute PETSc.
> > Is there any binary of petsc for windows so that the software that I
> > develop will be more portable and can be run on other windows machine as
> > well?
> Are you developing an application or a library?
Sent from Gmail Mobile
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161130/ddfa3a96/attachment.html>
