[petsc-users] superlu_dist issue
Kong, Fande fande.kong at inl.gov
Tue Nov 29 15:09:17 CST 2016
Hi All,
I think we have been discussing this topic for a while in other threads.
But I still did not get yet. PETSc uses 'SamePattern' as the default
FactPattern. Some test cases in MOOSE fail with this default option, but I
can make these tests pass if I set the FactPattern as
'SamePattern_SameRowPerm' by using -mat_superlu_dist_fact
SamePattern_SameRowPerm.
Does this make sense mathematically? I can not understand.  'SamePattern'
should  be more general than 'SamePattern_SameRowPerm'. In other words, if
something works with 'SamePattern_SameRowPerm', it definitely should work
with 'SamePattern' too.
Thanks as always.
Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161129/73cba36d/attachment.html>
