[petsc-users] SAWs does not work in parallel on my laptop
Tobin Isaac tisaac at uchicago.edu
Thu Nov 10 14:21:49 CST 2016
I tried running the first example with SAWs, and it works with one
process, but not in parallel.  This is a minimal install using the
downloaded mpich version.  Any suggestions?
/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -o ex1.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3   -I/home/tisaac/Projects/petsc/include -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include    `pwd`/ex1.c
/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  -o ex1 ex1.o  -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib  -lpetsc -llapack -lblas -lX11 -lssl -lcrypto -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lSAWs -lpthread -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lmpifort -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpicxx -lstdc++ -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lmpi -lgcc_s -ldl
/bin/rm -f -f ex1.o
[0] PetscGetHostName(): Rejecting domainname, likely is NIS alembic.(none)
[0] PetscGetFileStat(): System call stat() succeeded on file /home/tisaac/Projects/petsc/share/petsc/saws/js
[0] PetscTestOwnership(): System call access() succeeded on file /home/tisaac/Projects/petsc/share/petsc/saws/js
[0] PetscInitialize(): PETSc successfully started: number of processors = 2
[0] PetscInitialize(): Running on machine: alembic
[1]PETSC ERROR: #1 PetscLogInitialize() line 229 in /home/tisaac/Projects/petsc/src/sys/logging/plog.c
[1]PETSC ERROR: #2 PetscInitialize() line 891 in /home/tisaac/Projects/petsc/src/sys/objects/pinit.c
[0] PetscSAWsBlock(): Blocking on SAWs
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 21665 RUNNING AT alembic
=   EXIT CODE: 14
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
                            Pushing language C
                            Popping language C
                            Pushing language CUDA
                            Popping language CUDA
                            Pushing language Cxx
                            Popping language Cxx
                            Pushing language FC
                            Popping language FC
Starting Configure Run at Thu Nov 10 13:56:54 2016
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --download-saws --download-mpich PETSC_ARCH=arch-linux2-c-debug-mpich
Working directory: /home/tisaac/Projects/petsc
Machine platform:
('Linux', 'alembic', '3.2.0-115-generic', '#157-Ubuntu SMP Tue Oct 25 16:32:19 UTC 2016', 'x86_64', 'x86_64')
Python version:
2.7.3 (default, Jun 22 2015, 19:33:41)
[GCC 4.6.3]
        Pushing language C
        Popping language C
        Pushing language FC
        Popping language FC
TEST configureExternalPackagesDir from config.framework(/home/tisaac/Projects/petsc/config/BuildSystem/config/framework.py:840)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:840)
TEST configureDebuggers from config.utilities.debuggers(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
Checking for program /usr/lib/mutt/gdb...not found
Checking for program /home/tisaac/.local/bin/gdb...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/gdb...not found
Checking for program /home/tisaac/.bin/gdb...not found
Checking for program /usr/lib/lightdm/lightdm/gdb...not found
Checking for program /usr/local/sbin/gdb...not found
Checking for program /usr/local/bin/gdb...not found
Checking for program /usr/sbin/gdb...not found
Checking for program /usr/bin/gdb...found
              Defined make macro "GDB" to "/usr/bin/gdb"
Checking for program /usr/lib/mutt/dbx...not found
Checking for program /home/tisaac/.local/bin/dbx...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/dbx...not found
Checking for program /home/tisaac/.bin/dbx...not found
Checking for program /usr/lib/lightdm/lightdm/dbx...not found
Checking for program /usr/local/sbin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/sbin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /sbin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /usr/games/dbx...not found
Checking for program /home/tisaac/dbx...not found
Checking for program /usr/lib/mutt/xdb...not found
Checking for program /home/tisaac/.local/bin/xdb...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/xdb...not found
Checking for program /home/tisaac/.bin/xdb...not found
Checking for program /usr/lib/lightdm/lightdm/xdb...not found
Checking for program /usr/local/sbin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/sbin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /sbin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /usr/games/xdb...not found
Checking for program /home/tisaac/xdb...not found
Checking for program /usr/lib/mutt/dsymutil...not found
Checking for program /home/tisaac/.local/bin/dsymutil...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/dsymutil...not found
Checking for program /home/tisaac/.bin/dsymutil...not found
Checking for program /usr/lib/lightdm/lightdm/dsymutil...not found
Checking for program /usr/local/sbin/dsymutil...not found
Checking for program /usr/local/bin/dsymutil...not found
Checking for program /usr/sbin/dsymutil...not found
Checking for program /usr/bin/dsymutil...not found
Checking for program /sbin/dsymutil...not found
Checking for program /bin/dsymutil...not found
Checking for program /usr/games/dsymutil...not found
Checking for program /home/tisaac/dsymutil...not found
            Defined make macro "DSYMUTIL" to "true"
            Defined "USE_GDB_DEBUGGER" to "1"
TEST configureGit from config.sourceControl(/home/tisaac/Projects/petsc/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /usr/lib/mutt/git...not found
Checking for program /home/tisaac/.local/bin/git...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/git...not found
Checking for program /home/tisaac/.bin/git...not found
Checking for program /usr/lib/lightdm/lightdm/git...not found
Checking for program /usr/local/sbin/git...not found
Checking for program /usr/local/bin/git...not found
Checking for program /usr/sbin/git...not found
Checking for program /usr/bin/git...found
              Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.10.2
TEST configureMercurial from config.sourceControl(/home/tisaac/Projects/petsc/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
  Find the Mercurial executable
Checking for program /usr/lib/mutt/hg...not found
Checking for program /home/tisaac/.local/bin/hg...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/hg...not found
Checking for program /home/tisaac/.bin/hg...not found
Checking for program /usr/lib/lightdm/lightdm/hg...not found
Checking for program /usr/local/sbin/hg...not found
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/sbin/hg...not found
Checking for program /usr/bin/hg...found
              Defined make macro "HG" to "hg"
Executing: hg version -q
stdout: Mercurial Distributed SCM (version 2.0.2)
TEST configureCLanguage from PETSc.options.languages(/home/tisaac/Projects/petsc/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
          C language is C
            Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/home/tisaac/Projects/petsc/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
          Version Information:
          #define PETSC_VERSION_RELEASE    0
          #define PETSC_VERSION_MAJOR      3
          #define PETSC_VERSION_MINOR      7
          #define PETSC_VERSION_SUBMINOR   4
          #define PETSC_VERSION_PATCH      0
          #define PETSC_VERSION_DATE       "unknown"
          #define PETSC_VERSION_GIT        "unknown"
          #define PETSC_VERSION_DATE_GIT   "unknown"
          #define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
          #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
            Defined make macro "DIR" to "/home/tisaac/Projects/petsc"
TEST getDatafilespath from PETSc.options.dataFilesPath(/home/tisaac/Projects/petsc/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
            Defined make macro "DATAFILESPATH" to "/home/tisaac/datafiles"
TEST configureInstallationMethod from PETSc.options.petscclone(/home/tisaac/Projects/petsc/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
          bin/maint exists. This appears to be a repository clone
          .git directory exists
Executing: cd /home/tisaac/Projects/petsc && git describe
stdout: v3.7.4-1922-geb30558
Executing: cd /home/tisaac/Projects/petsc && git log -1 --pretty=format:%H
stdout: eb305583891044e39bdd576a7266be98a7cf3a54
Executing: cd /home/tisaac/Projects/petsc && git log -1 --pretty=format:%ci
stdout: 2016-11-10 08:59:24 -0600
Executing: cd /home/tisaac/Projects/petsc && git branch
stdout:
maint
  mark/feature-picell
  mark/feature-picell-diverged
  mark/feature-picell-quad
  mark/ksp-ex56
  mark/ksp-newex56
* master
  next
  next-merge-tisaac/dmforest
  tisaac/buildsystem-feature-parallel
  tisaac/buildsystem-feature-subst-link-flags
  tisaac/config-fix-petsc-py
  tisaac/dm-project-function-label
  tisaac/dmplex-feature-ex3-high-order
  tisaac/dmplex-feature-ex6-symmetry
  tisaac/dmplex-feature-quadrature-in-geom
  tisaac/dmplex-use-symmetry
  tisaac/dt-feature-vector-quadrature
  tisaac/dualspace-feature-get-symmetries
  tisaac/dualspace-feature-symmetry
  tisaac/dualspace-feature-symmetry-old
  tisaac/feature-add-petscfe-tensor
  tisaac/feature-dm-reembed
  tisaac/feature-parallel-config-context-mask
  tisaac/feature-picell
  tisaac/feature-plex-example-nonconforming
  tisaac/feature-typed-orientation
  tisaac/fix-gamg-set-coordinates
  tisaac/fix-tests
  tisaac/master-merge-mark-snesex56
  tisaac/petscfe-matching-quadrature-order-back
  tisaac/plex-descriptive-debug
  tisaac/plex-feature-tree-fv-no-redistribute
  tisaac/plex-feature-vec-get-star
  tisaac/plex-fv-without-ghosts
  tisaac/thplex-makefile-examples
            Defined "VERSION_GIT" to ""v3.7.4-1922-geb30558""
            Defined "VERSION_DATE_GIT" to ""2016-11-10 08:59:24 -0600""
            Defined "VERSION_BRANCH_GIT" to ""master""
TEST configureArchitecture from PETSc.options.arch(/home/tisaac/Projects/petsc/config/PETSc/options/arch.py:25)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:25)
  Checks PETSC_ARCH and sets if not set
            Defined "ARCH" to ""arch-linux2-c-debug-mpich""
TEST setInstallDir from PETSc.options.installDir(/home/tisaac/Projects/petsc/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:35)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.options.installDir(/home/tisaac/Projects/petsc/config/PETSc/options/installDir.py:74)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:74)
TEST cleanInstallDir from PETSc.options.installDir(/home/tisaac/Projects/petsc/config/PETSc/options/installDir.py:67)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:67)
TEST configureInstallDir from PETSc.options.installDir(/home/tisaac/Projects/petsc/config/PETSc/options/installDir.py:51)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:51)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
          Changed persistence directory to /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/home/tisaac/Projects/petsc/config/PETSc/options/installDir.py:87)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:87)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/home/tisaac/Projects/petsc/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/home/tisaac/Projects/petsc/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1600)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1600)
          **** printenv ****
TODO_FILE=/home/tisaac/todo/todo.txt
MAKEN=8
WORK=/home/tisaac/work
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
BROWSER=firefox
XDG_CURRENT_DESKTOP=GNOME
DONE_FILE=/home/tisaac/todo/done.txt
LOGNAME=tisaac
USER=tisaac
PATH=/usr/lib/mutt:/home/tisaac/.local/bin:/usr/local/texlive/2015/bin/x86_64-linux:/home/tisaac/.bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/tisaac/.bin
CCGOLOCAL=/home/tisaac/ccgo
GNOME_KEYRING_CONTROL=/tmp/keyring-984kz1
DISPLAY=:0
vcs_info_msg_0_=%{%}?%{%}%{%}?%{(B%}%{%}master=
SSH_AGENT_PID=2524
LANG=en_US.UTF-8
MPICH_DBG_FILENAME=dbg-%w-%d.log
TERM=xterm-256color
SHELL=/usr/bin/zsh
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
XDG_SESSION_COOKIE=0bb413799794f59deebb04d900000003-1478788580.738106-107490020
SESSION_MANAGER=local/alembic:@/tmp/.ICE-unix/2478,unix/alembic:/tmp/.ICE-unix/2478
XDG_DATA_DIRS=/usr/share/gnome-xmonad:/usr/share/gnome:/usr/local/share/:/usr/share/
MANDATORY_PATH=/usr/share/gconf/gnome-xmonad.mandatory.path
MPICH_DBG_LEVEL=verbose
T8_ARCH=arch-debug
WINDOWID=48235846
PETSC_DIR=/home/tisaac/Projects/petsc
EDITOR=vim
DESKTOP_AUTOSTART_ID=1083d73533c5ccf823147878858097140900000024780037
PETSC_OPTIONS=-malloc_test
OMPI_CC=clang
GPG_AGENT_INFO=/tmp/keyring-984kz1/gpg:0:1
HOME=/home/tisaac
TODO_ACTIONS_DIR=/home/tisaac/.todo.actions.d
REPORT_FILE=/home/tisaac/todo/report.txt
TODOTXT_DEFAULT_ACTION=ls
TODO_DIR=/home/tisaac/todo
EXEC=/home/tisaac/exec
PYTHONPATH=/home/tisaac/.local/lib/python2.7/site-packages
SSH_AUTH_SOCK=/tmp/keyring-984kz1/ssh
FULLHOST=alembic
XENVIRONMENT=/home/tisaac/.Xresources
GDMSESSION=gnome-xmonad
BUILD=/home/tisaac/build
GNOME_KEYRING_PID=2467
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
COLORFGBG=default;default;0
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-Pwy2k05FP3,guid=0f6504b3754592c949b131dc0000001c
_=/home/tisaac/Projects/petsc/./reconfigure-arch-linux2-c-debug-mpich.py
XAUTHORITY=/home/tisaac/.Xauthority
CCGOREPO=https://svn.ices.utexas.edu/repos/ccgo
DESKTOP_SESSION=gnome-xmonad
GTAGSLIBPATH=/home/tisaac/Projects/petsc
XDG_CONFIG_DIRS=/etc/xdg/xdg-gnome-xmonad:/etc/xdg
DEFAULTS_PATH=/usr/share/gconf/gnome-xmonad.default.path
UBUNTU_MENUPROXY=libappmenu.so
SCRATCH=/home/tisaac/scratch
OLDPWD=/home/tisaac/Projects/petsc/src/sys/examples/tutorials
MPICH_DBG_CLASS=all
SHLVL=1
COLORTERM=rxvt-xpm
vcs_info_msg_1_=
OMPI_CXX=clang++
TEST resetEnvCompilers from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1607)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1607)
TEST checkEnvCompilers from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1637)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1637)
TEST checkMPICompilerOverride from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1572)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1572)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1591)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1591)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:417)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:417)
  Determine the compiler vendor
          Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:427)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:427)
  Initialize the compiler and linker flags
            Pushing language C
          Initialized CFLAGS to
          Initialized LDFLAGS to
            Popping language C
          Initialized CUDAFLAGS to
          Initialized CXXFLAGS to
          Initialized CXX_CXXFLAGS to
            Pushing language FC
          Initialized FFLAGS to
            Popping language FC
          Initialized CPPFLAGS to
          Initialized CUDAPPFLAGS to
          Initialized CXXCPPFLAGS to
          Initialized CC_LINKER_FLAGS to []
          Initialized CXX_LINKER_FLAGS to []
          Initialized FC_LINKER_FLAGS to []
          Initialized CUDAC_LINKER_FLAGS to []
          Initialized sharedLibraryFlags to []
          Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:553)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:553)
  Locate a functional C compiler
Checking for program /usr/lib/mutt/gcc...not found
Checking for program /home/tisaac/.local/bin/gcc...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/gcc...not found
Checking for program /home/tisaac/.bin/gcc...not found
Checking for program /usr/lib/lightdm/lightdm/gcc...not found
Checking for program /usr/local/sbin/gcc...not found
Checking for program /usr/local/bin/gcc...not found
Checking for program /usr/sbin/gcc...not found
Checking for program /usr/bin/gcc...found
              Defined make macro "CC" to "gcc"
              Pushing language C
                          All intermediate test results are stored in /tmp/petsc-W4It8W
                        All intermediate test results are stored in /tmp/petsc-W4It8W/config.setCompilers
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                              Pushing language C
                                              Popping language C
                                              Pushing language FC
                                              Popping language FC
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: ld returned 1 exit status
Successful compile:
Source:
int main() {
  return 0;
                          Pushing language C
                          Popping language C
Testing executable /tmp/petsc-W4It8W/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.setCompilers/conftest
              Popping language C
TEST checkCPreprocessor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:586)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:586)
  Locate a functional C preprocessor
              Defined make macro "CPP" to "gcc -E"
            Pushing language C
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers  /tmp/petsc-W4It8W/config.setCompilers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.setCompilers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.setCompilers/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.setCompilers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.setCompilers/conffix.h" 1
# 3 "/tmp/petsc-W4It8W/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 324 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 325 "/usr/include/features.h" 2 3 4
# 357 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 324 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef int wchar_t;
# 34 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/waitflags.h" 1 3 4
# 43 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 1 3 4
# 65 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/endian.h" 1 3 4
# 38 "/usr/include/endian.h" 2 3 4
# 61 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 2 3 4
# 62 "/usr/include/endian.h" 2 3 4
# 66 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 44 "/usr/include/stdlib.h" 2 3 4
# 68 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 96 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 140 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (__const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (__const char *__nptr)
extern long int atol (__const char *__nptr)
__extension__ extern long long int atoll (__const char *__nptr)
extern double strtod (__const char *__restrict __nptr,
        char **__restrict __endptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern float strtof (__const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern long double strtold (__const char *__restrict __nptr,
extern long int strtol (__const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (__const char *__restrict __nptr,
__extension__
extern long long int strtoq (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (__const char *__restrict __nptr,
__extension__
extern long long int strtoll (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (__const char *__restrict __nptr,
# 311 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (__const char *__s)
# 1 "/usr/include/x86_64-linux-gnu/sys/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 131 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/typesizes.h" 1 3 4
# 132 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 31 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 61 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 99 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 133 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 58 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 74 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 92 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 104 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 134 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 147 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 148 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 195 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 220 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/select.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/select.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/select.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/select.h" 2 3 4
# 32 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 35 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 45 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/time.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 47 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 65 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 97 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 107 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 119 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 132 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 221 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 1 3 4
# 30 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 64 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
# 224 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 271 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 2 3 4
# 50 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 76 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    int __spins;
    __pthread_list_t __list;
# 101 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 187 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 272 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 321 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 25 "/usr/include/alloca.h" 3 4
# 26 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 498 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 531 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
# 554 "/usr/include/stdlib.h" 3 4
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *__secure_getenv (__const char *__name)
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (__const char *__name, __const char *__value, int __replace)
extern int unsetenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 620 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 642 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 663 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 712 "/usr/include/stdlib.h" 3 4
extern int system (__const char *__command) ;
# 734 "/usr/include/stdlib.h" 3 4
extern char *realpath (__const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (__const void *, __const void *);
# 752 "/usr/include/stdlib.h" 3 4
extern void *bsearch (__const void *__key, __const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 771 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 808 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (__const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int mbtowc (wchar_t *__restrict __pwc,
     __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__)) ;
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
   __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern size_t wcstombs (char *__restrict __s,
   __const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (__const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 896 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *__const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 948 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 964 "/usr/include/stdlib.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
            Popping language C
TEST checkCUDACompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:627)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:627)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:667)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:667)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:779)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:779)
  Locate a functional Cxx compiler
Checking for program /usr/lib/mutt/g++...not found
Checking for program /home/tisaac/.local/bin/g++...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/g++...not found
Checking for program /home/tisaac/.bin/g++...not found
Checking for program /usr/lib/lightdm/lightdm/g++...not found
Checking for program /usr/local/sbin/g++...not found
Checking for program /usr/local/bin/g++...not found
Checking for program /usr/sbin/g++...not found
Checking for program /usr/bin/g++...found
              Defined make macro "CXX" to "g++"
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers     /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                              Pushing language C
                                              Popping language C
                                              Pushing language FC
                                              Popping language FC
                      Pushing language CXX
                      Popping language CXX
Executing: g++  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: g++  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
TEST checkCxxPreprocessor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:817)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:817)
  Locate a functional Cxx preprocessor
              Defined make macro "CXXCPP" to "g++ -E"
Executing: g++ -E  -I/tmp/petsc-W4It8W/config.setCompilers   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
stdout:
# 1 "/tmp/petsc-W4It8W/config.setCompilers/conftest.cc"
# 1 "<built-in>"
# 2 "/tmp/petsc-W4It8W/config.setCompilers/conftest.cc" 2
extern "C" {
# 3 "/tmp/petsc-W4It8W/config.setCompilers/conftest.cc" 2
# 1 "/usr/include/c++/4.6/cstdlib" 1 3
# 41 "/usr/include/c++/4.6/cstdlib" 3
# 42 "/usr/include/c++/4.6/cstdlib" 3
# 1 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 1 3
# 153 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 3
namespace std
  typedef long int ptrdiff_t;
# 393 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 3
# 1 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/os_defines.h" 1 3
# 40 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/os_defines.h" 3
# 41 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/os_defines.h" 2 3
# 394 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 2 3
# 1 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/cpu_defines.h" 1 3
# 397 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 2 3
# 44 "/usr/include/c++/4.6/cstdlib" 2 3
# 66 "/usr/include/c++/4.6/cstdlib" 3
# 33 "/usr/include/stdlib.h" 3 4
extern "C" {
union wait
    int w_status;
    struct
 unsigned int:16;
    struct
 unsigned int:16;
      } __wait_stopped;
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
    long long int quot;
    long long int rem;
  } lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) throw () ;
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1))) ;
       char **__restrict __endptr) throw () __attribute__ ((__nonnull__ (1))) ;
__extension__
__extension__
__extension__
__extension__
# 236 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 28 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 237 "/usr/include/stdlib.h" 2 3 4
extern long int strtol_l (__const char *__restrict __nptr,
     char **__restrict __endptr, int __base,
     __locale_t __loc) throw () __attribute__ ((__nonnull__ (1, 4))) ;
extern unsigned long int strtoul_l (__const char *__restrict __nptr,
        int __base, __locale_t __loc)
__extension__
extern long long int strtoll_l (__const char *__restrict __nptr,
    __locale_t __loc)
__extension__
extern unsigned long long int strtoull_l (__const char *__restrict __nptr,
extern double strtod_l (__const char *__restrict __nptr,
   char **__restrict __endptr, __locale_t __loc)
     throw () __attribute__ ((__nonnull__ (1, 3))) ;
extern float strtof_l (__const char *__restrict __nptr,
extern long double strtold_l (__const char *__restrict __nptr,
         __locale_t __loc)
extern char *l64a (long int __n) throw () ;
extern "C" {
typedef __ino64_t ino64_t;
typedef __off64_t off64_t;
typedef __useconds_t useconds_t;
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
# 55 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
typedef struct
    __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
extern "C" {
extern "C" {
__extension__
     throw () __attribute__ ((__const__));
__extension__
__extension__
# 263 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
extern long int random (void) throw ();
extern void srandom (unsigned int __seed) throw ();
   size_t __statelen) throw () __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) throw () __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
       int32_t *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
   size_t __statelen,
     throw () __attribute__ ((__nonnull__ (2, 4)));
extern int rand (void) throw ();
extern void srand (unsigned int __seed) throw ();
extern int rand_r (unsigned int *__seed) throw ();
extern double drand48 (void) throw ();
extern double erand48 (unsigned short int __xsubi[3]) throw () __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) throw ();
extern long int mrand48 (void) throw ();
extern void srand48 (long int __seedval) throw ();
extern void lcong48 (unsigned short int __param[7]) throw () __attribute__ ((__nonnull__ (1)));
struct drand48_data
        double *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
       struct drand48_data *__buffer) throw () __attribute__ ((__nonnull__ (1, 2)));
extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
     throw () __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) throw ();
extern void cfree (void *__ptr) throw ();
extern "C" {
extern void *alloca (size_t __size) throw ();
extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
extern void abort (void) throw () __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) throw () __attribute__ ((__nonnull__ (1)));
extern "C++" int at_quick_exit (void (*__func) (void))
     throw () __asm ("at_quick_exit") __attribute__ ((__nonnull__ (1)));
extern void exit (int __status) throw () __attribute__ ((__noreturn__));
extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
extern char *getenv (__const char *__name) throw () __attribute__ ((__nonnull__ (1))) ;
extern int putenv (char *__string) throw () __attribute__ ((__nonnull__ (1)));
extern int unsetenv (__const char *__name) throw () __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) throw ();
extern char *mktemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 630 "/usr/include/stdlib.h" 3 4
extern int mkstemp64 (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 652 "/usr/include/stdlib.h" 3 4
extern int mkstemps64 (char *__template, int __suffixlen)
extern char *mkdtemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 674 "/usr/include/stdlib.h" 3 4
extern int mkostemp (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 684 "/usr/include/stdlib.h" 3 4
extern int mkostemp64 (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 694 "/usr/include/stdlib.h" 3 4
extern int mkostemps (char *__template, int __suffixlen, int __flags)
# 706 "/usr/include/stdlib.h" 3 4
extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
extern char *canonicalize_file_name (__const char *__name)
         char *__restrict __resolved) throw () ;
typedef __compar_fn_t comparison_fn_t;
typedef int (*__compar_d_fn_t) (__const void *, __const void *, void *);
extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
       __compar_d_fn_t __compar, void *__arg)
extern int abs (int __x) throw () __attribute__ ((__const__)) ;
extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
     int *__restrict __sign) throw () __attribute__ ((__nonnull__ (3, 4))) ;
     throw () __attribute__ ((__nonnull__ (3))) ;
     size_t __len) throw () __attribute__ ((__nonnull__ (3, 4, 5)));
extern int mblen (__const char *__s, size_t __n) throw () ;
     __const char *__restrict __s, size_t __n) throw () ;
extern int wctomb (char *__s, wchar_t __wchar) throw () ;
   __const char *__restrict __s, size_t __n) throw ();
     throw ();
extern int rpmatch (__const char *__response) throw () __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1, 2, 3))) ;
extern void setkey (__const char *__key) throw () __attribute__ ((__nonnull__ (1)));
extern int posix_openpt (int __oflag) ;
extern int grantpt (int __fd) throw ();
extern int unlockpt (int __fd) throw ();
extern char *ptsname (int __fd) throw () ;
extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
extern int getpt (void);
# 67 "/usr/include/c++/4.6/cstdlib" 2 3
# 98 "/usr/include/c++/4.6/cstdlib" 3
namespace std __attribute__ ((__visibility__ ("default")))
  using ::div_t;
  using ::ldiv_t;
  using ::abort;
  using ::abs;
  using ::atexit;
  using ::atof;
  using ::atoi;
  using ::atol;
  using ::bsearch;
  using ::calloc;
  using ::div;
  using ::exit;
  using ::free;
  using ::getenv;
  using ::labs;
  using ::ldiv;
  using ::malloc;
  using ::mblen;
  using ::mbstowcs;
  using ::mbtowc;
  using ::qsort;
  using ::rand;
  using ::realloc;
  using ::srand;
  using ::strtod;
  using ::strtol;
  using ::strtoul;
  using ::system;
  using ::wcstombs;
  using ::wctomb;
  inline long
  abs(long __i) { return labs(__i); }
  inline ldiv_t
  div(long __i, long __j) { return ldiv(__i, __j); }
# 158 "/usr/include/c++/4.6/cstdlib" 3
namespace __gnu_cxx __attribute__ ((__visibility__ ("default")))
  using ::lldiv_t;
  using ::_Exit;
  inline long long
  abs(long long __x) { return __x >= 0 ? __x : -__x; }
  using ::llabs;
  inline lldiv_t
  div(long long __n, long long __d)
  { lldiv_t __q; __q.quot = __n / __d; __q.rem = __n % __d; return __q; }
  using ::lldiv;
# 193 "/usr/include/c++/4.6/cstdlib" 3
  using ::atoll;
  using ::strtoll;
  using ::strtoull;
  using ::strtof;
  using ::strtold;
namespace std
  using ::__gnu_cxx::lldiv_t;
  using ::__gnu_cxx::_Exit;
  using ::__gnu_cxx::abs;
  using ::__gnu_cxx::llabs;
  using ::__gnu_cxx::div;
  using ::__gnu_cxx::lldiv;
  using ::__gnu_cxx::atoll;
  using ::__gnu_cxx::strtof;
  using ::__gnu_cxx::strtoll;
  using ::__gnu_cxx::strtoull;
  using ::__gnu_cxx::strtold;
TEST checkFortranCompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:934)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:934)
  Locate a functional Fortran compiler
Checking for program /usr/lib/mutt/gfortran...not found
Checking for program /home/tisaac/.local/bin/gfortran...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/gfortran...not found
Checking for program /home/tisaac/.bin/gfortran...not found
Checking for program /usr/lib/lightdm/lightdm/gfortran...not found
Checking for program /usr/local/sbin/gfortran...not found
Checking for program /usr/local/bin/gfortran...not found
Checking for program /usr/sbin/gfortran...not found
Checking for program /usr/bin/gfortran...found
              Defined make macro "FC" to "gfortran"
              Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                              Pushing language C
                                              Popping language C
                                              Pushing language FC
                                              Popping language FC
                      Pushing language FC
                      Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                      Pushing language FC
                      Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
      program main
      end
                          Pushing language FC
                          Popping language FC
              Popping language FC
TEST checkFortranComments from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:955)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:955)
  Make sure fortran comment "!" works
            Pushing language FC
Successful compile:
Source:
! comment
      program main
      end
          Fortran comments can use ! in column 1
            Popping language FC
TEST checkLargeFileIO from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1072)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1072)
TEST checkArchiver from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1171)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1171)
  Check that the archiver exists and can make a library usable by the compiler
            Pushing language C
Executing: ar -V
stdout:
GNU ar (GNU Binutils for Ubuntu) 2.22
Copyright 2011 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
                Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /usr/lib/mutt/ar...not found
Checking for program /home/tisaac/.local/bin/ar...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/ar...not found
Checking for program /home/tisaac/.bin/ar...not found
Checking for program /usr/lib/lightdm/lightdm/ar...not found
Checking for program /usr/local/sbin/ar...not found
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/sbin/ar...not found
Checking for program /usr/bin/ar...found
              Defined make macro "AR" to "/usr/bin/ar"
Checking for program /usr/lib/mutt/ranlib...not found
Checking for program /home/tisaac/.local/bin/ranlib...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/ranlib...not found
Checking for program /home/tisaac/.bin/ranlib...not found
Checking for program /usr/lib/lightdm/lightdm/ranlib...not found
Checking for program /usr/local/sbin/ranlib...not found
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/sbin/ranlib...not found
Checking for program /usr/bin/ranlib...found
              Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-W4It8W/config.setCompilers/libconf1.a /tmp/petsc-W4It8W/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-W4It8W/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- 'c'
          Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
Successful compile:
Source:
int foo(int a) {
  return a+1;
              Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-W4It8W/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o -L/tmp/petsc-W4It8W/config.setCompilers -lconf1
            Defined make macro "AR_FLAGS" to "cr"
            Defined make macro "AR_LIB_SUFFIX" to "a"
            Popping language C
TEST checkSharedLinker from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1285)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1285)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: Linux
          Checking shared linker gcc using flags ['-shared']
              Defined make macro "LD_SHARED" to "gcc"
          Trying C compiler flag
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -shared    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
            Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
int foo(void) {fprintf(stdout,"hello");
return 0;}
                                            Pushing language C
                                            Popping language C
                                            Pushing language FC
                                            Popping language FC
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/libconftest.so  -shared   /tmp/petsc-W4It8W/config.setCompilers/conftest.o
stderr:
/usr/bin/ld: /tmp/petsc-W4It8W/config.setCompilers/conftest.o: relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/tmp/petsc-W4It8W/config.setCompilers/conftest.o: could not read symbols: Bad value
          Rejected C compiler flag  because it was not compatible with shared linker gcc using flags ['-shared']
Executing: gcc --help
stdout:
Usage: gcc [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase
  --help                   Display this information
  --target-help            Display target specific command line options
  --help={target|optimizers|warnings|params|[^]{joined|separate|undocumented}}[,...]
                           Display specific types of command line options
  (Use '-v --help' to display command line options of sub-processes)
  --version                Display compiler version information
  -dumpspecs               Display all of the built in spec strings
  -dumpversion             Display the version of the compiler
  -dumpmachine             Display the compiler's target processor
  -print-search-dirs       Display the directories in the compiler's search path
  -print-libgcc-file-name  Display the name of the compiler's companion library
  -print-file-name=<lib>   Display the full path to library <lib>
  -print-prog-name=<prog>  Display the full path to compiler component <prog>
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path
  -print-multi-directory   Display the root directory for versions of libgcc
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories
  -print-multi-os-directory Display the relative path to OS libraries
  -print-sysroot           Display the target libraries directory
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers
  -Wa,<options>            Pass comma-separated <options> on to the assembler
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor
  -Wl,<options>            Pass comma-separated <options> on to the linker
  -Xassembler <arg>        Pass <arg> on to the assembler
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor
  -Xlinker <arg>           Pass <arg> on to the linker
  -save-temps              Do not delete intermediate files
  -save-temps=<arg>        Do not delete intermediate files
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components
  -pipe                    Use pipes rather than intermediate files
  -time                    Time the execution of each subprocess
  -specs=<file>            Override built-in specs with the contents of <file>
  -std=<standard>          Assume that the input sources are for <standard>
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries
  -B <directory>           Add <directory> to the compiler's search paths
  -v                       Display the programs invoked by the compiler
  -###                     Like -v but options quoted and commands not executed
  -E                       Preprocess only; do not compile, assemble or link
  -S                       Compile only; do not assemble or link
  -c                       Compile and assemble, but do not link
  -o <file>                Place the output into <file>
  -x <language>            Specify the language of the following input files
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by gcc.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<file:///usr/share/doc/gcc-4.6/README.Bugs>.
          Trying C compiler flag -fPIC
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fPIC
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -shared   -fPIC /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
#include <stdio.h>
return 0;}
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/libconftest.so  -shared  -fPIC /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if (ret) {}
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -L/tmp/petsc-W4It8W/config.setCompilers -lconftest
          Using shared linker gcc with flags ['-shared'] and library extension so
Executing: uname -s
stdout: Linux
TEST checkPIC from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1031)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1031)
  Determine the PIC option for each compiler
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
#include<stdio.h>
void foo(void){fprintf(stdout,"hello");
return;}
void bar(void){foo();}
                    Pushing language C
                    Popping language C
          Accepted C compiler flag
            Popping language C
            Pushing language Cxx
          Trying Cxx compiler flag
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag
Successful compile:
Source:
#include<stdio.h>
return;}
                Pushing language C
                    Pushing language C
                    Popping language C
                Popping language C
stderr:
          Rejected Cxx compiler flag  because shared linker cannot handle it
Executing: g++ --help
stdout:
Usage: g++ [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by g++.  In order to pass
          Trying Cxx compiler flag -fPIC
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers   -fPIC    /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fPIC
Successful compile:
Source:
#include<stdio.h>
return;}
                Pushing language C
                    Pushing language C
                    Popping language C
                Popping language C
          Accepted Cxx compiler flag -fPIC
            Popping language Cxx
            Pushing language FC
          Trying FC compiler flag
Successful compile:
Source:
      program main
      end
Added FC compiler flag
Successful compile:
Source:
      function foo(a)
      real:: a,x,bar
      common /xx/ x
      x=a
      foo = bar(x)
      end
                Pushing language C
                    Pushing language C
                    Popping language C
                Popping language C
stderr:
/usr/bin/ld: /tmp/petsc-W4It8W/config.setCompilers/conftest.o: relocation R_X86_64_32 against `xx_' can not be used when making a shared object; recompile with -fPIC
          Rejected FC compiler flag  because shared linker cannot handle it
Executing: gfortran --help
stdout:
Usage: gfortran [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by gfortran.  In order to pass
          Trying FC compiler flag -fPIC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -fPIC
Successful compile:
Source:
      function foo(a)
      real:: a,x,bar
      common /xx/ x
      x=a
      foo = bar(x)
      end
                Pushing language C
                    Pushing language C
                    Popping language C
                Popping language C
          Accepted FC compiler flag -fPIC
            Popping language FC
TEST checkSharedLinkerPaths from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1380)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1380)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
            Pushing language C
Executing: uname -s
stdout: Linux
Executing: gcc -V
          Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -Wl,-rpath,/home/tisaac/Projects/petsc   -fPIC  /tmp/petsc-W4It8W/config.setCompilers/conftest.o
            Valid C linker flag -Wl,-rpath,/home/tisaac/Projects/petsc
            Popping language C
Executing: uname -s
stdout: Linux
Executing: gcc -V
          Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
Executing: g++  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -Wl,-rpath,/home/tisaac/Projects/petsc   /tmp/petsc-W4It8W/config.setCompilers/conftest.o
            Valid Cxx linker flag -Wl,-rpath,/home/tisaac/Projects/petsc
            Pushing language FC
Executing: uname -s
stdout: Linux
Executing: gcc -V
          Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -Wl,-rpath,/home/tisaac/Projects/petsc   -fPIC /tmp/petsc-W4It8W/config.setCompilers/conftest.o
            Valid FC linker flag -Wl,-rpath,/home/tisaac/Projects/petsc
            Popping language FC
TEST checkLibC from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1415)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1415)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
                    Pushing language C
                    Popping language C
          Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1464)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1464)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
                        All intermediate test results are stored in /tmp/petsc-W4It8W/config.headers
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-W4It8W/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.headers/conffix.h" 1
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 23 "/usr/include/dlfcn.h" 3 4
# 24 "/usr/include/dlfcn.h" 2 3 4
# 26 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/dlfcn.h" 1 3 4
# 29 "/usr/include/dlfcn.h" 2 3 4
# 53 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (__const char *__file, int __mode) __attribute__ ((__nothrow__ , __leaf__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
      __const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 83 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/dlfcn.h" 3 4
              Defined "HAVE_DLFCN_H" to "1"
              Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
                Pushing language C
                            All intermediate test results are stored in /tmp/petsc-W4It8W/config.libraries
Executing: gcc -c -o /tmp/petsc-W4It8W/config.libraries/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.libraries  -fPIC   /tmp/petsc-W4It8W/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  /tmp/petsc-W4It8W/config.libraries/conftest.o  -ldl
                Defined "HAVE_LIBDL" to "1"
                Popping language C
            Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
          Checking dynamic linker gcc using flags ['-shared']
              Defined make macro "DYNAMICLINKER" to "gcc"
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -shared   -fPIC  /tmp/petsc-W4It8W/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
                                            Pushing language C
                                            Popping language C
                                            Pushing language CUDA
                                            Popping language CUDA
                                            Pushing language FC
                                            Popping language FC
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/libconftest.so  -shared  -fPIC  /tmp/petsc-W4It8W/config.setCompilers/conftest.o -ldl
Possible ERROR while running compiler:
stderr:
/tmp/petsc-W4It8W/config.setCompilers/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:11:3: warning: incompatible implicit declaration of built-in function ?printf? [enabled by default]
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:15:3: warning: incompatible implicit declaration of built-in function ?printf? [enabled by default]
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:19:3: warning: incompatible implicit declaration of built-in function ?printf? [enabled by default]
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/tmp/petsc-W4It8W/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
  printf("Could not load symbol\n");
  return -1;
if ((*foo)()) {
  printf("Invalid return from foo()\n");
  return -1;
if (dlclose(handle)) {
  printf("Could not close library\n");
  return -1;
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC  /tmp/petsc-W4It8W/config.setCompilers/conftest.o -ldl
          Using dynamic linker gcc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1516)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1516)
  Output module data as defines and substitutions
            Substituting "CC" with "gcc"
            Substituting "CFLAGS" with " -fPIC "
            Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
            Substituting "CPP" with "gcc -E"
            Substituting "CPPFLAGS" with ""
            Substituting "CXX" with "g++"
            Substituting "CXX_CXXFLAGS" with " -fPIC"
            Substituting "CXXFLAGS" with ""
            Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
            Substituting "CXXCPP" with "g++ -E"
            Substituting "CXXCPPFLAGS" with ""
            Substituting "FC" with "gfortran"
            Substituting "FFLAGS" with " -fPIC"
            Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
            Substituting "LDFLAGS" with ""
            Substituting "LIBS" with "-ldl "
            Substituting "SHARED_LIBRARY_FLAG" with "-shared"
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/home/tisaac/Projects/petsc/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/home/tisaac/Projects/petsc/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
            Defined make rule "shared_arch" with dependencies "shared_linux" and code []
            Defined make macro "SONAME_FUNCTION" to "$(1).so.$(2)"
            Defined make macro "SL_LINKER_FUNCTION" to "-shared -Wl,-soname,$(call SONAME_FUNCTION,$(notdir $(1)),$(2))"
            Defined make macro "BUILDSHAREDLIB" to "yes"
            Defined "HAVE_SHARED_LIBRARIES" to "1"
            Defined "USE_SHARED_LIBRARIES" to "1"
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/home/tisaac/Projects/petsc/config/PETSc/options/sharedLibraries.py:99)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:99)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
            Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/home/tisaac/Projects/petsc/config/PETSc/options/sharedLibraries.py:105)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:105)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
TEST configureIndexSize from PETSc.options.indexTypes(/home/tisaac/Projects/petsc/config/PETSc/options/indexTypes.py:31)
TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:31)
            Defined make macro "PETSC_INDEX_SIZE" to "32"
TEST configureCompilerFlags from config.compilerFlags(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilerFlags.py:72)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:72)
  Get the default compiler flags
          Trying C compiler flag -Wall
          Trying C compiler flag -Wwrite-strings
          Trying C compiler flag -Wno-strict-aliasing
          Trying C compiler flag -Wno-unknown-pragmas
          Trying C compiler flag -fvisibility=hidden
          Trying C compiler flag -g3
          Trying Cxx compiler flag -Wall
          Trying Cxx compiler flag -Wwrite-strings
          Trying Cxx compiler flag -Wno-strict-aliasing
          Trying Cxx compiler flag -Wno-unknown-pragmas
          Trying Cxx compiler flag -fvisibility=hidden
          Trying Cxx compiler flag -g
          Trying FC compiler flag -Wall
          Trying FC compiler flag -ffree-line-length-0
          Trying FC compiler flag -Wno-unused-dummy-argument
          Trying FC compiler flag -Wno-unused-variable
          Trying FC compiler flag -g
            Pushing language C
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC  -Wall   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Added C compiler flag -Wall
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC  -Wall -Wwrite-strings   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wwrite-strings
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-strict-aliasing
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-unknown-pragmas
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fvisibility=hidden
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -g3
            Popping language C
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -Wall   -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wall
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -Wall -Wwrite-strings   -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wwrite-strings
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing   -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-strict-aliasing
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-unknown-pragmas
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden   -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fvisibility=hidden
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g   -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -g
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC -Wall   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wall
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC -Wall -ffree-line-length-0   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -ffree-line-length-0
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-dummy-argument
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-variable
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -g
            Popping language FC
Executing: gcc --version
stdout:
gcc (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
getCompilerVersion: gcc gcc (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
stdout:
Options:
                           and libraries
stdout:
Options:
                           and libraries
Executing: g++ --version
stdout:
g++ (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
getCompilerVersion: g++ g++ (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
stdout:
Options:
                           and libraries
Executing: gfortran --version
stdout:
GNU Fortran (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
getCompilerVersion: gfortran GNU Fortran (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
stdout:
Options:
                           and libraries
stdout:
stdout:
stdout:
TEST configureDebugging from PETSc.options.debugging(/home/tisaac/Projects/petsc/config/PETSc/options/debugging.py:25)
TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
            Defined "USE_ERRORCHECKING" to "1"
TEST checkRestrict from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:137)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:137)
  Check for the C/CXX restrict keyword
Executing: gcc -V
            Pushing language C
                      All intermediate test results are stored in /tmp/petsc-W4It8W/config.compilers
Executing: gcc -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.compilers/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-W4It8W/config.compilers/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:18: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?x?
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:18: error: ?x? undeclared (first use in this function)
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:18: note: each undeclared identifier is reported only once for each function it appears in
Source:
int main() {
float * restrict x;;
  return 0;
stderr:
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:23: warning: unused variable ?x? [-Wunused-variable]
Source:
int main() {
float *  __restrict__ x;;
  return 0;
          compilers: Set C restrict keyword to  __restrict__
            Defined "C_RESTRICT" to " __restrict__"
            Popping language C
TEST checkCFormatting from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:321)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:321)
  Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:108)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:108)
  Check for C keyword: static inline
            Pushing language C
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
          compilers: Set C StaticInline keyword to static inline
            Popping language C
            Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:332)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:332)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.compilers/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.compilers/conftest.o -ldl
            Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:168)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:168)
  Determines the libraries needed to link with C
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.compilers/conftest  -v   -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.compilers/conftest.o -ldl
Possible ERROR while running linker:
stderr:
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.4-1ubuntu1~12.04' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.6.4 (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04)
COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-W4It8W/config.compilers/conftest' '-v' '-fPIC' '-Wall' '-Wwrite-strings' '-Wno-strict-aliasing' '-Wno-unknown-pragmas' '-fvisibility=hidden' '-g3' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2 --sysroot=/ --build-id --no-add-needed --as-needed --eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o /tmp/petsc-W4It8W/config.compilers/conftest /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. /tmp/petsc-W4It8W/config.compilers/conftest.o -ldl -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
            Popping language C
          compilers: Checking arg Using
          compilers: Unknown arg Using
          compilers: Checking arg built-in
          compilers: Unknown arg built-in
          compilers: Checking arg specs.
          compilers: Unknown arg specs.
          compilers: Checking arg COLLECT_GCC=gcc
          compilers: Unknown arg COLLECT_GCC=gcc
          compilers: Checking arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
          compilers: Unknown arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
          compilers: Checking arg Target:
          compilers: Unknown arg Target:
          compilers: Checking arg x86_64-linux-gnu
          compilers: Unknown arg x86_64-linux-gnu
          compilers: Checking arg Configured
          compilers: Unknown arg Configured
          compilers: Checking arg with:
          compilers: Unknown arg with:
          compilers: Checking arg ../src/configure
          compilers: Unknown arg ../src/configure
          compilers: Checking arg -v
          compilers: Unknown arg -v
          compilers: Checking arg --with-pkgversion=
          compilers: Unknown arg --with-pkgversion=
          compilers: Checking arg --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs
          compilers: Unknown arg --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs
          compilers: Checking arg --enable-languages=c,c++,fortran,objc,obj-c++
          compilers: Unknown arg --enable-languages=c,c++,fortran,objc,obj-c++
          compilers: Checking arg --prefix=/usr
          compilers: Unknown arg --prefix=/usr
          compilers: Checking arg --program-suffix=-4.6
          compilers: Unknown arg --program-suffix=-4.6
          compilers: Checking arg --enable-shared
          compilers: Unknown arg --enable-shared
          compilers: Checking arg --enable-linker-build-id
          compilers: Unknown arg --enable-linker-build-id
          compilers: Checking arg --with-system-zlib
          compilers: Unknown arg --with-system-zlib
          compilers: Checking arg --libexecdir=/usr/lib
          compilers: Unknown arg --libexecdir=/usr/lib
          compilers: Checking arg --without-included-gettext
          compilers: Unknown arg --without-included-gettext
          compilers: Checking arg --enable-threads=posix
          compilers: Unknown arg --enable-threads=posix
          compilers: Checking arg --with-gxx-include-dir=/usr/include/c++/4.6
          compilers: Unknown arg --with-gxx-include-dir=/usr/include/c++/4.6
          compilers: Checking arg --libdir=/usr/lib
          compilers: Unknown arg --libdir=/usr/lib
          compilers: Checking arg --enable-nls
          compilers: Unknown arg --enable-nls
          compilers: Checking arg --with-sysroot=/
          compilers: Unknown arg --with-sysroot=/
          compilers: Checking arg --enable-clocale=gnu
          compilers: Unknown arg --enable-clocale=gnu
          compilers: Checking arg --enable-libstdcxx-debug
          compilers: Unknown arg --enable-libstdcxx-debug
          compilers: Checking arg --enable-libstdcxx-time=yes
          compilers: Unknown arg --enable-libstdcxx-time=yes
          compilers: Checking arg --enable-gnu-unique-object
          compilers: Unknown arg --enable-gnu-unique-object
          compilers: Checking arg --enable-plugin
          compilers: Unknown arg --enable-plugin
          compilers: Checking arg --enable-objc-gc
          compilers: Unknown arg --enable-objc-gc
          compilers: Checking arg --disable-werror
          compilers: Unknown arg --disable-werror
          compilers: Checking arg --with-arch-32=i686
          compilers: Unknown arg --with-arch-32=i686
          compilers: Checking arg --with-tune=generic
          compilers: Unknown arg --with-tune=generic
          compilers: Checking arg --enable-checking=release
          compilers: Unknown arg --enable-checking=release
          compilers: Checking arg --build=x86_64-linux-gnu
          compilers: Unknown arg --build=x86_64-linux-gnu
          compilers: Checking arg --host=x86_64-linux-gnu
          compilers: Unknown arg --host=x86_64-linux-gnu
          compilers: Checking arg --target=x86_64-linux-gnu
          compilers: Unknown arg --target=x86_64-linux-gnu
          compilers: Checking arg Thread
          compilers: Unknown arg Thread
          compilers: Checking arg model:
          compilers: Unknown arg model:
          compilers: Checking arg posix
          compilers: Unknown arg posix
          compilers: Checking arg gcc
          compilers: Unknown arg gcc
          compilers: Checking arg version
          compilers: Unknown arg version
          compilers: Checking arg 4.6.4
          compilers: Unknown arg 4.6.4
          compilers: Checking arg (Ubuntu/Linaro
          compilers: Unknown arg (Ubuntu/Linaro
          compilers: Checking arg 4.6.4-1ubuntu1~12.04)
          compilers: Unknown arg 4.6.4-1ubuntu1~12.04)
          compilers: Checking arg COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/
          compilers: Unknown arg COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/
          compilers: Checking arg LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../:/lib/:/usr/lib/
          compilers: Unknown arg LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../:/lib/:/usr/lib/
          compilers: Checking arg COLLECT_GCC_OPTIONS=
          compilers: Unknown arg COLLECT_GCC_OPTIONS=
          compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2
          compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2
          compilers: Checking arg --sysroot=/
          compilers: Unknown arg --sysroot=/
          compilers: Checking arg --build-id
          compilers: Unknown arg --build-id
          compilers: Checking arg --no-add-needed
          compilers: Unknown arg --no-add-needed
          compilers: Checking arg --as-needed
          compilers: Unknown arg --as-needed
          compilers: Checking arg --eh-frame-hdr
          compilers: Unknown arg --eh-frame-hdr
          compilers: Checking arg -m
          compilers: Unknown arg -m
          compilers: Checking arg elf_x86_64
          compilers: Unknown arg elf_x86_64
          compilers: Checking arg --hash-style=gnu
          compilers: Unknown arg --hash-style=gnu
          compilers: Checking arg -dynamic-linker
          compilers: Unknown arg -dynamic-linker
          compilers: Checking arg /lib64/ld-linux-x86-64.so.2
          compilers: Unknown arg /lib64/ld-linux-x86-64.so.2
          compilers: Checking arg -z
          compilers: Unknown arg -z
          compilers: Checking arg relro
          compilers: Unknown arg relro
          compilers: Checking arg -o
          compilers: Unknown arg -o
          compilers: Checking arg /tmp/petsc-W4It8W/config.compilers/conftest
          compilers: Unknown arg /tmp/petsc-W4It8W/config.compilers/conftest
          compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o
          compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o
          compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o
          compilers: Checking arg -L/usr/lib/gcc/x86_64-linux-gnu/4.6
          compilers: Found library directory: -L/usr/lib/gcc/x86_64-linux-gnu/4.6
          compilers: Checking arg -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu
          compilers: Found library directory: -L/usr/lib/x86_64-linux-gnu
          compilers: Checking arg -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib
          compilers: Checking arg -L/lib/x86_64-linux-gnu
          compilers: Found library directory: -L/lib/x86_64-linux-gnu
          compilers: Checking arg -L/lib/../lib
          compilers: Checking arg -L/usr/lib/x86_64-linux-gnu
          compilers: Checking arg -L/usr/lib/../lib
          compilers: Checking arg /tmp/petsc-W4It8W/config.compilers/conftest.o
          compilers: Unknown arg /tmp/petsc-W4It8W/config.compilers/conftest.o
          compilers: Checking arg -ldl
          compilers: Found library : -ldl
          compilers: Checking arg -lgcc
          compilers: Skipping system library: -lgcc
          compilers: Checking arg -lgcc_s
          compilers: Found library : -lgcc_s
          compilers: Checking arg --no-as-needed
          compilers: Unknown arg --no-as-needed
          compilers: Checking arg -lc
          compilers: Skipping system library: -lc
          compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o
          compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
          compilers: Libraries needed to link C code with another linker: ['-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-L/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-L/lib/x86_64-linux-gnu', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-ldl', '-lgcc_s']
          compilers: Check that C libraries can be used from Fortran
                      Pushing language FC
                      Popping language FC
                      Pushing language FC
                      Popping language FC
                          Pushing language FC
                          Popping language FC
              Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
Executing: gfortran  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Successful compile:
Source:
      program main
      end
Executing: gfortran  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
Testing executable /tmp/petsc-W4It8W/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.setCompilers/conftest
              Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1377)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1377)
  Check if -MMD works for dependency generation, and add it if it does
          Trying C compiler flag -MMD -MP
            Defined make macro "C_DEPFLAGS" to "-MMD -MP"
            Pushing language C
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 -MMD -MP  /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
            Popping language C
          Trying Cxx compiler flag -MMD -MP
            Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  -fPIC -MMD -MP   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
          Trying FC compiler flag -MMD -MP
            Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g -MMD -MP  /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
            Popping language FC
TEST checkC99Flag from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1423)
TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1423)
  Check for -std=c99 or equivalent flag
          Accepted C99 compile flag: -std=c99
            Pushing language C
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
stderr:
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:11:5: error: ?for? loop initial declarations are only allowed in C99 mode
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:11:5: note: use option -std=c99 or -std=gnu99 to compile your code
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:7:11: warning: variable ?x? set but not used [-Wunused-but-set-variable]
Source:
#include <float.h>
int main() {
    float x[2],y;
    y = FLT_ROUNDS;
    // c++ comment
    int j = 2;
    for (int i=0; i<2; i++){
      x[i] = i*j*y;
  return 0;
            Rejecting compiler flag  due to nonzero status from link
PETSc Error: No output file produced
Executing: gcc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 -std=c99  /tmp/petsc-W4It8W/config.setCompilers/conftest.c
stderr:
Source:
#include <float.h>
int main() {
    float x[2],y;
    y = FLT_ROUNDS;
    // c++ comment
    int j = 2;
      x[i] = i*j*y;
  return 0;
            Popping language C
Executing: gcc -V
Executing: g++ -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  -fPIC   /tmp/petsc-W4It8W/config.compilers/conftest.cc
stderr:
/tmp/petsc-W4It8W/config.compilers/conftest.cc: In function ?int main()?:
/tmp/petsc-W4It8W/config.compilers/conftest.cc:5:18: error: expected initializer before ?x?
Source:
int main() {
  return 0;
stderr:
/tmp/petsc-W4It8W/config.compilers/conftest.cc:5:23: warning: unused variable ?x? [-Wunused-variable]
Source:
int main() {
  return 0;
          compilers: Set Cxx restrict keyword to  __restrict__
            Defined "CXX_RESTRICT" to " __restrict__"
TEST checkCxxNamespace from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:372)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:372)
  Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
  return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
  return 0;
          compilers: C++ has namespaces
            Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:345)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:345)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g    -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
  return 0;
TEST checkCxxStaticInline from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:122)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:122)
  Check for C++ keyword: static inline
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
          compilers: Set Cxx StaticInline keyword to static inline
            Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:430)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:430)
  Determines the libraries needed to link with C++
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language CXX
                  Popping language CXX
Executing: g++  -o /tmp/petsc-W4It8W/config.compilers/conftest  -v   -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  /tmp/petsc-W4It8W/config.compilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
stderr:
COLLECT_GCC=g++
Thread model: posix
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-W4It8W/config.compilers/conftest' '-v' '-Wall' '-Wwrite-strings' '-Wno-strict-aliasing' '-Wno-unknown-pragmas' '-fvisibility=hidden' '-g' '-L/usr/lib/gcc/x86_64-linux-gnu/4.6' '-L/usr/lib/x86_64-linux-gnu' '-L/lib/x86_64-linux-gnu' '-L/usr/lib/x86_64-linux-gnu' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2 --sysroot=/ --build-id --no-add-needed --as-needed --eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o /tmp/petsc-W4It8W/config.compilers/conftest /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. /tmp/petsc-W4It8W/config.compilers/conftest.o -rpath /usr/lib/gcc/x86_64-linux-gnu/4.6 -rpath /usr/lib/x86_64-linux-gnu -rpath /lib/x86_64-linux-gnu -rpath /usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
          compilers: Checking arg COLLECT_GCC=g++
          compilers: Unknown arg COLLECT_GCC=g++
          compilers: Checking arg -rpath
          compilers: Found -rpath library: /usr/lib/gcc/x86_64-linux-gnu/4.6
          compilers: Found -rpath library: /usr/lib/x86_64-linux-gnu
          compilers: Found -rpath library: /lib/x86_64-linux-gnu
          compilers: Already in rpathflags, skipping:-rpath
          compilers: Found library: -ldl
          Library already in C list so skipping in C++
          compilers: Found library: -lgcc_s
          compilers: Checking arg -lstdc++
          compilers: Found library: -lstdc++
          compilers: Checking arg -lm
          compilers: Libraries needed to link Cxx code with another linker: ['-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-L/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-L/lib/x86_64-linux-gnu', '-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-lstdc++']
          compilers: Check that Cxx libraries can be used from C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                          Pushing language C
                          Popping language C
              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lstdc++ -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lstdc++ -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
              Popping language C
          compilers: Check that Cxx libraries can be used from Fortran
                      Pushing language FC
                      Popping language FC
                      Pushing language FC
                      Popping language FC
                          Pushing language FC
                          Popping language FC
              Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
Executing: gfortran  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lstdc++ -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Successful compile:
Source:
      program main
      end
Executing: gfortran  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lstdc++ -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
      program main
      end
              Popping language FC
TEST checkCxx11 from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:387)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:387)
  Determine the option needed to support the C++11 dialect
    We auto-detect C++11 if the compiler supports it without options,
    otherwise we require with-cxx-dialect=C++11 to try adding flags to
    support it.
Executing: g++ -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g    -fPIC   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
stderr:
In file included from /usr/include/c++/4.6/random:35:0,
                 from /tmp/petsc-W4It8W/config.setCompilers/conftest.cc:4:
/usr/include/c++/4.6/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the upcoming ISO C++ standard, C++0x. This support is currently experimental, and must be enabled with the -std=c++0x or -std=gnu++0x compiler options.
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:5:11: warning: identifier ?constexpr? will become a keyword in C++0x [-Wc++0x-compat]
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:5:32: error: ?constexpr? does not name a type
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:5:32: note: C++0x ?constexpr? only available with -std=c++0x or -std=gnu++0x
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc: In function ?int main()?:
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:10:11: error: ?random_device? is not a member of ?std?
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:10:30: error: expected ?;? before ?rd?
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:11:11: error: ?mt19937? is not a member of ?std?
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:11:24: error: expected ?;? before ?mt?
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:12:11: error: ?normal_distribution? is not a member of ?std?
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:12:36: error: expected primary-expression before ?double?
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:12:36: error: expected ?;? before ?double?
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:13:33: error: ?mt? was not declared in this scope
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:13:35: error: ?dist? was not declared in this scope
/tmp/petsc-W4It8W/config.setCompilers/conftest.cc:13:24: warning: unused variable ?x? [-Wunused-variable]
Source:
          #include <random>
          template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
          std::random_device rd;
          std::mt19937 mt(rd());
          std::normal_distribution<double> dist(0,1);
          const double x = dist(mt);
  return 0;
TEST checkFortranTypeSizes from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:593)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:593)
  Check whether real*8 is supported and suggest flags which will allow support
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  /tmp/petsc-W4It8W/config.compilers/conftest.F90
Successful compile:
Source:
      program main
      real*8 variable
      end
            Popping language FC
TEST checkFortranNameMangling from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:652)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:652)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
              Pushing language C
Successful compile:
Source:
              Popping language C
              Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                      Pushing language FC
                      Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.compilers/conftest.o /tmp/petsc-W4It8W/config.compilers/confc.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
              Popping language FC
          compilers: Fortran name mangling is underscore
            Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
TEST checkFortranNameManglingDouble from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:689)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:689)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
              Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
              Popping language C
              Pushing language FC
Successful compile:
Source:
      program main
       call d1_chk()
      end
                      Pushing language FC
                      Popping language FC
stderr:
/tmp/petsc-W4It8W/config.compilers/conftest.o: In function `MAIN__':
/tmp/petsc-W4It8W/config.compilers/conftest.F90:2: undefined reference to `d1_chk_'
              Popping language FC
TEST checkFortranPreprocessor from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:699)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:699)
  Determine if Fortran handles preprocessing properly
          compilers: Fortran uses CPP preprocessor
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g    /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
            Popping language FC
TEST checkFortranDefineCompilerOption from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:723)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:723)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
            Defined make macro "FC_DEFINE_FLAG" to "-D"
          compilers: Fortran uses -D for defining macro
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  -DTesting  /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
            Popping language FC
TEST checkFortranLibraries from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:743)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:743)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
            Pushing language FC
Executing: gfortran -V
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.compilers/conftest  -v   -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  /tmp/petsc-W4It8W/config.compilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
stderr:
Driving: gfortran -o /tmp/petsc-W4It8W/config.compilers/conftest -v -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.compilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl -l gfortran -l m -shared-libgcc -specs=/usr/lib/gcc/x86_64-linux-gnu/4.6/libgfortran.spec
Reading specs from /usr/lib/gcc/x86_64-linux-gnu/4.6/libgfortran.spec
rename spec lib to liborig
COLLECT_GCC=gfortran
Thread model: posix
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-W4It8W/config.compilers/conftest' '-v' '-fPIC' '-Wall' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-Wno-unused-variable' '-g' '-L/usr/lib/gcc/x86_64-linux-gnu/4.6' '-L/usr/lib/x86_64-linux-gnu' '-L/lib/x86_64-linux-gnu' '-L/usr/lib/x86_64-linux-gnu' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2 --sysroot=/ --build-id --no-add-needed --as-needed --eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o /tmp/petsc-W4It8W/config.compilers/conftest /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. /tmp/petsc-W4It8W/config.compilers/conftest.o -rpath /usr/lib/gcc/x86_64-linux-gnu/4.6 -rpath /usr/lib/x86_64-linux-gnu -rpath /lib/x86_64-linux-gnu -rpath /usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
            Popping language FC
          compilers: Checking arg Driving:
          compilers: Unknown arg Driving:
          compilers: Checking arg gfortran
          compilers: Unknown arg gfortran
          compilers: Checking arg -fPIC
          compilers: Unknown arg -fPIC
          compilers: Checking arg -Wall
          compilers: Unknown arg -Wall
          compilers: Checking arg -ffree-line-length-0
          compilers: Unknown arg -ffree-line-length-0
          compilers: Checking arg -Wno-unused-dummy-argument
          compilers: Unknown arg -Wno-unused-dummy-argument
          compilers: Checking arg -Wno-unused-variable
          compilers: Unknown arg -Wno-unused-variable
          compilers: Checking arg -g
          compilers: Unknown arg -g
          compilers: Checking arg -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6
          compilers: Unknown arg -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6
          compilers: Checking arg -Wl,-rpath,/usr/lib/x86_64-linux-gnu
          compilers: Unknown arg -Wl,-rpath,/usr/lib/x86_64-linux-gnu
          compilers: Checking arg -Wl,-rpath,/lib/x86_64-linux-gnu
          compilers: Unknown arg -Wl,-rpath,/lib/x86_64-linux-gnu
          compilers: Already in lflags so skipping: -L/usr/lib/x86_64-linux-gnu
          Library already in C list so skipping in Fortran
          compilers: Already in lflags: -ldl
          compilers: Found canonical library: -lgfortran
          compilers: Found canonical library: -lm
          compilers: Checking arg -shared-libgcc
          compilers: Unknown arg -shared-libgcc
          compilers: Checking arg -specs=/usr/lib/gcc/x86_64-linux-gnu/4.6/libgfortran.spec
          compilers: Unknown arg -specs=/usr/lib/gcc/x86_64-linux-gnu/4.6/libgfortran.spec
          compilers: Checking arg Reading
          compilers: Unknown arg Reading
          compilers: Checking arg from
          compilers: Unknown arg from
          compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/libgfortran.spec
          compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/libgfortran.spec
          compilers: Checking arg rename
          compilers: Unknown arg rename
          compilers: Checking arg lib
          compilers: Unknown arg lib
          compilers: Checking arg to
          compilers: Unknown arg to
          compilers: Checking arg liborig
          compilers: Unknown arg liborig
          compilers: Checking arg COLLECT_GCC=gfortran
          compilers: Unknown arg COLLECT_GCC=gfortran
          compilers: Skipping arg COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/
          compilers: Skipping arg LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../:/lib/:/usr/lib/
          compilers: Already in lflags so skipping: -L/usr/lib/gcc/x86_64-linux-gnu/4.6
          compilers: Already in lflags so skipping: -L/lib/x86_64-linux-gnu
          compilers: Already in rpathflags so skipping: -rpath
          compilers: Already in lflags: -lgcc_s
          compilers: Checking arg -lgfortran
          compilers: Found library: -lgfortran
          compilers: Found library: -lm
          compilers: Found system library therefor skipping: -lgcc
          compilers: Checking arg -lquadmath
          compilers: Found library: -lquadmath
          compilers: Found system library therefor skipping: -lc
          compilers: Libraries needed to link Fortran code with the C linker: ['-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-L/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-L/lib/x86_64-linux-gnu', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-lgfortran', '-lm', '-lquadmath', '-lm']
          compilers: Libraries needed to link Fortran main with the C linker: []
          compilers: Check that Fortran libraries can be used from C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                          Pushing language C
                          Popping language C
              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lgfortran -lm -lquadmath -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: gcc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lgfortran -lm -lquadmath -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
              Popping language C
          compilers: Check that Fortran libraries can be used from C++
          compilers: Fortran libraries can be used from C++
              Pushing language Cxx
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: g++  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lgfortran -lm -lquadmath -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: g++  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lgfortran -lm -lquadmath -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
              Popping language Cxx
TEST checkFortranLinkingCxx from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1097)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1097)
  Check that Fortran can be linked against C++
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
              Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                      Pushing language FC
                      Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  /tmp/petsc-W4It8W/config.compilers/conftest.o /tmp/petsc-W4It8W/config.compilers/cxxobj.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s /tmp/petsc-W4It8W/config.compilers/confc.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
              Popping language FC
          compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1132)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1132)
  Determine whether the Fortran compiler handles F90
            Pushing language FC
Successful compile:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  /tmp/petsc-W4It8W/config.compilers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
            Defined "USING_F90" to "1"
          Fortran compiler supports F90
            Popping language FC
TEST checkFortran90FreeForm from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1145)
TESTING: checkFortran90FreeForm from config.compilers(config/BuildSystem/config/compilers.py:1145)
  Determine whether the Fortran compiler handles F90FreeForm
       We also require that the compiler handles lines longer than 132 characters
            Pushing language FC
Successful compile:
Source:
      program main
      INTEGER, PARAMETER ::        int = SELECTED_INT_KIND(8);              INTEGER (KIND=int) :: ierr;       ierr                            = 1
      end
                    Pushing language FC
                    Popping language FC
            Defined "USING_F90FREEFORM" to "1"
          Fortran compiler supports F90FreeForm
            Popping language FC
TEST checkFortran2003 from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1159)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1159)
  Determine whether the Fortran compiler handles F2003
            Pushing language FC
Successful compile:
Source:
      program main
      use,intrinsic :: iso_c_binding
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
                    Pushing language FC
                    Popping language FC
            Defined "USING_F2003" to "1"
          Fortran compiler supports F2003
            Popping language FC
TEST checkFortran90Array from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1179)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1179)
  Check for F90 array interfaces
Executing: uname -s
stdout: Linux
            Pushing language C
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
  printf("arrays [%p %p %p]\n",a1,a2,a3);
  fflush(stdout);
  return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
  if ((p1 == p3) && (p1 != p2)) {
    printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
  } else {
    printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
    exit(111);
  return;
            Popping language C
            Pushing language FC
Successful compile:
Source:
      program main
      Interface
         Subroutine f90ptrtest(p1,p2,p3,i)
         integer, pointer :: p1(:,:)
         integer, pointer :: p2(:,:)
         integer, pointer :: p3(:,:)
         integer i
         End Subroutine
      End Interface
      integer, pointer :: ptr1(:,:),ptr2(:,:)
      integer, target  :: array(6:8,9:21)
      integer  in
      in   = 25
      ptr1 => array
      ptr2 => array
      call f90arraytest(ptr1,ptr2,ptr1,in)
      call f90ptrtest(ptr1,ptr2,ptr1,in)
      end
                        Pushing language FC
                        Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  /tmp/petsc-W4It8W/config.compilers/conftest.o /tmp/petsc-W4It8W/config.compilers/fooobj.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Testing executable /tmp/petsc-W4It8W/config.compilers/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.compilers/conftest
stdout:
arrays [0x7ffe59f155b0 0x7ffe59f155b0 0x7ffe59f155b0]
arrays [0x7ffe59f15560 0x7ffe59f15510 0x7ffe59f15560]
pointers do not match! [0xffffffff 0x7ffe59f155b0] [0x2]
ERROR while running executable: Could not execute "/tmp/petsc-W4It8W/config.compilers/conftest":
            Popping language FC
          compilers: F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1266)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1266)
  Figures out what flag is used to specify the include path for Fortran modules
            Pushing language FC
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.compilers/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.compilers/conftest.F90
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.compilers/conftest   -I/tmp/petsc-W4It8W/config.compilers/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  /tmp/petsc-W4It8W/config.compilers/conftest.o /tmp/petsc-W4It8W/config.compilers/configtest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
          compilers: Fortran module include flag -I found
            Popping language FC
TEST checkFortranModuleOutput from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1332)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1332)
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -module /tmp/petsc-W4It8W/config.compilers/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.compilers/conftest.F90
stderr:
f951: error: unrecognized command line option ?-module?
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module  compile failed
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -module:/tmp/petsc-W4It8W/config.compilers/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.compilers/conftest.F90
stderr:
f951: error: unrecognized command line option ?-module:/tmp/petsc-W4It8W/config.compilers/confdir?
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module: compile failed
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -fmod=/tmp/petsc-W4It8W/config.compilers/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.compilers/conftest.F90
stderr:
f951: error: unrecognized command line option ?-fmod=/tmp/petsc-W4It8W/config.compilers/confdir?
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -fmod= compile failed
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -J/tmp/petsc-W4It8W/config.compilers/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.compilers/conftest.F90
Successful compile:
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -J found
            Popping language FC
TEST setupFrameworkCompilers from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1491)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1491)
TEST configureClosure from config.utilities.closure(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/closure.py:18)
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
  Determine if Apple ^close syntax is supported in C
            Pushing language C
                        All intermediate test results are stored in /tmp/petsc-W4It8W/config.utilities.closure
Executing: gcc -c -o /tmp/petsc-W4It8W/config.utilities.closure/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.compilers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.utilities.closure/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-W4It8W/config.utilities.closure/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.utilities.closure/conftest.c:6:6: error: expected identifier or ?(? before ?^? token
Source:
#include <stdio.h>
int main() {
int (^closure)(int);;
  return 0;
              Compile failed inside link
TEST configureFortranCPP from PETSc.options.fortranCPP(/home/tisaac/Projects/petsc/config/PETSc/options/fortranCPP.py:27)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:27)
  Handle case where Fortran cannot preprocess properly
            Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<']
            Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
            Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<']
            Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
            Defined "USE_FORTRAN_INTERFACES" to "1"
TEST checkStdC from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: gcc -c -o /tmp/petsc-W4It8W/config.headers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.headers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Source:
#include <string.h>
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.headers/conffix.h" 1
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/usr/include/string.h" 1 3 4
# 27 "/usr/include/string.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 324 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 325 "/usr/include/features.h" 2 3 4
# 357 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 28 "/usr/include/string.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 35 "/usr/include/string.h" 2 3 4
extern void *memcpy (void *__restrict __dest,
       __const void *__restrict __src, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, __const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, __const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (__const void *__s1, __const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 95 "/usr/include/string.h" 3 4
extern void *memchr (__const void *__s, int __c, size_t __n)
      __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 126 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, __const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        __const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, __const char *__restrict __src)
extern char *strncat (char *__restrict __dest, __const char *__restrict __src,
        size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int strcmp (__const char *__s1, __const char *__s2)
extern int strncmp (__const char *__s1, __const char *__s2, size_t __n)
extern int strcoll (__const char *__s1, __const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 1 "/usr/include/xlocale.h" 1 3 4
# 28 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 163 "/usr/include/string.h" 2 3 4
extern int strcoll_l (__const char *__s1, __const char *__s2, __locale_t __l)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, __const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (__const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (__const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (__const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (__const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (__const char *__s, __const char *__reject)
extern size_t strspn (__const char *__s, __const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (__const char *__s, __const char *__accept)
# 342 "/usr/include/string.h" 3 4
extern char *strstr (__const char *__haystack, __const char *__needle)
extern char *strtok (char *__restrict __s, __const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    __const char *__restrict __delim,
    char **__restrict __save_ptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern char *strtok_r (char *__restrict __s, __const char *__restrict __delim,
# 397 "/usr/include/string.h" 3 4
extern size_t strlen (__const char *__s)
extern size_t strnlen (__const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 427 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 445 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bcopy (__const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int bcmp (__const void *__s1, __const void *__s2, size_t __n)
# 489 "/usr/include/string.h" 3 4
extern char *index (__const char *__s, int __c)
# 517 "/usr/include/string.h" 3 4
extern char *rindex (__const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 536 "/usr/include/string.h" 3 4
extern int strcasecmp (__const char *__s1, __const char *__s2)
extern int strncasecmp (__const char *__s1, __const char *__s2, size_t __n)
# 559 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, __const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, __const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 646 "/usr/include/string.h" 3 4
Source:
#include <stdlib.h>
stdout:
# 1 "<built-in>"
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
# 324 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef int wchar_t;
# 34 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/waitflags.h" 1 3 4
# 43 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 1 3 4
# 65 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/endian.h" 1 3 4
# 38 "/usr/include/endian.h" 2 3 4
# 61 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 2 3 4
# 62 "/usr/include/endian.h" 2 3 4
# 66 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 44 "/usr/include/stdlib.h" 2 3 4
# 68 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 96 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 140 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (__const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (__const char *__nptr)
extern long int atol (__const char *__nptr)
__extension__ extern long long int atoll (__const char *__nptr)
extern double strtod (__const char *__restrict __nptr,
        char **__restrict __endptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern float strtof (__const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern long double strtold (__const char *__restrict __nptr,
extern long int strtol (__const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (__const char *__restrict __nptr,
__extension__
extern long long int strtoq (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (__const char *__restrict __nptr,
__extension__
extern long long int strtoll (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (__const char *__restrict __nptr,
# 311 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (__const char *__s)
# 1 "/usr/include/x86_64-linux-gnu/sys/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 131 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/typesizes.h" 1 3 4
# 132 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 31 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 61 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 99 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 133 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 58 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 74 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 92 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 104 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 134 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 147 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 148 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 195 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 220 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/select.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/select.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/select.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/select.h" 2 3 4
# 32 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 35 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 45 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/time.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 47 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 65 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 97 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 107 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 119 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 132 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 221 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 1 3 4
# 30 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 64 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
# 224 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 271 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 2 3 4
# 50 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 76 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    int __spins;
    __pthread_list_t __list;
# 101 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 187 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 272 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 321 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 25 "/usr/include/alloca.h" 3 4
# 26 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 498 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 531 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
# 554 "/usr/include/stdlib.h" 3 4
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *__secure_getenv (__const char *__name)
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (__const char *__name, __const char *__value, int __replace)
extern int unsetenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 620 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 642 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 663 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 712 "/usr/include/stdlib.h" 3 4
extern int system (__const char *__command) ;
# 734 "/usr/include/stdlib.h" 3 4
extern char *realpath (__const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (__const void *, __const void *);
# 752 "/usr/include/stdlib.h" 3 4
extern void *bsearch (__const void *__key, __const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 771 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 808 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (__const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int mbtowc (wchar_t *__restrict __pwc,
     __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__)) ;
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
   __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern size_t wcstombs (char *__restrict __s,
   __const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (__const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 896 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *__const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 948 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 964 "/usr/include/stdlib.h" 3 4
Successful compile:
Source:
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
        int i;
        for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
        exit(0);
  return 0;
                        Pushing language C
                        Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.headers/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.headers/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Testing executable /tmp/petsc-W4It8W/config.headers/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.headers/conftest
            Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
  You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
  You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
  You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
  You lose.
# endif
#endif
stdout:
# 1 "<built-in>"
# 26 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 217 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 218 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 5 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/usr/include/x86_64-linux-gnu/sys/stat.h" 1 3 4
# 39 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
# 40 "/usr/include/x86_64-linux-gnu/sys/stat.h" 2 3 4
# 105 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/stat.h" 1 3 4
# 46 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad0;
    __dev_t st_rdev;
    __off_t st_size;
    __blksize_t st_blksize;
    __blkcnt_t st_blocks;
# 91 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
# 106 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
    long int __unused[3];
# 115 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
# 108 "/usr/include/x86_64-linux-gnu/sys/stat.h" 2 3 4
# 211 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
extern int stat (__const char *__restrict __file,
   struct stat *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fstat (int __fd, struct stat *__buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 240 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
extern int fstatat (int __fd, __const char *__restrict __file,
      struct stat *__restrict __buf, int __flag)
# 265 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
extern int lstat (__const char *__restrict __file,
# 286 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
extern int chmod (__const char *__file, __mode_t __mode)
extern int lchmod (__const char *__file, __mode_t __mode)
extern int fchmod (int __fd, __mode_t __mode) __attribute__ ((__nothrow__ , __leaf__));
extern int fchmodat (int __fd, __const char *__file, __mode_t __mode,
       int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
extern __mode_t umask (__mode_t __mask) __attribute__ ((__nothrow__ , __leaf__));
# 323 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
extern int mkdir (__const char *__path, __mode_t __mode)
extern int mkdirat (int __fd, __const char *__path, __mode_t __mode)
extern int mknod (__const char *__path, __mode_t __mode, __dev_t __dev)
extern int mknodat (int __fd, __const char *__path, __mode_t __mode,
      __dev_t __dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int mkfifo (__const char *__path, __mode_t __mode)
extern int mkfifoat (int __fd, __const char *__path, __mode_t __mode)
extern int utimensat (int __fd, __const char *__path,
        __const struct timespec __times[2],
        int __flags)
extern int futimens (int __fd, __const struct timespec __times[2]) __attribute__ ((__nothrow__ , __leaf__));
# 401 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
extern int __fxstat (int __ver, int __fildes, struct stat *__stat_buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int __xstat (int __ver, __const char *__filename,
      struct stat *__stat_buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int __lxstat (int __ver, __const char *__filename,
extern int __fxstatat (int __ver, int __fildes, __const char *__filename,
         struct stat *__stat_buf, int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4)));
# 444 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
extern int __xmknod (int __ver, __const char *__path, __mode_t __mode,
       __dev_t *__dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int __xmknodat (int __ver, int __fd, __const char *__path,
         __mode_t __mode, __dev_t *__dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 5)));
# 536 "/usr/include/x86_64-linux-gnu/sys/stat.h" 3 4
# 6 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
TEST checkSysWait from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
            Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 28 "/usr/include/time.h" 3 4
# 29 "/usr/include/time.h" 2 3 4
# 39 "/usr/include/time.h" 2 3 4
# 43 "/usr/include/time.h" 2 3 4
# 56 "/usr/include/time.h" 3 4
# 57 "/usr/include/time.h" 2 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  __const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   __const char *__restrict __format,
   __const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 215 "/usr/include/time.h" 3 4
} *__locale_t;
# 216 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     __const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 230 "/usr/include/time.h" 3 4
extern struct tm *gmtime (__const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (__const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (__const time_t *__restrict __timer,
extern struct tm *localtime_r (__const time_t *__restrict __timer,
extern char *asctime (__const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (__const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (__const struct tm *__restrict __tp,
   char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime_r (__const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (__const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 313 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 328 "/usr/include/time.h" 3 4
extern int nanosleep (__const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, __const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       __const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     __const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 417 "/usr/include/time.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/time.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
# 26 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
struct timeval
    __time_t tv_sec;
# 30 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
typedef struct
  } fd_set;
# 32 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
# 57 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 73 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (__const struct timeval *__tv,
    __const struct timezone *__tz)
extern int adjtime (__const struct timeval *__delta,
      struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
        __const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (__const char *__file, __const struct timeval __tvp[2])
extern int lutimes (__const char *__file, __const struct timeval __tvp[2])
extern int futimes (int __fd, __const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 191 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
              Defined "HAVE_SYS_TIME_H" to "1"
Successful compile:
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
  return 0;
            Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
  Checks for the math headers and defines
Checking for header: math.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/math.h" 1 3 4
# 28 "/usr/include/math.h" 3 4
# 29 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/huge_val.h" 1 3 4
# 35 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/huge_valf.h" 1 3 4
# 37 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/huge_vall.h" 1 3 4
# 38 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/inf.h" 1 3 4
# 41 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/nan.h" 1 3 4
# 44 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/mathdef.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/mathdef.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/bits/mathdef.h" 2 3 4
typedef float float_t;
typedef double double_t;
# 48 "/usr/include/math.h" 2 3 4
# 71 "/usr/include/math.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/mathcalls.h" 1 3 4
# 53 "/usr/include/x86_64-linux-gnu/bits/mathcalls.h" 3 4
extern double acos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
# 87 "/usr/include/x86_64-linux-gnu/bits/mathcalls.h" 3 4
extern double acosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double log (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log10 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log10 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern double __modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__))
# 128 "/usr/include/x86_64-linux-gnu/bits/mathcalls.h" 3 4
extern double expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log1p (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log1p (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double logb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __logb (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double significand (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __significand (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double nan (__const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nan (__const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double j0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double j1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double jn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __jn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double y0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double y1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double yn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __yn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double erf (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erf (double) __attribute__ ((__nothrow__ , __leaf__));
extern double erfc (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erfc (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double tgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __tgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double gamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __gamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern double rint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __rint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern double nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern double __remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long long int llrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lround (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long long int llround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llround (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __fpclassify (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbit (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern double fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__)); extern double __fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__));
extern double scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__));
# 72 "/usr/include/math.h" 2 3 4
# 94 "/usr/include/math.h" 3 4
extern float acosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float cosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float coshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __coshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float expf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float logf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log10f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log10f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern float __modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__))
extern float expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float logbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float significandf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __significandf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float nanf (__const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nanf (__const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float j0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float j1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float jnf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __jnf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float y0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float y1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float ynf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __ynf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float erff (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erff (float) __attribute__ ((__nothrow__ , __leaf__));
extern float erfcf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erfcf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float tgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __tgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float gammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __gammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern float rintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __rintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern float nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern float __remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern long long int llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern long long int llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __fpclassifyf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern float fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__));
# 95 "/usr/include/math.h" 2 3 4
# 146 "/usr/include/math.h" 3 4
extern long double acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double expl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double logl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern long double __modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__))
extern long double expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double nanl (__const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nanl (__const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double j0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double j1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfcl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfcl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double tgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double gammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __gammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern long double rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern long double nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long long int llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long long int llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __fpclassifyl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern long double fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__));
# 147 "/usr/include/math.h" 2 3 4
# 162 "/usr/include/math.h" 3 4
extern int signgam;
# 203 "/usr/include/math.h" 3 4
enum
    FP_NAN,
    FP_INFINITE,
    FP_ZERO,
    FP_SUBNORMAL,
    FP_NORMAL
# 296 "/usr/include/math.h" 3 4
typedef enum
  _IEEE_ = -1,
  _SVID_,
  _XOPEN_,
  _POSIX_,
  _ISOC_
} _LIB_VERSION_TYPE;
extern _LIB_VERSION_TYPE _LIB_VERSION;
# 321 "/usr/include/math.h" 3 4
struct exception
    int type;
    char *name;
    double arg1;
    double arg2;
    double retval;
extern int matherr (struct exception *__exc);
# 483 "/usr/include/math.h" 3 4
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
              Defined "HAVE_MATH_H" to "1"
Executing: gcc -c -o /tmp/petsc-W4It8W/config.headers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.headers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
          Found math #defines, like M_PI
TEST check from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.headers/conffix.h" 1
# 1 "/usr/include/x86_64-linux-gnu/sys/socket.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 324 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 325 "/usr/include/features.h" 2 3 4
# 357 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 25 "/usr/include/x86_64-linux-gnu/sys/socket.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/uio.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 131 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/typesizes.h" 1 3 4
# 132 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 31 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 61 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 99 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 133 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 58 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 74 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 92 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 104 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 134 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 147 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 148 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 195 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 1 "/usr/include/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/endian.h" 1 3 4
# 38 "/usr/include/endian.h" 2 3 4
# 61 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 2 3 4
# 62 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/select.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/select.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/select.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/select.h" 2 3 4
# 32 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 35 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 45 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/time.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 47 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 65 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 97 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 107 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 119 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 132 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 221 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 1 3 4
# 30 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 64 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
# 224 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 271 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 2 3 4
# 50 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 76 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    int __spins;
    __pthread_list_t __list;
# 101 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 187 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 272 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 25 "/usr/include/x86_64-linux-gnu/sys/uio.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/uio.h" 1 3 4
# 44 "/usr/include/x86_64-linux-gnu/bits/uio.h" 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
extern ssize_t process_vm_readv (pid_t __pid, __const struct iovec *__lvec,
     unsigned long int __liovcnt,
     __const struct iovec *__rvec,
     unsigned long int __riovcnt,
     unsigned long int __flags)
extern ssize_t process_vm_writev (pid_t __pid, __const struct iovec *__lvec,
# 30 "/usr/include/x86_64-linux-gnu/sys/uio.h" 2 3 4
# 40 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t readv (int __fd, __const struct iovec *__iovec, int __count)
# 51 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t writev (int __fd, __const struct iovec *__iovec, int __count)
# 66 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t preadv (int __fd, __const struct iovec *__iovec, int __count,
         __off_t __offset) ;
# 78 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t pwritev (int __fd, __const struct iovec *__iovec, int __count,
   __off_t __offset) ;
# 121 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/sys/socket.h" 2 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/socket.h" 2 3 4
# 40 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/socket.h" 1 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
# 30 "/usr/include/x86_64-linux-gnu/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
  SOCK_CLOEXEC = 02000000,
  SOCK_NONBLOCK = 04000
# 177 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sockaddr.h" 1 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 178 "/usr/include/x86_64-linux-gnu/bits/socket.h" 2 3 4
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
# 193 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_DONTROUTE = 0x04,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_DONTWAIT = 0x40,
    MSG_EOR = 0x80,
    MSG_WAITALL = 0x100,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_CONFIRM = 0x800,
    MSG_RST = 0x1000,
    MSG_ERRQUEUE = 0x2000,
    MSG_NOSIGNAL = 0x4000,
    MSG_MORE = 0x8000,
    MSG_WAITFORONE = 0x10000,
    MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
    int msg_flags;
# 280 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
# 310 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
          struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 337 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
enum
    SCM_RIGHTS = 0x01
# 383 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/sockios.h" 2 3 4
# 5 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/socket.h" 2 3 4
# 384 "/usr/include/x86_64-linux-gnu/bits/socket.h" 2 3 4
# 417 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
struct linger
    int l_onoff;
    int l_linger;
extern int recvmmsg (int __fd, struct mmsghdr *__vmessages,
       unsigned int __vlen, int __flags,
       __const struct timespec *__tmo);
extern int sendmmsg (int __fd, struct mmsghdr *__vmessages,
       unsigned int __vlen, int __flags);
# 41 "/usr/include/x86_64-linux-gnu/sys/socket.h" 2 3 4
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
# 105 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
         int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, __const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
   socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 129 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int connect (int __fd, __const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, __const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, __const void *__buf, size_t __n,
         int __flags, __const struct sockaddr * __addr,
         socklen_t __addr_len);
# 166 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
    int __flags, struct sockaddr *__restrict __addr,
    socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, __const struct msghdr *__message,
   int __flags);
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
extern int getsockopt (int __fd, int __level, int __optname,
         void *__restrict __optval,
         socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
         __const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 214 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 232 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 254 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
              Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/types.h
stdout:
# 1 "<built-in>"
# 26 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 217 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 218 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/malloc.h" 1 3 4
# 24 "/usr/include/malloc.h" 3 4
# 25 "/usr/include/malloc.h" 2 3 4
# 150 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 324 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef int wchar_t;
# 26 "/usr/include/malloc.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 30 "/usr/include/stdio.h" 3 4
# 35 "/usr/include/stdio.h" 2 3 4
# 37 "/usr/include/stdio.h" 2 3 4
# 45 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 65 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 75 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 32 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 83 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 53 "/usr/include/_G_config.h" 3 4
typedef int _G_int16_t __attribute__ ((__mode__ (__HI__)));
typedef int _G_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int _G_uint16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int _G_uint32_t __attribute__ ((__mode__ (__SI__)));
# 33 "/usr/include/libio.h" 2 3 4
# 53 "/usr/include/libio.h" 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 54 "/usr/include/libio.h" 2 3 4
# 172 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 182 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 205 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 273 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 321 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 330 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
typedef struct _IO_FILE _IO_FILE;
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 366 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, __const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
# 418 "/usr/include/libio.h" 3 4
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 462 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ferror (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern void _IO_funlockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ftrylockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 492 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 76 "/usr/include/stdio.h" 2 3 4
typedef __gnuc_va_list va_list;
# 91 "/usr/include/stdio.h" 3 4
# 103 "/usr/include/stdio.h" 3 4
typedef _G_fpos_t fpos_t;
# 165 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/stdio_lim.h" 1 3 4
# 166 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (__const char *__filename) __attribute__ ((__nothrow__ , __leaf__));
extern int rename (__const char *__old, __const char *__new) __attribute__ ((__nothrow__ , __leaf__));
extern int renameat (int __oldfd, __const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 210 "/usr/include/stdio.h" 3 4
extern char *tmpnam (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
extern char *tmpnam_r (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
# 228 "/usr/include/stdio.h" 3 4
extern char *tempnam (__const char *__dir, __const char *__pfx)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 253 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 267 "/usr/include/stdio.h" 3 4
extern FILE *fopen (__const char *__restrict __filename,
      __const char *__restrict __modes) ;
extern FILE *freopen (__const char *__restrict __filename,
        __const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 296 "/usr/include/stdio.h" 3 4
# 307 "/usr/include/stdio.h" 3 4
extern FILE *fdopen (int __fd, __const char *__modes) __attribute__ ((__nothrow__ , __leaf__)) ;
# 320 "/usr/include/stdio.h" 3 4
extern FILE *fmemopen (void *__s, size_t __len, __const char *__modes)
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
         size_t __size) __attribute__ ((__nothrow__ , __leaf__));
extern void setlinebuf (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int fprintf (FILE *__restrict __stream,
      __const char *__restrict __format, ...);
extern int printf (__const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      __const char *__restrict __format, ...) __attribute__ ((__nothrow__));
extern int vfprintf (FILE *__restrict __s, __const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (__const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, __const char *__restrict __format,
       __gnuc_va_list __arg) __attribute__ ((__nothrow__));
extern int snprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 0)));
# 418 "/usr/include/stdio.h" 3 4
extern int vdprintf (int __fd, __const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, __const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     __const char *__restrict __format, ...) ;
extern int scanf (__const char *__restrict __format, ...) ;
extern int sscanf (__const char *__restrict __s,
     __const char *__restrict __format, ...) __attribute__ ((__nothrow__ , __leaf__));
# 449 "/usr/include/stdio.h" 3 4
extern int fscanf (FILE *__restrict __stream, __const char *__restrict __format, ...) __asm__ ("" "__isoc99_fscanf")
extern int scanf (__const char *__restrict __format, ...) __asm__ ("" "__isoc99_scanf")
extern int sscanf (__const char *__restrict __s, __const char *__restrict __format, ...) __asm__ ("" "__isoc99_sscanf") __attribute__ ((__nothrow__ , __leaf__))
# 469 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, __const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (__const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (__const char *__restrict __s,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__format__ (__scanf__, 2, 0)));
# 500 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, __const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vfscanf")
extern int vscanf (__const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vscanf")
extern int vsscanf (__const char *__restrict __s, __const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vsscanf") __attribute__ ((__nothrow__ , __leaf__))
# 528 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 556 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 567 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 600 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
extern char *gets (char *__s) ;
# 662 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (__const char *__restrict __s, FILE *__restrict __stream);
extern int puts (__const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (__const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 734 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (__const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 770 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 789 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, __const fpos_t *__pos);
# 812 "/usr/include/stdio.h" 3 4
# 821 "/usr/include/stdio.h" 3 4
extern void clearerr (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void clearerr_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void perror (__const char *__s);
# 1 "/usr/include/x86_64-linux-gnu/bits/sys_errlist.h" 1 3 4
# 27 "/usr/include/x86_64-linux-gnu/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern __const char *__const sys_errlist[];
# 851 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int fileno_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
# 870 "/usr/include/stdio.h" 3 4
extern FILE *popen (__const char *__command, __const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) __attribute__ ((__nothrow__ , __leaf__));
# 910 "/usr/include/stdio.h" 3 4
extern void flockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int ftrylockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void funlockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
# 940 "/usr/include/stdio.h" 3 4
# 27 "/usr/include/malloc.h" 2 3 4
# 58 "/usr/include/malloc.h" 3 4
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void *memalign (size_t __alignment, size_t __size)
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void * pvalloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *(*__morecore) (ptrdiff_t __size);
extern void *__default_morecore (ptrdiff_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__));
struct mallinfo
  int arena;
  int ordblks;
  int smblks;
  int hblks;
  int hblkhd;
  int usmblks;
  int fsmblks;
  int uordblks;
  int fordblks;
  int keepcost;
extern struct mallinfo mallinfo (void) __attribute__ ((__nothrow__ , __leaf__));
# 144 "/usr/include/malloc.h" 3 4
extern int mallopt (int __param, int __val) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_trim (size_t __pad) __attribute__ ((__nothrow__ , __leaf__));
extern size_t malloc_usable_size (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void malloc_stats (void) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_info (int __options, FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern void *malloc_get_state (void) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_set_state (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void (*__volatile __malloc_initialize_hook) (void)
     __attribute__ ((__deprecated__));
extern void (*__volatile __free_hook) (void *__ptr,
         __const void *)
extern void *(*__volatile __malloc_hook) (size_t __size,
            __const void *)
extern void *(*__volatile __realloc_hook) (void *__ptr,
             size_t __size,
             __const void *)
extern void *(*__volatile __memalign_hook) (size_t __alignment,
       size_t __size,
       __const void *)
extern void (*__volatile __after_morecore_hook) (void);
extern void __malloc_check_init (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
              Defined "HAVE_MALLOC_H" to "1"
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 28 "/usr/include/time.h" 3 4
# 29 "/usr/include/time.h" 2 3 4
# 39 "/usr/include/time.h" 2 3 4
# 43 "/usr/include/time.h" 2 3 4
# 56 "/usr/include/time.h" 3 4
# 57 "/usr/include/time.h" 2 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  __const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   __const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 215 "/usr/include/time.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 28 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 216 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     __const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 230 "/usr/include/time.h" 3 4
extern struct tm *gmtime (__const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (__const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (__const time_t *__restrict __timer,
extern struct tm *localtime_r (__const time_t *__restrict __timer,
extern char *asctime (__const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (__const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (__const struct tm *__restrict __tp,
extern char *ctime_r (__const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (__const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 313 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 328 "/usr/include/time.h" 3 4
extern int nanosleep (__const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, __const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       __const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     __const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 417 "/usr/include/time.h" 3 4
              Defined "HAVE_TIME_H" to "1"
Checking for header: Direct.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2stderr:
/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory
compilation terminated.
Source:
#include <Direct.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directorycompilation terminated.:
Checking for header: Ws2tcpip.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory
Source:
#include <Ws2tcpip.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directorycompilation terminated.:
Checking for header: endian.h
stdout:
# 1 "<built-in>"
# 22 "/usr/include/endian.h" 3 4
# 23 "/usr/include/endian.h" 2 3 4
              Defined "HAVE_ENDIAN_H" to "1"
Checking for header: ieeefp.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory
Source:
#include <ieeefp.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directorycompilation terminated.:
Checking for header: strings.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/strings.h" 1 3 4
# 28 "/usr/include/strings.h" 3 4
# 29 "/usr/include/strings.h" 2 3 4
# 31 "/usr/include/strings.h" 2 3 4
extern int bcmp (__const void *__s1, __const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__));
extern void bcopy (__const void *__src, void *__dest, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
# 74 "/usr/include/strings.h" 3 4
extern char *index (__const char *__s, int __c)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 102 "/usr/include/strings.h" 3 4
extern char *rindex (__const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((const));
extern int strcasecmp (__const char *__s1, __const char *__s2)
extern int strncasecmp (__const char *__s1, __const char *__s2, size_t __n)
} *__locale_t;
# 126 "/usr/include/strings.h" 2 3 4
extern int strcasecmp_l (__const char *__s1, __const char *__s2,
    __locale_t __loc)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int strncasecmp_l (__const char *__s1, __const char *__s2,
     size_t __n, __locale_t __loc)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
              Defined "HAVE_STRINGS_H" to "1"
Checking for header: inttypes.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/inttypes.h" 1 3 4
# 26 "/usr/include/inttypes.h" 3 4
# 27 "/usr/include/inttypes.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdint.h" 1 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 27 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wchar.h" 1 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 29 "/usr/include/stdint.h" 2 3 4
# 37 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 66 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 91 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 104 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 120 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 135 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 4 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdint.h" 2 3 4
# 29 "/usr/include/inttypes.h" 2 3 4
typedef int __gwchar_t;
# 274 "/usr/include/inttypes.h" 3 4
typedef struct
    long int quot;
    long int rem;
  } imaxdiv_t;
# 298 "/usr/include/inttypes.h" 3 4
extern intmax_t imaxabs (intmax_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern imaxdiv_t imaxdiv (intmax_t __numer, intmax_t __denom)
extern intmax_t strtoimax (__const char *__restrict __nptr,
      char **__restrict __endptr, int __base) __attribute__ ((__nothrow__ , __leaf__));
extern uintmax_t strtoumax (__const char *__restrict __nptr,
       char ** __restrict __endptr, int __base) __attribute__ ((__nothrow__ , __leaf__));
extern intmax_t wcstoimax (__const __gwchar_t *__restrict __nptr,
      __gwchar_t **__restrict __endptr, int __base)
extern uintmax_t wcstoumax (__const __gwchar_t *__restrict __nptr,
       __gwchar_t ** __restrict __endptr, int __base)
# 442 "/usr/include/inttypes.h" 3 4
              Defined "HAVE_INTTYPES_H" to "1"
Checking for header: sched.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sched.h" 1 3 4
# 24 "/usr/include/sched.h" 3 4
# 25 "/usr/include/sched.h" 2 3 4
# 28 "/usr/include/sched.h" 2 3 4
# 31 "/usr/include/sched.h" 2 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 35 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sched.h" 1 3 4
# 74 "/usr/include/x86_64-linux-gnu/bits/sched.h" 3 4
struct sched_param
    int __sched_priority;
# 97 "/usr/include/x86_64-linux-gnu/bits/sched.h" 3 4
struct __sched_param
# 120 "/usr/include/x86_64-linux-gnu/bits/sched.h" 3 4
typedef unsigned long int __cpu_mask;
typedef struct
  __cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
# 203 "/usr/include/x86_64-linux-gnu/bits/sched.h" 3 4
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void __sched_cpufree (cpu_set_t *__set) __attribute__ ((__nothrow__ , __leaf__));
# 44 "/usr/include/sched.h" 2 3 4
extern int sched_setparam (__pid_t __pid, __const struct sched_param *__param)
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_setscheduler (__pid_t __pid, int __policy,
          __const struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_getscheduler (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_yield (void) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_max (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_min (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) __attribute__ ((__nothrow__ , __leaf__));
# 126 "/usr/include/sched.h" 3 4
              Defined "HAVE_SCHED_H" to "1"
Checking for header: cxxabi.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory
Source:
#include <cxxabi.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directorycompilation terminated.:
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
Source:
#include <sys/systeminfo.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directorycompilation terminated.:
Checking for header: dos.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory
Source:
#include <dos.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directorycompilation terminated.:
Checking for header: WindowsX.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory
Source:
#include <WindowsX.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directorycompilation terminated.:
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 1 3 4
# 22 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 3 4
# 23 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 2 3 4
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 12 "/usr/include/linux/kernel.h" 3 4
struct sysinfo {
 long uptime;
 unsigned long loads[3];
 unsigned long totalram;
 unsigned long freeram;
 unsigned long sharedram;
 unsigned long bufferram;
 unsigned long totalswap;
 unsigned long freeswap;
 unsigned short procs;
 unsigned short pad;
 unsigned long totalhigh;
 unsigned long freehigh;
 unsigned int mem_unit;
 char _f[20-2*sizeof(long)-sizeof(int)];
# 26 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/wait.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/wait.h" 1 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/wait.h" 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/wait.h" 2 3 4
# 1 "/usr/include/signal.h" 1 3 4
# 31 "/usr/include/signal.h" 3 4
typedef struct
  } __sigset_t;
# 104 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
extern int __sigismember (__const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
# 34 "/usr/include/signal.h" 2 3 4
typedef __sig_atomic_t sig_atomic_t;
# 58 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/signum.h" 1 3 4
# 59 "/usr/include/signal.h" 2 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 77 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/siginfo.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/bits/siginfo.h" 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/siginfo.h" 2 3 4
typedef union sigval
    int sival_int;
    void *sival_ptr;
  } sigval_t;
# 51 "/usr/include/x86_64-linux-gnu/bits/siginfo.h" 3 4
typedef struct siginfo
    int si_signo;
    int si_errno;
    int si_code;
    union
 int _pad[((128 / sizeof (int)) - 4)];
 struct
     __pid_t si_pid;
     __uid_t si_uid;
   } _kill;
 struct
     int si_tid;
     int si_overrun;
     sigval_t si_sigval;
   } _timer;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     sigval_t si_sigval;
   } _rt;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     int si_status;
     __clock_t si_utime;
     __clock_t si_stime;
   } _sigchld;
 struct
     void *si_addr;
   } _sigfault;
 struct
     long int si_band;
     int si_fd;
   } _sigpoll;
      } _sifields;
  } siginfo_t;
# 129 "/usr/include/x86_64-linux-gnu/bits/siginfo.h" 3 4
enum
  SI_ASYNCNL = -60,
  SI_TKILL = -6,
  SI_SIGIO,
  SI_ASYNCIO,
  SI_MESGQ,
  SI_TIMER,
  SI_QUEUE,
  SI_USER,
  SI_KERNEL = 0x80
enum
  ILL_ILLOPC = 1,
  ILL_ILLOPN,
  ILL_ILLADR,
  ILL_ILLTRP,
  ILL_PRVOPC,
  ILL_PRVREG,
  ILL_COPROC,
  ILL_BADSTK
enum
  FPE_INTDIV = 1,
  FPE_INTOVF,
  FPE_FLTDIV,
  FPE_FLTOVF,
  FPE_FLTUND,
  FPE_FLTRES,
  FPE_FLTINV,
  FPE_FLTSUB
enum
  SEGV_MAPERR = 1,
  SEGV_ACCERR
enum
  BUS_ADRALN = 1,
  BUS_ADRERR,
  BUS_OBJERR
enum
  TRAP_BRKPT = 1,
  TRAP_TRACE
enum
  CLD_EXITED = 1,
  CLD_KILLED,
  CLD_DUMPED,
  CLD_TRAPPED,
  CLD_STOPPED,
  CLD_CONTINUED
enum
  POLL_IN = 1,
  POLL_OUT,
  POLL_MSG,
  POLL_ERR,
  POLL_PRI,
  POLL_HUP
# 273 "/usr/include/x86_64-linux-gnu/bits/siginfo.h" 3 4
typedef struct sigevent
    sigval_t sigev_value;
    int sigev_signo;
    int sigev_notify;
    union
 int _pad[((64 / sizeof (int)) - 4)];
 __pid_t _tid;
 struct
     void (*_function) (sigval_t);
     void *_attribute;
   } _sigev_thread;
      } _sigev_un;
  } sigevent_t;
enum
  SIGEV_SIGNAL = 0,
  SIGEV_NONE,
  SIGEV_THREAD,
  SIGEV_THREAD_ID = 4
# 80 "/usr/include/signal.h" 2 3 4
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
# 99 "/usr/include/signal.h" 3 4
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
# 113 "/usr/include/signal.h" 3 4
# 126 "/usr/include/signal.h" 3 4
extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int raise (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern void psignal (int __sig, __const char *__s);
extern void psiginfo (__const siginfo_t *__pinfo, __const char *__s);
# 168 "/usr/include/signal.h" 3 4
extern int __sigpause (int __sig_or_mask, int __is_sig);
# 196 "/usr/include/signal.h" 3 4
extern int sigblock (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int sigsetmask (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int siggetmask (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
# 216 "/usr/include/signal.h" 3 4
typedef __sighandler_t sig_t;
extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigismember (__const sigset_t *__set, int __signo)
# 252 "/usr/include/signal.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigaction.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/bits/sigaction.h" 3 4
struct sigaction
    union
 __sighandler_t sa_handler;
 void (*sa_sigaction) (int, siginfo_t *, void *);
    __sigaction_handler;
    __sigset_t sa_mask;
    int sa_flags;
    void (*sa_restorer) (void);
# 253 "/usr/include/signal.h" 2 3 4
extern int sigprocmask (int __how, __const sigset_t *__restrict __set,
   sigset_t *__restrict __oset) __attribute__ ((__nothrow__ , __leaf__));
extern int sigsuspend (__const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
extern int sigaction (int __sig, __const struct sigaction *__restrict __act,
        struct sigaction *__restrict __oact) __attribute__ ((__nothrow__ , __leaf__));
extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigwait (__const sigset_t *__restrict __set, int *__restrict __sig)
     __attribute__ ((__nonnull__ (1, 2)));
extern int sigwaitinfo (__const sigset_t *__restrict __set,
   siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
extern int sigtimedwait (__const sigset_t *__restrict __set,
    siginfo_t *__restrict __info,
    __const struct timespec *__restrict __timeout)
extern int sigqueue (__pid_t __pid, int __sig, __const union sigval __val)
# 310 "/usr/include/signal.h" 3 4
extern __const char *__const _sys_siglist[65];
extern __const char *__const sys_siglist[65];
struct sigvec
    __sighandler_t sv_handler;
    int sv_mask;
    int sv_flags;
# 334 "/usr/include/signal.h" 3 4
extern int sigvec (int __sig, __const struct sigvec *__vec,
     struct sigvec *__ovec) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/x86_64-linux-gnu/bits/sigcontext.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/sigcontext.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/bits/sigcontext.h" 2 3 4
struct _fpreg
  unsigned short significand[4];
  unsigned short exponent;
struct _fpxreg
  unsigned short padding[3];
struct _xmmreg
  __uint32_t element[4];
# 109 "/usr/include/x86_64-linux-gnu/bits/sigcontext.h" 3 4
struct _fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  __uint32_t mxcr_mask;
  struct _fpxreg _st[8];
  struct _xmmreg _xmm[16];
  __uint32_t padding[24];
struct sigcontext
  unsigned long r8;
  unsigned long r9;
  unsigned long r10;
  unsigned long r11;
  unsigned long r12;
  unsigned long r13;
  unsigned long r14;
  unsigned long r15;
  unsigned long rdi;
  unsigned long rsi;
  unsigned long rbp;
  unsigned long rbx;
  unsigned long rdx;
  unsigned long rax;
  unsigned long rcx;
  unsigned long rsp;
  unsigned long rip;
  unsigned long eflags;
  unsigned short cs;
  unsigned short gs;
  unsigned short fs;
  unsigned short __pad0;
  unsigned long err;
  unsigned long trapno;
  unsigned long oldmask;
  unsigned long cr2;
  struct _fpstate * fpstate;
  unsigned long __reserved1 [8];
# 340 "/usr/include/signal.h" 2 3 4
extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__ , __leaf__));
# 350 "/usr/include/signal.h" 2 3 4
extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/x86_64-linux-gnu/bits/sigstack.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/sigstack.h" 3 4
struct sigstack
    void *ss_sp;
    int ss_onstack;
enum
  SS_ONSTACK = 1,
  SS_DISABLE
# 50 "/usr/include/x86_64-linux-gnu/bits/sigstack.h" 3 4
typedef struct sigaltstack
    void *ss_sp;
    int ss_flags;
    size_t ss_size;
  } stack_t;
# 357 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/ucontext.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/sys/ucontext.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/sys/ucontext.h" 2 3 4
# 25 "/usr/include/x86_64-linux-gnu/sys/ucontext.h" 2 3 4
# 33 "/usr/include/x86_64-linux-gnu/sys/ucontext.h" 3 4
typedef long int greg_t;
typedef greg_t gregset_t[23];
# 94 "/usr/include/x86_64-linux-gnu/sys/ucontext.h" 3 4
struct _libc_fpxreg
  unsigned short int significand[4];
  unsigned short int exponent;
  unsigned short int padding[3];
struct _libc_xmmreg
struct _libc_fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  struct _libc_fpxreg _st[8];
  struct _libc_xmmreg _xmm[16];
typedef struct _libc_fpstate *fpregset_t;
typedef struct
    gregset_t gregs;
    fpregset_t fpregs;
} mcontext_t;
typedef struct ucontext
    unsigned long int uc_flags;
    struct ucontext *uc_link;
    stack_t uc_stack;
    mcontext_t uc_mcontext;
    __sigset_t uc_sigmask;
    struct _libc_fpstate __fpregs_mem;
  } ucontext_t;
# 360 "/usr/include/signal.h" 2 3 4
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
extern int sigaltstack (__const struct sigaltstack *__restrict __ss,
   struct sigaltstack *__restrict __oss) __attribute__ ((__nothrow__ , __leaf__));
# 394 "/usr/include/signal.h" 3 4
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 395 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigthread.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/bits/sigthread.h" 3 4
extern int pthread_sigmask (int __how,
       __const __sigset_t *__restrict __newmask,
       __sigset_t *__restrict __oldmask)__attribute__ ((__nothrow__ , __leaf__));
extern int pthread_kill (pthread_t __threadid, int __signo) __attribute__ ((__nothrow__ , __leaf__));
# 396 "/usr/include/signal.h" 2 3 4
extern int __libc_current_sigrtmin (void) __attribute__ ((__nothrow__ , __leaf__));
extern int __libc_current_sigrtmax (void) __attribute__ ((__nothrow__ , __leaf__));
# 32 "/usr/include/x86_64-linux-gnu/sys/wait.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/resource.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/resource.h" 1 3 4
# 33 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
enum __rlimit_resource
  RLIMIT_CPU = 0,
  RLIMIT_FSIZE = 1,
  RLIMIT_DATA = 2,
  RLIMIT_STACK = 3,
  RLIMIT_CORE = 4,
  __RLIMIT_RSS = 5,
  RLIMIT_NOFILE = 7,
  __RLIMIT_OFILE = RLIMIT_NOFILE,
  RLIMIT_AS = 9,
  __RLIMIT_NPROC = 6,
  __RLIMIT_MEMLOCK = 8,
  __RLIMIT_LOCKS = 10,
  __RLIMIT_SIGPENDING = 11,
  __RLIMIT_MSGQUEUE = 12,
  __RLIMIT_NICE = 13,
  __RLIMIT_RTPRIO = 14,
  __RLIMIT_RTTIME = 15,
  __RLIMIT_NLIMITS = 16,
  __RLIM_NLIMITS = __RLIMIT_NLIMITS
# 133 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
typedef __rlim_t rlim_t;
struct rlimit
    rlim_t rlim_cur;
    rlim_t rlim_max;
# 160 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
enum __rusage_who
  RUSAGE_SELF = 0,
  RUSAGE_CHILDREN = -1
# 178 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
struct timeval
    __time_t tv_sec;
# 182 "/usr/include/x86_64-linux-gnu/bits/resource.h" 2 3 4
struct rusage
    struct timeval ru_utime;
    struct timeval ru_stime;
    long int ru_maxrss;
    long int ru_ixrss;
    long int ru_idrss;
    long int ru_isrss;
    long int ru_minflt;
    long int ru_majflt;
    long int ru_nswap;
    long int ru_inblock;
    long int ru_oublock;
    long int ru_msgsnd;
    long int ru_msgrcv;
    long int ru_nsignals;
    long int ru_nvcsw;
    long int ru_nivcsw;
enum __priority_which
  PRIO_PROCESS = 0,
  PRIO_PGRP = 1,
  PRIO_USER = 2
# 268 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
# 26 "/usr/include/x86_64-linux-gnu/sys/resource.h" 2 3 4
# 43 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
extern int getrlimit (__rlimit_resource_t __resource,
        struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 70 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
extern int setrlimit (__rlimit_resource_t __resource,
        __const struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 88 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) __attribute__ ((__nothrow__ , __leaf__));
extern int getpriority (__priority_which_t __which, id_t __who) __attribute__ ((__nothrow__ , __leaf__));
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
# 33 "/usr/include/x86_64-linux-gnu/sys/wait.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/waitflags.h" 1 3 4
# 39 "/usr/include/x86_64-linux-gnu/sys/wait.h" 2 3 4
# 63 "/usr/include/x86_64-linux-gnu/sys/wait.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 80 "/usr/include/x86_64-linux-gnu/sys/wait.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 1 3 4
# 65 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
# 66 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 81 "/usr/include/x86_64-linux-gnu/sys/wait.h" 2 3 4
# 102 "/usr/include/x86_64-linux-gnu/sys/wait.h" 3 4
typedef enum
  P_ALL,
  P_PID,
  P_PGID
} idtype_t;
# 116 "/usr/include/x86_64-linux-gnu/sys/wait.h" 3 4
extern __pid_t wait (__WAIT_STATUS __stat_loc);
# 139 "/usr/include/x86_64-linux-gnu/sys/wait.h" 3 4
extern __pid_t waitpid (__pid_t __pid, int *__stat_loc, int __options);
# 144 "/usr/include/x86_64-linux-gnu/sys/wait.h" 2 3 4
# 155 "/usr/include/x86_64-linux-gnu/sys/wait.h" 3 4
extern int waitid (idtype_t __idtype, __id_t __id, siginfo_t *__infop,
     int __options);
struct rusage;
extern __pid_t wait3 (__WAIT_STATUS __stat_loc, int __options,
        struct rusage * __usage) __attribute__ ((__nothrow__));
extern __pid_t wait4 (__pid_t __pid, __WAIT_STATUS __stat_loc, int __options,
        struct rusage *__usage) __attribute__ ((__nothrow__));
              Defined "HAVE_SYS_WAIT_H" to "1"
TEST check from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: stdlib.h
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.headers/conffix.h" 1
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 324 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 325 "/usr/include/features.h" 2 3 4
# 357 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 34 "/usr/include/stdlib.h" 2 3 4
# 43 "/usr/include/stdlib.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int:16;
    struct
 unsigned int:16;
      } __wait_stopped;
# 44 "/usr/include/stdlib.h" 2 3 4
# 68 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
# 96 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 140 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (__const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (__const char *__nptr)
extern long int atol (__const char *__nptr)
__extension__ extern long long int atoll (__const char *__nptr)
extern double strtod (__const char *__restrict __nptr,
        char **__restrict __endptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern float strtof (__const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern long double strtold (__const char *__restrict __nptr,
extern long int strtol (__const char *__restrict __nptr,
extern unsigned long int strtoul (__const char *__restrict __nptr,
__extension__
extern long long int strtoq (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (__const char *__restrict __nptr,
__extension__
extern long long int strtoll (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (__const char *__restrict __nptr,
# 311 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (__const char *__s)
# 1 "/usr/include/x86_64-linux-gnu/sys/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 131 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/typesizes.h" 1 3 4
# 132 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 31 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 61 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 99 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 133 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 58 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 74 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 92 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 104 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 134 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 147 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 148 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 195 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 220 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/select.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/select.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/select.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/select.h" 2 3 4
# 32 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 35 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 45 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/time.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 47 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 65 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 97 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 107 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 119 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 132 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 221 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 1 3 4
# 30 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 64 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
# 224 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 271 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 2 3 4
# 50 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 76 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    int __spins;
    __pthread_list_t __list;
# 101 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 187 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 272 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 321 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
# 1 "/usr/include/alloca.h" 1 3 4
# 25 "/usr/include/alloca.h" 3 4
# 26 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 498 "/usr/include/stdlib.h" 2 3 4
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 531 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
# 554 "/usr/include/stdlib.h" 3 4
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *__secure_getenv (__const char *__name)
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (__const char *__name, __const char *__value, int __replace)
extern int unsetenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 620 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 642 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 663 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 712 "/usr/include/stdlib.h" 3 4
extern int system (__const char *__command) ;
# 734 "/usr/include/stdlib.h" 3 4
extern char *realpath (__const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (__const void *, __const void *);
# 752 "/usr/include/stdlib.h" 3 4
extern void *bsearch (__const void *__key, __const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 771 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 808 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (__const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int mbtowc (wchar_t *__restrict __pwc,
     __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__)) ;
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
   __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern size_t wcstombs (char *__restrict __s,
   __const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (__const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 896 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *__const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 948 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 964 "/usr/include/stdlib.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_STDLIB_H" to "1"
Checking for header: pthread.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/pthread.h" 1 3 4
# 23 "/usr/include/pthread.h" 3 4
# 24 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/endian.h" 1 3 4
# 38 "/usr/include/endian.h" 2 3 4
# 61 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 2 3 4
# 62 "/usr/include/endian.h" 2 3 4
# 25 "/usr/include/pthread.h" 2 3 4
# 27 "/usr/include/sched.h" 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct sched_param
typedef struct
} cpu_set_t;
# 26 "/usr/include/pthread.h" 2 3 4
# 30 "/usr/include/time.h" 3 4
# 131 "/usr/include/time.h" 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
struct itimerspec
struct sigevent;
# 180 "/usr/include/time.h" 3 4
} *__locale_t;
   char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
# 27 "/usr/include/pthread.h" 2 3 4
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 29 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/setjmp.h" 1 3 4
# 27 "/usr/include/x86_64-linux-gnu/bits/setjmp.h" 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/setjmp.h" 2 3 4
typedef long int __jmp_buf[8];
# 30 "/usr/include/pthread.h" 2 3 4
# 31 "/usr/include/pthread.h" 2 3 4
enum
  PTHREAD_CREATE_JOINABLE,
  PTHREAD_CREATE_DETACHED
enum
  PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_ADAPTIVE_NP
  PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
enum
  PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_ROBUST,
  PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
# 115 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_RWLOCK_PREFER_READER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
  PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
# 147 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_INHERIT_SCHED,
  PTHREAD_EXPLICIT_SCHED
enum
  PTHREAD_SCOPE_SYSTEM,
  PTHREAD_SCOPE_PROCESS
enum
  PTHREAD_PROCESS_PRIVATE,
  PTHREAD_PROCESS_SHARED
# 182 "/usr/include/pthread.h" 3 4
struct _pthread_cleanup_buffer
  void (*__routine) (void *);
  void *__arg;
  int __canceltype;
  struct _pthread_cleanup_buffer *__prev;
enum
  PTHREAD_CANCEL_ENABLE,
  PTHREAD_CANCEL_DISABLE
enum
  PTHREAD_CANCEL_DEFERRED,
  PTHREAD_CANCEL_ASYNCHRONOUS
# 220 "/usr/include/pthread.h" 3 4
extern int pthread_create (pthread_t *__restrict __newthread,
      __const pthread_attr_t *__restrict __attr,
      void *(*__start_routine) (void *),
      void *__restrict __arg) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 3)));
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
extern int pthread_join (pthread_t __th, void **__thread_return);
# 263 "/usr/include/pthread.h" 3 4
extern int pthread_detach (pthread_t __th) __attribute__ ((__nothrow__ , __leaf__));
extern pthread_t pthread_self (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2) __attribute__ ((__nothrow__ , __leaf__));
extern int pthread_attr_init (pthread_attr_t *__attr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (__const pthread_attr_t *__attr,
     int *__detachstate)
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
     int __detachstate)
extern int pthread_attr_getguardsize (__const pthread_attr_t *__attr,
          size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
          size_t __guardsize)
extern int pthread_attr_getschedparam (__const pthread_attr_t *__restrict
           __attr,
           struct sched_param *__restrict __param)
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
           __const struct sched_param *__restrict
           __param) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_attr_getschedpolicy (__const pthread_attr_t *__restrict
     __attr, int *__restrict __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (__const pthread_attr_t *__restrict
      __attr, int *__restrict __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
      int __inherit)
extern int pthread_attr_getscope (__const pthread_attr_t *__restrict __attr,
      int *__restrict __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (__const pthread_attr_t *__restrict
          __attr, void **__restrict __stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) __attribute__ ((__deprecated__));
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
          void *__stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__));
extern int pthread_attr_getstacksize (__const pthread_attr_t *__restrict
          __attr, size_t *__restrict __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
          size_t __stacksize)
extern int pthread_attr_getstack (__const pthread_attr_t *__restrict __attr,
      void **__restrict __stackaddr,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
      size_t __stacksize) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 413 "/usr/include/pthread.h" 3 4
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int pthread_getschedparam (pthread_t __target_thread,
      int *__restrict __policy,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
# 478 "/usr/include/pthread.h" 3 4
extern int pthread_once (pthread_once_t *__once_control,
    void (*__init_routine) (void)) __attribute__ ((__nonnull__ (1, 2)));
# 490 "/usr/include/pthread.h" 3 4
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
  struct
    __jmp_buf __cancel_jmp_buf;
    int __mask_was_saved;
  } __cancel_jmp_buf[1];
  void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
# 524 "/usr/include/pthread.h" 3 4
struct __pthread_cleanup_frame
  void (*__cancel_routine) (void *);
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
# 664 "/usr/include/pthread.h" 3 4
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
# 676 "/usr/include/pthread.h" 3 4
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
# 717 "/usr/include/pthread.h" 3 4
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
     __attribute__ ((__weak__))
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) __attribute__ ((__nothrow__ , __leaf__));
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
          __const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
     __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
        __abstime) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
extern int pthread_mutex_getprioceiling (__const pthread_mutex_t *
      __restrict __mutex,
      int *__restrict __prioceiling)
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
      int __prioceiling,
      int *__restrict __old_ceiling)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3)));
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
# 790 "/usr/include/pthread.h" 3 4
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (__const pthread_mutexattr_t *
      __restrict __attr,
      int *__restrict __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
      int __pshared)
extern int pthread_mutexattr_gettype (__const pthread_mutexattr_t *__restrict
          __attr, int *__restrict __kind)
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
extern int pthread_mutexattr_getprotocol (__const pthread_mutexattr_t *
       __restrict __attr,
       int *__restrict __protocol)
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
       int __protocol)
extern int pthread_mutexattr_getprioceiling (__const pthread_mutexattr_t *
          __restrict __attr,
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
          int __prioceiling)
extern int pthread_mutexattr_getrobust (__const pthread_mutexattr_t *__attr,
     int *__robustness)
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
     int __robustness)
# 872 "/usr/include/pthread.h" 3 4
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
    __const pthread_rwlockattr_t *__restrict
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (__const pthread_rwlockattr_t *
       __restrict __attr,
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
       int __pshared)
extern int pthread_rwlockattr_getkind_np (__const pthread_rwlockattr_t *
       __restrict __attr,
       int *__restrict __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
       int __pref) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
         __const pthread_condattr_t *__restrict
         __cond_attr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
         pthread_mutex_t *__restrict __mutex)
# 984 "/usr/include/pthread.h" 3 4
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
       __abstime) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (__const pthread_condattr_t *
     __restrict __attr,
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
     int __pshared) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_condattr_getclock (__const pthread_condattr_t *
          __restrict __attr,
          __clockid_t *__restrict __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
          __clockid_t __clock_id)
# 1028 "/usr/include/pthread.h" 3 4
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
     __const pthread_barrierattr_t *__restrict
     __attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (__const pthread_barrierattr_t *
        __restrict __attr,
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
        int __pshared)
# 1095 "/usr/include/pthread.h" 3 4
extern int pthread_key_create (pthread_key_t *__key,
          void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern void *pthread_getspecific (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern int pthread_setspecific (pthread_key_t __key,
    __const void *__pointer) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
      __clockid_t *__clock_id)
# 1129 "/usr/include/pthread.h" 3 4
extern int pthread_atfork (void (*__prepare) (void),
      void (*__parent) (void),
      void (*__child) (void)) __attribute__ ((__nothrow__ , __leaf__));
# 1143 "/usr/include/pthread.h" 3 4
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
              Defined "HAVE_PTHREAD_H" to "1"
Checking for header: setjmp.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/setjmp.h" 1 3 4
# 26 "/usr/include/setjmp.h" 3 4
# 27 "/usr/include/setjmp.h" 2 3 4
# 31 "/usr/include/setjmp.h" 2 3 4
typedef struct
  } __sigset_t;
# 32 "/usr/include/setjmp.h" 2 3 4
    __jmp_buf __jmpbuf;
    __sigset_t __saved_mask;
typedef struct __jmp_buf_tag jmp_buf[1];
extern int setjmp (jmp_buf __env) __attribute__ ((__nothrow__));
extern int __sigsetjmp (struct __jmp_buf_tag __env[1], int __savemask) __attribute__ ((__nothrow__));
extern int _setjmp (struct __jmp_buf_tag __env[1]) __attribute__ ((__nothrow__));
# 78 "/usr/include/setjmp.h" 3 4
extern void longjmp (struct __jmp_buf_tag __env[1], int __val)
     __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
extern void _longjmp (struct __jmp_buf_tag __env[1], int __val)
typedef struct __jmp_buf_tag sigjmp_buf[1];
# 110 "/usr/include/setjmp.h" 3 4
extern void siglongjmp (sigjmp_buf __env, int __val)
# 120 "/usr/include/setjmp.h" 3 4
              Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/utsname.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/sys/utsname.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/utsname.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/utsname.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/utsname.h" 2 3 4
# 49 "/usr/include/x86_64-linux-gnu/sys/utsname.h" 3 4
struct utsname
    char sysname[65];
    char nodename[65];
    char release[65];
    char version[65];
    char machine[65];
    char __domainname[65];
# 82 "/usr/include/x86_64-linux-gnu/sys/utsname.h" 3 4
extern int uname (struct utsname *__name) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: machine/endian.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2stderr:
/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory
Source:
#include "confdefs.h"
#include "conffix.h"
#include <machine/endian.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directorycompilation terminated.:
Checking for header: limits.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include-fixed/limits.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include-fixed/limits.h" 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include-fixed/syslimits.h" 1 3 4
# 169 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include-fixed/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 27 "/usr/include/limits.h" 3 4
# 28 "/usr/include/limits.h" 2 3 4
# 145 "/usr/include/limits.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/posix1_lim.h" 1 3 4
# 157 "/usr/include/x86_64-linux-gnu/bits/posix1_lim.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/local_lim.h" 1 3 4
# 39 "/usr/include/x86_64-linux-gnu/bits/local_lim.h" 3 4
# 1 "/usr/include/linux/limits.h" 1 3 4
# 40 "/usr/include/x86_64-linux-gnu/bits/local_lim.h" 2 3 4
# 158 "/usr/include/x86_64-linux-gnu/bits/posix1_lim.h" 2 3 4
# 146 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/posix2_lim.h" 1 3 4
# 150 "/usr/include/limits.h" 2 3 4
# 170 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include-fixed/limits.h" 2 3 4
# 8 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include-fixed/syslimits.h" 2 3 4
# 35 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include-fixed/limits.h" 2 3 4
              Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/fcntl.h" 1 3 4
# 27 "/usr/include/fcntl.h" 3 4
# 28 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/fcntl.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/bits/fcntl.h" 3 4
# 217 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 218 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 26 "/usr/include/x86_64-linux-gnu/bits/fcntl.h" 2 3 4
# 27 "/usr/include/x86_64-linux-gnu/bits/fcntl.h" 2 3 4
# 168 "/usr/include/x86_64-linux-gnu/bits/fcntl.h" 3 4
struct flock
    short int l_type;
    short int l_whence;
    __off_t l_start;
    __off_t l_len;
    __pid_t l_pid;
# 282 "/usr/include/x86_64-linux-gnu/bits/fcntl.h" 3 4
# 356 "/usr/include/x86_64-linux-gnu/bits/fcntl.h" 3 4
# 35 "/usr/include/fcntl.h" 2 3 4
# 41 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/stat.h" 1 3 4
# 46 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad0;
    __dev_t st_rdev;
    __off_t st_size;
    __blksize_t st_blksize;
    __blkcnt_t st_blocks;
# 91 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
# 106 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
    long int __unused[3];
# 115 "/usr/include/x86_64-linux-gnu/bits/stat.h" 3 4
# 42 "/usr/include/fcntl.h" 2 3 4
# 110 "/usr/include/fcntl.h" 3 4
extern int fcntl (int __fd, int __cmd, ...);
# 119 "/usr/include/fcntl.h" 3 4
extern int open (__const char *__file, int __oflag, ...) __attribute__ ((__nonnull__ (1)));
# 143 "/usr/include/fcntl.h" 3 4
extern int openat (int __fd, __const char *__file, int __oflag, ...)
# 165 "/usr/include/fcntl.h" 3 4
extern int creat (__const char *__file, __mode_t __mode) __attribute__ ((__nonnull__ (1)));
# 194 "/usr/include/fcntl.h" 3 4
extern int lockf (int __fd, int __cmd, __off_t __len);
# 211 "/usr/include/fcntl.h" 3 4
extern int posix_fadvise (int __fd, __off_t __offset, __off_t __len,
     int __advise) __attribute__ ((__nothrow__ , __leaf__));
# 233 "/usr/include/fcntl.h" 3 4
extern int posix_fallocate (int __fd, __off_t __offset, __off_t __len);
# 255 "/usr/include/fcntl.h" 3 4
              Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/string.h" 1 3 4
# 27 "/usr/include/string.h" 3 4
# 28 "/usr/include/string.h" 2 3 4
# 35 "/usr/include/string.h" 2 3 4
extern void *memcpy (void *__restrict __dest,
       __const void *__restrict __src, size_t __n)
extern void *memmove (void *__dest, __const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, __const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (__const void *__s1, __const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 95 "/usr/include/string.h" 3 4
extern void *memchr (__const void *__s, int __c, size_t __n)
      __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 126 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, __const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        __const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, __const char *__restrict __src)
extern char *strncat (char *__restrict __dest, __const char *__restrict __src,
        size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int strcmp (__const char *__s1, __const char *__s2)
extern int strncmp (__const char *__s1, __const char *__s2, size_t __n)
extern int strcoll (__const char *__s1, __const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
# 1 "/usr/include/xlocale.h" 1 3 4
# 28 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 163 "/usr/include/string.h" 2 3 4
extern int strcoll_l (__const char *__s1, __const char *__s2, __locale_t __l)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, __const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (__const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (__const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (__const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (__const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (__const char *__s, __const char *__reject)
extern size_t strspn (__const char *__s, __const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (__const char *__s, __const char *__accept)
# 342 "/usr/include/string.h" 3 4
extern char *strstr (__const char *__haystack, __const char *__needle)
extern char *strtok (char *__restrict __s, __const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    __const char *__restrict __delim,
    char **__restrict __save_ptr)
extern char *strtok_r (char *__restrict __s, __const char *__restrict __delim,
# 397 "/usr/include/string.h" 3 4
extern size_t strlen (__const char *__s)
extern size_t strnlen (__const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 427 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 445 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bcopy (__const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int bcmp (__const void *__s1, __const void *__s2, size_t __n)
# 489 "/usr/include/string.h" 3 4
extern char *index (__const char *__s, int __c)
# 517 "/usr/include/string.h" 3 4
extern char *rindex (__const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 536 "/usr/include/string.h" 3 4
extern int strcasecmp (__const char *__s1, __const char *__s2)
extern int strncasecmp (__const char *__s1, __const char *__s2, size_t __n)
# 559 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, __const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, __const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 646 "/usr/include/string.h" 3 4
              Defined "HAVE_STRING_H" to "1"
Checking for header: sys/times.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/times.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/sys/times.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/times.h" 2 3 4
# 56 "/usr/include/time.h" 3 4
# 57 "/usr/include/time.h" 2 3 4
# 30 "/usr/include/x86_64-linux-gnu/sys/times.h" 2 3 4
struct tms
    clock_t tms_utime;
    clock_t tms_stime;
    clock_t tms_cutime;
    clock_t tms_cstime;
extern clock_t times (struct tms *__buffer) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: io.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory
Source:
#include <io.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directorycompilation terminated.:
Checking for header: stdint.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdint.h" 1 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 26 "/usr/include/stdint.h" 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wchar.h" 1 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 29 "/usr/include/stdint.h" 2 3 4
# 37 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 66 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 91 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 104 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 120 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 135 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 4 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdint.h" 2 3 4
              Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/pwd.h" 1 3 4
# 26 "/usr/include/pwd.h" 3 4
# 27 "/usr/include/pwd.h" 2 3 4
# 31 "/usr/include/pwd.h" 2 3 4
# 34 "/usr/include/pwd.h" 2 3 4
struct passwd
  char *pw_name;
  char *pw_passwd;
  __uid_t pw_uid;
  __gid_t pw_gid;
  char *pw_gecos;
  char *pw_dir;
  char *pw_shell;
# 1 "/usr/include/stdio.h" 1 3 4
# 45 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 65 "/usr/include/pwd.h" 2 3 4
# 73 "/usr/include/pwd.h" 3 4
extern void setpwent (void);
extern void endpwent (void);
extern struct passwd *getpwent (void);
# 95 "/usr/include/pwd.h" 3 4
extern struct passwd *fgetpwent (FILE *__stream);
extern int putpwent (__const struct passwd *__restrict __p,
       FILE *__restrict __f);
extern struct passwd *getpwuid (__uid_t __uid);
extern struct passwd *getpwnam (__const char *__name);
# 140 "/usr/include/pwd.h" 3 4
extern int getpwent_r (struct passwd *__restrict __resultbuf,
         char *__restrict __buffer, size_t __buflen,
         struct passwd **__restrict __result);
extern int getpwuid_r (__uid_t __uid,
extern int getpwnam_r (__const char *__restrict __name,
# 164 "/usr/include/pwd.h" 3 4
extern int fgetpwent_r (FILE *__restrict __stream,
# 184 "/usr/include/pwd.h" 3 4
              Defined "HAVE_PWD_H" to "1"
Checking for header: float.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/float.h" 1 3 4
              Defined "HAVE_FLOAT_H" to "1"
Checking for header: sys/param.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/param.h" 1 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/param.h" 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/param.h" 2 3 4
# 1 "/usr/include/linux/param.h" 1 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/param.h" 1 3 4
# 1 "/usr/include/asm-generic/param.h" 1 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/param.h" 2 3 4
# 5 "/usr/include/linux/param.h" 2 3 4
# 30 "/usr/include/x86_64-linux-gnu/sys/param.h" 2 3 4
# 53 "/usr/include/x86_64-linux-gnu/sys/param.h" 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 54 "/usr/include/x86_64-linux-gnu/sys/param.h" 2 3 4
              Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: netdb.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/netdb.h" 1 3 4
# 26 "/usr/include/netdb.h" 3 4
# 27 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/netinet/in.h" 1 3 4
# 24 "/usr/include/netinet/in.h" 3 4
# 27 "/usr/include/stdint.h" 3 4
# 25 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/socket.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/uio.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
# 201 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 25 "/usr/include/x86_64-linux-gnu/sys/uio.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/uio.h" 1 3 4
# 44 "/usr/include/x86_64-linux-gnu/bits/uio.h" 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
extern ssize_t process_vm_readv (pid_t __pid, __const struct iovec *__lvec,
     unsigned long int __liovcnt,
     __const struct iovec *__rvec,
     unsigned long int __riovcnt,
     unsigned long int __flags)
extern ssize_t process_vm_writev (pid_t __pid, __const struct iovec *__lvec,
# 30 "/usr/include/x86_64-linux-gnu/sys/uio.h" 2 3 4
# 40 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t readv (int __fd, __const struct iovec *__iovec, int __count)
# 51 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t writev (int __fd, __const struct iovec *__iovec, int __count)
# 66 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t preadv (int __fd, __const struct iovec *__iovec, int __count,
         __off_t __offset) ;
# 78 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
extern ssize_t pwritev (int __fd, __const struct iovec *__iovec, int __count,
   __off_t __offset) ;
# 121 "/usr/include/x86_64-linux-gnu/sys/uio.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/sys/socket.h" 2 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/socket.h" 2 3 4
# 40 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/socket.h" 1 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
# 30 "/usr/include/x86_64-linux-gnu/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
  SOCK_CLOEXEC = 02000000,
  SOCK_NONBLOCK = 04000
# 177 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sockaddr.h" 1 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 178 "/usr/include/x86_64-linux-gnu/bits/socket.h" 2 3 4
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
# 193 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_DONTROUTE = 0x04,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_DONTWAIT = 0x40,
    MSG_EOR = 0x80,
    MSG_WAITALL = 0x100,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_CONFIRM = 0x800,
    MSG_RST = 0x1000,
    MSG_ERRQUEUE = 0x2000,
    MSG_NOSIGNAL = 0x4000,
    MSG_MORE = 0x8000,
    MSG_WAITFORONE = 0x10000,
    MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
    int msg_flags;
# 280 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
# 310 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
          struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 337 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
enum
    SCM_RIGHTS = 0x01
# 383 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/sockios.h" 2 3 4
# 5 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/asm/socket.h" 2 3 4
# 384 "/usr/include/x86_64-linux-gnu/bits/socket.h" 2 3 4
# 417 "/usr/include/x86_64-linux-gnu/bits/socket.h" 3 4
struct linger
    int l_onoff;
    int l_linger;
extern int recvmmsg (int __fd, struct mmsghdr *__vmessages,
       unsigned int __vlen, int __flags,
       __const struct timespec *__tmo);
extern int sendmmsg (int __fd, struct mmsghdr *__vmessages,
       unsigned int __vlen, int __flags);
# 41 "/usr/include/x86_64-linux-gnu/sys/socket.h" 2 3 4
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
# 105 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
         int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, __const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
   socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 129 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int connect (int __fd, __const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, __const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, __const void *__buf, size_t __n,
         int __flags, __const struct sockaddr * __addr,
         socklen_t __addr_len);
# 166 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
    int __flags, struct sockaddr *__restrict __addr,
    socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, __const struct msghdr *__message,
   int __flags);
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
extern int getsockopt (int __fd, int __level, int __optname,
         void *__restrict __optval,
         socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
         __const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 214 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 232 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 254 "/usr/include/x86_64-linux-gnu/sys/socket.h" 3 4
# 26 "/usr/include/netinet/in.h" 2 3 4
enum
    IPPROTO_IP = 0,
    IPPROTO_HOPOPTS = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_ROUTING = 43,
    IPPROTO_FRAGMENT = 44,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_ICMPV6 = 58,
    IPPROTO_NONE = 59,
    IPPROTO_DSTOPTS = 60,
    IPPROTO_MTP = 92,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_UDPLITE = 136,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
typedef uint16_t in_port_t;
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_DAYTIME = 13,
    IPPORT_NETSTAT = 15,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_TIMESERVER = 37,
    IPPORT_NAMESERVER = 42,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_TTYLINK = 87,
    IPPORT_SUPDUP = 95,
    IPPORT_EXECSERVER = 512,
    IPPORT_LOGINSERVER = 513,
    IPPORT_CMDSERVER = 514,
    IPPORT_EFSSERVER = 520,
    IPPORT_BIFFUDP = 512,
    IPPORT_WHOSERVER = 513,
    IPPORT_ROUTESERVER = 520,
    IPPORT_RESERVED = 1024,
    IPPORT_USERRESERVED = 5000
typedef uint32_t in_addr_t;
struct in_addr
    in_addr_t s_addr;
# 198 "/usr/include/netinet/in.h" 3 4
struct in6_addr
    union
 uint8_t __u6_addr8[16];
 uint16_t __u6_addr16[8];
 uint32_t __u6_addr32[4];
      } __in6_u;
extern const struct in6_addr in6addr_any;
extern const struct in6_addr in6addr_loopback;
# 225 "/usr/include/netinet/in.h" 3 4
struct sockaddr_in
    sa_family_t sin_family;
    in_port_t sin_port;
    struct in_addr sin_addr;
    unsigned char sin_zero[sizeof (struct sockaddr) -
      (sizeof (unsigned short int)) -
      sizeof (in_port_t) -
      sizeof (struct in_addr)];
struct sockaddr_in6
    sa_family_t sin6_family;
    in_port_t sin6_port;
    uint32_t sin6_flowinfo;
    struct in6_addr sin6_addr;
    uint32_t sin6_scope_id;
struct ip_mreq
    struct in_addr imr_multiaddr;
    struct in_addr imr_interface;
struct ip_mreq_source
    struct in_addr imr_sourceaddr;
struct ipv6_mreq
    struct in6_addr ipv6mr_multiaddr;
    unsigned int ipv6mr_interface;
struct group_req
    uint32_t gr_interface;
    struct sockaddr_storage gr_group;
struct group_source_req
    uint32_t gsr_interface;
    struct sockaddr_storage gsr_group;
    struct sockaddr_storage gsr_source;
struct ip_msfilter
    struct in_addr imsf_multiaddr;
    struct in_addr imsf_interface;
    uint32_t imsf_fmode;
    uint32_t imsf_numsrc;
    struct in_addr imsf_slist[1];
struct group_filter
    uint32_t gf_interface;
    struct sockaddr_storage gf_group;
    uint32_t gf_fmode;
    uint32_t gf_numsrc;
    struct sockaddr_storage gf_slist[1];
# 356 "/usr/include/netinet/in.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/in.h" 1 3 4
# 99 "/usr/include/x86_64-linux-gnu/bits/in.h" 3 4
struct ip_opts
    struct in_addr ip_dst;
    char ip_opts[40];
struct ip_mreqn
    struct in_addr imr_address;
    int imr_ifindex;
struct in_pktinfo
    int ipi_ifindex;
    struct in_addr ipi_spec_dst;
    struct in_addr ipi_addr;
# 357 "/usr/include/netinet/in.h" 2 3 4
# 365 "/usr/include/netinet/in.h" 3 4
extern uint32_t ntohl (uint32_t __netlong) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern uint16_t ntohs (uint16_t __netshort)
extern uint32_t htonl (uint32_t __hostlong)
extern uint16_t htons (uint16_t __hostshort)
# 377 "/usr/include/netinet/in.h" 2 3 4
# 492 "/usr/include/netinet/in.h" 3 4
extern int bindresvport (int __sockfd, struct sockaddr_in *__sock_in) __attribute__ ((__nothrow__ , __leaf__));
extern int bindresvport6 (int __sockfd, struct sockaddr_in6 *__sock_in)
# 617 "/usr/include/netinet/in.h" 3 4
# 29 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/rpc/netdb.h" 1 3 4
# 42 "/usr/include/rpc/netdb.h" 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
# 43 "/usr/include/rpc/netdb.h" 2 3 4
struct rpcent
  char *r_name;
  char **r_aliases;
  int r_number;
extern void setrpcent (int __stayopen) __attribute__ ((__nothrow__ , __leaf__));
extern void endrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbyname (__const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbynumber (int __number) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbyname_r (__const char *__name, struct rpcent *__result_buf,
      char *__buffer, size_t __buflen,
      struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbynumber_r (int __number, struct rpcent *__result_buf,
extern int getrpcent_r (struct rpcent *__result_buf, char *__buffer,
   size_t __buflen, struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
# 34 "/usr/include/netdb.h" 2 3 4
# 43 "/usr/include/netdb.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/netdb.h" 1 3 4
# 27 "/usr/include/x86_64-linux-gnu/bits/netdb.h" 3 4
struct netent
  char *n_name;
  char **n_aliases;
  int n_addrtype;
  uint32_t n_net;
# 44 "/usr/include/netdb.h" 2 3 4
# 54 "/usr/include/netdb.h" 3 4
extern int *__h_errno_location (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 93 "/usr/include/netdb.h" 3 4
extern void herror (__const char *__str) __attribute__ ((__nothrow__ , __leaf__));
extern __const char *hstrerror (int __err_num) __attribute__ ((__nothrow__ , __leaf__));
struct hostent
  char *h_name;
  char **h_aliases;
  int h_addrtype;
  int h_length;
  char **h_addr_list;
extern void sethostent (int __stay_open);
extern void endhostent (void);
extern struct hostent *gethostent (void);
extern struct hostent *gethostbyaddr (__const void *__addr, __socklen_t __len,
          int __type);
extern struct hostent *gethostbyname (__const char *__name);
# 156 "/usr/include/netdb.h" 3 4
extern struct hostent *gethostbyname2 (__const char *__name, int __af);
# 168 "/usr/include/netdb.h" 3 4
extern int gethostent_r (struct hostent *__restrict __result_buf,
    char *__restrict __buf, size_t __buflen,
    struct hostent **__restrict __result,
    int *__restrict __h_errnop);
extern int gethostbyaddr_r (__const void *__restrict __addr, __socklen_t __len,
       int __type,
extern int gethostbyname_r (__const char *__restrict __name,
extern int gethostbyname2_r (__const char *__restrict __name, int __af,
# 199 "/usr/include/netdb.h" 3 4
extern void setnetent (int __stay_open);
extern void endnetent (void);
extern struct netent *getnetent (void);
extern struct netent *getnetbyaddr (uint32_t __net, int __type);
extern struct netent *getnetbyname (__const char *__name);
# 238 "/usr/include/netdb.h" 3 4
extern int getnetent_r (struct netent *__restrict __result_buf,
   struct netent **__restrict __result,
extern int getnetbyaddr_r (uint32_t __net, int __type,
extern int getnetbyname_r (__const char *__restrict __name,
struct servent
  char *s_name;
  char **s_aliases;
  int s_port;
  char *s_proto;
extern void setservent (int __stay_open);
extern void endservent (void);
extern struct servent *getservent (void);
extern struct servent *getservbyname (__const char *__name,
          __const char *__proto);
extern struct servent *getservbyport (int __port, __const char *__proto);
# 310 "/usr/include/netdb.h" 3 4
extern int getservent_r (struct servent *__restrict __result_buf,
    struct servent **__restrict __result);
extern int getservbyname_r (__const char *__restrict __name,
       __const char *__restrict __proto,
extern int getservbyport_r (int __port, __const char *__restrict __proto,
struct protoent
  char *p_name;
  char **p_aliases;
  int p_proto;
extern void setprotoent (int __stay_open);
extern void endprotoent (void);
extern struct protoent *getprotoent (void);
extern struct protoent *getprotobyname (__const char *__name);
extern struct protoent *getprotobynumber (int __proto);
# 376 "/usr/include/netdb.h" 3 4
extern int getprotoent_r (struct protoent *__restrict __result_buf,
     struct protoent **__restrict __result);
extern int getprotobyname_r (__const char *__restrict __name,
extern int getprotobynumber_r (int __proto,
# 397 "/usr/include/netdb.h" 3 4
extern int setnetgrent (__const char *__netgroup);
extern void endnetgrent (void);
# 414 "/usr/include/netdb.h" 3 4
extern int getnetgrent (char **__restrict __hostp,
   char **__restrict __userp,
   char **__restrict __domainp);
# 425 "/usr/include/netdb.h" 3 4
extern int innetgr (__const char *__netgroup, __const char *__host,
      __const char *__user, __const char *__domain);
extern int getnetgrent_r (char **__restrict __hostp,
     char **__restrict __domainp,
     char *__restrict __buffer, size_t __buflen);
# 453 "/usr/include/netdb.h" 3 4
extern int rcmd (char **__restrict __ahost, unsigned short int __rport,
   __const char *__restrict __locuser,
   __const char *__restrict __remuser,
   __const char *__restrict __cmd, int *__restrict __fd2p);
# 465 "/usr/include/netdb.h" 3 4
extern int rcmd_af (char **__restrict __ahost, unsigned short int __rport,
      __const char *__restrict __cmd, int *__restrict __fd2p,
      sa_family_t __af);
# 481 "/usr/include/netdb.h" 3 4
extern int rexec (char **__restrict __ahost, int __rport,
    __const char *__restrict __pass,
# 493 "/usr/include/netdb.h" 3 4
extern int rexec_af (char **__restrict __ahost, int __rport,
       sa_family_t __af);
# 507 "/usr/include/netdb.h" 3 4
extern int ruserok (__const char *__rhost, int __suser,
      __const char *__remuser, __const char *__locuser);
# 517 "/usr/include/netdb.h" 3 4
extern int ruserok_af (__const char *__rhost, int __suser,
         __const char *__remuser, __const char *__locuser,
         sa_family_t __af);
# 530 "/usr/include/netdb.h" 3 4
extern int iruserok (uint32_t __raddr, int __suser,
# 541 "/usr/include/netdb.h" 3 4
extern int iruserok_af (__const void *__raddr, int __suser,
   sa_family_t __af);
# 553 "/usr/include/netdb.h" 3 4
extern int rresvport (int *__alport);
# 562 "/usr/include/netdb.h" 3 4
extern int rresvport_af (int *__alport, sa_family_t __af);
struct addrinfo
  int ai_flags;
  int ai_family;
  int ai_socktype;
  int ai_protocol;
  socklen_t ai_addrlen;
  struct sockaddr *ai_addr;
  char *ai_canonname;
  struct addrinfo *ai_next;
# 664 "/usr/include/netdb.h" 3 4
extern int getaddrinfo (__const char *__restrict __name,
   __const char *__restrict __service,
   __const struct addrinfo *__restrict __req,
   struct addrinfo **__restrict __pai);
extern void freeaddrinfo (struct addrinfo *__ai) __attribute__ ((__nothrow__ , __leaf__));
extern __const char *gai_strerror (int __ecode) __attribute__ ((__nothrow__ , __leaf__));
extern int getnameinfo (__const struct sockaddr *__restrict __sa,
   socklen_t __salen, char *__restrict __host,
   socklen_t __hostlen, char *__restrict __serv,
   socklen_t __servlen, int __flags);
# 715 "/usr/include/netdb.h" 3 4
              Defined "HAVE_NETDB_H" to "1"
TEST check from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: search.h
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.headers/conffix.h" 1
# 1 "/usr/include/search.h" 1 3 4
# 23 "/usr/include/search.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 324 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 325 "/usr/include/features.h" 2 3 4
# 357 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 24 "/usr/include/search.h" 2 3 4
# 212 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 27 "/usr/include/search.h" 2 3 4
# 45 "/usr/include/search.h" 3 4
extern void insque (void *__elem, void *__prev) __attribute__ ((__nothrow__ , __leaf__));
extern void remque (void *__elem) __attribute__ ((__nothrow__ , __leaf__));
typedef enum
    FIND,
    ENTER
ACTION;
typedef struct entry
    char *key;
    void *data;
ENTRY;
struct _ENTRY;
# 88 "/usr/include/search.h" 3 4
extern ENTRY *hsearch (ENTRY __item, ACTION __action) __attribute__ ((__nothrow__ , __leaf__));
extern int hcreate (size_t __nel) __attribute__ ((__nothrow__ , __leaf__));
extern void hdestroy (void) __attribute__ ((__nothrow__ , __leaf__));
# 119 "/usr/include/search.h" 3 4
typedef enum
  preorder,
  postorder,
  endorder,
  leaf
VISIT;
extern void *tsearch (__const void *__key, void **__rootp,
        __compar_fn_t __compar);
extern void *tfind (__const void *__key, void *__const *__rootp,
extern void *tdelete (__const void *__restrict __key,
        void **__restrict __rootp,
typedef void (*__action_fn_t) (__const void *__nodep, VISIT __value,
          int __level);
extern void twalk (__const void *__root, __action_fn_t __action);
# 165 "/usr/include/search.h" 3 4
extern void *lfind (__const void *__key, __const void *__base,
      size_t *__nmemb, size_t __size, __compar_fn_t __compar);
extern void *lsearch (__const void *__key, void *__base,
              Defined "HAVE_SEARCH_H" to "1"
Checking for header: mathimf.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory
Source:
#include <mathimf.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directorycompilation terminated.:
Checking for header: sys/procfs.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 3 4
# 32 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/time.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 131 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/typesizes.h" 1 3 4
# 132 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 26 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
# 1 "/usr/include/time.h" 1 3 4
# 74 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 28 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/time.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 30 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/select.h" 1 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/select.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/select.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/select.h" 2 3 4
# 32 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 35 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 45 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 47 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 65 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 97 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 107 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 119 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 132 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 32 "/usr/include/x86_64-linux-gnu/sys/time.h" 2 3 4
# 57 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 73 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (__const struct timeval *__tv,
    __const struct timezone *__tz)
extern int adjtime (__const struct timeval *__delta,
      struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
        __const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (__const char *__file, __const struct timeval __tvp[2])
extern int lutimes (__const char *__file, __const struct timeval __tvp[2])
extern int futimes (int __fd, __const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 191 "/usr/include/x86_64-linux-gnu/sys/time.h" 3 4
# 33 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/types.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 61 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 99 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 133 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 58 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 92 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 104 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 134 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 147 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 148 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 195 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 1 "/usr/include/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/endian.h" 1 3 4
# 38 "/usr/include/endian.h" 2 3 4
# 61 "/usr/include/endian.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 1 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 2 3 4
# 62 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 1 3 4
# 30 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 64 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
# 224 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 271 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 2 3 4
# 50 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 76 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    int __spins;
    __pthread_list_t __list;
# 101 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 187 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 272 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 34 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/user.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/sys/user.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/user.h" 2 3 4
# 1 "/usr/include/unistd.h" 1 3 4
# 28 "/usr/include/unistd.h" 3 4
# 203 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/posix_opt.h" 1 3 4
# 204 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/environments.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/environments.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/environments.h" 2 3 4
# 208 "/usr/include/unistd.h" 2 3 4
# 227 "/usr/include/unistd.h" 3 4
# 228 "/usr/include/unistd.h" 2 3 4
# 256 "/usr/include/unistd.h" 3 4
typedef __useconds_t useconds_t;
# 268 "/usr/include/unistd.h" 3 4
typedef __intptr_t intptr_t;
# 288 "/usr/include/unistd.h" 3 4
extern int access (__const char *__name, int __type) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 305 "/usr/include/unistd.h" 3 4
extern int faccessat (int __fd, __const char *__file, int __type, int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
# 335 "/usr/include/unistd.h" 3 4
extern __off_t lseek (int __fd, __off_t __offset, int __whence) __attribute__ ((__nothrow__ , __leaf__));
# 354 "/usr/include/unistd.h" 3 4
extern int close (int __fd);
extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
extern ssize_t write (int __fd, __const void *__buf, size_t __n) ;
# 377 "/usr/include/unistd.h" 3 4
extern ssize_t pread (int __fd, void *__buf, size_t __nbytes,
        __off_t __offset) ;
extern ssize_t pwrite (int __fd, __const void *__buf, size_t __n,
         __off_t __offset) ;
# 418 "/usr/include/unistd.h" 3 4
extern int pipe (int __pipedes[2]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 433 "/usr/include/unistd.h" 3 4
extern unsigned int alarm (unsigned int __seconds) __attribute__ ((__nothrow__ , __leaf__));
# 445 "/usr/include/unistd.h" 3 4
extern unsigned int sleep (unsigned int __seconds);
extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
extern int usleep (__useconds_t __useconds);
# 470 "/usr/include/unistd.h" 3 4
extern int pause (void);
extern int chown (__const char *__file, __uid_t __owner, __gid_t __group)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchown (int __fd, __uid_t __owner, __gid_t __group) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int lchown (__const char *__file, __uid_t __owner, __gid_t __group)
extern int fchownat (int __fd, __const char *__file, __uid_t __owner,
       __gid_t __group, int __flag)
extern int chdir (__const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchdir (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
# 512 "/usr/include/unistd.h" 3 4
extern char *getcwd (char *__buf, size_t __size) __attribute__ ((__nothrow__ , __leaf__)) ;
# 526 "/usr/include/unistd.h" 3 4
extern char *getwd (char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__)) ;
extern int dup (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int dup2 (int __fd, int __fd2) __attribute__ ((__nothrow__ , __leaf__));
# 544 "/usr/include/unistd.h" 3 4
extern char **__environ;
extern int execve (__const char *__path, char *__const __argv[],
     char *__const __envp[]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fexecve (int __fd, char *__const __argv[], char *__const __envp[])
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int execv (__const char *__path, char *__const __argv[])
extern int execle (__const char *__path, __const char *__arg, ...)
extern int execl (__const char *__path, __const char *__arg, ...)
extern int execvp (__const char *__file, char *__const __argv[])
extern int execlp (__const char *__file, __const char *__arg, ...)
# 599 "/usr/include/unistd.h" 3 4
extern int nice (int __inc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void _exit (int __status) __attribute__ ((__noreturn__));
# 1 "/usr/include/x86_64-linux-gnu/bits/confname.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/confname.h" 3 4
enum
    _PC_LINK_MAX,
    _PC_MAX_CANON,
    _PC_MAX_INPUT,
    _PC_NAME_MAX,
    _PC_PATH_MAX,
    _PC_PIPE_BUF,
    _PC_CHOWN_RESTRICTED,
    _PC_NO_TRUNC,
    _PC_VDISABLE,
    _PC_SYNC_IO,
    _PC_ASYNC_IO,
    _PC_PRIO_IO,
    _PC_SOCK_MAXBUF,
    _PC_FILESIZEBITS,
    _PC_REC_INCR_XFER_SIZE,
    _PC_REC_MAX_XFER_SIZE,
    _PC_REC_MIN_XFER_SIZE,
    _PC_REC_XFER_ALIGN,
    _PC_ALLOC_SIZE_MIN,
    _PC_SYMLINK_MAX,
    _PC_2_SYMLINKS
enum
    _SC_ARG_MAX,
    _SC_CHILD_MAX,
    _SC_CLK_TCK,
    _SC_NGROUPS_MAX,
    _SC_OPEN_MAX,
    _SC_STREAM_MAX,
    _SC_TZNAME_MAX,
    _SC_JOB_CONTROL,
    _SC_SAVED_IDS,
    _SC_REALTIME_SIGNALS,
    _SC_PRIORITY_SCHEDULING,
    _SC_TIMERS,
    _SC_ASYNCHRONOUS_IO,
    _SC_PRIORITIZED_IO,
    _SC_SYNCHRONIZED_IO,
    _SC_FSYNC,
    _SC_MAPPED_FILES,
    _SC_MEMLOCK,
    _SC_MEMLOCK_RANGE,
    _SC_MEMORY_PROTECTION,
    _SC_MESSAGE_PASSING,
    _SC_SEMAPHORES,
    _SC_SHARED_MEMORY_OBJECTS,
    _SC_AIO_LISTIO_MAX,
    _SC_AIO_MAX,
    _SC_AIO_PRIO_DELTA_MAX,
    _SC_DELAYTIMER_MAX,
    _SC_MQ_OPEN_MAX,
    _SC_MQ_PRIO_MAX,
    _SC_VERSION,
    _SC_PAGESIZE,
    _SC_RTSIG_MAX,
    _SC_SEM_NSEMS_MAX,
    _SC_SEM_VALUE_MAX,
    _SC_SIGQUEUE_MAX,
    _SC_TIMER_MAX,
    _SC_BC_BASE_MAX,
    _SC_BC_DIM_MAX,
    _SC_BC_SCALE_MAX,
    _SC_BC_STRING_MAX,
    _SC_COLL_WEIGHTS_MAX,
    _SC_EQUIV_CLASS_MAX,
    _SC_EXPR_NEST_MAX,
    _SC_LINE_MAX,
    _SC_RE_DUP_MAX,
    _SC_CHARCLASS_NAME_MAX,
    _SC_2_VERSION,
    _SC_2_C_BIND,
    _SC_2_C_DEV,
    _SC_2_FORT_DEV,
    _SC_2_FORT_RUN,
    _SC_2_SW_DEV,
    _SC_2_LOCALEDEF,
    _SC_PII,
    _SC_PII_XTI,
    _SC_PII_SOCKET,
    _SC_PII_INTERNET,
    _SC_PII_OSI,
    _SC_POLL,
    _SC_SELECT,
    _SC_UIO_MAXIOV,
    _SC_IOV_MAX = _SC_UIO_MAXIOV,
    _SC_PII_INTERNET_STREAM,
    _SC_PII_INTERNET_DGRAM,
    _SC_PII_OSI_COTS,
    _SC_PII_OSI_CLTS,
    _SC_PII_OSI_M,
    _SC_T_IOV_MAX,
    _SC_THREADS,
    _SC_THREAD_SAFE_FUNCTIONS,
    _SC_GETGR_R_SIZE_MAX,
    _SC_GETPW_R_SIZE_MAX,
    _SC_LOGIN_NAME_MAX,
    _SC_TTY_NAME_MAX,
    _SC_THREAD_DESTRUCTOR_ITERATIONS,
    _SC_THREAD_KEYS_MAX,
    _SC_THREAD_STACK_MIN,
    _SC_THREAD_THREADS_MAX,
    _SC_THREAD_ATTR_STACKADDR,
    _SC_THREAD_ATTR_STACKSIZE,
    _SC_THREAD_PRIORITY_SCHEDULING,
    _SC_THREAD_PRIO_INHERIT,
    _SC_THREAD_PRIO_PROTECT,
    _SC_THREAD_PROCESS_SHARED,
    _SC_NPROCESSORS_CONF,
    _SC_NPROCESSORS_ONLN,
    _SC_PHYS_PAGES,
    _SC_AVPHYS_PAGES,
    _SC_ATEXIT_MAX,
    _SC_PASS_MAX,
    _SC_XOPEN_VERSION,
    _SC_XOPEN_XCU_VERSION,
    _SC_XOPEN_UNIX,
    _SC_XOPEN_CRYPT,
    _SC_XOPEN_ENH_I18N,
    _SC_XOPEN_SHM,
    _SC_2_CHAR_TERM,
    _SC_2_C_VERSION,
    _SC_2_UPE,
    _SC_XOPEN_XPG2,
    _SC_XOPEN_XPG3,
    _SC_XOPEN_XPG4,
    _SC_CHAR_BIT,
    _SC_CHAR_MAX,
    _SC_CHAR_MIN,
    _SC_INT_MAX,
    _SC_INT_MIN,
    _SC_LONG_BIT,
    _SC_WORD_BIT,
    _SC_MB_LEN_MAX,
    _SC_NZERO,
    _SC_SSIZE_MAX,
    _SC_SCHAR_MAX,
    _SC_SCHAR_MIN,
    _SC_SHRT_MAX,
    _SC_SHRT_MIN,
    _SC_UCHAR_MAX,
    _SC_UINT_MAX,
    _SC_ULONG_MAX,
    _SC_USHRT_MAX,
    _SC_NL_ARGMAX,
    _SC_NL_LANGMAX,
    _SC_NL_MSGMAX,
    _SC_NL_NMAX,
    _SC_NL_SETMAX,
    _SC_NL_TEXTMAX,
    _SC_XBS5_ILP32_OFF32,
    _SC_XBS5_ILP32_OFFBIG,
    _SC_XBS5_LP64_OFF64,
    _SC_XBS5_LPBIG_OFFBIG,
    _SC_XOPEN_LEGACY,
    _SC_XOPEN_REALTIME,
    _SC_XOPEN_REALTIME_THREADS,
    _SC_ADVISORY_INFO,
    _SC_BARRIERS,
    _SC_BASE,
    _SC_C_LANG_SUPPORT,
    _SC_C_LANG_SUPPORT_R,
    _SC_CLOCK_SELECTION,
    _SC_CPUTIME,
    _SC_THREAD_CPUTIME,
    _SC_DEVICE_IO,
    _SC_DEVICE_SPECIFIC,
    _SC_DEVICE_SPECIFIC_R,
    _SC_FD_MGMT,
    _SC_FIFO,
    _SC_PIPE,
    _SC_FILE_ATTRIBUTES,
    _SC_FILE_LOCKING,
    _SC_FILE_SYSTEM,
    _SC_MONOTONIC_CLOCK,
    _SC_MULTI_PROCESS,
    _SC_SINGLE_PROCESS,
    _SC_NETWORKING,
    _SC_READER_WRITER_LOCKS,
    _SC_SPIN_LOCKS,
    _SC_REGEXP,
    _SC_REGEX_VERSION,
    _SC_SHELL,
    _SC_SIGNALS,
    _SC_SPAWN,
    _SC_SPORADIC_SERVER,
    _SC_THREAD_SPORADIC_SERVER,
    _SC_SYSTEM_DATABASE,
    _SC_SYSTEM_DATABASE_R,
    _SC_TIMEOUTS,
    _SC_TYPED_MEMORY_OBJECTS,
    _SC_USER_GROUPS,
    _SC_USER_GROUPS_R,
    _SC_2_PBS,
    _SC_2_PBS_ACCOUNTING,
    _SC_2_PBS_LOCATE,
    _SC_2_PBS_MESSAGE,
    _SC_2_PBS_TRACK,
    _SC_SYMLOOP_MAX,
    _SC_STREAMS,
    _SC_2_PBS_CHECKPOINT,
    _SC_V6_ILP32_OFF32,
    _SC_V6_ILP32_OFFBIG,
    _SC_V6_LP64_OFF64,
    _SC_V6_LPBIG_OFFBIG,
    _SC_HOST_NAME_MAX,
    _SC_TRACE,
    _SC_TRACE_EVENT_FILTER,
    _SC_TRACE_INHERIT,
    _SC_TRACE_LOG,
    _SC_LEVEL1_ICACHE_SIZE,
    _SC_LEVEL1_ICACHE_ASSOC,
    _SC_LEVEL1_ICACHE_LINESIZE,
    _SC_LEVEL1_DCACHE_SIZE,
    _SC_LEVEL1_DCACHE_ASSOC,
    _SC_LEVEL1_DCACHE_LINESIZE,
    _SC_LEVEL2_CACHE_SIZE,
    _SC_LEVEL2_CACHE_ASSOC,
    _SC_LEVEL2_CACHE_LINESIZE,
    _SC_LEVEL3_CACHE_SIZE,
    _SC_LEVEL3_CACHE_ASSOC,
    _SC_LEVEL3_CACHE_LINESIZE,
    _SC_LEVEL4_CACHE_SIZE,
    _SC_LEVEL4_CACHE_ASSOC,
    _SC_LEVEL4_CACHE_LINESIZE,
    _SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
    _SC_RAW_SOCKETS,
    _SC_V7_ILP32_OFF32,
    _SC_V7_ILP32_OFFBIG,
    _SC_V7_LP64_OFF64,
    _SC_V7_LPBIG_OFFBIG,
    _SC_SS_REPL_MAX,
    _SC_TRACE_EVENT_NAME_MAX,
    _SC_TRACE_NAME_MAX,
    _SC_TRACE_SYS_MAX,
    _SC_TRACE_USER_EVENT_MAX,
    _SC_XOPEN_STREAMS,
    _SC_THREAD_ROBUST_PRIO_INHERIT,
    _SC_THREAD_ROBUST_PRIO_PROTECT
enum
    _CS_PATH,
    _CS_V6_WIDTH_RESTRICTED_ENVS,
    _CS_GNU_LIBC_VERSION,
    _CS_GNU_LIBPTHREAD_VERSION,
    _CS_V5_WIDTH_RESTRICTED_ENVS,
    _CS_V7_WIDTH_RESTRICTED_ENVS,
    _CS_LFS_CFLAGS = 1000,
    _CS_LFS_LDFLAGS,
    _CS_LFS_LIBS,
    _CS_LFS_LINTFLAGS,
    _CS_LFS64_CFLAGS,
    _CS_LFS64_LDFLAGS,
    _CS_LFS64_LIBS,
    _CS_LFS64_LINTFLAGS,
    _CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
    _CS_XBS5_ILP32_OFF32_LDFLAGS,
    _CS_XBS5_ILP32_OFF32_LIBS,
    _CS_XBS5_ILP32_OFF32_LINTFLAGS,
    _CS_XBS5_ILP32_OFFBIG_CFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LDFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LIBS,
    _CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
    _CS_XBS5_LP64_OFF64_CFLAGS,
    _CS_XBS5_LP64_OFF64_LDFLAGS,
    _CS_XBS5_LP64_OFF64_LIBS,
    _CS_XBS5_LP64_OFF64_LINTFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_CFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LIBS,
    _CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LIBS,
    _CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_LP64_OFF64_CFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LIBS,
    _CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LIBS,
    _CS_POSIX_V7_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V7_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_LP64_OFF64_CFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LIBS,
    _CS_POSIX_V7_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LINTFLAGS,
    _CS_V6_ENV,
    _CS_V7_ENV
# 611 "/usr/include/unistd.h" 2 3 4
extern long int pathconf (__const char *__path, int __name)
extern long int fpathconf (int __fd, int __name) __attribute__ ((__nothrow__ , __leaf__));
extern long int sysconf (int __name) __attribute__ ((__nothrow__ , __leaf__));
extern size_t confstr (int __name, char *__buf, size_t __len) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getppid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
# 647 "/usr/include/unistd.h" 3 4
extern __pid_t __getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int setpgid (__pid_t __pid, __pid_t __pgid) __attribute__ ((__nothrow__ , __leaf__));
# 673 "/usr/include/unistd.h" 3 4
extern int setpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
# 690 "/usr/include/unistd.h" 3 4
extern __pid_t setsid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getsid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t getuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t geteuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getgid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getegid (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getgroups (int __size, __gid_t __list[]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 723 "/usr/include/unistd.h" 3 4
extern int setuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__));
extern int setreuid (__uid_t __ruid, __uid_t __euid) __attribute__ ((__nothrow__ , __leaf__));
extern int seteuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__));
extern int setgid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__));
extern int setregid (__gid_t __rgid, __gid_t __egid) __attribute__ ((__nothrow__ , __leaf__));
extern int setegid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__));
# 779 "/usr/include/unistd.h" 3 4
extern __pid_t fork (void) __attribute__ ((__nothrow__));
extern __pid_t vfork (void) __attribute__ ((__nothrow__ , __leaf__));
extern char *ttyname (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
extern int isatty (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyslot (void) __attribute__ ((__nothrow__ , __leaf__));
extern int link (__const char *__from, __const char *__to)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) ;
extern int linkat (int __fromfd, __const char *__from, int __tofd,
     __const char *__to, int __flags)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4))) ;
extern int symlink (__const char *__from, __const char *__to)
extern ssize_t readlink (__const char *__restrict __path,
    char *__restrict __buf, size_t __len)
extern int symlinkat (__const char *__from, int __tofd,
        __const char *__to) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3))) ;
extern ssize_t readlinkat (int __fd, __const char *__restrict __path,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3))) ;
extern int unlink (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int unlinkat (int __fd, __const char *__name, int __flag)
extern int rmdir (__const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern __pid_t tcgetpgrp (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) __attribute__ ((__nothrow__ , __leaf__));
extern char *getlogin (void);
extern int getlogin_r (char *__name, size_t __name_len) __attribute__ ((__nonnull__ (1)));
extern int setlogin (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 894 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/getopt.h" 1 3 4
# 59 "/usr/include/getopt.h" 3 4
extern char *optarg;
# 73 "/usr/include/getopt.h" 3 4
extern int optind;
extern int opterr;
extern int optopt;
# 152 "/usr/include/getopt.h" 3 4
extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
# 895 "/usr/include/unistd.h" 2 3 4
extern int gethostname (char *__name, size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sethostname (__const char *__name, size_t __len)
extern int sethostid (long int __id) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int getdomainname (char *__name, size_t __len)
extern int setdomainname (__const char *__name, size_t __len)
extern int vhangup (void) __attribute__ ((__nothrow__ , __leaf__));
extern int revoke (__const char *__file) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int profil (unsigned short int *__sample_buffer, size_t __size,
     size_t __offset, unsigned int __scale)
extern int acct (__const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern char *getusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void endusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void setusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daemon (int __nochdir, int __noclose) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int chroot (__const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *getpass (__const char *__prompt) __attribute__ ((__nonnull__ (1)));
# 980 "/usr/include/unistd.h" 3 4
extern int fsync (int __fd);
# 994 "/usr/include/unistd.h" 3 4
extern long int gethostid (void);
extern void sync (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getpagesize (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int getdtablesize (void) __attribute__ ((__nothrow__ , __leaf__));
# 1018 "/usr/include/unistd.h" 3 4
extern int truncate (__const char *__file, __off_t __length)
# 1040 "/usr/include/unistd.h" 3 4
extern int ftruncate (int __fd, __off_t __length) __attribute__ ((__nothrow__ , __leaf__)) ;
# 1061 "/usr/include/unistd.h" 3 4
extern int brk (void *__addr) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void *sbrk (intptr_t __delta) __attribute__ ((__nothrow__ , __leaf__));
# 1082 "/usr/include/unistd.h" 3 4
extern long int syscall (long int __sysno, ...) __attribute__ ((__nothrow__ , __leaf__));
# 1105 "/usr/include/unistd.h" 3 4
extern int lockf (int __fd, int __cmd, __off_t __len) ;
# 1136 "/usr/include/unistd.h" 3 4
extern int fdatasync (int __fildes);
# 1165 "/usr/include/unistd.h" 3 4
extern char *ctermid (char *__s) __attribute__ ((__nothrow__ , __leaf__));
# 1174 "/usr/include/unistd.h" 3 4
# 28 "/usr/include/x86_64-linux-gnu/sys/user.h" 2 3 4
struct user_fpregs_struct
  unsigned short int cwd;
  unsigned short int swd;
  unsigned short int ftw;
  unsigned short int fop;
  unsigned long int rip;
  unsigned long int rdp;
  unsigned int mxcsr;
  unsigned int mxcr_mask;
  unsigned int st_space[32];
  unsigned int xmm_space[64];
  unsigned int padding[24];
struct user_regs_struct
  unsigned long int r15;
  unsigned long int r14;
  unsigned long int r13;
  unsigned long int r12;
  unsigned long int rbp;
  unsigned long int rbx;
  unsigned long int r11;
  unsigned long int r10;
  unsigned long int r9;
  unsigned long int r8;
  unsigned long int rax;
  unsigned long int rcx;
  unsigned long int rdx;
  unsigned long int rsi;
  unsigned long int rdi;
  unsigned long int orig_rax;
  unsigned long int cs;
  unsigned long int eflags;
  unsigned long int rsp;
  unsigned long int ss;
  unsigned long int fs_base;
  unsigned long int gs_base;
  unsigned long int ds;
  unsigned long int es;
  unsigned long int fs;
  unsigned long int gs;
struct user
  struct user_regs_struct regs;
  int u_fpvalid;
  struct user_fpregs_struct i387;
  unsigned long int u_tsize;
  unsigned long int u_dsize;
  unsigned long int u_ssize;
  unsigned long int start_code;
  unsigned long int start_stack;
  long int signal;
  int reserved;
  struct user_regs_struct* u_ar0;
  struct user_fpregs_struct* u_fpstate;
  unsigned long int magic;
  char u_comm [32];
  unsigned long int u_debugreg [8];
# 35 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 2 3 4
typedef unsigned long elf_greg_t;
typedef elf_greg_t elf_gregset_t[(sizeof (struct user_regs_struct) / sizeof(elf_greg_t))];
# 60 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 3 4
typedef struct user_fpregs_struct elf_fpregset_t;
struct elf_siginfo
    int si_signo;
    int si_code;
    int si_errno;
# 79 "/usr/include/x86_64-linux-gnu/sys/procfs.h" 3 4
struct elf_prstatus
    struct elf_siginfo pr_info;
    short int pr_cursig;
    unsigned long int pr_sigpend;
    unsigned long int pr_sighold;
    __pid_t pr_pid;
    __pid_t pr_ppid;
    __pid_t pr_pgrp;
    __pid_t pr_sid;
    struct timeval pr_utime;
    struct timeval pr_stime;
    struct timeval pr_cutime;
    struct timeval pr_cstime;
    elf_gregset_t pr_reg;
    int pr_fpvalid;
struct elf_prpsinfo
    char pr_state;
    char pr_sname;
    char pr_zomb;
    char pr_nice;
    unsigned long int pr_flag;
    unsigned int pr_uid;
    unsigned int pr_gid;
    int pr_pid, pr_ppid, pr_pgrp, pr_sid;
    char pr_fname[16];
    char pr_psargs[(80)];
typedef void *psaddr_t;
typedef elf_gregset_t prgregset_t;
typedef elf_fpregset_t prfpregset_t;
typedef __pid_t lwpid_t;
typedef struct elf_prstatus prstatus_t;
typedef struct elf_prpsinfo prpsinfo_t;
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_SYS_PROCFS_H" to "1"
Checking for header: sys/resource.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/resource.h" 1 3 4
# 22 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
# 23 "/usr/include/x86_64-linux-gnu/sys/resource.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/resource.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/resource.h" 2 3 4
enum __rlimit_resource
  RLIMIT_CPU = 0,
  RLIMIT_FSIZE = 1,
  RLIMIT_DATA = 2,
  RLIMIT_STACK = 3,
  RLIMIT_CORE = 4,
  __RLIMIT_RSS = 5,
  RLIMIT_NOFILE = 7,
  __RLIMIT_OFILE = RLIMIT_NOFILE,
  RLIMIT_AS = 9,
  __RLIMIT_NPROC = 6,
  __RLIMIT_MEMLOCK = 8,
  __RLIMIT_LOCKS = 10,
  __RLIMIT_SIGPENDING = 11,
  __RLIMIT_MSGQUEUE = 12,
  __RLIMIT_NICE = 13,
  __RLIMIT_RTPRIO = 14,
  __RLIMIT_RTTIME = 15,
  __RLIMIT_NLIMITS = 16,
  __RLIM_NLIMITS = __RLIMIT_NLIMITS
# 133 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
typedef __rlim_t rlim_t;
struct rlimit
    rlim_t rlim_cur;
    rlim_t rlim_max;
# 160 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
enum __rusage_who
  RUSAGE_SELF = 0,
  RUSAGE_CHILDREN = -1
# 178 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
struct timeval
    __time_t tv_sec;
# 182 "/usr/include/x86_64-linux-gnu/bits/resource.h" 2 3 4
struct rusage
    struct timeval ru_utime;
    struct timeval ru_stime;
    long int ru_maxrss;
    long int ru_ixrss;
    long int ru_idrss;
    long int ru_isrss;
    long int ru_minflt;
    long int ru_majflt;
    long int ru_nswap;
    long int ru_inblock;
    long int ru_oublock;
    long int ru_msgsnd;
    long int ru_msgrcv;
    long int ru_nsignals;
    long int ru_nvcsw;
    long int ru_nivcsw;
enum __priority_which
  PRIO_PROCESS = 0,
  PRIO_PGRP = 1,
  PRIO_USER = 2
# 268 "/usr/include/x86_64-linux-gnu/bits/resource.h" 3 4
# 26 "/usr/include/x86_64-linux-gnu/sys/resource.h" 2 3 4
# 43 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
extern int getrlimit (__rlimit_resource_t __resource,
        struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 70 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
extern int setrlimit (__rlimit_resource_t __resource,
        __const struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 88 "/usr/include/x86_64-linux-gnu/sys/resource.h" 3 4
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) __attribute__ ((__nothrow__ , __leaf__));
extern int getpriority (__priority_which_t __which, id_t __who) __attribute__ ((__nothrow__ , __leaf__));
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
              Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: unistd.h
stdout:
# 1 "<built-in>"
# 26 "/usr/include/unistd.h" 3 4
# 27 "/usr/include/unistd.h" 2 3 4
# 218 "/usr/include/unistd.h" 3 4
# 219 "/usr/include/unistd.h" 2 3 4
        __off_t __offset) ;
         __off_t __offset) ;
enum
    _PC_LINK_MAX,
    _PC_MAX_CANON,
    _PC_MAX_INPUT,
    _PC_NAME_MAX,
    _PC_PATH_MAX,
    _PC_PIPE_BUF,
    _PC_NO_TRUNC,
    _PC_VDISABLE,
    _PC_SYNC_IO,
    _PC_ASYNC_IO,
    _PC_PRIO_IO,
    _PC_SOCK_MAXBUF,
    _PC_FILESIZEBITS,
    _PC_REC_XFER_ALIGN,
    _PC_ALLOC_SIZE_MIN,
    _PC_SYMLINK_MAX,
    _PC_2_SYMLINKS
enum
    _SC_ARG_MAX,
    _SC_CHILD_MAX,
    _SC_CLK_TCK,
    _SC_NGROUPS_MAX,
    _SC_OPEN_MAX,
    _SC_STREAM_MAX,
    _SC_TZNAME_MAX,
    _SC_JOB_CONTROL,
    _SC_SAVED_IDS,
    _SC_TIMERS,
    _SC_PRIORITIZED_IO,
    _SC_FSYNC,
    _SC_MAPPED_FILES,
    _SC_MEMLOCK,
    _SC_MEMLOCK_RANGE,
    _SC_SEMAPHORES,
    _SC_AIO_LISTIO_MAX,
    _SC_AIO_MAX,
    _SC_DELAYTIMER_MAX,
    _SC_MQ_OPEN_MAX,
    _SC_MQ_PRIO_MAX,
    _SC_VERSION,
    _SC_PAGESIZE,
    _SC_RTSIG_MAX,
    _SC_SEM_NSEMS_MAX,
    _SC_SEM_VALUE_MAX,
    _SC_SIGQUEUE_MAX,
    _SC_TIMER_MAX,
    _SC_BC_BASE_MAX,
    _SC_BC_DIM_MAX,
    _SC_BC_SCALE_MAX,
    _SC_BC_STRING_MAX,
    _SC_EXPR_NEST_MAX,
    _SC_LINE_MAX,
    _SC_RE_DUP_MAX,
    _SC_2_VERSION,
    _SC_2_C_BIND,
    _SC_2_C_DEV,
    _SC_2_FORT_DEV,
    _SC_2_FORT_RUN,
    _SC_2_SW_DEV,
    _SC_2_LOCALEDEF,
    _SC_PII,
    _SC_PII_XTI,
    _SC_PII_SOCKET,
    _SC_PII_INTERNET,
    _SC_PII_OSI,
    _SC_POLL,
    _SC_SELECT,
    _SC_UIO_MAXIOV,
    _SC_PII_OSI_COTS,
    _SC_PII_OSI_CLTS,
    _SC_PII_OSI_M,
    _SC_T_IOV_MAX,
    _SC_THREADS,
    _SC_LOGIN_NAME_MAX,
    _SC_TTY_NAME_MAX,
    _SC_PHYS_PAGES,
    _SC_AVPHYS_PAGES,
    _SC_ATEXIT_MAX,
    _SC_PASS_MAX,
    _SC_XOPEN_VERSION,
    _SC_XOPEN_UNIX,
    _SC_XOPEN_CRYPT,
    _SC_XOPEN_ENH_I18N,
    _SC_XOPEN_SHM,
    _SC_2_CHAR_TERM,
    _SC_2_C_VERSION,
    _SC_2_UPE,
    _SC_XOPEN_XPG2,
    _SC_XOPEN_XPG3,
    _SC_XOPEN_XPG4,
    _SC_CHAR_BIT,
    _SC_CHAR_MAX,
    _SC_CHAR_MIN,
    _SC_INT_MAX,
    _SC_INT_MIN,
    _SC_LONG_BIT,
    _SC_WORD_BIT,
    _SC_MB_LEN_MAX,
    _SC_NZERO,
    _SC_SSIZE_MAX,
    _SC_SCHAR_MAX,
    _SC_SCHAR_MIN,
    _SC_SHRT_MAX,
    _SC_SHRT_MIN,
    _SC_UCHAR_MAX,
    _SC_UINT_MAX,
    _SC_ULONG_MAX,
    _SC_USHRT_MAX,
    _SC_NL_ARGMAX,
    _SC_NL_LANGMAX,
    _SC_NL_MSGMAX,
    _SC_NL_NMAX,
    _SC_NL_SETMAX,
    _SC_NL_TEXTMAX,
    _SC_XOPEN_LEGACY,
    _SC_XOPEN_REALTIME,
    _SC_ADVISORY_INFO,
    _SC_BARRIERS,
    _SC_BASE,
    _SC_C_LANG_SUPPORT,
    _SC_CPUTIME,
    _SC_THREAD_CPUTIME,
    _SC_DEVICE_IO,
    _SC_FD_MGMT,
    _SC_FIFO,
    _SC_PIPE,
    _SC_FILE_LOCKING,
    _SC_FILE_SYSTEM,
    _SC_MULTI_PROCESS,
    _SC_SINGLE_PROCESS,
    _SC_NETWORKING,
    _SC_SPIN_LOCKS,
    _SC_REGEXP,
    _SC_REGEX_VERSION,
    _SC_SHELL,
    _SC_SIGNALS,
    _SC_SPAWN,
    _SC_TIMEOUTS,
    _SC_USER_GROUPS,
    _SC_USER_GROUPS_R,
    _SC_2_PBS,
    _SC_2_PBS_LOCATE,
    _SC_2_PBS_MESSAGE,
    _SC_2_PBS_TRACK,
    _SC_SYMLOOP_MAX,
    _SC_STREAMS,
    _SC_V6_ILP32_OFF32,
    _SC_V6_LP64_OFF64,
    _SC_HOST_NAME_MAX,
    _SC_TRACE,
    _SC_TRACE_INHERIT,
    _SC_TRACE_LOG,
    _SC_RAW_SOCKETS,
    _SC_V7_ILP32_OFF32,
    _SC_V7_LP64_OFF64,
    _SC_SS_REPL_MAX,
    _SC_TRACE_NAME_MAX,
    _SC_TRACE_SYS_MAX,
    _SC_XOPEN_STREAMS,
enum
    _CS_PATH,
    _CS_LFS_LDFLAGS,
    _CS_LFS_LIBS,
    _CS_LFS_LINTFLAGS,
    _CS_LFS64_CFLAGS,
    _CS_LFS64_LDFLAGS,
    _CS_LFS64_LIBS,
    _CS_V6_ENV,
    _CS_V7_ENV
extern int optind;
extern int opterr;
extern int optopt;
              Defined "HAVE_UNISTD_H" to "1"
Checking for header: netinet/in.h
stdout:
# 1 "<built-in>"
# 23 "/usr/include/netinet/in.h" 3 4
# 24 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdint.h" 1 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wchar.h" 1 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 29 "/usr/include/stdint.h" 2 3 4
# 37 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 66 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 91 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 104 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 120 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 135 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 4 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stdint.h" 2 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 217 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 218 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
# 221 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
__extension__
__extension__
__extension__
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
struct iovec
    void *iov_base;
    size_t iov_len;
         __off_t __offset) ;
   __off_t __offset) ;
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
struct sockaddr
    char sa_data[14];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_EOR = 0x80,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_RST = 0x1000,
    MSG_MORE = 0x8000,
struct msghdr
    void *msg_name;
    size_t msg_iovlen;
    void *msg_control;
    int msg_flags;
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
enum
    SCM_RIGHTS = 0x01
struct linger
    int l_onoff;
    int l_linger;
struct osockaddr
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
   int __flags);
enum
    IPPROTO_IP = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_NONE = 59,
    IPPROTO_MTP = 92,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_SUPDUP = 95,
struct in_addr
    in_addr_t s_addr;
struct in6_addr
    union
      } __in6_u;
struct sockaddr_in
    in_port_t sin_port;
struct sockaddr_in6
struct ip_mreq
struct ipv6_mreq
struct group_req
struct ip_msfilter
struct group_filter
    uint32_t gf_fmode;
    uint32_t gf_numsrc;
struct ip_opts
    char ip_opts[40];
struct ip_mreqn
    int imr_ifindex;
struct in_pktinfo
    int ipi_ifindex;
              Defined "HAVE_NETINET_IN_H" to "1"
TEST checkRecursiveMacros from config.headers(/home/tisaac/Projects/petsc/config/BuildSystem/config/headers.py:218)
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:218)
  Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Executing: gcc -c -o /tmp/petsc-W4It8W/config.headers/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.headers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
  return 0;
TEST configureCacheDetails from config.utilities.cacheDetails(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
  Try to determine the size and associativity of the cache.
              Pushing language C
                        All intermediate test results are stored in /tmp/petsc-W4It8W/config.utilities.cacheDetails
Executing: gcc -c -o /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.headers  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
  return 0;
              Popping language C
            Pushing language C
Executing: gcc -c -o /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_SIZE()); fclose(output);;
  return 0;
                        Pushing language C
                        Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Testing executable /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.utilities.cacheDetails/conftest
            Popping language C
            Defined "LEVEL1_DCACHE_SIZE" to "32768"
            Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "LEVEL1_DCACHE_LINESIZE" to "64"
            Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_ASSOC() { long val = sysconf(_SC_LEVEL1_DCACHE_ASSOC); return (0 <= val && val <= 2147483647) ? val : 2; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_ASSOC()); fclose(output);;
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "LEVEL1_DCACHE_ASSOC" to "8"
TEST check_siginfo_t from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:46)
TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
  Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
Checking for type: siginfo_t
                        All intermediate test results are stored in /tmp/petsc-W4It8W/config.types
Executing: gcc -c -o /tmp/petsc-W4It8W/config.types/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.utilities.cacheDetails  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.types/conftest.c
Possible ERROR while running compiler:
stderr:
/tmp/petsc-W4It8W/config.types/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.types/conftest.c:13:11: warning: unused variable ?a? [-Wunused-variable]
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
siginfo_t a;;
  return 0;
siginfo_t found
            Defined "HAVE_SIGINFO_T" to "1"
TEST check__int64 from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
  Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
Executing: gcc -c -o /tmp/petsc-W4It8W/config.types/conftest.o -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.types/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-W4It8W/config.types/conftest.c:13:1: error: unknown type name ?__int64?
/tmp/petsc-W4It8W/config.types/conftest.c:13:9: warning: unused variable ?a? [-Wunused-variable]
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
  return 0;
__int64 found
TEST checkSizeTypes from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
  Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stderr:
/tmp/petsc-W4It8W/config.types/conftest.c:13:8: warning: unused variable ?a? [-Wunused-variable]
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
  return 0;
size_t found
TEST checkFileTypes from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
  Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stderr:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
  return 0;
mode_t found
Checking for type: off_t
stderr:
/tmp/petsc-W4It8W/config.types/conftest.c:13:7: warning: unused variable ?a? [-Wunused-variable]
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
  return 0;
off_t found
TEST checkIntegerTypes from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
  Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stderr:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
  return 0;
int32_t found
TEST checkPID from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
  Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stderr:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
  return 0;
pid_t found
TEST checkUID from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
  Checks for uid_t and gid_t, and defines them if necessary
Source:
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.types/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.types/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-W4It8W/config.types/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.types/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.types/conffix.h" 1
# 3 "/tmp/petsc-W4It8W/config.types/conftest.c" 2
# 26 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 27 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
TEST checkSignal from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
  Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
  return 0;
            Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
  Check for complex numbers in in C99 std
       Note that since PETSc source code uses _Complex we test specifically for that, not complex
stderr:
/tmp/petsc-W4It8W/config.types/conftest.c:6:17: warning: variable ?x? set but not used [-Wunused-but-set-variable]
Source:
#include <complex.h>
int main() {
double _Complex x;
 x = I;
  return 0;
stderr:
Source:
int main() {
double _Complex x;
 x = I;
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.types/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.types/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
            Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
  Check for complex numbers in namespace std
            Pushing language Cxx
Executing: g++ -c -o /tmp/petsc-W4It8W/config.types/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g   -fPIC   /tmp/petsc-W4It8W/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
  return 0;
                    Pushing language CXX
                    Popping language CXX
Executing: g++  -o /tmp/petsc-W4It8W/config.types/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  /tmp/petsc-W4It8W/config.types/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
            Defined "HAVE_CXX_COMPLEX" to "1"
            Popping language Cxx
TEST checkFortranKind from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
  Checks whether selected_int_kind etc work USE_FORTRANKIND
            Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.types/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.types/conftest.F90
Successful compile:
Source:
      program main
        integer(kind=selected_int_kind(10)) i
        real(kind=selected_real_kind(10)) d
      end
            Defined "USE_FORTRANKIND" to "1"
            Popping language FC
TEST checkConst from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:150)
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:150)
  Checks for working const, and if not found defines it to empty string
stderr:
/tmp/petsc-W4It8W/config.types/conftest.c:30:12: warning: ?t? is used uninitialized in this function [-Wuninitialized]
/tmp/petsc-W4It8W/config.types/conftest.c:46:25: warning: ?b? is used uninitialized in this function [-Wuninitialized]
Source:
int main() {
    /* Ultrix mips cc rejects this.  */
    typedef int charset[2]; const charset x;
    /* SunOS 4.1.1 cc rejects this.  */
    char const *const *ccp;
    char **p;
    /* NEC SVR4.0.2 mips cc rejects this.  */
    struct point {int x, y;};
    static struct point const zero = {0,0};
    /* AIX XL C 1.02.0.0 rejects this.
    It does not let you subtract one const X* pointer from another in an arm
    of an if-expression whose if-part is not a constant expression */
    const char *g = "string";
    ccp = &g + (g ? g-g : 0);
    /* HPUX 7.0 cc rejects these. */
    ++ccp;
    p = (char**) ccp;
    ccp = (char const *const *) p;
    /* This section avoids unused variable warnings */
    if (zero.x);
    if (x[0]);
    { /* SCO 3.2v4 cc rejects this.  */
      char *t;
      char const *s = 0 ? (char *) 0 : (char const *) 0;
      *t++ = 0;
      if (*s);
    { /* Someone thinks the Sun supposedly-ANSI compiler will reject this.  */
      int x[] = {25, 17};
      const int *foo = &x[0];
      ++foo;
    { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
      typedef const int *iptr;
      iptr p = 0;
      ++p;
    { /* AIX XL C 1.02.0.0 rejects this saying
      "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
      struct s { int j; const int *ap[3]; };
      struct s *b; b->j = 5;
    { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
      const int foo = 10;
      /* Get rid of unused variable warning */
      if (foo);
  return 0;
TEST checkEndian from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:206)
TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:206)
  If the machine is big endian, defines WORDS_BIGENDIAN
Successful compile:
Source:
#ifdef HAVE_SYS_PARAM_H
  #include <sys/param.h>
#endif
int main() {
#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
  bogus endian macros
#endif
  return 0;
stderr:
/tmp/petsc-W4It8W/config.types/conftest.c:11:3: error: unknown type name ?not?
/tmp/petsc-W4It8W/config.types/conftest.c:11:11: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?endian?
Source:
#endif
int main() {
#if BYTE_ORDER != BIG_ENDIAN
  not big endian
#endif
  return 0;
TEST checkSizeof from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:259)
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:259)
  Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(char));
  return 0;
                          Pushing language C
                          Popping language C
Testing executable /tmp/petsc-W4It8W/config.types/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.types/conftest
              Popping language C
              Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(void *));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(short));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(int));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_INT" to "4"
Checking for size of type: long
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long long));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(float));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(double));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(size_t));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:310)
TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:310)
  Determine the nubmer of bits per byte and define BITS_PER_BYTE
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#endif
int main() {
    char val[2];
    int i = 0;
    if (!f) exit(1);
    val[0]='\1';
    val[1]='\0';
    while(val[0]) {val[0] <<= 1; i++;}
    fprintf(f, "%d\n", i);
  return 0;
                        Pushing language C
                        Popping language C
            Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/home/tisaac/Projects/petsc/config/BuildSystem/config/types.py:356)
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:356)
            Pushing language C
Successful compile:
Source:
int main() {
__attribute__((visibility ("default"))) int foo(void);;
  return 0;
            Defined "USE_VISIBILITY_C" to "1"
            Popping language C
Executing: g++ -c -o /tmp/petsc-W4It8W/config.types/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g   -fPIC   /tmp/petsc-W4It8W/config.types/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            Defined "USE_VISIBILITY_CXX" to "1"
TEST configureMemAlign from PETSc.options.memAlign(/home/tisaac/Projects/petsc/config/PETSc/options/memAlign.py:30)
TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:30)
  Choose alignment
            Defined "MEMALIGN" to "16"
          Memory alignment is 16
TEST check from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            Checking for functions [socket] in library ['socket', 'nsl'] []
              Pushing language C
Executing: gcc -c -o /tmp/petsc-W4It8W/config.libraries/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.libraries  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o  -lsocket -lnsl -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lsocket
collect2: ld returned 1 exit status
              Popping language C
            Checking for functions [handle_sigfpes] in library ['fpe'] []
              Pushing language C
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o  -lfpe -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
stderr:
/usr/bin/ld: cannot find -lfpe
              Popping language C
              Pushing language C
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
              Popping language C
              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
stderr:
              Popping language C
TEST checkMath from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:251)
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:251)
  Check for sin() in libm, the math library
            Checking for functions [sin floor log10 pow] in library [''] []
              Pushing language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_sin?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:5:41: warning: variable ?y? set but not used [-Wunused-but-set-variable]
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_floor?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:8:43: warning: variable ?y? set but not used [-Wunused-but-set-variable]
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_log10?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:11:43: warning: variable ?y? set but not used [-Wunused-but-set-variable]
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_pow?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:14:41: warning: variable ?y? set but not used [-Wunused-but-set-variable]
Source:
double sin(double);
static void _check_sin() { double x = 0,y; y = sin(x);
double floor(double);
static void _check_floor() { double x = 0,y; y = floor(x);
double log10(double);
static void _check_log10() { double x = 0,y; y = log10(x);
double pow(double, double);
static void _check_pow() { double x = 0,y ; y = pow(x, x);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o   -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_sin':
/tmp/petsc-W4It8W/config.libraries/conftest.c:5: undefined reference to `sin'
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_floor':
/tmp/petsc-W4It8W/config.libraries/conftest.c:8: undefined reference to `floor'
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_log10':
/tmp/petsc-W4It8W/config.libraries/conftest.c:11: undefined reference to `log10'
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_pow':
/tmp/petsc-W4It8W/config.libraries/conftest.c:14: undefined reference to `pow'
              Popping language C
            Checking for functions [sin floor log10 pow] in library ['m'] []
              Pushing language C
stderr:
Source:
double sin(double);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o  -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
              Defined "HAVE_LIBM" to "1"
              Popping language C
          Using libm for the math library
TEST checkMathErf from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:267)
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:267)
  Check for erf() in libm, the math library
            Checking for functions [erf] in library ['libm.a'] []
              Pushing language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_erf?:
Source:
double erf(double);
static void _check_erf() { double x = 0,y; y = erf(x);
int main() {
_check_erf();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
          erf() found
            Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:276)
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:276)
  Check for tgama() in libm, the math library
            Checking for functions [tgamma] in library ['libm.a'] []
              Pushing language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_tgamma?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:5:44: warning: variable ?y? set but not used [-Wunused-but-set-variable]
Source:
double tgamma(double);
static void _check_tgamma() { double x = 0,y; y = tgamma(x);
int main() {
_check_tgamma();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
          tgamma() found
            Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:285)
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:285)
  Checks if <fenv.h> can be used with FE_DFL_ENV
            Checking for functions [fesetenv] in library ['libm.a'] []
              Pushing language C
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
            Defined "HAVE_FENV_H" to "1"
TEST checkMathLog2 from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:293)
TESTING: checkMathLog2 from config.libraries(config/BuildSystem/config/libraries.py:293)
  Check for log2() in libm, the math library
            Checking for functions [log2] in library ['libm.a'] []
              Pushing language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_log2?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:5:42: warning: variable ?y? set but not used [-Wunused-but-set-variable]
Source:
double log2(double);
static void _check_log2() { double x = 1,y; y = log2(x);
int main() {
_check_log2();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
          log2() found
            Defined "HAVE_LOG2" to "1"
TEST checkCompression from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:302)
TESTING: checkCompression from config.libraries(config/BuildSystem/config/libraries.py:302)
  Check for libz, the compression library
            Checking for functions [compress uncompress] in library [''] []
              Pushing language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_compress?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:5:119: warning: variable ?ret? set but not used [-Wunused-but-set-variable]
/tmp/petsc-W4It8W/config.libraries/conftest.c: In function ?_check_uncompress?:
/tmp/petsc-W4It8W/config.libraries/conftest.c:8:121: warning: variable ?ret? set but not used [-Wunused-but-set-variable]
Source:
int   compress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
static void _check_compress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret =   compress(dest, &destLen, source, sourceLen);
int uncompress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
static void _check_uncompress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret = uncompress(dest, &destLen, source, sourceLen);
int main() {
_check_compress();
_check_uncompress();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_compress':
/tmp/petsc-W4It8W/config.libraries/conftest.c:5: undefined reference to `compress'
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_uncompress':
/tmp/petsc-W4It8W/config.libraries/conftest.c:8: undefined reference to `uncompress'
              Popping language C
            Checking for functions [compress uncompress] in library ['z'] []
              Pushing language C
stderr:
Source:
int main() {
_check_compress();
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o  -lz -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
              Defined "HAVE_LIBZ" to "1"
              Popping language C
          Using libz for the compression library
TEST checkRealtime from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:323)
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:323)
  Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
            Checking for functions [clock_gettime] in library [''] []
              Pushing language C
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_clock_gettime':
/tmp/petsc-W4It8W/config.libraries/conftest.c:5: undefined reference to `clock_gettime'
              Popping language C
            Checking for functions [clock_gettime] in library ['rt'] []
              Pushing language C
Successful compile:
Source:
#include <time.h>
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o  -lrt -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
              Defined "HAVE_LIBRT" to "1"
              Popping language C
          Using librt for the realtime library
TEST checkDynamic from config.libraries(/home/tisaac/Projects/petsc/config/BuildSystem/config/libraries.py:339)
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:339)
  Check for the header and libraries necessary for dynamic library manipulation
            Checking for functions [dlopen] in library ['dl'] []
              Pushing language C
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o  -ldl -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
              Defined "HAVE_LIBDL" to "1"
              Popping language C
Checking for header: dlfcn.h
Executing: gcc -E  -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.headers/conffix.h" 1
# 1 "/usr/include/dlfcn.h" 1 3 4
# 23 "/usr/include/dlfcn.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 324 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 325 "/usr/include/features.h" 2 3 4
# 357 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 24 "/usr/include/dlfcn.h" 2 3 4
# 212 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 26 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/dlfcn.h" 1 3 4
# 29 "/usr/include/dlfcn.h" 2 3 4
# 53 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (__const char *__file, int __mode) __attribute__ ((__nothrow__ , __leaf__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
      __const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 83 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/dlfcn.h" 3 4
              Defined "HAVE_DLFCN_H" to "1"
TEST configureLibraryOptions from PETSc.options.libraryOptions(/home/tisaac/Projects/petsc/config/PETSc/options/libraryOptions.py:37)
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:37)
  Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE and PETSC_USE_FORTRAN_KERNELS
            Defined "USE_LOG" to "1"
            Defined "USE_DEBUG" to "1"
            Defined "USE_INFO" to "1"
            Defined "USE_CTABLE" to "1"
            Defined "USE_BACKWARD_LOOP" to "1"
            **********Checking if running on BGL/IBM detected
              Checking for functions [bgl_perfctr_void] in library [''] []
                Pushing language C
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_bgl_perfctr_void':
/tmp/petsc-W4It8W/config.libraries/conftest.c:5: undefined reference to `bgl_perfctr_void'
                Popping language C
              Checking for functions [ADIOI_BGL_Open] in library [''] []
                Pushing language C
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_ADIOI_BGL_Open':
/tmp/petsc-W4It8W/config.libraries/conftest.c:5: undefined reference to `ADIOI_BGL_Open'
                Popping language C
            *********BGL/IBM test failure
            Defined "Alignx(a,b)" to "  "
TEST configureISColorValueType from PETSc.options.libraryOptions(/home/tisaac/Projects/petsc/config/PETSc/options/libraryOptions.py:91)
TESTING: configureISColorValueType from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:91)
  Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
            Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
            Defined "IS_COLORING_MAX" to "65535"
            Defined "IS_COLOR_VALUE_TYPE" to "short"
            Defined "IS_COLOR_VALUE_TYPE_F" to "integer2"
TEST configureCPURelax from config.atomics(/home/tisaac/Projects/petsc/config/BuildSystem/config/atomics.py:17)
TESTING: configureCPURelax from config.atomics(config/BuildSystem/config/atomics.py:17)
   Definitions for cpu relax assembly instructions
                      All intermediate test results are stored in /tmp/petsc-W4It8W/config.atomics
Executing: gcc -c -o /tmp/petsc-W4It8W/config.atomics/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.atomics  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.atomics/conftest.c
Successful compile:
Source:
int main() {
asm volatile("rep; nop" ::: "memory");;
  return 0;
            Defined "CPU_RELAX()" to "asm volatile("rep; nop" ::: "memory")"
TEST configureMemoryBarriers from config.atomics(/home/tisaac/Projects/petsc/config/BuildSystem/config/atomics.py:36)
TESTING: configureMemoryBarriers from config.atomics(config/BuildSystem/config/atomics.py:36)
   Definitions for memory barrier instructions
Successful compile:
Source:
int main() {
asm volatile("mfence":::"memory");
  return 0;
            Defined "MEMORY_BARRIER()" to "asm volatile("mfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("lfence":::"memory");
  return 0;
            Defined "READ_MEMORY_BARRIER()" to "asm volatile("lfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("sfence":::"memory");
  return 0;
            Defined "WRITE_MEMORY_BARRIER()" to "asm volatile("sfence":::"memory")"
TEST checkMemcmp from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:110)
TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:110)
  Check for 8-bit clean memcmp
          Making executable to test memcmp()
                            All intermediate test results are stored in /tmp/petsc-W4It8W/config.functions
Executing: gcc -c -o /tmp/petsc-W4It8W/config.functions/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.atomics  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.functions/conftest.c
Successful compile:
Source:
#include <string.h>
void exit(int);
int main() {
char c0 = 0x40;
char c1 = (char) 0x80;
char c2 = (char) 0x81;
exit(memcmp(&c0, &c2, 1) < 0 && memcmp(&c1, &c2, 1) < 0 ? 0 : 1);
  return 0;
                        Pushing language C
                        Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.functions/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.functions/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Testing executable /tmp/petsc-W4It8W/config.functions/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.functions/conftest
TEST checkSysinfo from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:135)
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:135)
  Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Executing: gcc -c -o /tmp/petsc-W4It8W/config.functions/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_SYSINFO" to "1"
Checking for header: linux/kernel.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 12 "/usr/include/linux/kernel.h" 3 4
struct sysinfo {
 long uptime;
 unsigned long loads[3];
 unsigned long totalram;
 unsigned long freeram;
 unsigned long sharedram;
 unsigned long bufferram;
 unsigned long totalswap;
 unsigned long freeswap;
 unsigned short procs;
 unsigned short pad;
 unsigned long totalhigh;
 unsigned long freehigh;
 unsigned int mem_unit;
 char _f[20-2*sizeof(long)-sizeof(int)];
              Defined "HAVE_LINUX_KERNEL_H" to "1"
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 1 3 4
# 22 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 3 4
# 23 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 2 3 4
struct sysinfo {
 long uptime;
 unsigned short pad;
# 26 "/usr/include/x86_64-linux-gnu/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2stderr:
/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
compilation terminated.
Source:
#include <sys/systeminfo.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directorycompilation terminated.:
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:13:4: error: #error "Cannot check sysinfo without special headers"
/tmp/petsc-W4It8W/config.functions/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.functions/conftest.c:17:1: warning: implicit declaration of function ?sysinfo? [-Wimplicit-function-declaration]
Source:
#ifdef HAVE_LINUX_KERNEL_H
#  include <linux/kernel.h>
#  include <linux/sys.h>
#  ifdef HAVE_SYS_SYSINFO_H
#    include <sys/sysinfo.h>
#  endif
#elif defined(HAVE_SYS_SYSTEMINFO_H)
#  include <sys/systeminfo.h>
#else
#  error "Cannot check sysinfo without special headers"
#endif
int main() {
char buf[10]; long count=10; sysinfo(1, buf, count);
  return 0;
              Compile failed inside link
TEST checkVPrintf from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:158)
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:158)
  Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?vprintf? [enabled by default]
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_VPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
  return 0;
                    Pushing language C
                    Popping language C
TEST checkVFPrintf from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:165)
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:165)
  Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?vfprintf? [enabled by default]
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_VFPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
  return 0;
                    Pushing language C
                    Popping language C
TEST checkVSNPrintf from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:172)
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:172)
  Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:6:1: warning: implicit declaration of function ?_vsnprintf? [-Wimplicit-function-declaration]
Source:
#include <stdio.h>
int main() {
_vsnprintf(0,0,0,0);
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.o: In function `main':
/tmp/petsc-W4It8W/config.functions/conftest.c:6: undefined reference to `_vsnprintf'
Checking for functions [vsnprintf]
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?vsnprintf? [enabled by default]
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vsnprintf) || defined (__stub___vsnprintf)
vsnprintf_will_always_fail_with_ENOSYS();
#else
vsnprintf();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_VSNPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
  return 0;
                    Pushing language C
                    Popping language C
TEST checkNanosleep from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:206)
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:206)
  Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
 tp.tv_sec = 0;
 tp.tv_nsec = (long)(1e9);
 nanosleep(&tp,0);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_NANOSLEEP" to "1"
TEST checkSignalHandlerType from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:182)
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:182)
  Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
Executing: g++ -c -o /tmp/petsc-W4It8W/config.functions/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g   -fPIC   /tmp/petsc-W4It8W/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
  return 0;
Executing: g++  -o /tmp/petsc-W4It8W/config.functions/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  /tmp/petsc-W4It8W/config.functions/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
            Defined "SIGNAL_CAST" to " "
TEST checkFreeReturnType from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:192)
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:192)
  Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:6:25: error: void value not ignored as it ought to be
/tmp/petsc-W4It8W/config.functions/conftest.c:6:5: warning: variable ?ierr? set but not used [-Wunused-but-set-variable]
Source:
#include <stdlib.h>
int main() {
int ierr; void *p; ierr = free(p); return 0;
  return 0;
TEST checkVariableArgumentLists from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:198)
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:198)
  Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
  va_list l1, l2;
  va_copy(l1, l2);
  return 0;
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/home/tisaac/Projects/petsc/config/BuildSystem/config/functions.py:89)
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:89)
  Recursive decompose to rapidly classify functions as found or missing
    To confirm that a function is missing, we require a compile/link
    failure with only that function in a compilation unit.  In contrast,
    we can confirm that many functions are present by compiling them all
    together in a large compilation unit.  We optimistically compile
    everything together, then trim all functions that were named in the
    error message and bisect the result.  The trimming is only an
    optimization to increase the likelihood of a big-batch compile
    succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink _set_output_format PXFGETARG sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times _mkdir time sysctlbyname stricmp]
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:16:6: warning: conflicting types for built-in function ?snprintf? [enabled by default]
/tmp/petsc-W4It8W/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ?bzero? [enabled by default]
/tmp/petsc-W4It8W/config.functions/conftest.c:36:6: warning: conflicting types for built-in function ?fork? [enabled by default]
/tmp/petsc-W4It8W/config.functions/conftest.c:48:6: warning: conflicting types for built-in function ?strcasecmp? [enabled by default]
/tmp/petsc-W4It8W/config.functions/conftest.c:52:6: warning: conflicting types for built-in function ?memmove? [enabled by default]
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _sleep();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _access();
char lseek();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char access();
char _snprintf();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
char sbreak();
char memalign();
char sigset();
char getcwd();
char gethostbyname();
char gettimeofday();
char readlink();
char _set_output_format();
char PXFGETARG();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char _mkdir();
char time();
char sysctlbyname();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_memmove) || defined (__stub___memmove)
memmove_will_always_fail_with_ENOSYS();
#else
memmove();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub__mkdir) || defined (__stub____mkdir)
_mkdir_will_always_fail_with_ENOSYS();
#else
_mkdir();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:83: undefined reference to `_sleep'
/tmp/petsc-W4It8W/config.functions/conftest.c:113: undefined reference to `_getcwd'
/tmp/petsc-W4It8W/config.functions/conftest.c:131: undefined reference to `_lseek'
/tmp/petsc-W4It8W/config.functions/conftest.c:143: undefined reference to `_access'
/tmp/petsc-W4It8W/config.functions/conftest.c:191: undefined reference to `_snprintf'
/tmp/petsc-W4It8W/config.functions/conftest.c:221: undefined reference to `sbreak'
/tmp/petsc-W4It8W/config.functions/conftest.c:263: undefined reference to `_set_output_format'
/tmp/petsc-W4It8W/config.functions/conftest.c:269: undefined reference to `PXFGETARG'
/tmp/petsc-W4It8W/config.functions/conftest.c:335: undefined reference to `_mkdir'
/tmp/petsc-W4It8W/config.functions/conftest.c:347: undefined reference to `sysctlbyname'
/tmp/petsc-W4It8W/config.functions/conftest.c:353: undefined reference to `stricmp'
Checking for functions [rand getdomainname realpath dlsym bzero getwd uname usleep dlclose gethostname clock get_nprocs dlerror mkstemp fork getpagesize]
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:17:6: warning: conflicting types for built-in function ?bzero? [enabled by default]
/tmp/petsc-W4It8W/config.functions/conftest.c:27:6: warning: conflicting types for built-in function ?fork? [enabled by default]
Source:
#include "confdefs.h"
#include "conffix.h"
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char getwd();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
getwd();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
get_nprocs();
#endif
#else
dlerror();
#endif
#else
mkstemp();
#endif
#else
fork();
#endif
#else
getpagesize();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_RAND" to "1"
                    Defined "HAVE_GETDOMAINNAME" to "1"
                    Defined "HAVE_REALPATH" to "1"
                    Defined "HAVE_DLSYM" to "1"
                    Defined "HAVE_BZERO" to "1"
                    Defined "HAVE_GETWD" to "1"
                    Defined "HAVE_UNAME" to "1"
                    Defined "HAVE_USLEEP" to "1"
                    Defined "HAVE_DLCLOSE" to "1"
                    Defined "HAVE_GETHOSTNAME" to "1"
                    Defined "HAVE_CLOCK" to "1"
                    Defined "HAVE_GET_NPROCS" to "1"
                    Defined "HAVE_DLERROR" to "1"
                    Defined "HAVE_MKSTEMP" to "1"
                    Defined "HAVE_FORK" to "1"
                    Defined "HAVE_GETPAGESIZE" to "1"
Checking for functions [memalign sigset gethostbyname gettimeofday readlink sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time]
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ?strcasecmp? [enabled by default]
/tmp/petsc-W4It8W/config.functions/conftest.c:23:6: warning: conflicting types for built-in function ?memmove? [enabled by default]
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
char sigset();
char readlink();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
#else
sigset();
#endif
#else
gethostbyname();
#endif
#else
gettimeofday();
#endif
#else
readlink();
#endif
#else
sigaction();
#endif
#else
strcasecmp();
#endif
#else
dlopen();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
memmove();
#endif
#else
signal();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
times();
#endif
#else
time();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_MEMALIGN" to "1"
                    Defined "HAVE_SIGSET" to "1"
                    Defined "HAVE_GETHOSTBYNAME" to "1"
                    Defined "HAVE_GETTIMEOFDAY" to "1"
                    Defined "HAVE_READLINK" to "1"
                    Defined "HAVE_SIGACTION" to "1"
                    Defined "HAVE_STRCASECMP" to "1"
                    Defined "HAVE_DLOPEN" to "1"
                    Defined "HAVE_DRAND48" to "1"
                    Defined "HAVE_SOCKET" to "1"
                    Defined "HAVE_MEMMOVE" to "1"
                    Defined "HAVE_SIGNAL" to "1"
                    Defined "HAVE_POPEN" to "1"
                    Defined "HAVE_GETRUSAGE" to "1"
                    Defined "HAVE_TIMES" to "1"
                    Defined "HAVE_TIME" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `_sleep'
Checking for functions [snprintf]
Possible ERROR while running compiler:
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ?snprintf? [enabled by default]
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `_getcwd'
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `_lseek'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_SLEEP" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `_access'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_LSEEK" to "1"
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `_snprintf'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `sbreak'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_GETCWD" to "1"
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `_set_output_format'
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `PXFGETARG'
Checking for functions [_mkdir]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `_mkdir'
Checking for functions [sysctlbyname]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
sysctlbyname();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `sysctlbyname'
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `stricmp'
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
  Check for the mechanism to retrieve command line arguments in Fortran
            Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
            Pushing language FC
            Checking for functions [] in library [''] []
              Pushing language FC
Executing: gfortran -c -o /tmp/petsc-W4It8W/config.libraries/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.libraries/conftest.F90
Successful compile:
Source:
      program main
      integer i
      character*(80) arg
       i = command_argument_count()
       call get_command_argument(i,arg)
      end
                      Pushing language FC
                      Popping language FC
Executing: gfortran  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g  /tmp/petsc-W4It8W/config.libraries/conftest.o   -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
              Popping language FC
            Popping language FC
            Pushing language C
            Defined "HAVE_GFORTRAN_IARGC" to "1"
            Popping language C
            Checking for functions [get_command_argument_] in library [''] ['-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-L/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-L/lib/x86_64-linux-gnu', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-lgfortran', '-lm', '-lquadmath', '-lm']
              Pushing language C
Executing: gcc -c -o /tmp/petsc-W4It8W/config.libraries/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument_();
static void _check_get_command_argument_() { get_command_argument_(); }
int main() {
_check_get_command_argument_();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/config.libraries/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.libraries/conftest.o  -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lgfortran -lm -lquadmath -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_get_command_argument_':
/tmp/petsc-W4It8W/config.libraries/conftest.c:5: undefined reference to `get_command_argument_'
              Popping language C
            Checking for functions [getarg_] in library [''] ['-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-L/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-L/lib/x86_64-linux-gnu', '-lgfortran', '-lm', '-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-lgfortran', '-lm', '-lquadmath', '-lm']
              Pushing language C
Successful compile:
Source:
char getarg_();
static void _check_getarg_() { getarg_(); }
int main() {
_check_getarg_();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-W4It8W/config.libraries/conftest.o: In function `_check_getarg_':
/tmp/petsc-W4It8W/config.libraries/conftest.c:5: undefined reference to `getarg_'
              Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
Checking for functions [ipxfargc_]
Executing: gcc -c -o /tmp/petsc-W4It8W/config.functions/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.functions/conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
  return 0;
Executing: gcc  -o /tmp/petsc-W4It8W/config.functions/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.functions/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl  -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lgfortran -lm -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -lgfortran -lm -lquadmath -lm
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `ipxfargc_'
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
  return 0;
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `f90_unix_MP_iargc'
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
stderr:
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
  return 0;
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:24: undefined reference to `iargc_'
Checking for functions [GETARG at 16]
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-W4It8W/config.functions/conftest.c:13:1: error: stray ?@? in program
/tmp/petsc-W4It8W/config.functions/conftest.c:13:13: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before numeric constant
/tmp/petsc-W4It8W/config.functions/conftest.c:21:27: error: missing ')' after "defined"
/tmp/petsc-W4It8W/config.functions/conftest.c:21:28: error: missing binary operator before token "16"
/tmp/petsc-W4It8W/config.functions/conftest.c:24:1: error: stray ?@? in program
/tmp/petsc-W4It8W/config.functions/conftest.c:24:1: error: ?GETARG? undeclared (first use in this function)
/tmp/petsc-W4It8W/config.functions/conftest.c:24:1: note: each undeclared identifier is reported only once for each function it appears in
/tmp/petsc-W4It8W/config.functions/conftest.c:24:8: error: expected ?;? before numeric constant
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char GETARG at 16();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_GETARG at 16) || defined (__stub___GETARG at 16)
GETARG at 16_will_always_fail_with_ENOSYS();
#else
GETARG at 16();
#endif
  return 0;
Checking for functions [_gfortran_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _gfortran_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__gfortran_iargc) || defined (__stub____gfortran_iargc)
_gfortran_iargc_will_always_fail_with_ENOSYS();
#else
_gfortran_iargc();
#endif
  return 0;
              Defined "HAVE__GFORTRAN_IARGC" to "1"
TEST configureMemorySize from config.utilities.getResidentSetSize(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
  Try to determine how to measure the memory usage
            Defined "USE_PROC_FOR_SIZE" to "1"
          Using /proc for PetscMemoryGetCurrentUsage()
TEST configureFPTrap from config.utilities.FPTrap(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/FPTrap.py:27)
TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:27)
  Checking the handling of floating point traps
Checking for header: sigfpe.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory
Source:
#include <sigfpe.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directorycompilation terminated.:
Checking for header: fpxcp.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory
Source:
#include <fpxcp.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directorycompilation terminated.:
Checking for header: floatingpoint.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-W4It8W/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory
Source:
#include <floatingpoint.h>
Preprocess stderr before filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-W4It8W/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directorycompilation terminated.:
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
  Checks if certain feature test macros are support
                      All intermediate test results are stored in /tmp/petsc-W4It8W/config.utilities.featureTestMacros
Executing: gcc -c -o /tmp/petsc-W4It8W/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.utilities.featureTestMacros/conftest.c
stderr:
/tmp/petsc-W4It8W/config.utilities.featureTestMacros/conftest.c:4:20: fatal error: sysctl.h: No such file or directory
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
  return 0;
Executing: gcc -c -o /tmp/petsc-W4It8W/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.utilities.featureTestMacros/conftest.c
Successful compile:
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_DEFAULT_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
  return 0;
            Defined "_GNU_SOURCE" to "1"
TEST configureMissingDefines from config.utilities.missing(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/missing.py:57)
TESTING: configureMissingDefines from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:57)
  Checks for limits
                      All intermediate test results are stored in /tmp/petsc-W4It8W/config.utilities.missing
Executing: gcc -c -o /tmp/petsc-W4It8W/config.utilities.missing/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_LIMITS_H
  #include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
  return 0;
Successful compile:
Source:
#ifdef PETSC_HAVE_FLOAT_H
  #include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
  return 0;
TEST configureMissingUtypeTypedefs from config.utilities.missing(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/missing.py:67)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:67)
   Checks if u_short is undefined
stderr:
/tmp/petsc-W4It8W/config.utilities.missing/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.utilities.missing/conftest.c:6:9: warning: unused variable ?foo? [-Wunused-variable]
Source:
#include <sys/types.h>
int main() {
u_short foo;
  return 0;
TEST configureMissingFunctions from config.utilities.missing(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/missing.py:73)
TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:73)
  Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/missing.py:93)
TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:93)
  Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
  return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/missing.py:110)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:110)
Successful compile:
Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#if !defined(_GNU_SOURCE)
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
  return 0;
            Pushing language Cxx
Executing: g++ -c -o /tmp/petsc-W4It8W/config.utilities.missing/conftest.o -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g   -fPIC   /tmp/petsc-W4It8W/config.utilities.missing/conftest.cc
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
                    Pushing language CXX
                    Popping language CXX
Executing: g++  -o /tmp/petsc-W4It8W/config.utilities.missing/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g  /tmp/petsc-W4It8W/config.utilities.missing/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
            Popping language Cxx
TEST configureMissingSrandPrototype from config.utilities.missing(/home/tisaac/Projects/petsc/config/BuildSystem/config/utilities/missing.py:135)
TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:135)
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
  return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
  return 0;
TEST configureScalarType from PETSc.options.scalarTypes(/home/tisaac/Projects/petsc/config/PETSc/options/scalarTypes.py:36)
TESTING: configureScalarType from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:36)
  Choose between real and complex numbers
            Defined "USE_SCALAR_REAL" to "1"
          Scalar type is real
            Pushing language C
                        All intermediate test results are stored in /tmp/petsc-W4It8W/PETSc.options.scalarTypes
Executing: gcc -c -o /tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.utilities.missing  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c
stderr:
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c:6:21: warning: unused variable ?a? [-Wunused-variable]
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnormal(b);
  return 0;
                    Pushing language C
                    Popping language C
Executing: gcc  -o /tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest    -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.o -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.o: In function `main':
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `__fpclassify'
collect2: ld returned 1 exit status
Executing: gcc -c -o /tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes  -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c
stderr:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnan(b);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_ISNAN" to "1"
stderr:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isinf(b);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_ISINF" to "1"
stderr:
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c:6:1: warning: implicit declaration of function ?_isnan? [-Wimplicit-function-declaration]
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c:6:20: warning: unused variable ?a? [-Wunused-variable]
Source:
#include <float.h>
int main() {
double b = 2.0;int a = _isnan(b);
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_isnan'
stderr:
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c:6:1: warning: implicit declaration of function ?_finite? [-Wimplicit-function-declaration]
Source:
#include <float.h>
int main() {
double b = 2.0;int a = _finite(b);
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-W4It8W/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_finite'
            Popping language C
TEST configurePrecision from PETSc.options.scalarTypes(/home/tisaac/Projects/petsc/config/PETSc/options/scalarTypes.py:76)
TESTING: configurePrecision from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:76)
  Set the default real number precision for PETSc objects
            Defined "USE_REAL_DOUBLE" to "1"
            Defined make macro "PETSC_SCALAR_SIZE" to "64"
          Precision is double
TEST configureMkdir from config.programs(/home/tisaac/Projects/petsc/config/BuildSystem/config/programs.py:23)
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:23)
  Make sure we can have mkdir automatically make intermediate directories
Checking for program /usr/lib/mutt/mkdir...not found
Checking for program /home/tisaac/.local/bin/mkdir...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/mkdir...not found
Checking for program /home/tisaac/.bin/mkdir...not found
Checking for program /usr/lib/lightdm/lightdm/mkdir...not found
Checking for program /usr/local/sbin/mkdir...not found
Checking for program /usr/local/bin/mkdir...not found
Checking for program /usr/sbin/mkdir...not found
Checking for program /usr/bin/mkdir...not found
Checking for program /sbin/mkdir...not found
Checking for program /bin/mkdir...found
Executing: /bin/mkdir -p .conftest/tmp
          Adding -p flag to /bin/mkdir -p to automatically create directories
            Defined make macro "MKDIR" to "/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/home/tisaac/Projects/petsc/config/BuildSystem/config/programs.py:45)
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:45)
  Check for autoreconf
Checking for program /usr/lib/mutt/autoreconf...not found
Checking for program /home/tisaac/.local/bin/autoreconf...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/autoreconf...not found
Checking for program /home/tisaac/.bin/autoreconf...not found
Checking for program /usr/lib/lightdm/lightdm/autoreconf...not found
Checking for program /usr/local/sbin/autoreconf...not found
Checking for program /usr/local/bin/autoreconf...not found
Checking for program /usr/sbin/autoreconf...not found
Checking for program /usr/bin/autoreconf...found
            All intermediate test results are stored in /tmp/petsc-W4It8W/config.programs
Executing: cd /tmp/petsc-W4It8W/config.programs/autoconfdir&&/usr/bin/autoreconf
          autoreconf test successful!
Checking for program /usr/lib/mutt/libtoolize...not found
Checking for program /home/tisaac/.local/bin/libtoolize...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/libtoolize...not found
Checking for program /home/tisaac/.bin/libtoolize...not found
Checking for program /usr/lib/lightdm/lightdm/libtoolize...not found
Checking for program /usr/local/sbin/libtoolize...not found
Checking for program /usr/local/bin/libtoolize...not found
Checking for program /usr/sbin/libtoolize...not found
Checking for program /usr/bin/libtoolize...found
TEST configurePrograms from config.programs(/home/tisaac/Projects/petsc/config/BuildSystem/config/programs.py:72)
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:72)
  Check for the programs needed to build and run PETSc
Checking for program /usr/lib/mutt/sh...not found
Checking for program /home/tisaac/.local/bin/sh...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/sh...not found
Checking for program /home/tisaac/.bin/sh...not found
Checking for program /usr/lib/lightdm/lightdm/sh...not found
Checking for program /usr/local/sbin/sh...not found
Checking for program /usr/local/bin/sh...not found
Checking for program /usr/sbin/sh...not found
Checking for program /usr/bin/sh...not found
Checking for program /sbin/sh...not found
Checking for program /bin/sh...found
              Defined make macro "SHELL" to "/bin/sh"
Checking for program /usr/lib/mutt/sed...not found
Checking for program /home/tisaac/.local/bin/sed...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/sed...not found
Checking for program /home/tisaac/.bin/sed...not found
Checking for program /usr/lib/lightdm/lightdm/sed...not found
Checking for program /usr/local/sbin/sed...not found
Checking for program /usr/local/bin/sed...not found
Checking for program /usr/sbin/sed...not found
Checking for program /usr/bin/sed...not found
Checking for program /sbin/sed...not found
Checking for program /bin/sed...found
              Defined make macro "SED" to "/bin/sed"
Executing: /bin/sed -i s/sed/sd/g "/tmp/petsc-W4It8W/config.programs/sed1"
          Adding SEDINPLACE cmd: /bin/sed -i
            Defined make macro "SEDINPLACE" to "/bin/sed -i"
Checking for program /usr/lib/mutt/mv...not found
Checking for program /home/tisaac/.local/bin/mv...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/mv...not found
Checking for program /home/tisaac/.bin/mv...not found
Checking for program /usr/lib/lightdm/lightdm/mv...not found
Checking for program /usr/local/sbin/mv...not found
Checking for program /usr/local/bin/mv...not found
Checking for program /usr/sbin/mv...not found
Checking for program /usr/bin/mv...not found
Checking for program /sbin/mv...not found
Checking for program /bin/mv...found
              Defined make macro "MV" to "/bin/mv"
Checking for program /usr/lib/mutt/cp...not found
Checking for program /home/tisaac/.local/bin/cp...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/cp...not found
Checking for program /home/tisaac/.bin/cp...not found
Checking for program /usr/lib/lightdm/lightdm/cp...not found
Checking for program /usr/local/sbin/cp...not found
Checking for program /usr/local/bin/cp...not found
Checking for program /usr/sbin/cp...not found
Checking for program /usr/bin/cp...not found
Checking for program /sbin/cp...not found
Checking for program /bin/cp...found
              Defined make macro "CP" to "/bin/cp"
Checking for program /usr/lib/mutt/grep...not found
Checking for program /home/tisaac/.local/bin/grep...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/grep...not found
Checking for program /home/tisaac/.bin/grep...not found
Checking for program /usr/lib/lightdm/lightdm/grep...not found
Checking for program /usr/local/sbin/grep...not found
Checking for program /usr/local/bin/grep...not found
Checking for program /usr/sbin/grep...not found
Checking for program /usr/bin/grep...not found
Checking for program /sbin/grep...not found
Checking for program /bin/grep...found
              Defined make macro "GREP" to "/bin/grep"
Checking for program /usr/lib/mutt/rm...not found
Checking for program /home/tisaac/.local/bin/rm...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/rm...not found
Checking for program /home/tisaac/.bin/rm...not found
Checking for program /usr/lib/lightdm/lightdm/rm...not found
Checking for program /usr/local/sbin/rm...not found
Checking for program /usr/local/bin/rm...not found
Checking for program /usr/sbin/rm...not found
Checking for program /usr/bin/rm...not found
Checking for program /sbin/rm...not found
Checking for program /bin/rm...found
              Defined make macro "RM" to "/bin/rm -f"
Checking for program /usr/lib/mutt/diff...not found
Checking for program /home/tisaac/.local/bin/diff...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/diff...not found
Checking for program /home/tisaac/.bin/diff...not found
Checking for program /usr/lib/lightdm/lightdm/diff...not found
Checking for program /usr/local/sbin/diff...not found
Checking for program /usr/local/bin/diff...not found
Checking for program /usr/sbin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/tmp/petsc-W4It8W/config.programs/diff1" "/tmp/petsc-W4It8W/config.programs/diff2"
            Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /home/tisaac/ps...not found
Checking for program /home/tisaac/Projects/petsc/bin/win32fe/ps...not found
Checking for program /usr/lib/mutt/gzip...not found
Checking for program /home/tisaac/.local/bin/gzip...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/gzip...not found
Checking for program /home/tisaac/.bin/gzip...not found
Checking for program /usr/lib/lightdm/lightdm/gzip...not found
Checking for program /usr/local/sbin/gzip...not found
Checking for program /usr/local/bin/gzip...not found
Checking for program /usr/sbin/gzip...not found
Checking for program /usr/bin/gzip...not found
Checking for program /sbin/gzip...not found
Checking for program /bin/gzip...found
              Defined make macro "GZIP" to "/bin/gzip"
            Defined "HAVE_GZIP" to "1"
            Defined make macro "PYTHON" to "/usr/bin/python"
TEST configureMake from config.packages.make(/home/tisaac/Projects/petsc/config/BuildSystem/config/packages/make.py:82)
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:82)
  Check for user specified make - or gmake, make
Checking for program /usr/lib/mutt/gmake...not found
Checking for program /home/tisaac/.local/bin/gmake...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/gmake...not found
Checking for program /home/tisaac/.bin/gmake...not found
Checking for program /usr/lib/lightdm/lightdm/gmake...not found
Checking for program /usr/local/sbin/gmake...not found
Checking for program /usr/local/bin/gmake...not found
Checking for program /usr/sbin/gmake...not found
Checking for program /usr/bin/gmake...not found
Checking for program /sbin/gmake...not found
Checking for program /bin/gmake...not found
Checking for program /usr/games/gmake...not found
Checking for program /home/tisaac/gmake...not found
Checking for program /home/tisaac/Projects/petsc/bin/win32fe/gmake...not found
Checking for program /usr/lib/mutt/make...not found
Checking for program /home/tisaac/.local/bin/make...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/make...not found
Checking for program /home/tisaac/.bin/make...not found
Checking for program /usr/lib/lightdm/lightdm/make...not found
Checking for program /usr/local/sbin/make...not found
Checking for program /usr/local/bin/make...not found
Checking for program /usr/sbin/make...not found
Checking for program /usr/bin/make...found
              Defined make macro "MAKE" to "/usr/bin/make"
Executing: /usr/bin/make --version
stdout:
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for x86_64-pc-linux-gnu
TEST configureCheckGNUMake from config.packages.make(/home/tisaac/Projects/petsc/config/BuildSystem/config/packages/make.py:119)
TESTING: configureCheckGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:119)
  Setup other GNU make stuff
stdout:
GNU Make 3.81
PARTICULAR PURPOSE.
            Defined make macro "MAKE_IS_GNUMAKE" to "1"
            Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
            Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
            Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
            Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
TEST configureMakeNP from config.packages.make(/home/tisaac/Projects/petsc/config/BuildSystem/config/packages/make.py:157)
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:157)
  check no of cores on the build machine [perhaps to do make '-j ncores']
          module multiprocessing found 4 cores: using make_np = 4
            Defined make macro "MAKE_NP" to "4"
            Defined make macro "NPMAX" to "4"
        Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/make  --print-directory"
        Defined make macro "OMAKE" to "/usr/bin/make  --no-print-directory"
        Defined make macro "MAKE_PAR_OUT_FLG" to ""
TEST alternateConfigureLibrary from config.packages.OpenMPI(/home/tisaac/Projects/petsc/config/BuildSystem/config/package.py:755)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:755)
  Called if --with-packagename=0; does nothing by default
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
          Pushing language C
TEST configureLibrary from config.packages.MPICH(/home/tisaac/Projects/petsc/config/BuildSystem/config/package.py:692)
TESTING: configureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:692)
  Find an installation and check if it can work with PETSc
            Checking for a functional MPICH
Executing: uname -s
stdout: Linux
                    Looking for MPICH at git.mpich, hg.mpich or a directory starting with mpich
                    Could not locate an existing copy of MPICH:
                    Downloading MPICH
                            Trying to download http://www.mpich.org/static/downloads/3.1.3/mpich-3.1.3.tar.gz for MPICH
                      Downloading http://www.mpich.org/static/downloads/3.1.3/mpich-3.1.3.tar.gz to /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/_d_mpich-3.1.3.tar.gz
                      Extracting /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/_d_mpich-3.1.3.tar.gz
Executing: cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages; chmod -R a+r mpich-3.1.3;find  mpich-3.1.3 -type d -name "*" -exec chmod a+rx {} \;
                      Found a copy of MPICH in mpich-3.1.3
                            Pushing language C
                                All intermediate test results are stored in /tmp/petsc-W4It8W/config.packages.MPICH
                            Popping language C
                            Pushing language FC
Executing: gfortran -v
                            Popping language FC
                          Removing configure arguments ['--disable-f90', '--enable-f90']
                            Removing configure arguments ['F90="gfortran"', 'F90FLAGS="-fPIC -ffree-line-length-0 -g"']
Have to rebuild MPICH, /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/mpich.petscconf != /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/petsc/conf/pkg.conf.mpich
                              Running configure on MPICH; this may take several minutes
Executing: cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3 && ./configure --prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich MAKE=/usr/bin/make --libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib CC="gcc" CFLAGS="-fPIC -g3" AR="/usr/bin/ar" ARFLAGS="cr" CXX="g++" CXXFLAGS="-g -fPIC" F77="gfortran" FFLAGS="-fPIC -ffree-line-length-0 -g" FC="gfortran" FCFLAGS="-fPIC -ffree-line-length-0 -g" --enable-shared --with-device=ch3:sock --with-pm=hydra --enable-fast=no --enable-g=meminit
stdout:
Configuring MPICH version 3.1.3 with  '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich' 'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit'
Running on system: Linux alembic 3.2.0-115-generic #157-Ubuntu SMP Tue Oct 25 16:32:19 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking how to run the C preprocessor... gcc -E
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether /usr/bin/make sets $(MAKE)... yes
checking for style of include used by /usr/bin/make... GNU
checking whether /usr/bin/make supports nested variables... yes
checking dependency style of gcc... gcc3
checking whether to enable maintainer-specific portions of Makefiles... yes
checking the archiver (/usr/bin/ar) interface... ar
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether /usr/bin/make supports nested variables... (cached) yes
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking if gfortran supports -c -o file.o... (cached) yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether we are using the GNU Fortran 77 compiler... yes
checking hcoll/api/hcoll_api.h usability... no
checking hcoll/api/hcoll_api.h presence... no
checking for hcoll/api/hcoll_api.h... no
checking for hcoll_init in -lhcoll... no
checking for getpagesize... yes
checking for getpagesize... (cached) yes
configure: RUNNING PREREQ FOR ch3:sock
configure: ===== configuring src/mpl =====
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich'  'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3  ' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC ' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g ' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g ' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for inline... inline
checking for variable argument list macro functionality... yes
checking for gcov... gcov
checking whether the compiler supports __typeof(variable)... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking for sys/uio.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... yes
checking valgrind/valgrind.h presence... yes
checking for valgrind/valgrind.h... yes
checking valgrind/memcheck.h usability... yes
checking valgrind/memcheck.h presence... yes
checking for valgrind/memcheck.h... yes
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... yes
checking valgrind/helgrind.h presence... yes
checking for valgrind/helgrind.h... yes
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... yes
checking valgrind/drd.h presence... yes
checking for valgrind/drd.h... yes
checking whether the valgrind headers are broken or too old... no
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
configure: ===== done with src/mpl configure =====
configure: sourcing src/mpl/localdefs
configure: ===== configuring src/openpa =====
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich' --with-atomic-primitives=auto_allow_emulation 'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3  ' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC ' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g ' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g ' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
checking for gcc... gcc
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 8
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc ARM atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
configure: ===== done with src/openpa configure =====
sourcing /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/mpichprereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O0... yes
checking whether C compiler option -O0 works with an invalid prototype program... yes
checking whether routines compiled with -O0 can be linked with ones compiled without -O0... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... yes
checking for multiple weak symbol support... yes
checking for shared library (esp. rpath) characteristics of CC... done (results in src/env/cc_shlib.conf)
checking whether Fortran 77 compiler accepts option -O0... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lgfortran -lm -lquadmath
checking whether gfortran accepts the FLIBS found by autoconf... yes
checking whether gcc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... yes
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower uscore
checking for libraries to link Fortran main with C stdio routines... none
checking whether Fortran init will work with C... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (gfortran -fPIC -ffree-line-length-0 -g   ) works... yes
checking whether the Fortran 90 compiler (gfortran -fPIC -ffree-line-length-0 -g   ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking for shared library (esp. rpath) characteristics of F77... done (results in src/env/f77_shlib.conf)
checking whether Fortran 77 accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether gfortran allows mismatched arguments... yes
checking for Fortran 2008 support... no
checking for shared library (esp. rpath) characteristics of FC... done (results in src/env/fc_shlib.conf)
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking for Fortran 90 module output directory flag... -J
checking whether Fortran 90 compiler accepts option -O0... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking whether the C++ compiler g++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 6
checking for shared library (esp. rpath) characteristics of CXX... done (results in src/env/cxx_shlib.conf)
checking whether C++ compiler accepts option -O0... yes
checking for perl... /usr/bin/perl
checking for ar... /usr/bin/ar
checking for killall... killall
checking whether install works... yes
checking whether mkdir -p works... yes
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /bin/bash
checking whether /bin/bash supports arrays... yes
checking for doctext... false
checking for working volatile... yes
checking if C compiler supports __builtin_expect... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... sixteen
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... sixteen
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 8
checking size of unsigned long... 8
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 16
checking for ANSI C header files... (cached) yes
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 16
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 32
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 32
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... yes
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran real... float
checking for C type matching Fortran double... double
checking for C type matching Fortran integer... int
checking for values of Fortran logicals... True is 1 and False is 0
checking for Fortran 90 integer kind for 8-byte integers... 8
checking for Fortran 90 integer kind for 4-byte integers... 4
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 32
checking for alignment restrictions on int64_t... no
checking for alignment restrictions on int32_t... no
checking for gcc __asm__ and pentium cmpxchgl instruction... no
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... yes
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
checking size of MPIR_Bsend_data_t... 96
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking whether pthread_mutexattr_settype needs a declaration... no
checking for thread local storage specifier... __thread
checking for getpid... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking whether usleep needs a declaration... no
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: RUNNING CONFIGURE FOR F90 CODE
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
checking for sys/socket.h... (cached) yes
checking for strings.h... (cached) yes
checking for assert.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for snprintf... (cached) yes
checking whether snprintf needs a declaration... (cached) no
checking for strncasecmp... (cached) yes
checking for sys/param.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
checking whether struct hostent contains h_addr_list... yes
checking whether __attribute__ allowed... (cached) yes
checking whether __attribute__((format)) allowed... (cached) yes
configure: RUNNING CONFIGURE FOR CH3 DEVICE
checking for limits.h... (cached) yes
checking for sys/uio.h... (cached) yes
checking uuid/uuid.h usability... no
checking uuid/uuid.h presence... no
checking for uuid/uuid.h... no
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for arpa/inet.h... (cached) yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking for OpenPA atomic primitive availability... yes
checking whether byte ordering is bigendian... (cached) no
configure: RUNNING CONFIGURE FOR ch3:sock
checking for netdb.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking for errno.h... (cached) yes
checking for netinet/in.h... (cached) yes
configure: RUNNING CONFIGURE FOR src/mpid/common/sock
checking for strerror... (cached) yes
configure: RUNNING CONFIGURE FOR src/mpid/common/sock/poll
checking for poll... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for netinet/tcp.h... (cached) yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking if struct poll is defined... yes
checking if a simple program using poll() can be compiled... yes
checking whether bit fields work in ip.h... yes
checking for gethostname... (cached) yes
checking whether gethostname needs a declaration... (cached) no
checking for library containing socket... (cached) none required
checking for library containing gethostbyname... (cached) none required
checking whether socklen_t is defined (in sys/socket.h if present)... (cached) yes
configure: RUNNING CONFIGURE FOR CH3U SOCK CODE
checking for time.h... (cached) yes
checking for ctype.h... (cached) yes
checking for net/if.h... (cached) yes
checking for pid_t... (cached) yes
checking for inet_pton... (cached) yes
checking whether we can use struct ifconf... yes
configure: ===== configuring src/mpid/common/sock =====
configure: ===== done with src/mpid/common/sock configure =====
configure: ===== configuring src/mpi/romio =====
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich'  'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3   -O0' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC  -O0' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g  -O0' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g  -O0' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
checking for a thread-safe mkdir -p... mkdir -p
checking for ld used by gcc... /usr/bin/ld -m elf_x86_64
checking for /usr/bin/ld -m elf_x86_64 option to reload object files... -r
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64 -m elf_x86_64) supports shared libraries... yes
Configuring with args dummy mt
checking for architecture... LINUX
ROMIO home directory is /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64 -m elf_x86_64) supports shared libraries... yes
checking for long long... yes
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking for ssize_t... yes
checking for off_t... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for mpix.h... no
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... no
checking size of long long... (cached) 8
checking for Fortran 90 KIND parameter for 8-byte integers...            8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
checking gpfs.h usability... no
checking gpfs.h presence... no
checking for gpfs.h... no
checking gpfs_fcntl.h usability... no
checking gpfs_fcntl.h presence... no
checking for gpfs_fcntl.h... no
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking for statfs... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for blksize_t... yes
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to gfortran
setting TEST_CC to $(bindir)/mpicc
setting TEST_F77 to $(bindir)/mpifort
setting CFLAGS to -fPIC -g3   -O0  -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating adio/include/romioconf.h
config.status: executing default-1 commands
configure: ===== done with src/mpi/romio configure =====
configure: sourcing src/mpi/romio/localdefs
configure: ===== configuring src/pm/hydra =====
checking target system type... x86_64-unknown-linux-gnu
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for doxygen... /usr/bin/doxygen
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for library containing hstrerror... none required
checking for sigaction... yes
checking for signal... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for fcntl... yes
checking for isatty... yes
checking for inet_ntop... yes
checking for getpgid... yes
checking for setsid... yes
checking for killpg... yes
checking whether gettimeofday needs a declaration... no
checking whether getpgid needs a declaration... no
checking whether killpg needs a declaration... no
checking for environ in unistd.h... yes
checking bootstrap server... user,ssh,rsh,fork,slurm,ll,lsf,sge,pbs,cobalt,manual,persist
checking tm.h usability... no
checking tm.h presence... no
checking for tm.h... no
checking for tm_init in -ltorque... no
checking process manager... pmiserv
checking user interface... mpich
checking desired processor topology libraries... hwloc
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for X... libraries , headers
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc
configure: hwloc srcdir: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... tools/topo/hwloc/hwloc/
checking for hwloc symbol prefix... hwloc_
checking which OS support to include... Linux
checking which CPU support to include... x86_64
checking size of unsigned long... (cached) 8
checking for the C compiler vendor... gnu
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... yes
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... yes
checking for __attribute__(hot)... yes
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... yes
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... yes
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking if gcc supports -fvisibility=hidden... yes
checking whether to enable symbol visibility... yes (via -fvisibility=hidden)
checking whether the C compiler rejects function calls with too many arguments... yes
checking whether the C compiler rejects function calls with too few arguments... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... no
checking for windows.h... (cached) no
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether fabsf is declared... yes
checking for fabsf in -lm... yes
checking picl.h usability... no
checking picl.h presence... no
checking for picl.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_PAGESIZE is declared... yes
checking whether _SC_PAGE_SIZE is declared... yes
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... yes
checking whether CTL_HW is declared... no
checking whether HW_NCPU is declared... no
checking whether strtoull is declared... yes
checking for pthread_t... yes
checking whether function sched_setaffinity is declared... yes
checking for old prototype of sched_setaffinity... no
checking for working CPU_SET... yes
checking for working CPU_SET_S... yes
checking for working _syscall3... no
checking for KERRIGHED... no
checking for lib... no
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... yes
checking whether function ffsl is declared... yes
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... yes
checking whether pthread_getaffinity_np is declared... yes
checking for sys/cpuset.h... no
checking for cpuset_setaffinity... no
checking for library containing pthread_getthrds_np... no
checking for cpuset_setid... no
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking for PCIACCESS... no
checking for PCIUTILS... no
checking pci/pci.h usability... no
checking pci/pci.h presence... no
checking for pci/pci.h... no
checking CL/cl_ext.h usability... no
checking CL/cl_ext.h presence... no
checking for CL/cl_ext.h... no
checking cuda.h usability... no
checking cuda.h presence... no
checking for cuda.h... no
checking cuda_runtime_api.h usability... no
checking cuda_runtime_api.h presence... no
checking for cuda_runtime_api.h... no
checking nvml.h usability... no
checking nvml.h presence... no
checking for nvml.h... no
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking X11/Xlib.h usability... yes
checking X11/Xlib.h presence... yes
checking for X11/Xlib.h... yes
checking for XOpenDisplay in -lX11... yes
checking X11/Xutil.h usability... yes
checking X11/Xutil.h presence... yes
checking for X11/Xutil.h... yes
checking X11/keysym.h usability... yes
checking X11/keysym.h presence... yes
checking for X11/keysym.h... yes
checking NVCtrl/NVCtrl.h usability... no
checking NVCtrl/NVCtrl.h presence... no
checking for NVCtrl/NVCtrl.h... no
checking for LIBXML2... yes
checking for xmlNewDoc... yes
checking for final LIBXML2 support... yes
checking for x86 cpuid... yes
checking for pthread_mutex_lock... yes
checking if plugin support is enabled... no
checking components to build statically...  noos xml synthetic custom xml_nolibxml linux linuxpci xml_libxml x86
checking components to build as plugins...
checking available processor topology libraries... hwloc
checking checkpointing library... blcr
checking libcr.h usability... no
checking libcr.h presence... no
checking for libcr.h... no
checking for cr_init in -lcr... no
checking demux engine... poll,select,port
checking debugging support... meminit
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/topo/hwloc/hwloc/Makefile
config.status: creating tools/topo/hwloc/hwloc/include/Makefile
config.status: creating tools/topo/hwloc/hwloc/src/Makefile
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
config.status: creating tools/topo/hwloc/hwloc/include/private/autogen/config.h
config.status: creating tools/topo/hwloc/hwloc/include/hwloc/autogen/config.h
configure: ===== done with src/pm/hydra configure =====
checking size of OPA_ptr_t... 8
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran 77... yes
checking whether the Fortran Offset type works with Fortran 90... yes
checking for size of MPI_Status... 20
checking for BSD/POSIX style global symbol lister... BSD style,/usr/bin/nm -g -B
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 16
checking the minimum alignment of Fortran common block of 5 integers... 16, too small! reset to 32
configure: creating ./config.lt
config.lt: creating libtool
config.status: creating src/binding/fortran/use_mpi/mpif90model.h
config.status: creating examples/Makefile
config.status: creating test/commands/Makefile
config.status: creating src/include/mpichinfo.h
config.status: creating mpich-doxygen
config.status: creating src/include/glue_romio.h
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/fortran/mpif_h/mpif.h
config.status: creating src/binding/fortran/mpif_h/setbotf.f
config.status: creating src/binding/fortran/mpif_h/setbot.c
config.status: creating src/binding/fortran/use_mpi/mpi_sizeofs.f90
config.status: creating src/binding/fortran/use_mpi/mpi_base.f90
config.status: creating src/binding/fortran/use_mpi/mpi_constants.f90
config.status: creating src/packaging/pkgconfig/mpich.pc
config.status: creating src/packaging/envmods/mpich.module
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc.sh
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx.sh
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77.sh
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpifort.sh
config.status: creating src/env/mpifort.bash
config.status: creating src/env/parkill
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/include/mpi.h
config.status: creating doc/design/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/refman/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating test/commands/cmdtests
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
=== configuring in test/mpi (/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich'  'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking for library containing pthread_create... -lpthread
checking for library containing pthread_barrier_init... none required
checking for pthread_create... yes
checking for pthread_barrier_init... yes
checking for pthread_barrier_wait... yes
checking for getrusage... yes
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lpthread -lgfortran -lm -lquadmath
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... yes
checking for Fortran 77 compiler flag for Cray-style pointer... -fcray-pointer
checking for Fortran flag needed to accept free-form source... none
checking whether Fortran 90 supports Cray-style pointer... yes
checking for Fortran 90 compiler flag for Cray-style pointer... -fcray-pointer
checking whether gfortran supports the Fortran 2003 routines to access the commandline... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of void *... (cached) 8
checking for C integer type of address size... long
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating checktests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating util/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating datatype/testlist
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating mpi_t/Makefile
config.status: creating rma/Makefile
config.status: creating rma/testlist
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/testlist
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f77/profile/Makefile
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/spawn/testlist
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating f90/profile/Makefile
config.status: creating f08/Makefile
config.status: creating f08/attr/Makefile
config.status: creating f08/datatype/Makefile
config.status: creating f08/util/Makefile
config.status: creating f08/coll/Makefile
config.status: creating f08/comm/Makefile
config.status: creating f08/pt2pt/Makefile
config.status: creating f08/rma/Makefile
config.status: creating f08/subarray/Makefile
config.status: creating f08/topo/Makefile
config.status: creating f08/io/Makefile
config.status: creating f08/init/Makefile
config.status: creating f08/info/Makefile
config.status: creating f08/spawn/Makefile
config.status: creating f08/timer/Makefile
config.status: creating f08/ext/Makefile
config.status: creating f08/misc/Makefile
config.status: creating f08/profile/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating cxx/topo/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/mpi_t/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating threads/rma/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/datatype/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f77/io/Makefile
config.status: creating errors/f77/io/addsize.h
config.status: creating errors/f77/io/iooffset.h
config.status: creating errors/f90/Makefile
config.status: creating errors/f90/io/Makefile
config.status: creating errors/f08/Makefile
config.status: creating errors/f08/io/Makefile
config.status: creating ckpoint/Makefile
config.status: creating ft/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating manual/mpi_t/Makefile
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating cxx/topo/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating errors/f77/testlist
config.status: creating errors/f90/testlist
config.status: creating impls/testlist
config.status: creating impls/Makefile
config.status: creating impls/hydra/Makefile
config.status: creating impls/hydra/proc_binding.sh
config.status: creating impls/mpich/Makefile
config.status: creating impls/mpich/testlist
config.status: creating impls/mpich/mpi_t/Makefile
config.status: creating include/mpitestconf.h
Configuration completed.
                              Running make on MPICH; this may take several minutes
Executing: cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3 && /usr/bin/make clean
stdout:
Making clean in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
 rm -f strsep
rm -rf .libs _libs
rm -rf src/.libs src/_libs
test -z "libmpl.la" || rm -f libmpl.la
rm -f ./so_locations
rm -f *.o
rm -f src/*.o
rm -f src/*.lo
rm -f test/*.o
test -z "strsep.log" || rm -f strsep.log
test -z "strsep.trs" || rm -f strsep.trs
test -z "test-suite.log" || rm -f test-suite.log
rm -f *.lo
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making clean in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making clean in src
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
rm -rf .libs _libs
test -z "libopa.la" || rm -f libopa.la
rm -f *.o
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
Making clean in test
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
 rm -f sanity test_primitives test_barriers test_queue
rm -rf .libs _libs
rm -f *.o
test -z "sanity.log test_primitives.log test_barriers.log test_queue.log" || rm -f sanity.log test_primitives.log test_barriers.log test_queue.log
test -z "sanity.trs test_primitives.trs test_barriers.trs test_queue.trs" || rm -f sanity.trs test_primitives.trs test_barriers.trs test_queue.trs
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
rm -rf .libs _libs
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making clean in src/mpi/romio
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
test -z "" || rm -f
rm -rf .libs _libs
rm -rf adio/ad_gpfs/.libs adio/ad_gpfs/_libs
rm -rf adio/ad_gpfs/bg/.libs adio/ad_gpfs/bg/_libs
rm -rf adio/ad_gpfs/pe/.libs adio/ad_gpfs/pe/_libs
rm -rf adio/ad_gridftp/.libs adio/ad_gridftp/_libs
rm -rf adio/ad_hfs/.libs adio/ad_hfs/_libs
rm -rf adio/ad_lustre/.libs adio/ad_lustre/_libs
rm -rf adio/ad_nfs/.libs adio/ad_nfs/_libs
rm -rf adio/ad_panfs/.libs adio/ad_panfs/_libs
rm -rf adio/ad_pfs/.libs adio/ad_pfs/_libs
rm -rf adio/ad_piofs/.libs adio/ad_piofs/_libs
rm -rf adio/ad_pvfs/.libs adio/ad_pvfs/_libs
rm -rf adio/ad_pvfs2/.libs adio/ad_pvfs2/_libs
rm -rf adio/ad_sfs/.libs adio/ad_sfs/_libs
rm -rf adio/ad_testfs/.libs adio/ad_testfs/_libs
rm -rf adio/ad_ufs/.libs adio/ad_ufs/_libs
rm -rf adio/ad_xfs/.libs adio/ad_xfs/_libs
rm -rf adio/ad_zoidfs/.libs adio/ad_zoidfs/_libs
rm -rf adio/common/.libs adio/common/_libs
rm -rf mpi-io/.libs mpi-io/_libs
rm -rf mpi-io/fortran/.libs mpi-io/fortran/_libs
rm -rf mpi-io/glue/.libs mpi-io/glue/_libs
rm -rf mpi-io/glue/default/.libs mpi-io/glue/default/_libs
rm -rf mpi-io/glue/mpich/.libs mpi-io/glue/mpich/_libs
test -z "libromio.la " || rm -f libromio.la
rm -f *.o
rm -f adio/ad_gpfs/*.o
rm -f adio/ad_gpfs/*.lo
rm -f adio/ad_gpfs/bg/*.o
rm -f adio/ad_gpfs/bg/*.lo
rm -f adio/ad_gpfs/pe/*.o
rm -f adio/ad_gpfs/pe/*.lo
rm -f adio/ad_gridftp/*.o
rm -f adio/ad_gridftp/*.lo
rm -f adio/ad_hfs/*.o
rm -f adio/ad_hfs/*.lo
rm -f adio/ad_lustre/*.o
rm -f adio/ad_lustre/*.lo
rm -f adio/ad_nfs/*.o
rm -f adio/ad_nfs/*.lo
rm -f adio/ad_panfs/*.o
rm -f adio/ad_panfs/*.lo
rm -f adio/ad_pfs/*.o
rm -f adio/ad_pfs/*.lo
rm -f adio/ad_piofs/*.o
rm -f adio/ad_piofs/*.lo
rm -f adio/ad_pvfs/*.o
rm -f adio/ad_pvfs/*.lo
rm -f adio/ad_pvfs2/*.o
rm -f adio/ad_pvfs2/*.lo
rm -f adio/ad_sfs/*.o
rm -f adio/ad_sfs/*.lo
rm -f adio/ad_testfs/*.o
rm -f adio/ad_testfs/*.lo
rm -f adio/ad_ufs/*.o
rm -f adio/ad_ufs/*.lo
rm -f adio/ad_xfs/*.o
rm -f adio/ad_xfs/*.lo
rm -f adio/ad_zoidfs/*.o
rm -f adio/ad_zoidfs/*.lo
rm -f adio/common/*.o
rm -f adio/common/*.lo
rm -f mpi-io/*.o
rm -f mpi-io/*.lo
rm -f mpi-io/fortran/*.o
rm -f mpi-io/fortran/*.lo
rm -f mpi-io/glue/*.o
rm -f mpi-io/glue/*.lo
rm -f mpi-io/glue/default/*.o
rm -f mpi-io/glue/default/*.lo
rm -f mpi-io/glue/mpich/*.o
rm -f mpi-io/glue/mpich/*.lo
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
Making clean in src/pm/hydra
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making clean in ../../mpl
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f src/*.o
rm -f src/*.lo
rm -f test/*.o
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making clean in tools/topo/hwloc/hwloc
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making clean in src
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
test -z "" || rm -f
test -z "" || rm -f
rm -rf .libs _libs
test -z "libhwloc_embedded.la" || rm -f libhwloc_embedded.la
test -z "     " || rm -f
rm -f *.o
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
Making clean in include
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
rm -rf .libs _libs
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
rm -rf .libs _libs
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making clean in .
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
 rm -f hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra
rm -rf .libs _libs
rm -rf pm/pmiserv/.libs pm/pmiserv/_libs
rm -rf tools/bootstrap/external/.libs tools/bootstrap/external/_libs
rm -rf tools/bootstrap/persist/.libs tools/bootstrap/persist/_libs
rm -rf tools/bootstrap/src/.libs tools/bootstrap/src/_libs
rm -rf tools/bootstrap/utils/.libs tools/bootstrap/utils/_libs
rm -rf tools/ckpoint/.libs tools/ckpoint/_libs
rm -rf tools/ckpoint/blcr/.libs tools/ckpoint/blcr/_libs
rm -rf tools/debugger/.libs tools/debugger/_libs
rm -rf tools/demux/.libs tools/demux/_libs
rm -rf tools/ftb/.libs tools/ftb/_libs
rm -rf tools/topo/.libs tools/topo/_libs
rm -rf tools/topo/hwloc/.libs tools/topo/hwloc/_libs
rm -rf ui/utils/.libs ui/utils/_libs
rm -rf utils/alloc/.libs utils/alloc/_libs
rm -rf utils/args/.libs utils/args/_libs
rm -rf utils/dbg/.libs utils/dbg/_libs
rm -rf utils/env/.libs utils/env/_libs
rm -rf utils/launch/.libs utils/launch/_libs
rm -rf utils/others/.libs utils/others/_libs
rm -rf utils/signals/.libs utils/signals/_libs
rm -rf utils/sock/.libs utils/sock/_libs
rm -rf utils/string/.libs utils/string/_libs
test -z "libhydra.la libpm.la" || rm -f libhydra.la libpm.la
rm -f *.o
rm -f pm/pmiserv/*.o
rm -f pm/pmiserv/*.lo
rm -f tools/bootstrap/external/*.o
rm -f tools/bootstrap/external/*.lo
rm -f tools/bootstrap/persist/*.o
rm -f tools/bootstrap/persist/*.lo
rm -f tools/bootstrap/src/*.o
rm -f tools/bootstrap/src/*.lo
rm -f tools/bootstrap/utils/*.o
rm -f tools/bootstrap/utils/*.lo
rm -f tools/ckpoint/*.o
rm -f tools/ckpoint/*.lo
rm -f tools/ckpoint/blcr/*.o
rm -f tools/ckpoint/blcr/*.lo
rm -f tools/debugger/*.o
rm -f tools/debugger/*.lo
rm -f tools/demux/*.o
rm -f tools/demux/*.lo
rm -f tools/ftb/*.o
rm -f tools/ftb/*.lo
rm -f tools/nameserver/*.o
rm -f tools/topo/*.o
rm -f tools/topo/*.lo
rm -f tools/topo/hwloc/*.o
rm -f tools/topo/hwloc/*.lo
rm -f ui/mpich/*.o
rm -f ui/utils/*.o
rm -f ui/utils/*.lo
rm -f utils/alloc/*.o
rm -f utils/alloc/*.lo
rm -f utils/args/*.o
rm -f utils/args/*.lo
rm -f utils/dbg/*.o
rm -f utils/dbg/*.lo
rm -f utils/env/*.o
rm -f utils/env/*.lo
rm -f utils/launch/*.o
rm -f utils/launch/*.lo
rm -f utils/others/*.o
rm -f utils/others/*.lo
rm -f utils/signals/*.o
rm -f utils/signals/*.lo
rm -f utils/sock/*.o
rm -f utils/sock/*.lo
rm -f utils/string/*.o
rm -f utils/string/*.lo
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making clean in .
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
 rm -f src/env/mpichversion src/env/mpivars
test -z "src/binding/fortran/use_mpi/mpi.mod-stamp src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi.lo src/binding/fortran/use_mpi/mpi-tmp src/binding/fortran/use_mpi/mpi_constants.mod-stamp src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_constants.lo src/binding/fortran/use_mpi/mpi_constants-tmp src/binding/fortran/use_mpi/mpi_sizeofs.mod-stamp src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_sizeofs.lo src/binding/fortran/use_mpi/mpi_sizeofs-tmp src/binding/fortran/use_mpi/mpi_base.mod-stamp src/binding/fortran/use_mpi/mpi_base.mod src/binding/fortran/use_mpi/mpi_base.lo src/binding/fortran/use_mpi/mpi_base-tmp src/binding/fortran/use_mpi/mpifnoext.h src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod  " || rm -f src/binding/fortran/use_mpi/mpi.mod-stamp src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi.lo src/binding/fortran/use_mpi/mpi-tmp src/binding/fortran/use_mpi/mpi_constants.mod-stamp src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_constants.lo src/binding/fortran/use_mpi/mpi_constants-tmp src/binding/fortran/use_mpi/mpi_sizeofs.mod-stamp src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_sizeofs.lo src/binding/fortran/use_mpi/mpi_sizeofs-tmp src/binding/fortran/use_mpi/mpi_base.mod-stamp src/binding/fortran/use_mpi/mpi_base.mod src/binding/fortran/use_mpi/mpi_base.lo src/binding/fortran/use_mpi/mpi_base-tmp src/binding/fortran/use_mpi/mpifnoext.h src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod
test -z "   lib/libmpi.la lib/libmpifort.la lib/libmpicxx.la" || rm -f    lib/libmpi.la lib/libmpifort.la lib/libmpicxx.la
rm -f lib/so_locations
rm -rf .libs _libs
rm -rf lib/.libs lib/_libs
rm -rf src/binding/cxx/.libs src/binding/cxx/_libs
rm -rf src/binding/fortran/mpif_h/.libs src/binding/fortran/mpif_h/_libs
rm -rf src/binding/fortran/use_mpi/.libs src/binding/fortran/use_mpi/_libs
rm -rf src/binding/fortran/use_mpi_f08/.libs src/binding/fortran/use_mpi_f08/_libs
rm -rf src/binding/fortran/use_mpi_f08/wrappers_c/.libs src/binding/fortran/use_mpi_f08/wrappers_c/_libs
rm -rf src/binding/fortran/use_mpi_f08/wrappers_f/.libs src/binding/fortran/use_mpi_f08/wrappers_f/_libs
rm -rf src/binding/fortran/use_mpi_f08/wrappers_f/profiling/.libs src/binding/fortran/use_mpi_f08/wrappers_f/profiling/_libs
rm -rf src/env/.libs src/env/_libs
rm -rf src/glue/romio/.libs src/glue/romio/_libs
rm -rf src/mpi/attr/.libs src/mpi/attr/_libs
rm -rf src/mpi/coll/.libs src/mpi/coll/_libs
rm -rf src/mpi/comm/.libs src/mpi/comm/_libs
rm -rf src/mpi/datatype/.libs src/mpi/datatype/_libs
rm -rf src/mpi/debugger/.libs src/mpi/debugger/_libs
rm -rf src/mpi/errhan/.libs src/mpi/errhan/_libs
rm -rf src/mpi/group/.libs src/mpi/group/_libs
rm -rf src/mpi/info/.libs src/mpi/info/_libs
rm -rf src/mpi/init/.libs src/mpi/init/_libs
rm -rf src/mpi/misc/.libs src/mpi/misc/_libs
rm -rf src/mpi/pt2pt/.libs src/mpi/pt2pt/_libs
rm -rf src/mpi/rma/.libs src/mpi/rma/_libs
rm -rf src/mpi/spawn/.libs src/mpi/spawn/_libs
rm -rf src/mpi/timer/.libs src/mpi/timer/_libs
rm -rf src/mpi/topo/.libs src/mpi/topo/_libs
rm -rf src/mpi_t/.libs src/mpi_t/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/ib/.libs src/mpid/ch3/channels/nemesis/netmod/ib/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/mx/.libs src/mpid/ch3/channels/nemesis/netmod/mx/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/mxm/.libs src/mpid/ch3/channels/nemesis/netmod/mxm/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/newmad/.libs src/mpid/ch3/channels/nemesis/netmod/newmad/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/none/.libs src/mpid/ch3/channels/nemesis/netmod/none/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/portals4/.libs src/mpid/ch3/channels/nemesis/netmod/portals4/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/scif/.libs src/mpid/ch3/channels/nemesis/netmod/scif/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/tcp/.libs src/mpid/ch3/channels/nemesis/netmod/tcp/_libs
rm -rf src/mpid/ch3/channels/nemesis/src/.libs src/mpid/ch3/channels/nemesis/src/_libs
rm -rf src/mpid/ch3/channels/nemesis/utils/monitor/.libs src/mpid/ch3/channels/nemesis/utils/monitor/_libs
rm -rf src/mpid/ch3/channels/nemesis/utils/replacements/.libs src/mpid/ch3/channels/nemesis/utils/replacements/_libs
rm -rf src/mpid/ch3/channels/sock/src/.libs src/mpid/ch3/channels/sock/src/_libs
rm -rf src/mpid/ch3/src/.libs src/mpid/ch3/src/_libs
rm -rf src/mpid/ch3/util/ftb/.libs src/mpid/ch3/util/ftb/_libs
rm -rf src/mpid/ch3/util/sock/.libs src/mpid/ch3/util/sock/_libs
rm -rf src/mpid/common/datatype/.libs src/mpid/common/datatype/_libs
rm -rf src/mpid/common/datatype/dataloop/.libs src/mpid/common/datatype/dataloop/_libs
rm -rf src/mpid/common/hcoll/.libs src/mpid/common/hcoll/_libs
rm -rf src/mpid/common/sched/.libs src/mpid/common/sched/_libs
rm -rf src/mpid/common/sock/poll/.libs src/mpid/common/sock/poll/_libs
rm -rf src/mpid/common/thread/.libs src/mpid/common/thread/_libs
rm -rf src/mpid/pamid/src/.libs src/mpid/pamid/src/_libs
rm -rf src/mpid/pamid/src/coll/.libs src/mpid/pamid/src/coll/_libs
rm -rf src/mpid/pamid/src/coll/allgather/.libs src/mpid/pamid/src/coll/allgather/_libs
rm -rf src/mpid/pamid/src/coll/allgatherv/.libs src/mpid/pamid/src/coll/allgatherv/_libs
rm -rf src/mpid/pamid/src/coll/allreduce/.libs src/mpid/pamid/src/coll/allreduce/_libs
rm -rf src/mpid/pamid/src/coll/alltoall/.libs src/mpid/pamid/src/coll/alltoall/_libs
rm -rf src/mpid/pamid/src/coll/alltoallv/.libs src/mpid/pamid/src/coll/alltoallv/_libs
rm -rf src/mpid/pamid/src/coll/alltoallw/.libs src/mpid/pamid/src/coll/alltoallw/_libs
rm -rf src/mpid/pamid/src/coll/barrier/.libs src/mpid/pamid/src/coll/barrier/_libs
rm -rf src/mpid/pamid/src/coll/bcast/.libs src/mpid/pamid/src/coll/bcast/_libs
rm -rf src/mpid/pamid/src/coll/exscan/.libs src/mpid/pamid/src/coll/exscan/_libs
rm -rf src/mpid/pamid/src/coll/gather/.libs src/mpid/pamid/src/coll/gather/_libs
rm -rf src/mpid/pamid/src/coll/gatherv/.libs src/mpid/pamid/src/coll/gatherv/_libs
rm -rf src/mpid/pamid/src/coll/ired_scat/.libs src/mpid/pamid/src/coll/ired_scat/_libs
rm -rf src/mpid/pamid/src/coll/ired_scat_block/.libs src/mpid/pamid/src/coll/ired_scat_block/_libs
rm -rf src/mpid/pamid/src/coll/reduce/.libs src/mpid/pamid/src/coll/reduce/_libs
rm -rf src/mpid/pamid/src/coll/scan/.libs src/mpid/pamid/src/coll/scan/_libs
rm -rf src/mpid/pamid/src/coll/scatter/.libs src/mpid/pamid/src/coll/scatter/_libs
rm -rf src/mpid/pamid/src/coll/scatterv/.libs src/mpid/pamid/src/coll/scatterv/_libs
rm -rf src/mpid/pamid/src/comm/.libs src/mpid/pamid/src/comm/_libs
rm -rf src/mpid/pamid/src/dyntask/.libs src/mpid/pamid/src/dyntask/_libs
rm -rf src/mpid/pamid/src/misc/.libs src/mpid/pamid/src/misc/_libs
rm -rf src/mpid/pamid/src/mpix/.libs src/mpid/pamid/src/mpix/_libs
rm -rf src/mpid/pamid/src/onesided/.libs src/mpid/pamid/src/onesided/_libs
rm -rf src/mpid/pamid/src/pamix/.libs src/mpid/pamid/src/pamix/_libs
rm -rf src/mpid/pamid/src/pt2pt/.libs src/mpid/pamid/src/pt2pt/_libs
rm -rf src/mpid/pamid/src/pt2pt/persistent/.libs src/mpid/pamid/src/pt2pt/persistent/_libs
rm -rf src/mutex/.libs src/mutex/_libs
rm -rf src/nameserv/file/.libs src/nameserv/file/_libs
rm -rf src/nameserv/pmi/.libs src/nameserv/pmi/_libs
rm -rf src/pm/gforker/.libs src/pm/gforker/_libs
rm -rf src/pm/remshell/.libs src/pm/remshell/_libs
rm -rf src/pmi/pmi2/poe/.libs src/pmi/pmi2/poe/_libs
rm -rf src/pmi/pmi2/simple/.libs src/pmi/pmi2/simple/_libs
rm -rf src/pmi/simple/.libs src/pmi/simple/_libs
rm -rf src/util/cvar/.libs src/util/cvar/_libs
rm -rf src/util/dbg/.libs src/util/dbg/_libs
rm -rf src/util/instrm/.libs src/util/instrm/_libs
rm -rf src/util/logging/rlog/.libs src/util/logging/rlog/_libs
rm -rf src/util/mem/.libs src/util/mem/_libs
rm -rf src/util/msgs/.libs src/util/msgs/_libs
rm -rf src/util/other/.libs src/util/other/_libs
rm -rf src/util/procmap/.libs src/util/procmap/_libs
rm -rf src/util/thread/.libs src/util/thread/_libs
( cd test && /usr/bin/make  clean )
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
Making clean in mpi
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
Making clean in util
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/util'
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/util'
Making clean in attr
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/attr'
test -z "summary.xml summary.tap summary.junit.xml" || rm -f summary.xml summary.tap summary.junit.xml
test -z "attrt attrend attrend2 attric attrerr attrerrcomm attrerrtype attrdeleteget attr2type attrorder attrordercomm attrordertype baseattr2 baseattrcomm fkeyval fkeyvalcomm fkeyvaltype keyval_double_free" || rm -f attrt attrend attrend2 attric attrerr attrerrcomm attrerrtype attrdeleteget attr2type attrorder attrordercomm attrordertype baseattr2 baseattrcomm fkeyval fkeyvalcomm fkeyvaltype keyval_double_free
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/attr'
Making clean in basic
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/basic'
test -z "self simple sendrecv srtest wtime netpipe patterns adapt" || rm -f self simple sendrecv srtest wtime netpipe patterns adapt
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/basic'
Making clean in datatype
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/datatype'
test -z "blockindexed-misc blockindexed-zero-count contents contig-zero-count contigstruct cxx-types dataalign darray-pack darray-cyclic gaddress get-elements get-elements-pairtype getpartelm hindexed-zeros hindexed_block hindexed_block_contents hvecblklen indexed-misc large-count large_type large_type_sendrec lbub localpack longdouble lots-of-types pairtype-pack pairtype-size-extent sendrecvt2 sendrecvt4 simple-commit simple-pack simple-pack-external simple-resized simple-size-extent sizedtypes slice-pack slice-pack-external struct-derived-zeros struct-empty-el struct-ezhov struct-no-real-types struct-pack structpack2 struct-verydeep struct-zero-count subarray subarray-pack tfree tmatchsize transpose-pack tresized tresized2 triangular-pack typecommit typefree typelb typename unpack unusual-noncontigs vecblklen zeroblks zeroparms" || rm -f blockindexed-misc blockindexed-zero-count contents contig-zero-count contigstruct cxx-types dataalign darray-pack darray-cyclic gaddress get-elements get-elements-pairtype getpartelm hindexed-zeros hindexed_block hindexed_block_contents hvecblklen indexed-misc large-count large_type large_type_sendrec lbub localpack longdouble lots-of-types pairtype-pack pairtype-size-extent sendrecvt2 sendrecvt4 simple-commit simple-pack simple-pack-external simple-resized simple-size-extent sizedtypes slice-pack slice-pack-external struct-derived-zeros struct-empty-el struct-ezhov struct-no-real-types struct-pack structpack2 struct-verydeep struct-zero-count subarray subarray-pack tfree tmatchsize transpose-pack tresized tresized2 triangular-pack typecommit typefree typelb typename unpack unusual-noncontigs vecblklen zeroblks zeroparms
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/datatype'
Making clean in coll
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/coll'
test -z "allgather2 allgather3 allgatherv2 allgatherv3 allgatherv4 allred allred2 allred3 allred4 allred5 allred6 allredmany alltoall1 alltoallv alltoallv0 alltoallw1 alltoallw2 alltoallw_zeros bcast2 bcast3 bcasttest bcastzerotype coll2 coll3 coll4 coll5 coll6 coll7 coll8 coll9 coll10 coll11 coll12 coll13 exscan exscan2 gather gather2 iallred ibarrier icallgather icallgatherv icallreduce icalltoall icalltoallv icalltoallw icbarrier icbcast icgather icgatherv icreduce icscatter icscatterv longuser nonblocking nonblocking2 nonblocking3 nonblocking4 op_commutative opband opbor opbxor opland oplor oplxor opmax opmaxloc opmin opminloc opprod opsum red3 red4 red_scat_block red_scat_block2 redscat redscat2 redscat3 redscatblk3 redscatinter redscatbkinter reduce reduce_local scantst scatter2 scatter3 scattern scatterv uoplong nballtoall1 nbredscat nbredscat3 nbredscatinter nbcoll2" || rm -f allgather2 allgather3 allgatherv2 allgatherv3 allgatherv4 allred allred2 allred3 allred4 allred5 allred6 allredmany alltoall1 alltoallv alltoallv0 alltoallw1 alltoallw2 alltoallw_zeros bcast2 bcast3 bcasttest bcastzerotype coll2 coll3 coll4 coll5 coll6 coll7 coll8 coll9 coll10 coll11 coll12 coll13 exscan exscan2 gather gather2 iallred ibarrier icallgather icallgatherv icallreduce icalltoall icalltoallv icalltoallw icbarrier icbcast icgather icgatherv icreduce icscatter icscatterv longuser nonblocking nonblocking2 nonblocking3 nonblocking4 op_commutative opband opbor opbxor opland oplor oplxor opmax opmaxloc opmin opminloc opprod opsum red3 red4 red_scat_block red_scat_block2 redscat redscat2 redscat3 redscatblk3 redscatinter redscatbkinter reduce reduce_local scantst scatter2 scatter3 scattern scatterv uoplong nballtoall1 nbredscat nbredscat3 nbredscatinter nbcoll2
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/coll'
Making clean in comm
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/comm'
test -z "commcreate1 dup dupic dup_with_info ic1 ic2 commname ctxalloc ctxsplit icgroup icsplit iccreate cmfree icm cmsplit cmsplit2 cmsplit_type comm_create_group comm_group_half comm_group_rand probe-intercomm comm_idup comm_idup_mul comm_idup_overlap comm_info" || rm -f commcreate1 dup dupic dup_with_info ic1 ic2 commname ctxalloc ctxsplit icgroup icsplit iccreate cmfree icm cmsplit cmsplit2 cmsplit_type comm_create_group comm_group_half comm_group_rand probe-intercomm comm_idup comm_idup_mul comm_idup_overlap comm_info
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/comm'
Making clean in errhan
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errhan'
test -z "adderr commcall errfatal predef_eh errstring2" || rm -f adderr commcall errfatal predef_eh errstring2
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errhan'
Making clean in group
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/group'
test -z "grouptest grouptest2 groupcreate gtranks groupnullincl gtranksperf" || rm -f grouptest grouptest2 groupcreate gtranks groupnullincl gtranksperf
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/group'
Making clean in info
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/info'
test -z "infodup infodel infovallen infoorder infomany infomany2 infotest infoenv" || rm -f infodup infodel infovallen infoorder infomany infomany2 infotest infoenv
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/info'
Making clean in init
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/init'
test -z "attrself exitst1 exitst2 exitst3 initstat version library_version timeout finalized" || rm -f attrself exitst1 exitst2 exitst3 initstat version library_version timeout finalized
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/init'
Making clean in pt2pt
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/pt2pt'
test -z "anyall bottom bsend1 bsend2 bsend3 bsend4 bsend5 bsendalign cancelrecv cancelanysrc isendself issendselfcancel sendself eagerdt isendselfprobe bsendfrag bsendpending icsend rqstatus rqfreeb greq1 scancel scancel2 rcancel pscancel sendflood sendrecv1 sendrecv2 sendrecv3 waitany-null pingping probe-unexp probenull inactivereq waittestnull sendall large_message mprobe big_count_status" || rm -f anyall bottom bsend1 bsend2 bsend3 bsend4 bsend5 bsendalign cancelrecv cancelanysrc isendself issendselfcancel sendself eagerdt isendselfprobe bsendfrag bsendpending icsend rqstatus rqfreeb greq1 scancel scancel2 rcancel pscancel sendflood sendrecv1 sendrecv2 sendrecv3 waitany-null pingping probe-unexp probenull inactivereq waittestnull sendall large_message mprobe big_count_status
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/pt2pt'
Making clean in rma
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/rma'
test -z "allocmem ircpi test1 test2 test2_shm test3 test3_shm test4 test5 lockcontention lockcontention2 lockcontention3 lockopts contention_put contention_putget put_base put_bottom locknull wintest wintest_shm transpose1 transpose2 transpose3 transpose3_shm transpose4 transpose5 transpose6 transpose7 fetchandadd fetchandadd_tree winname putfence1 putfidx epochtest getfence1 accfence1 accfence2 adlb_mimic1 putpscw1 accpscw1 getgroup contig_displ test1_am test2_am test2_am_shm test3_am test3_am_shm test4_am test5_am fetchandadd_am fetchandadd_tree_am accfence2_am test1_dt attrorderwin wincall fkeyvalwin baseattrwin nullpscw nullpscw_shm rmanull rmazero mixedsync manyrma2 manyrma2_shm manyrma3 selfrma strided_acc_onelock strided_putget_indexed strided_putget_indexed_shared strided_acc_indexed strided_acc_subarray strided_get_indexed strided_getacc_indexed strided_getacc_indexed_shared window_creation win_flavors win_shared win_shared_noncontig win_shared_noncontig_put win_shared_zerobyte win_zero win_large_shm win_dynamic_acc get_acc_local compare_and_swap linked_list linked_list_fop linked_list_lockall linked_list_bench_lock_all linked_list_bench_lock_excl linked_list_bench_lock_shr linked_list_bench_lock_shr_nocheck fetch_and_op_char fetch_and_op_short fetch_and_op_int fetch_and_op_long fetch_and_op_double fetch_and_op_long_double get_accumulate_short get_accumulate_long get_accumulate_double get_accumulate_int get_accumulate_short_derived get_accumulate_long_derived get_accumulate_double_derived get_accumulate_int_derived flush win_shared_put_flush_get reqops req_example req_example_shm win_info pscw_ordering pscw_ordering_shm mutex_bench mutex_bench_shared mutex_bench_shm mutex_bench_shm_ordered rma-contig badrma nb_test acc-loc fence_shm get-struct at_complete" || rm -f allocmem ircpi test1 test2 test2_shm test3 test3_shm test4 test5 lockcontention lockcontention2 lockcontention3 lockopts contention_put contention_putget put_base put_bottom locknull wintest wintest_shm transpose1 transpose2 transpose3 transpose3_shm transpose4 transpose5 transpose6 transpose7 fetchandadd fetchandadd_tree winname putfence1 putfidx epochtest getfence1 accfence1 accfence2 adlb_mimic1 putpscw1 accpscw1 getgroup contig_displ test1_am test2_am test2_am_shm test3_am test3_am_shm test4_am test5_am fetchandadd_am fetchandadd_tree_am accfence2_am test1_dt attrorderwin wincall fkeyvalwin baseattrwin nullpscw nullpscw_shm rmanull rmazero mixedsync manyrma2 manyrma2_shm manyrma3 selfrma strided_acc_onelock strided_putget_indexed strided_putget_indexed_shared strided_acc_indexed strided_acc_subarray strided_get_indexed strided_getacc_indexed strided_getacc_indexed_shared window_creation win_flavors win_shared win_shared_noncontig win_shared_noncontig_put win_shared_zerobyte win_zero win_large_shm win_dynamic_acc get_acc_local compare_and_swap linked_list linked_list_fop linked_list_lockall linked_list_bench_lock_all linked_list_bench_lock_excl linked_list_bench_lock_shr linked_list_bench_lock_shr_nocheck fetch_and_op_char fetch_and_op_short fetch_and_op_int fetch_and_op_long fetch_and_op_double fetch_and_op_long_double get_accumulate_short get_accumulate_long get_accumulate_double get_accumulate_int get_accumulate_short_derived get_accumulate_long_derived get_accumulate_double_derived get_accumulate_int_derived flush win_shared_put_flush_get reqops req_example req_example_shm win_info pscw_ordering pscw_ordering_shm mutex_bench mutex_bench_shared mutex_bench_shm mutex_bench_shm_ordered rma-contig badrma nb_test acc-loc fence_shm get-struct at_complete
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/rma'
Making clean in topo
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/topo'
test -z "cartmap1 cartzero cartshift1 cartsuball cartcreates dims1 dims2 dims3 dims4 graphmap1 topotest topodup graphcr graphcr2 distgraph1 dgraph_unwgt neighb_coll" || rm -f cartmap1 cartzero cartshift1 cartsuball cartcreates dims1 dims2 dims3 dims4 graphmap1 topotest topodup graphcr graphcr2 distgraph1 dgraph_unwgt neighb_coll
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/topo'
Making clean in errors
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/attr'
test -z "keyvalmis" || rm -f keyvalmis
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/coll'
test -z "noalias rerr bcastlength reduce_local" || rm -f noalias rerr bcastlength reduce_local
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/comm'
test -z "cfree ccreate1 manysplit userdup too_many_comms too_many_comms2 too_many_comms3" || rm -f cfree ccreate1 manysplit userdup too_many_comms too_many_comms2 too_many_comms3
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/datatype'
test -z "getcnterr" || rm -f getcnterr
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/group'
test -z "gerr" || rm -f gerr
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/group'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/pt2pt'
test -z "proberank truncmsg1 truncmsg2 errinstatts errinstatta errinstatws errinstatwa" || rm -f proberank truncmsg1 truncmsg2 errinstatts errinstatta errinstatws errinstatwa
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/pt2pt'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/rma'
test -z "winerr winerr2 cas_type_check win_sync_unlock win_sync_free_pt win_sync_free_at win_sync_complete win_sync_lock_at win_sync_lock_pt win_sync_lock_fence win_sync_nested win_sync_op" || rm -f winerr winerr2 cas_type_check win_sync_unlock win_sync_free_pt win_sync_free_at win_sync_complete win_sync_lock_at win_sync_lock_pt win_sync_lock_fence win_sync_nested win_sync_op
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/topo'
test -z "cartsmall" || rm -f cartsmall
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/topo'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/basic'
test -z "lefthandles debabort" || rm -f lefthandles debabort
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/basic'
Making clean in faults
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/faults'
test -z "pt2ptf1 pt2ptf2 collf1 collf2" || rm -f pt2ptf1 pt2ptf2 collf1 collf2
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/faults'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/io'
test -z "fileerrret openerr" || rm -f fileerrret openerr
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/io'
Making clean in f77
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
Making clean in io
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77/io'
test -z "summary.xml summary.tap" || rm -f summary.xml summary.tap
test -z "uerrhandf" || rm -f uerrhandf
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77/io'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
Making clean in f90
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
Making clean in io
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90/io'
test -z "uerrhandf90" || rm -f uerrhandf90
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90/io'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
Making clean in cxx
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
Making clean in io
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/io'
test -z "fileerrretx errgetfilex throwtestfilex" || rm -f fileerrretx errgetfilex throwtestfilex
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/io'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/errhan'
test -z "commerrx errgetx errsetx throwtest" || rm -f commerrx errgetx errsetx throwtest
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/errhan'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
Making clean in spawn
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/spawn'
test -z "badport unpub lookup_name" || rm -f badport unpub lookup_name
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/spawn'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
Making clean in manual
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
Making clean in mpi_t
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual/mpi_t'
test -z "mpit_test mpit_test2 nem_fbox_fallback_to_queue_count unexpected_recvq_buffer_size" || rm -f mpit_test mpit_test2 nem_fbox_fallback_to_queue_count unexpected_recvq_buffer_size
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual/mpi_t'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
test -z "summary.xml summary.tap summary.junit.xml test-port" || rm -f summary.xml summary.tap summary.junit.xml test-port
test -z "singjoin testconnect testconnectserial dimsbalanced spawntest_master spawntest_child segfault" || rm -f singjoin testconnect testconnectserial dimsbalanced spawntest_master spawntest_child segfault
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
Making clean in perf
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/perf'
test -z "transp-datatype non_zero_root sendrecvl twovec dtpack allredtrace commcreatep allredtrace commcreatep timer manyrma nestvec nestvec2 indexperf" || rm -f transp-datatype non_zero_root sendrecvl twovec dtpack allredtrace commcreatep allredtrace commcreatep timer manyrma nestvec nestvec2 indexperf
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/perf'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/mpi_t'
test -z "mpi_t_str mpit_vars cvarwrite" || rm -f mpi_t_str mpit_vars cvarwrite
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/mpi_t'
Making clean in impls
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
Making clean in mpich
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich/mpi_t'
test -z "collparmt" || rm -f collparmt
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich/mpi_t'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
Making clean in ckpoint
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ckpoint'
test -z "write_ckpoint" || rm -f write_ckpoint
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ckpoint'
Making clean in ft
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ft'
test -z "die abort sendalive isendalive senddead recvdead isenddead irecvdead barrier gather reduce bcast scatter failure_ack anysource revoke_nofail shrink agree multi_isendalive" || rm -f die abort sendalive isendalive senddead recvdead isenddead irecvdead barrier gather reduce bcast scatter failure_ack anysource revoke_nofail shrink agree multi_isendalive
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ft'
Making clean in io
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/io'
rm -f testfile testfile.*
test -z "rdwrord rdwrzero getextent setinfo setviewcur i_noncontig async async_any userioerr resized resized2 bigtype hindexed_io" || rm -f rdwrord rdwrzero getextent setinfo setviewcur i_noncontig async async_any userioerr resized resized2 bigtype hindexed_io
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/io'
Making clean in f77
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/util'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/attr'
test -z "attrmpi1f baseattrf baseattr2f commattrf commattr2f commattr3f typeattrf typeattr2f typeattr3f" || rm -f attrmpi1f baseattrf baseattr2f commattrf commattr2f commattr3f typeattrf typeattr2f typeattr3f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/datatype'
test -z "typenamef typesnamef typecntsf typesubf typem2f gaddressf packef allctypesf hindex1f hindexed_blockf typename3f" || rm -f typenamef typesnamef typecntsf typesubf typem2f gaddressf packef allctypesf hindex1f hindexed_blockf typename3f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/coll'
test -z "uallreducef exscanf alltoallwf inplacef allredint8f allredopttf reducelocalf alltoallvf redscatf split_typef nonblockingf vw_inplacef red_scat_blockf nonblocking_inpf" || rm -f uallreducef exscanf alltoallwf inplacef allredint8f allredopttf reducelocalf alltoallvf redscatf split_typef nonblockingf vw_inplacef red_scat_blockf nonblocking_inpf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/pt2pt'
test -z "allpairf statusesf greqf mprobef" || rm -f allpairf statusesf greqf mprobef
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/info'
test -z "infotestf infotest2f" || rm -f infotestf infotest2f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/info'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/init'
test -z "baseenvf" || rm -f baseenvf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/init'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/comm'
test -z "commnamef commerrf" || rm -f commnamef commerrf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/topo'
test -z "cartcrf dgraph_wgtf dgraph_unwgtf" || rm -f cartcrf dgraph_wgtf dgraph_unwgtf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/topo'
Making clean in ext
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/ext'
test -z "c2f2cf ctypesinf c2fmult" || rm -f c2f2cf ctypesinf c2fmult
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/ext'
Making clean in profile
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/profile'
test -z "profile1f" || rm -f profile1f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/profile'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/spawn'
test -z "namepubf spawnf spawnargvf spawnmultf spawnmult2f connaccf" || rm -f namepubf spawnf spawnargvf spawnmultf spawnmult2f connaccf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/spawn'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/io'
test -z "summary.xml summary.tap gen-src-tmp gen-src-stamp" || rm -f summary.xml summary.tap gen-src-tmp gen-src-stamp
rm -f .iotest.txt.*
test -z "iwriteatf iwritef iwriteshf writef writeatf writeallf writeallbef writeordf writeordbef writeshf writeatallf writeatallbef fileerrf fileinfof shpositionf atomicityf miscfilef setviewcurf c2fmultio c2f2ciof" || rm -f iwriteatf iwritef iwriteshf writef writeatf writeallf writeallbef writeordf writeordbef writeshf writeatallf writeatallbef fileerrf fileinfof shpositionf atomicityf miscfilef setviewcurf c2fmultio c2f2ciof
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/io'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/rma'
test -z "winscale1f winscale2f winfencef wingetf winerrf winnamef wingroupf winaccf winaccf c2f2cwinf baseattrwinf winattrf winattr2f" || rm -f winscale1f winscale2f winfencef wingetf winerrf winnamef wingroupf winaccf winaccf c2f2cwinf baseattrwinf winattrf winattr2f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
Making clean in f90
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/util'
Making clean in timer
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/timer'
test -z "wtimef90" || rm -f wtimef90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/timer'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/attr'
if [ "mod" != "" ] ; then rm -f *.mod ; fi
test -z "attrmpi1f90 baseattrf90 baseattr2f90 commattrf90 commattr2f90 commattr3f90 typeattrf90 typeattr2f90 typeattr3f90 fandcattrf90 baseattr3f90 attrlangf90" || rm -f attrmpi1f90 baseattrf90 baseattr2f90 commattrf90 commattr2f90 commattr3f90 typeattrf90 typeattr2f90 typeattr3f90 fandcattrf90 baseattr3f90 attrlangf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/coll'
test -z "uallreducef90 exscanf90 alltoallwf90 inplacef90 allredint8f90 allredopttf90 reducelocalf90 alltoallvf90 redscatf90 split_typef90 nonblockingf90 vw_inplacef90 red_scat_blockf90 nonblocking_inpf90" || rm -f uallreducef90 exscanf90 alltoallwf90 inplacef90 allredint8f90 allredopttf90 reducelocalf90 alltoallvf90 redscatf90 split_typef90 nonblockingf90 vw_inplacef90 red_scat_blockf90 nonblocking_inpf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/datatype'
test -z "typenamef90 typesnamef90 typecntsf90 typesubf90 typem2f90 gaddressf90 packef90 allctypesf90 hindex1f90 hindexed_blockf90 typename3f90 structf indtype createf90 sizeof kinds trf90 get_elem_d get_elem_u" || rm -f typenamef90 typesnamef90 typecntsf90 typesubf90 typem2f90 gaddressf90 packef90 allctypesf90 hindex1f90 hindexed_blockf90 typename3f90 structf indtype createf90 sizeof kinds trf90 get_elem_d get_elem_u
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/pt2pt'
test -z "allpairf90 statusesf90 greqf90 mprobef90" || rm -f allpairf90 statusesf90 greqf90 mprobef90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/info'
test -z "infotestf90 infotest2f90" || rm -f infotestf90 infotest2f90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/info'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/comm'
test -z "commnamef90 commerrf90" || rm -f commnamef90 commerrf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/topo'
test -z "cartcrf90 dgraph_wgtf90 dgraph_unwgtf90" || rm -f cartcrf90 dgraph_wgtf90 dgraph_unwgtf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/topo'
Making clean in ext
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/ext'
test -z "c2f2cf90 ctypesinf90 c2f90mult" || rm -f c2f2cf90 ctypesinf90 c2f90mult
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/ext'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/init'
test -z "baseenvf90" || rm -f baseenvf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/init'
Making clean in misc
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/misc'
test -z "sizeof2" || rm -f sizeof2
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/misc'
Making clean in f90types
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/f90types'
test -z "createf90types" || rm -f createf90types
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/f90types'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/profile'
test -z "profile1f90" || rm -f profile1f90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/profile'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/rma'
test -z "winscale1f90 winscale2f90 winfencef90 wingetf90 winerrf90 winnamef90 wingroupf90 winaccf90 winaccf90 c2f2cwinf90 baseattrwinf90 winattrf90 winattr2f90" || rm -f winscale1f90 winscale2f90 winfencef90 wingetf90 winerrf90 winnamef90 wingroupf90 winaccf90 winaccf90 c2f2cwinf90 baseattrwinf90 winattrf90 winattr2f90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/spawn'
test -z "namepubf90 spawnf90 spawnargvf90 spawnmultf90 spawnmult2f90 connaccf90 spawnargvf03 spawnmultf03" || rm -f namepubf90 spawnf90 spawnargvf90 spawnmultf90 spawnmult2f90 connaccf90 spawnargvf03 spawnmultf03
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/spawn'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/io'
rm -f .iotest.txt.*
test -z "iwriteatf90 iwritef90 iwriteshf90 writef90 writeatf90 writeallf90 writeallbef90 writeordf90 writeordbef90 writeshf90 writeatallf90 writeatallbef90 fileerrf90 fileinfof90 shpositionf90 atomicityf90 miscfilef90 setviewcurf90 c2f90multio c2f2ciof90" || rm -f iwriteatf90 iwritef90 iwriteshf90 writef90 writeatf90 writeallf90 writeallbef90 writeordf90 writeordbef90 writeshf90 writeatallf90 writeatallbef90 fileerrf90 fileinfof90 shpositionf90 atomicityf90 miscfilef90 setviewcurf90 c2f90multio c2f2ciof90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/io'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
Making clean in cxx
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/util'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/attr'
test -z "attrtx attricx baseattrcommx fkeyvalcommx fkeyvaltypex" || rm -f attrtx attricx baseattrcommx fkeyvalcommx fkeyvaltypex
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/pt2pt'
test -z "bsend1cxx sendrecvx" || rm -f bsend1cxx sendrecvx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/init'
test -z "baseenv initstatx initstat2x" || rm -f baseenv initstatx initstat2x
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/init'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/info'
test -z "infodupx infodelx infovallenx infoorderx" || rm -f infodupx infodelx infovallenx infoorderx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/info'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/comm'
test -z "commname2" || rm -f commname2
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/coll'
test -z "arcomplex uallredx uallreduce ureduce ureducelocal uscan uexscan icbcastx icbarrierx icgatherx icgathervx icscatterx icscattervx icallgatherx icallgathervx icallreducex icreducex icalltoallx alltoallw2x reduceboolx redscatblk" || rm -f arcomplex uallredx uallreduce ureduce ureducelocal uscan uexscan icbcastx icbarrierx icgatherx icgathervx icscatterx icscattervx icallgatherx icallgathervx icallreducex icreducex icalltoallx alltoallw2x reduceboolx redscatblk
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/datatype'
test -z "packsizex typecntsx typenamex typemiscx" || rm -f packsizex typecntsx typenamex typemiscx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/errhan'
test -z "commcallx" || rm -f commcallx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/errhan'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/topo'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/topo'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/io'
rm -f .iotest.txt.*
test -z "iwriteatx iwritex iwriteshx writex writeatx writeallx writeatallx writeallbex writeordx writeordbex writeshx writeatallbex iwriteatnosx iwritenosx iwriteshnosx writenosx writeatnosx writeallnosx writeatallnosx writeallbenosx writeordnosx writeordbenosx writeshnosx writeatallbenosx fileerrx fileinfox shpositionx setinfox filemiscx seekavail" || rm -f iwriteatx iwritex iwriteshx writex writeatx writeallx writeatallx writeallbex writeordx writeordbex writeshx writeatallbex iwriteatnosx iwritenosx iwriteshnosx writenosx writeatnosx writeallnosx writeatallnosx writeallbenosx writeordnosx writeordbenosx writeshnosx writeatallbenosx fileerrx fileinfox shpositionx setinfox filemiscx seekavail
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/io'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/rma'
test -z "winnamex wincallx getgroupx winfencex winscale1x winscale2x fkeyvalwinx" || rm -f winnamex wincallx getgroupx winfencex winscale1x winscale2x fkeyvalwinx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/spawn'
test -z "spawnargvx spawnintrax namepubx selfconaccx" || rm -f spawnargvx spawnintrax namepubx selfconaccx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/spawn'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
Making clean in threads
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/util'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/pt2pt'
test -z "threads threaded_sr alltoall sendselfth greq_wait greq_test multisend multisend2 multisend3 multisend4 ibsend" || rm -f threads threaded_sr alltoall sendselfth greq_wait greq_test multisend multisend2 multisend3 multisend4 ibsend
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/comm'
test -z "ctxdup dup_leak_test comm_dup_deadlock comm_create_threads comm_create_group_threads comm_idup ctxidup" || rm -f ctxdup dup_leak_test comm_dup_deadlock comm_create_threads comm_create_group_threads comm_idup ctxidup
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/init'
test -z "initth" || rm -f initth
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/init'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/mpi_t'
test -z "mpit_threading" || rm -f mpit_threading
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/mpi_t'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/spawn'
test -z "multispawn th_taskmaster" || rm -f multispawn th_taskmaster
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/spawn'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/rma'
test -z "multirma multiget" || rm -f multirma multiget
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/spawn'
test -z "namepub spawn1 spawninfo1 spawnminfo1 spawn2 spawnintra spawnargv spawnmanyarg spaconacc spaconacc2 selfconacc spawnmult2 taskmaster join disconnect_reconnect disconnect_reconnect2 disconnect_reconnect3 multiple_ports multiple_ports2 spaiccreate spaiccreate2 disconnect disconnect2 disconnect3 pgroup_connect_test pgroup_intercomm_test concurrent_spawns" || rm -f namepub spawn1 spawninfo1 spawnminfo1 spawn2 spawnintra spawnargv spawnmanyarg spaconacc spaconacc2 selfconacc spawnmult2 taskmaster join disconnect_reconnect disconnect_reconnect2 disconnect_reconnect3 multiple_ports multiple_ports2 spaiccreate spaiccreate2 disconnect disconnect2 disconnect3 pgroup_connect_test pgroup_intercomm_test concurrent_spawns
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/spawn'
Making clean in ft
rm -f *.o
Making clean in .
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
Making clean in commands
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/commands'
test -z "err.txt out.log out.txt a.out" || rm -f err.txt out.log out.txt a.out
rm -rf .libs _libs
 rm -f stdiotest stdintest stdintest2 checkenv1 rtest rtestf rtestx testout
rm -f *.o
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/commands'
Making clean in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
rm -rf .libs _libs
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
test -z "" || rm -f
test -z "" || rm -f
rm -f *.o
rm -f src/binding/cxx/*.o
rm -f src/binding/cxx/*.lo
rm -f src/binding/fortran/mpif_h/*.o
rm -f src/binding/fortran/mpif_h/*.lo
rm -f src/binding/fortran/use_mpi/*.o
rm -f src/binding/fortran/use_mpi/*.lo
rm -f src/binding/fortran/use_mpi_f08/*.o
rm -f src/binding/fortran/use_mpi_f08/*.lo
rm -f src/binding/fortran/use_mpi_f08/wrappers_c/*.o
rm -f src/binding/fortran/use_mpi_f08/wrappers_c/*.lo
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/*.o
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/*.lo
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/profiling/*.o
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/profiling/*.lo
rm -f src/env/*.o
rm -f src/glue/romio/*.o
rm -f src/glue/romio/*.lo
rm -f src/mpi/attr/*.o
rm -f src/mpi/attr/*.lo
rm -f src/mpi/coll/*.o
rm -f src/mpi/coll/*.lo
rm -f src/mpi/comm/*.o
rm -f src/mpi/comm/*.lo
rm -f src/mpi/datatype/*.o
rm -f src/mpi/datatype/*.lo
rm -f src/mpi/debugger/*.o
rm -f src/mpi/debugger/*.lo
rm -f src/mpi/errhan/*.o
rm -f src/mpi/errhan/*.lo
rm -f src/mpi/group/*.o
rm -f src/mpi/group/*.lo
rm -f src/mpi/info/*.o
rm -f src/mpi/info/*.lo
rm -f src/mpi/init/*.o
rm -f src/mpi/init/*.lo
rm -f src/mpi/misc/*.o
rm -f src/mpi/misc/*.lo
rm -f src/mpi/pt2pt/*.o
rm -f src/mpi/pt2pt/*.lo
rm -f src/mpi/rma/*.o
rm -f src/mpi/rma/*.lo
rm -f src/mpi/spawn/*.o
rm -f src/mpi/spawn/*.lo
rm -f src/mpi/timer/*.o
rm -f src/mpi/timer/*.lo
rm -f src/mpi/topo/*.o
rm -f src/mpi/topo/*.lo
rm -f src/mpi_t/*.o
rm -f src/mpi_t/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/ib/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/ib/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/mx/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/mx/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/mxm/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/mxm/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/newmad/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/newmad/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/none/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/none/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/portals4/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/portals4/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/scif/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/scif/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/tcp/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/tcp/*.lo
rm -f src/mpid/ch3/channels/nemesis/src/*.o
rm -f src/mpid/ch3/channels/nemesis/src/*.lo
rm -f src/mpid/ch3/channels/nemesis/utils/monitor/*.o
rm -f src/mpid/ch3/channels/nemesis/utils/monitor/*.lo
rm -f src/mpid/ch3/channels/nemesis/utils/replacements/*.o
rm -f src/mpid/ch3/channels/nemesis/utils/replacements/*.lo
rm -f src/mpid/ch3/channels/sock/src/*.o
rm -f src/mpid/ch3/channels/sock/src/*.lo
rm -f src/mpid/ch3/src/*.o
rm -f src/mpid/ch3/src/*.lo
rm -f src/mpid/ch3/util/ftb/*.o
rm -f src/mpid/ch3/util/ftb/*.lo
rm -f src/mpid/ch3/util/sock/*.o
rm -f src/mpid/ch3/util/sock/*.lo
rm -f src/mpid/common/datatype/*.o
rm -f src/mpid/common/datatype/*.lo
rm -f src/mpid/common/datatype/dataloop/*.o
rm -f src/mpid/common/datatype/dataloop/*.lo
rm -f src/mpid/common/hcoll/*.o
rm -f src/mpid/common/hcoll/*.lo
rm -f src/mpid/common/sched/*.o
rm -f src/mpid/common/sched/*.lo
rm -f src/mpid/common/sock/poll/*.o
rm -f src/mpid/common/sock/poll/*.lo
rm -f src/mpid/common/thread/*.o
rm -f src/mpid/common/thread/*.lo
rm -f src/mpid/pamid/src/*.o
rm -f src/mpid/pamid/src/*.lo
rm -f src/mpid/pamid/src/coll/*.o
rm -f src/mpid/pamid/src/coll/*.lo
rm -f src/mpid/pamid/src/coll/allgather/*.o
rm -f src/mpid/pamid/src/coll/allgather/*.lo
rm -f src/mpid/pamid/src/coll/allgatherv/*.o
rm -f src/mpid/pamid/src/coll/allgatherv/*.lo
rm -f src/mpid/pamid/src/coll/allreduce/*.o
rm -f src/mpid/pamid/src/coll/allreduce/*.lo
rm -f src/mpid/pamid/src/coll/alltoall/*.o
rm -f src/mpid/pamid/src/coll/alltoall/*.lo
rm -f src/mpid/pamid/src/coll/alltoallv/*.o
rm -f src/mpid/pamid/src/coll/alltoallv/*.lo
rm -f src/mpid/pamid/src/coll/alltoallw/*.o
rm -f src/mpid/pamid/src/coll/alltoallw/*.lo
rm -f src/mpid/pamid/src/coll/barrier/*.o
rm -f src/mpid/pamid/src/coll/barrier/*.lo
rm -f src/mpid/pamid/src/coll/bcast/*.o
rm -f src/mpid/pamid/src/coll/bcast/*.lo
rm -f src/mpid/pamid/src/coll/exscan/*.o
rm -f src/mpid/pamid/src/coll/exscan/*.lo
rm -f src/mpid/pamid/src/coll/gather/*.o
rm -f src/mpid/pamid/src/coll/gather/*.lo
rm -f src/mpid/pamid/src/coll/gatherv/*.o
rm -f src/mpid/pamid/src/coll/gatherv/*.lo
rm -f src/mpid/pamid/src/coll/ired_scat/*.o
rm -f src/mpid/pamid/src/coll/ired_scat/*.lo
rm -f src/mpid/pamid/src/coll/ired_scat_block/*.o
rm -f src/mpid/pamid/src/coll/ired_scat_block/*.lo
rm -f src/mpid/pamid/src/coll/reduce/*.o
rm -f src/mpid/pamid/src/coll/reduce/*.lo
rm -f src/mpid/pamid/src/coll/scan/*.o
rm -f src/mpid/pamid/src/coll/scan/*.lo
rm -f src/mpid/pamid/src/coll/scatter/*.o
rm -f src/mpid/pamid/src/coll/scatter/*.lo
rm -f src/mpid/pamid/src/coll/scatterv/*.o
rm -f src/mpid/pamid/src/coll/scatterv/*.lo
rm -f src/mpid/pamid/src/comm/*.o
rm -f src/mpid/pamid/src/comm/*.lo
rm -f src/mpid/pamid/src/dyntask/*.o
rm -f src/mpid/pamid/src/dyntask/*.lo
rm -f src/mpid/pamid/src/misc/*.o
rm -f src/mpid/pamid/src/misc/*.lo
rm -f src/mpid/pamid/src/mpix/*.o
rm -f src/mpid/pamid/src/mpix/*.lo
rm -f src/mpid/pamid/src/onesided/*.o
rm -f src/mpid/pamid/src/onesided/*.lo
rm -f src/mpid/pamid/src/pamix/*.o
rm -f src/mpid/pamid/src/pamix/*.lo
rm -f src/mpid/pamid/src/pt2pt/*.o
rm -f src/mpid/pamid/src/pt2pt/*.lo
rm -f src/mpid/pamid/src/pt2pt/persistent/*.o
rm -f src/mpid/pamid/src/pt2pt/persistent/*.lo
rm -f src/mutex/*.o
rm -f src/mutex/*.lo
rm -f src/nameserv/file/*.o
rm -f src/nameserv/file/*.lo
rm -f src/nameserv/pmi/*.o
rm -f src/nameserv/pmi/*.lo
rm -f src/pm/gforker/*.o
rm -f src/pm/remshell/*.o
rm -f src/pm/util/*.o
rm -f src/pmi/pmi2/poe/*.o
rm -f src/pmi/pmi2/poe/*.lo
rm -f src/pmi/pmi2/simple/*.o
rm -f src/pmi/pmi2/simple/*.lo
rm -f src/pmi/simple/*.o
rm -f src/pmi/simple/*.lo
rm -f src/util/cvar/*.o
rm -f src/util/cvar/*.lo
rm -f src/util/dbg/*.o
rm -f src/util/dbg/*.lo
rm -f src/util/instrm/*.o
rm -f src/util/instrm/*.lo
rm -f src/util/logging/rlog/*.o
rm -f src/util/logging/rlog/*.lo
rm -f src/util/mem/*.o
rm -f src/util/mem/*.lo
rm -f src/util/msgs/*.o
rm -f src/util/msgs/*.lo
rm -f src/util/other/*.o
rm -f src/util/other/*.lo
rm -f src/util/procmap/*.o
rm -f src/util/procmap/*.lo
rm -f src/util/thread/*.o
rm -f src/util/thread/*.lo
rm -f *.lo
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making clean in examples
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
rm -rf .libs _libs
 rm -f cpi
rm -f *.o
rm -f *.lo
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
Executing: cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3 && /usr/bin/make -j 4
stdout:
if test ! -h ./src/include/mpio.h ; then \
	    rm -f ./src/include/mpio.h ; \
	    ( cd ./src/include &&       \
	        ln -s ../mpi/romio/include/mpio.h ) ; \
	fi
/usr/bin/make  all-recursive
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making all in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
  CC       src/mplstr.lo
  CC       src/mpltrmem.lo
  CC       src/mplenv.lo
  CC       src/mplsock.lo
  CCLD     libmpl.la
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making all in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making all in src
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
/usr/bin/make  all-am
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
  CC       opa_primitives.lo
  CC       opa_queue.lo
  CCLD     libopa.la
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
Making all in test
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making all in src/mpi/romio
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
  CC       mpi-io/mpich_fileutil.lo
  CC       mpi-io/mpir-mpioinit.lo
  CC       mpi-io/mpiu_greq.lo
  CC       mpi-io/mpiu_external32.lo
  CC       mpi-io/close.lo
  CC       mpi-io/file_c2f.lo
  CC       mpi-io/delete.lo
  CC       mpi-io/file_f2c.lo
  CC       mpi-io/fsync.lo
  CC       mpi-io/get_amode.lo
  CC       mpi-io/get_atom.lo
  CC       mpi-io/get_bytoff.lo
  CC       mpi-io/get_extent.lo
  CC       mpi-io/get_group.lo
  CC       mpi-io/get_info.lo
  CC       mpi-io/get_posn.lo
  CC       mpi-io/get_posn_sh.lo
  CC       mpi-io/get_size.lo
  CC       mpi-io/get_view.lo
  CC       mpi-io/iread.lo
  CC       mpi-io/iread_at.lo
  CC       mpi-io/iread_sh.lo
  CC       mpi-io/iwrite.lo
  CC       mpi-io/iwrite_at.lo
  CC       mpi-io/iwrite_sh.lo
  CC       mpi-io/open.lo
  CC       mpi-io/prealloc.lo
  CC       mpi-io/rd_atallb.lo
  CC       mpi-io/rd_atalle.lo
  CC       mpi-io/read.lo
  CC       mpi-io/read_all.lo
  CC       mpi-io/read_allb.lo
  CC       mpi-io/read_alle.lo
  CC       mpi-io/read_at.lo
  CC       mpi-io/read_atall.lo
  CC       mpi-io/read_ord.lo
  CC       mpi-io/read_ordb.lo
  CC       mpi-io/read_orde.lo
  CC       mpi-io/read_sh.lo
  CC       mpi-io/register_datarep.lo
  CC       mpi-io/seek.lo
  CC       mpi-io/seek_sh.lo
  CC       mpi-io/set_atom.lo
  CC       mpi-io/set_info.lo
  CC       mpi-io/set_size.lo
  CC       mpi-io/set_view.lo
  CC       mpi-io/wr_atallb.lo
  CC       mpi-io/wr_atalle.lo
  CC       mpi-io/write.lo
  CC       mpi-io/write_all.lo
  CC       mpi-io/write_allb.lo
  CC       mpi-io/write_alle.lo
  CC       mpi-io/write_at.lo
  CC       mpi-io/write_atall.lo
  CC       mpi-io/write_ord.lo
  CC       mpi-io/write_ordb.lo
  CC       mpi-io/write_orde.lo
  CC       mpi-io/write_sh.lo
  CC       mpi-io/glue/mpich/mpio_file.lo
  CC       mpi-io/glue/mpich/mpio_err.lo
  CC       adio/ad_nfs/ad_nfs_read.lo
  CC       adio/ad_nfs/ad_nfs_open.lo
  CC       adio/ad_nfs/ad_nfs_write.lo
  CC       adio/ad_nfs/ad_nfs_done.lo
  CC       adio/ad_nfs/ad_nfs_fcntl.lo
  CC       adio/ad_nfs/ad_nfs_iread.lo
  CC       adio/ad_nfs/ad_nfs_iwrite.lo
  CC       adio/ad_nfs/ad_nfs_wait.lo
  CC       adio/ad_nfs/ad_nfs_setsh.lo
  CC       adio/ad_nfs/ad_nfs_getsh.lo
  CC       adio/ad_nfs/ad_nfs.lo
  CC       adio/ad_nfs/ad_nfs_resize.lo
  CC       adio/ad_nfs/ad_nfs_features.lo
  CC       adio/ad_testfs/ad_testfs_close.lo
  CC       adio/ad_testfs/ad_testfs_read.lo
  CC       adio/ad_testfs/ad_testfs_rdcoll.lo
  CC       adio/ad_testfs/ad_testfs_wrcoll.lo
  CC       adio/ad_testfs/ad_testfs_open.lo
  CC       adio/ad_testfs/ad_testfs_write.lo
  CC       adio/ad_testfs/ad_testfs_done.lo
  CC       adio/ad_testfs/ad_testfs_fcntl.lo
  CC       adio/ad_testfs/ad_testfs_iread.lo
  CC       adio/ad_testfs/ad_testfs_iwrite.lo
  CC       adio/ad_testfs/ad_testfs_wait.lo
  CC       adio/ad_testfs/ad_testfs_flush.lo
  CC       adio/ad_testfs/ad_testfs_seek.lo
  CC       adio/ad_testfs/ad_testfs_resize.lo
  CC       adio/ad_testfs/ad_testfs_hints.lo
  CC       adio/ad_testfs/ad_testfs_delete.lo
  CC       adio/ad_testfs/ad_testfs.lo
  CC       adio/ad_ufs/ad_ufs.lo
  CC       adio/ad_ufs/ad_ufs_open.lo
  CC       adio/common/ad_aggregate.lo
  CC       adio/common/ad_aggregate_new.lo
  CC       adio/common/ad_close.lo
  CC       adio/common/ad_coll_build_req_new.lo
  CC       adio/common/ad_coll_exch_new.lo
  CC       adio/common/ad_darray.lo
  CC       adio/common/ad_delete.lo
  CC       adio/common/ad_done.lo
  CC       adio/common/ad_done_fake.lo
  CC       adio/common/ad_end.lo
  CC       adio/common/ad_fcntl.lo
  CC       adio/common/ad_features.lo
  CC       adio/common/ad_flush.lo
  CC       adio/common/ad_fstype.lo
  CC       adio/common/ad_get_sh_fp.lo
  CC       adio/common/ad_hints.lo
  CC       adio/common/ad_init.lo
  CC       adio/common/ad_io_coll.lo
  CC       adio/common/ad_iopen.lo
  CC       adio/common/ad_iread.lo
  CC       adio/common/ad_iread_fake.lo
  CC       adio/common/ad_iwrite.lo
  CC       adio/common/ad_iwrite_fake.lo
  CC       adio/common/ad_open.lo
  CC       adio/common/ad_opencoll.lo
  CC       adio/common/ad_opencoll_failsafe.lo
  CC       adio/common/ad_opencoll_scalable.lo
  CC       adio/common/ad_prealloc.lo
  CC       adio/common/ad_read.lo
  CC       adio/common/ad_read_coll.lo
  CC       adio/common/ad_read_str.lo
  CC       adio/common/ad_read_str_naive.lo
  CC       adio/common/ad_resize.lo
  CC       adio/common/ad_seek.lo
  CC       adio/common/ad_set_sh_fp.lo
  CC       adio/common/ad_set_view.lo
  CC       adio/common/ad_subarray.lo
  CC       adio/common/ad_wait.lo
  CC       adio/common/ad_wait_fake.lo
  CC       adio/common/ad_write.lo
  CC       adio/common/ad_write_coll.lo
  CC       adio/common/ad_write_nolock.lo
  CC       adio/common/ad_write_str.lo
  CC       adio/common/ad_write_str_naive.lo
  CC       adio/common/adi_close.lo
  CC       adio/common/byte_offset.lo
  CC       adio/common/cb_config_list.lo
  CC       adio/common/eof_offset.lo
  CC       adio/common/error.lo
  CC       adio/common/flatten.lo
  CC       adio/common/get_fp_posn.lo
  CC       adio/common/greq_fns.lo
  CC       adio/common/heap-sort.lo
  CC       adio/common/iscontig.lo
  CC       adio/common/lock.lo
  CC       adio/common/malloc.lo
  CC       adio/common/shfp_fname.lo
  CC       adio/common/status_setb.lo
  CC       adio/common/strfns.lo
  CC       adio/common/system_hints.lo
  CC       adio/common/hint_fns.lo
  CC       adio/common/ad_threaded_io.lo
  CC       adio/common/p2p_aggregation.lo
  CC       adio/common/utils.lo
  CCLD     libromio.la
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
Making all in src/pm/hydra
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making all in ../../mpl
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making all in tools/topo/hwloc/hwloc
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making all in src
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
  CC       topology.lo
  CC       traversal.lo
  CC       distances.lo
  CC       components.lo
  CC       bind.lo
  CC       bitmap.lo
  CC       pci-common.lo
  CC       diff.lo
  CC       misc.lo
  CC       base64.lo
  CC       topology-noos.lo
  CC       topology-synthetic.lo
  CC       topology-custom.lo
  CC       topology-xml.lo
  CC       topology-xml-nolibxml.lo
  CC       topology-xml-libxml.lo
  CC       topology-linux.lo
  CC       topology-x86.lo
  CCLD     libhwloc_embedded.la
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
Making all in include
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making all in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
  CC       tools/bootstrap/persist/hydra_persist-persist_server.o
  CC       utils/alloc/alloc.lo
  CC       utils/args/args.lo
  CC       utils/dbg/dbg.lo
  CC       utils/env/env.lo
  CC       utils/launch/launch.lo
  CC       utils/others/others.lo
  CC       utils/signals/signals.lo
  CC       utils/sock/sock.lo
  CC       utils/string/string.lo
  CC       tools/topo/topo.lo
  CC       tools/topo/hwloc/topo_hwloc.lo
  CC       tools/bootstrap/src/bsci_init.lo
  CC       tools/bootstrap/src/bsci_finalize.lo
  CC       tools/bootstrap/src/bsci_launch.lo
  CC       tools/bootstrap/src/bsci_query_node_list.lo
  CC       tools/bootstrap/src/bsci_query_proxy_id.lo
  CC       tools/bootstrap/src/bsci_query_native_int.lo
  CC       tools/bootstrap/src/bsci_wait.lo
  CC       tools/bootstrap/src/bsci_env.lo
  CC       tools/bootstrap/utils/bscu_wait.lo
  CC       tools/bootstrap/utils/bscu_cb.lo
  CC       tools/bootstrap/external/external_common.lo
  CC       tools/bootstrap/external/external_common_launch.lo
  CC       tools/bootstrap/external/fork_init.lo
  CC       tools/bootstrap/external/user_init.lo
  CC       tools/bootstrap/external/manual_init.lo
  CC       tools/bootstrap/external/rsh_init.lo
  CC       tools/bootstrap/external/rsh_env.lo
  CC       tools/bootstrap/external/ssh_init.lo
  CC       tools/bootstrap/external/ssh.lo
  CC       tools/bootstrap/external/ssh_env.lo
  CC       tools/bootstrap/external/ssh_finalize.lo
  CC       tools/bootstrap/external/slurm_init.lo
  CC       tools/bootstrap/external/slurm_launch.lo
  CC       tools/bootstrap/external/slurm_env.lo
  CC       tools/bootstrap/external/slurm_query_native_int.lo
  CC       tools/bootstrap/external/slurm_query_node_list.lo
  CC       tools/bootstrap/external/slurm_query_proxy_id.lo
  CC       tools/bootstrap/external/ll_init.lo
  CC       tools/bootstrap/external/ll_launch.lo
  CC       tools/bootstrap/external/ll_query_native_int.lo
  CC       tools/bootstrap/external/ll_query_node_list.lo
  CC       tools/bootstrap/external/ll_query_proxy_id.lo
  CC       tools/bootstrap/external/ll_env.lo
  CC       tools/bootstrap/external/lsf_init.lo
  CC       tools/bootstrap/external/lsf_query_native_int.lo
  CC       tools/bootstrap/external/lsf_query_node_list.lo
  CC       tools/bootstrap/external/lsf_env.lo
  CC       tools/bootstrap/external/sge_init.lo
  CC       tools/bootstrap/external/sge_query_native_int.lo
  CC       tools/bootstrap/external/sge_query_node_list.lo
  CC       tools/bootstrap/external/sge_env.lo
  CC       tools/bootstrap/external/pbs_init.lo
  CC       tools/bootstrap/external/pbs_query_native_int.lo
  CC       tools/bootstrap/external/pbs_query_node_list.lo
  CC       tools/bootstrap/external/cobalt_init.lo
  CC       tools/bootstrap/external/cobalt_query_native_int.lo
  CC       tools/bootstrap/external/cobalt_query_node_list.lo
  CC       tools/bootstrap/persist/persist_init.lo
  CC       tools/bootstrap/persist/persist_launch.lo
  CC       tools/bootstrap/persist/persist_wait.lo
  CC       tools/ckpoint/ckpoint.lo
  CC       tools/demux/demux.lo
  CC       tools/demux/demux_poll.lo
  CC       tools/demux/demux_select.lo
  CC       tools/debugger/debugger.lo
  CC       tools/ftb/hydt_ftb_dummy.lo
  CC       ui/utils/uiu.lo
  CC       pm/pmiserv/pmiserv_pmi.lo
  CC       pm/pmiserv/pmiserv_pmi_v1.lo
  CC       pm/pmiserv/pmiserv_pmi_v2.lo
  CC       pm/pmiserv/pmiserv_pmci.lo
  CC       pm/pmiserv/pmiserv_cb.lo
  CC       pm/pmiserv/pmiserv_utils.lo
  CC       pm/pmiserv/common.lo
  CC       pm/pmiserv/pmi_v2_common.lo
  CC       tools/nameserver/hydra_nameserver-hydra_nameserver.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_cb.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_utils.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_pmi_v1.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_pmi_v2.o
  CC       pm/pmiserv/hydra_pmi_proxy-common.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmi_v2_common.o
  CC       ui/mpich/mpiexec.o
  CC       ui/mpich/utils.o
  CCLD     libhydra.la
  CCLD     hydra_persist
  CCLD     hydra_nameserver
  CCLD     hydra_pmi_proxy
  CCLD     libpm.la
  CCLD     mpiexec.hydra
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making all in .
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
  CC       src/mpi/attr/lib_libmpi_la-attrutil.lo
  CC       src/mpi/coll/lib_libmpi_la-allred_group.lo
  CC       src/mpi/attr/lib_libmpi_la-dup_fn.lo
  CC       src/mpi/coll/lib_libmpi_la-barrier_group.lo
  CC       src/mpi/coll/lib_libmpi_la-helper_fns.lo
  CC       src/mpi/coll/lib_libmpi_la-opsum.lo
  CC       src/mpi/coll/lib_libmpi_la-opmax.lo
  CC       src/mpi/coll/lib_libmpi_la-opmin.lo
  CC       src/mpi/coll/lib_libmpi_la-opband.lo
  CC       src/mpi/coll/lib_libmpi_la-opbor.lo
  CC       src/mpi/coll/lib_libmpi_la-opbxor.lo
  CC       src/mpi/coll/lib_libmpi_la-opland.lo
  CC       src/mpi/coll/lib_libmpi_la-oplor.lo
  CC       src/mpi/coll/lib_libmpi_la-oplxor.lo
  CC       src/mpi/coll/lib_libmpi_la-opprod.lo
  CC       src/mpi/coll/lib_libmpi_la-opminloc.lo
  CC       src/mpi/coll/lib_libmpi_la-opmaxloc.lo
  CC       src/mpi/coll/lib_libmpi_la-opno_op.lo
  CC       src/mpi/coll/lib_libmpi_la-opreplace.lo
  CC       src/mpi/coll/lib_libmpi_la-nbcutil.lo
  CC       src/mpi/comm/lib_libmpi_la-commutil.lo
  CC       src/mpi/datatype/lib_libmpi_la-typeutil.lo
  CC       src/mpi/errhan/lib_libmpi_la-errutil.lo
  CC       src/mpi/errhan/lib_libmpi_la-dynerrutil.lo
  CC       src/mpi/group/lib_libmpi_la-grouputil.lo
  CC       src/mpi/info/lib_libmpi_la-infoutil.lo
  CC       src/mpi/init/lib_libmpi_la-initinfo.lo
  CC       src/mpi/init/lib_libmpi_la-async.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bsendutil.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-mpir_request.lo
  CC       src/mpi/rma/lib_libmpi_la-winutil.lo
  CC       src/mpi/rma/lib_libmpi_la-rmatypeutil.lo
  CC       src/mpi/timer/lib_libmpi_la-mpidtime.lo
  CC       src/mpi/topo/lib_libmpi_la-topoutil.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-fdebug.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-setbot.lo
  F77      src/binding/fortran/mpif_h/setbotf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_util.lo
  CC       src/glue/romio/lib_libmpi_la-glue_romio.lo
  CC       src/mpi_t/lib_libmpi_la-mpit.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-sendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-recvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_countf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ssendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bufattachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bufdetachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-isendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ibsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-issendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-irsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-irecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-request_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitanyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testanyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitsomef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testsomef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iprobef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-probef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cancelf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testcancelf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-send_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bsend_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ssend_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rsend_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-recv_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-startf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-startallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-sendrecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-sndrcvrplf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecontigf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_vectorf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_hvectorf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_indexedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_hindexedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_structf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_extentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_lbf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_ubf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_commitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_elementsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-packf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-unpackf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-pack_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-barrierf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bcastf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-gatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-gathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-scatterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-scattervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-allgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-allgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-exscanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-op_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-op_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-allreducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-redscatf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-scanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_rankf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grouptranksf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_comparef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_unionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-groupinterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-groupdifff.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_inclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_exclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grouprinclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grouprexclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_rankf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_comparef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dup_with_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_splitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commtesticf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commrsizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commrgroupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iccreatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-icmergef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-attr_putf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-attr_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-attr_deletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-topo_testf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dims_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graph_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graphdims_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graph_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cartdim_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_rankf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_coordsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbcountf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbrsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_shiftf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_subf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_mapf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graph_mapf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-getpnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_versionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_library_versionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhcreatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhsetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhgetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhfreef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-error_stringf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-error_classf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-finalizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-initializedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-abortf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-close_portf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_acceptf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_connectf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commdiscf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commparentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_joinf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_spawnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-spawnmultf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-lookup_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-open_portf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-publish_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-unpubnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-accumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-putf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_completef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_fencef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_lockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_postf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_startf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_testf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_waitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocate_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_shared_queryf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_create_dynamicf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_attachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_detachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_accumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-fetch_and_opf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-compare_and_swapf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rputf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rgetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-raccumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rget_accumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_lock_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlock_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flushf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_localf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_local_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_syncf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-adderrclassf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-adderrcodef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-adderrstringf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commcallerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commnewkeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commdelattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commfreekeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commgetnamf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-filecallerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-greqcompletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-greqstartf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-isthrmainf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-query_threadf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-statgetclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-statsetelf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typenewkeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typedelattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_dupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typefreekeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegetcntsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegetenvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typesetattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typesetnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_match_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wincallerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-winnewkeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-windelattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-winfreekeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alloc_memf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commcreerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commgeterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commseterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-filecreerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-filegeterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-fileseterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-finalizedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-free_memf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_deletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_dupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-infognkf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-infognthkf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-infovallenf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_setf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-pack_externalf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-packesizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reqgetstatf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typedarrayf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typechindf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typechvecf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecindbf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_create_hindexed_blockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecresizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecstructf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecsubarrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegetextentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegtextf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-unpackextf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wincreerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wingeterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-winseterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_localf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-op_commutativef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_scatter_blockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_create_adjacentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighbors_countf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighborsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-improbef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-imrecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-mprobef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-mrecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_idupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ibarrierf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ibcastf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-igatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-igathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iscatterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iscattervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iallgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iallgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ireducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iallreducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatter_blockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iscanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iexscanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_split_typef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_elements_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-status_set_elements_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_extent_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_true_extent_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_size_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_create_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_ackf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_get_ackedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_revokef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_shrinkf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_agreef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_openf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_closef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_deletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_preallocatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_amodef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_viewf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_viewf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_readf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_writef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_ireadf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwritef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_seekf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_positionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_byte_offsetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_orderedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_orderedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_seek_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_position_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_type_extentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-register_datarepf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_atomicityf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_atomicityf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_syncf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-initthreadf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-pcontrolf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-addressf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-getaddressf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wtimef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wtickf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_copy_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_comm_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_copy_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_win_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_copy_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_type_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_copy_fnf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpifort_la-typef90cmplxf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpifort_la-typef90realf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpifort_la-typef90intf.lo
rm -f src/binding/fortran/use_mpi/mpifnoext.h
sed -e 's/^C/\!/g' -e '/EXTERNAL/d' \
	-e '/REAL\*8/d' \
	-e '/DOUBLE PRECISION/d' \
	-e '/MPI_WTICK/d' src/binding/fortran/mpif_h/mpif.h > src/binding/fortran/use_mpi/mpifnoext.h
cp -p src/env/mpicc.bash src/env/mpicc
cp -p src/env/mpifort.bash src/env/mpifort
cp -p src/env/mpicxx.bash src/env/mpicxx
  CC       src/mpi/attr/lib_libmpi_la-attr_delete.lo
  CC       src/mpi/attr/lib_libmpi_la-attr_get.lo
  CC       src/mpi/attr/lib_libmpi_la-attr_put.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_create_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_delete_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_free_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_get_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_set_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-keyval_create.lo
  CC       src/mpi/attr/lib_libmpi_la-keyval_free.lo
  CC       src/mpi/attr/lib_libmpi_la-type_create_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-type_delete_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-type_free_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-type_get_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-type_set_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-win_create_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-win_delete_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-win_free_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-win_get_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-win_set_attr.lo
  CC       src/mpi/coll/lib_libmpi_la-allreduce.lo
  CC       src/mpi/coll/lib_libmpi_la-barrier.lo
  CC       src/mpi/coll/lib_libmpi_la-op_create.lo
  CC       src/mpi/coll/lib_libmpi_la-op_free.lo
  CC       src/mpi/coll/lib_libmpi_la-bcast.lo
  CC       src/mpi/coll/lib_libmpi_la-alltoall.lo
  CC       src/mpi/coll/lib_libmpi_la-alltoallv.lo
  CC       src/mpi/coll/lib_libmpi_la-reduce.lo
  CC       src/mpi/coll/lib_libmpi_la-scatter.lo
  CC       src/mpi/coll/lib_libmpi_la-gather.lo
  CC       src/mpi/coll/lib_libmpi_la-scatterv.lo
  CC       src/mpi/coll/lib_libmpi_la-gatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-scan.lo
  CC       src/mpi/coll/lib_libmpi_la-exscan.lo
  CC       src/mpi/coll/lib_libmpi_la-allgather.lo
  CC       src/mpi/coll/lib_libmpi_la-allgatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-red_scat.lo
  CC       src/mpi/coll/lib_libmpi_la-alltoallw.lo
  CC       src/mpi/coll/lib_libmpi_la-reduce_local.lo
  CC       src/mpi/coll/lib_libmpi_la-op_commutative.lo
  CC       src/mpi/coll/lib_libmpi_la-red_scat_block.lo
  CC       src/mpi/coll/lib_libmpi_la-iallgather.lo
  CC       src/mpi/coll/lib_libmpi_la-iallgatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-iallreduce.lo
  CC       src/mpi/coll/lib_libmpi_la-ialltoall.lo
  CC       src/mpi/coll/lib_libmpi_la-ialltoallv.lo
  CC       src/mpi/coll/lib_libmpi_la-ialltoallw.lo
  CC       src/mpi/coll/lib_libmpi_la-ibarrier.lo
  CC       src/mpi/coll/lib_libmpi_la-ibcast.lo
  CC       src/mpi/coll/lib_libmpi_la-iexscan.lo
  CC       src/mpi/coll/lib_libmpi_la-igather.lo
  CC       src/mpi/coll/lib_libmpi_la-igatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-ired_scat.lo
  CC       src/mpi/coll/lib_libmpi_la-ired_scat_block.lo
  CC       src/mpi/coll/lib_libmpi_la-ireduce.lo
  CC       src/mpi/coll/lib_libmpi_la-iscan.lo
  CC       src/mpi/coll/lib_libmpi_la-iscatter.lo
  CC       src/mpi/coll/lib_libmpi_la-iscatterv.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_compare.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_create.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_create_group.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_dup.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_dup_with_info.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_free.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_get_name.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_get_info.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_set_info.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_group.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_idup.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_rank.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_size.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_remote_group.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_remote_size.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_set_name.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_split.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_test_inter.lo
  CC       src/mpi/comm/lib_libmpi_la-intercomm_create.lo
  CC       src/mpi/comm/lib_libmpi_la-intercomm_merge.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_split_type.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_failure_ack.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_failure_get_acked.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_revoke.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_shrink.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_agree.lo
  CC       src/mpi/datatype/lib_libmpi_la-address.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_address.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_count.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_elements.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_elements_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack.lo
  CC       src/mpi/datatype/lib_libmpi_la-unpack.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-status_set_elements.lo
  CC       src/mpi/datatype/lib_libmpi_la-status_set_elements_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_name.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_set_name.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_size_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_extent.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_vector.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_commit.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_indexed.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_hindexed.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_struct.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_contiguous.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_free.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_hvector.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_dup.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_envelope.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_contents.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_ub.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_lb.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_extent.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_extent_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_true_extent.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_true_extent_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_match_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_struct.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_hindexed.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_hvector.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack_external.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack_external_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-unpack_external.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_indexed_block.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_hindexed_block.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_resized.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_darray.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_subarray.lo
  CC       src/mpi/errhan/lib_libmpi_la-add_error_code.lo
  CC       src/mpi/errhan/lib_libmpi_la-add_error_class.lo
  CC       src/mpi/errhan/lib_libmpi_la-add_error_string.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_call_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_create_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_get_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_set_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_create.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_free.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_get.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_set.lo
  CC       src/mpi/errhan/lib_libmpi_la-error_class.lo
  CC       src/mpi/errhan/lib_libmpi_la-error_string.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_create_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_get_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_set_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_call_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_create_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_call_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_get_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_set_errhandler.lo
  CC       src/mpi/group/lib_libmpi_la-group_compare.lo
  CC       src/mpi/group/lib_libmpi_la-group_difference.lo
  CC       src/mpi/group/lib_libmpi_la-group_excl.lo
  CC       src/mpi/group/lib_libmpi_la-group_free.lo
  CC       src/mpi/group/lib_libmpi_la-group_incl.lo
  CC       src/mpi/group/lib_libmpi_la-group_intersection.lo
  CC       src/mpi/group/lib_libmpi_la-group_range_excl.lo
  CC       src/mpi/group/lib_libmpi_la-group_range_incl.lo
  CC       src/mpi/group/lib_libmpi_la-group_rank.lo
  CC       src/mpi/group/lib_libmpi_la-group_size.lo
  CC       src/mpi/group/lib_libmpi_la-group_translate_ranks.lo
  CC       src/mpi/group/lib_libmpi_la-group_union.lo
  CC       src/mpi/info/lib_libmpi_la-info_create.lo
  CC       src/mpi/info/lib_libmpi_la-info_delete.lo
  CC       src/mpi/info/lib_libmpi_la-info_dup.lo
  CC       src/mpi/info/lib_libmpi_la-info_free.lo
  CC       src/mpi/info/lib_libmpi_la-info_get.lo
  CC       src/mpi/info/lib_libmpi_la-info_getn.lo
  CC       src/mpi/info/lib_libmpi_la-info_getnth.lo
  CC       src/mpi/info/lib_libmpi_la-info_getvallen.lo
  CC       src/mpi/info/lib_libmpi_la-info_set.lo
  CC       src/mpi/init/lib_libmpi_la-abort.lo
  CC       src/mpi/init/lib_libmpi_la-init.lo
  CC       src/mpi/init/lib_libmpi_la-initialized.lo
  CC       src/mpi/init/lib_libmpi_la-initthread.lo
  CC       src/mpi/init/lib_libmpi_la-ismain.lo
  CC       src/mpi/init/lib_libmpi_la-finalize.lo
  CC       src/mpi/init/lib_libmpi_la-finalized.lo
  CC       src/mpi/init/lib_libmpi_la-querythread.lo
  CC       src/mpi/misc/lib_libmpi_la-getpname.lo
  CC       src/mpi/misc/lib_libmpi_la-pcontrol.lo
  CC       src/mpi/misc/lib_libmpi_la-version.lo
  CC       src/mpi/misc/lib_libmpi_la-library_version.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bsend_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bufattach.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-buffree.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-cancel.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-greq_start.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-greq_complete.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-ibsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-improbe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-imrecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-iprobe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-irecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-irsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-isend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-issend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-mprobe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-mrecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-probe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-recv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-recv_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-request_free.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-request_get_status.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-rsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-rsend_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-send.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-send_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-sendrecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-sendrecv_rep.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-status_set_cancelled.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-ssend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-ssend_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-start.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-startall.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-test.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-test_cancelled.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-testall.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-testany.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-testsome.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-wait.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-waitall.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-waitany.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-waitsome.lo
  CC       src/mpi/rma/lib_libmpi_la-accumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-alloc_mem.lo
  CC       src/mpi/rma/lib_libmpi_la-compare_and_swap.lo
  CC       src/mpi/rma/lib_libmpi_la-fetch_and_op.lo
  CC       src/mpi/rma/lib_libmpi_la-free_mem.lo
  CC       src/mpi/rma/lib_libmpi_la-get.lo
  CC       src/mpi/rma/lib_libmpi_la-get_accumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-put.lo
  CC       src/mpi/rma/lib_libmpi_la-raccumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-rget.lo
  CC       src/mpi/rma/lib_libmpi_la-rget_accumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-rput.lo
  CC       src/mpi/rma/lib_libmpi_la-win_allocate.lo
  CC       src/mpi/rma/lib_libmpi_la-win_allocate_shared.lo
  CC       src/mpi/rma/lib_libmpi_la-win_attach.lo
  CC       src/mpi/rma/lib_libmpi_la-win_complete.lo
  CC       src/mpi/rma/lib_libmpi_la-win_create.lo
  CC       src/mpi/rma/lib_libmpi_la-win_create_dynamic.lo
  CC       src/mpi/rma/lib_libmpi_la-win_detach.lo
  CC       src/mpi/rma/lib_libmpi_la-win_fence.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush_local.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush_local_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_free.lo
  CC       src/mpi/rma/lib_libmpi_la-win_get_group.lo
  CC       src/mpi/rma/lib_libmpi_la-win_get_info.lo
  CC       src/mpi/rma/lib_libmpi_la-win_get_name.lo
  CC       src/mpi/rma/lib_libmpi_la-win_lock.lo
  CC       src/mpi/rma/lib_libmpi_la-win_lock_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_post.lo
  CC       src/mpi/rma/lib_libmpi_la-win_set_info.lo
  CC       src/mpi/rma/lib_libmpi_la-win_set_name.lo
  CC       src/mpi/rma/lib_libmpi_la-win_shared_query.lo
  CC       src/mpi/rma/lib_libmpi_la-win_start.lo
  CC       src/mpi/rma/lib_libmpi_la-win_sync.lo
  CC       src/mpi/rma/lib_libmpi_la-win_test.lo
  CC       src/mpi/rma/lib_libmpi_la-win_unlock.lo
  CC       src/mpi/rma/lib_libmpi_la-win_unlock_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_wait.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_disconnect.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_get_parent.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_join.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_spawn.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_spawn_multiple.lo
  CC       src/mpi/spawn/lib_libmpi_la-lookup_name.lo
  CC       src/mpi/spawn/lib_libmpi_la-publish_name.lo
  CC       src/mpi/spawn/lib_libmpi_la-unpublish_name.lo
  CC       src/mpi/spawn/lib_libmpi_la-open_port.lo
  CC       src/mpi/spawn/lib_libmpi_la-close_port.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_connect.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_accept.lo
  CC       src/mpi/timer/lib_libmpi_la-wtime.lo
  CC       src/mpi/timer/lib_libmpi_la-wtick.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_coords.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_create.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_get.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_map.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_rank.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_shift.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_sub.lo
  CC       src/mpi/topo/lib_libmpi_la-dims_create.lo
  CC       src/mpi/topo/lib_libmpi_la-graph_get.lo
  CC       src/mpi/topo/lib_libmpi_la-graph_map.lo
  CC       src/mpi/topo/lib_libmpi_la-graph_nbr.lo
  CC       src/mpi/topo/lib_libmpi_la-graphcreate.lo
  CC       src/mpi/topo/lib_libmpi_la-graphdimsget.lo
  CC       src/mpi/topo/lib_libmpi_la-graphnbrcnt.lo
  CC       src/mpi/topo/lib_libmpi_la-cartdim_get.lo
  CC       src/mpi/topo/lib_libmpi_la-topo_test.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_create_adj.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_create.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_neighb_count.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_neighb.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_allgather.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_allgatherv.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_alltoall.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_alltoallv.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_alltoallw.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_allgather.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_allgatherv.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_alltoall.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_alltoallv.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_alltoallw.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-statusf2c.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-statusc2f.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_int.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_real.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_complex.lo
  CC       src/glue/romio/lib_libmpi_la-all_romio_symbols.lo
  CC       src/mutex/lib_libmpi_la-mutex_create.lo
  CC       src/mutex/lib_libmpi_la-mutex_free.lo
  CC       src/mutex/lib_libmpi_la-mutex_lock.lo
  CC       src/mutex/lib_libmpi_la-mutex_unlock.lo
  CC       src/mpi_t/lib_libmpi_la-cat_changed.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_categories.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_cvars.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_num.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_pvars.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_get_num.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_handle_alloc.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_handle_free.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_read.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_write.lo
  CC       src/mpi_t/lib_libmpi_la-enum_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-enum_get_item.lo
  CC       src/mpi_t/lib_libmpi_la-mpit_finalize.lo
  CC       src/mpi_t/lib_libmpi_la-mpit_initthread.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_get_num.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_handle_alloc.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_handle_free.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_read.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_readreset.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_reset.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_session_create.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_session_free.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_start.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_stop.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_write.lo
  CC       src/util/dbg/lib_libmpi_la-dbg_printf.lo
  CC       src/util/dbg/lib_libmpi_la-timelimit.lo
  CC       src/util/dbg/lib_libmpi_la-exit.lo
  CC       src/util/instrm/lib_libmpi_la-states.lo
  CC       src/util/instrm/lib_libmpi_la-instr.lo
  CC       src/util/mem/lib_libmpi_la-trmem.lo
  CC       src/util/mem/lib_libmpi_la-handlemem.lo
  CC       src/util/mem/lib_libmpi_la-safestr.lo
  CC       src/util/mem/lib_libmpi_la-argstr.lo
  CC       src/util/mem/lib_libmpi_la-strerror.lo
  CC       src/util/msgs/lib_libmpi_la-msgprint.lo
  CC       src/util/other/lib_libmpi_la-outliers.lo
  CC       src/util/other/lib_libmpi_la-assert.lo
  CC       src/util/cvar/lib_libmpi_la-mpich_cvars.lo
  CC       src/util/procmap/lib_libmpi_la-local_proc.lo
  CC       src/util/thread/lib_libmpi_la-mpiu_thread.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_buffer.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_comm.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_comm_spawn_multiple.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_connection.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_recv_pkt.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_recv_req.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_revoke_pkt.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_send_req.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_port.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_recvq.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_request.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_acc_ops.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_ops.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_reqops.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_sync.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rndv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_eager.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_eagersync.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_win_fns.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_abort.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_cancel_recv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_cancel_send.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_disconnect.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_spawn_multiple.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_failure_ack.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_get_all_failed_procs.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_revoke.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_agree.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_finalize.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_get_universe_size.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_getpname.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_improbe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_imrecv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_init.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_iprobe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_irecv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_irsend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_isend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_issend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_mprobe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_mrecv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_port.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_probe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_recv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_rsend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_send.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_ssend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_startall.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_vc.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_rma.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpidi_isend_self.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpidi_pg.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpidi_printf.lo
  CC       src/mpid/ch3/util/sock/lib_libmpi_la-ch3u_init_sock.lo
  CC       src/mpid/ch3/util/sock/lib_libmpi_la-ch3u_connect_sock.lo
  CC       src/mpid/ch3/util/sock/lib_libmpi_la-ch3u_getinterfaces.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_finalize.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_init.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_isend.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_isendv.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_istartmsg.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_istartmsgv.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_progress.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_win_fns.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-darray_support.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_blockindexed.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_contig.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_indexed.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_pairtype.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_struct.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_vector.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment_count.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment_flatten.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment_packunpack.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-subarray_support.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_contents_support.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_datatype_contents.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_datatype_free.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_ext32_datatype.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_ext32_segment.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_segment.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_blockindexed.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_commit.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_contiguous.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_create_pairtype.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_create_resized.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_debug.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_dup.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_get_contents.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_get_envelope.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_indexed.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_struct.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_vector.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_zerolen.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpir_type_flatten.lo
  CC       src/mpid/common/sched/lib_libmpi_la-mpid_sched.lo
  CC       src/mpid/common/sock/poll/lib_libmpi_la-sock.lo
  CC       src/mpid/common/thread/lib_libmpi_la-mpid_thread.lo
  CC       src/nameserv/pmi/lib_libmpi_la-pmi_nameserv.lo
  CC       src/pmi/simple/lib_libmpi_la-simple_pmiutil.lo
  CC       src/pmi/simple/lib_libmpi_la-simple_pmi.lo
  MOD      src/binding/fortran/use_mpi/mpi_constants.mod-stamp
  MOD      src/binding/fortran/use_mpi/mpi_sizeofs.mod-stamp
  CXX      src/binding/cxx/initcxx.lo
  CC       src/env/mpichversion.o
  CC       src/env/mpivars.o
  GEN      lib/libmpi.la
  MOD      src/binding/fortran/use_mpi/mpi_base.mod-stamp
  MOD      src/binding/fortran/use_mpi/mpi.mod-stamp
  CXXLD    lib/libmpicxx.la
  GEN      lib/libmpifort.la
  CCLD     src/env/mpichversion
  CCLD     src/env/mpivars
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making all in examples
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
  CC       cpi.o
  CCLD     cpi
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
                              Running make install on MPICH; this may take several minutes
Executing: cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3 && /usr/bin/make install
stdout:
/usr/bin/make  install-recursive
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making install in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[3]: Nothing to be done for `install-exec-am'.
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making install in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making install in src
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[4]: Nothing to be done for `install-exec-am'.
 /bin/mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /usr/bin/install -c -m 644 opa_primitives.h opa_queue.h opa_util.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /bin/mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include/primitives'
 /usr/bin/install -c -m 644 opa_config.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
Making install in test
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[4]: Nothing to be done for `install-data-am'.
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
 /bin/mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
 /usr/bin/install -c -m 644 openpa.pc '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making install in src/mpi/romio
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
 /usr/bin/install -c -m 644 include/mpio.h include/mpiof.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
Making install in src/pm/hydra
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making install in ../../mpl
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making install in tools/topo/hwloc/hwloc
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
/usr/bin/make  install-exec-hook
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[6]: Nothing to be done for `install-exec-hook'.
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
Making install in include
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making install in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
  /bin/bash ./libtool   --mode=install /usr/bin/install -c hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
libtool: install: /usr/bin/install -c hydra_persist /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/hydra_persist
libtool: install: /usr/bin/install -c hydra_nameserver /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/hydra_nameserver
libtool: install: /usr/bin/install -c hydra_pmi_proxy /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/hydra_pmi_proxy
libtool: install: /usr/bin/install -c mpiexec.hydra /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpiexec.hydra
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
if [ -x /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpiexec.hydra ] ; then \
	    cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpiexec.hydra mpiexec ; \
	    cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpiexec.hydra mpirun ; \
	fi
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making install in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib'
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   lib/libmpi.la lib/libmpifort.la lib/libmpicxx.la '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib'
libtool: install: /usr/bin/install -c lib/.libs/libmpi.so.12.0.4 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.so.12.0.4
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpi.so.12.0.4 libmpi.so.12 || { rm -f libmpi.so.12 && ln -s libmpi.so.12.0.4 libmpi.so.12; }; })
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpi.so.12.0.4 libmpi.so || { rm -f libmpi.so && ln -s libmpi.so.12.0.4 libmpi.so; }; })
libtool: install: /usr/bin/install -c lib/.libs/libmpi.lai /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.la
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3; /bin/bash /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/libtool  --silent --tag FC --mode=relink gfortran -Isrc/binding/fortran/use_mpi -Jsrc/binding/fortran/use_mpi -fPIC -ffree-line-length-0 -g -O0 -version-info 12:4:0 -o lib/libmpifort.la -rpath /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib src/binding/fortran/mpif_h/lib_libmpifort_la-sendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-recvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_countf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ssendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bufattachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bufdetachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-isendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ibsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-issendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-irsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-irecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-request_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitanyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testanyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitsomef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testsomef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iprobef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-probef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cancelf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testcancelf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-send_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bsend_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ssend_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rsend_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-recv_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-startf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-startallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-sendrecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-sndrcvrplf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecontigf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_vectorf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_hvectorf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_indexedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_hindexedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_structf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_extentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_lbf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_ubf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_commitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_elementsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-packf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-unpackf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-pack_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-barrierf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bcastf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-gatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-gathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-scatterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-scattervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-allgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-allgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-exscanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-op_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-op_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-allreducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-redscatf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-scanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_rankf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grouptranksf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_comparef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_unionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-groupinterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-groupdifff.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_inclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_exclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grouprinclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grouprexclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_rankf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_comparef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dup_with_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_splitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commtesticf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commrsizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commrgroupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iccreatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-icmergef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-attr_putf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-attr_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-attr_deletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-topo_testf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dims_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graph_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graphdims_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graph_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cartdim_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_rankf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_coordsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbcountf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbrsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_shiftf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_subf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_mapf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graph_mapf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-getpnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_versionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_library_versionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhcreatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhsetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhgetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhfreef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-error_stringf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-error_classf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-finalizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-initializedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-abortf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-close_portf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_acceptf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_connectf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commdiscf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commparentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_joinf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_spawnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-spawnmultf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-lookup_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-open_portf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-publish_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-unpubnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-accumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-putf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_completef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_fencef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_lockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_postf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_startf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_testf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_waitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocate_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_shared_queryf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_create_dynamicf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_attachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_detachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_accumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-fetch_and_opf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-compare_and_swapf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rputf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rgetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-raccumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rget_accumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_lock_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlock_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flushf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_localf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_local_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_syncf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-adderrclassf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-adderrcodef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-adderrstringf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commcallerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commnewkeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commdelattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commfreekeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commgetnamf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-filecallerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-greqcompletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-greqstartf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-isthrmainf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-query_threadf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-statgetclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-statsetelf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typenewkeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typedelattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_dupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typefreekeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegetcntsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegetenvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typesetattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typesetnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_match_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wincallerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-winnewkeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-windelattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-winfreekeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alloc_memf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commcreerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commgeterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commseterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-filecreerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-filegeterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-fileseterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-finalizedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-free_memf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_deletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_dupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-infognkf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-infognthkf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-infovallenf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_setf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-pack_externalf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-packesizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reqgetstatf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typedarrayf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typechindf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typechvecf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecindbf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_create_hindexed_blockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecresizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecstructf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecsubarrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegetextentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegtextf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-unpackextf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wincreerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wingeterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-winseterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_localf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-op_commutativef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_scatter_blockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_create_adjacentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighbors_countf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighborsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-improbef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-imrecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-mprobef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-mrecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_idupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ibarrierf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ibcastf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-igatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-igathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iscatterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iscattervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iallgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iallgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ireducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iallreducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatter_blockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iscanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iexscanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_split_typef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_elements_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-status_set_elements_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_extent_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_true_extent_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_size_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_create_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_ackf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_get_ackedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_revokef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_shrinkf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_agreef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_openf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_closef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_deletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_preallocatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_amodef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_viewf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_viewf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_readf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_writef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_ireadf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwritef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_seekf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_positionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_byte_offsetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_orderedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_orderedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_seek_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_position_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_type_extentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-register_datarepf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_atomicityf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_atomicityf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_syncf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-initthreadf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-pcontrolf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-addressf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-getaddressf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wtimef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wtickf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_copy_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_comm_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_copy_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_win_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_copy_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_type_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_copy_fnf.lo src/binding/fortran/use_mpi/lib_libmpifort_la-typef90cmplxf.lo src/binding/fortran/use_mpi/lib_libmpifort_la-typef90realf.lo src/binding/fortran/use_mpi/lib_libmpifort_la-typef90intf.lo src/binding/fortran/use_mpi/mpi.lo src/binding/fortran/use_mpi/mpi_constants.lo src/binding/fortran/use_mpi/mpi_sizeofs.lo src/binding/fortran/use_mpi/mpi_base.lo lib/libmpi.la -lpthread )
libtool: install: /usr/bin/install -c lib/.libs/libmpifort.so.12.0.4T /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.so.12.0.4
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpifort.so.12.0.4 libmpifort.so.12 || { rm -f libmpifort.so.12 && ln -s libmpifort.so.12.0.4 libmpifort.so.12; }; })
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpifort.so.12.0.4 libmpifort.so || { rm -f libmpifort.so && ln -s libmpifort.so.12.0.4 libmpifort.so; }; })
libtool: install: /usr/bin/install -c lib/.libs/libmpifort.lai /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.la
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3; /bin/bash /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/libtool  --silent --tag CXX --mode=relink g++ -g -fPIC -O0 -version-info 12:4:0 -o lib/libmpicxx.la -rpath /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib src/binding/cxx/initcxx.lo lib/libmpi.la -lpthread )
libtool: install: /usr/bin/install -c lib/.libs/libmpicxx.so.12.0.4T /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.so.12.0.4
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpicxx.so.12.0.4 libmpicxx.so.12 || { rm -f libmpicxx.so.12 && ln -s libmpicxx.so.12.0.4 libmpicxx.so.12; }; })
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpicxx.so.12.0.4 libmpicxx.so || { rm -f libmpicxx.so && ln -s libmpicxx.so.12.0.4 libmpicxx.so; }; })
libtool: install: /usr/bin/install -c lib/.libs/libmpicxx.lai /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.la
libtool: install: /usr/bin/install -c lib/.libs/libmpi.a /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.a
libtool: install: chmod 644 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.a
libtool: install: ranlib /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.a
libtool: install: /usr/bin/install -c lib/.libs/libmpifort.a /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.a
libtool: install: chmod 644 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.a
libtool: install: ranlib /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.a
libtool: install: /usr/bin/install -c lib/.libs/libmpicxx.a /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.a
libtool: install: chmod 644 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.a
libtool: install: ranlib /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.a
libtool: finish: PATH="/usr/lib/mutt:/home/tisaac/.local/bin:/usr/local/texlive/2015/bin/x86_64-linux:/home/tisaac/.bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/tisaac/.bin:/sbin" ldconfig -n /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
  /bin/bash ./libtool   --mode=install /usr/bin/install -c src/env/mpichversion src/env/mpivars '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
libtool: install: /usr/bin/install -c src/env/mpichversion /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpichversion
libtool: install: /usr/bin/install -c src/env/mpivars /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpivars
 /usr/bin/install -c src/env/mpicc src/env/parkill src/env/mpifort src/env/mpicxx '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
for e in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx \
		/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif77 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpifort ; do \
		if test -e ${e} ; then \
			sed -e 's|__PREFIX_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich|g' \
				-e 's|__EXEC_PREFIX_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich|g' \
				-e 's|__SYSCONFDIR_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/etc|g' \
				-e 's|__INCLUDEDIR_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include|g' \
				-e 's|__LIBDIR_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib|g' ${e} > ${e}.tmp ; \
			/usr/bin/install -c ${e}.tmp ${e} ; \
			rm -f ${e}.tmp ; \
		fi ; \
	done ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpicxx mpic++ ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpifort ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpifort mpif90 ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpifort -a ! -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif77 ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpifort mpif77 ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.so ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpi.so libmpl.so ; \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpi.so libopa.so ; \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpi.so libmpich.so ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.so ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpifort.so libfmpich.so ; \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpifort.so libmpichf90.so ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.so ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpicxx.so libmpichcxx.so ; fi
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
/usr/bin/install -c -m 644 hydra_nameserver.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/hydra_nameserver.1
/usr/bin/install -c -m 644 hydra_persist.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/hydra_persist.1
/usr/bin/install -c -m 644 hydra_pmi_proxy.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/hydra_pmi_proxy.1
/usr/bin/install -c -m 644 mpicc.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpicc.1
/usr/bin/install -c -m 644 mpicxx.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpicxx.1
/usr/bin/install -c -m 644 mpiexec.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpiexec.1
/usr/bin/install -c -m 644 mpif77.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpif77.1
/usr/bin/install -c -m 644 mpifort.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpifort.1
/usr/bin/install -c -m 644 MPI_Abort.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Abort.3
/usr/bin/install -c -m 644 MPI_Accumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Accumulate.3
/usr/bin/install -c -m 644 MPI_Add_error_class.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Add_error_class.3
/usr/bin/install -c -m 644 MPI_Add_error_code.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Add_error_code.3
/usr/bin/install -c -m 644 MPI_Add_error_string.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Add_error_string.3
/usr/bin/install -c -m 644 MPI_Address.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Address.3
/usr/bin/install -c -m 644 MPI_Allgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Allgather.3
/usr/bin/install -c -m 644 MPI_Allgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Allgatherv.3
/usr/bin/install -c -m 644 MPI_Alloc_mem.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alloc_mem.3
/usr/bin/install -c -m 644 MPI_Allreduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Allreduce.3
/usr/bin/install -c -m 644 MPI_Alltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alltoall.3
/usr/bin/install -c -m 644 MPI_Alltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alltoallv.3
/usr/bin/install -c -m 644 MPI_Alltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alltoallw.3
/usr/bin/install -c -m 644 MPI_Attr_delete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Attr_delete.3
/usr/bin/install -c -m 644 MPI_Attr_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Attr_get.3
/usr/bin/install -c -m 644 MPI_Attr_put.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Attr_put.3
/usr/bin/install -c -m 644 MPI_Barrier.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Barrier.3
/usr/bin/install -c -m 644 MPI_Bcast.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Bcast.3
/usr/bin/install -c -m 644 MPI_Bsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Bsend.3
/usr/bin/install -c -m 644 MPI_Bsend_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Bsend_init.3
/usr/bin/install -c -m 644 MPI_Buffer_attach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Buffer_attach.3
/usr/bin/install -c -m 644 MPI_Buffer_detach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Buffer_detach.3
/usr/bin/install -c -m 644 MPI_Cancel.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cancel.3
/usr/bin/install -c -m 644 MPI_Cart_coords.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_coords.3
/usr/bin/install -c -m 644 MPI_Cart_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_create.3
/usr/bin/install -c -m 644 MPI_Cartdim_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cartdim_get.3
/usr/bin/install -c -m 644 MPI_Cart_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_get.3
/usr/bin/install -c -m 644 MPI_Cart_map.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_map.3
/usr/bin/install -c -m 644 MPI_Cart_rank.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_rank.3
/usr/bin/install -c -m 644 MPI_Cart_shift.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_shift.3
/usr/bin/install -c -m 644 MPI_Cart_sub.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_sub.3
/usr/bin/install -c -m 644 MPI_Close_port.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Close_port.3
/usr/bin/install -c -m 644 MPI_Comm_accept.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_accept.3
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_compare.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_compare.3
/usr/bin/install -c -m 644 MPI_Comm_connect.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_connect.3
/usr/bin/install -c -m 644 MPI_Comm_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create.3
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_create_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create_group.3
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_delete_attr.3
/usr/bin/install -c -m 644 MPI_Comm_disconnect.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_disconnect.3
/usr/bin/install -c -m 644 MPI_Comm_dup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_dup.3
/usr/bin/install -c -m 644 MPI_Comm_dup_with_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_dup_with_info.3
/usr/bin/install -c -m 644 MPI_Comm_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_free.3
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_free_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_get_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_attr.3
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_info.3
/usr/bin/install -c -m 644 MPI_Comm_get_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_name.3
/usr/bin/install -c -m 644 MPI_Comm_get_parent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_parent.3
/usr/bin/install -c -m 644 MPI_Comm_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_group.3
/usr/bin/install -c -m 644 MPI_Comm_idup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_idup.3
/usr/bin/install -c -m 644 MPI_Comm_join.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_join.3
/usr/bin/install -c -m 644 MPI_Comm_rank.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_rank.3
/usr/bin/install -c -m 644 MPI_Comm_remote_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_remote_group.3
/usr/bin/install -c -m 644 MPI_Comm_remote_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_remote_size.3
/usr/bin/install -c -m 644 MPI_Comm_set_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_attr.3
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_set_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_info.3
/usr/bin/install -c -m 644 MPI_Comm_set_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_name.3
/usr/bin/install -c -m 644 MPI_Comm_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_size.3
/usr/bin/install -c -m 644 MPI_Comm_spawn.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_spawn.3
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_spawn_multiple.3
/usr/bin/install -c -m 644 MPI_Comm_split.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_split.3
/usr/bin/install -c -m 644 MPI_Comm_split_type.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_split_type.3
/usr/bin/install -c -m 644 MPI_Comm_test_inter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_test_inter.3
/usr/bin/install -c -m 644 MPI_Compare_and_swap.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Compare_and_swap.3
/usr/bin/install -c -m 644 MPI_Dims_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dims_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_create_adjacent.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Errhandler_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_create.3
/usr/bin/install -c -m 644 MPI_Errhandler_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_free.3
/usr/bin/install -c -m 644 MPI_Errhandler_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_get.3
/usr/bin/install -c -m 644 MPI_Errhandler_set.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_set.3
/usr/bin/install -c -m 644 MPI_Error_class.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Error_class.3
/usr/bin/install -c -m 644 MPI_Error_string.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Error_string.3
/usr/bin/install -c -m 644 MPI_Exscan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Exscan.3
/usr/bin/install -c -m 644 MPI_Fetch_and_op.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Fetch_and_op.3
/usr/bin/install -c -m 644 MPI_File_c2f.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_c2f.3
/usr/bin/install -c -m 644 MPI_File_call_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_call_errhandler.3
/usr/bin/install -c -m 644 MPI_File_close.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_close.3
/usr/bin/install -c -m 644 MPI_File_create_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_create_errhandler.3
/usr/bin/install -c -m 644 MPI_File_delete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_delete.3
/usr/bin/install -c -m 644 MPI_File_f2c.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_f2c.3
/usr/bin/install -c -m 644 MPI_File_get_amode.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_amode.3
/usr/bin/install -c -m 644 MPI_File_get_atomicity.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_atomicity.3
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_byte_offset.3
/usr/bin/install -c -m 644 MPI_File_get_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_errhandler.3
/usr/bin/install -c -m 644 MPI_File_get_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_group.3
/usr/bin/install -c -m 644 MPI_File_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_info.3
/usr/bin/install -c -m 644 MPI_File_get_position.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_position.3
/usr/bin/install -c -m 644 MPI_File_get_position_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_position_shared.3
/usr/bin/install -c -m 644 MPI_File_get_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_size.3
/usr/bin/install -c -m 644 MPI_File_get_type_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_type_extent.3
/usr/bin/install -c -m 644 MPI_File_get_view.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_view.3
/usr/bin/install -c -m 644 MPI_File_iread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iread.3
/usr/bin/install -c -m 644 MPI_File_iread_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iread_at.3
/usr/bin/install -c -m 644 MPI_File_iread_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iread_shared.3
/usr/bin/install -c -m 644 MPI_File_iwrite.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iwrite.3
/usr/bin/install -c -m 644 MPI_File_iwrite_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iwrite_at.3
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iwrite_shared.3
/usr/bin/install -c -m 644 MPI_File_open.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_open.3
/usr/bin/install -c -m 644 MPI_File_preallocate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_preallocate.3
/usr/bin/install -c -m 644 MPI_File_read.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read.3
/usr/bin/install -c -m 644 MPI_File_read_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_all.3
/usr/bin/install -c -m 644 MPI_File_read_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at.3
/usr/bin/install -c -m 644 MPI_File_read_at_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at_all.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_ordered.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_ordered.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_read_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_shared.3
/usr/bin/install -c -m 644 MPI_File_seek.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_seek.3
/usr/bin/install -c -m 644 MPI_File_seek_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_seek_shared.3
/usr/bin/install -c -m 644 MPI_File_set_atomicity.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_atomicity.3
/usr/bin/install -c -m 644 MPI_File_set_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_errhandler.3
/usr/bin/install -c -m 644 MPI_File_set_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_info.3
/usr/bin/install -c -m 644 MPI_File_set_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_size.3
/usr/bin/install -c -m 644 MPI_File_set_view.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_view.3
/usr/bin/install -c -m 644 MPI_File_sync.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_sync.3
/usr/bin/install -c -m 644 MPI_File_write.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write.3
/usr/bin/install -c -m 644 MPI_File_write_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_all.3
/usr/bin/install -c -m 644 MPI_File_write_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at.3
/usr/bin/install -c -m 644 MPI_File_write_at_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at_all.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_ordered.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_ordered.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_write_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_shared.3
/usr/bin/install -c -m 644 MPI_Finalize.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Finalize.3
/usr/bin/install -c -m 644 MPI_Finalized.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Finalized.3
/usr/bin/install -c -m 644 MPI_Free_mem.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Free_mem.3
/usr/bin/install -c -m 644 MPI_Gather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Gather.3
/usr/bin/install -c -m 644 MPI_Gatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Gatherv.3
/usr/bin/install -c -m 644 MPI_Get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get.3
/usr/bin/install -c -m 644 MPI_Get_accumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_accumulate.3
/usr/bin/install -c -m 644 MPI_Get_address.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_address.3
/usr/bin/install -c -m 644 MPI_Get_count.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_count.3
/usr/bin/install -c -m 644 MPI_Get_elements.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_elements.3
/usr/bin/install -c -m 644 MPI_Get_elements_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_elements_x.3
/usr/bin/install -c -m 644 MPI_Get_library_version.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_library_version.3
/usr/bin/install -c -m 644 MPI_Get_processor_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_processor_name.3
/usr/bin/install -c -m 644 MPI_Get_version.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_version.3
/usr/bin/install -c -m 644 MPI_Graph_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_create.3
/usr/bin/install -c -m 644 MPI_Graphdims_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graphdims_get.3
/usr/bin/install -c -m 644 MPI_Graph_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_get.3
/usr/bin/install -c -m 644 MPI_Graph_map.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_map.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Grequest_complete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Grequest_complete.3
/usr/bin/install -c -m 644 MPI_Grequest_start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Grequest_start.3
/usr/bin/install -c -m 644 MPI_Group_compare.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_compare.3
/usr/bin/install -c -m 644 MPI_Group_difference.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_difference.3
/usr/bin/install -c -m 644 MPI_Group_excl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_excl.3
/usr/bin/install -c -m 644 MPI_Group_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_free.3
/usr/bin/install -c -m 644 MPI_Group_incl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_incl.3
/usr/bin/install -c -m 644 MPI_Group_intersection.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_intersection.3
/usr/bin/install -c -m 644 MPI_Group_range_excl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_range_excl.3
/usr/bin/install -c -m 644 MPI_Group_range_incl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_range_incl.3
/usr/bin/install -c -m 644 MPI_Group_rank.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_rank.3
/usr/bin/install -c -m 644 MPI_Group_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_size.3
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_translate_ranks.3
/usr/bin/install -c -m 644 MPI_Group_union.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_union.3
/usr/bin/install -c -m 644 MPI_Iallgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iallgather.3
/usr/bin/install -c -m 644 MPI_Iallgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iallgatherv.3
/usr/bin/install -c -m 644 MPI_Iallreduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iallreduce.3
/usr/bin/install -c -m 644 MPI_Ialltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ialltoall.3
/usr/bin/install -c -m 644 MPI_Ialltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ialltoallv.3
/usr/bin/install -c -m 644 MPI_Ialltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ialltoallw.3
/usr/bin/install -c -m 644 MPI_Ibarrier.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ibarrier.3
/usr/bin/install -c -m 644 MPI_Ibcast.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ibcast.3
/usr/bin/install -c -m 644 MPI_Ibsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ibsend.3
/usr/bin/install -c -m 644 MPI_Iexscan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iexscan.3
/usr/bin/install -c -m 644 MPI_Igather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Igather.3
/usr/bin/install -c -m 644 MPI_Igatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Igatherv.3
/usr/bin/install -c -m 644 MPI_Improbe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Improbe.3
/usr/bin/install -c -m 644 MPI_Imrecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Imrecv.3
/usr/bin/install -c -m 644 MPI_Ineighbor_allgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_allgather.3
/usr/bin/install -c -m 644 MPI_Ineighbor_allgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_allgatherv.3
/usr/bin/install -c -m 644 MPI_Ineighbor_alltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_alltoall.3
/usr/bin/install -c -m 644 MPI_Ineighbor_alltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_alltoallv.3
/usr/bin/install -c -m 644 MPI_Ineighbor_alltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_alltoallw.3
/usr/bin/install -c -m 644 MPI_Info_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_create.3
/usr/bin/install -c -m 644 MPI_Info_delete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_delete.3
/usr/bin/install -c -m 644 MPI_Info_dup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_dup.3
/usr/bin/install -c -m 644 MPI_Info_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_free.3
/usr/bin/install -c -m 644 MPI_Info_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get.3
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get_nkeys.3
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get_nthkey.3
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get_valuelen.3
/usr/bin/install -c -m 644 MPI_Info_set.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_set.3
/usr/bin/install -c -m 644 MPI_Init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Init.3
/usr/bin/install -c -m 644 MPI_Initialized.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Initialized.3
/usr/bin/install -c -m 644 MPI_Init_thread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Init_thread.3
/usr/bin/install -c -m 644 MPI_Intercomm_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Intercomm_create.3
/usr/bin/install -c -m 644 MPI_Intercomm_merge.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Intercomm_merge.3
/usr/bin/install -c -m 644 MPI_Iprobe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iprobe.3
/usr/bin/install -c -m 644 MPI_Irecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Irecv.3
/usr/bin/install -c -m 644 MPI_Ireduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ireduce.3
/usr/bin/install -c -m 644 MPI_Ireduce_scatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ireduce_scatter.3
/usr/bin/install -c -m 644 MPI_Ireduce_scatter_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ireduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Irsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Irsend.3
/usr/bin/install -c -m 644 MPI_Iscan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iscan.3
/usr/bin/install -c -m 644 MPI_Iscatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iscatter.3
/usr/bin/install -c -m 644 MPI_Iscatterv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iscatterv.3
/usr/bin/install -c -m 644 MPI_Isend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Isend.3
/usr/bin/install -c -m 644 MPI_Issend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Issend.3
/usr/bin/install -c -m 644 MPI_Is_thread_main.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Is_thread_main.3
/usr/bin/install -c -m 644 MPI_Keyval_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Keyval_create.3
/usr/bin/install -c -m 644 MPI_Keyval_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Keyval_free.3
/usr/bin/install -c -m 644 MPI_Lookup_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Lookup_name.3
/usr/bin/install -c -m 644 MPI_Mprobe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Mprobe.3
/usr/bin/install -c -m 644 MPI_Mrecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Mrecv.3
/usr/bin/install -c -m 644 MPI_Neighbor_allgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_allgather.3
/usr/bin/install -c -m 644 MPI_Neighbor_allgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_allgatherv.3
/usr/bin/install -c -m 644 MPI_Neighbor_alltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_alltoall.3
/usr/bin/install -c -m 644 MPI_Neighbor_alltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_alltoallv.3
/usr/bin/install -c -m 644 MPI_Neighbor_alltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_alltoallw.3
/usr/bin/install -c -m 644 MPI_Op_commute.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Op_commute.3
/usr/bin/install -c -m 644 MPI_Op_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Op_create.3
/usr/bin/install -c -m 644 MPI_Open_port.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Open_port.3
/usr/bin/install -c -m 644 MPI_Op_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Op_free.3
/usr/bin/install -c -m 644 MPI_Pack.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack.3
/usr/bin/install -c -m 644 MPI_Pack_external.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack_external.3
/usr/bin/install -c -m 644 MPI_Pack_external_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack_external_size.3
/usr/bin/install -c -m 644 MPI_Pack_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack_size.3
/usr/bin/install -c -m 644 MPI_Pcontrol.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pcontrol.3
/usr/bin/install -c -m 644 MPI_Probe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Probe.3
/usr/bin/install -c -m 644 MPI_Publish_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Publish_name.3
/usr/bin/install -c -m 644 MPI_Put.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Put.3
/usr/bin/install -c -m 644 MPI_Query_thread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Query_thread.3
/usr/bin/install -c -m 644 MPI_Raccumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Raccumulate.3
/usr/bin/install -c -m 644 MPI_Recv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Recv.3
/usr/bin/install -c -m 644 MPI_Recv_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Recv_init.3
/usr/bin/install -c -m 644 MPI_Reduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce.3
/usr/bin/install -c -m 644 MPI_Reduce_local.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce_local.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce_scatter.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Register_datarep.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Register_datarep.3
/usr/bin/install -c -m 644 MPI_Request_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Request_free.3
/usr/bin/install -c -m 644 MPI_Request_get_status.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Request_get_status.3
/usr/bin/install -c -m 644 MPI_Rget.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rget.3
/usr/bin/install -c -m 644 MPI_Rget_accumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rget_accumulate.3
/usr/bin/install -c -m 644 MPI_Rput.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rput.3
/usr/bin/install -c -m 644 MPI_Rsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rsend.3
/usr/bin/install -c -m 644 MPI_Rsend_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rsend_init.3
/usr/bin/install -c -m 644 MPI_Scan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Scan.3
/usr/bin/install -c -m 644 MPI_Scatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Scatter.3
/usr/bin/install -c -m 644 MPI_Scatterv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Scatterv.3
/usr/bin/install -c -m 644 MPI_Send.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Send.3
/usr/bin/install -c -m 644 MPI_Send_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Send_init.3
/usr/bin/install -c -m 644 MPI_Sendrecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Sendrecv.3
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Sendrecv_replace.3
/usr/bin/install -c -m 644 MPI_Ssend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ssend.3
/usr/bin/install -c -m 644 MPI_Ssend_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ssend_init.3
/usr/bin/install -c -m 644 MPI_Start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Start.3
/usr/bin/install -c -m 644 MPI_Startall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Startall.3
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Status_set_cancelled.3
/usr/bin/install -c -m 644 MPI_Status_set_elements.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Status_set_elements.3
/usr/bin/install -c -m 644 MPI_Status_set_elements_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Status_set_elements_x.3
/usr/bin/install -c -m 644 MPI_T_category_changed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_changed.3
/usr/bin/install -c -m 644 MPI_T_category_get_categories.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_categories.3
/usr/bin/install -c -m 644 MPI_T_category_get_cvars.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_cvars.3
/usr/bin/install -c -m 644 MPI_T_category_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_info.3
/usr/bin/install -c -m 644 MPI_T_category_get_num.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_num.3
/usr/bin/install -c -m 644 MPI_T_category_get_pvars.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_pvars.3
/usr/bin/install -c -m 644 MPI_T_cvar_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_get_info.3
/usr/bin/install -c -m 644 MPI_T_cvar_get_num.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_get_num.3
/usr/bin/install -c -m 644 MPI_T_cvar_handle_alloc.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_handle_alloc.3
/usr/bin/install -c -m 644 MPI_T_cvar_handle_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_handle_free.3
/usr/bin/install -c -m 644 MPI_T_cvar_read.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_read.3
/usr/bin/install -c -m 644 MPI_T_cvar_write.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_write.3
/usr/bin/install -c -m 644 MPI_T_enum_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_enum_get_info.3
/usr/bin/install -c -m 644 MPI_T_enum_get_item.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_enum_get_item.3
/usr/bin/install -c -m 644 MPI_Test.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Test.3
/usr/bin/install -c -m 644 MPI_Testall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Testall.3
/usr/bin/install -c -m 644 MPI_Testany.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Testany.3
/usr/bin/install -c -m 644 MPI_Test_cancelled.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Test_cancelled.3
/usr/bin/install -c -m 644 MPI_Testsome.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Testsome.3
/usr/bin/install -c -m 644 MPI_T_finalize.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_finalize.3
/usr/bin/install -c -m 644 MPI_T_init_thread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_init_thread.3
/usr/bin/install -c -m 644 MPI_Topo_test.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Topo_test.3
/usr/bin/install -c -m 644 MPI_T_pvar_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_get_info.3
/usr/bin/install -c -m 644 MPI_T_pvar_get_num.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_get_num.3
/usr/bin/install -c -m 644 MPI_T_pvar_handle_alloc.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_handle_alloc.3
/usr/bin/install -c -m 644 MPI_T_pvar_handle_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_handle_free.3
/usr/bin/install -c -m 644 MPI_T_pvar_read.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_read.3
/usr/bin/install -c -m 644 MPI_T_pvar_readreset.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_readreset.3
/usr/bin/install -c -m 644 MPI_T_pvar_reset.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_reset.3
/usr/bin/install -c -m 644 MPI_T_pvar_session_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_session_create.3
/usr/bin/install -c -m 644 MPI_T_pvar_session_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_session_free.3
/usr/bin/install -c -m 644 MPI_T_pvar_start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_start.3
/usr/bin/install -c -m 644 MPI_T_pvar_stop.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_stop.3
/usr/bin/install -c -m 644 MPI_T_pvar_write.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_write.3
/usr/bin/install -c -m 644 MPI_Type_commit.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_commit.3
/usr/bin/install -c -m 644 MPI_Type_contiguous.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_contiguous.3
/usr/bin/install -c -m 644 MPI_Type_create_darray.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_darray.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_hindexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_hvector.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_hvector.3
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_indexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_keyval.3
/usr/bin/install -c -m 644 MPI_Type_create_resized.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_resized.3
/usr/bin/install -c -m 644 MPI_Type_create_struct.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_struct.3
/usr/bin/install -c -m 644 MPI_Type_create_subarray.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_subarray.3
/usr/bin/install -c -m 644 MPI_Type_delete_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_delete_attr.3
/usr/bin/install -c -m 644 MPI_Type_dup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_dup.3
/usr/bin/install -c -m 644 MPI_Type_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_extent.3
/usr/bin/install -c -m 644 MPI_Type_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_free.3
/usr/bin/install -c -m 644 MPI_Type_free_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_free_keyval.3
/usr/bin/install -c -m 644 MPI_Type_get_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_attr.3
/usr/bin/install -c -m 644 MPI_Type_get_contents.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_contents.3
/usr/bin/install -c -m 644 MPI_Type_get_envelope.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_envelope.3
/usr/bin/install -c -m 644 MPI_Type_get_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_extent_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_extent_x.3
/usr/bin/install -c -m 644 MPI_Type_get_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_name.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_true_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_true_extent_x.3
/usr/bin/install -c -m 644 MPI_Type_hindexed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_hvector.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_hvector.3
/usr/bin/install -c -m 644 MPI_Type_indexed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_indexed.3
/usr/bin/install -c -m 644 MPI_Type_lb.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_lb.3
/usr/bin/install -c -m 644 MPI_Type_match_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_match_size.3
/usr/bin/install -c -m 644 MPI_Type_set_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_set_attr.3
/usr/bin/install -c -m 644 MPI_Type_set_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_set_name.3
/usr/bin/install -c -m 644 MPI_Type_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_size.3
/usr/bin/install -c -m 644 MPI_Type_size_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_size_x.3
/usr/bin/install -c -m 644 MPI_Type_struct.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_struct.3
/usr/bin/install -c -m 644 MPI_Type_ub.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_ub.3
/usr/bin/install -c -m 644 MPI_Type_vector.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_vector.3
/usr/bin/install -c -m 644 MPI_Unpack.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Unpack.3
/usr/bin/install -c -m 644 MPI_Unpack_external.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Unpack_external.3
/usr/bin/install -c -m 644 MPI_Unpublish_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Unpublish_name.3
/usr/bin/install -c -m 644 MPI_Wait.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Wait.3
/usr/bin/install -c -m 644 MPI_Waitall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Waitall.3
/usr/bin/install -c -m 644 MPI_Waitany.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Waitany.3
/usr/bin/install -c -m 644 MPI_Waitsome.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Waitsome.3
/usr/bin/install -c -m 644 MPI_Win_allocate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_allocate.3
/usr/bin/install -c -m 644 MPI_Win_allocate_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_allocate_shared.3
/usr/bin/install -c -m 644 MPI_Win_attach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_attach.3
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_complete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_complete.3
/usr/bin/install -c -m 644 MPI_Win_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create.3
/usr/bin/install -c -m 644 MPI_Win_create_dynamic.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create_dynamic.3
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_create_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create_keyval.3
/usr/bin/install -c -m 644 MPI_Win_delete_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_delete_attr.3
/usr/bin/install -c -m 644 MPI_Win_detach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_detach.3
/usr/bin/install -c -m 644 MPI_Win_fence.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_fence.3
/usr/bin/install -c -m 644 MPI_Win_flush.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush.3
/usr/bin/install -c -m 644 MPI_Win_flush_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush_all.3
/usr/bin/install -c -m 644 MPI_Win_flush_local.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush_local.3
/usr/bin/install -c -m 644 MPI_Win_flush_local_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush_local_all.3
/usr/bin/install -c -m 644 MPI_Win_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_free.3
/usr/bin/install -c -m 644 MPI_Win_free_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_free_keyval.3
/usr/bin/install -c -m 644 MPI_Win_get_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_attr.3
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_get_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_group.3
/usr/bin/install -c -m 644 MPI_Win_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_info.3
/usr/bin/install -c -m 644 MPI_Win_get_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_name.3
/usr/bin/install -c -m 644 MPI_Win_lock.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_lock.3
/usr/bin/install -c -m 644 MPI_Win_lock_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_lock_all.3
/usr/bin/install -c -m 644 MPI_Win_post.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_post.3
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_attr.3
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_set_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_info.3
/usr/bin/install -c -m 644 MPI_Win_set_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_name.3
/usr/bin/install -c -m 644 MPI_Win_shared_query.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_shared_query.3
/usr/bin/install -c -m 644 MPI_Win_start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_start.3
/usr/bin/install -c -m 644 MPI_Win_sync.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_sync.3
/usr/bin/install -c -m 644 MPI_Win_test.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_test.3
/usr/bin/install -c -m 644 MPI_Win_unlock.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_unlock.3
/usr/bin/install -c -m 644 MPI_Win_unlock_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_unlock_all.3
/usr/bin/install -c -m 644 MPI_Win_wait.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_wait.3
/usr/bin/install -c -m 644 MPI_Wtick.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Wtick.3
/usr/bin/install -c -m 644 MPI_Wtime.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Wtime.3
/usr/bin/install -c -m 644 MPIX_Comm_agree.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_agree.3
/usr/bin/install -c -m 644 MPIX_Comm_failure_ack.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_failure_ack.3
/usr/bin/install -c -m 644 MPIX_Comm_failure_get_acked.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_failure_get_acked.3
/usr/bin/install -c -m 644 MPIX_Comm_revoke.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_revoke.3
/usr/bin/install -c -m 644 MPIX_Comm_shrink.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_shrink.3
if [ ! -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich ] ; then mkdir -p /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644 ./doc/userguide/user.pdf /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich/user.pdf ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644 ./doc/installguide/install.pdf /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich/install.pdf ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644 ./doc/logging/logging.pdf /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich/logging.pdf ; fi
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /usr/bin/install -c -m 644 src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /usr/bin/install -c -m 644 src/binding/cxx/mpicxx.h src/binding/fortran/mpif_h/mpif.h src/include/mpi.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
 /usr/bin/install -c -m 644 src/packaging/pkgconfig/mpich.pc '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making install in examples
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
********Output of running make on MPICH follows *******
Configuring MPICH version 3.1.3 with  '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich' 'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit'
Running on system: Linux alembic 3.2.0-115-generic #157-Ubuntu SMP Tue Oct 25 16:32:19 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking how to run the C preprocessor... gcc -E
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether /usr/bin/make sets $(MAKE)... yes
checking for style of include used by /usr/bin/make... GNU
checking whether /usr/bin/make supports nested variables... yes
checking dependency style of gcc... gcc3
checking whether to enable maintainer-specific portions of Makefiles... yes
checking the archiver (/usr/bin/ar) interface... ar
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether /usr/bin/make supports nested variables... (cached) yes
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking if gfortran supports -c -o file.o... (cached) yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether we are using the GNU Fortran 77 compiler... yes
checking hcoll/api/hcoll_api.h usability... no
checking hcoll/api/hcoll_api.h presence... no
checking for hcoll/api/hcoll_api.h... no
checking for hcoll_init in -lhcoll... no
checking for getpagesize... yes
checking for getpagesize... (cached) yes
configure: RUNNING PREREQ FOR ch3:sock
configure: ===== configuring src/mpl =====
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich'  'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3  ' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC ' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g ' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g ' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for inline... inline
checking for variable argument list macro functionality... yes
checking for gcov... gcov
checking whether the compiler supports __typeof(variable)... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking for sys/uio.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... yes
checking valgrind/valgrind.h presence... yes
checking for valgrind/valgrind.h... yes
checking valgrind/memcheck.h usability... yes
checking valgrind/memcheck.h presence... yes
checking for valgrind/memcheck.h... yes
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... yes
checking valgrind/helgrind.h presence... yes
checking for valgrind/helgrind.h... yes
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... yes
checking valgrind/drd.h presence... yes
checking for valgrind/drd.h... yes
checking whether the valgrind headers are broken or too old... no
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
configure: ===== done with src/mpl configure =====
configure: sourcing src/mpl/localdefs
configure: ===== configuring src/openpa =====
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich' --with-atomic-primitives=auto_allow_emulation 'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3  ' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC ' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g ' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g ' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
checking for gcc... gcc
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 8
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc ARM atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
configure: ===== done with src/openpa configure =====
sourcing /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/mpichprereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O0... yes
checking whether C compiler option -O0 works with an invalid prototype program... yes
checking whether routines compiled with -O0 can be linked with ones compiled without -O0... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... yes
checking for multiple weak symbol support... yes
checking for shared library (esp. rpath) characteristics of CC... done (results in src/env/cc_shlib.conf)
checking whether Fortran 77 compiler accepts option -O0... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lgfortran -lm -lquadmath
checking whether gfortran accepts the FLIBS found by autoconf... yes
checking whether gcc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... yes
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower uscore
checking for libraries to link Fortran main with C stdio routines... none
checking whether Fortran init will work with C... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (gfortran -fPIC -ffree-line-length-0 -g   ) works... yes
checking whether the Fortran 90 compiler (gfortran -fPIC -ffree-line-length-0 -g   ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking for shared library (esp. rpath) characteristics of F77... done (results in src/env/f77_shlib.conf)
checking whether Fortran 77 accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether gfortran allows mismatched arguments... yes
checking for Fortran 2008 support... no
checking for shared library (esp. rpath) characteristics of FC... done (results in src/env/fc_shlib.conf)
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking for Fortran 90 module output directory flag... -J
checking whether Fortran 90 compiler accepts option -O0... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking whether the C++ compiler g++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 6
checking for shared library (esp. rpath) characteristics of CXX... done (results in src/env/cxx_shlib.conf)
checking whether C++ compiler accepts option -O0... yes
checking for perl... /usr/bin/perl
checking for ar... /usr/bin/ar
checking for killall... killall
checking whether install works... yes
checking whether mkdir -p works... yes
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /bin/bash
checking whether /bin/bash supports arrays... yes
checking for doctext... false
checking for working volatile... yes
checking if C compiler supports __builtin_expect... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... sixteen
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... sixteen
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 8
checking size of unsigned long... 8
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 16
checking for ANSI C header files... (cached) yes
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 16
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 32
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 32
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... yes
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran real... float
checking for C type matching Fortran double... double
checking for C type matching Fortran integer... int
checking for values of Fortran logicals... True is 1 and False is 0
checking for Fortran 90 integer kind for 8-byte integers... 8
checking for Fortran 90 integer kind for 4-byte integers... 4
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 32
checking for alignment restrictions on int64_t... no
checking for alignment restrictions on int32_t... no
checking for gcc __asm__ and pentium cmpxchgl instruction... no
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... yes
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
checking size of MPIR_Bsend_data_t... 96
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking whether pthread_mutexattr_settype needs a declaration... no
checking for thread local storage specifier... __thread
checking for getpid... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking whether usleep needs a declaration... no
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: RUNNING CONFIGURE FOR F90 CODE
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
checking for sys/socket.h... (cached) yes
checking for strings.h... (cached) yes
checking for assert.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for snprintf... (cached) yes
checking whether snprintf needs a declaration... (cached) no
checking for strncasecmp... (cached) yes
checking for sys/param.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
checking whether struct hostent contains h_addr_list... yes
checking whether __attribute__ allowed... (cached) yes
checking whether __attribute__((format)) allowed... (cached) yes
configure: RUNNING CONFIGURE FOR CH3 DEVICE
checking for limits.h... (cached) yes
checking for sys/uio.h... (cached) yes
checking uuid/uuid.h usability... no
checking uuid/uuid.h presence... no
checking for uuid/uuid.h... no
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for arpa/inet.h... (cached) yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking for OpenPA atomic primitive availability... yes
checking whether byte ordering is bigendian... (cached) no
configure: RUNNING CONFIGURE FOR ch3:sock
checking for netdb.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking for errno.h... (cached) yes
checking for netinet/in.h... (cached) yes
configure: RUNNING CONFIGURE FOR src/mpid/common/sock
checking for strerror... (cached) yes
configure: RUNNING CONFIGURE FOR src/mpid/common/sock/poll
checking for poll... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for netinet/tcp.h... (cached) yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking if struct poll is defined... yes
checking if a simple program using poll() can be compiled... yes
checking whether bit fields work in ip.h... yes
checking for gethostname... (cached) yes
checking whether gethostname needs a declaration... (cached) no
checking for library containing socket... (cached) none required
checking for library containing gethostbyname... (cached) none required
checking whether socklen_t is defined (in sys/socket.h if present)... (cached) yes
configure: RUNNING CONFIGURE FOR CH3U SOCK CODE
checking for time.h... (cached) yes
checking for ctype.h... (cached) yes
checking for net/if.h... (cached) yes
checking for pid_t... (cached) yes
checking for inet_pton... (cached) yes
checking whether we can use struct ifconf... yes
configure: ===== configuring src/mpid/common/sock =====
configure: ===== done with src/mpid/common/sock configure =====
configure: ===== configuring src/mpi/romio =====
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich'  'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3   -O0' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC  -O0' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g  -O0' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g  -O0' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
checking for a thread-safe mkdir -p... mkdir -p
checking for ld used by gcc... /usr/bin/ld -m elf_x86_64
checking for /usr/bin/ld -m elf_x86_64 option to reload object files... -r
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64 -m elf_x86_64) supports shared libraries... yes
Configuring with args dummy mt
checking for architecture... LINUX
ROMIO home directory is /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64 -m elf_x86_64) supports shared libraries... yes
checking for long long... yes
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking for ssize_t... yes
checking for off_t... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for mpix.h... no
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... no
checking size of long long... (cached) 8
checking for Fortran 90 KIND parameter for 8-byte integers...            8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
checking gpfs.h usability... no
checking gpfs.h presence... no
checking for gpfs.h... no
checking gpfs_fcntl.h usability... no
checking gpfs_fcntl.h presence... no
checking for gpfs_fcntl.h... no
checking for library containing aio_write... -lrt
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking for statfs... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for blksize_t... yes
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to gfortran
setting TEST_CC to $(bindir)/mpicc
setting TEST_F77 to $(bindir)/mpifort
setting CFLAGS to -fPIC -g3   -O0  -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating adio/include/romioconf.h
config.status: executing default-1 commands
configure: ===== done with src/mpi/romio configure =====
configure: sourcing src/mpi/romio/localdefs
configure: ===== configuring src/pm/hydra =====
checking target system type... x86_64-unknown-linux-gnu
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for doxygen... /usr/bin/doxygen
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for library containing hstrerror... none required
checking for sigaction... yes
checking for signal... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for fcntl... yes
checking for isatty... yes
checking for inet_ntop... yes
checking for getpgid... yes
checking for setsid... yes
checking for killpg... yes
checking whether gettimeofday needs a declaration... no
checking whether getpgid needs a declaration... no
checking whether killpg needs a declaration... no
checking for environ in unistd.h... yes
checking bootstrap server... user,ssh,rsh,fork,slurm,ll,lsf,sge,pbs,cobalt,manual,persist
checking tm.h usability... no
checking tm.h presence... no
checking for tm.h... no
checking for tm_init in -ltorque... no
checking process manager... pmiserv
checking user interface... mpich
checking desired processor topology libraries... hwloc
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for X... libraries , headers
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc
configure: hwloc srcdir: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... tools/topo/hwloc/hwloc/
checking for hwloc symbol prefix... hwloc_
checking which OS support to include... Linux
checking which CPU support to include... x86_64
checking size of unsigned long... (cached) 8
checking for the C compiler vendor... gnu
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... yes
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... yes
checking for __attribute__(hot)... yes
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... yes
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... yes
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking if gcc supports -fvisibility=hidden... yes
checking whether to enable symbol visibility... yes (via -fvisibility=hidden)
checking whether the C compiler rejects function calls with too many arguments... yes
checking whether the C compiler rejects function calls with too few arguments... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... no
checking for windows.h... (cached) no
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether fabsf is declared... yes
checking for fabsf in -lm... yes
checking picl.h usability... no
checking picl.h presence... no
checking for picl.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_PAGESIZE is declared... yes
checking whether _SC_PAGE_SIZE is declared... yes
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... yes
checking whether CTL_HW is declared... no
checking whether HW_NCPU is declared... no
checking whether strtoull is declared... yes
checking for pthread_t... yes
checking whether function sched_setaffinity is declared... yes
checking for old prototype of sched_setaffinity... no
checking for working CPU_SET... yes
checking for working CPU_SET_S... yes
checking for working _syscall3... no
checking for KERRIGHED... no
checking for lib... no
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... yes
checking whether function ffsl is declared... yes
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... yes
checking whether pthread_getaffinity_np is declared... yes
checking for sys/cpuset.h... no
checking for cpuset_setaffinity... no
checking for library containing pthread_getthrds_np... no
checking for cpuset_setid... no
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking for PCIACCESS... no
checking for PCIUTILS... no
checking pci/pci.h usability... no
checking pci/pci.h presence... no
checking for pci/pci.h... no
checking CL/cl_ext.h usability... no
checking CL/cl_ext.h presence... no
checking for CL/cl_ext.h... no
checking cuda.h usability... no
checking cuda.h presence... no
checking for cuda.h... no
checking cuda_runtime_api.h usability... no
checking cuda_runtime_api.h presence... no
checking for cuda_runtime_api.h... no
checking nvml.h usability... no
checking nvml.h presence... no
checking for nvml.h... no
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking X11/Xlib.h usability... yes
checking X11/Xlib.h presence... yes
checking for X11/Xlib.h... yes
checking for XOpenDisplay in -lX11... yes
checking X11/Xutil.h usability... yes
checking X11/Xutil.h presence... yes
checking for X11/Xutil.h... yes
checking X11/keysym.h usability... yes
checking X11/keysym.h presence... yes
checking for X11/keysym.h... yes
checking NVCtrl/NVCtrl.h usability... no
checking NVCtrl/NVCtrl.h presence... no
checking for NVCtrl/NVCtrl.h... no
checking for LIBXML2... yes
checking for xmlNewDoc... yes
checking for final LIBXML2 support... yes
checking for x86 cpuid... yes
checking for pthread_mutex_lock... yes
checking if plugin support is enabled... no
checking components to build statically...  noos xml synthetic custom xml_nolibxml linux linuxpci xml_libxml x86
checking components to build as plugins...
checking available processor topology libraries... hwloc
checking checkpointing library... blcr
checking libcr.h usability... no
checking libcr.h presence... no
checking for libcr.h... no
checking for cr_init in -lcr... no
checking demux engine... poll,select,port
checking debugging support... meminit
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/topo/hwloc/hwloc/Makefile
config.status: creating tools/topo/hwloc/hwloc/include/Makefile
config.status: creating tools/topo/hwloc/hwloc/src/Makefile
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
config.status: creating tools/topo/hwloc/hwloc/include/private/autogen/config.h
config.status: creating tools/topo/hwloc/hwloc/include/hwloc/autogen/config.h
configure: ===== done with src/pm/hydra configure =====
checking size of OPA_ptr_t... 8
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran 77... yes
checking whether the Fortran Offset type works with Fortran 90... yes
checking for size of MPI_Status... 20
checking for BSD/POSIX style global symbol lister... BSD style,/usr/bin/nm -g -B
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 16
checking the minimum alignment of Fortran common block of 5 integers... 16, too small! reset to 32
configure: creating ./config.lt
config.lt: creating libtool
config.status: creating src/binding/fortran/use_mpi/mpif90model.h
config.status: creating examples/Makefile
config.status: creating test/commands/Makefile
config.status: creating src/include/mpichinfo.h
config.status: creating mpich-doxygen
config.status: creating src/include/glue_romio.h
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/fortran/mpif_h/mpif.h
config.status: creating src/binding/fortran/mpif_h/setbotf.f
config.status: creating src/binding/fortran/mpif_h/setbot.c
config.status: creating src/binding/fortran/use_mpi/mpi_sizeofs.f90
config.status: creating src/binding/fortran/use_mpi/mpi_base.f90
config.status: creating src/binding/fortran/use_mpi/mpi_constants.f90
config.status: creating src/packaging/pkgconfig/mpich.pc
config.status: creating src/packaging/envmods/mpich.module
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc.sh
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx.sh
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77.sh
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpifort.sh
config.status: creating src/env/mpifort.bash
config.status: creating src/env/parkill
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/include/mpi.h
config.status: creating doc/design/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/refman/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating test/commands/cmdtests
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
=== configuring in test/mpi (/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich'  'MAKE=/usr/bin/make' '--libdir=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' 'CC=gcc' 'CFLAGS=-fPIC -g3' 'AR=/usr/bin/ar' 'ARFLAGS=cr' 'CXX=g++' 'CXXFLAGS=-g -fPIC' 'F77=gfortran' 'FFLAGS=-fPIC -ffree-line-length-0 -g' 'FC=gfortran' 'FCFLAGS=-fPIC -ffree-line-length-0 -g' '--enable-shared' '--with-device=ch3:sock' '--with-pm=hydra' '--enable-fast=no' '--enable-g=meminit' --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking for library containing pthread_create... -lpthread
checking for library containing pthread_barrier_init... none required
checking for pthread_create... yes
checking for pthread_barrier_init... yes
checking for pthread_barrier_wait... yes
checking for getrusage... yes
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lpthread -lgfortran -lm -lquadmath
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... yes
checking for Fortran 77 compiler flag for Cray-style pointer... -fcray-pointer
checking for Fortran flag needed to accept free-form source... none
checking whether Fortran 90 supports Cray-style pointer... yes
checking for Fortran 90 compiler flag for Cray-style pointer... -fcray-pointer
checking whether gfortran supports the Fortran 2003 routines to access the commandline... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of void *... (cached) 8
checking for C integer type of address size... long
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating checktests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating util/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating datatype/testlist
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating mpi_t/Makefile
config.status: creating rma/Makefile
config.status: creating rma/testlist
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/testlist
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f77/profile/Makefile
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/spawn/testlist
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating f90/profile/Makefile
config.status: creating f08/Makefile
config.status: creating f08/attr/Makefile
config.status: creating f08/datatype/Makefile
config.status: creating f08/util/Makefile
config.status: creating f08/coll/Makefile
config.status: creating f08/comm/Makefile
config.status: creating f08/pt2pt/Makefile
config.status: creating f08/rma/Makefile
config.status: creating f08/subarray/Makefile
config.status: creating f08/topo/Makefile
config.status: creating f08/io/Makefile
config.status: creating f08/init/Makefile
config.status: creating f08/info/Makefile
config.status: creating f08/spawn/Makefile
config.status: creating f08/timer/Makefile
config.status: creating f08/ext/Makefile
config.status: creating f08/misc/Makefile
config.status: creating f08/profile/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating cxx/topo/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/mpi_t/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating threads/rma/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/datatype/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f77/io/Makefile
config.status: creating errors/f77/io/addsize.h
config.status: creating errors/f77/io/iooffset.h
config.status: creating errors/f90/Makefile
config.status: creating errors/f90/io/Makefile
config.status: creating errors/f08/Makefile
config.status: creating errors/f08/io/Makefile
config.status: creating ckpoint/Makefile
config.status: creating ft/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating manual/mpi_t/Makefile
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating cxx/topo/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating errors/f77/testlist
config.status: creating errors/f90/testlist
config.status: creating impls/testlist
config.status: creating impls/Makefile
config.status: creating impls/hydra/Makefile
config.status: creating impls/hydra/proc_binding.sh
config.status: creating impls/mpich/Makefile
config.status: creating impls/mpich/testlist
config.status: creating impls/mpich/mpi_t/Makefile
config.status: creating include/mpitestconf.h
Configuration completed.configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs.  MPICH does not handle this case automatically and you should avoid assumed extents for structures containing float types.
configure: WARNING: no configuration information is in src/mpid/common/sock
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
configure: WARNING: "-fvisibility=hidden" has been added to the hwloc CFLAGS
configure: WARNING: The ch3:sock device did not set the maximum size of an error string, 512 being used.
config.status: WARNING:  'src/packaging/envmods/mpich.module.in' seems to ignore the --datarootdir setting
Making clean in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
 rm -f strsep
rm -rf .libs _libs
rm -rf src/.libs src/_libs
test -z "libmpl.la" || rm -f libmpl.la
rm -f ./so_locations
rm -f *.o
rm -f src/*.o
rm -f src/*.lo
rm -f test/*.o
test -z "strsep.log" || rm -f strsep.log
test -z "strsep.trs" || rm -f strsep.trs
test -z "test-suite.log" || rm -f test-suite.log
rm -f *.lo
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making clean in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making clean in src
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
rm -rf .libs _libs
test -z "libopa.la" || rm -f libopa.la
rm -f *.o
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
Making clean in test
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
 rm -f sanity test_primitives test_barriers test_queue
rm -rf .libs _libs
rm -f *.o
test -z "sanity.log test_primitives.log test_barriers.log test_queue.log" || rm -f sanity.log test_primitives.log test_barriers.log test_queue.log
test -z "sanity.trs test_primitives.trs test_barriers.trs test_queue.trs" || rm -f sanity.trs test_primitives.trs test_barriers.trs test_queue.trs
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
rm -rf .libs _libs
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making clean in src/mpi/romio
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
test -z "" || rm -f
rm -rf .libs _libs
rm -rf adio/ad_gpfs/.libs adio/ad_gpfs/_libs
rm -rf adio/ad_gpfs/bg/.libs adio/ad_gpfs/bg/_libs
rm -rf adio/ad_gpfs/pe/.libs adio/ad_gpfs/pe/_libs
rm -rf adio/ad_gridftp/.libs adio/ad_gridftp/_libs
rm -rf adio/ad_hfs/.libs adio/ad_hfs/_libs
rm -rf adio/ad_lustre/.libs adio/ad_lustre/_libs
rm -rf adio/ad_nfs/.libs adio/ad_nfs/_libs
rm -rf adio/ad_panfs/.libs adio/ad_panfs/_libs
rm -rf adio/ad_pfs/.libs adio/ad_pfs/_libs
rm -rf adio/ad_piofs/.libs adio/ad_piofs/_libs
rm -rf adio/ad_pvfs/.libs adio/ad_pvfs/_libs
rm -rf adio/ad_pvfs2/.libs adio/ad_pvfs2/_libs
rm -rf adio/ad_sfs/.libs adio/ad_sfs/_libs
rm -rf adio/ad_testfs/.libs adio/ad_testfs/_libs
rm -rf adio/ad_ufs/.libs adio/ad_ufs/_libs
rm -rf adio/ad_xfs/.libs adio/ad_xfs/_libs
rm -rf adio/ad_zoidfs/.libs adio/ad_zoidfs/_libs
rm -rf adio/common/.libs adio/common/_libs
rm -rf mpi-io/.libs mpi-io/_libs
rm -rf mpi-io/fortran/.libs mpi-io/fortran/_libs
rm -rf mpi-io/glue/.libs mpi-io/glue/_libs
rm -rf mpi-io/glue/default/.libs mpi-io/glue/default/_libs
rm -rf mpi-io/glue/mpich/.libs mpi-io/glue/mpich/_libs
test -z "libromio.la " || rm -f libromio.la
rm -f *.o
rm -f adio/ad_gpfs/*.o
rm -f adio/ad_gpfs/*.lo
rm -f adio/ad_gpfs/bg/*.o
rm -f adio/ad_gpfs/bg/*.lo
rm -f adio/ad_gpfs/pe/*.o
rm -f adio/ad_gpfs/pe/*.lo
rm -f adio/ad_gridftp/*.o
rm -f adio/ad_gridftp/*.lo
rm -f adio/ad_hfs/*.o
rm -f adio/ad_hfs/*.lo
rm -f adio/ad_lustre/*.o
rm -f adio/ad_lustre/*.lo
rm -f adio/ad_nfs/*.o
rm -f adio/ad_nfs/*.lo
rm -f adio/ad_panfs/*.o
rm -f adio/ad_panfs/*.lo
rm -f adio/ad_pfs/*.o
rm -f adio/ad_pfs/*.lo
rm -f adio/ad_piofs/*.o
rm -f adio/ad_piofs/*.lo
rm -f adio/ad_pvfs/*.o
rm -f adio/ad_pvfs/*.lo
rm -f adio/ad_pvfs2/*.o
rm -f adio/ad_pvfs2/*.lo
rm -f adio/ad_sfs/*.o
rm -f adio/ad_sfs/*.lo
rm -f adio/ad_testfs/*.o
rm -f adio/ad_testfs/*.lo
rm -f adio/ad_ufs/*.o
rm -f adio/ad_ufs/*.lo
rm -f adio/ad_xfs/*.o
rm -f adio/ad_xfs/*.lo
rm -f adio/ad_zoidfs/*.o
rm -f adio/ad_zoidfs/*.lo
rm -f adio/common/*.o
rm -f adio/common/*.lo
rm -f mpi-io/*.o
rm -f mpi-io/*.lo
rm -f mpi-io/fortran/*.o
rm -f mpi-io/fortran/*.lo
rm -f mpi-io/glue/*.o
rm -f mpi-io/glue/*.lo
rm -f mpi-io/glue/default/*.o
rm -f mpi-io/glue/default/*.lo
rm -f mpi-io/glue/mpich/*.o
rm -f mpi-io/glue/mpich/*.lo
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
Making clean in src/pm/hydra
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making clean in ../../mpl
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
 rm -f strsep
rm -rf .libs _libs
rm -f *.o
rm -f src/*.o
rm -f src/*.lo
rm -f test/*.o
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making clean in tools/topo/hwloc/hwloc
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making clean in src
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
test -z "" || rm -f
test -z "" || rm -f
rm -rf .libs _libs
test -z "libhwloc_embedded.la" || rm -f libhwloc_embedded.la
test -z "     " || rm -f
rm -f *.o
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
Making clean in include
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
rm -rf .libs _libs
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
rm -rf .libs _libs
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making clean in .
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
 rm -f hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra
rm -rf .libs _libs
rm -rf pm/pmiserv/.libs pm/pmiserv/_libs
rm -rf tools/bootstrap/external/.libs tools/bootstrap/external/_libs
rm -rf tools/bootstrap/persist/.libs tools/bootstrap/persist/_libs
rm -rf tools/bootstrap/src/.libs tools/bootstrap/src/_libs
rm -rf tools/bootstrap/utils/.libs tools/bootstrap/utils/_libs
rm -rf tools/ckpoint/.libs tools/ckpoint/_libs
rm -rf tools/ckpoint/blcr/.libs tools/ckpoint/blcr/_libs
rm -rf tools/debugger/.libs tools/debugger/_libs
rm -rf tools/demux/.libs tools/demux/_libs
rm -rf tools/ftb/.libs tools/ftb/_libs
rm -rf tools/topo/.libs tools/topo/_libs
rm -rf tools/topo/hwloc/.libs tools/topo/hwloc/_libs
rm -rf ui/utils/.libs ui/utils/_libs
rm -rf utils/alloc/.libs utils/alloc/_libs
rm -rf utils/args/.libs utils/args/_libs
rm -rf utils/dbg/.libs utils/dbg/_libs
rm -rf utils/env/.libs utils/env/_libs
rm -rf utils/launch/.libs utils/launch/_libs
rm -rf utils/others/.libs utils/others/_libs
rm -rf utils/signals/.libs utils/signals/_libs
rm -rf utils/sock/.libs utils/sock/_libs
rm -rf utils/string/.libs utils/string/_libs
test -z "libhydra.la libpm.la" || rm -f libhydra.la libpm.la
rm -f *.o
rm -f pm/pmiserv/*.o
rm -f pm/pmiserv/*.lo
rm -f tools/bootstrap/external/*.o
rm -f tools/bootstrap/external/*.lo
rm -f tools/bootstrap/persist/*.o
rm -f tools/bootstrap/persist/*.lo
rm -f tools/bootstrap/src/*.o
rm -f tools/bootstrap/src/*.lo
rm -f tools/bootstrap/utils/*.o
rm -f tools/bootstrap/utils/*.lo
rm -f tools/ckpoint/*.o
rm -f tools/ckpoint/*.lo
rm -f tools/ckpoint/blcr/*.o
rm -f tools/ckpoint/blcr/*.lo
rm -f tools/debugger/*.o
rm -f tools/debugger/*.lo
rm -f tools/demux/*.o
rm -f tools/demux/*.lo
rm -f tools/ftb/*.o
rm -f tools/ftb/*.lo
rm -f tools/nameserver/*.o
rm -f tools/topo/*.o
rm -f tools/topo/*.lo
rm -f tools/topo/hwloc/*.o
rm -f tools/topo/hwloc/*.lo
rm -f ui/mpich/*.o
rm -f ui/utils/*.o
rm -f ui/utils/*.lo
rm -f utils/alloc/*.o
rm -f utils/alloc/*.lo
rm -f utils/args/*.o
rm -f utils/args/*.lo
rm -f utils/dbg/*.o
rm -f utils/dbg/*.lo
rm -f utils/env/*.o
rm -f utils/env/*.lo
rm -f utils/launch/*.o
rm -f utils/launch/*.lo
rm -f utils/others/*.o
rm -f utils/others/*.lo
rm -f utils/signals/*.o
rm -f utils/signals/*.lo
rm -f utils/sock/*.o
rm -f utils/sock/*.lo
rm -f utils/string/*.o
rm -f utils/string/*.lo
rm -f *.lo
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making clean in .
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
 rm -f src/env/mpichversion src/env/mpivars
test -z "src/binding/fortran/use_mpi/mpi.mod-stamp src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi.lo src/binding/fortran/use_mpi/mpi-tmp src/binding/fortran/use_mpi/mpi_constants.mod-stamp src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_constants.lo src/binding/fortran/use_mpi/mpi_constants-tmp src/binding/fortran/use_mpi/mpi_sizeofs.mod-stamp src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_sizeofs.lo src/binding/fortran/use_mpi/mpi_sizeofs-tmp src/binding/fortran/use_mpi/mpi_base.mod-stamp src/binding/fortran/use_mpi/mpi_base.mod src/binding/fortran/use_mpi/mpi_base.lo src/binding/fortran/use_mpi/mpi_base-tmp src/binding/fortran/use_mpi/mpifnoext.h src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod  " || rm -f src/binding/fortran/use_mpi/mpi.mod-stamp src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi.lo src/binding/fortran/use_mpi/mpi-tmp src/binding/fortran/use_mpi/mpi_constants.mod-stamp src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_constants.lo src/binding/fortran/use_mpi/mpi_constants-tmp src/binding/fortran/use_mpi/mpi_sizeofs.mod-stamp src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_sizeofs.lo src/binding/fortran/use_mpi/mpi_sizeofs-tmp src/binding/fortran/use_mpi/mpi_base.mod-stamp src/binding/fortran/use_mpi/mpi_base.mod src/binding/fortran/use_mpi/mpi_base.lo src/binding/fortran/use_mpi/mpi_base-tmp src/binding/fortran/use_mpi/mpifnoext.h src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod
test -z "   lib/libmpi.la lib/libmpifort.la lib/libmpicxx.la" || rm -f    lib/libmpi.la lib/libmpifort.la lib/libmpicxx.la
rm -f lib/so_locations
rm -rf .libs _libs
rm -rf lib/.libs lib/_libs
rm -rf src/binding/cxx/.libs src/binding/cxx/_libs
rm -rf src/binding/fortran/mpif_h/.libs src/binding/fortran/mpif_h/_libs
rm -rf src/binding/fortran/use_mpi/.libs src/binding/fortran/use_mpi/_libs
rm -rf src/binding/fortran/use_mpi_f08/.libs src/binding/fortran/use_mpi_f08/_libs
rm -rf src/binding/fortran/use_mpi_f08/wrappers_c/.libs src/binding/fortran/use_mpi_f08/wrappers_c/_libs
rm -rf src/binding/fortran/use_mpi_f08/wrappers_f/.libs src/binding/fortran/use_mpi_f08/wrappers_f/_libs
rm -rf src/binding/fortran/use_mpi_f08/wrappers_f/profiling/.libs src/binding/fortran/use_mpi_f08/wrappers_f/profiling/_libs
rm -rf src/env/.libs src/env/_libs
rm -rf src/glue/romio/.libs src/glue/romio/_libs
rm -rf src/mpi/attr/.libs src/mpi/attr/_libs
rm -rf src/mpi/coll/.libs src/mpi/coll/_libs
rm -rf src/mpi/comm/.libs src/mpi/comm/_libs
rm -rf src/mpi/datatype/.libs src/mpi/datatype/_libs
rm -rf src/mpi/debugger/.libs src/mpi/debugger/_libs
rm -rf src/mpi/errhan/.libs src/mpi/errhan/_libs
rm -rf src/mpi/group/.libs src/mpi/group/_libs
rm -rf src/mpi/info/.libs src/mpi/info/_libs
rm -rf src/mpi/init/.libs src/mpi/init/_libs
rm -rf src/mpi/misc/.libs src/mpi/misc/_libs
rm -rf src/mpi/pt2pt/.libs src/mpi/pt2pt/_libs
rm -rf src/mpi/rma/.libs src/mpi/rma/_libs
rm -rf src/mpi/spawn/.libs src/mpi/spawn/_libs
rm -rf src/mpi/timer/.libs src/mpi/timer/_libs
rm -rf src/mpi/topo/.libs src/mpi/topo/_libs
rm -rf src/mpi_t/.libs src/mpi_t/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/ib/.libs src/mpid/ch3/channels/nemesis/netmod/ib/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/mx/.libs src/mpid/ch3/channels/nemesis/netmod/mx/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/mxm/.libs src/mpid/ch3/channels/nemesis/netmod/mxm/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/newmad/.libs src/mpid/ch3/channels/nemesis/netmod/newmad/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/none/.libs src/mpid/ch3/channels/nemesis/netmod/none/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/portals4/.libs src/mpid/ch3/channels/nemesis/netmod/portals4/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/scif/.libs src/mpid/ch3/channels/nemesis/netmod/scif/_libs
rm -rf src/mpid/ch3/channels/nemesis/netmod/tcp/.libs src/mpid/ch3/channels/nemesis/netmod/tcp/_libs
rm -rf src/mpid/ch3/channels/nemesis/src/.libs src/mpid/ch3/channels/nemesis/src/_libs
rm -rf src/mpid/ch3/channels/nemesis/utils/monitor/.libs src/mpid/ch3/channels/nemesis/utils/monitor/_libs
rm -rf src/mpid/ch3/channels/nemesis/utils/replacements/.libs src/mpid/ch3/channels/nemesis/utils/replacements/_libs
rm -rf src/mpid/ch3/channels/sock/src/.libs src/mpid/ch3/channels/sock/src/_libs
rm -rf src/mpid/ch3/src/.libs src/mpid/ch3/src/_libs
rm -rf src/mpid/ch3/util/ftb/.libs src/mpid/ch3/util/ftb/_libs
rm -rf src/mpid/ch3/util/sock/.libs src/mpid/ch3/util/sock/_libs
rm -rf src/mpid/common/datatype/.libs src/mpid/common/datatype/_libs
rm -rf src/mpid/common/datatype/dataloop/.libs src/mpid/common/datatype/dataloop/_libs
rm -rf src/mpid/common/hcoll/.libs src/mpid/common/hcoll/_libs
rm -rf src/mpid/common/sched/.libs src/mpid/common/sched/_libs
rm -rf src/mpid/common/sock/poll/.libs src/mpid/common/sock/poll/_libs
rm -rf src/mpid/common/thread/.libs src/mpid/common/thread/_libs
rm -rf src/mpid/pamid/src/.libs src/mpid/pamid/src/_libs
rm -rf src/mpid/pamid/src/coll/.libs src/mpid/pamid/src/coll/_libs
rm -rf src/mpid/pamid/src/coll/allgather/.libs src/mpid/pamid/src/coll/allgather/_libs
rm -rf src/mpid/pamid/src/coll/allgatherv/.libs src/mpid/pamid/src/coll/allgatherv/_libs
rm -rf src/mpid/pamid/src/coll/allreduce/.libs src/mpid/pamid/src/coll/allreduce/_libs
rm -rf src/mpid/pamid/src/coll/alltoall/.libs src/mpid/pamid/src/coll/alltoall/_libs
rm -rf src/mpid/pamid/src/coll/alltoallv/.libs src/mpid/pamid/src/coll/alltoallv/_libs
rm -rf src/mpid/pamid/src/coll/alltoallw/.libs src/mpid/pamid/src/coll/alltoallw/_libs
rm -rf src/mpid/pamid/src/coll/barrier/.libs src/mpid/pamid/src/coll/barrier/_libs
rm -rf src/mpid/pamid/src/coll/bcast/.libs src/mpid/pamid/src/coll/bcast/_libs
rm -rf src/mpid/pamid/src/coll/exscan/.libs src/mpid/pamid/src/coll/exscan/_libs
rm -rf src/mpid/pamid/src/coll/gather/.libs src/mpid/pamid/src/coll/gather/_libs
rm -rf src/mpid/pamid/src/coll/gatherv/.libs src/mpid/pamid/src/coll/gatherv/_libs
rm -rf src/mpid/pamid/src/coll/ired_scat/.libs src/mpid/pamid/src/coll/ired_scat/_libs
rm -rf src/mpid/pamid/src/coll/ired_scat_block/.libs src/mpid/pamid/src/coll/ired_scat_block/_libs
rm -rf src/mpid/pamid/src/coll/reduce/.libs src/mpid/pamid/src/coll/reduce/_libs
rm -rf src/mpid/pamid/src/coll/scan/.libs src/mpid/pamid/src/coll/scan/_libs
rm -rf src/mpid/pamid/src/coll/scatter/.libs src/mpid/pamid/src/coll/scatter/_libs
rm -rf src/mpid/pamid/src/coll/scatterv/.libs src/mpid/pamid/src/coll/scatterv/_libs
rm -rf src/mpid/pamid/src/comm/.libs src/mpid/pamid/src/comm/_libs
rm -rf src/mpid/pamid/src/dyntask/.libs src/mpid/pamid/src/dyntask/_libs
rm -rf src/mpid/pamid/src/misc/.libs src/mpid/pamid/src/misc/_libs
rm -rf src/mpid/pamid/src/mpix/.libs src/mpid/pamid/src/mpix/_libs
rm -rf src/mpid/pamid/src/onesided/.libs src/mpid/pamid/src/onesided/_libs
rm -rf src/mpid/pamid/src/pamix/.libs src/mpid/pamid/src/pamix/_libs
rm -rf src/mpid/pamid/src/pt2pt/.libs src/mpid/pamid/src/pt2pt/_libs
rm -rf src/mpid/pamid/src/pt2pt/persistent/.libs src/mpid/pamid/src/pt2pt/persistent/_libs
rm -rf src/mutex/.libs src/mutex/_libs
rm -rf src/nameserv/file/.libs src/nameserv/file/_libs
rm -rf src/nameserv/pmi/.libs src/nameserv/pmi/_libs
rm -rf src/pm/gforker/.libs src/pm/gforker/_libs
rm -rf src/pm/remshell/.libs src/pm/remshell/_libs
rm -rf src/pmi/pmi2/poe/.libs src/pmi/pmi2/poe/_libs
rm -rf src/pmi/pmi2/simple/.libs src/pmi/pmi2/simple/_libs
rm -rf src/pmi/simple/.libs src/pmi/simple/_libs
rm -rf src/util/cvar/.libs src/util/cvar/_libs
rm -rf src/util/dbg/.libs src/util/dbg/_libs
rm -rf src/util/instrm/.libs src/util/instrm/_libs
rm -rf src/util/logging/rlog/.libs src/util/logging/rlog/_libs
rm -rf src/util/mem/.libs src/util/mem/_libs
rm -rf src/util/msgs/.libs src/util/msgs/_libs
rm -rf src/util/other/.libs src/util/other/_libs
rm -rf src/util/procmap/.libs src/util/procmap/_libs
rm -rf src/util/thread/.libs src/util/thread/_libs
( cd test && /usr/bin/make  clean )
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
Making clean in mpi
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
Making clean in util
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/util'
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/util'
Making clean in attr
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/attr'
test -z "summary.xml summary.tap summary.junit.xml" || rm -f summary.xml summary.tap summary.junit.xml
test -z "attrt attrend attrend2 attric attrerr attrerrcomm attrerrtype attrdeleteget attr2type attrorder attrordercomm attrordertype baseattr2 baseattrcomm fkeyval fkeyvalcomm fkeyvaltype keyval_double_free" || rm -f attrt attrend attrend2 attric attrerr attrerrcomm attrerrtype attrdeleteget attr2type attrorder attrordercomm attrordertype baseattr2 baseattrcomm fkeyval fkeyvalcomm fkeyvaltype keyval_double_free
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/attr'
Making clean in basic
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/basic'
test -z "self simple sendrecv srtest wtime netpipe patterns adapt" || rm -f self simple sendrecv srtest wtime netpipe patterns adapt
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/basic'
Making clean in datatype
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/datatype'
test -z "blockindexed-misc blockindexed-zero-count contents contig-zero-count contigstruct cxx-types dataalign darray-pack darray-cyclic gaddress get-elements get-elements-pairtype getpartelm hindexed-zeros hindexed_block hindexed_block_contents hvecblklen indexed-misc large-count large_type large_type_sendrec lbub localpack longdouble lots-of-types pairtype-pack pairtype-size-extent sendrecvt2 sendrecvt4 simple-commit simple-pack simple-pack-external simple-resized simple-size-extent sizedtypes slice-pack slice-pack-external struct-derived-zeros struct-empty-el struct-ezhov struct-no-real-types struct-pack structpack2 struct-verydeep struct-zero-count subarray subarray-pack tfree tmatchsize transpose-pack tresized tresized2 triangular-pack typecommit typefree typelb typename unpack unusual-noncontigs vecblklen zeroblks zeroparms" || rm -f blockindexed-misc blockindexed-zero-count contents contig-zero-count contigstruct cxx-types dataalign darray-pack darray-cyclic gaddress get-elements get-elements-pairtype getpartelm hindexed-zeros hindexed_block hindexed_block_contents hvecblklen indexed-misc large-count large_type large_type_sendrec lbub localpack longdouble lots-of-types pairtype-pack pairtype-size-extent sendrecvt2 sendrecvt4 simple-commit simple-pack simple-pack-external simple-resized simple-size-extent sizedtypes slice-pack slice-pack-external struct-derived-zeros struct-empty-el struct-ezhov struct-no-real-types struct-pack structpack2 struct-verydeep struct-zero-count subarray subarray-pack tfree tmatchsize transpose-pack tresized tresized2 triangular-pack typecommit typefree typelb typename unpack unusual-noncontigs vecblklen zeroblks zeroparms
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/datatype'
Making clean in coll
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/coll'
test -z "allgather2 allgather3 allgatherv2 allgatherv3 allgatherv4 allred allred2 allred3 allred4 allred5 allred6 allredmany alltoall1 alltoallv alltoallv0 alltoallw1 alltoallw2 alltoallw_zeros bcast2 bcast3 bcasttest bcastzerotype coll2 coll3 coll4 coll5 coll6 coll7 coll8 coll9 coll10 coll11 coll12 coll13 exscan exscan2 gather gather2 iallred ibarrier icallgather icallgatherv icallreduce icalltoall icalltoallv icalltoallw icbarrier icbcast icgather icgatherv icreduce icscatter icscatterv longuser nonblocking nonblocking2 nonblocking3 nonblocking4 op_commutative opband opbor opbxor opland oplor oplxor opmax opmaxloc opmin opminloc opprod opsum red3 red4 red_scat_block red_scat_block2 redscat redscat2 redscat3 redscatblk3 redscatinter redscatbkinter reduce reduce_local scantst scatter2 scatter3 scattern scatterv uoplong nballtoall1 nbredscat nbredscat3 nbredscatinter nbcoll2" || rm -f allgather2 allgather3 allgatherv2 allgatherv3 allgatherv4 allred allred2 allred3 allred4 allred5 allred6 allredmany alltoall1 alltoallv alltoallv0 alltoallw1 alltoallw2 alltoallw_zeros bcast2 bcast3 bcasttest bcastzerotype coll2 coll3 coll4 coll5 coll6 coll7 coll8 coll9 coll10 coll11 coll12 coll13 exscan exscan2 gather gather2 iallred ibarrier icallgather icallgatherv icallreduce icalltoall icalltoallv icalltoallw icbarrier icbcast icgather icgatherv icreduce icscatter icscatterv longuser nonblocking nonblocking2 nonblocking3 nonblocking4 op_commutative opband opbor opbxor opland oplor oplxor opmax opmaxloc opmin opminloc opprod opsum red3 red4 red_scat_block red_scat_block2 redscat redscat2 redscat3 redscatblk3 redscatinter redscatbkinter reduce reduce_local scantst scatter2 scatter3 scattern scatterv uoplong nballtoall1 nbredscat nbredscat3 nbredscatinter nbcoll2
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/coll'
Making clean in comm
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/comm'
test -z "commcreate1 dup dupic dup_with_info ic1 ic2 commname ctxalloc ctxsplit icgroup icsplit iccreate cmfree icm cmsplit cmsplit2 cmsplit_type comm_create_group comm_group_half comm_group_rand probe-intercomm comm_idup comm_idup_mul comm_idup_overlap comm_info" || rm -f commcreate1 dup dupic dup_with_info ic1 ic2 commname ctxalloc ctxsplit icgroup icsplit iccreate cmfree icm cmsplit cmsplit2 cmsplit_type comm_create_group comm_group_half comm_group_rand probe-intercomm comm_idup comm_idup_mul comm_idup_overlap comm_info
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/comm'
Making clean in errhan
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errhan'
test -z "adderr commcall errfatal predef_eh errstring2" || rm -f adderr commcall errfatal predef_eh errstring2
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errhan'
Making clean in group
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/group'
test -z "grouptest grouptest2 groupcreate gtranks groupnullincl gtranksperf" || rm -f grouptest grouptest2 groupcreate gtranks groupnullincl gtranksperf
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/group'
Making clean in info
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/info'
test -z "infodup infodel infovallen infoorder infomany infomany2 infotest infoenv" || rm -f infodup infodel infovallen infoorder infomany infomany2 infotest infoenv
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/info'
Making clean in init
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/init'
test -z "attrself exitst1 exitst2 exitst3 initstat version library_version timeout finalized" || rm -f attrself exitst1 exitst2 exitst3 initstat version library_version timeout finalized
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/init'
Making clean in pt2pt
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/pt2pt'
test -z "anyall bottom bsend1 bsend2 bsend3 bsend4 bsend5 bsendalign cancelrecv cancelanysrc isendself issendselfcancel sendself eagerdt isendselfprobe bsendfrag bsendpending icsend rqstatus rqfreeb greq1 scancel scancel2 rcancel pscancel sendflood sendrecv1 sendrecv2 sendrecv3 waitany-null pingping probe-unexp probenull inactivereq waittestnull sendall large_message mprobe big_count_status" || rm -f anyall bottom bsend1 bsend2 bsend3 bsend4 bsend5 bsendalign cancelrecv cancelanysrc isendself issendselfcancel sendself eagerdt isendselfprobe bsendfrag bsendpending icsend rqstatus rqfreeb greq1 scancel scancel2 rcancel pscancel sendflood sendrecv1 sendrecv2 sendrecv3 waitany-null pingping probe-unexp probenull inactivereq waittestnull sendall large_message mprobe big_count_status
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/pt2pt'
Making clean in rma
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/rma'
test -z "allocmem ircpi test1 test2 test2_shm test3 test3_shm test4 test5 lockcontention lockcontention2 lockcontention3 lockopts contention_put contention_putget put_base put_bottom locknull wintest wintest_shm transpose1 transpose2 transpose3 transpose3_shm transpose4 transpose5 transpose6 transpose7 fetchandadd fetchandadd_tree winname putfence1 putfidx epochtest getfence1 accfence1 accfence2 adlb_mimic1 putpscw1 accpscw1 getgroup contig_displ test1_am test2_am test2_am_shm test3_am test3_am_shm test4_am test5_am fetchandadd_am fetchandadd_tree_am accfence2_am test1_dt attrorderwin wincall fkeyvalwin baseattrwin nullpscw nullpscw_shm rmanull rmazero mixedsync manyrma2 manyrma2_shm manyrma3 selfrma strided_acc_onelock strided_putget_indexed strided_putget_indexed_shared strided_acc_indexed strided_acc_subarray strided_get_indexed strided_getacc_indexed strided_getacc_indexed_shared window_creation win_flavors win_shared win_shared_noncontig win_shared_noncontig_put win_shared_zerobyte win_zero win_large_shm win_dynamic_acc get_acc_local compare_and_swap linked_list linked_list_fop linked_list_lockall linked_list_bench_lock_all linked_list_bench_lock_excl linked_list_bench_lock_shr linked_list_bench_lock_shr_nocheck fetch_and_op_char fetch_and_op_short fetch_and_op_int fetch_and_op_long fetch_and_op_double fetch_and_op_long_double get_accumulate_short get_accumulate_long get_accumulate_double get_accumulate_int get_accumulate_short_derived get_accumulate_long_derived get_accumulate_double_derived get_accumulate_int_derived flush win_shared_put_flush_get reqops req_example req_example_shm win_info pscw_ordering pscw_ordering_shm mutex_bench mutex_bench_shared mutex_bench_shm mutex_bench_shm_ordered rma-contig badrma nb_test acc-loc fence_shm get-struct at_complete" || rm -f allocmem ircpi test1 test2 test2_shm test3 test3_shm test4 test5 lockcontention lockcontention2 lockcontention3 lockopts contention_put contention_putget put_base put_bottom locknull wintest wintest_shm transpose1 transpose2 transpose3 transpose3_shm transpose4 transpose5 transpose6 transpose7 fetchandadd fetchandadd_tree winname putfence1 putfidx epochtest getfence1 accfence1 accfence2 adlb_mimic1 putpscw1 accpscw1 getgroup contig_displ test1_am test2_am test2_am_shm test3_am test3_am_shm test4_am test5_am fetchandadd_am fetchandadd_tree_am accfence2_am test1_dt attrorderwin wincall fkeyvalwin baseattrwin nullpscw nullpscw_shm rmanull rmazero mixedsync manyrma2 manyrma2_shm manyrma3 selfrma strided_acc_onelock strided_putget_indexed strided_putget_indexed_shared strided_acc_indexed strided_acc_subarray strided_get_indexed strided_getacc_indexed strided_getacc_indexed_shared window_creation win_flavors win_shared win_shared_noncontig win_shared_noncontig_put win_shared_zerobyte win_zero win_large_shm win_dynamic_acc get_acc_local compare_and_swap linked_list linked_list_fop linked_list_lockall linked_list_bench_lock_all linked_list_bench_lock_excl linked_list_bench_lock_shr linked_list_bench_lock_shr_nocheck fetch_and_op_char fetch_and_op_short fetch_and_op_int fetch_and_op_long fetch_and_op_double fetch_and_op_long_double get_accumulate_short get_accumulate_long get_accumulate_double get_accumulate_int get_accumulate_short_derived get_accumulate_long_derived get_accumulate_double_derived get_accumulate_int_derived flush win_shared_put_flush_get reqops req_example req_example_shm win_info pscw_ordering pscw_ordering_shm mutex_bench mutex_bench_shared mutex_bench_shm mutex_bench_shm_ordered rma-contig badrma nb_test acc-loc fence_shm get-struct at_complete
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/rma'
Making clean in topo
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/topo'
test -z "cartmap1 cartzero cartshift1 cartsuball cartcreates dims1 dims2 dims3 dims4 graphmap1 topotest topodup graphcr graphcr2 distgraph1 dgraph_unwgt neighb_coll" || rm -f cartmap1 cartzero cartshift1 cartsuball cartcreates dims1 dims2 dims3 dims4 graphmap1 topotest topodup graphcr graphcr2 distgraph1 dgraph_unwgt neighb_coll
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/topo'
Making clean in errors
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/attr'
test -z "keyvalmis" || rm -f keyvalmis
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/coll'
test -z "noalias rerr bcastlength reduce_local" || rm -f noalias rerr bcastlength reduce_local
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/comm'
test -z "cfree ccreate1 manysplit userdup too_many_comms too_many_comms2 too_many_comms3" || rm -f cfree ccreate1 manysplit userdup too_many_comms too_many_comms2 too_many_comms3
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/datatype'
test -z "getcnterr" || rm -f getcnterr
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/group'
test -z "gerr" || rm -f gerr
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/group'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/pt2pt'
test -z "proberank truncmsg1 truncmsg2 errinstatts errinstatta errinstatws errinstatwa" || rm -f proberank truncmsg1 truncmsg2 errinstatts errinstatta errinstatws errinstatwa
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/pt2pt'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/rma'
test -z "winerr winerr2 cas_type_check win_sync_unlock win_sync_free_pt win_sync_free_at win_sync_complete win_sync_lock_at win_sync_lock_pt win_sync_lock_fence win_sync_nested win_sync_op" || rm -f winerr winerr2 cas_type_check win_sync_unlock win_sync_free_pt win_sync_free_at win_sync_complete win_sync_lock_at win_sync_lock_pt win_sync_lock_fence win_sync_nested win_sync_op
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/topo'
test -z "cartsmall" || rm -f cartsmall
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/topo'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/basic'
test -z "lefthandles debabort" || rm -f lefthandles debabort
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/basic'
Making clean in faults
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/faults'
test -z "pt2ptf1 pt2ptf2 collf1 collf2" || rm -f pt2ptf1 pt2ptf2 collf1 collf2
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/faults'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/io'
test -z "fileerrret openerr" || rm -f fileerrret openerr
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/io'
Making clean in f77
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
Making clean in io
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77/io'
test -z "summary.xml summary.tap" || rm -f summary.xml summary.tap
test -z "uerrhandf" || rm -f uerrhandf
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77/io'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f77'
Making clean in f90
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
Making clean in io
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90/io'
test -z "uerrhandf90" || rm -f uerrhandf90
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90/io'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/f90'
Making clean in cxx
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
Making clean in io
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/io'
test -z "fileerrretx errgetfilex throwtestfilex" || rm -f fileerrretx errgetfilex throwtestfilex
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/io'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/errhan'
test -z "commerrx errgetx errsetx throwtest" || rm -f commerrx errgetx errsetx throwtest
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx/errhan'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/cxx'
Making clean in spawn
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/spawn'
test -z "badport unpub lookup_name" || rm -f badport unpub lookup_name
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors/spawn'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/errors'
Making clean in manual
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
Making clean in mpi_t
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual/mpi_t'
test -z "mpit_test mpit_test2 nem_fbox_fallback_to_queue_count unexpected_recvq_buffer_size" || rm -f mpit_test mpit_test2 nem_fbox_fallback_to_queue_count unexpected_recvq_buffer_size
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual/mpi_t'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
test -z "summary.xml summary.tap summary.junit.xml test-port" || rm -f summary.xml summary.tap summary.junit.xml test-port
test -z "singjoin testconnect testconnectserial dimsbalanced spawntest_master spawntest_child segfault" || rm -f singjoin testconnect testconnectserial dimsbalanced spawntest_master spawntest_child segfault
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/manual'
Making clean in perf
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/perf'
test -z "transp-datatype non_zero_root sendrecvl twovec dtpack allredtrace commcreatep allredtrace commcreatep timer manyrma nestvec nestvec2 indexperf" || rm -f transp-datatype non_zero_root sendrecvl twovec dtpack allredtrace commcreatep allredtrace commcreatep timer manyrma nestvec nestvec2 indexperf
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/perf'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/mpi_t'
test -z "mpi_t_str mpit_vars cvarwrite" || rm -f mpi_t_str mpit_vars cvarwrite
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/mpi_t'
Making clean in impls
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
Making clean in mpich
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich/mpi_t'
test -z "collparmt" || rm -f collparmt
rm -f *.o
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich/mpi_t'
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls/mpich'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/impls'
Making clean in ckpoint
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ckpoint'
test -z "write_ckpoint" || rm -f write_ckpoint
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ckpoint'
Making clean in ft
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ft'
test -z "die abort sendalive isendalive senddead recvdead isenddead irecvdead barrier gather reduce bcast scatter failure_ack anysource revoke_nofail shrink agree multi_isendalive" || rm -f die abort sendalive isendalive senddead recvdead isenddead irecvdead barrier gather reduce bcast scatter failure_ack anysource revoke_nofail shrink agree multi_isendalive
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/ft'
Making clean in io
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/io'
rm -f testfile testfile.*
test -z "rdwrord rdwrzero getextent setinfo setviewcur i_noncontig async async_any userioerr resized resized2 bigtype hindexed_io" || rm -f rdwrord rdwrzero getextent setinfo setviewcur i_noncontig async async_any userioerr resized resized2 bigtype hindexed_io
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/io'
Making clean in f77
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/util'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/attr'
test -z "attrmpi1f baseattrf baseattr2f commattrf commattr2f commattr3f typeattrf typeattr2f typeattr3f" || rm -f attrmpi1f baseattrf baseattr2f commattrf commattr2f commattr3f typeattrf typeattr2f typeattr3f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/datatype'
test -z "typenamef typesnamef typecntsf typesubf typem2f gaddressf packef allctypesf hindex1f hindexed_blockf typename3f" || rm -f typenamef typesnamef typecntsf typesubf typem2f gaddressf packef allctypesf hindex1f hindexed_blockf typename3f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/coll'
test -z "uallreducef exscanf alltoallwf inplacef allredint8f allredopttf reducelocalf alltoallvf redscatf split_typef nonblockingf vw_inplacef red_scat_blockf nonblocking_inpf" || rm -f uallreducef exscanf alltoallwf inplacef allredint8f allredopttf reducelocalf alltoallvf redscatf split_typef nonblockingf vw_inplacef red_scat_blockf nonblocking_inpf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/pt2pt'
test -z "allpairf statusesf greqf mprobef" || rm -f allpairf statusesf greqf mprobef
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/info'
test -z "infotestf infotest2f" || rm -f infotestf infotest2f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/info'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/init'
test -z "baseenvf" || rm -f baseenvf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/init'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/comm'
test -z "commnamef commerrf" || rm -f commnamef commerrf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/topo'
test -z "cartcrf dgraph_wgtf dgraph_unwgtf" || rm -f cartcrf dgraph_wgtf dgraph_unwgtf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/topo'
Making clean in ext
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/ext'
test -z "c2f2cf ctypesinf c2fmult" || rm -f c2f2cf ctypesinf c2fmult
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/ext'
Making clean in profile
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/profile'
test -z "profile1f" || rm -f profile1f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/profile'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/spawn'
test -z "namepubf spawnf spawnargvf spawnmultf spawnmult2f connaccf" || rm -f namepubf spawnf spawnargvf spawnmultf spawnmult2f connaccf
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/spawn'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/io'
test -z "summary.xml summary.tap gen-src-tmp gen-src-stamp" || rm -f summary.xml summary.tap gen-src-tmp gen-src-stamp
rm -f .iotest.txt.*
test -z "iwriteatf iwritef iwriteshf writef writeatf writeallf writeallbef writeordf writeordbef writeshf writeatallf writeatallbef fileerrf fileinfof shpositionf atomicityf miscfilef setviewcurf c2fmultio c2f2ciof" || rm -f iwriteatf iwritef iwriteshf writef writeatf writeallf writeallbef writeordf writeordbef writeshf writeatallf writeatallbef fileerrf fileinfof shpositionf atomicityf miscfilef setviewcurf c2fmultio c2f2ciof
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/io'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/rma'
test -z "winscale1f winscale2f winfencef wingetf winerrf winnamef wingroupf winaccf winaccf c2f2cwinf baseattrwinf winattrf winattr2f" || rm -f winscale1f winscale2f winfencef wingetf winerrf winnamef wingroupf winaccf winaccf c2f2cwinf baseattrwinf winattrf winattr2f
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f77'
Making clean in f90
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/util'
Making clean in timer
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/timer'
test -z "wtimef90" || rm -f wtimef90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/timer'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/attr'
if [ "mod" != "" ] ; then rm -f *.mod ; fi
test -z "attrmpi1f90 baseattrf90 baseattr2f90 commattrf90 commattr2f90 commattr3f90 typeattrf90 typeattr2f90 typeattr3f90 fandcattrf90 baseattr3f90 attrlangf90" || rm -f attrmpi1f90 baseattrf90 baseattr2f90 commattrf90 commattr2f90 commattr3f90 typeattrf90 typeattr2f90 typeattr3f90 fandcattrf90 baseattr3f90 attrlangf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/coll'
test -z "uallreducef90 exscanf90 alltoallwf90 inplacef90 allredint8f90 allredopttf90 reducelocalf90 alltoallvf90 redscatf90 split_typef90 nonblockingf90 vw_inplacef90 red_scat_blockf90 nonblocking_inpf90" || rm -f uallreducef90 exscanf90 alltoallwf90 inplacef90 allredint8f90 allredopttf90 reducelocalf90 alltoallvf90 redscatf90 split_typef90 nonblockingf90 vw_inplacef90 red_scat_blockf90 nonblocking_inpf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/datatype'
test -z "typenamef90 typesnamef90 typecntsf90 typesubf90 typem2f90 gaddressf90 packef90 allctypesf90 hindex1f90 hindexed_blockf90 typename3f90 structf indtype createf90 sizeof kinds trf90 get_elem_d get_elem_u" || rm -f typenamef90 typesnamef90 typecntsf90 typesubf90 typem2f90 gaddressf90 packef90 allctypesf90 hindex1f90 hindexed_blockf90 typename3f90 structf indtype createf90 sizeof kinds trf90 get_elem_d get_elem_u
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/pt2pt'
test -z "allpairf90 statusesf90 greqf90 mprobef90" || rm -f allpairf90 statusesf90 greqf90 mprobef90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/info'
test -z "infotestf90 infotest2f90" || rm -f infotestf90 infotest2f90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/info'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/comm'
test -z "commnamef90 commerrf90" || rm -f commnamef90 commerrf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/topo'
test -z "cartcrf90 dgraph_wgtf90 dgraph_unwgtf90" || rm -f cartcrf90 dgraph_wgtf90 dgraph_unwgtf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/topo'
Making clean in ext
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/ext'
test -z "c2f2cf90 ctypesinf90 c2f90mult" || rm -f c2f2cf90 ctypesinf90 c2f90mult
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/ext'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/init'
test -z "baseenvf90" || rm -f baseenvf90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/init'
Making clean in misc
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/misc'
test -z "sizeof2" || rm -f sizeof2
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/misc'
Making clean in f90types
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/f90types'
test -z "createf90types" || rm -f createf90types
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/f90types'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/profile'
test -z "profile1f90" || rm -f profile1f90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/profile'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/rma'
test -z "winscale1f90 winscale2f90 winfencef90 wingetf90 winerrf90 winnamef90 wingroupf90 winaccf90 winaccf90 c2f2cwinf90 baseattrwinf90 winattrf90 winattr2f90" || rm -f winscale1f90 winscale2f90 winfencef90 wingetf90 winerrf90 winnamef90 wingroupf90 winaccf90 winaccf90 c2f2cwinf90 baseattrwinf90 winattrf90 winattr2f90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/spawn'
test -z "namepubf90 spawnf90 spawnargvf90 spawnmultf90 spawnmult2f90 connaccf90 spawnargvf03 spawnmultf03" || rm -f namepubf90 spawnf90 spawnargvf90 spawnmultf90 spawnmult2f90 connaccf90 spawnargvf03 spawnmultf03
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/spawn'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/io'
rm -f .iotest.txt.*
test -z "iwriteatf90 iwritef90 iwriteshf90 writef90 writeatf90 writeallf90 writeallbef90 writeordf90 writeordbef90 writeshf90 writeatallf90 writeatallbef90 fileerrf90 fileinfof90 shpositionf90 atomicityf90 miscfilef90 setviewcurf90 c2f90multio c2f2ciof90" || rm -f iwriteatf90 iwritef90 iwriteshf90 writef90 writeatf90 writeallf90 writeallbef90 writeordf90 writeordbef90 writeshf90 writeatallf90 writeatallbef90 fileerrf90 fileinfof90 shpositionf90 atomicityf90 miscfilef90 setviewcurf90 c2f90multio c2f2ciof90
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90/io'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/f90'
Making clean in cxx
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/util'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/attr'
test -z "attrtx attricx baseattrcommx fkeyvalcommx fkeyvaltypex" || rm -f attrtx attricx baseattrcommx fkeyvalcommx fkeyvaltypex
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/attr'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/pt2pt'
test -z "bsend1cxx sendrecvx" || rm -f bsend1cxx sendrecvx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/init'
test -z "baseenv initstatx initstat2x" || rm -f baseenv initstatx initstat2x
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/init'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/info'
test -z "infodupx infodelx infovallenx infoorderx" || rm -f infodupx infodelx infovallenx infoorderx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/info'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/comm'
test -z "commname2" || rm -f commname2
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/coll'
test -z "arcomplex uallredx uallreduce ureduce ureducelocal uscan uexscan icbcastx icbarrierx icgatherx icgathervx icscatterx icscattervx icallgatherx icallgathervx icallreducex icreducex icalltoallx alltoallw2x reduceboolx redscatblk" || rm -f arcomplex uallredx uallreduce ureduce ureducelocal uscan uexscan icbcastx icbarrierx icgatherx icgathervx icscatterx icscattervx icallgatherx icallgathervx icallreducex icreducex icalltoallx alltoallw2x reduceboolx redscatblk
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/coll'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/datatype'
test -z "packsizex typecntsx typenamex typemiscx" || rm -f packsizex typecntsx typenamex typemiscx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/datatype'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/errhan'
test -z "commcallx" || rm -f commcallx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/errhan'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/topo'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/topo'
Making clean in io
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/io'
rm -f .iotest.txt.*
test -z "iwriteatx iwritex iwriteshx writex writeatx writeallx writeatallx writeallbex writeordx writeordbex writeshx writeatallbex iwriteatnosx iwritenosx iwriteshnosx writenosx writeatnosx writeallnosx writeatallnosx writeallbenosx writeordnosx writeordbenosx writeshnosx writeatallbenosx fileerrx fileinfox shpositionx setinfox filemiscx seekavail" || rm -f iwriteatx iwritex iwriteshx writex writeatx writeallx writeatallx writeallbex writeordx writeordbex writeshx writeatallbex iwriteatnosx iwritenosx iwriteshnosx writenosx writeatnosx writeallnosx writeatallnosx writeallbenosx writeordnosx writeordbenosx writeshnosx writeatallbenosx fileerrx fileinfox shpositionx setinfox filemiscx seekavail
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/io'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/rma'
test -z "winnamex wincallx getgroupx winfencex winscale1x winscale2x fkeyvalwinx" || rm -f winnamex wincallx getgroupx winfencex winscale1x winscale2x fkeyvalwinx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/spawn'
test -z "spawnargvx spawnintrax namepubx selfconaccx" || rm -f spawnargvx spawnintrax namepubx selfconaccx
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx/spawn'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/cxx'
Making clean in threads
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/util'
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/util'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/pt2pt'
test -z "threads threaded_sr alltoall sendselfth greq_wait greq_test multisend multisend2 multisend3 multisend4 ibsend" || rm -f threads threaded_sr alltoall sendselfth greq_wait greq_test multisend multisend2 multisend3 multisend4 ibsend
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/pt2pt'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/comm'
test -z "ctxdup dup_leak_test comm_dup_deadlock comm_create_threads comm_create_group_threads comm_idup ctxidup" || rm -f ctxdup dup_leak_test comm_dup_deadlock comm_create_threads comm_create_group_threads comm_idup ctxidup
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/comm'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/init'
test -z "initth" || rm -f initth
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/init'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/mpi_t'
test -z "mpit_threading" || rm -f mpit_threading
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/mpi_t'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/spawn'
test -z "multispawn th_taskmaster" || rm -f multispawn th_taskmaster
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/spawn'
Making clean in rma
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/rma'
test -z "multirma multiget" || rm -f multirma multiget
rm -f *.o
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads/rma'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/threads'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/spawn'
test -z "namepub spawn1 spawninfo1 spawnminfo1 spawn2 spawnintra spawnargv spawnmanyarg spaconacc spaconacc2 selfconacc spawnmult2 taskmaster join disconnect_reconnect disconnect_reconnect2 disconnect_reconnect3 multiple_ports multiple_ports2 spaiccreate spaiccreate2 disconnect disconnect2 disconnect3 pgroup_connect_test pgroup_intercomm_test concurrent_spawns" || rm -f namepub spawn1 spawninfo1 spawnminfo1 spawn2 spawnintra spawnargv spawnmanyarg spaconacc spaconacc2 selfconacc spawnmult2 taskmaster join disconnect_reconnect disconnect_reconnect2 disconnect_reconnect3 multiple_ports multiple_ports2 spaiccreate spaiccreate2 disconnect disconnect2 disconnect3 pgroup_connect_test pgroup_intercomm_test concurrent_spawns
rm -f *.o
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi/spawn'
Making clean in ft
rm -f *.o
Making clean in .
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/mpi'
Making clean in commands
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/commands'
test -z "err.txt out.log out.txt a.out" || rm -f err.txt out.log out.txt a.out
rm -rf .libs _libs
 rm -f stdiotest stdintest stdintest2 checkenv1 rtest rtestf rtestx testout
rm -f *.o
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test/commands'
Making clean in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
rm -rf .libs _libs
rm -f *.lo
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/test'
test -z "" || rm -f
test -z "" || rm -f
rm -f *.o
rm -f src/binding/cxx/*.o
rm -f src/binding/cxx/*.lo
rm -f src/binding/fortran/mpif_h/*.o
rm -f src/binding/fortran/mpif_h/*.lo
rm -f src/binding/fortran/use_mpi/*.o
rm -f src/binding/fortran/use_mpi/*.lo
rm -f src/binding/fortran/use_mpi_f08/*.o
rm -f src/binding/fortran/use_mpi_f08/*.lo
rm -f src/binding/fortran/use_mpi_f08/wrappers_c/*.o
rm -f src/binding/fortran/use_mpi_f08/wrappers_c/*.lo
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/*.o
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/*.lo
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/profiling/*.o
rm -f src/binding/fortran/use_mpi_f08/wrappers_f/profiling/*.lo
rm -f src/env/*.o
rm -f src/glue/romio/*.o
rm -f src/glue/romio/*.lo
rm -f src/mpi/attr/*.o
rm -f src/mpi/attr/*.lo
rm -f src/mpi/coll/*.o
rm -f src/mpi/coll/*.lo
rm -f src/mpi/comm/*.o
rm -f src/mpi/comm/*.lo
rm -f src/mpi/datatype/*.o
rm -f src/mpi/datatype/*.lo
rm -f src/mpi/debugger/*.o
rm -f src/mpi/debugger/*.lo
rm -f src/mpi/errhan/*.o
rm -f src/mpi/errhan/*.lo
rm -f src/mpi/group/*.o
rm -f src/mpi/group/*.lo
rm -f src/mpi/info/*.o
rm -f src/mpi/info/*.lo
rm -f src/mpi/init/*.o
rm -f src/mpi/init/*.lo
rm -f src/mpi/misc/*.o
rm -f src/mpi/misc/*.lo
rm -f src/mpi/pt2pt/*.o
rm -f src/mpi/pt2pt/*.lo
rm -f src/mpi/rma/*.o
rm -f src/mpi/rma/*.lo
rm -f src/mpi/spawn/*.o
rm -f src/mpi/spawn/*.lo
rm -f src/mpi/timer/*.o
rm -f src/mpi/timer/*.lo
rm -f src/mpi/topo/*.o
rm -f src/mpi/topo/*.lo
rm -f src/mpi_t/*.o
rm -f src/mpi_t/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/ib/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/ib/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/mx/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/mx/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/mxm/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/mxm/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/newmad/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/newmad/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/none/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/none/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/portals4/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/portals4/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/scif/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/scif/*.lo
rm -f src/mpid/ch3/channels/nemesis/netmod/tcp/*.o
rm -f src/mpid/ch3/channels/nemesis/netmod/tcp/*.lo
rm -f src/mpid/ch3/channels/nemesis/src/*.o
rm -f src/mpid/ch3/channels/nemesis/src/*.lo
rm -f src/mpid/ch3/channels/nemesis/utils/monitor/*.o
rm -f src/mpid/ch3/channels/nemesis/utils/monitor/*.lo
rm -f src/mpid/ch3/channels/nemesis/utils/replacements/*.o
rm -f src/mpid/ch3/channels/nemesis/utils/replacements/*.lo
rm -f src/mpid/ch3/channels/sock/src/*.o
rm -f src/mpid/ch3/channels/sock/src/*.lo
rm -f src/mpid/ch3/src/*.o
rm -f src/mpid/ch3/src/*.lo
rm -f src/mpid/ch3/util/ftb/*.o
rm -f src/mpid/ch3/util/ftb/*.lo
rm -f src/mpid/ch3/util/sock/*.o
rm -f src/mpid/ch3/util/sock/*.lo
rm -f src/mpid/common/datatype/*.o
rm -f src/mpid/common/datatype/*.lo
rm -f src/mpid/common/datatype/dataloop/*.o
rm -f src/mpid/common/datatype/dataloop/*.lo
rm -f src/mpid/common/hcoll/*.o
rm -f src/mpid/common/hcoll/*.lo
rm -f src/mpid/common/sched/*.o
rm -f src/mpid/common/sched/*.lo
rm -f src/mpid/common/sock/poll/*.o
rm -f src/mpid/common/sock/poll/*.lo
rm -f src/mpid/common/thread/*.o
rm -f src/mpid/common/thread/*.lo
rm -f src/mpid/pamid/src/*.o
rm -f src/mpid/pamid/src/*.lo
rm -f src/mpid/pamid/src/coll/*.o
rm -f src/mpid/pamid/src/coll/*.lo
rm -f src/mpid/pamid/src/coll/allgather/*.o
rm -f src/mpid/pamid/src/coll/allgather/*.lo
rm -f src/mpid/pamid/src/coll/allgatherv/*.o
rm -f src/mpid/pamid/src/coll/allgatherv/*.lo
rm -f src/mpid/pamid/src/coll/allreduce/*.o
rm -f src/mpid/pamid/src/coll/allreduce/*.lo
rm -f src/mpid/pamid/src/coll/alltoall/*.o
rm -f src/mpid/pamid/src/coll/alltoall/*.lo
rm -f src/mpid/pamid/src/coll/alltoallv/*.o
rm -f src/mpid/pamid/src/coll/alltoallv/*.lo
rm -f src/mpid/pamid/src/coll/alltoallw/*.o
rm -f src/mpid/pamid/src/coll/alltoallw/*.lo
rm -f src/mpid/pamid/src/coll/barrier/*.o
rm -f src/mpid/pamid/src/coll/barrier/*.lo
rm -f src/mpid/pamid/src/coll/bcast/*.o
rm -f src/mpid/pamid/src/coll/bcast/*.lo
rm -f src/mpid/pamid/src/coll/exscan/*.o
rm -f src/mpid/pamid/src/coll/exscan/*.lo
rm -f src/mpid/pamid/src/coll/gather/*.o
rm -f src/mpid/pamid/src/coll/gather/*.lo
rm -f src/mpid/pamid/src/coll/gatherv/*.o
rm -f src/mpid/pamid/src/coll/gatherv/*.lo
rm -f src/mpid/pamid/src/coll/ired_scat/*.o
rm -f src/mpid/pamid/src/coll/ired_scat/*.lo
rm -f src/mpid/pamid/src/coll/ired_scat_block/*.o
rm -f src/mpid/pamid/src/coll/ired_scat_block/*.lo
rm -f src/mpid/pamid/src/coll/reduce/*.o
rm -f src/mpid/pamid/src/coll/reduce/*.lo
rm -f src/mpid/pamid/src/coll/scan/*.o
rm -f src/mpid/pamid/src/coll/scan/*.lo
rm -f src/mpid/pamid/src/coll/scatter/*.o
rm -f src/mpid/pamid/src/coll/scatter/*.lo
rm -f src/mpid/pamid/src/coll/scatterv/*.o
rm -f src/mpid/pamid/src/coll/scatterv/*.lo
rm -f src/mpid/pamid/src/comm/*.o
rm -f src/mpid/pamid/src/comm/*.lo
rm -f src/mpid/pamid/src/dyntask/*.o
rm -f src/mpid/pamid/src/dyntask/*.lo
rm -f src/mpid/pamid/src/misc/*.o
rm -f src/mpid/pamid/src/misc/*.lo
rm -f src/mpid/pamid/src/mpix/*.o
rm -f src/mpid/pamid/src/mpix/*.lo
rm -f src/mpid/pamid/src/onesided/*.o
rm -f src/mpid/pamid/src/onesided/*.lo
rm -f src/mpid/pamid/src/pamix/*.o
rm -f src/mpid/pamid/src/pamix/*.lo
rm -f src/mpid/pamid/src/pt2pt/*.o
rm -f src/mpid/pamid/src/pt2pt/*.lo
rm -f src/mpid/pamid/src/pt2pt/persistent/*.o
rm -f src/mpid/pamid/src/pt2pt/persistent/*.lo
rm -f src/mutex/*.o
rm -f src/mutex/*.lo
rm -f src/nameserv/file/*.o
rm -f src/nameserv/file/*.lo
rm -f src/nameserv/pmi/*.o
rm -f src/nameserv/pmi/*.lo
rm -f src/pm/gforker/*.o
rm -f src/pm/remshell/*.o
rm -f src/pm/util/*.o
rm -f src/pmi/pmi2/poe/*.o
rm -f src/pmi/pmi2/poe/*.lo
rm -f src/pmi/pmi2/simple/*.o
rm -f src/pmi/pmi2/simple/*.lo
rm -f src/pmi/simple/*.o
rm -f src/pmi/simple/*.lo
rm -f src/util/cvar/*.o
rm -f src/util/cvar/*.lo
rm -f src/util/dbg/*.o
rm -f src/util/dbg/*.lo
rm -f src/util/instrm/*.o
rm -f src/util/instrm/*.lo
rm -f src/util/logging/rlog/*.o
rm -f src/util/logging/rlog/*.lo
rm -f src/util/mem/*.o
rm -f src/util/mem/*.lo
rm -f src/util/msgs/*.o
rm -f src/util/msgs/*.lo
rm -f src/util/other/*.o
rm -f src/util/other/*.lo
rm -f src/util/procmap/*.o
rm -f src/util/procmap/*.lo
rm -f src/util/thread/*.o
rm -f src/util/thread/*.lo
rm -f *.lo
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making clean in examples
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
rm -rf .libs _libs
 rm -f cpi
rm -f *.o
rm -f *.lo
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'if test ! -h ./src/include/mpio.h ; then \
	    rm -f ./src/include/mpio.h ; \
	    ( cd ./src/include &&       \
	        ln -s ../mpi/romio/include/mpio.h ) ; \
	fi
/usr/bin/make  all-recursive
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making all in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
  CC       src/mplstr.lo
  CC       src/mpltrmem.lo
  CC       src/mplenv.lo
  CC       src/mplsock.lo
  CCLD     libmpl.la
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making all in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making all in src
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
/usr/bin/make  all-am
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
  CC       opa_primitives.lo
  CC       opa_queue.lo
  CCLD     libopa.la
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
Making all in test
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making all in src/mpi/romio
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
  CC       mpi-io/mpich_fileutil.lo
  CC       mpi-io/mpir-mpioinit.lo
  CC       mpi-io/mpiu_greq.lo
  CC       mpi-io/mpiu_external32.lo
  CC       mpi-io/close.lo
  CC       mpi-io/file_c2f.lo
  CC       mpi-io/delete.lo
  CC       mpi-io/file_f2c.lo
  CC       mpi-io/fsync.lo
  CC       mpi-io/get_amode.lo
  CC       mpi-io/get_atom.lo
  CC       mpi-io/get_bytoff.lo
  CC       mpi-io/get_extent.lo
  CC       mpi-io/get_group.lo
  CC       mpi-io/get_info.lo
  CC       mpi-io/get_posn.lo
  CC       mpi-io/get_posn_sh.lo
  CC       mpi-io/get_size.lo
  CC       mpi-io/get_view.lo
  CC       mpi-io/iread.lo
  CC       mpi-io/iread_at.lo
  CC       mpi-io/iread_sh.lo
  CC       mpi-io/iwrite.lo
  CC       mpi-io/iwrite_at.lo
  CC       mpi-io/iwrite_sh.lo
  CC       mpi-io/open.lo
  CC       mpi-io/prealloc.lo
  CC       mpi-io/rd_atallb.lo
  CC       mpi-io/rd_atalle.lo
  CC       mpi-io/read.lo
  CC       mpi-io/read_all.lo
  CC       mpi-io/read_allb.lo
  CC       mpi-io/read_alle.lo
  CC       mpi-io/read_at.lo
  CC       mpi-io/read_atall.lo
  CC       mpi-io/read_ord.lo
  CC       mpi-io/read_ordb.lo
  CC       mpi-io/read_orde.lo
  CC       mpi-io/read_sh.lo
  CC       mpi-io/register_datarep.lo
  CC       mpi-io/seek.lo
  CC       mpi-io/seek_sh.lo
  CC       mpi-io/set_atom.lo
  CC       mpi-io/set_info.lo
  CC       mpi-io/set_size.lo
  CC       mpi-io/set_view.lo
  CC       mpi-io/wr_atallb.lo
  CC       mpi-io/wr_atalle.lo
  CC       mpi-io/write.lo
  CC       mpi-io/write_all.lo
  CC       mpi-io/write_allb.lo
  CC       mpi-io/write_alle.lo
  CC       mpi-io/write_at.lo
  CC       mpi-io/write_atall.lo
  CC       mpi-io/write_ord.lo
  CC       mpi-io/write_ordb.lo
  CC       mpi-io/write_orde.lo
  CC       mpi-io/write_sh.lo
  CC       mpi-io/glue/mpich/mpio_file.lo
  CC       mpi-io/glue/mpich/mpio_err.lo
  CC       adio/ad_nfs/ad_nfs_read.lo
  CC       adio/ad_nfs/ad_nfs_open.lo
  CC       adio/ad_nfs/ad_nfs_write.lo
  CC       adio/ad_nfs/ad_nfs_done.lo
  CC       adio/ad_nfs/ad_nfs_fcntl.lo
  CC       adio/ad_nfs/ad_nfs_iread.lo
  CC       adio/ad_nfs/ad_nfs_iwrite.lo
  CC       adio/ad_nfs/ad_nfs_wait.lo
  CC       adio/ad_nfs/ad_nfs_setsh.lo
  CC       adio/ad_nfs/ad_nfs_getsh.lo
  CC       adio/ad_nfs/ad_nfs.lo
  CC       adio/ad_nfs/ad_nfs_resize.lo
  CC       adio/ad_nfs/ad_nfs_features.lo
  CC       adio/ad_testfs/ad_testfs_close.lo
  CC       adio/ad_testfs/ad_testfs_read.lo
  CC       adio/ad_testfs/ad_testfs_rdcoll.lo
  CC       adio/ad_testfs/ad_testfs_wrcoll.lo
  CC       adio/ad_testfs/ad_testfs_open.lo
  CC       adio/ad_testfs/ad_testfs_write.lo
  CC       adio/ad_testfs/ad_testfs_done.lo
  CC       adio/ad_testfs/ad_testfs_fcntl.lo
  CC       adio/ad_testfs/ad_testfs_iread.lo
  CC       adio/ad_testfs/ad_testfs_iwrite.lo
  CC       adio/ad_testfs/ad_testfs_wait.lo
  CC       adio/ad_testfs/ad_testfs_flush.lo
  CC       adio/ad_testfs/ad_testfs_seek.lo
  CC       adio/ad_testfs/ad_testfs_resize.lo
  CC       adio/ad_testfs/ad_testfs_hints.lo
  CC       adio/ad_testfs/ad_testfs_delete.lo
  CC       adio/ad_testfs/ad_testfs.lo
  CC       adio/ad_ufs/ad_ufs.lo
  CC       adio/ad_ufs/ad_ufs_open.lo
  CC       adio/common/ad_aggregate.lo
  CC       adio/common/ad_aggregate_new.lo
  CC       adio/common/ad_close.lo
  CC       adio/common/ad_coll_build_req_new.lo
  CC       adio/common/ad_coll_exch_new.lo
  CC       adio/common/ad_darray.lo
  CC       adio/common/ad_delete.lo
  CC       adio/common/ad_done.lo
  CC       adio/common/ad_done_fake.lo
  CC       adio/common/ad_end.lo
  CC       adio/common/ad_fcntl.lo
  CC       adio/common/ad_features.lo
  CC       adio/common/ad_flush.lo
  CC       adio/common/ad_fstype.lo
  CC       adio/common/ad_get_sh_fp.lo
  CC       adio/common/ad_hints.lo
  CC       adio/common/ad_init.lo
  CC       adio/common/ad_io_coll.lo
  CC       adio/common/ad_iopen.lo
  CC       adio/common/ad_iread.lo
  CC       adio/common/ad_iread_fake.lo
  CC       adio/common/ad_iwrite.lo
  CC       adio/common/ad_iwrite_fake.lo
  CC       adio/common/ad_open.lo
  CC       adio/common/ad_opencoll.lo
  CC       adio/common/ad_opencoll_failsafe.lo
  CC       adio/common/ad_opencoll_scalable.lo
  CC       adio/common/ad_prealloc.lo
  CC       adio/common/ad_read.lo
  CC       adio/common/ad_read_coll.lo
  CC       adio/common/ad_read_str.lo
  CC       adio/common/ad_read_str_naive.lo
  CC       adio/common/ad_resize.lo
  CC       adio/common/ad_seek.lo
  CC       adio/common/ad_set_sh_fp.lo
  CC       adio/common/ad_set_view.lo
  CC       adio/common/ad_subarray.lo
  CC       adio/common/ad_wait.lo
  CC       adio/common/ad_wait_fake.lo
  CC       adio/common/ad_write.lo
  CC       adio/common/ad_write_coll.lo
  CC       adio/common/ad_write_nolock.lo
  CC       adio/common/ad_write_str.lo
  CC       adio/common/ad_write_str_naive.lo
  CC       adio/common/adi_close.lo
  CC       adio/common/byte_offset.lo
  CC       adio/common/cb_config_list.lo
  CC       adio/common/eof_offset.lo
  CC       adio/common/error.lo
  CC       adio/common/flatten.lo
  CC       adio/common/get_fp_posn.lo
  CC       adio/common/greq_fns.lo
  CC       adio/common/heap-sort.lo
  CC       adio/common/iscontig.lo
  CC       adio/common/lock.lo
  CC       adio/common/malloc.lo
  CC       adio/common/shfp_fname.lo
  CC       adio/common/status_setb.lo
  CC       adio/common/strfns.lo
  CC       adio/common/system_hints.lo
  CC       adio/common/hint_fns.lo
  CC       adio/common/ad_threaded_io.lo
  CC       adio/common/p2p_aggregation.lo
  CC       adio/common/utils.lo
  CCLD     libromio.la
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
Making all in src/pm/hydra
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making all in ../../mpl
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making all in tools/topo/hwloc/hwloc
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making all in src
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
  CC       topology.lo
  CC       traversal.lo
  CC       distances.lo
  CC       components.lo
  CC       bind.lo
  CC       bitmap.lo
  CC       pci-common.lo
  CC       diff.lo
  CC       misc.lo
  CC       base64.lo
  CC       topology-noos.lo
  CC       topology-synthetic.lo
  CC       topology-custom.lo
  CC       topology-xml.lo
  CC       topology-xml-nolibxml.lo
  CC       topology-xml-libxml.lo
  CC       topology-linux.lo
  CC       topology-x86.lo
  CCLD     libhwloc_embedded.la
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
Making all in include
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making all in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
  CC       tools/bootstrap/persist/hydra_persist-persist_server.o
  CC       utils/alloc/alloc.lo
  CC       utils/args/args.lo
  CC       utils/dbg/dbg.lo
  CC       utils/env/env.lo
  CC       utils/launch/launch.lo
  CC       utils/others/others.lo
  CC       utils/signals/signals.lo
  CC       utils/sock/sock.lo
  CC       utils/string/string.lo
  CC       tools/topo/topo.lo
  CC       tools/topo/hwloc/topo_hwloc.lo
  CC       tools/bootstrap/src/bsci_init.lo
  CC       tools/bootstrap/src/bsci_finalize.lo
  CC       tools/bootstrap/src/bsci_launch.lo
  CC       tools/bootstrap/src/bsci_query_node_list.lo
  CC       tools/bootstrap/src/bsci_query_proxy_id.lo
  CC       tools/bootstrap/src/bsci_query_native_int.lo
  CC       tools/bootstrap/src/bsci_wait.lo
  CC       tools/bootstrap/src/bsci_env.lo
  CC       tools/bootstrap/utils/bscu_wait.lo
  CC       tools/bootstrap/utils/bscu_cb.lo
  CC       tools/bootstrap/external/external_common.lo
  CC       tools/bootstrap/external/external_common_launch.lo
  CC       tools/bootstrap/external/fork_init.lo
  CC       tools/bootstrap/external/user_init.lo
  CC       tools/bootstrap/external/manual_init.lo
  CC       tools/bootstrap/external/rsh_init.lo
  CC       tools/bootstrap/external/rsh_env.lo
  CC       tools/bootstrap/external/ssh_init.lo
  CC       tools/bootstrap/external/ssh.lo
  CC       tools/bootstrap/external/ssh_env.lo
  CC       tools/bootstrap/external/ssh_finalize.lo
  CC       tools/bootstrap/external/slurm_init.lo
  CC       tools/bootstrap/external/slurm_launch.lo
  CC       tools/bootstrap/external/slurm_env.lo
  CC       tools/bootstrap/external/slurm_query_native_int.lo
  CC       tools/bootstrap/external/slurm_query_node_list.lo
  CC       tools/bootstrap/external/slurm_query_proxy_id.lo
  CC       tools/bootstrap/external/ll_init.lo
  CC       tools/bootstrap/external/ll_launch.lo
  CC       tools/bootstrap/external/ll_query_native_int.lo
  CC       tools/bootstrap/external/ll_query_node_list.lo
  CC       tools/bootstrap/external/ll_query_proxy_id.lo
  CC       tools/bootstrap/external/ll_env.lo
  CC       tools/bootstrap/external/lsf_init.lo
  CC       tools/bootstrap/external/lsf_query_native_int.lo
  CC       tools/bootstrap/external/lsf_query_node_list.lo
  CC       tools/bootstrap/external/lsf_env.lo
  CC       tools/bootstrap/external/sge_init.lo
  CC       tools/bootstrap/external/sge_query_native_int.lo
  CC       tools/bootstrap/external/sge_query_node_list.lo
  CC       tools/bootstrap/external/sge_env.lo
  CC       tools/bootstrap/external/pbs_init.lo
  CC       tools/bootstrap/external/pbs_query_native_int.lo
  CC       tools/bootstrap/external/pbs_query_node_list.lo
  CC       tools/bootstrap/external/cobalt_init.lo
  CC       tools/bootstrap/external/cobalt_query_native_int.lo
  CC       tools/bootstrap/external/cobalt_query_node_list.lo
  CC       tools/bootstrap/persist/persist_init.lo
  CC       tools/bootstrap/persist/persist_launch.lo
  CC       tools/bootstrap/persist/persist_wait.lo
  CC       tools/ckpoint/ckpoint.lo
  CC       tools/demux/demux.lo
  CC       tools/demux/demux_poll.lo
  CC       tools/demux/demux_select.lo
  CC       tools/debugger/debugger.lo
  CC       tools/ftb/hydt_ftb_dummy.lo
  CC       ui/utils/uiu.lo
  CC       pm/pmiserv/pmiserv_pmi.lo
  CC       pm/pmiserv/pmiserv_pmi_v1.lo
  CC       pm/pmiserv/pmiserv_pmi_v2.lo
  CC       pm/pmiserv/pmiserv_pmci.lo
  CC       pm/pmiserv/pmiserv_cb.lo
  CC       pm/pmiserv/pmiserv_utils.lo
  CC       pm/pmiserv/common.lo
  CC       pm/pmiserv/pmi_v2_common.lo
  CC       tools/nameserver/hydra_nameserver-hydra_nameserver.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_cb.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_utils.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_pmi_v1.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmip_pmi_v2.o
  CC       pm/pmiserv/hydra_pmi_proxy-common.o
  CC       pm/pmiserv/hydra_pmi_proxy-pmi_v2_common.o
  CC       ui/mpich/mpiexec.o
  CC       ui/mpich/utils.o
  CCLD     libhydra.la
  CCLD     hydra_persist
  CCLD     hydra_nameserver
  CCLD     hydra_pmi_proxy
  CCLD     libpm.la
  CCLD     mpiexec.hydra
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making all in .
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
  CC       src/mpi/attr/lib_libmpi_la-attrutil.lo
  CC       src/mpi/coll/lib_libmpi_la-allred_group.lo
  CC       src/mpi/attr/lib_libmpi_la-dup_fn.lo
  CC       src/mpi/coll/lib_libmpi_la-barrier_group.lo
  CC       src/mpi/coll/lib_libmpi_la-helper_fns.lo
  CC       src/mpi/coll/lib_libmpi_la-opsum.lo
  CC       src/mpi/coll/lib_libmpi_la-opmax.lo
  CC       src/mpi/coll/lib_libmpi_la-opmin.lo
  CC       src/mpi/coll/lib_libmpi_la-opband.lo
  CC       src/mpi/coll/lib_libmpi_la-opbor.lo
  CC       src/mpi/coll/lib_libmpi_la-opbxor.lo
  CC       src/mpi/coll/lib_libmpi_la-opland.lo
  CC       src/mpi/coll/lib_libmpi_la-oplor.lo
  CC       src/mpi/coll/lib_libmpi_la-oplxor.lo
  CC       src/mpi/coll/lib_libmpi_la-opprod.lo
  CC       src/mpi/coll/lib_libmpi_la-opminloc.lo
  CC       src/mpi/coll/lib_libmpi_la-opmaxloc.lo
  CC       src/mpi/coll/lib_libmpi_la-opno_op.lo
  CC       src/mpi/coll/lib_libmpi_la-opreplace.lo
  CC       src/mpi/coll/lib_libmpi_la-nbcutil.lo
  CC       src/mpi/comm/lib_libmpi_la-commutil.lo
  CC       src/mpi/datatype/lib_libmpi_la-typeutil.lo
  CC       src/mpi/errhan/lib_libmpi_la-errutil.lo
  CC       src/mpi/errhan/lib_libmpi_la-dynerrutil.lo
  CC       src/mpi/group/lib_libmpi_la-grouputil.lo
  CC       src/mpi/info/lib_libmpi_la-infoutil.lo
  CC       src/mpi/init/lib_libmpi_la-initinfo.lo
  CC       src/mpi/init/lib_libmpi_la-async.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bsendutil.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-mpir_request.lo
  CC       src/mpi/rma/lib_libmpi_la-winutil.lo
  CC       src/mpi/rma/lib_libmpi_la-rmatypeutil.lo
  CC       src/mpi/timer/lib_libmpi_la-mpidtime.lo
  CC       src/mpi/topo/lib_libmpi_la-topoutil.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-fdebug.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-setbot.lo
  F77      src/binding/fortran/mpif_h/setbotf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_util.lo
  CC       src/glue/romio/lib_libmpi_la-glue_romio.lo
  CC       src/mpi_t/lib_libmpi_la-mpit.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-sendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-recvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_countf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ssendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bufattachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bufdetachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-isendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ibsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-issendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-irsendf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-irecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-request_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitanyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testanyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-waitsomef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testsomef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iprobef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-probef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cancelf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-testcancelf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-send_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bsend_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ssend_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rsend_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-recv_initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-startf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-startallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-sendrecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-sndrcvrplf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecontigf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_vectorf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_hvectorf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_indexedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_hindexedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_structf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_extentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_lbf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_ubf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_commitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_elementsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-packf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-unpackf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-pack_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-barrierf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-bcastf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-gatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-gathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-scatterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-scattervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-allgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-allgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-exscanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-op_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-op_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-allreducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-redscatf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-scanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_rankf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grouptranksf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_comparef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_unionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-groupinterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-groupdifff.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_inclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_exclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grouprinclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grouprexclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-group_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_rankf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_comparef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dup_with_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_splitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commtesticf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commrsizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commrgroupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iccreatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-icmergef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-attr_putf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-attr_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-attr_deletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-topo_testf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dims_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graph_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graphdims_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graph_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cartdim_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_rankf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_coordsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbcountf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbrsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_shiftf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_subf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-cart_mapf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-graph_mapf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-getpnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_versionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_library_versionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhcreatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhsetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhgetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-errhfreef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-error_stringf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-error_classf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-finalizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-initializedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-abortf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-close_portf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_acceptf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_connectf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commdiscf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commparentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_joinf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_spawnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-spawnmultf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-lookup_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-open_portf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-publish_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-unpubnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-accumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-putf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_completef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_fencef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_lockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_postf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_startf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_testf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_waitf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocate_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_shared_queryf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_create_dynamicf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_attachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_detachf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_accumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-fetch_and_opf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-compare_and_swapf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rputf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rgetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-raccumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-rget_accumulatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_lock_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlock_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flushf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_localf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_local_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_syncf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-adderrclassf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-adderrcodef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-adderrstringf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commcallerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commnewkeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commdelattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commfreekeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commgetnamf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-filecallerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-greqcompletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-greqstartf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-isthrmainf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-query_threadf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-statgetclf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-statsetelf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typenewkeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typedelattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_dupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typefreekeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegetcntsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegetenvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typesetattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typesetnamef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_match_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wincallerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-winnewkeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-windelattrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-winfreekeyf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_attrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_namef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-alloc_memf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commcreerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commgeterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-commseterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-filecreerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-filegeterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-fileseterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-finalizedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-free_memf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_deletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_dupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_freef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_getf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-infognkf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-infognthkf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-infovallenf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-info_setf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-pack_externalf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-packesizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reqgetstatf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typedarrayf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typechindf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typechvecf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecindbf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_create_hindexed_blockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecresizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecstructf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typecsubarrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegetextentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-typegtextf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-unpackextf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wincreerrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wingeterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-winseterrf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_localf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-op_commutativef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_scatter_blockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_create_adjacentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighbors_countf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighborsf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-improbef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-imrecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-mprobef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-mrecvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_idupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ibarrierf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ibcastf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-igatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-igathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iscatterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iscattervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iallgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iallgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ireducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iallreducef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatterf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatter_blockf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iscanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-iexscanf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgatherf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgathervf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallvf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallwf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_split_typef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-get_elements_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-status_set_elements_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_extent_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_true_extent_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-type_size_xf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_create_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_ackf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_get_ackedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_revokef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_shrinkf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-comm_agreef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_openf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_closef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_deletef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_preallocatef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_sizef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_groupf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_amodef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_infof.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_viewf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_viewf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_atf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_readf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_writef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_allf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_ireadf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwritef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_seekf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_positionf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_byte_offsetf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_orderedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_orderedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_seek_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_position_sharedf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_beginf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_endf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_type_extentf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-register_datarepf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_atomicityf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_atomicityf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-file_syncf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-initf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-initthreadf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-pcontrolf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-addressf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-getaddressf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wtimef.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-wtickf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_createf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_copy_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_comm_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_copy_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_win_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_copy_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-dup_type_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_del_fnf.lo
  CC       src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_copy_fnf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpifort_la-typef90cmplxf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpifort_la-typef90realf.lo
  CC       src/binding/fortran/use_mpi/lib_libmpifort_la-typef90intf.lo
rm -f src/binding/fortran/use_mpi/mpifnoext.h
sed -e 's/^C/\!/g' -e '/EXTERNAL/d' \
	-e '/REAL\*8/d' \
	-e '/DOUBLE PRECISION/d' \
	-e '/MPI_WTICK/d' src/binding/fortran/mpif_h/mpif.h > src/binding/fortran/use_mpi/mpifnoext.h
cp -p src/env/mpicc.bash src/env/mpicc
cp -p src/env/mpifort.bash src/env/mpifort
cp -p src/env/mpicxx.bash src/env/mpicxx
  CC       src/mpi/attr/lib_libmpi_la-attr_delete.lo
  CC       src/mpi/attr/lib_libmpi_la-attr_get.lo
  CC       src/mpi/attr/lib_libmpi_la-attr_put.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_create_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_delete_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_free_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_get_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-comm_set_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-keyval_create.lo
  CC       src/mpi/attr/lib_libmpi_la-keyval_free.lo
  CC       src/mpi/attr/lib_libmpi_la-type_create_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-type_delete_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-type_free_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-type_get_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-type_set_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-win_create_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-win_delete_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-win_free_keyval.lo
  CC       src/mpi/attr/lib_libmpi_la-win_get_attr.lo
  CC       src/mpi/attr/lib_libmpi_la-win_set_attr.lo
  CC       src/mpi/coll/lib_libmpi_la-allreduce.lo
  CC       src/mpi/coll/lib_libmpi_la-barrier.lo
  CC       src/mpi/coll/lib_libmpi_la-op_create.lo
  CC       src/mpi/coll/lib_libmpi_la-op_free.lo
  CC       src/mpi/coll/lib_libmpi_la-bcast.lo
  CC       src/mpi/coll/lib_libmpi_la-alltoall.lo
  CC       src/mpi/coll/lib_libmpi_la-alltoallv.lo
  CC       src/mpi/coll/lib_libmpi_la-reduce.lo
  CC       src/mpi/coll/lib_libmpi_la-scatter.lo
  CC       src/mpi/coll/lib_libmpi_la-gather.lo
  CC       src/mpi/coll/lib_libmpi_la-scatterv.lo
  CC       src/mpi/coll/lib_libmpi_la-gatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-scan.lo
  CC       src/mpi/coll/lib_libmpi_la-exscan.lo
  CC       src/mpi/coll/lib_libmpi_la-allgather.lo
  CC       src/mpi/coll/lib_libmpi_la-allgatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-red_scat.lo
  CC       src/mpi/coll/lib_libmpi_la-alltoallw.lo
  CC       src/mpi/coll/lib_libmpi_la-reduce_local.lo
  CC       src/mpi/coll/lib_libmpi_la-op_commutative.lo
  CC       src/mpi/coll/lib_libmpi_la-red_scat_block.lo
  CC       src/mpi/coll/lib_libmpi_la-iallgather.lo
  CC       src/mpi/coll/lib_libmpi_la-iallgatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-iallreduce.lo
  CC       src/mpi/coll/lib_libmpi_la-ialltoall.lo
  CC       src/mpi/coll/lib_libmpi_la-ialltoallv.lo
  CC       src/mpi/coll/lib_libmpi_la-ialltoallw.lo
  CC       src/mpi/coll/lib_libmpi_la-ibarrier.lo
  CC       src/mpi/coll/lib_libmpi_la-ibcast.lo
  CC       src/mpi/coll/lib_libmpi_la-iexscan.lo
  CC       src/mpi/coll/lib_libmpi_la-igather.lo
  CC       src/mpi/coll/lib_libmpi_la-igatherv.lo
  CC       src/mpi/coll/lib_libmpi_la-ired_scat.lo
  CC       src/mpi/coll/lib_libmpi_la-ired_scat_block.lo
  CC       src/mpi/coll/lib_libmpi_la-ireduce.lo
  CC       src/mpi/coll/lib_libmpi_la-iscan.lo
  CC       src/mpi/coll/lib_libmpi_la-iscatter.lo
  CC       src/mpi/coll/lib_libmpi_la-iscatterv.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_compare.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_create.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_create_group.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_dup.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_dup_with_info.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_free.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_get_name.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_get_info.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_set_info.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_group.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_idup.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_rank.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_size.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_remote_group.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_remote_size.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_set_name.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_split.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_test_inter.lo
  CC       src/mpi/comm/lib_libmpi_la-intercomm_create.lo
  CC       src/mpi/comm/lib_libmpi_la-intercomm_merge.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_split_type.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_failure_ack.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_failure_get_acked.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_revoke.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_shrink.lo
  CC       src/mpi/comm/lib_libmpi_la-comm_agree.lo
  CC       src/mpi/datatype/lib_libmpi_la-address.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_address.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_count.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_elements.lo
  CC       src/mpi/datatype/lib_libmpi_la-get_elements_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack.lo
  CC       src/mpi/datatype/lib_libmpi_la-unpack.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-status_set_elements.lo
  CC       src/mpi/datatype/lib_libmpi_la-status_set_elements_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_name.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_set_name.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_size_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_extent.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_vector.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_commit.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_indexed.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_hindexed.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_struct.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_contiguous.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_free.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_hvector.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_dup.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_envelope.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_contents.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_ub.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_lb.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_extent.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_extent_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_true_extent.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_get_true_extent_x.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_match_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_struct.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_hindexed.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_hvector.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack_external.lo
  CC       src/mpi/datatype/lib_libmpi_la-pack_external_size.lo
  CC       src/mpi/datatype/lib_libmpi_la-unpack_external.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_indexed_block.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_hindexed_block.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_resized.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_darray.lo
  CC       src/mpi/datatype/lib_libmpi_la-type_create_subarray.lo
  CC       src/mpi/errhan/lib_libmpi_la-add_error_code.lo
  CC       src/mpi/errhan/lib_libmpi_la-add_error_class.lo
  CC       src/mpi/errhan/lib_libmpi_la-add_error_string.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_call_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_create_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_get_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-comm_set_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_create.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_free.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_get.lo
  CC       src/mpi/errhan/lib_libmpi_la-errhandler_set.lo
  CC       src/mpi/errhan/lib_libmpi_la-error_class.lo
  CC       src/mpi/errhan/lib_libmpi_la-error_string.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_create_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_get_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_set_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-file_call_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_create_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_call_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_get_errhandler.lo
  CC       src/mpi/errhan/lib_libmpi_la-win_set_errhandler.lo
  CC       src/mpi/group/lib_libmpi_la-group_compare.lo
  CC       src/mpi/group/lib_libmpi_la-group_difference.lo
  CC       src/mpi/group/lib_libmpi_la-group_excl.lo
  CC       src/mpi/group/lib_libmpi_la-group_free.lo
  CC       src/mpi/group/lib_libmpi_la-group_incl.lo
  CC       src/mpi/group/lib_libmpi_la-group_intersection.lo
  CC       src/mpi/group/lib_libmpi_la-group_range_excl.lo
  CC       src/mpi/group/lib_libmpi_la-group_range_incl.lo
  CC       src/mpi/group/lib_libmpi_la-group_rank.lo
  CC       src/mpi/group/lib_libmpi_la-group_size.lo
  CC       src/mpi/group/lib_libmpi_la-group_translate_ranks.lo
  CC       src/mpi/group/lib_libmpi_la-group_union.lo
  CC       src/mpi/info/lib_libmpi_la-info_create.lo
  CC       src/mpi/info/lib_libmpi_la-info_delete.lo
  CC       src/mpi/info/lib_libmpi_la-info_dup.lo
  CC       src/mpi/info/lib_libmpi_la-info_free.lo
  CC       src/mpi/info/lib_libmpi_la-info_get.lo
  CC       src/mpi/info/lib_libmpi_la-info_getn.lo
  CC       src/mpi/info/lib_libmpi_la-info_getnth.lo
  CC       src/mpi/info/lib_libmpi_la-info_getvallen.lo
  CC       src/mpi/info/lib_libmpi_la-info_set.lo
  CC       src/mpi/init/lib_libmpi_la-abort.lo
  CC       src/mpi/init/lib_libmpi_la-init.lo
  CC       src/mpi/init/lib_libmpi_la-initialized.lo
  CC       src/mpi/init/lib_libmpi_la-initthread.lo
  CC       src/mpi/init/lib_libmpi_la-ismain.lo
  CC       src/mpi/init/lib_libmpi_la-finalize.lo
  CC       src/mpi/init/lib_libmpi_la-finalized.lo
  CC       src/mpi/init/lib_libmpi_la-querythread.lo
  CC       src/mpi/misc/lib_libmpi_la-getpname.lo
  CC       src/mpi/misc/lib_libmpi_la-pcontrol.lo
  CC       src/mpi/misc/lib_libmpi_la-version.lo
  CC       src/mpi/misc/lib_libmpi_la-library_version.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bsend_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-bufattach.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-buffree.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-cancel.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-greq_start.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-greq_complete.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-ibsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-improbe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-imrecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-iprobe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-irecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-irsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-isend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-issend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-mprobe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-mrecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-probe.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-recv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-recv_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-request_free.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-request_get_status.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-rsend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-rsend_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-send.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-send_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-sendrecv.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-sendrecv_rep.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-status_set_cancelled.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-ssend.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-ssend_init.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-start.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-startall.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-test.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-test_cancelled.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-testall.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-testany.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-testsome.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-wait.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-waitall.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-waitany.lo
  CC       src/mpi/pt2pt/lib_libmpi_la-waitsome.lo
  CC       src/mpi/rma/lib_libmpi_la-accumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-alloc_mem.lo
  CC       src/mpi/rma/lib_libmpi_la-compare_and_swap.lo
  CC       src/mpi/rma/lib_libmpi_la-fetch_and_op.lo
  CC       src/mpi/rma/lib_libmpi_la-free_mem.lo
  CC       src/mpi/rma/lib_libmpi_la-get.lo
  CC       src/mpi/rma/lib_libmpi_la-get_accumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-put.lo
  CC       src/mpi/rma/lib_libmpi_la-raccumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-rget.lo
  CC       src/mpi/rma/lib_libmpi_la-rget_accumulate.lo
  CC       src/mpi/rma/lib_libmpi_la-rput.lo
  CC       src/mpi/rma/lib_libmpi_la-win_allocate.lo
  CC       src/mpi/rma/lib_libmpi_la-win_allocate_shared.lo
  CC       src/mpi/rma/lib_libmpi_la-win_attach.lo
  CC       src/mpi/rma/lib_libmpi_la-win_complete.lo
  CC       src/mpi/rma/lib_libmpi_la-win_create.lo
  CC       src/mpi/rma/lib_libmpi_la-win_create_dynamic.lo
  CC       src/mpi/rma/lib_libmpi_la-win_detach.lo
  CC       src/mpi/rma/lib_libmpi_la-win_fence.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush_local.lo
  CC       src/mpi/rma/lib_libmpi_la-win_flush_local_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_free.lo
  CC       src/mpi/rma/lib_libmpi_la-win_get_group.lo
  CC       src/mpi/rma/lib_libmpi_la-win_get_info.lo
  CC       src/mpi/rma/lib_libmpi_la-win_get_name.lo
  CC       src/mpi/rma/lib_libmpi_la-win_lock.lo
  CC       src/mpi/rma/lib_libmpi_la-win_lock_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_post.lo
  CC       src/mpi/rma/lib_libmpi_la-win_set_info.lo
  CC       src/mpi/rma/lib_libmpi_la-win_set_name.lo
  CC       src/mpi/rma/lib_libmpi_la-win_shared_query.lo
  CC       src/mpi/rma/lib_libmpi_la-win_start.lo
  CC       src/mpi/rma/lib_libmpi_la-win_sync.lo
  CC       src/mpi/rma/lib_libmpi_la-win_test.lo
  CC       src/mpi/rma/lib_libmpi_la-win_unlock.lo
  CC       src/mpi/rma/lib_libmpi_la-win_unlock_all.lo
  CC       src/mpi/rma/lib_libmpi_la-win_wait.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_disconnect.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_get_parent.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_join.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_spawn.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_spawn_multiple.lo
  CC       src/mpi/spawn/lib_libmpi_la-lookup_name.lo
  CC       src/mpi/spawn/lib_libmpi_la-publish_name.lo
  CC       src/mpi/spawn/lib_libmpi_la-unpublish_name.lo
  CC       src/mpi/spawn/lib_libmpi_la-open_port.lo
  CC       src/mpi/spawn/lib_libmpi_la-close_port.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_connect.lo
  CC       src/mpi/spawn/lib_libmpi_la-comm_accept.lo
  CC       src/mpi/timer/lib_libmpi_la-wtime.lo
  CC       src/mpi/timer/lib_libmpi_la-wtick.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_coords.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_create.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_get.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_map.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_rank.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_shift.lo
  CC       src/mpi/topo/lib_libmpi_la-cart_sub.lo
  CC       src/mpi/topo/lib_libmpi_la-dims_create.lo
  CC       src/mpi/topo/lib_libmpi_la-graph_get.lo
  CC       src/mpi/topo/lib_libmpi_la-graph_map.lo
  CC       src/mpi/topo/lib_libmpi_la-graph_nbr.lo
  CC       src/mpi/topo/lib_libmpi_la-graphcreate.lo
  CC       src/mpi/topo/lib_libmpi_la-graphdimsget.lo
  CC       src/mpi/topo/lib_libmpi_la-graphnbrcnt.lo
  CC       src/mpi/topo/lib_libmpi_la-cartdim_get.lo
  CC       src/mpi/topo/lib_libmpi_la-topo_test.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_create_adj.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_create.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_neighb_count.lo
  CC       src/mpi/topo/lib_libmpi_la-dist_gr_neighb.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_allgather.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_allgatherv.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_alltoall.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_alltoallv.lo
  CC       src/mpi/topo/lib_libmpi_la-inhb_alltoallw.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_allgather.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_allgatherv.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_alltoall.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_alltoallv.lo
  CC       src/mpi/topo/lib_libmpi_la-nhb_alltoallw.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-statusf2c.lo
  CC       src/binding/fortran/mpif_h/lib_libmpi_la-statusc2f.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_int.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_real.lo
  CC       src/binding/fortran/use_mpi/lib_libmpi_la-create_f90_complex.lo
  CC       src/glue/romio/lib_libmpi_la-all_romio_symbols.lo
  CC       src/mutex/lib_libmpi_la-mutex_create.lo
  CC       src/mutex/lib_libmpi_la-mutex_free.lo
  CC       src/mutex/lib_libmpi_la-mutex_lock.lo
  CC       src/mutex/lib_libmpi_la-mutex_unlock.lo
  CC       src/mpi_t/lib_libmpi_la-cat_changed.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_categories.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_cvars.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_num.lo
  CC       src/mpi_t/lib_libmpi_la-cat_get_pvars.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_get_num.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_handle_alloc.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_handle_free.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_read.lo
  CC       src/mpi_t/lib_libmpi_la-cvar_write.lo
  CC       src/mpi_t/lib_libmpi_la-enum_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-enum_get_item.lo
  CC       src/mpi_t/lib_libmpi_la-mpit_finalize.lo
  CC       src/mpi_t/lib_libmpi_la-mpit_initthread.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_get_info.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_get_num.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_handle_alloc.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_handle_free.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_read.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_readreset.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_reset.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_session_create.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_session_free.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_start.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_stop.lo
  CC       src/mpi_t/lib_libmpi_la-pvar_write.lo
  CC       src/util/dbg/lib_libmpi_la-dbg_printf.lo
  CC       src/util/dbg/lib_libmpi_la-timelimit.lo
  CC       src/util/dbg/lib_libmpi_la-exit.lo
  CC       src/util/instrm/lib_libmpi_la-states.lo
  CC       src/util/instrm/lib_libmpi_la-instr.lo
  CC       src/util/mem/lib_libmpi_la-trmem.lo
  CC       src/util/mem/lib_libmpi_la-handlemem.lo
  CC       src/util/mem/lib_libmpi_la-safestr.lo
  CC       src/util/mem/lib_libmpi_la-argstr.lo
  CC       src/util/mem/lib_libmpi_la-strerror.lo
  CC       src/util/msgs/lib_libmpi_la-msgprint.lo
  CC       src/util/other/lib_libmpi_la-outliers.lo
  CC       src/util/other/lib_libmpi_la-assert.lo
  CC       src/util/cvar/lib_libmpi_la-mpich_cvars.lo
  CC       src/util/procmap/lib_libmpi_la-local_proc.lo
  CC       src/util/thread/lib_libmpi_la-mpiu_thread.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_buffer.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_comm.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_comm_spawn_multiple.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_connection.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_recv_pkt.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_recv_req.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_revoke_pkt.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_handle_send_req.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_port.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_recvq.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_request.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_acc_ops.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_ops.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_reqops.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rma_sync.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_rndv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_eager.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_eagersync.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-ch3u_win_fns.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_abort.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_cancel_recv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_cancel_send.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_disconnect.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_spawn_multiple.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_failure_ack.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_get_all_failed_procs.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_revoke.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_comm_agree.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_finalize.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_get_universe_size.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_getpname.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_improbe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_imrecv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_init.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_iprobe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_irecv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_irsend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_isend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_issend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_mprobe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_mrecv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_port.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_probe.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_recv.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_rsend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_send.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_ssend.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_startall.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_vc.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpid_rma.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpidi_isend_self.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpidi_pg.lo
  CC       src/mpid/ch3/src/lib_libmpi_la-mpidi_printf.lo
  CC       src/mpid/ch3/util/sock/lib_libmpi_la-ch3u_init_sock.lo
  CC       src/mpid/ch3/util/sock/lib_libmpi_la-ch3u_connect_sock.lo
  CC       src/mpid/ch3/util/sock/lib_libmpi_la-ch3u_getinterfaces.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_finalize.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_init.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_isend.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_isendv.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_istartmsg.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_istartmsgv.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_progress.lo
  CC       src/mpid/ch3/channels/sock/src/lib_libmpi_la-ch3_win_fns.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-darray_support.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_blockindexed.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_contig.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_indexed.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_pairtype.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_struct.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-dataloop_create_vector.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment_count.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment_flatten.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-segment_packunpack.lo
  CC       src/mpid/common/datatype/dataloop/lib_libmpi_la-subarray_support.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_contents_support.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_datatype_contents.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_datatype_free.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_ext32_datatype.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_ext32_segment.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_segment.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_blockindexed.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_commit.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_contiguous.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_create_pairtype.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_create_resized.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_debug.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_dup.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_get_contents.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_get_envelope.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_indexed.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_struct.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_vector.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpid_type_zerolen.lo
  CC       src/mpid/common/datatype/lib_libmpi_la-mpir_type_flatten.lo
  CC       src/mpid/common/sched/lib_libmpi_la-mpid_sched.lo
  CC       src/mpid/common/sock/poll/lib_libmpi_la-sock.lo
  CC       src/mpid/common/thread/lib_libmpi_la-mpid_thread.lo
  CC       src/nameserv/pmi/lib_libmpi_la-pmi_nameserv.lo
  CC       src/pmi/simple/lib_libmpi_la-simple_pmiutil.lo
  CC       src/pmi/simple/lib_libmpi_la-simple_pmi.lo
  MOD      src/binding/fortran/use_mpi/mpi_constants.mod-stamp
  MOD      src/binding/fortran/use_mpi/mpi_sizeofs.mod-stamp
  CXX      src/binding/cxx/initcxx.lo
  CC       src/env/mpichversion.o
  CC       src/env/mpivars.o
  GEN      lib/libmpi.la
  MOD      src/binding/fortran/use_mpi/mpi_base.mod-stamp
  MOD      src/binding/fortran/use_mpi/mpi.mod-stamp
  CXXLD    lib/libmpicxx.la
  GEN      lib/libmpifort.la
  CCLD     src/env/mpichversion
  CCLD     src/env/mpivars
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making all in examples
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
  CC       cpi.o
  CCLD     cpi
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'libtool: link: warning: `-version-info/-version-number' is ignored for convenience libraries
/usr/bin/make  install-recursive
make[1]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making install in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[3]: Nothing to be done for `install-exec-am'.
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making install in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making install in src
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[4]: Nothing to be done for `install-exec-am'.
 /bin/mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /usr/bin/install -c -m 644 opa_primitives.h opa_queue.h opa_util.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /bin/mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include/primitives'
 /usr/bin/install -c -m 644 opa_config.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/src'
Making install in test
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[4]: Nothing to be done for `install-data-am'.
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa/test'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
 /bin/mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
 /usr/bin/install -c -m 644 openpa.pc '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/openpa'
Making install in src/mpi/romio
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
 /usr/bin/install -c -m 644 include/mpio.h include/mpiof.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpi/romio'
Making install in src/pm/hydra
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making install in ../../mpl
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/mpl'
Making install in tools/topo/hwloc/hwloc
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
/usr/bin/make  install-exec-hook
make[6]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[6]: Nothing to be done for `install-exec-hook'.
make[6]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/src'
Making install in include
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra/tools/topo/hwloc/hwloc'
Making install in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
  /bin/bash ./libtool   --mode=install /usr/bin/install -c hydra_persist hydra_nameserver hydra_pmi_proxy mpiexec.hydra '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
libtool: install: /usr/bin/install -c hydra_persist /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/hydra_persist
libtool: install: /usr/bin/install -c hydra_nameserver /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/hydra_nameserver
libtool: install: /usr/bin/install -c hydra_pmi_proxy /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/hydra_pmi_proxy
libtool: install: /usr/bin/install -c mpiexec.hydra /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpiexec.hydra
make[5]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
if [ -x /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpiexec.hydra ] ; then \
	    cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpiexec.hydra mpiexec ; \
	    cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpiexec.hydra mpirun ; \
	fi
make[5]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/src/pm/hydra'
Making install in .
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib'
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   lib/libmpi.la lib/libmpifort.la lib/libmpicxx.la '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib'
libtool: install: /usr/bin/install -c lib/.libs/libmpi.so.12.0.4 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.so.12.0.4
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpi.so.12.0.4 libmpi.so.12 || { rm -f libmpi.so.12 && ln -s libmpi.so.12.0.4 libmpi.so.12; }; })
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpi.so.12.0.4 libmpi.so || { rm -f libmpi.so && ln -s libmpi.so.12.0.4 libmpi.so; }; })
libtool: install: /usr/bin/install -c lib/.libs/libmpi.lai /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.la
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3; /bin/bash /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/libtool  --silent --tag FC --mode=relink gfortran -Isrc/binding/fortran/use_mpi -Jsrc/binding/fortran/use_mpi -fPIC -ffree-line-length-0 -g -O0 -version-info 12:4:0 -o lib/libmpifort.la -rpath /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib src/binding/fortran/mpif_h/lib_libmpifort_la-sendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-recvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_countf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ssendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bufattachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bufdetachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-isendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ibsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-issendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-irsendf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-irecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-request_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitanyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testanyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-waitsomef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testsomef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iprobef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-probef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cancelf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-testcancelf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-send_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bsend_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ssend_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rsend_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-recv_initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-startf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-startallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-sendrecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-sndrcvrplf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecontigf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_vectorf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_hvectorf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_indexedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_hindexedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_structf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_extentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_lbf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_ubf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_commitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_elementsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-packf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-unpackf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-pack_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-barrierf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-bcastf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-gatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-gathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-scatterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-scattervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-allgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-allgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-exscanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-op_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-op_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-allreducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-redscatf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-scanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_rankf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grouptranksf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_comparef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_unionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-groupinterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-groupdifff.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_inclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_exclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grouprinclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grouprexclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-group_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_rankf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_comparef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_dup_with_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_splitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commtesticf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commrsizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commrgroupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iccreatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-icmergef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-attr_putf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-attr_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-attr_deletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-topo_testf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dims_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graph_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graphdims_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graph_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cartdim_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_rankf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_coordsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbcountf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-grfnbrsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_shiftf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_subf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-cart_mapf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-graph_mapf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-getpnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_versionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_library_versionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhcreatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhsetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhgetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-errhfreef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-error_stringf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-error_classf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-finalizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-initializedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-abortf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-close_portf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_acceptf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_connectf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commdiscf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commparentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_joinf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_spawnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-spawnmultf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-lookup_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-open_portf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-publish_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-unpubnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-accumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-putf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_completef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_fencef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_lockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_postf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_startf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_testf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_waitf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_allocate_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_shared_queryf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_create_dynamicf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_attachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_detachf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_accumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-fetch_and_opf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-compare_and_swapf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rputf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rgetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-raccumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-rget_accumulatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_lock_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_unlock_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flushf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_localf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_flush_local_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_syncf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-adderrclassf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-adderrcodef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-adderrstringf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commcallerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commnewkeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commdelattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commfreekeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_get_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commgetnamf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_set_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-filecallerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-greqcompletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-greqstartf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-isthrmainf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-query_threadf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-statgetclf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-statsetelf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typenewkeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typedelattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_dupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typefreekeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegetcntsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegetenvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typesetattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typesetnamef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_match_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wincallerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-winnewkeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-windelattrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-winfreekeyf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_get_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_attrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-win_set_namef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-alloc_memf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commcreerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commgeterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-commseterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-filecreerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-filegeterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-fileseterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-finalizedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-free_memf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_deletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_dupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_freef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_getf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-infognkf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-infognthkf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-infovallenf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-info_setf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-pack_externalf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-packesizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reqgetstatf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typedarrayf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typechindf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typechvecf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecindbf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_create_hindexed_blockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecresizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecstructf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typecsubarrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegetextentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-typegtextf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-unpackextf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wincreerrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wingeterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-winseterrf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_localf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-op_commutativef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-reduce_scatter_blockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_create_adjacentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighbors_countf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dist_graph_neighborsf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-improbef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-imrecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-mprobef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-mrecvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_idupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ibarrierf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ibcastf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-igatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-igathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iscatterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iscattervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iallgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iallgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ialltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ireducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iallreducef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatterf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ireduce_scatter_blockf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iscanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-iexscanf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_allgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-ineighbor_alltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgatherf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_allgathervf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallvf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-neighbor_alltoallwf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_split_typef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-get_elements_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-status_set_elements_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_extent_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_get_true_extent_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-type_size_xf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_create_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_ackf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_failure_get_ackedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_revokef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_shrinkf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-comm_agreef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_openf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_closef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_deletef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_preallocatef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_sizef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_groupf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_amodef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_infof.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_viewf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_viewf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_atf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_readf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_writef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_allf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_ireadf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwritef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_seekf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_positionf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_byte_offsetf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iread_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_iwrite_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_orderedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_orderedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_seek_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_position_sharedf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_at_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_at_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_all_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_read_ordered_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_beginf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_write_ordered_endf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_type_extentf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-register_datarepf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_set_atomicityf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_get_atomicityf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-file_syncf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-initf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-initthreadf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-pcontrolf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-addressf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-getaddressf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wtimef.lo src/binding/fortran/mpif_h/lib_libmpifort_la-wtickf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-keyval_createf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_copy_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_comm_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_comm_copy_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_win_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_win_copy_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-dup_type_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_del_fnf.lo src/binding/fortran/mpif_h/lib_libmpifort_la-null_type_copy_fnf.lo src/binding/fortran/use_mpi/lib_libmpifort_la-typef90cmplxf.lo src/binding/fortran/use_mpi/lib_libmpifort_la-typef90realf.lo src/binding/fortran/use_mpi/lib_libmpifort_la-typef90intf.lo src/binding/fortran/use_mpi/mpi.lo src/binding/fortran/use_mpi/mpi_constants.lo src/binding/fortran/use_mpi/mpi_sizeofs.lo src/binding/fortran/use_mpi/mpi_base.lo lib/libmpi.la -lpthread )
libtool: install: /usr/bin/install -c lib/.libs/libmpifort.so.12.0.4T /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.so.12.0.4
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpifort.so.12.0.4 libmpifort.so.12 || { rm -f libmpifort.so.12 && ln -s libmpifort.so.12.0.4 libmpifort.so.12; }; })
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpifort.so.12.0.4 libmpifort.so || { rm -f libmpifort.so && ln -s libmpifort.so.12.0.4 libmpifort.so; }; })
libtool: install: /usr/bin/install -c lib/.libs/libmpifort.lai /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.la
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3; /bin/bash /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/libtool  --silent --tag CXX --mode=relink g++ -g -fPIC -O0 -version-info 12:4:0 -o lib/libmpicxx.la -rpath /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib src/binding/cxx/initcxx.lo lib/libmpi.la -lpthread )
libtool: install: /usr/bin/install -c lib/.libs/libmpicxx.so.12.0.4T /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.so.12.0.4
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpicxx.so.12.0.4 libmpicxx.so.12 || { rm -f libmpicxx.so.12 && ln -s libmpicxx.so.12.0.4 libmpicxx.so.12; }; })
libtool: install: (cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && { ln -s -f libmpicxx.so.12.0.4 libmpicxx.so || { rm -f libmpicxx.so && ln -s libmpicxx.so.12.0.4 libmpicxx.so; }; })
libtool: install: /usr/bin/install -c lib/.libs/libmpicxx.lai /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.la
libtool: install: /usr/bin/install -c lib/.libs/libmpi.a /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.a
libtool: install: chmod 644 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.a
libtool: install: ranlib /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.a
libtool: install: /usr/bin/install -c lib/.libs/libmpifort.a /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.a
libtool: install: chmod 644 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.a
libtool: install: ranlib /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.a
libtool: install: /usr/bin/install -c lib/.libs/libmpicxx.a /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.a
libtool: install: chmod 644 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.a
libtool: install: ranlib /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.a
libtool: finish: PATH="/usr/lib/mutt:/home/tisaac/.local/bin:/usr/local/texlive/2015/bin/x86_64-linux:/home/tisaac/.bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/tisaac/.bin:/sbin" ldconfig -n /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
  /bin/bash ./libtool   --mode=install /usr/bin/install -c src/env/mpichversion src/env/mpivars '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
libtool: install: /usr/bin/install -c src/env/mpichversion /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpichversion
libtool: install: /usr/bin/install -c src/env/mpivars /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpivars
 /usr/bin/install -c src/env/mpicc src/env/parkill src/env/mpifort src/env/mpicxx '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin'
make[4]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
for e in /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx \
		/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif77 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpifort ; do \
		if test -e ${e} ; then \
			sed -e 's|__PREFIX_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich|g' \
				-e 's|__EXEC_PREFIX_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich|g' \
				-e 's|__SYSCONFDIR_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/etc|g' \
				-e 's|__INCLUDEDIR_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include|g' \
				-e 's|__LIBDIR_TO_BE_FILLED_AT_INSTALL_TIME__|/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib|g' ${e} > ${e}.tmp ; \
			/usr/bin/install -c ${e}.tmp ${e} ; \
			rm -f ${e}.tmp ; \
		fi ; \
	done ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpicxx mpic++ ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpifort ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpifort mpif90 ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpifort -a ! -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif77 ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin && ln -f -s mpifort mpif77 ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpi.so ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpi.so libmpl.so ; \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpi.so libopa.so ; \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpi.so libmpich.so ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpifort.so ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpifort.so libfmpich.so ; \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpifort.so libmpichf90.so ; fi ; \
	if test -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/libmpicxx.so ; then \
		cd /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib && ln -f -s libmpicxx.so libmpichcxx.so ; fi
make[4]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
/usr/bin/install -c -m 644 hydra_nameserver.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/hydra_nameserver.1
/usr/bin/install -c -m 644 hydra_persist.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/hydra_persist.1
/usr/bin/install -c -m 644 hydra_pmi_proxy.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/hydra_pmi_proxy.1
/usr/bin/install -c -m 644 mpicc.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpicc.1
/usr/bin/install -c -m 644 mpicxx.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpicxx.1
/usr/bin/install -c -m 644 mpiexec.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpiexec.1
/usr/bin/install -c -m 644 mpif77.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpif77.1
/usr/bin/install -c -m 644 mpifort.1 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man1/mpifort.1
/usr/bin/install -c -m 644 MPI_Abort.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Abort.3
/usr/bin/install -c -m 644 MPI_Accumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Accumulate.3
/usr/bin/install -c -m 644 MPI_Add_error_class.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Add_error_class.3
/usr/bin/install -c -m 644 MPI_Add_error_code.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Add_error_code.3
/usr/bin/install -c -m 644 MPI_Add_error_string.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Add_error_string.3
/usr/bin/install -c -m 644 MPI_Address.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Address.3
/usr/bin/install -c -m 644 MPI_Allgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Allgather.3
/usr/bin/install -c -m 644 MPI_Allgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Allgatherv.3
/usr/bin/install -c -m 644 MPI_Alloc_mem.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alloc_mem.3
/usr/bin/install -c -m 644 MPI_Allreduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Allreduce.3
/usr/bin/install -c -m 644 MPI_Alltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alltoall.3
/usr/bin/install -c -m 644 MPI_Alltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alltoallv.3
/usr/bin/install -c -m 644 MPI_Alltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Alltoallw.3
/usr/bin/install -c -m 644 MPI_Attr_delete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Attr_delete.3
/usr/bin/install -c -m 644 MPI_Attr_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Attr_get.3
/usr/bin/install -c -m 644 MPI_Attr_put.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Attr_put.3
/usr/bin/install -c -m 644 MPI_Barrier.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Barrier.3
/usr/bin/install -c -m 644 MPI_Bcast.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Bcast.3
/usr/bin/install -c -m 644 MPI_Bsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Bsend.3
/usr/bin/install -c -m 644 MPI_Bsend_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Bsend_init.3
/usr/bin/install -c -m 644 MPI_Buffer_attach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Buffer_attach.3
/usr/bin/install -c -m 644 MPI_Buffer_detach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Buffer_detach.3
/usr/bin/install -c -m 644 MPI_Cancel.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cancel.3
/usr/bin/install -c -m 644 MPI_Cart_coords.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_coords.3
/usr/bin/install -c -m 644 MPI_Cart_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_create.3
/usr/bin/install -c -m 644 MPI_Cartdim_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cartdim_get.3
/usr/bin/install -c -m 644 MPI_Cart_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_get.3
/usr/bin/install -c -m 644 MPI_Cart_map.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_map.3
/usr/bin/install -c -m 644 MPI_Cart_rank.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_rank.3
/usr/bin/install -c -m 644 MPI_Cart_shift.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_shift.3
/usr/bin/install -c -m 644 MPI_Cart_sub.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Cart_sub.3
/usr/bin/install -c -m 644 MPI_Close_port.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Close_port.3
/usr/bin/install -c -m 644 MPI_Comm_accept.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_accept.3
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_compare.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_compare.3
/usr/bin/install -c -m 644 MPI_Comm_connect.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_connect.3
/usr/bin/install -c -m 644 MPI_Comm_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create.3
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_create_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create_group.3
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_create_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_delete_attr.3
/usr/bin/install -c -m 644 MPI_Comm_disconnect.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_disconnect.3
/usr/bin/install -c -m 644 MPI_Comm_dup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_dup.3
/usr/bin/install -c -m 644 MPI_Comm_dup_with_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_dup_with_info.3
/usr/bin/install -c -m 644 MPI_Comm_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_free.3
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_free_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_get_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_attr.3
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_info.3
/usr/bin/install -c -m 644 MPI_Comm_get_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_name.3
/usr/bin/install -c -m 644 MPI_Comm_get_parent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_get_parent.3
/usr/bin/install -c -m 644 MPI_Comm_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_group.3
/usr/bin/install -c -m 644 MPI_Comm_idup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_idup.3
/usr/bin/install -c -m 644 MPI_Comm_join.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_join.3
/usr/bin/install -c -m 644 MPI_Comm_rank.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_rank.3
/usr/bin/install -c -m 644 MPI_Comm_remote_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_remote_group.3
/usr/bin/install -c -m 644 MPI_Comm_remote_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_remote_size.3
/usr/bin/install -c -m 644 MPI_Comm_set_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_attr.3
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_set_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_info.3
/usr/bin/install -c -m 644 MPI_Comm_set_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_set_name.3
/usr/bin/install -c -m 644 MPI_Comm_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_size.3
/usr/bin/install -c -m 644 MPI_Comm_spawn.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_spawn.3
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_spawn_multiple.3
/usr/bin/install -c -m 644 MPI_Comm_split.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_split.3
/usr/bin/install -c -m 644 MPI_Comm_split_type.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_split_type.3
/usr/bin/install -c -m 644 MPI_Comm_test_inter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Comm_test_inter.3
/usr/bin/install -c -m 644 MPI_Compare_and_swap.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Compare_and_swap.3
/usr/bin/install -c -m 644 MPI_Dims_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dims_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_create_adjacent.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Dist_graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Errhandler_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_create.3
/usr/bin/install -c -m 644 MPI_Errhandler_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_free.3
/usr/bin/install -c -m 644 MPI_Errhandler_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_get.3
/usr/bin/install -c -m 644 MPI_Errhandler_set.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Errhandler_set.3
/usr/bin/install -c -m 644 MPI_Error_class.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Error_class.3
/usr/bin/install -c -m 644 MPI_Error_string.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Error_string.3
/usr/bin/install -c -m 644 MPI_Exscan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Exscan.3
/usr/bin/install -c -m 644 MPI_Fetch_and_op.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Fetch_and_op.3
/usr/bin/install -c -m 644 MPI_File_c2f.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_c2f.3
/usr/bin/install -c -m 644 MPI_File_call_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_call_errhandler.3
/usr/bin/install -c -m 644 MPI_File_close.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_close.3
/usr/bin/install -c -m 644 MPI_File_create_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_create_errhandler.3
/usr/bin/install -c -m 644 MPI_File_delete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_delete.3
/usr/bin/install -c -m 644 MPI_File_f2c.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_f2c.3
/usr/bin/install -c -m 644 MPI_File_get_amode.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_amode.3
/usr/bin/install -c -m 644 MPI_File_get_atomicity.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_atomicity.3
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_byte_offset.3
/usr/bin/install -c -m 644 MPI_File_get_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_errhandler.3
/usr/bin/install -c -m 644 MPI_File_get_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_group.3
/usr/bin/install -c -m 644 MPI_File_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_info.3
/usr/bin/install -c -m 644 MPI_File_get_position.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_position.3
/usr/bin/install -c -m 644 MPI_File_get_position_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_position_shared.3
/usr/bin/install -c -m 644 MPI_File_get_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_size.3
/usr/bin/install -c -m 644 MPI_File_get_type_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_type_extent.3
/usr/bin/install -c -m 644 MPI_File_get_view.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_get_view.3
/usr/bin/install -c -m 644 MPI_File_iread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iread.3
/usr/bin/install -c -m 644 MPI_File_iread_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iread_at.3
/usr/bin/install -c -m 644 MPI_File_iread_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iread_shared.3
/usr/bin/install -c -m 644 MPI_File_iwrite.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iwrite.3
/usr/bin/install -c -m 644 MPI_File_iwrite_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iwrite_at.3
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_iwrite_shared.3
/usr/bin/install -c -m 644 MPI_File_open.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_open.3
/usr/bin/install -c -m 644 MPI_File_preallocate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_preallocate.3
/usr/bin/install -c -m 644 MPI_File_read.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read.3
/usr/bin/install -c -m 644 MPI_File_read_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_all.3
/usr/bin/install -c -m 644 MPI_File_read_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at.3
/usr/bin/install -c -m 644 MPI_File_read_at_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at_all.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_ordered.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_ordered.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_read_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_read_shared.3
/usr/bin/install -c -m 644 MPI_File_seek.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_seek.3
/usr/bin/install -c -m 644 MPI_File_seek_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_seek_shared.3
/usr/bin/install -c -m 644 MPI_File_set_atomicity.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_atomicity.3
/usr/bin/install -c -m 644 MPI_File_set_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_errhandler.3
/usr/bin/install -c -m 644 MPI_File_set_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_info.3
/usr/bin/install -c -m 644 MPI_File_set_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_size.3
/usr/bin/install -c -m 644 MPI_File_set_view.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_set_view.3
/usr/bin/install -c -m 644 MPI_File_sync.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_sync.3
/usr/bin/install -c -m 644 MPI_File_write.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write.3
/usr/bin/install -c -m 644 MPI_File_write_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_all.3
/usr/bin/install -c -m 644 MPI_File_write_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_at.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at.3
/usr/bin/install -c -m 644 MPI_File_write_at_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at_all.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_ordered.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_ordered.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_write_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_File_write_shared.3
/usr/bin/install -c -m 644 MPI_Finalize.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Finalize.3
/usr/bin/install -c -m 644 MPI_Finalized.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Finalized.3
/usr/bin/install -c -m 644 MPI_Free_mem.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Free_mem.3
/usr/bin/install -c -m 644 MPI_Gather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Gather.3
/usr/bin/install -c -m 644 MPI_Gatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Gatherv.3
/usr/bin/install -c -m 644 MPI_Get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get.3
/usr/bin/install -c -m 644 MPI_Get_accumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_accumulate.3
/usr/bin/install -c -m 644 MPI_Get_address.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_address.3
/usr/bin/install -c -m 644 MPI_Get_count.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_count.3
/usr/bin/install -c -m 644 MPI_Get_elements.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_elements.3
/usr/bin/install -c -m 644 MPI_Get_elements_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_elements_x.3
/usr/bin/install -c -m 644 MPI_Get_library_version.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_library_version.3
/usr/bin/install -c -m 644 MPI_Get_processor_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_processor_name.3
/usr/bin/install -c -m 644 MPI_Get_version.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Get_version.3
/usr/bin/install -c -m 644 MPI_Graph_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_create.3
/usr/bin/install -c -m 644 MPI_Graphdims_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graphdims_get.3
/usr/bin/install -c -m 644 MPI_Graph_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_get.3
/usr/bin/install -c -m 644 MPI_Graph_map.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_map.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Grequest_complete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Grequest_complete.3
/usr/bin/install -c -m 644 MPI_Grequest_start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Grequest_start.3
/usr/bin/install -c -m 644 MPI_Group_compare.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_compare.3
/usr/bin/install -c -m 644 MPI_Group_difference.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_difference.3
/usr/bin/install -c -m 644 MPI_Group_excl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_excl.3
/usr/bin/install -c -m 644 MPI_Group_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_free.3
/usr/bin/install -c -m 644 MPI_Group_incl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_incl.3
/usr/bin/install -c -m 644 MPI_Group_intersection.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_intersection.3
/usr/bin/install -c -m 644 MPI_Group_range_excl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_range_excl.3
/usr/bin/install -c -m 644 MPI_Group_range_incl.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_range_incl.3
/usr/bin/install -c -m 644 MPI_Group_rank.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_rank.3
/usr/bin/install -c -m 644 MPI_Group_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_size.3
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_translate_ranks.3
/usr/bin/install -c -m 644 MPI_Group_union.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Group_union.3
/usr/bin/install -c -m 644 MPI_Iallgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iallgather.3
/usr/bin/install -c -m 644 MPI_Iallgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iallgatherv.3
/usr/bin/install -c -m 644 MPI_Iallreduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iallreduce.3
/usr/bin/install -c -m 644 MPI_Ialltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ialltoall.3
/usr/bin/install -c -m 644 MPI_Ialltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ialltoallv.3
/usr/bin/install -c -m 644 MPI_Ialltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ialltoallw.3
/usr/bin/install -c -m 644 MPI_Ibarrier.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ibarrier.3
/usr/bin/install -c -m 644 MPI_Ibcast.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ibcast.3
/usr/bin/install -c -m 644 MPI_Ibsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ibsend.3
/usr/bin/install -c -m 644 MPI_Iexscan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iexscan.3
/usr/bin/install -c -m 644 MPI_Igather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Igather.3
/usr/bin/install -c -m 644 MPI_Igatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Igatherv.3
/usr/bin/install -c -m 644 MPI_Improbe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Improbe.3
/usr/bin/install -c -m 644 MPI_Imrecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Imrecv.3
/usr/bin/install -c -m 644 MPI_Ineighbor_allgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_allgather.3
/usr/bin/install -c -m 644 MPI_Ineighbor_allgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_allgatherv.3
/usr/bin/install -c -m 644 MPI_Ineighbor_alltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_alltoall.3
/usr/bin/install -c -m 644 MPI_Ineighbor_alltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_alltoallv.3
/usr/bin/install -c -m 644 MPI_Ineighbor_alltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ineighbor_alltoallw.3
/usr/bin/install -c -m 644 MPI_Info_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_create.3
/usr/bin/install -c -m 644 MPI_Info_delete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_delete.3
/usr/bin/install -c -m 644 MPI_Info_dup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_dup.3
/usr/bin/install -c -m 644 MPI_Info_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_free.3
/usr/bin/install -c -m 644 MPI_Info_get.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get.3
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get_nkeys.3
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get_nthkey.3
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_get_valuelen.3
/usr/bin/install -c -m 644 MPI_Info_set.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Info_set.3
/usr/bin/install -c -m 644 MPI_Init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Init.3
/usr/bin/install -c -m 644 MPI_Initialized.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Initialized.3
/usr/bin/install -c -m 644 MPI_Init_thread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Init_thread.3
/usr/bin/install -c -m 644 MPI_Intercomm_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Intercomm_create.3
/usr/bin/install -c -m 644 MPI_Intercomm_merge.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Intercomm_merge.3
/usr/bin/install -c -m 644 MPI_Iprobe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iprobe.3
/usr/bin/install -c -m 644 MPI_Irecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Irecv.3
/usr/bin/install -c -m 644 MPI_Ireduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ireduce.3
/usr/bin/install -c -m 644 MPI_Ireduce_scatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ireduce_scatter.3
/usr/bin/install -c -m 644 MPI_Ireduce_scatter_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ireduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Irsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Irsend.3
/usr/bin/install -c -m 644 MPI_Iscan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iscan.3
/usr/bin/install -c -m 644 MPI_Iscatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iscatter.3
/usr/bin/install -c -m 644 MPI_Iscatterv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Iscatterv.3
/usr/bin/install -c -m 644 MPI_Isend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Isend.3
/usr/bin/install -c -m 644 MPI_Issend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Issend.3
/usr/bin/install -c -m 644 MPI_Is_thread_main.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Is_thread_main.3
/usr/bin/install -c -m 644 MPI_Keyval_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Keyval_create.3
/usr/bin/install -c -m 644 MPI_Keyval_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Keyval_free.3
/usr/bin/install -c -m 644 MPI_Lookup_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Lookup_name.3
/usr/bin/install -c -m 644 MPI_Mprobe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Mprobe.3
/usr/bin/install -c -m 644 MPI_Mrecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Mrecv.3
/usr/bin/install -c -m 644 MPI_Neighbor_allgather.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_allgather.3
/usr/bin/install -c -m 644 MPI_Neighbor_allgatherv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_allgatherv.3
/usr/bin/install -c -m 644 MPI_Neighbor_alltoall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_alltoall.3
/usr/bin/install -c -m 644 MPI_Neighbor_alltoallv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_alltoallv.3
/usr/bin/install -c -m 644 MPI_Neighbor_alltoallw.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Neighbor_alltoallw.3
/usr/bin/install -c -m 644 MPI_Op_commute.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Op_commute.3
/usr/bin/install -c -m 644 MPI_Op_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Op_create.3
/usr/bin/install -c -m 644 MPI_Open_port.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Open_port.3
/usr/bin/install -c -m 644 MPI_Op_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Op_free.3
/usr/bin/install -c -m 644 MPI_Pack.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack.3
/usr/bin/install -c -m 644 MPI_Pack_external.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack_external.3
/usr/bin/install -c -m 644 MPI_Pack_external_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack_external_size.3
/usr/bin/install -c -m 644 MPI_Pack_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pack_size.3
/usr/bin/install -c -m 644 MPI_Pcontrol.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Pcontrol.3
/usr/bin/install -c -m 644 MPI_Probe.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Probe.3
/usr/bin/install -c -m 644 MPI_Publish_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Publish_name.3
/usr/bin/install -c -m 644 MPI_Put.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Put.3
/usr/bin/install -c -m 644 MPI_Query_thread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Query_thread.3
/usr/bin/install -c -m 644 MPI_Raccumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Raccumulate.3
/usr/bin/install -c -m 644 MPI_Recv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Recv.3
/usr/bin/install -c -m 644 MPI_Recv_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Recv_init.3
/usr/bin/install -c -m 644 MPI_Reduce.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce.3
/usr/bin/install -c -m 644 MPI_Reduce_local.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce_local.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce_scatter.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Reduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Register_datarep.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Register_datarep.3
/usr/bin/install -c -m 644 MPI_Request_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Request_free.3
/usr/bin/install -c -m 644 MPI_Request_get_status.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Request_get_status.3
/usr/bin/install -c -m 644 MPI_Rget.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rget.3
/usr/bin/install -c -m 644 MPI_Rget_accumulate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rget_accumulate.3
/usr/bin/install -c -m 644 MPI_Rput.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rput.3
/usr/bin/install -c -m 644 MPI_Rsend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rsend.3
/usr/bin/install -c -m 644 MPI_Rsend_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Rsend_init.3
/usr/bin/install -c -m 644 MPI_Scan.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Scan.3
/usr/bin/install -c -m 644 MPI_Scatter.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Scatter.3
/usr/bin/install -c -m 644 MPI_Scatterv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Scatterv.3
/usr/bin/install -c -m 644 MPI_Send.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Send.3
/usr/bin/install -c -m 644 MPI_Send_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Send_init.3
/usr/bin/install -c -m 644 MPI_Sendrecv.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Sendrecv.3
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Sendrecv_replace.3
/usr/bin/install -c -m 644 MPI_Ssend.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ssend.3
/usr/bin/install -c -m 644 MPI_Ssend_init.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Ssend_init.3
/usr/bin/install -c -m 644 MPI_Start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Start.3
/usr/bin/install -c -m 644 MPI_Startall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Startall.3
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Status_set_cancelled.3
/usr/bin/install -c -m 644 MPI_Status_set_elements.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Status_set_elements.3
/usr/bin/install -c -m 644 MPI_Status_set_elements_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Status_set_elements_x.3
/usr/bin/install -c -m 644 MPI_T_category_changed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_changed.3
/usr/bin/install -c -m 644 MPI_T_category_get_categories.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_categories.3
/usr/bin/install -c -m 644 MPI_T_category_get_cvars.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_cvars.3
/usr/bin/install -c -m 644 MPI_T_category_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_info.3
/usr/bin/install -c -m 644 MPI_T_category_get_num.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_num.3
/usr/bin/install -c -m 644 MPI_T_category_get_pvars.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_category_get_pvars.3
/usr/bin/install -c -m 644 MPI_T_cvar_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_get_info.3
/usr/bin/install -c -m 644 MPI_T_cvar_get_num.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_get_num.3
/usr/bin/install -c -m 644 MPI_T_cvar_handle_alloc.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_handle_alloc.3
/usr/bin/install -c -m 644 MPI_T_cvar_handle_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_handle_free.3
/usr/bin/install -c -m 644 MPI_T_cvar_read.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_read.3
/usr/bin/install -c -m 644 MPI_T_cvar_write.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_cvar_write.3
/usr/bin/install -c -m 644 MPI_T_enum_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_enum_get_info.3
/usr/bin/install -c -m 644 MPI_T_enum_get_item.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_enum_get_item.3
/usr/bin/install -c -m 644 MPI_Test.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Test.3
/usr/bin/install -c -m 644 MPI_Testall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Testall.3
/usr/bin/install -c -m 644 MPI_Testany.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Testany.3
/usr/bin/install -c -m 644 MPI_Test_cancelled.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Test_cancelled.3
/usr/bin/install -c -m 644 MPI_Testsome.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Testsome.3
/usr/bin/install -c -m 644 MPI_T_finalize.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_finalize.3
/usr/bin/install -c -m 644 MPI_T_init_thread.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_init_thread.3
/usr/bin/install -c -m 644 MPI_Topo_test.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Topo_test.3
/usr/bin/install -c -m 644 MPI_T_pvar_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_get_info.3
/usr/bin/install -c -m 644 MPI_T_pvar_get_num.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_get_num.3
/usr/bin/install -c -m 644 MPI_T_pvar_handle_alloc.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_handle_alloc.3
/usr/bin/install -c -m 644 MPI_T_pvar_handle_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_handle_free.3
/usr/bin/install -c -m 644 MPI_T_pvar_read.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_read.3
/usr/bin/install -c -m 644 MPI_T_pvar_readreset.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_readreset.3
/usr/bin/install -c -m 644 MPI_T_pvar_reset.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_reset.3
/usr/bin/install -c -m 644 MPI_T_pvar_session_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_session_create.3
/usr/bin/install -c -m 644 MPI_T_pvar_session_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_session_free.3
/usr/bin/install -c -m 644 MPI_T_pvar_start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_start.3
/usr/bin/install -c -m 644 MPI_T_pvar_stop.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_stop.3
/usr/bin/install -c -m 644 MPI_T_pvar_write.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_T_pvar_write.3
/usr/bin/install -c -m 644 MPI_Type_commit.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_commit.3
/usr/bin/install -c -m 644 MPI_Type_contiguous.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_contiguous.3
/usr/bin/install -c -m 644 MPI_Type_create_darray.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_darray.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_hindexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_hvector.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_hvector.3
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_indexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_keyval.3
/usr/bin/install -c -m 644 MPI_Type_create_resized.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_resized.3
/usr/bin/install -c -m 644 MPI_Type_create_struct.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_struct.3
/usr/bin/install -c -m 644 MPI_Type_create_subarray.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_create_subarray.3
/usr/bin/install -c -m 644 MPI_Type_delete_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_delete_attr.3
/usr/bin/install -c -m 644 MPI_Type_dup.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_dup.3
/usr/bin/install -c -m 644 MPI_Type_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_extent.3
/usr/bin/install -c -m 644 MPI_Type_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_free.3
/usr/bin/install -c -m 644 MPI_Type_free_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_free_keyval.3
/usr/bin/install -c -m 644 MPI_Type_get_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_attr.3
/usr/bin/install -c -m 644 MPI_Type_get_contents.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_contents.3
/usr/bin/install -c -m 644 MPI_Type_get_envelope.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_envelope.3
/usr/bin/install -c -m 644 MPI_Type_get_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_extent_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_extent_x.3
/usr/bin/install -c -m 644 MPI_Type_get_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_name.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_true_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_get_true_extent_x.3
/usr/bin/install -c -m 644 MPI_Type_hindexed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_hvector.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_hvector.3
/usr/bin/install -c -m 644 MPI_Type_indexed.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_indexed.3
/usr/bin/install -c -m 644 MPI_Type_lb.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_lb.3
/usr/bin/install -c -m 644 MPI_Type_match_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_match_size.3
/usr/bin/install -c -m 644 MPI_Type_set_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_set_attr.3
/usr/bin/install -c -m 644 MPI_Type_set_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_set_name.3
/usr/bin/install -c -m 644 MPI_Type_size.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_size.3
/usr/bin/install -c -m 644 MPI_Type_size_x.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_size_x.3
/usr/bin/install -c -m 644 MPI_Type_struct.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_struct.3
/usr/bin/install -c -m 644 MPI_Type_ub.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_ub.3
/usr/bin/install -c -m 644 MPI_Type_vector.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Type_vector.3
/usr/bin/install -c -m 644 MPI_Unpack.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Unpack.3
/usr/bin/install -c -m 644 MPI_Unpack_external.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Unpack_external.3
/usr/bin/install -c -m 644 MPI_Unpublish_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Unpublish_name.3
/usr/bin/install -c -m 644 MPI_Wait.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Wait.3
/usr/bin/install -c -m 644 MPI_Waitall.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Waitall.3
/usr/bin/install -c -m 644 MPI_Waitany.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Waitany.3
/usr/bin/install -c -m 644 MPI_Waitsome.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Waitsome.3
/usr/bin/install -c -m 644 MPI_Win_allocate.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_allocate.3
/usr/bin/install -c -m 644 MPI_Win_allocate_shared.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_allocate_shared.3
/usr/bin/install -c -m 644 MPI_Win_attach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_attach.3
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_complete.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_complete.3
/usr/bin/install -c -m 644 MPI_Win_create.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create.3
/usr/bin/install -c -m 644 MPI_Win_create_dynamic.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create_dynamic.3
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_create_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_create_keyval.3
/usr/bin/install -c -m 644 MPI_Win_delete_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_delete_attr.3
/usr/bin/install -c -m 644 MPI_Win_detach.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_detach.3
/usr/bin/install -c -m 644 MPI_Win_fence.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_fence.3
/usr/bin/install -c -m 644 MPI_Win_flush.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush.3
/usr/bin/install -c -m 644 MPI_Win_flush_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush_all.3
/usr/bin/install -c -m 644 MPI_Win_flush_local.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush_local.3
/usr/bin/install -c -m 644 MPI_Win_flush_local_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_flush_local_all.3
/usr/bin/install -c -m 644 MPI_Win_free.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_free.3
/usr/bin/install -c -m 644 MPI_Win_free_keyval.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_free_keyval.3
/usr/bin/install -c -m 644 MPI_Win_get_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_attr.3
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_get_group.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_group.3
/usr/bin/install -c -m 644 MPI_Win_get_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_info.3
/usr/bin/install -c -m 644 MPI_Win_get_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_get_name.3
/usr/bin/install -c -m 644 MPI_Win_lock.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_lock.3
/usr/bin/install -c -m 644 MPI_Win_lock_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_lock_all.3
/usr/bin/install -c -m 644 MPI_Win_post.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_post.3
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_attr.3
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_set_info.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_info.3
/usr/bin/install -c -m 644 MPI_Win_set_name.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_set_name.3
/usr/bin/install -c -m 644 MPI_Win_shared_query.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_shared_query.3
/usr/bin/install -c -m 644 MPI_Win_start.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_start.3
/usr/bin/install -c -m 644 MPI_Win_sync.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_sync.3
/usr/bin/install -c -m 644 MPI_Win_test.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_test.3
/usr/bin/install -c -m 644 MPI_Win_unlock.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_unlock.3
/usr/bin/install -c -m 644 MPI_Win_unlock_all.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_unlock_all.3
/usr/bin/install -c -m 644 MPI_Win_wait.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Win_wait.3
/usr/bin/install -c -m 644 MPI_Wtick.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Wtick.3
/usr/bin/install -c -m 644 MPI_Wtime.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPI_Wtime.3
/usr/bin/install -c -m 644 MPIX_Comm_agree.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_agree.3
/usr/bin/install -c -m 644 MPIX_Comm_failure_ack.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_failure_ack.3
/usr/bin/install -c -m 644 MPIX_Comm_failure_get_acked.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_failure_get_acked.3
/usr/bin/install -c -m 644 MPIX_Comm_revoke.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_revoke.3
/usr/bin/install -c -m 644 MPIX_Comm_shrink.3 /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/man/man3/MPIX_Comm_shrink.3
if [ ! -e /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich ] ; then mkdir -p /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644 ./doc/userguide/user.pdf /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich/user.pdf ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644 ./doc/installguide/install.pdf /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich/install.pdf ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644 ./doc/logging/logging.pdf /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/share/doc/mpich/logging.pdf ; fi
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /usr/bin/install -c -m 644 src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 /usr/bin/install -c -m 644 src/binding/cxx/mpicxx.h src/binding/fortran/mpif_h/mpif.h src/include/mpi.h '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include'
 mkdir -p '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
 /usr/bin/install -c -m 644 src/packaging/pkgconfig/mpich.pc '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib/pkgconfig'
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'
Making install in examples
make[2]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[3]: Entering directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[2]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3/examples'
make[1]: Leaving directory `/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/externalpackages/mpich-3.1.3'libtool: install: warning: relinking `lib/libmpifort.la'
libtool: install: warning: relinking `lib/libmpicxx.la'
********End of Output of running make on MPICH *******
                          Deleting "CC"
                          Deleting "CXX"
                          Deleting "FC"
TEST printEnvVariables from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1600)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1600)
                              **** printenv ****
TODO_FILE=/home/tisaac/todo/todo.txt
MAKEN=8
LD_LIBRARY_PATH=/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib
WORK=/home/tisaac/work
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
BROWSER=firefox
XDG_CURRENT_DESKTOP=GNOME
DONE_FILE=/home/tisaac/todo/done.txt
LOGNAME=tisaac
USER=tisaac
PATH=/usr/lib/mutt:/home/tisaac/.local/bin:/usr/local/texlive/2015/bin/x86_64-linux:/home/tisaac/.bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/tisaac/.bin
CCGOLOCAL=/home/tisaac/ccgo
GNOME_KEYRING_CONTROL=/tmp/keyring-984kz1
DISPLAY=:0
vcs_info_msg_0_=%{%}?%{%}%{%}?%{(B%}%{%}master=
SSH_AGENT_PID=2524
LANG=en_US.UTF-8
MPICH_DBG_FILENAME=dbg-%w-%d.log
TERM=xterm-256color
SHELL=/usr/bin/zsh
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
XDG_SESSION_COOKIE=0bb413799794f59deebb04d900000003-1478788580.738106-107490020
SESSION_MANAGER=local/alembic:@/tmp/.ICE-unix/2478,unix/alembic:/tmp/.ICE-unix/2478
XDG_DATA_DIRS=/usr/share/gnome-xmonad:/usr/share/gnome:/usr/local/share/:/usr/share/
MANDATORY_PATH=/usr/share/gconf/gnome-xmonad.mandatory.path
PETSC_ARCH=arch-linux2-c-debug-mpich
MPICH_DBG_LEVEL=verbose
T8_ARCH=arch-debug
WINDOWID=48235846
PETSC_DIR=/home/tisaac/Projects/petsc
EDITOR=vim
DESKTOP_AUTOSTART_ID=1083d73533c5ccf823147878858097140900000024780037
PETSC_OPTIONS=-malloc_test
OMPI_CC=clang
GPG_AGENT_INFO=/tmp/keyring-984kz1/gpg:0:1
HOME=/home/tisaac
TODO_ACTIONS_DIR=/home/tisaac/.todo.actions.d
REPORT_FILE=/home/tisaac/todo/report.txt
TODOTXT_DEFAULT_ACTION=ls
TODO_DIR=/home/tisaac/todo
EXEC=/home/tisaac/exec
PYTHONPATH=/home/tisaac/.local/lib/python2.7/site-packages
SSH_AUTH_SOCK=/tmp/keyring-984kz1/ssh
FULLHOST=alembic
XENVIRONMENT=/home/tisaac/.Xresources
GDMSESSION=gnome-xmonad
BUILD=/home/tisaac/build
GNOME_KEYRING_PID=2467
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
COLORFGBG=default;default;0
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-Pwy2k05FP3,guid=0f6504b3754592c949b131dc0000001c
_=/home/tisaac/Projects/petsc/./reconfigure-arch-linux2-c-debug-mpich.py
XAUTHORITY=/home/tisaac/.Xauthority
CCGOREPO=https://svn.ices.utexas.edu/repos/ccgo
DESKTOP_SESSION=gnome-xmonad
GTAGSLIBPATH=/home/tisaac/Projects/petsc
XDG_CONFIG_DIRS=/etc/xdg/xdg-gnome-xmonad:/etc/xdg
DEFAULTS_PATH=/usr/share/gconf/gnome-xmonad.default.path
UBUNTU_MENUPROXY=libappmenu.so
SCRATCH=/home/tisaac/scratch
OLDPWD=/home/tisaac/Projects/petsc/src/sys/examples/tutorials
MPICH_DBG_CLASS=all
SHLVL=1
COLORTERM=rxvt-xpm
vcs_info_msg_1_=
OMPI_CXX=clang++
TEST resetEnvCompilers from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1607)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1607)
TEST checkEnvCompilers from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1637)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1637)
TEST checkMPICompilerOverride from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1572)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1572)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1591)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1591)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:417)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:417)
  Determine the compiler vendor
                              Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:427)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:427)
  Initialize the compiler and linker flags
                                Pushing language C
                              Initialized CFLAGS to
                              Initialized LDFLAGS to
                                Popping language C
                                Pushing language CUDA
                              Initialized CUDAFLAGS to
                                Popping language CUDA
                                Pushing language Cxx
                              Initialized CXXFLAGS to
                              Initialized CXX_CXXFLAGS to
                                Popping language Cxx
                                Pushing language FC
                              Initialized FFLAGS to
                                Popping language FC
                              Initialized CPPFLAGS to
                              Initialized CUDAPPFLAGS to
                              Initialized CXXCPPFLAGS to
                              Initialized CC_LINKER_FLAGS to []
                              Initialized CXX_LINKER_FLAGS to []
                              Initialized FC_LINKER_FLAGS to []
                              Initialized CUDAC_LINKER_FLAGS to []
                              Initialized sharedLibraryFlags to []
                              Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:553)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:553)
  Locate a functional C compiler
Checking for program /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc...found
                                  Defined make macro "CC" to "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc"
                                  Pushing language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.setCompilers   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                          Pushing language C
                                          Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
                                          Pushing language C
                                          Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: ld returned 1 exit status
Successful compile:
Source:
int main() {
  return 0;
                                              Pushing language C
                                              Popping language C
Testing executable /tmp/petsc-W4It8W/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.setCompilers/conftest
                                  Popping language C
TEST checkCPreprocessor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:586)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:586)
  Locate a functional C preprocessor
                                  Defined make macro "CPP" to "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -E"
                                Pushing language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -E  -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.setCompilers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.setCompilers/conftest.c"
# 1 "/home/tisaac/Projects/petsc//"
# 1 "<built-in>"
#define __STDC__ 1
#define __STDC_HOSTED__ 1
#define __GNUC__ 4
#define __GNUC_MINOR__ 6
#define __GNUC_PATCHLEVEL__ 4
#define __VERSION__ "4.6.4"
#define __pic__ 2
#define __PIC__ 2
#define __FINITE_MATH_ONLY__ 0
#define _LP64 1
#define __LP64__ 1
#define __SIZEOF_INT__ 4
#define __SIZEOF_LONG__ 8
#define __SIZEOF_LONG_LONG__ 8
#define __SIZEOF_SHORT__ 2
#define __SIZEOF_FLOAT__ 4
#define __SIZEOF_DOUBLE__ 8
#define __SIZEOF_LONG_DOUBLE__ 16
#define __SIZEOF_SIZE_T__ 8
#define __CHAR_BIT__ 8
#define __BIGGEST_ALIGNMENT__ 16
#define __ORDER_LITTLE_ENDIAN__ 1234
#define __ORDER_BIG_ENDIAN__ 4321
#define __ORDER_PDP_ENDIAN__ 3412
#define __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__
#define __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__
#define __SIZEOF_POINTER__ 8
#define __SIZE_TYPE__ long unsigned int
#define __PTRDIFF_TYPE__ long int
#define __WCHAR_TYPE__ int
#define __WINT_TYPE__ unsigned int
#define __INTMAX_TYPE__ long int
#define __UINTMAX_TYPE__ long unsigned int
#define __CHAR16_TYPE__ short unsigned int
#define __CHAR32_TYPE__ unsigned int
#define __SIG_ATOMIC_TYPE__ int
#define __INT8_TYPE__ signed char
#define __INT16_TYPE__ short int
#define __INT32_TYPE__ int
#define __INT64_TYPE__ long int
#define __UINT8_TYPE__ unsigned char
#define __UINT16_TYPE__ short unsigned int
#define __UINT32_TYPE__ unsigned int
#define __UINT64_TYPE__ long unsigned int
#define __INT_LEAST8_TYPE__ signed char
#define __INT_LEAST16_TYPE__ short int
#define __INT_LEAST32_TYPE__ int
#define __INT_LEAST64_TYPE__ long int
#define __UINT_LEAST8_TYPE__ unsigned char
#define __UINT_LEAST16_TYPE__ short unsigned int
#define __UINT_LEAST32_TYPE__ unsigned int
#define __UINT_LEAST64_TYPE__ long unsigned int
#define __INT_FAST8_TYPE__ signed char
#define __INT_FAST16_TYPE__ long int
#define __INT_FAST32_TYPE__ long int
#define __INT_FAST64_TYPE__ long int
#define __UINT_FAST8_TYPE__ unsigned char
#define __UINT_FAST16_TYPE__ long unsigned int
#define __UINT_FAST32_TYPE__ long unsigned int
#define __UINT_FAST64_TYPE__ long unsigned int
#define __INTPTR_TYPE__ long int
#define __UINTPTR_TYPE__ long unsigned int
#define __GXX_ABI_VERSION 1002
#define __SCHAR_MAX__ 127
#define __SHRT_MAX__ 32767
#define __INT_MAX__ 2147483647
#define __LONG_MAX__ 9223372036854775807L
#define __LONG_LONG_MAX__ 9223372036854775807LL
#define __WCHAR_MAX__ 2147483647
#define __WCHAR_MIN__ (-__WCHAR_MAX__ - 1)
#define __WINT_MAX__ 4294967295U
#define __WINT_MIN__ 0U
#define __PTRDIFF_MAX__ 9223372036854775807L
#define __SIZE_MAX__ 18446744073709551615UL
#define __INTMAX_MAX__ 9223372036854775807L
#define __INTMAX_C(c) c ## L
#define __UINTMAX_MAX__ 18446744073709551615UL
#define __UINTMAX_C(c) c ## UL
#define __SIG_ATOMIC_MAX__ 2147483647
#define __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1)
#define __INT8_MAX__ 127
#define __INT16_MAX__ 32767
#define __INT32_MAX__ 2147483647
#define __INT64_MAX__ 9223372036854775807L
#define __UINT8_MAX__ 255
#define __UINT16_MAX__ 65535
#define __UINT32_MAX__ 4294967295U
#define __UINT64_MAX__ 18446744073709551615UL
#define __INT_LEAST8_MAX__ 127
#define __INT8_C(c) c
#define __INT_LEAST16_MAX__ 32767
#define __INT16_C(c) c
#define __INT_LEAST32_MAX__ 2147483647
#define __INT32_C(c) c
#define __INT_LEAST64_MAX__ 9223372036854775807L
#define __INT64_C(c) c ## L
#define __UINT_LEAST8_MAX__ 255
#define __UINT8_C(c) c
#define __UINT_LEAST16_MAX__ 65535
#define __UINT16_C(c) c
#define __UINT_LEAST32_MAX__ 4294967295U
#define __UINT32_C(c) c ## U
#define __UINT_LEAST64_MAX__ 18446744073709551615UL
#define __UINT64_C(c) c ## UL
#define __INT_FAST8_MAX__ 127
#define __INT_FAST16_MAX__ 9223372036854775807L
#define __INT_FAST32_MAX__ 9223372036854775807L
#define __INT_FAST64_MAX__ 9223372036854775807L
#define __UINT_FAST8_MAX__ 255
#define __UINT_FAST16_MAX__ 18446744073709551615UL
#define __UINT_FAST32_MAX__ 18446744073709551615UL
#define __UINT_FAST64_MAX__ 18446744073709551615UL
#define __INTPTR_MAX__ 9223372036854775807L
#define __UINTPTR_MAX__ 18446744073709551615UL
#define __FLT_EVAL_METHOD__ 0
#define __DEC_EVAL_METHOD__ 2
#define __FLT_RADIX__ 2
#define __FLT_MANT_DIG__ 24
#define __FLT_DIG__ 6
#define __FLT_MIN_EXP__ (-125)
#define __FLT_MIN_10_EXP__ (-37)
#define __FLT_MAX_EXP__ 128
#define __FLT_MAX_10_EXP__ 38
#define __FLT_DECIMAL_DIG__ 9
#define __FLT_MAX__ 3.40282346638528859812e+38F
#define __FLT_MIN__ 1.17549435082228750797e-38F
#define __FLT_EPSILON__ 1.19209289550781250000e-7F
#define __FLT_DENORM_MIN__ 1.40129846432481707092e-45F
#define __FLT_HAS_DENORM__ 1
#define __FLT_HAS_INFINITY__ 1
#define __FLT_HAS_QUIET_NAN__ 1
#define __DBL_MANT_DIG__ 53
#define __DBL_DIG__ 15
#define __DBL_MIN_EXP__ (-1021)
#define __DBL_MIN_10_EXP__ (-307)
#define __DBL_MAX_EXP__ 1024
#define __DBL_MAX_10_EXP__ 308
#define __DBL_DECIMAL_DIG__ 17
#define __DBL_MAX__ ((double)1.79769313486231570815e+308L)
#define __DBL_MIN__ ((double)2.22507385850720138309e-308L)
#define __DBL_EPSILON__ ((double)2.22044604925031308085e-16L)
#define __DBL_DENORM_MIN__ ((double)4.94065645841246544177e-324L)
#define __DBL_HAS_DENORM__ 1
#define __DBL_HAS_INFINITY__ 1
#define __DBL_HAS_QUIET_NAN__ 1
#define __LDBL_MANT_DIG__ 64
#define __LDBL_DIG__ 18
#define __LDBL_MIN_EXP__ (-16381)
#define __LDBL_MIN_10_EXP__ (-4931)
#define __LDBL_MAX_EXP__ 16384
#define __LDBL_MAX_10_EXP__ 4932
#define __DECIMAL_DIG__ 21
#define __LDBL_MAX__ 1.18973149535723176502e+4932L
#define __LDBL_MIN__ 3.36210314311209350626e-4932L
#define __LDBL_EPSILON__ 1.08420217248550443401e-19L
#define __LDBL_DENORM_MIN__ 3.64519953188247460253e-4951L
#define __LDBL_HAS_DENORM__ 1
#define __LDBL_HAS_INFINITY__ 1
#define __LDBL_HAS_QUIET_NAN__ 1
#define __DEC32_MANT_DIG__ 7
#define __DEC32_MIN_EXP__ (-94)
#define __DEC32_MAX_EXP__ 97
#define __DEC32_MIN__ 1E-95DF
#define __DEC32_MAX__ 9.999999E96DF
#define __DEC32_EPSILON__ 1E-6DF
#define __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF
#define __DEC64_MANT_DIG__ 16
#define __DEC64_MIN_EXP__ (-382)
#define __DEC64_MAX_EXP__ 385
#define __DEC64_MIN__ 1E-383DD
#define __DEC64_MAX__ 9.999999999999999E384DD
#define __DEC64_EPSILON__ 1E-15DD
#define __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD
#define __DEC128_MANT_DIG__ 34
#define __DEC128_MIN_EXP__ (-6142)
#define __DEC128_MAX_EXP__ 6145
#define __DEC128_MIN__ 1E-6143DL
#define __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL
#define __DEC128_EPSILON__ 1E-33DL
#define __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL
#define __REGISTER_PREFIX__
#define __USER_LABEL_PREFIX__
#define _FORTIFY_SOURCE 2
#define __GNUC_GNU_INLINE__ 1
#define __NO_INLINE__ 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1
#define __GCC_HAVE_DWARF2_CFI_ASM 1
#define __PRAGMA_REDEFINE_EXTNAME 1
#define __SSP__ 1
#define __SIZEOF_INT128__ 16
#define __SIZEOF_WCHAR_T__ 4
#define __SIZEOF_WINT_T__ 4
#define __SIZEOF_PTRDIFF_T__ 8
#define __amd64 1
#define __amd64__ 1
#define __x86_64 1
#define __x86_64__ 1
#define __k8 1
#define __k8__ 1
#define __MMX__ 1
#define __SSE__ 1
#define __SSE2__ 1
#define __SSE_MATH__ 1
#define __SSE2_MATH__ 1
#define __gnu_linux__ 1
#define __linux 1
#define __linux__ 1
#define linux 1
#define __unix 1
#define __unix__ 1
#define unix 1
#define __ELF__ 1
#define __DECIMAL_BID_FORMAT__ 1
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.setCompilers/confdefs.h" 1
#define INCLUDED_CONFDEFS_H
#define IS_COLORING_MAX 65535
#define STDC_HEADERS 1
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#define PETSC_HAVE_GZIP 1
#define PETSC_HAVE_STRING_H 1
#define PETSC_HAVE_SYS_TYPES_H 1
#define PETSC_HAVE_ENDIAN_H 1
#define PETSC_HAVE_SYS_PROCFS_H 1
#define PETSC_HAVE_DLFCN_H 1
#define PETSC_HAVE_SCHED_H 1
#define PETSC_HAVE_STDINT_H 1
#define PETSC_HAVE_LINUX_KERNEL_H 1
#define PETSC_HAVE_TIME_H 1
#define PETSC_HAVE_MATH_H 1
#define PETSC_HAVE_INTTYPES_H 1
#define PETSC_TIME_WITH_SYS_TIME 1
#define PETSC_HAVE_SYS_PARAM_H 1
#define PETSC_HAVE_PTHREAD_H 1
#define PETSC_HAVE_UNISTD_H 1
#define PETSC_HAVE_STDLIB_H 1
#define PETSC_HAVE_SYS_WAIT_H 1
#define PETSC_HAVE_SETJMP_H 1
#define PETSC_HAVE_LIMITS_H 1
#define PETSC_HAVE_SYS_UTSNAME_H 1
#define PETSC_HAVE_NETINET_IN_H 1
#define PETSC_HAVE_SYS_SOCKET_H 1
#define PETSC_HAVE_FLOAT_H 1
#define PETSC_HAVE_SEARCH_H 1
#define PETSC_HAVE_SYS_RESOURCE_H 1
#define PETSC_HAVE_SYS_TIMES_H 1
#define PETSC_HAVE_NETDB_H 1
#define PETSC_HAVE_MALLOC_H 1
#define PETSC_HAVE_PWD_H 1
#define PETSC_HAVE_FCNTL_H 1
#define PETSC_HAVE_STRINGS_H 1
#define PETSC_HAVE_SYS_SYSINFO_H 1
#define PETSC_HAVE_SYS_TIME_H 1
#define PETSC_USING_F90 1
#define PETSC_USING_F2003 1
#define PETSC_HAVE_RTLD_NOW 1
#define PETSC_HAVE_RTLD_LOCAL 1
#define PETSC_HAVE_RTLD_LAZY 1
#define PETSC_C_STATIC_INLINE static inline
#define PETSC_USING_F90FREEFORM 1
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#define PETSC_HAVE_CXX_NAMESPACE 1
#define PETSC_HAVE_RTLD_GLOBAL 1
#define PETSC_C_RESTRICT __restrict__
#define PETSC_CXX_RESTRICT __restrict__
#define PETSC_CXX_STATIC_INLINE static inline
#define PETSC_HAVE_LIBZ 1
#define PETSC_HAVE_LIBDL 1
#define PETSC_HAVE_LIBM 1
#define PETSC_HAVE_FENV_H 1
#define PETSC_HAVE_LOG2 1
#define PETSC_HAVE_ERF 1
#define PETSC_HAVE_TGAMMA 1
#define PETSC_HAVE_LIBRT 1
#define PETSC_ARCH "arch-linux2-c-debug-mpich"
#define PETSC_USE_SCALAR_REAL 1
#define PETSC_HAVE_ISINF 1
#define PETSC_HAVE_ISNAN 1
#define PETSC_USE_REAL_DOUBLE 1
#define PETSC_BITS_PER_BYTE 8
#define PETSC_USE_VISIBILITY_C 1
#define PETSC_SIZEOF_VOID_P 8
#define PETSC_RETSIGTYPE void
#define PETSC_HAVE_CXX_COMPLEX 1
#define PETSC_SIZEOF_LONG 8
#define PETSC_USE_FORTRANKIND 1
#define PETSC_USE_VISIBILITY_CXX 1
#define PETSC_SIZEOF_SIZE_T 8
#define PETSC_HAVE_SIGINFO_T 1
#define PETSC_SIZEOF_CHAR 1
#define PETSC_SIZEOF_DOUBLE 8
#define PETSC_SIZEOF_FLOAT 4
#define PETSC_HAVE_C99_COMPLEX 1
#define PETSC_SIZEOF_INT 4
#define PETSC_SIZEOF_LONG_LONG 8
#define PETSC_SIZEOF_SHORT 2
#define PETSC_CLANGUAGE_C 1
#define PETSC_USE_ERRORCHECKING 1
#define PETSC_HAVE_STRCASECMP 1
#define PETSC_HAVE_GET_NPROCS 1
#define PETSC_HAVE_POPEN 1
#define PETSC_HAVE_SIGSET 1
#define PETSC_HAVE_GETWD 1
#define PETSC_HAVE_VSNPRINTF 1
#define PETSC_HAVE_TIMES 1
#define PETSC_HAVE_DLSYM 1
#define PETSC_HAVE_SNPRINTF 1
#define PETSC_HAVE_GETHOSTBYNAME 1
#define PETSC_HAVE_GETCWD 1
#define PETSC_HAVE_DLERROR 1
#define PETSC_HAVE_FORK 1
#define PETSC_HAVE_RAND 1
#define PETSC_HAVE_GETTIMEOFDAY 1
#define PETSC_HAVE_DLCLOSE 1
#define PETSC_HAVE_UNAME 1
#define PETSC_HAVE_GETHOSTNAME 1
#define PETSC_HAVE_MKSTEMP 1
#define PETSC_HAVE_SIGACTION 1
#define PETSC_HAVE_DRAND48 1
#define PETSC_HAVE_MEMALIGN 1
#define PETSC_HAVE_VA_COPY 1
#define PETSC_HAVE_CLOCK 1
#define PETSC_HAVE_ACCESS 1
#define PETSC_HAVE_SIGNAL 1
#define PETSC_HAVE_USLEEP 1
#define PETSC_HAVE_GETRUSAGE 1
#define PETSC_HAVE_VFPRINTF 1
#define PETSC_HAVE_NANOSLEEP 1
#define PETSC_HAVE_GETDOMAINNAME 1
#define PETSC_HAVE_TIME 1
#define PETSC_HAVE_LSEEK 1
#define PETSC_HAVE_SOCKET 1
#define PETSC_HAVE_SYSINFO 1
#define PETSC_HAVE_READLINK 1
#define PETSC_HAVE_REALPATH 1
#define PETSC_HAVE_DLOPEN 1
#define PETSC_HAVE_MEMMOVE 1
#define PETSC_HAVE__GFORTRAN_IARGC 1
#define PETSC_HAVE_GETPAGESIZE 1
#define PETSC_HAVE_SLEEP 1
#define PETSC_HAVE_VPRINTF 1
#define PETSC_HAVE_BZERO 1
#define PETSC_SIGNAL_CAST
#define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
#define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
#define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
#define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#define PETSC_HAVE_SHARED_LIBRARIES 1
#define PETSC_USE_SHARED_LIBRARIES 1
#define PETSC_USE_GDB_DEBUGGER 1
#define PETSC_VERSION_DATE_GIT "2016-11-10 08:59:24 -0600"
#define PETSC_VERSION_BRANCH_GIT "master"
#define PETSC_VERSION_GIT "v3.7.4-1922-geb30558"
#define PETSC_USE_INFO 1
#define PETSC_Alignx(a,b)
#define PETSC_USE_BACKWARD_LOOP 1
#define PETSC_USE_DEBUG 1
#define PETSC_USE_LOG 1
#define PETSC_IS_COLOR_VALUE_TYPE_F integer2
#define PETSC_IS_COLOR_VALUE_TYPE short
#define PETSC_USE_CTABLE 1
#define PETSC_USE_FORTRAN_INTERFACES 1
#define PETSC_MEMALIGN 16
#define PETSC__GNU_SOURCE 1
#define PETSC__BSD_SOURCE 1
#define PETSC__DEFAULT_SOURCE 1
#define PETSC_USE_PROC_FOR_SIZE 1
#define PETSC_LEVEL1_DCACHE_LINESIZE 64
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#define PETSC_LEVEL1_DCACHE_ASSOC 8
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#define PETSC_HAVE_GFORTRAN_IARGC 1
# 2 "/tmp/petsc-W4It8W/config.setCompilers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.setCompilers/conffix.h" 1
#define INCLUDED_CONFFIX_H
# 3 "/tmp/petsc-W4It8W/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 25 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 21 "/usr/include/features.h" 3 4
#define _FEATURES_H 1
# 98 "/usr/include/features.h" 3 4
#undef __USE_ISOC99
#undef __USE_ISOC95
#undef __USE_POSIX
#undef __USE_POSIX2
#undef __USE_POSIX199309
#undef __USE_POSIX199506
#undef __USE_XOPEN
#undef __USE_XOPEN_EXTENDED
#undef __USE_UNIX98
#undef __USE_XOPEN2K
#undef __USE_XOPEN2KXSI
#undef __USE_XOPEN2K8
#undef __USE_XOPEN2K8XSI
#undef __USE_LARGEFILE
#undef __USE_LARGEFILE64
#undef __USE_FILE_OFFSET64
#undef __USE_BSD
#undef __USE_SVID
#undef __USE_MISC
#undef __USE_ATFILE
#undef __USE_GNU
#undef __USE_REENTRANT
#undef __USE_FORTIFY_LEVEL
#undef __FAVOR_BSD
#undef __KERNEL_STRICT_NAMES
#define __KERNEL_STRICT_NAMES
#define __USE_ANSI 1
# 141 "/usr/include/features.h" 3 4
#define __GNUC_PREREQ(maj,min) ((__GNUC__ << 16) + __GNUC_MINOR__ >= ((maj) << 16) + (min))
# 184 "/usr/include/features.h" 3 4
#define _BSD_SOURCE 1
#define _SVID_SOURCE 1
# 207 "/usr/include/features.h" 3 4
#define _POSIX_SOURCE 1
#define _POSIX_C_SOURCE 200809L
#define __USE_POSIX_IMPLICITLY 1
#define __USE_POSIX 1
#define __USE_POSIX2 1
#define __USE_POSIX199309 1
#define __USE_POSIX199506 1
#define __USE_XOPEN2K 1
#undef __USE_ISOC95
#define __USE_ISOC95 1
#undef __USE_ISOC99
#define __USE_ISOC99 1
#define __USE_XOPEN2K8 1
#undef _ATFILE_SOURCE
#define _ATFILE_SOURCE 1
# 289 "/usr/include/features.h" 3 4
#define __USE_MISC 1
#define __USE_BSD 1
#define __USE_SVID 1
#define __USE_ATFILE 1
# 320 "/usr/include/features.h" 3 4
#define __USE_FORTIFY_LEVEL 0
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 3 4
#define _PREDEFS_H
#define __STDC_IEC_559__ 1
#define __STDC_IEC_559_COMPLEX__ 1
# 325 "/usr/include/features.h" 2 3 4
#define __STDC_ISO_10646__ 200009L
#undef __GNU_LIBRARY__
#define __GNU_LIBRARY__ 6
#define __GLIBC__ 2
#define __GLIBC_MINOR__ 15
#define __GLIBC_PREREQ(maj,min) ((__GLIBC__ << 16) + __GLIBC_MINOR__ >= ((maj) << 16) + (min))
#define __GLIBC_HAVE_LONG_LONG 1
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 21 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define _SYS_CDEFS_H 1
# 36 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#undef __P
#undef __PMT
#define __LEAF , __leaf__
#define __LEAF_ATTR __attribute__ ((__leaf__))
# 57 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __THROW __attribute__ ((__nothrow__ __LEAF))
#define __THROWNL __attribute__ ((__nothrow__))
#define __NTH(fct) __attribute__ ((__nothrow__ __LEAF)) fct
# 88 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __P(args) args
#define __PMT(args) args
#define __CONCAT(x,y) x ## y
#define __STRING(x) #x
#define __ptr_t void *
#define __long_double_t long double
#define __BEGIN_DECLS
#define __END_DECLS
# 128 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __BEGIN_NAMESPACE_STD
#define __END_NAMESPACE_STD
#define __USING_NAMESPACE_STD(name)
#define __BEGIN_NAMESPACE_C99
#define __END_NAMESPACE_C99
#define __USING_NAMESPACE_C99(name)
#define __bounded
#define __unbounded
#define __ptrvalue
#define __bos(ptr) __builtin_object_size (ptr, __USE_FORTIFY_LEVEL > 1)
#define __bos0(ptr) __builtin_object_size (ptr, 0)
#define __warndecl(name,msg) extern void name (void) __attribute__((__warning__ (msg)))
#define __warnattr(msg) __attribute__((__warning__ (msg)))
#define __errordecl(name,msg) extern void name (void) __attribute__((__error__ (msg)))
# 164 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __flexarr []
# 191 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __REDIRECT(name,proto,alias) name proto __asm__ (__ASMNAME (#alias))
#define __REDIRECT_NTH(name,proto,alias) name proto __asm__ (__ASMNAME (#alias)) __THROW
#define __REDIRECT_NTHNL(name,proto,alias) name proto __asm__ (__ASMNAME (#alias)) __THROWNL
#define __ASMNAME(cname) __ASMNAME2 (__USER_LABEL_PREFIX__, cname)
#define __ASMNAME2(prefix,cname) __STRING (prefix) cname
# 225 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_malloc__ __attribute__ ((__malloc__))
# 234 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_pure__ __attribute__ ((__pure__))
#define __attribute_const__ __attribute__ ((__const__))
# 250 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_used__ __attribute__ ((__used__))
#define __attribute_noinline__ __attribute__ ((__noinline__))
#define __attribute_deprecated__ __attribute__ ((__deprecated__))
# 271 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_format_arg__(x) __attribute__ ((__format_arg__ (x)))
# 281 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_format_strfmon__(a,b) __attribute__ ((__format__ (__strfmon__, a, b)))
# 290 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __nonnull(params) __attribute__ ((__nonnull__ params))
#define __attribute_warn_unused_result__ __attribute__ ((__warn_unused_result__))
# 307 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __wur
#define __always_inline __inline __attribute__ ((__always_inline__))
# 330 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __extern_inline extern __inline
#define __extern_always_inline extern __always_inline __attribute__ ((__artificial__))
# 343 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __va_arg_pack() __builtin_va_arg_pack ()
#define __va_arg_pack_len() __builtin_va_arg_pack_len ()
# 364 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __restrict_arr __restrict
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
#define __WORDSIZE 64
#define __WORDSIZE_COMPAT32 1
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 400 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __LDBL_REDIR1(name,proto,alias) name proto
#define __LDBL_REDIR(name,proto) name proto
#define __LDBL_REDIR1_NTH(name,proto,alias) name proto __THROW
#define __LDBL_REDIR_NTH(name,proto) name proto __THROW
#define __LDBL_REDIR_DECL(name)
#define __REDIRECT_LDBL(name,proto,alias) __REDIRECT (name, proto, alias)
#define __REDIRECT_NTH_LDBL(name,proto,alias) __REDIRECT_NTH (name, proto, alias)
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 3 4
#define __stub_bdflush
#define __stub_chflags
#define __stub_fattach
#define __stub_fchflags
#define __stub_fdetach
#define __stub_getmsg
#define __stub_gtty
#define __stub_lchmod
#define __stub_putmsg
#define __stub_revoke
#define __stub_setlogin
#define __stub_sigreturn
#define __stub_sstk
#define __stub_stty
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/stdlib.h" 2 3 4
#define __need_size_t
#define __need_wchar_t
#define __need_NULL
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
# 187 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#define __size_t__
#define __SIZE_T__
#define _SIZE_T
#define _SYS_SIZE_T_H
#define _T_SIZE_
#define _T_SIZE
#define __SIZE_T
#define _SIZE_T_
#define _BSD_SIZE_T_
#define _SIZE_T_DEFINED_
#define _BSD_SIZE_T_DEFINED_
#define _SIZE_T_DECLARED
#define ___int_size_t_h
#define _GCC_SIZE_T
#define _SIZET_
#define __size_t
typedef long unsigned int size_t;
# 234 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#undef __need_size_t
# 263 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#define __wchar_t__
#define __WCHAR_T__
#define _WCHAR_T
#define _T_WCHAR_
#define _T_WCHAR
#define __WCHAR_T
#define _WCHAR_T_
#define _BSD_WCHAR_T_
#define _WCHAR_T_DEFINED_
#define _WCHAR_T_H
#define ___int_wchar_t_h
#define __INT_WCHAR_T_H
#define _GCC_WCHAR_T
#define _WCHAR_T_DECLARED
# 290 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#undef _BSD_WCHAR_T_
# 324 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
typedef int wchar_t;
# 343 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#undef __need_wchar_t
# 397 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#undef NULL
#define NULL ((void *)0)
#undef __need_NULL
# 34 "/usr/include/stdlib.h" 2 3 4
#define _STDLIB_H 1
# 1 "/usr/include/x86_64-linux-gnu/bits/waitflags.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/waitflags.h" 3 4
#define WNOHANG 1
#define WUNTRACED 2
#define WSTOPPED 2
#define WEXITED 4
#define WCONTINUED 8
#define WNOWAIT 0x01000000
#define __WNOTHREAD 0x20000000
#define __WALL 0x40000000
#define __WCLONE 0x80000000
# 43 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 1 3 4
# 29 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 3 4
#define __WEXITSTATUS(status) (((status) & 0xff00) >> 8)
#define __WTERMSIG(status) ((status) & 0x7f)
#define __WSTOPSIG(status) __WEXITSTATUS(status)
#define __WIFEXITED(status) (__WTERMSIG(status) == 0)
#define __WIFSIGNALED(status) (((signed char) (((status) & 0x7f) + 1) >> 1) > 0)
#define __WIFSTOPPED(status) (((status) & 0xff) == 0x7f)
#define __WIFCONTINUED(status) ((status) == __W_CONTINUED)
#define __WCOREDUMP(status) ((status) & __WCOREFLAG)
#define __W_EXITCODE(ret,sig) ((ret) << 8 | (sig))
#define __W_STOPCODE(sig) ((sig) << 8 | 0x7f)
#define __W_CONTINUED 0xffff
#define __WCOREFLAG 0x80
# 1 "/usr/include/endian.h" 1 3 4
# 20 "/usr/include/endian.h" 3 4
#define _ENDIAN_H 1
# 32 "/usr/include/endian.h" 3 4
#define __LITTLE_ENDIAN 1234
#define __BIG_ENDIAN 4321
#define __PDP_ENDIAN 3412
# 1 "/usr/include/x86_64-linux-gnu/bits/endian.h" 1 3 4
#define __BYTE_ORDER __LITTLE_ENDIAN
# 38 "/usr/include/endian.h" 2 3 4
#define __FLOAT_WORD_ORDER __BYTE_ORDER
#define LITTLE_ENDIAN __LITTLE_ENDIAN
#define BIG_ENDIAN __BIG_ENDIAN
#define PDP_ENDIAN __PDP_ENDIAN
#define BYTE_ORDER __BYTE_ORDER
#define __LONG_LONG_PAIR(HI,LO) LO, HI
# 1 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
#define _BITS_BYTESWAP_H 1
# 29 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 2 3 4
#define __bswap_constant_16(x) ((unsigned short int) ((((x) >> 8) & 0xff) | (((x) & 0xff) << 8)))
#define __bswap_16(x) (__extension__ ({ register unsigned short int __v, __x = (unsigned short int) (x); if (__builtin_constant_p (__x)) __v = __bswap_constant_16 (__x); else __asm__ ("rorw $8, %w0" : "=r" (__v) : "0" (__x) : "cc"); __v; }))
# 56 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
#define __bswap_constant_32(x) ((((x) & 0xff000000) >> 24) | (((x) & 0x00ff0000) >> 8) | (((x) & 0x0000ff00) << 8) | (((x) & 0x000000ff) << 24))
# 69 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
#define __bswap_32(x) (__extension__ ({ register unsigned int __v, __x = (x); if (__builtin_constant_p (__x)) __v = __bswap_constant_32 (__x); else __asm__ ("bswap %0" : "=r" (__v) : "0" (__x)); __v; }))
# 101 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
#define __bswap_constant_64(x) (__extension__ ((((x) & 0xff00000000000000ull) >> 56) | (((x) & 0x00ff000000000000ull) >> 40) | (((x) & 0x0000ff0000000000ull) >> 24) | (((x) & 0x000000ff00000000ull) >> 8) | (((x) & 0x00000000ff000000ull) << 8) | (((x) & 0x0000000000ff0000ull) << 24) | (((x) & 0x000000000000ff00ull) << 40) | (((x) & 0x00000000000000ffull) << 56)))
# 112 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
#define __bswap_64(x) (__extension__ ({ register unsigned long __v, __x = (x); if (__builtin_constant_p (__x)) __v = __bswap_constant_64 (__x); else __asm__ ("bswap %q0" : "=r" (__v) : "0" (__x)); __v; }))
# 62 "/usr/include/endian.h" 2 3 4
#define htobe16(x) __bswap_16 (x)
#define htole16(x) (x)
#define be16toh(x) __bswap_16 (x)
#define le16toh(x) (x)
#define htobe32(x) __bswap_32 (x)
#define htole32(x) (x)
#define be32toh(x) __bswap_32 (x)
#define le32toh(x) (x)
#define htobe64(x) __bswap_64 (x)
#define htole64(x) (x)
#define be64toh(x) __bswap_64 (x)
#define le64toh(x) (x)
# 66 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
#define w_termsig __wait_terminated.__w_termsig
#define w_coredump __wait_terminated.__w_coredump
#define w_retcode __wait_terminated.__w_retcode
#define w_stopsig __wait_stopped.__w_stopsig
#define w_stopval __wait_stopped.__w_stopval
# 44 "/usr/include/stdlib.h" 2 3 4
#define __WAIT_INT(status) (__extension__ (((union { __typeof(status) __in; int __i; }) { .__in = (status) }).__i))
# 68 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
#define __WAIT_STATUS_DEFN int *
# 85 "/usr/include/stdlib.h" 3 4
#define WEXITSTATUS(status) __WEXITSTATUS (__WAIT_INT (status))
#define WTERMSIG(status) __WTERMSIG (__WAIT_INT (status))
#define WSTOPSIG(status) __WSTOPSIG (__WAIT_INT (status))
#define WIFEXITED(status) __WIFEXITED (__WAIT_INT (status))
#define WIFSIGNALED(status) __WIFSIGNALED (__WAIT_INT (status))
#define WIFSTOPPED(status) __WIFSTOPPED (__WAIT_INT (status))
#define WIFCONTINUED(status) __WIFCONTINUED (__WAIT_INT (status))
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
#define __ldiv_t_defined 1
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
#define __lldiv_t_defined 1
#define RAND_MAX 2147483647
#define EXIT_FAILURE 1
#define EXIT_SUCCESS 0
#define MB_CUR_MAX (__ctype_get_mb_cur_max ())
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (__const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (__const char *__nptr)
extern long int atol (__const char *__nptr)
__extension__ extern long long int atoll (__const char *__nptr)
extern double strtod (__const char *__restrict __nptr,
        char **__restrict __endptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern float strtof (__const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern long double strtold (__const char *__restrict __nptr,
extern long int strtol (__const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (__const char *__restrict __nptr,
__extension__
extern long long int strtoq (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (__const char *__restrict __nptr,
__extension__
extern long long int strtoll (__const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (__const char *__restrict __nptr,
# 311 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (__const char *__s)
# 1 "/usr/include/x86_64-linux-gnu/sys/types.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
#define _SYS_TYPES_H 1
# 1 "/usr/include/x86_64-linux-gnu/bits/types.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
#define _BITS_TYPES_H 1
# 29 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 99 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
#define __S16_TYPE short int
#define __U16_TYPE unsigned short int
#define __S32_TYPE int
#define __U32_TYPE unsigned int
#define __SLONGWORD_TYPE long int
#define __ULONGWORD_TYPE unsigned long int
# 118 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
#define __SQUAD_TYPE long int
#define __UQUAD_TYPE unsigned long int
#define __SWORD_TYPE long int
#define __UWORD_TYPE unsigned long int
#define __SLONG32_TYPE int
#define __ULONG32_TYPE unsigned int
#define __S64_TYPE long int
#define __U64_TYPE unsigned long int
#define __STD_TYPE typedef
# 1 "/usr/include/x86_64-linux-gnu/bits/typesizes.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/bits/typesizes.h" 3 4
#define _BITS_TYPESIZES_H 1
#define __DEV_T_TYPE __UQUAD_TYPE
#define __UID_T_TYPE __U32_TYPE
#define __GID_T_TYPE __U32_TYPE
#define __INO_T_TYPE __ULONGWORD_TYPE
#define __INO64_T_TYPE __UQUAD_TYPE
#define __MODE_T_TYPE __U32_TYPE
#define __NLINK_T_TYPE __UWORD_TYPE
#define __OFF_T_TYPE __SLONGWORD_TYPE
#define __OFF64_T_TYPE __SQUAD_TYPE
#define __PID_T_TYPE __S32_TYPE
#define __RLIM_T_TYPE __ULONGWORD_TYPE
#define __RLIM64_T_TYPE __UQUAD_TYPE
#define __BLKCNT_T_TYPE __SLONGWORD_TYPE
#define __BLKCNT64_T_TYPE __SQUAD_TYPE
#define __FSBLKCNT_T_TYPE __ULONGWORD_TYPE
#define __FSBLKCNT64_T_TYPE __UQUAD_TYPE
#define __FSFILCNT_T_TYPE __ULONGWORD_TYPE
#define __FSFILCNT64_T_TYPE __UQUAD_TYPE
#define __ID_T_TYPE __U32_TYPE
#define __CLOCK_T_TYPE __SLONGWORD_TYPE
#define __TIME_T_TYPE __SLONGWORD_TYPE
#define __USECONDS_T_TYPE __U32_TYPE
#define __SUSECONDS_T_TYPE __SLONGWORD_TYPE
#define __DADDR_T_TYPE __S32_TYPE
#define __SWBLK_T_TYPE __SLONGWORD_TYPE
#define __KEY_T_TYPE __S32_TYPE
#define __CLOCKID_T_TYPE __S32_TYPE
#define __TIMER_T_TYPE void *
#define __BLKSIZE_T_TYPE __SLONGWORD_TYPE
#define __FSID_T_TYPE struct { int __val[2]; }
#define __SSIZE_T_TYPE __SWORD_TYPE
#define __FD_SETSIZE 1024
# 132 "/usr/include/x86_64-linux-gnu/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#undef __STD_TYPE
# 31 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
#define __u_char_defined
typedef __loff_t loff_t;
typedef __ino_t ino_t;
#define __ino_t_defined
typedef __dev_t dev_t;
#define __dev_t_defined
typedef __gid_t gid_t;
#define __gid_t_defined
typedef __mode_t mode_t;
#define __mode_t_defined
typedef __nlink_t nlink_t;
#define __nlink_t_defined
typedef __uid_t uid_t;
#define __uid_t_defined
typedef __off_t off_t;
#define __off_t_defined
typedef __pid_t pid_t;
#define __pid_t_defined
typedef __id_t id_t;
#define __id_t_defined
typedef __ssize_t ssize_t;
#define __ssize_t_defined
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
#define __daddr_t_defined
typedef __key_t key_t;
#define __key_t_defined
#define __need_clock_t
#define __need_time_t
#define __need_timer_t
#define __need_clockid_t
# 1 "/usr/include/time.h" 1 3 4
# 54 "/usr/include/time.h" 3 4
#define __clock_t_defined 1
typedef __clock_t clock_t;
#undef __need_clock_t
#define __time_t_defined 1
typedef __time_t time_t;
#undef __need_time_t
#define __clockid_t_defined 1
typedef __clockid_t clockid_t;
#undef __clockid_time_t
#define __timer_t_defined 1
typedef __timer_t timer_t;
#undef __need_timer_t
# 127 "/usr/include/time.h" 3 4
#undef __need_timespec
# 134 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 146 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 408 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#undef __need_NULL
# 148 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 188 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
#define __intN_t(N,MODE) typedef int int ##N ##_t __attribute__ ((__mode__ (MODE)))
#define __u_intN_t(N,MODE) typedef unsigned int u_int ##N ##_t __attribute__ ((__mode__ (MODE)))
#define __int8_t_defined
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
#define __BIT_TYPES_DEFINED__ 1
# 1 "/usr/include/x86_64-linux-gnu/sys/select.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
#define _SYS_SELECT_H 1
# 1 "/usr/include/x86_64-linux-gnu/bits/select.h" 1 3 4
# 23 "/usr/include/x86_64-linux-gnu/bits/select.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/select.h" 2 3 4
#define __FD_ZERO_STOS "stosq"
#define __FD_ZERO(fdsp) do { int __d0, __d1; __asm__ __volatile__ ("cld; rep; " __FD_ZERO_STOS : "=c" (__d0), "=D" (__d1) : "a" (0), "0" (sizeof (fd_set) / sizeof (__fd_mask)), "1" (&__FDS_BITS (fdsp)[0]) : "memory"); } while (0)
# 59 "/usr/include/x86_64-linux-gnu/bits/select.h" 3 4
#define __FD_SET(d,set) ((void) (__FDS_BITS (set)[__FD_ELT (d)] |= __FD_MASK (d)))
#define __FD_CLR(d,set) ((void) (__FDS_BITS (set)[__FD_ELT (d)] &= ~__FD_MASK (d)))
#define __FD_ISSET(d,set) ((__FDS_BITS (set)[__FD_ELT (d)] & __FD_MASK (d)) != 0)
# 32 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 1 3 4
# 22 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
#define _SIGSET_H_types 1
typedef int __sig_atomic_t;
#define _SIGSET_NWORDS (1024 / (8 * sizeof (unsigned long int)))
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 35 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
#define __sigset_t_defined
typedef __sigset_t sigset_t;
#define __need_timespec
# 67 "/usr/include/time.h" 3 4
# 83 "/usr/include/time.h" 3 4
# 95 "/usr/include/time.h" 3 4
# 107 "/usr/include/time.h" 3 4
#define __timespec_defined 1
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 45 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
#define __need_timeval
# 1 "/usr/include/x86_64-linux-gnu/bits/time.h" 1 3 4
# 26 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
#define _STRUCT_TIMEVAL 1
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 99 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
#undef __need_timeval
# 47 "/usr/include/x86_64-linux-gnu/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
#define __suseconds_t_defined
typedef long int __fd_mask;
#undef __NFDBITS
#define __NFDBITS (8 * (int) sizeof (__fd_mask))
#define __FD_ELT(d) ((d) / __NFDBITS)
#define __FD_MASK(d) ((__fd_mask) 1 << ((d) % __NFDBITS))
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
#define __FDS_BITS(set) ((set)->__fds_bits)
  } fd_set;
#define FD_SETSIZE __FD_SETSIZE
typedef __fd_mask fd_mask;
#define NFDBITS __NFDBITS
#define FD_SET(fd,fdsetp) __FD_SET (fd, fdsetp)
#define FD_CLR(fd,fdsetp) __FD_CLR (fd, fdsetp)
#define FD_ISSET(fd,fdsetp) __FD_ISSET (fd, fdsetp)
#define FD_ZERO(fdsetp) __FD_ZERO (fdsetp)
# 107 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 119 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 132 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 221 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 1 3 4
# 22 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
#define _SYS_SYSMACROS_H 1
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 64 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
#define major(dev) gnu_dev_major (dev)
#define minor(dev) gnu_dev_minor (dev)
#define makedev(maj,min) gnu_dev_makedev (maj, min)
# 224 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
#define __blksize_t_defined
typedef __blkcnt_t blkcnt_t;
#define __blkcnt_t_defined
typedef __fsblkcnt_t fsblkcnt_t;
#define __fsblkcnt_t_defined
typedef __fsfilcnt_t fsfilcnt_t;
#define __fsfilcnt_t_defined
# 271 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
#define _BITS_PTHREADTYPES_H 1
# 24 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 2 3 4
#define __SIZEOF_PTHREAD_ATTR_T 56
#define __SIZEOF_PTHREAD_MUTEX_T 40
#define __SIZEOF_PTHREAD_MUTEXATTR_T 4
#define __SIZEOF_PTHREAD_COND_T 48
#define __SIZEOF_PTHREAD_CONDATTR_T 4
#define __SIZEOF_PTHREAD_RWLOCK_T 56
#define __SIZEOF_PTHREAD_RWLOCKATTR_T 8
#define __SIZEOF_PTHREAD_BARRIER_T 32
#define __SIZEOF_PTHREAD_BARRIERATTR_T 4
# 50 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 76 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    int __spins;
    __pthread_list_t __list;
#define __PTHREAD_MUTEX_HAVE_PREV 1
# 101 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    unsigned long int __pad1;
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 187 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 272 "/usr/include/x86_64-linux-gnu/sys/types.h" 2 3 4
# 321 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
#define __malloc_and_calloc_defined
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 20 "/usr/include/alloca.h" 3 4
#define _ALLOCA_H 1
#undef __need_NULL
# 26 "/usr/include/alloca.h" 2 3 4
#undef alloca
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
#define alloca(size) __builtin_alloca (size)
# 498 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 531 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
# 554 "/usr/include/stdlib.h" 3 4
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *__secure_getenv (__const char *__name)
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (__const char *__name, __const char *__value, int __replace)
extern int unsetenv (__const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 620 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 642 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 663 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 712 "/usr/include/stdlib.h" 3 4
extern int system (__const char *__command) ;
# 734 "/usr/include/stdlib.h" 3 4
extern char *realpath (__const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
#define __COMPAR_FN_T
typedef int (*__compar_fn_t) (__const void *, __const void *);
# 752 "/usr/include/stdlib.h" 3 4
extern void *bsearch (__const void *__key, __const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 771 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 808 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (__const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int mbtowc (wchar_t *__restrict __pwc,
     __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__)) ;
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
   __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern size_t wcstombs (char *__restrict __s,
   __const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (__const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 896 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *__const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 948 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 962 "/usr/include/stdlib.h" 3 4
#undef __need_malloc_and_calloc
Preprocess stderr before filtering::
Preprocess stderr after filtering::
                                Popping language C
TEST checkCUDACompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:627)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:627)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:667)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:667)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:779)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:779)
  Locate a functional Cxx compiler
Checking for program /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx...found
                                  Defined make macro "CXX" to "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx"
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.missing     /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                          Pushing language CXX
                                          Popping language CXX
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
TEST checkCxxPreprocessor from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:817)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:817)
  Locate a functional Cxx preprocessor
                                  Defined make macro "CXXCPP" to "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -E"
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -E  -I/tmp/petsc-W4It8W/config.setCompilers   /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
stdout:
# 1 "/tmp/petsc-W4It8W/config.setCompilers/conftest.cc"
# 1 "<built-in>"
# 2 "/tmp/petsc-W4It8W/config.setCompilers/conftest.cc" 2
extern "C" {
# 3 "/tmp/petsc-W4It8W/config.setCompilers/conftest.cc" 2
# 1 "/usr/include/c++/4.6/cstdlib" 1 3
# 41 "/usr/include/c++/4.6/cstdlib" 3
# 42 "/usr/include/c++/4.6/cstdlib" 3
# 1 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 1 3
# 153 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 3
namespace std
  typedef long int ptrdiff_t;
# 393 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 3
# 1 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/os_defines.h" 1 3
# 40 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/os_defines.h" 3
# 324 "/usr/include/features.h" 3 4
# 357 "/usr/include/features.h" 3 4
# 41 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/os_defines.h" 2 3
# 394 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 2 3
# 1 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/cpu_defines.h" 1 3
# 397 "/usr/include/c++/4.6/x86_64-linux-gnu/./bits/c++config.h" 2 3
# 44 "/usr/include/c++/4.6/cstdlib" 2 3
# 66 "/usr/include/c++/4.6/cstdlib" 3
# 33 "/usr/include/stdlib.h" 3 4
# 212 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
extern "C" {
# 65 "/usr/include/x86_64-linux-gnu/bits/waitstatus.h" 3 4
# 37 "/usr/include/endian.h" 3 4
# 61 "/usr/include/endian.h" 3 4
# 28 "/usr/include/x86_64-linux-gnu/bits/byteswap.h" 3 4
union wait
    int w_status;
    struct
 unsigned int:16;
    struct
 unsigned int:16;
      } __wait_stopped;
# 96 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
    long long int quot;
    long long int rem;
  } lldiv_t;
# 140 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) throw () ;
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1))) ;
       char **__restrict __endptr) throw () __attribute__ ((__nonnull__ (1))) ;
__extension__
__extension__
__extension__
__extension__
# 236 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 28 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 237 "/usr/include/stdlib.h" 2 3 4
extern long int strtol_l (__const char *__restrict __nptr,
     char **__restrict __endptr, int __base,
     __locale_t __loc) throw () __attribute__ ((__nonnull__ (1, 4))) ;
extern unsigned long int strtoul_l (__const char *__restrict __nptr,
        int __base, __locale_t __loc)
__extension__
extern long long int strtoll_l (__const char *__restrict __nptr,
    __locale_t __loc)
__extension__
extern unsigned long long int strtoull_l (__const char *__restrict __nptr,
extern double strtod_l (__const char *__restrict __nptr,
   char **__restrict __endptr, __locale_t __loc)
     throw () __attribute__ ((__nonnull__ (1, 3))) ;
extern float strtof_l (__const char *__restrict __nptr,
extern long double strtold_l (__const char *__restrict __nptr,
         __locale_t __loc)
extern char *l64a (long int __n) throw () ;
# 28 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
extern "C" {
# 28 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
# 131 "/usr/include/x86_64-linux-gnu/bits/types.h" 3 4
typedef __ino64_t ino64_t;
typedef __off64_t off64_t;
# 133 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 58 "/usr/include/time.h" 3 4
# 74 "/usr/include/time.h" 3 4
# 92 "/usr/include/time.h" 3 4
# 104 "/usr/include/time.h" 3 4
typedef __useconds_t useconds_t;
# 195 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 220 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
# 31 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/sigset.h" 3 4
typedef struct
  } __sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    long int tv_nsec;
# 31 "/usr/include/x86_64-linux-gnu/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
# 55 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
# 65 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
typedef struct
    __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
# 97 "/usr/include/x86_64-linux-gnu/sys/select.h" 3 4
extern "C" {
# 30 "/usr/include/x86_64-linux-gnu/sys/sysmacros.h" 3 4
extern "C" {
__extension__
     throw () __attribute__ ((__const__));
__extension__
__extension__
# 263 "/usr/include/x86_64-linux-gnu/sys/types.h" 3 4
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
# 23 "/usr/include/x86_64-linux-gnu/bits/pthreadtypes.h" 3 4
typedef union
  char __size[56];
  long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    int __spins;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
extern long int random (void) throw ();
extern void srandom (unsigned int __seed) throw ();
   size_t __statelen) throw () __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) throw () __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
       int32_t *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
   size_t __statelen,
     throw () __attribute__ ((__nonnull__ (2, 4)));
extern int rand (void) throw ();
extern void srand (unsigned int __seed) throw ();
extern int rand_r (unsigned int *__seed) throw ();
extern double drand48 (void) throw ();
extern double erand48 (unsigned short int __xsubi[3]) throw () __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) throw ();
extern long int mrand48 (void) throw ();
extern void srand48 (long int __seedval) throw ();
extern void lcong48 (unsigned short int __param[7]) throw () __attribute__ ((__nonnull__ (1)));
struct drand48_data
        double *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
       struct drand48_data *__buffer) throw () __attribute__ ((__nonnull__ (1, 2)));
extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
     throw () __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) throw ();
extern void cfree (void *__ptr) throw ();
# 25 "/usr/include/alloca.h" 3 4
extern "C" {
extern void *alloca (size_t __size) throw ();
extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
extern void abort (void) throw () __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) throw () __attribute__ ((__nonnull__ (1)));
extern "C++" int at_quick_exit (void (*__func) (void))
     throw () __asm ("at_quick_exit") __attribute__ ((__nonnull__ (1)));
extern void exit (int __status) throw () __attribute__ ((__noreturn__));
extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
extern char *getenv (__const char *__name) throw () __attribute__ ((__nonnull__ (1))) ;
extern int putenv (char *__string) throw () __attribute__ ((__nonnull__ (1)));
extern int unsetenv (__const char *__name) throw () __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) throw ();
extern char *mktemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 630 "/usr/include/stdlib.h" 3 4
extern int mkstemp64 (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 652 "/usr/include/stdlib.h" 3 4
extern int mkstemps64 (char *__template, int __suffixlen)
extern char *mkdtemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 674 "/usr/include/stdlib.h" 3 4
extern int mkostemp (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 684 "/usr/include/stdlib.h" 3 4
extern int mkostemp64 (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 694 "/usr/include/stdlib.h" 3 4
extern int mkostemps (char *__template, int __suffixlen, int __flags)
# 706 "/usr/include/stdlib.h" 3 4
extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
extern char *canonicalize_file_name (__const char *__name)
         char *__restrict __resolved) throw () ;
typedef __compar_fn_t comparison_fn_t;
typedef int (*__compar_d_fn_t) (__const void *, __const void *, void *);
extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
       __compar_d_fn_t __compar, void *__arg)
extern int abs (int __x) throw () __attribute__ ((__const__)) ;
extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
     int *__restrict __sign) throw () __attribute__ ((__nonnull__ (3, 4))) ;
     throw () __attribute__ ((__nonnull__ (3))) ;
     size_t __len) throw () __attribute__ ((__nonnull__ (3, 4, 5)));
extern int mblen (__const char *__s, size_t __n) throw () ;
     __const char *__restrict __s, size_t __n) throw () ;
extern int wctomb (char *__s, wchar_t __wchar) throw () ;
   __const char *__restrict __s, size_t __n) throw ();
     throw ();
extern int rpmatch (__const char *__response) throw () __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1, 2, 3))) ;
extern void setkey (__const char *__key) throw () __attribute__ ((__nonnull__ (1)));
extern int posix_openpt (int __oflag) ;
extern int grantpt (int __fd) throw ();
extern int unlockpt (int __fd) throw ();
extern char *ptsname (int __fd) throw () ;
extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
extern int getpt (void);
# 964 "/usr/include/stdlib.h" 3 4
# 67 "/usr/include/c++/4.6/cstdlib" 2 3
# 98 "/usr/include/c++/4.6/cstdlib" 3
namespace std __attribute__ ((__visibility__ ("default")))
  using ::div_t;
  using ::ldiv_t;
  using ::abort;
  using ::abs;
  using ::atexit;
  using ::atof;
  using ::atoi;
  using ::atol;
  using ::bsearch;
  using ::calloc;
  using ::div;
  using ::exit;
  using ::free;
  using ::getenv;
  using ::labs;
  using ::ldiv;
  using ::malloc;
  using ::mblen;
  using ::mbstowcs;
  using ::mbtowc;
  using ::qsort;
  using ::rand;
  using ::realloc;
  using ::srand;
  using ::strtod;
  using ::strtol;
  using ::strtoul;
  using ::system;
  using ::wcstombs;
  using ::wctomb;
  inline long
  abs(long __i) { return labs(__i); }
  inline ldiv_t
  div(long __i, long __j) { return ldiv(__i, __j); }
# 158 "/usr/include/c++/4.6/cstdlib" 3
namespace __gnu_cxx __attribute__ ((__visibility__ ("default")))
  using ::lldiv_t;
  using ::_Exit;
  inline long long
  abs(long long __x) { return __x >= 0 ? __x : -__x; }
  using ::llabs;
  inline lldiv_t
  div(long long __n, long long __d)
  { lldiv_t __q; __q.quot = __n / __d; __q.rem = __n % __d; return __q; }
  using ::lldiv;
# 193 "/usr/include/c++/4.6/cstdlib" 3
  using ::atoll;
  using ::strtoll;
  using ::strtoull;
  using ::strtof;
  using ::strtold;
namespace std
  using ::__gnu_cxx::lldiv_t;
  using ::__gnu_cxx::_Exit;
  using ::__gnu_cxx::abs;
  using ::__gnu_cxx::llabs;
  using ::__gnu_cxx::div;
  using ::__gnu_cxx::lldiv;
  using ::__gnu_cxx::atoll;
  using ::__gnu_cxx::strtof;
  using ::__gnu_cxx::strtoll;
  using ::__gnu_cxx::strtoull;
  using ::__gnu_cxx::strtold;
                                Popping language Cxx
TEST checkFortranCompiler from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:934)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:934)
  Locate a functional Fortran compiler
Checking for program /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90...found
                                  Defined make macro "FC" to "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90"
                                  Pushing language FC
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                          Pushing language FC
                                          Popping language FC
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                                          Pushing language FC
                                          Popping language FC
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
                                              Pushing language FC
                                              Popping language FC
Testing executable /tmp/petsc-W4It8W/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.setCompilers/conftest
                                  Popping language FC
TEST checkFortranComments from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:955)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:955)
  Make sure fortran comment "!" works
                                Pushing language FC
Successful compile:
Source:
! comment
      program main
      end
                              Fortran comments can use ! in column 1
                                Popping language FC
TEST checkLargeFileIO from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1072)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1072)
TEST checkArchiver from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1171)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1171)
  Check that the archiver exists and can make a library usable by the compiler
                                Pushing language C
Executing: ar -V
stdout:
GNU ar (GNU Binutils for Ubuntu) 2.22
Copyright 2011 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
                                    Defined make macro "FAST_AR_FLAGS" to "Scq"
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.setCompilers   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int foo(int a) {
  return a+1;
Checking for program /usr/lib/mutt/ar...not found
Checking for program /home/tisaac/.local/bin/ar...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/ar...not found
Checking for program /home/tisaac/.bin/ar...not found
Checking for program /usr/lib/lightdm/lightdm/ar...not found
Checking for program /usr/local/sbin/ar...not found
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/sbin/ar...not found
Checking for program /usr/bin/ar...found
                                  Defined make macro "AR" to "/usr/bin/ar"
Checking for program /usr/lib/mutt/ranlib...not found
Checking for program /home/tisaac/.local/bin/ranlib...not found
Checking for program /usr/local/texlive/2015/bin/x86_64-linux/ranlib...not found
Checking for program /home/tisaac/.bin/ranlib...not found
Checking for program /usr/lib/lightdm/lightdm/ranlib...not found
Checking for program /usr/local/sbin/ranlib...not found
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/sbin/ranlib...not found
Checking for program /usr/bin/ranlib...found
                                  Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-W4It8W/config.setCompilers/libconf1.a /tmp/petsc-W4It8W/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /tmp/petsc-W4It8W/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- 'c'
                              Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
Successful compile:
Source:
int foo(int a) {
  return a+1;
                                  Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /tmp/petsc-W4It8W/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest    /tmp/petsc-W4It8W/config.setCompilers/conftest.o -L/tmp/petsc-W4It8W/config.setCompilers -lconf1
                                Defined make macro "AR_FLAGS" to "cr"
                                Defined make macro "AR_LIB_SUFFIX" to "a"
                                Popping language C
TEST checkSharedLinker from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1285)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1285)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: Linux
                              Checking shared linker /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc using flags ['-shared']
Checking for program /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc...found
                                  Defined make macro "LD_SHARED" to "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc"
                              Trying C compiler flag
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag
Successful compile:
Source:
int main() {
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -shared    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
                                Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
int foo(void) {fprintf(stdout,"hello");
return 0;}
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/libconftest.so  -shared   /tmp/petsc-W4It8W/config.setCompilers/conftest.o
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if (ret) {}
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest     /tmp/petsc-W4It8W/config.setCompilers/conftest.o  -L/tmp/petsc-W4It8W/config.setCompilers -lconftest
                              Using shared linker /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc with flags ['-shared'] and library extension so
Executing: uname -s
stdout: Linux
TEST checkPIC from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1031)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1031)
  Determine the PIC option for each compiler
                                Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
#include<stdio.h>
void foo(void){fprintf(stdout,"hello");
return;}
void bar(void){foo();}
                                        Pushing language C
                                        Popping language C
                              Accepted C compiler flag
                                Popping language C
                                Pushing language Cxx
                              Trying Cxx compiler flag
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag
Successful compile:
Source:
#include<stdio.h>
return;}
                                    Pushing language C
                                        Pushing language C
                                        Popping language C
                                    Popping language C
                              Accepted Cxx compiler flag
                                Pushing language FC
                              Trying FC compiler flag
Successful compile:
Source:
      program main
      end
Added FC compiler flag
Successful compile:
Source:
      function foo(a)
      real:: a,x,bar
      common /xx/ x
      x=a
      foo = bar(x)
      end
                                    Pushing language C
                                        Pushing language C
                                        Popping language C
                                    Popping language C
                              Accepted FC compiler flag
                                Popping language FC
TEST checkSharedLinkerPaths from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1380)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1380)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
                                Pushing language C
Executing: uname -s
stdout: Linux
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -V
                              Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -Wl,-rpath,/home/tisaac/Projects/petsc     /tmp/petsc-W4It8W/config.setCompilers/conftest.o
                                Valid C linker flag -Wl,-rpath,/home/tisaac/Projects/petsc
                                Popping language C
Executing: uname -s
stdout: Linux
                              Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -Wl,-rpath,/home/tisaac/Projects/petsc   /tmp/petsc-W4It8W/config.setCompilers/conftest.o
                                Valid Cxx linker flag -Wl,-rpath,/home/tisaac/Projects/petsc
                                Pushing language FC
Executing: uname -s
stdout: Linux
                              Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
      program main
      end
                                        Pushing language FC
                                        Popping language FC
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -Wl,-rpath,/home/tisaac/Projects/petsc    /tmp/petsc-W4It8W/config.setCompilers/conftest.o
                                Valid FC linker flag -Wl,-rpath,/home/tisaac/Projects/petsc
                                Popping language FC
TEST checkLibC from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1415)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1415)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
                                        Pushing language C
                                        Popping language C
                              Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1464)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1464)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -E  -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.headers  /tmp/petsc-W4It8W/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-W4It8W/config.headers/conftest.c"
# 1 "/home/tisaac/Projects/petsc//"
# 1 "<built-in>"
#define __STDC__ 1
#define __STDC_HOSTED__ 1
#define __GNUC__ 4
#define __GNUC_MINOR__ 6
#define __GNUC_PATCHLEVEL__ 4
#define __VERSION__ "4.6.4"
#define __pic__ 2
#define __PIC__ 2
#define __FINITE_MATH_ONLY__ 0
#define _LP64 1
#define __LP64__ 1
#define __SIZEOF_INT__ 4
#define __SIZEOF_LONG__ 8
#define __SIZEOF_LONG_LONG__ 8
#define __SIZEOF_SHORT__ 2
#define __SIZEOF_FLOAT__ 4
#define __SIZEOF_DOUBLE__ 8
#define __SIZEOF_LONG_DOUBLE__ 16
#define __SIZEOF_SIZE_T__ 8
#define __CHAR_BIT__ 8
#define __BIGGEST_ALIGNMENT__ 16
#define __ORDER_LITTLE_ENDIAN__ 1234
#define __ORDER_BIG_ENDIAN__ 4321
#define __ORDER_PDP_ENDIAN__ 3412
#define __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__
#define __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__
#define __SIZEOF_POINTER__ 8
#define __SIZE_TYPE__ long unsigned int
#define __PTRDIFF_TYPE__ long int
#define __WCHAR_TYPE__ int
#define __WINT_TYPE__ unsigned int
#define __INTMAX_TYPE__ long int
#define __UINTMAX_TYPE__ long unsigned int
#define __CHAR16_TYPE__ short unsigned int
#define __CHAR32_TYPE__ unsigned int
#define __SIG_ATOMIC_TYPE__ int
#define __INT8_TYPE__ signed char
#define __INT16_TYPE__ short int
#define __INT32_TYPE__ int
#define __INT64_TYPE__ long int
#define __UINT8_TYPE__ unsigned char
#define __UINT16_TYPE__ short unsigned int
#define __UINT32_TYPE__ unsigned int
#define __UINT64_TYPE__ long unsigned int
#define __INT_LEAST8_TYPE__ signed char
#define __INT_LEAST16_TYPE__ short int
#define __INT_LEAST32_TYPE__ int
#define __INT_LEAST64_TYPE__ long int
#define __UINT_LEAST8_TYPE__ unsigned char
#define __UINT_LEAST16_TYPE__ short unsigned int
#define __UINT_LEAST32_TYPE__ unsigned int
#define __UINT_LEAST64_TYPE__ long unsigned int
#define __INT_FAST8_TYPE__ signed char
#define __INT_FAST16_TYPE__ long int
#define __INT_FAST32_TYPE__ long int
#define __INT_FAST64_TYPE__ long int
#define __UINT_FAST8_TYPE__ unsigned char
#define __UINT_FAST16_TYPE__ long unsigned int
#define __UINT_FAST32_TYPE__ long unsigned int
#define __UINT_FAST64_TYPE__ long unsigned int
#define __INTPTR_TYPE__ long int
#define __UINTPTR_TYPE__ long unsigned int
#define __GXX_ABI_VERSION 1002
#define __SCHAR_MAX__ 127
#define __SHRT_MAX__ 32767
#define __INT_MAX__ 2147483647
#define __LONG_MAX__ 9223372036854775807L
#define __LONG_LONG_MAX__ 9223372036854775807LL
#define __WCHAR_MAX__ 2147483647
#define __WCHAR_MIN__ (-__WCHAR_MAX__ - 1)
#define __WINT_MAX__ 4294967295U
#define __WINT_MIN__ 0U
#define __PTRDIFF_MAX__ 9223372036854775807L
#define __SIZE_MAX__ 18446744073709551615UL
#define __INTMAX_MAX__ 9223372036854775807L
#define __INTMAX_C(c) c ## L
#define __UINTMAX_MAX__ 18446744073709551615UL
#define __UINTMAX_C(c) c ## UL
#define __SIG_ATOMIC_MAX__ 2147483647
#define __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1)
#define __INT8_MAX__ 127
#define __INT16_MAX__ 32767
#define __INT32_MAX__ 2147483647
#define __INT64_MAX__ 9223372036854775807L
#define __UINT8_MAX__ 255
#define __UINT16_MAX__ 65535
#define __UINT32_MAX__ 4294967295U
#define __UINT64_MAX__ 18446744073709551615UL
#define __INT_LEAST8_MAX__ 127
#define __INT8_C(c) c
#define __INT_LEAST16_MAX__ 32767
#define __INT16_C(c) c
#define __INT_LEAST32_MAX__ 2147483647
#define __INT32_C(c) c
#define __INT_LEAST64_MAX__ 9223372036854775807L
#define __INT64_C(c) c ## L
#define __UINT_LEAST8_MAX__ 255
#define __UINT8_C(c) c
#define __UINT_LEAST16_MAX__ 65535
#define __UINT16_C(c) c
#define __UINT_LEAST32_MAX__ 4294967295U
#define __UINT32_C(c) c ## U
#define __UINT_LEAST64_MAX__ 18446744073709551615UL
#define __UINT64_C(c) c ## UL
#define __INT_FAST8_MAX__ 127
#define __INT_FAST16_MAX__ 9223372036854775807L
#define __INT_FAST32_MAX__ 9223372036854775807L
#define __INT_FAST64_MAX__ 9223372036854775807L
#define __UINT_FAST8_MAX__ 255
#define __UINT_FAST16_MAX__ 18446744073709551615UL
#define __UINT_FAST32_MAX__ 18446744073709551615UL
#define __UINT_FAST64_MAX__ 18446744073709551615UL
#define __INTPTR_MAX__ 9223372036854775807L
#define __UINTPTR_MAX__ 18446744073709551615UL
#define __FLT_EVAL_METHOD__ 0
#define __DEC_EVAL_METHOD__ 2
#define __FLT_RADIX__ 2
#define __FLT_MANT_DIG__ 24
#define __FLT_DIG__ 6
#define __FLT_MIN_EXP__ (-125)
#define __FLT_MIN_10_EXP__ (-37)
#define __FLT_MAX_EXP__ 128
#define __FLT_MAX_10_EXP__ 38
#define __FLT_DECIMAL_DIG__ 9
#define __FLT_MAX__ 3.40282346638528859812e+38F
#define __FLT_MIN__ 1.17549435082228750797e-38F
#define __FLT_EPSILON__ 1.19209289550781250000e-7F
#define __FLT_DENORM_MIN__ 1.40129846432481707092e-45F
#define __FLT_HAS_DENORM__ 1
#define __FLT_HAS_INFINITY__ 1
#define __FLT_HAS_QUIET_NAN__ 1
#define __DBL_MANT_DIG__ 53
#define __DBL_DIG__ 15
#define __DBL_MIN_EXP__ (-1021)
#define __DBL_MIN_10_EXP__ (-307)
#define __DBL_MAX_EXP__ 1024
#define __DBL_MAX_10_EXP__ 308
#define __DBL_DECIMAL_DIG__ 17
#define __DBL_MAX__ ((double)1.79769313486231570815e+308L)
#define __DBL_MIN__ ((double)2.22507385850720138309e-308L)
#define __DBL_EPSILON__ ((double)2.22044604925031308085e-16L)
#define __DBL_DENORM_MIN__ ((double)4.94065645841246544177e-324L)
#define __DBL_HAS_DENORM__ 1
#define __DBL_HAS_INFINITY__ 1
#define __DBL_HAS_QUIET_NAN__ 1
#define __LDBL_MANT_DIG__ 64
#define __LDBL_DIG__ 18
#define __LDBL_MIN_EXP__ (-16381)
#define __LDBL_MIN_10_EXP__ (-4931)
#define __LDBL_MAX_EXP__ 16384
#define __LDBL_MAX_10_EXP__ 4932
#define __DECIMAL_DIG__ 21
#define __LDBL_MAX__ 1.18973149535723176502e+4932L
#define __LDBL_MIN__ 3.36210314311209350626e-4932L
#define __LDBL_EPSILON__ 1.08420217248550443401e-19L
#define __LDBL_DENORM_MIN__ 3.64519953188247460253e-4951L
#define __LDBL_HAS_DENORM__ 1
#define __LDBL_HAS_INFINITY__ 1
#define __LDBL_HAS_QUIET_NAN__ 1
#define __DEC32_MANT_DIG__ 7
#define __DEC32_MIN_EXP__ (-94)
#define __DEC32_MAX_EXP__ 97
#define __DEC32_MIN__ 1E-95DF
#define __DEC32_MAX__ 9.999999E96DF
#define __DEC32_EPSILON__ 1E-6DF
#define __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF
#define __DEC64_MANT_DIG__ 16
#define __DEC64_MIN_EXP__ (-382)
#define __DEC64_MAX_EXP__ 385
#define __DEC64_MIN__ 1E-383DD
#define __DEC64_MAX__ 9.999999999999999E384DD
#define __DEC64_EPSILON__ 1E-15DD
#define __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD
#define __DEC128_MANT_DIG__ 34
#define __DEC128_MIN_EXP__ (-6142)
#define __DEC128_MAX_EXP__ 6145
#define __DEC128_MIN__ 1E-6143DL
#define __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL
#define __DEC128_EPSILON__ 1E-33DL
#define __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL
#define __REGISTER_PREFIX__
#define __USER_LABEL_PREFIX__
#define _FORTIFY_SOURCE 2
#define __GNUC_GNU_INLINE__ 1
#define __NO_INLINE__ 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1
#define __GCC_HAVE_DWARF2_CFI_ASM 1
#define __PRAGMA_REDEFINE_EXTNAME 1
#define __SSP__ 1
#define __SIZEOF_INT128__ 16
#define __SIZEOF_WCHAR_T__ 4
#define __SIZEOF_WINT_T__ 4
#define __SIZEOF_PTRDIFF_T__ 8
#define __amd64 1
#define __amd64__ 1
#define __x86_64 1
#define __x86_64__ 1
#define __k8 1
#define __k8__ 1
#define __MMX__ 1
#define __SSE__ 1
#define __SSE2__ 1
#define __SSE_MATH__ 1
#define __SSE2_MATH__ 1
#define __gnu_linux__ 1
#define __linux 1
#define __linux__ 1
#define linux 1
#define __unix 1
#define __unix__ 1
#define unix 1
#define __ELF__ 1
#define __DECIMAL_BID_FORMAT__ 1
# 1 "<command-line>"
# 1 "/tmp/petsc-W4It8W/config.headers/confdefs.h" 1
#define INCLUDED_CONFDEFS_H
#define IS_COLORING_MAX 65535
#define STDC_HEADERS 1
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#define PETSC_HAVE_GZIP 1
#define PETSC_HAVE_STRING_H 1
#define PETSC_HAVE_SYS_TYPES_H 1
#define PETSC_HAVE_ENDIAN_H 1
#define PETSC_HAVE_SYS_PROCFS_H 1
#define PETSC_HAVE_DLFCN_H 1
#define PETSC_HAVE_SCHED_H 1
#define PETSC_HAVE_STDINT_H 1
#define PETSC_HAVE_LINUX_KERNEL_H 1
#define PETSC_HAVE_TIME_H 1
#define PETSC_HAVE_MATH_H 1
#define PETSC_HAVE_INTTYPES_H 1
#define PETSC_TIME_WITH_SYS_TIME 1
#define PETSC_HAVE_SYS_PARAM_H 1
#define PETSC_HAVE_PTHREAD_H 1
#define PETSC_HAVE_UNISTD_H 1
#define PETSC_HAVE_STDLIB_H 1
#define PETSC_HAVE_SYS_WAIT_H 1
#define PETSC_HAVE_SETJMP_H 1
#define PETSC_HAVE_LIMITS_H 1
#define PETSC_HAVE_SYS_UTSNAME_H 1
#define PETSC_HAVE_NETINET_IN_H 1
#define PETSC_HAVE_SYS_SOCKET_H 1
#define PETSC_HAVE_FLOAT_H 1
#define PETSC_HAVE_SEARCH_H 1
#define PETSC_HAVE_SYS_RESOURCE_H 1
#define PETSC_HAVE_SYS_TIMES_H 1
#define PETSC_HAVE_NETDB_H 1
#define PETSC_HAVE_MALLOC_H 1
#define PETSC_HAVE_PWD_H 1
#define PETSC_HAVE_FCNTL_H 1
#define PETSC_HAVE_STRINGS_H 1
#define PETSC_HAVE_SYS_SYSINFO_H 1
#define PETSC_HAVE_SYS_TIME_H 1
#define PETSC_USING_F90 1
#define PETSC_USING_F2003 1
#define PETSC_HAVE_RTLD_NOW 1
#define PETSC_HAVE_RTLD_LOCAL 1
#define PETSC_HAVE_RTLD_LAZY 1
#define PETSC_C_STATIC_INLINE static inline
#define PETSC_USING_F90FREEFORM 1
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#define PETSC_HAVE_CXX_NAMESPACE 1
#define PETSC_HAVE_RTLD_GLOBAL 1
#define PETSC_C_RESTRICT __restrict__
#define PETSC_CXX_RESTRICT __restrict__
#define PETSC_CXX_STATIC_INLINE static inline
#define PETSC_HAVE_LIBZ 1
#define PETSC_HAVE_LIBDL 1
#define PETSC_HAVE_LIBM 1
#define PETSC_HAVE_FENV_H 1
#define PETSC_HAVE_LOG2 1
#define PETSC_HAVE_ERF 1
#define PETSC_HAVE_TGAMMA 1
#define PETSC_HAVE_LIBRT 1
#define PETSC_ARCH "arch-linux2-c-debug-mpich"
#define PETSC_USE_SCALAR_REAL 1
#define PETSC_HAVE_ISINF 1
#define PETSC_HAVE_ISNAN 1
#define PETSC_USE_REAL_DOUBLE 1
#define PETSC_BITS_PER_BYTE 8
#define PETSC_USE_VISIBILITY_C 1
#define PETSC_SIZEOF_VOID_P 8
#define PETSC_RETSIGTYPE void
#define PETSC_HAVE_CXX_COMPLEX 1
#define PETSC_SIZEOF_LONG 8
#define PETSC_USE_FORTRANKIND 1
#define PETSC_USE_VISIBILITY_CXX 1
#define PETSC_SIZEOF_SIZE_T 8
#define PETSC_HAVE_SIGINFO_T 1
#define PETSC_SIZEOF_CHAR 1
#define PETSC_SIZEOF_DOUBLE 8
#define PETSC_SIZEOF_FLOAT 4
#define PETSC_HAVE_C99_COMPLEX 1
#define PETSC_SIZEOF_INT 4
#define PETSC_SIZEOF_LONG_LONG 8
#define PETSC_SIZEOF_SHORT 2
#define PETSC_CLANGUAGE_C 1
#define PETSC_USE_ERRORCHECKING 1
#define PETSC_HAVE_STRCASECMP 1
#define PETSC_HAVE_GET_NPROCS 1
#define PETSC_HAVE_POPEN 1
#define PETSC_HAVE_SIGSET 1
#define PETSC_HAVE_GETWD 1
#define PETSC_HAVE_VSNPRINTF 1
#define PETSC_HAVE_TIMES 1
#define PETSC_HAVE_DLSYM 1
#define PETSC_HAVE_SNPRINTF 1
#define PETSC_HAVE_GETHOSTBYNAME 1
#define PETSC_HAVE_GETCWD 1
#define PETSC_HAVE_DLERROR 1
#define PETSC_HAVE_FORK 1
#define PETSC_HAVE_RAND 1
#define PETSC_HAVE_GETTIMEOFDAY 1
#define PETSC_HAVE_DLCLOSE 1
#define PETSC_HAVE_UNAME 1
#define PETSC_HAVE_GETHOSTNAME 1
#define PETSC_HAVE_MKSTEMP 1
#define PETSC_HAVE_SIGACTION 1
#define PETSC_HAVE_DRAND48 1
#define PETSC_HAVE_MEMALIGN 1
#define PETSC_HAVE_VA_COPY 1
#define PETSC_HAVE_CLOCK 1
#define PETSC_HAVE_ACCESS 1
#define PETSC_HAVE_SIGNAL 1
#define PETSC_HAVE_USLEEP 1
#define PETSC_HAVE_GETRUSAGE 1
#define PETSC_HAVE_VFPRINTF 1
#define PETSC_HAVE_NANOSLEEP 1
#define PETSC_HAVE_GETDOMAINNAME 1
#define PETSC_HAVE_TIME 1
#define PETSC_HAVE_LSEEK 1
#define PETSC_HAVE_SOCKET 1
#define PETSC_HAVE_SYSINFO 1
#define PETSC_HAVE_READLINK 1
#define PETSC_HAVE_REALPATH 1
#define PETSC_HAVE_DLOPEN 1
#define PETSC_HAVE_MEMMOVE 1
#define PETSC_HAVE__GFORTRAN_IARGC 1
#define PETSC_HAVE_GETPAGESIZE 1
#define PETSC_HAVE_SLEEP 1
#define PETSC_HAVE_VPRINTF 1
#define PETSC_HAVE_BZERO 1
#define PETSC_SIGNAL_CAST
#define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
#define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
#define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
#define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#define PETSC_HAVE_SHARED_LIBRARIES 1
#define PETSC_USE_SHARED_LIBRARIES 1
#define PETSC_USE_GDB_DEBUGGER 1
#define PETSC_VERSION_DATE_GIT "2016-11-10 08:59:24 -0600"
#define PETSC_VERSION_BRANCH_GIT "master"
#define PETSC_VERSION_GIT "v3.7.4-1922-geb30558"
#define PETSC_USE_INFO 1
#define PETSC_Alignx(a,b)
#define PETSC_USE_BACKWARD_LOOP 1
#define PETSC_USE_DEBUG 1
#define PETSC_USE_LOG 1
#define PETSC_IS_COLOR_VALUE_TYPE_F integer2
#define PETSC_IS_COLOR_VALUE_TYPE short
#define PETSC_USE_CTABLE 1
#define PETSC_USE_FORTRAN_INTERFACES 1
#define PETSC_MEMALIGN 16
#define PETSC__GNU_SOURCE 1
#define PETSC__BSD_SOURCE 1
#define PETSC__DEFAULT_SOURCE 1
#define PETSC_USE_PROC_FOR_SIZE 1
#define PETSC_LEVEL1_DCACHE_LINESIZE 64
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#define PETSC_LEVEL1_DCACHE_ASSOC 8
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#define PETSC_HAVE_GFORTRAN_IARGC 1
# 2 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/tmp/petsc-W4It8W/config.headers/conffix.h" 1
#define INCLUDED_CONFFIX_H
# 3 "/tmp/petsc-W4It8W/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 21 "/usr/include/dlfcn.h" 3 4
#define _DLFCN_H 1
# 1 "/usr/include/features.h" 1 3 4
# 21 "/usr/include/features.h" 3 4
#define _FEATURES_H 1
# 98 "/usr/include/features.h" 3 4
#undef __USE_ISOC99
#undef __USE_ISOC95
#undef __USE_POSIX
#undef __USE_POSIX2
#undef __USE_POSIX199309
#undef __USE_POSIX199506
#undef __USE_XOPEN
#undef __USE_XOPEN_EXTENDED
#undef __USE_UNIX98
#undef __USE_XOPEN2K
#undef __USE_XOPEN2KXSI
#undef __USE_XOPEN2K8
#undef __USE_XOPEN2K8XSI
#undef __USE_LARGEFILE
#undef __USE_LARGEFILE64
#undef __USE_FILE_OFFSET64
#undef __USE_BSD
#undef __USE_SVID
#undef __USE_MISC
#undef __USE_ATFILE
#undef __USE_GNU
#undef __USE_REENTRANT
#undef __USE_FORTIFY_LEVEL
#undef __FAVOR_BSD
#undef __KERNEL_STRICT_NAMES
#define __KERNEL_STRICT_NAMES
#define __USE_ANSI 1
# 141 "/usr/include/features.h" 3 4
#define __GNUC_PREREQ(maj,min) ((__GNUC__ << 16) + __GNUC_MINOR__ >= ((maj) << 16) + (min))
# 184 "/usr/include/features.h" 3 4
#define _BSD_SOURCE 1
#define _SVID_SOURCE 1
# 207 "/usr/include/features.h" 3 4
#define _POSIX_SOURCE 1
#define _POSIX_C_SOURCE 200809L
#define __USE_POSIX_IMPLICITLY 1
#define __USE_POSIX 1
#define __USE_POSIX2 1
#define __USE_POSIX199309 1
#define __USE_POSIX199506 1
#define __USE_XOPEN2K 1
#undef __USE_ISOC95
#define __USE_ISOC95 1
#undef __USE_ISOC99
#define __USE_ISOC99 1
#define __USE_XOPEN2K8 1
#undef _ATFILE_SOURCE
#define _ATFILE_SOURCE 1
# 289 "/usr/include/features.h" 3 4
#define __USE_MISC 1
#define __USE_BSD 1
#define __USE_SVID 1
#define __USE_ATFILE 1
# 320 "/usr/include/features.h" 3 4
#define __USE_FORTIFY_LEVEL 0
# 1 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 1 3 4
# 24 "/usr/include/x86_64-linux-gnu/bits/predefs.h" 3 4
#define _PREDEFS_H
#define __STDC_IEC_559__ 1
#define __STDC_IEC_559_COMPLEX__ 1
# 325 "/usr/include/features.h" 2 3 4
#define __STDC_ISO_10646__ 200009L
#undef __GNU_LIBRARY__
#define __GNU_LIBRARY__ 6
#define __GLIBC__ 2
#define __GLIBC_MINOR__ 15
#define __GLIBC_PREREQ(maj,min) ((__GLIBC__ << 16) + __GLIBC_MINOR__ >= ((maj) << 16) + (min))
#define __GLIBC_HAVE_LONG_LONG 1
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 21 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define _SYS_CDEFS_H 1
# 36 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#undef __P
#undef __PMT
#define __LEAF , __leaf__
#define __LEAF_ATTR __attribute__ ((__leaf__))
# 57 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __THROW __attribute__ ((__nothrow__ __LEAF))
#define __THROWNL __attribute__ ((__nothrow__))
#define __NTH(fct) __attribute__ ((__nothrow__ __LEAF)) fct
# 88 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __P(args) args
#define __PMT(args) args
#define __CONCAT(x,y) x ## y
#define __STRING(x) #x
#define __ptr_t void *
#define __long_double_t long double
#define __BEGIN_DECLS
#define __END_DECLS
# 128 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __BEGIN_NAMESPACE_STD
#define __END_NAMESPACE_STD
#define __USING_NAMESPACE_STD(name)
#define __BEGIN_NAMESPACE_C99
#define __END_NAMESPACE_C99
#define __USING_NAMESPACE_C99(name)
#define __bounded
#define __unbounded
#define __ptrvalue
#define __bos(ptr) __builtin_object_size (ptr, __USE_FORTIFY_LEVEL > 1)
#define __bos0(ptr) __builtin_object_size (ptr, 0)
#define __warndecl(name,msg) extern void name (void) __attribute__((__warning__ (msg)))
#define __warnattr(msg) __attribute__((__warning__ (msg)))
#define __errordecl(name,msg) extern void name (void) __attribute__((__error__ (msg)))
# 164 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __flexarr []
# 191 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __REDIRECT(name,proto,alias) name proto __asm__ (__ASMNAME (#alias))
#define __REDIRECT_NTH(name,proto,alias) name proto __asm__ (__ASMNAME (#alias)) __THROW
#define __REDIRECT_NTHNL(name,proto,alias) name proto __asm__ (__ASMNAME (#alias)) __THROWNL
#define __ASMNAME(cname) __ASMNAME2 (__USER_LABEL_PREFIX__, cname)
#define __ASMNAME2(prefix,cname) __STRING (prefix) cname
# 225 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_malloc__ __attribute__ ((__malloc__))
# 234 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_pure__ __attribute__ ((__pure__))
#define __attribute_const__ __attribute__ ((__const__))
# 250 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_used__ __attribute__ ((__used__))
#define __attribute_noinline__ __attribute__ ((__noinline__))
#define __attribute_deprecated__ __attribute__ ((__deprecated__))
# 271 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_format_arg__(x) __attribute__ ((__format_arg__ (x)))
# 281 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __attribute_format_strfmon__(a,b) __attribute__ ((__format__ (__strfmon__, a, b)))
# 290 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __nonnull(params) __attribute__ ((__nonnull__ params))
#define __attribute_warn_unused_result__ __attribute__ ((__warn_unused_result__))
# 307 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __wur
#define __always_inline __inline __attribute__ ((__always_inline__))
# 330 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __extern_inline extern __inline
#define __extern_always_inline extern __always_inline __attribute__ ((__artificial__))
# 343 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __va_arg_pack() __builtin_va_arg_pack ()
#define __va_arg_pack_len() __builtin_va_arg_pack_len ()
# 364 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __restrict_arr __restrict
# 378 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
#define __WORDSIZE 64
#define __WORDSIZE_COMPAT32 1
# 379 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 400 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
#define __LDBL_REDIR1(name,proto,alias) name proto
#define __LDBL_REDIR(name,proto) name proto
#define __LDBL_REDIR1_NTH(name,proto,alias) name proto __THROW
#define __LDBL_REDIR_NTH(name,proto) name proto __THROW
#define __LDBL_REDIR_DECL(name)
#define __REDIRECT_LDBL(name,proto,alias) __REDIRECT (name, proto, alias)
#define __REDIRECT_NTH_LDBL(name,proto,alias) __REDIRECT_NTH (name, proto, alias)
# 358 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 5 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 3 4
#define __stub_bdflush
#define __stub_chflags
#define __stub_fattach
#define __stub_fchflags
#define __stub_fdetach
#define __stub_getmsg
#define __stub_gtty
#define __stub_lchmod
#define __stub_putmsg
#define __stub_revoke
#define __stub_setlogin
#define __stub_sigreturn
#define __stub_sstk
#define __stub_stty
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 24 "/usr/include/dlfcn.h" 2 3 4
#define __need_size_t
# 1 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 1 3 4
# 187 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#define __size_t__
#define __SIZE_T__
#define _SIZE_T
#define _SYS_SIZE_T_H
#define _T_SIZE_
#define _T_SIZE
#define __SIZE_T
#define _SIZE_T_
#define _BSD_SIZE_T_
#define _SIZE_T_DEFINED_
#define _BSD_SIZE_T_DEFINED_
#define _SIZE_T_DECLARED
#define ___int_size_t_h
#define _GCC_SIZE_T
#define _SIZET_
#define __size_t
typedef long unsigned int size_t;
# 234 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#undef __need_size_t
# 408 "/usr/lib/gcc/x86_64-linux-gnu/4.6/include/stddef.h" 3 4
#undef __need_NULL
# 26 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/dlfcn.h" 1 3 4
# 25 "/usr/include/x86_64-linux-gnu/bits/dlfcn.h" 3 4
#define RTLD_LAZY 0x00001
#define RTLD_NOW 0x00002
#define RTLD_BINDING_MASK 0x3
#define RTLD_NOLOAD 0x00004
#define RTLD_DEEPBIND 0x00008
#define RTLD_GLOBAL 0x00100
#define RTLD_LOCAL 0
#define RTLD_NODELETE 0x01000
# 29 "/usr/include/dlfcn.h" 2 3 4
# 53 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (__const char *__file, int __mode) __attribute__ ((__nothrow__ , __leaf__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
      __const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 83 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/dlfcn.h" 3 4
                                  Defined "HAVE_DLFCN_H" to "1"
                                  Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
                                    Pushing language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.libraries/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers     /tmp/petsc-W4It8W/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
                                            Pushing language C
                                            Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.libraries/conftest      /tmp/petsc-W4It8W/config.libraries/conftest.o  -ldl
                                    Defined "HAVE_LIBDL" to "1"
                                    Popping language C
                                Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
                              Checking dynamic linker /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc using flags ['-shared']
                                  Defined make macro "DYNAMICLINKER" to "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc"
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers     /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest  -shared     /tmp/petsc-W4It8W/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/libconftest.so  -shared    /tmp/petsc-W4It8W/config.setCompilers/conftest.o -ldl
Possible ERROR while running compiler:
stderr:
/tmp/petsc-W4It8W/config.setCompilers/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:11:3: warning: incompatible implicit declaration of built-in function ?printf? [enabled by default]
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:15:3: warning: incompatible implicit declaration of built-in function ?printf? [enabled by default]
/tmp/petsc-W4It8W/config.setCompilers/conftest.c:19:3: warning: incompatible implicit declaration of built-in function ?printf? [enabled by default]
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/tmp/petsc-W4It8W/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
  printf("Could not load symbol\n");
  return -1;
if ((*foo)()) {
  printf("Invalid return from foo()\n");
  return -1;
if (dlclose(handle)) {
  printf("Could not close library\n");
  return -1;
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.setCompilers/conftest      /tmp/petsc-W4It8W/config.setCompilers/conftest.o -ldl
                              Using dynamic linker /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/setCompilers.py:1516)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1516)
  Output module data as defines and substitutions
                                Substituting "CC" with "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc"
                                Substituting "CFLAGS" with "  "
                                Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
                                Substituting "CPP" with "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -E"
                                Substituting "CPPFLAGS" with ""
                                Substituting "CXX" with "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx"
                                Substituting "CXX_CXXFLAGS" with " "
                                Substituting "CXXFLAGS" with ""
                                Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
                                Substituting "CXXCPP" with "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -E"
                                Substituting "CXXCPPFLAGS" with ""
                                Substituting "FC" with "/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90"
                                Substituting "FFLAGS" with " "
                                Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
                                Substituting "LDFLAGS" with ""
                                Substituting "LIBS" with "-ldl "
                                Substituting "SHARED_LIBRARY_FLAG" with "-shared"
                                  Defined make macro "MPICC_SHOW" to "gcc -fPIC -g3 -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,-rpath -Wl,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,--enable-new-dtags -lmpi"
                                  Defined make macro "MPICXX_SHOW" to "g++ -g -fPIC -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lmpicxx -Wl,-rpath -Wl,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,--enable-new-dtags -lmpi"
                                  Defined make macro "MPIFC_SHOW" to "gfortran -fPIC -ffree-line-length-0 -g -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lmpifort -Wl,-rpath -Wl,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,--enable-new-dtags -lmpi"
TEST configureCompilerFlags from config.compilerFlags(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilerFlags.py:72)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:72)
  Get the default compiler flags
                            Trying C compiler flag -Wall
                            Trying C compiler flag -Wwrite-strings
                            Trying C compiler flag -Wno-strict-aliasing
                            Trying C compiler flag -Wno-unknown-pragmas
                            Trying C compiler flag -fvisibility=hidden
                            Trying C compiler flag -g3
                            Trying Cxx compiler flag -Wall
                            Trying Cxx compiler flag -Wwrite-strings
                            Trying Cxx compiler flag -Wno-strict-aliasing
                            Trying Cxx compiler flag -Wno-unknown-pragmas
                            Trying Cxx compiler flag -fvisibility=hidden
                            Trying Cxx compiler flag -g
                            Trying FC compiler flag -Wall
                            Trying FC compiler flag -ffree-line-length-0
                            Trying FC compiler flag -Wno-unused-dummy-argument
                            Trying FC compiler flag -Wno-unused-variable
                            Trying FC compiler flag -g
                              Pushing language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers    -Wall   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wall
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers    -Wall -Wwrite-strings   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wwrite-strings
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-strict-aliasing
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-unknown-pragmas
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fvisibility=hidden
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3   /tmp/petsc-W4It8W/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -g3
                              Popping language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.missing  -Wall      /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wall
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.missing  -Wall -Wwrite-strings      /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wwrite-strings
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing      /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-strict-aliasing
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas      /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-unknown-pragmas
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden      /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fvisibility=hidden
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.setCompilers -I/tmp/petsc-W4It8W/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g      /tmp/petsc-W4It8W/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -g
                              Pushing language FC
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers   -Wall   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wall
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers   -Wall -ffree-line-length-0   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -ffree-line-length-0
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-dummy-argument
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-variable
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g   /tmp/petsc-W4It8W/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -g
                              Popping language FC
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc --version
stdout:
gcc (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
getCompilerVersion: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc gcc (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -show
stdout: gcc -fPIC -g3 -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,-rpath -Wl,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,--enable-new-dtags -lmpi
Executing: gcc --help
stdout:
Usage: gcc [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase
  --help                   Display this information
  --target-help            Display target specific command line options
  --help={target|optimizers|warnings|params|[^]{joined|separate|undocumented}}[,...]
                           Display specific types of command line options
  (Use '-v --help' to display command line options of sub-processes)
  --version                Display compiler version information
  -dumpspecs               Display all of the built in spec strings
  -dumpversion             Display the version of the compiler
  -dumpmachine             Display the compiler's target processor
  -print-search-dirs       Display the directories in the compiler's search path
  -print-libgcc-file-name  Display the name of the compiler's companion library
  -print-file-name=<lib>   Display the full path to library <lib>
  -print-prog-name=<prog>  Display the full path to compiler component <prog>
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path
  -print-multi-directory   Display the root directory for versions of libgcc
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories
  -print-multi-os-directory Display the relative path to OS libraries
  -print-sysroot           Display the target libraries directory
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers
  -Wa,<options>            Pass comma-separated <options> on to the assembler
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor
  -Wl,<options>            Pass comma-separated <options> on to the linker
  -Xassembler <arg>        Pass <arg> on to the assembler
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor
  -Xlinker <arg>           Pass <arg> on to the linker
  -save-temps              Do not delete intermediate files
  -save-temps=<arg>        Do not delete intermediate files
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components
  -pipe                    Use pipes rather than intermediate files
  -time                    Time the execution of each subprocess
  -specs=<file>            Override built-in specs with the contents of <file>
  -std=<standard>          Assume that the input sources are for <standard>
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries
  -B <directory>           Add <directory> to the compiler's search paths
  -v                       Display the programs invoked by the compiler
  -###                     Like -v but options quoted and commands not executed
  -E                       Preprocess only; do not compile, assemble or link
  -S                       Compile only; do not assemble or link
  -c                       Compile and assemble, but do not link
  -o <file>                Place the output into <file>
  -x <language>            Specify the language of the following input files
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by gcc.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<file:///usr/share/doc/gcc-4.6/README.Bugs>.
stdout:
Options:
                           and libraries
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx --version
stdout:
g++ (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
getCompilerVersion: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx g++ (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicxx -show
stdout: g++ -g -fPIC -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lmpicxx -Wl,-rpath -Wl,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,--enable-new-dtags -lmpi
Executing: g++ --help
stdout:
Usage: g++ [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by g++.  In order to pass
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 --version
stdout:
GNU Fortran (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
getCompilerVersion: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 GNU Fortran (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90 -show
stdout: gfortran -fPIC -ffree-line-length-0 -g -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -I/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lmpifort -Wl,-rpath -Wl,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,--enable-new-dtags -lmpi
Executing: gfortran --help
stdout:
Usage: gfortran [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by gfortran.  In order to pass
Executing: gfortran --version
stdout:
stdout:
stdout:
                                      Pushing language C
                                      Popping language C
                                      Pushing language C
                                      Popping language C
                                      Pushing language C
                                      Popping language C
                                      Pushing language C
                                      Popping language C
                                    Pushing language C
                                    Popping language C
                                        Pushing language FC
                                        Popping language FC
                                        Pushing language FC
                                        Popping language FC
                                            Pushing language FC
                                            Popping language FC
                              Defined make macro "C_DEPFLAGS" to "-MMD -MP"
                              Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
                              Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
                            Accepted C99 compile flag: -std=c99
                                    Pushing language CXX
                                    Popping language CXX
                                        Pushing language C
                                        Popping language C
                                        Pushing language C
                                        Popping language C
                                            Pushing language C
                                            Popping language C
                                        Pushing language FC
                                        Popping language FC
                                        Pushing language FC
                                        Popping language FC
                                            Pushing language FC
                                            Popping language FC
                                        Pushing language FC
                                        Popping language FC
                                        Pushing language FC
                                        Popping language FC
                              Defined make macro "FC_DEFINE_FLAG" to "-D"
                                    Pushing language FC
                                    Popping language FC
                                        Pushing language C
                                        Popping language C
                                        Pushing language C
                                        Popping language C
                                            Pushing language C
                                            Popping language C
                                        Pushing language FC
                                        Popping language FC
                                      Pushing language FC
                                      Popping language FC
                                      Pushing language FC
                                      Popping language FC
                                      Pushing language FC
                                      Popping language FC
                                          Pushing language FC
                                          Popping language FC
                                      Pushing language FC
                                      Popping language FC
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc --help
stdout:
Options:
                           and libraries
TEST checkRestrict from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:137)
TESTING: checkRestrict from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:137)
  Check for the C/CXX restrict keyword
Pushing language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.compilers/conftest.o -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8W/PETSc.options.scalarTypes -I/tmp/petsc-W4It8W/config.compilers -I/tmp/petsc-W4It8W/config.libraries -I/tmp/petsc-W4It8W/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3  /tmp/petsc-W4It8W/config.compilers/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-W4It8W/config.compilers/conftest.c: In function ?main?:
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:18: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?x?
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:18: error: ?x? undeclared (first use in this function)
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:18: note: each undeclared identifier is reported only once for each function it appears in
Source:
int main() {
float * restrict x;;
  return 0;
stderr:
/tmp/petsc-W4It8W/config.compilers/conftest.c:5:23: warning: unused variable ?x? [-Wunused-variable]
Source:
int main() {
float *  __restrict__ x;;
  return 0;
compilers: Set C restrict keyword to  __restrict__
Defined "C_RESTRICT" to " __restrict__"
Popping language C
TEST checkCFormatting from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:321)
TESTING: checkCFormatting from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:321)
  Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:108)
TESTING: checkCStaticInline from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:108)
  Check for C keyword: static inline
Pushing language C
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
compilers: Set C StaticInline keyword to static inline
Popping language C
Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:332)
TESTING: checkDynamicLoadFlag from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:332)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
  return 0;
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.compilers/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.compilers/conftest.o -ldl
Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
  return 0;
Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
  return 0;
Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
  return 0;
Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:168)
TESTING: checkCLibraries from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:168)
  Determines the libraries needed to link with C
Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc  -o /tmp/petsc-W4It8W/config.compilers/conftest  -v     -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g3 /tmp/petsc-W4It8W/config.compilers/conftest.o -ldl
stdout: mpicc for MPICH version 3.1.3
Possible ERROR while running linker:
stdout:
mpicc for MPICH version 3.1.3stderr:
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.4-1ubuntu1~12.04' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.6.4 (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04)
COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-fPIC' '-g3' '-o' '/tmp/petsc-W4It8W/config.compilers/conftest' '-v' '-Wall' '-Wwrite-strings' '-Wno-strict-aliasing' '-Wno-unknown-pragmas' '-fvisibility=hidden' '-g3' '-I' '/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/include' '-L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib' '-mtune=generic' '-march=x86-64'
 /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2 --sysroot=/ --build-id --no-add-needed --as-needed --eh-frame-hdr -m elf_x86_64 --hash-style=gnu -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o /tmp/petsc-W4It8W/config.compilers/conftest /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. /tmp/petsc-W4It8W/config.compilers/conftest.o -ldl -rpath /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib --enable-new-dtags -lmpi -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
Popping language C
compilers: Checking arg mpicc
compilers: Unknown arg mpicc
compilers: Checking arg for
compilers: Unknown arg for
compilers: Checking arg MPICH
compilers: Unknown arg MPICH
compilers: Checking arg version
compilers: Unknown arg version
compilers: Checking arg 3.1.3
compilers: Unknown arg 3.1.3
compilers: Checking arg Using
compilers: Unknown arg Using
compilers: Checking arg built-in
compilers: Unknown arg built-in
compilers: Checking arg specs.
compilers: Unknown arg specs.
compilers: Checking arg COLLECT_GCC=gcc
compilers: Unknown arg COLLECT_GCC=gcc
compilers: Checking arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
compilers: Unknown arg COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
compilers: Checking arg Target:
compilers: Unknown arg Target:
compilers: Checking arg x86_64-linux-gnu
compilers: Unknown arg x86_64-linux-gnu
compilers: Checking arg Configured
compilers: Unknown arg Configured
compilers: Checking arg with:
compilers: Unknown arg with:
compilers: Checking arg ../src/configure
compilers: Unknown arg ../src/configure
compilers: Checking arg -v
compilers: Unknown arg -v
compilers: Checking arg --with-pkgversion=
compilers: Unknown arg --with-pkgversion=
compilers: Checking arg --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs
compilers: Unknown arg --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs
compilers: Checking arg --enable-languages=c,c++,fortran,objc,obj-c++
compilers: Unknown arg --enable-languages=c,c++,fortran,objc,obj-c++
compilers: Checking arg --prefix=/usr
compilers: Unknown arg --prefix=/usr
compilers: Checking arg --program-suffix=-4.6
compilers: Unknown arg --program-suffix=-4.6
compilers: Checking arg --enable-shared
compilers: Unknown arg --enable-shared
compilers: Checking arg --enable-linker-build-id
compilers: Unknown arg --enable-linker-build-id
compilers: Checking arg --with-system-zlib
compilers: Unknown arg --with-system-zlib
compilers: Checking arg --libexecdir=/usr/lib
compilers: Unknown arg --libexecdir=/usr/lib
compilers: Checking arg --without-included-gettext
compilers: Unknown arg --without-included-gettext
compilers: Checking arg --enable-threads=posix
compilers: Unknown arg --enable-threads=posix
compilers: Checking arg --with-gxx-include-dir=/usr/include/c++/4.6
compilers: Unknown arg --with-gxx-include-dir=/usr/include/c++/4.6
compilers: Checking arg --libdir=/usr/lib
compilers: Unknown arg --libdir=/usr/lib
compilers: Checking arg --enable-nls
compilers: Unknown arg --enable-nls
compilers: Checking arg --with-sysroot=/
compilers: Unknown arg --with-sysroot=/
compilers: Checking arg --enable-clocale=gnu
compilers: Unknown arg --enable-clocale=gnu
compilers: Checking arg --enable-libstdcxx-debug
compilers: Unknown arg --enable-libstdcxx-debug
compilers: Checking arg --enable-libstdcxx-time=yes
compilers: Unknown arg --enable-libstdcxx-time=yes
compilers: Checking arg --enable-gnu-unique-object
compilers: Unknown arg --enable-gnu-unique-object
compilers: Checking arg --enable-plugin
compilers: Unknown arg --enable-plugin
compilers: Checking arg --enable-objc-gc
compilers: Unknown arg --enable-objc-gc
compilers: Checking arg --disable-werror
compilers: Unknown arg --disable-werror
compilers: Checking arg --with-arch-32=i686
compilers: Unknown arg --with-arch-32=i686
compilers: Checking arg --with-tune=generic
compilers: Unknown arg --with-tune=generic
compilers: Checking arg --enable-checking=release
compilers: Unknown arg --enable-checking=release
compilers: Checking arg --build=x86_64-linux-gnu
compilers: Unknown arg --build=x86_64-linux-gnu
compilers: Checking arg --host=x86_64-linux-gnu
compilers: Unknown arg --host=x86_64-linux-gnu
compilers: Checking arg --target=x86_64-linux-gnu
compilers: Unknown arg --target=x86_64-linux-gnu
compilers: Checking arg Thread
compilers: Unknown arg Thread
compilers: Checking arg model:
compilers: Unknown arg model:
compilers: Checking arg posix
compilers: Unknown arg posix
compilers: Checking arg gcc
compilers: Unknown arg gcc
compilers: Checking arg 4.6.4
compilers: Unknown arg 4.6.4
compilers: Checking arg (Ubuntu/Linaro
compilers: Unknown arg (Ubuntu/Linaro
compilers: Checking arg 4.6.4-1ubuntu1~12.04)
compilers: Unknown arg 4.6.4-1ubuntu1~12.04)
compilers: Checking arg COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/
compilers: Unknown arg COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/
compilers: Checking arg LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../:/lib/:/usr/lib/
compilers: Unknown arg LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.6/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../:/lib/:/usr/lib/
compilers: Checking arg COLLECT_GCC_OPTIONS=
compilers: Unknown arg COLLECT_GCC_OPTIONS=
compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2
compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/collect2
compilers: Checking arg --sysroot=/
compilers: Unknown arg --sysroot=/
compilers: Checking arg --build-id
compilers: Unknown arg --build-id
compilers: Checking arg --no-add-needed
compilers: Unknown arg --no-add-needed
compilers: Checking arg --as-needed
compilers: Unknown arg --as-needed
compilers: Checking arg --eh-frame-hdr
compilers: Unknown arg --eh-frame-hdr
compilers: Checking arg -m
compilers: Unknown arg -m
compilers: Checking arg elf_x86_64
compilers: Unknown arg elf_x86_64
compilers: Checking arg --hash-style=gnu
compilers: Unknown arg --hash-style=gnu
compilers: Checking arg -dynamic-linker
compilers: Unknown arg -dynamic-linker
compilers: Checking arg /lib64/ld-linux-x86-64.so.2
compilers: Unknown arg /lib64/ld-linux-x86-64.so.2
compilers: Checking arg -z
compilers: Unknown arg -z
compilers: Checking arg relro
compilers: Unknown arg relro
compilers: Checking arg -o
compilers: Unknown arg -o
compilers: Checking arg /tmp/petsc-W4It8W/config.compilers/conftest
compilers: Unknown arg /tmp/petsc-W4It8W/config.compilers/conftest
compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o
compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o
compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o
compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o
compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o
compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbegin.o
compilers: Checking arg -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib
compilers: Found library directory: -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib
compilers: Checking arg -L/usr/lib/gcc/x86_64-linux-gnu/4.6
compilers: Found library directory: -L/usr/lib/gcc/x86_64-linux-gnu/4.6
compilers: Checking arg -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu
compilers: Found library directory: -L/usr/lib/x86_64-linux-gnu
compilers: Checking arg -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib
compilers: Checking arg -L/lib/x86_64-linux-gnu
compilers: Found library directory: -L/lib/x86_64-linux-gnu
compilers: Checking arg -L/lib/../lib
compilers: Checking arg -L/usr/lib/x86_64-linux-gnu
compilers: Checking arg -L/usr/lib/../lib
compilers: Checking arg /tmp/petsc-W4It8W/config.compilers/conftest.o
compilers: Unknown arg /tmp/petsc-W4It8W/config.compilers/conftest.o
compilers: Checking arg -ldl
compilers: Found library : -ldl
compilers: Checking arg -rpath
compilers: Found -rpath library: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib
compilers: Checking arg --enable-new-dtags
compilers: Unknown arg --enable-new-dtags
compilers: Checking arg -lmpi
compilers: Found library : -lmpi
compilers: Checking arg -lgcc
compilers: Skipping system library: -lgcc
compilers: Checking arg -lgcc_s
compilers: Found library : -lgcc_s
compilers: Checking arg --no-as-needed
compilers: Unknown arg --no-as-needed
compilers: Checking arg -lc
compilers: Skipping system library: -lc
compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o
compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/crtend.o
compilers: Checking arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
compilers: Unknown arg /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o
compilers: Libraries needed to link C code with another linker: ['-Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib', '-L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib', '-Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6', '-L/usr/lib/gcc/x86_64-linux-gnu/4.6', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-Wl,-rpath,/lib/x86_64-linux-gnu', '-L/lib/x86_64-linux-gnu', '-Wl,-rpath,/usr/lib/x86_64-linux-gnu', '-L/usr/lib/x86_64-linux-gnu', '-ldl', '-Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib', '-lmpi', '-lgcc_s']
compilers: Check that C libraries can be used from Fortran
                                Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90  -o /tmp/petsc-W4It8W/config.setCompilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
      program main
      end
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpif90  -o /tmp/petsc-W4It8W/config.setCompilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -Wno-unused-variable -g /tmp/petsc-W4It8W/config.setCompilers/conftest.o -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -L/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -ldl -Wl,-rpath,/home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
Testing executable /tmp/petsc-W4It8W/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-W4It8W/config.setCompilers/conftest
                                Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1377)
TESTING: checkDependencyGenerationFlag from config.compilers(/home/tisaac/Projects/petsc/config/BuildSystem/config/compilers.py:1377)
  Check if -MMD works for dependency generation, and add it if it does
Trying C compiler flag -MMD -MP
                              Pushing language C
Executing: /home/tisaac/Projects/petsc/arch-linux2-c-debug-mpich/bin/mpicc -c -o /tmp/petsc-W4It8W/config.setCompilers/conftest.o -I/tmp/petsc-W4It8W/config.utilities.closure -I/tmp/petsc-W4It8W/config.headers -I/tmp/petsc-W4It8W/config.utilities.cacheDetails -I/tmp/petsc-W4It8W/config.types -I/tmp/petsc-W4It8W/config.atomics -I/tmp/petsc-W4It8W/config.functions -I/tmp/petsc-W4It8W/config.utilities.featureTestMacros -I/tmp/petsc-W4It8W/config.utilities.missing -I/tmp/petsc-W4It8
