[petsc-users] PetscFE and TS
Julian Andrej juan at tf.uni-kiel.de
Wed Nov 9 00:32:38 CST 2016
I tested a few other things and it turned out that the function added
as a dirichlet boundary condition via PetscDSAddBoundary doesn't
receive the time values correctly (PetscReal time is always 0.0).
I also see no effect adding DMTSSetIJacobianLocal vs. not setting the
jacobian function. The analytic solution i used in my attached example
is the same as in the src/ts/examples/tutorials/ex32.c.
Am i doing anything obviously wrong here? My next step would be to try
if assembling the matrices myself and writing a custom
IFunction/IJacobian which assembles the different parts of the matrix
like M and J for the stiff ODE with nontrivial mass matrix (see manual
section of TS -> F = M u' - f) but i think this should be obsolete
right?
Appreciate your help.
Regards
Julian
On Mon, Nov 7, 2016 at 10:49 AM, Julian Andrej <juan at tf.uni-kiel.de> wrote:
> Hello,
> i'm using PetscFE in combination with SNES and a hand written backward
> euler solver right now and like to hand that over to TS. I have been
> fiddling quite a while getting TS to work with PetscFE and have
> encountered a few unclarities.
> I have looked at examples which are outdated i guess
> (src/ts/examples/tutorials/ex32.c) and i am confused on how i have to
> formulate the discretization of the jacobian and the residual. It
> seems obvious to use the DMTSSetIFunctionLocal and
> DMTSSetIJacobianLocal functions because there are prepared wrappers
> from DMPlexTSComputeIFunctionFEM and DMPlexTSComputeIJacobianFEM.
> I need a Mass matrix for my problem, is that formed from the function
> space information or do i have to form it myself? Is there any working
> example which uses PetscFE and TS to form the DMTSSetIFunctionLocal
> and DMTSSetIJacobianLocal? (grepping the tree tells me "no"
> unfortunately).
> Regards
> Julian
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161109/69125cdd/attachment.c>
