[petsc-users] Shell preconditioner within a fieldsplit
Dave May dave.mayhem23 at gmail.com
Mon Nov 14 00:04:08 CST 2016
Looks like you want the contents of your mat shell, specifically the op Ax,
to define the action of the preconditioner.
You need to either create a PCShell (rather than a MatShell), and define
the operation called by PCApply(), or keep you current shell but change
"preonly" to "mat".
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCMAT.html#PCMAT
Thanks
Dave
On Mon, 14 Nov 2016 at 06:36, Safin, Artur <aks084000 at utdallas.edu> wrote:
> Hello,
> What is the proper way to set up a shell preconditioner within a
> fielsplit? I have tried it on my own, but do not get the proper
> behavior. The relevant portion looks like this:
> __________________________________________________________________
> // Global System
> KSPSetOperators(ksp, A, A);
> // Skipped code..
> // Shell Preconditioner for the pressure sub-block
> KSP *subksp;
> PCFieldSplitGetSubKSP(pc, NULL, &subksp);
> Mat pressureA;
> KSPSetType(subksp[0], "preonly");
> MatCreateShell(MPI_COMM_WORLD, n_local_P_dofs, n_local_P_dofs, ,
> PETSC_DETERMINE, PETSC_DETERMINE, &pressureA);
> MatShellSetOperation(pressureA, MATOP_MULT, (void(*)(void))
> PressureBlock);
> KSPSetOperators(subksp[0], pressureA, pressureA);
> // Skipped code..
> KSPSetUp(ksp);
> KSPSolve(ksp, b, x);
> The fieldsplit component works fine; the solver however does not go into
> the custom function PressureBlock(), so I am curious as to what the correct
> approach is.
> Best,
> Artur
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161114/f42c6564/attachment.html>
