[petsc-users] how to output components of a section
leejearl leejearl at 126.com
Thu Nov 10 07:04:26 CST 2016
Hi Matt:
     It is okay. I will wait for your coding.
     Thanks
leejearl
On 2016年11月10日 18:42, Matthew Knepley wrote:
> On Wed, Nov 9, 2016 at 11:54 PM, leejearl <leejearl at 126.com
> <mailto:leejearl at 126.com>> wrote:
>     Hi, Matt
>         Thanks for your reply, and will it be solved in the newest
>     version of PETSc?
> Yes, we are just working out how to do it. I might not actually code
> it until classes end Dec. 2. Is that
> an okay timeline?
>   Thanks,
>      Matt
>     leejearl
>     On 2016年11月07日 20:09, Matthew Knepley wrote:
>>     On Mon, Nov 7, 2016 at 4:17 AM, Sander Arens
>>     <Sander.Arens at ugent.be <mailto:Sander.Arens at ugent.be>> wrote:
>>         Ok, I see what happened.
>>         If you create a a vector with DMGetGlobalVector, the VecView
>>         function is overloaded with some DM-specific VecView function
>>         (e.g. VecView_Plex), but this doesn't happen with the vec
>>         that you get from VecGetSubVector. So one way to solve this
>>         would be to create a global vector from your subdm and do the
>>         scatters yourself.
>>         But I think it would be better if these VecView operations
>>         could be copied from the original vec in VecGetSubVector?
>>     You are right. I am moving this to petsc-dev temporarily for
>>     discussion.
>>       Thanks,
>>         Matt
>>         Thanks,
>>         Sander
>>         On 7 November 2016 at 09:08, leejearl <leejearl at 126.com
>>             Hi Sander:
>>                 Thank your for your assistance, but it is still not
>>             works. The code is now as follows:
>>                     Vec subX, X;
>>                     DM subdm;
>>                     IS subIS;
>>                     PetscInt numSubFields = 2;
>>                     PetscInt subFields[2];
>>                     subFields[0] = 0; subFields[1] =1 ;
>>                     ierr = DMCreateSubDM(dm, numSubFields, subFields,
>>             &subIS, &subdm);CHKERRQ(ierr);
>>                     ierr = DMGetGlobalVector(dm, &X);CHKERRQ(ierr);
>>                     ierr = VecGetSubVector(X,subIS,&subX);CHKERRQ(ierr);
>>                     ierr = VecSetDM(subX, dm);CHKERRQ(ierr);
>>                       ierr = PetscObjectSetName((PetscObject) subX,
>>                 "sol.");CHKERRQ(ierr);
>>                         ierr = PetscViewerSetType(*viewer,
>>                 PETSCVIEWERVTK);CHKERRQ(ierr);
>>                        ierr = PetscViewerPushFormat(*viewer,
>>                 PETSC_VIEWER_VTK_VTU);CHKERRQ(ierr);
>>                         ierr = PetscViewerFileSetName(*viewer,
>>                 "subsol.vtu");CHKERRQ(ierr);
>>                         ierr = VecView(subX, viewer);CHKERRQ(ierr);
>>                         ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>>                         ierr = VecRestoreSubVector(X, subIS,
>>                 DMDestroy(&subdm);
>>                         ierr = DMRestoreGlobalVector(dm,
>>                 &X);CHKERRQ(ierr);
>>             I have add "VecSetDm", but it has not output file.
>>             Thanks
>>             leejearl
>>             On 2016年11月07日 15:35, Sander Arens wrote:
>>>             Does it work if you put
>>>             ierr = VecSetDM(subX, subdm);CHKERRQ(ierr);
>>>             before the VecView?
>>>             Thanks,
>>>             Sander
>>>             On 7 November 2016 at 03:50, leejearl <leejearl at 126.com
>>>                 Hi, Barry:
>>>                     I must have some make some mistakes. I post the
>>>                 code as follows:
>>>                         Vec subX, X;
>>>                         DM subdm;
>>>                         IS subIS;
>>>                 subFields, &subIS, &subdm);CHKERRQ(ierr);
>>>                         ierr =
>>>                 subX, "sol.");CHKERRQ(ierr);
>>>                         ierr =
>>>                 DMDestroy(&subdm);
>>>                 &X);CHKERRQ(ierr);
>>>                 There are three fields in dm, and I want to obtain
>>>                 the vector of the two of them. But, I can not
>>>                 get the output file “subsol.vtu”. Can you help me
>>>                 with the code?
>>>                 Thanks
>>>                 leejearl
>>>                 On 2016年11月06日 12:21, Barry Smith wrote:
>>>                         On Nov 5, 2016, at 8:36 PM, leejearl
>>>                         <leejearl at 126.com <mailto:leejearl at 126.com>>
>>>                         wrote:
>>>                         Hi Sander:
>>>                              Thank you for your advices, and it
>>>                         works. But it is only available in th local
>>>                         vector.
>>>                        This should work on the global vector. Please
>>>                     send the full output of the error messages when
>>>                     used with a global vector.
>>>                         Barry
>>>                         Is there any methods to reach this purposes
>>>                         in the global vector?
>>>                              Thanks
>>>                         leejearl
>>>                         On 2016年11月05日 19:29, Sander Arens wrote:
>>>                             You can first obtain an IS with
>>>                             http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateSubDM.html
>>>                             <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateSubDM.html>
>>>                             and with that you can obtain a subvector
>>>                             with
>>>                             http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetSubVector.html
>>>                             <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetSubVector.html>
>>>                             which you can then view the usual way.
>>>                             Thanks,
>>>                             Sander
>>>                             On 5 November 2016 at 12:17, leejearl
>>>                             Hi, all:
>>>                                  I meet a problems which I can not
>>>                             overcome. The programe is like the code in
>>>                             "http://www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/plex/examples/tutorials/ex1.c.html
>>>                             <http://www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/plex/examples/tutorials/ex1.c.html>".
>>>                                 The code create a section which has
>>>                             three fields: u,v,w. How can I output
>>>                             the fields u and v without together with w?
>>>                                 Thanks!
>>>                             leejearl
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
>     李季
>     西北工业大学航空学院流体力学系
>     Phone:17792092487 <tel:17792092487>
>     QQ: 188524324
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
李季
西北工业大学航空学院流体力学系
Phone: 17792092487
QQ: 188524324
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161110/a89a6f55/attachment-0001.html>
