[petsc-users] Access to 'step' in 'toil_ims.f90' and 'pm_toil_ims.f90'
Jed Brown jed at jedbrown.org
Mon Nov 21 13:10:09 CST 2016
The files and functions you reference are not part of PETSc.  Perhaps
you can look at how they call PETSc.
Robert Annewandter <robert.annewandter at opengosim.com> writes:
> Hi,
> Is there a way to access 'step' as used in the output log file :
>  Step     35 Time=  1.00000E-03 Dt=  2.73903E-05 [d] snes_conv_reason:   10,
> from within the subroutines ' TOilImsResidual(snes,xx,r,realization,ierr)' and
> 'TOilImsJacobian(snes,xx,A,B,realization,ierr)' in 'toil_ims.f90', as well as
> from within 'PMTOilImsCheckUpdatePre(this,line_search,X,dX,changed,ierr)' in
> 'pm_toil_ims.f90'?
> I like to make sure that J, b and dx are taken from the same step. I can do
> that if the filenames of the exports reflect step and NR iteration. The problem
> is that, e.g. 'TOilImsResidual()' is called more often than is 'TOilImsJacobian
> ()', so using a simple counter which gets increased every time when the
> subroutines are called doesn't help unfortunately.
> Thank you for any pointers!
> Robert
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161121/ca655dd3/attachment.pgp>
