[petsc-users] error with libpetsc.so.3.7.4 during make test
Elaine Tang lingdeer at gmail.com
Sun Nov 27 23:13:50 CST 2016
I finish configured and make petsc on Cygwin.
Here are the last few lines of the make output:
          CC
arch-mswin-c-debug/obj/src/tao/linesearch/impls/owarmijo/owarmijo.o
          CC arch-mswin-c-debug/obj/src/tao/constrained/impls/ipm/ipm.o
          CC arch-mswin-c-debug/obj/src/tao/linesearch/impls/unit/unit.o
          CC
arch-mswin-c-debug/obj/src/tao/linesearch/impls/gpcglinesearch/gpcglinesearch.o
          CC
arch-mswin-c-debug/obj/src/tao/linesearch/interface/dlregis_taolinesearch.o
          CC
arch-mswin-c-debug/obj/src/tao/linesearch/interface/ftn-auto/taolinesearchf.o
          CC
arch-mswin-c-debug/obj/src/tao/linesearch/interface/taolinesearch.o
          CC
arch-mswin-c-debug/obj/src/tao/linesearch/interface/ftn-custom/ztaolinesearchf.o
          CC
arch-mswin-c-debug/obj/src/tao/leastsquares/impls/pounders/gqt.o
          CC
arch-mswin-c-debug/obj/src/tao/leastsquares/impls/pounders/pounders.o
     CLINKER
/home/Elaine/petsc-3.7.4/arch-mswin-c-debug/lib/libpetsc.so.3.7.4
make[2]: Leaving directory '/home/Elaine/petsc-3.7.4'
make[1]: Leaving directory '/home/Elaine/petsc-3.7.4'
Now to check if the libraries are working do:
make PETSC_DIR=/home/Elaine/petsc-3.7.4 PETSC_ARCH=arch-mswin-c-debug test
Then I did:
$ make PETSC_DIR=/home/Elaine/petsc-3.7.4 PETSC_ARCH=arch-mswin-c-debug test
Output is:
Running test examples to verify correct installation
Using PETSC_DIR=/home/Elaine/petsc-3.7.4 and PETSC_ARCH=arch-mswin-c-debug
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
process
See http://www.mcs.anl.gov/petsc/documentation/faq.html
C:/cygwin64/home/Elaine/petsc-3.7.4/src/snes/examples/tutorials/ex19.exe:
error while loading shared libraries: libpetsc.so.3.7.4: cannot open shared
object file: No such file or directory
Primary job  terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpiexec detected that one or more processes exited with non-zero status,
thus causing
the job to be terminated. The first process to do so was:
  Process name: [[46069,1],0]
  Exit code:    127
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI
processes
Possible error running Fortran example src/snes/examples/tutorials/ex5f
with 1 MPI process
C:/cygwin64/home/Elaine/petsc-3.7.4/src/snes/examples/tutorials/ex5f.exe:
thus causing
  Process name: [[38897,1],0]
  Exit code:    127
Completed test examples
Now to evaluate the computer systems you plan use - do:
streams
When I navigate to /home/Elaine/petsc-3.7.4/arch-mswin-c-debug/lib/ I did
find libpetsc.so.3.7.4
Why is make not able to locate it?
Thanks!
Elaine
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161128/ddc87cf4/attachment-0001.html>
