[petsc-users] solving system with 2x2 block size
Manav Bhatia bhatiamanav at gmail.com
Tue Nov 15 17:16:35 CST 2016
I tried the options "-mat_type baij” and that seemed to change the type of matrix to BAIJ.
I am now experimenting with various preconditioners (ILU, ASM, etc.), and things seem to be working fine so far.
KSP Object:(fluid_complex_) 4 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object:(fluid_complex_) 4 MPI processes
  type: asm
    Additive Schwarz: total subdomain blocks = 4, amount of overlap = 1
    Additive Schwarz: restriction/interpolation type - RESTRICT
    Local solve is same for all blocks, in the following KSP and PC objects:
  KSP Object:  (fluid_complex_sub_)   1 MPI processes
    type: gmres
    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
  PC Object:  (fluid_complex_sub_)   1 MPI processes
    type: ilu
      ILU: out-of-place factorization
      3 levels of fill
      tolerance for zero pivot 2.22045e-14
      matrix ordering: natural
      factor fill ratio given 1., needed 2.32913
        Factored matrix follows:
          Mat Object:           1 MPI processes
            type: seqbaij
            rows=294752, cols=294752, bs=2
            package used to perform factorization: petsc
            total: nonzeros=49050496, allocated nonzeros=49050496
            total number of mallocs used during MatSetValues calls =0
                block size is 2
    linear system matrix = precond matrix:
    Mat Object:    (fluid_complex_)     1 MPI processes
      type: seqbaij
      total: nonzeros=21059584, allocated nonzeros=21059584
          block size is 2
  Mat Object:  (fluid_complex_)   4 MPI processes
    type: mpibaij
    rows=1158728, cols=1158728, bs=2
    total: nonzeros=83105344, allocated nonzeros=83266816
        block size is 2
-Manav
> On Nov 15, 2016, at 3:34 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Nov 15, 2016, at 3:23 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>> I have a complex system,   (A + i B) (x + i y) = (f + ig), that I am trying to solve using real matrices:
>>    [A  -B;   B A ] [x; y] = [f; g]
>> So, the 2x2 block is made of the real and imaginary component of each entry in the complex matrix.
>> I am following the discussion in the following paper:
>> DAY D. \& HEROUX M.A. 2001. Solving complex-valued linear systems via equivalent real formulations. \textit{SIAM Journal on Scientific Computing} 23: 480-498.
>> Following is an excerpt.
>> The matrix K in the K formulation has a natural 2-by-2 block structure that can be exploited by using block entry data structures. Using the block entry features of these packages has the following benefits.
>> 	• Applying 2-by-2 block Jacobi scaling to K corresponds exactly to applying point Jacobi scaling to C.
>> 	• The block sparsity pattern of K exactly matches the point sparsity pattern of C. Thus any pattern-based preconditioners such as block ILU(l) applied to K correspond exactly to ILU(l) applied to C. See section 4 for definitions of block ILU(l) and ILU(l).
>> 	• Any drop tolerance-based complex preconditioner has a straightforward K formulation since the absolute value of a complex entry equals the scaled Frobenius norm of the corresponding block entry in K.
>> The paper additional outlines the challenges of the poor spectral properties of the equivalent real system.
>> So, I am assembling the system with a 2x2 block, but am not sure how to best pick the right solver options in Petsc.
>> I agree that I am getting confused by the “block” nomenclature. Particularly, I am not sure how to reconcile the different notions with points 1 and 2 from the paper (noted above).
>    In PETSc we call this 2x2 block Jacobi "point-block Jacobi"  you can use the option -pc_type pbjacobi.  The ILU() in PETSc can also be "point block", this is obtained with the usual -pc_type ilu (that is there is no different preconditioner name for ILU point block).  To use all these things you need to make your matrix a BAIJ matrix (not an AIJ) and set its block size to 2.
>   Have you tried solving the matrices as complex? Is there a reason you wish to reformulate them as real?
>   The convergence of iterative methods (either with real or complex numbers) depends on the properties of the A and B (i.e. C) matrix. Where does the C matrix come from? There are many applications that result in complex matrices that are poorly conditioned for iterative methods.
>   Barry
>> Any guidance would be appreciated!
>> Thanks,
>> Manav
>>> On Nov 15, 2016, at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>  We can help you if you provide more information about what the blocks represent in your problem.
>>>  Do you have two degrees of freedom at each grid point? What physically are the two degrees of freedom. What equations are you solving?
>>>   I think you may be mixing up the "matrix block size" of 2 with the blocks in "block Jacobi". Though both are called "block" they really don't have anything to do with each other.
>>>  Barry
>>>> On Nov 15, 2016, at 3:03 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>>>> Hi,
>>>>  I am setting up a matrix with the following calls. The intent is to solve the system with a 2x2 block size.
>>>>  What combinations of KSP/PC will effectively translate to solving this block matrix system?
>>>>  I saw a discussion about bjacobi in the manual with the following calls (I omitted the prefixes from my actual command):
>>>> -pc_type bjacobi -pc_bjacobi_blocks 2 -sub_ksp_type preonly -sub_pc_type lu  -ksp_view
>>>> which provides the following output:
>>>> KSP Object:(fluid_complex_) 1 MPI processes
>>>> type: gmres
>>>> PC Object:(fluid_complex_) 1 MPI processes
>>>> type: bjacobi
>>>>   block Jacobi: number of blocks = 2
>>>>     type: preonly
>>>>     using NONE norm type for convergence test
>>>>     type: lu
>>>>       matrix ordering: nd
>>>>       factor fill ratio given 5., needed 5.70941
>>>>             type: seqaij
>>>>             rows=36844, cols=36844
>>>>             total: nonzeros=14748816, allocated nonzeros=14748816
>>>>               using I-node routines: found 9211 nodes, limit used is 5
>>>>       type: seqaij
>>>>       total: nonzeros=2583248, allocated nonzeros=2583248
>>>>   type: seqaij
>>>>   rows=73688, cols=73688, bs=2
>>>>   total: nonzeros=5224384, allocated nonzeros=5224384
>>>>     using I-node routines: found 18422 nodes, limit used is 5
>>>> Likewise, I tried to use a more generic option:
>>>> -mat_set_block_size 2 -ksp_type gmres -pc_type ilu  -sub_ksp_type preonly -sub_pc_type lu  -ksp_view
>>>> with the following output:
>>>> Linear fluid_complex_ solve converged due to CONVERGED_RTOL iterations 38
>>>> type: gmres
>>>> type: ilu
>>>>   0 levels of fill
>>>>   factor fill ratio given 1., needed 1.
>>>>         type: seqaij
>>>>   type: seqaij
>>>> Are other PC types expected to translate to the block matrices?
>>>> I would appreciate any guidance.
>>>> Thanks,
>>>> Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161115/b85a83b1/attachment-0001.html>
