[petsc-users] how to output components of a section
Sander Arens Sander.Arens at ugent.be
Mon Nov 7 04:17:00 CST 2016
Ok, I see what happened.
If you create a a vector with DMGetGlobalVector, the VecView function is
overloaded with some DM-specific VecView function (e.g. VecView_Plex), but
this doesn't happen with the vec that you get from VecGetSubVector. So one
way to solve this would be to create a global vector from your subdm and do
the scatters yourself.
But I think it would be better if these VecView operations could be copied
from the original vec in VecGetSubVector?
Sander
On 7 November 2016 at 09:08, leejearl <leejearl at 126.com> wrote:
> Hi Sander:
>     Thank your for your assistance, but it is still not works. The code is
> now as follows:
>         Vec subX, X;
>         DM subdm;
>         IS subIS;
>         PetscInt numSubFields = 2;
>         PetscInt subFields[2];
>         subFields[0] = 0; subFields[1] =1 ;
>         ierr = DMCreateSubDM(dm, numSubFields, subFields, &subIS,
> &subdm);CHKERRQ(ierr);
>         ierr = DMGetGlobalVector(dm, &X);CHKERRQ(ierr);
>         ierr = VecGetSubVector(X,subIS,&subX);CHKERRQ(ierr);
>         ierr = VecSetDM(subX, dm);CHKERRQ(ierr);
>>         ierr = PetscObjectSetName((PetscObject) subX,
>> "sol.");CHKERRQ(ierr);
>>         ierr = PetscViewerSetType(*viewer, PETSCVIEWERVTK);CHKERRQ(ierr);
>>        ierr = PetscViewerPushFormat(*viewer,
>> PETSC_VIEWER_VTK_VTU);CHKERRQ(ierr);
>>         ierr = PetscViewerFileSetName(*viewer,
>> "subsol.vtu");CHKERRQ(ierr);
>>         ierr = VecView(subX, viewer);CHKERRQ(ierr);
>>         ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>>         ierr = VecRestoreSubVector(X, subIS, &subX);CHKERRQ(ierr);
>>         DMDestroy(&subdm);
>>         ierr = DMRestoreGlobalVector(dm, &X);CHKERRQ(ierr);
> I have add "VecSetDm", but it has not output file.
> Thanks
> leejearl
> On 2016年11月07日 15:35, Sander Arens wrote:
> Does it work if you put
> ierr = VecSetDM(subX, subdm);CHKERRQ(ierr);
> before the VecView?
> Thanks,
> Sander
> On 7 November 2016 at 03:50, leejearl <leejearl at 126.com> wrote:
>> Hi, Barry:
>>     I must have some make some mistakes. I post the code as follows:
>>         Vec subX, X;
>>         DM subdm;
>>         IS subIS;
>>         DMDestroy(&subdm);
>> There are three fields in dm, and I want to obtain the vector of the two
>> of them. But, I can not
>> get the output file “subsol.vtu”. Can you help me with the code?
>> Thanks
>> leejearl
>> On 2016年11月06日 12:21, Barry Smith wrote:
>>> On Nov 5, 2016, at 8:36 PM, leejearl <leejearl at 126.com> wrote:
>>>> Hi Sander:
>>>>      Thank you for your advices, and it works. But it is only available
>>>> in th local vector.
>>>    This should work on the global vector. Please send the full output of
>>> the error messages when used with a global vector.
>>>     Barry
>>> Is there any methods to reach this purposes in the global vector?
>>>>      Thanks
>>>> leejearl
>>>> On 2016年11月05日 19:29, Sander Arens wrote:
>>>>> You can first obtain an IS with
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>> DM/DMCreateSubDM.html
>>>>> and with that you can obtain a subvector with
>>>>> Vec/VecGetSubVector.html
>>>>> which you can then view the usual way.
>>>>> Thanks,
>>>>> Sander
>>>>> On 5 November 2016 at 12:17, leejearl <leejearl at 126.com> wrote:
>>>>> Hi, all:
>>>>>      I meet a problems which I can not overcome. The programe is like
>>>>> the code in
>>>>> "http://www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/ple
>>>>> x/examples/tutorials/ex1.c.html".
>>>>>     The code create a section which has three fields: u,v,w. How can I
>>>>> output the fields u and v without together with w?
>>>>>     Thanks!
>>>>> leejearl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161107/1e266af1/attachment-0001.html>
