[petsc-users] KSP ex65 and DMShell context
Anton Popov popov at uni-mainz.de
Fri Nov 18 05:29:46 CST 2016
Hi all,
KSP ex65 fails with -pc_type mg -pc_mg_galerkin
[0]PETSC ERROR: Nonconforming object sizes
[0]PETSC ERROR: Matrix dimensions are incompatible, 129 != 65
This can be fixed either by adding MatTranspose after
DMCreateInterpolation in CreateRestriction, or by commenting out
DMShellSetCreateRestriction.
Replacing DMCreateInterpolation with DMCreateRestriction in
CreateRestriction also fails with a segfault:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: [0] DMCreateRestriction line 1064
/home/anton/LIB/petsc-3.7.4-debug/src/dm/interface/dm.c
This example uses DMDA objects as context variables, and calls destroy
on them right after creating coarse DMShell. Due to PETSc reference
counting mechanism they are not destroyed immediately, so everything
works without access violations and memory leaks.
I wander how I should destroy my ordinary user contexts. One option is
keeping a pointer to coarse context in the fine context, and destroying
hierarchy recursively.
Is there anything better (e.g. something like DMShellSetDestroyContext)?
Anton
