[petsc-users] solving system with 2x2 block size
Manav Bhatia bhatiamanav at gmail.com
Tue Nov 15 15:23:14 CST 2016
I have a complex system,   (A + i B) (x + i y) = (f + ig), that I am trying to solve using real matrices:
    [A  -B;   B A ] [x; y] = [f; g]
So, the 2x2 block is made of the real and imaginary component of each entry in the complex matrix.
I am following the discussion in the following paper:
DAY D. \& HEROUX M.A. 2001. Solving complex-valued linear systems via equivalent real formulations. \textit{SIAM Journal on Scientific Computing} 23: 480-498.
Following is an excerpt.
The matrix K in the K formulation has a natural 2-by-2 block structure that can be exploited by using block entry data structures. Using the block entry features of these packages has the following benefits.
Applying 2-by-2 block Jacobi scaling to K corresponds exactly to applying point Jacobi scaling to C.
The block sparsity pattern of K exactly matches the point sparsity pattern of C. Thus any pattern-based preconditioners such as block ILU(l) applied to K correspond exactly to ILU(l) applied to C. See section 4 for definitions of block ILU(l) and ILU(l).
Any drop tolerance-based complex preconditioner has a straightforward K formulation since the absolute value of a complex entry equals the scaled Frobenius norm of the corresponding block entry in K.
The paper additional outlines the challenges of the poor spectral properties of the equivalent real system.
So, I am assembling the system with a 2x2 block, but am not sure how to best pick the right solver options in Petsc.
I agree that I am getting confused by the “block” nomenclature. Particularly, I am not sure how to reconcile the different notions with points 1 and 2 from the paper (noted above).
Any guidance would be appreciated!
Manav
> On Nov 15, 2016, at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   We can help you if you provide more information about what the blocks represent in your problem.
>   Do you have two degrees of freedom at each grid point? What physically are the two degrees of freedom. What equations are you solving?
>    I think you may be mixing up the "matrix block size" of 2 with the blocks in "block Jacobi". Though both are called "block" they really don't have anything to do with each other.
>   Barry
>> On Nov 15, 2016, at 3:03 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>> Hi,
>>   I am setting up a matrix with the following calls. The intent is to solve the system with a 2x2 block size.
>>   What combinations of KSP/PC will effectively translate to solving this block matrix system?
>>   I saw a discussion about bjacobi in the manual with the following calls (I omitted the prefixes from my actual command):
>> -pc_type bjacobi -pc_bjacobi_blocks 2 -sub_ksp_type preonly -sub_pc_type lu  -ksp_view
>> which provides the following output:
>> KSP Object:(fluid_complex_) 1 MPI processes
>>  type: gmres
>>    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>    GMRES: happy breakdown tolerance 1e-30
>>  maximum iterations=10000, initial guess is zero
>>  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>  left preconditioning
>>  using PRECONDITIONED norm type for convergence test
>> PC Object:(fluid_complex_) 1 MPI processes
>>  type: bjacobi
>>    block Jacobi: number of blocks = 2
>>    Local solve is same for all blocks, in the following KSP and PC objects:
>>    KSP Object:    (fluid_complex_sub_)     1 MPI processes
>>      type: preonly
>>      using NONE norm type for convergence test
>>    PC Object:    (fluid_complex_sub_)     1 MPI processes
>>      type: lu
>>        LU: out-of-place factorization
>>        tolerance for zero pivot 2.22045e-14
>>        matrix ordering: nd
>>        factor fill ratio given 5., needed 5.70941
>>          Factored matrix follows:
>>            Mat Object:             1 MPI processes
>>              type: seqaij
>>              rows=36844, cols=36844
>>              package used to perform factorization: petsc
>>              total: nonzeros=14748816, allocated nonzeros=14748816
>>              total number of mallocs used during MatSetValues calls =0
>>                using I-node routines: found 9211 nodes, limit used is 5
>>      linear system matrix = precond matrix:
>>      Mat Object:      (fluid_complex_)       1 MPI processes
>>        type: seqaij
>>        total: nonzeros=2583248, allocated nonzeros=2583248
>>    type: seqaij
>>    rows=73688, cols=73688, bs=2
>>    total: nonzeros=5224384, allocated nonzeros=5224384
>>      using I-node routines: found 18422 nodes, limit used is 5
>> Likewise, I tried to use a more generic option:
>> -mat_set_block_size 2 -ksp_type gmres -pc_type ilu  -sub_ksp_type preonly -sub_pc_type lu  -ksp_view
>> with the following output:
>> Linear fluid_complex_ solve converged due to CONVERGED_RTOL iterations 38
>>  type: gmres
>>  type: ilu
>>    ILU: out-of-place factorization
>>    0 levels of fill
>>    matrix ordering: natural
>>    factor fill ratio given 1., needed 1.
>>          type: seqaij
>>    type: seqaij
>>  Are other PC types expected to translate to the block matrices?
>>  I would appreciate any guidance.
>> Thanks,
>> Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161115/039c66e1/attachment.html>
