[petsc-users] How to dump and load a petsc object in python?
Ji Zhang gotofd at gmail.com
Tue Nov 8 02:57:03 CST 2016
Dear all,
I'm a petsc and petsc4py user. I want to save some petsc matrices and
vectors after calculation, and reload them later. However, it is difficult
for me. I think one of the following two ways may have the potential to
perform what I want.
1) Using the pickle (a python module), I can not load the dates after dump
them, and the error message is limited. I don't know why. The related codes
and error messages are presented latter.
2) Assuming I have a matrix named mat1, and save it to a binary file using
petsc4py.PETSc.Viewer.createBinary() method, how can I reload the date and
set to another matrix mat2 ?
The code is:
import pickle
filename = 'debug'
with open(filename + '.pickle', 'rb') as input:
    unpick = pickle.Unpickler(input)
    M = unpick.load()
    temp = M.getVecLeft()
pass
and the error message is:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
with errorcode 59.
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
You may or may not see output from other processes, depending on
[0]PETSC ERROR: to get more information on the crash.
exactly when Open MPI kills them.
此致
    敬礼
张骥(博士研究生)
北京计算科学研究中心
北京市海淀区西北旺东路10号院东区9号楼 (100193)
Best,
Zhang Ji, PhD student
Beijing Computational Science Research Center
Zhongguancun Software Park II, No. 10 Dongbeiwang West Road, Haidian
District, Beijing 100193, China
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161108/9738aec4/attachment.html>
