[petsc-users] Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
Beheshti, Mohammadali Mohammadali.Beheshti at uhn.ca
Wed Nov 16 10:47:38 CST 2016
I am running a simulation using a software that solves a FEM problem. My job script is as follows:
#!/bin/bash
#PBS -N myjob
#PBS -l nodes=1:ppn=8
#PBS -l walltime=120:00:00
#PBS -l mem=32000MB
module load openmpi/2.0.0
cd /cluster/home/t48263uhn/Carp/PlosOneData/
mpirun -np 8 carp.debug.petsc.pt +F /cluster/home/t48263uhn/Carp/PlosOneData/parameters_ECG_adjust.par
When I run this job I get following PETSC error:
[5]PETSC ERROR: ------------------------------------------------------------------------
[5]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[5]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[5]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[5]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[5]PETSC ERROR: likely location of problem given in stack below
[5]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[5]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[5]PETSC ERROR:       INSTEAD the line number of the start of the function
[5]PETSC ERROR:       is given.
[5]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[5]PETSC ERROR: Signal received
[5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[5]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
[5]PETSC ERROR: carp.debug.petsc.pt on a linux-gnu named node46.uhnh4h.cluster by t48263uhn Wed Nov 16 10:50:03 2016
[5]PETSC ERROR: Configure options --with-petsc-arch=linux-gnu --with-debugging=yes --with-mpi-dir=/cluster/tools/software/openmpi/2.0.0/ --download-ml=yes --download-fblaspack=yes -PETSC_ARCH=linux-gnu --download-superlu_dist=yes --download-superlu=yes --download-hypre=yes --download-mumps=yes --download-scalapack=yes --download-blacs=yes --download-hdf5=yes --download-metis=yes --download-parmetis=yes --download-pastix=yes --download-ptscotch=yes --download-sundials=yes --with-shared-libraries=1
[5]PETSC ERROR: #1 User provided function() line 0 in  unknown file
I appreciate any help in finding the cause of the error.
Best Regards,
Ali
This e-mail may contain confidential and/or privileged information for the sole use of the intended recipient.
Any review or distribution by anyone other than the person for whom it was originally intended is strictly prohibited.
If you have received this e-mail in error, please contact the sender and delete all copies.
Opinions, conclusions or other information contained in this e-mail may not be that of the organization.
