[petsc-users] A question of DMPlexGetAdjacency
leejearl leejearl at 126.com
Mon Nov 14 08:59:30 CST 2016
Hi all:
     I am not sure the using of the function "DMPlexGetAdjacency".
     My codes are as follows:
     PetscInt adj, *adjSize=NULL;
     ierr = DMPlexGetAdjacency(dm, p,  &adj, &adj);
     Sometimes, The above codes works. But, it always gets an error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: Invalid mesh exceeded adjacency allocation (1)
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-1864-ga10654c
GIT Date: 2016-11-01 22:25:06 -0500
[0]PETSC ERROR: ./cavity on a arch-linux2-c-debug named leejearl by
leejearl Mon Nov 14 22:57:03 2016
[0]PETSC ERROR: Configure options --prefix=/home/leejearl/Install/Petsc
--with-mpi-dir=/home/leejearl/Install/openmpi/1.8.5_gnu
--download-exodusii=../externalpackages/exodus-5.24.tar.bz2
--download-netcdf=../externalpackages/netcdf-4.3.2.tar.gz
--download-hdf5=../externalpackages/hdf5-1.8.12.tar.gz
--download-triangle=../externalpackages/Triangle.tar.gz
--download-sowing=../externalpackages/git.sowing.tar.gz
[0]PETSC ERROR: #1 DMPlexGetAdjacency_Cone_Internal() line 193 in
/home/leejearl/Software/petsc/petsc/src/dm/impls/plex/plexdistribute.c
[0]PETSC ERROR: #2 DMPlexGetAdjacency_Internal() line 298 in
[0]PETSC ERROR: #3 DMPlexGetAdjacency() line 372 in
[0]PETSC ERROR: #4 CalcConVarGradient() line 98 in
/home/leejearl/Desktop/PETSc/gkscavity/cavity.c
     Can anyone help me with the origin of the error? or help me with a
sample code of the use of function "DMPlexGetAdjacency".
     Thanks
leejearl
