[petsc-users] strange error during configuration
Michael Povolotskyi mpovolot at purdue.edu
Sun Nov 6 01:03:00 CST 2016
Dear Petsc developers,
I'm trying to execute
./config/configure.py --with-x=0 --with-hdf5 \
--with-hdf5-include=/usr/include \
--with-hdf5-lib=/usr/lib/libhdf5.so\
  --with-scalar-type=real --with-single-library=1\
   --with-pic=1 --with-shared-libraries=0  --with-log=0 \
          --with-clanguage=C++ --CXXFLAGS=-fopenmp --with-fortran=1 \
--with-debugging=0 --with-cc="mpicc" --with-fc="mpif90"
--with-cxx="mpic++" COPTFLAGS="-O3"   CXXOPTFLAGS="-O3" FOPTFLAGS="-O3"
--download-metis=1 \
--download-parmetis=1  --with-valgrind-dir= /usr/include/valgrind \
         --download-mumps=1 --with-fortran-kernels=0 \
         --download-superlu_dist=1 \
         --with-blas-lapack-lib ="-L/opt/intel/mkl/lib/intel64
-lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core " \
  --with-blacs-lib=/opt/intel/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so \
--with-blacs-include=/opt/intel/mkl/include \
--with-scalapack-lib="-Wl,-rpath,/opt/intel/mkl/lib/intel64
-L/opt/intel/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_gnu_thread
-lmkl_core  -lpthread  -L/opt/intel/mkl/lib/intel64 -lmkl_scalapack_lp64
-lmkl_blacs_intelmpi_lp64" \
--with-scalapack-include=/opt/intel/mkl/include
and I get a strange error:
  UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
You set a value for --with-blas-lapack-lib=<lib>, but ['1'] cannot be used
The log file is attached.
Please advise.
Thank you,
Michael.
                            Pushing language C
                            Popping language C
                            Pushing language CUDA
                            Popping language CUDA
                            Pushing language Cxx
                            Popping language Cxx
                            Pushing language FC
                            Popping language FC
Starting Configure Run at Sun Nov  6 01:52:04 2016
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-x=0 --with-hdf5 --with-hdf5-include=/usr/include --with-hdf5-lib=/usr/lib/libhdf5.so --with-scalar-type=real --with-single-library=1 --with-pic=1 --with-shared-libraries=0 --with-log=0 --with-clanguage=C++ --CXXFLAGS=-fopenmp --with-fortran=1 --with-debugging=0 --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpic++ COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 --download-metis=1 --download-parmetis=1 --with-valgrind-dir= /usr/include/valgrind --download-mumps=1 --with-fortran-kernels=0 --download-superlu_dist=1 --with-blas-lapack-lib ="-L/opt/intel/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core " --with-blacs-lib=/opt/intel/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so --with-blacs-include=/opt/intel/mkl/include --with-scalapack-lib="-Wl,-rpath,/opt/intel/mkl/lib/intel64 -L/opt/intel/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core  -lpthread  -L/opt/intel/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64" --with-scalapack-include=/opt/intel/mkl/include
Working directory: /home/mpovolot/NEMO5/NEMO/libs/petsc/build-real
Machine platform:
('Linux', 'ncnlnx15.ecn.purdue.edu', '4.0.5-200.fc21.x86_64', '#1 SMP Mon Jun 8 16:25:02 UTC 2015', 'x86_64', 'x86_64')
Python version:
2.7.8 (default, Sep 24 2015, 18:26:19)
[GCC 4.9.2 20150212 (Red Hat 4.9.2-6)]
        Pushing language C
        Popping language C
        Pushing language FC
        Popping language FC
TEST configureExternalPackagesDir from config.framework(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/framework.py:834)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:834)
TEST configureDebuggers from config.utilities.debuggers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
Checking for program ./gdb...not found
Checking for program /home/mpovolot/bin/gdb...not found
Checking for program /bin/gdb...found
              Defined make macro "GDB" to "/bin/gdb"
Checking for program ./dbx...not found
Checking for program /home/mpovolot/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/local/visit/bin/dbx...not found
Checking for program /opt/matlab/bin/dbx...not found
Checking for program /home/mpovolot/dbx...not found
Checking for program ./xdb...not found
Checking for program /home/mpovolot/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/local/visit/bin/xdb...not found
Checking for program /opt/matlab/bin/xdb...not found
Checking for program /home/mpovolot/xdb...not found
Checking for program ./dsymutil...not found
Checking for program /home/mpovolot/bin/dsymutil...not found
Checking for program /bin/dsymutil...not found
Checking for program /usr/bin/dsymutil...not found
Checking for program /usr/local/bin/dsymutil...not found
Checking for program /usr/local/visit/bin/dsymutil...not found
Checking for program /opt/matlab/bin/dsymutil...not found
Checking for program /home/mpovolot/dsymutil...not found
            Defined make macro "DSYMUTIL" to "true"
            Defined "USE_GDB_DEBUGGER" to "1"
TEST configureGit from config.sourceControl(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program ./git...not found
Checking for program /home/mpovolot/bin/git...not found
Checking for program /bin/git...found
              Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.1.0
TEST configureMercurial from config.sourceControl(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
  Find the Mercurial executable
Checking for program ./hg...not found
Checking for program /home/mpovolot/bin/hg...not found
Checking for program /bin/hg...not found
Checking for program /usr/bin/hg...not found
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/local/visit/bin/hg...not found
Checking for program /opt/matlab/bin/hg...not found
Checking for program /home/mpovolot/hg...not found
TEST configureCLanguage from PETSc.options.languages(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
          C language is Cxx
            Defined "CLANGUAGE_CXX" to "1"
TEST configureDirectories from PETSc.options.petscdir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
          Version Information:
          #define PETSC_VERSION_RELEASE    1
          #define PETSC_VERSION_MAJOR      3
          #define PETSC_VERSION_MINOR      7
          #define PETSC_VERSION_SUBMINOR   2
          #define PETSC_VERSION_PATCH      0
          #define PETSC_VERSION_DATE       "Jun, 05, 2016"
          #define PETSC_VERSION_GIT        "v3.7.2"
          #define PETSC_VERSION_DATE_GIT   "2016-06-05 12:07:54 -0500"
          #define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
          #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
            Defined make macro "DIR" to "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real"
TEST getDatafilespath from PETSc.options.dataFilesPath(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
          This is a tarball installation
TEST configureArchitecture from PETSc.options.arch(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/arch.py:25)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:25)
  Checks PETSC_ARCH and sets if not set
            Defined "ARCH" to ""linux""
TEST setInstallDir from PETSc.options.installDir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:35)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.options.installDir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/installDir.py:74)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:74)
TEST cleanInstallDir from PETSc.options.installDir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/installDir.py:67)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:67)
TEST configureInstallDir from PETSc.options.installDir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/installDir.py:51)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:51)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
          Changed persistence directory to /home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/linux/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/installDir.py:87)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:87)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1592)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1592)
          **** printenv ****
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
LOADEDMODULES=
GROUP=mpovolot
REMOTEHOST=c-98-223-96-89.hsd1.in.comcast.net
HOSTTYPE=x86_64-linux
LESSOPEN=||/usr/bin/lesspipe.sh %s
SSH_CLIENT=98.223.96.89 50712 22
SELINUX_USE_CURRENT_RANGE=
LOGNAME=mpovolot
USER=mpovolot
PATH=./:/home/mpovolot/bin/:/bin/:/usr/bin/:/usr/local/bin/:/usr/local/visit/bin/:/opt/matlab/bin/
QTDIR=/usr/lib64/qt-3.3
MAKEFLAGS=
SSH_CONNECTION=98.223.96.89 50712 128.46.94.46 22
LANG=en_US.UTF-8
QTLIB=/usr/lib64/qt-3.3/lib
TERM=xterm
SHELL=/usr/bin/csh
QTINC=/usr/lib64/qt-3.3/include
PWD=/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real
PETSC_DIR=/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real
EDITOR=joe
OSTYPE=linux
MFLAGS=
MODULESHOME=/usr/share/Modules
VENDOR=unknown
XDG_RUNTIME_DIR=/run/user/1000
HOME=/home/mpovolot
SHLVL=2
HOST=ncnlnx15.ecn.purdue.edu
QT_GRAPHICSSYSTEM_CHECKED=1
XDG_SESSION_ID=3087
_=./config/configure.py
MODULEPATH=/usr/share/Modules/modulefiles:/etc/modulefiles:/usr/share/modulefiles
KDEDIRS=/usr
MACHTYPE=x86_64
SSH_TTY=/dev/pts/11
OLDPWD=/home/mpovolot/NEMO5/NEMO/libs/petsc
HOSTNAME=ncnlnx15.ecn.purdue.edu
SELINUX_ROLE_REQUESTED=
SELINUX_LEVEL_REQUESTED=
MAKELEVEL=1
PETSC_ARCH=linux
MAIL=/var/spool/mail/mpovolot
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=01;36:*.au=01;36:*.flac=01;36:*.mid=01;36:*.midi=01;36:*.mka=01;36:*.mp3=01;36:*.mpc=01;36:*.ogg=01;36:*.ra=01;36:*.wav=01;36:*.axa=01;36:*.oga=01;36:*.spx=01;36:*.xspf=01;36:
TEST resetEnvCompilers from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1599)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1599)
                  ***** WARNING: MAKEFLAGS (set to ) found in environment variables - ignoring
                   use ./configure MAKEFLAGS=$MAKEFLAGS if you really want to use that value ******
TEST checkEnvCompilers from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1629)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1629)
TEST checkMPICompilerOverride from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1564)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1564)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1583)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1583)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:417)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:417)
  Determine the compiler vendor
          Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:427)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:427)
  Initialize the compiler and linker flags
            Pushing language C
          Initialized CFLAGS to
          Initialized LDFLAGS to
            Popping language C
          Initialized CUDAFLAGS to
          Initialized CXXFLAGS to -fopenmp
          Initialized CXX_CXXFLAGS to
            Pushing language FC
          Initialized FFLAGS to
            Popping language FC
          Initialized CPPFLAGS to
          Initialized CUDAPPFLAGS to
          Initialized CXXCPPFLAGS to
          Initialized CC_LINKER_FLAGS to []
          Initialized CXX_LINKER_FLAGS to []
          Initialized FC_LINKER_FLAGS to []
          Initialized CUDAC_LINKER_FLAGS to []
          Initialized sharedLibraryFlags to []
          Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:553)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:553)
  Locate a functional C compiler
Checking for program ./mpicc...not found
Checking for program /home/mpovolot/bin/mpicc...not found
Checking for program /bin/mpicc...not found
Checking for program /usr/bin/mpicc...not found
Checking for program /usr/local/bin/mpicc...found
              Defined make macro "CC" to "mpicc"
              Pushing language C
                          All intermediate test results are stored in /tmp/petsc-F9l5hH
                        All intermediate test results are stored in /tmp/petsc-F9l5hH/config.setCompilers
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                              Pushing language C
                                              Popping language C
                                              Pushing language FC
                                              Popping language FC
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest    /tmp/petsc-F9l5hH/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest    /tmp/petsc-F9l5hH/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Successful compile:
Source:
int main() {
  return 0;
                          Pushing language C
                          Popping language C
Testing executable /tmp/petsc-F9l5hH/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.setCompilers/conftest
              Popping language C
TEST checkCPreprocessor from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:586)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:586)
  Locate a functional C preprocessor
              Defined make macro "CPP" to "mpicc -E"
            Pushing language C
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers  /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.setCompilers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.setCompilers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.setCompilers/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.setCompilers/conffix.h" 1
# 3 "/tmp/petsc-F9l5hH/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 324 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef int wchar_t;
# 33 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
            Popping language C
TEST checkCUDACompiler from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:627)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:627)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:667)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:667)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:779)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:779)
  Locate a functional Cxx compiler
Checking for program ./mpic++...not found
Checking for program /home/mpovolot/bin/mpic++...not found
Checking for program /bin/mpic++...not found
Checking for program /usr/bin/mpic++...not found
Checking for program /usr/local/bin/mpic++...found
              Defined make macro "CXX" to "mpic++"
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -fopenmp    /tmp/petsc-F9l5hH/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                              Pushing language C
                                              Popping language C
                                              Pushing language FC
                                              Popping language FC
                      Pushing language CXX
                      Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest   -fopenmp /tmp/petsc-F9l5hH/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest   -fopenmp /tmp/petsc-F9l5hH/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
TEST checkCxxPreprocessor from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:817)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:817)
  Locate a functional Cxx preprocessor
              Defined make macro "CXXCPP" to "mpic++ -E"
Executing: mpic++ -E  -I/tmp/petsc-F9l5hH/config.setCompilers   /tmp/petsc-F9l5hH/config.setCompilers/conftest.cc
stdout:
# 1 "/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc"
# 1 "<built-in>"
# 2 "/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc" 2
extern "C" {
# 3 "/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc" 2
# 1 "/usr/include/c++/4.9.2/cstdlib" 1 3
# 39 "/usr/include/c++/4.9.2/cstdlib" 3
# 40 "/usr/include/c++/4.9.2/cstdlib" 3
# 1 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/c++config.h" 1 3
# 4 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/c++config.h" 2 3
# 1865 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/c++config.h" 3
namespace std
  typedef long int ptrdiff_t;
# 2109 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/c++config.h" 3
# 1 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/os_defines.h" 1 3
# 39 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/os_defines.h" 3
# 40 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/os_defines.h" 2 3
# 2110 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/c++config.h" 2 3
# 1 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/cpu_defines.h" 1 3
# 2113 "/usr/include/c++/4.9.2/x86_64-redhat-linux/bits/c++config.h" 2 3
# 42 "/usr/include/c++/4.9.2/cstdlib" 2 3
# 72 "/usr/include/c++/4.9.2/cstdlib" 3
# 32 "/usr/include/stdlib.h" 3 4
extern "C" {
union wait
    int w_status;
    struct
 unsigned int:16;
    struct
 unsigned int:16;
      } __wait_stopped;
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
    long long int quot;
    long long int rem;
  } lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) throw () ;
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1)));
       char **__restrict __endptr) throw () __attribute__ ((__nonnull__ (1)));
__extension__
__extension__
__extension__
__extension__
# 235 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 236 "/usr/include/stdlib.h" 2 3 4
extern long int strtol_l (const char *__restrict __nptr,
     char **__restrict __endptr, int __base,
     __locale_t __loc) throw () __attribute__ ((__nonnull__ (1, 4)));
extern unsigned long int strtoul_l (const char *__restrict __nptr,
        int __base, __locale_t __loc)
__extension__
extern long long int strtoll_l (const char *__restrict __nptr,
    __locale_t __loc)
__extension__
extern unsigned long long int strtoull_l (const char *__restrict __nptr,
extern double strtod_l (const char *__restrict __nptr,
   char **__restrict __endptr, __locale_t __loc)
     throw () __attribute__ ((__nonnull__ (1, 3)));
extern float strtof_l (const char *__restrict __nptr,
extern long double strtold_l (const char *__restrict __nptr,
         __locale_t __loc)
extern char *l64a (long int __n) throw () ;
extern "C" {
typedef __ino64_t ino64_t;
typedef __off64_t off64_t;
typedef __useconds_t useconds_t;
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
# 54 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
extern "C" {
extern "C" {
__extension__
     throw () __attribute__ ((__const__));
__extension__
__extension__
# 262 "/usr/include/sys/types.h" 3 4
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
extern long int random (void) throw ();
extern void srandom (unsigned int __seed) throw ();
   size_t __statelen) throw () __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) throw () __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
       int32_t *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
   size_t __statelen,
     throw () __attribute__ ((__nonnull__ (2, 4)));
extern int rand (void) throw ();
extern void srand (unsigned int __seed) throw ();
extern int rand_r (unsigned int *__seed) throw ();
extern double drand48 (void) throw ();
extern double erand48 (unsigned short int __xsubi[3]) throw () __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) throw ();
extern long int mrand48 (void) throw ();
extern void srand48 (long int __seedval) throw ();
extern void lcong48 (unsigned short int __param[7]) throw () __attribute__ ((__nonnull__ (1)));
struct drand48_data
        double *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
       struct drand48_data *__buffer) throw () __attribute__ ((__nonnull__ (1, 2)));
extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
     throw () __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) throw ();
extern void cfree (void *__ptr) throw ();
extern "C" {
extern void *alloca (size_t __size) throw ();
extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
     throw () __attribute__ ((__nonnull__ (1))) ;
extern void *aligned_alloc (size_t __alignment, size_t __size)
     throw () __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) throw () __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) throw () __attribute__ ((__nonnull__ (1)));
extern "C++" int at_quick_exit (void (*__func) (void))
     throw () __asm ("at_quick_exit") __attribute__ ((__nonnull__ (1)));
extern void exit (int __status) throw () __attribute__ ((__noreturn__));
extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) throw () __attribute__ ((__nonnull__ (1))) ;
extern char *secure_getenv (const char *__name)
extern int putenv (char *__string) throw () __attribute__ ((__nonnull__ (1)));
extern int unsetenv (const char *__name) throw () __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) throw ();
extern char *mktemp (char *__template) throw () __attribute__ ((__nonnull__ (1)));
# 629 "/usr/include/stdlib.h" 3 4
extern int mkstemp64 (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 651 "/usr/include/stdlib.h" 3 4
extern int mkstemps64 (char *__template, int __suffixlen)
extern char *mkdtemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 673 "/usr/include/stdlib.h" 3 4
extern int mkostemp (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 683 "/usr/include/stdlib.h" 3 4
extern int mkostemp64 (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 693 "/usr/include/stdlib.h" 3 4
extern int mkostemps (char *__template, int __suffixlen, int __flags)
# 705 "/usr/include/stdlib.h" 3 4
extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
extern char *canonicalize_file_name (const char *__name)
         char *__restrict __resolved) throw () ;
typedef __compar_fn_t comparison_fn_t;
typedef int (*__compar_d_fn_t) (const void *, const void *, void *);
extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
       __compar_d_fn_t __compar, void *__arg)
extern int abs (int __x) throw () __attribute__ ((__const__)) ;
extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
     int *__restrict __sign) throw () __attribute__ ((__nonnull__ (3, 4))) ;
     throw () __attribute__ ((__nonnull__ (3))) ;
     size_t __len) throw () __attribute__ ((__nonnull__ (3, 4, 5)));
extern int mblen (const char *__s, size_t __n) throw ();
     const char *__restrict __s, size_t __n) throw ();
extern int wctomb (char *__s, wchar_t __wchar) throw ();
     throw ();
extern int rpmatch (const char *__response) throw () __attribute__ ((__nonnull__ (1))) ;
     throw () __attribute__ ((__nonnull__ (1, 2, 3))) ;
extern void setkey (const char *__key) throw () __attribute__ ((__nonnull__ (1)));
extern int posix_openpt (int __oflag) ;
extern int grantpt (int __fd) throw ();
extern int unlockpt (int __fd) throw ();
extern char *ptsname (int __fd) throw () ;
extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
extern int getpt (void);
# 73 "/usr/include/c++/4.9.2/cstdlib" 2 3
# 114 "/usr/include/c++/4.9.2/cstdlib" 3
namespace std __attribute__ ((__visibility__ ("default")))
  using ::div_t;
  using ::ldiv_t;
  using ::abort;
  using ::abs;
  using ::atexit;
  using ::atof;
  using ::atoi;
  using ::atol;
  using ::bsearch;
  using ::calloc;
  using ::div;
  using ::exit;
  using ::free;
  using ::getenv;
  using ::labs;
  using ::ldiv;
  using ::malloc;
  using ::mblen;
  using ::mbstowcs;
  using ::mbtowc;
  using ::qsort;
  using ::rand;
  using ::realloc;
  using ::srand;
  using ::strtod;
  using ::strtol;
  using ::strtoul;
  using ::system;
  using ::wcstombs;
  using ::wctomb;
  inline long
  abs(long __i) { return __builtin_labs(__i); }
  inline ldiv_t
  div(long __i, long __j) { return ldiv(__i, __j); }
  inline long long
  abs(long long __x) { return __builtin_llabs (__x); }
  inline __int128
  abs(__int128 __x) { return __x >= 0 ? __x : -__x; }
# 196 "/usr/include/c++/4.9.2/cstdlib" 3
namespace __gnu_cxx __attribute__ ((__visibility__ ("default")))
  using ::lldiv_t;
  using ::_Exit;
  using ::llabs;
  inline lldiv_t
  div(long long __n, long long __d)
  { lldiv_t __q; __q.quot = __n / __d; __q.rem = __n % __d; return __q; }
  using ::lldiv;
# 228 "/usr/include/c++/4.9.2/cstdlib" 3
  using ::atoll;
  using ::strtoll;
  using ::strtoull;
  using ::strtof;
  using ::strtold;
namespace std
  using ::__gnu_cxx::lldiv_t;
  using ::__gnu_cxx::_Exit;
  using ::__gnu_cxx::llabs;
  using ::__gnu_cxx::div;
  using ::__gnu_cxx::lldiv;
  using ::__gnu_cxx::atoll;
  using ::__gnu_cxx::strtof;
  using ::__gnu_cxx::strtoll;
  using ::__gnu_cxx::strtoull;
  using ::__gnu_cxx::strtold;
TEST checkFortranCompiler from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:934)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:934)
  Locate a functional Fortran compiler
Checking for program ./mpif90...not found
Checking for program /home/mpovolot/bin/mpif90...not found
Checking for program /bin/mpif90...not found
Checking for program /usr/bin/mpif90...not found
Checking for program /usr/local/bin/mpif90...found
              Defined make macro "FC" to "mpif90"
              Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers   /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                              Pushing language C
                                              Popping language C
                                              Pushing language FC
                                              Popping language FC
                      Pushing language FC
                      Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest    /tmp/petsc-F9l5hH/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                      Pushing language FC
                      Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest    /tmp/petsc-F9l5hH/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
      program main
      end
                          Pushing language FC
                          Popping language FC
              Popping language FC
TEST checkFortranComments from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:955)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:955)
  Make sure fortran comment "!" works
            Pushing language FC
Successful compile:
Source:
! comment
      program main
      end
          Fortran comments can use ! in column 1
            Popping language FC
TEST checkLargeFileIO from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1072)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1072)
TEST checkArchiver from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1171)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1171)
  Check that the archiver exists and can make a library usable by the compiler
            Pushing language C
Executing: ar -V
stdout:
GNU ar version 2.24
Copyright 2013 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
GNU ar version 2.24
                Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program ./ar...not found
Checking for program /home/mpovolot/bin/ar...not found
Checking for program /bin/ar...found
              Defined make macro "AR" to "/bin/ar"
Checking for program ./ranlib...not found
Checking for program /home/mpovolot/bin/ranlib...not found
Checking for program /bin/ranlib...found
              Defined make macro "RANLIB" to "/bin/ranlib -c"
Executing: /bin/ar cr /tmp/petsc-F9l5hH/config.setCompilers/libconf1.a /tmp/petsc-F9l5hH/config.setCompilers/conf1.o
Executing: /bin/ranlib -c /tmp/petsc-F9l5hH/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/bin/ranlib: invalid option -- 'c'
          Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
GNU ar version 2.24
Executing: ar -V
stdout:
GNU ar version 2.24
Successful compile:
Source:
int foo(int a) {
  return a+1;
              Defined make macro "RANLIB" to "/bin/ranlib"
Executing: /bin/ranlib /tmp/petsc-F9l5hH/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest    /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/tmp/petsc-F9l5hH/config.setCompilers -lconf1
            Defined make macro "AR_FLAGS" to "cr"
            Defined make macro "AR_LIB_SUFFIX" to "a"
            Popping language C
TEST checkSharedLinker from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1283)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1283)
  Check that the linker can produce shared libraries
                                      Pushing language C
                                      Popping language C
                                      Pushing language FC
                                      Popping language FC
          Checking shared linker /bin/ar using flags []
              Defined make macro "LD_SHARED" to "/bin/ar"
          Trying C compiler flag
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("hello");
return 0;}
                      Pushing language C
                      Popping language C
Executing: /bin/ar  cr /tmp/petsc-F9l5hH/config.setCompilers/libconftest.a  /tmp/petsc-F9l5hH/config.setCompilers/conftest.o ; /bin/ranlib /tmp/petsc-F9l5hH/config.setCompilers/libconftest.a
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if(ret);;
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest     /tmp/petsc-F9l5hH/config.setCompilers/conftest.o  -L/tmp/petsc-F9l5hH/config.setCompilers -lconftest
          Using shared linker /bin/ar with flags [] and library extension a
Executing: uname -s
stdout: Linux
TEST checkPIC from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1031)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1031)
  Determine the PIC option for each compiler
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
void foo(void);
void bar(void){foo();}
                      Pushing language C
                      Popping language C
          Accepted C compiler flag
            Popping language C
          Trying Cxx compiler flag
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag
Successful compile:
Source:
void foo(void);
                Pushing language C
                      Pushing language C
                      Popping language C
                Popping language C
          Accepted Cxx compiler flag
            Pushing language FC
          Trying FC compiler flag
Successful compile:
Source:
      program main
      end
Added FC compiler flag
Successful compile:
Source:
      function foo(a)
      real:: a, bar
      foo = bar(a)
      end
                Pushing language C
                      Pushing language C
                      Popping language C
                Popping language C
          Accepted FC compiler flag
            Popping language FC
TEST checkSharedLinkerPaths from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1372)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1372)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
            Pushing language C
Executing: uname -s
stdout: Linux
Executing: mpicc -V
          Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest  -Wl,-rpath,/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real     /tmp/petsc-F9l5hH/config.setCompilers/conftest.o
            Valid C linker flag -Wl,-rpath,/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real
            Popping language C
Executing: uname -s
stdout: Linux
Executing: mpicc -V
          Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest  -Wl,-rpath,/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real  -fopenmp /tmp/petsc-F9l5hH/config.setCompilers/conftest.o
            Valid Cxx linker flag -Wl,-rpath,/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real
            Pushing language FC
Executing: uname -s
stdout: Linux
Executing: mpicc -V
          Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest  -Wl,-rpath,/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real    /tmp/petsc-F9l5hH/config.setCompilers/conftest.o
            Valid FC linker flag -Wl,-rpath,/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real
            Popping language FC
TEST checkLibC from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1407)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1407)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
TEST checkDynamicLinker from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1456)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1456)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
                        All intermediate test results are stored in /tmp/petsc-F9l5hH/config.headers
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 22 "/usr/include/dlfcn.h" 3 4
# 23 "/usr/include/dlfcn.h" 2 3 4
# 25 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/bits/dlfcn.h" 1 3 4
# 28 "/usr/include/dlfcn.h" 2 3 4
# 52 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (const char *__file, int __mode) __attribute__ ((__nothrow__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
      const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 82 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 188 "/usr/include/dlfcn.h" 3 4
              Defined "HAVE_DLFCN_H" to "1"
              Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
                Pushing language C
                            All intermediate test results are stored in /tmp/petsc-F9l5hH/config.libraries
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.libraries     /tmp/petsc-F9l5hH/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      /tmp/petsc-F9l5hH/config.libraries/conftest.o  -ldl
                Defined "HAVE_LIBDL" to "1"
                Popping language C
            Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
          Checking dynamic linker /bin/ar using flags []
              Defined make macro "DYNAMICLINKER" to "/bin/ar"
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers     /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
                                            Pushing language C
                                            Popping language C
                                            Pushing language CUDA
                                            Popping language CUDA
                                            Pushing language Cxx
                                            Popping language Cxx
                                            Pushing language FC
                                            Popping language FC
                    Pushing language C
                    Popping language C
Executing: /bin/ar  -o /tmp/petsc-F9l5hH/config.setCompilers/libconftest.so   /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -ldl
stderr:
/bin/ar: creating /tmp/petsc-F9l5hH/config.setCompilers/libconftest.so
Possible ERROR while running compiler:
stderr:
/tmp/petsc-F9l5hH/config.setCompilers/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.setCompilers/conftest.c:11:3: warning: incompatible implicit declaration of built-in function ‘printf’
   printf("Could not load symbol\n");
/tmp/petsc-F9l5hH/config.setCompilers/conftest.c:15:3: warning: incompatible implicit declaration of built-in function ‘printf’
   printf("Invalid return from foo()\n");
/tmp/petsc-F9l5hH/config.setCompilers/conftest.c:19:3: warning: incompatible implicit declaration of built-in function ‘printf’
   printf("Could not close library\n");
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/tmp/petsc-F9l5hH/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
  return -1;
if ((*foo)()) {
  return -1;
if (dlclose(handle)) {
  return -1;
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest      /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -ldl
          Using dynamic linker /bin/ar with flags [] and library extension so
TEST output from config.setCompilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/setCompilers.py:1508)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1508)
  Output module data as defines and substitutions
            Substituting "CC" with "mpicc"
            Substituting "CFLAGS" with "  "
            Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
            Substituting "CPP" with "mpicc -E"
            Substituting "CPPFLAGS" with ""
            Substituting "CXX" with "mpic++"
            Substituting "CXX_CXXFLAGS" with " "
            Substituting "CXXFLAGS" with "-fopenmp"
            Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
            Substituting "CXXCPP" with "mpic++ -E"
            Substituting "CXXCPPFLAGS" with ""
            Substituting "FC" with "mpif90"
            Substituting "FFLAGS" with " "
            Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
            Substituting "LDFLAGS" with ""
            Substituting "LIBS" with "-ldl "
            Substituting "SHARED_LIBRARY_FLAG" with ""
TEST configureIndexSize from PETSc.options.indexTypes(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/indexTypes.py:31)
TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:31)
            Defined make macro "PETSC_INDEX_SIZE" to "32"
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
            Defined make rule "shared_arch" with dependencies "" and code []
            Defined make macro "BUILDSHAREDLIB" to "no"
            Defined "HAVE_SHARED_LIBRARIES" to "1"
          Shared libraries - disabled
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/sharedLibraries.py:96)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:96)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
            Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/sharedLibraries.py:102)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:102)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
TEST configureCompilerFlags from config.compilerFlags(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilerFlags.py:72)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:72)
  Get the default compiler flags
                Defined make macro "MPICC_SHOW" to "gcc -I/usr/local/include -L/usr/local/lib -Wl,-rpath -Wl,/usr/local/lib -Wl,--enable-new-dtags -lmpi"
          Trying C compiler flag -Wall
          Trying C compiler flag -Wwrite-strings
          Trying C compiler flag -Wno-strict-aliasing
          Trying C compiler flag -Wno-unknown-pragmas
          Trying C compiler flag -fvisibility=hidden
          Trying C compiler flag -O3
          Ignoring default options which were overridden using --CXXFLAGS -fopenmp
          Trying Cxx compiler flag -O3
                Defined make macro "MPIFC_SHOW" to "gfortran -I/usr/local/include -I/usr/local/include -L/usr/local/lib -lmpifort -Wl,-rpath -Wl,/usr/local/lib -Wl,--enable-new-dtags -lmpi"
          Trying FC compiler flag -Wall
          Trying FC compiler flag -ffree-line-length-0
          Trying FC compiler flag -Wno-unused-dummy-argument
          Trying FC compiler flag -O3
            Pushing language C
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wall
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wwrite-strings
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-strict-aliasing
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-unknown-pragmas
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fvisibility=hidden
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -O3
            Popping language C
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -fopenmp -O3      /tmp/petsc-F9l5hH/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -O3
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers   -Wall   /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wall
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers   -Wall -ffree-line-length-0   /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -ffree-line-length-0
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument   /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-dummy-argument
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -O3
            Popping language FC
Executing: mpicc --version
stdout:
gcc (GCC) 4.9.2 20150212 (Red Hat 4.9.2-6)
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
getCompilerVersion: mpicc gcc (GCC) 4.9.2 20150212 (Red Hat 4.9.2-6)
Executing: mpicc -show
stdout: gcc -I/usr/local/include -L/usr/local/lib -Wl,-rpath -Wl,/usr/local/lib -Wl,--enable-new-dtags -lmpi
Executing: gcc --help
stdout:
Usage: gcc [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase
  --help                   Display this information
  --target-help            Display target specific command line options
  --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...]
                           Display specific types of command line options
  (Use '-v --help' to display command line options of sub-processes)
  --version                Display compiler version information
  -dumpspecs               Display all of the built in spec strings
  -dumpversion             Display the version of the compiler
  -dumpmachine             Display the compiler's target processor
  -print-search-dirs       Display the directories in the compiler's search path
  -print-libgcc-file-name  Display the name of the compiler's companion library
  -print-file-name=<lib>   Display the full path to library <lib>
  -print-prog-name=<prog>  Display the full path to compiler component <prog>
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path
  -print-multi-directory   Display the root directory for versions of libgcc
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories
  -print-multi-os-directory Display the relative path to OS libraries
  -print-sysroot           Display the target libraries directory
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers
  -Wa,<options>            Pass comma-separated <options> on to the assembler
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor
  -Wl,<options>            Pass comma-separated <options> on to the linker
  -Xassembler <arg>        Pass <arg> on to the assembler
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor
  -Xlinker <arg>           Pass <arg> on to the linker
  -save-temps              Do not delete intermediate files
  -save-temps=<arg>        Do not delete intermediate files
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components
  -pipe                    Use pipes rather than intermediate files
  -time                    Time the execution of each subprocess
  -specs=<file>            Override built-in specs with the contents of <file>
  -std=<standard>          Assume that the input sources are for <standard>
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries
  -B <directory>           Add <directory> to the compiler's search paths
  -v                       Display the programs invoked by the compiler
  -###                     Like -v but options quoted and commands not executed
  -E                       Preprocess only; do not compile, assemble or link
  -S                       Compile only; do not assemble or link
  -c                       Compile and assemble, but do not link
  -o <file>                Place the output into <file>
  -pie                     Create a position independent executable
  -shared                  Create a shared library
  -x <language>            Specify the language of the following input files
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by gcc.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<http://bugzilla.redhat.com/bugzilla>.
stdout:
Options:
                           and libraries
Executing: mpic++ --version
stdout:
g++ (GCC) 4.9.2 20150212 (Red Hat 4.9.2-6)
getCompilerVersion: mpic++ g++ (GCC) 4.9.2 20150212 (Red Hat 4.9.2-6)
Executing: mpif90 --version
stdout:
GNU Fortran (GCC) 4.9.2 20150212 (Red Hat 4.9.2-6)
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
getCompilerVersion: mpif90 GNU Fortran (GCC) 4.9.2 20150212 (Red Hat 4.9.2-6)
Executing: mpif90 -show
stdout: gfortran -I/usr/local/include -I/usr/local/include -L/usr/local/lib -lmpifort -Wl,-rpath -Wl,/usr/local/lib -Wl,--enable-new-dtags -lmpi
Executing: gfortran --help
stdout:
Usage: gfortran [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by gfortran.  In order to pass
Executing: gfortran --version
stdout:
stdout:
stdout:
TEST configureDebugging from PETSc.options.debugging(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/debugging.py:25)
TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
            Defined "USE_ERRORCHECKING" to "1"
                            WARNING! Compiling PETSc with no debugging, this should
                                  only be done for timing and production runs. All development should
                                  be done when configured using --with-debugging=1
Executing: mpicc --help
stdout:
Options:
                           and libraries
TEST checkRestrict from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:137)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:137)
  Check for the C/CXX restrict keyword
Executing: mpicc -V
            Pushing language C
                      All intermediate test results are stored in /tmp/petsc-F9l5hH/config.compilers
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.compilers/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.compilers/conftest.c:5:18: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘x’
 float * restrict x;;
/tmp/petsc-F9l5hH/config.compilers/conftest.c:5:18: error: ‘x’ undeclared (first use in this function)
/tmp/petsc-F9l5hH/config.compilers/conftest.c:5:18: note: each undeclared identifier is reported only once for each function it appears in
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.c
stderr:
/tmp/petsc-F9l5hH/config.compilers/conftest.c:5:23: warning: unused variable ‘x’ [-Wunused-variable]
 float *  __restrict__ x;;
Source:
int main() {
  return 0;
          compilers: Set C restrict keyword to  __restrict__
            Defined "C_RESTRICT" to " __restrict__"
            Popping language C
TEST checkCFormatting from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:317)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:317)
  Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:108)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:108)
  Check for C keyword: static inline
            Pushing language C
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
          compilers: Set C StaticInline keyword to static inline
            Popping language C
            Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:328)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:328)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.compilers/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.compilers/conftest.o -ldl
            Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:168)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:168)
  Determines the libraries needed to link with C
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.compilers/conftest  -v     -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.compilers/conftest.o -ldl
stdout: mpicc for MPICH version 3.2
Possible ERROR while running linker:
stdout:
mpicc for MPICH version 3.2stderr:
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-linker-hash-style=gnu --enable-languages=c,c++,objc,obj-c++,fortran,ada,go,lto --enable-plugin --enable-initfini-array --disable-libgcj --with-isl=/builddir/build/BUILD/gcc-4.9.2-20150212/obj-x86_64-redhat-linux/isl-install --with-cloog=/builddir/build/BUILD/gcc-4.9.2-20150212/obj-x86_64-redhat-linux/cloog-install --enable-gnu-indirect-function --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Thread model: posix
gcc version 4.9.2 20150212 (Red Hat 4.9.2-6) (GCC)
COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/
LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-F9l5hH/config.compilers/conftest' '-v' '-Wall' '-Wwrite-strings' '-Wno-strict-aliasing' '-Wno-unknown-pragmas' '-fvisibility=hidden' '-O3' '-I' '/usr/local/include' '-L/usr/local/lib' '-mtune=generic' '-march=x86-64'
 /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper -plugin-opt=-fresolution=/tmp/cc4dMD6n.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /tmp/petsc-F9l5hH/config.compilers/conftest /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtbegin.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../.. /tmp/petsc-F9l5hH/config.compilers/conftest.o -ldl -rpath /usr/local/lib --enable-new-dtags -lmpi -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crtn.o
            Popping language C
          compilers: Checking arg mpicc
          compilers: Unknown arg mpicc
          compilers: Checking arg for
          compilers: Unknown arg for
          compilers: Checking arg MPICH
          compilers: Unknown arg MPICH
          compilers: Checking arg version
          compilers: Unknown arg version
          compilers: Checking arg 3.2
          compilers: Unknown arg 3.2
          compilers: Checking arg Using
          compilers: Unknown arg Using
          compilers: Checking arg built-in
          compilers: Unknown arg built-in
          compilers: Checking arg specs.
          compilers: Unknown arg specs.
          compilers: Checking arg COLLECT_GCC=gcc
          compilers: Unknown arg COLLECT_GCC=gcc
          compilers: Checking arg COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper
          compilers: Unknown arg COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper
          compilers: Checking arg Target:
          compilers: Unknown arg Target:
          compilers: Checking arg x86_64-redhat-linux
          compilers: Unknown arg x86_64-redhat-linux
          compilers: Checking arg Configured
          compilers: Unknown arg Configured
          compilers: Checking arg with:
          compilers: Unknown arg with:
          compilers: Checking arg ../configure
          compilers: Unknown arg ../configure
          compilers: Checking arg --prefix=/usr
          compilers: Unknown arg --prefix=/usr
          compilers: Checking arg --mandir=/usr/share/man
          compilers: Unknown arg --mandir=/usr/share/man
          compilers: Checking arg --infodir=/usr/share/info
          compilers: Unknown arg --infodir=/usr/share/info
          compilers: Checking arg --with-bugurl=http://bugzilla.redhat.com/bugzilla
          compilers: Unknown arg --with-bugurl=http://bugzilla.redhat.com/bugzilla
          compilers: Checking arg --enable-bootstrap
          compilers: Unknown arg --enable-bootstrap
          compilers: Checking arg --enable-shared
          compilers: Unknown arg --enable-shared
          compilers: Checking arg --enable-threads=posix
          compilers: Unknown arg --enable-threads=posix
          compilers: Checking arg --enable-checking=release
          compilers: Unknown arg --enable-checking=release
          compilers: Checking arg --enable-multilib
          compilers: Unknown arg --enable-multilib
          compilers: Checking arg --with-system-zlib
          compilers: Unknown arg --with-system-zlib
          compilers: Checking arg --enable-__cxa_atexit
          compilers: Unknown arg --enable-__cxa_atexit
          compilers: Checking arg --disable-libunwind-exceptions
          compilers: Unknown arg --disable-libunwind-exceptions
          compilers: Checking arg --enable-gnu-unique-object
          compilers: Unknown arg --enable-gnu-unique-object
          compilers: Checking arg --enable-linker-build-id
          compilers: Unknown arg --enable-linker-build-id
          compilers: Checking arg --with-linker-hash-style=gnu
          compilers: Unknown arg --with-linker-hash-style=gnu
          compilers: Checking arg --enable-languages=c,c++,objc,obj-c++,fortran,ada,go,lto
          compilers: Unknown arg --enable-languages=c,c++,objc,obj-c++,fortran,ada,go,lto
          compilers: Checking arg --enable-plugin
          compilers: Unknown arg --enable-plugin
          compilers: Checking arg --enable-initfini-array
          compilers: Unknown arg --enable-initfini-array
          compilers: Checking arg --disable-libgcj
          compilers: Unknown arg --disable-libgcj
          compilers: Checking arg --with-isl=/builddir/build/BUILD/gcc-4.9.2-20150212/obj-x86_64-redhat-linux/isl-install
          compilers: Unknown arg --with-isl=/builddir/build/BUILD/gcc-4.9.2-20150212/obj-x86_64-redhat-linux/isl-install
          compilers: Checking arg --with-cloog=/builddir/build/BUILD/gcc-4.9.2-20150212/obj-x86_64-redhat-linux/cloog-install
          compilers: Unknown arg --with-cloog=/builddir/build/BUILD/gcc-4.9.2-20150212/obj-x86_64-redhat-linux/cloog-install
          compilers: Checking arg --enable-gnu-indirect-function
          compilers: Unknown arg --enable-gnu-indirect-function
          compilers: Checking arg --with-tune=generic
          compilers: Unknown arg --with-tune=generic
          compilers: Checking arg --with-arch_32=i686
          compilers: Unknown arg --with-arch_32=i686
          compilers: Checking arg --build=x86_64-redhat-linux
          compilers: Unknown arg --build=x86_64-redhat-linux
          compilers: Checking arg Thread
          compilers: Unknown arg Thread
          compilers: Checking arg model:
          compilers: Unknown arg model:
          compilers: Checking arg posix
          compilers: Unknown arg posix
          compilers: Checking arg gcc
          compilers: Unknown arg gcc
          compilers: Checking arg 4.9.2
          compilers: Unknown arg 4.9.2
          compilers: Checking arg 20150212
          compilers: Unknown arg 20150212
          compilers: Checking arg (Red
          compilers: Unknown arg (Red
          compilers: Checking arg Hat
          compilers: Unknown arg Hat
          compilers: Checking arg 4.9.2-6)
          compilers: Unknown arg 4.9.2-6)
          compilers: Checking arg (GCC)
          compilers: Unknown arg (GCC)
          compilers: Checking arg COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/
          compilers: Unknown arg COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/
          compilers: Checking arg LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../:/lib/:/usr/lib/
          compilers: Unknown arg LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../:/lib/:/usr/lib/
          compilers: Checking arg COLLECT_GCC_OPTIONS=
          compilers: Unknown arg COLLECT_GCC_OPTIONS=
          compilers: Checking arg /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/collect2
          compilers: Unknown arg /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/collect2
          compilers: Checking arg -plugin
          compilers: Unknown arg -plugin
          compilers: Checking arg /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/liblto_plugin.so
          compilers: Unknown arg /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/liblto_plugin.so
          compilers: Checking arg -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper
          compilers: Unknown arg -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper
          compilers: Checking arg -plugin-opt=-fresolution=/tmp/cc4dMD6n.res
          compilers: Unknown arg -plugin-opt=-fresolution=/tmp/cc4dMD6n.res
          compilers: Checking arg -plugin-opt=-pass-through=-lgcc
          compilers: Unknown arg -plugin-opt=-pass-through=-lgcc
          compilers: Checking arg -plugin-opt=-pass-through=-lgcc_s
          compilers: Unknown arg -plugin-opt=-pass-through=-lgcc_s
          compilers: Checking arg -plugin-opt=-pass-through=-lc
          compilers: Unknown arg -plugin-opt=-pass-through=-lc
          compilers: Checking arg --build-id
          compilers: Unknown arg --build-id
          compilers: Checking arg --no-add-needed
          compilers: Unknown arg --no-add-needed
          compilers: Checking arg --eh-frame-hdr
          compilers: Unknown arg --eh-frame-hdr
          compilers: Checking arg --hash-style=gnu
          compilers: Unknown arg --hash-style=gnu
          compilers: Checking arg -m
          compilers: Unknown arg -m
          compilers: Checking arg elf_x86_64
          compilers: Unknown arg elf_x86_64
          compilers: Checking arg -dynamic-linker
          compilers: Unknown arg -dynamic-linker
          compilers: Checking arg /lib64/ld-linux-x86-64.so.2
          compilers: Unknown arg /lib64/ld-linux-x86-64.so.2
          compilers: Checking arg -o
          compilers: Unknown arg -o
          compilers: Checking arg /tmp/petsc-F9l5hH/config.compilers/conftest
          compilers: Unknown arg /tmp/petsc-F9l5hH/config.compilers/conftest
          compilers: Checking arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crt1.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crt1.o
          compilers: Checking arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crti.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crti.o
          compilers: Checking arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtbegin.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtbegin.o
          compilers: Checking arg -L/usr/local/lib
          compilers: Found library directory: -L/usr/local/lib
          compilers: Checking arg -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2
          compilers: Found library directory: -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2
          compilers: Checking arg -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64
          compilers: Checking arg -L/lib/../lib64
          compilers: Checking arg -L/usr/lib/../lib64
          compilers: Checking arg /tmp/petsc-F9l5hH/config.compilers/conftest.o
          compilers: Unknown arg /tmp/petsc-F9l5hH/config.compilers/conftest.o
          compilers: Checking arg -ldl
          compilers: Found library : -ldl
          compilers: Checking arg -rpath
          compilers: Found -rpath library: /usr/local/lib
          compilers: Checking arg --enable-new-dtags
          compilers: Unknown arg --enable-new-dtags
          compilers: Checking arg -lmpi
          compilers: Found library : -lmpi
          compilers: Checking arg -lgcc
          compilers: Skipping system library: -lgcc
          compilers: Checking arg --as-needed
          compilers: Unknown arg --as-needed
          compilers: Checking arg -lgcc_s
          compilers: Found library : -lgcc_s
          compilers: Checking arg --no-as-needed
          compilers: Unknown arg --no-as-needed
          compilers: Checking arg -lc
          compilers: Skipping system library: -lc
          compilers: Checking arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtend.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtend.o
          compilers: Checking arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crtn.o
          compilers: Unknown arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crtn.o
          compilers: Libraries needed to link C code with another linker: ['-L/usr/local/lib', '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2', '-ldl', '-Wl,-rpath,/usr/local/lib', '-lmpi', '-lgcc_s']
          compilers: Check that C libraries can be used from Fortran
                      Pushing language FC
                      Popping language FC
                      Pushing language FC
                      Popping language FC
                          Pushing language FC
                          Popping language FC
              Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
Testing executable /tmp/petsc-F9l5hH/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.setCompilers/conftest
              Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1359)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1359)
  Check if -MMD works for dependency generation, and add it if it does
          Trying C compiler flag -MMD -MP
            Defined make macro "C_DEPFLAGS" to "-MMD -MP"
            Pushing language C
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 -MMD -MP  /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
            Popping language C
          Trying Cxx compiler flag -MMD -MP
            Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -fopenmp -O3   -MMD -MP   /tmp/petsc-F9l5hH/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
          Trying FC compiler flag -MMD -MP
            Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 -MMD -MP  /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
            Popping language FC
TEST checkC99Flag from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1405)
TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1405)
  Check for -std=c99 or equivalent flag
          Accepted C99 compile flag: -std=c99
            Pushing language C
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3   /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
stderr:
/tmp/petsc-F9l5hH/config.setCompilers/conftest.c:11:5: error: ‘for’ loop initial declarations are only allowed in C99 or C11 mode
     for (int i=0; i<2; i++){
/tmp/petsc-F9l5hH/config.setCompilers/conftest.c:11:5: note: use option -std=c99, -std=gnu99, -std=c11 or -std=gnu11 to compile your code
/tmp/petsc-F9l5hH/config.setCompilers/conftest.c:7:11: warning: variable ‘x’ set but not used [-Wunused-but-set-variable]
     float x[2],y;
Source:
#include <float.h>
int main() {
    float x[2],y;
    y = FLT_ROUNDS;
    // c++ comment
    int j = 2;
      x[i] = i*j*y;
  return 0;
            Rejecting compiler flag  due to nonzero status from link
     float x[2],y;
PETSc Error: No output file produced
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 -std=c99  /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
stderr:
     float x[2],y;
Source:
#include <float.h>
int main() {
    float x[2],y;
    y = FLT_ROUNDS;
    // c++ comment
    int j = 2;
      x[i] = i*j*y;
  return 0;
            Popping language C
Executing: mpic++ --help
stdout:
Usage: g++ [options] file...
Options:
                           and libraries
 passed on to the various sub-processes invoked by g++.  In order to pass
Executing: mpicc -V
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -fopenmp -O3     /tmp/petsc-F9l5hH/config.compilers/conftest.cc
stderr:
/tmp/petsc-F9l5hH/config.compilers/conftest.cc: In function ‘int main()’:
/tmp/petsc-F9l5hH/config.compilers/conftest.cc:5:18: error: expected initializer before ‘x’
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
          compilers: Set Cxx restrict keyword to  __restrict__
            Defined "CXX_RESTRICT" to " __restrict__"
TEST checkCxxNamespace from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:368)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:368)
  Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
  return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
  return 0;
          compilers: C++ has namespaces
            Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:341)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:341)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -fopenmp -O3       /tmp/petsc-F9l5hH/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
  return 0;
TEST checkCxxStaticInline from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:122)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:122)
  Check for C++ keyword: static inline
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
          compilers: Set Cxx StaticInline keyword to static inline
            Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:426)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:426)
  Determines the libraries needed to link with C++
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language CXX
                  Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.compilers/conftest  -v  -fopenmp -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stdout: mpicxx for MPICH version 3.2
stdout:
mpicxx for MPICH version 3.2stderr:
COLLECT_GCC=g++
Thread model: posix
Reading specs from /usr/lib/gcc/x86_64-redhat-linux/4.9.2/libgomp.spec
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-F9l5hH/config.compilers/conftest' '-v' '-fopenmp' '-O3' '-L/usr/local/lib' '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2' '-I' '/usr/local/include' '-L/usr/local/lib' '-shared-libgcc' '-mtune=generic' '-march=x86-64' '-pthread'
 /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper -plugin-opt=-fresolution=/tmp/cc89tjJV.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lpthread -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /tmp/petsc-F9l5hH/config.compilers/conftest /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtbegin.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../.. /tmp/petsc-F9l5hH/config.compilers/conftest.o -ldl -rpath /usr/local/lib -lmpi -lgcc_s -ldl -lmpicxx -rpath /usr/local/lib --enable-new-dtags -lmpi -lstdc++ -lm -lgomp -lgcc_s -lgcc -lpthread -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crtn.o
          compilers: Checking arg mpicxx
          compilers: Unknown arg mpicxx
          compilers: Checking arg COLLECT_GCC=g++
          compilers: Unknown arg COLLECT_GCC=g++
          compilers: Checking arg Reading
          compilers: Unknown arg Reading
          compilers: Checking arg from
          compilers: Unknown arg from
          compilers: Checking arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/libgomp.spec
          compilers: Unknown arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/libgomp.spec
          compilers: Checking arg -plugin-opt=-fresolution=/tmp/cc89tjJV.res
          compilers: Unknown arg -plugin-opt=-fresolution=/tmp/cc89tjJV.res
          compilers: Checking arg -plugin-opt=-pass-through=-lpthread
          compilers: Unknown arg -plugin-opt=-pass-through=-lpthread
          compilers: Found library: -ldl
          Library already in C list so skipping in C++
          compilers: Found library: -lmpi
          compilers: Found library: -lgcc_s
          compilers: Checking arg -lmpicxx
          compilers: Found library: -lmpicxx
          compilers: Already in rpathflags, skipping:-rpath
          compilers: Checking arg -lstdc++
          compilers: Found library: -lstdc++
          compilers: Checking arg -lgomp
          compilers: Found library: -lgomp
          compilers: Checking arg -lpthread
          compilers: Found library: -lpthread
          compilers: Libraries needed to link Cxx code with another linker: ['-L/usr/local/lib', '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2', '-Wl,-rpath,/usr/local/lib', '-lmpicxx', '-lstdc++', '-lgomp', '-lpthread']
          compilers: Check that Cxx libraries can be used from C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                          Pushing language C
                          Popping language C
              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -Wl,-rpath,/usr/local/lib -lmpicxx -lstdc++ -lgomp -lpthread -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -Wl,-rpath,/usr/local/lib -lmpicxx -lstdc++ -lgomp -lpthread -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
              Popping language C
          compilers: Check that Cxx libraries can be used from Fortran
                      Pushing language FC
                      Popping language FC
                      Pushing language FC
                      Popping language FC
                          Pushing language FC
                          Popping language FC
              Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -Wl,-rpath,/usr/local/lib -lmpicxx -lstdc++ -lgomp -lpthread -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -Wl,-rpath,/usr/local/lib -lmpicxx -lstdc++ -lgomp -lpthread -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
      program main
      end
              Popping language FC
TEST checkCxx11 from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:383)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:383)
  Determine the option needed to support the C++11 dialect
    We auto-detect C++11 if the compiler supports it without options,
    otherwise we require with-cxx-dialect=C++11 to try adding flags to
    support it.
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -fopenmp -O3       /tmp/petsc-F9l5hH/config.setCompilers/conftest.cc
stderr:
In file included from /usr/include/c++/4.9.2/random:35:0,
                 from /tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:4:
/usr/include/c++/4.9.2/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
 #error This file requires compiler and library support for the \
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:5:32: error: ‘constexpr’ does not name a type
           template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:5:32: note: C++11 ‘constexpr’ only available with -std=c++11 or -std=gnu++11
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc: In function ‘int main()’:
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:10:11: error: ‘random_device’ is not a member of ‘std’
           std::random_device rd;
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:11:11: error: ‘mt19937’ is not a member of ‘std’
           std::mt19937 mt(rd());
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:12:11: error: ‘normal_distribution’ is not a member of ‘std’
           std::normal_distribution<double> dist(0,1);
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:12:36: error: expected primary-expression before ‘double’
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:13:33: error: ‘mt’ was not declared in this scope
           const double x = dist(mt);
/tmp/petsc-F9l5hH/config.setCompilers/conftest.cc:13:35: error: ‘dist’ was not declared in this scope
Source:
          #include <random>
int main() {
  return 0;
TEST checkFortranTypeSizes from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:589)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:589)
  Check whether real*8 is supported and suggest flags which will allow support
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.F
stderr:
/tmp/petsc-F9l5hH/config.compilers/conftest.F:2.21:
      real*8 variable
                     1
Warning: Unused variable 'variable' declared at (1)
Source:
      program main
      real*8 variable
      end
            Popping language FC
TEST checkFortranNameMangling from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:648)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:648)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
              Pushing language C
Successful compile:
Source:
              Popping language C
              Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                      Pushing language FC
                      Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.compilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 /tmp/petsc-F9l5hH/config.compilers/conftest.o /tmp/petsc-F9l5hH/config.compilers/confc.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
              Popping language FC
          compilers: Fortran name mangling is underscore
            Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
TEST checkFortranNameManglingDouble from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:685)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:685)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
              Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
              Popping language C
              Pushing language FC
Successful compile:
Source:
      program main
       call d1_chk()
      end
                      Pushing language FC
                      Popping language FC
stderr:
/tmp/petsc-F9l5hH/config.compilers/conftest.o: In function `main':
conftest.F:(.text.startup+0x1b): undefined reference to `d1_chk_'
              Popping language FC
TEST checkFortranPreprocessor from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:695)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:695)
  Determine if Fortran handles preprocessing properly
          compilers: Fortran uses CPP preprocessor
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3    /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
            Popping language FC
TEST checkFortranDefineCompilerOption from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:719)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:719)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
            Defined make macro "FC_DEFINE_FLAG" to "-D"
          compilers: Fortran uses -D for defining macro
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  -DTesting  /tmp/petsc-F9l5hH/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
            Popping language FC
TEST checkFortranLibraries from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:739)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:739)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
            Pushing language FC
Executing: mpif90 -V
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.compilers/conftest  -v    -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stdout: mpifort for MPICH version 3.2
stdout:
mpifort for MPICH version 3.2stderr:
Driving: gfortran -o /tmp/petsc-F9l5hH/config.compilers/conftest -v -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 /tmp/petsc-F9l5hH/config.compilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl -I/usr/local/include -I/usr/local/include -L/usr/local/lib -lmpifort -Wl,-rpath -Wl,/usr/local/lib -Wl,--enable-new-dtags -lmpi -l gfortran -l m -shared-libgcc
COLLECT_GCC=gfortran
Thread model: posix
Reading specs from /usr/lib/gcc/x86_64-redhat-linux/4.9.2/libgfortran.spec
rename spec lib to liborig
COLLECT_GCC_OPTIONS='-o' '/tmp/petsc-F9l5hH/config.compilers/conftest' '-v' '-Wall' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-O3' '-L/usr/local/lib' '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2' '-I' '/usr/local/include' '-I' '/usr/local/include' '-L/usr/local/lib' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
 /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/4.9.2/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/lto-wrapper -plugin-opt=-fresolution=/tmp/ccTUJmlT.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lquadmath -plugin-opt=-pass-through=-lm -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /tmp/petsc-F9l5hH/config.compilers/conftest /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtbegin.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../.. /tmp/petsc-F9l5hH/config.compilers/conftest.o -ldl -rpath /usr/local/lib -lmpi -lgcc_s -ldl -lmpifort -rpath /usr/local/lib --enable-new-dtags -lmpi -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/4.9.2/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/crtn.o
            Popping language FC
          compilers: Checking arg mpifort
          compilers: Unknown arg mpifort
          compilers: Checking arg Driving:
          compilers: Unknown arg Driving:
          compilers: Checking arg gfortran
          compilers: Unknown arg gfortran
          compilers: Checking arg -v
          compilers: Unknown arg -v
          compilers: Checking arg -Wall
          compilers: Unknown arg -Wall
          compilers: Checking arg -ffree-line-length-0
          compilers: Unknown arg -ffree-line-length-0
          compilers: Checking arg -Wno-unused-dummy-argument
          compilers: Unknown arg -Wno-unused-dummy-argument
          compilers: Checking arg -O3
          compilers: Unknown arg -O3
          Library already in C list so skipping in Fortran
          compilers: Checking arg -Wl,-rpath,/usr/local/lib
          compilers: Unknown arg -Wl,-rpath,/usr/local/lib
          compilers: Already in lflags: -ldl
          compilers: Checking arg -I/usr/local/include
          compilers: Found include directory: /usr/local/include
          compilers: Already in lflags so skipping: -L/usr/local/lib
          compilers: Checking arg -lmpifort
          compilers: Found library: -lmpifort
          compilers: Checking arg -Wl,/usr/local/lib
          compilers: Unknown arg -Wl,/usr/local/lib
          compilers: Checking arg -Wl,--enable-new-dtags
          compilers: Unknown arg -Wl,--enable-new-dtags
          compilers: Already in lflags: -lmpi
          compilers: Found canonical library: -lgfortran
          compilers: Found canonical library: -lm
          compilers: Checking arg -shared-libgcc
          compilers: Unknown arg -shared-libgcc
          compilers: Checking arg COLLECT_GCC=gfortran
          compilers: Unknown arg COLLECT_GCC=gfortran
          compilers: Checking arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/libgfortran.spec
          compilers: Unknown arg /usr/lib/gcc/x86_64-redhat-linux/4.9.2/libgfortran.spec
          compilers: Checking arg rename
          compilers: Unknown arg rename
          compilers: Checking arg lib
          compilers: Unknown arg lib
          compilers: Checking arg to
          compilers: Unknown arg to
          compilers: Checking arg liborig
          compilers: Unknown arg liborig
          compilers: Skipping arg COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/4.9.2/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/
          compilers: Skipping arg LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/4.9.2/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/4.9.2/../../../:/lib/:/usr/lib/
          compilers: Checking arg -plugin-opt=-fresolution=/tmp/ccTUJmlT.res
          compilers: Unknown arg -plugin-opt=-fresolution=/tmp/ccTUJmlT.res
          compilers: Checking arg -plugin-opt=-pass-through=-lquadmath
          compilers: Unknown arg -plugin-opt=-pass-through=-lquadmath
          compilers: Checking arg -plugin-opt=-pass-through=-lm
          compilers: Unknown arg -plugin-opt=-pass-through=-lm
          compilers: Already in lflags so skipping: -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2
          compilers: Already in lflags: -lgcc_s
          compilers: Already in lflags: -lmpifort
          compilers: Already in rpathflags so skipping: -rpath
          compilers: Checking arg -lgfortran
          compilers: Found library: -lgfortran
          compilers: Found system library therefor skipping: -lgcc
          compilers: Checking arg -lquadmath
          compilers: Found library: -lquadmath
          compilers: Found system library therefor skipping: -lc
          compilers: Libraries needed to link Fortran code with the C linker: ['-L/usr/local/lib', '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/usr/local/lib', '-lgfortran', '-lm', '-lquadmath', '-lm']
          compilers: Libraries needed to link Fortran main with the C linker: []
          compilers: Check that Fortran libraries can be used from C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                          Pushing language C
                          Popping language C
              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -lmpifort -lgfortran -lm -Wl,-rpath,/usr/local/lib -lgfortran -lm -lquadmath -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -lmpifort -lgfortran -lm -Wl,-rpath,/usr/local/lib -lgfortran -lm -lquadmath -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
              Popping language C
          compilers: Check that Fortran libraries can be used from C++
          compilers: Fortran libraries can be used from C++
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -lmpifort -lgfortran -lm -Wl,-rpath,/usr/local/lib -lgfortran -lm -lquadmath -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.setCompilers/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.setCompilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -lmpifort -lgfortran -lm -Wl,-rpath,/usr/local/lib -lgfortran -lm -lquadmath -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
              Popping language Cxx
TEST checkFortranLinkingCxx from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1093)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1093)
  Check that Fortran can be linked against C++
            Pushing language Cxx
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
              Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                      Pushing language FC
                      Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.compilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.o /tmp/petsc-F9l5hH/config.compilers/cxxobj.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s /tmp/petsc-F9l5hH/config.compilers/confc.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
              Popping language FC
          compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1128)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1128)
  Determine whether the Fortran compiler handles F90
            Pushing language FC
Successful compile:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
                    Pushing language FC
                    Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.compilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
            Defined "USING_F90" to "1"
          Fortran compiler supports F90
            Popping language FC
TEST checkFortran2003 from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1141)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1141)
  Determine whether the Fortran compiler handles F2003
            Pushing language FC
stderr:
/tmp/petsc-F9l5hH/config.compilers/conftest.F: In function ‘main’:
/tmp/petsc-F9l5hH/config.compilers/conftest.F:9:0: warning: ‘carray.dim[0].lbound’ may be used uninitialized in this function [-Wmaybe-uninitialized]
       CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
/tmp/petsc-F9l5hH/config.compilers/conftest.F:4:0: note: ‘carray.dim[0].lbound’ was declared here
       Type(C_Ptr),Dimension(:),Pointer :: CArray
/tmp/petsc-F9l5hH/config.compilers/conftest.F:9:0: warning: ‘carray.dim[0].stride’ may be used uninitialized in this function [-Wmaybe-uninitialized]
/tmp/petsc-F9l5hH/config.compilers/conftest.F:4:0: note: ‘carray.dim[0].stride’ was declared here
/tmp/petsc-F9l5hH/config.compilers/conftest.F:9:0: warning: ‘carray.offset’ may be used uninitialized in this function [-Wmaybe-uninitialized]
/tmp/petsc-F9l5hH/config.compilers/conftest.F:4:0: note: ‘carray.offset’ was declared here
Source:
      program main
      use,intrinsic :: iso_c_binding
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      end
                    Pushing language FC
                    Popping language FC
            Defined "USING_F2003" to "1"
          Fortran compiler supports F2003
            Popping language FC
TEST checkFortran90Array from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1161)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1161)
  Check for F90 array interfaces
Executing: uname -s
stdout: Linux
            Pushing language C
Successful compile:
Source:
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
  printf("arrays [%p %p %p]\n",a1,a2,a3);
  fflush(stdout);
  return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
  if ((p1 == p3) && (p1 != p2)) {
    printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
  } else {
    printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
    exit(111);
  return;
            Popping language C
            Pushing language FC
Successful compile:
Source:
      program main
      Interface
         Subroutine f90ptrtest(p1,p2,p3,i)
         integer, pointer :: p1(:,:)
         integer, pointer :: p2(:,:)
         integer, pointer :: p3(:,:)
         integer i
         End Subroutine
      End Interface
      integer, pointer :: ptr1(:,:),ptr2(:,:)
      integer, target  :: array(6:8,9:21)
      integer  in
      in   = 25
      ptr1 => array
      ptr2 => array
      call f90arraytest(ptr1,ptr2,ptr1,in)
      call f90ptrtest(ptr1,ptr2,ptr1,in)
      end
                        Pushing language FC
                        Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.compilers/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.o /tmp/petsc-F9l5hH/config.compilers/fooobj.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-F9l5hH/config.compilers/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.compilers/conftest
stdout:
arrays [0x7ffdba8e89a0 0x7ffdba8e89a0 0x7ffdba8e89a0]
arrays [0x7ffdba8e8900 0x7ffdba8e8950 0x7ffdba8e8900]
pointers do not match! [0x7efcca768a40 0x7efccacbb520] [0x7efccbc99b40]
ERROR while running executable: Could not execute "/tmp/petsc-F9l5hH/config.compilers/conftest":
            Popping language FC
          compilers: F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1248)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1248)
  Figures out what flag is used to specify the include path for Fortran modules
            Pushing language FC
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.compilers/confdir   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.compilers/conftest.F
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
                    Pushing language FC
                    Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.compilers/conftest   -I/tmp/petsc-F9l5hH/config.compilers/confdir   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.compilers/conftest.o /tmp/petsc-F9l5hH/config.compilers/configtest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
          compilers: Fortran module include flag -I found
            Popping language FC
TEST checkFortranModuleOutput from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1314)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1314)
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -module /tmp/petsc-F9l5hH/config.compilers/confdir   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.compilers/conftest.F
stderr:
gfortran: error: unrecognized command line option ‘-module’
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module  compile failed
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -module:/tmp/petsc-F9l5hH/config.compilers/confdir   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.compilers/conftest.F
stderr:
gfortran: error: unrecognized command line option ‘-module:/tmp/petsc-F9l5hH/config.compilers/confdir’
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module: compile failed
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -fmod=/tmp/petsc-F9l5hH/config.compilers/confdir   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.compilers/conftest.F
stderr:
gfortran: error: unrecognized command line option ‘-fmod=/tmp/petsc-F9l5hH/config.compilers/confdir’
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -fmod= compile failed
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.compilers/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -J/tmp/petsc-F9l5hH/config.compilers/confdir   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.compilers/conftest.F
Successful compile:
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -J found
            Popping language FC
TEST setupFrameworkCompilers from config.compilers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/compilers.py:1472)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1472)
TEST configureClosure from config.utilities.closure(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/closure.py:18)
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
  Determine if Apple ^close syntax is supported in C
            Pushing language C
                        All intermediate test results are stored in /tmp/petsc-F9l5hH/config.utilities.closure
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.utilities.closure/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.utilities.closure    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.utilities.closure/conftest.c
stderr:
/tmp/petsc-F9l5hH/config.utilities.closure/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.utilities.closure/conftest.c:6:6: error: expected identifier or ‘(’ before ‘^’ token
 int (^closure)(int);;
Source:
#include <stdio.h>
int main() {
  return 0;
              Compile failed inside link
TEST configureFortranCPP from PETSc.options.fortranCPP(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/fortranCPP.py:27)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:27)
  Handle case where Fortran cannot preprocess properly
            Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<']
            Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
            Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<']
            Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
TEST checkStdC from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.headers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Source:
#include <string.h>
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/usr/include/string.h" 1 3 4
# 25 "/usr/include/string.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 26 "/usr/include/string.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 33 "/usr/include/string.h" 2 3 4
# 44 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
       size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 96 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
      __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 127 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 164 "/usr/include/string.h" 2 3 4
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 341 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    const char *__restrict __delim,
    char **__restrict __save_ptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 396 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 426 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 444 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
# 488 "/usr/include/string.h" 3 4
extern char *index (const char *__s, int __c)
# 516 "/usr/include/string.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 533 "/usr/include/string.h" 3 4
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
# 556 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 643 "/usr/include/string.h" 3 4
Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdlib.h>
stdout:
# 1 "<built-in>"
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 324 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef int wchar_t;
# 33 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
Successful compile:
Source:
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
        int i;
        for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
        exit(0);
  return 0;
                        Pushing language C
                        Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.headers/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.headers/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-F9l5hH/config.headers/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.headers/conftest
            Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
  You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
  You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
  You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
  You lose.
# endif
#endif
stdout:
# 1 "<built-in>"
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 5 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/usr/include/sys/stat.h" 1 3 4
# 36 "/usr/include/sys/stat.h" 3 4
# 37 "/usr/include/sys/stat.h" 2 3 4
# 102 "/usr/include/sys/stat.h" 3 4
# 1 "/usr/include/bits/stat.h" 1 3 4
# 46 "/usr/include/bits/stat.h" 3 4
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad0;
    __dev_t st_rdev;
    __off_t st_size;
    __blksize_t st_blksize;
    __blkcnt_t st_blocks;
# 91 "/usr/include/bits/stat.h" 3 4
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
# 106 "/usr/include/bits/stat.h" 3 4
    __syscall_slong_t __glibc_reserved[3];
# 115 "/usr/include/bits/stat.h" 3 4
# 105 "/usr/include/sys/stat.h" 2 3 4
# 208 "/usr/include/sys/stat.h" 3 4
extern int stat (const char *__restrict __file,
   struct stat *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fstat (int __fd, struct stat *__buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 237 "/usr/include/sys/stat.h" 3 4
extern int fstatat (int __fd, const char *__restrict __file,
      struct stat *__restrict __buf, int __flag)
# 262 "/usr/include/sys/stat.h" 3 4
extern int lstat (const char *__restrict __file,
# 283 "/usr/include/sys/stat.h" 3 4
extern int chmod (const char *__file, __mode_t __mode)
extern int lchmod (const char *__file, __mode_t __mode)
extern int fchmod (int __fd, __mode_t __mode) __attribute__ ((__nothrow__ , __leaf__));
extern int fchmodat (int __fd, const char *__file, __mode_t __mode,
       int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
extern __mode_t umask (__mode_t __mask) __attribute__ ((__nothrow__ , __leaf__));
# 320 "/usr/include/sys/stat.h" 3 4
extern int mkdir (const char *__path, __mode_t __mode)
extern int mkdirat (int __fd, const char *__path, __mode_t __mode)
extern int mknod (const char *__path, __mode_t __mode, __dev_t __dev)
extern int mknodat (int __fd, const char *__path, __mode_t __mode,
      __dev_t __dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int mkfifo (const char *__path, __mode_t __mode)
extern int mkfifoat (int __fd, const char *__path, __mode_t __mode)
extern int utimensat (int __fd, const char *__path,
        const struct timespec __times[2],
        int __flags)
extern int futimens (int __fd, const struct timespec __times[2]) __attribute__ ((__nothrow__ , __leaf__));
# 398 "/usr/include/sys/stat.h" 3 4
extern int __fxstat (int __ver, int __fildes, struct stat *__stat_buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int __xstat (int __ver, const char *__filename,
      struct stat *__stat_buf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int __lxstat (int __ver, const char *__filename,
extern int __fxstatat (int __ver, int __fildes, const char *__filename,
         struct stat *__stat_buf, int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4)));
# 441 "/usr/include/sys/stat.h" 3 4
extern int __xmknod (int __ver, const char *__path, __mode_t __mode,
       __dev_t *__dev) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int __xmknodat (int __ver, int __fd, const char *__path,
         __mode_t __mode, __dev_t *__dev)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 5)));
# 533 "/usr/include/sys/stat.h" 3 4
# 6 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
TEST checkSysWait from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
            Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 27 "/usr/include/time.h" 3 4
# 28 "/usr/include/time.h" 2 3 4
# 38 "/usr/include/time.h" 2 3 4
# 42 "/usr/include/time.h" 2 3 4
# 55 "/usr/include/time.h" 3 4
# 56 "/usr/include/time.h" 2 3 4
struct timespec
    __time_t tv_sec;
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const char *__restrict __format,
   const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 221 "/usr/include/time.h" 3 4
} *__locale_t;
# 222 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 236 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
   char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 430 "/usr/include/time.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/time.h" 1 3 4
# 21 "/usr/include/sys/time.h" 3 4
# 22 "/usr/include/sys/time.h" 2 3 4
# 24 "/usr/include/sys/time.h" 2 3 4
# 26 "/usr/include/sys/time.h" 2 3 4
struct timeval
    __time_t tv_sec;
# 28 "/usr/include/sys/time.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
typedef struct
  } fd_set;
# 30 "/usr/include/sys/time.h" 2 3 4
# 55 "/usr/include/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 71 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
    const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
      struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
        const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/sys/time.h" 3 4
              Defined "HAVE_SYS_TIME_H" to "1"
Successful compile:
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
  return 0;
            Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
  Checks for the math headers and defines
Checking for header: math.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/math.h" 1 3 4
# 26 "/usr/include/math.h" 3 4
# 27 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/huge_val.h" 1 3 4
# 33 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/huge_valf.h" 1 3 4
# 35 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/huge_vall.h" 1 3 4
# 36 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/inf.h" 1 3 4
# 39 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/nan.h" 1 3 4
# 42 "/usr/include/math.h" 2 3 4
# 1 "/usr/include/bits/mathdef.h" 1 3 4
# 28 "/usr/include/bits/mathdef.h" 3 4
typedef float float_t;
typedef double double_t;
# 46 "/usr/include/math.h" 2 3 4
# 69 "/usr/include/math.h" 3 4
# 1 "/usr/include/bits/mathcalls.h" 1 3 4
# 52 "/usr/include/bits/mathcalls.h" 3 4
extern double acos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atan2 (double __y, double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cos (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cos (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sin (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sin (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tan (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tan (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double cosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double sinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double tanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __tanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
# 86 "/usr/include/bits/mathcalls.h" 3 4
extern double acosh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __acosh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double asinh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __asinh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double atanh (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __atanh (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __frexp (double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern double __ldexp (double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern double log (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log10 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log10 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern double __modf (double __x, double *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 126 "/usr/include/bits/mathcalls.h" 3 4
extern double expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __expm1 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log1p (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log1p (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double logb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __logb (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __exp2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double log2 (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __log2 (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __pow (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __sqrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __hypot (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __cbrt (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __ceil (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fabs (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __floor (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fmod (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinf (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finite (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __drem (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double significand (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __significand (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __copysign (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double nan (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nan (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnan (double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double j0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double j1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __j1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double jn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __jn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double y0 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y0 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double y1 (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __y1 (double) __attribute__ ((__nothrow__ , __leaf__));
extern double yn (int, double) __attribute__ ((__nothrow__ , __leaf__)); extern double __yn (int, double) __attribute__ ((__nothrow__ , __leaf__));
extern double erf (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erf (double) __attribute__ ((__nothrow__ , __leaf__));
extern double erfc (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __erfc (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double tgamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __tgamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double gamma (double) __attribute__ ((__nothrow__ , __leaf__)); extern double __gamma (double) __attribute__ ((__nothrow__ , __leaf__));
extern double lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern double __lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern double rint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __rint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nextafter (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __nexttoward (double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __remainder (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbn (double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogb (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalbln (double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern double nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern double __nearbyint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __round (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __trunc (double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern double __remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrint (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrint (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lround (double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llround (double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llround (double __x) __attribute__ ((__nothrow__ , __leaf__));
extern double fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)); extern double __fdim (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__));
extern double fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fmax (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern double fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern double __fmin (double __x, double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __fpclassify (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbit (double __value) __attribute__ ((__nothrow__ , __leaf__))
extern double fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__)); extern double __fma (double __x, double __y, double __z) __attribute__ ((__nothrow__ , __leaf__));
# 371 "/usr/include/bits/mathcalls.h" 3 4
extern double scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__)); extern double __scalb (double __x, double __n) __attribute__ ((__nothrow__ , __leaf__));
# 70 "/usr/include/math.h" 2 3 4
# 88 "/usr/include/math.h" 3 4
extern float acosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atan2f (float __y, float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float cosf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cosf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float coshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __coshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __tanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __acoshf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __asinhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __atanhf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float expf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern float __ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern float logf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log10f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log10f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern float __modff (float __x, float *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern float expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __expm1f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log1pf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float logbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __logbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __exp2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float log2f (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __log2f (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __powf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __sqrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __hypotf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __cbrtf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __ceilf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fabsf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __floorf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmodf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinff (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitef (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __dremf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float significandf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __significandf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __copysignf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float nanf (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nanf (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnanf (float __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float j0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float j1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __j1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float jnf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __jnf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float y0f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y0f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float y1f (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __y1f (float) __attribute__ ((__nothrow__ , __leaf__));
extern float ynf (int, float) __attribute__ ((__nothrow__ , __leaf__)); extern float __ynf (int, float) __attribute__ ((__nothrow__ , __leaf__));
extern float erff (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erff (float) __attribute__ ((__nothrow__ , __leaf__));
extern float erfcf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __erfcf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float tgammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __tgammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float gammaf (float) __attribute__ ((__nothrow__ , __leaf__)); extern float __gammaf (float) __attribute__ ((__nothrow__ , __leaf__));
extern float lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern float __lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern float rintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __rintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nextafterf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __remainderf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbnf (float __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalblnf (float __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern float nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern float __nearbyintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __roundf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __truncf (float __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern float __remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundf (float __x) __attribute__ ((__nothrow__ , __leaf__));
extern float fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)); extern float __fdimf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__));
extern float fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fmaxf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern float fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern float __fminf (float __x, float __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __fpclassifyf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitf (float __value) __attribute__ ((__nothrow__ , __leaf__))
extern float fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__)); extern float __fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__ , __leaf__));
extern float scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__)); extern float __scalbf (float __x, float __n) __attribute__ ((__nothrow__ , __leaf__));
# 89 "/usr/include/math.h" 2 3 4
# 132 "/usr/include/math.h" 3 4
extern long double acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atan2l (long double __y, long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cosl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __coshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __acoshl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __asinhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __atanhl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double expl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__ , __leaf__));
extern long double logl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log10l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__)); extern long double __modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern long double expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __expm1l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log1pl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __logbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __exp2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __log2l (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __powl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __sqrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __hypotl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __cbrtl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __ceill (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fabsl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __floorl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmodl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern int __isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isinfl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int finitel (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __dreml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __significandl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __copysignl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double nanl (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nanl (const char *__tagb) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int isnanl (long double __value) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double j0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double j1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __j1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __jnl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y0l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y0l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double y1l (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __y1l (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __ynl (int, long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double erfcl (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __erfcl (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double tgammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __tgammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double gammal (long double) __attribute__ ((__nothrow__ , __leaf__)); extern long double __gammal (long double) __attribute__ ((__nothrow__ , __leaf__));
extern long double lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__)); extern long double __lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__ , __leaf__));
extern long double rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __rintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remainderl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbnl (long double __x, int __n) __attribute__ ((__nothrow__ , __leaf__));
extern int ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern int __ilogbl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__ , __leaf__));
extern long double nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long double __nearbyintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __roundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __truncl (long double __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__)); extern long double __remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__ , __leaf__));
extern long int lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llrintl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long int lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long int __lroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
__extension__
extern long long int llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__)); extern long long int __llroundl (long double __x) __attribute__ ((__nothrow__ , __leaf__));
extern long double fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fdiml (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__));
extern long double fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern long double fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)); extern long double __fminl (long double __x, long double __y) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int __fpclassifyl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern int __signbitl (long double __value) __attribute__ ((__nothrow__ , __leaf__))
extern long double fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__)); extern long double __fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__ , __leaf__));
extern long double scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__)); extern long double __scalbl (long double __x, long double __n) __attribute__ ((__nothrow__ , __leaf__));
# 133 "/usr/include/math.h" 2 3 4
# 148 "/usr/include/math.h" 3 4
extern int signgam;
# 189 "/usr/include/math.h" 3 4
enum
    FP_NAN =
      0,
    FP_INFINITE =
      1,
    FP_ZERO =
      2,
    FP_SUBNORMAL =
      3,
    FP_NORMAL =
      4
# 301 "/usr/include/math.h" 3 4
typedef enum
  _IEEE_ = -1,
  _SVID_,
  _XOPEN_,
  _POSIX_,
  _ISOC_
} _LIB_VERSION_TYPE;
extern _LIB_VERSION_TYPE _LIB_VERSION;
# 326 "/usr/include/math.h" 3 4
struct exception
    int type;
    char *name;
    double arg1;
    double arg2;
    double retval;
extern int matherr (struct exception *__exc);
# 488 "/usr/include/math.h" 3 4
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
              Defined "HAVE_MATH_H" to "1"
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.headers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
          Found math #defines, like M_PI
TEST check from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
# 1 "/usr/include/sys/socket.h" 1 3 4
# 22 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 23 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/sys/uio.h" 1 3 4
# 23 "/usr/include/sys/uio.h" 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 24 "/usr/include/sys/uio.h" 2 3 4
# 1 "/usr/include/bits/uio.h" 1 3 4
# 43 "/usr/include/bits/uio.h" 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
# 29 "/usr/include/sys/uio.h" 2 3 4
# 39 "/usr/include/sys/uio.h" 3 4
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count)
# 50 "/usr/include/sys/uio.h" 3 4
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count)
# 65 "/usr/include/sys/uio.h" 3 4
extern ssize_t preadv (int __fd, const struct iovec *__iovec, int __count,
         __off_t __offset) ;
# 77 "/usr/include/sys/uio.h" 3 4
extern ssize_t pwritev (int __fd, const struct iovec *__iovec, int __count,
   __off_t __offset) ;
# 120 "/usr/include/sys/uio.h" 3 4
# 27 "/usr/include/sys/socket.h" 2 3 4
# 29 "/usr/include/sys/socket.h" 2 3 4
# 38 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/bits/socket.h" 1 3 4
# 27 "/usr/include/bits/socket.h" 3 4
# 28 "/usr/include/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
# 1 "/usr/include/bits/socket_type.h" 1 3 4
# 24 "/usr/include/bits/socket_type.h" 3 4
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
  SOCK_CLOEXEC = 02000000,
  SOCK_NONBLOCK = 00004000
# 39 "/usr/include/bits/socket.h" 2 3 4
# 146 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/bits/sockaddr.h" 1 3 4
# 28 "/usr/include/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 147 "/usr/include/bits/socket.h" 2 3 4
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
# 162 "/usr/include/bits/socket.h" 3 4
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_DONTROUTE = 0x04,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_DONTWAIT = 0x40,
    MSG_EOR = 0x80,
    MSG_WAITALL = 0x100,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_CONFIRM = 0x800,
    MSG_RST = 0x1000,
    MSG_ERRQUEUE = 0x2000,
    MSG_NOSIGNAL = 0x4000,
    MSG_MORE = 0x8000,
    MSG_WAITFORONE = 0x10000,
    MSG_FASTOPEN = 0x20000000,
    MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
    int msg_flags;
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
# 272 "/usr/include/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
          struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 299 "/usr/include/bits/socket.h" 3 4
enum
    SCM_RIGHTS = 0x01
# 345 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 2 3 4
# 5 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/asm/socket.h" 2 3 4
# 346 "/usr/include/bits/socket.h" 2 3 4
# 379 "/usr/include/bits/socket.h" 3 4
struct linger
    int l_onoff;
    int l_linger;
# 39 "/usr/include/sys/socket.h" 2 3 4
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
# 113 "/usr/include/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
         int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
   socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 137 "/usr/include/sys/socket.h" 3 4
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
         int __flags, const struct sockaddr * __addr,
         socklen_t __addr_len);
# 174 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
    int __flags, struct sockaddr *__restrict __addr,
    socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
   int __flags);
# 202 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
# 219 "/usr/include/sys/socket.h" 3 4
extern int getsockopt (int __fd, int __level, int __optname,
         void *__restrict __optval,
         socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
         const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 243 "/usr/include/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 261 "/usr/include/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 283 "/usr/include/sys/socket.h" 3 4
              Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/types.h
stdout:
# 1 "<built-in>"
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
              Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/malloc.h" 1 3 4
# 22 "/usr/include/malloc.h" 3 4
# 23 "/usr/include/malloc.h" 2 3 4
# 147 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 324 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef int wchar_t;
# 24 "/usr/include/malloc.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 29 "/usr/include/stdio.h" 3 4
# 34 "/usr/include/stdio.h" 2 3 4
# 36 "/usr/include/stdio.h" 2 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 74 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 31 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 82 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 32 "/usr/include/libio.h" 2 3 4
# 49 "/usr/include/libio.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 50 "/usr/include/libio.h" 2 3 4
# 144 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 154 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 177 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 245 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 293 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 302 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
typedef struct _IO_FILE _IO_FILE;
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 338 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
# 390 "/usr/include/libio.h" 3 4
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 434 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ferror (_IO_FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern void _IO_funlockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
extern int _IO_ftrylockfile (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 464 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) __attribute__ ((__nothrow__ , __leaf__));
# 75 "/usr/include/stdio.h" 2 3 4
typedef __gnuc_va_list va_list;
# 90 "/usr/include/stdio.h" 3 4
# 102 "/usr/include/stdio.h" 3 4
typedef _G_fpos_t fpos_t;
# 164 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 165 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) __attribute__ ((__nothrow__ , __leaf__));
extern int rename (const char *__old, const char *__new) __attribute__ ((__nothrow__ , __leaf__));
extern int renameat (int __oldfd, const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 209 "/usr/include/stdio.h" 3 4
extern char *tmpnam (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
extern char *tmpnam_r (char *__s) __attribute__ ((__nothrow__ , __leaf__)) ;
# 227 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 252 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 266 "/usr/include/stdio.h" 3 4
extern FILE *fopen (const char *__restrict __filename,
      const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
        const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 295 "/usr/include/stdio.h" 3 4
# 306 "/usr/include/stdio.h" 3 4
extern FILE *fdopen (int __fd, const char *__modes) __attribute__ ((__nothrow__ , __leaf__)) ;
# 319 "/usr/include/stdio.h" 3 4
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) __attribute__ ((__nothrow__ , __leaf__));
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
         size_t __size) __attribute__ ((__nothrow__ , __leaf__));
extern void setlinebuf (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int fprintf (FILE *__restrict __stream,
      const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      const char *__restrict __format, ...) __attribute__ ((__nothrow__));
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg) __attribute__ ((__nothrow__));
extern int snprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 0)));
# 412 "/usr/include/stdio.h" 3 4
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
     const char *__restrict __format, ...) __attribute__ ((__nothrow__ , __leaf__));
# 443 "/usr/include/stdio.h" 3 4
extern int fscanf (FILE *__restrict __stream, const char *__restrict __format, ...) __asm__ ("" "__isoc99_fscanf")
extern int scanf (const char *__restrict __format, ...) __asm__ ("" "__isoc99_scanf")
extern int sscanf (const char *__restrict __s, const char *__restrict __format, ...) __asm__ ("" "__isoc99_sscanf") __attribute__ ((__nothrow__ , __leaf__))
# 463 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__format__ (__scanf__, 2, 0)));
# 494 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vfscanf")
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vscanf")
extern int vsscanf (const char *__restrict __s, const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vsscanf") __attribute__ ((__nothrow__ , __leaf__))
# 522 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 550 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 561 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 594 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 638 "/usr/include/stdio.h" 3 4
extern char *gets (char *__s) __attribute__ ((__deprecated__));
# 665 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 737 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 773 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 792 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 815 "/usr/include/stdio.h" 3 4
# 824 "/usr/include/stdio.h" 3 4
extern void clearerr (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void clearerr_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int feof_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int ferror_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
# 854 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int fileno_unlocked (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
# 872 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) __attribute__ ((__nothrow__ , __leaf__));
# 912 "/usr/include/stdio.h" 3 4
extern void flockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
extern int ftrylockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void funlockfile (FILE *__stream) __attribute__ ((__nothrow__ , __leaf__));
# 942 "/usr/include/stdio.h" 3 4
# 25 "/usr/include/malloc.h" 2 3 4
# 35 "/usr/include/malloc.h" 3 4
extern void *malloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void cfree (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void *memalign (size_t __alignment, size_t __size)
extern void *valloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *pvalloc (size_t __size) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) ;
extern void *(*__morecore) (ptrdiff_t __size);
extern void *__default_morecore (ptrdiff_t __size)
__attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__));
struct mallinfo
  int arena;
  int ordblks;
  int smblks;
  int hblks;
  int hblkhd;
  int usmblks;
  int fsmblks;
  int uordblks;
  int fordblks;
  int keepcost;
extern struct mallinfo mallinfo (void) __attribute__ ((__nothrow__ , __leaf__));
# 121 "/usr/include/malloc.h" 3 4
extern int mallopt (int __param, int __val) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_trim (size_t __pad) __attribute__ ((__nothrow__ , __leaf__));
extern size_t malloc_usable_size (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void malloc_stats (void) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_info (int __options, FILE *__fp) __attribute__ ((__nothrow__ , __leaf__));
extern void *malloc_get_state (void) __attribute__ ((__nothrow__ , __leaf__));
extern int malloc_set_state (void *__ptr) __attribute__ ((__nothrow__ , __leaf__));
extern void (*volatile __malloc_initialize_hook) (void)
extern void (*volatile __free_hook) (void *__ptr,
                                                   const void *)
extern void *(*volatile __malloc_hook)(size_t __size,
                                                     const void *)
extern void *(*volatile __realloc_hook)(void *__ptr,
                                                      size_t __size,
                                                      const void *)
extern void *(*volatile __memalign_hook)(size_t __alignment,
                                                       size_t __size,
                                                       const void *)
extern void (*volatile __after_morecore_hook) (void);
extern void __malloc_check_init (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_MALLOC_H" to "1"
Checking for header: time.h
stdout:
# 1 "<built-in>"
# 27 "/usr/include/time.h" 3 4
# 28 "/usr/include/time.h" 2 3 4
# 38 "/usr/include/time.h" 2 3 4
# 42 "/usr/include/time.h" 2 3 4
# 55 "/usr/include/time.h" 3 4
# 56 "/usr/include/time.h" 2 3 4
struct timespec
    __time_t tv_sec;
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) __attribute__ ((__nothrow__ , __leaf__));
extern time_t time (time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const struct tm *__restrict __tp) __attribute__ ((__nothrow__ , __leaf__));
# 221 "/usr/include/time.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 222 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) __attribute__ ((__nothrow__ , __leaf__));
# 236 "/usr/include/time.h" 3 4
extern struct tm *gmtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *localtime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern char *ctime (const time_t *__timer) __attribute__ ((__nothrow__ , __leaf__));
extern char *asctime_r (const struct tm *__restrict __tp,
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) __attribute__ ((__nothrow__ , __leaf__));
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int dysize (int __year) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__ , __leaf__));
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__ , __leaf__));
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__ , __leaf__));
# 430 "/usr/include/time.h" 3 4
              Defined "HAVE_TIME_H" to "1"
Checking for header: Direct.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2stderr:
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory
 #include <Direct.h>
compilation terminated.
Source:
#include <Direct.h>
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory
 #include <Direct.h>
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory #include <Direct.h>                    ^compilation terminated.:
Checking for header: Ws2tcpip.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory
 #include <Ws2tcpip.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory #include <Ws2tcpip.h>                      ^compilation terminated.:
Checking for header: endian.h
stdout:
# 1 "<built-in>"
# 21 "/usr/include/endian.h" 3 4
# 22 "/usr/include/endian.h" 2 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 2 3 4
              Defined "HAVE_ENDIAN_H" to "1"
Checking for header: ieeefp.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory
 #include <ieeefp.h>
Source:
#include <ieeefp.h>
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory
 #include <ieeefp.h>
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory #include <ieeefp.h>                    ^compilation terminated.:
Checking for header: strings.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/strings.h" 1 3 4
# 26 "/usr/include/strings.h" 3 4
# 27 "/usr/include/strings.h" 2 3 4
# 29 "/usr/include/strings.h" 2 3 4
# 39 "/usr/include/strings.h" 3 4
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__));
extern void bcopy (const void *__src, void *__dest, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
# 76 "/usr/include/strings.h" 3 4
extern char *index (const char *__s, int __c)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
# 104 "/usr/include/strings.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((const));
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
} *__locale_t;
# 128 "/usr/include/strings.h" 2 3 4
extern int strcasecmp_l (const char *__s1, const char *__s2, __locale_t __loc)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int strncasecmp_l (const char *__s1, const char *__s2,
     size_t __n, __locale_t __loc)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
              Defined "HAVE_STRINGS_H" to "1"
Checking for header: sched.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sched.h" 1 3 4
# 22 "/usr/include/sched.h" 3 4
# 23 "/usr/include/sched.h" 2 3 4
# 26 "/usr/include/sched.h" 2 3 4
# 29 "/usr/include/sched.h" 2 3 4
struct timespec
    __time_t tv_sec;
# 35 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/bits/sched.h" 1 3 4
# 72 "/usr/include/bits/sched.h" 3 4
struct sched_param
    int __sched_priority;
# 95 "/usr/include/bits/sched.h" 3 4
struct __sched_param
# 118 "/usr/include/bits/sched.h" 3 4
typedef unsigned long int __cpu_mask;
typedef struct
  __cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
# 201 "/usr/include/bits/sched.h" 3 4
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void __sched_cpufree (cpu_set_t *__set) __attribute__ ((__nothrow__ , __leaf__));
# 44 "/usr/include/sched.h" 2 3 4
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_setscheduler (__pid_t __pid, int __policy,
          const struct sched_param *__param) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_getscheduler (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_yield (void) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_max (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_get_priority_min (int __algorithm) __attribute__ ((__nothrow__ , __leaf__));
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) __attribute__ ((__nothrow__ , __leaf__));
# 126 "/usr/include/sched.h" 3 4
              Defined "HAVE_SCHED_H" to "1"
Checking for header: cxxabi.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory
 #include <cxxabi.h>
Source:
#include <cxxabi.h>
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory
 #include <cxxabi.h>
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory #include <cxxabi.h>                    ^compilation terminated.:
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
 #include <sys/systeminfo.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory #include <sys/systeminfo.h>                            ^compilation terminated.:
Checking for header: dos.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory
 #include <dos.h>
Source:
#include <dos.h>
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory
 #include <dos.h>
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory #include <dos.h>                 ^compilation terminated.:
Checking for header: WindowsX.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory
 #include <WindowsX.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory #include <WindowsX.h>                      ^compilation terminated.:
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/sysinfo.h" 1 3 4
# 21 "/usr/include/sys/sysinfo.h" 3 4
# 22 "/usr/include/sys/sysinfo.h" 2 3 4
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 1 "/usr/include/linux/sysinfo.h" 1 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 1 "/usr/include/asm/types.h" 1 3 4
# 1 "/usr/include/asm-generic/types.h" 1 3 4
# 1 "/usr/include/asm-generic/int-ll64.h" 1 3 4
# 11 "/usr/include/asm-generic/int-ll64.h" 3 4
# 1 "/usr/include/asm/bitsperlong.h" 1 3 4
# 10 "/usr/include/asm/bitsperlong.h" 3 4
# 1 "/usr/include/asm-generic/bitsperlong.h" 1 3 4
# 11 "/usr/include/asm/bitsperlong.h" 2 3 4
# 12 "/usr/include/asm-generic/int-ll64.h" 2 3 4
typedef __signed__ char __s8;
typedef unsigned char __u8;
typedef __signed__ short __s16;
typedef unsigned short __u16;
typedef __signed__ int __s32;
typedef unsigned int __u32;
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
# 7 "/usr/include/asm-generic/types.h" 2 3 4
# 5 "/usr/include/asm/types.h" 2 3 4
# 5 "/usr/include/linux/types.h" 2 3 4
# 1 "/usr/include/linux/posix_types.h" 1 3 4
# 1 "/usr/include/linux/stddef.h" 1 3 4
# 5 "/usr/include/linux/posix_types.h" 2 3 4
# 24 "/usr/include/linux/posix_types.h" 3 4
typedef struct {
 unsigned long fds_bits[1024 / (8 * sizeof(long))];
} __kernel_fd_set;
typedef void (*__kernel_sighandler_t)(int);
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
# 1 "/usr/include/asm/posix_types.h" 1 3 4
# 1 "/usr/include/asm/posix_types_64.h" 1 3 4
# 10 "/usr/include/asm/posix_types_64.h" 3 4
typedef unsigned short __kernel_old_uid_t;
typedef unsigned short __kernel_old_gid_t;
typedef unsigned long __kernel_old_dev_t;
# 1 "/usr/include/asm-generic/posix_types.h" 1 3 4
# 14 "/usr/include/asm-generic/posix_types.h" 3 4
typedef long __kernel_long_t;
typedef unsigned long __kernel_ulong_t;
typedef __kernel_ulong_t __kernel_ino_t;
typedef unsigned int __kernel_mode_t;
typedef int __kernel_pid_t;
typedef int __kernel_ipc_pid_t;
typedef unsigned int __kernel_uid_t;
typedef unsigned int __kernel_gid_t;
typedef __kernel_long_t __kernel_suseconds_t;
typedef int __kernel_daddr_t;
typedef unsigned int __kernel_uid32_t;
typedef unsigned int __kernel_gid32_t;
# 71 "/usr/include/asm-generic/posix_types.h" 3 4
typedef __kernel_ulong_t __kernel_size_t;
typedef __kernel_long_t __kernel_ssize_t;
typedef __kernel_long_t __kernel_ptrdiff_t;
typedef struct {
 int val[2];
} __kernel_fsid_t;
typedef __kernel_long_t __kernel_off_t;
typedef long long __kernel_loff_t;
typedef __kernel_long_t __kernel_time_t;
typedef __kernel_long_t __kernel_clock_t;
typedef int __kernel_timer_t;
typedef int __kernel_clockid_t;
typedef char * __kernel_caddr_t;
typedef unsigned short __kernel_uid16_t;
typedef unsigned short __kernel_gid16_t;
# 18 "/usr/include/asm/posix_types_64.h" 2 3 4
# 7 "/usr/include/asm/posix_types.h" 2 3 4
# 36 "/usr/include/linux/posix_types.h" 2 3 4
# 9 "/usr/include/linux/types.h" 2 3 4
# 27 "/usr/include/linux/types.h" 3 4
typedef __u16 __le16;
typedef __u16 __be16;
typedef __u32 __le32;
typedef __u32 __be32;
typedef __u64 __le64;
typedef __u64 __be64;
typedef __u16 __sum16;
typedef __u32 __wsum;
# 5 "/usr/include/linux/sysinfo.h" 2 3 4
struct sysinfo {
 __kernel_long_t uptime;
 __kernel_ulong_t loads[3];
 __kernel_ulong_t totalram;
 __kernel_ulong_t freeram;
 __kernel_ulong_t sharedram;
 __kernel_ulong_t bufferram;
 __kernel_ulong_t totalswap;
 __kernel_ulong_t freeswap;
 __u16 procs;
 __u16 pad;
 __kernel_ulong_t totalhigh;
 __kernel_ulong_t freehigh;
 __u32 mem_unit;
 char _f[20-2*sizeof(__kernel_ulong_t)-sizeof(__u32)];
# 5 "/usr/include/linux/kernel.h" 2 3 4
# 25 "/usr/include/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/wait.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/wait.h" 1 3 4
# 25 "/usr/include/sys/wait.h" 3 4
# 26 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/signal.h" 1 3 4
# 30 "/usr/include/signal.h" 3 4
typedef struct
  } __sigset_t;
# 102 "/usr/include/bits/sigset.h" 3 4
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
# 33 "/usr/include/signal.h" 2 3 4
typedef __sig_atomic_t sig_atomic_t;
# 57 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/signum.h" 1 3 4
# 58 "/usr/include/signal.h" 2 3 4
struct timespec
    __time_t tv_sec;
# 76 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/siginfo.h" 1 3 4
# 24 "/usr/include/bits/siginfo.h" 3 4
# 25 "/usr/include/bits/siginfo.h" 2 3 4
typedef union sigval
    int sival_int;
    void *sival_ptr;
  } sigval_t;
# 58 "/usr/include/bits/siginfo.h" 3 4
typedef __clock_t __sigchld_clock_t;
typedef struct
    int si_signo;
    int si_errno;
    int si_code;
    union
 int _pad[((128 / sizeof (int)) - 4)];
 struct
     __pid_t si_pid;
     __uid_t si_uid;
   } _kill;
 struct
     int si_tid;
     int si_overrun;
     sigval_t si_sigval;
   } _timer;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     sigval_t si_sigval;
   } _rt;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     int si_status;
     __sigchld_clock_t si_utime;
     __sigchld_clock_t si_stime;
   } _sigchld;
 struct
     void *si_addr;
     short int si_addr_lsb;
   } _sigfault;
 struct
     long int si_band;
     int si_fd;
   } _sigpoll;
 struct
     void *_call_addr;
     int _syscall;
     unsigned int _arch;
   } _sigsys;
      } _sifields;
  } siginfo_t ;
# 153 "/usr/include/bits/siginfo.h" 3 4
enum
  SI_ASYNCNL = -60,
  SI_TKILL = -6,
  SI_SIGIO,
  SI_ASYNCIO,
  SI_MESGQ,
  SI_TIMER,
  SI_QUEUE,
  SI_USER,
  SI_KERNEL = 0x80
enum
  ILL_ILLOPC = 1,
  ILL_ILLOPN,
  ILL_ILLADR,
  ILL_ILLTRP,
  ILL_PRVOPC,
  ILL_PRVREG,
  ILL_COPROC,
  ILL_BADSTK
enum
  FPE_INTDIV = 1,
  FPE_INTOVF,
  FPE_FLTDIV,
  FPE_FLTOVF,
  FPE_FLTUND,
  FPE_FLTRES,
  FPE_FLTINV,
  FPE_FLTSUB
enum
  SEGV_MAPERR = 1,
  SEGV_ACCERR
enum
  BUS_ADRALN = 1,
  BUS_ADRERR,
  BUS_OBJERR,
  BUS_MCEERR_AR,
  BUS_MCEERR_AO
# 257 "/usr/include/bits/siginfo.h" 3 4
enum
  CLD_EXITED = 1,
  CLD_KILLED,
  CLD_DUMPED,
  CLD_TRAPPED,
  CLD_STOPPED,
  CLD_CONTINUED
enum
  POLL_IN = 1,
  POLL_OUT,
  POLL_MSG,
  POLL_ERR,
  POLL_PRI,
  POLL_HUP
# 309 "/usr/include/bits/siginfo.h" 3 4
typedef struct sigevent
    sigval_t sigev_value;
    int sigev_signo;
    int sigev_notify;
    union
 int _pad[((64 / sizeof (int)) - 4)];
 __pid_t _tid;
 struct
     void (*_function) (sigval_t);
     pthread_attr_t *_attribute;
   } _sigev_thread;
      } _sigev_un;
  } sigevent_t;
enum
  SIGEV_SIGNAL = 0,
  SIGEV_NONE,
  SIGEV_THREAD,
  SIGEV_THREAD_ID = 4
# 81 "/usr/include/signal.h" 2 3 4
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
# 100 "/usr/include/signal.h" 3 4
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
# 114 "/usr/include/signal.h" 3 4
# 127 "/usr/include/signal.h" 3 4
extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int raise (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern void psignal (int __sig, const char *__s);
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
# 167 "/usr/include/signal.h" 3 4
extern int __sigpause (int __sig_or_mask, int __is_sig);
# 189 "/usr/include/signal.h" 3 4
extern int sigblock (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int sigsetmask (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int siggetmask (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
# 209 "/usr/include/signal.h" 3 4
typedef __sighandler_t sig_t;
extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigismember (const sigset_t *__set, int __signo)
# 245 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigaction.h" 1 3 4
# 24 "/usr/include/bits/sigaction.h" 3 4
struct sigaction
    union
 __sighandler_t sa_handler;
 void (*sa_sigaction) (int, siginfo_t *, void *);
    __sigaction_handler;
    __sigset_t sa_mask;
    int sa_flags;
    void (*sa_restorer) (void);
# 246 "/usr/include/signal.h" 2 3 4
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
   sigset_t *__restrict __oset) __attribute__ ((__nothrow__ , __leaf__));
extern int sigsuspend (const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
        struct sigaction *__restrict __oact) __attribute__ ((__nothrow__ , __leaf__));
extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
     __attribute__ ((__nonnull__ (1, 2)));
extern int sigwaitinfo (const sigset_t *__restrict __set,
   siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
extern int sigtimedwait (const sigset_t *__restrict __set,
    siginfo_t *__restrict __info,
    const struct timespec *__restrict __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
# 303 "/usr/include/signal.h" 3 4
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
struct sigvec
    __sighandler_t sv_handler;
    int sv_mask;
    int sv_flags;
# 327 "/usr/include/signal.h" 3 4
extern int sigvec (int __sig, const struct sigvec *__vec,
     struct sigvec *__ovec) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigcontext.h" 1 3 4
# 29 "/usr/include/bits/sigcontext.h" 3 4
struct _fpx_sw_bytes
  __uint32_t magic1;
  __uint32_t extended_size;
  __uint64_t xstate_bv;
  __uint32_t xstate_size;
  __uint32_t padding[7];
struct _fpreg
  unsigned short significand[4];
  unsigned short exponent;
struct _fpxreg
  unsigned short padding[3];
struct _xmmreg
  __uint32_t element[4];
# 121 "/usr/include/bits/sigcontext.h" 3 4
struct _fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  __uint32_t mxcr_mask;
  struct _fpxreg _st[8];
  struct _xmmreg _xmm[16];
  __uint32_t padding[24];
struct sigcontext
  __uint64_t r8;
  __uint64_t r9;
  __uint64_t r10;
  __uint64_t r11;
  __uint64_t r12;
  __uint64_t r13;
  __uint64_t r14;
  __uint64_t r15;
  __uint64_t rdi;
  __uint64_t rsi;
  __uint64_t rbp;
  __uint64_t rbx;
  __uint64_t rdx;
  __uint64_t rax;
  __uint64_t rcx;
  __uint64_t rsp;
  __uint64_t rip;
  __uint64_t eflags;
  unsigned short cs;
  unsigned short gs;
  unsigned short fs;
  unsigned short __pad0;
  __uint64_t err;
  __uint64_t trapno;
  __uint64_t oldmask;
  __uint64_t cr2;
  __extension__ union
      struct _fpstate * fpstate;
      __uint64_t __fpstate_word;
  __uint64_t __reserved1 [8];
struct _xsave_hdr
  __uint64_t reserved1[2];
  __uint64_t reserved2[5];
struct _ymmh_state
  __uint32_t ymmh_space[64];
struct _xstate
  struct _fpstate fpstate;
  struct _xsave_hdr xstate_hdr;
  struct _ymmh_state ymmh;
# 333 "/usr/include/signal.h" 2 3 4
extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__ , __leaf__));
# 343 "/usr/include/signal.h" 2 3 4
extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigstack.h" 1 3 4
# 25 "/usr/include/bits/sigstack.h" 3 4
struct sigstack
    void *ss_sp;
    int ss_onstack;
enum
  SS_ONSTACK = 1,
  SS_DISABLE
# 49 "/usr/include/bits/sigstack.h" 3 4
typedef struct sigaltstack
    void *ss_sp;
    int ss_flags;
    size_t ss_size;
  } stack_t;
# 350 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/sys/ucontext.h" 1 3 4
# 22 "/usr/include/sys/ucontext.h" 3 4
# 23 "/usr/include/sys/ucontext.h" 2 3 4
# 31 "/usr/include/sys/ucontext.h" 3 4
__extension__ typedef long long int greg_t;
typedef greg_t gregset_t[23];
# 92 "/usr/include/sys/ucontext.h" 3 4
struct _libc_fpxreg
  unsigned short int significand[4];
  unsigned short int exponent;
  unsigned short int padding[3];
struct _libc_xmmreg
struct _libc_fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  struct _libc_fpxreg _st[8];
  struct _libc_xmmreg _xmm[16];
typedef struct _libc_fpstate *fpregset_t;
typedef struct
    gregset_t gregs;
    fpregset_t fpregs;
    __extension__ unsigned long long __reserved1 [8];
} mcontext_t;
typedef struct ucontext
    unsigned long int uc_flags;
    struct ucontext *uc_link;
    stack_t uc_stack;
    mcontext_t uc_mcontext;
    __sigset_t uc_sigmask;
    struct _libc_fpstate __fpregs_mem;
  } ucontext_t;
# 353 "/usr/include/signal.h" 2 3 4
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
extern int sigaltstack (const struct sigaltstack *__restrict __ss,
   struct sigaltstack *__restrict __oss) __attribute__ ((__nothrow__ , __leaf__));
# 387 "/usr/include/signal.h" 3 4
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 388 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/sigthread.h" 1 3 4
# 30 "/usr/include/bits/sigthread.h" 3 4
extern int pthread_sigmask (int __how,
       const __sigset_t *__restrict __newmask,
       __sigset_t *__restrict __oldmask)__attribute__ ((__nothrow__ , __leaf__));
extern int pthread_kill (pthread_t __threadid, int __signo) __attribute__ ((__nothrow__ , __leaf__));
# 389 "/usr/include/signal.h" 2 3 4
extern int __libc_current_sigrtmin (void) __attribute__ ((__nothrow__ , __leaf__));
extern int __libc_current_sigrtmax (void) __attribute__ ((__nothrow__ , __leaf__));
# 30 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 36 "/usr/include/sys/wait.h" 2 3 4
# 60 "/usr/include/sys/wait.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
  } __WAIT_STATUS __attribute__ ((__transparent_union__));
# 77 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 78 "/usr/include/sys/wait.h" 2 3 4
# 99 "/usr/include/sys/wait.h" 3 4
typedef enum
  P_ALL,
  P_PID,
  P_PGID
} idtype_t;
# 113 "/usr/include/sys/wait.h" 3 4
extern __pid_t wait (__WAIT_STATUS __stat_loc);
# 136 "/usr/include/sys/wait.h" 3 4
extern __pid_t waitpid (__pid_t __pid, int *__stat_loc, int __options);
# 147 "/usr/include/sys/wait.h" 2 3 4
# 159 "/usr/include/sys/wait.h" 3 4
extern int waitid (idtype_t __idtype, __id_t __id, siginfo_t *__infop,
     int __options);
struct rusage;
extern __pid_t wait3 (__WAIT_STATUS __stat_loc, int __options,
        struct rusage * __usage) __attribute__ ((__nothrow__));
extern __pid_t wait4 (__pid_t __pid, __WAIT_STATUS __stat_loc, int __options,
        struct rusage *__usage) __attribute__ ((__nothrow__));
              Defined "HAVE_SYS_WAIT_H" to "1"
Checking for header: stdlib.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 33 "/usr/include/stdlib.h" 2 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int:16;
    struct
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 67 "/usr/include/stdlib.h" 3 4
typedef union
    union wait *__uptr;
    int *__iptr;
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__ , __leaf__)) ;
extern double atof (const char *__nptr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) __attribute__ ((__nothrow__ , __leaf__)) ;
extern long int a64l (const char *__s)
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) __attribute__ ((__nothrow__ , __leaf__));
extern void srand (unsigned int __seed) __attribute__ ((__nothrow__ , __leaf__));
extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__ , __leaf__));
extern double drand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) __attribute__ ((__nothrow__ , __leaf__));
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern void *alloca (size_t __size) __attribute__ ((__nothrow__ , __leaf__));
# 493 "/usr/include/stdlib.h" 2 3 4
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 513 "/usr/include/stdlib.h" 3 4
extern void abort (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 530 "/usr/include/stdlib.h" 3 4
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern void _Exit (int __status) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 578 "/usr/include/stdlib.h" 3 4
extern int putenv (char *__string) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) __attribute__ ((__nothrow__ , __leaf__));
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 711 "/usr/include/stdlib.h" 3 4
extern int system (const char *__command) ;
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) __attribute__ ((__nothrow__ , __leaf__)) ;
typedef int (*__compar_fn_t) (const void *, const void *);
# 751 "/usr/include/stdlib.h" 3 4
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
# 774 "/usr/include/stdlib.h" 3 4
extern int abs (int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
extern long int labs (long int __x) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__ , __leaf__));
extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__ , __leaf__));
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
extern int rpmatch (const char *__response) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3))) ;
# 950 "/usr/include/stdlib.h" 3 4
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
              Defined "HAVE_STDLIB_H" to "1"
TEST check from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: pthread.h
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
# 1 "/usr/include/pthread.h" 1 3 4
# 21 "/usr/include/pthread.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 22 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 23 "/usr/include/pthread.h" 2 3 4
# 28 "/usr/include/sched.h" 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 1 "/usr/include/time.h" 1 3 4
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
typedef __pid_t pid_t;
struct sched_param
typedef struct
} cpu_set_t;
# 24 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/time.h" 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/time.h" 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
struct itimerspec
struct sigevent;
} *__locale_t;
# 25 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 27 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/setjmp.h" 1 3 4
# 26 "/usr/include/bits/setjmp.h" 3 4
# 27 "/usr/include/bits/setjmp.h" 2 3 4
typedef long int __jmp_buf[8];
# 28 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/pthread.h" 2 3 4
enum
  PTHREAD_CREATE_JOINABLE,
  PTHREAD_CREATE_DETACHED
enum
  PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_ADAPTIVE_NP
  PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
enum
  PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_ROBUST,
  PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
enum
  PTHREAD_PRIO_NONE,
  PTHREAD_PRIO_INHERIT,
  PTHREAD_PRIO_PROTECT
# 116 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_RWLOCK_PREFER_READER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
  PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
# 157 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_INHERIT_SCHED,
  PTHREAD_EXPLICIT_SCHED
enum
  PTHREAD_SCOPE_SYSTEM,
  PTHREAD_SCOPE_PROCESS
enum
  PTHREAD_PROCESS_PRIVATE,
  PTHREAD_PROCESS_SHARED
# 192 "/usr/include/pthread.h" 3 4
struct _pthread_cleanup_buffer
  void (*__routine) (void *);
  void *__arg;
  int __canceltype;
  struct _pthread_cleanup_buffer *__prev;
enum
  PTHREAD_CANCEL_ENABLE,
  PTHREAD_CANCEL_DISABLE
enum
  PTHREAD_CANCEL_DEFERRED,
  PTHREAD_CANCEL_ASYNCHRONOUS
# 230 "/usr/include/pthread.h" 3 4
extern int pthread_create (pthread_t *__restrict __newthread,
      const pthread_attr_t *__restrict __attr,
      void *(*__start_routine) (void *),
      void *__restrict __arg) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 3)));
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
extern int pthread_join (pthread_t __th, void **__thread_return);
# 273 "/usr/include/pthread.h" 3 4
extern int pthread_detach (pthread_t __th) __attribute__ ((__nothrow__ , __leaf__));
extern pthread_t pthread_self (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2)
extern int pthread_attr_init (pthread_attr_t *__attr) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
     int *__detachstate)
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
     int __detachstate)
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
          size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
          size_t __guardsize)
extern int pthread_attr_getschedparam (const pthread_attr_t *__restrict __attr,
           struct sched_param *__restrict __param)
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
           const struct sched_param *__restrict
           __param) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_attr_getschedpolicy (const pthread_attr_t *__restrict
     __attr, int *__restrict __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (const pthread_attr_t *__restrict
      __attr, int *__restrict __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
      int __inherit)
extern int pthread_attr_getscope (const pthread_attr_t *__restrict __attr,
      int *__restrict __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (const pthread_attr_t *__restrict
          __attr, void **__restrict __stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) __attribute__ ((__deprecated__));
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
          void *__stackaddr)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__));
extern int pthread_attr_getstacksize (const pthread_attr_t *__restrict
          __attr, size_t *__restrict __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
          size_t __stacksize)
extern int pthread_attr_getstack (const pthread_attr_t *__restrict __attr,
      void **__restrict __stackaddr,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
      size_t __stacksize) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 431 "/usr/include/pthread.h" 3 4
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (3)));
extern int pthread_getschedparam (pthread_t __target_thread,
      int *__restrict __policy,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3)));
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
# 496 "/usr/include/pthread.h" 3 4
extern int pthread_once (pthread_once_t *__once_control,
    void (*__init_routine) (void)) __attribute__ ((__nonnull__ (1, 2)));
# 508 "/usr/include/pthread.h" 3 4
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
  struct
    __jmp_buf __cancel_jmp_buf;
    int __mask_was_saved;
  } __cancel_jmp_buf[1];
  void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
# 542 "/usr/include/pthread.h" 3 4
struct __pthread_cleanup_frame
  void (*__cancel_routine) (void *);
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
# 682 "/usr/include/pthread.h" 3 4
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
# 694 "/usr/include/pthread.h" 3 4
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
# 735 "/usr/include/pthread.h" 3 4
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
     __attribute__ ((__weak__))
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) __attribute__ ((__nothrow__));
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
          const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
     __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
        __abstime) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
extern int pthread_mutex_getprioceiling (const pthread_mutex_t *
      __restrict __mutex,
      int *__restrict __prioceiling)
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
      int __prioceiling,
      int *__restrict __old_ceiling)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3)));
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
# 808 "/usr/include/pthread.h" 3 4
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
      __restrict __attr,
      int *__restrict __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
      int __pshared)
extern int pthread_mutexattr_gettype (const pthread_mutexattr_t *__restrict
          __attr, int *__restrict __kind)
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
extern int pthread_mutexattr_getprotocol (const pthread_mutexattr_t *
       __restrict __attr,
       int *__restrict __protocol)
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
       int __protocol)
extern int pthread_mutexattr_getprioceiling (const pthread_mutexattr_t *
          __restrict __attr,
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
          int __prioceiling)
extern int pthread_mutexattr_getrobust (const pthread_mutexattr_t *__attr,
     int *__robustness)
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
     int __robustness)
# 890 "/usr/include/pthread.h" 3 4
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
    const pthread_rwlockattr_t *__restrict
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
       __restrict __attr,
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
       int __pshared)
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
       __restrict __attr,
       int *__restrict __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
       int __pref) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
         const pthread_condattr_t *__restrict __cond_attr)
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
         pthread_mutex_t *__restrict __mutex)
# 1002 "/usr/include/pthread.h" 3 4
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
       const struct timespec *__restrict __abstime)
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (const pthread_condattr_t *
     __restrict __attr,
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
     int __pshared) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int pthread_condattr_getclock (const pthread_condattr_t *
          __restrict __attr,
          __clockid_t *__restrict __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
          __clockid_t __clock_id)
# 1046 "/usr/include/pthread.h" 3 4
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
     const pthread_barrierattr_t *__restrict
     __attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
        __restrict __attr,
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
        int __pshared)
# 1113 "/usr/include/pthread.h" 3 4
extern int pthread_key_create (pthread_key_t *__key,
          void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern void *pthread_getspecific (pthread_key_t __key) __attribute__ ((__nothrow__ , __leaf__));
extern int pthread_setspecific (pthread_key_t __key,
    const void *__pointer) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
      __clockid_t *__clock_id)
# 1147 "/usr/include/pthread.h" 3 4
extern int pthread_atfork (void (*__prepare) (void),
      void (*__parent) (void),
      void (*__child) (void)) __attribute__ ((__nothrow__ , __leaf__));
# 1161 "/usr/include/pthread.h" 3 4
              Defined "HAVE_PTHREAD_H" to "1"
Checking for header: setjmp.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/setjmp.h" 1 3 4
# 25 "/usr/include/setjmp.h" 3 4
# 26 "/usr/include/setjmp.h" 2 3 4
# 30 "/usr/include/setjmp.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 31 "/usr/include/setjmp.h" 2 3 4
    __jmp_buf __jmpbuf;
    __sigset_t __saved_mask;
typedef struct __jmp_buf_tag jmp_buf[1];
extern int setjmp (jmp_buf __env) __attribute__ ((__nothrow__));
extern int __sigsetjmp (struct __jmp_buf_tag __env[1], int __savemask) __attribute__ ((__nothrow__));
extern int _setjmp (struct __jmp_buf_tag __env[1]) __attribute__ ((__nothrow__));
extern void longjmp (struct __jmp_buf_tag __env[1], int __val)
     __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
extern void _longjmp (struct __jmp_buf_tag __env[1], int __val)
typedef struct __jmp_buf_tag sigjmp_buf[1];
# 102 "/usr/include/setjmp.h" 3 4
extern void siglongjmp (sigjmp_buf __env, int __val)
# 112 "/usr/include/setjmp.h" 3 4
              Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/utsname.h" 1 3 4
# 25 "/usr/include/sys/utsname.h" 3 4
# 26 "/usr/include/sys/utsname.h" 2 3 4
# 1 "/usr/include/bits/utsname.h" 1 3 4
# 30 "/usr/include/sys/utsname.h" 2 3 4
# 48 "/usr/include/sys/utsname.h" 3 4
struct utsname
    char sysname[65];
    char nodename[65];
    char release[65];
    char version[65];
    char machine[65];
    char __domainname[65];
# 81 "/usr/include/sys/utsname.h" 3 4
extern int uname (struct utsname *__name) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: machine/endian.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory
 #include <machine/endian.h>
Source:
#include "confdefs.h"
#include "conffix.h"
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory #include <machine/endian.h>                            ^compilation terminated.:
Checking for header: limits.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/syslimits.h" 1 3 4
# 168 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 25 "/usr/include/limits.h" 3 4
# 26 "/usr/include/limits.h" 2 3 4
# 143 "/usr/include/limits.h" 3 4
# 1 "/usr/include/bits/posix1_lim.h" 1 3 4
# 160 "/usr/include/bits/posix1_lim.h" 3 4
# 1 "/usr/include/bits/local_lim.h" 1 3 4
# 38 "/usr/include/bits/local_lim.h" 3 4
# 1 "/usr/include/linux/limits.h" 1 3 4
# 39 "/usr/include/bits/local_lim.h" 2 3 4
# 161 "/usr/include/bits/posix1_lim.h" 2 3 4
# 144 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/posix2_lim.h" 1 3 4
# 148 "/usr/include/limits.h" 2 3 4
# 169 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 2 3 4
# 8 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/syslimits.h" 2 3 4
# 35 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 2 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/fcntl.h" 1 3 4
# 25 "/usr/include/fcntl.h" 3 4
# 26 "/usr/include/fcntl.h" 2 3 4
# 32 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/bits/fcntl.h" 1 3 4
# 35 "/usr/include/bits/fcntl.h" 3 4
struct flock
    short int l_type;
    short int l_whence;
    __off_t l_start;
    __off_t l_len;
    __pid_t l_pid;
# 61 "/usr/include/bits/fcntl.h" 3 4
# 1 "/usr/include/bits/fcntl-linux.h" 1 3 4
# 345 "/usr/include/bits/fcntl-linux.h" 3 4
# 419 "/usr/include/bits/fcntl-linux.h" 3 4
# 61 "/usr/include/bits/fcntl.h" 2 3 4
# 36 "/usr/include/fcntl.h" 2 3 4
typedef __mode_t mode_t;
typedef __off_t off_t;
# 60 "/usr/include/fcntl.h" 3 4
struct timespec
    __time_t tv_sec;
# 68 "/usr/include/fcntl.h" 2 3 4
# 1 "/usr/include/bits/stat.h" 1 3 4
# 46 "/usr/include/bits/stat.h" 3 4
struct stat
    __dev_t st_dev;
    __ino_t st_ino;
    __nlink_t st_nlink;
    __mode_t st_mode;
    __uid_t st_uid;
    __gid_t st_gid;
    int __pad0;
    __dev_t st_rdev;
    __off_t st_size;
    __blksize_t st_blksize;
    __blkcnt_t st_blocks;
# 91 "/usr/include/bits/stat.h" 3 4
    struct timespec st_atim;
    struct timespec st_mtim;
    struct timespec st_ctim;
# 106 "/usr/include/bits/stat.h" 3 4
    __syscall_slong_t __glibc_reserved[3];
# 115 "/usr/include/bits/stat.h" 3 4
# 69 "/usr/include/fcntl.h" 2 3 4
# 160 "/usr/include/fcntl.h" 3 4
extern int fcntl (int __fd, int __cmd, ...);
# 169 "/usr/include/fcntl.h" 3 4
extern int open (const char *__file, int __oflag, ...) __attribute__ ((__nonnull__ (1)));
# 193 "/usr/include/fcntl.h" 3 4
extern int openat (int __fd, const char *__file, int __oflag, ...)
# 215 "/usr/include/fcntl.h" 3 4
extern int creat (const char *__file, mode_t __mode) __attribute__ ((__nonnull__ (1)));
# 244 "/usr/include/fcntl.h" 3 4
extern int lockf (int __fd, int __cmd, off_t __len);
# 261 "/usr/include/fcntl.h" 3 4
extern int posix_fadvise (int __fd, off_t __offset, off_t __len,
     int __advise) __attribute__ ((__nothrow__ , __leaf__));
# 283 "/usr/include/fcntl.h" 3 4
extern int posix_fallocate (int __fd, off_t __offset, off_t __len);
# 305 "/usr/include/fcntl.h" 3 4
              Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/string.h" 1 3 4
# 25 "/usr/include/string.h" 3 4
# 26 "/usr/include/string.h" 2 3 4
# 33 "/usr/include/string.h" 2 3 4
# 44 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
       size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
# 96 "/usr/include/string.h" 3 4
extern void *memchr (const void *__s, int __c, size_t __n)
# 127 "/usr/include/string.h" 3 4
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 164 "/usr/include/string.h" 2 3 4
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
    __locale_t __l) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
# 235 "/usr/include/string.h" 3 4
extern char *strchr (const char *__s, int __c)
# 262 "/usr/include/string.h" 3 4
extern char *strrchr (const char *__s, int __c)
# 281 "/usr/include/string.h" 3 4
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
# 314 "/usr/include/string.h" 3 4
extern char *strpbrk (const char *__s, const char *__accept)
# 341 "/usr/include/string.h" 3 4
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    const char *__restrict __delim,
    char **__restrict __save_ptr)
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
# 396 "/usr/include/string.h" 3 4
extern size_t strlen (const char *__s)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) __attribute__ ((__nothrow__ , __leaf__));
# 426 "/usr/include/string.h" 3 4
extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__ , __leaf__))
# 444 "/usr/include/string.h" 3 4
extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__ , __leaf__));
extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
# 488 "/usr/include/string.h" 3 4
extern char *index (const char *__s, int __c)
# 516 "/usr/include/string.h" 3 4
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 533 "/usr/include/string.h" 3 4
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
# 556 "/usr/include/string.h" 3 4
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
# 643 "/usr/include/string.h" 3 4
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
              Defined "HAVE_STRING_H" to "1"
Checking for header: sys/times.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/times.h" 1 3 4
# 25 "/usr/include/sys/times.h" 3 4
# 26 "/usr/include/sys/times.h" 2 3 4
# 55 "/usr/include/time.h" 3 4
# 56 "/usr/include/time.h" 2 3 4
# 29 "/usr/include/sys/times.h" 2 3 4
struct tms
    clock_t tms_utime;
    clock_t tms_stime;
    clock_t tms_cutime;
    clock_t tms_cstime;
extern clock_t times (struct tms *__buffer) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: io.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2stderr:
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory
 #include <io.h>
Source:
#include <io.h>
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory
 #include <io.h>
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory #include <io.h>                ^compilation terminated.:
Checking for header: stdint.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 25 "/usr/include/stdint.h" 3 4
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 36 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 65 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 90 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 103 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 119 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 134 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 10 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 2 3 4
              Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/pwd.h" 1 3 4
# 25 "/usr/include/pwd.h" 3 4
# 26 "/usr/include/pwd.h" 2 3 4
# 30 "/usr/include/pwd.h" 2 3 4
# 33 "/usr/include/pwd.h" 2 3 4
typedef __gid_t gid_t;
typedef __uid_t uid_t;
struct passwd
  char *pw_name;
  char *pw_passwd;
  __uid_t pw_uid;
  __gid_t pw_gid;
  char *pw_gecos;
  char *pw_dir;
  char *pw_shell;
# 1 "/usr/include/stdio.h" 1 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/pwd.h" 2 3 4
# 72 "/usr/include/pwd.h" 3 4
extern void setpwent (void);
extern void endpwent (void);
extern struct passwd *getpwent (void);
# 94 "/usr/include/pwd.h" 3 4
extern struct passwd *fgetpwent (FILE *__stream);
extern int putpwent (const struct passwd *__restrict __p,
       FILE *__restrict __f);
extern struct passwd *getpwuid (__uid_t __uid);
extern struct passwd *getpwnam (const char *__name);
# 139 "/usr/include/pwd.h" 3 4
extern int getpwent_r (struct passwd *__restrict __resultbuf,
         char *__restrict __buffer, size_t __buflen,
         struct passwd **__restrict __result);
extern int getpwuid_r (__uid_t __uid,
extern int getpwnam_r (const char *__restrict __name,
# 163 "/usr/include/pwd.h" 3 4
extern int fgetpwent_r (FILE *__restrict __stream,
# 183 "/usr/include/pwd.h" 3 4
              Defined "HAVE_PWD_H" to "1"
Checking for header: float.h
stdout:
# 1 "<built-in>"
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/float.h" 1 3 4
              Defined "HAVE_FLOAT_H" to "1"
Checking for header: sys/param.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/param.h" 1 3 4
# 23 "/usr/include/sys/param.h" 3 4
# 24 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __nlink_t nlink_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
typedef struct
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
struct timespec
    __time_t tv_sec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 271 "/usr/include/sys/types.h" 2 3 4
# 26 "/usr/include/sys/param.h" 2 3 4
# 27 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/signal.h" 1 3 4
# 30 "/usr/include/signal.h" 3 4
# 102 "/usr/include/bits/sigset.h" 3 4
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
# 33 "/usr/include/signal.h" 2 3 4
typedef __sig_atomic_t sig_atomic_t;
# 57 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/signum.h" 1 3 4
# 58 "/usr/include/signal.h" 2 3 4
# 75 "/usr/include/signal.h" 3 4
# 76 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/bits/siginfo.h" 1 3 4
# 24 "/usr/include/bits/siginfo.h" 3 4
# 25 "/usr/include/bits/siginfo.h" 2 3 4
typedef union sigval
    int sival_int;
    void *sival_ptr;
  } sigval_t;
# 58 "/usr/include/bits/siginfo.h" 3 4
typedef __clock_t __sigchld_clock_t;
typedef struct
    int si_signo;
    int si_errno;
    int si_code;
    union
 int _pad[((128 / sizeof (int)) - 4)];
 struct
     __pid_t si_pid;
     __uid_t si_uid;
   } _kill;
 struct
     int si_tid;
     int si_overrun;
     sigval_t si_sigval;
   } _timer;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     sigval_t si_sigval;
   } _rt;
 struct
     __pid_t si_pid;
     __uid_t si_uid;
     int si_status;
     __sigchld_clock_t si_utime;
     __sigchld_clock_t si_stime;
   } _sigchld;
 struct
     void *si_addr;
     short int si_addr_lsb;
   } _sigfault;
 struct
     long int si_band;
     int si_fd;
   } _sigpoll;
 struct
     void *_call_addr;
     int _syscall;
     unsigned int _arch;
   } _sigsys;
      } _sifields;
  } siginfo_t ;
# 153 "/usr/include/bits/siginfo.h" 3 4
enum
  SI_ASYNCNL = -60,
  SI_TKILL = -6,
  SI_SIGIO,
  SI_ASYNCIO,
  SI_MESGQ,
  SI_TIMER,
  SI_QUEUE,
  SI_USER,
  SI_KERNEL = 0x80
enum
  ILL_ILLOPC = 1,
  ILL_ILLOPN,
  ILL_ILLADR,
  ILL_ILLTRP,
  ILL_PRVOPC,
  ILL_PRVREG,
  ILL_COPROC,
  ILL_BADSTK
enum
  FPE_INTDIV = 1,
  FPE_INTOVF,
  FPE_FLTDIV,
  FPE_FLTOVF,
  FPE_FLTUND,
  FPE_FLTRES,
  FPE_FLTINV,
  FPE_FLTSUB
enum
  SEGV_MAPERR = 1,
  SEGV_ACCERR
enum
  BUS_ADRALN = 1,
  BUS_ADRERR,
  BUS_OBJERR,
  BUS_MCEERR_AR,
  BUS_MCEERR_AO
# 257 "/usr/include/bits/siginfo.h" 3 4
enum
  CLD_EXITED = 1,
  CLD_KILLED,
  CLD_DUMPED,
  CLD_TRAPPED,
  CLD_STOPPED,
  CLD_CONTINUED
enum
  POLL_IN = 1,
  POLL_OUT,
  POLL_MSG,
  POLL_ERR,
  POLL_PRI,
  POLL_HUP
# 313 "/usr/include/bits/siginfo.h" 3 4
typedef struct sigevent
    sigval_t sigev_value;
    int sigev_signo;
    int sigev_notify;
    union
 int _pad[((64 / sizeof (int)) - 4)];
 __pid_t _tid;
 struct
     void (*_function) (sigval_t);
     pthread_attr_t *_attribute;
   } _sigev_thread;
      } _sigev_un;
  } sigevent_t;
enum
  SIGEV_SIGNAL = 0,
  SIGEV_NONE,
  SIGEV_THREAD,
  SIGEV_THREAD_ID = 4
# 81 "/usr/include/signal.h" 2 3 4
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
# 100 "/usr/include/signal.h" 3 4
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
# 114 "/usr/include/signal.h" 3 4
# 127 "/usr/include/signal.h" 3 4
extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern int raise (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) __attribute__ ((__nothrow__ , __leaf__));
extern void psignal (int __sig, const char *__s);
extern void psiginfo (const siginfo_t *__pinfo, const char *__s);
# 167 "/usr/include/signal.h" 3 4
extern int __sigpause (int __sig_or_mask, int __is_sig);
# 189 "/usr/include/signal.h" 3 4
extern int sigblock (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int sigsetmask (int __mask) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
extern int siggetmask (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__deprecated__));
# 209 "/usr/include/signal.h" 3 4
typedef __sighandler_t sig_t;
extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigismember (const sigset_t *__set, int __signo)
# 245 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigaction.h" 1 3 4
# 24 "/usr/include/bits/sigaction.h" 3 4
struct sigaction
    union
 __sighandler_t sa_handler;
 void (*sa_sigaction) (int, siginfo_t *, void *);
    __sigaction_handler;
    __sigset_t sa_mask;
    int sa_flags;
    void (*sa_restorer) (void);
# 246 "/usr/include/signal.h" 2 3 4
extern int sigprocmask (int __how, const sigset_t *__restrict __set,
   sigset_t *__restrict __oset) __attribute__ ((__nothrow__ , __leaf__));
extern int sigsuspend (const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
extern int sigaction (int __sig, const struct sigaction *__restrict __act,
        struct sigaction *__restrict __oact) __attribute__ ((__nothrow__ , __leaf__));
extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sigwait (const sigset_t *__restrict __set, int *__restrict __sig)
extern int sigwaitinfo (const sigset_t *__restrict __set,
   siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
extern int sigtimedwait (const sigset_t *__restrict __set,
    siginfo_t *__restrict __info,
    const struct timespec *__restrict __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
# 303 "/usr/include/signal.h" 3 4
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
struct sigvec
    __sighandler_t sv_handler;
    int sv_mask;
    int sv_flags;
# 327 "/usr/include/signal.h" 3 4
extern int sigvec (int __sig, const struct sigvec *__vec,
     struct sigvec *__ovec) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigcontext.h" 1 3 4
# 29 "/usr/include/bits/sigcontext.h" 3 4
struct _fpx_sw_bytes
  __uint32_t magic1;
  __uint32_t extended_size;
  __uint64_t xstate_bv;
  __uint32_t xstate_size;
  __uint32_t padding[7];
struct _fpreg
  unsigned short significand[4];
  unsigned short exponent;
struct _fpxreg
  unsigned short padding[3];
struct _xmmreg
  __uint32_t element[4];
# 121 "/usr/include/bits/sigcontext.h" 3 4
struct _fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  __uint32_t mxcr_mask;
  struct _fpxreg _st[8];
  struct _xmmreg _xmm[16];
  __uint32_t padding[24];
struct sigcontext
  __uint64_t r8;
  __uint64_t r9;
  __uint64_t r10;
  __uint64_t r11;
  __uint64_t r12;
  __uint64_t r13;
  __uint64_t r14;
  __uint64_t r15;
  __uint64_t rdi;
  __uint64_t rsi;
  __uint64_t rbp;
  __uint64_t rbx;
  __uint64_t rdx;
  __uint64_t rax;
  __uint64_t rcx;
  __uint64_t rsp;
  __uint64_t rip;
  __uint64_t eflags;
  unsigned short cs;
  unsigned short gs;
  unsigned short fs;
  unsigned short __pad0;
  __uint64_t err;
  __uint64_t trapno;
  __uint64_t oldmask;
  __uint64_t cr2;
  __extension__ union
      struct _fpstate * fpstate;
      __uint64_t __fpstate_word;
  __uint64_t __reserved1 [8];
struct _xsave_hdr
  __uint64_t reserved1[2];
  __uint64_t reserved2[5];
struct _ymmh_state
  __uint32_t ymmh_space[64];
struct _xstate
  struct _fpstate fpstate;
  struct _xsave_hdr xstate_hdr;
  struct _ymmh_state ymmh;
# 333 "/usr/include/signal.h" 2 3 4
extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__ , __leaf__));
# 343 "/usr/include/signal.h" 2 3 4
extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__ , __leaf__));
# 1 "/usr/include/bits/sigstack.h" 1 3 4
# 25 "/usr/include/bits/sigstack.h" 3 4
struct sigstack
    void *ss_sp;
    int ss_onstack;
enum
  SS_ONSTACK = 1,
  SS_DISABLE
# 49 "/usr/include/bits/sigstack.h" 3 4
typedef struct sigaltstack
    void *ss_sp;
    int ss_flags;
    size_t ss_size;
  } stack_t;
# 350 "/usr/include/signal.h" 2 3 4
# 1 "/usr/include/sys/ucontext.h" 1 3 4
# 22 "/usr/include/sys/ucontext.h" 3 4
# 23 "/usr/include/sys/ucontext.h" 2 3 4
# 31 "/usr/include/sys/ucontext.h" 3 4
__extension__ typedef long long int greg_t;
typedef greg_t gregset_t[23];
# 92 "/usr/include/sys/ucontext.h" 3 4
struct _libc_fpxreg
  unsigned short int significand[4];
  unsigned short int exponent;
  unsigned short int padding[3];
struct _libc_xmmreg
struct _libc_fpstate
  __uint16_t cwd;
  __uint16_t swd;
  __uint16_t ftw;
  __uint16_t fop;
  __uint64_t rip;
  __uint64_t rdp;
  __uint32_t mxcsr;
  struct _libc_fpxreg _st[8];
  struct _libc_xmmreg _xmm[16];
typedef struct _libc_fpstate *fpregset_t;
typedef struct
    gregset_t gregs;
    fpregset_t fpregs;
    __extension__ unsigned long long __reserved1 [8];
} mcontext_t;
typedef struct ucontext
    unsigned long int uc_flags;
    struct ucontext *uc_link;
    stack_t uc_stack;
    mcontext_t uc_mcontext;
    __sigset_t uc_sigmask;
    struct _libc_fpstate __fpregs_mem;
  } ucontext_t;
# 353 "/usr/include/signal.h" 2 3 4
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
extern int sigaltstack (const struct sigaltstack *__restrict __ss,
   struct sigaltstack *__restrict __oss) __attribute__ ((__nothrow__ , __leaf__));
# 388 "/usr/include/signal.h" 3 4
# 1 "/usr/include/bits/sigthread.h" 1 3 4
# 30 "/usr/include/bits/sigthread.h" 3 4
extern int pthread_sigmask (int __how,
       const __sigset_t *__restrict __newmask,
       __sigset_t *__restrict __oldmask)__attribute__ ((__nothrow__ , __leaf__));
extern int pthread_kill (pthread_t __threadid, int __signo) __attribute__ ((__nothrow__ , __leaf__));
# 389 "/usr/include/signal.h" 2 3 4
extern int __libc_current_sigrtmin (void) __attribute__ ((__nothrow__ , __leaf__));
extern int __libc_current_sigrtmax (void) __attribute__ ((__nothrow__ , __leaf__));
# 29 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/bits/param.h" 1 3 4
# 28 "/usr/include/bits/param.h" 3 4
# 1 "/usr/include/linux/param.h" 1 3 4
# 1 "/usr/include/asm/param.h" 1 3 4
# 1 "/usr/include/asm-generic/param.h" 1 3 4
# 1 "/usr/include/asm/param.h" 2 3 4
# 5 "/usr/include/linux/param.h" 2 3 4
# 29 "/usr/include/bits/param.h" 2 3 4
# 32 "/usr/include/sys/param.h" 2 3 4
              Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: netdb.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/netdb.h" 1 3 4
# 25 "/usr/include/netdb.h" 3 4
# 26 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/netinet/in.h" 1 3 4
# 22 "/usr/include/netinet/in.h" 3 4
# 26 "/usr/include/stdint.h" 3 4
# 23 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/include/sys/socket.h" 1 3 4
# 24 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/sys/uio.h" 1 3 4
# 23 "/usr/include/sys/uio.h" 3 4
# 27 "/usr/include/sys/types.h" 3 4
# 200 "/usr/include/sys/types.h" 3 4
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 24 "/usr/include/sys/uio.h" 2 3 4
# 1 "/usr/include/bits/uio.h" 1 3 4
# 43 "/usr/include/bits/uio.h" 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
# 29 "/usr/include/sys/uio.h" 2 3 4
# 39 "/usr/include/sys/uio.h" 3 4
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count)
# 50 "/usr/include/sys/uio.h" 3 4
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count)
# 65 "/usr/include/sys/uio.h" 3 4
extern ssize_t preadv (int __fd, const struct iovec *__iovec, int __count,
         __off_t __offset) ;
# 77 "/usr/include/sys/uio.h" 3 4
extern ssize_t pwritev (int __fd, const struct iovec *__iovec, int __count,
   __off_t __offset) ;
# 120 "/usr/include/sys/uio.h" 3 4
# 27 "/usr/include/sys/socket.h" 2 3 4
# 29 "/usr/include/sys/socket.h" 2 3 4
# 38 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/bits/socket.h" 1 3 4
# 27 "/usr/include/bits/socket.h" 3 4
# 28 "/usr/include/bits/socket.h" 2 3 4
typedef __socklen_t socklen_t;
# 1 "/usr/include/bits/socket_type.h" 1 3 4
# 24 "/usr/include/bits/socket_type.h" 3 4
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
  SOCK_CLOEXEC = 02000000,
  SOCK_NONBLOCK = 00004000
# 39 "/usr/include/bits/socket.h" 2 3 4
# 146 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/bits/sockaddr.h" 1 3 4
# 28 "/usr/include/bits/sockaddr.h" 3 4
typedef unsigned short int sa_family_t;
# 147 "/usr/include/bits/socket.h" 2 3 4
struct sockaddr
    sa_family_t sa_family;
    char sa_data[14];
# 162 "/usr/include/bits/socket.h" 3 4
struct sockaddr_storage
    sa_family_t ss_family;
    unsigned long int __ss_align;
    char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_DONTROUTE = 0x04,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_DONTWAIT = 0x40,
    MSG_EOR = 0x80,
    MSG_WAITALL = 0x100,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_CONFIRM = 0x800,
    MSG_RST = 0x1000,
    MSG_ERRQUEUE = 0x2000,
    MSG_NOSIGNAL = 0x4000,
    MSG_MORE = 0x8000,
    MSG_WAITFORONE = 0x10000,
    MSG_FASTOPEN = 0x20000000,
    MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
    void *msg_name;
    socklen_t msg_namelen;
    struct iovec *msg_iov;
    size_t msg_iovlen;
    void *msg_control;
    size_t msg_controllen;
    int msg_flags;
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
    __extension__ unsigned char __cmsg_data [];
# 272 "/usr/include/bits/socket.h" 3 4
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
          struct cmsghdr *__cmsg) __attribute__ ((__nothrow__ , __leaf__));
# 299 "/usr/include/bits/socket.h" 3 4
enum
    SCM_RIGHTS = 0x01
# 345 "/usr/include/bits/socket.h" 3 4
# 1 "/usr/include/asm/socket.h" 1 3 4
# 1 "/usr/include/asm-generic/socket.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 1 3 4
# 1 "/usr/include/asm-generic/sockios.h" 1 3 4
# 1 "/usr/include/asm/sockios.h" 2 3 4
# 5 "/usr/include/asm-generic/socket.h" 2 3 4
# 1 "/usr/include/asm/socket.h" 2 3 4
# 346 "/usr/include/bits/socket.h" 2 3 4
# 379 "/usr/include/bits/socket.h" 3 4
struct linger
    int l_onoff;
    int l_linger;
# 39 "/usr/include/sys/socket.h" 2 3 4
struct osockaddr
    unsigned short int sa_family;
    unsigned char sa_data[14];
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
# 113 "/usr/include/sys/socket.h" 3 4
extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__ , __leaf__));
extern int socketpair (int __domain, int __type, int __protocol,
         int __fds[2]) __attribute__ ((__nothrow__ , __leaf__));
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
   socklen_t *__restrict __len) __attribute__ ((__nothrow__ , __leaf__));
# 137 "/usr/include/sys/socket.h" 3 4
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
         int __flags, const struct sockaddr * __addr,
         socklen_t __addr_len);
# 174 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
    int __flags, struct sockaddr *__restrict __addr,
    socklen_t *__restrict __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
   int __flags);
# 202 "/usr/include/sys/socket.h" 3 4
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
# 219 "/usr/include/sys/socket.h" 3 4
extern int getsockopt (int __fd, int __level, int __optname,
         void *__restrict __optval,
         socklen_t *__restrict __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int setsockopt (int __fd, int __level, int __optname,
         const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__ , __leaf__));
extern int listen (int __fd, int __n) __attribute__ ((__nothrow__ , __leaf__));
# 243 "/usr/include/sys/socket.h" 3 4
extern int accept (int __fd, struct sockaddr *__restrict __addr,
# 261 "/usr/include/sys/socket.h" 3 4
extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__ , __leaf__));
extern int sockatmark (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__ , __leaf__));
# 283 "/usr/include/sys/socket.h" 3 4
# 24 "/usr/include/netinet/in.h" 2 3 4
typedef uint32_t in_addr_t;
struct in_addr
    in_addr_t s_addr;
# 1 "/usr/include/bits/in.h" 1 3 4
# 138 "/usr/include/bits/in.h" 3 4
struct ip_opts
    struct in_addr ip_dst;
    char ip_opts[40];
struct ip_mreqn
    struct in_addr imr_multiaddr;
    struct in_addr imr_address;
    int imr_ifindex;
struct in_pktinfo
    int ipi_ifindex;
    struct in_addr ipi_spec_dst;
    struct in_addr ipi_addr;
# 38 "/usr/include/netinet/in.h" 2 3 4
enum
    IPPROTO_IP = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_MTP = 92,
    IPPROTO_BEETPH = 94,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_UDPLITE = 136,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
enum
    IPPROTO_HOPOPTS = 0,
    IPPROTO_ROUTING = 43,
    IPPROTO_FRAGMENT = 44,
    IPPROTO_ICMPV6 = 58,
    IPPROTO_NONE = 59,
    IPPROTO_DSTOPTS = 60,
    IPPROTO_MH = 135
typedef uint16_t in_port_t;
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_DAYTIME = 13,
    IPPORT_NETSTAT = 15,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_TIMESERVER = 37,
    IPPORT_NAMESERVER = 42,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_TTYLINK = 87,
    IPPORT_SUPDUP = 95,
    IPPORT_EXECSERVER = 512,
    IPPORT_LOGINSERVER = 513,
    IPPORT_CMDSERVER = 514,
    IPPORT_EFSSERVER = 520,
    IPPORT_BIFFUDP = 512,
    IPPORT_WHOSERVER = 513,
    IPPORT_ROUTESERVER = 520,
    IPPORT_RESERVED = 1024,
    IPPORT_USERRESERVED = 5000
# 209 "/usr/include/netinet/in.h" 3 4
struct in6_addr
    union
 uint8_t __u6_addr8[16];
 uint16_t __u6_addr16[8];
 uint32_t __u6_addr32[4];
      } __in6_u;
extern const struct in6_addr in6addr_any;
extern const struct in6_addr in6addr_loopback;
# 237 "/usr/include/netinet/in.h" 3 4
struct sockaddr_in
    sa_family_t sin_family;
    in_port_t sin_port;
    struct in_addr sin_addr;
    unsigned char sin_zero[sizeof (struct sockaddr) -
      (sizeof (unsigned short int)) -
      sizeof (in_port_t) -
      sizeof (struct in_addr)];
struct sockaddr_in6
    sa_family_t sin6_family;
    in_port_t sin6_port;
    uint32_t sin6_flowinfo;
    struct in6_addr sin6_addr;
    uint32_t sin6_scope_id;
struct ip_mreq
    struct in_addr imr_interface;
struct ip_mreq_source
    struct in_addr imr_sourceaddr;
struct ipv6_mreq
    struct in6_addr ipv6mr_multiaddr;
    unsigned int ipv6mr_interface;
struct group_req
    uint32_t gr_interface;
    struct sockaddr_storage gr_group;
struct group_source_req
    uint32_t gsr_interface;
    struct sockaddr_storage gsr_group;
    struct sockaddr_storage gsr_source;
struct ip_msfilter
    struct in_addr imsf_multiaddr;
    struct in_addr imsf_interface;
    uint32_t imsf_fmode;
    uint32_t imsf_numsrc;
    struct in_addr imsf_slist[1];
struct group_filter
    uint32_t gf_interface;
    struct sockaddr_storage gf_group;
    uint32_t gf_fmode;
    uint32_t gf_numsrc;
    struct sockaddr_storage gf_slist[1];
# 374 "/usr/include/netinet/in.h" 3 4
extern uint32_t ntohl (uint32_t __netlong) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern uint16_t ntohs (uint16_t __netshort)
extern uint32_t htonl (uint32_t __hostlong)
extern uint16_t htons (uint16_t __hostshort)
# 386 "/usr/include/netinet/in.h" 2 3 4
# 501 "/usr/include/netinet/in.h" 3 4
extern int bindresvport (int __sockfd, struct sockaddr_in *__sock_in) __attribute__ ((__nothrow__ , __leaf__));
extern int bindresvport6 (int __sockfd, struct sockaddr_in6 *__sock_in)
# 628 "/usr/include/netinet/in.h" 3 4
# 28 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/rpc/netdb.h" 1 3 4
# 42 "/usr/include/rpc/netdb.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 43 "/usr/include/rpc/netdb.h" 2 3 4
struct rpcent
  char *r_name;
  char **r_aliases;
  int r_number;
extern void setrpcent (int __stayopen) __attribute__ ((__nothrow__ , __leaf__));
extern void endrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbyname (const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcbynumber (int __number) __attribute__ ((__nothrow__ , __leaf__));
extern struct rpcent *getrpcent (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbyname_r (const char *__name, struct rpcent *__result_buf,
      char *__buffer, size_t __buflen,
      struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
extern int getrpcbynumber_r (int __number, struct rpcent *__result_buf,
extern int getrpcent_r (struct rpcent *__result_buf, char *__buffer,
   size_t __buflen, struct rpcent **__result) __attribute__ ((__nothrow__ , __leaf__));
# 33 "/usr/include/netdb.h" 2 3 4
# 42 "/usr/include/netdb.h" 3 4
# 1 "/usr/include/bits/netdb.h" 1 3 4
# 26 "/usr/include/bits/netdb.h" 3 4
struct netent
  char *n_name;
  char **n_aliases;
  int n_addrtype;
  uint32_t n_net;
# 43 "/usr/include/netdb.h" 2 3 4
# 53 "/usr/include/netdb.h" 3 4
extern int *__h_errno_location (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
# 92 "/usr/include/netdb.h" 3 4
extern void herror (const char *__str) __attribute__ ((__nothrow__ , __leaf__));
extern const char *hstrerror (int __err_num) __attribute__ ((__nothrow__ , __leaf__));
struct hostent
  char *h_name;
  char **h_aliases;
  int h_addrtype;
  int h_length;
  char **h_addr_list;
extern void sethostent (int __stay_open);
extern void endhostent (void);
extern struct hostent *gethostent (void);
extern struct hostent *gethostbyaddr (const void *__addr, __socklen_t __len,
          int __type);
extern struct hostent *gethostbyname (const char *__name);
# 155 "/usr/include/netdb.h" 3 4
extern struct hostent *gethostbyname2 (const char *__name, int __af);
# 167 "/usr/include/netdb.h" 3 4
extern int gethostent_r (struct hostent *__restrict __result_buf,
    char *__restrict __buf, size_t __buflen,
    struct hostent **__restrict __result,
    int *__restrict __h_errnop);
extern int gethostbyaddr_r (const void *__restrict __addr, __socklen_t __len,
       int __type,
extern int gethostbyname_r (const char *__restrict __name,
extern int gethostbyname2_r (const char *__restrict __name, int __af,
# 198 "/usr/include/netdb.h" 3 4
extern void setnetent (int __stay_open);
extern void endnetent (void);
extern struct netent *getnetent (void);
extern struct netent *getnetbyaddr (uint32_t __net, int __type);
extern struct netent *getnetbyname (const char *__name);
# 237 "/usr/include/netdb.h" 3 4
extern int getnetent_r (struct netent *__restrict __result_buf,
   struct netent **__restrict __result,
extern int getnetbyaddr_r (uint32_t __net, int __type,
extern int getnetbyname_r (const char *__restrict __name,
struct servent
  char *s_name;
  char **s_aliases;
  int s_port;
  char *s_proto;
extern void setservent (int __stay_open);
extern void endservent (void);
extern struct servent *getservent (void);
extern struct servent *getservbyname (const char *__name, const char *__proto);
extern struct servent *getservbyport (int __port, const char *__proto);
# 308 "/usr/include/netdb.h" 3 4
extern int getservent_r (struct servent *__restrict __result_buf,
    struct servent **__restrict __result);
extern int getservbyname_r (const char *__restrict __name,
       const char *__restrict __proto,
extern int getservbyport_r (int __port, const char *__restrict __proto,
struct protoent
  char *p_name;
  char **p_aliases;
  int p_proto;
extern void setprotoent (int __stay_open);
extern void endprotoent (void);
extern struct protoent *getprotoent (void);
extern struct protoent *getprotobyname (const char *__name);
extern struct protoent *getprotobynumber (int __proto);
# 374 "/usr/include/netdb.h" 3 4
extern int getprotoent_r (struct protoent *__restrict __result_buf,
     struct protoent **__restrict __result);
extern int getprotobyname_r (const char *__restrict __name,
extern int getprotobynumber_r (int __proto,
# 395 "/usr/include/netdb.h" 3 4
extern int setnetgrent (const char *__netgroup);
extern void endnetgrent (void);
# 412 "/usr/include/netdb.h" 3 4
extern int getnetgrent (char **__restrict __hostp,
   char **__restrict __userp,
   char **__restrict __domainp);
# 423 "/usr/include/netdb.h" 3 4
extern int innetgr (const char *__netgroup, const char *__host,
      const char *__user, const char *__domain);
extern int getnetgrent_r (char **__restrict __hostp,
     char **__restrict __domainp,
     char *__restrict __buffer, size_t __buflen);
# 451 "/usr/include/netdb.h" 3 4
extern int rcmd (char **__restrict __ahost, unsigned short int __rport,
   const char *__restrict __locuser,
   const char *__restrict __remuser,
   const char *__restrict __cmd, int *__restrict __fd2p);
# 463 "/usr/include/netdb.h" 3 4
extern int rcmd_af (char **__restrict __ahost, unsigned short int __rport,
      const char *__restrict __cmd, int *__restrict __fd2p,
      sa_family_t __af);
# 479 "/usr/include/netdb.h" 3 4
extern int rexec (char **__restrict __ahost, int __rport,
    const char *__restrict __pass,
# 491 "/usr/include/netdb.h" 3 4
extern int rexec_af (char **__restrict __ahost, int __rport,
       sa_family_t __af);
# 505 "/usr/include/netdb.h" 3 4
extern int ruserok (const char *__rhost, int __suser,
      const char *__remuser, const char *__locuser);
# 515 "/usr/include/netdb.h" 3 4
extern int ruserok_af (const char *__rhost, int __suser,
         const char *__remuser, const char *__locuser,
         sa_family_t __af);
# 528 "/usr/include/netdb.h" 3 4
extern int iruserok (uint32_t __raddr, int __suser,
# 539 "/usr/include/netdb.h" 3 4
extern int iruserok_af (const void *__raddr, int __suser,
   sa_family_t __af);
# 551 "/usr/include/netdb.h" 3 4
extern int rresvport (int *__alport);
# 560 "/usr/include/netdb.h" 3 4
extern int rresvport_af (int *__alport, sa_family_t __af);
struct addrinfo
  int ai_flags;
  int ai_family;
  int ai_socktype;
  int ai_protocol;
  socklen_t ai_addrlen;
  struct sockaddr *ai_addr;
  char *ai_canonname;
  struct addrinfo *ai_next;
# 662 "/usr/include/netdb.h" 3 4
extern int getaddrinfo (const char *__restrict __name,
   const char *__restrict __service,
   const struct addrinfo *__restrict __req,
   struct addrinfo **__restrict __pai);
extern void freeaddrinfo (struct addrinfo *__ai) __attribute__ ((__nothrow__ , __leaf__));
extern const char *gai_strerror (int __ecode) __attribute__ ((__nothrow__ , __leaf__));
extern int getnameinfo (const struct sockaddr *__restrict __sa,
   socklen_t __salen, char *__restrict __host,
   socklen_t __hostlen, char *__restrict __serv,
   socklen_t __servlen, int __flags);
# 713 "/usr/include/netdb.h" 3 4
              Defined "HAVE_NETDB_H" to "1"
TEST check from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: search.h
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
# 1 "/usr/include/search.h" 1 3 4
# 22 "/usr/include/search.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 23 "/usr/include/search.h" 2 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 26 "/usr/include/search.h" 2 3 4
# 44 "/usr/include/search.h" 3 4
extern void insque (void *__elem, void *__prev) __attribute__ ((__nothrow__ , __leaf__));
extern void remque (void *__elem) __attribute__ ((__nothrow__ , __leaf__));
typedef int (*__compar_fn_t) (const void *, const void *);
typedef enum
    FIND,
    ENTER
ACTION;
typedef struct entry
    char *key;
    void *data;
ENTRY;
struct _ENTRY;
# 87 "/usr/include/search.h" 3 4
extern ENTRY *hsearch (ENTRY __item, ACTION __action) __attribute__ ((__nothrow__ , __leaf__));
extern int hcreate (size_t __nel) __attribute__ ((__nothrow__ , __leaf__));
extern void hdestroy (void) __attribute__ ((__nothrow__ , __leaf__));
# 118 "/usr/include/search.h" 3 4
typedef enum
  preorder,
  postorder,
  endorder,
  leaf
VISIT;
extern void *tsearch (const void *__key, void **__rootp,
        __compar_fn_t __compar);
extern void *tfind (const void *__key, void *const *__rootp,
extern void *tdelete (const void *__restrict __key,
        void **__restrict __rootp,
typedef void (*__action_fn_t) (const void *__nodep, VISIT __value,
          int __level);
extern void twalk (const void *__root, __action_fn_t __action);
# 164 "/usr/include/search.h" 3 4
extern void *lfind (const void *__key, const void *__base,
      size_t *__nmemb, size_t __size, __compar_fn_t __compar);
extern void *lsearch (const void *__key, void *__base,
              Defined "HAVE_SEARCH_H" to "1"
Checking for header: mathimf.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory
 #include <mathimf.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory #include <mathimf.h>                     ^compilation terminated.:
Checking for header: sys/procfs.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/procfs.h" 1 3 4
# 30 "/usr/include/sys/procfs.h" 3 4
# 31 "/usr/include/sys/procfs.h" 2 3 4
# 1 "/usr/include/sys/time.h" 1 3 4
# 23 "/usr/include/sys/time.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 24 "/usr/include/sys/time.h" 2 3 4
# 1 "/usr/include/time.h" 1 3 4
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 26 "/usr/include/sys/time.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
struct timeval
    __time_t tv_sec;
# 28 "/usr/include/sys/time.h" 2 3 4
typedef struct
  } __sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
typedef struct
  } fd_set;
# 30 "/usr/include/sys/time.h" 2 3 4
# 55 "/usr/include/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 71 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
    const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
      struct timeval *__olddelta) __attribute__ ((__nothrow__ , __leaf__));
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) __attribute__ ((__nothrow__ , __leaf__));
extern int setitimer (__itimer_which_t __which,
        const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) __attribute__ ((__nothrow__ , __leaf__));
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) __attribute__ ((__nothrow__ , __leaf__));
# 189 "/usr/include/sys/time.h" 3 4
# 32 "/usr/include/sys/procfs.h" 2 3 4
typedef __pid_t pid_t;
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
__extension__
__extension__
__extension__
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 33 "/usr/include/sys/procfs.h" 2 3 4
# 1 "/usr/include/sys/user.h" 1 3 4
# 27 "/usr/include/sys/user.h" 3 4
struct user_fpregs_struct
  unsigned short int cwd;
  unsigned short int swd;
  unsigned short int ftw;
  unsigned short int fop;
  __extension__ unsigned long long int rip;
  __extension__ unsigned long long int rdp;
  unsigned int mxcsr;
  unsigned int mxcr_mask;
  unsigned int st_space[32];
  unsigned int xmm_space[64];
  unsigned int padding[24];
struct user_regs_struct
  __extension__ unsigned long long int r15;
  __extension__ unsigned long long int r14;
  __extension__ unsigned long long int r13;
  __extension__ unsigned long long int r12;
  __extension__ unsigned long long int rbp;
  __extension__ unsigned long long int rbx;
  __extension__ unsigned long long int r11;
  __extension__ unsigned long long int r10;
  __extension__ unsigned long long int r9;
  __extension__ unsigned long long int r8;
  __extension__ unsigned long long int rax;
  __extension__ unsigned long long int rcx;
  __extension__ unsigned long long int rdx;
  __extension__ unsigned long long int rsi;
  __extension__ unsigned long long int rdi;
  __extension__ unsigned long long int orig_rax;
  __extension__ unsigned long long int cs;
  __extension__ unsigned long long int eflags;
  __extension__ unsigned long long int rsp;
  __extension__ unsigned long long int ss;
  __extension__ unsigned long long int fs_base;
  __extension__ unsigned long long int gs_base;
  __extension__ unsigned long long int ds;
  __extension__ unsigned long long int es;
  __extension__ unsigned long long int fs;
  __extension__ unsigned long long int gs;
struct user
  struct user_regs_struct regs;
  int u_fpvalid;
  struct user_fpregs_struct i387;
  __extension__ unsigned long long int u_tsize;
  __extension__ unsigned long long int u_dsize;
  __extension__ unsigned long long int u_ssize;
  __extension__ unsigned long long int start_code;
  __extension__ unsigned long long int start_stack;
  __extension__ long long int signal;
  int reserved;
  __extension__ union
      struct user_regs_struct* u_ar0;
      __extension__ unsigned long long int __u_ar0_word;
  __extension__ union
      struct user_fpregs_struct* u_fpstate;
      __extension__ unsigned long long int __u_fpstate_word;
  __extension__ unsigned long long int magic;
  char u_comm [32];
  __extension__ unsigned long long int u_debugreg [8];
# 34 "/usr/include/sys/procfs.h" 2 3 4
__extension__ typedef unsigned long long elf_greg_t;
# 49 "/usr/include/sys/procfs.h" 3 4
typedef elf_greg_t elf_gregset_t[(sizeof (struct user_regs_struct) / sizeof(elf_greg_t))];
# 63 "/usr/include/sys/procfs.h" 3 4
typedef struct user_fpregs_struct elf_fpregset_t;
struct elf_siginfo
    int si_signo;
    int si_code;
    int si_errno;
# 82 "/usr/include/sys/procfs.h" 3 4
struct elf_prstatus
    struct elf_siginfo pr_info;
    short int pr_cursig;
    unsigned long int pr_sigpend;
    unsigned long int pr_sighold;
    __pid_t pr_pid;
    __pid_t pr_ppid;
    __pid_t pr_pgrp;
    __pid_t pr_sid;
    struct timeval pr_utime;
    struct timeval pr_stime;
    struct timeval pr_cutime;
    struct timeval pr_cstime;
    elf_gregset_t pr_reg;
    int pr_fpvalid;
struct elf_prpsinfo
    char pr_state;
    char pr_sname;
    char pr_zomb;
    char pr_nice;
    unsigned long int pr_flag;
    unsigned int pr_uid;
    unsigned int pr_gid;
    int pr_pid, pr_ppid, pr_pgrp, pr_sid;
    char pr_fname[16];
    char pr_psargs[(80)];
typedef void *psaddr_t;
typedef elf_gregset_t prgregset_t;
typedef elf_fpregset_t prfpregset_t;
typedef __pid_t lwpid_t;
typedef struct elf_prstatus prstatus_t;
typedef struct elf_prpsinfo prpsinfo_t;
              Defined "HAVE_SYS_PROCFS_H" to "1"
Checking for header: sys/resource.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/resource.h" 1 3 4
# 21 "/usr/include/sys/resource.h" 3 4
# 22 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/bits/resource.h" 1 3 4
# 23 "/usr/include/bits/resource.h" 3 4
# 24 "/usr/include/bits/resource.h" 2 3 4
enum __rlimit_resource
  RLIMIT_CPU = 0,
  RLIMIT_FSIZE = 1,
  RLIMIT_DATA = 2,
  RLIMIT_STACK = 3,
  RLIMIT_CORE = 4,
  __RLIMIT_RSS = 5,
  RLIMIT_NOFILE = 7,
  __RLIMIT_OFILE = RLIMIT_NOFILE,
  RLIMIT_AS = 9,
  __RLIMIT_NPROC = 6,
  __RLIMIT_MEMLOCK = 8,
  __RLIMIT_LOCKS = 10,
  __RLIMIT_SIGPENDING = 11,
  __RLIMIT_MSGQUEUE = 12,
  __RLIMIT_NICE = 13,
  __RLIMIT_RTPRIO = 14,
  __RLIMIT_RTTIME = 15,
  __RLIMIT_NLIMITS = 16,
  __RLIM_NLIMITS = __RLIMIT_NLIMITS
# 131 "/usr/include/bits/resource.h" 3 4
typedef __rlim_t rlim_t;
struct rlimit
    rlim_t rlim_cur;
    rlim_t rlim_max;
# 158 "/usr/include/bits/resource.h" 3 4
enum __rusage_who
  RUSAGE_SELF = 0,
  RUSAGE_CHILDREN = -1
# 176 "/usr/include/bits/resource.h" 3 4
struct timeval
    __time_t tv_sec;
# 180 "/usr/include/bits/resource.h" 2 3 4
struct rusage
    struct timeval ru_utime;
    struct timeval ru_stime;
    __extension__ union
 long int ru_maxrss;
 __syscall_slong_t __ru_maxrss_word;
    __extension__ union
 long int ru_ixrss;
 __syscall_slong_t __ru_ixrss_word;
    __extension__ union
 long int ru_idrss;
 __syscall_slong_t __ru_idrss_word;
    __extension__ union
 long int ru_isrss;
  __syscall_slong_t __ru_isrss_word;
    __extension__ union
 long int ru_minflt;
 __syscall_slong_t __ru_minflt_word;
    __extension__ union
 long int ru_majflt;
 __syscall_slong_t __ru_majflt_word;
    __extension__ union
 long int ru_nswap;
 __syscall_slong_t __ru_nswap_word;
    __extension__ union
 long int ru_inblock;
 __syscall_slong_t __ru_inblock_word;
    __extension__ union
 long int ru_oublock;
 __syscall_slong_t __ru_oublock_word;
    __extension__ union
 long int ru_msgsnd;
 __syscall_slong_t __ru_msgsnd_word;
    __extension__ union
 long int ru_msgrcv;
 __syscall_slong_t __ru_msgrcv_word;
    __extension__ union
 long int ru_nsignals;
 __syscall_slong_t __ru_nsignals_word;
    __extension__ union
 long int ru_nvcsw;
 __syscall_slong_t __ru_nvcsw_word;
    __extension__ union
 long int ru_nivcsw;
 __syscall_slong_t __ru_nivcsw_word;
enum __priority_which
  PRIO_PROCESS = 0,
  PRIO_PGRP = 1,
  PRIO_USER = 2
# 328 "/usr/include/bits/resource.h" 3 4
# 25 "/usr/include/sys/resource.h" 2 3 4
# 42 "/usr/include/sys/resource.h" 3 4
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
extern int getrlimit (__rlimit_resource_t __resource,
        struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 69 "/usr/include/sys/resource.h" 3 4
extern int setrlimit (__rlimit_resource_t __resource,
        const struct rlimit *__rlimits) __attribute__ ((__nothrow__ , __leaf__));
# 87 "/usr/include/sys/resource.h" 3 4
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) __attribute__ ((__nothrow__ , __leaf__));
extern int getpriority (__priority_which_t __which, id_t __who) __attribute__ ((__nothrow__ , __leaf__));
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
              Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: unistd.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/unistd.h" 1 3 4
# 25 "/usr/include/unistd.h" 3 4
# 26 "/usr/include/unistd.h" 2 3 4
# 202 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/bits/posix_opt.h" 1 3 4
# 203 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/bits/environments.h" 1 3 4
# 22 "/usr/include/bits/environments.h" 3 4
# 23 "/usr/include/bits/environments.h" 2 3 4
# 207 "/usr/include/unistd.h" 2 3 4
# 217 "/usr/include/unistd.h" 3 4
# 218 "/usr/include/unistd.h" 2 3 4
# 227 "/usr/include/unistd.h" 2 3 4
# 255 "/usr/include/unistd.h" 3 4
typedef __useconds_t useconds_t;
typedef __intptr_t intptr_t;
# 287 "/usr/include/unistd.h" 3 4
extern int access (const char *__name, int __type) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 304 "/usr/include/unistd.h" 3 4
extern int faccessat (int __fd, const char *__file, int __type, int __flag)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2))) ;
# 334 "/usr/include/unistd.h" 3 4
extern __off_t lseek (int __fd, __off_t __offset, int __whence) __attribute__ ((__nothrow__ , __leaf__));
# 353 "/usr/include/unistd.h" 3 4
extern int close (int __fd);
extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
extern ssize_t write (int __fd, const void *__buf, size_t __n) ;
# 376 "/usr/include/unistd.h" 3 4
extern ssize_t pread (int __fd, void *__buf, size_t __nbytes,
        __off_t __offset) ;
extern ssize_t pwrite (int __fd, const void *__buf, size_t __n,
         __off_t __offset) ;
# 417 "/usr/include/unistd.h" 3 4
extern int pipe (int __pipedes[2]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 432 "/usr/include/unistd.h" 3 4
extern unsigned int alarm (unsigned int __seconds) __attribute__ ((__nothrow__ , __leaf__));
# 444 "/usr/include/unistd.h" 3 4
extern unsigned int sleep (unsigned int __seconds);
extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
extern int usleep (__useconds_t __useconds);
# 469 "/usr/include/unistd.h" 3 4
extern int pause (void);
extern int chown (const char *__file, __uid_t __owner, __gid_t __group)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchown (int __fd, __uid_t __owner, __gid_t __group) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int lchown (const char *__file, __uid_t __owner, __gid_t __group)
extern int fchownat (int __fd, const char *__file, __uid_t __owner,
       __gid_t __group, int __flag)
extern int chdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int fchdir (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
# 511 "/usr/include/unistd.h" 3 4
extern char *getcwd (char *__buf, size_t __size) __attribute__ ((__nothrow__ , __leaf__)) ;
# 525 "/usr/include/unistd.h" 3 4
extern char *getwd (char *__buf)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__)) ;
extern int dup (int __fd) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int dup2 (int __fd, int __fd2) __attribute__ ((__nothrow__ , __leaf__));
# 543 "/usr/include/unistd.h" 3 4
extern char **__environ;
extern int execve (const char *__path, char *const __argv[],
     char *const __envp[]) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2)));
extern int fexecve (int __fd, char *const __argv[], char *const __envp[])
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
extern int execv (const char *__path, char *const __argv[])
extern int execle (const char *__path, const char *__arg, ...)
extern int execl (const char *__path, const char *__arg, ...)
extern int execvp (const char *__file, char *const __argv[])
extern int execlp (const char *__file, const char *__arg, ...)
# 598 "/usr/include/unistd.h" 3 4
extern int nice (int __inc) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void _exit (int __status) __attribute__ ((__noreturn__));
# 1 "/usr/include/bits/confname.h" 1 3 4
# 24 "/usr/include/bits/confname.h" 3 4
enum
    _PC_LINK_MAX,
    _PC_MAX_CANON,
    _PC_MAX_INPUT,
    _PC_NAME_MAX,
    _PC_PATH_MAX,
    _PC_PIPE_BUF,
    _PC_CHOWN_RESTRICTED,
    _PC_NO_TRUNC,
    _PC_VDISABLE,
    _PC_SYNC_IO,
    _PC_ASYNC_IO,
    _PC_PRIO_IO,
    _PC_SOCK_MAXBUF,
    _PC_FILESIZEBITS,
    _PC_REC_INCR_XFER_SIZE,
    _PC_REC_MAX_XFER_SIZE,
    _PC_REC_MIN_XFER_SIZE,
    _PC_REC_XFER_ALIGN,
    _PC_ALLOC_SIZE_MIN,
    _PC_SYMLINK_MAX,
    _PC_2_SYMLINKS
enum
    _SC_ARG_MAX,
    _SC_CHILD_MAX,
    _SC_CLK_TCK,
    _SC_NGROUPS_MAX,
    _SC_OPEN_MAX,
    _SC_STREAM_MAX,
    _SC_TZNAME_MAX,
    _SC_JOB_CONTROL,
    _SC_SAVED_IDS,
    _SC_REALTIME_SIGNALS,
    _SC_PRIORITY_SCHEDULING,
    _SC_TIMERS,
    _SC_ASYNCHRONOUS_IO,
    _SC_PRIORITIZED_IO,
    _SC_SYNCHRONIZED_IO,
    _SC_FSYNC,
    _SC_MAPPED_FILES,
    _SC_MEMLOCK,
    _SC_MEMLOCK_RANGE,
    _SC_MEMORY_PROTECTION,
    _SC_MESSAGE_PASSING,
    _SC_SEMAPHORES,
    _SC_SHARED_MEMORY_OBJECTS,
    _SC_AIO_LISTIO_MAX,
    _SC_AIO_MAX,
    _SC_AIO_PRIO_DELTA_MAX,
    _SC_DELAYTIMER_MAX,
    _SC_MQ_OPEN_MAX,
    _SC_MQ_PRIO_MAX,
    _SC_VERSION,
    _SC_PAGESIZE,
    _SC_RTSIG_MAX,
    _SC_SEM_NSEMS_MAX,
    _SC_SEM_VALUE_MAX,
    _SC_SIGQUEUE_MAX,
    _SC_TIMER_MAX,
    _SC_BC_BASE_MAX,
    _SC_BC_DIM_MAX,
    _SC_BC_SCALE_MAX,
    _SC_BC_STRING_MAX,
    _SC_COLL_WEIGHTS_MAX,
    _SC_EQUIV_CLASS_MAX,
    _SC_EXPR_NEST_MAX,
    _SC_LINE_MAX,
    _SC_RE_DUP_MAX,
    _SC_CHARCLASS_NAME_MAX,
    _SC_2_VERSION,
    _SC_2_C_BIND,
    _SC_2_C_DEV,
    _SC_2_FORT_DEV,
    _SC_2_FORT_RUN,
    _SC_2_SW_DEV,
    _SC_2_LOCALEDEF,
    _SC_PII,
    _SC_PII_XTI,
    _SC_PII_SOCKET,
    _SC_PII_INTERNET,
    _SC_PII_OSI,
    _SC_POLL,
    _SC_SELECT,
    _SC_UIO_MAXIOV,
    _SC_IOV_MAX = _SC_UIO_MAXIOV,
    _SC_PII_INTERNET_STREAM,
    _SC_PII_INTERNET_DGRAM,
    _SC_PII_OSI_COTS,
    _SC_PII_OSI_CLTS,
    _SC_PII_OSI_M,
    _SC_T_IOV_MAX,
    _SC_THREADS,
    _SC_THREAD_SAFE_FUNCTIONS,
    _SC_GETGR_R_SIZE_MAX,
    _SC_GETPW_R_SIZE_MAX,
    _SC_LOGIN_NAME_MAX,
    _SC_TTY_NAME_MAX,
    _SC_THREAD_DESTRUCTOR_ITERATIONS,
    _SC_THREAD_KEYS_MAX,
    _SC_THREAD_STACK_MIN,
    _SC_THREAD_THREADS_MAX,
    _SC_THREAD_ATTR_STACKADDR,
    _SC_THREAD_ATTR_STACKSIZE,
    _SC_THREAD_PRIORITY_SCHEDULING,
    _SC_THREAD_PRIO_INHERIT,
    _SC_THREAD_PRIO_PROTECT,
    _SC_THREAD_PROCESS_SHARED,
    _SC_NPROCESSORS_CONF,
    _SC_NPROCESSORS_ONLN,
    _SC_PHYS_PAGES,
    _SC_AVPHYS_PAGES,
    _SC_ATEXIT_MAX,
    _SC_PASS_MAX,
    _SC_XOPEN_VERSION,
    _SC_XOPEN_XCU_VERSION,
    _SC_XOPEN_UNIX,
    _SC_XOPEN_CRYPT,
    _SC_XOPEN_ENH_I18N,
    _SC_XOPEN_SHM,
    _SC_2_CHAR_TERM,
    _SC_2_C_VERSION,
    _SC_2_UPE,
    _SC_XOPEN_XPG2,
    _SC_XOPEN_XPG3,
    _SC_XOPEN_XPG4,
    _SC_CHAR_BIT,
    _SC_CHAR_MAX,
    _SC_CHAR_MIN,
    _SC_INT_MAX,
    _SC_INT_MIN,
    _SC_LONG_BIT,
    _SC_WORD_BIT,
    _SC_MB_LEN_MAX,
    _SC_NZERO,
    _SC_SSIZE_MAX,
    _SC_SCHAR_MAX,
    _SC_SCHAR_MIN,
    _SC_SHRT_MAX,
    _SC_SHRT_MIN,
    _SC_UCHAR_MAX,
    _SC_UINT_MAX,
    _SC_ULONG_MAX,
    _SC_USHRT_MAX,
    _SC_NL_ARGMAX,
    _SC_NL_LANGMAX,
    _SC_NL_MSGMAX,
    _SC_NL_NMAX,
    _SC_NL_SETMAX,
    _SC_NL_TEXTMAX,
    _SC_XBS5_ILP32_OFF32,
    _SC_XBS5_ILP32_OFFBIG,
    _SC_XBS5_LP64_OFF64,
    _SC_XBS5_LPBIG_OFFBIG,
    _SC_XOPEN_LEGACY,
    _SC_XOPEN_REALTIME,
    _SC_XOPEN_REALTIME_THREADS,
    _SC_ADVISORY_INFO,
    _SC_BARRIERS,
    _SC_BASE,
    _SC_C_LANG_SUPPORT,
    _SC_C_LANG_SUPPORT_R,
    _SC_CLOCK_SELECTION,
    _SC_CPUTIME,
    _SC_THREAD_CPUTIME,
    _SC_DEVICE_IO,
    _SC_DEVICE_SPECIFIC,
    _SC_DEVICE_SPECIFIC_R,
    _SC_FD_MGMT,
    _SC_FIFO,
    _SC_PIPE,
    _SC_FILE_ATTRIBUTES,
    _SC_FILE_LOCKING,
    _SC_FILE_SYSTEM,
    _SC_MONOTONIC_CLOCK,
    _SC_MULTI_PROCESS,
    _SC_SINGLE_PROCESS,
    _SC_NETWORKING,
    _SC_READER_WRITER_LOCKS,
    _SC_SPIN_LOCKS,
    _SC_REGEXP,
    _SC_REGEX_VERSION,
    _SC_SHELL,
    _SC_SIGNALS,
    _SC_SPAWN,
    _SC_SPORADIC_SERVER,
    _SC_THREAD_SPORADIC_SERVER,
    _SC_SYSTEM_DATABASE,
    _SC_SYSTEM_DATABASE_R,
    _SC_TIMEOUTS,
    _SC_TYPED_MEMORY_OBJECTS,
    _SC_USER_GROUPS,
    _SC_USER_GROUPS_R,
    _SC_2_PBS,
    _SC_2_PBS_ACCOUNTING,
    _SC_2_PBS_LOCATE,
    _SC_2_PBS_MESSAGE,
    _SC_2_PBS_TRACK,
    _SC_SYMLOOP_MAX,
    _SC_STREAMS,
    _SC_2_PBS_CHECKPOINT,
    _SC_V6_ILP32_OFF32,
    _SC_V6_ILP32_OFFBIG,
    _SC_V6_LP64_OFF64,
    _SC_V6_LPBIG_OFFBIG,
    _SC_HOST_NAME_MAX,
    _SC_TRACE,
    _SC_TRACE_EVENT_FILTER,
    _SC_TRACE_INHERIT,
    _SC_TRACE_LOG,
    _SC_LEVEL1_ICACHE_SIZE,
    _SC_LEVEL1_ICACHE_ASSOC,
    _SC_LEVEL1_ICACHE_LINESIZE,
    _SC_LEVEL1_DCACHE_SIZE,
    _SC_LEVEL1_DCACHE_ASSOC,
    _SC_LEVEL1_DCACHE_LINESIZE,
    _SC_LEVEL2_CACHE_SIZE,
    _SC_LEVEL2_CACHE_ASSOC,
    _SC_LEVEL2_CACHE_LINESIZE,
    _SC_LEVEL3_CACHE_SIZE,
    _SC_LEVEL3_CACHE_ASSOC,
    _SC_LEVEL3_CACHE_LINESIZE,
    _SC_LEVEL4_CACHE_SIZE,
    _SC_LEVEL4_CACHE_ASSOC,
    _SC_LEVEL4_CACHE_LINESIZE,
    _SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
    _SC_RAW_SOCKETS,
    _SC_V7_ILP32_OFF32,
    _SC_V7_ILP32_OFFBIG,
    _SC_V7_LP64_OFF64,
    _SC_V7_LPBIG_OFFBIG,
    _SC_SS_REPL_MAX,
    _SC_TRACE_EVENT_NAME_MAX,
    _SC_TRACE_NAME_MAX,
    _SC_TRACE_SYS_MAX,
    _SC_TRACE_USER_EVENT_MAX,
    _SC_XOPEN_STREAMS,
    _SC_THREAD_ROBUST_PRIO_INHERIT,
    _SC_THREAD_ROBUST_PRIO_PROTECT
enum
    _CS_PATH,
    _CS_V6_WIDTH_RESTRICTED_ENVS,
    _CS_GNU_LIBC_VERSION,
    _CS_GNU_LIBPTHREAD_VERSION,
    _CS_V5_WIDTH_RESTRICTED_ENVS,
    _CS_V7_WIDTH_RESTRICTED_ENVS,
    _CS_LFS_CFLAGS = 1000,
    _CS_LFS_LDFLAGS,
    _CS_LFS_LIBS,
    _CS_LFS_LINTFLAGS,
    _CS_LFS64_CFLAGS,
    _CS_LFS64_LDFLAGS,
    _CS_LFS64_LIBS,
    _CS_LFS64_LINTFLAGS,
    _CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
    _CS_XBS5_ILP32_OFF32_LDFLAGS,
    _CS_XBS5_ILP32_OFF32_LIBS,
    _CS_XBS5_ILP32_OFF32_LINTFLAGS,
    _CS_XBS5_ILP32_OFFBIG_CFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LDFLAGS,
    _CS_XBS5_ILP32_OFFBIG_LIBS,
    _CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
    _CS_XBS5_LP64_OFF64_CFLAGS,
    _CS_XBS5_LP64_OFF64_LDFLAGS,
    _CS_XBS5_LP64_OFF64_LIBS,
    _CS_XBS5_LP64_OFF64_LINTFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_CFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
    _CS_XBS5_LPBIG_OFFBIG_LIBS,
    _CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFF32_LIBS,
    _CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V6_LP64_OFF64_CFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V6_LP64_OFF64_LIBS,
    _CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_CFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFF32_LIBS,
    _CS_POSIX_V7_ILP32_OFF32_LINTFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_ILP32_OFFBIG_LIBS,
    _CS_POSIX_V7_ILP32_OFFBIG_LINTFLAGS,
    _CS_POSIX_V7_LP64_OFF64_CFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LDFLAGS,
    _CS_POSIX_V7_LP64_OFF64_LIBS,
    _CS_POSIX_V7_LP64_OFF64_LINTFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LIBS,
    _CS_POSIX_V7_LPBIG_OFFBIG_LINTFLAGS,
    _CS_V6_ENV,
    _CS_V7_ENV
# 610 "/usr/include/unistd.h" 2 3 4
extern long int pathconf (const char *__path, int __name)
extern long int fpathconf (int __fd, int __name) __attribute__ ((__nothrow__ , __leaf__));
extern long int sysconf (int __name) __attribute__ ((__nothrow__ , __leaf__));
extern size_t confstr (int __name, char *__buf, size_t __len) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getppid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t __getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getpgid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern int setpgid (__pid_t __pid, __pid_t __pgid) __attribute__ ((__nothrow__ , __leaf__));
# 660 "/usr/include/unistd.h" 3 4
extern int setpgrp (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t setsid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __pid_t getsid (__pid_t __pid) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t getuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __uid_t geteuid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getgid (void) __attribute__ ((__nothrow__ , __leaf__));
extern __gid_t getegid (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getgroups (int __size, __gid_t __list[]) __attribute__ ((__nothrow__ , __leaf__)) ;
# 700 "/usr/include/unistd.h" 3 4
extern int setuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setreuid (__uid_t __ruid, __uid_t __euid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int seteuid (__uid_t __uid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setgid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setregid (__gid_t __rgid, __gid_t __egid) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int setegid (__gid_t __gid) __attribute__ ((__nothrow__ , __leaf__)) ;
# 756 "/usr/include/unistd.h" 3 4
extern __pid_t fork (void) __attribute__ ((__nothrow__));
extern __pid_t vfork (void) __attribute__ ((__nothrow__ , __leaf__));
extern char *ttyname (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
extern int isatty (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int ttyslot (void) __attribute__ ((__nothrow__ , __leaf__));
extern int link (const char *__from, const char *__to)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 2))) ;
extern int linkat (int __fromfd, const char *__from, int __tofd,
     const char *__to, int __flags)
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 4))) ;
extern int symlink (const char *__from, const char *__to)
extern ssize_t readlink (const char *__restrict __path,
    char *__restrict __buf, size_t __len)
extern int symlinkat (const char *__from, int __tofd,
        const char *__to) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1, 3))) ;
extern ssize_t readlinkat (int __fd, const char *__restrict __path,
     __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2, 3))) ;
extern int unlink (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int unlinkat (int __fd, const char *__name, int __flag)
extern int rmdir (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern __pid_t tcgetpgrp (int __fd) __attribute__ ((__nothrow__ , __leaf__));
extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) __attribute__ ((__nothrow__ , __leaf__));
extern char *getlogin (void);
extern int getlogin_r (char *__name, size_t __name_len) __attribute__ ((__nonnull__ (1)));
extern int setlogin (const char *__name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
# 871 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/getopt.h" 1 3 4
# 57 "/usr/include/getopt.h" 3 4
extern char *optarg;
# 71 "/usr/include/getopt.h" 3 4
extern int optind;
extern int opterr;
extern int optopt;
# 150 "/usr/include/getopt.h" 3 4
extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
# 872 "/usr/include/unistd.h" 2 3 4
extern int gethostname (char *__name, size_t __len) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1)));
extern int sethostname (const char *__name, size_t __len)
extern int sethostid (long int __id) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int getdomainname (char *__name, size_t __len)
extern int setdomainname (const char *__name, size_t __len)
extern int vhangup (void) __attribute__ ((__nothrow__ , __leaf__));
extern int revoke (const char *__file) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern int profil (unsigned short int *__sample_buffer, size_t __size,
     size_t __offset, unsigned int __scale)
extern int acct (const char *__name) __attribute__ ((__nothrow__ , __leaf__));
extern char *getusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void endusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern void setusershell (void) __attribute__ ((__nothrow__ , __leaf__));
extern int daemon (int __nochdir, int __noclose) __attribute__ ((__nothrow__ , __leaf__)) ;
extern int chroot (const char *__path) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (1))) ;
extern char *getpass (const char *__prompt) __attribute__ ((__nonnull__ (1)));
extern int fsync (int __fd);
# 969 "/usr/include/unistd.h" 3 4
extern long int gethostid (void);
extern void sync (void) __attribute__ ((__nothrow__ , __leaf__));
extern int getpagesize (void) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__const__));
extern int getdtablesize (void) __attribute__ ((__nothrow__ , __leaf__));
# 993 "/usr/include/unistd.h" 3 4
extern int truncate (const char *__file, __off_t __length)
# 1016 "/usr/include/unistd.h" 3 4
extern int ftruncate (int __fd, __off_t __length) __attribute__ ((__nothrow__ , __leaf__)) ;
# 1037 "/usr/include/unistd.h" 3 4
extern int brk (void *__addr) __attribute__ ((__nothrow__ , __leaf__)) ;
extern void *sbrk (intptr_t __delta) __attribute__ ((__nothrow__ , __leaf__));
# 1058 "/usr/include/unistd.h" 3 4
extern long int syscall (long int __sysno, ...) __attribute__ ((__nothrow__ , __leaf__));
# 1081 "/usr/include/unistd.h" 3 4
extern int lockf (int __fd, int __cmd, __off_t __len) ;
# 1112 "/usr/include/unistd.h" 3 4
extern int fdatasync (int __fildes);
# 1151 "/usr/include/unistd.h" 3 4
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_UNISTD_H" to "1"
Checking for header: netinet/in.h
stdout:
# 1 "<built-in>"
# 21 "/usr/include/netinet/in.h" 3 4
# 22 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 36 "/usr/include/stdint.h" 3 4
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 65 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 90 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 103 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 119 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 134 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 10 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
# 60 "/usr/include/sys/types.h" 3 4
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
# 98 "/usr/include/sys/types.h" 3 4
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 133 "/usr/include/sys/types.h" 2 3 4
# 146 "/usr/include/sys/types.h" 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 216 "/usr/include/sys/types.h" 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
struct timespec
    __time_t tv_sec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 270 "/usr/include/sys/types.h" 3 4
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
# 271 "/usr/include/sys/types.h" 2 3 4
struct iovec
    void *iov_base;
    size_t iov_len;
         __off_t __offset) ;
   __off_t __offset) ;
enum __socket_type
  SOCK_STREAM = 1,
  SOCK_DGRAM = 2,
  SOCK_RAW = 3,
  SOCK_RDM = 4,
  SOCK_SEQPACKET = 5,
  SOCK_DCCP = 6,
  SOCK_PACKET = 10,
struct sockaddr
    char sa_data[14];
enum
    MSG_OOB = 0x01,
    MSG_PEEK = 0x02,
    MSG_CTRUNC = 0x08,
    MSG_PROXY = 0x10,
    MSG_TRUNC = 0x20,
    MSG_EOR = 0x80,
    MSG_FIN = 0x200,
    MSG_SYN = 0x400,
    MSG_RST = 0x1000,
    MSG_MORE = 0x8000,
struct msghdr
    void *msg_name;
    size_t msg_iovlen;
    void *msg_control;
    int msg_flags;
struct cmsghdr
    size_t cmsg_len;
    int cmsg_level;
    int cmsg_type;
enum
    SCM_RIGHTS = 0x01
struct linger
    int l_onoff;
    int l_linger;
struct osockaddr
enum
  SHUT_RD = 0,
  SHUT_WR,
  SHUT_RDWR
   int __flags);
struct in_addr
    in_addr_t s_addr;
struct ip_opts
    char ip_opts[40];
struct ip_mreqn
    int imr_ifindex;
struct in_pktinfo
    int ipi_ifindex;
enum
    IPPROTO_IP = 0,
    IPPROTO_ICMP = 1,
    IPPROTO_IGMP = 2,
    IPPROTO_IPIP = 4,
    IPPROTO_TCP = 6,
    IPPROTO_EGP = 8,
    IPPROTO_PUP = 12,
    IPPROTO_UDP = 17,
    IPPROTO_IDP = 22,
    IPPROTO_TP = 29,
    IPPROTO_DCCP = 33,
    IPPROTO_IPV6 = 41,
    IPPROTO_RSVP = 46,
    IPPROTO_GRE = 47,
    IPPROTO_ESP = 50,
    IPPROTO_AH = 51,
    IPPROTO_MTP = 92,
    IPPROTO_ENCAP = 98,
    IPPROTO_PIM = 103,
    IPPROTO_COMP = 108,
    IPPROTO_SCTP = 132,
    IPPROTO_RAW = 255,
    IPPROTO_MAX
enum
    IPPROTO_NONE = 59,
    IPPROTO_MH = 135
enum
    IPPORT_ECHO = 7,
    IPPORT_DISCARD = 9,
    IPPORT_SYSTAT = 11,
    IPPORT_FTP = 21,
    IPPORT_TELNET = 23,
    IPPORT_SMTP = 25,
    IPPORT_WHOIS = 43,
    IPPORT_MTP = 57,
    IPPORT_TFTP = 69,
    IPPORT_RJE = 77,
    IPPORT_FINGER = 79,
    IPPORT_SUPDUP = 95,
struct in6_addr
    union
      } __in6_u;
struct sockaddr_in
    in_port_t sin_port;
struct sockaddr_in6
struct ip_mreq
struct ipv6_mreq
struct group_req
struct ip_msfilter
struct group_filter
    uint32_t gf_fmode;
    uint32_t gf_numsrc;
              Defined "HAVE_NETINET_IN_H" to "1"
TEST checkRecursiveMacros from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:218)
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:218)
  Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.headers/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
  return 0;
TEST configureCacheDetails from config.utilities.cacheDetails(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
  Try to determine the size and associativity of the cache.
              Pushing language C
                        All intermediate test results are stored in /tmp/petsc-F9l5hH/config.utilities.cacheDetails
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
  return 0;
              Popping language C
            Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_SIZE()); fclose(output);;
  return 0;
                        Pushing language C
                        Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.utilities.cacheDetails/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.utilities.cacheDetails/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-F9l5hH/config.utilities.cacheDetails/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.utilities.cacheDetails/conftest
            Popping language C
            Defined "LEVEL1_DCACHE_SIZE" to "32768"
            Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "LEVEL1_DCACHE_LINESIZE" to "64"
            Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_ASSOC() { long val = sysconf(_SC_LEVEL1_DCACHE_ASSOC); return (0 <= val && val <= 2147483647) ? val : 2; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_ASSOC()); fclose(output);;
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "LEVEL1_DCACHE_ASSOC" to "8"
TEST check_siginfo_t from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:46)
TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
  Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
Checking for type: siginfo_t
                        All intermediate test results are stored in /tmp/petsc-F9l5hH/config.types
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.types/conftest.o -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.types    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.types/conftest.c
Possible ERROR while running compiler:
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.types/conftest.c:13:11: warning: unused variable ‘a’ [-Wunused-variable]
 siginfo_t a;;
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
siginfo_t a;;
  return 0;
siginfo_t found
            Defined "HAVE_SIGINFO_T" to "1"
TEST check__int64 from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
  Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.c:13:1: error: unknown type name ‘__int64’
 __int64 a;;
/tmp/petsc-F9l5hH/config.types/conftest.c:13:9: warning: unused variable ‘a’ [-Wunused-variable]
 __int64 a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
  return 0;
__int64 found
TEST checkSizeTypes from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
  Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.c:13:8: warning: unused variable ‘a’ [-Wunused-variable]
 size_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
  return 0;
size_t found
TEST checkFileTypes from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
  Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stderr:
 mode_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
  return 0;
mode_t found
Checking for type: off_t
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.c:13:7: warning: unused variable ‘a’ [-Wunused-variable]
 off_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
  return 0;
off_t found
TEST checkIntegerTypes from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
  Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stderr:
 int32_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
  return 0;
int32_t found
TEST checkPID from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
  Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stderr:
 pid_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
  return 0;
pid_t found
TEST checkUID from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
  Checks for uid_t and gid_t, and defines them if necessary
Source:
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.types/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.types/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-F9l5hH/config.types/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.types/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.types/conffix.h" 1
# 3 "/tmp/petsc-F9l5hH/config.types/conftest.c" 2
# 25 "/usr/include/sys/types.h" 3 4
# 26 "/usr/include/sys/types.h" 2 3 4
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef struct
  } __sigset_t;
struct timespec
    __time_t tv_sec;
struct timeval
    __time_t tv_sec;
typedef struct
  } fd_set;
__extension__
__extension__
__extension__
  char __size[56];
  long int __align;
} __pthread_list_t;
typedef union
    int __lock;
    int __owner;
    int __kind;
    short __spins;
    short __elision;
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    void *__mutex;
  } __data;
  char __size[48];
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
typedef union
  struct
    int __lock;
    int __writer;
    int __shared;
  } __data;
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
typedef union
  char __size[32];
  long int __align;
typedef union
  char __size[4];
  int __align;
TEST checkSignal from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
  Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
  return 0;
            Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
  Check for complex numbers in in C99 std
       Note that since PETSc source code uses _Complex we test specifically for that, not complex
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.c:6:17: warning: variable ‘x’ set but not used [-Wunused-but-set-variable]
 double _Complex x;
Source:
#include <complex.h>
int main() {
double _Complex x;
 x = I;
  return 0;
stderr:
 double _Complex x;
Source:
int main() {
double _Complex x;
 x = I;
  return 0;
                    Pushing language C
                    Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.types/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.types/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
            Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
  Check for complex numbers in namespace std
            Pushing language Cxx
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.types/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -fopenmp -O3      /tmp/petsc-F9l5hH/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
  return 0;
                    Pushing language CXX
                    Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.types/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.types/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
            Defined "HAVE_CXX_COMPLEX" to "1"
            Popping language Cxx
TEST checkFortranKind from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
  Checks whether selected_int_kind etc work USE_FORTRANKIND
            Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.types/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.types/conftest.F
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.F:4.43:
        real(kind=selected_real_kind(10)) d
                                           1
Warning: Unused variable 'd' declared at (1)
/tmp/petsc-F9l5hH/config.types/conftest.F:3.45:
        integer(kind=selected_int_kind(10)) i
                                             1
Warning: Unused variable 'i' declared at (1)
Source:
      program main
      end
            Defined "USE_FORTRANKIND" to "1"
            Popping language FC
TEST checkConst from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:150)
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:150)
  Checks for working const, and if not found defines it to empty string
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.c:30:9: warning: ‘t’ is used uninitialized in this function [-Wuninitialized]
       *t++ = 0;
/tmp/petsc-F9l5hH/config.types/conftest.c:46:25: warning: ‘b’ is used uninitialized in this function [-Wuninitialized]
       struct s *b; b->j = 5;
Source:
int main() {
    /* Ultrix mips cc rejects this.  */
    typedef int charset[2]; const charset x;
    /* SunOS 4.1.1 cc rejects this.  */
    char const *const *ccp;
    char **p;
    /* NEC SVR4.0.2 mips cc rejects this.  */
    struct point {int x, y;};
    static struct point const zero = {0,0};
    /* AIX XL C 1.02.0.0 rejects this.
    It does not let you subtract one const X* pointer from another in an arm
    of an if-expression whose if-part is not a constant expression */
    const char *g = "string";
    ccp = &g + (g ? g-g : 0);
    /* HPUX 7.0 cc rejects these. */
    ++ccp;
    p = (char**) ccp;
    ccp = (char const *const *) p;
    /* This section avoids unused variable warnings */
    if (zero.x);
    if (x[0]);
    { /* SCO 3.2v4 cc rejects this.  */
      char *t;
      char const *s = 0 ? (char *) 0 : (char const *) 0;
      *t++ = 0;
      if (*s);
    { /* Someone thinks the Sun supposedly-ANSI compiler will reject this.  */
      int x[] = {25, 17};
      const int *foo = &x[0];
      ++foo;
    { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
      typedef const int *iptr;
      iptr p = 0;
      ++p;
    { /* AIX XL C 1.02.0.0 rejects this saying
      "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
      struct s { int j; const int *ap[3]; };
    { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
      const int foo = 10;
      /* Get rid of unused variable warning */
      if (foo);
  return 0;
TEST checkEndian from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:206)
TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:206)
  If the machine is big endian, defines WORDS_BIGENDIAN
Successful compile:
Source:
#ifdef HAVE_SYS_PARAM_H
  #include <sys/param.h>
#endif
int main() {
#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
  bogus endian macros
#endif
  return 0;
stderr:
/tmp/petsc-F9l5hH/config.types/conftest.c:11:3: error: unknown type name ‘not’
   not big endian
/tmp/petsc-F9l5hH/config.types/conftest.c:11:11: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘endian’
   not big endian
Source:
#endif
int main() {
#if BYTE_ORDER != BIG_ENDIAN
  not big endian
#endif
  return 0;
TEST checkSizeof from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:259)
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:259)
  Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(char));
  return 0;
                          Pushing language C
                          Popping language C
Testing executable /tmp/petsc-F9l5hH/config.types/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.types/conftest
              Popping language C
              Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(void *));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(short));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(int));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_INT" to "4"
Checking for size of type: long
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long long));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(float));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(double));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
              Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(size_t));
  return 0;
                          Pushing language C
                          Popping language C
              Popping language C
              Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:310)
TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:310)
  Determine the nubmer of bits per byte and define BITS_PER_BYTE
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#endif
int main() {
    char val[2];
    int i = 0;
    if (!f) exit(1);
    val[0]='\1';
    val[1]='\0';
    while(val[0]) {val[0] <<= 1; i++;}
    fprintf(f, "%d\n", i);
  return 0;
                        Pushing language C
                        Popping language C
            Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/types.py:356)
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:356)
            Pushing language C
Successful compile:
Source:
int main() {
__attribute__((visibility ("default"))) int foo(void);;
  return 0;
            Defined "USE_VISIBILITY_C" to "1"
            Popping language C
Successful compile:
Source:
int main() {
  return 0;
            Defined "USE_VISIBILITY_CXX" to "1"
TEST configureMemAlign from PETSc.options.memAlign(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/memAlign.py:30)
TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:30)
  Choose alignment
            Defined "MEMALIGN" to "16"
          Memory alignment is 16
TEST check from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            Checking for functions [socket] in library ['socket', 'nsl'] []
              Pushing language C
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.types    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o  -lsocket -lnsl -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/bin/ld: cannot find -lsocket
collect2: error: ld returned 1 exit status
              Popping language C
            Checking for functions [handle_sigfpes] in library ['fpe'] []
              Pushing language C
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o  -lfpe -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
/bin/ld: cannot find -lfpe
              Popping language C
              Pushing language C
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
              Popping language C
              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
stderr:
              Popping language C
TEST checkMath from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:251)
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:251)
  Check for sin() in libm, the math library
            Checking for functions [sin floor log10 pow] in library [''] []
              Pushing language C
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_sin’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:5:41: warning: variable ‘y’ set but not used [-Wunused-but-set-variable]
 static void _check_sin() { double x = 0,y; y = sin(x);
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_floor’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:8:43: warning: variable ‘y’ set but not used [-Wunused-but-set-variable]
 static void _check_floor() { double x = 0,y; y = floor(x);
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_log10’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:11:43: warning: variable ‘y’ set but not used [-Wunused-but-set-variable]
 static void _check_log10() { double x = 0,y; y = log10(x);
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_pow’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:14:41: warning: variable ‘y’ set but not used [-Wunused-but-set-variable]
 static void _check_pow() { double x = 0,y ; y = pow(x, x);
Source:
double sin(double);
double floor(double);
double log10(double);
double pow(double, double);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o   -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
/bin/ld: /tmp/petsc-F9l5hH/config.libraries/conftest.o: undefined reference to symbol 'log10@@GLIBC_2.2.5'
/lib64/libm.so.6: error adding symbols: DSO missing from command line
              Popping language C
            Checking for functions [sin floor log10 pow] in library ['m'] []
              Pushing language C
stderr:
Source:
double sin(double);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o  -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
              Defined "HAVE_LIBM" to "1"
              Popping language C
          Using libm for the math library
TEST checkMathErf from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:267)
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:267)
  Check for erf() in libm, the math library
            Checking for functions [erf] in library ['libm.a'] []
              Pushing language C
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_erf’:
 static void _check_erf() { double x = 0,y; y = erf(x);
Source:
double erf(double);
int main() {
_check_erf();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
          erf() found
            Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:276)
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:276)
  Check for tgama() in libm, the math library
            Checking for functions [tgamma] in library ['libm.a'] []
              Pushing language C
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_tgamma’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:5:44: warning: variable ‘y’ set but not used [-Wunused-but-set-variable]
 static void _check_tgamma() { double x = 0,y; y = tgamma(x);
Source:
double tgamma(double);
int main() {
_check_tgamma();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
          tgamma() found
            Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:285)
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:285)
  Checks if <fenv.h> can be used with FE_DFL_ENV
            Checking for functions [fesetenv] in library ['libm.a'] []
              Pushing language C
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
            Defined "HAVE_FENV_H" to "1"
TEST checkMathLog2 from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:293)
TESTING: checkMathLog2 from config.libraries(config/BuildSystem/config/libraries.py:293)
  Check for log2() in libm, the math library
            Checking for functions [log2] in library ['libm.a'] []
              Pushing language C
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_log2’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:5:42: warning: variable ‘y’ set but not used [-Wunused-but-set-variable]
 static void _check_log2() { double x = 1,y; y = log2(x);
Source:
double log2(double);
int main() {
_check_log2();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
          log2() found
            Defined "HAVE_LOG2" to "1"
TEST checkCompression from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:302)
TESTING: checkCompression from config.libraries(config/BuildSystem/config/libraries.py:302)
  Check for libz, the compression library
            Checking for functions [compress uncompress] in library [''] []
              Pushing language C
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_compress’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:5:119: warning: variable ‘ret’ set but not used [-Wunused-but-set-variable]
 static void _check_compress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret =   compress(dest, &destLen, source, sourceLen);
/tmp/petsc-F9l5hH/config.libraries/conftest.c: In function ‘_check_uncompress’:
/tmp/petsc-F9l5hH/config.libraries/conftest.c:8:121: warning: variable ‘ret’ set but not used [-Wunused-but-set-variable]
 static void _check_uncompress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret = uncompress(dest, &destLen, source, sourceLen);
Source:
int   compress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
int uncompress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
int main() {
_check_compress();
_check_uncompress();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.o: In function `main':
conftest.c:(.text.startup+0x19): undefined reference to `compress'
conftest.c:(.text.startup+0x32): undefined reference to `uncompress'
              Popping language C
            Checking for functions [compress uncompress] in library ['z'] []
              Pushing language C
stderr:
Source:
int main() {
_check_compress();
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o  -lz -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
              Defined "HAVE_LIBZ" to "1"
              Popping language C
          Using libz for the compression library
TEST checkRealtime from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:323)
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:323)
  Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
            Checking for functions [clock_gettime] in library [''] []
              Pushing language C
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
  return 0;
                      Pushing language C
                      Popping language C
              Popping language C
          realtime functions are linked in by default
TEST checkDynamic from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:339)
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:339)
  Check for the header and libraries necessary for dynamic library manipulation
            Checking for functions [dlopen] in library ['dl'] []
              Pushing language C
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o  -ldl -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
              Defined "HAVE_LIBDL" to "1"
              Popping language C
Checking for header: dlfcn.h
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.headers/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
# 1 "/usr/include/dlfcn.h" 1 3 4
# 22 "/usr/include/dlfcn.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 23 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 25 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/bits/dlfcn.h" 1 3 4
# 28 "/usr/include/dlfcn.h" 2 3 4
# 52 "/usr/include/dlfcn.h" 3 4
extern void *dlopen (const char *__file, int __mode) __attribute__ ((__nothrow__));
extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
extern void *dlsym (void *__restrict __handle,
      const char *__restrict __name) __attribute__ ((__nothrow__ , __leaf__)) __attribute__ ((__nonnull__ (2)));
# 82 "/usr/include/dlfcn.h" 3 4
extern char *dlerror (void) __attribute__ ((__nothrow__ , __leaf__));
# 188 "/usr/include/dlfcn.h" 3 4
              Defined "HAVE_DLFCN_H" to "1"
TEST configureLibraryOptions from PETSc.options.libraryOptions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/libraryOptions.py:37)
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:37)
  Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE and PETSC_USE_FORTRAN_KERNELS
            Defined "USE_LOG" to "0"
Executing: mpicc -qversion
            Defined "USE_MALLOC_COALESCED" to "1"
            Defined "USE_INFO" to "1"
            Defined "USE_CTABLE" to "1"
            Defined "USE_BACKWARD_LOOP" to "1"
            **********Checking if running on BGL/IBM detected
              Checking for functions [bgl_perfctr_void] in library [''] []
                Pushing language C
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `bgl_perfctr_void'
                Popping language C
              Checking for functions [ADIOI_BGL_Open] in library [''] []
                Pushing language C
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `ADIOI_BGL_Open'
                Popping language C
            *********BGL/IBM test failure
            Defined "Alignx(a,b)" to "  "
TEST configureISColorValueType from PETSc.options.libraryOptions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/libraryOptions.py:91)
TESTING: configureISColorValueType from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:91)
  Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
            Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
            Defined "IS_COLORING_MAX" to "65535"
            Defined "IS_COLOR_VALUE_TYPE" to "short"
            Defined "IS_COLOR_VALUE_TYPE_SIZE" to "PETSC_SIZEOF_SHORT"
TEST configureCPURelax from config.atomics(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/atomics.py:17)
TESTING: configureCPURelax from config.atomics(config/BuildSystem/config/atomics.py:17)
   Definitions for cpu relax assembly instructions
                      All intermediate test results are stored in /tmp/petsc-F9l5hH/config.atomics
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.atomics/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.atomics/conftest.c
Successful compile:
Source:
int main() {
asm volatile("rep; nop" ::: "memory");;
  return 0;
            Defined "CPU_RELAX()" to "asm volatile("rep; nop" ::: "memory")"
TEST configureMemoryBarriers from config.atomics(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/atomics.py:36)
TESTING: configureMemoryBarriers from config.atomics(config/BuildSystem/config/atomics.py:36)
   Definitions for memory barrier instructions
Successful compile:
Source:
int main() {
asm volatile("mfence":::"memory");
  return 0;
            Defined "MEMORY_BARRIER()" to "asm volatile("mfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("lfence":::"memory");
  return 0;
            Defined "READ_MEMORY_BARRIER()" to "asm volatile("lfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("sfence":::"memory");
  return 0;
            Defined "WRITE_MEMORY_BARRIER()" to "asm volatile("sfence":::"memory")"
TEST checkMemcmp from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:110)
TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:110)
  Check for 8-bit clean memcmp
          Making executable to test memcmp()
                            All intermediate test results are stored in /tmp/petsc-F9l5hH/config.functions
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.functions/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.atomics    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.functions/conftest.c
Successful compile:
Source:
#include <string.h>
void exit(int);
int main() {
char c0 = 0x40;
char c1 = (char) 0x80;
char c2 = (char) 0x81;
exit(memcmp(&c0, &c2, 1) < 0 && memcmp(&c1, &c2, 1) < 0 ? 0 : 1);
  return 0;
                        Pushing language C
                        Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.functions/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.functions/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-F9l5hH/config.functions/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.functions/conftest
TEST checkSysinfo from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:135)
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:135)
  Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.functions/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.functions    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_SYSINFO" to "1"
Checking for header: linux/kernel.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 1 "/usr/include/linux/sysinfo.h" 1 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 1 "/usr/include/asm/types.h" 1 3 4
# 1 "/usr/include/asm-generic/types.h" 1 3 4
# 1 "/usr/include/asm-generic/int-ll64.h" 1 3 4
# 11 "/usr/include/asm-generic/int-ll64.h" 3 4
# 1 "/usr/include/asm/bitsperlong.h" 1 3 4
# 10 "/usr/include/asm/bitsperlong.h" 3 4
# 1 "/usr/include/asm-generic/bitsperlong.h" 1 3 4
# 11 "/usr/include/asm/bitsperlong.h" 2 3 4
# 12 "/usr/include/asm-generic/int-ll64.h" 2 3 4
typedef __signed__ char __s8;
typedef unsigned char __u8;
typedef __signed__ short __s16;
typedef unsigned short __u16;
typedef __signed__ int __s32;
typedef unsigned int __u32;
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
# 7 "/usr/include/asm-generic/types.h" 2 3 4
# 5 "/usr/include/asm/types.h" 2 3 4
# 5 "/usr/include/linux/types.h" 2 3 4
# 1 "/usr/include/linux/posix_types.h" 1 3 4
# 1 "/usr/include/linux/stddef.h" 1 3 4
# 5 "/usr/include/linux/posix_types.h" 2 3 4
# 24 "/usr/include/linux/posix_types.h" 3 4
typedef struct {
 unsigned long fds_bits[1024 / (8 * sizeof(long))];
} __kernel_fd_set;
typedef void (*__kernel_sighandler_t)(int);
typedef int __kernel_key_t;
typedef int __kernel_mqd_t;
# 1 "/usr/include/asm/posix_types.h" 1 3 4
# 1 "/usr/include/asm/posix_types_64.h" 1 3 4
# 10 "/usr/include/asm/posix_types_64.h" 3 4
typedef unsigned short __kernel_old_uid_t;
typedef unsigned short __kernel_old_gid_t;
typedef unsigned long __kernel_old_dev_t;
# 1 "/usr/include/asm-generic/posix_types.h" 1 3 4
# 14 "/usr/include/asm-generic/posix_types.h" 3 4
typedef long __kernel_long_t;
typedef unsigned long __kernel_ulong_t;
typedef __kernel_ulong_t __kernel_ino_t;
typedef unsigned int __kernel_mode_t;
typedef int __kernel_pid_t;
typedef int __kernel_ipc_pid_t;
typedef unsigned int __kernel_uid_t;
typedef unsigned int __kernel_gid_t;
typedef __kernel_long_t __kernel_suseconds_t;
typedef int __kernel_daddr_t;
typedef unsigned int __kernel_uid32_t;
typedef unsigned int __kernel_gid32_t;
# 71 "/usr/include/asm-generic/posix_types.h" 3 4
typedef __kernel_ulong_t __kernel_size_t;
typedef __kernel_long_t __kernel_ssize_t;
typedef __kernel_long_t __kernel_ptrdiff_t;
typedef struct {
 int val[2];
} __kernel_fsid_t;
typedef __kernel_long_t __kernel_off_t;
typedef long long __kernel_loff_t;
typedef __kernel_long_t __kernel_time_t;
typedef __kernel_long_t __kernel_clock_t;
typedef int __kernel_timer_t;
typedef int __kernel_clockid_t;
typedef char * __kernel_caddr_t;
typedef unsigned short __kernel_uid16_t;
typedef unsigned short __kernel_gid16_t;
# 18 "/usr/include/asm/posix_types_64.h" 2 3 4
# 7 "/usr/include/asm/posix_types.h" 2 3 4
# 36 "/usr/include/linux/posix_types.h" 2 3 4
# 9 "/usr/include/linux/types.h" 2 3 4
# 27 "/usr/include/linux/types.h" 3 4
typedef __u16 __le16;
typedef __u16 __be16;
typedef __u32 __le32;
typedef __u32 __be32;
typedef __u64 __le64;
typedef __u64 __be64;
typedef __u16 __sum16;
typedef __u32 __wsum;
# 5 "/usr/include/linux/sysinfo.h" 2 3 4
struct sysinfo {
 __kernel_long_t uptime;
 __kernel_ulong_t loads[3];
 __kernel_ulong_t totalram;
 __kernel_ulong_t freeram;
 __kernel_ulong_t sharedram;
 __kernel_ulong_t bufferram;
 __kernel_ulong_t totalswap;
 __kernel_ulong_t freeswap;
 __u16 procs;
 __u16 pad;
 __kernel_ulong_t totalhigh;
 __kernel_ulong_t freehigh;
 __u32 mem_unit;
 char _f[20-2*sizeof(__kernel_ulong_t)-sizeof(__u32)];
# 5 "/usr/include/linux/kernel.h" 2 3 4
              Defined "HAVE_LINUX_KERNEL_H" to "1"
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>"
# 1 "/usr/include/sys/sysinfo.h" 1 3 4
# 21 "/usr/include/sys/sysinfo.h" 3 4
# 22 "/usr/include/sys/sysinfo.h" 2 3 4
typedef struct {
} __kernel_fd_set;
typedef struct {
 int val[2];
} __kernel_fsid_t;
struct sysinfo {
 __u16 procs;
 __u16 pad;
 __u32 mem_unit;
# 25 "/usr/include/sys/sysinfo.h" 2 3 4
extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs_conf (void) __attribute__ ((__nothrow__ , __leaf__));
extern int get_nprocs (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_phys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
extern long int get_avphys_pages (void) __attribute__ ((__nothrow__ , __leaf__));
              Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>"
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>"
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.c" 2stderr:
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
 #include <sys/systeminfo.h>
compilation terminated.
Source:
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory #include <sys/systeminfo.h>                            ^compilation terminated.:
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:13:4: error: #error "Cannot check sysinfo without special headers"
 #  error "Cannot check sysinfo without special headers"
/tmp/petsc-F9l5hH/config.functions/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.functions/conftest.c:17:1: warning: implicit declaration of function ‘sysinfo’ [-Wimplicit-function-declaration]
 char buf[10]; long count=10; sysinfo(1, buf, count);
Source:
#ifdef HAVE_LINUX_KERNEL_H
#  include <linux/kernel.h>
#  include <linux/sys.h>
#  ifdef HAVE_SYS_SYSINFO_H
#    include <sys/sysinfo.h>
#  endif
#elif defined(HAVE_SYS_SYSTEMINFO_H)
#  include <sys/systeminfo.h>
#else
#endif
int main() {
  return 0;
              Compile failed inside link
TEST checkVPrintf from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:158)
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:158)
  Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ‘vprintf’
 char vprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_VPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
  return 0;
                    Pushing language C
                    Popping language C
TEST checkVFPrintf from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:165)
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:165)
  Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ‘vfprintf’
 char vfprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_VFPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
  return 0;
                    Pushing language C
                    Popping language C
TEST checkVSNPrintf from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:172)
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:172)
  Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:6:1: warning: implicit declaration of function ‘_vsnprintf’ [-Wimplicit-function-declaration]
 _vsnprintf(0,0,0,0);
Source:
#include <stdio.h>
int main() {
  return 0;
                    Pushing language C
                    Popping language C
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.o: In function `main':
conftest.c:(.text.startup+0xf): undefined reference to `_vsnprintf'
Checking for functions [vsnprintf]
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ‘vsnprintf’
 char vsnprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vsnprintf) || defined (__stub___vsnprintf)
vsnprintf_will_always_fail_with_ENOSYS();
#else
vsnprintf();
#endif
  return 0;
                      Pushing language C
                      Popping language C
              Defined "HAVE_VSNPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
  return 0;
                    Pushing language C
                    Popping language C
TEST checkNanosleep from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:206)
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:206)
  Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
 tp.tv_sec = 0;
 tp.tv_nsec = (long)(1e9);
 nanosleep(&tp,0);
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_NANOSLEEP" to "1"
TEST checkSignalHandlerType from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:182)
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:182)
  Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.functions/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.types -fopenmp -O3      /tmp/petsc-F9l5hH/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.functions/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.functions/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
            Defined "SIGNAL_CAST" to " "
TEST checkFreeReturnType from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:192)
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:192)
  Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:6:25: error: void value not ignored as it ought to be
 int ierr; void *p; ierr = free(p); return 0;
/tmp/petsc-F9l5hH/config.functions/conftest.c:6:5: warning: variable ‘ierr’ set but not used [-Wunused-but-set-variable]
Source:
#include <stdlib.h>
int main() {
  return 0;
TEST checkVariableArgumentLists from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:198)
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:198)
  Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
  va_list l1, l2;
  va_copy(l1, l2);
  return 0;
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/functions.py:89)
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:89)
  Recursive decompose to rapidly classify functions as found or missing
    To confirm that a function is missing, we require a compile/link
    failure with only that function in a compilation unit.  In contrast,
    we can confirm that many functions are present by compiling them all
    together in a large compilation unit.  We optimistically compile
    everything together, then trim all functions that were named in the
    error message and bisect the result.  The trimming is only an
    optimization to increase the likelihood of a big-batch compile
    succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink _set_output_format PXFGETARG sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times _mkdir time sysctlbyname stricmp]
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:16:6: warning: conflicting types for built-in function ‘snprintf’
 char snprintf();
/tmp/petsc-F9l5hH/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ‘bzero’
 char bzero();
/tmp/petsc-F9l5hH/config.functions/conftest.c:36:6: warning: conflicting types for built-in function ‘fork’
 char fork();
/tmp/petsc-F9l5hH/config.functions/conftest.c:48:6: warning: conflicting types for built-in function ‘strcasecmp’
 char strcasecmp();
/tmp/petsc-F9l5hH/config.functions/conftest.c:52:6: warning: conflicting types for built-in function ‘memmove’
 char memmove();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _sleep();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _access();
char lseek();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char access();
char _snprintf();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
char sbreak();
char memalign();
char sigset();
char getcwd();
char gethostbyname();
char gettimeofday();
char readlink();
char _set_output_format();
char PXFGETARG();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char _mkdir();
char time();
char sysctlbyname();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_memmove) || defined (__stub___memmove)
memmove_will_always_fail_with_ENOSYS();
#else
memmove();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub__mkdir) || defined (__stub____mkdir)
_mkdir_will_always_fail_with_ENOSYS();
#else
_mkdir();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
conftest.c:(.text.startup+0x3f): warning: the `getwd' function is dangerous and should not be used.
conftest.c:(.text.startup+0x15): undefined reference to `_sleep'
conftest.c:(.text.startup+0x38): undefined reference to `_getcwd'
conftest.c:(.text.startup+0x4d): undefined reference to `_lseek'
conftest.c:(.text.startup+0x5b): undefined reference to `_access'
conftest.c:(.text.startup+0x93): undefined reference to `_snprintf'
conftest.c:(.text.startup+0xb6): undefined reference to `sbreak'
conftest.c:(.text.startup+0xe7): undefined reference to `_set_output_format'
conftest.c:(.text.startup+0xee): undefined reference to `PXFGETARG'
conftest.c:(.text.startup+0x13b): undefined reference to `_mkdir'
conftest.c:(.text.startup+0x149): undefined reference to `sysctlbyname'
conftest.c:(.text.startup+0x150): undefined reference to `stricmp'
Checking for functions [rand getdomainname realpath dlsym bzero uname usleep dlclose gethostname clock get_nprocs dlerror mkstemp fork getpagesize]
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:17:6: warning: conflicting types for built-in function ‘bzero’
 char bzero();
/tmp/petsc-F9l5hH/config.functions/conftest.c:26:6: warning: conflicting types for built-in function ‘fork’
 char fork();
Source:
#include "confdefs.h"
#include "conffix.h"
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
get_nprocs();
#endif
#else
dlerror();
#endif
#else
mkstemp();
#endif
#else
fork();
#endif
#else
getpagesize();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_RAND" to "1"
                    Defined "HAVE_GETDOMAINNAME" to "1"
                    Defined "HAVE_REALPATH" to "1"
                    Defined "HAVE_DLSYM" to "1"
                    Defined "HAVE_BZERO" to "1"
                    Defined "HAVE_UNAME" to "1"
                    Defined "HAVE_USLEEP" to "1"
                    Defined "HAVE_DLCLOSE" to "1"
                    Defined "HAVE_GETHOSTNAME" to "1"
                    Defined "HAVE_CLOCK" to "1"
                    Defined "HAVE_GET_NPROCS" to "1"
                    Defined "HAVE_DLERROR" to "1"
                    Defined "HAVE_MKSTEMP" to "1"
                    Defined "HAVE_FORK" to "1"
                    Defined "HAVE_GETPAGESIZE" to "1"
Checking for functions [memalign sigset gethostbyname gettimeofday readlink sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time]
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ‘strcasecmp’
 char strcasecmp();
/tmp/petsc-F9l5hH/config.functions/conftest.c:23:6: warning: conflicting types for built-in function ‘memmove’
 char memmove();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
char sigset();
char readlink();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
#else
sigset();
#endif
#else
gethostbyname();
#endif
#else
gettimeofday();
#endif
#else
readlink();
#endif
#else
sigaction();
#endif
#else
strcasecmp();
#endif
#else
dlopen();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
memmove();
#endif
#else
signal();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
times();
#endif
#else
time();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_MEMALIGN" to "1"
                    Defined "HAVE_SIGSET" to "1"
                    Defined "HAVE_GETHOSTBYNAME" to "1"
                    Defined "HAVE_GETTIMEOFDAY" to "1"
                    Defined "HAVE_READLINK" to "1"
                    Defined "HAVE_SIGACTION" to "1"
                    Defined "HAVE_STRCASECMP" to "1"
                    Defined "HAVE_DLOPEN" to "1"
                    Defined "HAVE_DRAND48" to "1"
                    Defined "HAVE_SOCKET" to "1"
                    Defined "HAVE_MEMMOVE" to "1"
                    Defined "HAVE_SIGNAL" to "1"
                    Defined "HAVE_POPEN" to "1"
                    Defined "HAVE_GETRUSAGE" to "1"
                    Defined "HAVE_TIMES" to "1"
                    Defined "HAVE_TIME" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `_sleep'
Checking for functions [snprintf]
Possible ERROR while running compiler:
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ‘snprintf’
 char snprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `_getcwd'
Checking for functions [getwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): warning: the `getwd' function is dangerous and should not be used.
                    Defined "HAVE_GETWD" to "1"
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `_lseek'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_SLEEP" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `_access'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_LSEEK" to "1"
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `_snprintf'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `sbreak'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
  return 0;
                            Pushing language C
                            Popping language C
                    Defined "HAVE_GETCWD" to "1"
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `_set_output_format'
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `PXFGETARG'
Checking for functions [_mkdir]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `_mkdir'
Checking for functions [sysctlbyname]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
sysctlbyname();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `sysctlbyname'
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
  return 0;
                            Pushing language C
                            Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `stricmp'
TEST configureMemorySize from config.utilities.getResidentSetSize(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
  Try to determine how to measure the memory usage
            Defined "USE_PROC_FOR_SIZE" to "1"
          Using /proc for PetscMemoryGetCurrentUsage()
TEST configureFPTrap from config.utilities.FPTrap(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/FPTrap.py:27)
TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:27)
  Checking the handling of floating point traps
Checking for header: sigfpe.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory
 #include <sigfpe.h>
Source:
#include <sigfpe.h>
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory
 #include <sigfpe.h>
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory #include <sigfpe.h>                    ^compilation terminated.:
Checking for header: fpxcp.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory
 #include <fpxcp.h>
Source:
#include <fpxcp.h>
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory
 #include <fpxcp.h>
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory #include <fpxcp.h>                   ^compilation terminated.:
Checking for header: floatingpoint.h
stdout:
# 1 "<built-in>"
stdout:
# 1 "<built-in>"
/tmp/petsc-F9l5hH/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory
 #include <floatingpoint.h>
Source:
Preprocess stderr before filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory
Preprocess stderr after filtering:/tmp/petsc-F9l5hH/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory #include <floatingpoint.h>                           ^compilation terminated.:
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
  Check for the mechanism to retrieve command line arguments in Fortran
            Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
            Pushing language FC
            Checking for functions [] in library [''] []
              Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.libraries   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3   /tmp/petsc-F9l5hH/config.libraries/conftest.F
Successful compile:
Source:
      program main
      integer i
      character*(80) arg
       i = command_argument_count()
       call get_command_argument(i,arg)
      end
                      Pushing language FC
                      Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.libraries/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o   -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
              Popping language FC
            Popping language FC
            Pushing language C
            Defined "HAVE_GFORTRAN_IARGC" to "1"
            Popping language C
            Checking for functions [get_command_argument_] in library [''] ['-L/usr/local/lib', '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/usr/local/lib', '-lgfortran', '-lm', '-lquadmath', '-lm']
              Pushing language C
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument_();
static void _check_get_command_argument_() { get_command_argument_(); }
int main() {
_check_get_command_argument_();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o  -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -lmpifort -lgfortran -lm -Wl,-rpath,/usr/local/lib -lgfortran -lm -lquadmath -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `get_command_argument_'
              Popping language C
            Checking for functions [getarg_] in library [''] ['-L/usr/local/lib', '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/usr/local/lib', '-lgfortran', '-lm', '-lquadmath', '-lm']
              Pushing language C
Successful compile:
Source:
char getarg_();
static void _check_getarg_() { getarg_(); }
int main() {
_check_getarg_();;
  return 0;
                      Pushing language C
                      Popping language C
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `getarg_'
              Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
                      Pushing language C
                      Popping language C
Checking for functions [ipxfargc_]
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.functions/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.functions/conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
  return 0;
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.functions/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.functions/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl  -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -lmpifort -lgfortran -lm -Wl,-rpath,/usr/local/lib -lgfortran -lm -lquadmath -lm
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `ipxfargc_'
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
  return 0;
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `f90_unix_MP_iargc'
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
stderr:
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
  return 0;
stderr:
conftest.c:(.text.startup+0x7): undefined reference to `iargc_'
Checking for functions [GETARG at 16]
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.functions/conftest.c:13:12: error: stray ‘@’ in program
 char GETARG at 16();
/tmp/petsc-F9l5hH/config.functions/conftest.c:13:13: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before numeric constant
/tmp/petsc-F9l5hH/config.functions/conftest.c:21:27: error: missing ')' after "defined"
 #if defined (__stub_GETARG at 16) || defined (__stub___GETARG at 16)
/tmp/petsc-F9l5hH/config.functions/conftest.c:21:28: error: missing binary operator before token "16"
/tmp/petsc-F9l5hH/config.functions/conftest.c:24:7: error: stray ‘@’ in program
 GETARG at 16();
/tmp/petsc-F9l5hH/config.functions/conftest.c:24:1: error: ‘GETARG’ undeclared (first use in this function)
 GETARG at 16();
/tmp/petsc-F9l5hH/config.functions/conftest.c:24:1: note: each undeclared identifier is reported only once for each function it appears in
/tmp/petsc-F9l5hH/config.functions/conftest.c:24:8: error: expected ‘;’ before numeric constant
 GETARG at 16();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
GETARG at 16_will_always_fail_with_ENOSYS();
#else
GETARG at 16();
#endif
  return 0;
Checking for functions [_gfortran_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _gfortran_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__gfortran_iargc) || defined (__stub____gfortran_iargc)
_gfortran_iargc_will_always_fail_with_ENOSYS();
#else
_gfortran_iargc();
#endif
  return 0;
              Defined "HAVE__GFORTRAN_IARGC" to "1"
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
  Checks if certain feature test macros are support
                      All intermediate test results are stored in /tmp/petsc-F9l5hH/config.utilities.featureTestMacros
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.utilities.featureTestMacros/conftest.c
stderr:
/tmp/petsc-F9l5hH/config.utilities.featureTestMacros/conftest.c:4:20: fatal error: sysctl.h: No such file or directory
 #include <sysctl.h>
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
  return 0;
stderr:
In file included from /usr/include/stdlib.h:24:0,
                 from /tmp/petsc-F9l5hH/config.utilities.featureTestMacros/conftest.c:4:
/usr/include/features.h:148:3: warning: #warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
 # warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE"
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_DEFAULT_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
  return 0;
            Defined "_GNU_SOURCE" to "1"
TEST configureMissingDefines from config.utilities.missing(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/missing.py:57)
TESTING: configureMissingDefines from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:57)
  Checks for limits
                      All intermediate test results are stored in /tmp/petsc-F9l5hH/config.utilities.missing
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.utilities.missing/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_LIMITS_H
  #include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
  return 0;
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.utilities.missing/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_FLOAT_H
  #include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
  return 0;
TEST configureMissingUtypeTypedefs from config.utilities.missing(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/missing.py:67)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:67)
   Checks if u_short is undefined
stderr:
/tmp/petsc-F9l5hH/config.utilities.missing/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.utilities.missing/conftest.c:6:9: warning: unused variable ‘foo’ [-Wunused-variable]
 u_short foo;
Source:
#include <sys/types.h>
int main() {
u_short foo;
  return 0;
TEST configureMissingFunctions from config.utilities.missing(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/missing.py:73)
TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:73)
  Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/missing.py:93)
TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:93)
  Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
  return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/missing.py:110)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:110)
Successful compile:
Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#if !defined(_GNU_SOURCE)
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
  return 0;
            Pushing language Cxx
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.utilities.missing/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.utilities.missing -fopenmp -O3      /tmp/petsc-F9l5hH/config.utilities.missing/conftest.cc
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
                    Pushing language CXX
                    Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.utilities.missing/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.utilities.missing/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
            Popping language Cxx
TEST configureMissingSrandPrototype from config.utilities.missing(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/utilities/missing.py:135)
TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:135)
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
  return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
  return 0;
TEST configureMkdir from config.programs(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/programs.py:23)
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:23)
  Make sure we can have mkdir automatically make intermediate directories
Checking for program ./mkdir...not found
Checking for program /home/mpovolot/bin/mkdir...not found
Checking for program /bin/mkdir...found
Executing: /bin/mkdir -p .conftest/tmp
          Adding -p flag to /bin/mkdir -p to automatically create directories
            Defined make macro "MKDIR" to "/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/programs.py:45)
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:45)
  Check for autoreconf
Checking for program ./autoreconf...not found
Checking for program /home/mpovolot/bin/autoreconf...not found
Checking for program /bin/autoreconf...found
            All intermediate test results are stored in /tmp/petsc-F9l5hH/config.programs
Executing: cd /tmp/petsc-F9l5hH/config.programs/autoconfdir&&/bin/autoreconf
          autoreconf test successful!
Checking for program ./libtoolize...not found
Checking for program /home/mpovolot/bin/libtoolize...not found
Checking for program /bin/libtoolize...not found
Checking for program /usr/bin/libtoolize...not found
Checking for program /usr/local/bin/libtoolize...not found
Checking for program /usr/local/visit/bin/libtoolize...not found
Checking for program /opt/matlab/bin/libtoolize...not found
Checking for program /home/mpovolot/libtoolize...not found
Checking for program /home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/bin/win32fe/libtoolize...not found
Checking for program ./glibtoolize...not found
Checking for program /home/mpovolot/bin/glibtoolize...not found
Checking for program /bin/glibtoolize...not found
Checking for program /usr/bin/glibtoolize...not found
Checking for program /usr/local/bin/glibtoolize...not found
Checking for program /usr/local/visit/bin/glibtoolize...not found
Checking for program /opt/matlab/bin/glibtoolize...not found
Checking for program /home/mpovolot/glibtoolize...not found
Checking for program /home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/bin/win32fe/glibtoolize...not found
TEST configurePrograms from config.programs(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/programs.py:72)
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:72)
  Check for the programs needed to build and run PETSc
Checking for program ./sh...not found
Checking for program /home/mpovolot/bin/sh...not found
Checking for program /bin/sh...found
              Defined make macro "SHELL" to "/bin/sh"
Checking for program ./sed...not found
Checking for program /home/mpovolot/bin/sed...not found
Checking for program /bin/sed...found
              Defined make macro "SED" to "/bin/sed"
Executing: /bin/sed -i s/sed/sd/g "/tmp/petsc-F9l5hH/config.programs/sed1"
          Adding SEDINPLACE cmd: /bin/sed -i
            Defined make macro "SEDINPLACE" to "/bin/sed -i"
Checking for program ./mv...not found
Checking for program /home/mpovolot/bin/mv...not found
Checking for program /bin/mv...found
              Defined make macro "MV" to "/bin/mv"
Checking for program ./cp...not found
Checking for program /home/mpovolot/bin/cp...not found
Checking for program /bin/cp...found
              Defined make macro "CP" to "/bin/cp"
Checking for program ./grep...not found
Checking for program /home/mpovolot/bin/grep...not found
Checking for program /bin/grep...found
              Defined make macro "GREP" to "/bin/grep"
Checking for program ./rm...not found
Checking for program /home/mpovolot/bin/rm...not found
Checking for program /bin/rm...found
              Defined make macro "RM" to "/bin/rm -f"
Checking for program ./diff...not found
Checking for program /home/mpovolot/bin/diff...not found
Checking for program /bin/diff...found
Executing: "/bin/diff" -w "/tmp/petsc-F9l5hH/config.programs/diff1" "/tmp/petsc-F9l5hH/config.programs/diff2"
            Defined make macro "DIFF" to "/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /home/mpovolot/ps...not found
Checking for program /home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/bin/win32fe/ps...not found
Checking for program ./gzip...not found
Checking for program /home/mpovolot/bin/gzip...not found
Checking for program /bin/gzip...found
              Defined make macro "GZIP" to "/bin/gzip"
            Defined "HAVE_GZIP" to "1"
            Defined make macro "PYTHON" to "/bin/python"
TEST configureMake from config.packages.make(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/make.py:83)
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:83)
  Check for user specified make - or gmake, make
Checking for program ./gmake...not found
Checking for program /home/mpovolot/bin/gmake...not found
Checking for program /bin/gmake...found
              Defined make macro "MAKE" to "/bin/gmake"
Executing: /bin/gmake --version
stdout:
GNU Make 4.0
Built for x86_64-redhat-linux-gnu
Copyright (C) 1988-2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
TEST configureCheckGNUMake from config.packages.make(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/make.py:120)
TESTING: configureCheckGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:120)
  Setup other GNU make stuff
stdout:
GNU Make 4.0
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
            Defined make macro "MAKE_IS_GNUMAKE" to "1"
            Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
            Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
            Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
            Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
TEST configureMakeNP from config.packages.make(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/make.py:158)
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:158)
  check no of cores on the build machine [perhaps to do make '-j ncores']
          module multiprocessing found 8 cores: using make_np = 7
            Defined make macro "MAKE_NP" to "7"
            Defined make macro "NPMAX" to "8"
        Defined make macro "OMAKE_PRINTDIR " to "/bin/gmake  --print-directory"
        Defined make macro "OMAKE" to "/bin/gmake  --no-print-directory"
        Defined make macro "MAKE_PAR_OUT_FLG" to "--output-sync=recurse"
TEST alternateConfigureLibrary from config.packages.OpenMPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:735)
  Called if --with-packagename=0; does nothing by default
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
TEST alternateConfigureLibrary from config.packages.MPICH(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:735)
TEST configureLibrary from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:483)
TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:483)
  Calls the regular package configureLibrary and then does an additional test needed by MPI
            Checking for a functional MPI
            Checking for library in Compiler specific search MPI: []
TEST check from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
                Checking for functions [MPI_Init MPI_Comm_create] in library [] []
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.utilities.missing -fopenmp -O3      /tmp/petsc-F9l5hH/config.libraries/conftest.cc
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
            Checking for headers Compiler specific search MPI: ['/usr/local/include']
TEST checkInclude from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['mpi.h'] in ['/usr/local/include']
                  Checking include with compiler flags var CPPFLAGS ['/usr/local/include']
Executing: mpic++ -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers   -I/usr/local/include /tmp/petsc-F9l5hH/config.headers/conftest.cc
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.cc"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
extern "C" {
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
# 1 "/usr/local/include/mpi.h" 1 3
# 14 "/usr/local/include/mpi.h" 3
extern "C" {
# 98 "/usr/local/include/mpi.h" 3
typedef int MPI_Datatype;
# 281 "/usr/local/include/mpi.h" 3
typedef int MPI_Comm;
typedef int MPI_Group;
typedef int MPI_Win;
typedef struct ADIOI_FileD *MPI_File;
typedef int MPI_Op;
# 364 "/usr/local/include/mpi.h" 3
typedef enum MPIR_Win_flavor {
    MPI_WIN_FLAVOR_CREATE = 1,
    MPI_WIN_FLAVOR_ALLOCATE = 2,
    MPI_WIN_FLAVOR_DYNAMIC = 3,
    MPI_WIN_FLAVOR_SHARED = 4
} MPIR_Win_flavor_t;
typedef enum MPIR_Win_model {
    MPI_WIN_SEPARATE = 1,
    MPI_WIN_UNIFIED = 2
} MPIR_Win_model_t;
typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
extern int * const MPI_UNWEIGHTED;
extern int * const MPI_WEIGHTS_EMPTY;
# 396 "/usr/local/include/mpi.h" 3
typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
       void *, int *);
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
       void *, int *);
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
      int *);
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
# 424 "/usr/local/include/mpi.h" 3
typedef int MPI_Errhandler;
# 445 "/usr/local/include/mpi.h" 3
typedef int MPI_Request;
typedef int MPI_Message;
typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
# 499 "/usr/local/include/mpi.h" 3
enum MPIR_Combiner_enum {
    MPI_COMBINER_NAMED = 1,
    MPI_COMBINER_DUP = 2,
    MPI_COMBINER_CONTIGUOUS = 3,
    MPI_COMBINER_VECTOR = 4,
    MPI_COMBINER_HVECTOR_INTEGER = 5,
    MPI_COMBINER_HVECTOR = 6,
    MPI_COMBINER_INDEXED = 7,
    MPI_COMBINER_HINDEXED_INTEGER = 8,
    MPI_COMBINER_HINDEXED = 9,
    MPI_COMBINER_INDEXED_BLOCK = 10,
    MPI_COMBINER_STRUCT_INTEGER = 11,
    MPI_COMBINER_STRUCT = 12,
    MPI_COMBINER_SUBARRAY = 13,
    MPI_COMBINER_DARRAY = 14,
    MPI_COMBINER_F90_REAL = 15,
    MPI_COMBINER_F90_COMPLEX = 16,
    MPI_COMBINER_F90_INTEGER = 17,
    MPI_COMBINER_RESIZED = 18,
    MPI_COMBINER_HINDEXED_BLOCK = 19
typedef int MPI_Info;
# 549 "/usr/local/include/mpi.h" 3
typedef long MPI_Aint;
typedef int MPI_Fint;
typedef long long MPI_Count;
# 568 "/usr/local/include/mpi.h" 3
typedef long long MPI_Offset;
typedef struct MPI_Status {
    int count_lo;
    int count_hi_and_cancelled;
    int MPI_SOURCE;
    int MPI_TAG;
    int MPI_ERROR;
} MPI_Status;
struct MPIR_T_enum_s;
struct MPIR_T_cvar_handle_s;
struct MPIR_T_pvar_handle_s;
struct MPIR_T_pvar_session_s;
typedef struct MPIR_T_enum_s * MPI_T_enum;
typedef struct MPIR_T_cvar_handle_s * MPI_T_cvar_handle;
typedef struct MPIR_T_pvar_handle_s * MPI_T_pvar_handle;
typedef struct MPIR_T_pvar_session_s * MPI_T_pvar_session;
extern struct MPIR_T_pvar_handle_s * const MPI_T_PVAR_ALL_HANDLES;
# 605 "/usr/local/include/mpi.h" 3
typedef enum MPIR_T_verbosity_t {
    MPIX_T_VERBOSITY_INVALID = 0,
    MPI_T_VERBOSITY_USER_BASIC = 221,
    MPI_T_VERBOSITY_USER_DETAIL,
    MPI_T_VERBOSITY_USER_ALL,
    MPI_T_VERBOSITY_TUNER_BASIC,
    MPI_T_VERBOSITY_TUNER_DETAIL,
    MPI_T_VERBOSITY_TUNER_ALL,
    MPI_T_VERBOSITY_MPIDEV_BASIC,
    MPI_T_VERBOSITY_MPIDEV_DETAIL,
    MPI_T_VERBOSITY_MPIDEV_ALL
} MPIR_T_verbosity_t;
typedef enum MPIR_T_bind_t {
    MPIX_T_BIND_INVALID = 0,
    MPI_T_BIND_NO_OBJECT = 9700,
    MPI_T_BIND_MPI_COMM,
    MPI_T_BIND_MPI_DATATYPE,
    MPI_T_BIND_MPI_ERRHANDLER,
    MPI_T_BIND_MPI_FILE,
    MPI_T_BIND_MPI_GROUP,
    MPI_T_BIND_MPI_OP,
    MPI_T_BIND_MPI_REQUEST,
    MPI_T_BIND_MPI_WIN,
    MPI_T_BIND_MPI_MESSAGE,
    MPI_T_BIND_MPI_INFO
} MPIR_T_bind_t;
typedef enum MPIR_T_scope_t {
    MPIX_T_SCOPE_INVALID = 0,
    MPI_T_SCOPE_CONSTANT = 60438,
    MPI_T_SCOPE_READONLY,
    MPI_T_SCOPE_LOCAL,
    MPI_T_SCOPE_GROUP,
    MPI_T_SCOPE_GROUP_EQ,
    MPI_T_SCOPE_ALL,
    MPI_T_SCOPE_ALL_EQ
} MPIR_T_scope_t;
typedef enum MPIR_T_pvar_class_t {
    MPIX_T_PVAR_CLASS_INVALID = 0,
    MPIR_T_PVAR_CLASS_FIRST = 240,
    MPI_T_PVAR_CLASS_STATE = MPIR_T_PVAR_CLASS_FIRST,
    MPI_T_PVAR_CLASS_LEVEL,
    MPI_T_PVAR_CLASS_SIZE,
    MPI_T_PVAR_CLASS_PERCENTAGE,
    MPI_T_PVAR_CLASS_HIGHWATERMARK,
    MPI_T_PVAR_CLASS_LOWWATERMARK,
    MPI_T_PVAR_CLASS_COUNTER,
    MPI_T_PVAR_CLASS_AGGREGATE,
    MPI_T_PVAR_CLASS_TIMER,
    MPI_T_PVAR_CLASS_GENERIC,
    MPIR_T_PVAR_CLASS_LAST,
    MPIR_T_PVAR_CLASS_NUMBER = MPIR_T_PVAR_CLASS_LAST - MPIR_T_PVAR_CLASS_FIRST
} MPIR_T_pvar_class_t;
# 727 "/usr/local/include/mpi.h" 3
extern MPI_Fint * MPI_F_STATUS_IGNORE;
extern MPI_Fint * MPI_F_STATUSES_IGNORE;
# 742 "/usr/local/include/mpi.h" 3
typedef struct {
    MPI_Fint count_lo;
    MPI_Fint count_hi_and_cancelled;
    MPI_Fint MPI_SOURCE;
    MPI_Fint MPI_TAG;
    MPI_Fint MPI_ERROR;
} MPI_F08_Status;
extern MPI_F08_Status MPIR_F08_MPI_STATUS_IGNORE_OBJ;
extern MPI_F08_Status MPIR_F08_MPI_STATUSES_IGNORE_OBJ[1];
extern int MPIR_F08_MPI_IN_PLACE;
extern int MPIR_F08_MPI_BOTTOM;
extern MPI_F08_Status *MPI_F08_STATUS_IGNORE;
extern MPI_F08_Status *MPI_F08_STATUSES_IGNORE;
# 766 "/usr/local/include/mpi.h" 3
typedef int (MPI_Grequest_cancel_function)(void *, int);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_poll_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_wait_function)(int, void **, double, MPI_Status *);
# 896 "/usr/local/include/mpi.h" 3
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
             void *, MPI_Offset, void *);
typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
                      void *);
# 916 "/usr/local/include/mpi.h" 3
int MPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
             MPI_Comm comm) ;
int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
             MPI_Comm comm, MPI_Status *status) ;
int MPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Buffer_attach(void *buffer, int size);
int MPI_Buffer_detach(void *buffer_addr, int *size);
int MPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm, MPI_Request *request) ;
int MPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Wait(MPI_Request *request, MPI_Status *status);
int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int MPI_Request_free(MPI_Request *request);
int MPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int MPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int MPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int MPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
                 int array_of_indices[], MPI_Status array_of_statuses[]);
int MPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int MPI_Cancel(MPI_Request *request);
int MPI_Test_cancelled(const MPI_Status *status, int *flag);
int MPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Start(MPI_Request *request);
int MPI_Startall(int count, MPI_Request array_of_requests[]);
int MPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
                 int sendtag, void *recvbuf, int recvcount, MPI_Datatype recvtype,
                 int source, int recvtag, MPI_Comm comm, MPI_Status *status)
int MPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
                         int sendtag, int source, int recvtag, MPI_Comm comm,
int MPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_indexed(int count, const int *array_of_blocklengths,
                     const int *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_hindexed(int count, const int *array_of_blocklengths,
                      const MPI_Aint *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_struct(int count, const int *array_of_blocklengths,
                    const MPI_Datatype *array_of_types, MPI_Datatype *newtype);
int MPI_Address(const void *location, MPI_Aint *address);
int MPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Type_size(MPI_Datatype datatype, int *size);
int MPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_commit(MPI_Datatype *datatype);
int MPI_Type_free(MPI_Datatype *datatype);
int MPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
             int outsize, int *position, MPI_Comm comm) ;
int MPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
               MPI_Datatype datatype, MPI_Comm comm) ;
int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int MPI_Barrier(MPI_Comm comm);
int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int MPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
               int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm)
int MPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root,
                MPI_Comm comm)
int MPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
                 MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype,
int MPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                  int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
                  MPI_Datatype sendtype, void *recvbuf, const int *recvcounts,
                  const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                  const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[],
                  const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, MPI_Comm comm)
int MPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, int root, MPI_Comm comm)
int MPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int MPI_Op_free(MPI_Op *op);
int MPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                       MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
int MPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
             MPI_Comm comm)
int MPI_Group_size(MPI_Group group, int *size);
int MPI_Group_rank(MPI_Group group, int *rank);
int MPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                              int ranks2[]);
int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int MPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_free(MPI_Group *group);
int MPI_Comm_size(MPI_Comm comm, int *size);
int MPI_Comm_rank(MPI_Comm comm, int *rank);
int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int MPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int MPI_Comm_free(MPI_Comm *comm);
int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
int MPI_Comm_remote_size(MPI_Comm comm, int *size);
int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
                         int remote_leader, int tag, MPI_Comm *newintercomm);
int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int MPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
                      int *keyval, void *extra_state);
int MPI_Keyval_free(int *keyval);
int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int MPI_Attr_delete(MPI_Comm comm, int keyval);
int MPI_Topo_test(MPI_Comm comm, int *status);
int MPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
                    int reorder, MPI_Comm *comm_cart);
int MPI_Dims_create(int nnodes, int ndims, int dims[]);
int MPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
                     int reorder, MPI_Comm *comm_graph);
int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
int MPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int MPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int MPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int MPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int MPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int MPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int MPI_Get_processor_name(char *name, int *resultlen);
int MPI_Get_version(int *version, int *subversion);
int MPI_Get_library_version(char *version, int *resultlen);
int MPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Errhandler_free(MPI_Errhandler *errhandler);
int MPI_Error_string(int errorcode, char *string, int *resultlen);
int MPI_Error_class(int errorcode, int *errorclass);
double MPI_Wtime(void);
double MPI_Wtick(void);
int MPI_Init(int *argc, char ***argv);
int MPI_Finalize(void);
int MPI_Initialized(int *flag);
int MPI_Abort(MPI_Comm comm, int errorcode);
int MPI_Pcontrol(const int level, ...);
int MPIR_Dup_fn(MPI_Comm oldcomm, int keyval, void *extra_state, void *attribute_val_in,
               void *attribute_val_out, int *flag);
int MPI_Close_port(const char *port_name);
int MPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                    MPI_Comm *newcomm);
int MPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int MPI_Comm_disconnect(MPI_Comm *comm);
int MPI_Comm_get_parent(MPI_Comm *parent);
int MPI_Comm_join(int fd, MPI_Comm *intercomm);
int MPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
                   MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
                            const int array_of_maxprocs[], const MPI_Info array_of_info[],
                            int root, MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int MPI_Open_port(MPI_Info info, char *port_name);
int MPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int MPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int MPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
                   int target_rank, MPI_Aint target_disp, int target_count,
                   MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
            MPI_Datatype target_datatype, MPI_Win win) ;
int MPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int MPI_Win_complete(MPI_Win win);
int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                   MPI_Win *win);
int MPI_Win_fence(int assert, MPI_Win win);
int MPI_Win_free(MPI_Win *win);
int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_test(MPI_Win win, int *flag);
int MPI_Win_unlock(int rank, MPI_Win win);
int MPI_Win_wait(MPI_Win win);
int MPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                     MPI_Win *win);
int MPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                            void *baseptr, MPI_Win *win);
int MPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int MPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int MPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int MPI_Win_detach(MPI_Win win, const void *base);
int MPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int MPI_Win_set_info(MPI_Win win, MPI_Info info);
int MPI_Get_accumulate(const void *origin_addr, int origin_count,
                        MPI_Datatype origin_datatype, void *result_addr, int result_count,
                        MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
                        int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Fetch_and_op(const void *origin_addr, void *result_addr,
                      MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
int MPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
                          void *result_addr, MPI_Datatype datatype, int target_rank,
                          MPI_Aint target_disp, MPI_Win win)
int MPI_Rput(const void *origin_addr, int origin_count,
              MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
              int target_count, MPI_Datatype target_datatype, MPI_Win win,
int MPI_Rget(void *origin_addr, int origin_count,
int MPI_Raccumulate(const void *origin_addr, int origin_count,
                     int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
int MPI_Rget_accumulate(const void *origin_addr, int origin_count,
int MPI_Win_lock_all(int assert, MPI_Win win);
int MPI_Win_unlock_all(MPI_Win win);
int MPI_Win_flush(int rank, MPI_Win win);
int MPI_Win_flush_all(MPI_Win win);
int MPI_Win_flush_local(int rank, MPI_Win win);
int MPI_Win_flush_local_all(MPI_Win win);
int MPI_Win_sync(MPI_Win win);
int MPI_Add_error_class(int *errorclass);
int MPI_Add_error_code(int errorclass, int *errorcode);
int MPI_Add_error_string(int errorcode, const char *string);
int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                           MPI_Comm_delete_attr_function *comm_delete_attr_fn, int *comm_keyval,
                           void *extra_state);
int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int MPI_Comm_free_keyval(int *comm_keyval);
int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int MPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int MPI_File_call_errhandler(MPI_File fh, int errorcode);
int MPI_Grequest_complete(MPI_Request request);
int MPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
                       MPI_Grequest_cancel_function *cancel_fn, void *extra_state,
int MPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int MPI_Is_thread_main(int *flag);
int MPI_Query_thread(int *provided);
int MPI_Status_set_cancelled(MPI_Status *status, int flag);
int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
                           MPI_Type_delete_attr_function *type_delete_attr_fn,
                           int *type_keyval, void *extra_state);
int MPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_free_keyval(int *type_keyval);
int MPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int MPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
                          int max_datatypes, int array_of_integers[],
                          MPI_Aint array_of_addresses[], MPI_Datatype array_of_datatypes[]);
int MPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
                          int *num_datatypes, int *combiner);
int MPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int MPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int MPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                          MPI_Win_delete_attr_function *win_delete_attr_fn, int *win_keyval,
                          void *extra_state);
int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
int MPI_Win_free_keyval(int *win_keyval);
int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int MPI_Win_set_name(MPI_Win win, const char *win_name);
int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int MPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int MPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int MPI_Finalized(int *flag);
int MPI_Free_mem(void *base);
int MPI_Get_address(const void *location, MPI_Aint *address);
int MPI_Info_create(MPI_Info *info);
int MPI_Info_delete(MPI_Info info, const char *key);
int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int MPI_Info_free(MPI_Info *info);
int MPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int MPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int MPI_Info_set(MPI_Info info, const char *key, const char *value);
int MPI_Pack_external(const char datarep[], const void *inbuf, int incount,
                      MPI_Datatype datatype, void *outbuf, MPI_Aint outsize, MPI_Aint *position)
int MPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                           MPI_Aint *size);
int MPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int MPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int MPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
                           const int array_of_distribs[], const int array_of_dargs[],
                           const int array_of_psizes[], int order, MPI_Datatype oldtype,
int MPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
                             const MPI_Aint array_of_displacements[], MPI_Datatype oldtype,
int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int MPI_Type_create_hindexed_block(int count, int blocklength,
int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int MPI_Type_create_struct(int count, const int array_of_blocklengths[],
                           const MPI_Datatype array_of_types[], MPI_Datatype *newtype);
int MPI_Type_create_subarray(int ndims, const int array_of_sizes[],
                             const int array_of_subsizes[], const int array_of_starts[],
                             int order, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int MPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
                        MPI_Aint *position, void *outbuf, int outcount, MPI_Datatype datatype)
int MPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int MPI_Type_create_f90_integer(int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_real(int precision, int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_complex(int precision, int range, MPI_Datatype *newtype);
int MPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                     MPI_Op op)
int MPI_Op_commutative(MPI_Op op, int *commute);
int MPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
                                   const int sourceweights[], int outdegree,
                                   const int destinations[], const int destweights[],
                                   MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
                          const int destinations[], const int weights[], MPI_Info info,
int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
                             int maxoutdegree, int destinations[], int destweights[]);
int MPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int MPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int MPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int MPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm,
int MPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 const int recvcounts[], const int displs[], MPI_Datatype recvtype, int root,
int MPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
                  int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   MPI_Datatype sendtype, void *recvbuf, const int recvcounts[],
                   const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm,
int MPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                   MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                        MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int MPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                             void *recvbuf, const int recvcounts[], const int displs[],
int MPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int MPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
                            const MPI_Aint sdispls[], const MPI_Datatype sendtypes[],
                            void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[],
                            const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
int MPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                           const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                           const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int MPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int MPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
int MPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
MPI_Aint MPI_Aint_add(MPI_Aint base, MPI_Aint disp);
MPI_Aint MPI_Aint_diff(MPI_Aint addr1, MPI_Aint addr2);
int MPI_T_init_thread(int required, int *provided);
int MPI_T_finalize(void);
int MPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int MPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int MPI_T_cvar_get_num(int *num_cvar);
int MPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
                        MPI_Datatype *datatype, MPI_T_enum *enumtype, char *desc, int *desc_len,
                        int *binding, int *scope);
int MPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                            int *count);
int MPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int MPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int MPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int MPI_T_pvar_get_num(int *num_pvar);
int MPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
                        int *binding, int *readonly, int *continuous, int *atomic);
int MPI_T_pvar_session_create(MPI_T_pvar_session *session);
int MPI_T_pvar_session_free(MPI_T_pvar_session *session);
int MPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
                            MPI_T_pvar_handle *handle, int *count);
int MPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int MPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int MPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_category_get_num(int *num_cat);
int MPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
                            int *num_cvars, int *num_pvars, int *num_categories);
int MPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_categories(int cat_index, int len, int indices[]);
int MPI_T_category_changed(int *stamp);
int MPI_T_cvar_get_index(const char *name, int *cvar_index);
int MPI_T_pvar_get_index(const char *name, int var_class, int *pvar_index);
int MPI_T_category_get_index(const char *name, int *cat_index);
int MPIX_Comm_failure_ack(MPI_Comm comm);
int MPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int MPIX_Comm_revoke(MPI_Comm comm);
int MPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int MPIX_Comm_agree(MPI_Comm comm, int *flag);
# 1561 "/usr/local/include/mpi.h" 3
int PMPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Buffer_attach(void *buffer, int size);
int PMPI_Buffer_detach(void *buffer_addr, int *size);
int PMPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Wait(MPI_Request *request, MPI_Status *status);
int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int PMPI_Request_free(MPI_Request *request);
int PMPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int PMPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int PMPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int PMPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int PMPI_Cancel(MPI_Request *request);
int PMPI_Test_cancelled(const MPI_Status *status, int *flag);
int PMPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Start(MPI_Request *request);
int PMPI_Startall(int count, MPI_Request array_of_requests[]);
int PMPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
int PMPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_indexed(int count, const int *array_of_blocklengths,
int PMPI_Type_hindexed(int count, const int *array_of_blocklengths,
int PMPI_Type_struct(int count, const int *array_of_blocklengths,
int PMPI_Address(const void *location, MPI_Aint *address);
int PMPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int PMPI_Type_size(MPI_Datatype datatype, int *size);
int PMPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_commit(MPI_Datatype *datatype);
int PMPI_Type_free(MPI_Datatype *datatype);
int PMPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
int PMPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int PMPI_Barrier(MPI_Comm comm);
int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int PMPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 MPI_Comm comm)
int PMPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
int PMPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
int PMPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int PMPI_Op_free(MPI_Op *op);
int PMPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
              MPI_Comm comm)
int PMPI_Group_size(MPI_Group group, int *size);
int PMPI_Group_rank(MPI_Group group, int *rank);
int PMPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                               int ranks2[]);
int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_free(MPI_Group *group);
int PMPI_Comm_size(MPI_Comm comm, int *size);
int PMPI_Comm_rank(MPI_Comm comm, int *rank);
int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int PMPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int PMPI_Comm_free(MPI_Comm *comm);
int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
int PMPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int PMPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
int PMPI_Keyval_free(int *keyval);
int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int PMPI_Attr_delete(MPI_Comm comm, int keyval);
int PMPI_Topo_test(MPI_Comm comm, int *status);
int PMPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
int PMPI_Dims_create(int nnodes, int ndims, int dims[]);
int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
int PMPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int PMPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int PMPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int PMPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int PMPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int PMPI_Get_processor_name(char *name, int *resultlen);
int PMPI_Get_version(int *version, int *subversion);
int PMPI_Get_library_version(char *version, int *resultlen);
int PMPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
int PMPI_Error_string(int errorcode, char *string, int *resultlen);
int PMPI_Error_class(int errorcode, int *errorclass);
double PMPI_Wtime(void);
double PMPI_Wtick(void);
int PMPI_Init(int *argc, char ***argv);
int PMPI_Finalize(void);
int PMPI_Initialized(int *flag);
int PMPI_Abort(MPI_Comm comm, int errorcode);
int PMPI_Pcontrol(const int level, ...);
int PMPI_Close_port(const char *port_name);
int PMPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int PMPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                      MPI_Comm *newcomm);
int PMPI_Comm_disconnect(MPI_Comm *comm);
int PMPI_Comm_get_parent(MPI_Comm *parent);
int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
int PMPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
int PMPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
int PMPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int PMPI_Open_port(MPI_Info info, char *port_name);
int PMPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int PMPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int PMPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Win_complete(MPI_Win win);
int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                    MPI_Win *win);
int PMPI_Win_fence(int assert, MPI_Win win);
int PMPI_Win_free(MPI_Win *win);
int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_test(MPI_Win win, int *flag);
int PMPI_Win_unlock(int rank, MPI_Win win);
int PMPI_Win_wait(MPI_Win win);
int PMPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                      MPI_Win *win);
int PMPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
int PMPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int PMPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int PMPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int PMPI_Win_detach(MPI_Win win, const void *base);
int PMPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int PMPI_Win_set_info(MPI_Win win, MPI_Info info);
int PMPI_Get_accumulate(const void *origin_addr, int origin_count,
int PMPI_Fetch_and_op(const void *origin_addr, void *result_addr,
int PMPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
int PMPI_Rput(const void *origin_addr, int origin_count,
int PMPI_Rget(void *origin_addr, int origin_count,
int PMPI_Raccumulate(const void *origin_addr, int origin_count,
int PMPI_Rget_accumulate(const void *origin_addr, int origin_count,
int PMPI_Win_lock_all(int assert, MPI_Win win);
int PMPI_Win_unlock_all(MPI_Win win);
int PMPI_Win_flush(int rank, MPI_Win win);
int PMPI_Win_flush_all(MPI_Win win);
int PMPI_Win_flush_local(int rank, MPI_Win win);
int PMPI_Win_flush_local_all(MPI_Win win);
int PMPI_Win_sync(MPI_Win win);
int PMPI_Add_error_class(int *errorclass);
int PMPI_Add_error_code(int errorclass, int *errorcode);
int PMPI_Add_error_string(int errorcode, const char *string);
int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                            void *extra_state);
int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int PMPI_Comm_free_keyval(int *comm_keyval);
int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int PMPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
int PMPI_Grequest_complete(MPI_Request request);
int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
int PMPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int PMPI_Is_thread_main(int *flag);
int PMPI_Query_thread(int *provided);
int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
int PMPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int PMPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_free_keyval(int *type_keyval);
int PMPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int PMPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
int PMPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
int PMPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int PMPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int PMPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                           void *extra_state);
int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
int PMPI_Win_free_keyval(int *win_keyval);
int PMPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int PMPI_Win_set_name(MPI_Win win, const char *win_name);
int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int PMPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int PMPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int PMPI_Finalized(int *flag);
int PMPI_Free_mem(void *base);
int PMPI_Get_address(const void *location, MPI_Aint *address);
int PMPI_Info_create(MPI_Info *info);
int PMPI_Info_delete(MPI_Info info, const char *key);
int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int PMPI_Info_free(MPI_Info *info);
int PMPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int PMPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int PMPI_Info_set(MPI_Info info, const char *key, const char *value);
int PMPI_Pack_external(const char datarep[], const void *inbuf, int incount,
int PMPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                            MPI_Aint *size);
int PMPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int PMPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int PMPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int PMPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
int PMPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int PMPI_Type_create_hindexed_block(int count, int blocklength,
int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int PMPI_Type_create_struct(int count, const int array_of_blocklengths[],
int PMPI_Type_create_subarray(int ndims, const int array_of_sizes[],
int PMPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int PMPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int PMPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                      MPI_Op op)
int PMPI_Op_commutative(MPI_Op op, int *commute);
int PMPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
int PMPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int PMPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int PMPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int PMPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
int PMPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int PMPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
int PMPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                            MPI_Comm comm);
int PMPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
int PMPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int PMPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int PMPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
MPI_Aint PMPI_Aint_add(MPI_Aint base, MPI_Aint disp);
MPI_Aint PMPI_Aint_diff(MPI_Aint addr1, MPI_Aint addr2);
int PMPI_T_init_thread(int required, int *provided);
int PMPI_T_finalize(void);
int PMPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int PMPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int PMPI_T_cvar_get_num(int *num_cvar);
int PMPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
int PMPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                             int *count);
int PMPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int PMPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int PMPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int PMPI_T_pvar_get_num(int *num_pvar);
int PMPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
int PMPI_T_pvar_session_create(MPI_T_pvar_session *session);
int PMPI_T_pvar_session_free(MPI_T_pvar_session *session);
int PMPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
int PMPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int PMPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int PMPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_category_get_num(int *num_cat);
int PMPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
int PMPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_categories(int cat_index, int len, int indices[]);
int PMPI_T_category_changed(int *stamp);
int PMPI_T_cvar_get_index(const char *name, int *cvar_index);
int PMPI_T_pvar_get_index(const char *name, int var_class, int *pvar_index);
int PMPI_T_category_get_index(const char *name, int *cat_index);
int PMPIX_Comm_failure_ack(MPI_Comm comm);
int PMPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int PMPIX_Comm_revoke(MPI_Comm comm);
int PMPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int PMPIX_Comm_agree(MPI_Comm comm, int *flag);
# 2215 "/usr/local/include/mpi.h" 3
# 1 "/usr/local/include/mpio.h" 1 3
# 13 "/usr/local/include/mpio.h" 3
# 1 "/usr/local/include/mpi.h" 1 3
# 14 "/usr/local/include/mpio.h" 2 3
extern "C" {
# 123 "/usr/local/include/mpio.h" 3
int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh);
int MPI_File_close(MPI_File *fh);
int MPI_File_delete(const char *filename, MPI_Info info);
int MPI_File_set_size(MPI_File fh, MPI_Offset size);
int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
int MPI_File_get_group(MPI_File fh, MPI_Group *group);
int MPI_File_get_amode(MPI_File fh, int *amode);
int MPI_File_set_info(MPI_File fh, MPI_Info info);
int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype,
                      const char *datarep, MPI_Info info);
int MPI_File_get_view(MPI_File fh, MPI_Offset *disp, MPI_Datatype *etype, MPI_Datatype *filetype,
                      char *datarep);
int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf, int count,
                         MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void * buf, int count,
int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void *buf, int count,
                       MPI_Datatype datatype, MPI_Request *request)
int MPI_File_read(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_read_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Request *request)
int MPI_File_iwrite(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset, MPI_Offset *disp);
int MPI_File_read_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_ordered(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_ordered(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf, int count,
                               MPI_Datatype datatype) ;
int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_write_at_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_all_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_all_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_ordered_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_ordered_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Register_datarep(const char *datarep, MPI_Datarep_conversion_function *read_conversion_fn,
    MPI_Datarep_conversion_function *write_conversion_fn,
    MPI_Datarep_extent_function *dtype_file_extent_fn, void *extra_state);
int MPI_File_set_atomicity(MPI_File fh, int flag);
int MPI_File_get_atomicity(MPI_File fh, int *flag);
int MPI_File_sync(MPI_File fh);
# 242 "/usr/local/include/mpio.h" 3
int MPI_File_iread_at_all(MPI_File fh, MPI_Offset offset, void *buf, int count,
int MPI_File_iwrite_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_iread_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
# 282 "/usr/local/include/mpio.h" 3
MPI_File MPI_File_f2c(MPI_Fint file);
MPI_Fint MPI_File_c2f(MPI_File file);
# 343 "/usr/local/include/mpio.h" 3
int PMPI_File_open(MPI_Comm, const char *, int, MPI_Info, MPI_File *);
int PMPI_File_close(MPI_File *);
int PMPI_File_delete(const char *, MPI_Info);
int PMPI_File_set_size(MPI_File, MPI_Offset);
int PMPI_File_preallocate(MPI_File, MPI_Offset);
int PMPI_File_get_size(MPI_File, MPI_Offset *);
int PMPI_File_get_group(MPI_File, MPI_Group *);
int PMPI_File_get_amode(MPI_File, int *);
int PMPI_File_set_info(MPI_File, MPI_Info);
int PMPI_File_get_info(MPI_File, MPI_Info *);
int PMPI_File_set_view(MPI_File, MPI_Offset,
    MPI_Datatype, MPI_Datatype, const char *, MPI_Info);
int PMPI_File_get_view(MPI_File, MPI_Offset *,
      MPI_Datatype *, MPI_Datatype *, char *);
int PMPI_File_read_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_at_all(MPI_File, MPI_Offset, void *,
int PMPI_File_write_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_write_at_all(MPI_File, MPI_Offset, const void *,
int PMPI_File_iread_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_read(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_all(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_all(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread(MPI_File, void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite(MPI_File, const void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_seek(MPI_File, MPI_Offset, int);
int PMPI_File_get_position(MPI_File, MPI_Offset *);
int PMPI_File_get_byte_offset(MPI_File, MPI_Offset, MPI_Offset *);
int PMPI_File_read_shared(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_shared(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread_shared(MPI_File, void *, int,
int PMPI_File_iwrite_shared(MPI_File, const void *, int,
int PMPI_File_read_ordered(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_ordered(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_seek_shared(MPI_File, MPI_Offset, int);
int PMPI_File_get_position_shared(MPI_File, MPI_Offset *);
int PMPI_File_read_at_all_begin(MPI_File, MPI_Offset, void *,
                               int, MPI_Datatype)
int PMPI_File_read_at_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_at_all_begin(MPI_File, MPI_Offset, const void *,
                                 int, MPI_Datatype)
int PMPI_File_write_at_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_all_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_all_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_ordered_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_ordered_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_ordered_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_ordered_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_get_type_extent(MPI_File, MPI_Datatype, MPI_Aint *);
int PMPI_Register_datarep(const char *,
    MPI_Datarep_conversion_function *,
    MPI_Datarep_extent_function *,
    void *);
int PMPI_File_set_atomicity(MPI_File, int);
int PMPI_File_get_atomicity(MPI_File, int *);
int PMPI_File_sync(MPI_File);
# 471 "/usr/local/include/mpio.h" 3
int PMPI_File_iread_at_all(MPI_File fh, MPI_Offset offset, void *buf, int count,
int PMPI_File_iwrite_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int PMPI_File_iread_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int PMPI_File_iwrite_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
# 495 "/usr/local/include/mpio.h" 3
MPI_File PMPI_File_f2c(MPI_Fint);
MPI_Fint PMPI_File_c2f(MPI_File);
# 532 "/usr/local/include/mpio.h" 3
# 2216 "/usr/local/include/mpi.h" 2 3
# 2231 "/usr/local/include/mpi.h" 3
# 1 "/usr/local/include/mpicxx.h" 1 3
# 54 "/usr/local/include/mpicxx.h" 3
# 1 "/usr/include/stdio.h" 1 3 4
# 27 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 28 "/usr/include/stdio.h" 2 3 4
extern "C" {
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 34 "/usr/include/stdio.h" 2 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 36 "/usr/include/stdio.h" 2 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 74 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 31 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 82 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 32 "/usr/include/libio.h" 2 3 4
# 49 "/usr/include/libio.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 50 "/usr/include/libio.h" 2 3 4
# 144 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 154 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 177 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 245 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 293 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 302 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 338 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
typedef __io_read_fn cookie_read_function_t;
typedef __io_write_fn cookie_write_function_t;
typedef __io_seek_fn cookie_seek_function_t;
typedef __io_close_fn cookie_close_function_t;
typedef struct
  __io_read_fn *read;
  __io_write_fn *write;
  __io_seek_fn *seek;
  __io_close_fn *close;
} _IO_cookie_io_functions_t;
typedef _IO_cookie_io_functions_t cookie_io_functions_t;
struct _IO_cookie_file;
extern void _IO_cookie_init (struct _IO_cookie_file *__cfile, int __read_write,
        void *__cookie, _IO_cookie_io_functions_t __fns);
extern "C" {
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 434 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) throw ();
extern int _IO_ferror (_IO_FILE *__fp) throw ();
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) throw ();
extern void _IO_funlockfile (_IO_FILE *) throw ();
extern int _IO_ftrylockfile (_IO_FILE *) throw ();
# 464 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) throw ();
# 526 "/usr/include/libio.h" 3 4
# 75 "/usr/include/stdio.h" 2 3 4
typedef __gnuc_va_list va_list;
# 90 "/usr/include/stdio.h" 3 4
typedef __off_t off_t;
typedef __off64_t off64_t;
typedef __ssize_t ssize_t;
typedef _G_fpos_t fpos_t;
typedef _G_fpos64_t fpos64_t;
# 164 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 165 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) throw ();
extern int rename (const char *__old, const char *__new) throw ();
extern int renameat (int __oldfd, const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 205 "/usr/include/stdio.h" 3 4
extern FILE *tmpfile64 (void) ;
extern char *tmpnam (char *__s) throw () ;
extern char *tmpnam_r (char *__s) throw () ;
# 227 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
     throw () __attribute__ ((__malloc__)) ;
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 252 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 262 "/usr/include/stdio.h" 3 4
extern int fcloseall (void);
extern FILE *fopen (const char *__restrict __filename,
      const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
        const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 295 "/usr/include/stdio.h" 3 4
extern FILE *fopen64 (const char *__restrict __filename,
extern FILE *freopen64 (const char *__restrict __filename,
extern FILE *fdopen (int __fd, const char *__modes) throw () ;
extern FILE *fopencookie (void *__restrict __magic_cookie,
     _IO_cookie_io_functions_t __io_funcs) throw () ;
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
  throw () ;
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) throw () ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) throw ();
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) throw ();
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
         size_t __size) throw ();
extern void setlinebuf (FILE *__stream) throw ();
extern int fprintf (FILE *__restrict __stream,
      const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      const char *__restrict __format, ...) throw ();
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg) throw ();
extern int snprintf (char *__restrict __s, size_t __maxlen,
     throw () __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     throw () __attribute__ ((__format__ (__printf__, 3, 0)));
extern int vasprintf (char **__restrict __ptr, const char *__restrict __f,
     throw () __attribute__ ((__format__ (__printf__, 2, 0))) ;
extern int __asprintf (char **__restrict __ptr,
         const char *__restrict __fmt, ...)
     throw () __attribute__ ((__format__ (__printf__, 2, 3))) ;
extern int asprintf (char **__restrict __ptr,
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
# 463 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
     throw () __attribute__ ((__format__ (__scanf__, 2, 0)));
# 522 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 550 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 561 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 594 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 638 "/usr/include/stdio.h" 3 4
extern char *gets (char *__s) __attribute__ ((__deprecated__));
# 649 "/usr/include/stdio.h" 3 4
extern char *fgets_unlocked (char *__restrict __s, int __n,
# 665 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 726 "/usr/include/stdio.h" 3 4
extern int fputs_unlocked (const char *__restrict __s,
# 737 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 773 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 792 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 815 "/usr/include/stdio.h" 3 4
extern int fseeko64 (FILE *__stream, __off64_t __off, int __whence);
extern __off64_t ftello64 (FILE *__stream) ;
extern int fgetpos64 (FILE *__restrict __stream, fpos64_t *__restrict __pos);
extern int fsetpos64 (FILE *__stream, const fpos64_t *__pos);
extern void clearerr (FILE *__stream) throw ();
extern int feof (FILE *__stream) throw () ;
extern int ferror (FILE *__stream) throw () ;
extern void clearerr_unlocked (FILE *__stream) throw ();
extern int feof_unlocked (FILE *__stream) throw () ;
extern int ferror_unlocked (FILE *__stream) throw () ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
extern int _sys_nerr;
extern const char *const _sys_errlist[];
# 854 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) throw () ;
extern int fileno_unlocked (FILE *__stream) throw () ;
# 872 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) throw ();
extern char *cuserid (char *__s);
struct obstack;
extern int obstack_printf (struct obstack *__restrict __obstack,
     throw () __attribute__ ((__format__ (__printf__, 2, 3)));
extern int obstack_vprintf (struct obstack *__restrict __obstack,
       __gnuc_va_list __args)
     throw () __attribute__ ((__format__ (__printf__, 2, 0)));
extern void flockfile (FILE *__stream) throw ();
extern int ftrylockfile (FILE *__stream) throw () ;
extern void funlockfile (FILE *__stream) throw ();
# 942 "/usr/include/stdio.h" 3 4
# 55 "/usr/local/include/mpicxx.h" 2 3
enum MPIR_Dummy_seek_type {
    MPIR_DUMMY_SEEK_COMMA_VAL = -1
    , MPIR_SEEK_SET = 0
    , SEEK_SET = MPIR_SEEK_SET
    , MPIR_SEEK_CUR = 1
    , SEEK_CUR = MPIR_SEEK_CUR
    , MPIR_SEEK_END = 2
    , SEEK_END = MPIR_SEEK_END
namespace MPI {
extern void MPIR_Call_world_errhand( int );
typedef MPI_Offset Offset;
typedef MPI_Aint Aint;
typedef MPI_Fint Fint;
void MPIR_CXX_InitDatatypeNames( void );
class Comm;
class Nullcomm;
class Intercomm;
class Intracomm;
class Cartcomm;
class Graphcomm;
class File;
extern int Detach_buffer( void *&v1 ) ;
extern bool Is_initialized( void ) ;
extern void Get_processor_name( char * v1, int &v2 ) ;
extern void Get_error_string( int v1, char * v2, int &v3 ) ;
extern void Compute_dims( int v1, int v2, int v3[] ) ;
extern void Get_version( int &v1, int &v2 ) ;
extern void Finalize( void ) ;
extern void Pcontrol( const int v1, ... ) ;
extern void Attach_buffer( void * v1, int v2 ) ;
extern int Get_error_class( int v1 ) ;
extern Intracomm COMM_WORLD;
extern File FILE_NULL;
class Exception {
  protected:
    int the_real_exception;
  public:
    inline Exception(int obj) : the_real_exception(obj) {}
    inline Exception(void) : the_real_exception(0) {}
    virtual ~Exception() {}
    Exception(const Exception &obj) : the_real_exception(obj.the_real_exception){}
    Exception& operator=(const Exception &obj) {
      the_real_exception = obj.the_real_exception; return *this; }
    bool operator== (const Exception &obj) {
      return (the_real_exception == obj.the_real_exception); }
    bool operator!= (const Exception &obj) {
      return (the_real_exception != obj.the_real_exception); }
    inline operator int*() { return &the_real_exception; }
    inline operator int() const { return the_real_exception; }
    Exception& operator=(const int& obj) {
      the_real_exception = obj; return *this; }
  protected:
    char the_error_message[512];
  public:
    int Get_error_code(void) { return the_real_exception; }
    int Get_error_class(void) { return MPI::Get_error_class(the_real_exception); }
    const char *Get_error_string(void)
 int len;
 MPI_Error_string(the_real_exception, the_error_message, &len);
 return the_error_message;
class Datatype {
    friend class Comm;
    friend class Status;
    friend class Intracomm;
    friend class Intercomm;
    friend class Win;
    friend class File;
    friend class Op;
  protected:
    MPI_Datatype the_real_datatype;
  public:
    inline Datatype(MPI_Datatype obj) : the_real_datatype(obj) {}
    inline Datatype(void) : the_real_datatype(((MPI_Datatype)0x0c000000)) {}
    virtual ~Datatype() {}
    Datatype(const Datatype &obj) : the_real_datatype(obj.the_real_datatype){}
    Datatype& operator=(const Datatype &obj) {
      the_real_datatype = obj.the_real_datatype; return *this; }
    bool operator== (const Datatype &obj) {
      return (the_real_datatype == obj.the_real_datatype); }
    bool operator!= (const Datatype &obj) {
      return (the_real_datatype != obj.the_real_datatype); }
    inline operator MPI_Datatype*() { return &the_real_datatype; }
    inline operator MPI_Datatype() const { return the_real_datatype; }
    Datatype& operator=(const MPI_Datatype& obj) {
      the_real_datatype = obj; return *this; }
    virtual void Commit( void )
        { int err = MPI_Type_commit( (MPI_Datatype *) &the_real_datatype ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Free( void )
        { int err = MPI_Type_free( (MPI_Datatype *) &the_real_datatype ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual Datatype Create_indexed( int v1, const int * v2, const int * v3 ) const
        Datatype v5;
        { int err = MPI_Type_indexed( v1, (const int *)v2, (const int *)v3, (MPI_Datatype) the_real_datatype, &(v5.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v5;
    virtual Datatype Create_contiguous( int v1 ) const
        Datatype v3;
        { int err = MPI_Type_contiguous( v1, (MPI_Datatype) the_real_datatype, &(v3.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    virtual Datatype Create_vector( int v1, int v2, int v3 ) const
        Datatype v5;
        { int err = MPI_Type_vector( v1, v2, v3, (MPI_Datatype) the_real_datatype, &(v5.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v5;
    static Datatype Create_struct( int v1, int v2[], Aint v3[], const Datatype v4[] )
        Datatype v5;
        MPI_Datatype *l4 = new MPI_Datatype[v1];
            int i4;
            for (i4=0;i4<v1;i4++) {
                l4[i4] = v4[i4].the_real_datatype;
        { int err = MPI_Type_create_struct( v1, (const int *)v2, (const MPI_Aint *)v3, l4, &(v5.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
                    delete[] l4;
        return v5;
    virtual int Pack_size( int v1, const Comm &v3 ) const;
    virtual void Pack( const void * v1, int v2, void * v4, int v5, int &v6, const Comm &v7 ) const;
    virtual int Get_size( void ) const
        int v2;
        { int err = MPI_Type_size( (MPI_Datatype) the_real_datatype, &v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2;
    virtual void Get_envelope( int &v2, int &v3, int &v4, int &v5 ) const
        { int err = MPI_Type_get_envelope( (MPI_Datatype) the_real_datatype, &v2, &v3, &v4, &v5 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual Datatype Create_hvector( int v1, int v2, Aint v3 ) const
        Datatype v5;
        { int err = MPI_Type_create_hvector( v1, v2, v3, (MPI_Datatype) the_real_datatype, &(v5.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v5;
    static Datatype Match_size( int v1, int v2 )
        Datatype v3;
        { int err = MPI_Type_match_size( v1, v2, &(v3.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    virtual Datatype Create_resized( const Aint v2, const Aint v3 ) const
        Datatype v4;
        { int err = MPI_Type_create_resized( (MPI_Datatype) the_real_datatype, (MPI_Aint)v2, (MPI_Aint)v3, &(v4.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4;
    virtual Datatype Create_indexed_block( int v1, int v2, const int v3[] ) const
        Datatype v5;
        { int err = MPI_Type_create_indexed_block( v1, v2, (const int *)v3, (MPI_Datatype) the_real_datatype, &(v5.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v5;
    virtual Aint Pack_external_size( const char v1[], int v2 ) const
        MPI_Aint v4;
        { int err = MPI_Pack_external_size( v1, v2, (MPI_Datatype) the_real_datatype, &v4 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4;
    Datatype Dup( void ) const
        Datatype v2;
        { int err = MPI_Type_dup( (MPI_Datatype) the_real_datatype, &(v2.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2;
    virtual Datatype Create_hindexed( int v1, const int v2[], const Aint v3[] ) const
        Datatype v5;
        { int err = MPI_Type_create_hindexed( v1, (const int *)v2, (const MPI_Aint *)v3, (MPI_Datatype) the_real_datatype, &(v5.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v5;
    virtual bool Get_attr( int v2, void * v3 ) const
        int v4;
        { int err = MPI_Type_get_attr( (MPI_Datatype) the_real_datatype, v2, v3, &v4 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4!= 0;
    virtual void Get_true_extent( Aint & v2, Aint & v3 ) const
        { int err = MPI_Type_get_true_extent( (MPI_Datatype) the_real_datatype, &v2, &v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual Datatype Create_darray( int v1, int v2, int v3, const int v4[], const int v5[], const int v6[], const int v7[], int v8 ) const
        Datatype v10;
        { int err = MPI_Type_create_darray( v1, v2, v3, (const int *)v4, (const int *)v5, (const int *)v6, (const int *)v7, v8, (MPI_Datatype) the_real_datatype, &(v10.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v10;
    static Datatype Create_f90_real( int v1, int v2 )
        Datatype v3;
        { int err = MPI_Type_create_f90_real( v1, v2, &(v3.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    virtual void Get_contents( int v2, int v3, int v4, int v5[], Aint v6[], Datatype v7[] ) const
        MPI_Datatype *l7 = new MPI_Datatype[v4];
        { int err = MPI_Type_get_contents( (MPI_Datatype) the_real_datatype, v2, v3, v4, v5, v6, l7 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i7;
            for (i7=0;i7<v4;i7++) {
                v7[i7].the_real_datatype = l7[i7];
            delete[] l7;
    virtual void Set_attr( int v2, const void * v3 )
        { int err = MPI_Type_set_attr( (MPI_Datatype) the_real_datatype, v2, (void *)v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Set_name( const char * v2 )
        { int err = MPI_Type_set_name( (MPI_Datatype) the_real_datatype, (const char *)v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
    static Datatype Create_f90_complex( int v1, int v2 )
        Datatype v3;
        { int err = MPI_Type_create_f90_complex( v1, v2, &(v3.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    virtual Datatype Create_subarray( int v1, const int v2[], const int v3[], const int v4[], const int v5 ) const
        Datatype v7;
        { int err = MPI_Type_create_subarray( v1, v2, (const int *)v3, (const int *)v4, (int)v5, (MPI_Datatype) the_real_datatype, &(v7.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v7;
    virtual void Unpack_external( const char v1[], const void * v2, const Aint v3, Aint & v4, void * v5, int v6 ) const
        { int err = MPI_Unpack_external( v1, (const void *)v2, (MPI_Aint)v3, &v4, v5, v6, (MPI_Datatype) the_real_datatype ) ; if (err) MPIR_Call_world_errhand( err ); };
    static void Free_keyval( int &v1 )
        { int err = MPI_Type_free_keyval( &v1 ) ; if (err) MPIR_Call_world_errhand( err ); };
    static Datatype Create_struct( int v1, const int v2[], const Aint v3[], const Datatype v4[] )
        Datatype v5;
            int i4;
                    delete[] l4;
        return v5;
    static Datatype Create_f90_integer( int v1 )
        Datatype v2;
        { int err = MPI_Type_create_f90_integer( v1, &(v2.the_real_datatype) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2;
    virtual void Pack_external( const char v1[], const void * v2, const int v3, void * v5, Aint v6, Aint & v7 ) const
        { int err = MPI_Pack_external( v1, (const void *)v2, (int)v3, (MPI_Datatype) the_real_datatype, v5, v6, &v7 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Get_extent( Aint & v2, Aint & v3 ) const
        { int err = MPI_Type_get_extent( (MPI_Datatype) the_real_datatype, &v2, &v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Delete_attr( int v2 )
        { int err = MPI_Type_delete_attr( (MPI_Datatype) the_real_datatype, v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Get_name( char * v2, int &v3 ) const
    MPIR_CXX_InitDatatypeNames();
        { int err = MPI_Type_get_name( (MPI_Datatype) the_real_datatype, v2, &v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
    void Unpack( const void *, int, void *, int, int &, const Comm & ) const;
    typedef int Copy_attr_function(const Datatype& oldtype, int type_keyval, void* extra_state, void* attribute_val_in, void* attribute_val_out, bool& flag);
    typedef int Delete_attr_function(Datatype& type, int type_keyval, void* attribute_val, void* extra_state);
    static int Create_keyval( Copy_attr_function *, Delete_attr_function *,
                              void * );
    static int NULL_COPY_FN( const Datatype &oldtype __attribute__((unused)),
        int keyval __attribute__((unused)), void *ex __attribute__((unused)),
        void *attr_in __attribute__((unused)), void *attr_out __attribute__((unused)),
        bool &flag ) { flag = 1; return 0;}
    static int NULL_DELETE_FN( Datatype &type __attribute__((unused)),
        int keyval __attribute__((unused)), void * attr __attribute__((unused)),
        void *ex __attribute__((unused)) ) { return 0; }
    static int DUP_FN( const Datatype &oldtype __attribute__((unused)),
        void *attr_in, void *attr_out, bool &flag ) { flag = 1;
            *(void **)attr_out = attr_in; return 0;}
    typedef void User_function(const void *, void*, int, const Datatype&);
class Info {
    friend class File;
    friend class Win;
    friend class Comm;
  protected:
    MPI_Info the_real_info;
  public:
    inline Info(MPI_Info obj) : the_real_info(obj) {}
    inline Info(void) : the_real_info(((MPI_Info)0x1c000000)) {}
    virtual ~Info() {}
    Info(const Info &obj) : the_real_info(obj.the_real_info){}
    Info& operator=(const Info &obj) {
      the_real_info = obj.the_real_info; return *this; }
    bool operator== (const Info &obj) {
      return (the_real_info == obj.the_real_info); }
    bool operator!= (const Info &obj) {
      return (the_real_info != obj.the_real_info); }
    inline operator MPI_Info*() { return &the_real_info; }
    inline operator MPI_Info() const { return the_real_info; }
    Info& operator=(const MPI_Info& obj) {
      the_real_info = obj; return *this; }
    virtual void Delete( const char * v2 )
        { int err = MPI_Info_delete( (MPI_Info) the_real_info, (const char *)v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Get_nthkey( int v2, char * v3 ) const
        { int err = MPI_Info_get_nthkey( (MPI_Info) the_real_info, v2, v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
        { int err = MPI_Info_free( (MPI_Info *) &the_real_info ) ; if (err) MPIR_Call_world_errhand( err ); };
    static Info Create( void )
        Info v1;
        { int err = MPI_Info_create( &(v1.the_real_info) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v1;
    virtual void Set( const char * v2, const char * v3 )
        { int err = MPI_Info_set( (MPI_Info) the_real_info, (const char *)v2, (const char *)v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
    Info Dup( void ) const
        Info v2;
        { int err = MPI_Info_dup( (MPI_Info) the_real_info, &(v2.the_real_info) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2;
    virtual bool Get_valuelen( const char * v2, int &v3 ) const
        int v4;
        { int err = MPI_Info_get_valuelen( (MPI_Info) the_real_info, (const char *)v2, &v3, &v4 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4!= 0;
    virtual bool Get( const char * v2, int v3, char * v4 ) const
        int v5;
        { int err = MPI_Info_get( (MPI_Info) the_real_info, (const char *)v2, v3, v4, &v5 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v5!= 0;
    virtual int Get_nkeys( void ) const
        int v2;
        { int err = MPI_Info_get_nkeys( (MPI_Info) the_real_info, &v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2;
class Status {
    friend class Comm;
    friend class File;
    friend class Request;
  protected:
    MPI_Status the_real_status;
  public:
    inline Status(MPI_Status obj) : the_real_status(obj) {}
    inline Status(void) : the_real_status() {}
    virtual ~Status() {}
    Status(const Status &obj) : the_real_status(obj.the_real_status){}
    Status& operator=(const Status &obj) {
      the_real_status = obj.the_real_status; return *this; }
    inline operator MPI_Status*() { return &the_real_status; }
    inline operator MPI_Status() const { return the_real_status; }
    Status& operator=(const MPI_Status& obj) {
      the_real_status = obj; return *this; }
    virtual bool Is_cancelled( void ) const
        int v2;
        { int err = MPI_Test_cancelled( (const MPI_Status *) &the_real_status, &v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2!= 0;
    virtual int Get_elements( const Datatype &v2 ) const
        int v3;
        { int err = MPI_Get_elements( (const MPI_Status *) &the_real_status, (MPI_Datatype)(v2.the_real_datatype), &v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    virtual int Get_count( const Datatype &v2 ) const
        int v3;
        { int err = MPI_Get_count( (const MPI_Status *) &the_real_status, (MPI_Datatype)(v2.the_real_datatype), &v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    virtual void Set_cancelled( bool v2 )
        int l2;
         l2 = (v2 == true) ? 1 : 0;
        { int err = MPI_Status_set_cancelled( (MPI_Status *) &the_real_status, l2 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Set_elements( const Datatype &v2, int v3 )
        { int err = MPI_Status_set_elements( (MPI_Status *) &the_real_status, (MPI_Datatype)(v2.the_real_datatype), v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
    int Get_source(void) const { return the_real_status.MPI_SOURCE; }
    int Get_tag(void) const { return the_real_status.MPI_TAG; }
    int Get_error(void) const { return the_real_status.MPI_ERROR; }
    void Set_source(int source) { the_real_status.MPI_SOURCE = source; }
    void Set_tag(int tag) { the_real_status.MPI_TAG = tag; }
    void Set_error(int error) { the_real_status.MPI_ERROR = error; }
class Group {
    friend class Comm;
    friend class Win;
    friend class File;
  protected:
    MPI_Group the_real_group;
  public:
    inline Group(MPI_Group obj) : the_real_group(obj) {}
    inline Group(void) : the_real_group(((MPI_Group)0x08000000)) {}
    virtual ~Group() {}
    Group(const Group &obj) : the_real_group(obj.the_real_group){}
    Group& operator=(const Group &obj) {
      the_real_group = obj.the_real_group; return *this; }
    bool operator== (const Group &obj) {
      return (the_real_group == obj.the_real_group); }
    bool operator!= (const Group &obj) {
      return (the_real_group != obj.the_real_group); }
    inline operator MPI_Group*() { return &the_real_group; }
    inline operator MPI_Group() const { return the_real_group; }
    Group& operator=(const MPI_Group& obj) {
      the_real_group = obj; return *this; }
    virtual Group Excl( int v2, const int v3[] ) const
        Group v4;
        { int err = MPI_Group_excl( (MPI_Group) the_real_group, v2, (const int *)v3, &(v4.the_real_group) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4;
    virtual int Get_rank( void ) const
        int v2;
        { int err = MPI_Group_rank( (MPI_Group) the_real_group, &v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2;
        { int err = MPI_Group_free( (MPI_Group *) &the_real_group ) ; if (err) MPIR_Call_world_errhand( err ); };
    static Group Union( const Group &v1, const Group &v2 )
        Group v3;
        { int err = MPI_Group_union( (MPI_Group)(v1.the_real_group), (MPI_Group)(v2.the_real_group), &(v3.the_real_group) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    static Group Intersect( const Group &v1, const Group &v2 )
        Group v3;
        { int err = MPI_Group_intersection( (MPI_Group)(v1.the_real_group), (MPI_Group)(v2.the_real_group), &(v3.the_real_group) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    virtual Group Range_excl( int v2, const int v3[][3] ) const
        Group v4;
        { int err = MPI_Group_range_excl( (MPI_Group) the_real_group, v2, (int (*)[3])v3, &(v4.the_real_group) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4;
    virtual Group Range_incl( int v2, const int v3[][3] ) const
        Group v4;
        { int err = MPI_Group_range_incl( (MPI_Group) the_real_group, v2, (int (*)[3])v3, &(v4.the_real_group) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4;
    static Group Difference( const Group &v1, const Group &v2 )
        Group v3;
        { int err = MPI_Group_difference( (MPI_Group)(v1.the_real_group), (MPI_Group)(v2.the_real_group), &(v3.the_real_group) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
    static void Translate_ranks( const Group &v1, int v2, const int v3[], const Group &v4, int v5[] )
        { int err = MPI_Group_translate_ranks( (MPI_Group)(v1.the_real_group), v2, (const int *)v3, (MPI_Group)(v4.the_real_group), v5 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual Group Incl( int v2, const int v3[] ) const
        Group v4;
        { int err = MPI_Group_incl( (MPI_Group) the_real_group, v2, (const int *)v3, &(v4.the_real_group) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v4;
        int v2;
        { int err = MPI_Group_size( (MPI_Group) the_real_group, &v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2;
    static int Compare( const Group &v1, const Group &v2 )
        int v3;
        { int err = MPI_Group_compare( (MPI_Group)(v1.the_real_group), (MPI_Group)(v2.the_real_group), &v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
class Op {
    friend class Win;
    friend class Comm;
  protected:
    MPI_Op the_real_op;
  public:
    inline Op(MPI_Op obj) : the_real_op(obj) {}
    inline Op(void) : the_real_op(((MPI_Op)0x18000000)) {}
    virtual ~Op() {}
    Op(const Op &obj) : the_real_op(obj.the_real_op){}
    Op& operator=(const Op &obj) {
      the_real_op = obj.the_real_op; return *this; }
    bool operator== (const Op &obj) {
      return (the_real_op == obj.the_real_op); }
    bool operator!= (const Op &obj) {
      return (the_real_op != obj.the_real_op); }
    inline operator MPI_Op*() { return &the_real_op; }
    inline operator MPI_Op() const { return the_real_op; }
    Op& operator=(const MPI_Op& obj) {
      the_real_op = obj; return *this; }
        { int err = MPI_Op_free( (MPI_Op *) &the_real_op ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual bool Is_commutative( void ) const
        int v2;
        { int err = MPI_Op_commutative( (MPI_Op) the_real_op, &v2 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2!= 0;
    virtual void Reduce_local( const void * v1, void * v2, int v3, const Datatype &v4 ) const
        { int err = MPI_Reduce_local( (const void *)v1, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Op) the_real_op ) ; if (err) MPIR_Call_world_errhand( err ); };
    void Init( User_function *, bool );
class Errhandler {
    friend class Comm;
    friend class File;
    friend class Win;
  protected:
    MPI_Errhandler the_real_errhandler;
  public:
    inline Errhandler(MPI_Errhandler obj) : the_real_errhandler(obj) {}
    inline Errhandler(void) : the_real_errhandler(((MPI_Errhandler)0x14000000)) {}
    virtual ~Errhandler() {}
    Errhandler(const Errhandler &obj) : the_real_errhandler(obj.the_real_errhandler){}
    Errhandler& operator=(const Errhandler &obj) {
      the_real_errhandler = obj.the_real_errhandler; return *this; }
    bool operator== (const Errhandler &obj) {
      return (the_real_errhandler == obj.the_real_errhandler); }
    bool operator!= (const Errhandler &obj) {
      return (the_real_errhandler != obj.the_real_errhandler); }
    inline operator MPI_Errhandler*() { return &the_real_errhandler; }
    inline operator MPI_Errhandler() const { return the_real_errhandler; }
    Errhandler& operator=(const MPI_Errhandler& obj) {
      the_real_errhandler = obj; return *this; }
        { int err = MPI_Errhandler_free( (MPI_Errhandler *) &the_real_errhandler ) ; if (err) MPIR_Call_world_errhand( err ); };
class Request {
    friend class Comm;
    friend class File;
    friend class Grequest;
  protected:
    MPI_Request the_real_request;
  public:
    inline Request(MPI_Request obj) : the_real_request(obj) {}
    inline Request(void) : the_real_request(((MPI_Request)0x2c000000)) {}
    virtual ~Request() {}
    Request(const Request &obj) : the_real_request(obj.the_real_request){}
    Request& operator=(const Request &obj) {
      the_real_request = obj.the_real_request; return *this; }
    bool operator== (const Request &obj) {
      return (the_real_request == obj.the_real_request); }
    bool operator!= (const Request &obj) {
      return (the_real_request != obj.the_real_request); }
    inline operator MPI_Request*() { return &the_real_request; }
    inline operator MPI_Request() const { return the_real_request; }
    Request& operator=(const MPI_Request& obj) {
      the_real_request = obj; return *this; }
    static bool Testany( int v1, Request v2[], int &v3, Status & v5 )
        int v4;
        MPI_Request *l2 = new MPI_Request[v1];
            int i2;
            for (i2=0;i2<v1;i2++) {
                l2[i2] = v2[i2].the_real_request;
        { int err = MPI_Testany( v1, l2, &v3, &v4, (MPI_Status *)&(v5.the_real_status ) ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
                v2[i2].the_real_request = l2[i2];
            delete[] l2;
        return v4!= 0;
    static bool Testany( int v1, Request v2[], int &v3 )
        int v4;
            int i2;
        { int err = MPI_Testany( v1, l2, &v3, &v4, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
        return v4!= 0;
    static int Waitsome( int v1, Request v2[], int v4[], Status v5[] )
        int v3;
        MPI_Status *l5 = new MPI_Status[v1];
            int i2;
        { int err = MPI_Waitsome( v1, l2, &v3, v4, l5 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
            int i5;
            for (i5=0;i5<v1;i5++) {
                v5[i5].the_real_status = l5[i5];
            delete[] l5;
        return v3;
    static int Waitsome( int v1, Request v2[], int v4[] )
        int v3;
            int i2;
        { int err = MPI_Waitsome( v1, l2, &v3, v4, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
        return v3;
        { int err = MPI_Request_free( (MPI_Request *) &the_real_request ) ; if (err) MPIR_Call_world_errhand( err ); };
    static bool Testall( int v1, Request v2[], Status v4[] )
        int v3;
        MPI_Status *l4 = new MPI_Status[v1];
            int i2;
        { int err = MPI_Testall( v1, l2, &v3, l4 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
            int i4;
                v4[i4].the_real_status = l4[i4];
            delete[] l4;
        return v3!= 0;
    static bool Testall( int v1, Request v2[] )
        int v3;
            int i2;
        { int err = MPI_Testall( v1, l2, &v3, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
        return v3!= 0;
    virtual void Wait( Status & v2 )
        { int err = MPI_Wait( (MPI_Request *) &the_real_request, (MPI_Status *)&(v2.the_real_status ) ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Wait( void )
        { int err = MPI_Wait( (MPI_Request *) &the_real_request, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
    static int Testsome( int v1, Request v2[], int v4[], Status v5[] )
        int v3;
            int i2;
        { int err = MPI_Testsome( v1, l2, &v3, v4, l5 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
            int i5;
            delete[] l5;
        return v3;
    static int Testsome( int v1, Request v2[], int v4[] )
        int v3;
            int i2;
        { int err = MPI_Testsome( v1, l2, &v3, v4, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
        return v3;
    static void Waitall( int v1, Request v2[], Status v3[] )
        MPI_Status *l3 = new MPI_Status[v1];
            int i2;
        { int err = MPI_Waitall( v1, l2, l3 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
            int i3;
            for (i3=0;i3<v1;i3++) {
                v3[i3].the_real_status = l3[i3];
            delete[] l3;
    static void Waitall( int v1, Request v2[] )
            int i2;
        { int err = MPI_Waitall( v1, l2, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
    static int Waitany( int v1, Request v2[], Status & v4 )
        int v3;
            int i2;
        { int err = MPI_Waitany( v1, l2, &v3, (MPI_Status *)&(v4.the_real_status ) ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
        return v3;
    static int Waitany( int v1, Request v2[] )
        int v3;
            int i2;
        { int err = MPI_Waitany( v1, l2, &v3, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
        return v3;
    virtual bool Test( Status & v3 )
        int v2;
        { int err = MPI_Test( (MPI_Request *) &the_real_request, &v2, (MPI_Status *)&(v3.the_real_status ) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2!= 0;
    virtual bool Test( void )
        int v2;
        { int err = MPI_Test( (MPI_Request *) &the_real_request, &v2, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2!= 0;
    virtual void Cancel( void ) const
        { int err = MPI_Cancel( (MPI_Request *) &the_real_request ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual bool Get_status( Status & v3 ) const
        int v2;
        { int err = MPI_Request_get_status( (MPI_Request) the_real_request, &v2, (MPI_Status *)&(v3.the_real_status ) ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2!= 0;
    virtual bool Get_status( void ) const
        int v2;
        { int err = MPI_Request_get_status( (MPI_Request) the_real_request, &v2, (MPI_Status *)1 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v2!= 0;
class Prequest : public Request {
  public:
    inline Prequest(MPI_Request obj) : Request(obj) {}
    inline Prequest(void) : Request() {}
    virtual ~Prequest() {}
    Prequest(const Prequest &obj) : Request(obj) {}
    Prequest& operator=(const Prequest &obj) {
    Prequest& operator=(const MPI_Request& obj) {
    virtual void Start( void )
        { int err = MPI_Start( (MPI_Request *) &the_real_request ) ; if (err) MPIR_Call_world_errhand( err ); };
    static void Startall( int v1, Prequest v2[] )
            int i2;
        { int err = MPI_Startall( v1, l2 ) ; if (err) MPIR_Call_world_errhand( err ); };
            int i2;
            delete[] l2;
class Comm {
    friend class Cartcomm;
    friend class Graphcomm;
    friend class Nullcomm;
    friend class Datatype;
    friend class Win;
    friend class File;
  protected:
    MPI_Comm the_real_comm;
  public:
    inline Comm(MPI_Comm obj) : the_real_comm(obj) {}
    inline Comm(void) : the_real_comm(((MPI_Comm)0x04000000)) {}
    virtual ~Comm() {}
    Comm(const Comm &obj) : the_real_comm(obj.the_real_comm){}
    Comm& operator=(const Comm &obj) {
      the_real_comm = obj.the_real_comm; return *this; }
    bool operator== (const Comm &obj) {
      return (the_real_comm == obj.the_real_comm); }
    bool operator!= (const Comm &obj) {
      return (the_real_comm != obj.the_real_comm); }
    inline operator MPI_Comm*() { return &the_real_comm; }
    inline operator MPI_Comm() const { return the_real_comm; }
    Comm& operator=(const MPI_Comm& obj) {
      the_real_comm = obj; return *this; }
    virtual Group Get_group( void ) const
        Group v2;
        { int err = MPI_Comm_group( (MPI_Comm) the_real_comm, &(v2.the_real_group) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
        int v2;
        { int err = MPI_Comm_rank( (MPI_Comm) the_real_comm, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual Prequest Bsend_init( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Prequest v7;
        { int err = MPI_Bsend_init( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual Prequest Ssend_init( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Prequest v7;
        { int err = MPI_Ssend_init( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual bool Is_inter( void ) const
        int v2;
        { int err = MPI_Comm_test_inter( (MPI_Comm) the_real_comm, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2!= 0;
    virtual Prequest Rsend_init( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Prequest v7;
        { int err = MPI_Rsend_init( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual Request Ibsend( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Request v7;
        { int err = MPI_Ibsend( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual void Abort( int v2 ) const
        { int err = MPI_Abort( (MPI_Comm) the_real_comm, v2 ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Comm_free( (MPI_Comm *) &the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Prequest Send_init( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Prequest v7;
        { int err = MPI_Send_init( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual void Recv( void * v1, int v2, const Datatype &v3, int v4, int v5, Status & v7 ) const
        { int err = MPI_Recv( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, (MPI_Status *)&(v7.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Recv( void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        { int err = MPI_Recv( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Sendrecv( const void * v1, int v2, const Datatype &v3, int v4, int v5, void * v6, int v7, const Datatype &v8, int v9, int v10, Status & v12 ) const
        { int err = MPI_Sendrecv( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, v6, v7, (MPI_Datatype)(v8.the_real_datatype), v9, v10, (MPI_Comm) the_real_comm, (MPI_Status *)&(v12.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Sendrecv( const void * v1, int v2, const Datatype &v3, int v4, int v5, void * v6, int v7, const Datatype &v8, int v9, int v10 ) const
        { int err = MPI_Sendrecv( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, v6, v7, (MPI_Datatype)(v8.the_real_datatype), v9, v10, (MPI_Comm) the_real_comm, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Sendrecv_replace( void * v1, int v2, const Datatype &v3, int v4, int v5, int v6, int v7, Status & v9 ) const
        { int err = MPI_Sendrecv_replace( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, v6, v7, (MPI_Comm) the_real_comm, (MPI_Status *)&(v9.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Sendrecv_replace( void * v1, int v2, const Datatype &v3, int v4, int v5, int v6, int v7 ) const
        { int err = MPI_Sendrecv_replace( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, v6, v7, (MPI_Comm) the_real_comm, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual int Get_topology( void ) const
        int v2;
        { int err = MPI_Topo_test( (MPI_Comm) the_real_comm, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual Request Isend( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Request v7;
        { int err = MPI_Isend( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual void Probe( int v1, int v2, Status & v4 ) const
        { int err = MPI_Probe( v1, v2, (MPI_Comm) the_real_comm, (MPI_Status *)&(v4.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Probe( int v1, int v2 ) const
        { int err = MPI_Probe( v1, v2, (MPI_Comm) the_real_comm, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    static int Compare( const Comm &v1, const Comm &v2 )
        int v3;
        { int err = MPI_Comm_compare( (MPI_Comm)(v1.the_real_comm), (MPI_Comm)(v2.the_real_comm), &v3 ) ; if (err) MPIR_Call_world_errhand( err ); };
        return v3;
        int v2;
        { int err = MPI_Comm_size( (MPI_Comm) the_real_comm, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual Request Issend( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Request v7;
        { int err = MPI_Issend( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual void Set_errhandler( const Errhandler &v2 )
        { int err = MPI_Comm_set_errhandler( (MPI_Comm) the_real_comm, (MPI_Errhandler)(v2.the_real_errhandler) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Send( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        { int err = MPI_Send( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Request Irsend( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Request v7;
        { int err = MPI_Irsend( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual void Ssend( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        { int err = MPI_Ssend( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Prequest Recv_init( void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Prequest v7;
        { int err = MPI_Recv_init( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual bool Iprobe( int v1, int v2, Status & v5 ) const
        int v4;
        { int err = MPI_Iprobe( v1, v2, (MPI_Comm) the_real_comm, &v4, (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
        return v4!= 0;
    virtual bool Iprobe( int v1, int v2 ) const
        int v4;
        { int err = MPI_Iprobe( v1, v2, (MPI_Comm) the_real_comm, &v4, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
        return v4!= 0;
    virtual void Bsend( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        { int err = MPI_Bsend( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Request Irecv( void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        Request v7;
        { int err = MPI_Irecv( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm, &(v7.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v7;
    virtual Errhandler Get_errhandler( void ) const
        Errhandler v2;
        { int err = MPI_Comm_get_errhandler( (MPI_Comm) the_real_comm, &(v2.the_real_errhandler) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual void Rsend( const void * v1, int v2, const Datatype &v3, int v4, int v5 ) const
        { int err = MPI_Rsend( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Gatherv( const void * v1, int v2, const Datatype &v3, void * v4, const int * v5, const int * v6, const Datatype &v7, int v8 ) const
        { int err = MPI_Gatherv( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, (const int *)v5, (const int *)v6, (MPI_Datatype)(v7.the_real_datatype), v8, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Disconnect( void )
        { int err = MPI_Comm_disconnect( (MPI_Comm *) &the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Allreduce( const void * v1, void * v2, int v3, const Datatype &v4, const Op &v5 ) const
        { int err = MPI_Allreduce( (const void *)v1, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Op)(v5.the_real_op), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Alltoallw( const void * v1, const int v2[], const int v3[], const Datatype v4[], void * v5, const int v6[], const int v7[], const Datatype v8[] ) const
        MPI_Datatype *l4 = new MPI_Datatype[Get_size()];
        MPI_Datatype *l8 = new MPI_Datatype[Get_size()];
            int i4;
            for (i4=0;i4<Get_size();i4++) {
            int i8;
            for (i8=0;i8<Get_size();i8++) {
                l8[i8] = v8[i8].the_real_datatype;
        { int err = MPI_Alltoallw( (const void *)v1, (const int *)v2, (const int *)v3, l4, v5, (const int *)v6, (const int *)v7, l8, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
                    delete[] l4;
                    delete[] l8;
    static Intercomm Join( const int v1 ) ;
    virtual void Alltoall( const void * v1, int v2, const Datatype &v3, void * v4, int v5, const Datatype &v6 ) const
        { int err = MPI_Alltoall( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Datatype)(v6.the_real_datatype), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
        int v4;
        { int err = MPI_Comm_get_attr( (MPI_Comm) the_real_comm, v2, v3, &v4 ); if (err) { (this)->Call_errhandler( err ); }};
        return v4!= 0;
    virtual void Barrier( void ) const
        { int err = MPI_Barrier( (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Bcast( void * v1, int v2, const Datatype &v3, int v4 ) const
        { int err = MPI_Bcast( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Comm_set_attr( (MPI_Comm) the_real_comm, v2, (void *)v3 ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Comm_set_name( (MPI_Comm) the_real_comm, (const char *)v2 ); if (err) { (this)->Call_errhandler( err ); }};
    static Intercomm Get_parent( void ) ;
    virtual void Alltoallv( const void * v1, const int * v2, const int * v3, const Datatype &v4, void * v5, const int * v6, const int * v7, const Datatype &v8 ) const
        { int err = MPI_Alltoallv( (const void *)v1, (const int *)v2, (const int *)v3, (MPI_Datatype)(v4.the_real_datatype), v5, (const int *)v6, (const int *)v7, (MPI_Datatype)(v8.the_real_datatype), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Reduce_scatter( const void * v1, void * v2, const int v3[], const Datatype &v4, const Op &v5 ) const
        { int err = MPI_Reduce_scatter( (const void *)v1, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Op)(v5.the_real_op), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Scatter( const void * v1, int v2, const Datatype &v3, void * v4, int v5, const Datatype &v6, int v7 ) const
        { int err = MPI_Scatter( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Datatype)(v6.the_real_datatype), v7, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Gather( const void * v1, int v2, const Datatype &v3, void * v4, int v5, const Datatype &v6, int v7 ) const
        { int err = MPI_Gather( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Datatype)(v6.the_real_datatype), v7, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Comm_free_keyval( &v1 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Reduce( const void * v1, void * v2, int v3, const Datatype &v4, const Op &v5, int v6 ) const
        { int err = MPI_Reduce( (const void *)v1, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Op)(v5.the_real_op), v6, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Allgather( const void * v1, int v2, const Datatype &v3, void * v4, int v5, const Datatype &v6 ) const
        { int err = MPI_Allgather( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, (MPI_Datatype)(v6.the_real_datatype), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Comm_delete_attr( (MPI_Comm) the_real_comm, v2 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Scatterv( const void * v1, const int * v2, const int * v3, const Datatype &v4, void * v5, int v6, const Datatype &v7, int v8 ) const
        { int err = MPI_Scatterv( (const void *)v1, (const int *)v2, (const int *)v3, (MPI_Datatype)(v4.the_real_datatype), v5, v6, (MPI_Datatype)(v7.the_real_datatype), v8, (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Comm_get_name( (MPI_Comm) the_real_comm, v2, &v3 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Allgatherv( const void * v1, int v2, const Datatype &v3, void * v4, const int * v5, const int * v6, const Datatype &v7 ) const
        { int err = MPI_Allgatherv( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, (const int *)v5, (const int *)v6, (MPI_Datatype)(v7.the_real_datatype), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Comm &Clone(void) const = 0;
    typedef int Copy_attr_function(const Comm& oldcomm, int comm_keyval, void* extra_state, void* attribute_val_in, void* attribute_val_out, bool& flag);
    typedef int Delete_attr_function(Comm& comm, int comm_keyval, void* attribute_val, void* extra_state);
    typedef void Errhandler_function(Comm &, int *, ... );
    typedef Errhandler_function Errhandler_fn;
                              void * );
    static int NULL_COPY_FN( const Comm &oldcomm __attribute__((unused)),
    bool &flag ) { flag = 0; return 0;}
    static int NULL_DELETE_FN( Comm &comm __attribute__((unused)),
    static int DUP_FN( const Comm &oldcomm __attribute__((unused)),
    static Errhandler Create_errhandler( Errhandler_function * );
    virtual void Call_errhandler( int v2 ) const;
    virtual void Reduce_scatter_block( const void * v1, void * v2, int v3, const Datatype &v4, const Op &v5 ) const
        { int err = MPI_Reduce_scatter_block( (const void *)v1, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Op)(v5.the_real_op), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
class Nullcomm : public Comm {
  public:
    inline Nullcomm(MPI_Comm obj) : Comm(obj) {}
    inline Nullcomm(void) : Comm() {}
    virtual ~Nullcomm() {}
    Nullcomm(const Nullcomm &obj) : Comm(obj) {}
    Nullcomm& operator=(const Nullcomm &obj) {
    Nullcomm& operator=(const MPI_Comm& obj) {
# 1525 "/usr/local/include/mpicxx.h" 3
    virtual Nullcomm & Clone(void) const {
        Nullcomm *clone = new Nullcomm();
        return *clone;
class Intercomm : public Comm {
  public:
    inline Intercomm(MPI_Comm obj) : Comm(obj) {}
    inline Intercomm(void) : Comm() {}
    virtual ~Intercomm() {}
    Intercomm(const Intercomm &obj) : Comm(obj) {}
    Intercomm& operator=(const Intercomm &obj) {
    Intercomm& operator=(const MPI_Comm& obj) {
    virtual Intracomm Merge( bool v2 ) const;
    virtual Group Get_remote_group( void ) const
        Group v2;
        { int err = MPI_Comm_remote_group( (MPI_Comm) the_real_comm, &(v2.the_real_group) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual int Get_remote_size( void ) const
        int v2;
        { int err = MPI_Comm_remote_size( (MPI_Comm) the_real_comm, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    Intercomm Dup( void ) const
        Intercomm v2;
        { int err = MPI_Comm_dup( (MPI_Comm) the_real_comm, &(v2.the_real_comm) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual Intercomm Split( int v2, int v3 ) const
        Intercomm v4;
        { int err = MPI_Comm_split( (MPI_Comm) the_real_comm, v2, v3, &(v4.the_real_comm) ); if (err) { (this)->Call_errhandler( err ); }};
        return v4;
# 1591 "/usr/local/include/mpicxx.h" 3
    virtual Intercomm & Clone(void) const {
        MPI_Comm ncomm;
        MPI_Comm_dup( (MPI_Comm)the_real_comm, &ncomm);
        Intercomm *clone = new Intercomm(ncomm);
        return *clone;
class Intracomm : public Comm {
  public:
    inline Intracomm(MPI_Comm obj) : Comm(obj) {}
    inline Intracomm(void) : Comm() {}
    virtual ~Intracomm() {}
    Intracomm(const Intracomm &obj) : Comm(obj) {}
    Intracomm& operator=(const Intracomm &obj) {
    Intracomm& operator=(const MPI_Comm& obj) {
    virtual Intercomm Create_intercomm( int v2, const Comm &v3, int v4, int v5 ) const
        Intercomm v6;
        { int err = MPI_Intercomm_create( (MPI_Comm) the_real_comm, v2, (MPI_Comm)(v3.the_real_comm), v4, v5, &(v6.the_real_comm) ); if (err) { (this)->Call_errhandler( err ); }};
        return v6;
    virtual Intracomm Split( int v2, int v3 ) const
        Intracomm v4;
        return v4;
    virtual Graphcomm Create_graph( int v2, const int v3[], const int v4[], bool v5 ) const;
    virtual Cartcomm Create_cart( int v2, const int v3[], const bool v4[], bool v5 ) const;
    virtual Intracomm Create( const Group &v2 ) const
        Intracomm v3;
        { int err = MPI_Comm_create( (MPI_Comm) the_real_comm, (MPI_Group)(v2.the_real_group), &(v3.the_real_comm) ); if (err) { (this)->Call_errhandler( err ); }};
        return v3;
    Intracomm Dup( void ) const
        Intracomm v2;
        return v2;
    virtual void Scan( const void * v1, void * v2, int v3, const Datatype &v4, const Op &v5 ) const
        { int err = MPI_Scan( (const void *)v1, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Op)(v5.the_real_op), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Exscan( const void * v1, void * v2, int v3, const Datatype &v4, const Op &v5 ) const
        { int err = MPI_Exscan( (const void *)v1, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Op)(v5.the_real_op), (MPI_Comm) the_real_comm ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Intercomm Accept( const char * v1, const Info &v2, int v3 ) const
        Intercomm v5;
        { int err = MPI_Comm_accept( (const char *)v1, (MPI_Info)(v2.the_real_info), v3, (MPI_Comm) the_real_comm, &(v5.the_real_comm) ); if (err) { (this)->Call_errhandler( err ); }};
        return v5;
    virtual Intercomm Connect( const char * v1, const Info &v2, int v3 ) const
        Intercomm v5;
        { int err = MPI_Comm_connect( (const char *)v1, (MPI_Info)(v2.the_real_info), v3, (MPI_Comm) the_real_comm, &(v5.the_real_comm) ); if (err) { (this)->Call_errhandler( err ); }};
        return v5;
# 1682 "/usr/local/include/mpicxx.h" 3
    virtual Intracomm & Clone(void) const {
        MPI_Comm ncomm;
        Intracomm *clone = new Intracomm(ncomm);
        return *clone;
Intercomm Spawn(const char* command, const char* argv[], int maxprocs, const MPI::Info& info, int root) const {
    Intercomm ic;
    { int err = MPI_Comm_spawn( (char *)command, (char **)argv, maxprocs, info.the_real_info, root, the_real_comm, &(ic.the_real_comm), (int *)0 ); if (err) { (this)->Call_errhandler( err ); }}
    return ic;
Intercomm Spawn(const char* command, const char* argv[], int maxprocs, const MPI::Info& info, int root, int array_of_errcodes[]) const {
    Intercomm ic;
    { int err = MPI_Comm_spawn( (char *)command, (char **)argv, maxprocs, info.the_real_info, root, the_real_comm, &(ic.the_real_comm), array_of_errcodes ); if (err) { (this)->Call_errhandler( err ); }}
    return ic;
Intercomm Spawn_multiple(int count, const char* array_of_commands[], const char** array_of_argv[], const int array_of_maxprocs[], const MPI::Info array_of_info[], int root) {
    Intercomm ic;
    MPI_Info *li = new MPI_Info [count];
    int i;
    for (i=0; i<count; i++) {
        li[i] = array_of_info[i].the_real_info;
    { int err = MPI_Comm_spawn_multiple( count, (char **)array_of_commands, (char ***)array_of_argv, (int *)array_of_maxprocs, li, root, the_real_comm, &(ic.the_real_comm), (int *)0 ); if (err) { (this)->Call_errhandler( err ); }}
    delete [] li;
    return ic;
Intercomm Spawn_multiple(int count, const char* array_of_commands[], const char** array_of_argv[], const int array_of_maxprocs[], const MPI::Info array_of_info[], int root, int array_of_errcodes[]) {
    Intercomm ic;
    int i;
    { int err = MPI_Comm_spawn_multiple( count, (char **)array_of_commands, (char ***)array_of_argv, (int *)array_of_maxprocs, li, root, the_real_comm, &(ic.the_real_comm), array_of_errcodes ); if (err) { (this)->Call_errhandler( err ); }}
    delete [] li;
    return ic;
class Grequest : public Request {
  public:
    inline Grequest(MPI_Request obj) : Request(obj) {}
    inline Grequest(void) : Request() {}
    virtual ~Grequest() {}
    Grequest(const Grequest &obj) : Request(obj) {}
    Grequest& operator=(const Grequest &obj) {
    bool operator== (const Grequest &obj) {
    bool operator!= (const Grequest &obj) {
    Grequest& operator=(const MPI_Request& obj) {
    virtual void Complete( void )
        { int err = MPI_Grequest_complete( (MPI_Request) the_real_request ) ; if (err) MPIR_Call_world_errhand( err ); };
    typedef int Query_function( void *, Status & );
    typedef int Free_function( void * );
    typedef int Cancel_function( void *, bool );
    Grequest Start( Query_function *query_fn,
                    Free_function *free_fn,
                    Cancel_function *cancel_fn,
                    void *extra_state );
class Win {
  protected:
    MPI_Win the_real_win;
  public:
    inline Win(MPI_Win obj) : the_real_win(obj) {}
    inline Win(void) : the_real_win(((MPI_Win)0x20000000)) {}
    virtual ~Win() {}
    Win(const Win &obj) : the_real_win(obj.the_real_win){}
    Win& operator=(const Win &obj) {
      the_real_win = obj.the_real_win; return *this; }
    bool operator== (const Win &obj) {
      return (the_real_win == obj.the_real_win); }
    bool operator!= (const Win &obj) {
      return (the_real_win != obj.the_real_win); }
    inline operator MPI_Win*() { return &the_real_win; }
    inline operator MPI_Win() const { return the_real_win; }
    Win& operator=(const MPI_Win& obj) {
      the_real_win = obj; return *this; }
        Group v2;
        { int err = MPI_Win_get_group( (MPI_Win) the_real_win, &(v2.the_real_group) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual void Fence( int v1 ) const
        { int err = MPI_Win_fence( v1, (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Start( const Group &v1, int v2 ) const
        { int err = MPI_Win_start( (MPI_Group)(v1.the_real_group), v2, (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Win_free( (MPI_Win *) &the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Put( const void * v1, int v2, const Datatype &v3, int v4, Aint v5, int v6, const Datatype &v7 ) const
        { int err = MPI_Put( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, v6, (MPI_Datatype)(v7.the_real_datatype), (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Wait( void ) const
        { int err = MPI_Win_wait( (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
    virtual bool Test( void ) const
        int v2;
        { int err = MPI_Win_test( (MPI_Win) the_real_win, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2!= 0;
    virtual void Get( void * v1, int v2, const Datatype &v3, int v4, Aint v5, int v6, const Datatype &v7 ) const
        { int err = MPI_Get( v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, v6, (MPI_Datatype)(v7.the_real_datatype), (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
        int v4;
        { int err = MPI_Win_get_attr( (MPI_Win) the_real_win, v2, v3, &v4 ); if (err) { (this)->Call_errhandler( err ); }};
        return v4!= 0;
        { int err = MPI_Win_set_attr( (MPI_Win) the_real_win, v2, (void *)v3 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Complete( void ) const
        { int err = MPI_Win_complete( (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Win_set_errhandler( (MPI_Win) the_real_win, (MPI_Errhandler)(v2.the_real_errhandler) ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Win_set_name( (MPI_Win) the_real_win, (const char *)v2 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Accumulate( const void * v1, int v2, const Datatype &v3, int v4, Aint v5, int v6, const Datatype &v7, const Op &v8 ) const
        { int err = MPI_Accumulate( (const void *)v1, v2, (MPI_Datatype)(v3.the_real_datatype), v4, v5, v6, (MPI_Datatype)(v7.the_real_datatype), (MPI_Op)(v8.the_real_op), (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
    static Win Create( const void * v1, Aint v2, int v3, const Info &v4, const Intracomm &v5 )
        Win v6;
        { int err = MPI_Win_create( (void *)v1, v2, v3, (MPI_Info)(v4.the_real_info), (MPI_Comm)(v5.the_real_comm), &(v6.the_real_win) ); if (err) { (v5).Call_errhandler( err ); }};
        return v6;
        { int err = MPI_Win_free_keyval( &v1 ) ; if (err) MPIR_Call_world_errhand( err ); };
    virtual void Post( const Group &v1, int v2 ) const
        { int err = MPI_Win_post( (MPI_Group)(v1.the_real_group), v2, (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Unlock( int v1 ) const
        { int err = MPI_Win_unlock( v1, (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
        { int err = MPI_Win_delete_attr( (MPI_Win) the_real_win, v2 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Lock( int v1, int v2, int v3 ) const
        { int err = MPI_Win_lock( v1, v2, v3, (MPI_Win) the_real_win ); if (err) { (this)->Call_errhandler( err ); }};
        Errhandler v2;
        { int err = MPI_Win_get_errhandler( (MPI_Win) the_real_win, &(v2.the_real_errhandler) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
        { int err = MPI_Win_get_name( (MPI_Win) the_real_win, v2, &v3 ); if (err) { (this)->Call_errhandler( err ); }};
    typedef void Errhandler_function(Win &, int *, ... );
    typedef int Copy_attr_function(const Win& oldwin, int win_keyval, void* extra_state, void* attribute_val_in, void* attribute_val_out, bool& flag);
    typedef int Delete_attr_function(Win& win, int win_keyval, void* attribute_val, void* extra_state);
                              void * );
    static int NULL_COPY_FN( const Win &oldwin __attribute__((unused)),
    static int NULL_DELETE_FN( Win &win __attribute__((unused)),
    static int DUP_FN( const Win &oldwin __attribute__((unused)),
class File {
  protected:
    MPI_File the_real_file;
  public:
    inline File(MPI_File obj) : the_real_file(obj) {}
    inline File(void) : the_real_file(((MPI_File)0)) {}
    virtual ~File() {}
    File(const File &obj) : the_real_file(obj.the_real_file){}
    File& operator=(const File &obj) {
      the_real_file = obj.the_real_file; return *this; }
    bool operator== (const File &obj) {
      return (the_real_file == obj.the_real_file); }
    bool operator!= (const File &obj) {
      return (the_real_file != obj.the_real_file); }
    inline operator MPI_File*() { return &the_real_file; }
    inline operator MPI_File() const { return the_real_file; }
    File& operator=(const MPI_File& obj) {
      the_real_file = obj; return *this; }
    virtual Aint Get_type_extent( const Datatype &v2 ) const
        MPI_Aint v3;
        { int err = MPI_File_get_type_extent( (MPI_File) the_real_file, (MPI_Datatype)(v2.the_real_datatype), &v3 ); if (err) { (this)->Call_errhandler( err ); }};
        return v3;
    virtual void Read_ordered_end( void * v2, Status & v3 )
        { int err = MPI_File_read_ordered_end( (MPI_File) the_real_file, v2, (MPI_Status *)&(v3.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_ordered_end( void * v2 )
        { int err = MPI_File_read_ordered_end( (MPI_File) the_real_file, v2, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Seek_shared( Offset v2, int v3 )
        { int err = MPI_File_seek_shared( (MPI_File) the_real_file, v2, v3 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_ordered( void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_read_ordered( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_ordered( void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_read_ordered( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Request Iread_shared( void * v2, int v3, const Datatype &v4 )
        Request v5;
        { int err = MPI_File_iread_shared( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Request *)&(v5.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v5;
    virtual Info Get_info( void ) const
        Info v2;
        { int err = MPI_File_get_info( (MPI_File) the_real_file, &(v2.the_real_info) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual void Write_ordered_begin( const void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_write_ordered_begin( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Set_info( const Info &v2 )
        { int err = MPI_File_set_info( (MPI_File) the_real_file, (MPI_Info)(v2.the_real_info) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_ordered( const void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_write_ordered( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_ordered( const void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_write_ordered( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Sync( void )
        { int err = MPI_File_sync( (MPI_File) the_real_file ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read( void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_read( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read( void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_read( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_all( const void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_write_all( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_all( const void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_write_all( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Offset Get_size( void ) const
        MPI_Offset v2;
        { int err = MPI_File_get_size( (MPI_File) the_real_file, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual void Write_all_end( const void * v2, Status & v3 )
        { int err = MPI_File_write_all_end( (MPI_File) the_real_file, (const void *)v2, (MPI_Status *)&(v3.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_all_end( const void * v2 )
        { int err = MPI_File_write_all_end( (MPI_File) the_real_file, (const void *)v2, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    static void Delete( const char * v1, const Info &v2 )
        { int err = MPI_File_delete( (const char *)v1, (MPI_Info)(v2.the_real_info) ); if (err) { (FILE_NULL).Call_errhandler( err ); }};
    virtual void Read_ordered_begin( void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_read_ordered_begin( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Request Iread_at( Offset v2, void * v3, int v4, const Datatype &v5 )
        Request v6;
        { int err = MPI_File_iread_at( (MPI_File) the_real_file, v2, v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Request *)&(v6.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v6;
    virtual void Write_at_all_end( const void * v2, Status & v3 )
        { int err = MPI_File_write_at_all_end( (MPI_File) the_real_file, (const void *)v2, (MPI_Status *)&(v3.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_at_all_end( const void * v2 )
        { int err = MPI_File_write_at_all_end( (MPI_File) the_real_file, (const void *)v2, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Offset Get_position_shared( void ) const
        MPI_Offset v2;
        { int err = MPI_File_get_position_shared( (MPI_File) the_real_file, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual void Write_shared( const void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_write_shared( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_shared( const void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_write_shared( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Request Iwrite_at( Offset v2, const void * v3, int v4, const Datatype &v5 )
        Request v6;
        { int err = MPI_File_iwrite_at( (MPI_File) the_real_file, (MPI_Offset)v2, (const void *)v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Request *)&(v6.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v6;
    virtual void Get_view( Offset & v2, Datatype &v3, Datatype &v4, char * v5 ) const
        { int err = MPI_File_get_view( (MPI_File) the_real_file, &v2, (MPI_Datatype *)&(v3.the_real_datatype), (MPI_Datatype *)&(v4.the_real_datatype), v5 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_all_begin( const void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_write_all_begin( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_all_end( void * v2, Status & v3 )
        { int err = MPI_File_read_all_end( (MPI_File) the_real_file, v2, (MPI_Status *)&(v3.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_all_end( void * v2 )
        { int err = MPI_File_read_all_end( (MPI_File) the_real_file, v2, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Offset Get_byte_offset( const Offset v2 ) const
        MPI_Offset v3;
        { int err = MPI_File_get_byte_offset( (MPI_File) the_real_file, (MPI_Offset)v2, &v3 ); if (err) { (this)->Call_errhandler( err ); }};
        return v3;
    virtual Request Iread( void * v2, int v3, const Datatype &v4 )
        Request v5;
        { int err = MPI_File_iread( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Request *)&(v5.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v5;
    virtual void Read_at_all_end( void * v2, Status & v3 )
        { int err = MPI_File_read_at_all_end( (MPI_File) the_real_file, v2, (MPI_Status *)&(v3.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_at_all_end( void * v2 )
        { int err = MPI_File_read_at_all_end( (MPI_File) the_real_file, v2, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_at( Offset v2, const void * v3, int v4, const Datatype &v5, Status & v6 )
        { int err = MPI_File_write_at( (MPI_File) the_real_file, v2, (const void *)v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)&(v6.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_at( Offset v2, const void * v3, int v4, const Datatype &v5 )
        { int err = MPI_File_write_at( (MPI_File) the_real_file, v2, (const void *)v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_at_all_begin( Offset v2, const void * v3, int v4, const Datatype &v5 )
        { int err = MPI_File_write_at_all_begin( (MPI_File) the_real_file, v2, (const void *)v3, v4, (MPI_Datatype)(v5.the_real_datatype) ); if (err) { (this)->Call_errhandler( err ); }};
        Errhandler v2;
        { int err = MPI_File_get_errhandler( (MPI_File) the_real_file, &(v2.the_real_errhandler) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual int Get_amode( void ) const
        int v2;
        { int err = MPI_File_get_amode( (MPI_File) the_real_file, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual void Set_atomicity( bool v2 )
        int l2;
        { int err = MPI_File_set_atomicity( (MPI_File) the_real_file, l2 ); if (err) { (this)->Call_errhandler( err ); }};
        Group v2;
        { int err = MPI_File_get_group( (MPI_File) the_real_file, &(v2.the_real_group) ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    virtual Offset Get_position( void ) const
        MPI_Offset v2;
        { int err = MPI_File_get_position( (MPI_File) the_real_file, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    static File Open( const Intracomm &v1, const char * v2, int v3, const Info &v4 )
        File v5;
        { int err = MPI_File_open( (MPI_Comm)(v1.the_real_comm), (const char *)v2, v3, (MPI_Info)(v4.the_real_info), &(v5.the_real_file) ); if (err) { (FILE_NULL).Call_errhandler( err ); }};
        return v5;
    virtual void Seek( Offset v2, int v3 )
        { int err = MPI_File_seek( (MPI_File) the_real_file, v2, v3 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_all_begin( void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_read_all_begin( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_at_all_begin( Offset v2, void * v3, int v4, const Datatype &v5 )
        { int err = MPI_File_read_at_all_begin( (MPI_File) the_real_file, v2, v3, v4, (MPI_Datatype)(v5.the_real_datatype) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_all( void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_read_all( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_all( void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_read_all( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Preallocate( Offset v2 )
        { int err = MPI_File_preallocate( (MPI_File) the_real_file, v2 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_at_all( Offset v2, void * v3, int v4, const Datatype &v5, Status & v6 )
        { int err = MPI_File_read_at_all( (MPI_File) the_real_file, v2, v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)&(v6.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_at_all( Offset v2, void * v3, int v4, const Datatype &v5 )
        { int err = MPI_File_read_at_all( (MPI_File) the_real_file, v2, v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_shared( void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_read_shared( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_shared( void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_read_shared( (MPI_File) the_real_file, v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual Request Iwrite( const void * v2, int v3, const Datatype &v4 )
        Request v5;
        { int err = MPI_File_iwrite( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Request *)&(v5.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v5;
    virtual Request Iwrite_shared( const void * v2, int v3, const Datatype &v4 )
        Request v5;
        { int err = MPI_File_iwrite_shared( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Request *)&(v5.the_real_request) ); if (err) { (this)->Call_errhandler( err ); }};
        return v5;
        { int err = MPI_File_set_errhandler( (MPI_File) the_real_file, (MPI_Errhandler)(v2.the_real_errhandler) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_at_all( Offset v2, const void * v3, int v4, const Datatype &v5, Status & v6 )
        { int err = MPI_File_write_at_all( (MPI_File) the_real_file, v2, (const void *)v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)&(v6.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_at_all( Offset v2, const void * v3, int v4, const Datatype &v5 )
        { int err = MPI_File_write_at_all( (MPI_File) the_real_file, v2, (const void *)v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Set_size( Offset v2 )
        { int err = MPI_File_set_size( (MPI_File) the_real_file, v2 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Set_view( Offset v2, const Datatype &v3, const Datatype v4, const char * v5, const Info &v6 )
        { int err = MPI_File_set_view( (MPI_File) the_real_file, v2, (MPI_Datatype)(v3.the_real_datatype), (MPI_Datatype)v4, (const char *)v5, (MPI_Info)(v6.the_real_info) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_at( Offset v2, void * v3, int v4, const Datatype &v5, Status & v6 )
        { int err = MPI_File_read_at( (MPI_File) the_real_file, v2, v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)&(v6.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Read_at( Offset v2, void * v3, int v4, const Datatype &v5 )
        { int err = MPI_File_read_at( (MPI_File) the_real_file, v2, v3, v4, (MPI_Datatype)(v5.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Close( void )
        { int err = MPI_File_close( (MPI_File *) &the_real_file ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_ordered_end( const void * v2, Status & v3 )
        { int err = MPI_File_write_ordered_end( (MPI_File) the_real_file, (const void *)v2, (MPI_Status *)&(v3.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write_ordered_end( const void * v2 )
        { int err = MPI_File_write_ordered_end( (MPI_File) the_real_file, (const void *)v2, (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write( const void * v2, int v3, const Datatype &v4, Status & v5 )
        { int err = MPI_File_write( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)&(v5.the_real_status ) ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Write( const void * v2, int v3, const Datatype &v4 )
        { int err = MPI_File_write( (MPI_File) the_real_file, (const void *)v2, v3, (MPI_Datatype)(v4.the_real_datatype), (MPI_Status *)1 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual bool Get_atomicity( void ) const
        int v2;
        { int err = MPI_File_get_atomicity( (MPI_File) the_real_file, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2!= 0;
    typedef void Errhandler_function(File &, int *, ... );
class Graphcomm : public Intracomm {
  public:
    inline Graphcomm(MPI_Comm obj) : Intracomm(obj) {}
    inline Graphcomm(void) : Intracomm() {}
    virtual ~Graphcomm() {}
    Graphcomm(const Graphcomm &obj) : Intracomm(obj) {}
    Graphcomm& operator=(const Graphcomm &obj) {
    Graphcomm& operator=(const MPI_Comm& obj) {
    virtual void Get_dims( int * v2, int * v3 ) const
        { int err = MPI_Graphdims_get( (MPI_Comm) the_real_comm, v2, v3 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual void Get_topo( int v2, int v3, int v4[], int v5[] ) const
        { int err = MPI_Graph_get( (MPI_Comm) the_real_comm, v2, v3, v4, v5 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual int Map( int v2, const int v3[], const int v4[] ) const
        int v5;
        { int err = MPI_Graph_map( (MPI_Comm) the_real_comm, v2, (const int *)v3, (const int *)v4, &v5 ); if (err) { (this)->Call_errhandler( err ); }};
        return v5;
    virtual void Get_neighbors( int v2, int v3, int v4[] ) const
        { int err = MPI_Graph_neighbors( (MPI_Comm) the_real_comm, v2, v3, v4 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual int Get_neighbors_count( int v2 ) const
        int v3;
        { int err = MPI_Graph_neighbors_count( (MPI_Comm) the_real_comm, v2, &v3 ); if (err) { (this)->Call_errhandler( err ); }};
        return v3;
    Graphcomm Dup( void ) const
        Graphcomm v2;
        return v2;
# 2360 "/usr/local/include/mpicxx.h" 3
    virtual Graphcomm & Clone(void) const {
        MPI_Comm ncomm;
        Graphcomm *clone = new Graphcomm(ncomm);
        return *clone;
class Cartcomm : public Intracomm {
  public:
    inline Cartcomm(MPI_Comm obj) : Intracomm(obj) {}
    inline Cartcomm(void) : Intracomm() {}
    virtual ~Cartcomm() {}
    Cartcomm(const Cartcomm &obj) : Intracomm(obj) {}
    Cartcomm& operator=(const Cartcomm &obj) {
    Cartcomm& operator=(const MPI_Comm& obj) {
    virtual void Get_coords( int v2, int v3, int v4[] ) const
        { int err = MPI_Cart_coords( (MPI_Comm) the_real_comm, v2, v3, v4 ); if (err) { (this)->Call_errhandler( err ); }};
    virtual int Get_cart_rank( const int v2[] ) const
        int v3;
        { int err = MPI_Cart_rank( (MPI_Comm) the_real_comm, (const int *)v2, &v3 ); if (err) { (this)->Call_errhandler( err ); }};
        return v3;
    virtual int Get_dim( void ) const
        int v2;
        { int err = MPI_Cartdim_get( (MPI_Comm) the_real_comm, &v2 ); if (err) { (this)->Call_errhandler( err ); }};
        return v2;
    Cartcomm Dup( void ) const
        Cartcomm v2;
        return v2;
    virtual void Get_topo( int v2, int v3[], bool v4[], int v5[] ) const
        int *l4 = new int[v2];
        { int err = MPI_Cart_get( (MPI_Comm) the_real_comm, v2, v3, l4, v5 ); if (err) { (this)->Call_errhandler( err ); }};
            int i4;
            for (i4=0;i4<v2;i4++) {
                v4[i4] = l4[i4] != 0;
            delete[] l4;
    virtual int Map( int v2, const int v3[], const bool v4[] ) const
        int v5;
            int i4;
                l4[i4] = v4[i4] == true ? 1 : 0;
        { int err = MPI_Cart_map( (MPI_Comm) the_real_comm, v2, (const int *)v3, l4, &v5 ); if (err) { (this)->Call_errhandler( err ); }};
            delete[] l4;
        return v5;
    virtual Cartcomm Sub( const bool v2[] ) const
        Cartcomm v3;
        int *l2 = new int[10];
            int i2;
            for (i2=0;i2<10;i2++) {
                l2[i2] = v2[i2] == true ? 1 : 0;
        { int err = MPI_Cart_sub( (MPI_Comm) the_real_comm, l2, &(v3.the_real_comm) ); if (err) { (this)->Call_errhandler( err ); }};
            delete[] l2;
        return v3;
    virtual void Shift( int v2, int v3, int &v4, int &v5 ) const
        { int err = MPI_Cart_shift( (MPI_Comm) the_real_comm, v2, v3, &v4, &v5 ); if (err) { (this)->Call_errhandler( err ); }};
# 2475 "/usr/local/include/mpicxx.h" 3
    virtual Cartcomm & Clone(void) const {
        MPI_Comm ncomm;
        Cartcomm *clone = new Cartcomm(ncomm);
        return *clone;
extern int Add_error_class( void ) ;
extern void* Alloc_mem( Aint v1, const Info &v2 ) ;
extern void Lookup_name( const char * v1, const Info &v2, char * v3 ) ;
extern void Publish_name( const char * v1, const Info &v2, const char * v3 ) ;
extern void Unpublish_name( const char * v1, const Info &v2, const char * v3 ) ;
extern Aint Get_address( const void * v1 ) ;
extern void Add_error_string( int v1, const char * v2 ) ;
extern int Query_thread( void ) ;
extern void Close_port( const char * v1 ) ;
extern int Add_error_code( int v1 ) ;
extern void Free_mem( void * v1 ) ;
extern void Open_port( const Info &v1, char * v2 ) ;
extern bool Is_finalized( void ) ;
extern bool Is_thread_main( void ) ;
typedef int Datarep_extent_function( const Datatype&, Aint&, void *);
typedef int Datarep_conversion_function( void *, Datatype &, int, void *,
                Offset, void * );
extern Datatype CHAR;
extern Datatype UNSIGNED_CHAR;
extern Datatype BYTE;
extern Datatype SHORT;
extern Datatype UNSIGNED_SHORT;
extern Datatype INT;
extern Datatype UNSIGNED;
extern Datatype LONG;
extern Datatype UNSIGNED_LONG;
extern Datatype FLOAT;
extern Datatype DOUBLE;
extern Datatype LONG_DOUBLE;
extern Datatype LONG_LONG_INT;
extern Datatype LONG_LONG;
extern Datatype PACKED;
extern Datatype LB;
extern Datatype UB;
extern Datatype FLOAT_INT;
extern Datatype DOUBLE_INT;
extern Datatype LONG_INT;
extern Datatype SHORT_INT;
extern Datatype LONG_DOUBLE_INT;
extern Datatype REAL4;
extern Datatype REAL8;
extern Datatype REAL16;
extern Datatype COMPLEX8;
extern Datatype COMPLEX16;
extern Datatype COMPLEX32;
extern Datatype INTEGER1;
extern Datatype INTEGER2;
extern Datatype INTEGER4;
extern Datatype INTEGER8;
extern Datatype INTEGER16;
extern Datatype WCHAR;
extern Datatype SIGNED_CHAR;
extern Datatype UNSIGNED_LONG_LONG;
extern Datatype TWOINT;
extern Datatype BOOL;
extern Datatype COMPLEX;
extern Datatype DOUBLE_COMPLEX;
extern Datatype LONG_DOUBLE_COMPLEX;
extern Datatype DATATYPE_NULL;
extern Datatype INTEGER;
extern Datatype REAL;
extern Datatype DOUBLE_PRECISION;
extern Datatype F_COMPLEX;
extern Datatype F_DOUBLE_COMPLEX;
extern Datatype LOGICAL;
extern Datatype CHARACTER;
extern Datatype TWOREAL;
extern Datatype TWODOUBLE_PRECISION;
extern Datatype TWOINTEGER;
extern const Op MAX;
extern const Op MIN;
extern const Op SUM;
extern const Op PROD;
extern const Op LAND;
extern const Op BAND;
extern const Op LOR;
extern const Op BOR;
extern const Op LXOR;
extern const Op BXOR;
extern const Op MINLOC;
extern const Op MAXLOC;
extern const Op REPLACE;
extern const Op OP_NULL;
extern Intracomm COMM_SELF;
extern const Group GROUP_EMPTY;
extern const Nullcomm COMM_NULL;
extern const Group GROUP_NULL;
extern const Request REQUEST_NULL;
extern const Errhandler ERRHANDLER_NULL;
extern const Errhandler ERRORS_RETURN;
extern const Errhandler ERRORS_ARE_FATAL;
extern const Errhandler ERRORS_THROW_EXCEPTIONS;
extern const Info INFO_NULL;
extern const Win WIN_NULL;
extern const int BSEND_OVERHEAD;
extern const int KEYVAL_INVALID;
extern const int CART;
extern const int GRAPH;
extern const int IDENT;
extern const int SIMILAR;
extern const int CONGRUENT;
extern const int UNEQUAL;
extern const int PROC_NULL;
extern const int ANY_TAG;
extern const int ANY_SOURCE;
extern const int ROOT;
extern const int TAG_UB;
extern const int IO;
extern const int HOST;
extern const int WTIME_IS_GLOBAL;
extern const int UNIVERSE_SIZE;
extern const int LASTUSEDCODE;
extern const int APPNUM;
extern const int MAX_PROCESSOR_NAME;
extern const int MAX_ERROR_STRING;
extern const int MAX_PORT_NAME;
extern const int MAX_OBJECT_NAME;
extern const int MAX_INFO_VAL;
extern const int MAX_INFO_KEY;
extern const int UNDEFINED;
extern const int LOCK_EXCLUSIVE;
extern const int LOCK_SHARED;
extern const int WIN_BASE;
extern const int WIN_DISP_UNIT;
extern const int WIN_SIZE;
extern const int SUCCESS;
extern const int ERR_BUFFER;
extern const int ERR_COUNT;
extern const int ERR_TYPE;
extern const int ERR_TAG;
extern const int ERR_COMM;
extern const int ERR_RANK;
extern const int ERR_REQUEST;
extern const int ERR_ROOT;
extern const int ERR_GROUP;
extern const int ERR_OP;
extern const int ERR_TOPOLOGY;
extern const int ERR_DIMS;
extern const int ERR_ARG;
extern const int ERR_UNKNOWN;
extern const int ERR_TRUNCATE;
extern const int ERR_OTHER;
extern const int ERR_INTERN;
extern const int ERR_PENDING;
extern const int ERR_IN_STATUS;
extern const int ERR_LASTCODE;
extern const int ERR_FILE;
extern const int ERR_ACCESS;
extern const int ERR_AMODE;
extern const int ERR_BAD_FILE;
extern const int ERR_FILE_EXISTS;
extern const int ERR_FILE_IN_USE;
extern const int ERR_NO_SPACE;
extern const int ERR_NO_SUCH_FILE;
extern const int ERR_IO;
extern const int ERR_READ_ONLY;
extern const int ERR_CONVERSION;
extern const int ERR_DUP_DATAREP;
extern const int ERR_UNSUPPORTED_DATAREP;
extern const int ERR_INFO;
extern const int ERR_INFO_KEY;
extern const int ERR_INFO_VALUE;
extern const int ERR_INFO_NOKEY;
extern const int ERR_NAME;
extern const int ERR_NO_MEM;
extern const int ERR_NOT_SAME;
extern const int ERR_PORT;
extern const int ERR_QUOTA;
extern const int ERR_SERVICE;
extern const int ERR_SPAWN;
extern const int ERR_UNSUPPORTED_OPERATION;
extern const int ERR_WIN;
extern const int ERR_BASE;
extern const int ERR_LOCKTYPE;
extern const int ERR_KEYVAL;
extern const int ERR_RMA_CONFLICT;
extern const int ERR_RMA_SYNC;
extern const int ERR_SIZE;
extern const int ERR_DISP;
extern const int ERR_ASSERT;
extern const int TYPECLASS_REAL;
extern const int TYPECLASS_INTEGER;
extern const int TYPECLASS_COMPLEX;
extern const int SEEK_SET;
extern const int SEEK_END;
extern const int SEEK_CUR;
extern const int DISTRIBUTE_BLOCK;
extern const int DISTRIBUTE_CYCLIC;
extern const int DISTRIBUTE_DFLT_DARG;
extern const int DISTRIBUTE_NONE;
extern const int ORDER_C;
extern const int ORDER_FORTRAN;
extern const int MAX_DATAREP_STRING;
extern const MPI_Offset DISPLACEMENT_CURRENT;
extern const int MODE_APPEND;
extern const int MODE_CREATE;
extern const int MODE_DELETE_ON_CLOSE;
extern const int MODE_EXCL;
extern const int MODE_RDONLY;
extern const int MODE_RDWR;
extern const int MODE_SEQUENTIAL;
extern const int MODE_UNIQUE_OPEN;
extern const int MODE_WRONLY;
extern const int MODE_NOCHECK;
extern const int MODE_NOPRECEDE;
extern const int MODE_NOPUT;
extern const int MODE_NOSTORE;
extern const int MODE_NOSUCCEED;
extern const int COMM_TYPE_SHARED;
extern const int COMBINER_CONTIGUOUS;
extern const int COMBINER_DARRAY;
extern const int COMBINER_DUP;
extern const int COMBINER_F90_COMPLEX;
extern const int COMBINER_F90_INTEGER;
extern const int COMBINER_F90_REAL;
extern const int COMBINER_HINDEXED_INTEGER;
extern const int COMBINER_HINDEXED;
extern const int COMBINER_HVECTOR_INTEGER;
extern const int COMBINER_HVECTOR;
extern const int COMBINER_INDEXED_BLOCK;
extern const int COMBINER_INDEXED;
extern const int COMBINER_NAMED;
extern const int COMBINER_RESIZED;
extern const int COMBINER_STRUCT_INTEGER;
extern const int COMBINER_STRUCT;
extern const int COMBINER_SUBARRAY;
extern const int COMBINER_VECTOR;
extern const int COMBINER_HINDEXED_BLOCK;
extern const int THREAD_FUNNELED;
extern const int THREAD_MULTIPLE;
extern const int THREAD_SERIALIZED;
extern const int THREAD_SINGLE;
extern const char ** const ARGV_NULL;
extern const char *** const ARGVS_NULL;
extern void * const BOTTOM;
extern void * const IN_PLACE;
extern void Init(void);
extern void Init(int &, char **& );
extern int Init_thread(int);
extern int Init_thread(int &, char **&, int );
extern double Wtime(void);
extern double Wtick(void);
# 2232 "/usr/local/include/mpi.h" 2 3
typedef int MPIX_Grequest_class;
int MPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
                               MPI_Grequest_free_function *free_fn,
                               MPI_Grequest_cancel_function *cancel_fn,
                               MPIX_Grequest_poll_function *poll_fn,
                               MPIX_Grequest_wait_function *wait_fn,
                               MPIX_Grequest_class *greq_class);
int MPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
                                 MPI_Request *request);
int MPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
                        MPIX_Grequest_wait_function *wait_fn, void *extra_state,
struct mpixi_mutex_s;
typedef struct mpixi_mutex_s * MPIX_Mutex;
int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int MPIX_Mutex_free(MPIX_Mutex *hdl);
int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
int PMPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
int PMPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int PMPIX_Mutex_free(MPIX_Mutex *hdl);
int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['mpi.h'] in ['/usr/local/include']
                Popping language Cxx
TEST configureConversion from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:217)
TESTING: configureConversion from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:217)
  Check for the functions which convert communicators between C and Fortran
       - Define HAVE_MPI_COMM_F2C and HAVE_MPI_COMM_C2F if they are present
       - Some older MPI 1 implementations are missing these
                            All intermediate test results are stored in /tmp/petsc-F9l5hH/config.packages.MPI
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.packages.MPI/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.packages.MPI    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3   /tmp/petsc-F9l5hH/config.packages.MPI/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <mpi.h>
int main() {
if (MPI_Comm_f2c((MPI_Fint)0));
  return 0;
                        Pushing language C
                        Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.packages.MPI/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.packages.MPI/conftest.o  -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
                Defined "HAVE_MPI_COMM_F2C" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_c2f(MPI_COMM_WORLD));
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_MPI_COMM_C2F" to "1"
Possible ERROR while running compiler:
stderr:
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:6:10: warning: unused variable ‘a’ [-Wunused-variable]
 MPI_Fint a;
Source:
#include <mpi.h>
int main() {
MPI_Fint a;
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_MPI_FINT" to "1"
TEST configureMPI2 from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:180)
TESTING: configureMPI2 from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:180)
  Check for functions added to the interface in MPI-2
Successful compile:
Source:
#include <mpi.h>
int main() {
int flag;if (MPI_Finalized(&flag));
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_MPI_FINALIZED" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_MPI_IN_PLACE" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={0,1}; MPI_Datatype *newtype = 0;
                                              if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
  return 0;
                        Pushing language C
                        Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
  return 0;
                        Pushing language C
                        Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
  return 0;
                        Pushing language C
                        Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Reduce_local(0, 0, 0, MPI_INT, MPI_SUM));;
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_MPI_REDUCE_LOCAL" to "1"
TEST configureTypes from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:237)
TESTING: configureTypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:237)
  Checking for MPI types
Checking for size of type: MPI_Comm
                  Pushing language C
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.types/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3   /tmp/petsc-F9l5hH/config.types/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#define MPICH_IGNORE_CXX_SEEK
#define MPICH_SKIP_MPICXX 1
#define OMPI_SKIP_MPICXX 1
#include <mpi.h>
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Comm));
  return 0;
                              Pushing language C
                              Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.types/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.types/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Testing executable /tmp/petsc-F9l5hH/config.types/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.types/conftest
                  Popping language C
                  Defined "SIZEOF_MPI_COMM" to "4"
Checking for size of type: MPI_Fint
                  Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#include <mpi.h>
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Fint));
  return 0;
                              Pushing language C
                              Popping language C
                  Popping language C
                  Defined "SIZEOF_MPI_FINT" to "4"
TEST configureMPITypes from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:249)
TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:249)
  Checking for MPI Datatype handles
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.packages.MPI/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3   /tmp/petsc-F9l5hH/config.packages.MPI/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_STDLIB_H
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_LONG_DOUBLE, &size);
if(ierr || (size == 0)) exit(1);
MPI_Finalize();
  return 0;
                Pushing language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
  return 0;
                            Pushing language C
                            Popping language C
Testing executable /tmp/petsc-F9l5hH/config.packages.MPI/conftest to see if it can be run
Executing: /tmp/petsc-F9l5hH/config.packages.MPI/conftest
                Defined "HAVE_MPI_LONG_DOUBLE" to "1"
                Popping language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_INT64_T, &size);
MPI_Finalize();
  return 0;
                Pushing language C
Successful compile:
Source:
  #include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
  return 0;
                            Pushing language C
                            Popping language C
                Defined "HAVE_MPI_INT64_T" to "1"
                Popping language C
TEST configureMissingPrototypes from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:325)
TESTING: configureMissingPrototypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:325)
  Checks for missing prototypes, which it adds to petscfix.h
TEST SGIMPICheck from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:344)
TESTING: SGIMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:344)
  Returns true if SGI MPI is used
                Checking for functions [MPI_SGI_barrier] in library [] []
                  Pushing language Cxx
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.libraries -fopenmp -O3      /tmp/petsc-F9l5hH/config.libraries/conftest.cc
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
char MPI_SGI_barrier();
static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPI_SGI_barrier();;
  return 0;
                          Pushing language CXX
                          Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.o: In function `main':
conftest.cc:(.text.startup+0x5): undefined reference to `MPI_SGI_barrier'
collect2: error: ld returned 1 exit status
              SGI MPI test failure
TEST CxxMPICheck from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:354)
TESTING: CxxMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:354)
  Make sure C++ can compile and link
Checking for header mpi.h
Successful compile:
Source:
#include <mpi.h>
int main() {
  return 0;
Checking for C++ MPI_Finalize()
                Checking for functions [MPI_Finalize] in library [] []
Successful compile:
Source:
#include <mpi.h>
static void _check_MPI_Finalize() { int ierr;
ierr = MPI_Finalize();; }
int main() {
_check_MPI_Finalize();;
  return 0;
TEST FortranMPICheck from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:372)
TESTING: FortranMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:372)
  Make sure fortran include [mpif.h] and library symbols are found
                Pushing language FC
Checking for header mpif.h
Executing: mpif90 -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.libraries   -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3    /tmp/petsc-F9l5hH/config.libraries/conftest.F
Successful compile:
Source:
      program main
#include "mpif.h"
      end
Checking for fortran mpi_init()
                Checking for functions [] in library [] []
                  Pushing language FC
Successful compile:
Source:
      program main
#include "mpif.h"
       integer ierr
       call mpi_init(ierr)
      end
                          Pushing language FC
                          Popping language FC
Executing: mpif90  -o /tmp/petsc-F9l5hH/config.libraries/conftest     -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
                  Popping language FC
Checking for mpi.mod
                  Pushing language FC
Successful compile:
Source:
      program main
       use mpi
       integer ierr,rank
       call mpi_init(ierr)
       call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
      end
                          Pushing language FC
                          Popping language FC
                  Popping language FC
                Defined "HAVE_MPI_F90MODULE" to "1"
                Popping language FC
TEST configureIO from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:397)
TESTING: configureIO from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:397)
  Check for the functions in MPI/IO
       - Define HAVE_MPIIO if they are present
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Aint lb, extent;
if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:9:5: warning: ‘fh’ is used uninitialized in this function [-Wuninitialized]
 if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:9:5: warning: ‘buf’ is used uninitialized in this function [-Wuninitialized]
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
 if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
 if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:9:5: warning: ‘disp’ is used uninitialized in this function [-Wuninitialized]
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:9:5: warning: ‘info’ is used uninitialized in this function [-Wuninitialized]
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Offset disp;
MPI_Info info;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:8:5: warning: ‘info’ is used uninitialized in this function [-Wuninitialized]
 if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
  return 0;
                        Pushing language C
                        Popping language C
stderr:
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:7:10: warning: unused variable ‘info’ [-Wunused-variable]
 MPI_Info info;
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
if (MPI_File_close(&fh));
  return 0;
                        Pushing language C
                        Popping language C
                Defined "HAVE_MPIIO" to "1"
TEST findMPIInc from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:459)
TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:459)
  Find MPI include paths from "mpicc -show"
Executing: mpicc -show
stdout: gcc -I/usr/local/include -L/usr/local/lib -Wl,-rpath -Wl,/usr/local/lib -Wl,--enable-new-dtags -lmpi
              compilers: Checking arg gcc
              compilers: Checking arg -I/usr/local/include
              compilers: Found include directory: /usr/local/include
              compilers: Checking arg -L/usr/local/lib
              compilers: Checking arg -Wl,-rpath
              compilers: Checking arg -Wl,/usr/local/lib
              compilers: Checking arg -Wl,--enable-new-dtags
              compilers: Checking arg -lmpi
TEST checkMPICHorOpenMPI from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:434)
TESTING: checkMPICHorOpenMPI from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:434)
  Determine if MPICH_NUMVERSION or OMPI_MAJOR_VERSION exist in mpi.h
       Used for consistency checking of MPI installation at compile time
Successful compile:
Source:
#include <mpi.h>
int mpich_ver = MPICH_NUMVERSION;
int main() {
  return 0;
Source:
#include <mpi.h>
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI -I/tmp/petsc-F9l5hH/config.headers  /tmp/petsc-F9l5hH/config.packages.MPI/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.packages.MPI/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.packages.MPI/conffix.h" 1
# 3 "/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c" 2
# 1 "/usr/local/include/mpi.h" 1 3
# 98 "/usr/local/include/mpi.h" 3
typedef int MPI_Datatype;
# 281 "/usr/local/include/mpi.h" 3
typedef int MPI_Comm;
typedef int MPI_Group;
typedef int MPI_Win;
typedef struct ADIOI_FileD *MPI_File;
typedef int MPI_Op;
# 364 "/usr/local/include/mpi.h" 3
typedef enum MPIR_Win_flavor {
    MPI_WIN_FLAVOR_CREATE = 1,
    MPI_WIN_FLAVOR_ALLOCATE = 2,
    MPI_WIN_FLAVOR_DYNAMIC = 3,
    MPI_WIN_FLAVOR_SHARED = 4
} MPIR_Win_flavor_t;
typedef enum MPIR_Win_model {
    MPI_WIN_SEPARATE = 1,
    MPI_WIN_UNIFIED = 2
} MPIR_Win_model_t;
typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
extern int * const MPI_UNWEIGHTED;
extern int * const MPI_WEIGHTS_EMPTY;
# 396 "/usr/local/include/mpi.h" 3
typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
       void *, int *);
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
       void *, int *);
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
      int *);
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
# 424 "/usr/local/include/mpi.h" 3
typedef int MPI_Errhandler;
# 445 "/usr/local/include/mpi.h" 3
typedef int MPI_Request;
typedef int MPI_Message;
typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
# 499 "/usr/local/include/mpi.h" 3
enum MPIR_Combiner_enum {
    MPI_COMBINER_NAMED = 1,
    MPI_COMBINER_DUP = 2,
    MPI_COMBINER_CONTIGUOUS = 3,
    MPI_COMBINER_VECTOR = 4,
    MPI_COMBINER_HVECTOR_INTEGER = 5,
    MPI_COMBINER_HVECTOR = 6,
    MPI_COMBINER_INDEXED = 7,
    MPI_COMBINER_HINDEXED_INTEGER = 8,
    MPI_COMBINER_HINDEXED = 9,
    MPI_COMBINER_INDEXED_BLOCK = 10,
    MPI_COMBINER_STRUCT_INTEGER = 11,
    MPI_COMBINER_STRUCT = 12,
    MPI_COMBINER_SUBARRAY = 13,
    MPI_COMBINER_DARRAY = 14,
    MPI_COMBINER_F90_REAL = 15,
    MPI_COMBINER_F90_COMPLEX = 16,
    MPI_COMBINER_F90_INTEGER = 17,
    MPI_COMBINER_RESIZED = 18,
    MPI_COMBINER_HINDEXED_BLOCK = 19
typedef int MPI_Info;
# 549 "/usr/local/include/mpi.h" 3
typedef long MPI_Aint;
typedef int MPI_Fint;
typedef long long MPI_Count;
# 568 "/usr/local/include/mpi.h" 3
typedef long long MPI_Offset;
typedef struct MPI_Status {
    int count_lo;
    int count_hi_and_cancelled;
    int MPI_SOURCE;
    int MPI_TAG;
    int MPI_ERROR;
} MPI_Status;
struct MPIR_T_enum_s;
struct MPIR_T_cvar_handle_s;
struct MPIR_T_pvar_handle_s;
struct MPIR_T_pvar_session_s;
typedef struct MPIR_T_enum_s * MPI_T_enum;
typedef struct MPIR_T_cvar_handle_s * MPI_T_cvar_handle;
typedef struct MPIR_T_pvar_handle_s * MPI_T_pvar_handle;
typedef struct MPIR_T_pvar_session_s * MPI_T_pvar_session;
extern struct MPIR_T_pvar_handle_s * const MPI_T_PVAR_ALL_HANDLES;
# 605 "/usr/local/include/mpi.h" 3
typedef enum MPIR_T_verbosity_t {
    MPIX_T_VERBOSITY_INVALID = 0,
    MPI_T_VERBOSITY_USER_BASIC = 221,
    MPI_T_VERBOSITY_USER_DETAIL,
    MPI_T_VERBOSITY_USER_ALL,
    MPI_T_VERBOSITY_TUNER_BASIC,
    MPI_T_VERBOSITY_TUNER_DETAIL,
    MPI_T_VERBOSITY_TUNER_ALL,
    MPI_T_VERBOSITY_MPIDEV_BASIC,
    MPI_T_VERBOSITY_MPIDEV_DETAIL,
    MPI_T_VERBOSITY_MPIDEV_ALL
} MPIR_T_verbosity_t;
typedef enum MPIR_T_bind_t {
    MPIX_T_BIND_INVALID = 0,
    MPI_T_BIND_NO_OBJECT = 9700,
    MPI_T_BIND_MPI_COMM,
    MPI_T_BIND_MPI_DATATYPE,
    MPI_T_BIND_MPI_ERRHANDLER,
    MPI_T_BIND_MPI_FILE,
    MPI_T_BIND_MPI_GROUP,
    MPI_T_BIND_MPI_OP,
    MPI_T_BIND_MPI_REQUEST,
    MPI_T_BIND_MPI_WIN,
    MPI_T_BIND_MPI_MESSAGE,
    MPI_T_BIND_MPI_INFO
} MPIR_T_bind_t;
typedef enum MPIR_T_scope_t {
    MPIX_T_SCOPE_INVALID = 0,
    MPI_T_SCOPE_CONSTANT = 60438,
    MPI_T_SCOPE_READONLY,
    MPI_T_SCOPE_LOCAL,
    MPI_T_SCOPE_GROUP,
    MPI_T_SCOPE_GROUP_EQ,
    MPI_T_SCOPE_ALL,
    MPI_T_SCOPE_ALL_EQ
} MPIR_T_scope_t;
typedef enum MPIR_T_pvar_class_t {
    MPIX_T_PVAR_CLASS_INVALID = 0,
    MPIR_T_PVAR_CLASS_FIRST = 240,
    MPI_T_PVAR_CLASS_STATE = MPIR_T_PVAR_CLASS_FIRST,
    MPI_T_PVAR_CLASS_LEVEL,
    MPI_T_PVAR_CLASS_SIZE,
    MPI_T_PVAR_CLASS_PERCENTAGE,
    MPI_T_PVAR_CLASS_HIGHWATERMARK,
    MPI_T_PVAR_CLASS_LOWWATERMARK,
    MPI_T_PVAR_CLASS_COUNTER,
    MPI_T_PVAR_CLASS_AGGREGATE,
    MPI_T_PVAR_CLASS_TIMER,
    MPI_T_PVAR_CLASS_GENERIC,
    MPIR_T_PVAR_CLASS_LAST,
    MPIR_T_PVAR_CLASS_NUMBER = MPIR_T_PVAR_CLASS_LAST - MPIR_T_PVAR_CLASS_FIRST
} MPIR_T_pvar_class_t;
# 727 "/usr/local/include/mpi.h" 3
extern MPI_Fint * MPI_F_STATUS_IGNORE;
extern MPI_Fint * MPI_F_STATUSES_IGNORE;
# 742 "/usr/local/include/mpi.h" 3
typedef struct {
    MPI_Fint count_lo;
    MPI_Fint count_hi_and_cancelled;
    MPI_Fint MPI_SOURCE;
    MPI_Fint MPI_TAG;
    MPI_Fint MPI_ERROR;
} MPI_F08_Status;
extern MPI_F08_Status MPIR_F08_MPI_STATUS_IGNORE_OBJ;
extern MPI_F08_Status MPIR_F08_MPI_STATUSES_IGNORE_OBJ[1];
extern int MPIR_F08_MPI_IN_PLACE;
extern int MPIR_F08_MPI_BOTTOM;
extern MPI_F08_Status *MPI_F08_STATUS_IGNORE;
extern MPI_F08_Status *MPI_F08_STATUSES_IGNORE;
# 766 "/usr/local/include/mpi.h" 3
typedef int (MPI_Grequest_cancel_function)(void *, int);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_poll_function)(void *, MPI_Status *);
typedef int (MPIX_Grequest_wait_function)(int, void **, double, MPI_Status *);
# 896 "/usr/local/include/mpi.h" 3
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
             void *, MPI_Offset, void *);
typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
                      void *);
# 916 "/usr/local/include/mpi.h" 3
int MPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
             MPI_Comm comm) ;
int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
             MPI_Comm comm, MPI_Status *status) ;
int MPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int MPI_Buffer_attach(void *buffer, int size);
int MPI_Buffer_detach(void *buffer_addr, int *size);
int MPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm, MPI_Request *request) ;
int MPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Wait(MPI_Request *request, MPI_Status *status);
int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int MPI_Request_free(MPI_Request *request);
int MPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int MPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int MPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int MPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
                 int array_of_indices[], MPI_Status array_of_statuses[]);
int MPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int MPI_Cancel(MPI_Request *request);
int MPI_Test_cancelled(const MPI_Status *status, int *flag);
int MPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int MPI_Start(MPI_Request *request);
int MPI_Startall(int count, MPI_Request array_of_requests[]);
int MPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
                 int sendtag, void *recvbuf, int recvcount, MPI_Datatype recvtype,
                 int source, int recvtag, MPI_Comm comm, MPI_Status *status)
int MPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
                         int sendtag, int source, int recvtag, MPI_Comm comm,
int MPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_indexed(int count, const int *array_of_blocklengths,
                     const int *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_hindexed(int count, const int *array_of_blocklengths,
                      const MPI_Aint *array_of_displacements, MPI_Datatype oldtype,
int MPI_Type_struct(int count, const int *array_of_blocklengths,
                    const MPI_Datatype *array_of_types, MPI_Datatype *newtype);
int MPI_Address(const void *location, MPI_Aint *address);
int MPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Type_size(MPI_Datatype datatype, int *size);
int MPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int MPI_Type_commit(MPI_Datatype *datatype);
int MPI_Type_free(MPI_Datatype *datatype);
int MPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
             int outsize, int *position, MPI_Comm comm) ;
int MPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
               MPI_Datatype datatype, MPI_Comm comm) ;
int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int MPI_Barrier(MPI_Comm comm);
int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int MPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
               int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm)
int MPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root,
                MPI_Comm comm)
int MPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
                 MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype,
int MPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                  int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
                  MPI_Datatype sendtype, void *recvbuf, const int *recvcounts,
                  const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                  const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[],
                  const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, MPI_Comm comm)
int MPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
               MPI_Op op, int root, MPI_Comm comm)
int MPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int MPI_Op_free(MPI_Op *op);
int MPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                       MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
int MPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
             MPI_Comm comm)
int MPI_Group_size(MPI_Group group, int *size);
int MPI_Group_rank(MPI_Group group, int *rank);
int MPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                              int ranks2[]);
int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int MPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int MPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int MPI_Group_free(MPI_Group *group);
int MPI_Comm_size(MPI_Comm comm, int *size);
int MPI_Comm_rank(MPI_Comm comm, int *rank);
int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int MPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int MPI_Comm_free(MPI_Comm *comm);
int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
int MPI_Comm_remote_size(MPI_Comm comm, int *size);
int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
                         int remote_leader, int tag, MPI_Comm *newintercomm);
int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int MPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
                      int *keyval, void *extra_state);
int MPI_Keyval_free(int *keyval);
int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int MPI_Attr_delete(MPI_Comm comm, int keyval);
int MPI_Topo_test(MPI_Comm comm, int *status);
int MPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
                    int reorder, MPI_Comm *comm_cart);
int MPI_Dims_create(int nnodes, int ndims, int dims[]);
int MPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
                     int reorder, MPI_Comm *comm_graph);
int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
int MPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int MPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int MPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int MPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int MPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int MPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int MPI_Get_processor_name(char *name, int *resultlen);
int MPI_Get_version(int *version, int *subversion);
int MPI_Get_library_version(char *version, int *resultlen);
int MPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Errhandler_free(MPI_Errhandler *errhandler);
int MPI_Error_string(int errorcode, char *string, int *resultlen);
int MPI_Error_class(int errorcode, int *errorclass);
double MPI_Wtime(void);
double MPI_Wtick(void);
int MPI_Init(int *argc, char ***argv);
int MPI_Finalize(void);
int MPI_Initialized(int *flag);
int MPI_Abort(MPI_Comm comm, int errorcode);
int MPI_Pcontrol(const int level, ...);
int MPIR_Dup_fn(MPI_Comm oldcomm, int keyval, void *extra_state, void *attribute_val_in,
               void *attribute_val_out, int *flag);
int MPI_Close_port(const char *port_name);
int MPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                    MPI_Comm *newcomm);
int MPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int MPI_Comm_disconnect(MPI_Comm *comm);
int MPI_Comm_get_parent(MPI_Comm *parent);
int MPI_Comm_join(int fd, MPI_Comm *intercomm);
int MPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
                   MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
                            const int array_of_maxprocs[], const MPI_Info array_of_info[],
                            int root, MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
int MPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int MPI_Open_port(MPI_Info info, char *port_name);
int MPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int MPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int MPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int MPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
                   int target_rank, MPI_Aint target_disp, int target_count,
                   MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
            MPI_Datatype target_datatype, MPI_Win win) ;
int MPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int MPI_Win_complete(MPI_Win win);
int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                   MPI_Win *win);
int MPI_Win_fence(int assert, MPI_Win win);
int MPI_Win_free(MPI_Win *win);
int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_test(MPI_Win win, int *flag);
int MPI_Win_unlock(int rank, MPI_Win win);
int MPI_Win_wait(MPI_Win win);
int MPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                     MPI_Win *win);
int MPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                            void *baseptr, MPI_Win *win);
int MPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int MPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int MPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int MPI_Win_detach(MPI_Win win, const void *base);
int MPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int MPI_Win_set_info(MPI_Win win, MPI_Info info);
int MPI_Get_accumulate(const void *origin_addr, int origin_count,
                        MPI_Datatype origin_datatype, void *result_addr, int result_count,
                        MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
                        int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
int MPI_Fetch_and_op(const void *origin_addr, void *result_addr,
                      MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
int MPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
                          void *result_addr, MPI_Datatype datatype, int target_rank,
                          MPI_Aint target_disp, MPI_Win win)
int MPI_Rput(const void *origin_addr, int origin_count,
              MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
              int target_count, MPI_Datatype target_datatype, MPI_Win win,
int MPI_Rget(void *origin_addr, int origin_count,
int MPI_Raccumulate(const void *origin_addr, int origin_count,
                     int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
int MPI_Rget_accumulate(const void *origin_addr, int origin_count,
int MPI_Win_lock_all(int assert, MPI_Win win);
int MPI_Win_unlock_all(MPI_Win win);
int MPI_Win_flush(int rank, MPI_Win win);
int MPI_Win_flush_all(MPI_Win win);
int MPI_Win_flush_local(int rank, MPI_Win win);
int MPI_Win_flush_local_all(MPI_Win win);
int MPI_Win_sync(MPI_Win win);
int MPI_Add_error_class(int *errorclass);
int MPI_Add_error_code(int errorclass, int *errorcode);
int MPI_Add_error_string(int errorcode, const char *string);
int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                           MPI_Comm_delete_attr_function *comm_delete_attr_fn, int *comm_keyval,
                           void *extra_state);
int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int MPI_Comm_free_keyval(int *comm_keyval);
int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int MPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int MPI_File_call_errhandler(MPI_File fh, int errorcode);
int MPI_Grequest_complete(MPI_Request request);
int MPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
                       MPI_Grequest_cancel_function *cancel_fn, void *extra_state,
int MPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int MPI_Is_thread_main(int *flag);
int MPI_Query_thread(int *provided);
int MPI_Status_set_cancelled(MPI_Status *status, int flag);
int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
                           MPI_Type_delete_attr_function *type_delete_attr_fn,
                           int *type_keyval, void *extra_state);
int MPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_free_keyval(int *type_keyval);
int MPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int MPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
                          int max_datatypes, int array_of_integers[],
                          MPI_Aint array_of_addresses[], MPI_Datatype array_of_datatypes[]);
int MPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
                          int *num_datatypes, int *combiner);
int MPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int MPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int MPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                          MPI_Win_delete_attr_function *win_delete_attr_fn, int *win_keyval,
                          void *extra_state);
int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
int MPI_Win_free_keyval(int *win_keyval);
int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int MPI_Win_set_name(MPI_Win win, const char *win_name);
int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int MPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int MPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int MPI_Finalized(int *flag);
int MPI_Free_mem(void *base);
int MPI_Get_address(const void *location, MPI_Aint *address);
int MPI_Info_create(MPI_Info *info);
int MPI_Info_delete(MPI_Info info, const char *key);
int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int MPI_Info_free(MPI_Info *info);
int MPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int MPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int MPI_Info_set(MPI_Info info, const char *key, const char *value);
int MPI_Pack_external(const char datarep[], const void *inbuf, int incount,
                      MPI_Datatype datatype, void *outbuf, MPI_Aint outsize, MPI_Aint *position)
int MPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                           MPI_Aint *size);
int MPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int MPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int MPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
                           const int array_of_distribs[], const int array_of_dargs[],
                           const int array_of_psizes[], int order, MPI_Datatype oldtype,
int MPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
                             const MPI_Aint array_of_displacements[], MPI_Datatype oldtype,
int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int MPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int MPI_Type_create_hindexed_block(int count, int blocklength,
int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int MPI_Type_create_struct(int count, const int array_of_blocklengths[],
                           const MPI_Datatype array_of_types[], MPI_Datatype *newtype);
int MPI_Type_create_subarray(int ndims, const int array_of_sizes[],
                             const int array_of_subsizes[], const int array_of_starts[],
                             int order, MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int MPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
                        MPI_Aint *position, void *outbuf, int outcount, MPI_Datatype datatype)
int MPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int MPI_Type_create_f90_integer(int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_real(int precision, int range, MPI_Datatype *newtype);
int MPI_Type_create_f90_complex(int precision, int range, MPI_Datatype *newtype);
int MPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                     MPI_Op op)
int MPI_Op_commutative(MPI_Op op, int *commute);
int MPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
                                   const int sourceweights[], int outdegree,
                                   const int destinations[], const int destweights[],
                                   MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
                          const int destinations[], const int weights[], MPI_Info info,
int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
                             int maxoutdegree, int destinations[], int destweights[]);
int MPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int MPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int MPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int MPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int MPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm,
int MPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 const int recvcounts[], const int displs[], MPI_Datatype recvtype, int root,
int MPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
                  int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                   int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)
int MPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int MPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   MPI_Datatype sendtype, void *recvbuf, const int recvcounts[],
                   const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
                   const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm,
int MPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)
int MPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
                   MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
                        MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)
int MPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int MPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int MPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int MPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                             void *recvbuf, const int recvcounts[], const int displs[],
int MPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm,
int MPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int MPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
                            const MPI_Aint sdispls[], const MPI_Datatype sendtypes[],
                            void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[],
                            const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
int MPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
                           void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
                           const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)
int MPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                           const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
int MPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int MPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int MPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int MPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
int MPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
MPI_Aint MPI_Aint_add(MPI_Aint base, MPI_Aint disp);
MPI_Aint MPI_Aint_diff(MPI_Aint addr1, MPI_Aint addr2);
int MPI_T_init_thread(int required, int *provided);
int MPI_T_finalize(void);
int MPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int MPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int MPI_T_cvar_get_num(int *num_cvar);
int MPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
                        MPI_Datatype *datatype, MPI_T_enum *enumtype, char *desc, int *desc_len,
                        int *binding, int *scope);
int MPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                            int *count);
int MPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int MPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int MPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int MPI_T_pvar_get_num(int *num_pvar);
int MPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
                        int *binding, int *readonly, int *continuous, int *atomic);
int MPI_T_pvar_session_create(MPI_T_pvar_session *session);
int MPI_T_pvar_session_free(MPI_T_pvar_session *session);
int MPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
                            MPI_T_pvar_handle *handle, int *count);
int MPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int MPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int MPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int MPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int MPI_T_category_get_num(int *num_cat);
int MPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
                            int *num_cvars, int *num_pvars, int *num_categories);
int MPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int MPI_T_category_get_categories(int cat_index, int len, int indices[]);
int MPI_T_category_changed(int *stamp);
int MPI_T_cvar_get_index(const char *name, int *cvar_index);
int MPI_T_pvar_get_index(const char *name, int var_class, int *pvar_index);
int MPI_T_category_get_index(const char *name, int *cat_index);
int MPIX_Comm_failure_ack(MPI_Comm comm);
int MPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int MPIX_Comm_revoke(MPI_Comm comm);
int MPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int MPIX_Comm_agree(MPI_Comm comm, int *flag);
# 1561 "/usr/local/include/mpi.h" 3
int PMPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
              MPI_Comm comm) ;
int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
               MPI_Comm comm) ;
int PMPI_Buffer_attach(void *buffer, int size);
int PMPI_Buffer_detach(void *buffer_addr, int *size);
int PMPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Wait(MPI_Request *request, MPI_Status *status);
int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int PMPI_Request_free(MPI_Request *request);
int PMPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
int PMPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
int PMPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int PMPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int PMPI_Cancel(MPI_Request *request);
int PMPI_Test_cancelled(const MPI_Status *status, int *flag);
int PMPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
int PMPI_Start(MPI_Request *request);
int PMPI_Startall(int count, MPI_Request array_of_requests[]);
int PMPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
int PMPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_indexed(int count, const int *array_of_blocklengths,
int PMPI_Type_hindexed(int count, const int *array_of_blocklengths,
int PMPI_Type_struct(int count, const int *array_of_blocklengths,
int PMPI_Address(const void *location, MPI_Aint *address);
int PMPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
int PMPI_Type_size(MPI_Datatype datatype, int *size);
int PMPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
int PMPI_Type_commit(MPI_Datatype *datatype);
int PMPI_Type_free(MPI_Datatype *datatype);
int PMPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
int PMPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
int PMPI_Barrier(MPI_Comm comm);
int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
int PMPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
                 MPI_Comm comm)
int PMPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
int PMPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
int PMPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
int PMPI_Op_free(MPI_Op *op);
int PMPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
              MPI_Comm comm)
int PMPI_Group_size(MPI_Group group, int *size);
int PMPI_Group_rank(MPI_Group group, int *rank);
int PMPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
                               int ranks2[]);
int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
int PMPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
int PMPI_Group_free(MPI_Group *group);
int PMPI_Comm_size(MPI_Comm comm, int *size);
int PMPI_Comm_rank(MPI_Comm comm, int *rank);
int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
int PMPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int PMPI_Comm_free(MPI_Comm *comm);
int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
int PMPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
int PMPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
int PMPI_Keyval_free(int *keyval);
int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
int PMPI_Attr_delete(MPI_Comm comm, int keyval);
int PMPI_Topo_test(MPI_Comm comm, int *status);
int PMPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
int PMPI_Dims_create(int nnodes, int ndims, int dims[]);
int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
int PMPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
int PMPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
int PMPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
int PMPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
int PMPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
int PMPI_Get_processor_name(char *name, int *resultlen);
int PMPI_Get_version(int *version, int *subversion);
int PMPI_Get_library_version(char *version, int *resultlen);
int PMPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
int PMPI_Error_string(int errorcode, char *string, int *resultlen);
int PMPI_Error_class(int errorcode, int *errorclass);
double PMPI_Wtime(void);
double PMPI_Wtick(void);
int PMPI_Init(int *argc, char ***argv);
int PMPI_Finalize(void);
int PMPI_Initialized(int *flag);
int PMPI_Abort(MPI_Comm comm, int errorcode);
int PMPI_Pcontrol(const int level, ...);
int PMPI_Close_port(const char *port_name);
int PMPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                     MPI_Comm *newcomm);
int PMPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
                      MPI_Comm *newcomm);
int PMPI_Comm_disconnect(MPI_Comm *comm);
int PMPI_Comm_get_parent(MPI_Comm *parent);
int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
int PMPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
int PMPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
int PMPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
int PMPI_Open_port(MPI_Info info, char *port_name);
int PMPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
int PMPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
int PMPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
int PMPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Win_complete(MPI_Win win);
int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
                    MPI_Win *win);
int PMPI_Win_fence(int assert, MPI_Win win);
int PMPI_Win_free(MPI_Win *win);
int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_test(MPI_Win win, int *flag);
int PMPI_Win_unlock(int rank, MPI_Win win);
int PMPI_Win_wait(MPI_Win win);
int PMPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
                      MPI_Win *win);
int PMPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
int PMPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
int PMPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
int PMPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
int PMPI_Win_detach(MPI_Win win, const void *base);
int PMPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
int PMPI_Win_set_info(MPI_Win win, MPI_Info info);
int PMPI_Get_accumulate(const void *origin_addr, int origin_count,
int PMPI_Fetch_and_op(const void *origin_addr, void *result_addr,
int PMPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
int PMPI_Rput(const void *origin_addr, int origin_count,
int PMPI_Rget(void *origin_addr, int origin_count,
int PMPI_Raccumulate(const void *origin_addr, int origin_count,
int PMPI_Rget_accumulate(const void *origin_addr, int origin_count,
int PMPI_Win_lock_all(int assert, MPI_Win win);
int PMPI_Win_unlock_all(MPI_Win win);
int PMPI_Win_flush(int rank, MPI_Win win);
int PMPI_Win_flush_all(MPI_Win win);
int PMPI_Win_flush_local(int rank, MPI_Win win);
int PMPI_Win_flush_local_all(MPI_Win win);
int PMPI_Win_sync(MPI_Win win);
int PMPI_Add_error_class(int *errorclass);
int PMPI_Add_error_code(int errorclass, int *errorcode);
int PMPI_Add_error_string(int errorcode, const char *string);
int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
                            void *extra_state);
int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int PMPI_Comm_free_keyval(int *comm_keyval);
int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int PMPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
int PMPI_Grequest_complete(MPI_Request request);
int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
int PMPI_Init_thread(int *argc, char ***argv, int required, int *provided);
int PMPI_Is_thread_main(int *flag);
int PMPI_Query_thread(int *provided);
int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
int PMPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
int PMPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
int PMPI_Type_free_keyval(int *type_keyval);
int PMPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
int PMPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
int PMPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
int PMPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
int PMPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
int PMPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
                           void *extra_state);
int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
int PMPI_Win_free_keyval(int *win_keyval);
int PMPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int PMPI_Win_set_name(MPI_Win win, const char *win_name);
int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
int PMPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
int PMPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
int PMPI_Finalized(int *flag);
int PMPI_Free_mem(void *base);
int PMPI_Get_address(const void *location, MPI_Aint *address);
int PMPI_Info_create(MPI_Info *info);
int PMPI_Info_delete(MPI_Info info, const char *key);
int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
int PMPI_Info_free(MPI_Info *info);
int PMPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int PMPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
int PMPI_Info_set(MPI_Info info, const char *key, const char *value);
int PMPI_Pack_external(const char datarep[], const void *inbuf, int incount,
int PMPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
                            MPI_Aint *size);
int PMPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
int PMPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
int PMPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
int PMPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
int PMPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
int PMPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
int PMPI_Type_create_hindexed_block(int count, int blocklength,
int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
int PMPI_Type_create_struct(int count, const int array_of_blocklengths[],
int PMPI_Type_create_subarray(int ndims, const int array_of_sizes[],
int PMPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
int PMPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int PMPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
                      MPI_Op op)
int PMPI_Op_commutative(MPI_Op op, int *commute);
int PMPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
int PMPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
int PMPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
int PMPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
int PMPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
int PMPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
int PMPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
int PMPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
int PMPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
int PMPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
int PMPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
int PMPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
int PMPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
                            MPI_Comm comm);
int PMPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
int PMPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
int PMPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
int PMPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
int PMPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
int PMPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
MPI_Aint PMPI_Aint_add(MPI_Aint base, MPI_Aint disp);
MPI_Aint PMPI_Aint_diff(MPI_Aint addr1, MPI_Aint addr2);
int PMPI_T_init_thread(int required, int *provided);
int PMPI_T_finalize(void);
int PMPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
int PMPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
int PMPI_T_cvar_get_num(int *num_cvar);
int PMPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
int PMPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
                             int *count);
int PMPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
int PMPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
int PMPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
int PMPI_T_pvar_get_num(int *num_pvar);
int PMPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
int PMPI_T_pvar_session_create(MPI_T_pvar_session *session);
int PMPI_T_pvar_session_free(MPI_T_pvar_session *session);
int PMPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
int PMPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
int PMPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
int PMPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
int PMPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
int PMPI_T_category_get_num(int *num_cat);
int PMPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
int PMPI_T_category_get_cvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_pvars(int cat_index, int len, int indices[]);
int PMPI_T_category_get_categories(int cat_index, int len, int indices[]);
int PMPI_T_category_changed(int *stamp);
int PMPI_T_cvar_get_index(const char *name, int *cvar_index);
int PMPI_T_pvar_get_index(const char *name, int var_class, int *pvar_index);
int PMPI_T_category_get_index(const char *name, int *cat_index);
int PMPIX_Comm_failure_ack(MPI_Comm comm);
int PMPIX_Comm_failure_get_acked(MPI_Comm comm, MPI_Group *failedgrp);
int PMPIX_Comm_revoke(MPI_Comm comm);
int PMPIX_Comm_shrink(MPI_Comm comm, MPI_Comm *newcomm);
int PMPIX_Comm_agree(MPI_Comm comm, int *flag);
# 2215 "/usr/local/include/mpi.h" 3
# 1 "/usr/local/include/mpio.h" 1 3
# 13 "/usr/local/include/mpio.h" 3
# 1 "/usr/local/include/mpi.h" 1 3
# 14 "/usr/local/include/mpio.h" 2 3
# 123 "/usr/local/include/mpio.h" 3
int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh);
int MPI_File_close(MPI_File *fh);
int MPI_File_delete(const char *filename, MPI_Info info);
int MPI_File_set_size(MPI_File fh, MPI_Offset size);
int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
int MPI_File_get_group(MPI_File fh, MPI_Group *group);
int MPI_File_get_amode(MPI_File fh, int *amode);
int MPI_File_set_info(MPI_File fh, MPI_Info info);
int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype,
                      const char *datarep, MPI_Info info);
int MPI_File_get_view(MPI_File fh, MPI_Offset *disp, MPI_Datatype *etype, MPI_Datatype *filetype,
                      char *datarep);
int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf, int count,
                         MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void * buf, int count,
int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void *buf, int count,
                       MPI_Datatype datatype, MPI_Request *request)
int MPI_File_read(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_read_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
int MPI_File_write(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Request *request)
int MPI_File_iwrite(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset, MPI_Offset *disp);
int MPI_File_read_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_iread_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_read_ordered(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_write_ordered(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf, int count,
                               MPI_Datatype datatype) ;
int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_write_at_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_all_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_all_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_all_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_ordered_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
int MPI_File_write_ordered_end(MPI_File fh, const void *buf, MPI_Status *status);
int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype, MPI_Aint *extent);
int MPI_Register_datarep(const char *datarep, MPI_Datarep_conversion_function *read_conversion_fn,
    MPI_Datarep_conversion_function *write_conversion_fn,
    MPI_Datarep_extent_function *dtype_file_extent_fn, void *extra_state);
int MPI_File_set_atomicity(MPI_File fh, int flag);
int MPI_File_get_atomicity(MPI_File fh, int *flag);
int MPI_File_sync(MPI_File fh);
# 242 "/usr/local/include/mpio.h" 3
int MPI_File_iread_at_all(MPI_File fh, MPI_Offset offset, void *buf, int count,
int MPI_File_iwrite_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int MPI_File_iread_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int MPI_File_iwrite_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
# 282 "/usr/local/include/mpio.h" 3
MPI_File MPI_File_f2c(MPI_Fint file);
MPI_Fint MPI_File_c2f(MPI_File file);
# 343 "/usr/local/include/mpio.h" 3
int PMPI_File_open(MPI_Comm, const char *, int, MPI_Info, MPI_File *);
int PMPI_File_close(MPI_File *);
int PMPI_File_delete(const char *, MPI_Info);
int PMPI_File_set_size(MPI_File, MPI_Offset);
int PMPI_File_preallocate(MPI_File, MPI_Offset);
int PMPI_File_get_size(MPI_File, MPI_Offset *);
int PMPI_File_get_group(MPI_File, MPI_Group *);
int PMPI_File_get_amode(MPI_File, int *);
int PMPI_File_set_info(MPI_File, MPI_Info);
int PMPI_File_get_info(MPI_File, MPI_Info *);
int PMPI_File_set_view(MPI_File, MPI_Offset,
    MPI_Datatype, MPI_Datatype, const char *, MPI_Info);
int PMPI_File_get_view(MPI_File, MPI_Offset *,
      MPI_Datatype *, MPI_Datatype *, char *);
int PMPI_File_read_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_at_all(MPI_File, MPI_Offset, void *,
int PMPI_File_write_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_write_at_all(MPI_File, MPI_Offset, const void *,
int PMPI_File_iread_at(MPI_File, MPI_Offset, void *,
       int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite_at(MPI_File, MPI_Offset, const void *,
int PMPI_File_read(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_read_all(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_all(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread(MPI_File, void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_iwrite(MPI_File, const void *, int, MPI_Datatype, MPI_Request *)
int PMPI_File_seek(MPI_File, MPI_Offset, int);
int PMPI_File_get_position(MPI_File, MPI_Offset *);
int PMPI_File_get_byte_offset(MPI_File, MPI_Offset, MPI_Offset *);
int PMPI_File_read_shared(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_shared(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_iread_shared(MPI_File, void *, int,
int PMPI_File_iwrite_shared(MPI_File, const void *, int,
int PMPI_File_read_ordered(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_write_ordered(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
int PMPI_File_seek_shared(MPI_File, MPI_Offset, int);
int PMPI_File_get_position_shared(MPI_File, MPI_Offset *);
int PMPI_File_read_at_all_begin(MPI_File, MPI_Offset, void *,
                               int, MPI_Datatype)
int PMPI_File_read_at_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_at_all_begin(MPI_File, MPI_Offset, const void *,
                                 int, MPI_Datatype)
int PMPI_File_write_at_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_all_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_all_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_all_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_all_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_read_ordered_begin(MPI_File, void *, int, MPI_Datatype)
int PMPI_File_read_ordered_end(MPI_File, void *, MPI_Status *);
int PMPI_File_write_ordered_begin(MPI_File, const void *, int, MPI_Datatype)
int PMPI_File_write_ordered_end(MPI_File, const void *, MPI_Status *);
int PMPI_File_get_type_extent(MPI_File, MPI_Datatype, MPI_Aint *);
int PMPI_Register_datarep(const char *,
    MPI_Datarep_conversion_function *,
    MPI_Datarep_extent_function *,
    void *);
int PMPI_File_set_atomicity(MPI_File, int);
int PMPI_File_get_atomicity(MPI_File, int *);
int PMPI_File_sync(MPI_File);
# 471 "/usr/local/include/mpio.h" 3
int PMPI_File_iread_at_all(MPI_File fh, MPI_Offset offset, void *buf, int count,
int PMPI_File_iwrite_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
int PMPI_File_iread_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
int PMPI_File_iwrite_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
# 495 "/usr/local/include/mpio.h" 3
MPI_File PMPI_File_f2c(MPI_Fint);
MPI_Fint PMPI_File_c2f(MPI_File);
# 2216 "/usr/local/include/mpi.h" 2 3
# 2237 "/usr/local/include/mpi.h" 3
typedef int MPIX_Grequest_class;
int MPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
                               MPIX_Grequest_poll_function *poll_fn,
                               MPIX_Grequest_wait_function *wait_fn,
                               MPIX_Grequest_class *greq_class);
int MPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
int MPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
                        MPIX_Grequest_wait_function *wait_fn, void *extra_state,
struct mpixi_mutex_s;
typedef struct mpixi_mutex_s * MPIX_Mutex;
int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int MPIX_Mutex_free(MPIX_Mutex *hdl);
int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
int PMPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
int PMPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
int PMPIX_Mutex_free(MPIX_Mutex *hdl);
int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
# 4 "/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c" 2
int mpich_ver = 30200300;
                Defined "HAVE_MPICH_NUMVERSION" to "30200300"
            Checking for functions [MPI_Alltoallw] in library [] []
              Pushing language Cxx
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.libraries -fopenmp -O3      /tmp/petsc-F9l5hH/config.libraries/conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
char MPI_Alltoallw();
static void _check_MPI_Alltoallw() { MPI_Alltoallw(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPI_Alltoallw();;
  return 0;
                      Pushing language CXX
                      Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
              Popping language Cxx
            Checking for functions [MPI_Type_create_indexed_block] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char MPI_Type_create_indexed_block();
static void _check_MPI_Type_create_indexed_block() { MPI_Type_create_indexed_block(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPI_Type_create_indexed_block();;
  return 0;
            Defined "HAVE_MPI_ALLTOALLW" to "1"
            Checking for functions [MPI_Win_create] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char MPI_Win_create();
static void _check_MPI_Win_create() { MPI_Win_create(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPI_Win_create();;
  return 0;
            Defined "HAVE_MPI_WIN_CREATE" to "1"
            Defined "HAVE_MPI_REPLACE" to "1"
                  Checking for functions [MPI_Comm_spawn MPI_Type_get_envelope MPI_Type_get_extent MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan MPI_Reduce_scatter MPI_Reduce_scatter_block] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char MPI_Comm_spawn();
static void _check_MPI_Comm_spawn() { MPI_Comm_spawn(); }
char MPI_Type_get_envelope();
static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
char MPI_Type_get_extent();
static void _check_MPI_Type_get_extent() { MPI_Type_get_extent(); }
char MPI_Type_dup();
static void _check_MPI_Type_dup() { MPI_Type_dup(); }
char MPI_Init_thread();
static void _check_MPI_Init_thread() { MPI_Init_thread(); }
char MPI_Iallreduce();
static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
char MPI_Ibarrier();
static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
char MPI_Finalized();
static void _check_MPI_Finalized() { MPI_Finalized(); }
char MPI_Exscan();
static void _check_MPI_Exscan() { MPI_Exscan(); }
char MPI_Reduce_scatter();
static void _check_MPI_Reduce_scatter() { MPI_Reduce_scatter(); }
char MPI_Reduce_scatter_block();
static void _check_MPI_Reduce_scatter_block() { MPI_Reduce_scatter_block(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPI_Comm_spawn();
_check_MPI_Type_get_envelope();
_check_MPI_Type_get_extent();
_check_MPI_Type_dup();
_check_MPI_Init_thread();
_check_MPI_Iallreduce();
_check_MPI_Ibarrier();
_check_MPI_Finalized();
_check_MPI_Exscan();
_check_MPI_Reduce_scatter();
_check_MPI_Reduce_scatter_block();;
  return 0;
            Defined "HAVE_MPI_COMM_SPAWN" to "1"
            Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
            Defined "HAVE_MPI_TYPE_GET_EXTENT" to "1"
            Defined "HAVE_MPI_TYPE_DUP" to "1"
            Defined "HAVE_MPI_INIT_THREAD" to "1"
            Defined "HAVE_MPI_IALLREDUCE" to "1"
            Defined "HAVE_MPI_IBARRIER" to "1"
            Defined "HAVE_MPI_FINALIZED" to "1"
            Defined "HAVE_MPI_EXSCAN" to "1"
            Defined "HAVE_MPI_REDUCE_SCATTER" to "1"
            Defined "HAVE_MPI_REDUCE_SCATTER_BLOCK" to "1"
            Checking for functions [MPIX_Iallreduce] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char MPIX_Iallreduce();
static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPIX_Iallreduce();;
  return 0;
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.o: In function `main':
conftest.cc:(.text.startup+0x5): undefined reference to `MPIX_Iallreduce'
collect2: error: ld returned 1 exit status
            Checking for functions [MPIX_Ibarrier] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char MPIX_Ibarrier();
static void _check_MPIX_Ibarrier() { MPIX_Ibarrier(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPIX_Ibarrier();;
  return 0;
stderr:
conftest.cc:(.text.startup+0x5): undefined reference to `MPIX_Ibarrier'
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.packages.MPI/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  -I/usr/local/include /tmp/petsc-F9l5hH/config.packages.MPI/conftest.c
Possible ERROR while running compiler:
stderr:
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.packages.MPI/conftest.c:6:5: warning: unused variable ‘combiner’ [-Wunused-variable]
 int combiner = MPI_COMBINER_DUP;;
Source:
#include <mpi.h>
int main() {
  return 0;
            Defined "HAVE_MPI_COMBINER_DUP" to "1"
stderr:
 int combiner = MPI_COMBINER_CONTIGUOUS;;
Source:
#include <mpi.h>
int main() {
  return 0;
            Defined "HAVE_MPI_COMBINER_CONTIGUOUS" to "1"
            Checking for functions [MPIDI_CH3I_sock_set] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char MPIDI_CH3I_sock_set();
static void _check_MPIDI_CH3I_sock_set() { MPIDI_CH3I_sock_set(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPIDI_CH3I_sock_set();;
  return 0;
stderr:
conftest.cc:(.text.startup+0x5): undefined reference to `MPIDI_CH3I_sock_set'
            Checking for functions [MPIDI_CH3I_sock_fixed_nbc_progress] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char MPIDI_CH3I_sock_fixed_nbc_progress();
static void _check_MPIDI_CH3I_sock_fixed_nbc_progress() { MPIDI_CH3I_sock_fixed_nbc_progress(); }
#ifdef __cplusplus
#endif
int main() {
_check_MPIDI_CH3I_sock_fixed_nbc_progress();;
  return 0;
stderr:
conftest.cc:(.text.startup+0x5): undefined reference to `MPIDI_CH3I_sock_fixed_nbc_progress'
TEST checkSharedLibrary from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:130)
TESTING: checkSharedLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:130)
  Sets flag indicating if MPI libraries are shared or not and
    determines if MPI libraries CANNOT be used by shared libraries
TEST configureMPIEXEC from config.packages.MPI(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/MPI.py:143)
TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:143)
  Checking for mpiexec
                Pushing language C
                Popping language C
Checking for program /usr/local/bin/mpiexec...found
                Defined make macro "MPIEXEC" to "/usr/local/bin/mpiexec"
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int init(int argc,  char *argv[]) {
  int isInitialized;
  MPI_Init(&argc, &argv);
  MPI_Initialized(&isInitialized);
  return (int) isInitialized;
                          Pushing language C
                          Popping language C
Executing: /bin/ar  cr /tmp/petsc-F9l5hH/config.packages.MPI/libconftest.a  /tmp/petsc-F9l5hH/config.packages.MPI/conftest.o ; /bin/ranlib /tmp/petsc-F9l5hH/config.packages.MPI/libconftest.a
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int checkInit(void) {
  int isInitialized;
  if (isInitialized) MPI_Finalize();
                          Pushing language C
                          Popping language C
Successful compile:
Source:
#include <stdio.h>
#include <stdlib.h>
#ifdef PETSC_HAVE_DLFCN_H
#include <dlfcn.h>
#endif
int main() {
  int   argc    = 1;
  char *argv[2] = {(char *) "conftest", NULL};
  void *lib;
  int (*init)(int, char **);
  int (*checkInit)(void);
  lib = dlopen("/tmp/petsc-F9l5hH/config.libraries/lib1.a", RTLD_LAZY);
  if (!lib) {
    fprintf(stderr, "Could not open lib1.so: %s\n", dlerror());
    exit(1);
  init = (int (*)(int, char **)) dlsym(lib, "init");
  if (!init) {
    fprintf(stderr, "Could not find initialization function\n");
    exit(1);
  if (!(*init)(argc, argv)) {
    fprintf(stderr, "Could not initialize library\n");
    exit(1);
  lib = dlopen("/tmp/petsc-F9l5hH/config.libraries/lib2.a", RTLD_LAZY);
  if (!lib) {
    fprintf(stderr, "Could not open lib2.so: %s\n", dlerror());
    exit(1);
  checkInit = (int (*)(void)) dlsym(lib, "checkInit");
  if (!checkInit) {
    fprintf(stderr, "Could not find initialization check function\n");
    exit(1);
  if (!(*checkInit)()) {
    fprintf(stderr, "Did not link with shared library\n");
    exit(2);
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl  -ldl
Testing executable /tmp/petsc-F9l5hH/config.libraries/conftest to see if it can be run
Executing: /usr/local/bin/mpiexec /tmp/petsc-F9l5hH/config.libraries/conftest
ERROR while running executable: Could not execute "/usr/local/bin/mpiexec /tmp/petsc-F9l5hH/config.libraries/conftest":
Could not open lib1.so: /tmp/petsc-F9l5hH/config.libraries/lib1.a: invalid ELF header
            Library was not shared
TEST alternateConfigureLibrary from config.packages.concurrencykit(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.concurrencykit(config/BuildSystem/config/package.py:735)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.mpe(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.mpe(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.ctetgen(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.ctetgen(config/BuildSystem/config/package.py:735)
TEST configureLibrary from config.packages.pthread(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/pthread.py:19)
TESTING: configureLibrary from config.packages.pthread(config/BuildSystem/config/packages/pthread.py:19)
   Checks for pthread_barrier_t, cpu_set_t, and sys/sysctl.h
            Checking for a functional pthread
            Checking for library in Compiler specific search PTHREAD: []
TEST check from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
                Checking for functions [pthread_create] in library [] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char pthread_create();
static void _check_pthread_create() { pthread_create(); }
#ifdef __cplusplus
#endif
int main() {
_check_pthread_create();;
  return 0;
            Checking for headers Compiler specific search PTHREAD: ['/usr/local/include']
TEST checkInclude from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['pthread.h'] in ['/usr/local/include']
                  Checking include with compiler flags var CPPFLAGS ['/usr/local/include']
Executing: mpic++ -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers   -I/usr/local/include /tmp/petsc-F9l5hH/config.headers/conftest.cc
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.cc"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
extern "C" {
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
# 1 "/usr/include/pthread.h" 1 3 4
# 21 "/usr/include/pthread.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 22 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 23 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sched.h" 1 3 4
# 28 "/usr/include/sched.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 29 "/usr/include/sched.h" 2 3 4
# 1 "/usr/include/time.h" 1 3 4
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 35 "/usr/include/sched.h" 2 3 4
typedef __pid_t pid_t;
# 1 "/usr/include/bits/sched.h" 1 3 4
# 72 "/usr/include/bits/sched.h" 3 4
struct sched_param
    int __sched_priority;
extern "C" {
extern int clone (int (*__fn) (void *__arg), void *__child_stack,
    int __flags, void *__arg, ...) throw ();
extern int unshare (int __flags) throw ();
extern int sched_getcpu (void) throw ();
extern int setns (int __fd, int __nstype) throw ();
struct __sched_param
# 118 "/usr/include/bits/sched.h" 3 4
typedef unsigned long int __cpu_mask;
typedef struct
  __cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
# 201 "/usr/include/bits/sched.h" 3 4
extern "C" {
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
  throw ();
extern cpu_set_t *__sched_cpualloc (size_t __count) throw () ;
extern void __sched_cpufree (cpu_set_t *__set) throw ();
# 44 "/usr/include/sched.h" 2 3 4
extern "C" {
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
     throw ();
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) throw ();
extern int sched_setscheduler (__pid_t __pid, int __policy,
          const struct sched_param *__param) throw ();
extern int sched_getscheduler (__pid_t __pid) throw ();
extern int sched_yield (void) throw ();
extern int sched_get_priority_max (int __algorithm) throw ();
extern int sched_get_priority_min (int __algorithm) throw ();
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) throw ();
# 118 "/usr/include/sched.h" 3 4
extern int sched_setaffinity (__pid_t __pid, size_t __cpusetsize,
         const cpu_set_t *__cpuset) throw ();
extern int sched_getaffinity (__pid_t __pid, size_t __cpusetsize,
# 24 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/time.h" 3 4
extern "C" {
# 38 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 86 "/usr/include/bits/time.h" 3 4
# 1 "/usr/include/bits/timex.h" 1 3 4
# 25 "/usr/include/bits/timex.h" 3 4
struct timex
  unsigned int modes;
  __syscall_slong_t offset;
  __syscall_slong_t freq;
  __syscall_slong_t maxerror;
  __syscall_slong_t esterror;
  int status;
  __syscall_slong_t constant;
  __syscall_slong_t precision;
  __syscall_slong_t tolerance;
  struct timeval time;
  __syscall_slong_t tick;
  __syscall_slong_t ppsfreq;
  __syscall_slong_t jitter;
  int shift;
  __syscall_slong_t stabil;
  __syscall_slong_t jitcnt;
  __syscall_slong_t calcnt;
  __syscall_slong_t errcnt;
  __syscall_slong_t stbcnt;
  int tai;
  int :32; int :32; int :32; int :32;
# 87 "/usr/include/bits/time.h" 2 3 4
extern "C" {
extern int clock_adjtime (__clockid_t __clock_id, struct timex *__utx) throw ();
# 42 "/usr/include/time.h" 2 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 131 "/usr/include/time.h" 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) throw ();
extern time_t time (time_t *__timer) throw ();
extern double difftime (time_t __time1, time_t __time0)
     throw () __attribute__ ((__const__));
extern time_t mktime (struct tm *__tp) throw ();
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const char *__restrict __format,
   const struct tm *__restrict __tp) throw ();
extern char *strptime (const char *__restrict __s,
         const char *__restrict __fmt, struct tm *__tp)
     throw ();
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 222 "/usr/include/time.h" 2 3 4
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) throw ();
extern char *strptime_l (const char *__restrict __s,
    const char *__restrict __fmt, struct tm *__tp,
extern struct tm *gmtime (const time_t *__timer) throw ();
extern struct tm *localtime (const time_t *__timer) throw ();
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) throw ();
extern char *ctime (const time_t *__timer) throw ();
extern char *asctime_r (const struct tm *__restrict __tp,
   char *__restrict __buf) throw ();
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) throw ();
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) throw ();
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) throw ();
extern time_t timelocal (struct tm *__tp) throw ();
extern int dysize (int __year) throw () __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) throw ();
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) throw ();
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
     throw ();
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) throw ();
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) throw ();
extern int timer_delete (timer_t __timerid) throw ();
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) throw ();
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
     throw ();
extern int timer_getoverrun (timer_t __timerid) throw ();
extern int timespec_get (struct timespec *__ts, int __base)
     throw () __attribute__ ((__nonnull__ (1)));
# 403 "/usr/include/time.h" 3 4
extern int getdate_err;
# 412 "/usr/include/time.h" 3 4
extern struct tm *getdate (const char *__string);
# 426 "/usr/include/time.h" 3 4
extern int getdate_r (const char *__restrict __string,
        struct tm *__restrict __resbufp);
# 25 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 27 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/bits/setjmp.h" 1 3 4
# 26 "/usr/include/bits/setjmp.h" 3 4
# 27 "/usr/include/bits/setjmp.h" 2 3 4
typedef long int __jmp_buf[8];
# 28 "/usr/include/pthread.h" 2 3 4
# 29 "/usr/include/pthread.h" 2 3 4
enum
  PTHREAD_CREATE_JOINABLE,
  PTHREAD_CREATE_DETACHED
enum
  PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_ADAPTIVE_NP
  PTHREAD_MUTEX_NORMAL = PTHREAD_MUTEX_TIMED_NP,
  PTHREAD_MUTEX_RECURSIVE = PTHREAD_MUTEX_RECURSIVE_NP,
  PTHREAD_MUTEX_ERRORCHECK = PTHREAD_MUTEX_ERRORCHECK_NP,
  PTHREAD_MUTEX_DEFAULT = PTHREAD_MUTEX_NORMAL
  , PTHREAD_MUTEX_FAST_NP = PTHREAD_MUTEX_TIMED_NP
enum
  PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
  PTHREAD_MUTEX_ROBUST,
  PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
enum
  PTHREAD_PRIO_NONE,
  PTHREAD_PRIO_INHERIT,
  PTHREAD_PRIO_PROTECT
# 116 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_RWLOCK_PREFER_READER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NP,
  PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
  PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
# 157 "/usr/include/pthread.h" 3 4
enum
  PTHREAD_INHERIT_SCHED,
  PTHREAD_EXPLICIT_SCHED
enum
  PTHREAD_SCOPE_SYSTEM,
  PTHREAD_SCOPE_PROCESS
enum
  PTHREAD_PROCESS_PRIVATE,
  PTHREAD_PROCESS_SHARED
# 192 "/usr/include/pthread.h" 3 4
struct _pthread_cleanup_buffer
  void (*__routine) (void *);
  void *__arg;
  int __canceltype;
  struct _pthread_cleanup_buffer *__prev;
enum
  PTHREAD_CANCEL_ENABLE,
  PTHREAD_CANCEL_DISABLE
enum
  PTHREAD_CANCEL_DEFERRED,
  PTHREAD_CANCEL_ASYNCHRONOUS
# 230 "/usr/include/pthread.h" 3 4
extern "C" {
extern int pthread_create (pthread_t *__restrict __newthread,
      const pthread_attr_t *__restrict __attr,
      void *(*__start_routine) (void *),
      void *__restrict __arg) throw () __attribute__ ((__nonnull__ (1, 3)));
extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
extern int pthread_join (pthread_t __th, void **__thread_return);
extern int pthread_tryjoin_np (pthread_t __th, void **__thread_return) throw ();
extern int pthread_timedjoin_np (pthread_t __th, void **__thread_return,
     const struct timespec *__abstime);
extern int pthread_detach (pthread_t __th) throw ();
extern pthread_t pthread_self (void) throw () __attribute__ ((__const__));
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2)
extern int pthread_attr_init (pthread_attr_t *__attr) throw () __attribute__ ((__nonnull__ (1)));
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
     int *__detachstate)
     throw () __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
     int __detachstate)
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
          size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
          size_t __guardsize)
extern int pthread_attr_getschedparam (const pthread_attr_t *__restrict __attr,
           struct sched_param *__restrict __param)
extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
           const struct sched_param *__restrict
           __param) throw () __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_attr_getschedpolicy (const pthread_attr_t *__restrict
     __attr, int *__restrict __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (const pthread_attr_t *__restrict
      __attr, int *__restrict __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
      int __inherit)
extern int pthread_attr_getscope (const pthread_attr_t *__restrict __attr,
      int *__restrict __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (const pthread_attr_t *__restrict
          __attr, void **__restrict __stackaddr)
     throw () __attribute__ ((__nonnull__ (1, 2))) __attribute__ ((__deprecated__));
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
          void *__stackaddr)
     throw () __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__));
extern int pthread_attr_getstacksize (const pthread_attr_t *__restrict
          __attr, size_t *__restrict __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
          size_t __stacksize)
extern int pthread_attr_getstack (const pthread_attr_t *__restrict __attr,
      void **__restrict __stackaddr,
     throw () __attribute__ ((__nonnull__ (1, 2, 3)));
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
      size_t __stacksize) throw () __attribute__ ((__nonnull__ (1)));
extern int pthread_attr_setaffinity_np (pthread_attr_t *__attr,
extern int pthread_attr_getaffinity_np (const pthread_attr_t *__attr,
extern int pthread_getattr_default_np (pthread_attr_t *__attr)
extern int pthread_setattr_default_np (const pthread_attr_t *__attr)
extern int pthread_getattr_np (pthread_t __th, pthread_attr_t *__attr)
     throw () __attribute__ ((__nonnull__ (2)));
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
     throw () __attribute__ ((__nonnull__ (3)));
extern int pthread_getschedparam (pthread_t __target_thread,
      int *__restrict __policy,
     throw () __attribute__ ((__nonnull__ (2, 3)));
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
     throw ();
extern int pthread_getname_np (pthread_t __target_thread, char *__buf,
          size_t __buflen)
extern int pthread_setname_np (pthread_t __target_thread, const char *__name)
extern int pthread_getconcurrency (void) throw ();
extern int pthread_setconcurrency (int __level) throw ();
extern int pthread_yield (void) throw ();
extern int pthread_setaffinity_np (pthread_t __th, size_t __cpusetsize,
extern int pthread_getaffinity_np (pthread_t __th, size_t __cpusetsize,
# 496 "/usr/include/pthread.h" 3 4
extern int pthread_once (pthread_once_t *__once_control,
    void (*__init_routine) (void)) __attribute__ ((__nonnull__ (1, 2)));
# 508 "/usr/include/pthread.h" 3 4
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
  struct
    __jmp_buf __cancel_jmp_buf;
    int __mask_was_saved;
  } __cancel_jmp_buf[1];
  void *__pad[4];
} __pthread_unwind_buf_t __attribute__ ((__aligned__));
# 542 "/usr/include/pthread.h" 3 4
struct __pthread_cleanup_frame
  void (*__cancel_routine) (void *);
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
class __pthread_cleanup_class
  void *__cancel_arg;
  int __do_it;
  int __cancel_type;
 public:
  __pthread_cleanup_class (void (*__fct) (void *), void *__arg)
    : __cancel_routine (__fct), __cancel_arg (__arg), __do_it (1) { }
  ~__pthread_cleanup_class () { if (__do_it) __cancel_routine (__cancel_arg); }
  void __setdoit (int __newval) { __do_it = __newval; }
  void __defer () { pthread_setcanceltype (PTHREAD_CANCEL_DEFERRED,
        &__cancel_type); }
  void __restore () const { pthread_setcanceltype (__cancel_type, 0); }
# 744 "/usr/include/pthread.h" 3 4
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) throw ();
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
          const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
        const struct timespec *__restrict
        __abstime) throw () __attribute__ ((__nonnull__ (1, 2)));
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
extern int pthread_mutex_getprioceiling (const pthread_mutex_t *
      __restrict __mutex,
      int *__restrict __prioceiling)
extern int pthread_mutex_setprioceiling (pthread_mutex_t *__restrict __mutex,
      int __prioceiling,
      int *__restrict __old_ceiling)
extern int pthread_mutex_consistent (pthread_mutex_t *__mutex)
extern int pthread_mutex_consistent_np (pthread_mutex_t *__mutex)
# 808 "/usr/include/pthread.h" 3 4
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
      __restrict __attr,
      int *__restrict __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
      int __pshared)
extern int pthread_mutexattr_gettype (const pthread_mutexattr_t *__restrict
          __attr, int *__restrict __kind)
extern int pthread_mutexattr_settype (pthread_mutexattr_t *__attr, int __kind)
extern int pthread_mutexattr_getprotocol (const pthread_mutexattr_t *
       __restrict __attr,
       int *__restrict __protocol)
extern int pthread_mutexattr_setprotocol (pthread_mutexattr_t *__attr,
       int __protocol)
extern int pthread_mutexattr_getprioceiling (const pthread_mutexattr_t *
          __restrict __attr,
extern int pthread_mutexattr_setprioceiling (pthread_mutexattr_t *__attr,
          int __prioceiling)
extern int pthread_mutexattr_getrobust (const pthread_mutexattr_t *__attr,
     int *__robustness)
extern int pthread_mutexattr_getrobust_np (const pthread_mutexattr_t *__attr,
        int *__robustness)
extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
     int __robustness)
extern int pthread_mutexattr_setrobust_np (pthread_mutexattr_t *__attr,
        int __robustness)
# 890 "/usr/include/pthread.h" 3 4
extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
    const pthread_rwlockattr_t *__restrict
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
       __restrict __attr,
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
       int __pshared)
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
       __restrict __attr,
       int *__restrict __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
       int __pref) throw () __attribute__ ((__nonnull__ (1)));
extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
         const pthread_condattr_t *__restrict __cond_attr)
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
         pthread_mutex_t *__restrict __mutex)
# 1002 "/usr/include/pthread.h" 3 4
extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
       const struct timespec *__restrict __abstime)
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (const pthread_condattr_t *
     __restrict __attr,
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
     int __pshared) throw () __attribute__ ((__nonnull__ (1)));
extern int pthread_condattr_getclock (const pthread_condattr_t *
          __restrict __attr,
          __clockid_t *__restrict __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
          __clockid_t __clock_id)
# 1046 "/usr/include/pthread.h" 3 4
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
     const pthread_barrierattr_t *__restrict
     __attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
        __restrict __attr,
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
        int __pshared)
# 1113 "/usr/include/pthread.h" 3 4
extern int pthread_key_create (pthread_key_t *__key,
          void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) throw ();
extern void *pthread_getspecific (pthread_key_t __key) throw ();
extern int pthread_setspecific (pthread_key_t __key,
    const void *__pointer) throw () ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
      __clockid_t *__clock_id)
# 1147 "/usr/include/pthread.h" 3 4
extern int pthread_atfork (void (*__prepare) (void),
      void (*__parent) (void),
      void (*__child) (void)) throw ();
# 1161 "/usr/include/pthread.h" 3 4
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['pthread.h'] in ['/usr/local/include']
                      All intermediate test results are stored in /tmp/petsc-F9l5hH/config.packages.pthread
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.packages.pthread/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.packages.pthread -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.packages.pthread/conftest.c
stderr:
/tmp/petsc-F9l5hH/config.packages.pthread/conftest.c: In function ‘main’:
/tmp/petsc-F9l5hH/config.packages.pthread/conftest.c:6:20: warning: unused variable ‘a’ [-Wunused-variable]
 pthread_barrier_t *a;
Source:
#include <pthread.h>
int main() {
  return 0;
            Defined "HAVE_PTHREAD_BARRIER_T" to "1"
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.packages.pthread/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI -I/tmp/petsc-F9l5hH/config.packages.pthread    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.packages.pthread/conftest.c
stderr:
/tmp/petsc-F9l5hH/config.packages.pthread/conftest.c:6:12: warning: unused variable ‘a’ [-Wunused-variable]
 cpu_set_t *a;
Source:
#include <sched.h>
int main() {
cpu_set_t *a;
  return 0;
            Defined "HAVE_SCHED_CPU_SET_T" to "1"
Executing: mpicc -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.packages.pthread  /tmp/petsc-F9l5hH/config.packages.pthread/conftest.c
stdout:
# 1 "/tmp/petsc-F9l5hH/config.packages.pthread/conftest.c"
# 1 "<built-in>"
# 1 "/tmp/petsc-F9l5hH/config.packages.pthread/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.packages.pthread/conftest.c" 2
# 1 "/tmp/petsc-F9l5hH/config.packages.pthread/conffix.h" 1
# 3 "/tmp/petsc-F9l5hH/config.packages.pthread/conftest.c" 2
# 1 "/usr/include/sys/sysctl.h" 1 3 4
# 21 "/usr/include/sys/sysctl.h" 3 4
# 22 "/usr/include/sys/sysctl.h" 2 3 4
# 24 "/usr/include/sys/sysctl.h" 2 3 4
# 43 "/usr/include/sys/sysctl.h" 3 4
# 1 "/usr/include/linux/sysctl.h" 1 3 4
# 25 "/usr/include/linux/sysctl.h" 3 4
# 1 "/usr/include/linux/kernel.h" 1 3 4
# 26 "/usr/include/linux/sysctl.h" 2 3 4
# 1 "/usr/include/linux/types.h" 1 3 4
# 27 "/usr/include/linux/sysctl.h" 2 3 4
struct completion;
struct __sysctl_args {
 int *name;
 int nlen;
 void *oldval;
 size_t *oldlenp;
 void *newval;
 size_t newlen;
 unsigned long __unused[4];
enum
 CTL_KERN=1,
 CTL_VM=2,
 CTL_NET=3,
 CTL_PROC=4,
 CTL_FS=5,
 CTL_DEBUG=6,
 CTL_DEV=7,
 CTL_BUS=8,
 CTL_ABI=9,
 CTL_CPU=10,
 CTL_ARLAN=254,
 CTL_S390DBF=5677,
 CTL_SUNRPC=7249,
 CTL_PM=9899,
 CTL_FRV=9898,
enum
 CTL_BUS_ISA=1
enum
 INOTIFY_MAX_USER_INSTANCES=1,
 INOTIFY_MAX_USER_WATCHES=2,
 INOTIFY_MAX_QUEUED_EVENTS=3
enum
 KERN_OSTYPE=1,
 KERN_OSRELEASE=2,
 KERN_OSREV=3,
 KERN_VERSION=4,
 KERN_SECUREMASK=5,
 KERN_PROF=6,
 KERN_NODENAME=7,
 KERN_DOMAINNAME=8,
 KERN_PANIC=15,
 KERN_REALROOTDEV=16,
 KERN_SPARC_REBOOT=21,
 KERN_CTLALTDEL=22,
 KERN_PRINTK=23,
 KERN_NAMETRANS=24,
 KERN_PPC_HTABRECLAIM=25,
 KERN_PPC_ZEROPAGED=26,
 KERN_PPC_POWERSAVE_NAP=27,
 KERN_MODPROBE=28,
 KERN_SG_BIG_BUFF=29,
 KERN_ACCT=30,
 KERN_PPC_L2CR=31,
 KERN_RTSIGNR=32,
 KERN_RTSIGMAX=33,
 KERN_SHMMAX=34,
 KERN_MSGMAX=35,
 KERN_MSGMNB=36,
 KERN_MSGPOOL=37,
 KERN_SYSRQ=38,
 KERN_MAX_THREADS=39,
  KERN_RANDOM=40,
  KERN_SHMALL=41,
  KERN_MSGMNI=42,
  KERN_SEM=43,
  KERN_SPARC_STOP_A=44,
  KERN_SHMMNI=45,
 KERN_OVERFLOWUID=46,
 KERN_OVERFLOWGID=47,
 KERN_SHMPATH=48,
 KERN_HOTPLUG=49,
 KERN_IEEE_EMULATION_WARNINGS=50,
 KERN_S390_USER_DEBUG_LOGGING=51,
 KERN_CORE_USES_PID=52,
 KERN_TAINTED=53,
 KERN_CADPID=54,
 KERN_PIDMAX=55,
   KERN_CORE_PATTERN=56,
 KERN_PANIC_ON_OOPS=57,
 KERN_HPPA_PWRSW=58,
 KERN_HPPA_UNALIGNED=59,
 KERN_PRINTK_RATELIMIT=60,
 KERN_PRINTK_RATELIMIT_BURST=61,
 KERN_PTY=62,
 KERN_NGROUPS_MAX=63,
 KERN_SPARC_SCONS_PWROFF=64,
 KERN_HZ_TIMER=65,
 KERN_UNKNOWN_NMI_PANIC=66,
 KERN_BOOTLOADER_TYPE=67,
 KERN_RANDOMIZE=68,
 KERN_SETUID_DUMPABLE=69,
 KERN_SPIN_RETRY=70,
 KERN_ACPI_VIDEO_FLAGS=71,
 KERN_IA64_UNALIGNED=72,
 KERN_COMPAT_LOG=73,
 KERN_MAX_LOCK_DEPTH=74,
 KERN_NMI_WATCHDOG=75,
 KERN_PANIC_ON_NMI=76,
 KERN_PANIC_ON_WARN=77,
enum
 VM_UNUSED1=1,
 VM_UNUSED2=2,
 VM_UNUSED3=3,
 VM_UNUSED4=4,
 VM_OVERCOMMIT_MEMORY=5,
 VM_UNUSED5=6,
 VM_UNUSED7=7,
 VM_UNUSED8=8,
 VM_UNUSED9=9,
 VM_PAGE_CLUSTER=10,
 VM_DIRTY_BACKGROUND=11,
 VM_DIRTY_RATIO=12,
 VM_DIRTY_WB_CS=13,
 VM_DIRTY_EXPIRE_CS=14,
 VM_NR_PDFLUSH_THREADS=15,
 VM_OVERCOMMIT_RATIO=16,
 VM_PAGEBUF=17,
 VM_HUGETLB_PAGES=18,
 VM_SWAPPINESS=19,
 VM_LOWMEM_RESERVE_RATIO=20,
 VM_MIN_FREE_KBYTES=21,
 VM_MAX_MAP_COUNT=22,
 VM_LAPTOP_MODE=23,
 VM_BLOCK_DUMP=24,
 VM_HUGETLB_GROUP=25,
 VM_VFS_CACHE_PRESSURE=26,
 VM_LEGACY_VA_LAYOUT=27,
 VM_SWAP_TOKEN_TIMEOUT=28,
 VM_DROP_PAGECACHE=29,
 VM_PERCPU_PAGELIST_FRACTION=30,
 VM_ZONE_RECLAIM_MODE=31,
 VM_MIN_UNMAPPED=32,
 VM_PANIC_ON_OOM=33,
 VM_VDSO_ENABLED=34,
 VM_MIN_SLAB=35,
enum
 NET_CORE=1,
 NET_ETHER=2,
 NET_802=3,
 NET_UNIX=4,
 NET_IPV4=5,
 NET_IPX=6,
 NET_ATALK=7,
 NET_NETROM=8,
 NET_AX25=9,
 NET_BRIDGE=10,
 NET_ROSE=11,
 NET_IPV6=12,
 NET_X25=13,
 NET_TR=14,
 NET_DECNET=15,
 NET_ECONET=16,
 NET_SCTP=17,
 NET_LLC=18,
 NET_NETFILTER=19,
 NET_DCCP=20,
 NET_IRDA=412,
enum
 RANDOM_POOLSIZE=1,
 RANDOM_ENTROPY_COUNT=2,
 RANDOM_READ_THRESH=3,
 RANDOM_WRITE_THRESH=4,
 RANDOM_BOOT_ID=5,
 RANDOM_UUID=6
enum
 PTY_MAX=1,
 PTY_NR=2
enum
 BUS_ISA_MEM_BASE=1,
 BUS_ISA_PORT_BASE=2,
 BUS_ISA_PORT_SHIFT=3
enum
 NET_CORE_WMEM_MAX=1,
 NET_CORE_RMEM_MAX=2,
 NET_CORE_WMEM_DEFAULT=3,
 NET_CORE_RMEM_DEFAULT=4,
 NET_CORE_MAX_BACKLOG=6,
 NET_CORE_FASTROUTE=7,
 NET_CORE_MSG_COST=8,
 NET_CORE_MSG_BURST=9,
 NET_CORE_OPTMEM_MAX=10,
 NET_CORE_HOT_LIST_LENGTH=11,
 NET_CORE_DIVERT_VERSION=12,
 NET_CORE_NO_CONG_THRESH=13,
 NET_CORE_NO_CONG=14,
 NET_CORE_LO_CONG=15,
 NET_CORE_MOD_CONG=16,
 NET_CORE_DEV_WEIGHT=17,
 NET_CORE_SOMAXCONN=18,
 NET_CORE_BUDGET=19,
 NET_CORE_AEVENT_ETIME=20,
 NET_CORE_AEVENT_RSEQTH=21,
 NET_CORE_WARNINGS=22,
enum
 NET_UNIX_DESTROY_DELAY=1,
 NET_UNIX_DELETE_DELAY=2,
 NET_UNIX_MAX_DGRAM_QLEN=3,
enum
 NET_NF_CONNTRACK_MAX=1,
 NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
 NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
 NET_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
 NET_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
 NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
 NET_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
 NET_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
 NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
 NET_NF_CONNTRACK_UDP_TIMEOUT=10,
 NET_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
 NET_NF_CONNTRACK_ICMP_TIMEOUT=12,
 NET_NF_CONNTRACK_GENERIC_TIMEOUT=13,
 NET_NF_CONNTRACK_BUCKETS=14,
 NET_NF_CONNTRACK_LOG_INVALID=15,
 NET_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
 NET_NF_CONNTRACK_TCP_LOOSE=17,
 NET_NF_CONNTRACK_TCP_BE_LIBERAL=18,
 NET_NF_CONNTRACK_TCP_MAX_RETRANS=19,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
 NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
 NET_NF_CONNTRACK_COUNT=27,
 NET_NF_CONNTRACK_ICMPV6_TIMEOUT=28,
 NET_NF_CONNTRACK_FRAG6_TIMEOUT=29,
 NET_NF_CONNTRACK_FRAG6_LOW_THRESH=30,
 NET_NF_CONNTRACK_FRAG6_HIGH_THRESH=31,
 NET_NF_CONNTRACK_CHECKSUM=32,
enum
 NET_IPV4_FORWARD=8,
 NET_IPV4_DYNADDR=9,
 NET_IPV4_CONF=16,
 NET_IPV4_NEIGH=17,
 NET_IPV4_ROUTE=18,
 NET_IPV4_FIB_HASH=19,
 NET_IPV4_NETFILTER=20,
 NET_IPV4_TCP_TIMESTAMPS=33,
 NET_IPV4_TCP_WINDOW_SCALING=34,
 NET_IPV4_TCP_SACK=35,
 NET_IPV4_TCP_RETRANS_COLLAPSE=36,
 NET_IPV4_DEFAULT_TTL=37,
 NET_IPV4_AUTOCONFIG=38,
 NET_IPV4_NO_PMTU_DISC=39,
 NET_IPV4_TCP_SYN_RETRIES=40,
 NET_IPV4_IPFRAG_HIGH_THRESH=41,
 NET_IPV4_IPFRAG_LOW_THRESH=42,
 NET_IPV4_IPFRAG_TIME=43,
 NET_IPV4_TCP_MAX_KA_PROBES=44,
 NET_IPV4_TCP_KEEPALIVE_TIME=45,
 NET_IPV4_TCP_KEEPALIVE_PROBES=46,
 NET_IPV4_TCP_RETRIES1=47,
 NET_IPV4_TCP_RETRIES2=48,
 NET_IPV4_TCP_FIN_TIMEOUT=49,
 NET_IPV4_IP_MASQ_DEBUG=50,
 NET_TCP_SYNCOOKIES=51,
 NET_TCP_STDURG=52,
 NET_TCP_RFC1337=53,
 NET_TCP_SYN_TAILDROP=54,
 NET_TCP_MAX_SYN_BACKLOG=55,
 NET_IPV4_LOCAL_PORT_RANGE=56,
 NET_IPV4_ICMP_ECHO_IGNORE_ALL=57,
 NET_IPV4_ICMP_ECHO_IGNORE_BROADCASTS=58,
 NET_IPV4_ICMP_SOURCEQUENCH_RATE=59,
 NET_IPV4_ICMP_DESTUNREACH_RATE=60,
 NET_IPV4_ICMP_TIMEEXCEED_RATE=61,
 NET_IPV4_ICMP_PARAMPROB_RATE=62,
 NET_IPV4_ICMP_ECHOREPLY_RATE=63,
 NET_IPV4_ICMP_IGNORE_BOGUS_ERROR_RESPONSES=64,
 NET_IPV4_IGMP_MAX_MEMBERSHIPS=65,
 NET_TCP_TW_RECYCLE=66,
 NET_IPV4_ALWAYS_DEFRAG=67,
 NET_IPV4_TCP_KEEPALIVE_INTVL=68,
 NET_IPV4_INET_PEER_THRESHOLD=69,
 NET_IPV4_INET_PEER_MINTTL=70,
 NET_IPV4_INET_PEER_MAXTTL=71,
 NET_IPV4_INET_PEER_GC_MINTIME=72,
 NET_IPV4_INET_PEER_GC_MAXTIME=73,
 NET_TCP_ORPHAN_RETRIES=74,
 NET_TCP_ABORT_ON_OVERFLOW=75,
 NET_TCP_SYNACK_RETRIES=76,
 NET_TCP_MAX_ORPHANS=77,
 NET_TCP_MAX_TW_BUCKETS=78,
 NET_TCP_FACK=79,
 NET_TCP_REORDERING=80,
 NET_TCP_ECN=81,
 NET_TCP_DSACK=82,
 NET_TCP_MEM=83,
 NET_TCP_WMEM=84,
 NET_TCP_RMEM=85,
 NET_TCP_APP_WIN=86,
 NET_TCP_ADV_WIN_SCALE=87,
 NET_IPV4_NONLOCAL_BIND=88,
 NET_IPV4_ICMP_RATELIMIT=89,
 NET_IPV4_ICMP_RATEMASK=90,
 NET_TCP_TW_REUSE=91,
 NET_TCP_FRTO=92,
 NET_TCP_LOW_LATENCY=93,
 NET_IPV4_IPFRAG_SECRET_INTERVAL=94,
 NET_IPV4_IGMP_MAX_MSF=96,
 NET_TCP_NO_METRICS_SAVE=97,
 NET_TCP_DEFAULT_WIN_SCALE=105,
 NET_TCP_MODERATE_RCVBUF=106,
 NET_TCP_TSO_WIN_DIVISOR=107,
 NET_TCP_BIC_BETA=108,
 NET_IPV4_ICMP_ERRORS_USE_INBOUND_IFADDR=109,
 NET_TCP_CONG_CONTROL=110,
 NET_TCP_ABC=111,
 NET_IPV4_IPFRAG_MAX_DIST=112,
  NET_TCP_MTU_PROBING=113,
 NET_TCP_BASE_MSS=114,
 NET_IPV4_TCP_WORKAROUND_SIGNED_WINDOWS=115,
 NET_TCP_DMA_COPYBREAK=116,
 NET_TCP_SLOW_START_AFTER_IDLE=117,
 NET_CIPSOV4_CACHE_ENABLE=118,
 NET_CIPSOV4_CACHE_BUCKET_SIZE=119,
 NET_CIPSOV4_RBM_OPTFMT=120,
 NET_CIPSOV4_RBM_STRICTVALID=121,
 NET_TCP_AVAIL_CONG_CONTROL=122,
 NET_TCP_ALLOWED_CONG_CONTROL=123,
 NET_TCP_MAX_SSTHRESH=124,
 NET_TCP_FRTO_RESPONSE=125,
enum {
 NET_IPV4_ROUTE_FLUSH=1,
 NET_IPV4_ROUTE_MIN_DELAY=2,
 NET_IPV4_ROUTE_MAX_DELAY=3,
 NET_IPV4_ROUTE_GC_THRESH=4,
 NET_IPV4_ROUTE_MAX_SIZE=5,
 NET_IPV4_ROUTE_GC_MIN_INTERVAL=6,
 NET_IPV4_ROUTE_GC_TIMEOUT=7,
 NET_IPV4_ROUTE_GC_INTERVAL=8,
 NET_IPV4_ROUTE_REDIRECT_LOAD=9,
 NET_IPV4_ROUTE_REDIRECT_NUMBER=10,
 NET_IPV4_ROUTE_REDIRECT_SILENCE=11,
 NET_IPV4_ROUTE_ERROR_COST=12,
 NET_IPV4_ROUTE_ERROR_BURST=13,
 NET_IPV4_ROUTE_GC_ELASTICITY=14,
 NET_IPV4_ROUTE_MTU_EXPIRES=15,
 NET_IPV4_ROUTE_MIN_PMTU=16,
 NET_IPV4_ROUTE_MIN_ADVMSS=17,
 NET_IPV4_ROUTE_SECRET_INTERVAL=18,
 NET_IPV4_ROUTE_GC_MIN_INTERVAL_MS=19,
enum
 NET_PROTO_CONF_ALL=-2,
 NET_PROTO_CONF_DEFAULT=-3
enum
 NET_IPV4_CONF_FORWARDING=1,
 NET_IPV4_CONF_MC_FORWARDING=2,
 NET_IPV4_CONF_PROXY_ARP=3,
 NET_IPV4_CONF_ACCEPT_REDIRECTS=4,
 NET_IPV4_CONF_SECURE_REDIRECTS=5,
 NET_IPV4_CONF_SEND_REDIRECTS=6,
 NET_IPV4_CONF_SHARED_MEDIA=7,
 NET_IPV4_CONF_RP_FILTER=8,
 NET_IPV4_CONF_ACCEPT_SOURCE_ROUTE=9,
 NET_IPV4_CONF_BOOTP_RELAY=10,
 NET_IPV4_CONF_LOG_MARTIANS=11,
 NET_IPV4_CONF_TAG=12,
 NET_IPV4_CONF_ARPFILTER=13,
 NET_IPV4_CONF_MEDIUM_ID=14,
 NET_IPV4_CONF_NOXFRM=15,
 NET_IPV4_CONF_NOPOLICY=16,
 NET_IPV4_CONF_FORCE_IGMP_VERSION=17,
 NET_IPV4_CONF_ARP_ANNOUNCE=18,
 NET_IPV4_CONF_ARP_IGNORE=19,
 NET_IPV4_CONF_PROMOTE_SECONDARIES=20,
 NET_IPV4_CONF_ARP_ACCEPT=21,
 NET_IPV4_CONF_ARP_NOTIFY=22,
enum
 NET_IPV4_NF_CONNTRACK_MAX=1,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
 NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT=10,
 NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
 NET_IPV4_NF_CONNTRACK_ICMP_TIMEOUT=12,
 NET_IPV4_NF_CONNTRACK_GENERIC_TIMEOUT=13,
 NET_IPV4_NF_CONNTRACK_BUCKETS=14,
 NET_IPV4_NF_CONNTRACK_LOG_INVALID=15,
 NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
 NET_IPV4_NF_CONNTRACK_TCP_LOOSE=17,
 NET_IPV4_NF_CONNTRACK_TCP_BE_LIBERAL=18,
 NET_IPV4_NF_CONNTRACK_TCP_MAX_RETRANS=19,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
  NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
 NET_IPV4_NF_CONNTRACK_COUNT=27,
 NET_IPV4_NF_CONNTRACK_CHECKSUM=28,
enum {
 NET_IPV6_CONF=16,
 NET_IPV6_NEIGH=17,
 NET_IPV6_ROUTE=18,
 NET_IPV6_ICMP=19,
 NET_IPV6_BINDV6ONLY=20,
 NET_IPV6_IP6FRAG_HIGH_THRESH=21,
 NET_IPV6_IP6FRAG_LOW_THRESH=22,
 NET_IPV6_IP6FRAG_TIME=23,
 NET_IPV6_IP6FRAG_SECRET_INTERVAL=24,
 NET_IPV6_MLD_MAX_MSF=25,
enum {
 NET_IPV6_ROUTE_FLUSH=1,
 NET_IPV6_ROUTE_GC_THRESH=2,
 NET_IPV6_ROUTE_MAX_SIZE=3,
 NET_IPV6_ROUTE_GC_MIN_INTERVAL=4,
 NET_IPV6_ROUTE_GC_TIMEOUT=5,
 NET_IPV6_ROUTE_GC_INTERVAL=6,
 NET_IPV6_ROUTE_GC_ELASTICITY=7,
 NET_IPV6_ROUTE_MTU_EXPIRES=8,
 NET_IPV6_ROUTE_MIN_ADVMSS=9,
 NET_IPV6_ROUTE_GC_MIN_INTERVAL_MS=10
enum {
 NET_IPV6_FORWARDING=1,
 NET_IPV6_HOP_LIMIT=2,
 NET_IPV6_MTU=3,
 NET_IPV6_ACCEPT_RA=4,
 NET_IPV6_ACCEPT_REDIRECTS=5,
 NET_IPV6_AUTOCONF=6,
 NET_IPV6_DAD_TRANSMITS=7,
 NET_IPV6_RTR_SOLICITS=8,
 NET_IPV6_RTR_SOLICIT_INTERVAL=9,
 NET_IPV6_RTR_SOLICIT_DELAY=10,
 NET_IPV6_USE_TEMPADDR=11,
 NET_IPV6_TEMP_VALID_LFT=12,
 NET_IPV6_TEMP_PREFERED_LFT=13,
 NET_IPV6_REGEN_MAX_RETRY=14,
 NET_IPV6_MAX_DESYNC_FACTOR=15,
 NET_IPV6_MAX_ADDRESSES=16,
 NET_IPV6_FORCE_MLD_VERSION=17,
 NET_IPV6_ACCEPT_RA_DEFRTR=18,
 NET_IPV6_ACCEPT_RA_PINFO=19,
 NET_IPV6_ACCEPT_RA_RTR_PREF=20,
 NET_IPV6_RTR_PROBE_INTERVAL=21,
 NET_IPV6_ACCEPT_RA_RT_INFO_MAX_PLEN=22,
 NET_IPV6_PROXY_NDP=23,
 NET_IPV6_ACCEPT_SOURCE_ROUTE=25,
 NET_IPV6_ACCEPT_RA_FROM_LOCAL=26,
 __NET_IPV6_MAX
enum {
 NET_IPV6_ICMP_RATELIMIT=1
enum {
 NET_NEIGH_MCAST_SOLICIT=1,
 NET_NEIGH_UCAST_SOLICIT=2,
 NET_NEIGH_APP_SOLICIT=3,
 NET_NEIGH_RETRANS_TIME=4,
 NET_NEIGH_REACHABLE_TIME=5,
 NET_NEIGH_DELAY_PROBE_TIME=6,
 NET_NEIGH_GC_STALE_TIME=7,
 NET_NEIGH_UNRES_QLEN=8,
 NET_NEIGH_PROXY_QLEN=9,
 NET_NEIGH_ANYCAST_DELAY=10,
 NET_NEIGH_PROXY_DELAY=11,
 NET_NEIGH_LOCKTIME=12,
 NET_NEIGH_GC_INTERVAL=13,
 NET_NEIGH_GC_THRESH1=14,
 NET_NEIGH_GC_THRESH2=15,
 NET_NEIGH_GC_THRESH3=16,
 NET_NEIGH_RETRANS_TIME_MS=17,
 NET_NEIGH_REACHABLE_TIME_MS=18,
enum {
 NET_DCCP_DEFAULT=1,
enum {
 NET_IPX_PPROP_BROADCASTING=1,
 NET_IPX_FORWARDING=2
enum {
 NET_LLC2=1,
 NET_LLC_STATION=2,
enum {
 NET_LLC2_TIMEOUT=1,
enum {
 NET_LLC_STATION_ACK_TIMEOUT=1,
enum {
 NET_LLC2_ACK_TIMEOUT=1,
 NET_LLC2_P_TIMEOUT=2,
 NET_LLC2_REJ_TIMEOUT=3,
 NET_LLC2_BUSY_TIMEOUT=4,
enum {
 NET_ATALK_AARP_EXPIRY_TIME=1,
 NET_ATALK_AARP_TICK_TIME=2,
 NET_ATALK_AARP_RETRANSMIT_LIMIT=3,
 NET_ATALK_AARP_RESOLVE_TIME=4
enum {
 NET_NETROM_DEFAULT_PATH_QUALITY=1,
 NET_NETROM_OBSOLESCENCE_COUNT_INITIALISER=2,
 NET_NETROM_NETWORK_TTL_INITIALISER=3,
 NET_NETROM_TRANSPORT_TIMEOUT=4,
 NET_NETROM_TRANSPORT_MAXIMUM_TRIES=5,
 NET_NETROM_TRANSPORT_ACKNOWLEDGE_DELAY=6,
 NET_NETROM_TRANSPORT_BUSY_DELAY=7,
 NET_NETROM_TRANSPORT_REQUESTED_WINDOW_SIZE=8,
 NET_NETROM_TRANSPORT_NO_ACTIVITY_TIMEOUT=9,
 NET_NETROM_ROUTING_CONTROL=10,
 NET_NETROM_LINK_FAILS_COUNT=11,
 NET_NETROM_RESET=12
enum {
 NET_AX25_IP_DEFAULT_MODE=1,
 NET_AX25_DEFAULT_MODE=2,
 NET_AX25_BACKOFF_TYPE=3,
 NET_AX25_CONNECT_MODE=4,
 NET_AX25_STANDARD_WINDOW=5,
 NET_AX25_EXTENDED_WINDOW=6,
 NET_AX25_T1_TIMEOUT=7,
 NET_AX25_T2_TIMEOUT=8,
 NET_AX25_T3_TIMEOUT=9,
 NET_AX25_IDLE_TIMEOUT=10,
 NET_AX25_N2=11,
 NET_AX25_PACLEN=12,
 NET_AX25_PROTOCOL=13,
 NET_AX25_DAMA_SLAVE_TIMEOUT=14
enum {
 NET_ROSE_RESTART_REQUEST_TIMEOUT=1,
 NET_ROSE_CALL_REQUEST_TIMEOUT=2,
 NET_ROSE_RESET_REQUEST_TIMEOUT=3,
 NET_ROSE_CLEAR_REQUEST_TIMEOUT=4,
 NET_ROSE_ACK_HOLD_BACK_TIMEOUT=5,
 NET_ROSE_ROUTING_CONTROL=6,
 NET_ROSE_LINK_FAIL_TIMEOUT=7,
 NET_ROSE_MAX_VCS=8,
 NET_ROSE_WINDOW_SIZE=9,
 NET_ROSE_NO_ACTIVITY_TIMEOUT=10
enum {
 NET_X25_RESTART_REQUEST_TIMEOUT=1,
 NET_X25_CALL_REQUEST_TIMEOUT=2,
 NET_X25_RESET_REQUEST_TIMEOUT=3,
 NET_X25_CLEAR_REQUEST_TIMEOUT=4,
 NET_X25_ACK_HOLD_BACK_TIMEOUT=5,
 NET_X25_FORWARD=6
enum
 NET_TR_RIF_TIMEOUT=1
enum {
 NET_DECNET_NODE_TYPE = 1,
 NET_DECNET_NODE_ADDRESS = 2,
 NET_DECNET_NODE_NAME = 3,
 NET_DECNET_DEFAULT_DEVICE = 4,
 NET_DECNET_TIME_WAIT = 5,
 NET_DECNET_DN_COUNT = 6,
 NET_DECNET_DI_COUNT = 7,
 NET_DECNET_DR_COUNT = 8,
 NET_DECNET_DST_GC_INTERVAL = 9,
 NET_DECNET_CONF = 10,
 NET_DECNET_NO_FC_MAX_CWND = 11,
 NET_DECNET_MEM = 12,
 NET_DECNET_RMEM = 13,
 NET_DECNET_WMEM = 14,
 NET_DECNET_DEBUG_LEVEL = 255
enum {
 NET_DECNET_CONF_LOOPBACK = -2,
 NET_DECNET_CONF_DDCMP = -3,
 NET_DECNET_CONF_PPP = -4,
 NET_DECNET_CONF_X25 = -5,
 NET_DECNET_CONF_GRE = -6,
 NET_DECNET_CONF_ETHER = -7
enum {
 NET_DECNET_CONF_DEV_PRIORITY = 1,
 NET_DECNET_CONF_DEV_T1 = 2,
 NET_DECNET_CONF_DEV_T2 = 3,
 NET_DECNET_CONF_DEV_T3 = 4,
 NET_DECNET_CONF_DEV_FORWARDING = 5,
 NET_DECNET_CONF_DEV_BLKSIZE = 6,
 NET_DECNET_CONF_DEV_STATE = 7
enum {
 NET_SCTP_RTO_INITIAL = 1,
 NET_SCTP_RTO_MIN = 2,
 NET_SCTP_RTO_MAX = 3,
 NET_SCTP_RTO_ALPHA = 4,
 NET_SCTP_RTO_BETA = 5,
 NET_SCTP_VALID_COOKIE_LIFE = 6,
 NET_SCTP_ASSOCIATION_MAX_RETRANS = 7,
 NET_SCTP_PATH_MAX_RETRANS = 8,
 NET_SCTP_MAX_INIT_RETRANSMITS = 9,
 NET_SCTP_HB_INTERVAL = 10,
 NET_SCTP_PRESERVE_ENABLE = 11,
 NET_SCTP_MAX_BURST = 12,
 NET_SCTP_ADDIP_ENABLE = 13,
 NET_SCTP_PRSCTP_ENABLE = 14,
 NET_SCTP_SNDBUF_POLICY = 15,
 NET_SCTP_SACK_TIMEOUT = 16,
 NET_SCTP_RCVBUF_POLICY = 17,
enum {
 NET_BRIDGE_NF_CALL_ARPTABLES = 1,
 NET_BRIDGE_NF_CALL_IPTABLES = 2,
 NET_BRIDGE_NF_CALL_IP6TABLES = 3,
 NET_BRIDGE_NF_FILTER_VLAN_TAGGED = 4,
 NET_BRIDGE_NF_FILTER_PPPOE_TAGGED = 5,
enum {
 NET_IRDA_DISCOVERY=1,
 NET_IRDA_DEVNAME=2,
 NET_IRDA_DEBUG=3,
 NET_IRDA_FAST_POLL=4,
 NET_IRDA_DISCOVERY_SLOTS=5,
 NET_IRDA_DISCOVERY_TIMEOUT=6,
 NET_IRDA_SLOT_TIMEOUT=7,
 NET_IRDA_MAX_BAUD_RATE=8,
 NET_IRDA_MIN_TX_TURN_TIME=9,
 NET_IRDA_MAX_TX_DATA_SIZE=10,
 NET_IRDA_MAX_TX_WINDOW=11,
 NET_IRDA_MAX_NOREPLY_TIME=12,
 NET_IRDA_WARN_NOREPLY_TIME=13,
 NET_IRDA_LAP_KEEPALIVE_TIME=14,
enum
 FS_NRINODE=1,
 FS_STATINODE=2,
 FS_MAXINODE=3,
 FS_NRDQUOT=4,
 FS_MAXDQUOT=5,
 FS_NRFILE=6,
 FS_MAXFILE=7,
 FS_DENTRY=8,
 FS_NRSUPER=9,
 FS_MAXSUPER=10,
 FS_OVERFLOWUID=11,
 FS_OVERFLOWGID=12,
 FS_LEASES=13,
 FS_DIR_NOTIFY=14,
 FS_LEASE_TIME=15,
 FS_DQSTATS=16,
 FS_XFS=17,
 FS_AIO_NR=18,
 FS_AIO_MAX_NR=19,
 FS_INOTIFY=20,
 FS_OCFS2=988,
enum {
 FS_DQ_LOOKUPS = 1,
 FS_DQ_DROPS = 2,
 FS_DQ_READS = 3,
 FS_DQ_WRITES = 4,
 FS_DQ_CACHE_HITS = 5,
 FS_DQ_ALLOCATED = 6,
 FS_DQ_FREE = 7,
 FS_DQ_SYNCS = 8,
 FS_DQ_WARNINGS = 9,
enum {
 DEV_CDROM=1,
 DEV_HWMON=2,
 DEV_PARPORT=3,
 DEV_RAID=4,
 DEV_MAC_HID=5,
 DEV_SCSI=6,
 DEV_IPMI=7,
enum {
 DEV_CDROM_INFO=1,
 DEV_CDROM_AUTOCLOSE=2,
 DEV_CDROM_AUTOEJECT=3,
 DEV_CDROM_DEBUG=4,
 DEV_CDROM_LOCK=5,
 DEV_CDROM_CHECK_MEDIA=6
enum {
 DEV_PARPORT_DEFAULT=-3
enum {
 DEV_RAID_SPEED_LIMIT_MIN=1,
 DEV_RAID_SPEED_LIMIT_MAX=2
enum {
 DEV_PARPORT_DEFAULT_TIMESLICE=1,
 DEV_PARPORT_DEFAULT_SPINTIME=2
enum {
 DEV_PARPORT_SPINTIME=1,
 DEV_PARPORT_BASE_ADDR=2,
 DEV_PARPORT_IRQ=3,
 DEV_PARPORT_DMA=4,
 DEV_PARPORT_MODES=5,
 DEV_PARPORT_DEVICES=6,
 DEV_PARPORT_AUTOPROBE=16
enum {
 DEV_PARPORT_DEVICES_ACTIVE=-3,
enum {
 DEV_PARPORT_DEVICE_TIMESLICE=1,
enum {
 DEV_MAC_HID_KEYBOARD_SENDS_LINUX_KEYCODES=1,
 DEV_MAC_HID_KEYBOARD_LOCK_KEYCODES=2,
 DEV_MAC_HID_MOUSE_BUTTON_EMULATION=3,
 DEV_MAC_HID_MOUSE_BUTTON2_KEYCODE=4,
 DEV_MAC_HID_MOUSE_BUTTON3_KEYCODE=5,
 DEV_MAC_HID_ADB_MOUSE_SENDS_KEYCODES=6
enum {
 DEV_SCSI_LOGGING_LEVEL=1,
enum {
 DEV_IPMI_POWEROFF_POWERCYCLE=1,
enum
 ABI_DEFHANDLER_COFF=1,
 ABI_DEFHANDLER_ELF=2,
 ABI_DEFHANDLER_LCALL7=3,
 ABI_DEFHANDLER_LIBCSO=4,
 ABI_TRACE=5,
 ABI_FAKE_UTSNAME=6,
# 44 "/usr/include/sys/sysctl.h" 2 3 4
# 63 "/usr/include/sys/sysctl.h" 3 4
# 1 "/usr/include/bits/sysctl.h" 1 3 4
# 64 "/usr/include/sys/sysctl.h" 2 3 4
extern int sysctl (int *__name, int __nlen, void *__oldval,
     size_t *__oldlenp, void *__newval, size_t __newlen) __attribute__ ((__nothrow__ , __leaf__));
            Defined "HAVE_SYS_SYSCTL_H" to "1"
TEST checkSharedLibrary from config.packages.pthread(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:731)
TESTING: checkSharedLibrary from config.packages.pthread(config/BuildSystem/config/package.py:731)
  By default we don't care about checking if the library is shared
TEST alternateConfigureLibrary from config.packages.Mathematica(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.Mathematica(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.tetgen(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.tetgen(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.giflib(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.giflib(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.papi(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.papi(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.sprng(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.sprng(config/BuildSystem/config/package.py:735)
        Pushing language Cxx
TEST configureLibrary from config.packages.valgrind(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:672)
TESTING: configureLibrary from config.packages.valgrind(config/BuildSystem/config/package.py:672)
  Find an installation and check if it can work with PETSc
          Checking for a functional valgrind
          Not checking for library in User specified root directory VALGRIND: [] because no functions given to check for
              No functions to check for in library [] []
          Checking for headers User specified root directory VALGRIND: ['/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/include', '/usr/local/include']
Checking for header files ['valgrind/valgrind.h'] in ['/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/include', '/usr/local/include']
                Checking include with compiler flags var CPPFLAGS ['/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/include', '/usr/local/include']
Executing: mpic++ -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers   -I/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/include -I/usr/local/include /tmp/petsc-F9l5hH/config.headers/conftest.cc
stdout:
# 1 "<built-in>"
extern "C" {
# 1 "/usr/include/valgrind/valgrind.h" 1 3 4
# 95 "/usr/include/valgrind/valgrind.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 98 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 3 4
typedef __gnuc_va_list va_list;
# 96 "/usr/include/valgrind/valgrind.h" 2 3 4
# 390 "/usr/include/valgrind/valgrind.h" 3 4
typedef
   struct {
      unsigned long long int nraddr;
   OrigFn;
# 6111 "/usr/include/valgrind/valgrind.h" 3 4
typedef
   enum { VG_USERREQ__RUNNING_ON_VALGRIND = 0x1001,
          VG_USERREQ__DISCARD_TRANSLATIONS = 0x1002,
          VG_USERREQ__CLIENT_CALL0 = 0x1101,
          VG_USERREQ__CLIENT_CALL1 = 0x1102,
          VG_USERREQ__CLIENT_CALL2 = 0x1103,
          VG_USERREQ__CLIENT_CALL3 = 0x1104,
          VG_USERREQ__COUNT_ERRORS = 0x1201,
          VG_USERREQ__GDB_MONITOR_COMMAND = 0x1202,
          VG_USERREQ__MALLOCLIKE_BLOCK = 0x1301,
          VG_USERREQ__RESIZEINPLACE_BLOCK = 0x130b,
          VG_USERREQ__FREELIKE_BLOCK = 0x1302,
          VG_USERREQ__CREATE_MEMPOOL = 0x1303,
          VG_USERREQ__DESTROY_MEMPOOL = 0x1304,
          VG_USERREQ__MEMPOOL_ALLOC = 0x1305,
          VG_USERREQ__MEMPOOL_FREE = 0x1306,
          VG_USERREQ__MEMPOOL_TRIM = 0x1307,
          VG_USERREQ__MOVE_MEMPOOL = 0x1308,
          VG_USERREQ__MEMPOOL_CHANGE = 0x1309,
          VG_USERREQ__MEMPOOL_EXISTS = 0x130a,
# 6156 "/usr/include/valgrind/valgrind.h" 3 4
          VG_USERREQ__PRINTF = 0x1401,
          VG_USERREQ__PRINTF_BACKTRACE = 0x1402,
          VG_USERREQ__PRINTF_VALIST_BY_REF = 0x1403,
          VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF = 0x1404,
          VG_USERREQ__STACK_REGISTER = 0x1501,
          VG_USERREQ__STACK_DEREGISTER = 0x1502,
          VG_USERREQ__STACK_CHANGE = 0x1503,
          VG_USERREQ__LOAD_PDB_DEBUGINFO = 0x1601,
          VG_USERREQ__MAP_IP_TO_SRCLOC = 0x1701,
          VG_USERREQ__CHANGE_ERR_DISABLEMENT = 0x1801,
          VG_USERREQ__VEX_INIT_FOR_IRI = 0x1901
   } Vg_ClientRequest;
# 6216 "/usr/include/valgrind/valgrind.h" 3 4
static int VALGRIND_PRINTF(const char *format, ...)
   __attribute__((format(__printf__, 1, 2), __unused__));
static int
   unsigned long _qzz_res;
   va_list vargs;
   __builtin_va_start(vargs,format);
   _qzz_res = __extension__ ({ volatile unsigned long long int _zzq_args[6]; volatile unsigned long long int _zzq_result; _zzq_args[0] = (unsigned long long int)(VG_USERREQ__PRINTF_VALIST_BY_REF); _zzq_args[1] = (unsigned long long int)((unsigned long)format); _zzq_args[2] = (unsigned long long int)((unsigned long)&vargs); _zzq_args[3] = (unsigned long long int)(0); _zzq_args[4] = (unsigned long long int)(0); _zzq_args[5] = (unsigned long long int)(0); __asm__ volatile("rolq $3,  %%rdi ; rolq $13, %%rdi\n\t" "rolq $61, %%rdi ; rolq $51, %%rdi\n\t" "xchgq %%rbx,%%rbx" : "=d" (_zzq_result) : "a" (&_zzq_args[0]), "0" (0) : "cc", "memory" ); _zzq_result; })
   __builtin_va_end(vargs);
   return (int)_qzz_res;
static int VALGRIND_PRINTF_BACKTRACE(const char *format, ...)
static int
   va_list vargs;
   _qzz_res = __extension__ ({ volatile unsigned long long int _zzq_args[6]; volatile unsigned long long int _zzq_result; _zzq_args[0] = (unsigned long long int)(VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF); _zzq_args[1] = (unsigned long long int)((unsigned long)format); _zzq_args[2] = (unsigned long long int)((unsigned long)&vargs); _zzq_args[3] = (unsigned long long int)(0); _zzq_args[4] = (unsigned long long int)(0); _zzq_args[5] = (unsigned long long int)(0); __asm__ volatile("rolq $3,  %%rdi ; rolq $13, %%rdi\n\t" "rolq $61, %%rdi ; rolq $51, %%rdi\n\t" "xchgq %%rbx,%%rbx" : "=d" (_zzq_result) : "a" (&_zzq_args[0]), "0" (0) : "cc", "memory" ); _zzq_result; })
Found header files ['valgrind/valgrind.h'] in ['/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/include', '/usr/local/include']
              Popping language Cxx
                  All intermediate test results are stored in /tmp/petsc-F9l5hH/config.packages.valgrind
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.packages.valgrind/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI -I/tmp/petsc-F9l5hH/config.packages.pthread -I/tmp/petsc-F9l5hH/config.packages.valgrind    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  -I/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/include /tmp/petsc-F9l5hH/config.packages.valgrind/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <valgrind/valgrind.h>
int main() {
RUNNING_ON_VALGRIND;
  return 0;
TEST locateC2html from config.packages.c2html(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/c2html.py:33)
TESTING: locateC2html from config.packages.c2html(config/BuildSystem/config/packages/c2html.py:33)
Looking for default C2html executable
Checking for program ./c2html...not found
Checking for program /home/mpovolot/bin/c2html...not found
Checking for program /bin/c2html...not found
Checking for program /usr/bin/c2html...not found
Checking for program /usr/local/bin/c2html...not found
Checking for program /usr/local/visit/bin/c2html...not found
Checking for program /opt/matlab/bin/c2html...not found
Checking for program /home/mpovolot/c2html...not found
Checking for program /home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/bin/win32fe/c2html...not found
TEST alternateConfigureLibrary from config.packages.opengl(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.opengl(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.glut(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.glut(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.PARTY(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.PARTY(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.cgns(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.cgns(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.pami(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.pami(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.Chaco(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.Chaco(config/BuildSystem/config/package.py:735)
      Not a clone of PETSc, don't need Lgrind
TEST alternateConfigureLibrary from config.packages.opengles(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.opengles(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.Matlab(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/Matlab.py:35)
TESTING: alternateConfigureLibrary from config.packages.Matlab(config/BuildSystem/config/packages/Matlab.py:35)
TEST alternateConfigureLibrary from config.packages.MatlabEngine(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.MatlabEngine(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.scientificpython(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.scientificpython(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.fiat(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.fiat(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.Numpy(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.Numpy(config/BuildSystem/config/package.py:735)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.mpi4py(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/mpi4py.py:70)
TESTING: alternateConfigureLibrary from config.packages.mpi4py(config/BuildSystem/config/packages/mpi4py.py:70)
            Defined make rule "mpi4py-build" with dependencies "" and code []
            Defined make rule "mpi4py-install" with dependencies "" and code []
TEST alternateConfigureLibrary from config.packages.petsc4py(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/petsc4py.py:105)
TESTING: alternateConfigureLibrary from config.packages.petsc4py(config/BuildSystem/config/packages/petsc4py.py:105)
            Defined make rule "petsc4py-build" with dependencies "" and code []
            Defined make rule "petsc4py-install" with dependencies "" and code []
TEST configureLibrary from config.packages.ssl(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/ssl.py:23)
TESTING: configureLibrary from config.packages.ssl(config/BuildSystem/config/packages/ssl.py:23)
            Checking for a functional ssl
            Checking for library in Compiler specific search SSL: []
TEST check from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
                Checking for functions [SSLv23_method] in library [] []
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.libraries -fopenmp -O3      /tmp/petsc-F9l5hH/config.libraries/conftest.cc
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
char SSLv23_method();
static void _check_SSLv23_method() { SSLv23_method(); }
#ifdef __cplusplus
#endif
int main() {
_check_SSLv23_method();;
  return 0;
                          Pushing language CXX
                          Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.o: In function `main':
conftest.cc:(.text.startup+0x5): undefined reference to `SSLv23_method'
collect2: error: ld returned 1 exit status
            Checking for library in Compiler specific search SSL: ['libssl.a', 'libcrypto.a']
                Checking for functions [SSLv23_method] in library ['libssl.a', 'libcrypto.a'] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -lssl -lcrypto -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
                  Defined "HAVE_LIBSSL" to "1"
                  Defined "HAVE_LIBCRYPTO" to "1"
            Checking for headers Compiler specific search SSL: ['/usr/local/include']
TEST checkInclude from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['openssl/ssl.h'] in ['/usr/local/include']
                  Checking include with compiler flags var CPPFLAGS ['/usr/local/include']
Executing: mpic++ -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers   -I/usr/local/include /tmp/petsc-F9l5hH/config.headers/conftest.cc
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.cc"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
extern "C" {
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
# 1 "/usr/include/openssl/ssl.h" 1 3 4
# 146 "/usr/include/openssl/ssl.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 34 "/usr/include/openssl/opensslconf.h" 3 4
# 1 "/usr/include/openssl/opensslconf-x86_64.h" 1 3 4
# 12 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
extern "C" {
# 284 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
# 35 "/usr/include/openssl/opensslconf.h" 2 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
extern "C" {
# 313 "/usr/include/openssl/e_os2.h" 3 4
# 147 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/comp.h" 1 3 4
# 1 "/usr/include/openssl/crypto.h" 1 3 4
# 120 "/usr/include/openssl/crypto.h" 3 4
# 1 "/usr/include/stdlib.h" 1 3 4
# 24 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 25 "/usr/include/stdlib.h" 2 3 4
# 33 "/usr/include/stdlib.h" 2 3 4
extern "C" {
# 1 "/usr/include/bits/waitflags.h" 1 3 4
# 42 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/bits/waitstatus.h" 1 3 4
# 64 "/usr/include/bits/waitstatus.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 27 "/usr/include/bits/byteswap.h" 3 4
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 28 "/usr/include/bits/byteswap.h" 2 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 65 "/usr/include/bits/waitstatus.h" 2 3 4
union wait
    int w_status;
    struct
 unsigned int __w_termsig:7;
 unsigned int __w_coredump:1;
 unsigned int __w_retcode:8;
 unsigned int:16;
      } __wait_terminated;
    struct
 unsigned int __w_stopval:8;
 unsigned int __w_stopsig:8;
 unsigned int:16;
      } __wait_stopped;
# 43 "/usr/include/stdlib.h" 2 3 4
# 95 "/usr/include/stdlib.h" 3 4
typedef struct
    int quot;
    int rem;
  } div_t;
typedef struct
    long int quot;
    long int rem;
  } ldiv_t;
__extension__ typedef struct
    long long int quot;
    long long int rem;
  } lldiv_t;
# 139 "/usr/include/stdlib.h" 3 4
extern size_t __ctype_get_mb_cur_max (void) throw () ;
extern double atof (const char *__nptr)
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
__extension__ extern long long int atoll (const char *__nptr)
extern double strtod (const char *__restrict __nptr,
        char **__restrict __endptr)
extern float strtof (const char *__restrict __nptr,
       char **__restrict __endptr) throw () __attribute__ ((__nonnull__ (1)));
extern long double strtold (const char *__restrict __nptr,
extern long int strtol (const char *__restrict __nptr,
   char **__restrict __endptr, int __base)
extern unsigned long int strtoul (const char *__restrict __nptr,
__extension__
extern long long int strtoq (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtouq (const char *__restrict __nptr,
__extension__
extern long long int strtoll (const char *__restrict __nptr,
__extension__
extern unsigned long long int strtoull (const char *__restrict __nptr,
# 235 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/xlocale.h" 1 3 4
# 27 "/usr/include/xlocale.h" 3 4
typedef struct __locale_struct
  struct __locale_data *__locales[13];
  const unsigned short int *__ctype_b;
  const int *__ctype_tolower;
  const int *__ctype_toupper;
  const char *__names[13];
} *__locale_t;
typedef __locale_t locale_t;
# 236 "/usr/include/stdlib.h" 2 3 4
extern long int strtol_l (const char *__restrict __nptr,
     char **__restrict __endptr, int __base,
     __locale_t __loc) throw () __attribute__ ((__nonnull__ (1, 4)));
extern unsigned long int strtoul_l (const char *__restrict __nptr,
        int __base, __locale_t __loc)
__extension__
extern long long int strtoll_l (const char *__restrict __nptr,
    __locale_t __loc)
__extension__
extern unsigned long long int strtoull_l (const char *__restrict __nptr,
extern double strtod_l (const char *__restrict __nptr,
   char **__restrict __endptr, __locale_t __loc)
extern float strtof_l (const char *__restrict __nptr,
extern long double strtold_l (const char *__restrict __nptr,
         __locale_t __loc)
# 305 "/usr/include/stdlib.h" 3 4
extern char *l64a (long int __n) throw () ;
extern long int a64l (const char *__s)
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
extern "C" {
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
typedef __ino64_t ino64_t;
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
typedef __off64_t off64_t;
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
typedef __useconds_t useconds_t;
typedef __suseconds_t suseconds_t;
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 219 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
# 54 "/usr/include/sys/select.h" 3 4
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
extern "C" {
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
extern "C" {
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 262 "/usr/include/sys/types.h" 3 4
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 315 "/usr/include/stdlib.h" 2 3 4
extern long int random (void) throw ();
extern void srandom (unsigned int __seed) throw ();
extern char *initstate (unsigned int __seed, char *__statebuf,
   size_t __statelen) throw () __attribute__ ((__nonnull__ (2)));
extern char *setstate (char *__statebuf) throw () __attribute__ ((__nonnull__ (1)));
struct random_data
    int32_t *fptr;
    int32_t *rptr;
    int32_t *state;
    int rand_type;
    int rand_deg;
    int rand_sep;
    int32_t *end_ptr;
extern int random_r (struct random_data *__restrict __buf,
       int32_t *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
   size_t __statelen,
   struct random_data *__restrict __buf)
     throw () __attribute__ ((__nonnull__ (2, 4)));
extern int setstate_r (char *__restrict __statebuf,
extern int rand (void) throw ();
extern void srand (unsigned int __seed) throw ();
extern int rand_r (unsigned int *__seed) throw ();
extern double drand48 (void) throw ();
extern double erand48 (unsigned short int __xsubi[3]) throw () __attribute__ ((__nonnull__ (1)));
extern long int lrand48 (void) throw ();
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) throw ();
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) throw ();
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) throw () __attribute__ ((__nonnull__ (1)));
struct drand48_data
    unsigned short int __x[3];
    unsigned short int __old_x[3];
    unsigned short int __c;
    unsigned short int __init;
    __extension__ unsigned long long int __a;
extern int drand48_r (struct drand48_data *__restrict __buffer,
        double *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data *__restrict __buffer,
        long int *__restrict __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data *__restrict __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
       struct drand48_data *__buffer) throw () __attribute__ ((__nonnull__ (1, 2)));
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
     throw () __attribute__ ((__warn_unused_result__));
extern void free (void *__ptr) throw ();
extern void cfree (void *__ptr) throw ();
# 1 "/usr/include/alloca.h" 1 3 4
# 24 "/usr/include/alloca.h" 3 4
# 25 "/usr/include/alloca.h" 2 3 4
extern "C" {
extern void *alloca (size_t __size) throw ();
# 493 "/usr/include/stdlib.h" 2 3 4
extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
     throw () __attribute__ ((__nonnull__ (1))) ;
extern void *aligned_alloc (size_t __alignment, size_t __size)
     throw () __attribute__ ((__malloc__)) __attribute__ ((__alloc_size__ (2))) ;
extern void abort (void) throw () __attribute__ ((__noreturn__));
extern int atexit (void (*__func) (void)) throw () __attribute__ ((__nonnull__ (1)));
extern "C++" int at_quick_exit (void (*__func) (void))
     throw () __asm ("at_quick_exit") __attribute__ ((__nonnull__ (1)));
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) throw () __attribute__ ((__noreturn__));
extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
extern char *getenv (const char *__name) throw () __attribute__ ((__nonnull__ (1))) ;
extern char *secure_getenv (const char *__name)
extern int putenv (char *__string) throw () __attribute__ ((__nonnull__ (1)));
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) throw () __attribute__ ((__nonnull__ (1)));
extern int clearenv (void) throw ();
# 606 "/usr/include/stdlib.h" 3 4
extern char *mktemp (char *__template) throw () __attribute__ ((__nonnull__ (1)));
# 619 "/usr/include/stdlib.h" 3 4
extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 629 "/usr/include/stdlib.h" 3 4
extern int mkstemp64 (char *__template) __attribute__ ((__nonnull__ (1))) ;
# 641 "/usr/include/stdlib.h" 3 4
extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
# 651 "/usr/include/stdlib.h" 3 4
extern int mkstemps64 (char *__template, int __suffixlen)
# 662 "/usr/include/stdlib.h" 3 4
extern char *mkdtemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
# 673 "/usr/include/stdlib.h" 3 4
extern int mkostemp (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 683 "/usr/include/stdlib.h" 3 4
extern int mkostemp64 (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
# 693 "/usr/include/stdlib.h" 3 4
extern int mkostemps (char *__template, int __suffixlen, int __flags)
# 705 "/usr/include/stdlib.h" 3 4
extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
extern int system (const char *__command) ;
extern char *canonicalize_file_name (const char *__name)
# 733 "/usr/include/stdlib.h" 3 4
extern char *realpath (const char *__restrict __name,
         char *__restrict __resolved) throw () ;
typedef int (*__compar_fn_t) (const void *, const void *);
typedef __compar_fn_t comparison_fn_t;
typedef int (*__compar_d_fn_t) (const void *, const void *, void *);
extern void *bsearch (const void *__key, const void *__base,
        size_t __nmemb, size_t __size, __compar_fn_t __compar)
     __attribute__ ((__nonnull__ (1, 2, 5))) ;
extern void qsort (void *__base, size_t __nmemb, size_t __size,
     __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
       __compar_d_fn_t __compar, void *__arg)
extern int abs (int __x) throw () __attribute__ ((__const__)) ;
extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
__extension__ extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
__extension__ extern lldiv_t lldiv (long long int __numer,
        long long int __denom)
# 811 "/usr/include/stdlib.h" 3 4
extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign) throw () __attribute__ ((__nonnull__ (3, 4))) ;
extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
extern char *gcvt (double __value, int __ndigit, char *__buf)
     throw () __attribute__ ((__nonnull__ (3))) ;
extern char *qecvt (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
     int *__restrict __sign, char *__restrict __buf,
     size_t __len) throw () __attribute__ ((__nonnull__ (3, 4, 5)));
extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
extern int qecvt_r (long double __value, int __ndigit,
      int *__restrict __decpt, int *__restrict __sign,
      char *__restrict __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) throw ();
extern int mbtowc (wchar_t *__restrict __pwc,
     const char *__restrict __s, size_t __n) throw ();
extern int wctomb (char *__s, wchar_t __wchar) throw ();
extern size_t mbstowcs (wchar_t *__restrict __pwcs,
extern size_t wcstombs (char *__restrict __s,
   const wchar_t *__restrict __pwcs, size_t __n)
     throw ();
extern int rpmatch (const char *__response) throw () __attribute__ ((__nonnull__ (1))) ;
# 898 "/usr/include/stdlib.h" 3 4
extern int getsubopt (char **__restrict __optionp,
        char *const *__restrict __tokens,
        char **__restrict __valuep)
     throw () __attribute__ ((__nonnull__ (1, 2, 3))) ;
extern void setkey (const char *__key) throw () __attribute__ ((__nonnull__ (1)));
extern int posix_openpt (int __oflag) ;
extern int grantpt (int __fd) throw ();
extern int unlockpt (int __fd) throw ();
extern char *ptsname (int __fd) throw () ;
extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
extern int getpt (void);
extern int getloadavg (double __loadavg[], int __nelem)
# 1 "/usr/include/bits/stdlib-float.h" 1 3 4
# 955 "/usr/include/stdlib.h" 2 3 4
# 967 "/usr/include/stdlib.h" 3 4
# 121 "/usr/include/openssl/crypto.h" 2 3 4
extern "C" {
# 123 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 29 "/usr/include/stdio.h" 3 4
extern "C" {
# 34 "/usr/include/stdio.h" 2 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 74 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 31 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 82 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 32 "/usr/include/libio.h" 2 3 4
# 49 "/usr/include/libio.h" 3 4
# 50 "/usr/include/libio.h" 2 3 4
# 144 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 154 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 177 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 245 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 293 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 302 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 338 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
typedef __io_read_fn cookie_read_function_t;
typedef __io_write_fn cookie_write_function_t;
typedef __io_seek_fn cookie_seek_function_t;
typedef __io_close_fn cookie_close_function_t;
typedef struct
  __io_read_fn *read;
  __io_write_fn *write;
  __io_seek_fn *seek;
  __io_close_fn *close;
} _IO_cookie_io_functions_t;
typedef _IO_cookie_io_functions_t cookie_io_functions_t;
struct _IO_cookie_file;
extern void _IO_cookie_init (struct _IO_cookie_file *__cfile, int __read_write,
        void *__cookie, _IO_cookie_io_functions_t __fns);
extern "C" {
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 434 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) throw ();
extern int _IO_ferror (_IO_FILE *__fp) throw ();
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) throw ();
extern void _IO_funlockfile (_IO_FILE *) throw ();
extern int _IO_ftrylockfile (_IO_FILE *) throw ();
# 464 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) throw ();
# 526 "/usr/include/libio.h" 3 4
# 75 "/usr/include/stdio.h" 2 3 4
# 108 "/usr/include/stdio.h" 3 4
typedef _G_fpos_t fpos_t;
typedef _G_fpos64_t fpos64_t;
# 164 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 165 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) throw ();
extern int rename (const char *__old, const char *__new) throw ();
extern int renameat (int __oldfd, const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 205 "/usr/include/stdio.h" 3 4
extern FILE *tmpfile64 (void) ;
extern char *tmpnam (char *__s) throw () ;
extern char *tmpnam_r (char *__s) throw () ;
# 227 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 252 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 262 "/usr/include/stdio.h" 3 4
extern int fcloseall (void);
extern FILE *fopen (const char *__restrict __filename,
      const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
        const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 295 "/usr/include/stdio.h" 3 4
extern FILE *fopen64 (const char *__restrict __filename,
extern FILE *freopen64 (const char *__restrict __filename,
extern FILE *fdopen (int __fd, const char *__modes) throw () ;
extern FILE *fopencookie (void *__restrict __magic_cookie,
     _IO_cookie_io_functions_t __io_funcs) throw () ;
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
  throw () ;
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) throw () ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) throw ();
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) throw ();
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
extern void setlinebuf (FILE *__stream) throw ();
extern int fprintf (FILE *__restrict __stream,
      const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      const char *__restrict __format, ...) throw ();
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg) throw ();
extern int snprintf (char *__restrict __s, size_t __maxlen,
     throw () __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     throw () __attribute__ ((__format__ (__printf__, 3, 0)));
extern int vasprintf (char **__restrict __ptr, const char *__restrict __f,
     throw () __attribute__ ((__format__ (__printf__, 2, 0))) ;
extern int __asprintf (char **__restrict __ptr,
         const char *__restrict __fmt, ...)
     throw () __attribute__ ((__format__ (__printf__, 2, 3))) ;
extern int asprintf (char **__restrict __ptr,
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
# 463 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
     throw () __attribute__ ((__format__ (__scanf__, 2, 0)));
# 522 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 550 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 561 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 594 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 638 "/usr/include/stdio.h" 3 4
extern char *gets (char *__s) __attribute__ ((__deprecated__));
# 649 "/usr/include/stdio.h" 3 4
extern char *fgets_unlocked (char *__restrict __s, int __n,
# 665 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 726 "/usr/include/stdio.h" 3 4
extern int fputs_unlocked (const char *__restrict __s,
# 737 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 773 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 792 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 815 "/usr/include/stdio.h" 3 4
extern int fseeko64 (FILE *__stream, __off64_t __off, int __whence);
extern __off64_t ftello64 (FILE *__stream) ;
extern int fgetpos64 (FILE *__restrict __stream, fpos64_t *__restrict __pos);
extern int fsetpos64 (FILE *__stream, const fpos64_t *__pos);
extern void clearerr (FILE *__stream) throw ();
extern int feof (FILE *__stream) throw () ;
extern int ferror (FILE *__stream) throw () ;
extern void clearerr_unlocked (FILE *__stream) throw ();
extern int feof_unlocked (FILE *__stream) throw () ;
extern int ferror_unlocked (FILE *__stream) throw () ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
extern int _sys_nerr;
extern const char *const _sys_errlist[];
# 854 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) throw () ;
extern int fileno_unlocked (FILE *__stream) throw () ;
# 872 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) throw ();
extern char *cuserid (char *__s);
struct obstack;
extern int obstack_printf (struct obstack *__restrict __obstack,
     throw () __attribute__ ((__format__ (__printf__, 2, 3)));
extern int obstack_vprintf (struct obstack *__restrict __obstack,
       __gnuc_va_list __args)
     throw () __attribute__ ((__format__ (__printf__, 2, 0)));
extern void flockfile (FILE *__stream) throw ();
extern int ftrylockfile (FILE *__stream) throw () ;
extern void funlockfile (FILE *__stream) throw ();
# 942 "/usr/include/stdio.h" 3 4
# 126 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/stack.h" 1 3 4
# 63 "/usr/include/openssl/stack.h" 3 4
extern "C" {
typedef struct stack_st
 int num;
 char **data;
 int sorted;
 int num_alloc;
 int (*comp)(const void *, const void *);
 } _STACK;
int sk_num(const _STACK *);
void *sk_value(const _STACK *, int);
void *sk_set(_STACK *, int, void *);
_STACK *sk_new(int (*cmp)(const void *, const void *));
_STACK *sk_new_null(void);
void sk_free(_STACK *);
void sk_pop_free(_STACK *st, void (*func)(void *));
int sk_insert(_STACK *sk, void *data, int where);
void *sk_delete(_STACK *st, int loc);
void *sk_delete_ptr(_STACK *st, void *p);
int sk_find(_STACK *st, void *data);
int sk_find_ex(_STACK *st, void *data);
int sk_push(_STACK *st, void *data);
int sk_unshift(_STACK *st, void *data);
void *sk_shift(_STACK *st);
void *sk_pop(_STACK *st);
void sk_zero(_STACK *st);
int (*sk_set_cmp_func(_STACK *sk, int (*c)(const void *, const void *)))
_STACK *sk_dup(_STACK *st);
void sk_sort(_STACK *st);
int sk_is_sorted(const _STACK *st);
# 129 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/safestack.h" 1 3 4
# 61 "/usr/include/openssl/safestack.h" 3 4
extern "C" {
# 117 "/usr/include/openssl/safestack.h" 3 4
typedef char *OPENSSL_STRING;
typedef const char *OPENSSL_CSTRING;
# 129 "/usr/include/openssl/safestack.h" 3 4
struct stack_st_OPENSSL_STRING { _STACK stack; };
typedef void *OPENSSL_BLOCK;
struct stack_st_OPENSSL_BLOCK { _STACK stack; };
# 2669 "/usr/include/openssl/safestack.h" 3 4
# 130 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/opensslv.h" 1 3 4
extern "C" {
# 94 "/usr/include/openssl/opensslv.h" 3 4
# 131 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/ossl_typ.h" 1 3 4
# 59 "/usr/include/openssl/ossl_typ.h" 3 4
extern "C" {
extern "C" {
# 63 "/usr/include/openssl/ossl_typ.h" 2 3 4
# 83 "/usr/include/openssl/ossl_typ.h" 3 4
typedef struct asn1_string_st ASN1_INTEGER;
typedef struct asn1_string_st ASN1_ENUMERATED;
typedef struct asn1_string_st ASN1_BIT_STRING;
typedef struct asn1_string_st ASN1_OCTET_STRING;
typedef struct asn1_string_st ASN1_PRINTABLESTRING;
typedef struct asn1_string_st ASN1_T61STRING;
typedef struct asn1_string_st ASN1_IA5STRING;
typedef struct asn1_string_st ASN1_GENERALSTRING;
typedef struct asn1_string_st ASN1_UNIVERSALSTRING;
typedef struct asn1_string_st ASN1_BMPSTRING;
typedef struct asn1_string_st ASN1_UTCTIME;
typedef struct asn1_string_st ASN1_TIME;
typedef struct asn1_string_st ASN1_GENERALIZEDTIME;
typedef struct asn1_string_st ASN1_VISIBLESTRING;
typedef struct asn1_string_st ASN1_UTF8STRING;
typedef struct asn1_string_st ASN1_STRING;
typedef int ASN1_BOOLEAN;
typedef int ASN1_NULL;
typedef struct ASN1_ITEM_st ASN1_ITEM;
typedef struct asn1_pctx_st ASN1_PCTX;
# 118 "/usr/include/openssl/ossl_typ.h" 3 4
typedef struct bignum_st BIGNUM;
typedef struct bignum_ctx BN_CTX;
typedef struct bn_blinding_st BN_BLINDING;
typedef struct bn_mont_ctx_st BN_MONT_CTX;
typedef struct bn_recp_ctx_st BN_RECP_CTX;
typedef struct bn_gencb_st BN_GENCB;
typedef struct buf_mem_st BUF_MEM;
typedef struct evp_cipher_st EVP_CIPHER;
typedef struct evp_cipher_ctx_st EVP_CIPHER_CTX;
typedef struct env_md_st EVP_MD;
typedef struct env_md_ctx_st EVP_MD_CTX;
typedef struct evp_pkey_st EVP_PKEY;
typedef struct evp_pkey_asn1_method_st EVP_PKEY_ASN1_METHOD;
typedef struct evp_pkey_method_st EVP_PKEY_METHOD;
typedef struct evp_pkey_ctx_st EVP_PKEY_CTX;
typedef struct dh_st DH;
typedef struct dh_method DH_METHOD;
typedef struct dsa_st DSA;
typedef struct dsa_method DSA_METHOD;
typedef struct rsa_st RSA;
typedef struct rsa_meth_st RSA_METHOD;
typedef struct rand_meth_st RAND_METHOD;
typedef struct ecdh_method ECDH_METHOD;
typedef struct ecdsa_method ECDSA_METHOD;
typedef struct x509_st X509;
typedef struct X509_algor_st X509_ALGOR;
typedef struct X509_crl_st X509_CRL;
typedef struct x509_crl_method_st X509_CRL_METHOD;
typedef struct x509_revoked_st X509_REVOKED;
typedef struct X509_name_st X509_NAME;
typedef struct X509_pubkey_st X509_PUBKEY;
typedef struct x509_store_st X509_STORE;
typedef struct x509_store_ctx_st X509_STORE_CTX;
typedef struct pkcs8_priv_key_info_st PKCS8_PRIV_KEY_INFO;
typedef struct v3_ext_ctx X509V3_CTX;
typedef struct conf_st CONF;
typedef struct store_st STORE;
typedef struct store_method_st STORE_METHOD;
typedef struct ui_st UI;
typedef struct ui_method_st UI_METHOD;
typedef struct st_ERR_FNS ERR_FNS;
typedef struct engine_st ENGINE;
typedef struct ssl_st SSL;
typedef struct ssl_ctx_st SSL_CTX;
typedef struct X509_POLICY_NODE_st X509_POLICY_NODE;
typedef struct X509_POLICY_LEVEL_st X509_POLICY_LEVEL;
typedef struct X509_POLICY_TREE_st X509_POLICY_TREE;
typedef struct X509_POLICY_CACHE_st X509_POLICY_CACHE;
typedef struct AUTHORITY_KEYID_st AUTHORITY_KEYID;
typedef struct DIST_POINT_st DIST_POINT;
typedef struct ISSUING_DIST_POINT_st ISSUING_DIST_POINT;
typedef struct NAME_CONSTRAINTS_st NAME_CONSTRAINTS;
typedef struct crypto_ex_data_st CRYPTO_EX_DATA;
typedef int CRYPTO_EX_new(void *parent, void *ptr, CRYPTO_EX_DATA *ad,
     int idx, long argl, void *argp);
typedef void CRYPTO_EX_free(void *parent, void *ptr, CRYPTO_EX_DATA *ad,
typedef int CRYPTO_EX_dup(CRYPTO_EX_DATA *to, CRYPTO_EX_DATA *from, void *from_d,
typedef struct ocsp_req_ctx_st OCSP_REQ_CTX;
typedef struct ocsp_response_st OCSP_RESPONSE;
typedef struct ocsp_responder_id_st OCSP_RESPID;
# 132 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/symhacks.h" 1 3 4
# 58 "/usr/include/openssl/symhacks.h" 3 4
extern "C" {
# 59 "/usr/include/openssl/symhacks.h" 2 3 4
# 140 "/usr/include/openssl/crypto.h" 2 3 4
extern "C" {
# 171 "/usr/include/openssl/crypto.h" 3 4
typedef struct openssl_item_st
 int code;
 void *value;
 size_t value_size;
 size_t *value_length;
 } OPENSSL_ITEM;
# 256 "/usr/include/openssl/crypto.h" 3 4
typedef struct
 int references;
 struct CRYPTO_dynlock_value *data;
 } CRYPTO_dynlock;
# 283 "/usr/include/openssl/crypto.h" 3 4
typedef struct bio_st BIO_dummy;
 struct stack_st_void *sk;
 int dummy;
struct stack_st_void { _STACK stack; };
typedef struct crypto_ex_data_func_st
 long argl;
 void *argp;
 CRYPTO_EX_new *new_func;
 CRYPTO_EX_free *free_func;
 CRYPTO_EX_dup *dup_func;
 } CRYPTO_EX_DATA_FUNCS;
struct stack_st_CRYPTO_EX_DATA_FUNCS { _STACK stack; };
# 356 "/usr/include/openssl/crypto.h" 3 4
int CRYPTO_mem_ctrl(int mode);
int CRYPTO_is_mem_check_on(void);
# 384 "/usr/include/openssl/crypto.h" 3 4
const char *SSLeay_version(int type);
unsigned long SSLeay(void);
int OPENSSL_issetugid(void);
typedef struct st_CRYPTO_EX_DATA_IMPL CRYPTO_EX_DATA_IMPL;
const CRYPTO_EX_DATA_IMPL *CRYPTO_get_ex_data_implementation(void);
int CRYPTO_set_ex_data_implementation(const CRYPTO_EX_DATA_IMPL *i);
int CRYPTO_ex_data_new_class(void);
int CRYPTO_get_ex_new_index(int class_index, long argl, void *argp,
  CRYPTO_EX_new *new_func, CRYPTO_EX_dup *dup_func,
  CRYPTO_EX_free *free_func);
int CRYPTO_new_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad);
int CRYPTO_dup_ex_data(int class_index, CRYPTO_EX_DATA *to,
  CRYPTO_EX_DATA *from);
void CRYPTO_free_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad);
int CRYPTO_set_ex_data(CRYPTO_EX_DATA *ad, int idx, void *val);
void *CRYPTO_get_ex_data(const CRYPTO_EX_DATA *ad,int idx);
void CRYPTO_cleanup_all_ex_data(void);
int CRYPTO_get_new_lockid(char *name);
int CRYPTO_num_locks(void);
void CRYPTO_lock(int mode, int type,const char *file,int line);
void CRYPTO_set_locking_callback(void (*func)(int mode,int type,
           const char *file,int line));
void (*CRYPTO_get_locking_callback(void))(int mode,int type,const char *file,
  int line);
void CRYPTO_set_add_lock_callback(int (*func)(int *num,int mount,int type,
           const char *file, int line));
int (*CRYPTO_get_add_lock_callback(void))(int *num,int mount,int type,
typedef struct crypto_threadid_st
 void *ptr;
 unsigned long val;
 } CRYPTO_THREADID;
void CRYPTO_THREADID_set_numeric(CRYPTO_THREADID *id, unsigned long val);
void CRYPTO_THREADID_set_pointer(CRYPTO_THREADID *id, void *ptr);
int CRYPTO_THREADID_set_callback(void (*threadid_func)(CRYPTO_THREADID *));
void (*CRYPTO_THREADID_get_callback(void))(CRYPTO_THREADID *);
void CRYPTO_THREADID_current(CRYPTO_THREADID *id);
int CRYPTO_THREADID_cmp(const CRYPTO_THREADID *a, const CRYPTO_THREADID *b);
void CRYPTO_THREADID_cpy(CRYPTO_THREADID *dest, const CRYPTO_THREADID *src);
unsigned long CRYPTO_THREADID_hash(const CRYPTO_THREADID *id);
void CRYPTO_set_id_callback(unsigned long (*func)(void));
unsigned long (*CRYPTO_get_id_callback(void))(void);
unsigned long CRYPTO_thread_id(void);
const char *CRYPTO_get_lock_name(int type);
int CRYPTO_add_lock(int *pointer,int amount,int type, const char *file,
      int line);
int CRYPTO_get_new_dynlockid(void);
void CRYPTO_destroy_dynlockid(int i);
struct CRYPTO_dynlock_value *CRYPTO_get_dynlock_value(int i);
void CRYPTO_set_dynlock_create_callback(struct CRYPTO_dynlock_value *(*dyn_create_function)(const char *file, int line));
void CRYPTO_set_dynlock_lock_callback(void (*dyn_lock_function)(int mode, struct CRYPTO_dynlock_value *l, const char *file, int line));
void CRYPTO_set_dynlock_destroy_callback(void (*dyn_destroy_function)(struct CRYPTO_dynlock_value *l, const char *file, int line));
struct CRYPTO_dynlock_value *(*CRYPTO_get_dynlock_create_callback(void))(const char *file,int line);
void (*CRYPTO_get_dynlock_lock_callback(void))(int mode, struct CRYPTO_dynlock_value *l, const char *file,int line);
void (*CRYPTO_get_dynlock_destroy_callback(void))(struct CRYPTO_dynlock_value *l, const char *file,int line);
int CRYPTO_set_mem_functions(void *(*m)(size_t),void *(*r)(void *,size_t), void (*f)(void *));
int CRYPTO_set_locked_mem_functions(void *(*m)(size_t), void (*free_func)(void *));
int CRYPTO_set_mem_ex_functions(void *(*m)(size_t,const char *,int),
                                void *(*r)(void *,size_t,const char *,int),
                                void (*f)(void *));
int CRYPTO_set_locked_mem_ex_functions(void *(*m)(size_t,const char *,int),
int CRYPTO_set_mem_debug_functions(void (*m)(void *,int,const char *,int,int),
       void (*r)(void *,void *,int,const char *,int,int),
       void (*f)(void *,int),
       void (*so)(long),
       long (*go)(void));
void CRYPTO_get_mem_functions(void *(**m)(size_t),void *(**r)(void *, size_t), void (**f)(void *));
void CRYPTO_get_locked_mem_functions(void *(**m)(size_t), void (**f)(void *));
void CRYPTO_get_mem_ex_functions(void *(**m)(size_t,const char *,int),
                                 void *(**r)(void *, size_t,const char *,int),
void CRYPTO_get_locked_mem_ex_functions(void *(**m)(size_t,const char *,int),
void CRYPTO_get_mem_debug_functions(void (**m)(void *,int,const char *,int,int),
        void (**r)(void *,void *,int,const char *,int,int),
        void (**f)(void *,int),
        void (**so)(long),
        long (**go)(void));
void *CRYPTO_malloc_locked(int num, const char *file, int line);
void CRYPTO_free_locked(void *ptr);
void *CRYPTO_malloc(int num, const char *file, int line);
char *CRYPTO_strdup(const char *str, const char *file, int line);
void CRYPTO_free(void *ptr);
void *CRYPTO_realloc(void *addr,int num, const char *file, int line);
void *CRYPTO_realloc_clean(void *addr,int old_num,int num,const char *file,
      int line);
void *CRYPTO_remalloc(void *addr,int num, const char *file, int line);
void OPENSSL_cleanse(void *ptr, size_t len);
void CRYPTO_set_mem_debug_options(long bits);
long CRYPTO_get_mem_debug_options(void);
int CRYPTO_push_info_(const char *info, const char *file, int line);
int CRYPTO_pop_info(void);
int CRYPTO_remove_all_info(void);
# 519 "/usr/include/openssl/crypto.h" 3 4
void CRYPTO_dbg_malloc(void *addr,int num,const char *file,int line,int before_p);
void CRYPTO_dbg_realloc(void *addr1,void *addr2,int num,const char *file,int line,int before_p);
void CRYPTO_dbg_free(void *addr,int before_p);
# 530 "/usr/include/openssl/crypto.h" 3 4
void CRYPTO_dbg_set_options(long bits);
long CRYPTO_dbg_get_options(void);
void CRYPTO_mem_leaks_fp(FILE *);
void CRYPTO_mem_leaks(struct bio_st *bio);
typedef void *CRYPTO_MEM_LEAK_CB(unsigned long, const char *, int, int, void *);
void CRYPTO_mem_leaks_cb(CRYPTO_MEM_LEAK_CB *cb);
void OpenSSLDie(const char *file,int line,const char *assertion);
unsigned long *OPENSSL_ia32cap_loc(void);
int OPENSSL_isservice(void);
int FIPS_mode(void);
int FIPS_mode_set(int r);
void OPENSSL_init(void);
# 575 "/usr/include/openssl/crypto.h" 3 4
void FIPS_selftest_check(void);
# 587 "/usr/include/openssl/crypto.h" 3 4
int CRYPTO_memcmp(const void *a, const void *b, size_t len);
void ERR_load_CRYPTO_strings(void);
void OPENSSL_init_library(void);
# 617 "/usr/include/openssl/crypto.h" 3 4
# 6 "/usr/include/openssl/comp.h" 2 3 4
extern "C" {
typedef struct comp_ctx_st COMP_CTX;
typedef struct comp_method_st
 int type;
 const char *name;
 int (*init)(COMP_CTX *ctx);
 void (*finish)(COMP_CTX *ctx);
 int (*compress)(COMP_CTX *ctx,
   unsigned char *out, unsigned int olen,
   unsigned char *in, unsigned int ilen);
 int (*expand)(COMP_CTX *ctx,
 long (*ctrl)(void);
 long (*callback_ctrl)(void);
 } COMP_METHOD;
struct comp_ctx_st
 COMP_METHOD *meth;
 unsigned long compress_in;
 unsigned long compress_out;
 unsigned long expand_in;
 unsigned long expand_out;
 CRYPTO_EX_DATA ex_data;
COMP_CTX *COMP_CTX_new(COMP_METHOD *meth);
void COMP_CTX_free(COMP_CTX *ctx);
int COMP_compress_block(COMP_CTX *ctx, unsigned char *out, int olen,
 unsigned char *in, int ilen);
int COMP_expand_block(COMP_CTX *ctx, unsigned char *out, int olen,
COMP_METHOD *COMP_rle(void );
COMP_METHOD *COMP_zlib(void );
void COMP_zlib_cleanup(void);
# 62 "/usr/include/openssl/comp.h" 3 4
void ERR_load_COMP_strings(void);
# 78 "/usr/include/openssl/comp.h" 3 4
# 150 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/bio.h" 1 3 4
# 62 "/usr/include/openssl/bio.h" 3 4
extern "C" {
# 63 "/usr/include/openssl/bio.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 1 3 4
# 68 "/usr/include/openssl/bio.h" 2 3 4
# 80 "/usr/include/openssl/bio.h" 3 4
extern "C" {
# 233 "/usr/include/openssl/bio.h" 3 4
typedef struct bio_st BIO;
void BIO_set_flags(BIO *b, int flags);
int BIO_test_flags(const BIO *b, int flags);
void BIO_clear_flags(BIO *b, int flags);
# 287 "/usr/include/openssl/bio.h" 3 4
long (*BIO_get_callback(const BIO *b)) (struct bio_st *,int,const char *,int, long,long);
void BIO_set_callback(BIO *b,
 long (*callback)(struct bio_st *,int,const char *,int, long,long));
char *BIO_get_callback_arg(const BIO *b);
void BIO_set_callback_arg(BIO *b, char *arg);
const char * BIO_method_name(const BIO *b);
int BIO_method_type(const BIO *b);
typedef void bio_info_cb(struct bio_st *, int, const char *, int, long, long);
typedef struct bio_method_st
 int type;
 const char *name;
 int (*bwrite)(BIO *, const char *, int);
 int (*bread)(BIO *, char *, int);
 int (*bputs)(BIO *, const char *);
 int (*bgets)(BIO *, char *, int);
 long (*ctrl)(BIO *, int, long, void *);
 int (*create)(BIO *);
 int (*destroy)(BIO *);
        long (*callback_ctrl)(BIO *, int, bio_info_cb *);
 } BIO_METHOD;
struct bio_st
 BIO_METHOD *method;
 long (*callback)(struct bio_st *,int,const char *,int, long,long);
 char *cb_arg;
 int init;
 int shutdown;
 int flags;
 int retry_reason;
 int num;
 void *ptr;
 struct bio_st *next_bio;
 struct bio_st *prev_bio;
 int references;
 unsigned long num_read;
 unsigned long num_write;
struct stack_st_BIO { _STACK stack; };
typedef struct bio_f_buffer_ctx_struct
# 348 "/usr/include/openssl/bio.h" 3 4
 int ibuf_size;
 int obuf_size;
 char *ibuf;
 int ibuf_len;
 int ibuf_off;
 char *obuf;
 int obuf_len;
 int obuf_off;
 } BIO_F_BUFFER_CTX;
typedef int asn1_ps_func(BIO *b, unsigned char **pbuf, int *plen, void *parg);
# 576 "/usr/include/openssl/bio.h" 3 4
size_t BIO_ctrl_pending(BIO *b);
size_t BIO_ctrl_wpending(BIO *b);
# 595 "/usr/include/openssl/bio.h" 3 4
size_t BIO_ctrl_get_write_guarantee(BIO *b);
size_t BIO_ctrl_get_read_request(BIO *b);
int BIO_ctrl_reset_read_request(BIO *b);
# 618 "/usr/include/openssl/bio.h" 3 4
int BIO_set_ex_data(BIO *bio,int idx,void *data);
void *BIO_get_ex_data(BIO *bio,int idx);
int BIO_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
 CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
unsigned long BIO_number_read(BIO *bio);
unsigned long BIO_number_written(BIO *bio);
int BIO_asn1_set_prefix(BIO *b, asn1_ps_func *prefix,
     asn1_ps_func *prefix_free);
int BIO_asn1_get_prefix(BIO *b, asn1_ps_func **pprefix,
     asn1_ps_func **pprefix_free);
int BIO_asn1_set_suffix(BIO *b, asn1_ps_func *suffix,
     asn1_ps_func *suffix_free);
int BIO_asn1_get_suffix(BIO *b, asn1_ps_func **psuffix,
     asn1_ps_func **psuffix_free);
BIO_METHOD *BIO_s_file(void );
BIO *BIO_new_file(const char *filename, const char *mode);
BIO *BIO_new_fp(FILE *stream, int close_flag);
BIO * BIO_new(BIO_METHOD *type);
int BIO_set(BIO *a,BIO_METHOD *type);
int BIO_free(BIO *a);
void BIO_vfree(BIO *a);
int BIO_read(BIO *b, void *data, int len);
int BIO_gets(BIO *bp,char *buf, int size);
int BIO_write(BIO *b, const void *data, int len);
int BIO_puts(BIO *bp,const char *buf);
int BIO_indent(BIO *b,int indent,int max);
long BIO_ctrl(BIO *bp,int cmd,long larg,void *parg);
long BIO_callback_ctrl(BIO *b, int cmd, void (*fp)(struct bio_st *, int, const char *, int, long, long));
char * BIO_ptr_ctrl(BIO *bp,int cmd,long larg);
long BIO_int_ctrl(BIO *bp,int cmd,long larg,int iarg);
BIO * BIO_push(BIO *b,BIO *append);
BIO * BIO_pop(BIO *b);
void BIO_free_all(BIO *a);
BIO * BIO_find_type(BIO *b,int bio_type);
BIO * BIO_next(BIO *b);
BIO * BIO_get_retry_BIO(BIO *bio, int *reason);
int BIO_get_retry_reason(BIO *bio);
BIO * BIO_dup_chain(BIO *in);
int BIO_nread0(BIO *bio, char **buf);
int BIO_nread(BIO *bio, char **buf, int num);
int BIO_nwrite0(BIO *bio, char **buf);
int BIO_nwrite(BIO *bio, char **buf, int num);
long BIO_debug_callback(BIO *bio,int cmd,const char *argp,int argi,
 long argl,long ret);
BIO_METHOD *BIO_s_mem(void);
BIO *BIO_new_mem_buf(void *buf, int len);
BIO_METHOD *BIO_s_socket(void);
BIO_METHOD *BIO_s_connect(void);
BIO_METHOD *BIO_s_accept(void);
BIO_METHOD *BIO_s_fd(void);
BIO_METHOD *BIO_s_log(void);
BIO_METHOD *BIO_s_bio(void);
BIO_METHOD *BIO_s_null(void);
BIO_METHOD *BIO_f_null(void);
BIO_METHOD *BIO_f_buffer(void);
BIO_METHOD *BIO_f_nbio_test(void);
BIO_METHOD *BIO_s_datagram(void);
int BIO_sock_should_retry(int i);
int BIO_sock_non_fatal_error(int error);
int BIO_dgram_non_fatal_error(int error);
int BIO_fd_should_retry(int i);
int BIO_fd_non_fatal_error(int error);
int BIO_dump_cb(int (*cb)(const void *data, size_t len, void *u),
  void *u, const char *s, int len);
int BIO_dump_indent_cb(int (*cb)(const void *data, size_t len, void *u),
         void *u, const char *s, int len, int indent);
int BIO_dump(BIO *b,const char *bytes,int len);
int BIO_dump_indent(BIO *b,const char *bytes,int len,int indent);
int BIO_dump_fp(FILE *fp, const char *s, int len);
int BIO_dump_indent_fp(FILE *fp, const char *s, int len, int indent);
struct hostent *BIO_gethostbyname(const char *name);
# 722 "/usr/include/openssl/bio.h" 3 4
int BIO_sock_error(int sock);
int BIO_socket_ioctl(int fd, long type, void *arg);
int BIO_socket_nbio(int fd,int mode);
int BIO_get_port(const char *str, unsigned short *port_ptr);
int BIO_get_host_ip(const char *str, unsigned char *ip);
int BIO_get_accept_socket(char *host_port,int mode);
int BIO_accept(int sock,char **ip_port);
int BIO_sock_init(void );
void BIO_sock_cleanup(void);
int BIO_set_tcp_ndelay(int sock,int turn_on);
BIO *BIO_new_socket(int sock, int close_flag);
BIO *BIO_new_dgram(int fd, int close_flag);
# 744 "/usr/include/openssl/bio.h" 3 4
BIO *BIO_new_fd(int fd, int close_flag);
BIO *BIO_new_connect(char *host_port);
BIO *BIO_new_accept(char *host_port);
int BIO_new_bio_pair(BIO **bio1, size_t writebuf1,
 BIO **bio2, size_t writebuf2);
void BIO_copy_next_retry(BIO *b);
# 764 "/usr/include/openssl/bio.h" 3 4
int BIO_printf(BIO *bio, const char *format, ...)
 __attribute__((__format__(__printf__,2,3)));
int BIO_vprintf(BIO *bio, const char *format, va_list args)
 __attribute__((__format__(__printf__,2,0)));
int BIO_snprintf(char *buf, size_t n, const char *format, ...)
 __attribute__((__format__(__printf__,3,4)));
int BIO_vsnprintf(char *buf, size_t n, const char *format, va_list args)
 __attribute__((__format__(__printf__,3,0)));
void ERR_load_BIO_strings(void);
# 849 "/usr/include/openssl/bio.h" 3 4
# 153 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/x509.h" 1 3 4
# 67 "/usr/include/openssl/x509.h" 3 4
extern "C" {
# 68 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/buffer.h" 1 3 4
# 65 "/usr/include/openssl/buffer.h" 3 4
extern "C" {
# 147 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 69 "/usr/include/openssl/buffer.h" 2 3 4
# 77 "/usr/include/openssl/buffer.h" 3 4
struct buf_mem_st
 size_t length;
 char *data;
 size_t max;
BUF_MEM *BUF_MEM_new(void);
void BUF_MEM_free(BUF_MEM *a);
int BUF_MEM_grow(BUF_MEM *str, size_t len);
int BUF_MEM_grow_clean(BUF_MEM *str, size_t len);
char * BUF_strdup(const char *str);
char * BUF_strndup(const char *str, size_t siz);
void * BUF_memdup(const void *data, size_t siz);
void BUF_reverse(unsigned char *out, const unsigned char *in, size_t siz);
size_t BUF_strlcpy(char *dst,const char *src,size_t siz);
size_t BUF_strlcat(char *dst,const char *src,size_t siz);
void ERR_load_BUF_strings(void);
# 117 "/usr/include/openssl/buffer.h" 3 4
# 71 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/evp.h" 1 3 4
# 66 "/usr/include/openssl/evp.h" 3 4
extern "C" {
# 67 "/usr/include/openssl/evp.h" 2 3 4
# 79 "/usr/include/openssl/evp.h" 3 4
# 1 "/usr/include/openssl/fips.h" 1 3 4
# 50 "/usr/include/openssl/fips.h" 3 4
extern "C" {
# 51 "/usr/include/openssl/fips.h" 2 3 4
# 61 "/usr/include/openssl/fips.h" 3 4
extern "C" {
struct dsa_st;
struct rsa_st;
struct evp_pkey_st;
struct env_md_st;
struct env_md_ctx_st;
struct evp_cipher_st;
struct evp_cipher_ctx_st;
struct dh_method;
struct CMAC_CTX_st;
struct hmac_ctx_st;
int FIPS_module_mode_set(int onoff, const char *auth);
int FIPS_module_mode(void);
int FIPS_module_installed(void);
const void *FIPS_rand_check(void);
int FIPS_selftest(void);
int FIPS_selftest_failed(void);
void FIPS_corrupt_sha1(void);
int FIPS_selftest_sha1(void);
int FIPS_selftest_sha2(void);
void FIPS_corrupt_aes(void);
int FIPS_selftest_aes_ccm(void);
int FIPS_selftest_aes_gcm(void);
int FIPS_selftest_aes_xts(void);
int FIPS_selftest_aes(void);
void FIPS_corrupt_des(void);
int FIPS_selftest_des(void);
void FIPS_corrupt_rsa(void);
void FIPS_corrupt_rsa_keygen(void);
int FIPS_selftest_rsa(void);
void FIPS_corrupt_dsa(void);
void FIPS_corrupt_dsa_keygen(void);
int FIPS_selftest_dsa(void);
int FIPS_selftest_ecdsa(void);
int FIPS_selftest_ecdh(void);
int FIPS_selftest_dh(void);
void FIPS_corrupt_rng(void);
void FIPS_rng_stick(void);
void FIPS_x931_stick(int onoff);
void FIPS_drbg_stick(int onoff);
int FIPS_selftest_rng(void);
int FIPS_selftest_x931(void);
int FIPS_selftest_hmac(void);
int FIPS_selftest_drbg(void);
int FIPS_selftest_drbg_all(void);
int FIPS_selftest_cmac(void);
void FIPS_get_timevec(unsigned char *buf, unsigned long *pctr);
int fips_pkey_signature_test(struct evp_pkey_st *pkey,
   const unsigned char *tbs, int tbslen,
   const unsigned char *kat, unsigned int katlen,
   const struct env_md_st *digest, unsigned int md_flags,
   const char *fail_str);
int fips_cipher_test(struct evp_cipher_ctx_st *ctx,
   const struct evp_cipher_st *cipher,
   const unsigned char *key,
   const unsigned char *iv,
   const unsigned char *plaintext,
   const unsigned char *ciphertext,
   int len);
void fips_set_selftest_fail(void);
const struct env_md_st *FIPS_get_digestbynid(int nid);
const struct evp_cipher_st *FIPS_get_cipherbynid(int nid);
void ERR_load_FIPS_strings(void);
# 281 "/usr/include/openssl/fips.h" 3 4
# 80 "/usr/include/openssl/evp.h" 2 3 4
# 98 "/usr/include/openssl/evp.h" 3 4
# 1 "/usr/include/openssl/objects.h" 1 3 4
# 65 "/usr/include/openssl/objects.h" 3 4
# 1 "/usr/include/openssl/obj_mac.h" 1 3 4
# 66 "/usr/include/openssl/objects.h" 2 3 4
# 960 "/usr/include/openssl/objects.h" 3 4
# 1 "/usr/include/openssl/asn1.h" 1 3 4
# 62 "/usr/include/openssl/asn1.h" 3 4
# 29 "/usr/include/time.h" 3 4
extern "C" {
# 38 "/usr/include/time.h" 2 3 4
# 86 "/usr/include/bits/time.h" 3 4
# 1 "/usr/include/bits/timex.h" 1 3 4
# 25 "/usr/include/bits/timex.h" 3 4
struct timex
  unsigned int modes;
  __syscall_slong_t offset;
  __syscall_slong_t freq;
  __syscall_slong_t maxerror;
  __syscall_slong_t esterror;
  int status;
  __syscall_slong_t constant;
  __syscall_slong_t precision;
  __syscall_slong_t tolerance;
  struct timeval time;
  __syscall_slong_t tick;
  __syscall_slong_t ppsfreq;
  __syscall_slong_t jitter;
  int shift;
  __syscall_slong_t stabil;
  __syscall_slong_t jitcnt;
  __syscall_slong_t calcnt;
  __syscall_slong_t errcnt;
  __syscall_slong_t stbcnt;
  int tai;
  int :32; int :32; int :32; int :32;
# 87 "/usr/include/bits/time.h" 2 3 4
extern "C" {
extern int clock_adjtime (__clockid_t __clock_id, struct timex *__utx) throw ();
# 42 "/usr/include/time.h" 2 3 4
# 131 "/usr/include/time.h" 3 4
struct tm
  int tm_sec;
  int tm_min;
  int tm_hour;
  int tm_mday;
  int tm_mon;
  int tm_year;
  int tm_wday;
  int tm_yday;
  int tm_isdst;
  long int tm_gmtoff;
  const char *tm_zone;
struct itimerspec
    struct timespec it_interval;
    struct timespec it_value;
struct sigevent;
# 186 "/usr/include/time.h" 3 4
extern clock_t clock (void) throw ();
extern time_t time (time_t *__timer) throw ();
extern double difftime (time_t __time1, time_t __time0)
     throw () __attribute__ ((__const__));
extern time_t mktime (struct tm *__tp) throw ();
extern size_t strftime (char *__restrict __s, size_t __maxsize,
   const struct tm *__restrict __tp) throw ();
extern char *strptime (const char *__restrict __s,
         const char *__restrict __fmt, struct tm *__tp)
     throw ();
extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
     const struct tm *__restrict __tp,
     __locale_t __loc) throw ();
extern char *strptime_l (const char *__restrict __s,
    const char *__restrict __fmt, struct tm *__tp,
extern struct tm *gmtime (const time_t *__timer) throw ();
extern struct tm *localtime (const time_t *__timer) throw ();
extern struct tm *gmtime_r (const time_t *__restrict __timer,
extern struct tm *localtime_r (const time_t *__restrict __timer,
extern char *asctime (const struct tm *__tp) throw ();
extern char *ctime (const time_t *__timer) throw ();
extern char *asctime_r (const struct tm *__restrict __tp,
extern char *ctime_r (const time_t *__restrict __timer,
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) throw ();
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) throw ();
# 319 "/usr/include/time.h" 3 4
extern time_t timegm (struct tm *__tp) throw ();
extern time_t timelocal (struct tm *__tp) throw ();
extern int dysize (int __year) throw () __attribute__ ((__const__));
# 334 "/usr/include/time.h" 3 4
extern int nanosleep (const struct timespec *__requested_time,
        struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) throw ();
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) throw ();
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
     throw ();
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
       const struct timespec *__req,
       struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) throw ();
extern int timer_create (clockid_t __clock_id,
    struct sigevent *__restrict __evp,
    timer_t *__restrict __timerid) throw ();
extern int timer_delete (timer_t __timerid) throw ();
extern int timer_settime (timer_t __timerid, int __flags,
     const struct itimerspec *__restrict __value,
     struct itimerspec *__restrict __ovalue) throw ();
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
     throw ();
extern int timer_getoverrun (timer_t __timerid) throw ();
extern int timespec_get (struct timespec *__ts, int __base)
# 403 "/usr/include/time.h" 3 4
extern int getdate_err;
# 412 "/usr/include/time.h" 3 4
extern struct tm *getdate (const char *__string);
# 426 "/usr/include/time.h" 3 4
extern int getdate_r (const char *__restrict __string,
        struct tm *__restrict __resbufp);
# 63 "/usr/include/openssl/asn1.h" 2 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 34 "/usr/include/openssl/opensslconf.h" 3 4
# 1 "/usr/include/openssl/opensslconf-x86_64.h" 1 3 4
# 12 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
extern "C" {
# 284 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
# 35 "/usr/include/openssl/opensslconf.h" 2 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 64 "/usr/include/openssl/asn1.h" 2 3 4
# 74 "/usr/include/openssl/asn1.h" 3 4
# 1 "/usr/include/openssl/bn.h" 1 3 4
# 128 "/usr/include/openssl/bn.h" 3 4
extern "C" {
# 129 "/usr/include/openssl/bn.h" 2 3 4
extern "C" {
# 318 "/usr/include/openssl/bn.h" 3 4
struct bignum_st
 unsigned long *d;
 int top;
 int dmax;
 int neg;
 int flags;
 int ri;
 BIGNUM RR;
 BIGNUM N;
 BIGNUM Ni;
 unsigned long n0[2];
 int flags;
 BIGNUM N;
 BIGNUM Nr;
 int num_bits;
 int shift;
 int flags;
struct bn_gencb_st
 unsigned int ver;
 void *arg;
 union
  void (*cb_1)(int, int, void *);
  int (*cb_2)(int, int, BN_GENCB *);
  } cb;
int BN_GENCB_call(BN_GENCB *cb, int a, int b);
# 425 "/usr/include/openssl/bn.h" 3 4
const BIGNUM *BN_value_one(void);
char * BN_options(void);
BN_CTX *BN_CTX_new(void);
void BN_CTX_init(BN_CTX *c);
void BN_CTX_free(BN_CTX *c);
void BN_CTX_start(BN_CTX *ctx);
BIGNUM *BN_CTX_get(BN_CTX *ctx);
void BN_CTX_end(BN_CTX *ctx);
int BN_rand(BIGNUM *rnd, int bits, int top,int bottom);
int BN_pseudo_rand(BIGNUM *rnd, int bits, int top,int bottom);
int BN_rand_range(BIGNUM *rnd, const BIGNUM *range);
int BN_pseudo_rand_range(BIGNUM *rnd, const BIGNUM *range);
int BN_num_bits(const BIGNUM *a);
int BN_num_bits_word(unsigned long);
BIGNUM *BN_new(void);
void BN_init(BIGNUM *);
void BN_clear_free(BIGNUM *a);
BIGNUM *BN_copy(BIGNUM *a, const BIGNUM *b);
void BN_swap(BIGNUM *a, BIGNUM *b);
BIGNUM *BN_bin2bn(const unsigned char *s,int len,BIGNUM *ret);
int BN_bn2bin(const BIGNUM *a, unsigned char *to);
BIGNUM *BN_mpi2bn(const unsigned char *s,int len,BIGNUM *ret);
int BN_bn2mpi(const BIGNUM *a, unsigned char *to);
int BN_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_usub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_uadd(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
int BN_sqr(BIGNUM *r, const BIGNUM *a,BN_CTX *ctx);
void BN_set_negative(BIGNUM *b, int n);
int BN_div(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m, const BIGNUM *d,
 BN_CTX *ctx);
int BN_nnmod(BIGNUM *r, const BIGNUM *m, const BIGNUM *d, BN_CTX *ctx);
int BN_mod_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_add_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m);
int BN_mod_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_sub_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m);
int BN_mod_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift1(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift1_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *m);
int BN_mod_lshift(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift_quick(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m);
unsigned long BN_mod_word(const BIGNUM *a, unsigned long w);
unsigned long BN_div_word(BIGNUM *a, unsigned long w);
int BN_mul_word(BIGNUM *a, unsigned long w);
int BN_add_word(BIGNUM *a, unsigned long w);
int BN_sub_word(BIGNUM *a, unsigned long w);
int BN_set_word(BIGNUM *a, unsigned long w);
unsigned long BN_get_word(const BIGNUM *a);
int BN_cmp(const BIGNUM *a, const BIGNUM *b);
void BN_free(BIGNUM *a);
int BN_is_bit_set(const BIGNUM *a, int n);
int BN_lshift(BIGNUM *r, const BIGNUM *a, int n);
int BN_lshift1(BIGNUM *r, const BIGNUM *a);
int BN_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,BN_CTX *ctx);
int BN_mod_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m,BN_CTX *ctx);
int BN_mod_exp_mont(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *m_ctx);
int BN_mod_exp_mont_consttime(BIGNUM *rr, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *in_mont);
int BN_mod_exp_mont_word(BIGNUM *r, unsigned long a, const BIGNUM *p,
int BN_mod_exp2_mont(BIGNUM *r, const BIGNUM *a1, const BIGNUM *p1,
 const BIGNUM *a2, const BIGNUM *p2,const BIGNUM *m,
 BN_CTX *ctx,BN_MONT_CTX *m_ctx);
int BN_mod_exp_simple(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_mask_bits(BIGNUM *a,int n);
int BN_print_fp(FILE *fp, const BIGNUM *a);
int BN_print(BIO *fp, const BIGNUM *a);
int BN_reciprocal(BIGNUM *r, const BIGNUM *m, int len, BN_CTX *ctx);
int BN_rshift(BIGNUM *r, const BIGNUM *a, int n);
int BN_rshift1(BIGNUM *r, const BIGNUM *a);
void BN_clear(BIGNUM *a);
BIGNUM *BN_dup(const BIGNUM *a);
int BN_ucmp(const BIGNUM *a, const BIGNUM *b);
int BN_set_bit(BIGNUM *a, int n);
int BN_clear_bit(BIGNUM *a, int n);
char * BN_bn2hex(const BIGNUM *a);
char * BN_bn2dec(const BIGNUM *a);
int BN_hex2bn(BIGNUM **a, const char *str);
int BN_dec2bn(BIGNUM **a, const char *str);
int BN_asc2bn(BIGNUM **a, const char *str);
int BN_gcd(BIGNUM *r,const BIGNUM *a,const BIGNUM *b,BN_CTX *ctx);
int BN_kronecker(const BIGNUM *a,const BIGNUM *b,BN_CTX *ctx);
BIGNUM *BN_mod_inverse(BIGNUM *ret,
 const BIGNUM *a, const BIGNUM *n,BN_CTX *ctx);
BIGNUM *BN_mod_sqrt(BIGNUM *ret,
void BN_consttime_swap(unsigned long swap, BIGNUM *a, BIGNUM *b, int nwords);
BIGNUM *BN_generate_prime(BIGNUM *ret,int bits,int safe,
 const BIGNUM *add, const BIGNUM *rem,
 void (*callback)(int,int,void *),void *cb_arg);
int BN_is_prime(const BIGNUM *p,int nchecks,
 BN_CTX *ctx,void *cb_arg);
int BN_is_prime_fasttest(const BIGNUM *p,int nchecks,
 void (*callback)(int,int,void *),BN_CTX *ctx,void *cb_arg,
 int do_trial_division);
int BN_generate_prime_ex(BIGNUM *ret,int bits,int safe, const BIGNUM *add,
  const BIGNUM *rem, BN_GENCB *cb);
int BN_is_prime_ex(const BIGNUM *p,int nchecks, BN_CTX *ctx, BN_GENCB *cb);
int BN_is_prime_fasttest_ex(const BIGNUM *p,int nchecks, BN_CTX *ctx,
  int do_trial_division, BN_GENCB *cb);
int BN_X931_generate_Xpq(BIGNUM *Xp, BIGNUM *Xq, int nbits, BN_CTX *ctx);
int BN_X931_derive_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2,
   const BIGNUM *Xp, const BIGNUM *Xp1, const BIGNUM *Xp2,
   const BIGNUM *e, BN_CTX *ctx, BN_GENCB *cb);
int BN_X931_generate_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2,
   BIGNUM *Xp1, BIGNUM *Xp2,
   const BIGNUM *Xp,
   BN_GENCB *cb);
BN_MONT_CTX *BN_MONT_CTX_new(void );
void BN_MONT_CTX_init(BN_MONT_CTX *ctx);
int BN_mod_mul_montgomery(BIGNUM *r,const BIGNUM *a,const BIGNUM *b,
 BN_MONT_CTX *mont, BN_CTX *ctx);
int BN_from_montgomery(BIGNUM *r,const BIGNUM *a,
void BN_MONT_CTX_free(BN_MONT_CTX *mont);
int BN_MONT_CTX_set(BN_MONT_CTX *mont,const BIGNUM *mod,BN_CTX *ctx);
BN_MONT_CTX *BN_MONT_CTX_copy(BN_MONT_CTX *to,BN_MONT_CTX *from);
BN_MONT_CTX *BN_MONT_CTX_set_locked(BN_MONT_CTX **pmont, int lock,
     const BIGNUM *mod, BN_CTX *ctx);
BN_BLINDING *BN_BLINDING_new(const BIGNUM *A, const BIGNUM *Ai, BIGNUM *mod);
void BN_BLINDING_free(BN_BLINDING *b);
int BN_BLINDING_update(BN_BLINDING *b,BN_CTX *ctx);
int BN_BLINDING_convert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx);
int BN_BLINDING_invert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx);
int BN_BLINDING_convert_ex(BIGNUM *n, BIGNUM *r, BN_BLINDING *b, BN_CTX *);
int BN_BLINDING_invert_ex(BIGNUM *n, const BIGNUM *r, BN_BLINDING *b, BN_CTX *);
unsigned long BN_BLINDING_get_thread_id(const BN_BLINDING *);
void BN_BLINDING_set_thread_id(BN_BLINDING *, unsigned long);
CRYPTO_THREADID *BN_BLINDING_thread_id(BN_BLINDING *);
unsigned long BN_BLINDING_get_flags(const BN_BLINDING *);
void BN_BLINDING_set_flags(BN_BLINDING *, unsigned long);
BN_BLINDING *BN_BLINDING_create_param(BN_BLINDING *b,
 const BIGNUM *e, BIGNUM *m, BN_CTX *ctx,
 int (*bn_mod_exp)(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
     const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *m_ctx),
void BN_set_params(int mul,int high,int low,int mont);
int BN_get_params(int which);
void BN_RECP_CTX_init(BN_RECP_CTX *recp);
BN_RECP_CTX *BN_RECP_CTX_new(void);
void BN_RECP_CTX_free(BN_RECP_CTX *recp);
int BN_RECP_CTX_set(BN_RECP_CTX *recp,const BIGNUM *rdiv,BN_CTX *ctx);
int BN_mod_mul_reciprocal(BIGNUM *r, const BIGNUM *x, const BIGNUM *y,
 BN_RECP_CTX *recp,BN_CTX *ctx);
int BN_mod_exp_recp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_div_recp(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m,
 BN_RECP_CTX *recp, BN_CTX *ctx);
int BN_nist_mod_192(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_224(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_256(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_384(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_521(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
const BIGNUM *BN_get0_nist_prime_192(void);
const BIGNUM *BN_get0_nist_prime_224(void);
const BIGNUM *BN_get0_nist_prime_256(void);
const BIGNUM *BN_get0_nist_prime_384(void);
const BIGNUM *BN_get0_nist_prime_521(void);
BIGNUM *bn_expand2(BIGNUM *a, int words);
BIGNUM *bn_dup_expand(const BIGNUM *a, int words);
# 757 "/usr/include/openssl/bn.h" 3 4
unsigned long bn_mul_add_words(unsigned long *rp, const unsigned long *ap, int num, unsigned long w);
unsigned long bn_mul_words(unsigned long *rp, const unsigned long *ap, int num, unsigned long w);
void bn_sqr_words(unsigned long *rp, const unsigned long *ap, int num);
unsigned long bn_div_words(unsigned long h, unsigned long l, unsigned long d);
unsigned long bn_add_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,int num);
unsigned long bn_sub_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,int num);
BIGNUM *get_rfc2409_prime_768(BIGNUM *bn);
BIGNUM *get_rfc2409_prime_1024(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_1536(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_2048(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_3072(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_4096(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_6144(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_8192(BIGNUM *bn);
int BN_bntest_rand(BIGNUM *rnd, int bits, int top,int bottom);
void ERR_load_BN_strings(void);
# 848 "/usr/include/openssl/bn.h" 3 4
# 75 "/usr/include/openssl/asn1.h" 2 3 4
# 83 "/usr/include/openssl/asn1.h" 3 4
extern "C" {
# 165 "/usr/include/openssl/asn1.h" 3 4
struct X509_algor_st;
struct stack_st_X509_ALGOR { _STACK stack; };
# 175 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_ctx_st
 unsigned char *p;
 int eos;
 int error;
 int inf;
 int tag;
 int xclass;
 long slen;
 unsigned char *max;
 unsigned char *q;
 unsigned char **pp;
 int line;
 } ASN1_CTX;
typedef struct asn1_const_ctx_st
 const unsigned char *p;
 int eos;
 int error;
 int inf;
 int tag;
 int xclass;
 long slen;
 const unsigned char *max;
 const unsigned char *q;
 const unsigned char **pp;
 int line;
 } ASN1_const_CTX;
typedef struct asn1_object_st
 const char *sn,*ln;
 int nid;
 int length;
 const unsigned char *data;
 int flags;
 } ASN1_OBJECT;
# 238 "/usr/include/openssl/asn1.h" 3 4
 int length;
 int type;
 long flags;
typedef struct ASN1_ENCODING_st
 unsigned char *enc;
 long len;
 int modified;
 } ASN1_ENCODING;
# 271 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_string_table_st {
 int nid;
 long minsize;
 long maxsize;
 unsigned long mask;
 unsigned long flags;
} ASN1_STRING_TABLE;
struct stack_st_ASN1_STRING_TABLE { _STACK stack; };
# 295 "/usr/include/openssl/asn1.h" 3 4
typedef struct ASN1_TEMPLATE_st ASN1_TEMPLATE;
typedef struct ASN1_TLC_st ASN1_TLC;
typedef struct ASN1_VALUE_st ASN1_VALUE;
# 362 "/usr/include/openssl/asn1.h" 3 4
typedef void *d2i_of_void(void **,const unsigned char **,long); typedef int i2d_of_void(void *,unsigned char **);
# 402 "/usr/include/openssl/asn1.h" 3 4
typedef const ASN1_ITEM ASN1_ITEM_EXP;
# 516 "/usr/include/openssl/asn1.h" 3 4
struct stack_st_ASN1_INTEGER { _STACK stack; };
struct stack_st_ASN1_GENERALSTRING { _STACK stack; };
typedef struct asn1_type_st
 int type;
 union {
  char *ptr;
  ASN1_BOOLEAN boolean;
  ASN1_STRING * asn1_string;
  ASN1_OBJECT * object;
  ASN1_INTEGER * integer;
  ASN1_ENUMERATED * enumerated;
  ASN1_BIT_STRING * bit_string;
  ASN1_OCTET_STRING * octet_string;
  ASN1_PRINTABLESTRING * printablestring;
  ASN1_T61STRING * t61string;
  ASN1_IA5STRING * ia5string;
  ASN1_GENERALSTRING * generalstring;
  ASN1_BMPSTRING * bmpstring;
  ASN1_UNIVERSALSTRING * universalstring;
  ASN1_UTCTIME * utctime;
  ASN1_GENERALIZEDTIME * generalizedtime;
  ASN1_VISIBLESTRING * visiblestring;
  ASN1_UTF8STRING * utf8string;
  ASN1_STRING * set;
  ASN1_STRING * sequence;
  ASN1_VALUE * asn1_value;
  } value;
 } ASN1_TYPE;
struct stack_st_ASN1_TYPE { _STACK stack; };
typedef struct stack_st_ASN1_TYPE ASN1_SEQUENCE_ANY;
ASN1_SEQUENCE_ANY *d2i_ASN1_SEQUENCE_ANY(ASN1_SEQUENCE_ANY **a, const unsigned char **in, long len); int i2d_ASN1_SEQUENCE_ANY(const ASN1_SEQUENCE_ANY *a, unsigned char **out); extern const ASN1_ITEM ASN1_SEQUENCE_ANY_it;
ASN1_SEQUENCE_ANY *d2i_ASN1_SET_ANY(ASN1_SEQUENCE_ANY **a, const unsigned char **in, long len); int i2d_ASN1_SET_ANY(const ASN1_SEQUENCE_ANY *a, unsigned char **out); extern const ASN1_ITEM ASN1_SET_ANY_it;
typedef struct NETSCAPE_X509_st
 ASN1_OCTET_STRING *header;
 X509 *cert;
 } NETSCAPE_X509;
typedef struct BIT_STRING_BITNAME_st {
 int bitnum;
 const char *lname;
 const char *sname;
} BIT_STRING_BITNAME;
# 774 "/usr/include/openssl/asn1.h" 3 4
ASN1_TYPE *ASN1_TYPE_new(void); void ASN1_TYPE_free(ASN1_TYPE *a); ASN1_TYPE *d2i_ASN1_TYPE(ASN1_TYPE **a, const unsigned char **in, long len); int i2d_ASN1_TYPE(ASN1_TYPE *a, unsigned char **out); extern const ASN1_ITEM ASN1_ANY_it;
int ASN1_TYPE_get(ASN1_TYPE *a);
void ASN1_TYPE_set(ASN1_TYPE *a, int type, void *value);
int ASN1_TYPE_set1(ASN1_TYPE *a, int type, const void *value);
int ASN1_TYPE_cmp(const ASN1_TYPE *a, const ASN1_TYPE *b);
ASN1_OBJECT * ASN1_OBJECT_new(void );
void ASN1_OBJECT_free(ASN1_OBJECT *a);
int i2d_ASN1_OBJECT(ASN1_OBJECT *a,unsigned char **pp);
ASN1_OBJECT * c2i_ASN1_OBJECT(ASN1_OBJECT **a,const unsigned char **pp,
   long length);
ASN1_OBJECT * d2i_ASN1_OBJECT(ASN1_OBJECT **a,const unsigned char **pp,
   long length);
extern const ASN1_ITEM ASN1_OBJECT_it;
struct stack_st_ASN1_OBJECT { _STACK stack; };
ASN1_STRING * ASN1_STRING_new(void);
void ASN1_STRING_free(ASN1_STRING *a);
int ASN1_STRING_copy(ASN1_STRING *dst, const ASN1_STRING *str);
ASN1_STRING * ASN1_STRING_dup(const ASN1_STRING *a);
ASN1_STRING * ASN1_STRING_type_new(int type );
int ASN1_STRING_cmp(const ASN1_STRING *a, const ASN1_STRING *b);
int ASN1_STRING_set(ASN1_STRING *str, const void *data, int len);
void ASN1_STRING_set0(ASN1_STRING *str, void *data, int len);
int ASN1_STRING_length(const ASN1_STRING *x);
void ASN1_STRING_length_set(ASN1_STRING *x, int n);
int ASN1_STRING_type(ASN1_STRING *x);
unsigned char * ASN1_STRING_data(ASN1_STRING *x);
ASN1_BIT_STRING *ASN1_BIT_STRING_new(void); void ASN1_BIT_STRING_free(ASN1_BIT_STRING *a); ASN1_BIT_STRING *d2i_ASN1_BIT_STRING(ASN1_BIT_STRING **a, const unsigned char **in, long len); int i2d_ASN1_BIT_STRING(ASN1_BIT_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_BIT_STRING_it;
int i2c_ASN1_BIT_STRING(ASN1_BIT_STRING *a,unsigned char **pp);
ASN1_BIT_STRING *c2i_ASN1_BIT_STRING(ASN1_BIT_STRING **a,const unsigned char **pp,
   long length);
int ASN1_BIT_STRING_set(ASN1_BIT_STRING *a, unsigned char *d,
   int length );
int ASN1_BIT_STRING_set_bit(ASN1_BIT_STRING *a, int n, int value);
int ASN1_BIT_STRING_get_bit(ASN1_BIT_STRING *a, int n);
int ASN1_BIT_STRING_check(ASN1_BIT_STRING *a,
                                     unsigned char *flags, int flags_len);
int ASN1_BIT_STRING_name_print(BIO *out, ASN1_BIT_STRING *bs,
    BIT_STRING_BITNAME *tbl, int indent);
int ASN1_BIT_STRING_num_asc(char *name, BIT_STRING_BITNAME *tbl);
int ASN1_BIT_STRING_set_asc(ASN1_BIT_STRING *bs, char *name, int value,
int i2d_ASN1_BOOLEAN(int a,unsigned char **pp);
int d2i_ASN1_BOOLEAN(int *a,const unsigned char **pp,long length);
ASN1_INTEGER *ASN1_INTEGER_new(void); void ASN1_INTEGER_free(ASN1_INTEGER *a); ASN1_INTEGER *d2i_ASN1_INTEGER(ASN1_INTEGER **a, const unsigned char **in, long len); int i2d_ASN1_INTEGER(ASN1_INTEGER *a, unsigned char **out); extern const ASN1_ITEM ASN1_INTEGER_it;
int i2c_ASN1_INTEGER(ASN1_INTEGER *a,unsigned char **pp);
ASN1_INTEGER *c2i_ASN1_INTEGER(ASN1_INTEGER **a,const unsigned char **pp,
   long length);
ASN1_INTEGER *d2i_ASN1_UINTEGER(ASN1_INTEGER **a,const unsigned char **pp,
   long length);
ASN1_INTEGER * ASN1_INTEGER_dup(const ASN1_INTEGER *x);
int ASN1_INTEGER_cmp(const ASN1_INTEGER *x, const ASN1_INTEGER *y);
ASN1_ENUMERATED *ASN1_ENUMERATED_new(void); void ASN1_ENUMERATED_free(ASN1_ENUMERATED *a); ASN1_ENUMERATED *d2i_ASN1_ENUMERATED(ASN1_ENUMERATED **a, const unsigned char **in, long len); int i2d_ASN1_ENUMERATED(ASN1_ENUMERATED *a, unsigned char **out); extern const ASN1_ITEM ASN1_ENUMERATED_it;
int ASN1_UTCTIME_check(ASN1_UTCTIME *a);
ASN1_UTCTIME *ASN1_UTCTIME_set(ASN1_UTCTIME *s,time_t t);
ASN1_UTCTIME *ASN1_UTCTIME_adj(ASN1_UTCTIME *s, time_t t,
    int offset_day, long offset_sec);
int ASN1_UTCTIME_set_string(ASN1_UTCTIME *s, const char *str);
int ASN1_UTCTIME_cmp_time_t(const ASN1_UTCTIME *s, time_t t);
int ASN1_GENERALIZEDTIME_check(ASN1_GENERALIZEDTIME *a);
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_set(ASN1_GENERALIZEDTIME *s,time_t t);
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_adj(ASN1_GENERALIZEDTIME *s,
      time_t t, int offset_day, long offset_sec);
int ASN1_GENERALIZEDTIME_set_string(ASN1_GENERALIZEDTIME *s, const char *str);
ASN1_OCTET_STRING *ASN1_OCTET_STRING_new(void); void ASN1_OCTET_STRING_free(ASN1_OCTET_STRING *a); ASN1_OCTET_STRING *d2i_ASN1_OCTET_STRING(ASN1_OCTET_STRING **a, const unsigned char **in, long len); int i2d_ASN1_OCTET_STRING(ASN1_OCTET_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_OCTET_STRING_it;
ASN1_OCTET_STRING * ASN1_OCTET_STRING_dup(const ASN1_OCTET_STRING *a);
int ASN1_OCTET_STRING_cmp(const ASN1_OCTET_STRING *a, const ASN1_OCTET_STRING *b);
int ASN1_OCTET_STRING_set(ASN1_OCTET_STRING *str, const unsigned char *data, int len);
ASN1_VISIBLESTRING *ASN1_VISIBLESTRING_new(void); void ASN1_VISIBLESTRING_free(ASN1_VISIBLESTRING *a); ASN1_VISIBLESTRING *d2i_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING **a, const unsigned char **in, long len); int i2d_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_VISIBLESTRING_it;
ASN1_UNIVERSALSTRING *ASN1_UNIVERSALSTRING_new(void); void ASN1_UNIVERSALSTRING_free(ASN1_UNIVERSALSTRING *a); ASN1_UNIVERSALSTRING *d2i_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING **a, const unsigned char **in, long len); int i2d_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_UNIVERSALSTRING_it;
ASN1_UTF8STRING *ASN1_UTF8STRING_new(void); void ASN1_UTF8STRING_free(ASN1_UTF8STRING *a); ASN1_UTF8STRING *d2i_ASN1_UTF8STRING(ASN1_UTF8STRING **a, const unsigned char **in, long len); int i2d_ASN1_UTF8STRING(ASN1_UTF8STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_UTF8STRING_it;
ASN1_NULL *ASN1_NULL_new(void); void ASN1_NULL_free(ASN1_NULL *a); ASN1_NULL *d2i_ASN1_NULL(ASN1_NULL **a, const unsigned char **in, long len); int i2d_ASN1_NULL(ASN1_NULL *a, unsigned char **out); extern const ASN1_ITEM ASN1_NULL_it;
ASN1_BMPSTRING *ASN1_BMPSTRING_new(void); void ASN1_BMPSTRING_free(ASN1_BMPSTRING *a); ASN1_BMPSTRING *d2i_ASN1_BMPSTRING(ASN1_BMPSTRING **a, const unsigned char **in, long len); int i2d_ASN1_BMPSTRING(ASN1_BMPSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_BMPSTRING_it;
int UTF8_getc(const unsigned char *str, int len, unsigned long *val);
int UTF8_putc(unsigned char *str, int len, unsigned long value);
ASN1_STRING *ASN1_PRINTABLE_new(void); void ASN1_PRINTABLE_free(ASN1_STRING *a); ASN1_STRING *d2i_ASN1_PRINTABLE(ASN1_STRING **a, const unsigned char **in, long len); int i2d_ASN1_PRINTABLE(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_PRINTABLE_it;
ASN1_STRING *DIRECTORYSTRING_new(void); void DIRECTORYSTRING_free(ASN1_STRING *a); ASN1_STRING *d2i_DIRECTORYSTRING(ASN1_STRING **a, const unsigned char **in, long len); int i2d_DIRECTORYSTRING(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM DIRECTORYSTRING_it;
ASN1_STRING *DISPLAYTEXT_new(void); void DISPLAYTEXT_free(ASN1_STRING *a); ASN1_STRING *d2i_DISPLAYTEXT(ASN1_STRING **a, const unsigned char **in, long len); int i2d_DISPLAYTEXT(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM DISPLAYTEXT_it;
ASN1_PRINTABLESTRING *ASN1_PRINTABLESTRING_new(void); void ASN1_PRINTABLESTRING_free(ASN1_PRINTABLESTRING *a); ASN1_PRINTABLESTRING *d2i_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING **a, const unsigned char **in, long len); int i2d_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_PRINTABLESTRING_it;
ASN1_T61STRING *ASN1_T61STRING_new(void); void ASN1_T61STRING_free(ASN1_T61STRING *a); ASN1_T61STRING *d2i_ASN1_T61STRING(ASN1_T61STRING **a, const unsigned char **in, long len); int i2d_ASN1_T61STRING(ASN1_T61STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_T61STRING_it;
ASN1_IA5STRING *ASN1_IA5STRING_new(void); void ASN1_IA5STRING_free(ASN1_IA5STRING *a); ASN1_IA5STRING *d2i_ASN1_IA5STRING(ASN1_IA5STRING **a, const unsigned char **in, long len); int i2d_ASN1_IA5STRING(ASN1_IA5STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_IA5STRING_it;
ASN1_GENERALSTRING *ASN1_GENERALSTRING_new(void); void ASN1_GENERALSTRING_free(ASN1_GENERALSTRING *a); ASN1_GENERALSTRING *d2i_ASN1_GENERALSTRING(ASN1_GENERALSTRING **a, const unsigned char **in, long len); int i2d_ASN1_GENERALSTRING(ASN1_GENERALSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_GENERALSTRING_it;
ASN1_UTCTIME *ASN1_UTCTIME_new(void); void ASN1_UTCTIME_free(ASN1_UTCTIME *a); ASN1_UTCTIME *d2i_ASN1_UTCTIME(ASN1_UTCTIME **a, const unsigned char **in, long len); int i2d_ASN1_UTCTIME(ASN1_UTCTIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_UTCTIME_it;
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_new(void); void ASN1_GENERALIZEDTIME_free(ASN1_GENERALIZEDTIME *a); ASN1_GENERALIZEDTIME *d2i_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME **a, const unsigned char **in, long len); int i2d_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_GENERALIZEDTIME_it;
ASN1_TIME *ASN1_TIME_new(void); void ASN1_TIME_free(ASN1_TIME *a); ASN1_TIME *d2i_ASN1_TIME(ASN1_TIME **a, const unsigned char **in, long len); int i2d_ASN1_TIME(ASN1_TIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_TIME_it;
extern const ASN1_ITEM ASN1_OCTET_STRING_NDEF_it;
ASN1_TIME *ASN1_TIME_set(ASN1_TIME *s,time_t t);
ASN1_TIME *ASN1_TIME_adj(ASN1_TIME *s,time_t t,
int ASN1_TIME_check(ASN1_TIME *t);
ASN1_GENERALIZEDTIME *ASN1_TIME_to_generalizedtime(ASN1_TIME *t, ASN1_GENERALIZEDTIME **out);
int ASN1_TIME_set_string(ASN1_TIME *s, const char *str);
int i2d_ASN1_SET(struct stack_st_OPENSSL_BLOCK *a, unsigned char **pp,
   i2d_of_void *i2d, int ex_tag, int ex_class,
   int is_set);
struct stack_st_OPENSSL_BLOCK *d2i_ASN1_SET(struct stack_st_OPENSSL_BLOCK **a,
         long length, d2i_of_void *d2i,
         void (*free_func)(OPENSSL_BLOCK), int ex_tag,
         int ex_class);
int i2a_ASN1_INTEGER(BIO *bp, ASN1_INTEGER *a);
int a2i_ASN1_INTEGER(BIO *bp,ASN1_INTEGER *bs,char *buf,int size);
int i2a_ASN1_ENUMERATED(BIO *bp, ASN1_ENUMERATED *a);
int a2i_ASN1_ENUMERATED(BIO *bp,ASN1_ENUMERATED *bs,char *buf,int size);
int i2a_ASN1_OBJECT(BIO *bp,ASN1_OBJECT *a);
int a2i_ASN1_STRING(BIO *bp,ASN1_STRING *bs,char *buf,int size);
int i2a_ASN1_STRING(BIO *bp, ASN1_STRING *a, int type);
int i2t_ASN1_OBJECT(char *buf,int buf_len,ASN1_OBJECT *a);
int a2d_ASN1_OBJECT(unsigned char *out,int olen, const char *buf, int num);
ASN1_OBJECT *ASN1_OBJECT_create(int nid, unsigned char *data,int len,
 const char *sn, const char *ln);
int ASN1_INTEGER_set(ASN1_INTEGER *a, long v);
long ASN1_INTEGER_get(const ASN1_INTEGER *a);
ASN1_INTEGER *BN_to_ASN1_INTEGER(const BIGNUM *bn, ASN1_INTEGER *ai);
BIGNUM *ASN1_INTEGER_to_BN(const ASN1_INTEGER *ai,BIGNUM *bn);
int ASN1_ENUMERATED_set(ASN1_ENUMERATED *a, long v);
long ASN1_ENUMERATED_get(ASN1_ENUMERATED *a);
ASN1_ENUMERATED *BN_to_ASN1_ENUMERATED(BIGNUM *bn, ASN1_ENUMERATED *ai);
BIGNUM *ASN1_ENUMERATED_to_BN(ASN1_ENUMERATED *ai,BIGNUM *bn);
int ASN1_PRINTABLE_type(const unsigned char *s, int max);
int i2d_ASN1_bytes(ASN1_STRING *a, unsigned char **pp, int tag, int xclass);
ASN1_STRING *d2i_ASN1_bytes(ASN1_STRING **a, const unsigned char **pp,
 long length, int Ptag, int Pclass);
unsigned long ASN1_tag2bit(int tag);
ASN1_STRING *d2i_ASN1_type_bytes(ASN1_STRING **a,const unsigned char **pp,
  long length,int type);
int asn1_Finish(ASN1_CTX *c);
int asn1_const_Finish(ASN1_const_CTX *c);
int ASN1_get_object(const unsigned char **pp, long *plength, int *ptag,
 int *pclass, long omax);
int ASN1_check_infinite_end(unsigned char **p,long len);
int ASN1_const_check_infinite_end(const unsigned char **p,long len);
void ASN1_put_object(unsigned char **pp, int constructed, int length,
int ASN1_put_eoc(unsigned char **pp);
int ASN1_object_size(int constructed, int length, int tag);
void *ASN1_dup(i2d_of_void *i2d, d2i_of_void *d2i, void *x);
# 966 "/usr/include/openssl/asn1.h" 3 4
void *ASN1_item_dup(const ASN1_ITEM *it, void *x);
# 975 "/usr/include/openssl/asn1.h" 3 4
void *ASN1_d2i_fp(void *(*xnew)(void), d2i_of_void *d2i, FILE *in, void **x);
void *ASN1_item_d2i_fp(const ASN1_ITEM *it, FILE *in, void *x);
int ASN1_i2d_fp(i2d_of_void *i2d,FILE *out,void *x);
# 996 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_i2d_fp(const ASN1_ITEM *it, FILE *out, void *x);
int ASN1_STRING_print_ex_fp(FILE *fp, ASN1_STRING *str, unsigned long flags);
int ASN1_STRING_to_UTF8(unsigned char **out, ASN1_STRING *in);
void *ASN1_d2i_bio(void *(*xnew)(void), d2i_of_void *d2i, BIO *in, void **x);
void *ASN1_item_d2i_bio(const ASN1_ITEM *it, BIO *in, void *x);
int ASN1_i2d_bio(i2d_of_void *i2d,BIO *out, unsigned char *x);
# 1024 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_i2d_bio(const ASN1_ITEM *it, BIO *out, void *x);
int ASN1_UTCTIME_print(BIO *fp, const ASN1_UTCTIME *a);
int ASN1_GENERALIZEDTIME_print(BIO *fp, const ASN1_GENERALIZEDTIME *a);
int ASN1_TIME_print(BIO *fp, const ASN1_TIME *a);
int ASN1_STRING_print(BIO *bp, const ASN1_STRING *v);
int ASN1_STRING_print_ex(BIO *out, ASN1_STRING *str, unsigned long flags);
int ASN1_bn_print(BIO *bp, const char *number, const BIGNUM *num,
    unsigned char *buf, int off);
int ASN1_parse(BIO *bp,const unsigned char *pp,long len,int indent);
int ASN1_parse_dump(BIO *bp,const unsigned char *pp,long len,int indent,int dump);
const char *ASN1_tag2str(int tag);
NETSCAPE_X509 *NETSCAPE_X509_new(void); void NETSCAPE_X509_free(NETSCAPE_X509 *a); NETSCAPE_X509 *d2i_NETSCAPE_X509(NETSCAPE_X509 **a, const unsigned char **in, long len); int i2d_NETSCAPE_X509(NETSCAPE_X509 *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_X509_it;
int ASN1_UNIVERSALSTRING_to_string(ASN1_UNIVERSALSTRING *s);
int ASN1_TYPE_set_octetstring(ASN1_TYPE *a,
int ASN1_TYPE_get_octetstring(ASN1_TYPE *a,
 unsigned char *data, int max_len);
int ASN1_TYPE_set_int_octetstring(ASN1_TYPE *a, long num,
int ASN1_TYPE_get_int_octetstring(ASN1_TYPE *a,long *num,
struct stack_st_OPENSSL_BLOCK *ASN1_seq_unpack(const unsigned char *buf, int len,
     d2i_of_void *d2i, void (*free_func)(OPENSSL_BLOCK));
unsigned char *ASN1_seq_pack(struct stack_st_OPENSSL_BLOCK *safes, i2d_of_void *i2d,
        unsigned char **buf, int *len );
void *ASN1_unpack_string(ASN1_STRING *oct, d2i_of_void *d2i);
void *ASN1_item_unpack(ASN1_STRING *oct, const ASN1_ITEM *it);
ASN1_STRING *ASN1_pack_string(void *obj, i2d_of_void *i2d,
         ASN1_OCTET_STRING **oct);
ASN1_STRING *ASN1_item_pack(void *obj, const ASN1_ITEM *it, ASN1_OCTET_STRING **oct);
void ASN1_STRING_set_default_mask(unsigned long mask);
int ASN1_STRING_set_default_mask_asc(const char *p);
unsigned long ASN1_STRING_get_default_mask(void);
int ASN1_mbstring_copy(ASN1_STRING **out, const unsigned char *in, int len,
     int inform, unsigned long mask);
int ASN1_mbstring_ncopy(ASN1_STRING **out, const unsigned char *in, int len,
     int inform, unsigned long mask,
     long minsize, long maxsize);
ASN1_STRING *ASN1_STRING_set_by_NID(ASN1_STRING **out,
  const unsigned char *in, int inlen, int inform, int nid);
ASN1_STRING_TABLE *ASN1_STRING_TABLE_get(int nid);
int ASN1_STRING_TABLE_add(int, long, long, unsigned long, unsigned long);
void ASN1_STRING_TABLE_cleanup(void);
ASN1_VALUE *ASN1_item_new(const ASN1_ITEM *it);
void ASN1_item_free(ASN1_VALUE *val, const ASN1_ITEM *it);
ASN1_VALUE * ASN1_item_d2i(ASN1_VALUE **val, const unsigned char **in, long len, const ASN1_ITEM *it);
int ASN1_item_i2d(ASN1_VALUE *val, unsigned char **out, const ASN1_ITEM *it);
int ASN1_item_ndef_i2d(ASN1_VALUE *val, unsigned char **out, const ASN1_ITEM *it);
void ASN1_add_oid_module(void);
ASN1_TYPE *ASN1_generate_nconf(char *str, CONF *nconf);
ASN1_TYPE *ASN1_generate_v3(char *str, X509V3_CTX *cnf);
# 1118 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_print(BIO *out, ASN1_VALUE *ifld, int indent,
    const ASN1_ITEM *it, const ASN1_PCTX *pctx);
ASN1_PCTX *ASN1_PCTX_new(void);
void ASN1_PCTX_free(ASN1_PCTX *p);
unsigned long ASN1_PCTX_get_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_nm_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_nm_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_cert_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_cert_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_oid_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_oid_flags(ASN1_PCTX *p, unsigned long flags);
unsigned long ASN1_PCTX_get_str_flags(ASN1_PCTX *p);
void ASN1_PCTX_set_str_flags(ASN1_PCTX *p, unsigned long flags);
BIO_METHOD *BIO_f_asn1(void);
BIO *BIO_new_NDEF(BIO *out, ASN1_VALUE *val, const ASN1_ITEM *it);
int i2d_ASN1_bio_stream(BIO *out, ASN1_VALUE *val, BIO *in, int flags,
int PEM_write_bio_ASN1_stream(BIO *out, ASN1_VALUE *val, BIO *in, int flags,
    const char *hdr,
int SMIME_write_ASN1(BIO *bio, ASN1_VALUE *val, BIO *data, int flags,
    int ctype_nid, int econt_nid,
    struct stack_st_X509_ALGOR *mdalgs,
ASN1_VALUE *SMIME_read_ASN1(BIO *bio, BIO **bcont, const ASN1_ITEM *it);
int SMIME_crlf_copy(BIO *in, BIO *out, int flags);
int SMIME_text(BIO *in, BIO *out);
void ERR_load_ASN1_strings(void);
# 1404 "/usr/include/openssl/asn1.h" 3 4
# 961 "/usr/include/openssl/objects.h" 2 3 4
# 976 "/usr/include/openssl/objects.h" 3 4
extern "C" {
typedef struct obj_name_st
 int type;
 int alias;
 const char *name;
 const char *data;
 } OBJ_NAME;
int OBJ_NAME_init(void);
int OBJ_NAME_new_index(unsigned long (*hash_func)(const char *),
         int (*cmp_func)(const char *, const char *),
         void (*free_func)(const char *, int, const char *));
const char *OBJ_NAME_get(const char *name,int type);
int OBJ_NAME_add(const char *name,int type,const char *data);
int OBJ_NAME_remove(const char *name,int type);
void OBJ_NAME_cleanup(int type);
void OBJ_NAME_do_all(int type,void (*fn)(const OBJ_NAME *,void *arg),
       void *arg);
void OBJ_NAME_do_all_sorted(int type,void (*fn)(const OBJ_NAME *,void *arg),
       void *arg);
ASN1_OBJECT * OBJ_dup(const ASN1_OBJECT *o);
ASN1_OBJECT * OBJ_nid2obj(int n);
const char * OBJ_nid2ln(int n);
const char * OBJ_nid2sn(int n);
int OBJ_obj2nid(const ASN1_OBJECT *o);
ASN1_OBJECT * OBJ_txt2obj(const char *s, int no_name);
int OBJ_obj2txt(char *buf, int buf_len, const ASN1_OBJECT *a, int no_name);
int OBJ_txt2nid(const char *s);
int OBJ_ln2nid(const char *s);
int OBJ_sn2nid(const char *s);
int OBJ_cmp(const ASN1_OBJECT *a,const ASN1_OBJECT *b);
const void * OBJ_bsearch_(const void *key,const void *base,int num,int size,
const void * OBJ_bsearch_ex_(const void *key,const void *base,int num,
    int size,
    int (*cmp)(const void *, const void *),
    int flags);
# 1100 "/usr/include/openssl/objects.h" 3 4
int OBJ_new_nid(int num);
int OBJ_add_object(const ASN1_OBJECT *obj);
int OBJ_create(const char *oid,const char *sn,const char *ln);
void OBJ_cleanup(void );
int OBJ_create_objects(BIO *in);
int OBJ_find_sigid_algs(int signid, int *pdig_nid, int *ppkey_nid);
int OBJ_find_sigid_by_algs(int *psignid, int dig_nid, int pkey_nid);
int OBJ_add_sigid(int signid, int dig_id, int pkey_id);
void OBJ_sigid_free(void);
extern int obj_cleanup_defer;
void check_defer(int nid);
void ERR_load_OBJ_strings(void);
# 1136 "/usr/include/openssl/objects.h" 3 4
# 99 "/usr/include/openssl/evp.h" 2 3 4
# 126 "/usr/include/openssl/evp.h" 3 4
extern "C" {
struct evp_pkey_st
 int type;
 int save_type;
 int references;
 const EVP_PKEY_ASN1_METHOD *ameth;
 ENGINE *engine;
 union {
  char *ptr;
  struct rsa_st *rsa;
  struct dsa_st *dsa;
  struct dh_st *dh;
  struct ec_key_st *ec;
  } pkey;
 int save_parameters;
 struct stack_st_X509_ATTRIBUTE *attributes;
struct env_md_st
 int type;
 int pkey_type;
 int md_size;
 int (*init)(EVP_MD_CTX *ctx);
 int (*update)(EVP_MD_CTX *ctx,const void *data,size_t count);
 int (*final)(EVP_MD_CTX *ctx,unsigned char *md);
 int (*copy)(EVP_MD_CTX *to,const EVP_MD_CTX *from);
 int (*cleanup)(EVP_MD_CTX *ctx);
 int (*sign)(int type, const unsigned char *m, unsigned int m_length,
      unsigned char *sigret, unsigned int *siglen, void *key);
 int (*verify)(int type, const unsigned char *m, unsigned int m_length,
        const unsigned char *sigbuf, unsigned int siglen,
        void *key);
 int required_pkey_type[5];
 int block_size;
 int ctx_size;
 int (*md_ctrl)(EVP_MD_CTX *ctx, int cmd, int p1, void *p2);
typedef int evp_sign_method(int type,const unsigned char *m,
       unsigned int m_length,unsigned char *sigret,
typedef int evp_verify_method(int type,const unsigned char *m,
       unsigned int m_length,const unsigned char *sigbuf,
       unsigned int siglen, void *key);
# 269 "/usr/include/openssl/evp.h" 3 4
 const EVP_MD *digest;
 ENGINE *engine;
 void *md_data;
 EVP_PKEY_CTX *pctx;
# 307 "/usr/include/openssl/evp.h" 3 4
 int nid;
 int block_size;
 int key_len;
 int iv_len;
 int (*init)(EVP_CIPHER_CTX *ctx, const unsigned char *key,
      const unsigned char *iv, int enc);
 int (*do_cipher)(EVP_CIPHER_CTX *ctx, unsigned char *out,
    const unsigned char *in, size_t inl);
 int (*cleanup)(EVP_CIPHER_CTX *);
 int ctx_size;
 int (*set_asn1_parameters)(EVP_CIPHER_CTX *, ASN1_TYPE *);
 int (*get_asn1_parameters)(EVP_CIPHER_CTX *, ASN1_TYPE *);
 int (*ctrl)(EVP_CIPHER_CTX *, int type, int arg, void *ptr);
 void *app_data;
# 417 "/usr/include/openssl/evp.h" 3 4
typedef struct evp_cipher_info_st
 const EVP_CIPHER *cipher;
 unsigned char iv[16];
 } EVP_CIPHER_INFO;
 ENGINE *engine;
 int encrypt;
 int buf_len;
 unsigned char oiv[16];
 unsigned char buf[32];
 int num;
 void *app_data;
 int key_len;
 void *cipher_data;
 int final_used;
 int block_mask;
 unsigned char final[32];
typedef struct evp_Encode_Ctx_st
 int num;
 int length;
 unsigned char enc_data[80];
 int line_num;
 int expect_nl;
 } EVP_ENCODE_CTX;
typedef int (EVP_PBE_KEYGEN)(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
  ASN1_TYPE *param, const EVP_CIPHER *cipher,
                const EVP_MD *md, int en_de);
# 488 "/usr/include/openssl/evp.h" 3 4
int EVP_MD_type(const EVP_MD *md);
int EVP_MD_pkey_type(const EVP_MD *md);
int EVP_MD_size(const EVP_MD *md);
int EVP_MD_block_size(const EVP_MD *md);
unsigned long EVP_MD_flags(const EVP_MD *md);
const EVP_MD *EVP_MD_CTX_md(const EVP_MD_CTX *ctx);
int EVP_CIPHER_nid(const EVP_CIPHER *cipher);
int EVP_CIPHER_block_size(const EVP_CIPHER *cipher);
int EVP_CIPHER_key_length(const EVP_CIPHER *cipher);
int EVP_CIPHER_iv_length(const EVP_CIPHER *cipher);
unsigned long EVP_CIPHER_flags(const EVP_CIPHER *cipher);
const EVP_CIPHER * EVP_CIPHER_CTX_cipher(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_nid(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_block_size(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_key_length(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_iv_length(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_copy(EVP_CIPHER_CTX *out, const EVP_CIPHER_CTX *in);
void * EVP_CIPHER_CTX_get_app_data(const EVP_CIPHER_CTX *ctx);
void EVP_CIPHER_CTX_set_app_data(EVP_CIPHER_CTX *ctx, void *data);
unsigned long EVP_CIPHER_CTX_flags(const EVP_CIPHER_CTX *ctx);
# 546 "/usr/include/openssl/evp.h" 3 4
int EVP_Cipher(EVP_CIPHER_CTX *c,
  unsigned char *out,
  unsigned int inl);
# 560 "/usr/include/openssl/evp.h" 3 4
void EVP_MD_CTX_init(EVP_MD_CTX *ctx);
int EVP_MD_CTX_cleanup(EVP_MD_CTX *ctx);
EVP_MD_CTX *EVP_MD_CTX_create(void);
void EVP_MD_CTX_destroy(EVP_MD_CTX *ctx);
int EVP_MD_CTX_copy_ex(EVP_MD_CTX *out,const EVP_MD_CTX *in);
void EVP_MD_CTX_set_flags(EVP_MD_CTX *ctx, int flags);
void EVP_MD_CTX_clear_flags(EVP_MD_CTX *ctx, int flags);
int EVP_MD_CTX_test_flags(const EVP_MD_CTX *ctx,int flags);
int EVP_DigestInit_ex(EVP_MD_CTX *ctx, const EVP_MD *type, ENGINE *impl);
int EVP_DigestUpdate(EVP_MD_CTX *ctx,const void *d,
    size_t cnt);
int EVP_DigestFinal_ex(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s);
int EVP_Digest(const void *data, size_t count,
  unsigned char *md, unsigned int *size, const EVP_MD *type, ENGINE *impl);
int EVP_MD_CTX_copy(EVP_MD_CTX *out,const EVP_MD_CTX *in);
int EVP_DigestInit(EVP_MD_CTX *ctx, const EVP_MD *type);
int EVP_DigestFinal(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s);
int EVP_read_pw_string(char *buf,int length,const char *prompt,int verify);
int EVP_read_pw_string_min(char *buf,int minlen,int maxlen,const char *prompt,int verify);
void EVP_set_pw_prompt(const char *prompt);
char * EVP_get_pw_prompt(void);
int EVP_BytesToKey(const EVP_CIPHER *type,const EVP_MD *md,
  const unsigned char *salt, const unsigned char *data,
  int datal, int count, unsigned char *key,unsigned char *iv);
void EVP_CIPHER_CTX_set_flags(EVP_CIPHER_CTX *ctx, int flags);
void EVP_CIPHER_CTX_clear_flags(EVP_CIPHER_CTX *ctx, int flags);
int EVP_CIPHER_CTX_test_flags(const EVP_CIPHER_CTX *ctx,int flags);
int EVP_EncryptInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
  const unsigned char *key, const unsigned char *iv);
int EVP_EncryptInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
int EVP_EncryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
  int *outl, const unsigned char *in, int inl);
int EVP_EncryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_EncryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_DecryptInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
int EVP_DecryptInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
int EVP_DecryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
int EVP_DecryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_DecryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_CipherInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
         const unsigned char *key,const unsigned char *iv,
         int enc);
int EVP_CipherInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
         int enc);
int EVP_CipherUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
int EVP_CipherFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_CipherFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_SignFinal(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s,
  EVP_PKEY *pkey);
int EVP_VerifyFinal(EVP_MD_CTX *ctx,const unsigned char *sigbuf,
  unsigned int siglen,EVP_PKEY *pkey);
int EVP_DigestSignInit(EVP_MD_CTX *ctx, EVP_PKEY_CTX **pctx,
   const EVP_MD *type, ENGINE *e, EVP_PKEY *pkey);
int EVP_DigestSignFinal(EVP_MD_CTX *ctx,
   unsigned char *sigret, size_t *siglen);
int EVP_DigestVerifyInit(EVP_MD_CTX *ctx, EVP_PKEY_CTX **pctx,
int EVP_DigestVerifyFinal(EVP_MD_CTX *ctx,
   unsigned char *sig, size_t siglen);
int EVP_OpenInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *type,
  const unsigned char *ek, int ekl, const unsigned char *iv,
  EVP_PKEY *priv);
int EVP_OpenFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_SealInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *type,
   unsigned char **ek, int *ekl, unsigned char *iv,
  EVP_PKEY **pubk, int npubk);
int EVP_SealFinal(EVP_CIPHER_CTX *ctx,unsigned char *out,int *outl);
void EVP_EncodeInit(EVP_ENCODE_CTX *ctx);
void EVP_EncodeUpdate(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl,
  const unsigned char *in,int inl);
void EVP_EncodeFinal(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl);
int EVP_EncodeBlock(unsigned char *t, const unsigned char *f, int n);
void EVP_DecodeInit(EVP_ENCODE_CTX *ctx);
int EVP_DecodeUpdate(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl,
int EVP_DecodeFinal(EVP_ENCODE_CTX *ctx, unsigned
int EVP_DecodeBlock(unsigned char *t, const unsigned char *f, int n);
void EVP_CIPHER_CTX_init(EVP_CIPHER_CTX *a);
int EVP_CIPHER_CTX_cleanup(EVP_CIPHER_CTX *a);
EVP_CIPHER_CTX *EVP_CIPHER_CTX_new(void);
void EVP_CIPHER_CTX_free(EVP_CIPHER_CTX *a);
int EVP_CIPHER_CTX_set_key_length(EVP_CIPHER_CTX *x, int keylen);
int EVP_CIPHER_CTX_set_padding(EVP_CIPHER_CTX *c, int pad);
int EVP_CIPHER_CTX_ctrl(EVP_CIPHER_CTX *ctx, int type, int arg, void *ptr);
int EVP_CIPHER_CTX_rand_key(EVP_CIPHER_CTX *ctx, unsigned char *key);
BIO_METHOD *BIO_f_md(void);
BIO_METHOD *BIO_f_base64(void);
BIO_METHOD *BIO_f_cipher(void);
BIO_METHOD *BIO_f_reliable(void);
void BIO_set_cipher(BIO *b,const EVP_CIPHER *c,const unsigned char *k,
  const unsigned char *i, int enc);
const EVP_MD *EVP_md_null(void);
const EVP_MD *EVP_md2(void);
const EVP_MD *EVP_md4(void);
const EVP_MD *EVP_md5(void);
const EVP_MD *EVP_sha(void);
const EVP_MD *EVP_sha1(void);
const EVP_MD *EVP_dss(void);
const EVP_MD *EVP_dss1(void);
const EVP_MD *EVP_ecdsa(void);
const EVP_MD *EVP_sha224(void);
const EVP_MD *EVP_sha256(void);
const EVP_MD *EVP_sha384(void);
const EVP_MD *EVP_sha512(void);
const EVP_MD *EVP_ripemd160(void);
const EVP_MD *EVP_whirlpool(void);
const EVP_CIPHER *EVP_enc_null(void);
const EVP_CIPHER *EVP_des_ecb(void);
const EVP_CIPHER *EVP_des_ede(void);
const EVP_CIPHER *EVP_des_ede3(void);
const EVP_CIPHER *EVP_des_ede_ecb(void);
const EVP_CIPHER *EVP_des_ede3_ecb(void);
const EVP_CIPHER *EVP_des_cfb64(void);
const EVP_CIPHER *EVP_des_cfb1(void);
const EVP_CIPHER *EVP_des_cfb8(void);
const EVP_CIPHER *EVP_des_ede_cfb64(void);
const EVP_CIPHER *EVP_des_ede3_cfb64(void);
const EVP_CIPHER *EVP_des_ede3_cfb1(void);
const EVP_CIPHER *EVP_des_ede3_cfb8(void);
const EVP_CIPHER *EVP_des_ofb(void);
const EVP_CIPHER *EVP_des_ede_ofb(void);
const EVP_CIPHER *EVP_des_ede3_ofb(void);
const EVP_CIPHER *EVP_des_cbc(void);
const EVP_CIPHER *EVP_des_ede_cbc(void);
const EVP_CIPHER *EVP_des_ede3_cbc(void);
const EVP_CIPHER *EVP_desx_cbc(void);
const EVP_CIPHER *EVP_des_ede3_wrap(void);
# 752 "/usr/include/openssl/evp.h" 3 4
const EVP_CIPHER *EVP_rc4(void);
const EVP_CIPHER *EVP_rc4_40(void);
const EVP_CIPHER *EVP_rc4_hmac_md5(void);
const EVP_CIPHER *EVP_idea_ecb(void);
const EVP_CIPHER *EVP_idea_cfb64(void);
const EVP_CIPHER *EVP_idea_ofb(void);
const EVP_CIPHER *EVP_idea_cbc(void);
const EVP_CIPHER *EVP_rc2_ecb(void);
const EVP_CIPHER *EVP_rc2_cbc(void);
const EVP_CIPHER *EVP_rc2_40_cbc(void);
const EVP_CIPHER *EVP_rc2_64_cbc(void);
const EVP_CIPHER *EVP_rc2_cfb64(void);
const EVP_CIPHER *EVP_rc2_ofb(void);
const EVP_CIPHER *EVP_bf_ecb(void);
const EVP_CIPHER *EVP_bf_cbc(void);
const EVP_CIPHER *EVP_bf_cfb64(void);
const EVP_CIPHER *EVP_bf_ofb(void);
const EVP_CIPHER *EVP_cast5_ecb(void);
const EVP_CIPHER *EVP_cast5_cbc(void);
const EVP_CIPHER *EVP_cast5_cfb64(void);
const EVP_CIPHER *EVP_cast5_ofb(void);
const EVP_CIPHER *EVP_aes_128_ecb(void);
const EVP_CIPHER *EVP_aes_128_cbc(void);
const EVP_CIPHER *EVP_aes_128_cfb1(void);
const EVP_CIPHER *EVP_aes_128_cfb8(void);
const EVP_CIPHER *EVP_aes_128_cfb128(void);
const EVP_CIPHER *EVP_aes_128_ofb(void);
const EVP_CIPHER *EVP_aes_128_ctr(void);
const EVP_CIPHER *EVP_aes_128_ccm(void);
const EVP_CIPHER *EVP_aes_128_gcm(void);
const EVP_CIPHER *EVP_aes_128_xts(void);
const EVP_CIPHER *EVP_aes_128_wrap(void);
const EVP_CIPHER *EVP_aes_128_wrap_pad(void);
const EVP_CIPHER *EVP_aes_192_ecb(void);
const EVP_CIPHER *EVP_aes_192_cbc(void);
const EVP_CIPHER *EVP_aes_192_cfb1(void);
const EVP_CIPHER *EVP_aes_192_cfb8(void);
const EVP_CIPHER *EVP_aes_192_cfb128(void);
const EVP_CIPHER *EVP_aes_192_ofb(void);
const EVP_CIPHER *EVP_aes_192_ctr(void);
const EVP_CIPHER *EVP_aes_192_ccm(void);
const EVP_CIPHER *EVP_aes_192_gcm(void);
const EVP_CIPHER *EVP_aes_192_wrap(void);
const EVP_CIPHER *EVP_aes_192_wrap_pad(void);
const EVP_CIPHER *EVP_aes_256_ecb(void);
const EVP_CIPHER *EVP_aes_256_cbc(void);
const EVP_CIPHER *EVP_aes_256_cfb1(void);
const EVP_CIPHER *EVP_aes_256_cfb8(void);
const EVP_CIPHER *EVP_aes_256_cfb128(void);
const EVP_CIPHER *EVP_aes_256_ofb(void);
const EVP_CIPHER *EVP_aes_256_ctr(void);
const EVP_CIPHER *EVP_aes_256_ccm(void);
const EVP_CIPHER *EVP_aes_256_gcm(void);
const EVP_CIPHER *EVP_aes_256_xts(void);
const EVP_CIPHER *EVP_aes_256_wrap(void);
const EVP_CIPHER *EVP_aes_256_wrap_pad(void);
const EVP_CIPHER *EVP_aes_128_cbc_hmac_sha1(void);
const EVP_CIPHER *EVP_aes_256_cbc_hmac_sha1(void);
const EVP_CIPHER *EVP_camellia_128_ecb(void);
const EVP_CIPHER *EVP_camellia_128_cbc(void);
const EVP_CIPHER *EVP_camellia_128_cfb1(void);
const EVP_CIPHER *EVP_camellia_128_cfb8(void);
const EVP_CIPHER *EVP_camellia_128_cfb128(void);
const EVP_CIPHER *EVP_camellia_128_ofb(void);
const EVP_CIPHER *EVP_camellia_192_ecb(void);
const EVP_CIPHER *EVP_camellia_192_cbc(void);
const EVP_CIPHER *EVP_camellia_192_cfb1(void);
const EVP_CIPHER *EVP_camellia_192_cfb8(void);
const EVP_CIPHER *EVP_camellia_192_cfb128(void);
const EVP_CIPHER *EVP_camellia_192_ofb(void);
const EVP_CIPHER *EVP_camellia_256_ecb(void);
const EVP_CIPHER *EVP_camellia_256_cbc(void);
const EVP_CIPHER *EVP_camellia_256_cfb1(void);
const EVP_CIPHER *EVP_camellia_256_cfb8(void);
const EVP_CIPHER *EVP_camellia_256_cfb128(void);
const EVP_CIPHER *EVP_camellia_256_ofb(void);
const EVP_CIPHER *EVP_seed_ecb(void);
const EVP_CIPHER *EVP_seed_cbc(void);
const EVP_CIPHER *EVP_seed_cfb128(void);
const EVP_CIPHER *EVP_seed_ofb(void);
void OPENSSL_add_all_algorithms_noconf(void);
void OPENSSL_add_all_algorithms_conf(void);
# 875 "/usr/include/openssl/evp.h" 3 4
void OpenSSL_add_all_ciphers(void);
void OpenSSL_add_all_digests(void);
int EVP_add_cipher(const EVP_CIPHER *cipher);
int EVP_add_digest(const EVP_MD *digest);
const EVP_CIPHER *EVP_get_cipherbyname(const char *name);
const EVP_MD *EVP_get_digestbyname(const char *name);
void EVP_cleanup(void);
void EVP_CIPHER_do_all(void (*fn)(const EVP_CIPHER *ciph,
  const char *from, const char *to, void *x), void *arg);
void EVP_CIPHER_do_all_sorted(void (*fn)(const EVP_CIPHER *ciph,
void EVP_MD_do_all(void (*fn)(const EVP_MD *ciph,
void EVP_MD_do_all_sorted(void (*fn)(const EVP_MD *ciph,
int EVP_PKEY_decrypt_old(unsigned char *dec_key,
   const unsigned char *enc_key,int enc_key_len,
   EVP_PKEY *private_key);
int EVP_PKEY_encrypt_old(unsigned char *enc_key,
   const unsigned char *key,int key_len,
   EVP_PKEY *pub_key);
int EVP_PKEY_type(int type);
int EVP_PKEY_id(const EVP_PKEY *pkey);
int EVP_PKEY_base_id(const EVP_PKEY *pkey);
int EVP_PKEY_bits(EVP_PKEY *pkey);
int EVP_PKEY_size(EVP_PKEY *pkey);
int EVP_PKEY_set_type(EVP_PKEY *pkey,int type);
int EVP_PKEY_set_type_str(EVP_PKEY *pkey, const char *str, int len);
int EVP_PKEY_assign(EVP_PKEY *pkey,int type,void *key);
void * EVP_PKEY_get0(EVP_PKEY *pkey);
struct rsa_st;
int EVP_PKEY_set1_RSA(EVP_PKEY *pkey,struct rsa_st *key);
struct rsa_st *EVP_PKEY_get1_RSA(EVP_PKEY *pkey);
struct dsa_st;
int EVP_PKEY_set1_DSA(EVP_PKEY *pkey,struct dsa_st *key);
struct dsa_st *EVP_PKEY_get1_DSA(EVP_PKEY *pkey);
struct dh_st;
int EVP_PKEY_set1_DH(EVP_PKEY *pkey,struct dh_st *key);
struct dh_st *EVP_PKEY_get1_DH(EVP_PKEY *pkey);
struct ec_key_st;
int EVP_PKEY_set1_EC_KEY(EVP_PKEY *pkey,struct ec_key_st *key);
struct ec_key_st *EVP_PKEY_get1_EC_KEY(EVP_PKEY *pkey);
EVP_PKEY * EVP_PKEY_new(void);
void EVP_PKEY_free(EVP_PKEY *pkey);
EVP_PKEY * d2i_PublicKey(int type,EVP_PKEY **a, const unsigned char **pp,
   long length);
int i2d_PublicKey(EVP_PKEY *a, unsigned char **pp);
EVP_PKEY * d2i_PrivateKey(int type,EVP_PKEY **a, const unsigned char **pp,
   long length);
EVP_PKEY * d2i_AutoPrivateKey(EVP_PKEY **a, const unsigned char **pp,
   long length);
int i2d_PrivateKey(EVP_PKEY *a, unsigned char **pp);
int EVP_PKEY_copy_parameters(EVP_PKEY *to, const EVP_PKEY *from);
int EVP_PKEY_missing_parameters(const EVP_PKEY *pkey);
int EVP_PKEY_save_parameters(EVP_PKEY *pkey,int mode);
int EVP_PKEY_cmp_parameters(const EVP_PKEY *a, const EVP_PKEY *b);
int EVP_PKEY_cmp(const EVP_PKEY *a, const EVP_PKEY *b);
int EVP_PKEY_print_public(BIO *out, const EVP_PKEY *pkey,
    int indent, ASN1_PCTX *pctx);
int EVP_PKEY_print_private(BIO *out, const EVP_PKEY *pkey,
int EVP_PKEY_print_params(BIO *out, const EVP_PKEY *pkey,
int EVP_PKEY_get_default_digest_nid(EVP_PKEY *pkey, int *pnid);
int EVP_CIPHER_type(const EVP_CIPHER *ctx);
int EVP_CIPHER_param_to_asn1(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int EVP_CIPHER_asn1_to_param(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int EVP_CIPHER_set_asn1_iv(EVP_CIPHER_CTX *c,ASN1_TYPE *type);
int EVP_CIPHER_get_asn1_iv(EVP_CIPHER_CTX *c,ASN1_TYPE *type);
int PKCS5_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
    ASN1_TYPE *param, const EVP_CIPHER *cipher, const EVP_MD *md,
    int en_de);
int PKCS5_PBKDF2_HMAC_SHA1(const char *pass, int passlen,
      const unsigned char *salt, int saltlen, int iter,
      int keylen, unsigned char *out);
int PKCS5_PBKDF2_HMAC(const char *pass, int passlen,
      const EVP_MD *digest,
int PKCS5_v2_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
    int en_de);
void PKCS5_PBE_add(void);
int EVP_PBE_CipherInit (ASN1_OBJECT *pbe_obj, const char *pass, int passlen,
      ASN1_TYPE *param, EVP_CIPHER_CTX *ctx, int en_de);
# 1001 "/usr/include/openssl/evp.h" 3 4
int EVP_PBE_alg_add_type(int pbe_type, int pbe_nid, int cipher_nid, int md_nid,
      EVP_PBE_KEYGEN *keygen);
int EVP_PBE_alg_add(int nid, const EVP_CIPHER *cipher, const EVP_MD *md,
int EVP_PBE_find(int type, int pbe_nid,
   int *pcnid, int *pmnid, EVP_PBE_KEYGEN **pkeygen);
void EVP_PBE_cleanup(void);
# 1019 "/usr/include/openssl/evp.h" 3 4
int EVP_PKEY_asn1_get_count(void);
const EVP_PKEY_ASN1_METHOD *EVP_PKEY_asn1_get0(int idx);
const EVP_PKEY_ASN1_METHOD *EVP_PKEY_asn1_find(ENGINE **pe, int type);
const EVP_PKEY_ASN1_METHOD *EVP_PKEY_asn1_find_str(ENGINE **pe,
int EVP_PKEY_asn1_add0(const EVP_PKEY_ASN1_METHOD *ameth);
int EVP_PKEY_asn1_add_alias(int to, int from);
int EVP_PKEY_asn1_get0_info(int *ppkey_id, int *pkey_base_id, int *ppkey_flags,
    const char **pinfo, const char **ppem_str,
const EVP_PKEY_ASN1_METHOD* EVP_PKEY_get0_asn1(EVP_PKEY *pkey);
EVP_PKEY_ASN1_METHOD* EVP_PKEY_asn1_new(int id, int flags,
     const char *pem_str, const char *info);
void EVP_PKEY_asn1_copy(EVP_PKEY_ASN1_METHOD *dst,
   const EVP_PKEY_ASN1_METHOD *src);
void EVP_PKEY_asn1_free(EVP_PKEY_ASN1_METHOD *ameth);
void EVP_PKEY_asn1_set_public(EVP_PKEY_ASN1_METHOD *ameth,
  int (*pub_decode)(EVP_PKEY *pk, X509_PUBKEY *pub),
  int (*pub_encode)(X509_PUBKEY *pub, const EVP_PKEY *pk),
  int (*pub_cmp)(const EVP_PKEY *a, const EVP_PKEY *b),
  int (*pub_print)(BIO *out, const EVP_PKEY *pkey, int indent,
       ASN1_PCTX *pctx),
  int (*pkey_size)(const EVP_PKEY *pk),
  int (*pkey_bits)(const EVP_PKEY *pk));
void EVP_PKEY_asn1_set_private(EVP_PKEY_ASN1_METHOD *ameth,
  int (*priv_decode)(EVP_PKEY *pk, PKCS8_PRIV_KEY_INFO *p8inf),
  int (*priv_encode)(PKCS8_PRIV_KEY_INFO *p8, const EVP_PKEY *pk),
  int (*priv_print)(BIO *out, const EVP_PKEY *pkey, int indent,
       ASN1_PCTX *pctx));
void EVP_PKEY_asn1_set_param(EVP_PKEY_ASN1_METHOD *ameth,
  int (*param_decode)(EVP_PKEY *pkey,
    const unsigned char **pder, int derlen),
  int (*param_encode)(const EVP_PKEY *pkey, unsigned char **pder),
  int (*param_missing)(const EVP_PKEY *pk),
  int (*param_copy)(EVP_PKEY *to, const EVP_PKEY *from),
  int (*param_cmp)(const EVP_PKEY *a, const EVP_PKEY *b),
  int (*param_print)(BIO *out, const EVP_PKEY *pkey, int indent,
       ASN1_PCTX *pctx));
void EVP_PKEY_asn1_set_free(EVP_PKEY_ASN1_METHOD *ameth,
  void (*pkey_free)(EVP_PKEY *pkey));
void EVP_PKEY_asn1_set_ctrl(EVP_PKEY_ASN1_METHOD *ameth,
  int (*pkey_ctrl)(EVP_PKEY *pkey, int op,
       long arg1, void *arg2));
# 1125 "/usr/include/openssl/evp.h" 3 4
const EVP_PKEY_METHOD *EVP_PKEY_meth_find(int type);
EVP_PKEY_METHOD* EVP_PKEY_meth_new(int id, int flags);
void EVP_PKEY_meth_get0_info(int *ppkey_id, int *pflags,
    const EVP_PKEY_METHOD *meth);
void EVP_PKEY_meth_copy(EVP_PKEY_METHOD *dst, const EVP_PKEY_METHOD *src);
void EVP_PKEY_meth_free(EVP_PKEY_METHOD *pmeth);
int EVP_PKEY_meth_add0(const EVP_PKEY_METHOD *pmeth);
EVP_PKEY_CTX *EVP_PKEY_CTX_new(EVP_PKEY *pkey, ENGINE *e);
EVP_PKEY_CTX *EVP_PKEY_CTX_new_id(int id, ENGINE *e);
EVP_PKEY_CTX *EVP_PKEY_CTX_dup(EVP_PKEY_CTX *ctx);
void EVP_PKEY_CTX_free(EVP_PKEY_CTX *ctx);
int EVP_PKEY_CTX_ctrl(EVP_PKEY_CTX *ctx, int keytype, int optype,
int EVP_PKEY_CTX_ctrl_str(EVP_PKEY_CTX *ctx, const char *type,
      const char *value);
int EVP_PKEY_CTX_get_operation(EVP_PKEY_CTX *ctx);
void EVP_PKEY_CTX_set0_keygen_info(EVP_PKEY_CTX *ctx, int *dat, int datlen);
EVP_PKEY *EVP_PKEY_new_mac_key(int type, ENGINE *e,
    const unsigned char *key, int keylen);
void EVP_PKEY_CTX_set_data(EVP_PKEY_CTX *ctx, void *data);
void *EVP_PKEY_CTX_get_data(EVP_PKEY_CTX *ctx);
EVP_PKEY *EVP_PKEY_CTX_get0_pkey(EVP_PKEY_CTX *ctx);
EVP_PKEY *EVP_PKEY_CTX_get0_peerkey(EVP_PKEY_CTX *ctx);
void EVP_PKEY_CTX_set_app_data(EVP_PKEY_CTX *ctx, void *data);
void *EVP_PKEY_CTX_get_app_data(EVP_PKEY_CTX *ctx);
int EVP_PKEY_sign_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_sign(EVP_PKEY_CTX *ctx,
   unsigned char *sig, size_t *siglen,
   const unsigned char *tbs, size_t tbslen);
int EVP_PKEY_verify_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_verify(EVP_PKEY_CTX *ctx,
   const unsigned char *sig, size_t siglen,
int EVP_PKEY_verify_recover_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_verify_recover(EVP_PKEY_CTX *ctx,
   unsigned char *rout, size_t *routlen,
   const unsigned char *sig, size_t siglen);
int EVP_PKEY_encrypt_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_encrypt(EVP_PKEY_CTX *ctx,
   unsigned char *out, size_t *outlen,
   const unsigned char *in, size_t inlen);
int EVP_PKEY_decrypt_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_decrypt(EVP_PKEY_CTX *ctx,
int EVP_PKEY_derive_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_derive_set_peer(EVP_PKEY_CTX *ctx, EVP_PKEY *peer);
int EVP_PKEY_derive(EVP_PKEY_CTX *ctx, unsigned char *key, size_t *keylen);
typedef int EVP_PKEY_gen_cb(EVP_PKEY_CTX *ctx);
int EVP_PKEY_paramgen_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_paramgen(EVP_PKEY_CTX *ctx, EVP_PKEY **ppkey);
int EVP_PKEY_keygen_init(EVP_PKEY_CTX *ctx);
int EVP_PKEY_keygen(EVP_PKEY_CTX *ctx, EVP_PKEY **ppkey);
void EVP_PKEY_CTX_set_cb(EVP_PKEY_CTX *ctx, EVP_PKEY_gen_cb *cb);
EVP_PKEY_gen_cb *EVP_PKEY_CTX_get_cb(EVP_PKEY_CTX *ctx);
int EVP_PKEY_CTX_get_keygen_info(EVP_PKEY_CTX *ctx, int idx);
void EVP_PKEY_meth_set_init(EVP_PKEY_METHOD *pmeth,
 int (*init)(EVP_PKEY_CTX *ctx));
void EVP_PKEY_meth_set_copy(EVP_PKEY_METHOD *pmeth,
 int (*copy)(EVP_PKEY_CTX *dst, EVP_PKEY_CTX *src));
void EVP_PKEY_meth_set_cleanup(EVP_PKEY_METHOD *pmeth,
 void (*cleanup)(EVP_PKEY_CTX *ctx));
void EVP_PKEY_meth_set_paramgen(EVP_PKEY_METHOD *pmeth,
 int (*paramgen_init)(EVP_PKEY_CTX *ctx),
 int (*paramgen)(EVP_PKEY_CTX *ctx, EVP_PKEY *pkey));
void EVP_PKEY_meth_set_keygen(EVP_PKEY_METHOD *pmeth,
 int (*keygen_init)(EVP_PKEY_CTX *ctx),
 int (*keygen)(EVP_PKEY_CTX *ctx, EVP_PKEY *pkey));
void EVP_PKEY_meth_set_sign(EVP_PKEY_METHOD *pmeth,
 int (*sign_init)(EVP_PKEY_CTX *ctx),
 int (*sign)(EVP_PKEY_CTX *ctx, unsigned char *sig, size_t *siglen,
     const unsigned char *tbs, size_t tbslen));
void EVP_PKEY_meth_set_verify(EVP_PKEY_METHOD *pmeth,
 int (*verify_init)(EVP_PKEY_CTX *ctx),
 int (*verify)(EVP_PKEY_CTX *ctx, const unsigned char *sig, size_t siglen,
void EVP_PKEY_meth_set_verify_recover(EVP_PKEY_METHOD *pmeth,
 int (*verify_recover_init)(EVP_PKEY_CTX *ctx),
 int (*verify_recover)(EVP_PKEY_CTX *ctx,
void EVP_PKEY_meth_set_signctx(EVP_PKEY_METHOD *pmeth,
 int (*signctx_init)(EVP_PKEY_CTX *ctx, EVP_MD_CTX *mctx),
 int (*signctx)(EVP_PKEY_CTX *ctx, unsigned char *sig, size_t *siglen,
     EVP_MD_CTX *mctx));
void EVP_PKEY_meth_set_verifyctx(EVP_PKEY_METHOD *pmeth,
 int (*verifyctx_init)(EVP_PKEY_CTX *ctx, EVP_MD_CTX *mctx),
 int (*verifyctx)(EVP_PKEY_CTX *ctx, const unsigned char *sig,int siglen,
     EVP_MD_CTX *mctx));
void EVP_PKEY_meth_set_encrypt(EVP_PKEY_METHOD *pmeth,
 int (*encrypt_init)(EVP_PKEY_CTX *ctx),
 int (*encryptfn)(EVP_PKEY_CTX *ctx, unsigned char *out, size_t *outlen,
     const unsigned char *in, size_t inlen));
void EVP_PKEY_meth_set_decrypt(EVP_PKEY_METHOD *pmeth,
 int (*decrypt_init)(EVP_PKEY_CTX *ctx),
 int (*decrypt)(EVP_PKEY_CTX *ctx, unsigned char *out, size_t *outlen,
void EVP_PKEY_meth_set_derive(EVP_PKEY_METHOD *pmeth,
 int (*derive_init)(EVP_PKEY_CTX *ctx),
 int (*derive)(EVP_PKEY_CTX *ctx, unsigned char *key, size_t *keylen));
void EVP_PKEY_meth_set_ctrl(EVP_PKEY_METHOD *pmeth,
 int (*ctrl)(EVP_PKEY_CTX *ctx, int type, int p1, void *p2),
 int (*ctrl_str)(EVP_PKEY_CTX *ctx,
     const char *type, const char *value));
void EVP_add_alg_module(void);
void ERR_load_EVP_strings(void);
# 1420 "/usr/include/openssl/evp.h" 3 4
# 74 "/usr/include/openssl/x509.h" 2 3 4
# 83 "/usr/include/openssl/x509.h" 3 4
# 1 "/usr/include/openssl/ec.h" 1 3 4
# 79 "/usr/include/openssl/ec.h" 3 4
extern "C" {
# 80 "/usr/include/openssl/ec.h" 2 3 4
# 92 "/usr/include/openssl/ec.h" 3 4
extern "C" {
# 106 "/usr/include/openssl/ec.h" 3 4
typedef enum {
 POINT_CONVERSION_COMPRESSED = 2,
 POINT_CONVERSION_UNCOMPRESSED = 4,
 POINT_CONVERSION_HYBRID = 6
} point_conversion_form_t;
typedef struct ec_method_st EC_METHOD;
typedef struct ec_group_st
# 129 "/usr/include/openssl/ec.h" 3 4
 EC_GROUP;
typedef struct ec_point_st EC_POINT;
# 142 "/usr/include/openssl/ec.h" 3 4
const EC_METHOD *EC_GFp_simple_method(void);
const EC_METHOD *EC_GFp_mont_method(void);
const EC_METHOD *EC_GFp_nist_method(void);
# 181 "/usr/include/openssl/ec.h" 3 4
EC_GROUP *EC_GROUP_new(const EC_METHOD *meth);
void EC_GROUP_free(EC_GROUP *group);
void EC_GROUP_clear_free(EC_GROUP *group);
int EC_GROUP_copy(EC_GROUP *dst, const EC_GROUP *src);
EC_GROUP *EC_GROUP_dup(const EC_GROUP *src);
const EC_METHOD *EC_GROUP_method_of(const EC_GROUP *group);
int EC_METHOD_get_field_type(const EC_METHOD *meth);
# 227 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_set_generator(EC_GROUP *group, const EC_POINT *generator, const BIGNUM *order, const BIGNUM *cofactor);
const EC_POINT *EC_GROUP_get0_generator(const EC_GROUP *group);
int EC_GROUP_get_order(const EC_GROUP *group, BIGNUM *order, BN_CTX *ctx);
int EC_GROUP_get_cofactor(const EC_GROUP *group, BIGNUM *cofactor, BN_CTX *ctx);
void EC_GROUP_set_curve_name(EC_GROUP *group, int nid);
int EC_GROUP_get_curve_name(const EC_GROUP *group);
void EC_GROUP_set_asn1_flag(EC_GROUP *group, int flag);
int EC_GROUP_get_asn1_flag(const EC_GROUP *group);
void EC_GROUP_set_point_conversion_form(EC_GROUP *group, point_conversion_form_t form);
point_conversion_form_t EC_GROUP_get_point_conversion_form(const EC_GROUP *);
unsigned char *EC_GROUP_get0_seed(const EC_GROUP *x);
size_t EC_GROUP_get_seed_len(const EC_GROUP *);
size_t EC_GROUP_set_seed(EC_GROUP *, const unsigned char *, size_t len);
# 281 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_set_curve_GFp(EC_GROUP *group, const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
# 291 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_get_curve_GFp(const EC_GROUP *group, BIGNUM *p, BIGNUM *a, BIGNUM *b, BN_CTX *ctx);
int EC_GROUP_get_degree(const EC_GROUP *group);
int EC_GROUP_check(const EC_GROUP *group, BN_CTX *ctx);
int EC_GROUP_check_discriminant(const EC_GROUP *group, BN_CTX *ctx);
int EC_GROUP_cmp(const EC_GROUP *a, const EC_GROUP *b, BN_CTX *ctx);
# 332 "/usr/include/openssl/ec.h" 3 4
EC_GROUP *EC_GROUP_new_curve_GFp(const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
EC_GROUP *EC_GROUP_new_by_curve_name(int nid);
typedef struct {
 int nid;
 const char *comment;
 } EC_builtin_curve;
size_t EC_get_builtin_curves(EC_builtin_curve *r, size_t nitems);
# 365 "/usr/include/openssl/ec.h" 3 4
EC_POINT *EC_POINT_new(const EC_GROUP *group);
void EC_POINT_free(EC_POINT *point);
void EC_POINT_clear_free(EC_POINT *point);
int EC_POINT_copy(EC_POINT *dst, const EC_POINT *src);
EC_POINT *EC_POINT_dup(const EC_POINT *src, const EC_GROUP *group);
const EC_METHOD *EC_POINT_method_of(const EC_POINT *point);
int EC_POINT_set_to_infinity(const EC_GROUP *group, EC_POINT *point);
# 414 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_Jprojective_coordinates_GFp(const EC_GROUP *group, EC_POINT *p,
 const BIGNUM *x, const BIGNUM *y, const BIGNUM *z, BN_CTX *ctx);
# 426 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_get_Jprojective_coordinates_GFp(const EC_GROUP *group,
 const EC_POINT *p, BIGNUM *x, BIGNUM *y, BIGNUM *z, BN_CTX *ctx);
# 437 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_affine_coordinates_GFp(const EC_GROUP *group, EC_POINT *p,
 const BIGNUM *x, const BIGNUM *y, BN_CTX *ctx);
# 448 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_get_affine_coordinates_GFp(const EC_GROUP *group,
 const EC_POINT *p, BIGNUM *x, BIGNUM *y, BN_CTX *ctx);
# 459 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_set_compressed_coordinates_GFp(const EC_GROUP *group, EC_POINT *p,
 const BIGNUM *x, int y_bit, BN_CTX *ctx);
# 471 "/usr/include/openssl/ec.h" 3 4
size_t EC_POINT_point2oct(const EC_GROUP *group, const EC_POINT *p,
 point_conversion_form_t form,
        unsigned char *buf, size_t len, BN_CTX *ctx);
# 483 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_oct2point(const EC_GROUP *group, EC_POINT *p,
        const unsigned char *buf, size_t len, BN_CTX *ctx);
BIGNUM *EC_POINT_point2bn(const EC_GROUP *, const EC_POINT *,
 point_conversion_form_t form, BIGNUM *, BN_CTX *);
EC_POINT *EC_POINT_bn2point(const EC_GROUP *, const BIGNUM *,
 EC_POINT *, BN_CTX *);
char *EC_POINT_point2hex(const EC_GROUP *, const EC_POINT *,
 point_conversion_form_t form, BN_CTX *);
EC_POINT *EC_POINT_hex2point(const EC_GROUP *, const char *,
# 509 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_add(const EC_GROUP *group, EC_POINT *r, const EC_POINT *a, const EC_POINT *b, BN_CTX *ctx);
# 518 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_dbl(const EC_GROUP *group, EC_POINT *r, const EC_POINT *a, BN_CTX *ctx);
int EC_POINT_invert(const EC_GROUP *group, EC_POINT *a, BN_CTX *ctx);
int EC_POINT_is_at_infinity(const EC_GROUP *group, const EC_POINT *p);
int EC_POINT_is_on_curve(const EC_GROUP *group, const EC_POINT *point, BN_CTX *ctx);
# 550 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_cmp(const EC_GROUP *group, const EC_POINT *a, const EC_POINT *b, BN_CTX *ctx);
int EC_POINT_make_affine(const EC_GROUP *group, EC_POINT *point, BN_CTX *ctx);
int EC_POINTs_make_affine(const EC_GROUP *group, size_t num, EC_POINT *points[], BN_CTX *ctx);
# 565 "/usr/include/openssl/ec.h" 3 4
int EC_POINTs_mul(const EC_GROUP *group, EC_POINT *r, const BIGNUM *n, size_t num, const EC_POINT *p[], const BIGNUM *m[], BN_CTX *ctx);
# 576 "/usr/include/openssl/ec.h" 3 4
int EC_POINT_mul(const EC_GROUP *group, EC_POINT *r, const BIGNUM *n, const EC_POINT *q, const BIGNUM *m, BN_CTX *ctx);
int EC_GROUP_precompute_mult(EC_GROUP *group, BN_CTX *ctx);
int EC_GROUP_have_precompute_mult(const EC_GROUP *group);
# 598 "/usr/include/openssl/ec.h" 3 4
int EC_GROUP_get_basis_type(const EC_GROUP *);
typedef struct ecpk_parameters_st ECPKPARAMETERS;
EC_GROUP *d2i_ECPKParameters(EC_GROUP **, const unsigned char **in, long len);
int i2d_ECPKParameters(const EC_GROUP *, unsigned char **out);
# 615 "/usr/include/openssl/ec.h" 3 4
int ECPKParameters_print(BIO *bp, const EC_GROUP *x, int off);
int ECPKParameters_print_fp(FILE *fp, const EC_GROUP *x, int off);
typedef struct ec_key_st EC_KEY;
# 639 "/usr/include/openssl/ec.h" 3 4
EC_KEY *EC_KEY_new(void);
int EC_KEY_get_flags(const EC_KEY *key);
void EC_KEY_set_flags(EC_KEY *key, int flags);
void EC_KEY_clear_flags(EC_KEY *key, int flags);
EC_KEY *EC_KEY_new_by_curve_name(int nid);
void EC_KEY_free(EC_KEY *key);
EC_KEY *EC_KEY_copy(EC_KEY *dst, const EC_KEY *src);
EC_KEY *EC_KEY_dup(const EC_KEY *src);
int EC_KEY_up_ref(EC_KEY *key);
const EC_GROUP *EC_KEY_get0_group(const EC_KEY *key);
int EC_KEY_set_group(EC_KEY *key, const EC_GROUP *group);
const BIGNUM *EC_KEY_get0_private_key(const EC_KEY *key);
int EC_KEY_set_private_key(EC_KEY *key, const BIGNUM *prv);
const EC_POINT *EC_KEY_get0_public_key(const EC_KEY *key);
int EC_KEY_set_public_key(EC_KEY *key, const EC_POINT *pub);
unsigned EC_KEY_get_enc_flags(const EC_KEY *key);
void EC_KEY_set_enc_flags(EC_KEY *eckey, unsigned int flags);
point_conversion_form_t EC_KEY_get_conv_form(const EC_KEY *key);
void EC_KEY_set_conv_form(EC_KEY *eckey, point_conversion_form_t cform);
void *EC_KEY_get_key_method_data(EC_KEY *key,
 void *(*dup_func)(void *), void (*free_func)(void *), void (*clear_free_func)(void *));
# 735 "/usr/include/openssl/ec.h" 3 4
void *EC_KEY_insert_key_method_data(EC_KEY *key, void *data,
void EC_KEY_set_asn1_flag(EC_KEY *eckey, int asn1_flag);
int EC_KEY_precompute_mult(EC_KEY *key, BN_CTX *ctx);
int EC_KEY_generate_key(EC_KEY *key);
int EC_KEY_check_key(const EC_KEY *key);
# 767 "/usr/include/openssl/ec.h" 3 4
int EC_KEY_set_public_key_affine_coordinates(EC_KEY *key, BIGNUM *x, BIGNUM *y);
# 780 "/usr/include/openssl/ec.h" 3 4
EC_KEY *d2i_ECPrivateKey(EC_KEY **key, const unsigned char **in, long len);
int i2d_ECPrivateKey(EC_KEY *key, unsigned char **out);
# 802 "/usr/include/openssl/ec.h" 3 4
EC_KEY *d2i_ECParameters(EC_KEY **key, const unsigned char **in, long len);
int i2d_ECParameters(EC_KEY *key, unsigned char **out);
# 825 "/usr/include/openssl/ec.h" 3 4
EC_KEY *o2i_ECPublicKey(EC_KEY **key, const unsigned char **in, long len);
int i2o_ECPublicKey(EC_KEY *key, unsigned char **out);
int ECParameters_print(BIO *bp, const EC_KEY *key);
int EC_KEY_print(BIO *bp, const EC_KEY *key, int off);
# 858 "/usr/include/openssl/ec.h" 3 4
int ECParameters_print_fp(FILE *fp, const EC_KEY *key);
int EC_KEY_print_fp(FILE *fp, const EC_KEY *key, int off);
# 891 "/usr/include/openssl/ec.h" 3 4
void ERR_load_EC_strings(void);
# 1083 "/usr/include/openssl/ec.h" 3 4
# 84 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/ecdsa.h" 1 3 4
# 62 "/usr/include/openssl/ecdsa.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 34 "/usr/include/openssl/opensslconf.h" 3 4
# 1 "/usr/include/openssl/opensslconf-x86_64.h" 1 3 4
# 12 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
extern "C" {
# 284 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
# 35 "/usr/include/openssl/opensslconf.h" 2 3 4
# 63 "/usr/include/openssl/ecdsa.h" 2 3 4
# 75 "/usr/include/openssl/ecdsa.h" 3 4
extern "C" {
typedef struct ECDSA_SIG_st
 BIGNUM *r;
 BIGNUM *s;
 } ECDSA_SIG;
ECDSA_SIG *ECDSA_SIG_new(void);
void ECDSA_SIG_free(ECDSA_SIG *sig);
int i2d_ECDSA_SIG(const ECDSA_SIG *sig, unsigned char **pp);
# 109 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *d2i_ECDSA_SIG(ECDSA_SIG **sig, const unsigned char **pp, long len);
# 118 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *ECDSA_do_sign(const unsigned char *dgst,int dgst_len,EC_KEY *eckey);
# 130 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *ECDSA_do_sign_ex(const unsigned char *dgst, int dgstlen,
  const BIGNUM *kinv, const BIGNUM *rp, EC_KEY *eckey);
# 142 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_do_verify(const unsigned char *dgst, int dgst_len,
  const ECDSA_SIG *sig, EC_KEY* eckey);
const ECDSA_METHOD *ECDSA_OpenSSL(void);
void ECDSA_set_default_method(const ECDSA_METHOD *meth);
const ECDSA_METHOD *ECDSA_get_default_method(void);
int ECDSA_set_method(EC_KEY *eckey, const ECDSA_METHOD *meth);
int ECDSA_size(const EC_KEY *eckey);
# 177 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign_setup(EC_KEY *eckey, BN_CTX *ctx, BIGNUM **kinv,
  BIGNUM **rp);
# 190 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign(int type, const unsigned char *dgst, int dgstlen,
  unsigned char *sig, unsigned int *siglen, EC_KEY *eckey);
# 207 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign_ex(int type, const unsigned char *dgst, int dgstlen,
  unsigned char *sig, unsigned int *siglen, const BIGNUM *kinv,
# 222 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_verify(int type, const unsigned char *dgst, int dgstlen,
  const unsigned char *sig, int siglen, EC_KEY *eckey);
int ECDSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new
  *new_func, CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
int ECDSA_set_ex_data(EC_KEY *d, int idx, void *arg);
void *ECDSA_get_ex_data(EC_KEY *d, int idx);
void ERR_load_ECDSA_strings(void);
# 258 "/usr/include/openssl/ecdsa.h" 3 4
# 88 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/ecdh.h" 1 3 4
# 72 "/usr/include/openssl/ecdh.h" 3 4
extern "C" {
# 73 "/usr/include/openssl/ecdh.h" 2 3 4
# 85 "/usr/include/openssl/ecdh.h" 3 4
extern "C" {
const ECDH_METHOD *ECDH_OpenSSL(void);
void ECDH_set_default_method(const ECDH_METHOD *);
const ECDH_METHOD *ECDH_get_default_method(void);
int ECDH_set_method(EC_KEY *, const ECDH_METHOD *);
int ECDH_compute_key(void *out, size_t outlen, const EC_POINT *pub_key, EC_KEY *ecdh,
                     void *(*KDF)(const void *in, size_t inlen, void *out, size_t *outlen));
int ECDH_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new
int ECDH_set_ex_data(EC_KEY *d, int idx, void *arg);
void *ECDH_get_ex_data(EC_KEY *d, int idx);
void ERR_load_ECDH_strings(void);
# 125 "/usr/include/openssl/ecdh.h" 3 4
# 92 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/rsa.h" 1 3 4
# 78 "/usr/include/openssl/rsa.h" 3 4
extern "C" {
struct rsa_meth_st
 const char *name;
 int (*rsa_pub_enc)(int flen,const unsigned char *from,
      unsigned char *to,
      RSA *rsa,int padding);
 int (*rsa_pub_dec)(int flen,const unsigned char *from,
      unsigned char *to,
 int (*rsa_priv_enc)(int flen,const unsigned char *from,
       unsigned char *to,
 int (*rsa_priv_dec)(int flen,const unsigned char *from,
       unsigned char *to,
 int (*rsa_mod_exp)(BIGNUM *r0,const BIGNUM *I,RSA *rsa,BN_CTX *ctx);
 int (*bn_mod_exp)(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
     const BIGNUM *m, BN_CTX *ctx,
     BN_MONT_CTX *m_ctx);
 int (*init)(RSA *rsa);
 int (*finish)(RSA *rsa);
 int flags;
 char *app_data;
 int (*rsa_sign)(int type,
  unsigned char *sigret, unsigned int *siglen, const RSA *rsa);
 int (*rsa_verify)(int dtype,
        const RSA *rsa);
 int (*rsa_keygen)(RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb);
struct rsa_st
 int pad;
 long version;
 const RSA_METHOD *meth;
 ENGINE *engine;
 BIGNUM *n;
 BIGNUM *e;
 BIGNUM *d;
 BIGNUM *p;
 BIGNUM *q;
 BIGNUM *dmp1;
 BIGNUM *dmq1;
 BIGNUM *iqmp;
 CRYPTO_EX_DATA ex_data;
 int references;
 int flags;
 BN_MONT_CTX *_method_mod_n;
 BN_MONT_CTX *_method_mod_p;
 BN_MONT_CTX *_method_mod_q;
 char *bignum_data;
 BN_BLINDING *blinding;
 BN_BLINDING *mt_blinding;
# 283 "/usr/include/openssl/rsa.h" 3 4
RSA * RSA_new(void);
RSA * RSA_new_method(ENGINE *engine);
int RSA_size(const RSA *rsa);
RSA * RSA_generate_key(int bits, unsigned long e,void
  (*callback)(int,int,void *),void *cb_arg);
int RSA_generate_key_ex(RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb);
int RSA_X931_derive_ex(RSA *rsa, BIGNUM *p1, BIGNUM *p2, BIGNUM *q1, BIGNUM *q2,
   const BIGNUM *Xp1, const BIGNUM *Xp2, const BIGNUM *Xp,
   const BIGNUM *Xq1, const BIGNUM *Xq2, const BIGNUM *Xq,
   const BIGNUM *e, BN_GENCB *cb);
int RSA_X931_generate_key_ex(RSA *rsa, int bits, const BIGNUM *e, BN_GENCB *cb);
int RSA_check_key(const RSA *);
int RSA_public_encrypt(int flen, const unsigned char *from,
  unsigned char *to, RSA *rsa,int padding);
int RSA_private_encrypt(int flen, const unsigned char *from,
int RSA_public_decrypt(int flen, const unsigned char *from,
int RSA_private_decrypt(int flen, const unsigned char *from,
void RSA_free (RSA *r);
int RSA_up_ref(RSA *r);
int RSA_flags(const RSA *r);
void RSA_set_default_method(const RSA_METHOD *meth);
const RSA_METHOD *RSA_get_default_method(void);
const RSA_METHOD *RSA_get_method(const RSA *rsa);
int RSA_set_method(RSA *rsa, const RSA_METHOD *meth);
int RSA_memory_lock(RSA *r);
const RSA_METHOD *RSA_PKCS1_SSLeay(void);
const RSA_METHOD *RSA_null_method(void);
RSA *d2i_RSAPublicKey(RSA **a, const unsigned char **in, long len); int i2d_RSAPublicKey(const RSA *a, unsigned char **out); extern const ASN1_ITEM RSAPublicKey_it;
RSA *d2i_RSAPrivateKey(RSA **a, const unsigned char **in, long len); int i2d_RSAPrivateKey(const RSA *a, unsigned char **out); extern const ASN1_ITEM RSAPrivateKey_it;
typedef struct rsa_pss_params_st
 X509_ALGOR *hashAlgorithm;
 X509_ALGOR *maskGenAlgorithm;
 ASN1_INTEGER *saltLength;
 ASN1_INTEGER *trailerField;
 } RSA_PSS_PARAMS;
RSA_PSS_PARAMS *RSA_PSS_PARAMS_new(void); void RSA_PSS_PARAMS_free(RSA_PSS_PARAMS *a); RSA_PSS_PARAMS *d2i_RSA_PSS_PARAMS(RSA_PSS_PARAMS **a, const unsigned char **in, long len); int i2d_RSA_PSS_PARAMS(RSA_PSS_PARAMS *a, unsigned char **out); extern const ASN1_ITEM RSA_PSS_PARAMS_it;
int RSA_print_fp(FILE *fp, const RSA *r,int offset);
int RSA_print(BIO *bp, const RSA *r,int offset);
int i2d_RSA_NET(const RSA *a, unsigned char **pp,
  int (*cb)(char *buf, int len, const char *prompt, int verify),
  int sgckey);
RSA *d2i_RSA_NET(RSA **a, const unsigned char **pp, long length,
   int sgckey);
int i2d_Netscape_RSA(const RSA *a, unsigned char **pp,
          int verify));
RSA *d2i_Netscape_RSA(RSA **a, const unsigned char **pp, long length,
    int verify));
int RSA_sign(int type, const unsigned char *m, unsigned int m_length,
 unsigned char *sigret, unsigned int *siglen, RSA *rsa);
int RSA_verify(int type, const unsigned char *m, unsigned int m_length,
 const unsigned char *sigbuf, unsigned int siglen, RSA *rsa);
int RSA_sign_ASN1_OCTET_STRING(int type,
int RSA_verify_ASN1_OCTET_STRING(int type,
int RSA_blinding_on(RSA *rsa, BN_CTX *ctx);
void RSA_blinding_off(RSA *rsa);
BN_BLINDING *RSA_setup_blinding(RSA *rsa, BN_CTX *ctx);
int RSA_padding_add_PKCS1_type_1(unsigned char *to,int tlen,
 const unsigned char *f,int fl);
int RSA_padding_check_PKCS1_type_1(unsigned char *to,int tlen,
 const unsigned char *f,int fl,int rsa_len);
int RSA_padding_add_PKCS1_type_2(unsigned char *to,int tlen,
int RSA_padding_check_PKCS1_type_2(unsigned char *to,int tlen,
int PKCS1_MGF1(unsigned char *mask, long len,
 const unsigned char *seed, long seedlen, const EVP_MD *dgst);
int RSA_padding_add_PKCS1_OAEP(unsigned char *to,int tlen,
 const unsigned char *p,int pl);
int RSA_padding_check_PKCS1_OAEP(unsigned char *to,int tlen,
 const unsigned char *f,int fl,int rsa_len,
int RSA_padding_add_SSLv23(unsigned char *to,int tlen,
int RSA_padding_check_SSLv23(unsigned char *to,int tlen,
int RSA_padding_add_none(unsigned char *to,int tlen,
int RSA_padding_check_none(unsigned char *to,int tlen,
int RSA_padding_add_X931(unsigned char *to,int tlen,
int RSA_padding_check_X931(unsigned char *to,int tlen,
int RSA_X931_hash_id(int nid);
int RSA_verify_PKCS1_PSS(RSA *rsa, const unsigned char *mHash,
   const EVP_MD *Hash, const unsigned char *EM, int sLen);
int RSA_padding_add_PKCS1_PSS(RSA *rsa, unsigned char *EM,
   const EVP_MD *Hash, int sLen);
int RSA_verify_PKCS1_PSS_mgf1(RSA *rsa, const unsigned char *mHash,
   const EVP_MD *Hash, const EVP_MD *mgf1Hash,
int RSA_padding_add_PKCS1_PSS_mgf1(RSA *rsa, unsigned char *EM,
   const EVP_MD *Hash, const EVP_MD *mgf1Hash, int sLen);
int RSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int RSA_set_ex_data(RSA *r,int idx,void *arg);
void *RSA_get_ex_data(const RSA *r, int idx);
RSA *RSAPublicKey_dup(RSA *rsa);
RSA *RSAPrivateKey_dup(RSA *rsa);
# 462 "/usr/include/openssl/rsa.h" 3 4
void ERR_load_RSA_strings(void);
# 591 "/usr/include/openssl/rsa.h" 3 4
# 97 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/dsa.h" 1 3 4
# 68 "/usr/include/openssl/dsa.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
extern "C" {
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 69 "/usr/include/openssl/dsa.h" 2 3 4
# 83 "/usr/include/openssl/dsa.h" 3 4
# 1 "/usr/include/openssl/dh.h" 1 3 4
# 62 "/usr/include/openssl/dh.h" 3 4
extern "C" {
# 63 "/usr/include/openssl/dh.h" 2 3 4
# 108 "/usr/include/openssl/dh.h" 3 4
extern "C" {
struct dh_method
 const char *name;
 int (*generate_key)(DH *dh);
 int (*compute_key)(unsigned char *key,const BIGNUM *pub_key,DH *dh);
 int (*bn_mod_exp)(const DH *dh, BIGNUM *r, const BIGNUM *a,
    const BIGNUM *p, const BIGNUM *m, BN_CTX *ctx,
 int (*init)(DH *dh);
 int (*finish)(DH *dh);
 int flags;
 char *app_data;
 int (*generate_params)(DH *dh, int prime_len, int generator, BN_GENCB *cb);
struct dh_st
 int pad;
 int version;
 BIGNUM *p;
 BIGNUM *g;
 long length;
 BIGNUM *pub_key;
 BIGNUM *priv_key;
 int flags;
 BN_MONT_CTX *method_mont_p;
 BIGNUM *q;
 BIGNUM *j;
 unsigned char *seed;
 int seedlen;
 BIGNUM *counter;
 int references;
 const DH_METHOD *meth;
 ENGINE *engine;
# 185 "/usr/include/openssl/dh.h" 3 4
DH *DHparams_dup(DH *);
const DH_METHOD *DH_OpenSSL(void);
void DH_set_default_method(const DH_METHOD *meth);
const DH_METHOD *DH_get_default_method(void);
int DH_set_method(DH *dh, const DH_METHOD *meth);
DH *DH_new_method(ENGINE *engine);
DH * DH_new(void);
void DH_free(DH *dh);
int DH_up_ref(DH *dh);
int DH_size(const DH *dh);
int DH_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int DH_set_ex_data(DH *d, int idx, void *arg);
void *DH_get_ex_data(DH *d, int idx);
DH * DH_generate_parameters(int prime_len,int generator,
  void (*callback)(int,int,void *),void *cb_arg);
int DH_generate_parameters_ex(DH *dh, int prime_len,int generator, BN_GENCB *cb);
int DH_check(const DH *dh,int *codes);
int DH_check_pub_key(const DH *dh,const BIGNUM *pub_key, int *codes);
int DH_generate_key(DH *dh);
int DH_compute_key(unsigned char *key,const BIGNUM *pub_key,DH *dh);
int DH_compute_key_padded(unsigned char *key,const BIGNUM *pub_key,DH *dh);
DH * d2i_DHparams(DH **a,const unsigned char **pp, long length);
int i2d_DHparams(const DH *a,unsigned char **pp);
int DHparams_print_fp(FILE *fp, const DH *x);
int DHparams_print(BIO *bp, const DH *x);
# 244 "/usr/include/openssl/dh.h" 3 4
void ERR_load_DH_strings(void);
# 282 "/usr/include/openssl/dh.h" 3 4
# 84 "/usr/include/openssl/dsa.h" 2 3 4
# 119 "/usr/include/openssl/dsa.h" 3 4
extern "C" {
typedef struct DSA_SIG_st
 BIGNUM *r;
 BIGNUM *s;
 } DSA_SIG;
struct dsa_method
 const char *name;
 DSA_SIG * (*dsa_do_sign)(const unsigned char *dgst, int dlen, DSA *dsa);
 int (*dsa_sign_setup)(DSA *dsa, BN_CTX *ctx_in, BIGNUM **kinvp,
        BIGNUM **rp);
 int (*dsa_do_verify)(const unsigned char *dgst, int dgst_len,
        DSA_SIG *sig, DSA *dsa);
 int (*dsa_mod_exp)(DSA *dsa, BIGNUM *rr, BIGNUM *a1, BIGNUM *p1,
   BIGNUM *a2, BIGNUM *p2, BIGNUM *m, BN_CTX *ctx,
   BN_MONT_CTX *in_mont);
 int (*bn_mod_exp)(DSA *dsa, BIGNUM *r, BIGNUM *a, const BIGNUM *p,
 int (*init)(DSA *dsa);
 int (*finish)(DSA *dsa);
 int flags;
 char *app_data;
 int (*dsa_paramgen)(DSA *dsa, int bits,
   const unsigned char *seed, int seed_len,
   int *counter_ret, unsigned long *h_ret,
   BN_GENCB *cb);
 int (*dsa_keygen)(DSA *dsa);
struct dsa_st
 int pad;
 long version;
 int write_params;
 BIGNUM *p;
 BIGNUM *q;
 BIGNUM *g;
 BIGNUM *pub_key;
 BIGNUM *priv_key;
 BIGNUM *kinv;
 BIGNUM *r;
 int flags;
 int references;
 const DSA_METHOD *meth;
 ENGINE *engine;
# 194 "/usr/include/openssl/dsa.h" 3 4
DSA *DSAparams_dup(DSA *x);
DSA_SIG * DSA_SIG_new(void);
void DSA_SIG_free(DSA_SIG *a);
int i2d_DSA_SIG(const DSA_SIG *a, unsigned char **pp);
DSA_SIG * d2i_DSA_SIG(DSA_SIG **v, const unsigned char **pp, long length);
DSA_SIG * DSA_do_sign(const unsigned char *dgst,int dlen,DSA *dsa);
int DSA_do_verify(const unsigned char *dgst,int dgst_len,
        DSA_SIG *sig,DSA *dsa);
const DSA_METHOD *DSA_OpenSSL(void);
void DSA_set_default_method(const DSA_METHOD *);
const DSA_METHOD *DSA_get_default_method(void);
int DSA_set_method(DSA *dsa, const DSA_METHOD *);
DSA * DSA_new(void);
DSA * DSA_new_method(ENGINE *engine);
void DSA_free (DSA *r);
int DSA_up_ref(DSA *r);
int DSA_size(const DSA *);
int DSA_sign_setup( DSA *dsa,BN_CTX *ctx_in,BIGNUM **kinvp,BIGNUM **rp);
int DSA_sign(int type,const unsigned char *dgst,int dlen,
  unsigned char *sig, unsigned int *siglen, DSA *dsa);
int DSA_verify(int type,const unsigned char *dgst,int dgst_len,
  const unsigned char *sigbuf, int siglen, DSA *dsa);
int DSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int DSA_set_ex_data(DSA *d, int idx, void *arg);
void *DSA_get_ex_data(DSA *d, int idx);
DSA * d2i_DSAPublicKey(DSA **a, const unsigned char **pp, long length);
DSA * d2i_DSAPrivateKey(DSA **a, const unsigned char **pp, long length);
DSA * d2i_DSAparams(DSA **a, const unsigned char **pp, long length);
DSA * DSA_generate_parameters(int bits,
  unsigned char *seed,int seed_len,
  int *counter_ret, unsigned long *h_ret,void
  (*callback)(int, int, void *),void *cb_arg);
int DSA_generate_parameters_ex(DSA *dsa, int bits,
  const unsigned char *seed,int seed_len,
  int *counter_ret, unsigned long *h_ret, BN_GENCB *cb);
int DSA_generate_key(DSA *a);
int i2d_DSAPublicKey(const DSA *a, unsigned char **pp);
int i2d_DSAPrivateKey(const DSA *a, unsigned char **pp);
int i2d_DSAparams(const DSA *a,unsigned char **pp);
int DSAparams_print(BIO *bp, const DSA *x);
int DSA_print(BIO *bp, const DSA *x, int off);
int DSAparams_print_fp(FILE *fp, const DSA *x);
int DSA_print_fp(FILE *bp, const DSA *x, int off);
# 267 "/usr/include/openssl/dsa.h" 3 4
DH *DSA_dup_DH(const DSA *r);
int FIPS_dsa_builtin_paramgen(DSA *ret, size_t bits, size_t qbits,
 const EVP_MD *evpmd, const unsigned char *seed_in, size_t seed_len,
int FIPS_dsa_generate_pq(BN_CTX *ctx, size_t bits, size_t qbits,
  const EVP_MD *evpmd, unsigned char *seed, int seed_len,
  BIGNUM **p_ret, BIGNUM **q_ret, int *counter_ret, BN_GENCB *cb);
int FIPS_dsa_generate_g(BN_CTX *ctx, BIGNUM *p, BIGNUM *q,
  BIGNUM **g_ret, unsigned long *h_ret, BN_GENCB *cb);
# 293 "/usr/include/openssl/dsa.h" 3 4
void ERR_load_DSA_strings(void);
# 346 "/usr/include/openssl/dsa.h" 3 4
# 100 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/sha.h" 1 3 4
# 62 "/usr/include/openssl/sha.h" 3 4
extern "C" {
# 63 "/usr/include/openssl/sha.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 64 "/usr/include/openssl/sha.h" 2 3 4
extern "C" {
# 100 "/usr/include/openssl/sha.h" 3 4
typedef struct SHAstate_st
 unsigned int h0,h1,h2,h3,h4;
 unsigned int Nl,Nh;
 unsigned int data[16];
 unsigned int num;
 } SHA_CTX;
int private_SHA_Init(SHA_CTX *c);
int SHA_Init(SHA_CTX *c);
int SHA_Update(SHA_CTX *c, const void *data, size_t len);
int SHA_Final(unsigned char *md, SHA_CTX *c);
unsigned char *SHA(const unsigned char *d, size_t n, unsigned char *md);
void SHA_Transform(SHA_CTX *c, const unsigned char *data);
int SHA1_Init(SHA_CTX *c);
int SHA1_Update(SHA_CTX *c, const void *data, size_t len);
int SHA1_Final(unsigned char *md, SHA_CTX *c);
unsigned char *SHA1(const unsigned char *d, size_t n, unsigned char *md);
void SHA1_Transform(SHA_CTX *c, const unsigned char *data);
# 132 "/usr/include/openssl/sha.h" 3 4
typedef struct SHA256state_st
 unsigned int h[8];
 unsigned int Nl,Nh;
 unsigned int num,md_len;
 } SHA256_CTX;
int SHA224_Init(SHA256_CTX *c);
int SHA224_Update(SHA256_CTX *c, const void *data, size_t len);
int SHA224_Final(unsigned char *md, SHA256_CTX *c);
unsigned char *SHA224(const unsigned char *d, size_t n,unsigned char *md);
int SHA256_Init(SHA256_CTX *c);
int SHA256_Update(SHA256_CTX *c, const void *data, size_t len);
int SHA256_Final(unsigned char *md, SHA256_CTX *c);
unsigned char *SHA256(const unsigned char *d, size_t n,unsigned char *md);
void SHA256_Transform(SHA256_CTX *c, const unsigned char *data);
# 175 "/usr/include/openssl/sha.h" 3 4
typedef struct SHA512state_st
 unsigned long long h[8];
 unsigned long long Nl,Nh;
 union {
  unsigned long long d[16];
  unsigned char p[(16*8)];
 } u;
 } SHA512_CTX;
int SHA384_Init(SHA512_CTX *c);
int SHA384_Update(SHA512_CTX *c, const void *data, size_t len);
int SHA384_Final(unsigned char *md, SHA512_CTX *c);
unsigned char *SHA384(const unsigned char *d, size_t n,unsigned char *md);
int SHA512_Init(SHA512_CTX *c);
int SHA512_Update(SHA512_CTX *c, const void *data, size_t len);
int SHA512_Final(unsigned char *md, SHA512_CTX *c);
unsigned char *SHA512(const unsigned char *d, size_t n,unsigned char *md);
void SHA512_Transform(SHA512_CTX *c, const unsigned char *data);
# 108 "/usr/include/openssl/x509.h" 2 3 4
extern "C" {
# 137 "/usr/include/openssl/x509.h" 3 4
typedef struct X509_objects_st
 int nid;
 int (*a2i)(void);
 int (*i2a)(void);
 } X509_OBJECTS;
struct X509_algor_st
 ASN1_OBJECT *algorithm;
 ASN1_TYPE *parameter;
typedef struct stack_st_X509_ALGOR X509_ALGORS;
typedef struct X509_val_st
 ASN1_TIME *notBefore;
 ASN1_TIME *notAfter;
 } X509_VAL;
struct X509_pubkey_st
 X509_ALGOR *algor;
 ASN1_BIT_STRING *public_key;
 EVP_PKEY *pkey;
typedef struct X509_sig_st
 X509_ALGOR *algor;
 ASN1_OCTET_STRING *digest;
 } X509_SIG;
typedef struct X509_name_entry_st
 ASN1_OBJECT *object;
 ASN1_STRING *value;
 int set;
 int size;
 } X509_NAME_ENTRY;
struct stack_st_X509_NAME_ENTRY { _STACK stack; };
struct X509_name_st
 struct stack_st_X509_NAME_ENTRY *entries;
 int modified;
 BUF_MEM *bytes;
 unsigned char *canon_enc;
 int canon_enclen;
struct stack_st_X509_NAME { _STACK stack; };
typedef struct X509_extension_st
 ASN1_BOOLEAN critical;
 ASN1_OCTET_STRING *value;
 } X509_EXTENSION;
typedef struct stack_st_X509_EXTENSION X509_EXTENSIONS;
struct stack_st_X509_EXTENSION { _STACK stack; };
typedef struct x509_attributes_st
 int single;
 union {
  char *ptr;
         struct stack_st_ASN1_TYPE *set;
         ASN1_TYPE *single;
  } value;
 } X509_ATTRIBUTE;
struct stack_st_X509_ATTRIBUTE { _STACK stack; };
typedef struct X509_req_info_st
 ASN1_ENCODING enc;
 ASN1_INTEGER *version;
 X509_NAME *subject;
 X509_PUBKEY *pubkey;
 } X509_REQ_INFO;
typedef struct X509_req_st
 X509_REQ_INFO *req_info;
 X509_ALGOR *sig_alg;
 ASN1_BIT_STRING *signature;
 int references;
 } X509_REQ;
typedef struct x509_cinf_st
 ASN1_INTEGER *serialNumber;
 X509_ALGOR *signature;
 X509_NAME *issuer;
 X509_VAL *validity;
 X509_NAME *subject;
 X509_PUBKEY *key;
 ASN1_BIT_STRING *issuerUID;
 ASN1_BIT_STRING *subjectUID;
 struct stack_st_X509_EXTENSION *extensions;
 ASN1_ENCODING enc;
 } X509_CINF;
typedef struct x509_cert_aux_st
 struct stack_st_ASN1_OBJECT *trust;
 struct stack_st_ASN1_OBJECT *reject;
 ASN1_UTF8STRING *alias;
 ASN1_OCTET_STRING *keyid;
 struct stack_st_X509_ALGOR *other;
 } X509_CERT_AUX;
struct x509_st
 X509_CINF *cert_info;
 int valid;
 int references;
 char *name;
 long ex_pathlen;
 long ex_pcpathlen;
 unsigned long ex_flags;
 unsigned long ex_kusage;
 unsigned long ex_xkusage;
 unsigned long ex_nscert;
 ASN1_OCTET_STRING *skid;
 AUTHORITY_KEYID *akid;
 X509_POLICY_CACHE *policy_cache;
 struct stack_st_DIST_POINT *crldp;
 struct stack_st_GENERAL_NAME *altname;
 NAME_CONSTRAINTS *nc;
 struct stack_st_IPAddressFamily *rfc3779_addr;
 struct ASIdentifiers_st *rfc3779_asid;
 unsigned char sha1_hash[20];
 X509_CERT_AUX *aux;
struct stack_st_X509 { _STACK stack; };
typedef struct x509_trust_st {
 int trust;
 int flags;
 int (*check_trust)(struct x509_trust_st *, X509 *, int);
 char *name;
 int arg1;
 void *arg2;
} X509_TRUST;
struct stack_st_X509_TRUST { _STACK stack; };
typedef struct x509_cert_pair_st {
 X509 *forward;
 X509 *reverse;
} X509_CERT_PAIR;
# 434 "/usr/include/openssl/x509.h" 3 4
struct x509_revoked_st
 ASN1_TIME *revocationDate;
 struct stack_st_GENERAL_NAME *issuer;
 int reason;
 int sequence;
struct stack_st_X509_REVOKED { _STACK stack; };
typedef struct X509_crl_info_st
 X509_NAME *issuer;
 ASN1_TIME *lastUpdate;
 ASN1_TIME *nextUpdate;
 struct stack_st_X509_REVOKED *revoked;
 ASN1_ENCODING enc;
 } X509_CRL_INFO;
struct X509_crl_st
 X509_CRL_INFO *crl;
 int references;
 int flags;
 ISSUING_DIST_POINT *idp;
 int idp_flags;
 int idp_reasons;
 ASN1_INTEGER *crl_number;
 ASN1_INTEGER *base_crl_number;
 struct stack_st_GENERAL_NAMES *issuers;
 const X509_CRL_METHOD *meth;
 void *meth_data;
struct stack_st_X509_CRL { _STACK stack; };
typedef struct private_key_st
 int version;
 X509_ALGOR *enc_algor;
 ASN1_OCTET_STRING *enc_pkey;
 EVP_PKEY *dec_pkey;
 int key_length;
 char *key_data;
 int key_free;
 EVP_CIPHER_INFO cipher;
 int references;
 } X509_PKEY;
typedef struct X509_info_st
 X509 *x509;
 X509_CRL *crl;
 X509_PKEY *x_pkey;
 EVP_CIPHER_INFO enc_cipher;
 int enc_len;
 char *enc_data;
 int references;
 } X509_INFO;
struct stack_st_X509_INFO { _STACK stack; };
typedef struct Netscape_spkac_st
 ASN1_IA5STRING *challenge;
 } NETSCAPE_SPKAC;
typedef struct Netscape_spki_st
 NETSCAPE_SPKAC *spkac;
 X509_ALGOR *sig_algor;
 } NETSCAPE_SPKI;
typedef struct Netscape_certificate_sequence
 ASN1_OBJECT *type;
 struct stack_st_X509 *certs;
 } NETSCAPE_CERT_SEQUENCE;
# 560 "/usr/include/openssl/x509.h" 3 4
typedef struct PBEPARAM_st {
ASN1_OCTET_STRING *salt;
ASN1_INTEGER *iter;
} PBEPARAM;
typedef struct PBE2PARAM_st {
X509_ALGOR *keyfunc;
X509_ALGOR *encryption;
} PBE2PARAM;
typedef struct PBKDF2PARAM_st {
ASN1_TYPE *salt;
ASN1_INTEGER *iter;
ASN1_INTEGER *keylength;
X509_ALGOR *prf;
} PBKDF2PARAM;
struct pkcs8_priv_key_info_st
        int broken;
        X509_ALGOR *pkeyalg;
        ASN1_TYPE *pkey;
# 1 "/usr/include/openssl/x509_vfy.h" 1 3 4
# 68 "/usr/include/openssl/x509_vfy.h" 3 4
extern "C" {
# 69 "/usr/include/openssl/x509_vfy.h" 2 3 4
# 1 "/usr/include/openssl/lhash.h" 1 3 4
# 66 "/usr/include/openssl/lhash.h" 3 4
extern "C" {
# 67 "/usr/include/openssl/lhash.h" 2 3 4
# 76 "/usr/include/openssl/lhash.h" 3 4
extern "C" {
typedef struct lhash_node_st
 void *data;
 struct lhash_node_st *next;
 unsigned long hash;
 } LHASH_NODE;
typedef int (*LHASH_COMP_FN_TYPE)(const void *, const void *);
typedef unsigned long (*LHASH_HASH_FN_TYPE)(const void *);
typedef void (*LHASH_DOALL_FN_TYPE)(void *);
typedef void (*LHASH_DOALL_ARG_FN_TYPE)(void *, void *);
# 138 "/usr/include/openssl/lhash.h" 3 4
typedef struct lhash_st
 LHASH_NODE **b;
 LHASH_COMP_FN_TYPE comp;
 LHASH_HASH_FN_TYPE hash;
 unsigned int num_nodes;
 unsigned int num_alloc_nodes;
 unsigned int p;
 unsigned int pmax;
 unsigned long up_load;
 unsigned long down_load;
 unsigned long num_items;
 unsigned long num_expands;
 unsigned long num_expand_reallocs;
 unsigned long num_contracts;
 unsigned long num_contract_reallocs;
 unsigned long num_hash_calls;
 unsigned long num_comp_calls;
 unsigned long num_insert;
 unsigned long num_replace;
 unsigned long num_delete;
 unsigned long num_no_delete;
 unsigned long num_retrieve;
 unsigned long num_retrieve_miss;
 unsigned long num_hash_comps;
 int error;
 } _LHASH;
# 175 "/usr/include/openssl/lhash.h" 3 4
_LHASH *lh_new(LHASH_HASH_FN_TYPE h, LHASH_COMP_FN_TYPE c);
void lh_free(_LHASH *lh);
void *lh_insert(_LHASH *lh, void *data);
void *lh_delete(_LHASH *lh, const void *data);
void *lh_retrieve(_LHASH *lh, const void *data);
void lh_doall(_LHASH *lh, LHASH_DOALL_FN_TYPE func);
void lh_doall_arg(_LHASH *lh, LHASH_DOALL_ARG_FN_TYPE func, void *arg);
unsigned long lh_strhash(const char *c);
unsigned long lh_num_items(const _LHASH *lh);
void lh_stats(const _LHASH *lh, FILE *out);
void lh_node_stats(const _LHASH *lh, FILE *out);
void lh_node_usage_stats(const _LHASH *lh, FILE *out);
void lh_stats_bio(const _LHASH *lh, BIO *out);
void lh_node_stats_bio(const _LHASH *lh, BIO *out);
void lh_node_usage_stats_bio(const _LHASH *lh, BIO *out);
# 233 "/usr/include/openssl/lhash.h" 3 4
struct lhash_st_OPENSSL_STRING { int dummy; };
struct lhash_st_OPENSSL_CSTRING { int dummy; };
# 71 "/usr/include/openssl/x509_vfy.h" 2 3 4
extern "C" {
# 91 "/usr/include/openssl/x509_vfy.h" 3 4
typedef struct x509_file_st
 int num_paths;
 int num_alloced;
 char **paths;
 int *path_type;
 } X509_CERT_FILE_CTX;
# 123 "/usr/include/openssl/x509_vfy.h" 3 4
typedef struct x509_object_st
 int type;
 union {
  char *ptr;
  X509 *x509;
  X509_CRL *crl;
  EVP_PKEY *pkey;
  } data;
 } X509_OBJECT;
typedef struct x509_lookup_st X509_LOOKUP;
struct stack_st_X509_LOOKUP { _STACK stack; };
struct stack_st_X509_OBJECT { _STACK stack; };
typedef struct x509_lookup_method_st
 const char *name;
 int (*new_item)(X509_LOOKUP *ctx);
 void (*free)(X509_LOOKUP *ctx);
 int (*init)(X509_LOOKUP *ctx);
 int (*shutdown)(X509_LOOKUP *ctx);
 int (*ctrl)(X509_LOOKUP *ctx,int cmd,const char *argc,long argl,
   char **ret);
 int (*get_by_subject)(X509_LOOKUP *ctx,int type,X509_NAME *name,
         X509_OBJECT *ret);
 int (*get_by_issuer_serial)(X509_LOOKUP *ctx,int type,X509_NAME *name,
        ASN1_INTEGER *serial,X509_OBJECT *ret);
 int (*get_by_fingerprint)(X509_LOOKUP *ctx,int type,
      unsigned char *bytes,int len,
      X509_OBJECT *ret);
 int (*get_by_alias)(X509_LOOKUP *ctx,int type,char *str,int len,
       X509_OBJECT *ret);
 } X509_LOOKUP_METHOD;
typedef struct X509_VERIFY_PARAM_st
 char *name;
 time_t check_time;
 unsigned long inh_flags;
 unsigned long flags;
 int purpose;
 int trust;
 int depth;
 struct stack_st_ASN1_OBJECT *policies;
 } X509_VERIFY_PARAM;
struct stack_st_X509_VERIFY_PARAM { _STACK stack; };
struct x509_store_st
 int cache;
 struct stack_st_X509_OBJECT *objs;
 struct stack_st_X509_LOOKUP *get_cert_methods;
 X509_VERIFY_PARAM *param;
 int (*verify)(X509_STORE_CTX *ctx);
 int (*verify_cb)(int ok,X509_STORE_CTX *ctx);
 int (*get_issuer)(X509 **issuer, X509_STORE_CTX *ctx, X509 *x);
 int (*check_issued)(X509_STORE_CTX *ctx, X509 *x, X509 *issuer);
 int (*check_revocation)(X509_STORE_CTX *ctx);
 int (*get_crl)(X509_STORE_CTX *ctx, X509_CRL **crl, X509 *x);
 int (*check_crl)(X509_STORE_CTX *ctx, X509_CRL *crl);
 int (*cert_crl)(X509_STORE_CTX *ctx, X509_CRL *crl, X509 *x);
 struct stack_st_X509 * (*lookup_certs)(X509_STORE_CTX *ctx, X509_NAME *nm);
 struct stack_st_X509_CRL * (*lookup_crls)(X509_STORE_CTX *ctx, X509_NAME *nm);
 int (*cleanup)(X509_STORE_CTX *ctx);
 int references;
int X509_STORE_set_depth(X509_STORE *store, int depth);
 int init;
 int skip;
 X509_LOOKUP_METHOD *method;
 char *method_data;
 X509_STORE *store_ctx;
struct x509_store_ctx_st
 X509_STORE *ctx;
 int current_method;
 X509 *cert;
 struct stack_st_X509 *untrusted;
 struct stack_st_X509_CRL *crls;
 void *other_ctx;
 int (*check_policy)(X509_STORE_CTX *ctx);
 int valid;
 int last_untrusted;
 struct stack_st_X509 *chain;
 X509_POLICY_TREE *tree;
 int explicit_policy;
 int error_depth;
 int error;
 X509 *current_cert;
 X509 *current_issuer;
 X509_CRL *current_crl;
 int current_crl_score;
 unsigned int current_reasons;
 X509_STORE_CTX *parent;
void X509_STORE_CTX_set_depth(X509_STORE_CTX *ctx, int depth);
# 413 "/usr/include/openssl/x509_vfy.h" 3 4
int X509_OBJECT_idx_by_subject(struct stack_st_X509_OBJECT *h, int type,
      X509_NAME *name);
X509_OBJECT *X509_OBJECT_retrieve_by_subject(struct stack_st_X509_OBJECT *h,int type,X509_NAME *name);
X509_OBJECT *X509_OBJECT_retrieve_match(struct stack_st_X509_OBJECT *h, X509_OBJECT *x);
void X509_OBJECT_up_ref_count(X509_OBJECT *a);
void X509_OBJECT_free_contents(X509_OBJECT *a);
X509_STORE *X509_STORE_new(void );
void X509_STORE_free(X509_STORE *v);
struct stack_st_X509* X509_STORE_get1_certs(X509_STORE_CTX *st, X509_NAME *nm);
struct stack_st_X509_CRL* X509_STORE_get1_crls(X509_STORE_CTX *st, X509_NAME *nm);
int X509_STORE_set_flags(X509_STORE *ctx, unsigned long flags);
int X509_STORE_set_purpose(X509_STORE *ctx, int purpose);
int X509_STORE_set_trust(X509_STORE *ctx, int trust);
int X509_STORE_set1_param(X509_STORE *ctx, X509_VERIFY_PARAM *pm);
void X509_STORE_set_verify_cb(X509_STORE *ctx,
      int (*verify_cb)(int, X509_STORE_CTX *));
X509_STORE_CTX *X509_STORE_CTX_new(void);
int X509_STORE_CTX_get1_issuer(X509 **issuer, X509_STORE_CTX *ctx, X509 *x);
void X509_STORE_CTX_free(X509_STORE_CTX *ctx);
int X509_STORE_CTX_init(X509_STORE_CTX *ctx, X509_STORE *store,
    X509 *x509, struct stack_st_X509 *chain);
void X509_STORE_CTX_trusted_stack(X509_STORE_CTX *ctx, struct stack_st_X509 *sk);
void X509_STORE_CTX_cleanup(X509_STORE_CTX *ctx);
X509_LOOKUP *X509_STORE_add_lookup(X509_STORE *v, X509_LOOKUP_METHOD *m);
X509_LOOKUP_METHOD *X509_LOOKUP_hash_dir(void);
X509_LOOKUP_METHOD *X509_LOOKUP_file(void);
int X509_STORE_add_cert(X509_STORE *ctx, X509 *x);
int X509_STORE_add_crl(X509_STORE *ctx, X509_CRL *x);
int X509_STORE_get_by_subject(X509_STORE_CTX *vs,int type,X509_NAME *name,
 X509_OBJECT *ret);
int X509_LOOKUP_ctrl(X509_LOOKUP *ctx, int cmd, const char *argc,
 long argl, char **ret);
int X509_load_cert_file(X509_LOOKUP *ctx, const char *file, int type);
int X509_load_crl_file(X509_LOOKUP *ctx, const char *file, int type);
int X509_load_cert_crl_file(X509_LOOKUP *ctx, const char *file, int type);
X509_LOOKUP *X509_LOOKUP_new(X509_LOOKUP_METHOD *method);
void X509_LOOKUP_free(X509_LOOKUP *ctx);
int X509_LOOKUP_init(X509_LOOKUP *ctx);
int X509_LOOKUP_by_subject(X509_LOOKUP *ctx, int type, X509_NAME *name,
 X509_OBJECT *ret);
int X509_LOOKUP_by_issuer_serial(X509_LOOKUP *ctx, int type, X509_NAME *name,
 ASN1_INTEGER *serial, X509_OBJECT *ret);
int X509_LOOKUP_by_fingerprint(X509_LOOKUP *ctx, int type,
 unsigned char *bytes, int len, X509_OBJECT *ret);
int X509_LOOKUP_by_alias(X509_LOOKUP *ctx, int type, char *str,
int X509_LOOKUP_shutdown(X509_LOOKUP *ctx);
int X509_STORE_load_locations (X509_STORE *ctx,
  const char *file, const char *dir);
int X509_STORE_set_default_paths(X509_STORE *ctx);
int X509_STORE_CTX_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int X509_STORE_CTX_set_ex_data(X509_STORE_CTX *ctx,int idx,void *data);
void * X509_STORE_CTX_get_ex_data(X509_STORE_CTX *ctx,int idx);
int X509_STORE_CTX_get_error(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set_error(X509_STORE_CTX *ctx,int s);
int X509_STORE_CTX_get_error_depth(X509_STORE_CTX *ctx);
X509 * X509_STORE_CTX_get_current_cert(X509_STORE_CTX *ctx);
X509 *X509_STORE_CTX_get0_current_issuer(X509_STORE_CTX *ctx);
X509_CRL *X509_STORE_CTX_get0_current_crl(X509_STORE_CTX *ctx);
X509_STORE_CTX *X509_STORE_CTX_get0_parent_ctx(X509_STORE_CTX *ctx);
struct stack_st_X509 *X509_STORE_CTX_get_chain(X509_STORE_CTX *ctx);
struct stack_st_X509 *X509_STORE_CTX_get1_chain(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set_cert(X509_STORE_CTX *c,X509 *x);
void X509_STORE_CTX_set_chain(X509_STORE_CTX *c,struct stack_st_X509 *sk);
void X509_STORE_CTX_set0_crls(X509_STORE_CTX *c,struct stack_st_X509_CRL *sk);
int X509_STORE_CTX_set_purpose(X509_STORE_CTX *ctx, int purpose);
int X509_STORE_CTX_set_trust(X509_STORE_CTX *ctx, int trust);
int X509_STORE_CTX_purpose_inherit(X509_STORE_CTX *ctx, int def_purpose,
    int purpose, int trust);
void X509_STORE_CTX_set_flags(X509_STORE_CTX *ctx, unsigned long flags);
void X509_STORE_CTX_set_time(X509_STORE_CTX *ctx, unsigned long flags,
        time_t t);
void X509_STORE_CTX_set_verify_cb(X509_STORE_CTX *ctx,
X509_POLICY_TREE *X509_STORE_CTX_get0_policy_tree(X509_STORE_CTX *ctx);
int X509_STORE_CTX_get_explicit_policy(X509_STORE_CTX *ctx);
X509_VERIFY_PARAM *X509_STORE_CTX_get0_param(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set0_param(X509_STORE_CTX *ctx, X509_VERIFY_PARAM *param);
int X509_STORE_CTX_set_default(X509_STORE_CTX *ctx, const char *name);
X509_VERIFY_PARAM *X509_VERIFY_PARAM_new(void);
void X509_VERIFY_PARAM_free(X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_inherit(X509_VERIFY_PARAM *to,
      const X509_VERIFY_PARAM *from);
int X509_VERIFY_PARAM_set1(X509_VERIFY_PARAM *to,
int X509_VERIFY_PARAM_set1_name(X509_VERIFY_PARAM *param, const char *name);
int X509_VERIFY_PARAM_set_flags(X509_VERIFY_PARAM *param, unsigned long flags);
int X509_VERIFY_PARAM_clear_flags(X509_VERIFY_PARAM *param,
unsigned long X509_VERIFY_PARAM_get_flags(X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_set_purpose(X509_VERIFY_PARAM *param, int purpose);
int X509_VERIFY_PARAM_set_trust(X509_VERIFY_PARAM *param, int trust);
void X509_VERIFY_PARAM_set_depth(X509_VERIFY_PARAM *param, int depth);
void X509_VERIFY_PARAM_set_time(X509_VERIFY_PARAM *param, time_t t);
int X509_VERIFY_PARAM_add0_policy(X509_VERIFY_PARAM *param,
      ASN1_OBJECT *policy);
int X509_VERIFY_PARAM_set1_policies(X509_VERIFY_PARAM *param,
     struct stack_st_ASN1_OBJECT *policies);
int X509_VERIFY_PARAM_get_depth(const X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_add0_table(X509_VERIFY_PARAM *param);
const X509_VERIFY_PARAM *X509_VERIFY_PARAM_lookup(const char *name);
void X509_VERIFY_PARAM_table_cleanup(void);
int X509_policy_check(X509_POLICY_TREE **ptree, int *pexplicit_policy,
   struct stack_st_X509 *certs,
   struct stack_st_ASN1_OBJECT *policy_oids,
void X509_policy_tree_free(X509_POLICY_TREE *tree);
int X509_policy_tree_level_count(const X509_POLICY_TREE *tree);
X509_POLICY_LEVEL *
 X509_policy_tree_get0_level(const X509_POLICY_TREE *tree, int i);
struct stack_st_X509_POLICY_NODE *
 X509_policy_tree_get0_policies(const X509_POLICY_TREE *tree);
 X509_policy_tree_get0_user_policies(const X509_POLICY_TREE *tree);
int X509_policy_level_node_count(X509_POLICY_LEVEL *level);
X509_POLICY_NODE *X509_policy_level_get0_node(X509_POLICY_LEVEL *level, int i);
const ASN1_OBJECT *X509_policy_node_get0_policy(const X509_POLICY_NODE *node);
struct stack_st_POLICYQUALINFO *
 X509_policy_node_get0_qualifiers(const X509_POLICY_NODE *node);
 X509_policy_node_get0_parent(const X509_POLICY_NODE *node);
# 601 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/pkcs7.h" 1 3 4
# 64 "/usr/include/openssl/pkcs7.h" 3 4
extern "C" {
# 65 "/usr/include/openssl/pkcs7.h" 2 3 4
extern "C" {
# 86 "/usr/include/openssl/pkcs7.h" 3 4
typedef struct pkcs7_issuer_and_serial_st
 X509_NAME *issuer;
 ASN1_INTEGER *serial;
 } PKCS7_ISSUER_AND_SERIAL;
typedef struct pkcs7_signer_info_st
 PKCS7_ISSUER_AND_SERIAL *issuer_and_serial;
 X509_ALGOR *digest_alg;
 struct stack_st_X509_ATTRIBUTE *auth_attr;
 X509_ALGOR *digest_enc_alg;
 ASN1_OCTET_STRING *enc_digest;
 struct stack_st_X509_ATTRIBUTE *unauth_attr;
 EVP_PKEY *pkey;
 } PKCS7_SIGNER_INFO;
struct stack_st_PKCS7_SIGNER_INFO { _STACK stack; };
typedef struct pkcs7_recip_info_st
 X509_ALGOR *key_enc_algor;
 ASN1_OCTET_STRING *enc_key;
 X509 *cert;
 } PKCS7_RECIP_INFO;
struct stack_st_PKCS7_RECIP_INFO { _STACK stack; };
typedef struct pkcs7_signed_st
 struct stack_st_X509_ALGOR *md_algs;
 struct stack_st_X509 *cert;
 struct stack_st_X509_CRL *crl;
 struct stack_st_PKCS7_SIGNER_INFO *signer_info;
 struct pkcs7_st *contents;
 } PKCS7_SIGNED;
typedef struct pkcs7_enc_content_st
 ASN1_OBJECT *content_type;
 X509_ALGOR *algorithm;
 ASN1_OCTET_STRING *enc_data;
 const EVP_CIPHER *cipher;
 } PKCS7_ENC_CONTENT;
typedef struct pkcs7_enveloped_st
 struct stack_st_PKCS7_RECIP_INFO *recipientinfo;
 PKCS7_ENC_CONTENT *enc_data;
 } PKCS7_ENVELOPE;
typedef struct pkcs7_signedandenveloped_st
 } PKCS7_SIGN_ENVELOPE;
typedef struct pkcs7_digest_st
 X509_ALGOR *md;
 } PKCS7_DIGEST;
typedef struct pkcs7_encrypted_st
 } PKCS7_ENCRYPT;
typedef struct pkcs7_st
 unsigned char *asn1;
 long length;
 int state;
 int detached;
 ASN1_OBJECT *type;
 union {
  char *ptr;
  ASN1_OCTET_STRING *data;
  PKCS7_SIGNED *sign;
  PKCS7_ENVELOPE *enveloped;
  PKCS7_SIGN_ENVELOPE *signed_and_enveloped;
  PKCS7_DIGEST *digest;
  PKCS7_ENCRYPT *encrypted;
  ASN1_TYPE *other;
  } d;
 } PKCS7;
struct stack_st_PKCS7 { _STACK stack; };
# 275 "/usr/include/openssl/pkcs7.h" 3 4
PKCS7_ISSUER_AND_SERIAL *PKCS7_ISSUER_AND_SERIAL_new(void); void PKCS7_ISSUER_AND_SERIAL_free(PKCS7_ISSUER_AND_SERIAL *a); PKCS7_ISSUER_AND_SERIAL *d2i_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL **a, const unsigned char **in, long len); int i2d_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ISSUER_AND_SERIAL_it;
int PKCS7_ISSUER_AND_SERIAL_digest(PKCS7_ISSUER_AND_SERIAL *data,const EVP_MD *type,
 unsigned char *md,unsigned int *len);
PKCS7 *d2i_PKCS7_fp(FILE *fp,PKCS7 **p7);
int i2d_PKCS7_fp(FILE *fp,PKCS7 *p7);
PKCS7 *PKCS7_dup(PKCS7 *p7);
PKCS7 *d2i_PKCS7_bio(BIO *bp,PKCS7 **p7);
int i2d_PKCS7_bio(BIO *bp,PKCS7 *p7);
int i2d_PKCS7_bio_stream(BIO *out, PKCS7 *p7, BIO *in, int flags);
int PEM_write_bio_PKCS7_stream(BIO *out, PKCS7 *p7, BIO *in, int flags);
PKCS7_SIGNER_INFO *PKCS7_SIGNER_INFO_new(void); void PKCS7_SIGNER_INFO_free(PKCS7_SIGNER_INFO *a); PKCS7_SIGNER_INFO *d2i_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO **a, const unsigned char **in, long len); int i2d_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGNER_INFO_it;
PKCS7_RECIP_INFO *PKCS7_RECIP_INFO_new(void); void PKCS7_RECIP_INFO_free(PKCS7_RECIP_INFO *a); PKCS7_RECIP_INFO *d2i_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO **a, const unsigned char **in, long len); int i2d_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS7_RECIP_INFO_it;
PKCS7_SIGNED *PKCS7_SIGNED_new(void); void PKCS7_SIGNED_free(PKCS7_SIGNED *a); PKCS7_SIGNED *d2i_PKCS7_SIGNED(PKCS7_SIGNED **a, const unsigned char **in, long len); int i2d_PKCS7_SIGNED(PKCS7_SIGNED *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGNED_it;
PKCS7_ENC_CONTENT *PKCS7_ENC_CONTENT_new(void); void PKCS7_ENC_CONTENT_free(PKCS7_ENC_CONTENT *a); PKCS7_ENC_CONTENT *d2i_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT **a, const unsigned char **in, long len); int i2d_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENC_CONTENT_it;
PKCS7_ENVELOPE *PKCS7_ENVELOPE_new(void); void PKCS7_ENVELOPE_free(PKCS7_ENVELOPE *a); PKCS7_ENVELOPE *d2i_PKCS7_ENVELOPE(PKCS7_ENVELOPE **a, const unsigned char **in, long len); int i2d_PKCS7_ENVELOPE(PKCS7_ENVELOPE *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENVELOPE_it;
PKCS7_SIGN_ENVELOPE *PKCS7_SIGN_ENVELOPE_new(void); void PKCS7_SIGN_ENVELOPE_free(PKCS7_SIGN_ENVELOPE *a); PKCS7_SIGN_ENVELOPE *d2i_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE **a, const unsigned char **in, long len); int i2d_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGN_ENVELOPE_it;
PKCS7_DIGEST *PKCS7_DIGEST_new(void); void PKCS7_DIGEST_free(PKCS7_DIGEST *a); PKCS7_DIGEST *d2i_PKCS7_DIGEST(PKCS7_DIGEST **a, const unsigned char **in, long len); int i2d_PKCS7_DIGEST(PKCS7_DIGEST *a, unsigned char **out); extern const ASN1_ITEM PKCS7_DIGEST_it;
PKCS7_ENCRYPT *PKCS7_ENCRYPT_new(void); void PKCS7_ENCRYPT_free(PKCS7_ENCRYPT *a); PKCS7_ENCRYPT *d2i_PKCS7_ENCRYPT(PKCS7_ENCRYPT **a, const unsigned char **in, long len); int i2d_PKCS7_ENCRYPT(PKCS7_ENCRYPT *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENCRYPT_it;
PKCS7 *PKCS7_new(void); void PKCS7_free(PKCS7 *a); PKCS7 *d2i_PKCS7(PKCS7 **a, const unsigned char **in, long len); int i2d_PKCS7(PKCS7 *a, unsigned char **out); extern const ASN1_ITEM PKCS7_it;
extern const ASN1_ITEM PKCS7_ATTR_SIGN_it;
extern const ASN1_ITEM PKCS7_ATTR_VERIFY_it;
int i2d_PKCS7_NDEF(PKCS7 *a, unsigned char **out);
int PKCS7_print_ctx(BIO *out, PKCS7 *x, int indent, const ASN1_PCTX *pctx);
long PKCS7_ctrl(PKCS7 *p7, int cmd, long larg, char *parg);
int PKCS7_set_type(PKCS7 *p7, int type);
int PKCS7_set0_type_other(PKCS7 *p7, int type, ASN1_TYPE *other);
int PKCS7_set_content(PKCS7 *p7, PKCS7 *p7_data);
int PKCS7_SIGNER_INFO_set(PKCS7_SIGNER_INFO *p7i, X509 *x509, EVP_PKEY *pkey,
int PKCS7_SIGNER_INFO_sign(PKCS7_SIGNER_INFO *si);
int PKCS7_add_signer(PKCS7 *p7, PKCS7_SIGNER_INFO *p7i);
int PKCS7_add_certificate(PKCS7 *p7, X509 *x509);
int PKCS7_add_crl(PKCS7 *p7, X509_CRL *x509);
int PKCS7_content_new(PKCS7 *p7, int nid);
int PKCS7_dataVerify(X509_STORE *cert_store, X509_STORE_CTX *ctx,
 BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si);
int PKCS7_signatureVerify(BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si,
        X509 *x509);
BIO *PKCS7_dataInit(PKCS7 *p7, BIO *bio);
int PKCS7_dataFinal(PKCS7 *p7, BIO *bio);
BIO *PKCS7_dataDecode(PKCS7 *p7, EVP_PKEY *pkey, BIO *in_bio, X509 *pcert);
PKCS7_SIGNER_INFO *PKCS7_add_signature(PKCS7 *p7, X509 *x509,
 EVP_PKEY *pkey, const EVP_MD *dgst);
X509 *PKCS7_cert_from_signer_info(PKCS7 *p7, PKCS7_SIGNER_INFO *si);
int PKCS7_set_digest(PKCS7 *p7, const EVP_MD *md);
struct stack_st_PKCS7_SIGNER_INFO *PKCS7_get_signer_info(PKCS7 *p7);
PKCS7_RECIP_INFO *PKCS7_add_recipient(PKCS7 *p7, X509 *x509);
void PKCS7_SIGNER_INFO_get0_algs(PKCS7_SIGNER_INFO *si, EVP_PKEY **pk,
     X509_ALGOR **pdig, X509_ALGOR **psig);
void PKCS7_RECIP_INFO_get0_alg(PKCS7_RECIP_INFO *ri, X509_ALGOR **penc);
int PKCS7_add_recipient_info(PKCS7 *p7, PKCS7_RECIP_INFO *ri);
int PKCS7_RECIP_INFO_set(PKCS7_RECIP_INFO *p7i, X509 *x509);
int PKCS7_set_cipher(PKCS7 *p7, const EVP_CIPHER *cipher);
int PKCS7_stream(unsigned char ***boundary, PKCS7 *p7);
PKCS7_ISSUER_AND_SERIAL *PKCS7_get_issuer_and_serial(PKCS7 *p7, int idx);
ASN1_OCTET_STRING *PKCS7_digest_from_attributes(struct stack_st_X509_ATTRIBUTE *sk);
int PKCS7_add_signed_attribute(PKCS7_SIGNER_INFO *p7si,int nid,int type,
 void *data);
int PKCS7_add_attribute (PKCS7_SIGNER_INFO *p7si, int nid, int atrtype,
 void *value);
ASN1_TYPE *PKCS7_get_attribute(PKCS7_SIGNER_INFO *si, int nid);
ASN1_TYPE *PKCS7_get_signed_attribute(PKCS7_SIGNER_INFO *si, int nid);
int PKCS7_set_signed_attributes(PKCS7_SIGNER_INFO *p7si,
int PKCS7_set_attributes(PKCS7_SIGNER_INFO *p7si,struct stack_st_X509_ATTRIBUTE *sk);
PKCS7 *PKCS7_sign(X509 *signcert, EVP_PKEY *pkey, struct stack_st_X509 *certs,
       BIO *data, int flags);
PKCS7_SIGNER_INFO *PKCS7_sign_add_signer(PKCS7 *p7,
   X509 *signcert, EVP_PKEY *pkey, const EVP_MD *md,
   int flags);
int PKCS7_final(PKCS7 *p7, BIO *data, int flags);
int PKCS7_verify(PKCS7 *p7, struct stack_st_X509 *certs, X509_STORE *store,
     BIO *indata, BIO *out, int flags);
struct stack_st_X509 *PKCS7_get0_signers(PKCS7 *p7, struct stack_st_X509 *certs, int flags);
PKCS7 *PKCS7_encrypt(struct stack_st_X509 *certs, BIO *in, const EVP_CIPHER *cipher,
        int flags);
int PKCS7_decrypt(PKCS7 *p7, EVP_PKEY *pkey, X509 *cert, BIO *data, int flags);
int PKCS7_add_attrib_smimecap(PKCS7_SIGNER_INFO *si,
         struct stack_st_X509_ALGOR *cap);
struct stack_st_X509_ALGOR *PKCS7_get_smimecap(PKCS7_SIGNER_INFO *si);
int PKCS7_simple_smimecap(struct stack_st_X509_ALGOR *sk, int nid, int arg);
int PKCS7_add_attrib_content_type(PKCS7_SIGNER_INFO *si, ASN1_OBJECT *coid);
int PKCS7_add0_attrib_signing_time(PKCS7_SIGNER_INFO *si, ASN1_TIME *t);
int PKCS7_add1_attrib_digest(PKCS7_SIGNER_INFO *si,
    const unsigned char *md, int mdlen);
int SMIME_write_PKCS7(BIO *bio, PKCS7 *p7, BIO *data, int flags);
PKCS7 *SMIME_read_PKCS7(BIO *bio, BIO **bcont);
BIO *BIO_new_PKCS7(BIO *out, PKCS7 *p7);
void ERR_load_PKCS7_strings(void);
# 494 "/usr/include/openssl/pkcs7.h" 3 4
# 602 "/usr/include/openssl/x509.h" 2 3 4
extern "C" {
# 627 "/usr/include/openssl/x509.h" 3 4
void X509_CRL_set_default_method(const X509_CRL_METHOD *meth);
X509_CRL_METHOD *X509_CRL_METHOD_new(
 int (*crl_init)(X509_CRL *crl),
 int (*crl_free)(X509_CRL *crl),
 int (*crl_lookup)(X509_CRL *crl, X509_REVOKED **ret,
    ASN1_INTEGER *ser, X509_NAME *issuer),
 int (*crl_verify)(X509_CRL *crl, EVP_PKEY *pk));
void X509_CRL_METHOD_free(X509_CRL_METHOD *m);
void X509_CRL_set_meth_data(X509_CRL *crl, void *dat);
void *X509_CRL_get_meth_data(X509_CRL *crl);
const char *X509_verify_cert_error_string(long n);
int X509_verify(X509 *a, EVP_PKEY *r);
int X509_REQ_verify(X509_REQ *a, EVP_PKEY *r);
int X509_CRL_verify(X509_CRL *a, EVP_PKEY *r);
int NETSCAPE_SPKI_verify(NETSCAPE_SPKI *a, EVP_PKEY *r);
NETSCAPE_SPKI * NETSCAPE_SPKI_b64_decode(const char *str, int len);
char * NETSCAPE_SPKI_b64_encode(NETSCAPE_SPKI *x);
EVP_PKEY *NETSCAPE_SPKI_get_pubkey(NETSCAPE_SPKI *x);
int NETSCAPE_SPKI_set_pubkey(NETSCAPE_SPKI *x, EVP_PKEY *pkey);
int NETSCAPE_SPKI_print(BIO *out, NETSCAPE_SPKI *spki);
int X509_signature_dump(BIO *bp,const ASN1_STRING *sig, int indent);
int X509_signature_print(BIO *bp,X509_ALGOR *alg, ASN1_STRING *sig);
int X509_sign(X509 *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_sign_ctx(X509 *x, EVP_MD_CTX *ctx);
int X509_REQ_sign(X509_REQ *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_REQ_sign_ctx(X509_REQ *x, EVP_MD_CTX *ctx);
int X509_CRL_sign(X509_CRL *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_CRL_sign_ctx(X509_CRL *x, EVP_MD_CTX *ctx);
int NETSCAPE_SPKI_sign(NETSCAPE_SPKI *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_pubkey_digest(const X509 *data,const EVP_MD *type,
  unsigned char *md, unsigned int *len);
int X509_digest(const X509 *data,const EVP_MD *type,
int X509_CRL_digest(const X509_CRL *data,const EVP_MD *type,
int X509_REQ_digest(const X509_REQ *data,const EVP_MD *type,
int X509_NAME_digest(const X509_NAME *data,const EVP_MD *type,
X509 *d2i_X509_fp(FILE *fp, X509 **x509);
int i2d_X509_fp(FILE *fp,X509 *x509);
X509_CRL *d2i_X509_CRL_fp(FILE *fp,X509_CRL **crl);
int i2d_X509_CRL_fp(FILE *fp,X509_CRL *crl);
X509_REQ *d2i_X509_REQ_fp(FILE *fp,X509_REQ **req);
int i2d_X509_REQ_fp(FILE *fp,X509_REQ *req);
RSA *d2i_RSAPrivateKey_fp(FILE *fp,RSA **rsa);
int i2d_RSAPrivateKey_fp(FILE *fp,RSA *rsa);
RSA *d2i_RSAPublicKey_fp(FILE *fp,RSA **rsa);
int i2d_RSAPublicKey_fp(FILE *fp,RSA *rsa);
RSA *d2i_RSA_PUBKEY_fp(FILE *fp,RSA **rsa);
int i2d_RSA_PUBKEY_fp(FILE *fp,RSA *rsa);
DSA *d2i_DSA_PUBKEY_fp(FILE *fp, DSA **dsa);
int i2d_DSA_PUBKEY_fp(FILE *fp, DSA *dsa);
DSA *d2i_DSAPrivateKey_fp(FILE *fp, DSA **dsa);
int i2d_DSAPrivateKey_fp(FILE *fp, DSA *dsa);
EC_KEY *d2i_EC_PUBKEY_fp(FILE *fp, EC_KEY **eckey);
int i2d_EC_PUBKEY_fp(FILE *fp, EC_KEY *eckey);
EC_KEY *d2i_ECPrivateKey_fp(FILE *fp, EC_KEY **eckey);
int i2d_ECPrivateKey_fp(FILE *fp, EC_KEY *eckey);
X509_SIG *d2i_PKCS8_fp(FILE *fp,X509_SIG **p8);
int i2d_PKCS8_fp(FILE *fp,X509_SIG *p8);
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_fp(FILE *fp,
      PKCS8_PRIV_KEY_INFO **p8inf);
int i2d_PKCS8_PRIV_KEY_INFO_fp(FILE *fp,PKCS8_PRIV_KEY_INFO *p8inf);
int i2d_PKCS8PrivateKeyInfo_fp(FILE *fp, EVP_PKEY *key);
int i2d_PrivateKey_fp(FILE *fp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PrivateKey_fp(FILE *fp, EVP_PKEY **a);
int i2d_PUBKEY_fp(FILE *fp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PUBKEY_fp(FILE *fp, EVP_PKEY **a);
X509 *d2i_X509_bio(BIO *bp,X509 **x509);
int i2d_X509_bio(BIO *bp,X509 *x509);
X509_CRL *d2i_X509_CRL_bio(BIO *bp,X509_CRL **crl);
int i2d_X509_CRL_bio(BIO *bp,X509_CRL *crl);
X509_REQ *d2i_X509_REQ_bio(BIO *bp,X509_REQ **req);
int i2d_X509_REQ_bio(BIO *bp,X509_REQ *req);
RSA *d2i_RSAPrivateKey_bio(BIO *bp,RSA **rsa);
int i2d_RSAPrivateKey_bio(BIO *bp,RSA *rsa);
RSA *d2i_RSAPublicKey_bio(BIO *bp,RSA **rsa);
int i2d_RSAPublicKey_bio(BIO *bp,RSA *rsa);
RSA *d2i_RSA_PUBKEY_bio(BIO *bp,RSA **rsa);
int i2d_RSA_PUBKEY_bio(BIO *bp,RSA *rsa);
DSA *d2i_DSA_PUBKEY_bio(BIO *bp, DSA **dsa);
int i2d_DSA_PUBKEY_bio(BIO *bp, DSA *dsa);
DSA *d2i_DSAPrivateKey_bio(BIO *bp, DSA **dsa);
int i2d_DSAPrivateKey_bio(BIO *bp, DSA *dsa);
EC_KEY *d2i_EC_PUBKEY_bio(BIO *bp, EC_KEY **eckey);
int i2d_EC_PUBKEY_bio(BIO *bp, EC_KEY *eckey);
EC_KEY *d2i_ECPrivateKey_bio(BIO *bp, EC_KEY **eckey);
int i2d_ECPrivateKey_bio(BIO *bp, EC_KEY *eckey);
X509_SIG *d2i_PKCS8_bio(BIO *bp,X509_SIG **p8);
int i2d_PKCS8_bio(BIO *bp,X509_SIG *p8);
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_bio(BIO *bp,
int i2d_PKCS8_PRIV_KEY_INFO_bio(BIO *bp,PKCS8_PRIV_KEY_INFO *p8inf);
int i2d_PKCS8PrivateKeyInfo_bio(BIO *bp, EVP_PKEY *key);
int i2d_PrivateKey_bio(BIO *bp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PrivateKey_bio(BIO *bp, EVP_PKEY **a);
int i2d_PUBKEY_bio(BIO *bp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PUBKEY_bio(BIO *bp, EVP_PKEY **a);
X509 *X509_dup(X509 *x509);
X509_ATTRIBUTE *X509_ATTRIBUTE_dup(X509_ATTRIBUTE *xa);
X509_EXTENSION *X509_EXTENSION_dup(X509_EXTENSION *ex);
X509_CRL *X509_CRL_dup(X509_CRL *crl);
X509_REQ *X509_REQ_dup(X509_REQ *req);
X509_ALGOR *X509_ALGOR_dup(X509_ALGOR *xn);
int X509_ALGOR_set0(X509_ALGOR *alg, ASN1_OBJECT *aobj, int ptype, void *pval);
void X509_ALGOR_get0(ASN1_OBJECT **paobj, int *pptype, void **ppval,
      X509_ALGOR *algor);
void X509_ALGOR_set_md(X509_ALGOR *alg, const EVP_MD *md);
int X509_ALGOR_cmp(const X509_ALGOR *a, const X509_ALGOR *b);
X509_NAME *X509_NAME_dup(X509_NAME *xn);
X509_NAME_ENTRY *X509_NAME_ENTRY_dup(X509_NAME_ENTRY *ne);
int X509_cmp_time(const ASN1_TIME *s, time_t *t);
int X509_cmp_current_time(const ASN1_TIME *s);
ASN1_TIME * X509_time_adj(ASN1_TIME *s, long adj, time_t *t);
ASN1_TIME * X509_time_adj_ex(ASN1_TIME *s,
    int offset_day, long offset_sec, time_t *t);
ASN1_TIME * X509_gmtime_adj(ASN1_TIME *s, long adj);
const char * X509_get_default_cert_area(void );
const char * X509_get_default_cert_dir(void );
const char * X509_get_default_cert_file(void );
const char * X509_get_default_cert_dir_env(void );
const char * X509_get_default_cert_file_env(void );
const char * X509_get_default_private_dir(void );
X509_REQ * X509_to_X509_REQ(X509 *x, EVP_PKEY *pkey, const EVP_MD *md);
X509 * X509_REQ_to_X509(X509_REQ *r, int days,EVP_PKEY *pkey);
X509_ALGOR *X509_ALGOR_new(void); void X509_ALGOR_free(X509_ALGOR *a); X509_ALGOR *d2i_X509_ALGOR(X509_ALGOR **a, const unsigned char **in, long len); int i2d_X509_ALGOR(X509_ALGOR *a, unsigned char **out); extern const ASN1_ITEM X509_ALGOR_it;
X509_ALGORS *d2i_X509_ALGORS(X509_ALGORS **a, const unsigned char **in, long len); int i2d_X509_ALGORS(X509_ALGORS *a, unsigned char **out); extern const ASN1_ITEM X509_ALGORS_it;
X509_VAL *X509_VAL_new(void); void X509_VAL_free(X509_VAL *a); X509_VAL *d2i_X509_VAL(X509_VAL **a, const unsigned char **in, long len); int i2d_X509_VAL(X509_VAL *a, unsigned char **out); extern const ASN1_ITEM X509_VAL_it;
X509_PUBKEY *X509_PUBKEY_new(void); void X509_PUBKEY_free(X509_PUBKEY *a); X509_PUBKEY *d2i_X509_PUBKEY(X509_PUBKEY **a, const unsigned char **in, long len); int i2d_X509_PUBKEY(X509_PUBKEY *a, unsigned char **out); extern const ASN1_ITEM X509_PUBKEY_it;
int X509_PUBKEY_set(X509_PUBKEY **x, EVP_PKEY *pkey);
EVP_PKEY * X509_PUBKEY_get(X509_PUBKEY *key);
int X509_get_pubkey_parameters(EVP_PKEY *pkey,
int i2d_PUBKEY(EVP_PKEY *a,unsigned char **pp);
EVP_PKEY * d2i_PUBKEY(EVP_PKEY **a,const unsigned char **pp,
   long length);
int i2d_RSA_PUBKEY(RSA *a,unsigned char **pp);
RSA * d2i_RSA_PUBKEY(RSA **a,const unsigned char **pp,
   long length);
int i2d_DSA_PUBKEY(DSA *a,unsigned char **pp);
DSA * d2i_DSA_PUBKEY(DSA **a,const unsigned char **pp,
   long length);
int i2d_EC_PUBKEY(EC_KEY *a, unsigned char **pp);
EC_KEY *d2i_EC_PUBKEY(EC_KEY **a, const unsigned char **pp,
   long length);
X509_SIG *X509_SIG_new(void); void X509_SIG_free(X509_SIG *a); X509_SIG *d2i_X509_SIG(X509_SIG **a, const unsigned char **in, long len); int i2d_X509_SIG(X509_SIG *a, unsigned char **out); extern const ASN1_ITEM X509_SIG_it;
X509_REQ_INFO *X509_REQ_INFO_new(void); void X509_REQ_INFO_free(X509_REQ_INFO *a); X509_REQ_INFO *d2i_X509_REQ_INFO(X509_REQ_INFO **a, const unsigned char **in, long len); int i2d_X509_REQ_INFO(X509_REQ_INFO *a, unsigned char **out); extern const ASN1_ITEM X509_REQ_INFO_it;
X509_REQ *X509_REQ_new(void); void X509_REQ_free(X509_REQ *a); X509_REQ *d2i_X509_REQ(X509_REQ **a, const unsigned char **in, long len); int i2d_X509_REQ(X509_REQ *a, unsigned char **out); extern const ASN1_ITEM X509_REQ_it;
X509_ATTRIBUTE *X509_ATTRIBUTE_new(void); void X509_ATTRIBUTE_free(X509_ATTRIBUTE *a); X509_ATTRIBUTE *d2i_X509_ATTRIBUTE(X509_ATTRIBUTE **a, const unsigned char **in, long len); int i2d_X509_ATTRIBUTE(X509_ATTRIBUTE *a, unsigned char **out); extern const ASN1_ITEM X509_ATTRIBUTE_it;
X509_ATTRIBUTE *X509_ATTRIBUTE_create(int nid, int atrtype, void *value);
X509_EXTENSION *X509_EXTENSION_new(void); void X509_EXTENSION_free(X509_EXTENSION *a); X509_EXTENSION *d2i_X509_EXTENSION(X509_EXTENSION **a, const unsigned char **in, long len); int i2d_X509_EXTENSION(X509_EXTENSION *a, unsigned char **out); extern const ASN1_ITEM X509_EXTENSION_it;
X509_EXTENSIONS *d2i_X509_EXTENSIONS(X509_EXTENSIONS **a, const unsigned char **in, long len); int i2d_X509_EXTENSIONS(X509_EXTENSIONS *a, unsigned char **out); extern const ASN1_ITEM X509_EXTENSIONS_it;
X509_NAME_ENTRY *X509_NAME_ENTRY_new(void); void X509_NAME_ENTRY_free(X509_NAME_ENTRY *a); X509_NAME_ENTRY *d2i_X509_NAME_ENTRY(X509_NAME_ENTRY **a, const unsigned char **in, long len); int i2d_X509_NAME_ENTRY(X509_NAME_ENTRY *a, unsigned char **out); extern const ASN1_ITEM X509_NAME_ENTRY_it;
X509_NAME *X509_NAME_new(void); void X509_NAME_free(X509_NAME *a); X509_NAME *d2i_X509_NAME(X509_NAME **a, const unsigned char **in, long len); int i2d_X509_NAME(X509_NAME *a, unsigned char **out); extern const ASN1_ITEM X509_NAME_it;
int X509_NAME_set(X509_NAME **xn, X509_NAME *name);
X509_CINF *X509_CINF_new(void); void X509_CINF_free(X509_CINF *a); X509_CINF *d2i_X509_CINF(X509_CINF **a, const unsigned char **in, long len); int i2d_X509_CINF(X509_CINF *a, unsigned char **out); extern const ASN1_ITEM X509_CINF_it;
X509 *X509_new(void); void X509_free(X509 *a); X509 *d2i_X509(X509 **a, const unsigned char **in, long len); int i2d_X509(X509 *a, unsigned char **out); extern const ASN1_ITEM X509_it;
X509_CERT_AUX *X509_CERT_AUX_new(void); void X509_CERT_AUX_free(X509_CERT_AUX *a); X509_CERT_AUX *d2i_X509_CERT_AUX(X509_CERT_AUX **a, const unsigned char **in, long len); int i2d_X509_CERT_AUX(X509_CERT_AUX *a, unsigned char **out); extern const ASN1_ITEM X509_CERT_AUX_it;
X509_CERT_PAIR *X509_CERT_PAIR_new(void); void X509_CERT_PAIR_free(X509_CERT_PAIR *a); X509_CERT_PAIR *d2i_X509_CERT_PAIR(X509_CERT_PAIR **a, const unsigned char **in, long len); int i2d_X509_CERT_PAIR(X509_CERT_PAIR *a, unsigned char **out); extern const ASN1_ITEM X509_CERT_PAIR_it;
int X509_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int X509_set_ex_data(X509 *r, int idx, void *arg);
void *X509_get_ex_data(X509 *r, int idx);
int i2d_X509_AUX(X509 *a,unsigned char **pp);
X509 * d2i_X509_AUX(X509 **a,const unsigned char **pp,long length);
int X509_alias_set1(X509 *x, unsigned char *name, int len);
int X509_keyid_set1(X509 *x, unsigned char *id, int len);
unsigned char * X509_alias_get0(X509 *x, int *len);
unsigned char * X509_keyid_get0(X509 *x, int *len);
int (*X509_TRUST_set_default(int (*trust)(int , X509 *, int)))(int, X509 *, int);
int X509_TRUST_set(int *t, int trust);
int X509_add1_trust_object(X509 *x, ASN1_OBJECT *obj);
int X509_add1_reject_object(X509 *x, ASN1_OBJECT *obj);
void X509_trust_clear(X509 *x);
void X509_reject_clear(X509 *x);
X509_REVOKED *X509_REVOKED_new(void); void X509_REVOKED_free(X509_REVOKED *a); X509_REVOKED *d2i_X509_REVOKED(X509_REVOKED **a, const unsigned char **in, long len); int i2d_X509_REVOKED(X509_REVOKED *a, unsigned char **out); extern const ASN1_ITEM X509_REVOKED_it;
X509_CRL_INFO *X509_CRL_INFO_new(void); void X509_CRL_INFO_free(X509_CRL_INFO *a); X509_CRL_INFO *d2i_X509_CRL_INFO(X509_CRL_INFO **a, const unsigned char **in, long len); int i2d_X509_CRL_INFO(X509_CRL_INFO *a, unsigned char **out); extern const ASN1_ITEM X509_CRL_INFO_it;
X509_CRL *X509_CRL_new(void); void X509_CRL_free(X509_CRL *a); X509_CRL *d2i_X509_CRL(X509_CRL **a, const unsigned char **in, long len); int i2d_X509_CRL(X509_CRL *a, unsigned char **out); extern const ASN1_ITEM X509_CRL_it;
int X509_CRL_add0_revoked(X509_CRL *crl, X509_REVOKED *rev);
int X509_CRL_get0_by_serial(X509_CRL *crl,
  X509_REVOKED **ret, ASN1_INTEGER *serial);
int X509_CRL_get0_by_cert(X509_CRL *crl, X509_REVOKED **ret, X509 *x);
X509_PKEY * X509_PKEY_new(void );
void X509_PKEY_free(X509_PKEY *a);
int i2d_X509_PKEY(X509_PKEY *a,unsigned char **pp);
X509_PKEY * d2i_X509_PKEY(X509_PKEY **a,const unsigned char **pp,long length);
NETSCAPE_SPKI *NETSCAPE_SPKI_new(void); void NETSCAPE_SPKI_free(NETSCAPE_SPKI *a); NETSCAPE_SPKI *d2i_NETSCAPE_SPKI(NETSCAPE_SPKI **a, const unsigned char **in, long len); int i2d_NETSCAPE_SPKI(NETSCAPE_SPKI *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_SPKI_it;
NETSCAPE_SPKAC *NETSCAPE_SPKAC_new(void); void NETSCAPE_SPKAC_free(NETSCAPE_SPKAC *a); NETSCAPE_SPKAC *d2i_NETSCAPE_SPKAC(NETSCAPE_SPKAC **a, const unsigned char **in, long len); int i2d_NETSCAPE_SPKAC(NETSCAPE_SPKAC *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_SPKAC_it;
NETSCAPE_CERT_SEQUENCE *NETSCAPE_CERT_SEQUENCE_new(void); void NETSCAPE_CERT_SEQUENCE_free(NETSCAPE_CERT_SEQUENCE *a); NETSCAPE_CERT_SEQUENCE *d2i_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE **a, const unsigned char **in, long len); int i2d_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_CERT_SEQUENCE_it;
X509_INFO * X509_INFO_new(void);
void X509_INFO_free(X509_INFO *a);
char * X509_NAME_oneline(X509_NAME *a,char *buf,int size);
int ASN1_verify(i2d_of_void *i2d, X509_ALGOR *algor1,
  ASN1_BIT_STRING *signature,char *data,EVP_PKEY *pkey);
int ASN1_digest(i2d_of_void *i2d,const EVP_MD *type,char *data,
int ASN1_sign(i2d_of_void *i2d, X509_ALGOR *algor1,
       X509_ALGOR *algor2, ASN1_BIT_STRING *signature,
       char *data,EVP_PKEY *pkey, const EVP_MD *type);
int ASN1_item_digest(const ASN1_ITEM *it,const EVP_MD *type,void *data,
int ASN1_item_verify(const ASN1_ITEM *it, X509_ALGOR *algor1,
 ASN1_BIT_STRING *signature,void *data,EVP_PKEY *pkey);
int ASN1_item_sign(const ASN1_ITEM *it, X509_ALGOR *algor1, X509_ALGOR *algor2,
 void *data, EVP_PKEY *pkey, const EVP_MD *type);
int ASN1_item_sign_ctx(const ASN1_ITEM *it,
       ASN1_BIT_STRING *signature, void *asn, EVP_MD_CTX *ctx);
int X509_set_version(X509 *x,long version);
int X509_set_serialNumber(X509 *x, ASN1_INTEGER *serial);
ASN1_INTEGER * X509_get_serialNumber(X509 *x);
int X509_set_issuer_name(X509 *x, X509_NAME *name);
X509_NAME * X509_get_issuer_name(X509 *a);
int X509_set_subject_name(X509 *x, X509_NAME *name);
X509_NAME * X509_get_subject_name(X509 *a);
int X509_set_notBefore(X509 *x, const ASN1_TIME *tm);
int X509_set_notAfter(X509 *x, const ASN1_TIME *tm);
int X509_set_pubkey(X509 *x, EVP_PKEY *pkey);
EVP_PKEY * X509_get_pubkey(X509 *x);
ASN1_BIT_STRING * X509_get0_pubkey_bitstr(const X509 *x);
int X509_certificate_type(X509 *x,EVP_PKEY *pubkey );
int X509_REQ_set_version(X509_REQ *x,long version);
int X509_REQ_set_subject_name(X509_REQ *req,X509_NAME *name);
int X509_REQ_set_pubkey(X509_REQ *x, EVP_PKEY *pkey);
EVP_PKEY * X509_REQ_get_pubkey(X509_REQ *req);
int X509_REQ_extension_nid(int nid);
int * X509_REQ_get_extension_nids(void);
void X509_REQ_set_extension_nids(int *nids);
struct stack_st_X509_EXTENSION *X509_REQ_get_extensions(X509_REQ *req);
int X509_REQ_add_extensions_nid(X509_REQ *req, struct stack_st_X509_EXTENSION *exts,
    int nid);
int X509_REQ_add_extensions(X509_REQ *req, struct stack_st_X509_EXTENSION *exts);
int X509_REQ_get_attr_count(const X509_REQ *req);
int X509_REQ_get_attr_by_NID(const X509_REQ *req, int nid,
     int lastpos);
int X509_REQ_get_attr_by_OBJ(const X509_REQ *req, ASN1_OBJECT *obj,
     int lastpos);
X509_ATTRIBUTE *X509_REQ_get_attr(const X509_REQ *req, int loc);
X509_ATTRIBUTE *X509_REQ_delete_attr(X509_REQ *req, int loc);
int X509_REQ_add1_attr(X509_REQ *req, X509_ATTRIBUTE *attr);
int X509_REQ_add1_attr_by_OBJ(X509_REQ *req,
   const ASN1_OBJECT *obj, int type,
   const unsigned char *bytes, int len);
int X509_REQ_add1_attr_by_NID(X509_REQ *req,
   int nid, int type,
int X509_REQ_add1_attr_by_txt(X509_REQ *req,
   const char *attrname, int type,
int X509_CRL_set_version(X509_CRL *x, long version);
int X509_CRL_set_issuer_name(X509_CRL *x, X509_NAME *name);
int X509_CRL_set_lastUpdate(X509_CRL *x, const ASN1_TIME *tm);
int X509_CRL_set_nextUpdate(X509_CRL *x, const ASN1_TIME *tm);
int X509_CRL_sort(X509_CRL *crl);
int X509_REVOKED_set_serialNumber(X509_REVOKED *x, ASN1_INTEGER *serial);
int X509_REVOKED_set_revocationDate(X509_REVOKED *r, ASN1_TIME *tm);
int X509_REQ_check_private_key(X509_REQ *x509,EVP_PKEY *pkey);
int X509_check_private_key(X509 *x509,EVP_PKEY *pkey);
int X509_issuer_and_serial_cmp(const X509 *a, const X509 *b);
unsigned long X509_issuer_and_serial_hash(X509 *a);
int X509_issuer_name_cmp(const X509 *a, const X509 *b);
unsigned long X509_issuer_name_hash(X509 *a);
int X509_subject_name_cmp(const X509 *a, const X509 *b);
unsigned long X509_subject_name_hash(X509 *x);
unsigned long X509_issuer_name_hash_old(X509 *a);
unsigned long X509_subject_name_hash_old(X509 *x);
int X509_cmp(const X509 *a, const X509 *b);
int X509_NAME_cmp(const X509_NAME *a, const X509_NAME *b);
unsigned long X509_NAME_hash(X509_NAME *x);
unsigned long X509_NAME_hash_old(X509_NAME *x);
int X509_CRL_cmp(const X509_CRL *a, const X509_CRL *b);
int X509_CRL_match(const X509_CRL *a, const X509_CRL *b);
int X509_print_ex_fp(FILE *bp,X509 *x, unsigned long nmflag, unsigned long cflag);
int X509_print_fp(FILE *bp,X509 *x);
int X509_CRL_print_fp(FILE *bp,X509_CRL *x);
int X509_REQ_print_fp(FILE *bp,X509_REQ *req);
int X509_NAME_print_ex_fp(FILE *fp, X509_NAME *nm, int indent, unsigned long flags);
int X509_NAME_print(BIO *bp, X509_NAME *name, int obase);
int X509_NAME_print_ex(BIO *out, X509_NAME *nm, int indent, unsigned long flags);
int X509_print_ex(BIO *bp,X509 *x, unsigned long nmflag, unsigned long cflag);
int X509_print(BIO *bp,X509 *x);
int X509_ocspid_print(BIO *bp,X509 *x);
int X509_CERT_AUX_print(BIO *bp,X509_CERT_AUX *x, int indent);
int X509_CRL_print(BIO *bp,X509_CRL *x);
int X509_REQ_print_ex(BIO *bp, X509_REQ *x, unsigned long nmflag, unsigned long cflag);
int X509_REQ_print(BIO *bp,X509_REQ *req);
int X509_NAME_entry_count(X509_NAME *name);
int X509_NAME_get_text_by_NID(X509_NAME *name, int nid,
   char *buf,int len);
int X509_NAME_get_text_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj,
   char *buf,int len);
int X509_NAME_get_index_by_NID(X509_NAME *name,int nid,int lastpos);
int X509_NAME_get_index_by_OBJ(X509_NAME *name,ASN1_OBJECT *obj,
   int lastpos);
X509_NAME_ENTRY *X509_NAME_get_entry(X509_NAME *name, int loc);
X509_NAME_ENTRY *X509_NAME_delete_entry(X509_NAME *name, int loc);
int X509_NAME_add_entry(X509_NAME *name,X509_NAME_ENTRY *ne,
   int loc, int set);
int X509_NAME_add_entry_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj, int type,
   unsigned char *bytes, int len, int loc, int set);
int X509_NAME_add_entry_by_NID(X509_NAME *name, int nid, int type,
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_txt(X509_NAME_ENTRY **ne,
  const char *field, int type, const unsigned char *bytes, int len);
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_NID(X509_NAME_ENTRY **ne, int nid,
   int type,unsigned char *bytes, int len);
int X509_NAME_add_entry_by_txt(X509_NAME *name, const char *field, int type,
   const unsigned char *bytes, int len, int loc, int set);
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_OBJ(X509_NAME_ENTRY **ne,
   ASN1_OBJECT *obj, int type,const unsigned char *bytes,
   int len);
int X509_NAME_ENTRY_set_object(X509_NAME_ENTRY *ne,
   ASN1_OBJECT *obj);
int X509_NAME_ENTRY_set_data(X509_NAME_ENTRY *ne, int type,
ASN1_OBJECT * X509_NAME_ENTRY_get_object(X509_NAME_ENTRY *ne);
ASN1_STRING * X509_NAME_ENTRY_get_data(X509_NAME_ENTRY *ne);
int X509v3_get_ext_count(const struct stack_st_X509_EXTENSION *x);
int X509v3_get_ext_by_NID(const struct stack_st_X509_EXTENSION *x,
          int nid, int lastpos);
int X509v3_get_ext_by_OBJ(const struct stack_st_X509_EXTENSION *x,
          ASN1_OBJECT *obj,int lastpos);
int X509v3_get_ext_by_critical(const struct stack_st_X509_EXTENSION *x,
        int crit, int lastpos);
X509_EXTENSION *X509v3_get_ext(const struct stack_st_X509_EXTENSION *x, int loc);
X509_EXTENSION *X509v3_delete_ext(struct stack_st_X509_EXTENSION *x, int loc);
struct stack_st_X509_EXTENSION *X509v3_add_ext(struct stack_st_X509_EXTENSION **x,
      X509_EXTENSION *ex, int loc);
int X509_get_ext_count(X509 *x);
int X509_get_ext_by_NID(X509 *x, int nid, int lastpos);
int X509_get_ext_by_OBJ(X509 *x,ASN1_OBJECT *obj,int lastpos);
int X509_get_ext_by_critical(X509 *x, int crit, int lastpos);
X509_EXTENSION *X509_get_ext(X509 *x, int loc);
X509_EXTENSION *X509_delete_ext(X509 *x, int loc);
int X509_add_ext(X509 *x, X509_EXTENSION *ex, int loc);
void * X509_get_ext_d2i(X509 *x, int nid, int *crit, int *idx);
int X509_add1_ext_i2d(X509 *x, int nid, void *value, int crit,
int X509_CRL_get_ext_count(X509_CRL *x);
int X509_CRL_get_ext_by_NID(X509_CRL *x, int nid, int lastpos);
int X509_CRL_get_ext_by_OBJ(X509_CRL *x,ASN1_OBJECT *obj,int lastpos);
int X509_CRL_get_ext_by_critical(X509_CRL *x, int crit, int lastpos);
X509_EXTENSION *X509_CRL_get_ext(X509_CRL *x, int loc);
X509_EXTENSION *X509_CRL_delete_ext(X509_CRL *x, int loc);
int X509_CRL_add_ext(X509_CRL *x, X509_EXTENSION *ex, int loc);
void * X509_CRL_get_ext_d2i(X509_CRL *x, int nid, int *crit, int *idx);
int X509_CRL_add1_ext_i2d(X509_CRL *x, int nid, void *value, int crit,
int X509_REVOKED_get_ext_count(X509_REVOKED *x);
int X509_REVOKED_get_ext_by_NID(X509_REVOKED *x, int nid, int lastpos);
int X509_REVOKED_get_ext_by_OBJ(X509_REVOKED *x,ASN1_OBJECT *obj,int lastpos);
int X509_REVOKED_get_ext_by_critical(X509_REVOKED *x, int crit, int lastpos);
X509_EXTENSION *X509_REVOKED_get_ext(X509_REVOKED *x, int loc);
X509_EXTENSION *X509_REVOKED_delete_ext(X509_REVOKED *x, int loc);
int X509_REVOKED_add_ext(X509_REVOKED *x, X509_EXTENSION *ex, int loc);
void * X509_REVOKED_get_ext_d2i(X509_REVOKED *x, int nid, int *crit, int *idx);
int X509_REVOKED_add1_ext_i2d(X509_REVOKED *x, int nid, void *value, int crit,
X509_EXTENSION *X509_EXTENSION_create_by_NID(X509_EXTENSION **ex,
   int nid, int crit, ASN1_OCTET_STRING *data);
X509_EXTENSION *X509_EXTENSION_create_by_OBJ(X509_EXTENSION **ex,
   ASN1_OBJECT *obj,int crit,ASN1_OCTET_STRING *data);
int X509_EXTENSION_set_object(X509_EXTENSION *ex,ASN1_OBJECT *obj);
int X509_EXTENSION_set_critical(X509_EXTENSION *ex, int crit);
int X509_EXTENSION_set_data(X509_EXTENSION *ex,
ASN1_OBJECT * X509_EXTENSION_get_object(X509_EXTENSION *ex);
ASN1_OCTET_STRING *X509_EXTENSION_get_data(X509_EXTENSION *ne);
int X509_EXTENSION_get_critical(X509_EXTENSION *ex);
int X509at_get_attr_count(const struct stack_st_X509_ATTRIBUTE *x);
int X509at_get_attr_by_NID(const struct stack_st_X509_ATTRIBUTE *x, int nid,
     int lastpos);
int X509at_get_attr_by_OBJ(const struct stack_st_X509_ATTRIBUTE *sk, ASN1_OBJECT *obj,
     int lastpos);
X509_ATTRIBUTE *X509at_get_attr(const struct stack_st_X509_ATTRIBUTE *x, int loc);
X509_ATTRIBUTE *X509at_delete_attr(struct stack_st_X509_ATTRIBUTE *x, int loc);
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr(struct stack_st_X509_ATTRIBUTE **x,
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr_by_OBJ(struct stack_st_X509_ATTRIBUTE **x,
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr_by_NID(struct stack_st_X509_ATTRIBUTE **x,
   int nid, int type,
struct stack_st_X509_ATTRIBUTE *X509at_add1_attr_by_txt(struct stack_st_X509_ATTRIBUTE **x,
void *X509at_get0_data_by_OBJ(struct stack_st_X509_ATTRIBUTE *x,
    ASN1_OBJECT *obj, int lastpos, int type);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_NID(X509_ATTRIBUTE **attr, int nid,
      int atrtype, const void *data, int len);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_OBJ(X509_ATTRIBUTE **attr,
      const ASN1_OBJECT *obj, int atrtype, const void *data, int len);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_txt(X509_ATTRIBUTE **attr,
  const char *atrname, int type, const unsigned char *bytes, int len);
int X509_ATTRIBUTE_set1_object(X509_ATTRIBUTE *attr, const ASN1_OBJECT *obj);
int X509_ATTRIBUTE_set1_data(X509_ATTRIBUTE *attr, int attrtype, const void *data, int len);
void *X509_ATTRIBUTE_get0_data(X509_ATTRIBUTE *attr, int idx,
     int atrtype, void *data);
int X509_ATTRIBUTE_count(X509_ATTRIBUTE *attr);
ASN1_OBJECT *X509_ATTRIBUTE_get0_object(X509_ATTRIBUTE *attr);
ASN1_TYPE *X509_ATTRIBUTE_get0_type(X509_ATTRIBUTE *attr, int idx);
int EVP_PKEY_get_attr_count(const EVP_PKEY *key);
int EVP_PKEY_get_attr_by_NID(const EVP_PKEY *key, int nid,
     int lastpos);
int EVP_PKEY_get_attr_by_OBJ(const EVP_PKEY *key, ASN1_OBJECT *obj,
     int lastpos);
X509_ATTRIBUTE *EVP_PKEY_get_attr(const EVP_PKEY *key, int loc);
X509_ATTRIBUTE *EVP_PKEY_delete_attr(EVP_PKEY *key, int loc);
int EVP_PKEY_add1_attr(EVP_PKEY *key, X509_ATTRIBUTE *attr);
int EVP_PKEY_add1_attr_by_OBJ(EVP_PKEY *key,
int EVP_PKEY_add1_attr_by_NID(EVP_PKEY *key,
   int nid, int type,
int EVP_PKEY_add1_attr_by_txt(EVP_PKEY *key,
int X509_verify_cert(X509_STORE_CTX *ctx);
X509 *X509_find_by_issuer_and_serial(struct stack_st_X509 *sk,X509_NAME *name,
X509 *X509_find_by_subject(struct stack_st_X509 *sk,X509_NAME *name);
PBEPARAM *PBEPARAM_new(void); void PBEPARAM_free(PBEPARAM *a); PBEPARAM *d2i_PBEPARAM(PBEPARAM **a, const unsigned char **in, long len); int i2d_PBEPARAM(PBEPARAM *a, unsigned char **out); extern const ASN1_ITEM PBEPARAM_it;
PBE2PARAM *PBE2PARAM_new(void); void PBE2PARAM_free(PBE2PARAM *a); PBE2PARAM *d2i_PBE2PARAM(PBE2PARAM **a, const unsigned char **in, long len); int i2d_PBE2PARAM(PBE2PARAM *a, unsigned char **out); extern const ASN1_ITEM PBE2PARAM_it;
PBKDF2PARAM *PBKDF2PARAM_new(void); void PBKDF2PARAM_free(PBKDF2PARAM *a); PBKDF2PARAM *d2i_PBKDF2PARAM(PBKDF2PARAM **a, const unsigned char **in, long len); int i2d_PBKDF2PARAM(PBKDF2PARAM *a, unsigned char **out); extern const ASN1_ITEM PBKDF2PARAM_it;
int PKCS5_pbe_set0_algor(X509_ALGOR *algor, int alg, int iter,
    const unsigned char *salt, int saltlen);
X509_ALGOR *PKCS5_pbe_set(int alg, int iter,
X509_ALGOR *PKCS5_pbe2_set(const EVP_CIPHER *cipher, int iter,
X509_ALGOR *PKCS5_pbe2_set_iv(const EVP_CIPHER *cipher, int iter,
     unsigned char *salt, int saltlen,
     unsigned char *aiv, int prf_nid);
X509_ALGOR *PKCS5_pbkdf2_set(int iter, unsigned char *salt, int saltlen,
    int prf_nid, int keylen);
PKCS8_PRIV_KEY_INFO *PKCS8_PRIV_KEY_INFO_new(void); void PKCS8_PRIV_KEY_INFO_free(PKCS8_PRIV_KEY_INFO *a); PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO **a, const unsigned char **in, long len); int i2d_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS8_PRIV_KEY_INFO_it;
EVP_PKEY *EVP_PKCS82PKEY(PKCS8_PRIV_KEY_INFO *p8);
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8(EVP_PKEY *pkey);
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8_broken(EVP_PKEY *pkey, int broken);
PKCS8_PRIV_KEY_INFO *PKCS8_set_broken(PKCS8_PRIV_KEY_INFO *p8, int broken);
int PKCS8_pkey_set0(PKCS8_PRIV_KEY_INFO *priv, ASN1_OBJECT *aobj,
   int version, int ptype, void *pval,
    unsigned char *penc, int penclen);
int PKCS8_pkey_get0(ASN1_OBJECT **ppkalg,
  const unsigned char **pk, int *ppklen,
  X509_ALGOR **pa,
int X509_PUBKEY_set0_param(X509_PUBKEY *pub, ASN1_OBJECT *aobj,
int X509_PUBKEY_get0_param(ASN1_OBJECT **ppkalg,
  X509_ALGOR **pa,
  X509_PUBKEY *pub);
int X509_check_trust(X509 *x, int id, int flags);
int X509_TRUST_get_count(void);
X509_TRUST * X509_TRUST_get0(int idx);
int X509_TRUST_get_by_id(int id);
int X509_TRUST_add(int id, int flags, int (*ck)(X509_TRUST *, X509 *, int),
     char *name, int arg1, void *arg2);
void X509_TRUST_cleanup(void);
int X509_TRUST_get_flags(X509_TRUST *xp);
char *X509_TRUST_get0_name(X509_TRUST *xp);
int X509_TRUST_get_trust(X509_TRUST *xp);
void ERR_load_X509_strings(void);
# 1296 "/usr/include/openssl/x509.h" 3 4
# 157 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/pem.h" 1 3 4
# 62 "/usr/include/openssl/pem.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 34 "/usr/include/openssl/opensslconf.h" 3 4
# 1 "/usr/include/openssl/opensslconf-x86_64.h" 1 3 4
# 12 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
extern "C" {
# 284 "/usr/include/openssl/opensslconf-x86_64.h" 3 4
# 35 "/usr/include/openssl/opensslconf.h" 2 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 63 "/usr/include/openssl/pem.h" 2 3 4
# 71 "/usr/include/openssl/pem.h" 3 4
# 1 "/usr/include/openssl/pem2.h" 1 3 4
# 61 "/usr/include/openssl/pem2.h" 3 4
extern "C" {
# 72 "/usr/include/openssl/pem.h" 2 3 4
extern "C" {
# 142 "/usr/include/openssl/pem.h" 3 4
typedef struct PEM_Encode_Seal_st
 EVP_ENCODE_CTX encode;
 EVP_MD_CTX md;
 EVP_CIPHER_CTX cipher;
 } PEM_ENCODE_SEAL_CTX;
typedef struct pem_recip_st
 char *name;
 X509_NAME *dn;
 int cipher;
 int key_enc;
 } PEM_USER;
typedef struct pem_ctx_st
 int type;
 struct {
  int version;
  int mode;
  } proc_type;
 char *domain;
 struct {
  int cipher;
  } DEK_info;
 PEM_USER *originator;
 int num_recipient;
 PEM_USER **recipient;
 EVP_MD *md;
 int md_enc;
 int md_len;
 char *md_data;
 EVP_CIPHER *dec;
 int key_len;
 unsigned char *key;
 int data_enc;
 int data_len;
 unsigned char *data;
 } PEM_CTX;
# 400 "/usr/include/openssl/pem.h" 3 4
typedef int pem_password_cb(char *buf, int size, int rwflag, void *userdata);
int PEM_get_EVP_CIPHER_INFO(char *header, EVP_CIPHER_INFO *cipher);
int PEM_do_header (EVP_CIPHER_INFO *cipher, unsigned char *data,long *len,
 pem_password_cb *callback,void *u);
int PEM_read_bio(BIO *bp, char **name, char **header,
  unsigned char **data,long *len);
int PEM_write_bio(BIO *bp,const char *name,char *hdr,unsigned char *data,
  long len);
int PEM_bytes_read_bio(unsigned char **pdata, long *plen, char **pnm, const char *name, BIO *bp,
      pem_password_cb *cb, void *u);
void * PEM_ASN1_read_bio(d2i_of_void *d2i, const char *name, BIO *bp,
     void **x, pem_password_cb *cb, void *u);
int PEM_ASN1_write_bio(i2d_of_void *i2d,const char *name,BIO *bp, void *x,
      const EVP_CIPHER *enc,unsigned char *kstr,int klen,
struct stack_st_X509_INFO * PEM_X509_INFO_read_bio(BIO *bp, struct stack_st_X509_INFO *sk, pem_password_cb *cb, void *u);
int PEM_X509_INFO_write_bio(BIO *bp,X509_INFO *xi, EVP_CIPHER *enc,
  unsigned char *kstr, int klen, pem_password_cb *cd, void *u);
int PEM_read(FILE *fp, char **name, char **header,
int PEM_write(FILE *fp,char *name,char *hdr,unsigned char *data,long len);
void * PEM_ASN1_read(d2i_of_void *d2i, const char *name, FILE *fp, void **x,
int PEM_ASN1_write(i2d_of_void *i2d,const char *name,FILE *fp,
         void *x,const EVP_CIPHER *enc,unsigned char *kstr,
         int klen,pem_password_cb *callback, void *u);
struct stack_st_X509_INFO * PEM_X509_INFO_read(FILE *fp, struct stack_st_X509_INFO *sk,
int PEM_SealInit(PEM_ENCODE_SEAL_CTX *ctx, EVP_CIPHER *type,
  EVP_MD *md_type, unsigned char **ek, int *ekl,
  unsigned char *iv, EVP_PKEY **pubk, int npubk);
void PEM_SealUpdate(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *out, int *outl,
  unsigned char *in, int inl);
int PEM_SealFinal(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *sig,int *sigl,
  unsigned char *out, int *outl, EVP_PKEY *priv);
void PEM_SignInit(EVP_MD_CTX *ctx, EVP_MD *type);
void PEM_SignUpdate(EVP_MD_CTX *ctx,unsigned char *d,unsigned int cnt);
int PEM_SignFinal(EVP_MD_CTX *ctx, unsigned char *sigret,
  unsigned int *siglen, EVP_PKEY *pkey);
int PEM_def_callback(char *buf, int num, int w, void *key);
void PEM_proc_type(char *buf, int type);
void PEM_dek_info(char *buf, const char *type, int len, char *str);
X509 *PEM_read_bio_X509(BIO *bp, X509 **x, pem_password_cb *cb, void *u); X509 *PEM_read_X509(FILE *fp, X509 **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509(BIO *bp, X509 *x); int PEM_write_X509(FILE *fp, X509 *x);
X509 *PEM_read_bio_X509_AUX(BIO *bp, X509 **x, pem_password_cb *cb, void *u); X509 *PEM_read_X509_AUX(FILE *fp, X509 **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_AUX(BIO *bp, X509 *x); int PEM_write_X509_AUX(FILE *fp, X509 *x);
X509_CERT_PAIR *PEM_read_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR **x, pem_password_cb *cb, void *u); X509_CERT_PAIR *PEM_read_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR *x); int PEM_write_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR *x);
X509_REQ *PEM_read_bio_X509_REQ(BIO *bp, X509_REQ **x, pem_password_cb *cb, void *u); X509_REQ *PEM_read_X509_REQ(FILE *fp, X509_REQ **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_REQ(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ(FILE *fp, X509_REQ *x);
int PEM_write_bio_X509_REQ_NEW(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ_NEW(FILE *fp, X509_REQ *x);
X509_CRL *PEM_read_bio_X509_CRL(BIO *bp, X509_CRL **x, pem_password_cb *cb, void *u); X509_CRL *PEM_read_X509_CRL(FILE *fp, X509_CRL **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CRL(BIO *bp, X509_CRL *x); int PEM_write_X509_CRL(FILE *fp, X509_CRL *x);
PKCS7 *PEM_read_bio_PKCS7(BIO *bp, PKCS7 **x, pem_password_cb *cb, void *u); PKCS7 *PEM_read_PKCS7(FILE *fp, PKCS7 **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS7(BIO *bp, PKCS7 *x); int PEM_write_PKCS7(FILE *fp, PKCS7 *x);
NETSCAPE_CERT_SEQUENCE *PEM_read_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE **x, pem_password_cb *cb, void *u); NETSCAPE_CERT_SEQUENCE *PEM_read_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE **x, pem_password_cb *cb, void *u); int PEM_write_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE *x); int PEM_write_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE *x);
X509_SIG *PEM_read_bio_PKCS8(BIO *bp, X509_SIG **x, pem_password_cb *cb, void *u); X509_SIG *PEM_read_PKCS8(FILE *fp, X509_SIG **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8(BIO *bp, X509_SIG *x); int PEM_write_PKCS8(FILE *fp, X509_SIG *x);
PKCS8_PRIV_KEY_INFO *PEM_read_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO **x, pem_password_cb *cb, void *u); PKCS8_PRIV_KEY_INFO *PEM_read_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO *x); int PEM_write_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO *x);
RSA *PEM_read_bio_RSAPrivateKey(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPrivateKey(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPrivateKey(BIO *bp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_RSAPrivateKey(FILE *fp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
RSA *PEM_read_bio_RSAPublicKey(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPublicKey(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPublicKey(BIO *bp, const RSA *x); int PEM_write_RSAPublicKey(FILE *fp, const RSA *x);
RSA *PEM_read_bio_RSA_PUBKEY(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSA_PUBKEY(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSA_PUBKEY(BIO *bp, RSA *x); int PEM_write_RSA_PUBKEY(FILE *fp, RSA *x);
DSA *PEM_read_bio_DSAPrivateKey(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAPrivateKey(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAPrivateKey(BIO *bp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_DSAPrivateKey(FILE *fp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
DSA *PEM_read_bio_DSA_PUBKEY(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSA_PUBKEY(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSA_PUBKEY(BIO *bp, DSA *x); int PEM_write_DSA_PUBKEY(FILE *fp, DSA *x);
DSA *PEM_read_bio_DSAparams(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAparams(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAparams(BIO *bp, const DSA *x); int PEM_write_DSAparams(FILE *fp, const DSA *x);
EC_GROUP *PEM_read_bio_ECPKParameters(BIO *bp, EC_GROUP **x, pem_password_cb *cb, void *u); EC_GROUP *PEM_read_ECPKParameters(FILE *fp, EC_GROUP **x, pem_password_cb *cb, void *u); int PEM_write_bio_ECPKParameters(BIO *bp, const EC_GROUP *x); int PEM_write_ECPKParameters(FILE *fp, const EC_GROUP *x);
EC_KEY *PEM_read_bio_ECPrivateKey(BIO *bp, EC_KEY **x, pem_password_cb *cb, void *u); EC_KEY *PEM_read_ECPrivateKey(FILE *fp, EC_KEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_ECPrivateKey(BIO *bp, EC_KEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_ECPrivateKey(FILE *fp, EC_KEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
EC_KEY *PEM_read_bio_EC_PUBKEY(BIO *bp, EC_KEY **x, pem_password_cb *cb, void *u); EC_KEY *PEM_read_EC_PUBKEY(FILE *fp, EC_KEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_EC_PUBKEY(BIO *bp, EC_KEY *x); int PEM_write_EC_PUBKEY(FILE *fp, EC_KEY *x);
DH *PEM_read_bio_DHparams(BIO *bp, DH **x, pem_password_cb *cb, void *u); DH *PEM_read_DHparams(FILE *fp, DH **x, pem_password_cb *cb, void *u); int PEM_write_bio_DHparams(BIO *bp, const DH *x); int PEM_write_DHparams(FILE *fp, const DH *x);
EVP_PKEY *PEM_read_bio_PrivateKey(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PrivateKey(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_PrivateKey(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_PrivateKey(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
EVP_PKEY *PEM_read_bio_PUBKEY(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PUBKEY(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_PUBKEY(BIO *bp, EVP_PKEY *x); int PEM_write_PUBKEY(FILE *fp, EVP_PKEY *x);
int PEM_write_bio_PKCS8PrivateKey_nid(BIO *bp, EVP_PKEY *x, int nid,
int PEM_write_bio_PKCS8PrivateKey(BIO *, EVP_PKEY *, const EVP_CIPHER *,
                                  char *, int, pem_password_cb *, void *);
int i2d_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_bio(BIO *bp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u);
int i2d_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_fp(FILE *fp, EVP_PKEY *x, int nid,
int PEM_write_PKCS8PrivateKey_nid(FILE *fp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u);
int PEM_write_PKCS8PrivateKey(FILE *fp,EVP_PKEY *x,const EVP_CIPHER *enc,
         char *kstr,int klen, pem_password_cb *cd, void *u);
EVP_PKEY *PEM_read_bio_Parameters(BIO *bp, EVP_PKEY **x);
int PEM_write_bio_Parameters(BIO *bp, EVP_PKEY *x);
EVP_PKEY *b2i_PrivateKey(const unsigned char **in, long length);
EVP_PKEY *b2i_PublicKey(const unsigned char **in, long length);
EVP_PKEY *b2i_PrivateKey_bio(BIO *in);
EVP_PKEY *b2i_PublicKey_bio(BIO *in);
int i2b_PrivateKey_bio(BIO *out, EVP_PKEY *pk);
int i2b_PublicKey_bio(BIO *out, EVP_PKEY *pk);
EVP_PKEY *b2i_PVK_bio(BIO *in, pem_password_cb *cb, void *u);
int i2b_PVK_bio(BIO *out, EVP_PKEY *pk, int enclevel,
void ERR_load_PEM_strings(void);
# 639 "/usr/include/openssl/pem.h" 3 4
# 163 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/hmac.h" 1 3 4
# 61 "/usr/include/openssl/hmac.h" 3 4
extern "C" {
# 62 "/usr/include/openssl/hmac.h" 2 3 4
# 72 "/usr/include/openssl/hmac.h" 3 4
extern "C" {
typedef struct hmac_ctx_st
 const EVP_MD *md;
 EVP_MD_CTX md_ctx;
 EVP_MD_CTX i_ctx;
 EVP_MD_CTX o_ctx;
 unsigned int key_length;
 unsigned char key[128];
 } HMAC_CTX;
void HMAC_CTX_init(HMAC_CTX *ctx);
void HMAC_CTX_cleanup(HMAC_CTX *ctx);
int HMAC_Init(HMAC_CTX *ctx, const void *key, int len,
        const EVP_MD *md);
int HMAC_Init_ex(HMAC_CTX *ctx, const void *key, int len,
    const EVP_MD *md, ENGINE *impl);
int HMAC_Update(HMAC_CTX *ctx, const unsigned char *data, size_t len);
int HMAC_Final(HMAC_CTX *ctx, unsigned char *md, unsigned int *len);
unsigned char *HMAC(const EVP_MD *evp_md, const void *key, int key_len,
      const unsigned char *d, size_t n, unsigned char *md,
      unsigned int *md_len);
int HMAC_CTX_copy(HMAC_CTX *dctx, HMAC_CTX *sctx);
void HMAC_CTX_set_flags(HMAC_CTX *ctx, unsigned long flags);
# 164 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/kssl.h" 1 3 4
# 66 "/usr/include/openssl/kssl.h" 3 4
extern "C" {
# 67 "/usr/include/openssl/kssl.h" 2 3 4
# 1 "/usr/include/ctype.h" 1 3 4
# 28 "/usr/include/ctype.h" 3 4
extern "C" {
# 46 "/usr/include/ctype.h" 3 4
enum
  _ISupper = ((0) < 8 ? ((1 << (0)) << 8) : ((1 << (0)) >> 8)),
  _ISlower = ((1) < 8 ? ((1 << (1)) << 8) : ((1 << (1)) >> 8)),
  _ISalpha = ((2) < 8 ? ((1 << (2)) << 8) : ((1 << (2)) >> 8)),
  _ISdigit = ((3) < 8 ? ((1 << (3)) << 8) : ((1 << (3)) >> 8)),
  _ISxdigit = ((4) < 8 ? ((1 << (4)) << 8) : ((1 << (4)) >> 8)),
  _ISspace = ((5) < 8 ? ((1 << (5)) << 8) : ((1 << (5)) >> 8)),
  _ISprint = ((6) < 8 ? ((1 << (6)) << 8) : ((1 << (6)) >> 8)),
  _ISgraph = ((7) < 8 ? ((1 << (7)) << 8) : ((1 << (7)) >> 8)),
  _ISblank = ((8) < 8 ? ((1 << (8)) << 8) : ((1 << (8)) >> 8)),
  _IScntrl = ((9) < 8 ? ((1 << (9)) << 8) : ((1 << (9)) >> 8)),
  _ISpunct = ((10) < 8 ? ((1 << (10)) << 8) : ((1 << (10)) >> 8)),
  _ISalnum = ((11) < 8 ? ((1 << (11)) << 8) : ((1 << (11)) >> 8))
# 79 "/usr/include/ctype.h" 3 4
extern const unsigned short int **__ctype_b_loc (void)
     throw () __attribute__ ((__const__));
extern const __int32_t **__ctype_tolower_loc (void)
extern const __int32_t **__ctype_toupper_loc (void)
# 104 "/usr/include/ctype.h" 3 4
extern int isalnum (int) throw ();
extern int isalpha (int) throw ();
extern int iscntrl (int) throw ();
extern int isdigit (int) throw ();
extern int islower (int) throw ();
extern int isgraph (int) throw ();
extern int isprint (int) throw ();
extern int ispunct (int) throw ();
extern int isspace (int) throw ();
extern int isupper (int) throw ();
extern int isxdigit (int) throw ();
extern int tolower (int __c) throw ();
extern int toupper (int __c) throw ();
extern int isblank (int) throw ();
extern int isctype (int __c, int __mask) throw ();
extern int isascii (int __c) throw ();
extern int toascii (int __c) throw ();
extern int _toupper (int) throw ();
extern int _tolower (int) throw ();
# 271 "/usr/include/ctype.h" 3 4
extern int isalnum_l (int, __locale_t) throw ();
extern int isalpha_l (int, __locale_t) throw ();
extern int iscntrl_l (int, __locale_t) throw ();
extern int isdigit_l (int, __locale_t) throw ();
extern int islower_l (int, __locale_t) throw ();
extern int isgraph_l (int, __locale_t) throw ();
extern int isprint_l (int, __locale_t) throw ();
extern int ispunct_l (int, __locale_t) throw ();
extern int isspace_l (int, __locale_t) throw ();
extern int isupper_l (int, __locale_t) throw ();
extern int isxdigit_l (int, __locale_t) throw ();
extern int isblank_l (int, __locale_t) throw ();
extern int __tolower_l (int __c, __locale_t __l) throw ();
extern int tolower_l (int __c, __locale_t __l) throw ();
extern int __toupper_l (int __c, __locale_t __l) throw ();
extern int toupper_l (int __c, __locale_t __l) throw ();
# 347 "/usr/include/ctype.h" 3 4
# 72 "/usr/include/openssl/kssl.h" 2 3 4
# 1 "/usr/include/krb5.h" 1 3 4
# 1 "/usr/include/krb5/krb5.h" 1 3 4
# 102 "/usr/include/krb5/krb5.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/syslimits.h" 1 3 4
# 168 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 143 "/usr/include/limits.h" 3 4
# 1 "/usr/include/bits/posix1_lim.h" 1 3 4
# 160 "/usr/include/bits/posix1_lim.h" 3 4
# 1 "/usr/include/bits/local_lim.h" 1 3 4
# 38 "/usr/include/bits/local_lim.h" 3 4
# 1 "/usr/include/linux/limits.h" 1 3 4
# 39 "/usr/include/bits/local_lim.h" 2 3 4
# 161 "/usr/include/bits/posix1_lim.h" 2 3 4
# 144 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/posix2_lim.h" 1 3 4
# 148 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/xopen_lim.h" 1 3 4
# 33 "/usr/include/bits/xopen_lim.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 34 "/usr/include/bits/xopen_lim.h" 2 3 4
# 152 "/usr/include/limits.h" 2 3 4
# 169 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 2 3 4
# 8 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/syslimits.h" 2 3 4
# 35 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 2 3 4
# 103 "/usr/include/krb5/krb5.h" 2 3 4
# 115 "/usr/include/krb5/krb5.h" 3 4
extern "C" {
# 130 "/usr/include/krb5/krb5.h" 3 4
struct _profile_t;
# 141 "/usr/include/krb5/krb5.h" 3 4
typedef unsigned char krb5_octet;
typedef short krb5_int16;
typedef unsigned short krb5_ui_2;
typedef int krb5_int32;
typedef unsigned int krb5_ui_4;
# 198 "/usr/include/krb5/krb5.h" 3 4
typedef unsigned int krb5_boolean;
typedef unsigned int krb5_msgtype;
typedef unsigned int krb5_kvno;
typedef krb5_int32 krb5_addrtype;
typedef krb5_int32 krb5_enctype;
typedef krb5_int32 krb5_cksumtype;
typedef krb5_int32 krb5_authdatatype;
typedef krb5_int32 krb5_keyusage;
typedef krb5_int32 krb5_cryptotype;
typedef krb5_int32 krb5_preauthtype;
typedef krb5_int32 krb5_flags;
typedef krb5_int32 krb5_timestamp;
typedef krb5_int32 krb5_error_code;
typedef krb5_int32 krb5_deltat;
typedef krb5_error_code krb5_magic;
typedef struct _krb5_data {
    krb5_magic magic;
    unsigned int length;
    char *data;
} krb5_data;
typedef struct _krb5_octet_data {
    krb5_magic magic;
    krb5_octet *data;
} krb5_octet_data;
typedef void * krb5_pointer;
typedef void const * krb5_const_pointer;
typedef struct krb5_principal_data {
    krb5_magic magic;
    krb5_data realm;
    krb5_data *data;
    krb5_int32 length;
    krb5_int32 type;
} krb5_principal_data;
typedef krb5_principal_data * krb5_principal;
# 270 "/usr/include/krb5/krb5.h" 3 4
typedef const krb5_principal_data *krb5_const_principal;
# 298 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_is_referral_realm(const krb5_data *r);
# 308 "/usr/include/krb5/krb5.h" 3 4
const krb5_data *
krb5_anonymous_realm(void);
# 318 "/usr/include/krb5/krb5.h" 3 4
krb5_anonymous_principal(void);
# 332 "/usr/include/krb5/krb5.h" 3 4
typedef struct _krb5_address {
    krb5_magic magic;
    krb5_addrtype addrtype;
    krb5_octet *contents;
} krb5_address;
# 359 "/usr/include/krb5/krb5.h" 3 4
struct _krb5_context;
typedef struct _krb5_context * krb5_context;
struct _krb5_auth_context;
typedef struct _krb5_auth_context * krb5_auth_context;
struct _krb5_cryptosystem_entry;
typedef struct _krb5_keyblock {
    krb5_magic magic;
    krb5_enctype enctype;
} krb5_keyblock;
struct krb5_key_st;
# 388 "/usr/include/krb5/krb5.h" 3 4
typedef struct krb5_key_st *krb5_key;
typedef struct _krb5_encrypt_block {
    krb5_magic magic;
    krb5_enctype crypto_entry;
    krb5_keyblock *key;
} krb5_encrypt_block;
typedef struct _krb5_checksum {
    krb5_magic magic;
    krb5_cksumtype checksum_type;
} krb5_checksum;
typedef struct _krb5_enc_data {
    krb5_magic magic;
    krb5_kvno kvno;
    krb5_data ciphertext;
} krb5_enc_data;
# 424 "/usr/include/krb5/krb5.h" 3 4
typedef struct _krb5_crypto_iov {
    krb5_cryptotype flags;
    krb5_data data;
} krb5_crypto_iov;
# 484 "/usr/include/krb5/krb5.h" 3 4
enum {
    KRB5_C_RANDSOURCE_OLDAPI = 0,
    KRB5_C_RANDSOURCE_OSRAND = 1,
    KRB5_C_RANDSOURCE_TRUSTEDPARTY = 2,
    KRB5_C_RANDSOURCE_TIMING = 3,
    KRB5_C_RANDSOURCE_EXTERNAL_PROTOCOL = 4,
    KRB5_C_RANDSOURCE_MAX = 5
# 536 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_encrypt(krb5_context context, const krb5_keyblock *key,
               krb5_keyusage usage, const krb5_data *cipher_state,
               const krb5_data *input, krb5_enc_data *output);
# 565 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_decrypt(krb5_context context, const krb5_keyblock *key,
               const krb5_enc_data *input, krb5_data *output);
# 583 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_encrypt_length(krb5_context context, krb5_enctype enctype,
                      size_t inputlen, size_t *length);
# 596 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_block_size(krb5_context context, krb5_enctype enctype,
                  size_t *blocksize);
# 610 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_keylengths(krb5_context context, krb5_enctype enctype,
                  size_t *keybytes, size_t *keylength);
# 624 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_init_state(krb5_context context, const krb5_keyblock *key,
                  krb5_keyusage usage, krb5_data *new_state);
# 637 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_free_state(krb5_context context, const krb5_keyblock *key,
                  krb5_data *state);
# 656 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_prf(krb5_context context, const krb5_keyblock *keyblock,
           krb5_data *input, krb5_data *output);
# 669 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_prf_length(krb5_context context, krb5_enctype enctype, size_t *len);
# 690 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_fx_cf2_simple(krb5_context context,
                     krb5_keyblock *k1, const char *pepper1,
                     krb5_keyblock *k2, const char *pepper2,
                     krb5_keyblock **out);
# 708 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_make_random_key(krb5_context context, krb5_enctype enctype,
                       krb5_keyblock *k5_random_key);
# 730 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_random_to_key(krb5_context context, krb5_enctype enctype,
                     krb5_data *random_data, krb5_keyblock *k5_random_key);
# 747 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_random_add_entropy(krb5_context context, unsigned int randsource,
                          const krb5_data *data);
# 763 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_random_make_octets(krb5_context context, krb5_data *data);
# 780 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_random_os_entropy(krb5_context context, int strong, int *success);
krb5_error_code
krb5_c_random_seed(krb5_context context, krb5_data *data);
# 802 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_string_to_key(krb5_context context, krb5_enctype enctype,
                     const krb5_data *string, const krb5_data *salt,
                     krb5_keyblock *key);
# 824 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_string_to_key_with_params(krb5_context context,
                                 const krb5_data *params,
# 845 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_enctype_compare(krb5_context context, krb5_enctype e1, krb5_enctype e2,
                       krb5_boolean *similar);
# 874 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_make_checksum(krb5_context context, krb5_cksumtype cksumtype,
                     const krb5_keyblock *key, krb5_keyusage usage,
                     const krb5_data *input, krb5_checksum *cksum);
# 900 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_verify_checksum(krb5_context context, const krb5_keyblock *key,
                       krb5_keyusage usage, const krb5_data *data,
                       const krb5_checksum *cksum, krb5_boolean *valid);
# 914 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_checksum_length(krb5_context context, krb5_cksumtype cksumtype,
                       size_t *length);
# 931 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_keyed_checksum_types(krb5_context context, krb5_enctype enctype,
                            unsigned int *count, krb5_cksumtype **cksumtypes);
# 1003 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_c_valid_enctype(krb5_enctype ktype);
# 1013 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_c_valid_cksumtype(krb5_cksumtype ctype);
# 1024 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_c_is_coll_proof_cksum(krb5_cksumtype ctype);
# 1034 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_c_is_keyed_cksum(krb5_cksumtype ctype);
# 1074 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_make_checksum_iov(krb5_context context, krb5_cksumtype cksumtype,
                         krb5_crypto_iov *data, size_t num_data);
# 1101 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_verify_checksum_iov(krb5_context context, krb5_cksumtype cksumtype,
                           const krb5_crypto_iov *data, size_t num_data,
# 1137 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_encrypt_iov(krb5_context context, const krb5_keyblock *keyblock,
# 1172 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_decrypt_iov(krb5_context context, const krb5_keyblock *keyblock,
# 1187 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_crypto_length(krb5_context context, krb5_enctype enctype,
                     krb5_cryptotype type, unsigned int *size);
# 1206 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_crypto_length_iov(krb5_context context, krb5_enctype enctype,
# 1223 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_c_padding_length(krb5_context context, krb5_enctype enctype,
                      size_t data_length, unsigned int *size);
# 1239 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_create_key(krb5_context context, const krb5_keyblock *key_data,
                  krb5_key *out);
void
krb5_k_reference_key(krb5_context context, krb5_key key);
void
krb5_k_free_key(krb5_context context, krb5_key key);
krb5_error_code
krb5_k_key_keyblock(krb5_context context, krb5_key key,
                    krb5_keyblock **key_data);
krb5_enctype
krb5_k_key_enctype(krb5_context context, krb5_key key);
# 1283 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_encrypt(krb5_context context, krb5_key key, krb5_keyusage usage,
               const krb5_data *cipher_state, const krb5_data *input,
# 1318 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_encrypt_iov(krb5_context context, krb5_key key, krb5_keyusage usage,
                   const krb5_data *cipher_state, krb5_crypto_iov *data,
                   size_t num_data);
# 1347 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_decrypt(krb5_context context, krb5_key key, krb5_keyusage usage,
               const krb5_data *cipher_state, const krb5_enc_data *input,
               krb5_data *output);
# 1382 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_decrypt_iov(krb5_context context, krb5_key key, krb5_keyusage usage,
                   size_t num_data);
# 1411 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_make_checksum(krb5_context context, krb5_cksumtype cksumtype,
                     krb5_key key, krb5_keyusage usage, const krb5_data *input,
# 1437 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_make_checksum_iov(krb5_context context, krb5_cksumtype cksumtype,
# 1463 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_verify_checksum(krb5_context context, krb5_key key, krb5_keyusage usage,
                       const krb5_data *data, const krb5_checksum *cksum,
# 1490 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_verify_checksum_iov(krb5_context context, krb5_cksumtype cksumtype,
# 1514 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_k_prf(krb5_context context, krb5_key key, krb5_data *input, krb5_data *output);
krb5_error_code
krb5_encrypt(krb5_context context, krb5_const_pointer inptr,
             krb5_pointer outptr, size_t size, krb5_encrypt_block *eblock,
             krb5_pointer ivec);
krb5_error_code
krb5_decrypt(krb5_context context, krb5_const_pointer inptr,
             krb5_pointer ivec);
krb5_error_code
krb5_process_key(krb5_context context, krb5_encrypt_block *eblock,
                 const krb5_keyblock * key);
krb5_error_code
krb5_finish_key(krb5_context context, krb5_encrypt_block * eblock);
krb5_error_code
krb5_string_to_key(krb5_context context, const krb5_encrypt_block *eblock,
                   krb5_keyblock * keyblock, const krb5_data *data,
                   const krb5_data *salt);
krb5_error_code
krb5_init_random_key(krb5_context context, const krb5_encrypt_block *eblock,
                     const krb5_keyblock *keyblock, krb5_pointer *ptr);
krb5_error_code
krb5_finish_random_key(krb5_context context, const krb5_encrypt_block *eblock,
                       krb5_pointer *ptr);
krb5_error_code
krb5_random_key(krb5_context context, const krb5_encrypt_block *eblock,
                krb5_pointer ptr, krb5_keyblock **keyblock);
krb5_enctype
krb5_eblock_enctype(krb5_context context, const krb5_encrypt_block *eblock);
krb5_error_code
krb5_use_enctype(krb5_context context, krb5_encrypt_block *eblock,
                 krb5_enctype enctype);
size_t
krb5_encrypt_size(size_t length, krb5_enctype crypto);
size_t
krb5_checksum_size(krb5_context context, krb5_cksumtype ctype);
krb5_error_code
krb5_calculate_checksum(krb5_context context, krb5_cksumtype ctype,
                        krb5_const_pointer in, size_t in_length,
                        krb5_const_pointer seed, size_t seed_length,
                        krb5_checksum * outcksum);
krb5_error_code
krb5_verify_checksum(krb5_context context, krb5_cksumtype ctype,
                     const krb5_checksum * cksum, krb5_const_pointer in,
                     size_t in_length, krb5_const_pointer seed,
                     size_t seed_length);
# 1883 "/usr/include/krb5/krb5.h" 3 4
typedef struct _krb5_ticket_times {
    krb5_timestamp authtime;
    krb5_timestamp starttime;
    krb5_timestamp endtime;
    krb5_timestamp renew_till;
} krb5_ticket_times;
typedef struct _krb5_authdata {
    krb5_magic magic;
    krb5_authdatatype ad_type;
} krb5_authdata;
typedef struct _krb5_transited {
    krb5_magic magic;
    krb5_octet tr_type;
    krb5_data tr_contents;
} krb5_transited;
typedef struct _krb5_enc_tkt_part {
    krb5_magic magic;
    krb5_flags flags;
    krb5_keyblock *session;
    krb5_principal client;
    krb5_transited transited;
    krb5_ticket_times times;
    krb5_address **caddrs;
    krb5_authdata **authorization_data;
} krb5_enc_tkt_part;
typedef struct _krb5_ticket {
    krb5_magic magic;
    krb5_principal server;
    krb5_enc_data enc_part;
    krb5_enc_tkt_part *enc_part2;
} krb5_ticket;
typedef struct _krb5_authenticator {
    krb5_magic magic;
    krb5_checksum *checksum;
    krb5_int32 cusec;
    krb5_timestamp ctime;
    krb5_keyblock *subkey;
    krb5_ui_4 seq_number;
} krb5_authenticator;
typedef struct _krb5_tkt_authent {
    krb5_magic magic;
    krb5_ticket *ticket;
    krb5_authenticator *authenticator;
    krb5_flags ap_options;
} krb5_tkt_authent;
typedef struct _krb5_creds {
    krb5_magic magic;
    krb5_keyblock keyblock;
    krb5_boolean is_skey;
    krb5_flags ticket_flags;
    krb5_address **addresses;
    krb5_data ticket;
    krb5_data second_ticket;
    krb5_authdata **authdata;
} krb5_creds;
typedef struct _krb5_last_req_entry {
    krb5_magic magic;
    krb5_int32 lr_type;
    krb5_timestamp value;
} krb5_last_req_entry;
typedef struct _krb5_pa_data {
    krb5_magic magic;
    krb5_preauthtype pa_type;
} krb5_pa_data;
typedef struct _krb5_typed_data {
    krb5_magic magic;
    krb5_int32 type;
    krb5_octet *data;
} krb5_typed_data;
typedef struct _krb5_kdc_req {
    krb5_magic magic;
    krb5_msgtype msg_type;
    krb5_pa_data **padata;
    krb5_flags kdc_options;
    krb5_timestamp from;
    krb5_timestamp till;
    krb5_timestamp rtime;
    krb5_int32 nonce;
    int nktypes;
    krb5_enctype *ktype;
    krb5_enc_data authorization_data;
    krb5_authdata **unenc_authdata;
    krb5_ticket **second_ticket;
} krb5_kdc_req;
typedef struct _krb5_enc_kdc_rep_part {
    krb5_magic magic;
    krb5_last_req_entry **last_req;
    krb5_int32 nonce;
    krb5_timestamp key_exp;
    krb5_flags flags;
    krb5_pa_data **enc_padata;
} krb5_enc_kdc_rep_part;
typedef struct _krb5_kdc_rep {
    krb5_magic magic;
    krb5_enc_kdc_rep_part *enc_part2;
} krb5_kdc_rep;
typedef struct _krb5_error {
    krb5_magic magic;
    krb5_int32 cusec;
    krb5_int32 susec;
    krb5_timestamp stime;
    krb5_ui_4 error;
    krb5_data text;
    krb5_data e_data;
} krb5_error;
typedef struct _krb5_ap_req {
    krb5_magic magic;
    krb5_enc_data authenticator;
} krb5_ap_req;
typedef struct _krb5_ap_rep {
    krb5_magic magic;
} krb5_ap_rep;
typedef struct _krb5_ap_rep_enc_part {
    krb5_magic magic;
    krb5_int32 cusec;
} krb5_ap_rep_enc_part;
typedef struct _krb5_response {
    krb5_magic magic;
    krb5_octet message_type;
    krb5_data response;
    krb5_int32 expected_nonce;
    krb5_timestamp request_time;
} krb5_response;
typedef struct _krb5_cred_info {
    krb5_magic magic;
    krb5_flags flags;
} krb5_cred_info;
typedef struct _krb5_cred_enc_part {
    krb5_magic magic;
    krb5_int32 nonce;
    krb5_timestamp timestamp;
    krb5_int32 usec;
    krb5_address *s_address;
    krb5_address *r_address;
    krb5_cred_info **ticket_info;
} krb5_cred_enc_part;
typedef struct _krb5_cred {
    krb5_magic magic;
    krb5_ticket **tickets;
    krb5_cred_enc_part *enc_part2;
} krb5_cred;
typedef struct _passwd_phrase_element {
    krb5_magic magic;
    krb5_data *passwd;
    krb5_data *phrase;
} passwd_phrase_element;
typedef struct _krb5_pwd_data {
    krb5_magic magic;
    int sequence_count;
    passwd_phrase_element **element;
} krb5_pwd_data;
typedef struct _krb5_pa_svr_referral_data {
    krb5_principal principal;
} krb5_pa_svr_referral_data;
typedef struct _krb5_pa_server_referral_data {
    krb5_data *referred_realm;
    krb5_principal true_principal_name;
    krb5_principal requested_principal_name;
    krb5_timestamp referral_valid_until;
    krb5_checksum rep_cksum;
} krb5_pa_server_referral_data;
typedef struct _krb5_pa_pac_req {
    krb5_boolean include_pac;
} krb5_pa_pac_req;
# 2193 "/usr/include/krb5/krb5.h" 3 4
typedef struct krb5_replay_data {
    krb5_int32 usec;
    krb5_ui_4 seq;
} krb5_replay_data;
# 2211 "/usr/include/krb5/krb5.h" 3 4
( * krb5_mk_req_checksum_func)(krb5_context, krb5_auth_context,
                                            void *, krb5_data **);
# 2225 "/usr/include/krb5/krb5.h" 3 4
typedef krb5_pointer krb5_cc_cursor;
struct _krb5_ccache;
typedef struct _krb5_ccache *krb5_ccache;
struct _krb5_cc_ops;
typedef struct _krb5_cc_ops krb5_cc_ops;
struct _krb5_cccol_cursor;
typedef struct _krb5_cccol_cursor *krb5_cccol_cursor;
# 2277 "/usr/include/krb5/krb5.h" 3 4
const char *
krb5_cc_get_name(krb5_context context, krb5_ccache cache);
# 2291 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_get_full_name(krb5_context context, krb5_ccache cache,
                      char **fullname_out);
# 2315 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_initialize(krb5_context context, krb5_ccache cache,
                   krb5_principal principal);
# 2333 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_destroy(krb5_context context, krb5_ccache cache);
# 2350 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_close(krb5_context context, krb5_ccache cache);
# 2368 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_store_cred(krb5_context context, krb5_ccache cache, krb5_creds *creds);
# 2404 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_retrieve_cred(krb5_context context, krb5_ccache cache,
                      krb5_flags flags, krb5_creds *mcreds,
                      krb5_creds *creds);
# 2426 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_get_principal(krb5_context context, krb5_ccache cache,
                      krb5_principal *principal);
# 2444 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_start_seq_get(krb5_context context, krb5_ccache cache,
                      krb5_cc_cursor *cursor);
# 2465 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_next_cred(krb5_context context, krb5_ccache cache,
                  krb5_cc_cursor *cursor, krb5_creds *creds);
# 2483 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_end_seq_get(krb5_context context, krb5_ccache cache,
# 2502 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_remove_cred(krb5_context context, krb5_ccache cache, krb5_flags flags,
                    krb5_creds *creds);
# 2517 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_set_flags(krb5_context context, krb5_ccache cache, krb5_flags flags);
# 2531 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_get_flags(krb5_context context, krb5_ccache cache, krb5_flags *flags);
# 2543 "/usr/include/krb5/krb5.h" 3 4
const char *
krb5_cc_get_type(krb5_context context, krb5_ccache cache);
# 2561 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_move(krb5_context context, krb5_ccache src, krb5_ccache dst);
# 2573 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_last_change_time(krb5_context context, krb5_ccache ccache,
                         krb5_timestamp *change_time);
# 2587 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_lock(krb5_context context, krb5_ccache ccache);
# 2600 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_unlock(krb5_context context, krb5_ccache ccache);
# 2619 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cccol_cursor_new(krb5_context context, krb5_cccol_cursor *cursor);
# 2638 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cccol_cursor_next(krb5_context context, krb5_cccol_cursor cursor,
                       krb5_ccache *ccache);
# 2652 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cccol_cursor_free(krb5_context context, krb5_cccol_cursor *cursor);
# 2665 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cccol_have_content(krb5_context context);
# 2682 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cccol_last_change_time(krb5_context context, krb5_timestamp *change_time);
# 2699 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cccol_lock(krb5_context context);
# 2711 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cccol_unlock(krb5_context context);
# 2727 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_new_unique(krb5_context context, const char *type, const char *hint,
                   krb5_ccache *id);
# 2739 "/usr/include/krb5/krb5.h" 3 4
struct krb5_rc_st;
typedef struct krb5_rc_st *krb5_rcache;
# 2754 "/usr/include/krb5/krb5.h" 3 4
typedef krb5_pointer krb5_kt_cursor;
typedef struct krb5_keytab_entry_st {
    krb5_magic magic;
    krb5_kvno vno;
    krb5_keyblock key;
} krb5_keytab_entry;
struct _krb5_kt;
typedef struct _krb5_kt *krb5_keytab;
# 2777 "/usr/include/krb5/krb5.h" 3 4
const char *
krb5_kt_get_type(krb5_context context, krb5_keytab keytab);
# 2800 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_get_name(krb5_context context, krb5_keytab keytab, char *name,
                 unsigned int namelen);
# 2812 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_close(krb5_context context, krb5_keytab keytab);
# 2841 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_get_entry(krb5_context context, krb5_keytab keytab,
                  krb5_const_principal principal, krb5_kvno vno,
                  krb5_enctype enctype, krb5_keytab_entry *entry);
# 2863 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_start_seq_get(krb5_context context, krb5_keytab keytab,
                      krb5_kt_cursor *cursor);
# 2886 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_next_entry(krb5_context context, krb5_keytab keytab,
                   krb5_keytab_entry *entry, krb5_kt_cursor *cursor);
# 2905 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_end_seq_get(krb5_context context, krb5_keytab keytab,
# 2920 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_have_content(krb5_context context, krb5_keytab keytab);
# 2951 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_context(krb5_context *context);
# 2970 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_secure_context(krb5_context *context);
# 2989 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_context_profile(struct _profile_t *profile, krb5_flags flags,
# 3001 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_context(krb5_context context);
# 3018 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_context(krb5_context ctx, krb5_context *nctx_out);
# 3039 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_default_tgs_enctypes(krb5_context context, const krb5_enctype *etypes);
# 3056 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_permitted_enctypes(krb5_context context, krb5_enctype **ktypes);
krb5_boolean
krb5_is_thread_safe(void);
# 3082 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_server_decrypt_ticket_keytab(krb5_context context, const krb5_keytab kt,
                                  krb5_ticket *ticket);
# 3094 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_tgt_creds(krb5_context context, krb5_creds **tgts);
# 3148 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_credentials(krb5_context context, krb5_flags options,
                     krb5_ccache ccache, krb5_creds *in_creds,
                     krb5_creds **out_creds);
krb5_error_code
krb5_get_credentials_validate(krb5_context context, krb5_flags options,
krb5_error_code
krb5_get_credentials_renew(krb5_context context, krb5_flags options,
# 3187 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_req(krb5_context context, krb5_auth_context *auth_context,
            krb5_flags ap_req_options, char *service, char *hostname,
            krb5_data *in_data, krb5_ccache ccache, krb5_data *outbuf);
# 3229 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_req_extended(krb5_context context, krb5_auth_context *auth_context,
                     krb5_flags ap_req_options, krb5_data *in_data,
                     krb5_creds *in_creds, krb5_data *outbuf);
# 3254 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_rep(krb5_context context, krb5_auth_context auth_context, krb5_data *outbuf);
# 3268 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_rep_dce(krb5_context context, krb5_auth_context auth_context, krb5_data *outbuf);
# 3287 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_rd_rep(krb5_context context, krb5_auth_context auth_context,
            const krb5_data *inbuf, krb5_ap_rep_enc_part **repl);
# 3304 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_rd_rep_dce(krb5_context context, krb5_auth_context auth_context,
                const krb5_data *inbuf, krb5_ui_4 *nonce);
# 3320 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_error(krb5_context context, const krb5_error *dec_err,
              krb5_data *enc_err);
# 3337 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_rd_error(krb5_context context, const krb5_data *enc_errbuf,
              krb5_error **dec_error);
# 3377 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_rd_safe(krb5_context context, krb5_auth_context auth_context,
             const krb5_data *inbuf, krb5_data *outbuf,
             krb5_replay_data *outdata);
# 3417 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_rd_priv(krb5_context context, krb5_auth_context auth_context,
# 3454 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_parse_name(krb5_context context, const char *name,
                krb5_principal *principal_out);
# 3495 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_parse_name_flags(krb5_context context, const char *name,
                      int flags, krb5_principal *principal_out);
# 3516 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_unparse_name(krb5_context context, krb5_const_principal principal,
                  register char **name);
# 3543 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_unparse_name_ext(krb5_context context, krb5_const_principal principal,
                      char **name, unsigned int *size);
# 3574 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_unparse_name_flags(krb5_context context, krb5_const_principal principal,
                        int flags, char **name);
# 3594 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_unparse_name_flags_ext(krb5_context context, krb5_const_principal principal,
                            int flags, char **name, unsigned int *size);
# 3613 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_principal_realm(krb5_context context, krb5_principal principal,
                         const char *realm);
# 3631 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_address_search(krb5_context context, const krb5_address *addr,
                    krb5_address *const *addrlist);
# 3645 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_address_compare(krb5_context context, const krb5_address *addr1,
                     const krb5_address *addr2);
# 3663 "/usr/include/krb5/krb5.h" 3 4
int
krb5_address_order(krb5_context context, const krb5_address *addr1,
# 3677 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_realm_compare(krb5_context context, krb5_const_principal princ1,
                   krb5_const_principal princ2);
# 3691 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_principal_compare(krb5_context context,
# 3709 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_principal_compare_any_realm(krb5_context context,
# 3738 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_principal_compare_flags(krb5_context context,
                             krb5_const_principal princ2,
                             int flags);
# 3761 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_keyblock(krb5_context context, krb5_enctype enctype,
                   size_t length, krb5_keyblock **out);
# 3777 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_keyblock(krb5_context context, const krb5_keyblock *from,
                   krb5_keyblock **to);
# 3793 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_keyblock_contents(krb5_context context, const krb5_keyblock *from,
                            krb5_keyblock *to);
# 3809 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_creds(krb5_context context, const krb5_creds *incred, krb5_creds **outcred);
# 3824 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_data(krb5_context context, const krb5_data *indata, krb5_data **outdata);
# 3840 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_principal(krb5_context context, krb5_const_principal inprinc,
                    krb5_principal *outprinc);
# 3856 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_addresses(krb5_context context, krb5_address *const *inaddr,
                    krb5_address ***outaddr);
# 3872 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_ticket(krb5_context context, const krb5_ticket *from, krb5_ticket **pto);
# 3890 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_authdata(krb5_context context,
                   krb5_authdata *const *in_authdat, krb5_authdata ***out);
# 3912 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_find_authdata(krb5_context context, krb5_authdata *const *ticket_authdata,
                   krb5_authdata *const *ap_req_authdata,
                   krb5_authdatatype ad_type, krb5_authdata ***results);
# 3934 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_merge_authdata(krb5_context context,
                    krb5_authdata *const *inauthdat1,
                    krb5_authdata * const *inauthdat2,
                    krb5_authdata ***outauthdat);
# 3953 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_authenticator(krb5_context context, const krb5_authenticator *authfrom,
                        krb5_authenticator **authto);
# 3970 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_copy_checksum(krb5_context context, const krb5_checksum *ckfrom,
                   krb5_checksum **ckto);
# 3988 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_server_rcache(krb5_context context, const krb5_data *piece,
                       krb5_rcache *rcptr);
# 4021 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_build_principal_ext(krb5_context context, krb5_principal * princ,
                         unsigned int rlen, const char * realm, ...);
# 4051 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_build_principal(krb5_context context,
                     unsigned int rlen,
    __attribute__ ((sentinel))
# 4098 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_build_principal_alloc_va(krb5_context context,
                              krb5_principal *princ,
                              unsigned int rlen,
                              const char *realm,
                              va_list ap);
# 4121 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_425_conv_principal(krb5_context context, const char *name,
                        const char *instance, const char *realm,
                        krb5_principal *princ);
# 4147 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_524_conv_principal(krb5_context context, krb5_const_principal princ,
                        char *name, char *inst, char *realm);
struct credentials;
# 4162 "/usr/include/krb5/krb5.h" 3 4
int
krb5_524_convert_creds(krb5_context context, krb5_creds *v5creds,
                       struct credentials *v4creds);
# 4198 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_resolve(krb5_context context, const char *name, krb5_keytab *ktid);
# 4213 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_dup(krb5_context context, krb5_keytab in, krb5_keytab *out);
# 4234 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_default_name(krb5_context context, char *name, int name_size);
# 4251 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_default(krb5_context context, krb5_keytab *id);
# 4269 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_client_default(krb5_context context, krb5_keytab *keytab_out);
# 4282 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_free_keytab_entry_contents(krb5_context context, krb5_keytab_entry *entry);
krb5_error_code
krb5_kt_free_entry(krb5_context context, krb5_keytab_entry *entry);
# 4307 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_remove_entry(krb5_context context, krb5_keytab id, krb5_keytab_entry *entry);
# 4326 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_add_entry(krb5_context context, krb5_keytab id, krb5_keytab_entry *entry);
# 4338 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_principal2salt(krb5_context context,
                    register krb5_const_principal pr, krb5_data *ret);
# 4366 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_resolve(krb5_context context, const char *name, krb5_ccache *cache);
# 4379 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_dup(krb5_context context, krb5_ccache in, krb5_ccache *out);
# 4405 "/usr/include/krb5/krb5.h" 3 4
const char *
krb5_cc_default_name(krb5_context context);
# 4428 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_set_default_name(krb5_context context, const char *name);
# 4450 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_default(krb5_context context, krb5_ccache *ccache);
# 4462 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_copy_creds(krb5_context context, krb5_ccache incc, krb5_ccache outcc);
# 4482 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_get_config(krb5_context context, krb5_ccache id,
                   const char *key, krb5_data *data);
# 4506 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_set_config(krb5_context context, krb5_ccache id,
# 4521 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_is_config_principal(krb5_context context, krb5_const_principal principal);
# 4538 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_switch(krb5_context context, krb5_ccache cache);
# 4552 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_cc_support_switch(krb5_context context, const char *type);
# 4572 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_cache_match(krb5_context context, krb5_principal client,
                    krb5_ccache *cache_out);
# 4610 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cc_select(krb5_context context, krb5_principal server,
               krb5_ccache *cache_out, krb5_principal *princ_out);
# 4621 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_principal(krb5_context context, krb5_principal val);
# 4632 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_authenticator(krb5_context context, krb5_authenticator *val);
# 4645 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_addresses(krb5_context context, krb5_address **val);
# 4658 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_authdata(krb5_context context, krb5_authdata **val);
# 4669 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_ticket(krb5_context context, krb5_ticket *val);
# 4680 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_error(krb5_context context, register krb5_error *val);
# 4691 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_creds(krb5_context context, krb5_creds *val);
# 4702 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_cred_contents(krb5_context context, krb5_creds *val);
# 4713 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_checksum(krb5_context context, register krb5_checksum *val);
# 4724 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_checksum_contents(krb5_context context, register krb5_checksum *val);
# 4735 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_keyblock(krb5_context context, register krb5_keyblock *val);
# 4746 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_keyblock_contents(krb5_context context, register krb5_keyblock *key);
# 4757 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_ap_rep_enc_part(krb5_context context, krb5_ap_rep_enc_part *val);
# 4768 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_data(krb5_context context, krb5_data *val);
void
krb5_free_octet_data(krb5_context context, krb5_octet_data *val);
# 4783 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_data_contents(krb5_context context, krb5_data *val);
void
krb5_free_unparsed_name(krb5_context context, char *val);
# 4803 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_string(krb5_context context, char *val);
# 4814 "/usr/include/krb5/krb5.h" 3 4
void
krb5_free_enctypes(krb5_context context, krb5_enctype *val);
void
krb5_free_cksumtypes(krb5_context context, krb5_cksumtype *val);
# 4844 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_us_timeofday(krb5_context context,
                  krb5_timestamp *seconds, krb5_int32 *microseconds);
# 4862 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_timeofday(krb5_context context, register krb5_timestamp *timeret);
# 4879 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_check_clockskew(krb5_context context, krb5_timestamp date);
# 4893 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_os_localaddr(krb5_context context, krb5_address ***addr);
# 4912 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_default_realm(krb5_context context, char **lrealm);
# 4928 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_default_realm(krb5_context context, const char *lrealm);
void
krb5_free_default_realm(krb5_context context, char *lrealm);
# 4969 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_sname_to_principal(krb5_context context, const char *hostname, const char *sname,
                        krb5_int32 type, krb5_principal *ret_princ);
# 4993 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_sname_match(krb5_context context, krb5_const_principal matching,
                 krb5_const_principal princ);
# 5019 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_change_password(krb5_context context, krb5_creds *creds, char *newpw,
                     int *result_code, krb5_data *result_code_string,
                     krb5_data *result_string);
# 5054 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_password(krb5_context context, krb5_creds *creds, char *newpw,
                  krb5_principal change_password_for, int *result_code,
                  krb5_data *result_code_string, krb5_data *result_string);
# 5089 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_password_using_ccache(krb5_context context, krb5_ccache ccache,
                               char *newpw, krb5_principal change_password_for,
# 5117 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_chpw_message(krb5_context context, const krb5_data *server_string,
                  char **message_out);
# 5138 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_profile(krb5_context context, struct _profile_t ** profile);
# 5224 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_rd_req(krb5_context context, krb5_auth_context *auth_context,
            const krb5_data *inbuf, krb5_const_principal server,
            krb5_keytab keytab, krb5_flags *ap_req_options,
            krb5_ticket **ticket);
# 5252 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_kt_read_service_key(krb5_context context, krb5_pointer keyprocarg,
                         krb5_principal principal, krb5_kvno vno,
                         krb5_enctype enctype, krb5_keyblock **key);
# 5295 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_safe(krb5_context context, krb5_auth_context auth_context,
             const krb5_data *userdata, krb5_data *outbuf,
# 5334 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_priv(krb5_context context, krb5_auth_context auth_context,
# 5388 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_sendauth(krb5_context context, krb5_auth_context *auth_context,
              krb5_pointer fd, char *appl_version, krb5_principal client,
              krb5_principal server, krb5_flags ap_req_options,
              krb5_data *in_data, krb5_creds *in_creds, krb5_ccache ccache,
              krb5_error **error, krb5_ap_rep_enc_part **rep_result,
# 5418 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_recvauth(krb5_context context, krb5_auth_context *auth_context,
              krb5_pointer fd, char *appl_version, krb5_principal server,
              krb5_int32 flags, krb5_keytab keytab, krb5_ticket **ticket);
# 5440 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_recvauth_version(krb5_context context,
                      krb5_pointer fd,
                      krb5_int32 flags,
                      krb5_keytab keytab,
                      krb5_ticket **ticket,
                      krb5_data *version);
# 5477 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_ncred(krb5_context context, krb5_auth_context auth_context,
              krb5_creds **ppcreds, krb5_data **ppdata,
# 5503 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_mk_1cred(krb5_context context, krb5_auth_context auth_context,
              krb5_creds *pcreds, krb5_data **ppdata,
# 5528 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_rd_cred(krb5_context context, krb5_auth_context auth_context,
             krb5_data *pcreddata, krb5_creds ***pppcreds,
# 5562 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_fwd_tgt_creds(krb5_context context, krb5_auth_context auth_context,
                   char *rhost, krb5_principal client, krb5_principal server,
                   krb5_ccache cc, int forwardable, krb5_data *outbuf);
# 5586 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_init(krb5_context context, krb5_auth_context *auth_context);
# 5599 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_free(krb5_context context, krb5_auth_context auth_context);
# 5617 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setflags(krb5_context context, krb5_auth_context auth_context, krb5_int32 flags);
# 5635 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getflags(krb5_context context, krb5_auth_context auth_context,
                       krb5_int32 *flags);
# 5653 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_set_checksum_func( krb5_context context,
                                 krb5_mk_req_checksum_func func,
                                 void *data);
# 5669 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_get_checksum_func( krb5_context context,
                                 krb5_mk_req_checksum_func *func,
                                 void **data);
# 5691 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setaddrs(krb5_context context, krb5_auth_context auth_context,
                       krb5_address *local_addr, krb5_address *remote_addr);
# 5705 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getaddrs(krb5_context context, krb5_auth_context auth_context,
                       krb5_address **local_addr, krb5_address **remote_addr);
# 5725 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setports(krb5_context context, krb5_auth_context auth_context,
                       krb5_address *local_port, krb5_address *remote_port);
# 5738 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setuseruserkey(krb5_context context, krb5_auth_context auth_context,
                             krb5_keyblock *keyblock);
# 5755 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getkey(krb5_context context, krb5_auth_context auth_context,
# 5771 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getkey_k(krb5_context context, krb5_auth_context auth_context,
                       krb5_key *key);
# 5788 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getsendsubkey(krb5_context ctx, krb5_auth_context ac, krb5_keyblock **keyblock);
# 5803 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getsendsubkey_k(krb5_context ctx, krb5_auth_context ac,
                              krb5_key *key);
# 5820 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getrecvsubkey(krb5_context ctx, krb5_auth_context ac, krb5_keyblock **keyblock);
# 5835 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getrecvsubkey_k(krb5_context ctx, krb5_auth_context ac, krb5_key *key);
# 5849 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setsendsubkey(krb5_context ctx, krb5_auth_context ac,
# 5867 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setsendsubkey_k(krb5_context ctx, krb5_auth_context ac, krb5_key key);
# 5881 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setrecvsubkey(krb5_context ctx, krb5_auth_context ac,
# 5899 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setrecvsubkey_k(krb5_context ctx, krb5_auth_context ac,
                              krb5_key key);
# 5928 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getlocalseqnumber(krb5_context context, krb5_auth_context auth_context,
                                krb5_int32 *seqnumber);
# 5945 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getremoteseqnumber(krb5_context context, krb5_auth_context auth_context,
# 5972 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_setrcache(krb5_context context, krb5_auth_context auth_context,
                        krb5_rcache rcache);
# 5988 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getrcache(krb5_context context, krb5_auth_context auth_context,
                        krb5_rcache *rcache);
# 6004 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_getauthenticator(krb5_context context, krb5_auth_context auth_context,
                               krb5_authenticator **authenticator);
# 6020 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_set_req_cksumtype(krb5_context context, krb5_auth_context auth_context,
                                krb5_cksumtype cksumtype);
# 6065 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_read_password(krb5_context context,
                   const char *prompt, const char *prompt2,
                   char *return_pwd, unsigned int *size_return);
# 6093 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_aname_to_localname(krb5_context context, krb5_const_principal aname,
                        int lnsize_in, char *lname);
# 6120 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_host_realm(krb5_context context, const char *host, char ***realmsp);
# 6138 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_fallback_host_realm(krb5_context context,
                             krb5_data *hdata, char ***realmsp);
# 6153 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_free_host_realm(krb5_context context, char *const *realmlist);
# 6169 "/usr/include/krb5/krb5.h" 3 4
krb5_boolean
krb5_kuserok(krb5_context context, krb5_principal principal, const char *luser);
# 6191 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_auth_con_genaddrs(krb5_context context, krb5_auth_context auth_context,
                       int infd, int flags);
# 6208 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_real_time(krb5_context context, krb5_timestamp seconds,
                   krb5_int32 microseconds);
# 6223 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_time_offsets(krb5_context context, krb5_timestamp *seconds, krb5_int32 *microseconds);
# 6235 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_string_to_enctype(char *string, krb5_enctype *enctypep);
# 6246 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_string_to_salttype(char *string, krb5_int32 *salttypep);
# 6257 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_string_to_cksumtype(char *string, krb5_cksumtype *cksumtypep);
# 6268 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_string_to_timestamp(char *string, krb5_timestamp *timestampp);
# 6279 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_string_to_deltat(char *string, krb5_deltat *deltatp);
# 6291 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_enctype_to_string(krb5_enctype enctype, char *buffer, size_t buflen);
# 6310 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_enctype_to_name(krb5_enctype enctype, krb5_boolean shortest,
# 6323 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_salttype_to_string(krb5_int32 salttype, char *buffer, size_t buflen);
# 6335 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_cksumtype_to_string(krb5_cksumtype cksumtype, char *buffer, size_t buflen);
# 6350 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_timestamp_to_string(krb5_timestamp timestamp, char *buffer, size_t buflen);
# 6367 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_timestamp_to_sfstring(krb5_timestamp timestamp, char *buffer,
                           size_t buflen, char *pad);
# 6380 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_deltat_to_string(krb5_deltat deltat, char *buffer, size_t buflen);
# 6393 "/usr/include/krb5/krb5.h" 3 4
typedef struct _krb5_prompt {
    char *prompt;
    int hidden;
    krb5_data *reply;
} krb5_prompt;
( *krb5_prompter_fct)(krb5_context context, void *data,
                                   const char *name, const char *banner,
                                   int num_prompts, krb5_prompt prompts[]);
# 6430 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_prompter_posix(krb5_context context, void *data, const char *name,
                    const char *banner, int num_prompts,
# 6572 "/usr/include/krb5/krb5.h" 3 4
typedef struct krb5_responder_context_st *krb5_responder_context;
# 6588 "/usr/include/krb5/krb5.h" 3 4
const char * const *
krb5_responder_list_questions(krb5_context ctx, krb5_responder_context rctx);
# 6607 "/usr/include/krb5/krb5.h" 3 4
const char *
krb5_responder_get_challenge(krb5_context ctx, krb5_responder_context rctx,
                             const char *question);
# 6626 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_responder_set_answer(krb5_context ctx, krb5_responder_context rctx,
                          const char *question, const char *answer);
# 6650 "/usr/include/krb5/krb5.h" 3 4
( *krb5_responder_fn)(krb5_context ctx, void *data,
typedef struct _krb5_responder_otp_tokeninfo {
    krb5_flags flags;
    krb5_int32 format;
    krb5_int32 length;
    char *vendor;
    char *challenge;
    char *token_id;
    char *alg_id;
} krb5_responder_otp_tokeninfo;
typedef struct _krb5_responder_otp_challenge {
    char *service;
    krb5_responder_otp_tokeninfo **tokeninfo;
} krb5_responder_otp_challenge;
# 6686 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_responder_otp_get_challenge(krb5_context ctx,
                                 krb5_responder_otp_challenge **chl);
# 6702 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_responder_otp_set_answer(krb5_context ctx, krb5_responder_context rctx,
                              size_t ti, const char *value, const char *pin);
# 6715 "/usr/include/krb5/krb5.h" 3 4
void
krb5_responder_otp_challenge_free(krb5_context ctx,
                                  krb5_responder_otp_challenge *chl);
typedef struct _krb5_responder_pkinit_identity {
    char *identity;
    krb5_int32 token_flags;
} krb5_responder_pkinit_identity;
typedef struct _krb5_responder_pkinit_challenge {
    krb5_responder_pkinit_identity **identities;
} krb5_responder_pkinit_challenge;
# 6746 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_responder_pkinit_get_challenge(krb5_context ctx,
                                    krb5_responder_pkinit_challenge **chl_out);
# 6761 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_responder_pkinit_set_answer(krb5_context ctx, krb5_responder_context rctx,
                                 const char *identity, const char *pin);
# 6774 "/usr/include/krb5/krb5.h" 3 4
void
krb5_responder_pkinit_challenge_free(krb5_context ctx,
                                     krb5_responder_pkinit_challenge *chl);
typedef struct _krb5_get_init_creds_opt {
    krb5_flags flags;
    krb5_deltat tkt_life;
    krb5_deltat renew_life;
    int forwardable;
    int proxiable;
    krb5_enctype *etype_list;
    int etype_list_length;
    krb5_address **address_list;
    krb5_preauthtype *preauth_list;
    int preauth_list_length;
    krb5_data *salt;
} krb5_get_init_creds_opt;
# 6820 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_alloc(krb5_context context,
                              krb5_get_init_creds_opt **opt);
# 6832 "/usr/include/krb5/krb5.h" 3 4
void
krb5_get_init_creds_opt_free(krb5_context context,
                             krb5_get_init_creds_opt *opt);
void
krb5_get_init_creds_opt_init(krb5_get_init_creds_opt *opt);
void
krb5_get_init_creds_opt_set_tkt_life(krb5_get_init_creds_opt *opt,
                                     krb5_deltat tkt_life);
void
krb5_get_init_creds_opt_set_renew_life(krb5_get_init_creds_opt *opt,
                                       krb5_deltat renew_life);
void
krb5_get_init_creds_opt_set_forwardable(krb5_get_init_creds_opt *opt,
                                        int forwardable);
void
krb5_get_init_creds_opt_set_proxiable(krb5_get_init_creds_opt *opt,
                                      int proxiable);
void
krb5_get_init_creds_opt_set_canonicalize(krb5_get_init_creds_opt *opt,
                                         int canonicalize);
# 6901 "/usr/include/krb5/krb5.h" 3 4
void
krb5_get_init_creds_opt_set_anonymous(krb5_get_init_creds_opt *opt,
                                      int anonymous);
# 6912 "/usr/include/krb5/krb5.h" 3 4
void
krb5_get_init_creds_opt_set_etype_list(krb5_get_init_creds_opt *opt,
                                       krb5_enctype *etype_list,
                                       int etype_list_length);
void
krb5_get_init_creds_opt_set_address_list(krb5_get_init_creds_opt *opt,
                                         krb5_address **addresses);
# 6938 "/usr/include/krb5/krb5.h" 3 4
void
krb5_get_init_creds_opt_set_preauth_list(krb5_get_init_creds_opt *opt,
                                         krb5_preauthtype *preauth_list,
                                         int preauth_list_length);
# 6954 "/usr/include/krb5/krb5.h" 3 4
void
krb5_get_init_creds_opt_set_salt(krb5_get_init_creds_opt *opt,
                                 krb5_data *salt);
# 6968 "/usr/include/krb5/krb5.h" 3 4
void
krb5_get_init_creds_opt_set_change_password_prompt(krb5_get_init_creds_opt *opt,
                                                   int prompt);
typedef struct _krb5_gic_opt_pa_data {
    char *attr;
    char *value;
} krb5_gic_opt_pa_data;
# 6990 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_pa(krb5_context context,
                               krb5_get_init_creds_opt *opt, const char *attr,
                               const char *value);
# 7010 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_fast_ccache_name(krb5_context context,
                                             const char *fast_ccache_name);
# 7027 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_fast_ccache(krb5_context context,
# 7048 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_in_ccache(krb5_context context,
# 7066 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_out_ccache(krb5_context context,
# 7084 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_fast_flags(krb5_context context,
                                       krb5_flags flags);
# 7099 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_get_fast_flags(krb5_context context,
                                       krb5_flags *out_flags);
typedef void
( *krb5_expire_callback_func)(krb5_context context, void *data,
                                           krb5_timestamp password_expiration,
                                           krb5_timestamp account_expiration,
                                           krb5_boolean is_last_req);
# 7152 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_expire_callback(krb5_context context,
                                            krb5_expire_callback_func cb,
                                            void *data);
# 7168 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_opt_set_responder(krb5_context context,
                                      krb5_responder_fn responder, void *data);
# 7217 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_password(krb5_context context, krb5_creds *creds,
                             krb5_principal client, const char *password,
                             krb5_prompter_fct prompter, void *data,
                             krb5_deltat start_time,
                             const char *in_tkt_service,
                             krb5_get_init_creds_opt *k5_gic_options);
struct _krb5_init_creds_context;
typedef struct _krb5_init_creds_context *krb5_init_creds_context;
# 7236 "/usr/include/krb5/krb5.h" 3 4
void
krb5_init_creds_free(krb5_context context, krb5_init_creds_context ctx);
# 7251 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_get(krb5_context context, krb5_init_creds_context ctx);
# 7268 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_get_creds(krb5_context context, krb5_init_creds_context ctx,
                          krb5_creds *creds);
# 7281 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_get_error(krb5_context context, krb5_init_creds_context ctx,
                          krb5_error **error);
# 7301 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_init(krb5_context context, krb5_principal client,
                     krb5_deltat start_time, krb5_get_init_creds_opt *options,
                     krb5_init_creds_context *ctx);
# 7319 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_set_keytab(krb5_context context, krb5_init_creds_context ctx,
# 7350 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_step(krb5_context context, krb5_init_creds_context ctx,
                     krb5_data *in, krb5_data *out, krb5_data *realm,
                     unsigned int *flags);
# 7367 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_set_password(krb5_context context, krb5_init_creds_context ctx,
                             const char *password);
# 7384 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_set_service(krb5_context context, krb5_init_creds_context ctx,
                            const char *service);
# 7400 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_init_creds_get_times(krb5_context context, krb5_init_creds_context ctx,
                          krb5_ticket_times *times);
struct _krb5_tkt_creds_context;
typedef struct _krb5_tkt_creds_context *krb5_tkt_creds_context;
# 7431 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_tkt_creds_init(krb5_context context, krb5_ccache ccache,
                    krb5_creds *creds, krb5_flags options,
                    krb5_tkt_creds_context *ctx);
# 7450 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_tkt_creds_get(krb5_context context, krb5_tkt_creds_context ctx);
# 7469 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_tkt_creds_get_creds(krb5_context context, krb5_tkt_creds_context ctx,
                         krb5_creds *creds);
# 7481 "/usr/include/krb5/krb5.h" 3 4
void
krb5_tkt_creds_free(krb5_context context, krb5_tkt_creds_context ctx);
# 7514 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_tkt_creds_step(krb5_context context, krb5_tkt_creds_context ctx,
# 7533 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_tkt_creds_get_times(krb5_context context, krb5_tkt_creds_context ctx,
# 7561 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_init_creds_keytab(krb5_context context, krb5_creds *creds,
                           krb5_principal client, krb5_keytab arg_keytab,
                           krb5_deltat start_time, const char *in_tkt_service,
typedef struct _krb5_verify_init_creds_opt {
    krb5_flags flags;
    int ap_req_nofail;
} krb5_verify_init_creds_opt;
# 7579 "/usr/include/krb5/krb5.h" 3 4
void
krb5_verify_init_creds_opt_init(krb5_verify_init_creds_opt *k5_vic_options);
# 7597 "/usr/include/krb5/krb5.h" 3 4
void
krb5_verify_init_creds_opt_set_ap_req_nofail(krb5_verify_init_creds_opt * k5_vic_options,
                                             int ap_req_nofail);
# 7632 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_verify_init_creds(krb5_context context, krb5_creds *creds,
                       krb5_principal server, krb5_keytab keytab,
                       krb5_ccache *ccache,
                       krb5_verify_init_creds_opt *options);
# 7671 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_validated_creds(krb5_context context, krb5_creds *creds,
                         krb5_principal client, krb5_ccache ccache,
                         const char *in_tkt_service);
# 7697 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_get_renewed_creds(krb5_context context, krb5_creds *creds,
# 7710 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_decode_ticket(const krb5_data *code, krb5_ticket **rep);
# 7728 "/usr/include/krb5/krb5.h" 3 4
void
krb5_appdefault_string(krb5_context context, const char *appname,
                       const krb5_data *realm, const char *option,
                       const char *default_value, char ** ret_value);
# 7748 "/usr/include/krb5/krb5.h" 3 4
void
krb5_appdefault_boolean(krb5_context context, const char *appname,
                        int default_value, int *ret_value);
# 7765 "/usr/include/krb5/krb5.h" 3 4
typedef krb5_int32 krb5_prompt_type;
# 7780 "/usr/include/krb5/krb5.h" 3 4
krb5_prompt_type*
krb5_get_prompt_types(krb5_context context);
# 7792 "/usr/include/krb5/krb5.h" 3 4
void
krb5_set_error_message(krb5_context ctx, krb5_error_code code, const char *fmt, ...)
# 7807 "/usr/include/krb5/krb5.h" 3 4
void
krb5_vset_error_message(krb5_context ctx, krb5_error_code code,
                        const char *fmt, va_list args)
void
krb5_copy_error_message(krb5_context dest_ctx, krb5_context src_ctx);
# 7844 "/usr/include/krb5/krb5.h" 3 4
const char *
krb5_get_error_message(krb5_context ctx, krb5_error_code code);
void
krb5_free_error_message(krb5_context ctx, const char *msg);
# 7864 "/usr/include/krb5/krb5.h" 3 4
void
krb5_clear_error_message(krb5_context ctx);
# 7879 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_decode_authdata_container(krb5_context context,
                               krb5_authdatatype type,
                               const krb5_authdata *container,
                               krb5_authdata ***authdata);
# 7898 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_encode_authdata_container(krb5_context context,
                               krb5_authdata * const*authdata,
                               krb5_authdata ***container);
# 7920 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_make_authdata_kdc_issued(krb5_context context,
                              krb5_const_principal issuer,
                              krb5_authdata *const *authdata,
                              krb5_authdata ***ad_kdcissued);
# 7941 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_verify_authdata_kdc_issued(krb5_context context,
                                const krb5_authdata *ad_kdcissued,
                                krb5_principal *issuer,
# 7961 "/usr/include/krb5/krb5.h" 3 4
struct krb5_pac_data;
typedef struct krb5_pac_data *krb5_pac;
# 7987 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_pac_add_buffer(krb5_context context, krb5_pac pac, krb5_ui_4 type,
# 7999 "/usr/include/krb5/krb5.h" 3 4
void
krb5_pac_free(krb5_context context, krb5_pac pac);
# 8014 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_pac_get_buffer(krb5_context context, krb5_pac pac, krb5_ui_4 type,
                    krb5_data *data);
# 8028 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_pac_get_types(krb5_context context, krb5_pac pac, size_t *len,
                   krb5_ui_4 **types);
# 8042 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_pac_init(krb5_context context, krb5_pac *pac);
# 8057 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_pac_parse(krb5_context context, const void *ptr, size_t len,
               krb5_pac *pac);
# 8087 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_pac_verify(krb5_context context, const krb5_pac pac,
                krb5_timestamp authtime, krb5_const_principal principal,
                const krb5_keyblock *server, const krb5_keyblock *privsvr);
# 8110 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_pac_sign(krb5_context context, krb5_pac pac, krb5_timestamp authtime,
              krb5_const_principal principal, const krb5_keyblock *server_key,
              const krb5_keyblock *privsvr_key, krb5_data *data);
# 8126 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_allow_weak_crypto(krb5_context context, krb5_boolean enable);
# 8136 "/usr/include/krb5/krb5.h" 3 4
typedef struct _krb5_trace_info {
    const char *message;
} krb5_trace_info;
typedef void
( *krb5_trace_callback)(krb5_context context,
                                     const krb5_trace_info *info,
                                     void *cb_data);
# 8168 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_trace_callback(krb5_context context, krb5_trace_callback fn,
                        void *cb_data);
# 8188 "/usr/include/krb5/krb5.h" 3 4
krb5_error_code
krb5_set_trace_filename(krb5_context context, const char *filename);
# 8211 "/usr/include/krb5/krb5.h" 3 4
# 1 "/usr/include/et/com_err.h" 1 3 4
# 19 "/usr/include/et/com_err.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 20 "/usr/include/et/com_err.h" 2 3 4
typedef long errcode_t;
struct error_table {
 char const * const * msgs;
 long base;
 int n_msgs;
struct et_list;
extern void com_err (const char *, long, const char *, ...)
 __attribute__((format(printf, 3, 4)));
extern void com_err_va (const char *whoami, errcode_t code, const char *fmt,
   va_list args)
 __attribute__((format(printf, 3, 0)));
extern char const *error_message (long);
extern void (*com_err_hook) (const char *, long, const char *, va_list);
extern void (*set_com_err_hook (void (*) (const char *, long,
       const char *, va_list)))
extern void (*reset_com_err_hook (void)) (const char *, long,
extern int init_error_table(const char * const *msgs, long base, int count);
extern char *(*set_com_err_gettext (char *(*) (const char *)))
 (const char *);
extern errcode_t add_error_table(const struct error_table * et);
extern errcode_t remove_error_table(const struct error_table * et);
extern void add_to_error_table(struct et_list *new_table);
extern const char *com_right(struct et_list *list, long code);
extern const char *com_right_r(struct et_list *list, long code, char *str, size_t len);
extern void initialize_error_table_r(struct et_list **list,
         const char **messages,
         int num_errors,
         long base);
extern void free_error_table(struct et_list *et);
extern int et_list_lock(void);
extern int et_list_unlock(void);
# 8212 "/usr/include/krb5/krb5.h" 2 3 4
# 8469 "/usr/include/krb5/krb5.h" 3 4
extern const struct error_table et_krb5_error_table;
extern void initialize_krb5_error_table(void);
extern void initialize_krb5_error_table_r(struct et_list **list);
# 8485 "/usr/include/krb5/krb5.h" 3 4
# 8486 "/usr/include/krb5/krb5.h" 2 3 4
# 8495 "/usr/include/krb5/krb5.h" 3 4
extern const struct error_table et_k5e1_error_table;
extern void initialize_k5e1_error_table(void);
extern void initialize_k5e1_error_table_r(struct et_list **list);
# 8511 "/usr/include/krb5/krb5.h" 3 4
# 8512 "/usr/include/krb5/krb5.h" 2 3 4
# 8559 "/usr/include/krb5/krb5.h" 3 4
extern const struct error_table et_kdb5_error_table;
extern void initialize_kdb5_error_table(void);
extern void initialize_kdb5_error_table_r(struct et_list **list);
# 8575 "/usr/include/krb5/krb5.h" 3 4
# 8576 "/usr/include/krb5/krb5.h" 2 3 4
# 8638 "/usr/include/krb5/krb5.h" 3 4
extern const struct error_table et_kv5m_error_table;
extern void initialize_kv5m_error_table(void);
extern void initialize_kv5m_error_table_r(struct et_list **list);
# 8654 "/usr/include/krb5/krb5.h" 3 4
# 8655 "/usr/include/krb5/krb5.h" 2 3 4
# 8665 "/usr/include/krb5/krb5.h" 3 4
extern const struct error_table et_k524_error_table;
extern void initialize_k524_error_table(void);
extern void initialize_k524_error_table_r(struct et_list **list);
# 8681 "/usr/include/krb5/krb5.h" 3 4
# 8682 "/usr/include/krb5/krb5.h" 2 3 4
# 8697 "/usr/include/krb5/krb5.h" 3 4
extern const struct error_table et_asn1_error_table;
extern void initialize_asn1_error_table(void);
extern void initialize_asn1_error_table_r(struct et_list **list);
# 8 "/usr/include/krb5.h" 2 3 4
# 73 "/usr/include/openssl/kssl.h" 2 3 4
# 84 "/usr/include/openssl/kssl.h" 3 4
extern "C" {
# 129 "/usr/include/openssl/kssl.h" 3 4
typedef struct kssl_err_st {
 int reason;
 char text[255 +1];
 } KSSL_ERR;
typedef struct kssl_ctx_st
 char *service_name;
 char *service_host;
 char *client_princ;
 char *keytab_file;
 char *cred_cache;
 krb5_enctype enctype;
 int length;
 krb5_octet *key;
 } KSSL_CTX;
# 162 "/usr/include/openssl/kssl.h" 3 4
krb5_error_code kssl_ctx_setstring(KSSL_CTX *kssl_ctx, int which, char *text);
KSSL_CTX *kssl_ctx_new(void);
KSSL_CTX *kssl_ctx_free(KSSL_CTX *kssl_ctx);
void kssl_ctx_show(KSSL_CTX *kssl_ctx);
krb5_error_code kssl_ctx_setprinc(KSSL_CTX *kssl_ctx, int which,
        krb5_data *realm, krb5_data *entity, int nentities);
krb5_error_code kssl_cget_tkt(KSSL_CTX *kssl_ctx, krb5_data **enc_tktp,
        krb5_data *authenp, KSSL_ERR *kssl_err);
krb5_error_code kssl_sget_tkt(KSSL_CTX *kssl_ctx, krb5_data *indata,
        krb5_ticket_times *ttimes, KSSL_ERR *kssl_err);
krb5_error_code kssl_ctx_setkey(KSSL_CTX *kssl_ctx, krb5_keyblock *session);
void kssl_err_set(KSSL_ERR *kssl_err, int reason, char *text);
void kssl_krb5_free_data_contents(krb5_context context, krb5_data *data);
krb5_error_code kssl_build_principal_2(krb5_context context,
   krb5_principal *princ, int rlen, const char *realm,
   int slen, const char *svc, int hlen, const char *host);
krb5_error_code kssl_validate_times(krb5_timestamp atime,
     krb5_ticket_times *ttimes);
krb5_error_code kssl_check_authent(KSSL_CTX *kssl_ctx, krb5_data *authentp,
               krb5_timestamp *atimep, KSSL_ERR *kssl_err);
unsigned char *kssl_skip_confound(krb5_enctype enctype, unsigned char *authn);
void SSL_set0_kssl_ctx(SSL *s, KSSL_CTX *kctx);
KSSL_CTX * SSL_get0_kssl_ctx(SSL *s);
char *kssl_ctx_get0_client_princ(KSSL_CTX *kctx);
# 166 "/usr/include/openssl/ssl.h" 2 3 4
extern "C" {
# 353 "/usr/include/openssl/ssl.h" 3 4
extern "C" {
# 370 "/usr/include/openssl/ssl.h" 3 4
typedef struct ssl_st *ssl_crock_st;
typedef struct tls_session_ticket_ext_st TLS_SESSION_TICKET_EXT;
typedef struct ssl_method_st SSL_METHOD;
typedef struct ssl_cipher_st SSL_CIPHER;
typedef struct ssl_session_st SSL_SESSION;
struct stack_st_SSL_CIPHER { _STACK stack; };
typedef struct srtp_protection_profile_st
       const char *name;
       unsigned long id;
       } SRTP_PROTECTION_PROFILE;
struct stack_st_SRTP_PROTECTION_PROFILE { _STACK stack; };
typedef int (*tls_session_ticket_ext_cb_fn)(SSL *s, const unsigned char *data, int len, void *arg);
typedef int (*tls_session_secret_cb_fn)(SSL *s, void *secret, int *secret_len, struct stack_st_SSL_CIPHER *peer_ciphers, SSL_CIPHER **cipher, void *arg);
 int valid;
 const char *name;
 unsigned long id;
 unsigned long algorithm_mkey;
 unsigned long algorithm_auth;
 unsigned long algorithm_enc;
 unsigned long algorithm_mac;
 unsigned long algorithm_ssl;
 unsigned long algo_strength;
 unsigned long algorithm2;
 int strength_bits;
 int alg_bits;
 int version;
 int (*ssl_new)(SSL *s);
 void (*ssl_clear)(SSL *s);
 void (*ssl_free)(SSL *s);
 int (*ssl_accept)(SSL *s);
 int (*ssl_connect)(SSL *s);
 int (*ssl_read)(SSL *s,void *buf,int len);
 int (*ssl_peek)(SSL *s,void *buf,int len);
 int (*ssl_write)(SSL *s,const void *buf,int len);
 int (*ssl_shutdown)(SSL *s);
 int (*ssl_renegotiate)(SSL *s);
 int (*ssl_renegotiate_check)(SSL *s);
 long (*ssl_get_message)(SSL *s, int st1, int stn, int mt, long
  max, int *ok);
 int (*ssl_read_bytes)(SSL *s, int type, unsigned char *buf, int len,
  int peek);
 int (*ssl_write_bytes)(SSL *s, int type, const void *buf_, int len);
 int (*ssl_dispatch_alert)(SSL *s);
 long (*ssl_ctrl)(SSL *s,int cmd,long larg,void *parg);
 long (*ssl_ctx_ctrl)(SSL_CTX *ctx,int cmd,long larg,void *parg);
 const SSL_CIPHER *(*get_cipher_by_char)(const unsigned char *ptr);
 int (*put_cipher_by_char)(const SSL_CIPHER *cipher,unsigned char *ptr);
 int (*ssl_pending)(const SSL *s);
 int (*num_ciphers)(void);
 const SSL_CIPHER *(*get_cipher)(unsigned ncipher);
 const struct ssl_method_st *(*get_ssl_method)(int version);
 long (*get_timeout)(void);
 struct ssl3_enc_method *ssl3_enc;
 int (*ssl_version)(void);
 long (*ssl_callback_ctrl)(SSL *s, int cb_id, void (*fp)(void));
 long (*ssl_ctx_callback_ctrl)(SSL_CTX *s, int cb_id, void (*fp)(void));
# 475 "/usr/include/openssl/ssl.h" 3 4
 int ssl_version;
 unsigned int key_arg_length;
 unsigned char key_arg[8];
 int master_key_length;
 unsigned char master_key[48];
 unsigned int session_id_length;
 unsigned char session_id[32];
 unsigned int sid_ctx_length;
 unsigned char sid_ctx[32];
        unsigned int krb5_client_princ_len;
        unsigned char krb5_client_princ[256];
 char *psk_identity_hint;
 char *psk_identity;
 int not_resumable;
 struct sess_cert_st *sess_cert;
 X509 *peer;
 long verify_result;
 int references;
 long timeout;
 long time;
 unsigned int compress_meth;
 const SSL_CIPHER *cipher;
 unsigned long cipher_id;
 struct stack_st_SSL_CIPHER *ciphers;
 CRYPTO_EX_DATA ex_data;
 struct ssl_session_st *prev,*next;
 char *tlsext_hostname;
 size_t tlsext_ecpointformatlist_length;
 unsigned char *tlsext_ecpointformatlist;
 size_t tlsext_ellipticcurvelist_length;
 unsigned char *tlsext_ellipticcurvelist;
 unsigned char *tlsext_tick;
 size_t tlsext_ticklen;
 long tlsext_tick_lifetime_hint;
# 710 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_set_msg_callback(SSL_CTX *ctx, void (*cb)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg));
void SSL_set_msg_callback(SSL *ssl, void (*cb)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg));
# 737 "/usr/include/openssl/ssl.h" 3 4
typedef int (*GEN_SESSION_CB)(const SSL *ssl, unsigned char *id,
    unsigned int *id_len);
typedef struct ssl_comp_st SSL_COMP;
struct ssl_comp_st
 int id;
 const char *name;
 COMP_METHOD *method;
struct stack_st_SSL_COMP { _STACK stack; };
struct lhash_st_SSL_SESSION { int dummy; };
struct ssl_ctx_st
 const SSL_METHOD *method;
 struct stack_st_SSL_CIPHER *cipher_list;
 struct stack_st_SSL_CIPHER *cipher_list_by_id;
 struct x509_store_st *cert_store;
 struct lhash_st_SSL_SESSION *sessions;
 unsigned long session_cache_size;
 struct ssl_session_st *session_cache_head;
 struct ssl_session_st *session_cache_tail;
 int session_cache_mode;
 long session_timeout;
# 794 "/usr/include/openssl/ssl.h" 3 4
 int (*new_session_cb)(struct ssl_st *ssl,SSL_SESSION *sess);
 void (*remove_session_cb)(struct ssl_ctx_st *ctx,SSL_SESSION *sess);
 SSL_SESSION *(*get_session_cb)(struct ssl_st *ssl,
  unsigned char *data,int len,int *copy);
 struct
  int sess_connect;
  int sess_connect_renegotiate;
  int sess_connect_good;
  int sess_accept;
  int sess_accept_renegotiate;
  int sess_accept_good;
  int sess_miss;
  int sess_timeout;
  int sess_cache_full;
  int sess_hit;
  int sess_cb_hit;
  } stats;
 int references;
 int (*app_verify_callback)(X509_STORE_CTX *, void *);
 void *app_verify_arg;
 pem_password_cb *default_passwd_callback;
 void *default_passwd_callback_userdata;
 int (*client_cert_cb)(SSL *ssl, X509 **x509, EVP_PKEY **pkey);
    int (*app_gen_cookie_cb)(SSL *ssl, unsigned char *cookie,
        unsigned int *cookie_len);
    int (*app_verify_cookie_cb)(SSL *ssl, unsigned char *cookie,
        unsigned int cookie_len);
 const EVP_MD *rsa_md5;
 const EVP_MD *md5;
 const EVP_MD *sha1;
 struct stack_st_X509 *extra_certs;
 struct stack_st_SSL_COMP *comp_methods;
 void (*info_callback)(const SSL *ssl,int type,int val);
 struct stack_st_X509_NAME *client_CA;
 unsigned long options;
 unsigned long mode;
 long max_cert_list;
 struct cert_st *cert;
 int read_ahead;
 void (*msg_callback)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg);
 void *msg_callback_arg;
 int verify_mode;
 int (*default_verify_callback)(int ok,X509_STORE_CTX *ctx);
 GEN_SESSION_CB generate_session_id;
 X509_VERIFY_PARAM *param;
 int quiet_shutdown;
 unsigned int max_send_fragment;
 ENGINE *client_cert_engine;
 int (*tlsext_servername_callback)(SSL*, int *, void *);
 void *tlsext_servername_arg;
 unsigned char tlsext_tick_key_name[16];
 unsigned char tlsext_tick_hmac_key[16];
 unsigned char tlsext_tick_aes_key[16];
 int (*tlsext_ticket_key_cb)(SSL *ssl,
     unsigned char *name, unsigned char *iv,
     EVP_CIPHER_CTX *ectx,
      HMAC_CTX *hctx, int enc);
 int (*tlsext_status_cb)(SSL *ssl, void *arg);
 void *tlsext_status_arg;
 int (*tlsext_opaque_prf_input_callback)(SSL *, void *peerinput, size_t len, void *arg);
 void *tlsext_opaque_prf_input_callback_arg;
 unsigned int (*psk_client_callback)(SSL *ssl, const char *hint, char *identity,
  unsigned int max_identity_len, unsigned char *psk,
  unsigned int max_psk_len);
 unsigned int (*psk_server_callback)(SSL *ssl, const char *identity,
  unsigned char *psk, unsigned int max_psk_len);
 unsigned int freelist_max_len;
 struct ssl3_buf_freelist_st *wbuf_freelist;
 struct ssl3_buf_freelist_st *rbuf_freelist;
# 952 "/usr/include/openssl/ssl.h" 3 4
 int (*next_protos_advertised_cb)(SSL *s, const unsigned char **buf,
                    unsigned int *len, void *arg);
 void *next_protos_advertised_cb_arg;
 int (*next_proto_select_cb)(SSL *s, unsigned char **out,
        unsigned char *outlen,
        const unsigned char *in,
        unsigned int inlen,
        void *arg);
 void *next_proto_select_cb_arg;
        struct stack_st_SRTP_PROTECTION_PROFILE *srtp_profiles;
# 982 "/usr/include/openssl/ssl.h" 3 4
struct lhash_st_SSL_SESSION *SSL_CTX_sessions(SSL_CTX *ctx);
# 1008 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_sess_set_new_cb(SSL_CTX *ctx, int (*new_session_cb)(struct ssl_st *ssl,SSL_SESSION *sess));
int (*SSL_CTX_sess_get_new_cb(SSL_CTX *ctx))(struct ssl_st *ssl, SSL_SESSION *sess);
void SSL_CTX_sess_set_remove_cb(SSL_CTX *ctx, void (*remove_session_cb)(struct ssl_ctx_st *ctx,SSL_SESSION *sess));
void (*SSL_CTX_sess_get_remove_cb(SSL_CTX *ctx))(struct ssl_ctx_st *ctx, SSL_SESSION *sess);
void SSL_CTX_sess_set_get_cb(SSL_CTX *ctx, SSL_SESSION *(*get_session_cb)(struct ssl_st *ssl, unsigned char *data,int len,int *copy));
SSL_SESSION *(*SSL_CTX_sess_get_get_cb(SSL_CTX *ctx))(struct ssl_st *ssl, unsigned char *Data, int len, int *copy);
void SSL_CTX_set_info_callback(SSL_CTX *ctx, void (*cb)(const SSL *ssl,int type,int val));
void (*SSL_CTX_get_info_callback(SSL_CTX *ctx))(const SSL *ssl,int type,int val);
void SSL_CTX_set_client_cert_cb(SSL_CTX *ctx, int (*client_cert_cb)(SSL *ssl, X509 **x509, EVP_PKEY **pkey));
int (*SSL_CTX_get_client_cert_cb(SSL_CTX *ctx))(SSL *ssl, X509 **x509, EVP_PKEY **pkey);
int SSL_CTX_set_client_cert_engine(SSL_CTX *ctx, ENGINE *e);
void SSL_CTX_set_cookie_generate_cb(SSL_CTX *ctx, int (*app_gen_cookie_cb)(SSL *ssl, unsigned char *cookie, unsigned int *cookie_len));
void SSL_CTX_set_cookie_verify_cb(SSL_CTX *ctx, int (*app_verify_cookie_cb)(SSL *ssl, unsigned char *cookie, unsigned int cookie_len));
void SSL_CTX_set_next_protos_advertised_cb(SSL_CTX *s,
        int (*cb) (SSL *ssl,
            const unsigned char **out,
            unsigned int *outlen,
            void *arg),
        void *arg);
void SSL_CTX_set_next_proto_select_cb(SSL_CTX *s,
       unsigned int inlen,
       void *arg),
          void *arg);
int SSL_select_next_proto(unsigned char **out, unsigned char *outlen,
     const unsigned char *in, unsigned int inlen,
     const unsigned char *client, unsigned int client_len);
void SSL_get0_next_proto_negotiated(const SSL *s,
        const unsigned char **data, unsigned *len);
# 1055 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_set_psk_client_callback(SSL_CTX *ctx,
  char *identity, unsigned int max_identity_len, unsigned char *psk,
  unsigned int max_psk_len));
void SSL_set_psk_client_callback(SSL *ssl,
void SSL_CTX_set_psk_server_callback(SSL_CTX *ctx,
  unsigned char *psk, unsigned int max_psk_len));
void SSL_set_psk_server_callback(SSL *ssl,
int SSL_CTX_use_psk_identity_hint(SSL_CTX *ctx, const char *identity_hint);
int SSL_use_psk_identity_hint(SSL *s, const char *identity_hint);
const char *SSL_get_psk_identity_hint(const SSL *s);
const char *SSL_get_psk_identity(const SSL *s);
# 1091 "/usr/include/openssl/ssl.h" 3 4
struct ssl_st
 int version;
 int type;
 BIO *rbio;
 BIO *wbio;
 BIO *bbio;
# 1119 "/usr/include/openssl/ssl.h" 3 4
 int rwstate;
 int in_handshake;
 int (*handshake_func)(SSL *);
# 1133 "/usr/include/openssl/ssl.h" 3 4
 int server;
 int new_session;
 int quiet_shutdown;
 int shutdown;
 int state;
 int rstate;
 BUF_MEM *init_buf;
 void *init_msg;
 int init_num;
 int init_off;
 unsigned char *packet;
 unsigned int packet_length;
 struct ssl2_state_st *s2;
 struct ssl3_state_st *s3;
 struct dtls1_state_st *d1;
 int read_ahead;
 int hit;
 int mac_flags;
 EVP_CIPHER_CTX *enc_read_ctx;
 EVP_MD_CTX *read_hash;
 COMP_CTX *expand;
 EVP_CIPHER_CTX *enc_write_ctx;
 EVP_MD_CTX *write_hash;
 COMP_CTX *compress;
# 1201 "/usr/include/openssl/ssl.h" 3 4
 SSL_SESSION *session;
 int verify_mode;
 int (*verify_callback)(int ok,X509_STORE_CTX *ctx);
 int error;
 int error_code;
 KSSL_CTX *kssl_ctx;
 SSL_CTX *ctx;
 int debug;
 long verify_result;
 int references;
 unsigned long mode;
 long max_cert_list;
 int first_packet;
 int client_version;
 void (*tlsext_debug_cb)(SSL *s, int client_server, int type,
     void *arg);
 void *tlsext_debug_arg;
 int servername_done;
 int tlsext_status_type;
 int tlsext_status_expected;
 struct stack_st_OCSP_RESPID *tlsext_ocsp_ids;
 X509_EXTENSIONS *tlsext_ocsp_exts;
 unsigned char *tlsext_ocsp_resp;
 int tlsext_ocsp_resplen;
 int tlsext_ticket_expected;
 void *tlsext_opaque_prf_input;
 size_t tlsext_opaque_prf_input_len;
 TLS_SESSION_TICKET_EXT *tlsext_session_ticket;
 tls_session_ticket_ext_cb_fn tls_session_ticket_ext_cb;
 void *tls_session_ticket_ext_cb_arg;
 tls_session_secret_cb_fn tls_session_secret_cb;
 void *tls_session_secret_cb_arg;
 SSL_CTX * initial_ctx;
# 1314 "/usr/include/openssl/ssl.h" 3 4
 unsigned char *next_proto_negotiated;
 unsigned char next_proto_negotiated_len;
 SRTP_PROTECTION_PROFILE *srtp_profile;
 unsigned int tlsext_heartbeat;
 unsigned int tlsext_hb_pending;
 unsigned int tlsext_hb_seq;
 int renegotiate;
# 1 "/usr/include/openssl/ssl2.h" 1 3 4
# 63 "/usr/include/openssl/ssl2.h" 3 4
extern "C" {
# 160 "/usr/include/openssl/ssl2.h" 3 4
typedef struct ssl2_state_st
 int three_byte_header;
 int clear_text;
 int escape;
 int ssl2_rollback;
 unsigned int wnum;
 int wpend_tot;
 const unsigned char *wpend_buf;
 int wpend_off;
 int wpend_len;
 int wpend_ret;
 int rbuf_left;
 int rbuf_offs;
 unsigned char *rbuf;
 unsigned char *wbuf;
 unsigned char *write_ptr;
 unsigned int padding;
 unsigned int rlength;
 int ract_data_length;
 unsigned int wlength;
 int wact_data_length;
 unsigned char *ract_data;
 unsigned char *wact_data;
 unsigned char *mac_data;
 unsigned char *read_key;
 unsigned char *write_key;
 unsigned int challenge_length;
 unsigned char challenge[32];
 unsigned int conn_id_length;
 unsigned char conn_id[16];
 unsigned int key_material_length;
 unsigned char key_material[24*2];
 unsigned long read_sequence;
 unsigned long write_sequence;
 struct {
  unsigned int cert_type;
  unsigned int cert_length;
  unsigned int csl;
  unsigned int clear;
  unsigned int enc;
  unsigned char ccl[32];
  unsigned int cipher_spec_length;
  unsigned int clen;
  unsigned int rlen;
  } tmp;
 } SSL2_STATE;
# 269 "/usr/include/openssl/ssl2.h" 3 4
# 1347 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/ssl3.h" 1 3 4
# 125 "/usr/include/openssl/ssl3.h" 3 4
# 1 "/usr/include/openssl/ssl.h" 1 3 4
# 126 "/usr/include/openssl/ssl3.h" 2 3 4
extern "C" {
# 353 "/usr/include/openssl/ssl3.h" 3 4
typedef struct ssl3_record_st
       int type;
       unsigned int length;
       unsigned int off;
       unsigned char *data;
       unsigned char *input;
       unsigned char *comp;
        unsigned long epoch;
        unsigned char seq_num[8];
 } SSL3_RECORD;
typedef struct ssl3_buffer_st
 unsigned char *buf;
 size_t len;
 int offset;
 int left;
 } SSL3_BUFFER;
# 415 "/usr/include/openssl/ssl3.h" 3 4
typedef struct ssl3_state_st
 long flags;
 int delay_buf_pop_ret;
 unsigned char read_sequence[8];
 int read_mac_secret_size;
 unsigned char read_mac_secret[64];
 unsigned char write_sequence[8];
 int write_mac_secret_size;
 unsigned char write_mac_secret[64];
 unsigned char server_random[32];
 unsigned char client_random[32];
 int need_empty_fragments;
 int empty_fragment_done;
 int init_extra;
 SSL3_BUFFER rbuf;
 SSL3_BUFFER wbuf;
 SSL3_RECORD rrec;
 SSL3_RECORD wrec;
 unsigned char alert_fragment[2];
 unsigned int alert_fragment_len;
 unsigned char handshake_fragment[4];
 unsigned int handshake_fragment_len;
 unsigned int wnum;
 int wpend_tot;
 int wpend_type;
 int wpend_ret;
 BIO *handshake_buffer;
 EVP_MD_CTX **handshake_dgst;
 int change_cipher_spec;
 int warn_alert;
 int fatal_alert;
 int alert_dispatch;
 unsigned char send_alert[2];
 int renegotiate;
 int total_renegotiations;
 int num_renegotiations;
 int in_read_app_data;
 void *client_opaque_prf_input;
 size_t client_opaque_prf_input_len;
 void *server_opaque_prf_input;
 size_t server_opaque_prf_input_len;
 struct {
  unsigned char cert_verify_md[64*2];
  unsigned char finish_md[64*2];
  int finish_md_len;
  unsigned char peer_finish_md[64*2];
  int peer_finish_md_len;
  unsigned long message_size;
  int message_type;
  const SSL_CIPHER *new_cipher;
  DH *dh;
  EC_KEY *ecdh;
  int next_state;
  int reuse_message;
  int cert_req;
  int ctype_num;
  char ctype[9];
  struct stack_st_X509_NAME *ca_names;
  int use_rsa_tmp;
  int key_block_length;
  unsigned char *key_block;
  const EVP_CIPHER *new_sym_enc;
  const EVP_MD *new_hash;
  int new_mac_pkey_type;
  int new_mac_secret_size;
  const SSL_COMP *new_compression;
  int cert_request;
  } tmp;
        unsigned char previous_client_finished[64];
        unsigned char previous_client_finished_len;
        unsigned char previous_server_finished[64];
        unsigned char previous_server_finished_len;
        int send_connection_binding;
 int next_proto_neg_seen;
 char is_probably_safari;
 } SSL3_STATE;
# 703 "/usr/include/openssl/ssl3.h" 3 4
# 1348 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/tls1.h" 1 3 4
# 157 "/usr/include/openssl/tls1.h" 3 4
extern "C" {
# 291 "/usr/include/openssl/tls1.h" 3 4
const char *SSL_get_servername(const SSL *s, const int type);
int SSL_get_servername_type(const SSL *s);
int SSL_export_keying_material(SSL *s, unsigned char *out, size_t olen,
 const char *label, size_t llen, const unsigned char *p, size_t plen,
 int use_context);
# 735 "/usr/include/openssl/tls1.h" 3 4
 unsigned short length;
 void *data;
# 1349 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/dtls1.h" 1 3 4
# 64 "/usr/include/openssl/dtls1.h" 3 4
# 1 "/usr/include/openssl/pqueue.h" 1 3 4
# 65 "/usr/include/openssl/pqueue.h" 3 4
# 1 "/usr/include/string.h" 1 3 4
# 27 "/usr/include/string.h" 3 4
extern "C" {
# 33 "/usr/include/string.h" 2 3 4
# 44 "/usr/include/string.h" 3 4
extern void *memcpy (void *__restrict __dest, const void *__restrict __src,
       size_t __n) throw () __attribute__ ((__nonnull__ (1, 2)));
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void *__restrict __dest, const void *__restrict __src,
        int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) throw () __attribute__ ((__nonnull__ (1)));
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
extern "C++"
extern void *memchr (void *__s, int __c, size_t __n)
      throw () __asm ("memchr") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern const void *memchr (const void *__s, int __c, size_t __n)
# 94 "/usr/include/string.h" 3 4
extern "C++" void *rawmemchr (void *__s, int __c)
     throw () __asm ("rawmemchr") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern "C++" const void *rawmemchr (const void *__s, int __c)
extern "C++" void *memrchr (void *__s, int __c, size_t __n)
      throw () __asm ("memrchr") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern "C++" const void *memrchr (const void *__s, int __c, size_t __n)
extern char *strcpy (char *__restrict __dest, const char *__restrict __src)
extern char *strncpy (char *__restrict __dest,
        const char *__restrict __src, size_t __n)
extern char *strcat (char *__restrict __dest, const char *__restrict __src)
extern char *strncat (char *__restrict __dest, const char *__restrict __src,
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char *__restrict __dest,
     throw () __attribute__ ((__nonnull__ (2)));
# 166 "/usr/include/string.h" 3 4
extern int strcoll_l (const char *__s1, const char *__s2, __locale_t __l)
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
extern size_t strxfrm_l (char *__dest, const char *__src, size_t __n,
    __locale_t __l) throw () __attribute__ ((__nonnull__ (2, 4)));
extern char *strdup (const char *__s)
     throw () __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
extern char *strndup (const char *__string, size_t __n)
# 210 "/usr/include/string.h" 3 4
extern "C++"
extern char *strchr (char *__s, int __c)
     throw () __asm ("strchr") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern const char *strchr (const char *__s, int __c)
# 233 "/usr/include/string.h" 3 4
extern "C++"
extern char *strrchr (char *__s, int __c)
     throw () __asm ("strrchr") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern const char *strrchr (const char *__s, int __c)
# 260 "/usr/include/string.h" 3 4
extern "C++" char *strchrnul (char *__s, int __c)
     throw () __asm ("strchrnul") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern "C++" const char *strchrnul (const char *__s, int __c)
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
extern "C++"
extern char *strpbrk (char *__s, const char *__accept)
     throw () __asm ("strpbrk") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
extern const char *strpbrk (const char *__s, const char *__accept)
# 312 "/usr/include/string.h" 3 4
extern "C++"
extern char *strstr (char *__haystack, const char *__needle)
     throw () __asm ("strstr") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
extern const char *strstr (const char *__haystack, const char *__needle)
# 339 "/usr/include/string.h" 3 4
extern char *strtok (char *__restrict __s, const char *__restrict __delim)
extern char *__strtok_r (char *__restrict __s,
    const char *__restrict __delim,
    char **__restrict __save_ptr)
     throw () __attribute__ ((__nonnull__ (2, 3)));
extern char *strtok_r (char *__restrict __s, const char *__restrict __delim,
extern "C++" char *strcasestr (char *__haystack, const char *__needle)
     throw () __asm ("strcasestr") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
extern "C++" const char *strcasestr (const char *__haystack,
# 381 "/usr/include/string.h" 3 4
extern void *memmem (const void *__haystack, size_t __haystacklen,
       const void *__needle, size_t __needlelen)
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 3)));
extern void *__mempcpy (void *__restrict __dest,
   const void *__restrict __src, size_t __n)
extern void *mempcpy (void *__restrict __dest,
extern size_t strlen (const char *__s)
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern size_t strnlen (const char *__string, size_t __maxlen)
extern char *strerror (int __errnum) throw ();
# 437 "/usr/include/string.h" 3 4
extern char *strerror_r (int __errnum, char *__buf, size_t __buflen)
     throw () __attribute__ ((__nonnull__ (2))) ;
extern char *strerror_l (int __errnum, __locale_t __l) throw ();
extern void __bzero (void *__s, size_t __n) throw () __attribute__ ((__nonnull__ (1)));
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) throw () __attribute__ ((__nonnull__ (1)));
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
extern "C++"
extern char *index (char *__s, int __c)
     throw () __asm ("index") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern const char *index (const char *__s, int __c)
# 486 "/usr/include/string.h" 3 4
extern "C++"
extern char *rindex (char *__s, int __c)
     throw () __asm ("rindex") __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
extern const char *rindex (const char *__s, int __c)
# 514 "/usr/include/string.h" 3 4
extern int ffs (int __i) throw () __attribute__ ((__const__));
extern int ffsl (long int __l) throw () __attribute__ ((__const__));
__extension__ extern int ffsll (long long int __ll)
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
extern int strcasecmp_l (const char *__s1, const char *__s2,
    __locale_t __loc)
extern int strncasecmp_l (const char *__s1, const char *__s2,
     size_t __n, __locale_t __loc)
     throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
extern char *strsep (char **__restrict __stringp,
extern char *strsignal (int __sig) throw ();
extern char *__stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *stpcpy (char *__restrict __dest, const char *__restrict __src)
extern char *__stpncpy (char *__restrict __dest,
extern char *stpncpy (char *__restrict __dest,
extern int strverscmp (const char *__s1, const char *__s2)
extern char *strfry (char *__string) throw () __attribute__ ((__nonnull__ (1)));
extern void *memfrob (void *__s, size_t __n) throw () __attribute__ ((__nonnull__ (1)));
extern "C++" char *basename (char *__filename)
     throw () __asm ("basename") __attribute__ ((__nonnull__ (1)));
extern "C++" const char *basename (const char *__filename)
# 643 "/usr/include/string.h" 3 4
# 66 "/usr/include/openssl/pqueue.h" 2 3 4
extern "C" {
typedef struct _pqueue *pqueue;
typedef struct _pitem
 unsigned char priority[8];
 void *data;
 struct _pitem *next;
 } pitem;
typedef struct _pitem *piterator;
pitem *pitem_new(unsigned char *prio64be, void *data);
void pitem_free(pitem *item);
pqueue pqueue_new(void);
void pqueue_free(pqueue pq);
pitem *pqueue_insert(pqueue pq, pitem *item);
pitem *pqueue_peek(pqueue pq);
pitem *pqueue_pop(pqueue pq);
pitem *pqueue_find(pqueue pq, unsigned char *prio64be);
pitem *pqueue_iterator(pqueue pq);
pitem *pqueue_next(piterator *iter);
void pqueue_print(pqueue pq);
int pqueue_size(pqueue pq);
# 65 "/usr/include/openssl/dtls1.h" 2 3 4
# 78 "/usr/include/openssl/dtls1.h" 3 4
# 1 "/usr/include/sys/time.h" 1 3 4
# 27 "/usr/include/sys/time.h" 3 4
# 1 "/usr/include/bits/time.h" 1 3 4
# 28 "/usr/include/sys/time.h" 2 3 4
# 37 "/usr/include/sys/time.h" 3 4
extern "C" {
# 55 "/usr/include/sys/time.h" 3 4
struct timezone
    int tz_minuteswest;
    int tz_dsttime;
typedef struct timezone *__restrict __timezone_ptr_t;
# 71 "/usr/include/sys/time.h" 3 4
extern int gettimeofday (struct timeval *__restrict __tv,
    __timezone_ptr_t __tz) throw () __attribute__ ((__nonnull__ (1)));
extern int settimeofday (const struct timeval *__tv,
    const struct timezone *__tz)
     throw ();
extern int adjtime (const struct timeval *__delta,
      struct timeval *__olddelta) throw ();
enum __itimer_which
    ITIMER_REAL = 0,
    ITIMER_VIRTUAL = 1,
    ITIMER_PROF = 2
struct itimerval
    struct timeval it_interval;
    struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
        struct itimerval *__value) throw ();
extern int setitimer (__itimer_which_t __which,
        const struct itimerval *__restrict __new,
        struct itimerval *__restrict __old) throw ();
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) throw ();
extern int futimesat (int __fd, const char *__file,
# 189 "/usr/include/sys/time.h" 3 4
# 79 "/usr/include/openssl/dtls1.h" 2 3 4
extern "C" {
# 123 "/usr/include/openssl/dtls1.h" 3 4
typedef struct dtls1_bitmap_st
 unsigned long map;
 unsigned char max_seq_num[8];
 } DTLS1_BITMAP;
struct dtls1_retransmit_state
 COMP_CTX *compress;
 unsigned short epoch;
struct hm_header_st
 unsigned char type;
 unsigned long msg_len;
 unsigned short seq;
 unsigned long frag_off;
 unsigned long frag_len;
 unsigned int is_ccs;
 struct dtls1_retransmit_state saved_retransmit_state;
struct ccs_header_st
 unsigned char type;
 unsigned short seq;
struct dtls1_timeout_st
 unsigned int read_timeouts;
 unsigned int write_timeouts;
 unsigned int num_alerts;
typedef struct record_pqueue_st
 pqueue q;
 } record_pqueue;
typedef struct hm_fragment_st
 struct hm_header_st msg_header;
 unsigned char *fragment;
 unsigned char *reassembly;
 } hm_fragment;
typedef struct dtls1_state_st
 unsigned int send_cookie;
 unsigned char cookie[256];
 unsigned char rcvd_cookie[256];
 unsigned int cookie_len;
 unsigned short r_epoch;
 unsigned short w_epoch;
 DTLS1_BITMAP bitmap;
 DTLS1_BITMAP next_bitmap;
 unsigned short handshake_write_seq;
 unsigned short next_handshake_write_seq;
 unsigned short handshake_read_seq;
 unsigned char last_write_sequence[8];
 record_pqueue unprocessed_rcds;
 record_pqueue processed_rcds;
 pqueue buffered_messages;
 pqueue sent_messages;
 record_pqueue buffered_app_data;
 unsigned int mtu;
 struct hm_header_st w_msg_hdr;
 struct hm_header_st r_msg_hdr;
 struct dtls1_timeout_st timeout;
 struct timeval next_timeout;
 unsigned short timeout_duration;
 unsigned char handshake_fragment[12];
 unsigned int retransmitting;
 unsigned int change_cipher_spec_ok;
 unsigned int listen;
 unsigned int link_mtu;
# 273 "/usr/include/openssl/dtls1.h" 3 4
 } DTLS1_STATE;
typedef struct dtls1_record_data_st
 SSL3_BUFFER rbuf;
 SSL3_RECORD rrec;
 } DTLS1_RECORD_DATA;
# 295 "/usr/include/openssl/dtls1.h" 3 4
# 1350 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/ssl23.h" 1 3 4
# 63 "/usr/include/openssl/ssl23.h" 3 4
extern "C" {
# 80 "/usr/include/openssl/ssl23.h" 3 4
# 1351 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/srtp.h" 1 3 4
# 124 "/usr/include/openssl/srtp.h" 3 4
extern "C" {
# 137 "/usr/include/openssl/srtp.h" 3 4
int SSL_CTX_set_tlsext_use_srtp(SSL_CTX *ctx, const char *profiles);
int SSL_set_tlsext_use_srtp(SSL *ctx, const char *profiles);
SRTP_PROTECTION_PROFILE *SSL_get_selected_srtp_profile(SSL *s);
struct stack_st_SRTP_PROTECTION_PROFILE *SSL_get_srtp_profiles(SSL *ssl);
# 1352 "/usr/include/openssl/ssl.h" 2 3 4
extern "C" {
# 1412 "/usr/include/openssl/ssl.h" 3 4
size_t SSL_get_finished(const SSL *s, void *buf, size_t count);
size_t SSL_get_peer_finished(const SSL *s, void *buf, size_t count);
# 1450 "/usr/include/openssl/ssl.h" 3 4
SSL_SESSION *PEM_read_bio_SSL_SESSION(BIO *bp, SSL_SESSION **x, pem_password_cb *cb, void *u); SSL_SESSION *PEM_read_SSL_SESSION(FILE *fp, SSL_SESSION **x, pem_password_cb *cb, void *u); int PEM_write_bio_SSL_SESSION(BIO *bp, SSL_SESSION *x); int PEM_write_SSL_SESSION(FILE *fp, SSL_SESSION *x);
# 1646 "/usr/include/openssl/ssl.h" 3 4
BIO_METHOD *BIO_f_ssl(void);
BIO *BIO_new_ssl(SSL_CTX *ctx,int client);
BIO *BIO_new_ssl_connect(SSL_CTX *ctx);
BIO *BIO_new_buffer_ssl_connect(SSL_CTX *ctx);
int BIO_ssl_copy_session_id(BIO *to,BIO *from);
void BIO_ssl_shutdown(BIO *ssl_bio);
int SSL_CTX_set_cipher_list(SSL_CTX *,const char *str);
SSL_CTX *SSL_CTX_new(const SSL_METHOD *meth);
void SSL_CTX_free(SSL_CTX *);
long SSL_CTX_set_timeout(SSL_CTX *ctx,long t);
long SSL_CTX_get_timeout(const SSL_CTX *ctx);
X509_STORE *SSL_CTX_get_cert_store(const SSL_CTX *);
void SSL_CTX_set_cert_store(SSL_CTX *,X509_STORE *);
int SSL_want(const SSL *s);
int SSL_clear(SSL *s);
void SSL_CTX_flush_sessions(SSL_CTX *ctx,long tm);
const SSL_CIPHER *SSL_get_current_cipher(const SSL *s);
int SSL_CIPHER_get_bits(const SSL_CIPHER *c,int *alg_bits);
char * SSL_CIPHER_get_version(const SSL_CIPHER *c);
const char * SSL_CIPHER_get_name(const SSL_CIPHER *c);
unsigned long SSL_CIPHER_get_id(const SSL_CIPHER *c);
int SSL_get_fd(const SSL *s);
int SSL_get_rfd(const SSL *s);
int SSL_get_wfd(const SSL *s);
const char * SSL_get_cipher_list(const SSL *s,int n);
char * SSL_get_shared_ciphers(const SSL *s, char *buf, int len);
int SSL_get_read_ahead(const SSL * s);
int SSL_pending(const SSL *s);
int SSL_set_fd(SSL *s, int fd);
int SSL_set_rfd(SSL *s, int fd);
int SSL_set_wfd(SSL *s, int fd);
void SSL_set_bio(SSL *s, BIO *rbio,BIO *wbio);
BIO * SSL_get_rbio(const SSL *s);
BIO * SSL_get_wbio(const SSL *s);
int SSL_set_cipher_list(SSL *s, const char *str);
void SSL_set_read_ahead(SSL *s, int yes);
int SSL_get_verify_mode(const SSL *s);
int SSL_get_verify_depth(const SSL *s);
int (*SSL_get_verify_callback(const SSL *s))(int,X509_STORE_CTX *);
void SSL_set_verify(SSL *s, int mode,
         int (*callback)(int ok,X509_STORE_CTX *ctx));
void SSL_set_verify_depth(SSL *s, int depth);
int SSL_use_RSAPrivateKey(SSL *ssl, RSA *rsa);
int SSL_use_RSAPrivateKey_ASN1(SSL *ssl, unsigned char *d, long len);
int SSL_use_PrivateKey(SSL *ssl, EVP_PKEY *pkey);
int SSL_use_PrivateKey_ASN1(int pk,SSL *ssl, const unsigned char *d, long len);
int SSL_use_certificate(SSL *ssl, X509 *x);
int SSL_use_certificate_ASN1(SSL *ssl, const unsigned char *d, int len);
int SSL_use_RSAPrivateKey_file(SSL *ssl, const char *file, int type);
int SSL_use_PrivateKey_file(SSL *ssl, const char *file, int type);
int SSL_use_certificate_file(SSL *ssl, const char *file, int type);
int SSL_CTX_use_RSAPrivateKey_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_PrivateKey_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_certificate_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_certificate_chain_file(SSL_CTX *ctx, const char *file);
struct stack_st_X509_NAME *SSL_load_client_CA_file(const char *file);
int SSL_add_file_cert_subjects_to_stack(struct stack_st_X509_NAME *stackCAs,
         const char *file);
int SSL_add_dir_cert_subjects_to_stack(struct stack_st_X509_NAME *stackCAs,
        const char *dir);
void SSL_load_error_strings(void );
const char *SSL_state_string(const SSL *s);
const char *SSL_rstate_string(const SSL *s);
const char *SSL_state_string_long(const SSL *s);
const char *SSL_rstate_string_long(const SSL *s);
long SSL_SESSION_get_time(const SSL_SESSION *s);
long SSL_SESSION_set_time(SSL_SESSION *s, long t);
long SSL_SESSION_get_timeout(const SSL_SESSION *s);
long SSL_SESSION_set_timeout(SSL_SESSION *s, long t);
void SSL_copy_session_id(SSL *to,const SSL *from);
X509 *SSL_SESSION_get0_peer(SSL_SESSION *s);
int SSL_SESSION_set1_id_context(SSL_SESSION *s,const unsigned char *sid_ctx,
          unsigned int sid_ctx_len);
SSL_SESSION *SSL_SESSION_new(void);
const unsigned char *SSL_SESSION_get_id(const SSL_SESSION *s,
     unsigned int *len);
unsigned int SSL_SESSION_get_compress_id(const SSL_SESSION *s);
int SSL_SESSION_print_fp(FILE *fp,const SSL_SESSION *ses);
int SSL_SESSION_print(BIO *fp,const SSL_SESSION *ses);
void SSL_SESSION_free(SSL_SESSION *ses);
int i2d_SSL_SESSION(SSL_SESSION *in,unsigned char **pp);
int SSL_set_session(SSL *to, SSL_SESSION *session);
int SSL_CTX_add_session(SSL_CTX *s, SSL_SESSION *c);
int SSL_CTX_remove_session(SSL_CTX *,SSL_SESSION *c);
int SSL_CTX_set_generate_session_id(SSL_CTX *, GEN_SESSION_CB);
int SSL_set_generate_session_id(SSL *, GEN_SESSION_CB);
int SSL_has_matching_session_id(const SSL *ssl, const unsigned char *id,
     unsigned int id_len);
SSL_SESSION *d2i_SSL_SESSION(SSL_SESSION **a,const unsigned char **pp,
        long length);
X509 * SSL_get_peer_certificate(const SSL *s);
struct stack_st_X509 *SSL_get_peer_cert_chain(const SSL *s);
int SSL_CTX_get_verify_mode(const SSL_CTX *ctx);
int SSL_CTX_get_verify_depth(const SSL_CTX *ctx);
int (*SSL_CTX_get_verify_callback(const SSL_CTX *ctx))(int,X509_STORE_CTX *);
void SSL_CTX_set_verify(SSL_CTX *ctx,int mode,
   int (*callback)(int, X509_STORE_CTX *));
void SSL_CTX_set_verify_depth(SSL_CTX *ctx,int depth);
void SSL_CTX_set_cert_verify_callback(SSL_CTX *ctx, int (*cb)(X509_STORE_CTX *,void *), void *arg);
int SSL_CTX_use_RSAPrivateKey(SSL_CTX *ctx, RSA *rsa);
int SSL_CTX_use_RSAPrivateKey_ASN1(SSL_CTX *ctx, const unsigned char *d, long len);
int SSL_CTX_use_PrivateKey(SSL_CTX *ctx, EVP_PKEY *pkey);
int SSL_CTX_use_PrivateKey_ASN1(int pk,SSL_CTX *ctx,
int SSL_CTX_use_certificate(SSL_CTX *ctx, X509 *x);
int SSL_CTX_use_certificate_ASN1(SSL_CTX *ctx, int len, const unsigned char *d);
void SSL_CTX_set_default_passwd_cb(SSL_CTX *ctx, pem_password_cb *cb);
void SSL_CTX_set_default_passwd_cb_userdata(SSL_CTX *ctx, void *u);
int SSL_CTX_check_private_key(const SSL_CTX *ctx);
int SSL_check_private_key(const SSL *ctx);
int SSL_CTX_set_session_id_context(SSL_CTX *ctx,const unsigned char *sid_ctx,
SSL * SSL_new(SSL_CTX *ctx);
int SSL_set_session_id_context(SSL *ssl,const unsigned char *sid_ctx,
int SSL_CTX_set_purpose(SSL_CTX *s, int purpose);
int SSL_set_purpose(SSL *s, int purpose);
int SSL_CTX_set_trust(SSL_CTX *s, int trust);
int SSL_set_trust(SSL *s, int trust);
int SSL_CTX_set1_param(SSL_CTX *ctx, X509_VERIFY_PARAM *vpm);
int SSL_set1_param(SSL *ssl, X509_VERIFY_PARAM *vpm);
void SSL_free(SSL *ssl);
int SSL_accept(SSL *ssl);
int SSL_connect(SSL *ssl);
int SSL_read(SSL *ssl,void *buf,int num);
int SSL_peek(SSL *ssl,void *buf,int num);
int SSL_write(SSL *ssl,const void *buf,int num);
long SSL_ctrl(SSL *ssl,int cmd, long larg, void *parg);
long SSL_callback_ctrl(SSL *, int, void (*)(void));
long SSL_CTX_ctrl(SSL_CTX *ctx,int cmd, long larg, void *parg);
long SSL_CTX_callback_ctrl(SSL_CTX *, int, void (*)(void));
int SSL_get_error(const SSL *s,int ret_code);
const char *SSL_get_version(const SSL *s);
int SSL_CTX_set_ssl_version(SSL_CTX *ctx, const SSL_METHOD *meth);
const SSL_METHOD *SSLv2_method(void);
const SSL_METHOD *SSLv2_server_method(void);
const SSL_METHOD *SSLv2_client_method(void);
const SSL_METHOD *SSLv3_method(void);
const SSL_METHOD *SSLv3_server_method(void);
const SSL_METHOD *SSLv3_client_method(void);
const SSL_METHOD *SSLv23_method(void);
const SSL_METHOD *SSLv23_server_method(void);
const SSL_METHOD *SSLv23_client_method(void);
const SSL_METHOD *TLSv1_method(void);
const SSL_METHOD *TLSv1_server_method(void);
const SSL_METHOD *TLSv1_client_method(void);
const SSL_METHOD *TLSv1_1_method(void);
const SSL_METHOD *TLSv1_1_server_method(void);
const SSL_METHOD *TLSv1_1_client_method(void);
const SSL_METHOD *TLSv1_2_method(void);
const SSL_METHOD *TLSv1_2_server_method(void);
const SSL_METHOD *TLSv1_2_client_method(void);
const SSL_METHOD *DTLSv1_method(void);
const SSL_METHOD *DTLSv1_server_method(void);
const SSL_METHOD *DTLSv1_client_method(void);
struct stack_st_SSL_CIPHER *SSL_get_ciphers(const SSL *s);
int SSL_do_handshake(SSL *s);
int SSL_renegotiate(SSL *s);
int SSL_renegotiate_abbreviated(SSL *s);
int SSL_renegotiate_pending(SSL *s);
int SSL_shutdown(SSL *s);
const SSL_METHOD *SSL_get_ssl_method(SSL *s);
int SSL_set_ssl_method(SSL *s, const SSL_METHOD *method);
const char *SSL_alert_type_string_long(int value);
const char *SSL_alert_type_string(int value);
const char *SSL_alert_desc_string_long(int value);
const char *SSL_alert_desc_string(int value);
void SSL_set_client_CA_list(SSL *s, struct stack_st_X509_NAME *name_list);
void SSL_CTX_set_client_CA_list(SSL_CTX *ctx, struct stack_st_X509_NAME *name_list);
struct stack_st_X509_NAME *SSL_get_client_CA_list(const SSL *s);
struct stack_st_X509_NAME *SSL_CTX_get_client_CA_list(const SSL_CTX *s);
int SSL_add_client_CA(SSL *ssl,X509 *x);
int SSL_CTX_add_client_CA(SSL_CTX *ctx,X509 *x);
void SSL_set_connect_state(SSL *s);
void SSL_set_accept_state(SSL *s);
long SSL_get_default_timeout(const SSL *s);
int SSL_library_init(void );
char *SSL_CIPHER_description(const SSL_CIPHER *,char *buf,int size);
struct stack_st_X509_NAME *SSL_dup_CA_list(struct stack_st_X509_NAME *sk);
SSL *SSL_dup(SSL *ssl);
X509 *SSL_get_certificate(const SSL *ssl);
               struct evp_pkey_st *SSL_get_privatekey(SSL *ssl);
void SSL_CTX_set_quiet_shutdown(SSL_CTX *ctx,int mode);
int SSL_CTX_get_quiet_shutdown(const SSL_CTX *ctx);
void SSL_set_quiet_shutdown(SSL *ssl,int mode);
int SSL_get_quiet_shutdown(const SSL *ssl);
void SSL_set_shutdown(SSL *ssl,int mode);
int SSL_get_shutdown(const SSL *ssl);
int SSL_version(const SSL *ssl);
int SSL_CTX_set_default_verify_paths(SSL_CTX *ctx);
int SSL_CTX_load_verify_locations(SSL_CTX *ctx, const char *CAfile,
 const char *CApath);
SSL_SESSION *SSL_get_session(const SSL *ssl);
SSL_SESSION *SSL_get1_session(SSL *ssl);
SSL_CTX *SSL_get_SSL_CTX(const SSL *ssl);
SSL_CTX *SSL_set_SSL_CTX(SSL *ssl, SSL_CTX* ctx);
void SSL_set_info_callback(SSL *ssl,
void (*SSL_get_info_callback(const SSL *ssl))(const SSL *ssl,int type,int val);
int SSL_state(const SSL *ssl);
void SSL_set_state(SSL *ssl, int state);
void SSL_set_verify_result(SSL *ssl,long v);
long SSL_get_verify_result(const SSL *ssl);
int SSL_set_ex_data(SSL *ssl,int idx,void *data);
void *SSL_get_ex_data(const SSL *ssl,int idx);
int SSL_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
 CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
int SSL_SESSION_set_ex_data(SSL_SESSION *ss,int idx,void *data);
void *SSL_SESSION_get_ex_data(const SSL_SESSION *ss,int idx);
int SSL_SESSION_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int SSL_CTX_set_ex_data(SSL_CTX *ssl,int idx,void *data);
void *SSL_CTX_get_ex_data(const SSL_CTX *ssl,int idx);
int SSL_CTX_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int SSL_get_ex_data_X509_STORE_CTX_idx(void );
# 1967 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_set_tmp_rsa_callback(SSL_CTX *ctx,
      RSA *(*cb)(SSL *ssl,int is_export,
          int keylength));
void SSL_set_tmp_rsa_callback(SSL *ssl,
          int keylength));
void SSL_CTX_set_tmp_dh_callback(SSL_CTX *ctx,
     DH *(*dh)(SSL *ssl,int is_export,
        int keylength));
void SSL_set_tmp_dh_callback(SSL *ssl,
        int keylength));
void SSL_CTX_set_tmp_ecdh_callback(SSL_CTX *ctx,
     EC_KEY *(*ecdh)(SSL *ssl,int is_export,
        int keylength));
void SSL_set_tmp_ecdh_callback(SSL *ssl,
        int keylength));
const COMP_METHOD *SSL_get_current_compression(SSL *s);
const COMP_METHOD *SSL_get_current_expansion(SSL *s);
const char *SSL_COMP_get_name(const COMP_METHOD *comp);
struct stack_st_SSL_COMP *SSL_COMP_get_compression_methods(void);
int SSL_COMP_add_compression_method(int id,COMP_METHOD *cm);
# 2007 "/usr/include/openssl/ssl.h" 3 4
int SSL_set_session_ticket_ext(SSL *s, void *ext_data, int ext_len);
int SSL_set_session_ticket_ext_cb(SSL *s, tls_session_ticket_ext_cb_fn cb,
      void *arg);
int SSL_set_session_secret_cb(SSL *s, tls_session_secret_cb_fn tls_session_secret_cb, void *arg);
void SSL_set_debug(SSL *s, int debug);
int SSL_cache_hit(SSL *s);
# 2026 "/usr/include/openssl/ssl.h" 3 4
void ERR_load_SSL_strings(void);
# 2557 "/usr/include/openssl/ssl.h" 3 4
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['openssl/ssl.h'] in ['/usr/local/include']
                Popping language Cxx
TEST checkSharedLibrary from config.packages.ssl(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:731)
TESTING: checkSharedLibrary from config.packages.ssl(config/BuildSystem/config/package.py:731)
  By default we don't care about checking if the library is shared
TEST alternateConfigureLibrary from config.packages.boost(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.boost(config/BuildSystem/config/package.py:735)
  Called if --with-packagename=0; does nothing by default
          Pushing language Cxx
TEST configureLibrary from config.packages.hwloc(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:672)
TESTING: configureLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:672)
  Find an installation and check if it can work with PETSc
            Checking for a functional hwloc
            Checking for library in Compiler specific search HWLOC: []
TEST check from config.libraries(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
                Checking for functions [hwloc_topology_init] in library [] []
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.libraries -fopenmp -O3      /tmp/petsc-F9l5hH/config.libraries/conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
char hwloc_topology_init();
static void _check_hwloc_topology_init() { hwloc_topology_init(); }
#ifdef __cplusplus
#endif
int main() {
_check_hwloc_topology_init();;
  return 0;
                          Pushing language CXX
                          Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.o: In function `main':
conftest.cc:(.text.startup+0x5): undefined reference to `hwloc_topology_init'
collect2: error: ld returned 1 exit status
            Checking for library in Compiler specific search HWLOC: ['libhwloc.a']
                Checking for functions [hwloc_topology_init] in library ['libhwloc.a'] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -lhwloc -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
/bin/ld: cannot find -lhwloc
            Checking for library in Compiler specific search HWLOC: ['libhwloc.a', 'libxml2.a']
                Checking for functions [hwloc_topology_init] in library ['libhwloc.a', 'libxml2.a'] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -lhwloc -lxml2 -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
            Checking for library in Package specific search directory HWLOC: ['/usr/local/lib/libhwloc.a']
            Contents: ['bin', 'sbin', 'lib64', 'libexec', 'etc', 'include', 'share', 'src', 'games', 'lib']
                Checking for functions [hwloc_topology_init] in library ['/usr/local/lib/libhwloc.a'] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lhwloc -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
            Checking for library in Package specific search directory HWLOC: ['/usr/local/lib/libhwloc.a', 'libxml2.a']
                Checking for functions [hwloc_topology_init] in library ['/usr/local/lib/libhwloc.a', 'libxml2.a'] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lhwloc -lxml2 -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
            Checking for library in Package specific search directory HWLOC: ['/usr/local/lib64/libhwloc.a']
                Checking for functions [hwloc_topology_init] in library ['/usr/local/lib64/libhwloc.a'] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -Wl,-rpath,/usr/local/lib64 -L/usr/local/lib64 -lhwloc -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
            Checking for library in Package specific search directory HWLOC: ['/usr/local/lib64/libhwloc.a', 'libxml2.a']
                Checking for functions [hwloc_topology_init] in library ['/usr/local/lib64/libhwloc.a', 'libxml2.a'] []
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -Wl,-rpath,/usr/local/lib64 -L/usr/local/lib64 -lhwloc -lxml2 -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
              HWLOC: SearchDir DirPath not found.. skipping: /opt/local
TEST checkSharedLibrary from config.packages.hwloc(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:731)
TESTING: checkSharedLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:731)
TEST alternateConfigureLibrary from config.packages.revolve(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.revolve(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.tchem(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.tchem(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.PTScotch(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.PTScotch(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.X(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.X(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.Triangle(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.Triangle(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.yaml(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.yaml(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.fftw(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.fftw(config/BuildSystem/config/package.py:735)
      Not a clone of PETSc or no Fortran, don't need Sowing
TEST alternateConfigureLibrary from config.packages.gmp(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.gmp(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.mpfr(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.mpfr(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.saws(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.saws(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.libpng(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.libpng(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.openmp(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.openmp(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.libjpeg(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.libjpeg(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.p4est(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.p4est(config/BuildSystem/config/package.py:735)
TEST configureLibrary from config.packages.hdf5(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/hdf5.py:46)
TESTING: configureLibrary from config.packages.hdf5(config/BuildSystem/config/packages/hdf5.py:46)
            Checking for a functional hdf5
            Checking for library in User specified HDF5 libraries: ['/usr/lib/libhdf5.so']
            Contents: ['local', 'bin', 'sbin', 'lib64', 'libexec', 'tmp', 'include', 'share', 'src', 'games', 'lib']
                Checking for functions [H5T_init] in library ['/usr/lib/libhdf5.so'] ['libm.a']
Successful compile:
Source:
#ifdef __cplusplus
extern "C" {
#endif
char H5T_init();
static void _check_H5T_init() { H5T_init(); }
#ifdef __cplusplus
#endif
int main() {
_check_H5T_init();;
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -Wl,-rpath,/usr/lib -L/usr/lib -lhdf5 -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
                  Defined "HAVE_LIBHDF5" to "1"
            Checking for headers User specified HDF5 libraries: ['/usr/include', '/usr/local/include']
TEST checkInclude from config.headers(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['hdf5.h'] in ['/usr/include', '/usr/local/include']
                  Checking include with compiler flags var CPPFLAGS ['/usr/include', '/usr/local/include', '/usr/local/include']
Executing: mpic++ -E  -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.headers   -I/usr/include -I/usr/local/include -I/usr/local/include /tmp/petsc-F9l5hH/config.headers/conftest.cc
stdout:
# 1 "/tmp/petsc-F9l5hH/config.headers/conftest.cc"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 1 "<command-line>" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/confdefs.h" 1
# 2 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
# 1 "/tmp/petsc-F9l5hH/config.headers/conffix.h" 1
extern "C" {
# 1 "/usr/include/hdf5.h" 1 3 4
# 24 "/usr/include/hdf5.h" 3 4
# 1 "/usr/include/H5public.h" 1 3 4
# 31 "/usr/include/H5public.h" 3 4
# 1 "/usr/include/H5pubconf-64.h" 1 3 4
# 32 "/usr/include/H5public.h" 2 3 4
# 1 "/usr/include/H5version.h" 1 3 4
# 35 "/usr/include/H5public.h" 2 3 4
# 1 "/usr/include/features.h" 1 3 4
# 365 "/usr/include/features.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 402 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/bits/wordsize.h" 1 3 4
# 403 "/usr/include/sys/cdefs.h" 2 3 4
# 366 "/usr/include/features.h" 2 3 4
# 389 "/usr/include/features.h" 3 4
# 1 "/usr/include/gnu/stubs.h" 1 3 4
# 10 "/usr/include/gnu/stubs.h" 3 4
# 1 "/usr/include/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/gnu/stubs.h" 2 3 4
# 390 "/usr/include/features.h" 2 3 4
# 38 "/usr/include/H5public.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 27 "/usr/include/sys/types.h" 3 4
extern "C" {
# 1 "/usr/include/bits/types.h" 1 3 4
# 27 "/usr/include/bits/types.h" 3 4
# 28 "/usr/include/bits/types.h" 2 3 4
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
# 121 "/usr/include/bits/types.h" 3 4
# 1 "/usr/include/bits/typesizes.h" 1 3 4
# 122 "/usr/include/bits/types.h" 2 3 4
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned long int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef long int __suseconds_t;
typedef int __daddr_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __fsword_t;
typedef long int __ssize_t;
typedef long int __syscall_slong_t;
typedef unsigned long int __syscall_ulong_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
# 30 "/usr/include/sys/types.h" 2 3 4
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
typedef __ino64_t ino64_t;
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
typedef __off64_t off64_t;
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
# 132 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 57 "/usr/include/time.h" 3 4
typedef __clock_t clock_t;
# 73 "/usr/include/time.h" 3 4
typedef __time_t time_t;
# 91 "/usr/include/time.h" 3 4
typedef __clockid_t clockid_t;
# 103 "/usr/include/time.h" 3 4
typedef __timer_t timer_t;
# 133 "/usr/include/sys/types.h" 2 3 4
typedef __useconds_t useconds_t;
typedef __suseconds_t suseconds_t;
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 1 3 4
# 212 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long unsigned int size_t;
# 147 "/usr/include/sys/types.h" 2 3 4
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
# 194 "/usr/include/sys/types.h" 3 4
typedef int int8_t __attribute__ ((__mode__ (__QI__)));
typedef int int16_t __attribute__ ((__mode__ (__HI__)));
typedef int int32_t __attribute__ ((__mode__ (__SI__)));
typedef int int64_t __attribute__ ((__mode__ (__DI__)));
typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
typedef int register_t __attribute__ ((__mode__ (__word__)));
# 216 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/endian.h" 1 3 4
# 36 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/endian.h" 1 3 4
# 37 "/usr/include/endian.h" 2 3 4
# 60 "/usr/include/endian.h" 3 4
# 1 "/usr/include/bits/byteswap.h" 1 3 4
# 28 "/usr/include/bits/byteswap.h" 3 4
# 29 "/usr/include/bits/byteswap.h" 2 3 4
# 1 "/usr/include/bits/byteswap-16.h" 1 3 4
# 36 "/usr/include/bits/byteswap.h" 2 3 4
# 44 "/usr/include/bits/byteswap.h" 3 4
static __inline unsigned int
__bswap_32 (unsigned int __bsx)
  return __builtin_bswap32 (__bsx);
# 108 "/usr/include/bits/byteswap.h" 3 4
static __inline __uint64_t
__bswap_64 (__uint64_t __bsx)
  return __builtin_bswap64 (__bsx);
# 61 "/usr/include/endian.h" 2 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 30 "/usr/include/sys/select.h" 3 4
# 1 "/usr/include/bits/select.h" 1 3 4
# 22 "/usr/include/bits/select.h" 3 4
# 23 "/usr/include/bits/select.h" 2 3 4
# 31 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/bits/sigset.h" 1 3 4
# 22 "/usr/include/bits/sigset.h" 3 4
typedef int __sig_atomic_t;
typedef struct
    unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
  } __sigset_t;
# 34 "/usr/include/sys/select.h" 2 3 4
typedef __sigset_t sigset_t;
# 120 "/usr/include/time.h" 3 4
struct timespec
    __time_t tv_sec;
    __syscall_slong_t tv_nsec;
# 44 "/usr/include/sys/select.h" 2 3 4
# 30 "/usr/include/bits/time.h" 3 4
struct timeval
    __time_t tv_sec;
    __suseconds_t tv_usec;
# 46 "/usr/include/sys/select.h" 2 3 4
# 54 "/usr/include/sys/select.h" 3 4
typedef long int __fd_mask;
# 64 "/usr/include/sys/select.h" 3 4
typedef struct
    __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
  } fd_set;
typedef __fd_mask fd_mask;
# 96 "/usr/include/sys/select.h" 3 4
extern "C" {
# 106 "/usr/include/sys/select.h" 3 4
extern int select (int __nfds, fd_set *__restrict __readfds,
     fd_set *__restrict __writefds,
     fd_set *__restrict __exceptfds,
     struct timeval *__restrict __timeout);
# 118 "/usr/include/sys/select.h" 3 4
extern int pselect (int __nfds, fd_set *__restrict __readfds,
      const struct timespec *__restrict __timeout,
      const __sigset_t *__restrict __sigmask);
# 131 "/usr/include/sys/select.h" 3 4
# 220 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/sysmacros.h" 1 3 4
# 24 "/usr/include/sys/sysmacros.h" 3 4
extern "C" {
__extension__
extern unsigned int gnu_dev_major (unsigned long long int __dev)
__extension__
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
__extension__
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
            unsigned int __minor)
# 58 "/usr/include/sys/sysmacros.h" 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
typedef __blksize_t blksize_t;
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
# 262 "/usr/include/sys/types.h" 3 4
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
# 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
# 21 "/usr/include/bits/pthreadtypes.h" 3 4
# 22 "/usr/include/bits/pthreadtypes.h" 2 3 4
# 60 "/usr/include/bits/pthreadtypes.h" 3 4
typedef unsigned long int pthread_t;
union pthread_attr_t
  char __size[56];
  long int __align;
typedef union pthread_attr_t pthread_attr_t;
typedef struct __pthread_internal_list
  struct __pthread_internal_list *__prev;
  struct __pthread_internal_list *__next;
} __pthread_list_t;
# 90 "/usr/include/bits/pthreadtypes.h" 3 4
typedef union
  struct __pthread_mutex_s
    int __lock;
    unsigned int __count;
    int __owner;
    unsigned int __nusers;
    int __kind;
    short __spins;
    short __elision;
    __pthread_list_t __list;
# 125 "/usr/include/bits/pthreadtypes.h" 3 4
  } __data;
  char __size[40];
  long int __align;
} pthread_mutex_t;
typedef union
  char __size[4];
  int __align;
} pthread_mutexattr_t;
typedef union
  struct
    int __lock;
    unsigned int __futex;
    __extension__ unsigned long long int __total_seq;
    __extension__ unsigned long long int __wakeup_seq;
    __extension__ unsigned long long int __woken_seq;
    void *__mutex;
    unsigned int __nwaiters;
    unsigned int __broadcast_seq;
  } __data;
  char __size[48];
  __extension__ long long int __align;
} pthread_cond_t;
typedef union
  char __size[4];
  int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
  struct
    int __lock;
    unsigned int __nr_readers;
    unsigned int __readers_wakeup;
    unsigned int __writer_wakeup;
    unsigned int __nr_readers_queued;
    unsigned int __nr_writers_queued;
    int __writer;
    int __shared;
    signed char __rwelision;
    unsigned char __pad1[7];
    unsigned long int __pad2;
    unsigned int __flags;
  } __data;
# 220 "/usr/include/bits/pthreadtypes.h" 3 4
  char __size[56];
  long int __align;
} pthread_rwlock_t;
typedef union
  char __size[8];
  long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
  char __size[32];
  long int __align;
} pthread_barrier_t;
typedef union
  char __size[4];
  int __align;
} pthread_barrierattr_t;
# 271 "/usr/include/sys/types.h" 2 3 4
# 41 "/usr/include/H5public.h" 2 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 1 3 4
# 34 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/syslimits.h" 1 3 4
# 168 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 143 "/usr/include/limits.h" 3 4
# 1 "/usr/include/bits/posix1_lim.h" 1 3 4
# 160 "/usr/include/bits/posix1_lim.h" 3 4
# 1 "/usr/include/bits/local_lim.h" 1 3 4
# 38 "/usr/include/bits/local_lim.h" 3 4
# 1 "/usr/include/linux/limits.h" 1 3 4
# 39 "/usr/include/bits/local_lim.h" 2 3 4
# 161 "/usr/include/bits/posix1_lim.h" 2 3 4
# 144 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/posix2_lim.h" 1 3 4
# 148 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/bits/xopen_lim.h" 1 3 4
# 33 "/usr/include/bits/xopen_lim.h" 3 4
# 1 "/usr/include/bits/stdio_lim.h" 1 3 4
# 34 "/usr/include/bits/xopen_lim.h" 2 3 4
# 152 "/usr/include/limits.h" 2 3 4
# 169 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 2 3 4
# 8 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/syslimits.h" 2 3 4
# 35 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/limits.h" 2 3 4
# 44 "/usr/include/H5public.h" 2 3 4
# 55 "/usr/include/H5public.h" 3 4
# 1 "/usr/include/inttypes.h" 1 3 4
# 27 "/usr/include/inttypes.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 1 3 4
# 9 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 26 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/bits/wchar.h" 1 3 4
# 27 "/usr/include/stdint.h" 2 3 4
# 28 "/usr/include/stdint.h" 2 3 4
# 48 "/usr/include/stdint.h" 3 4
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
# 65 "/usr/include/stdint.h" 3 4
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
# 90 "/usr/include/stdint.h" 3 4
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
# 103 "/usr/include/stdint.h" 3 4
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
# 119 "/usr/include/stdint.h" 3 4
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
# 134 "/usr/include/stdint.h" 3 4
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
# 10 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdint.h" 2 3 4
# 28 "/usr/include/inttypes.h" 2 3 4
# 266 "/usr/include/inttypes.h" 3 4
extern "C" {
typedef struct
    long int quot;
    long int rem;
  } imaxdiv_t;
# 290 "/usr/include/inttypes.h" 3 4
extern intmax_t imaxabs (intmax_t __n) throw () __attribute__ ((__const__));
extern imaxdiv_t imaxdiv (intmax_t __numer, intmax_t __denom)
extern intmax_t strtoimax (const char *__restrict __nptr,
      char **__restrict __endptr, int __base) throw ();
extern uintmax_t strtoumax (const char *__restrict __nptr,
       char ** __restrict __endptr, int __base) throw ();
extern intmax_t wcstoimax (const wchar_t *__restrict __nptr,
      wchar_t **__restrict __endptr, int __base)
     throw ();
extern uintmax_t wcstoumax (const wchar_t *__restrict __nptr,
       wchar_t ** __restrict __endptr, int __base)
     throw ();
# 432 "/usr/include/inttypes.h" 3 4
# 56 "/usr/include/H5public.h" 2 3 4
# 147 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 59 "/usr/include/H5public.h" 2 3 4
# 69 "/usr/include/H5public.h" 3 4
# 1 "/usr/include/H5api_adpt.h" 1 3 4
# 70 "/usr/include/H5public.h" 2 3 4
extern "C" {
# 126 "/usr/include/H5public.h" 3 4
typedef int herr_t;
# 144 "/usr/include/H5public.h" 3 4
typedef unsigned int hbool_t;
typedef int htri_t;
# 170 "/usr/include/H5public.h" 3 4
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "-Wlong-long"
typedef unsigned long long hsize_t;
typedef signed long long hssize_t;
# 173 "/usr/include/H5public.h" 3 4
#pragma GCC diagnostic pop
# 184 "/usr/include/H5public.h" 3 4
    typedef uint64_t haddr_t;
# 289 "/usr/include/H5public.h" 3 4
typedef enum {
    H5_ITER_UNKNOWN = -1,
    H5_ITER_INC,
    H5_ITER_DEC,
    H5_ITER_NATIVE,
    H5_ITER_N
} H5_iter_order_t;
# 310 "/usr/include/H5public.h" 3 4
typedef enum H5_index_t {
    H5_INDEX_UNKNOWN = -1,
    H5_INDEX_NAME,
    H5_INDEX_CRT_ORDER,
    H5_INDEX_N
} H5_index_t;
typedef struct H5_ih_info_t {
    hsize_t index_size;
    hsize_t heap_size;
} H5_ih_info_t;
 herr_t H5open(void);
 herr_t H5close(void);
 herr_t H5dont_atexit(void);
 herr_t H5garbage_collect(void);
 herr_t H5set_free_list_limits (int reg_global_lim, int reg_list_lim,
                int arr_global_lim, int arr_list_lim, int blk_global_lim,
                int blk_list_lim);
 herr_t H5get_libversion(unsigned *majnum, unsigned *minnum,
    unsigned *relnum);
 herr_t H5check_version(unsigned majnum, unsigned minnum,
          unsigned relnum);
 herr_t H5free_memory(void *mem);
# 25 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Apublic.h" 1 3 4
# 23 "/usr/include/H5Apublic.h" 3 4
# 1 "/usr/include/H5Ipublic.h" 1 3 4
# 36 "/usr/include/H5Ipublic.h" 3 4
typedef enum H5I_type_t {
    H5I_UNINIT = (-2),
    H5I_BADID = (-1),
    H5I_FILE = 1,
    H5I_GROUP,
    H5I_DATATYPE,
    H5I_DATASPACE,
    H5I_DATASET,
    H5I_ATTR,
    H5I_REFERENCE,
    H5I_VFL,
    H5I_GENPROP_CLS,
    H5I_GENPROP_LST,
    H5I_ERROR_CLASS,
    H5I_ERROR_MSG,
    H5I_ERROR_STACK,
    H5I_NTYPES
} H5I_type_t;
typedef int hid_t;
# 69 "/usr/include/H5Ipublic.h" 3 4
typedef herr_t (*H5I_free_t)(void*);
typedef int (*H5I_search_func_t)(void *obj, hid_t id, void *key);
extern "C" {
 hid_t H5Iregister(H5I_type_t type, const void *object);
 void *H5Iobject_verify(hid_t id, H5I_type_t id_type);
 void *H5Iremove_verify(hid_t id, H5I_type_t id_type);
 H5I_type_t H5Iget_type(hid_t id);
 hid_t H5Iget_file_id(hid_t id);
 ssize_t H5Iget_name(hid_t id, char *name , size_t size);
 int H5Iinc_ref(hid_t id);
 int H5Idec_ref(hid_t id);
 int H5Iget_ref(hid_t id);
 H5I_type_t H5Iregister_type(size_t hash_size, unsigned reserved, H5I_free_t free_func);
 herr_t H5Iclear_type(H5I_type_t type, hbool_t force);
 herr_t H5Idestroy_type(H5I_type_t type);
 int H5Iinc_type_ref(H5I_type_t type);
 int H5Idec_type_ref(H5I_type_t type);
 int H5Iget_type_ref(H5I_type_t type);
 void *H5Isearch(H5I_type_t type, H5I_search_func_t func, void *key);
 herr_t H5Inmembers(H5I_type_t type, hsize_t *num_members);
 htri_t H5Itype_exists(H5I_type_t type);
 htri_t H5Iis_valid(hid_t id);
# 24 "/usr/include/H5Apublic.h" 2 3 4
# 1 "/usr/include/H5Opublic.h" 1 3 4
# 33 "/usr/include/H5Opublic.h" 3 4
# 1 "/usr/include/H5Lpublic.h" 1 3 4
# 32 "/usr/include/H5Lpublic.h" 3 4
# 1 "/usr/include/H5Tpublic.h" 1 3 4
# 30 "/usr/include/H5Tpublic.h" 3 4
typedef enum H5T_class_t {
    H5T_NO_CLASS = -1,
    H5T_INTEGER = 0,
    H5T_FLOAT = 1,
    H5T_TIME = 2,
    H5T_STRING = 3,
    H5T_BITFIELD = 4,
    H5T_OPAQUE = 5,
    H5T_COMPOUND = 6,
    H5T_REFERENCE = 7,
    H5T_ENUM = 8,
    H5T_VLEN = 9,
    H5T_ARRAY = 10,
    H5T_NCLASSES
} H5T_class_t;
typedef enum H5T_order_t {
    H5T_ORDER_ERROR = -1,
    H5T_ORDER_LE = 0,
    H5T_ORDER_BE = 1,
    H5T_ORDER_VAX = 2,
    H5T_ORDER_MIXED = 3,
    H5T_ORDER_NONE = 4
} H5T_order_t;
typedef enum H5T_sign_t {
    H5T_SGN_ERROR = -1,
    H5T_SGN_NONE = 0,
    H5T_SGN_2 = 1,
    H5T_NSGN = 2
} H5T_sign_t;
typedef enum H5T_norm_t {
    H5T_NORM_ERROR = -1,
    H5T_NORM_IMPLIED = 0,
    H5T_NORM_MSBSET = 1,
    H5T_NORM_NONE = 2
} H5T_norm_t;
typedef enum H5T_cset_t {
    H5T_CSET_ERROR = -1,
    H5T_CSET_ASCII = 0,
    H5T_CSET_UTF8 = 1,
    H5T_CSET_RESERVED_2 = 2,
    H5T_CSET_RESERVED_3 = 3,
    H5T_CSET_RESERVED_4 = 4,
    H5T_CSET_RESERVED_5 = 5,
    H5T_CSET_RESERVED_6 = 6,
    H5T_CSET_RESERVED_7 = 7,
    H5T_CSET_RESERVED_8 = 8,
    H5T_CSET_RESERVED_9 = 9,
    H5T_CSET_RESERVED_10 = 10,
    H5T_CSET_RESERVED_11 = 11,
    H5T_CSET_RESERVED_12 = 12,
    H5T_CSET_RESERVED_13 = 13,
    H5T_CSET_RESERVED_14 = 14,
    H5T_CSET_RESERVED_15 = 15
} H5T_cset_t;
typedef enum H5T_str_t {
    H5T_STR_ERROR = -1,
    H5T_STR_NULLTERM = 0,
    H5T_STR_NULLPAD = 1,
    H5T_STR_SPACEPAD = 2,
    H5T_STR_RESERVED_3 = 3,
    H5T_STR_RESERVED_4 = 4,
    H5T_STR_RESERVED_5 = 5,
    H5T_STR_RESERVED_6 = 6,
    H5T_STR_RESERVED_7 = 7,
    H5T_STR_RESERVED_8 = 8,
    H5T_STR_RESERVED_9 = 9,
    H5T_STR_RESERVED_10 = 10,
    H5T_STR_RESERVED_11 = 11,
    H5T_STR_RESERVED_12 = 12,
    H5T_STR_RESERVED_13 = 13,
    H5T_STR_RESERVED_14 = 14,
    H5T_STR_RESERVED_15 = 15
} H5T_str_t;
typedef enum H5T_pad_t {
    H5T_PAD_ERROR = -1,
    H5T_PAD_ZERO = 0,
    H5T_PAD_ONE = 1,
    H5T_PAD_BACKGROUND = 2,
    H5T_NPAD = 3
} H5T_pad_t;
typedef enum H5T_cmd_t {
    H5T_CONV_INIT = 0,
    H5T_CONV_CONV = 1,
    H5T_CONV_FREE = 2
} H5T_cmd_t;
typedef enum H5T_bkg_t {
    H5T_BKG_NO = 0,
    H5T_BKG_TEMP = 1,
    H5T_BKG_YES = 2
} H5T_bkg_t;
typedef struct H5T_cdata_t {
    H5T_cmd_t command;
    H5T_bkg_t need_bkg;
    hbool_t recalc;
    void *priv;
} H5T_cdata_t;
typedef enum H5T_pers_t {
    H5T_PERS_DONTCARE = -1,
    H5T_PERS_HARD = 0,
    H5T_PERS_SOFT = 1
} H5T_pers_t;
typedef enum H5T_direction_t {
    H5T_DIR_DEFAULT = 0,
    H5T_DIR_ASCEND = 1,
    H5T_DIR_DESCEND = 2
} H5T_direction_t;
typedef enum H5T_conv_except_t {
    H5T_CONV_EXCEPT_RANGE_HI = 0,
    H5T_CONV_EXCEPT_RANGE_LOW = 1,
    H5T_CONV_EXCEPT_PRECISION = 2,
    H5T_CONV_EXCEPT_TRUNCATE = 3,
    H5T_CONV_EXCEPT_PINF = 4,
    H5T_CONV_EXCEPT_NINF = 5,
    H5T_CONV_EXCEPT_NAN = 6
} H5T_conv_except_t;
typedef enum H5T_conv_ret_t {
    H5T_CONV_ABORT = -1,
    H5T_CONV_UNHANDLED = 0,
    H5T_CONV_HANDLED = 1
} H5T_conv_ret_t;
typedef struct {
    size_t len;
    void *p;
} hvl_t;
# 205 "/usr/include/H5Tpublic.h" 3 4
extern "C" {
typedef herr_t (*H5T_conv_t) (hid_t src_id, hid_t dst_id, H5T_cdata_t *cdata,
      size_t nelmts, size_t buf_stride, size_t bkg_stride, void *buf,
      void *bkg, hid_t dset_xfer_plist);
typedef H5T_conv_ret_t (*H5T_conv_except_func_t)(H5T_conv_except_t except_type,
    hid_t src_id, hid_t dst_id, void *src_buf, void *dst_buf, void *user_data);
# 234 "/usr/include/H5Tpublic.h" 3 4
extern hid_t H5T_IEEE_F32BE_g;
extern hid_t H5T_IEEE_F32LE_g;
extern hid_t H5T_IEEE_F64BE_g;
extern hid_t H5T_IEEE_F64LE_g;
# 269 "/usr/include/H5Tpublic.h" 3 4
extern hid_t H5T_STD_I8BE_g;
extern hid_t H5T_STD_I8LE_g;
extern hid_t H5T_STD_I16BE_g;
extern hid_t H5T_STD_I16LE_g;
extern hid_t H5T_STD_I32BE_g;
extern hid_t H5T_STD_I32LE_g;
extern hid_t H5T_STD_I64BE_g;
extern hid_t H5T_STD_I64LE_g;
extern hid_t H5T_STD_U8BE_g;
extern hid_t H5T_STD_U8LE_g;
extern hid_t H5T_STD_U16BE_g;
extern hid_t H5T_STD_U16LE_g;
extern hid_t H5T_STD_U32BE_g;
extern hid_t H5T_STD_U32LE_g;
extern hid_t H5T_STD_U64BE_g;
extern hid_t H5T_STD_U64LE_g;
extern hid_t H5T_STD_B8BE_g;
extern hid_t H5T_STD_B8LE_g;
extern hid_t H5T_STD_B16BE_g;
extern hid_t H5T_STD_B16LE_g;
extern hid_t H5T_STD_B32BE_g;
extern hid_t H5T_STD_B32LE_g;
extern hid_t H5T_STD_B64BE_g;
extern hid_t H5T_STD_B64LE_g;
extern hid_t H5T_STD_REF_OBJ_g;
extern hid_t H5T_STD_REF_DSETREG_g;
# 303 "/usr/include/H5Tpublic.h" 3 4
extern hid_t H5T_UNIX_D32BE_g;
extern hid_t H5T_UNIX_D32LE_g;
extern hid_t H5T_UNIX_D64BE_g;
extern hid_t H5T_UNIX_D64LE_g;
extern hid_t H5T_C_S1_g;
extern hid_t H5T_FORTRAN_S1_g;
# 383 "/usr/include/H5Tpublic.h" 3 4
extern hid_t H5T_VAX_F32_g;
extern hid_t H5T_VAX_F64_g;
# 421 "/usr/include/H5Tpublic.h" 3 4
extern hid_t H5T_NATIVE_SCHAR_g;
extern hid_t H5T_NATIVE_UCHAR_g;
extern hid_t H5T_NATIVE_SHORT_g;
extern hid_t H5T_NATIVE_USHORT_g;
extern hid_t H5T_NATIVE_INT_g;
extern hid_t H5T_NATIVE_UINT_g;
extern hid_t H5T_NATIVE_LONG_g;
extern hid_t H5T_NATIVE_ULONG_g;
extern hid_t H5T_NATIVE_LLONG_g;
extern hid_t H5T_NATIVE_ULLONG_g;
extern hid_t H5T_NATIVE_FLOAT_g;
extern hid_t H5T_NATIVE_DOUBLE_g;
extern hid_t H5T_NATIVE_LDOUBLE_g;
extern hid_t H5T_NATIVE_B8_g;
extern hid_t H5T_NATIVE_B16_g;
extern hid_t H5T_NATIVE_B32_g;
extern hid_t H5T_NATIVE_B64_g;
extern hid_t H5T_NATIVE_OPAQUE_g;
extern hid_t H5T_NATIVE_HADDR_g;
extern hid_t H5T_NATIVE_HSIZE_g;
extern hid_t H5T_NATIVE_HSSIZE_g;
extern hid_t H5T_NATIVE_HERR_g;
extern hid_t H5T_NATIVE_HBOOL_g;
# 454 "/usr/include/H5Tpublic.h" 3 4
extern hid_t H5T_NATIVE_INT8_g;
extern hid_t H5T_NATIVE_UINT8_g;
extern hid_t H5T_NATIVE_INT_LEAST8_g;
extern hid_t H5T_NATIVE_UINT_LEAST8_g;
extern hid_t H5T_NATIVE_INT_FAST8_g;
extern hid_t H5T_NATIVE_UINT_FAST8_g;
extern hid_t H5T_NATIVE_INT16_g;
extern hid_t H5T_NATIVE_UINT16_g;
extern hid_t H5T_NATIVE_INT_LEAST16_g;
extern hid_t H5T_NATIVE_UINT_LEAST16_g;
extern hid_t H5T_NATIVE_INT_FAST16_g;
extern hid_t H5T_NATIVE_UINT_FAST16_g;
extern hid_t H5T_NATIVE_INT32_g;
extern hid_t H5T_NATIVE_UINT32_g;
extern hid_t H5T_NATIVE_INT_LEAST32_g;
extern hid_t H5T_NATIVE_UINT_LEAST32_g;
extern hid_t H5T_NATIVE_INT_FAST32_g;
extern hid_t H5T_NATIVE_UINT_FAST32_g;
extern hid_t H5T_NATIVE_INT64_g;
extern hid_t H5T_NATIVE_UINT64_g;
extern hid_t H5T_NATIVE_INT_LEAST64_g;
extern hid_t H5T_NATIVE_UINT_LEAST64_g;
extern hid_t H5T_NATIVE_INT_FAST64_g;
extern hid_t H5T_NATIVE_UINT_FAST64_g;
 hid_t H5Tcreate(H5T_class_t type, size_t size);
 hid_t H5Tcopy(hid_t type_id);
 herr_t H5Tclose(hid_t type_id);
 htri_t H5Tequal(hid_t type1_id, hid_t type2_id);
 herr_t H5Tlock(hid_t type_id);
 herr_t H5Tcommit2(hid_t loc_id, const char *name, hid_t type_id,
    hid_t lcpl_id, hid_t tcpl_id, hid_t tapl_id);
 hid_t H5Topen2(hid_t loc_id, const char *name, hid_t tapl_id);
 herr_t H5Tcommit_anon(hid_t loc_id, hid_t type_id, hid_t tcpl_id, hid_t tapl_id);
 hid_t H5Tget_create_plist(hid_t type_id);
 htri_t H5Tcommitted(hid_t type_id);
 herr_t H5Tencode(hid_t obj_id, void *buf, size_t *nalloc);
 hid_t H5Tdecode(const void *buf);
 herr_t H5Tinsert(hid_t parent_id, const char *name, size_t offset,
    hid_t member_id);
 herr_t H5Tpack(hid_t type_id);
 hid_t H5Tenum_create(hid_t base_id);
 herr_t H5Tenum_insert(hid_t type, const char *name, const void *value);
 herr_t H5Tenum_nameof(hid_t type, const void *value, char *name ,
        size_t size);
 herr_t H5Tenum_valueof(hid_t type, const char *name,
         void *value );
 hid_t H5Tvlen_create(hid_t base_id);
 hid_t H5Tarray_create2(hid_t base_id, unsigned ndims,
            const hsize_t dim[ ]);
 int H5Tget_array_ndims(hid_t type_id);
 int H5Tget_array_dims2(hid_t type_id, hsize_t dims[]);
 herr_t H5Tset_tag(hid_t type, const char *tag);
 char *H5Tget_tag(hid_t type);
 hid_t H5Tget_super(hid_t type);
 H5T_class_t H5Tget_class(hid_t type_id);
 htri_t H5Tdetect_class(hid_t type_id, H5T_class_t cls);
 size_t H5Tget_size(hid_t type_id);
 H5T_order_t H5Tget_order(hid_t type_id);
 size_t H5Tget_precision(hid_t type_id);
 int H5Tget_offset(hid_t type_id);
 herr_t H5Tget_pad(hid_t type_id, H5T_pad_t *lsb ,
     H5T_pad_t *msb );
 H5T_sign_t H5Tget_sign(hid_t type_id);
 herr_t H5Tget_fields(hid_t type_id, size_t *spos ,
        size_t *epos , size_t *esize ,
        size_t *mpos , size_t *msize );
 size_t H5Tget_ebias(hid_t type_id);
 H5T_norm_t H5Tget_norm(hid_t type_id);
 H5T_pad_t H5Tget_inpad(hid_t type_id);
 H5T_str_t H5Tget_strpad(hid_t type_id);
 int H5Tget_nmembers(hid_t type_id);
 char *H5Tget_member_name(hid_t type_id, unsigned membno);
 int H5Tget_member_index(hid_t type_id, const char *name);
 size_t H5Tget_member_offset(hid_t type_id, unsigned membno);
 H5T_class_t H5Tget_member_class(hid_t type_id, unsigned membno);
 hid_t H5Tget_member_type(hid_t type_id, unsigned membno);
 herr_t H5Tget_member_value(hid_t type_id, unsigned membno, void *value );
 H5T_cset_t H5Tget_cset(hid_t type_id);
 htri_t H5Tis_variable_str(hid_t type_id);
 hid_t H5Tget_native_type(hid_t type_id, H5T_direction_t direction);
 herr_t H5Tset_size(hid_t type_id, size_t size);
 herr_t H5Tset_order(hid_t type_id, H5T_order_t order);
 herr_t H5Tset_precision(hid_t type_id, size_t prec);
 herr_t H5Tset_offset(hid_t type_id, size_t offset);
 herr_t H5Tset_pad(hid_t type_id, H5T_pad_t lsb, H5T_pad_t msb);
 herr_t H5Tset_sign(hid_t type_id, H5T_sign_t sign);
 herr_t H5Tset_fields(hid_t type_id, size_t spos, size_t epos,
        size_t esize, size_t mpos, size_t msize);
 herr_t H5Tset_ebias(hid_t type_id, size_t ebias);
 herr_t H5Tset_norm(hid_t type_id, H5T_norm_t norm);
 herr_t H5Tset_inpad(hid_t type_id, H5T_pad_t pad);
 herr_t H5Tset_cset(hid_t type_id, H5T_cset_t cset);
 herr_t H5Tset_strpad(hid_t type_id, H5T_str_t strpad);
 herr_t H5Tregister(H5T_pers_t pers, const char *name, hid_t src_id,
      hid_t dst_id, H5T_conv_t func);
 herr_t H5Tunregister(H5T_pers_t pers, const char *name, hid_t src_id,
 H5T_conv_t H5Tfind(hid_t src_id, hid_t dst_id, H5T_cdata_t **pcdata);
 htri_t H5Tcompiler_conv(hid_t src_id, hid_t dst_id);
 herr_t H5Tconvert(hid_t src_id, hid_t dst_id, size_t nelmts,
     void *buf, void *background, hid_t plist_id);
# 608 "/usr/include/H5Tpublic.h" 3 4
 herr_t H5Tcommit1(hid_t loc_id, const char *name, hid_t type_id);
 hid_t H5Topen1(hid_t loc_id, const char *name);
 hid_t H5Tarray_create1(hid_t base_id, int ndims,
            const hsize_t dim[ ],
            const int perm[ ]);
 int H5Tget_array_dims1(hid_t type_id, hsize_t dims[], int perm[]);
# 33 "/usr/include/H5Lpublic.h" 2 3 4
# 49 "/usr/include/H5Lpublic.h" 3 4
extern "C" {
# 64 "/usr/include/H5Lpublic.h" 3 4
typedef enum {
    H5L_TYPE_ERROR = (-1),
    H5L_TYPE_HARD = 0,
    H5L_TYPE_SOFT = 1,
    H5L_TYPE_EXTERNAL = 64,
    H5L_TYPE_MAX = 255
} H5L_type_t;
typedef struct {
    H5L_type_t type;
    hbool_t corder_valid;
    int64_t corder;
    H5T_cset_t cset;
    union {
        haddr_t address;
        size_t val_size;
    } u;
} H5L_info_t;
typedef herr_t (*H5L_create_func_t)(const char *link_name, hid_t loc_group,
    const void *lnkdata, size_t lnkdata_size, hid_t lcpl_id);
typedef herr_t (*H5L_move_func_t)(const char *new_name, hid_t new_loc,
    const void *lnkdata, size_t lnkdata_size);
typedef herr_t (*H5L_copy_func_t)(const char *new_name, hid_t new_loc,
typedef herr_t (*H5L_traverse_func_t)(const char *link_name, hid_t cur_group,
    const void *lnkdata, size_t lnkdata_size, hid_t lapl_id);
typedef herr_t (*H5L_delete_func_t)(const char *link_name, hid_t file,
typedef ssize_t (*H5L_query_func_t)(const char *link_name, const void *lnkdata,
    size_t lnkdata_size, void *buf , size_t buf_size);
typedef struct {
    int version;
    H5L_type_t id;
    const char *comment;
    H5L_create_func_t create_func;
    H5L_move_func_t move_func;
    H5L_copy_func_t copy_func;
    H5L_traverse_func_t trav_func;
    H5L_delete_func_t del_func;
    H5L_query_func_t query_func;
} H5L_class_t;
typedef herr_t (*H5L_iterate_t)(hid_t group, const char *name, const H5L_info_t *info,
    void *op_data);
typedef herr_t (*H5L_elink_traverse_t)(const char *parent_file_name,
    const char *parent_group_name, const char *child_file_name,
    const char *child_object_name, unsigned *acc_flags, hid_t fapl_id,
    void *op_data);
# 148 "/usr/include/H5Lpublic.h" 3 4
 herr_t H5Lmove(hid_t src_loc, const char *src_name, hid_t dst_loc,
    const char *dst_name, hid_t lcpl_id, hid_t lapl_id);
 herr_t H5Lcopy(hid_t src_loc, const char *src_name, hid_t dst_loc,
 herr_t H5Lcreate_hard(hid_t cur_loc, const char *cur_name,
    hid_t dst_loc, const char *dst_name, hid_t lcpl_id, hid_t lapl_id);
 herr_t H5Lcreate_soft(const char *link_target, hid_t link_loc_id,
    const char *link_name, hid_t lcpl_id, hid_t lapl_id);
 herr_t H5Ldelete(hid_t loc_id, const char *name, hid_t lapl_id);
 herr_t H5Ldelete_by_idx(hid_t loc_id, const char *group_name,
    H5_index_t idx_type, H5_iter_order_t order, hsize_t n, hid_t lapl_id);
 herr_t H5Lget_val(hid_t loc_id, const char *name, void *buf ,
    size_t size, hid_t lapl_id);
 herr_t H5Lget_val_by_idx(hid_t loc_id, const char *group_name,
    void *buf , size_t size, hid_t lapl_id);
 htri_t H5Lexists(hid_t loc_id, const char *name, hid_t lapl_id);
 herr_t H5Lget_info(hid_t loc_id, const char *name,
    H5L_info_t *linfo , hid_t lapl_id);
 herr_t H5Lget_info_by_idx(hid_t loc_id, const char *group_name,
 ssize_t H5Lget_name_by_idx(hid_t loc_id, const char *group_name,
    char *name , size_t size, hid_t lapl_id);
 herr_t H5Literate(hid_t grp_id, H5_index_t idx_type,
    H5_iter_order_t order, hsize_t *idx, H5L_iterate_t op, void *op_data);
 herr_t H5Literate_by_name(hid_t loc_id, const char *group_name,
    H5_index_t idx_type, H5_iter_order_t order, hsize_t *idx,
    H5L_iterate_t op, void *op_data, hid_t lapl_id);
 herr_t H5Lvisit(hid_t grp_id, H5_index_t idx_type, H5_iter_order_t order,
 herr_t H5Lvisit_by_name(hid_t loc_id, const char *group_name,
    H5_index_t idx_type, H5_iter_order_t order, H5L_iterate_t op,
 herr_t H5Lcreate_ud(hid_t link_loc_id, const char *link_name,
    H5L_type_t link_type, const void *udata, size_t udata_size, hid_t lcpl_id,
    hid_t lapl_id);
 herr_t H5Lregister(const H5L_class_t *cls);
 herr_t H5Lunregister(H5L_type_t id);
 htri_t H5Lis_registered(H5L_type_t id);
 herr_t H5Lunpack_elink_val(const void *ext_linkval , size_t link_size,
   unsigned *flags, const char **filename , const char **obj_path );
 herr_t H5Lcreate_external(const char *file_name, const char *obj_name,
    hid_t link_loc_id, const char *link_name, hid_t lcpl_id, hid_t lapl_id);
# 34 "/usr/include/H5Opublic.h" 2 3 4
# 83 "/usr/include/H5Opublic.h" 3 4
typedef enum H5O_type_t {
    H5O_TYPE_UNKNOWN = -1,
    H5O_TYPE_GROUP,
    H5O_TYPE_DATASET,
    H5O_TYPE_NAMED_DATATYPE,
    H5O_TYPE_NTYPES
} H5O_type_t;
typedef struct H5O_hdr_info_t {
    unsigned version;
    unsigned nmesgs;
    unsigned nchunks;
    unsigned flags;
    struct {
        hsize_t total;
        hsize_t meta;
        hsize_t mesg;
        hsize_t free;
    } space;
    struct {
        uint64_t present;
        uint64_t shared;
    } mesg;
} H5O_hdr_info_t;
typedef struct H5O_info_t {
    unsigned long fileno;
    haddr_t addr;
    H5O_type_t type;
    unsigned rc;
    time_t atime;
    time_t mtime;
    time_t ctime;
    time_t btime;
    hsize_t num_attrs;
    H5O_hdr_info_t hdr;
    struct {
        H5_ih_info_t obj;
        H5_ih_info_t attr;
    } meta_size;
} H5O_info_t;
typedef uint32_t H5O_msg_crt_idx_t;
typedef herr_t (*H5O_iterate_t)(hid_t obj, const char *name, const H5O_info_t *info,
    void *op_data);
typedef enum H5O_mcdt_search_ret_t {
    H5O_MCDT_SEARCH_ERROR = -1,
    H5O_MCDT_SEARCH_CONT,
    H5O_MCDT_SEARCH_STOP
} H5O_mcdt_search_ret_t;
typedef H5O_mcdt_search_ret_t (*H5O_mcdt_search_cb_t)(void *op_data);
extern "C" {
 hid_t H5Oopen(hid_t loc_id, const char *name, hid_t lapl_id);
 hid_t H5Oopen_by_addr(hid_t loc_id, haddr_t addr);
 hid_t H5Oopen_by_idx(hid_t loc_id, const char *group_name,
 htri_t H5Oexists_by_name(hid_t loc_id, const char *name, hid_t lapl_id);
 herr_t H5Oget_info(hid_t loc_id, H5O_info_t *oinfo);
 herr_t H5Oget_info_by_name(hid_t loc_id, const char *name, H5O_info_t *oinfo,
    hid_t lapl_id);
 herr_t H5Oget_info_by_idx(hid_t loc_id, const char *group_name,
    H5_index_t idx_type, H5_iter_order_t order, hsize_t n, H5O_info_t *oinfo,
    hid_t lapl_id);
 herr_t H5Olink(hid_t obj_id, hid_t new_loc_id, const char *new_name,
 herr_t H5Oincr_refcount(hid_t object_id);
 herr_t H5Odecr_refcount(hid_t object_id);
 herr_t H5Ocopy(hid_t src_loc_id, const char *src_name, hid_t dst_loc_id,
    const char *dst_name, hid_t ocpypl_id, hid_t lcpl_id);
 herr_t H5Oset_comment(hid_t obj_id, const char *comment);
 herr_t H5Oset_comment_by_name(hid_t loc_id, const char *name,
    const char *comment, hid_t lapl_id);
 ssize_t H5Oget_comment(hid_t obj_id, char *comment, size_t bufsize);
 ssize_t H5Oget_comment_by_name(hid_t loc_id, const char *name,
    char *comment, size_t bufsize, hid_t lapl_id);
 herr_t H5Ovisit(hid_t obj_id, H5_index_t idx_type, H5_iter_order_t order,
    H5O_iterate_t op, void *op_data);
 herr_t H5Ovisit_by_name(hid_t loc_id, const char *obj_name,
    H5_index_t idx_type, H5_iter_order_t order, H5O_iterate_t op,
 herr_t H5Oclose(hid_t object_id);
# 197 "/usr/include/H5Opublic.h" 3 4
typedef struct H5O_stat_t {
    hsize_t size;
    hsize_t free;
    unsigned nmesgs;
    unsigned nchunks;
} H5O_stat_t;
# 25 "/usr/include/H5Apublic.h" 2 3 4
extern "C" {
typedef struct {
    H5O_msg_crt_idx_t corder;
    H5T_cset_t cset;
    hsize_t data_size;
} H5A_info_t;
typedef herr_t (*H5A_operator2_t)(hid_t location_id ,
    const char *attr_name , const H5A_info_t *ainfo , void *op_data );
 hid_t H5Acreate2(hid_t loc_id, const char *attr_name, hid_t type_id,
    hid_t space_id, hid_t acpl_id, hid_t aapl_id);
 hid_t H5Acreate_by_name(hid_t loc_id, const char *obj_name, const char *attr_name,
    hid_t type_id, hid_t space_id, hid_t acpl_id, hid_t aapl_id, hid_t lapl_id);
 hid_t H5Aopen(hid_t obj_id, const char *attr_name, hid_t aapl_id);
 hid_t H5Aopen_by_name(hid_t loc_id, const char *obj_name,
    const char *attr_name, hid_t aapl_id, hid_t lapl_id);
 hid_t H5Aopen_by_idx(hid_t loc_id, const char *obj_name,
    H5_index_t idx_type, H5_iter_order_t order, hsize_t n, hid_t aapl_id,
    hid_t lapl_id);
 herr_t H5Awrite(hid_t attr_id, hid_t type_id, const void *buf);
 herr_t H5Aread(hid_t attr_id, hid_t type_id, void *buf);
 herr_t H5Aclose(hid_t attr_id);
 hid_t H5Aget_space(hid_t attr_id);
 hid_t H5Aget_type(hid_t attr_id);
 hid_t H5Aget_create_plist(hid_t attr_id);
 ssize_t H5Aget_name(hid_t attr_id, size_t buf_size, char *buf);
 ssize_t H5Aget_name_by_idx(hid_t loc_id, const char *obj_name,
 hsize_t H5Aget_storage_size(hid_t attr_id);
 herr_t H5Aget_info(hid_t attr_id, H5A_info_t *ainfo );
 herr_t H5Aget_info_by_name(hid_t loc_id, const char *obj_name,
    const char *attr_name, H5A_info_t *ainfo , hid_t lapl_id);
 herr_t H5Aget_info_by_idx(hid_t loc_id, const char *obj_name,
 herr_t H5Arename(hid_t loc_id, const char *old_name, const char *new_name);
 herr_t H5Arename_by_name(hid_t loc_id, const char *obj_name,
    const char *old_attr_name, const char *new_attr_name, hid_t lapl_id);
 herr_t H5Aiterate2(hid_t loc_id, H5_index_t idx_type,
    H5_iter_order_t order, hsize_t *idx, H5A_operator2_t op, void *op_data);
 herr_t H5Aiterate_by_name(hid_t loc_id, const char *obj_name, H5_index_t idx_type,
    H5_iter_order_t order, hsize_t *idx, H5A_operator2_t op, void *op_data,
    hid_t lapd_id);
 herr_t H5Adelete(hid_t loc_id, const char *name);
 herr_t H5Adelete_by_name(hid_t loc_id, const char *obj_name,
    const char *attr_name, hid_t lapl_id);
 herr_t H5Adelete_by_idx(hid_t loc_id, const char *obj_name,
 htri_t H5Aexists(hid_t obj_id, const char *attr_name);
 htri_t H5Aexists_by_name(hid_t obj_id, const char *obj_name,
# 100 "/usr/include/H5Apublic.h" 3 4
typedef herr_t (*H5A_operator1_t)(hid_t location_id ,
    const char *attr_name , void *operator_data );
 hid_t H5Acreate1(hid_t loc_id, const char *name, hid_t type_id,
    hid_t space_id, hid_t acpl_id);
 hid_t H5Aopen_name(hid_t loc_id, const char *name);
 hid_t H5Aopen_idx(hid_t loc_id, unsigned idx);
 int H5Aget_num_attrs(hid_t loc_id);
 herr_t H5Aiterate1(hid_t loc_id, unsigned *attr_num, H5A_operator1_t op,
    void *op_data);
# 26 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5ACpublic.h" 1 3 4
# 33 "/usr/include/H5ACpublic.h" 3 4
# 1 "/usr/include/H5Cpublic.h" 1 3 4
# 35 "/usr/include/H5Cpublic.h" 3 4
extern "C" {
enum H5C_cache_incr_mode
    H5C_incr__off,
    H5C_incr__threshold
enum H5C_cache_flash_incr_mode
     H5C_flash_incr__off,
     H5C_flash_incr__add_space
enum H5C_cache_decr_mode
    H5C_decr__off,
    H5C_decr__threshold,
    H5C_decr__age_out,
    H5C_decr__age_out_with_threshold
# 34 "/usr/include/H5ACpublic.h" 2 3 4
extern "C" {
# 443 "/usr/include/H5ACpublic.h" 3 4
typedef struct H5AC_cache_config_t
    int version;
    hbool_t rpt_fcn_enabled;
    hbool_t open_trace_file;
    hbool_t close_trace_file;
    char trace_file_name[1024 + 1];
    hbool_t evictions_enabled;
    hbool_t set_initial_size;
    size_t initial_size;
    double min_clean_fraction;
    size_t max_size;
    size_t min_size;
    long int epoch_length;
    enum H5C_cache_incr_mode incr_mode;
    double lower_hr_threshold;
    double increment;
    hbool_t apply_max_increment;
    size_t max_increment;
    enum H5C_cache_flash_incr_mode flash_incr_mode;
    double flash_multiple;
    double flash_threshold;
    enum H5C_cache_decr_mode decr_mode;
    double upper_hr_threshold;
    double decrement;
    hbool_t apply_max_decrement;
    size_t max_decrement;
    int epochs_before_eviction;
    hbool_t apply_empty_reserve;
    double empty_reserve;
    int dirty_bytes_threshold;
    int metadata_write_strategy;
} H5AC_cache_config_t;
# 27 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Dpublic.h" 1 3 4
# 48 "/usr/include/H5Dpublic.h" 3 4
typedef enum H5D_layout_t {
    H5D_LAYOUT_ERROR = -1,
    H5D_COMPACT = 0,
    H5D_CONTIGUOUS = 1,
    H5D_CHUNKED = 2,
    H5D_NLAYOUTS = 3
} H5D_layout_t;
typedef enum H5D_chunk_index_t {
    H5D_CHUNK_BTREE = 0
} H5D_chunk_index_t;
typedef enum H5D_alloc_time_t {
    H5D_ALLOC_TIME_ERROR = -1,
    H5D_ALLOC_TIME_DEFAULT = 0,
    H5D_ALLOC_TIME_EARLY = 1,
    H5D_ALLOC_TIME_LATE = 2,
    H5D_ALLOC_TIME_INCR = 3
} H5D_alloc_time_t;
typedef enum H5D_space_status_t {
    H5D_SPACE_STATUS_ERROR = -1,
    H5D_SPACE_STATUS_NOT_ALLOCATED = 0,
    H5D_SPACE_STATUS_PART_ALLOCATED = 1,
    H5D_SPACE_STATUS_ALLOCATED = 2
} H5D_space_status_t;
typedef enum H5D_fill_time_t {
    H5D_FILL_TIME_ERROR = -1,
    H5D_FILL_TIME_ALLOC = 0,
    H5D_FILL_TIME_NEVER = 1,
    H5D_FILL_TIME_IFSET = 2
} H5D_fill_time_t;
typedef enum H5D_fill_value_t {
    H5D_FILL_VALUE_ERROR =-1,
    H5D_FILL_VALUE_UNDEFINED =0,
    H5D_FILL_VALUE_DEFAULT =1,
    H5D_FILL_VALUE_USER_DEFINED =2
} H5D_fill_value_t;
# 103 "/usr/include/H5Dpublic.h" 3 4
extern "C" {
typedef herr_t (*H5D_operator_t)(void *elem, hid_t type_id, unsigned ndim,
     const hsize_t *point, void *operator_data);
typedef herr_t (*H5D_scatter_func_t)(const void **src_buf ,
                                     size_t *src_buf_bytes_used ,
                                     void *op_data);
typedef herr_t (*H5D_gather_func_t)(const void *dst_buf,
                                    size_t dst_buf_bytes_used, void *op_data);
 hid_t H5Dcreate2(hid_t loc_id, const char *name, hid_t type_id,
    hid_t space_id, hid_t lcpl_id, hid_t dcpl_id, hid_t dapl_id);
 hid_t H5Dcreate_anon(hid_t file_id, hid_t type_id, hid_t space_id,
    hid_t plist_id, hid_t dapl_id);
 hid_t H5Dopen2(hid_t file_id, const char *name, hid_t dapl_id);
 herr_t H5Dclose(hid_t dset_id);
 hid_t H5Dget_space(hid_t dset_id);
 herr_t H5Dget_space_status(hid_t dset_id, H5D_space_status_t *allocation);
 hid_t H5Dget_type(hid_t dset_id);
 hid_t H5Dget_create_plist(hid_t dset_id);
 hid_t H5Dget_access_plist(hid_t dset_id);
 hsize_t H5Dget_storage_size(hid_t dset_id);
 haddr_t H5Dget_offset(hid_t dset_id);
 herr_t H5Dread(hid_t dset_id, hid_t mem_type_id, hid_t mem_space_id,
   hid_t file_space_id, hid_t plist_id, void *buf );
 herr_t H5Dwrite(hid_t dset_id, hid_t mem_type_id, hid_t mem_space_id,
    hid_t file_space_id, hid_t plist_id, const void *buf);
 herr_t H5Diterate(void *buf, hid_t type_id, hid_t space_id,
            H5D_operator_t op, void *operator_data);
 herr_t H5Dvlen_reclaim(hid_t type_id, hid_t space_id, hid_t plist_id, void *buf);
 herr_t H5Dvlen_get_buf_size(hid_t dataset_id, hid_t type_id, hid_t space_id, hsize_t *size);
 herr_t H5Dfill(const void *fill, hid_t fill_type, void *buf,
        hid_t buf_type, hid_t space);
 herr_t H5Dset_extent(hid_t dset_id, const hsize_t size[]);
 herr_t H5Dscatter(H5D_scatter_func_t op, void *op_data, hid_t type_id,
    hid_t dst_space_id, void *dst_buf);
 herr_t H5Dgather(hid_t src_space_id, const void *src_buf, hid_t type_id,
    size_t dst_buf_size, void *dst_buf, H5D_gather_func_t op, void *op_data);
 herr_t H5Ddebug(hid_t dset_id);
# 162 "/usr/include/H5Dpublic.h" 3 4
 hid_t H5Dcreate1(hid_t file_id, const char *name, hid_t type_id,
    hid_t space_id, hid_t dcpl_id);
 hid_t H5Dopen1(hid_t file_id, const char *name);
 herr_t H5Dextend(hid_t dset_id, const hsize_t size[]);
# 28 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Epublic.h" 1 3 4
# 22 "/usr/include/H5Epublic.h" 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 29 "/usr/include/stdio.h" 3 4
extern "C" {
# 34 "/usr/include/stdio.h" 2 3 4
# 44 "/usr/include/stdio.h" 3 4
struct _IO_FILE;
typedef struct _IO_FILE FILE;
# 64 "/usr/include/stdio.h" 3 4
typedef struct _IO_FILE __FILE;
# 74 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/libio.h" 1 3 4
# 31 "/usr/include/libio.h" 3 4
# 1 "/usr/include/_G_config.h" 1 3 4
# 15 "/usr/include/_G_config.h" 3 4
# 16 "/usr/include/_G_config.h" 2 3 4
# 1 "/usr/include/wchar.h" 1 3 4
# 82 "/usr/include/wchar.h" 3 4
typedef struct
  int __count;
  union
    unsigned int __wch;
    char __wchb[4];
  } __value;
} __mbstate_t;
# 21 "/usr/include/_G_config.h" 2 3 4
typedef struct
  __off_t __pos;
  __mbstate_t __state;
} _G_fpos_t;
typedef struct
  __off64_t __pos;
} _G_fpos64_t;
# 32 "/usr/include/libio.h" 2 3 4
# 49 "/usr/include/libio.h" 3 4
# 1 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 1 3 4
# 40 "/usr/lib/gcc/x86_64-redhat-linux/4.9.2/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 50 "/usr/include/libio.h" 2 3 4
# 144 "/usr/include/libio.h" 3 4
struct _IO_jump_t; struct _IO_FILE;
# 154 "/usr/include/libio.h" 3 4
typedef void _IO_lock_t;
struct _IO_marker {
  struct _IO_marker *_next;
  struct _IO_FILE *_sbuf;
  int _pos;
# 177 "/usr/include/libio.h" 3 4
enum __codecvt_result
  __codecvt_ok,
  __codecvt_partial,
  __codecvt_error,
  __codecvt_noconv
# 245 "/usr/include/libio.h" 3 4
struct _IO_FILE {
  int _flags;
  char* _IO_read_ptr;
  char* _IO_read_end;
  char* _IO_read_base;
  char* _IO_write_base;
  char* _IO_write_ptr;
  char* _IO_write_end;
  char* _IO_buf_base;
  char* _IO_buf_end;
  char *_IO_save_base;
  char *_IO_backup_base;
  char *_IO_save_end;
  struct _IO_marker *_markers;
  struct _IO_FILE *_chain;
  int _fileno;
  int _flags2;
  __off_t _old_offset;
  unsigned short _cur_column;
  signed char _vtable_offset;
  char _shortbuf[1];
  _IO_lock_t *_lock;
# 293 "/usr/include/libio.h" 3 4
  __off64_t _offset;
# 302 "/usr/include/libio.h" 3 4
  void *__pad1;
  void *__pad2;
  void *__pad3;
  void *__pad4;
  size_t __pad5;
  int _mode;
  char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
# 338 "/usr/include/libio.h" 3 4
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
     size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
typedef __io_read_fn cookie_read_function_t;
typedef __io_write_fn cookie_write_function_t;
typedef __io_seek_fn cookie_seek_function_t;
typedef __io_close_fn cookie_close_function_t;
typedef struct
  __io_read_fn *read;
  __io_write_fn *write;
  __io_seek_fn *seek;
  __io_close_fn *close;
} _IO_cookie_io_functions_t;
typedef _IO_cookie_io_functions_t cookie_io_functions_t;
struct _IO_cookie_file;
extern void _IO_cookie_init (struct _IO_cookie_file *__cfile, int __read_write,
        void *__cookie, _IO_cookie_io_functions_t __fns);
extern "C" {
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
# 434 "/usr/include/libio.h" 3 4
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) throw ();
extern int _IO_ferror (_IO_FILE *__fp) throw ();
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) throw ();
extern void _IO_funlockfile (_IO_FILE *) throw ();
extern int _IO_ftrylockfile (_IO_FILE *) throw ();
# 464 "/usr/include/libio.h" 3 4
extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
   __gnuc_va_list, int *__restrict);
extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
    __gnuc_va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) throw ();
# 526 "/usr/include/libio.h" 3 4
# 75 "/usr/include/stdio.h" 2 3 4
typedef __gnuc_va_list va_list;
# 108 "/usr/include/stdio.h" 3 4
typedef _G_fpos_t fpos_t;
typedef _G_fpos64_t fpos64_t;
# 164 "/usr/include/stdio.h" 3 4
# 165 "/usr/include/stdio.h" 2 3 4
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) throw ();
extern int rename (const char *__old, const char *__new) throw ();
extern int renameat (int __oldfd, const char *__old, int __newfd,
extern FILE *tmpfile (void) ;
# 205 "/usr/include/stdio.h" 3 4
extern FILE *tmpfile64 (void) ;
extern char *tmpnam (char *__s) throw () ;
extern char *tmpnam_r (char *__s) throw () ;
# 227 "/usr/include/stdio.h" 3 4
extern char *tempnam (const char *__dir, const char *__pfx)
     throw () __attribute__ ((__malloc__)) ;
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
# 252 "/usr/include/stdio.h" 3 4
extern int fflush_unlocked (FILE *__stream);
# 262 "/usr/include/stdio.h" 3 4
extern int fcloseall (void);
extern FILE *fopen (const char *__restrict __filename,
      const char *__restrict __modes) ;
extern FILE *freopen (const char *__restrict __filename,
        const char *__restrict __modes,
        FILE *__restrict __stream) ;
# 295 "/usr/include/stdio.h" 3 4
extern FILE *fopen64 (const char *__restrict __filename,
extern FILE *freopen64 (const char *__restrict __filename,
extern FILE *fdopen (int __fd, const char *__modes) throw () ;
extern FILE *fopencookie (void *__restrict __magic_cookie,
     _IO_cookie_io_functions_t __io_funcs) throw () ;
extern FILE *fmemopen (void *__s, size_t __len, const char *__modes)
  throw () ;
extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) throw () ;
extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) throw ();
extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
      int __modes, size_t __n) throw ();
extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
         size_t __size) throw ();
extern void setlinebuf (FILE *__stream) throw ();
extern int fprintf (FILE *__restrict __stream,
      const char *__restrict __format, ...);
extern int printf (const char *__restrict __format, ...);
extern int sprintf (char *__restrict __s,
      const char *__restrict __format, ...) throw ();
extern int vfprintf (FILE *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg);
extern int vprintf (const char *__restrict __format, __gnuc_va_list __arg);
extern int vsprintf (char *__restrict __s, const char *__restrict __format,
       __gnuc_va_list __arg) throw ();
extern int snprintf (char *__restrict __s, size_t __maxlen,
     throw () __attribute__ ((__format__ (__printf__, 3, 4)));
extern int vsnprintf (char *__restrict __s, size_t __maxlen,
     throw () __attribute__ ((__format__ (__printf__, 3, 0)));
extern int vasprintf (char **__restrict __ptr, const char *__restrict __f,
     throw () __attribute__ ((__format__ (__printf__, 2, 0))) ;
extern int __asprintf (char **__restrict __ptr,
         const char *__restrict __fmt, ...)
     throw () __attribute__ ((__format__ (__printf__, 2, 3))) ;
extern int asprintf (char **__restrict __ptr,
extern int vdprintf (int __fd, const char *__restrict __fmt,
     __attribute__ ((__format__ (__printf__, 2, 0)));
extern int dprintf (int __fd, const char *__restrict __fmt, ...)
     __attribute__ ((__format__ (__printf__, 2, 3)));
extern int fscanf (FILE *__restrict __stream,
     const char *__restrict __format, ...) ;
extern int scanf (const char *__restrict __format, ...) ;
extern int sscanf (const char *__restrict __s,
# 463 "/usr/include/stdio.h" 3 4
extern int vfscanf (FILE *__restrict __s, const char *__restrict __format,
     __attribute__ ((__format__ (__scanf__, 2, 0))) ;
extern int vscanf (const char *__restrict __format, __gnuc_va_list __arg)
     __attribute__ ((__format__ (__scanf__, 1, 0))) ;
extern int vsscanf (const char *__restrict __s,
     throw () __attribute__ ((__format__ (__scanf__, 2, 0)));
# 522 "/usr/include/stdio.h" 3 4
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
# 550 "/usr/include/stdio.h" 3 4
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
# 561 "/usr/include/stdio.h" 3 4
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
# 594 "/usr/include/stdio.h" 3 4
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
# 638 "/usr/include/stdio.h" 3 4
extern char *gets (char *__s) __attribute__ ((__deprecated__));
# 649 "/usr/include/stdio.h" 3 4
extern char *fgets_unlocked (char *__restrict __s, int __n,
# 665 "/usr/include/stdio.h" 3 4
extern __ssize_t __getdelim (char **__restrict __lineptr,
          size_t *__restrict __n, int __delimiter,
extern __ssize_t getdelim (char **__restrict __lineptr,
extern __ssize_t getline (char **__restrict __lineptr,
extern int fputs (const char *__restrict __s, FILE *__restrict __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void *__restrict __ptr, size_t __size,
       size_t __n, FILE *__restrict __stream) ;
extern size_t fwrite (const void *__restrict __ptr, size_t __size,
        size_t __n, FILE *__restrict __s);
# 726 "/usr/include/stdio.h" 3 4
extern int fputs_unlocked (const char *__restrict __s,
# 737 "/usr/include/stdio.h" 3 4
extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
extern size_t fwrite_unlocked (const void *__restrict __ptr, size_t __size,
          size_t __n, FILE *__restrict __stream);
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
# 773 "/usr/include/stdio.h" 3 4
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
# 792 "/usr/include/stdio.h" 3 4
extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
# 815 "/usr/include/stdio.h" 3 4
extern int fseeko64 (FILE *__stream, __off64_t __off, int __whence);
extern __off64_t ftello64 (FILE *__stream) ;
extern int fgetpos64 (FILE *__restrict __stream, fpos64_t *__restrict __pos);
extern int fsetpos64 (FILE *__stream, const fpos64_t *__pos);
extern void clearerr (FILE *__stream) throw ();
extern int feof (FILE *__stream) throw () ;
extern int ferror (FILE *__stream) throw () ;
extern void clearerr_unlocked (FILE *__stream) throw ();
extern int feof_unlocked (FILE *__stream) throw () ;
extern int ferror_unlocked (FILE *__stream) throw () ;
extern void perror (const char *__s);
# 1 "/usr/include/bits/sys_errlist.h" 1 3 4
# 26 "/usr/include/bits/sys_errlist.h" 3 4
extern int sys_nerr;
extern const char *const sys_errlist[];
extern int _sys_nerr;
extern const char *const _sys_errlist[];
# 854 "/usr/include/stdio.h" 2 3 4
extern int fileno (FILE *__stream) throw () ;
extern int fileno_unlocked (FILE *__stream) throw () ;
# 872 "/usr/include/stdio.h" 3 4
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) throw ();
extern char *cuserid (char *__s);
struct obstack;
extern int obstack_printf (struct obstack *__restrict __obstack,
     throw () __attribute__ ((__format__ (__printf__, 2, 3)));
extern int obstack_vprintf (struct obstack *__restrict __obstack,
       __gnuc_va_list __args)
     throw () __attribute__ ((__format__ (__printf__, 2, 0)));
extern void flockfile (FILE *__stream) throw ();
extern int ftrylockfile (FILE *__stream) throw () ;
extern void funlockfile (FILE *__stream) throw ();
# 942 "/usr/include/stdio.h" 3 4
# 23 "/usr/include/H5Epublic.h" 2 3 4
# 32 "/usr/include/H5Epublic.h" 3 4
typedef enum H5E_type_t {
    H5E_MAJOR,
    H5E_MINOR
} H5E_type_t;
typedef struct H5E_error2_t {
    hid_t cls_id;
    hid_t maj_num;
    hid_t min_num;
    unsigned line;
    const char *func_name;
    const char *file_name;
    const char *desc;
} H5E_error2_t;
# 58 "/usr/include/H5Epublic.h" 3 4
extern hid_t H5E_ERR_CLS_g;
# 1 "/usr/include/H5Epubgen.h" 1 3 4
# 58 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_DATASET_g;
extern hid_t H5E_FUNC_g;
extern hid_t H5E_STORAGE_g;
extern hid_t H5E_FILE_g;
extern hid_t H5E_SOHM_g;
extern hid_t H5E_SYM_g;
extern hid_t H5E_PLUGIN_g;
extern hid_t H5E_VFL_g;
extern hid_t H5E_INTERNAL_g;
extern hid_t H5E_BTREE_g;
extern hid_t H5E_REFERENCE_g;
extern hid_t H5E_DATASPACE_g;
extern hid_t H5E_RESOURCE_g;
extern hid_t H5E_PLIST_g;
extern hid_t H5E_LINK_g;
extern hid_t H5E_DATATYPE_g;
extern hid_t H5E_RS_g;
extern hid_t H5E_HEAP_g;
extern hid_t H5E_OHDR_g;
extern hid_t H5E_ATOM_g;
extern hid_t H5E_ATTR_g;
extern hid_t H5E_NONE_MAJOR_g;
extern hid_t H5E_IO_g;
extern hid_t H5E_SLIST_g;
extern hid_t H5E_EFL_g;
extern hid_t H5E_TST_g;
extern hid_t H5E_ARGS_g;
extern hid_t H5E_ERROR_g;
extern hid_t H5E_PLINE_g;
extern hid_t H5E_FSPACE_g;
extern hid_t H5E_CACHE_g;
# 101 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_SEEKERROR_g;
extern hid_t H5E_READERROR_g;
extern hid_t H5E_WRITEERROR_g;
extern hid_t H5E_CLOSEERROR_g;
extern hid_t H5E_OVERFLOW_g;
extern hid_t H5E_FCNTL_g;
# 119 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_NOSPACE_g;
extern hid_t H5E_CANTALLOC_g;
extern hid_t H5E_CANTCOPY_g;
extern hid_t H5E_CANTFREE_g;
extern hid_t H5E_ALREADYEXISTS_g;
extern hid_t H5E_CANTLOCK_g;
extern hid_t H5E_CANTUNLOCK_g;
extern hid_t H5E_CANTGC_g;
extern hid_t H5E_CANTGETSIZE_g;
extern hid_t H5E_OBJOPEN_g;
# 137 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_CANTRESTORE_g;
extern hid_t H5E_CANTCOMPUTE_g;
extern hid_t H5E_CANTEXTEND_g;
extern hid_t H5E_CANTATTACH_g;
extern hid_t H5E_CANTUPDATE_g;
extern hid_t H5E_CANTOPERATE_g;
extern hid_t H5E_CANTINIT_g;
extern hid_t H5E_ALREADYINIT_g;
extern hid_t H5E_CANTRELEASE_g;
extern hid_t H5E_CANTGET_g;
extern hid_t H5E_CANTSET_g;
extern hid_t H5E_DUPCLASS_g;
extern hid_t H5E_SETDISALLOWED_g;
extern hid_t H5E_CANTMERGE_g;
extern hid_t H5E_CANTREVIVE_g;
extern hid_t H5E_CANTSHRINK_g;
# 180 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_LINKCOUNT_g;
extern hid_t H5E_VERSION_g;
extern hid_t H5E_ALIGNMENT_g;
extern hid_t H5E_BADMESG_g;
extern hid_t H5E_CANTDELETE_g;
extern hid_t H5E_BADITER_g;
extern hid_t H5E_CANTPACK_g;
extern hid_t H5E_CANTRESET_g;
extern hid_t H5E_CANTRENAME_g;
extern hid_t H5E_SYSERRSTR_g;
# 201 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_NOFILTER_g;
extern hid_t H5E_CALLBACK_g;
extern hid_t H5E_CANAPPLY_g;
extern hid_t H5E_SETLOCAL_g;
extern hid_t H5E_NOENCODER_g;
extern hid_t H5E_CANTFILTER_g;
extern hid_t H5E_CANTOPENOBJ_g;
extern hid_t H5E_CANTCLOSEOBJ_g;
extern hid_t H5E_COMPLEN_g;
extern hid_t H5E_PATH_g;
extern hid_t H5E_NONE_MINOR_g;
extern hid_t H5E_OPENERROR_g;
# 236 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_FILEEXISTS_g;
extern hid_t H5E_FILEOPEN_g;
extern hid_t H5E_CANTCREATE_g;
extern hid_t H5E_CANTOPENFILE_g;
extern hid_t H5E_CANTCLOSEFILE_g;
extern hid_t H5E_NOTHDF5_g;
extern hid_t H5E_BADFILE_g;
extern hid_t H5E_TRUNCATED_g;
extern hid_t H5E_MOUNT_g;
# 253 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_BADATOM_g;
extern hid_t H5E_BADGROUP_g;
extern hid_t H5E_CANTREGISTER_g;
extern hid_t H5E_CANTINC_g;
extern hid_t H5E_CANTDEC_g;
extern hid_t H5E_NOIDS_g;
# 276 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_CANTFLUSH_g;
extern hid_t H5E_CANTSERIALIZE_g;
extern hid_t H5E_CANTLOAD_g;
extern hid_t H5E_PROTECT_g;
extern hid_t H5E_NOTCACHED_g;
extern hid_t H5E_SYSTEM_g;
extern hid_t H5E_CANTINS_g;
extern hid_t H5E_CANTPROTECT_g;
extern hid_t H5E_CANTUNPROTECT_g;
extern hid_t H5E_CANTPIN_g;
extern hid_t H5E_CANTUNPIN_g;
extern hid_t H5E_CANTMARKDIRTY_g;
extern hid_t H5E_CANTDIRTY_g;
extern hid_t H5E_CANTEXPUNGE_g;
extern hid_t H5E_CANTRESIZE_g;
extern hid_t H5E_TRAVERSE_g;
extern hid_t H5E_NLINKS_g;
extern hid_t H5E_NOTREGISTERED_g;
extern hid_t H5E_CANTMOVE_g;
extern hid_t H5E_CANTSORT_g;
extern hid_t H5E_MPI_g;
extern hid_t H5E_MPIERRSTR_g;
extern hid_t H5E_CANTRECV_g;
# 319 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_CANTCLIP_g;
extern hid_t H5E_CANTCOUNT_g;
extern hid_t H5E_CANTSELECT_g;
extern hid_t H5E_CANTNEXT_g;
extern hid_t H5E_BADSELECT_g;
extern hid_t H5E_CANTCOMPARE_g;
extern hid_t H5E_UNINITIALIZED_g;
extern hid_t H5E_UNSUPPORTED_g;
extern hid_t H5E_BADTYPE_g;
extern hid_t H5E_BADRANGE_g;
extern hid_t H5E_BADVALUE_g;
# 350 "/usr/include/H5Epubgen.h" 3 4
extern hid_t H5E_NOTFOUND_g;
extern hid_t H5E_EXISTS_g;
extern hid_t H5E_CANTENCODE_g;
extern hid_t H5E_CANTDECODE_g;
extern hid_t H5E_CANTSPLIT_g;
extern hid_t H5E_CANTREDISTRIBUTE_g;
extern hid_t H5E_CANTSWAP_g;
extern hid_t H5E_CANTINSERT_g;
extern hid_t H5E_CANTLIST_g;
extern hid_t H5E_CANTMODIFY_g;
extern hid_t H5E_CANTREMOVE_g;
extern hid_t H5E_CANTCONVERT_g;
extern hid_t H5E_BADSIZE_g;
# 63 "/usr/include/H5Epublic.h" 2 3 4
# 141 "/usr/include/H5Epublic.h" 3 4
typedef enum H5E_direction_t {
    H5E_WALK_UPWARD = 0,
    H5E_WALK_DOWNWARD = 1
} H5E_direction_t;
extern "C" {
typedef herr_t (*H5E_walk2_t)(unsigned n, const H5E_error2_t *err_desc,
    void *client_data);
typedef herr_t (*H5E_auto2_t)(hid_t estack, void *client_data);
 hid_t H5Eregister_class(const char *cls_name, const char *lib_name,
    const char *version);
 herr_t H5Eunregister_class(hid_t class_id);
 herr_t H5Eclose_msg(hid_t err_id);
 hid_t H5Ecreate_msg(hid_t cls, H5E_type_t msg_type, const char *msg);
 hid_t H5Ecreate_stack(void);
 hid_t H5Eget_current_stack(void);
 herr_t H5Eclose_stack(hid_t stack_id);
 ssize_t H5Eget_class_name(hid_t class_id, char *name, size_t size);
 herr_t H5Eset_current_stack(hid_t err_stack_id);
 herr_t H5Epush2(hid_t err_stack, const char *file, const char *func, unsigned line,
    hid_t cls_id, hid_t maj_id, hid_t min_id, const char *msg, ...);
 herr_t H5Epop(hid_t err_stack, size_t count);
 herr_t H5Eprint2(hid_t err_stack, FILE *stream);
 herr_t H5Ewalk2(hid_t err_stack, H5E_direction_t direction, H5E_walk2_t func,
    void *client_data);
 herr_t H5Eget_auto2(hid_t estack_id, H5E_auto2_t *func, void **client_data);
 herr_t H5Eset_auto2(hid_t estack_id, H5E_auto2_t func, void *client_data);
 herr_t H5Eclear2(hid_t err_stack);
 herr_t H5Eauto_is_v2(hid_t err_stack, unsigned *is_stack);
 ssize_t H5Eget_msg(hid_t msg_id, H5E_type_t *type, char *msg,
    size_t size);
 ssize_t H5Eget_num(hid_t error_stack_id);
# 193 "/usr/include/H5Epublic.h" 3 4
typedef hid_t H5E_major_t;
typedef hid_t H5E_minor_t;
typedef struct H5E_error1_t {
    H5E_major_t maj_num;
    H5E_minor_t min_num;
    unsigned line;
    const char *desc;
} H5E_error1_t;
typedef herr_t (*H5E_walk1_t)(int n, H5E_error1_t *err_desc, void *client_data);
typedef herr_t (*H5E_auto1_t)(void *client_data);
 herr_t H5Eclear1(void);
 herr_t H5Eget_auto1(H5E_auto1_t *func, void **client_data);
 herr_t H5Epush1(const char *file, const char *func, unsigned line,
    H5E_major_t maj, H5E_minor_t min, const char *str);
 herr_t H5Eprint1(FILE *stream);
 herr_t H5Eset_auto1(H5E_auto1_t func, void *client_data);
 herr_t H5Ewalk1(H5E_direction_t direction, H5E_walk1_t func,
    void *client_data);
 char *H5Eget_major(H5E_major_t maj);
 char *H5Eget_minor(H5E_minor_t min);
# 29 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Fpublic.h" 1 3 4
# 79 "/usr/include/H5Fpublic.h" 3 4
typedef enum H5F_scope_t {
    H5F_SCOPE_LOCAL = 0,
    H5F_SCOPE_GLOBAL = 1
} H5F_scope_t;
# 95 "/usr/include/H5Fpublic.h" 3 4
typedef enum H5F_close_degree_t {
    H5F_CLOSE_DEFAULT = 0,
    H5F_CLOSE_WEAK = 1,
    H5F_CLOSE_SEMI = 2,
    H5F_CLOSE_STRONG = 3
} H5F_close_degree_t;
typedef struct H5F_info_t {
    hsize_t super_ext_size;
    struct {
 hsize_t hdr_size;
 H5_ih_info_t msgs_info;
    } sohm;
} H5F_info_t;
# 120 "/usr/include/H5Fpublic.h" 3 4
typedef enum H5F_mem_t {
    H5FD_MEM_NOLIST = -1,
    H5FD_MEM_DEFAULT = 0,
    H5FD_MEM_SUPER = 1,
    H5FD_MEM_BTREE = 2,
    H5FD_MEM_DRAW = 3,
    H5FD_MEM_GHEAP = 4,
    H5FD_MEM_LHEAP = 5,
    H5FD_MEM_OHDR = 6,
    H5FD_MEM_NTYPES
} H5F_mem_t;
typedef enum H5F_libver_t {
    H5F_LIBVER_EARLIEST,
    H5F_LIBVER_LATEST
} H5F_libver_t;
extern "C" {
 htri_t H5Fis_hdf5(const char *filename);
 hid_t H5Fcreate(const char *filename, unsigned flags,
       hid_t create_plist, hid_t access_plist);
 hid_t H5Fopen(const char *filename, unsigned flags,
 hid_t H5Freopen(hid_t file_id);
 herr_t H5Fflush(hid_t object_id, H5F_scope_t scope);
 herr_t H5Fclose(hid_t file_id);
 hid_t H5Fget_create_plist(hid_t file_id);
 hid_t H5Fget_access_plist(hid_t file_id);
 herr_t H5Fget_intent(hid_t file_id, unsigned * intent);
 ssize_t H5Fget_obj_count(hid_t file_id, unsigned types);
 ssize_t H5Fget_obj_ids(hid_t file_id, unsigned types, size_t max_objs, hid_t *obj_id_list);
 herr_t H5Fget_vfd_handle(hid_t file_id, hid_t fapl, void **file_handle);
 herr_t H5Fmount(hid_t loc, const char *name, hid_t child, hid_t plist);
 herr_t H5Funmount(hid_t loc, const char *name);
 hssize_t H5Fget_freespace(hid_t file_id);
 herr_t H5Fget_filesize(hid_t file_id, hsize_t *size);
 ssize_t H5Fget_file_image(hid_t file_id, void * buf_ptr, size_t buf_len);
 herr_t H5Fget_mdc_config(hid_t file_id,
    H5AC_cache_config_t * config_ptr);
 herr_t H5Fset_mdc_config(hid_t file_id,
 herr_t H5Fget_mdc_hit_rate(hid_t file_id, double * hit_rate_ptr);
 herr_t H5Fget_mdc_size(hid_t file_id,
                              size_t * max_size_ptr,
                              size_t * min_clean_size_ptr,
                              size_t * cur_size_ptr,
                              int * cur_num_entries_ptr);
 herr_t H5Freset_mdc_hit_rate_stats(hid_t file_id);
 ssize_t H5Fget_name(hid_t obj_id, char *name, size_t size);
 herr_t H5Fget_info(hid_t obj_id, H5F_info_t *bh_info);
 herr_t H5Fclear_elink_file_cache(hid_t file_id);
# 30 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDpublic.h" 1 3 4
# 30 "/usr/include/H5FDpublic.h" 3 4
typedef enum H5F_mem_t H5FD_mem_t;
# 195 "/usr/include/H5FDpublic.h" 3 4
typedef struct H5FD_t H5FD_t;
typedef struct H5FD_class_t {
    const char *name;
    haddr_t maxaddr;
    H5F_close_degree_t fc_degree;
    hsize_t (*sb_size)(H5FD_t *file);
    herr_t (*sb_encode)(H5FD_t *file, char *name ,
                         unsigned char *p );
    herr_t (*sb_decode)(H5FD_t *f, const char *name, const unsigned char *p);
    size_t fapl_size;
    void * (*fapl_get)(H5FD_t *file);
    void * (*fapl_copy)(const void *fapl);
    herr_t (*fapl_free)(void *fapl);
    size_t dxpl_size;
    void * (*dxpl_copy)(const void *dxpl);
    herr_t (*dxpl_free)(void *dxpl);
    H5FD_t *(*open)(const char *name, unsigned flags, hid_t fapl,
                    haddr_t maxaddr);
    herr_t (*close)(H5FD_t *file);
    int (*cmp)(const H5FD_t *f1, const H5FD_t *f2);
    herr_t (*query)(const H5FD_t *f1, unsigned long *flags);
    herr_t (*get_type_map)(const H5FD_t *file, H5FD_mem_t *type_map);
    haddr_t (*alloc)(H5FD_t *file, H5FD_mem_t type, hid_t dxpl_id, hsize_t size);
    herr_t (*free)(H5FD_t *file, H5FD_mem_t type, hid_t dxpl_id,
                    haddr_t addr, hsize_t size);
    haddr_t (*get_eoa)(const H5FD_t *file, H5FD_mem_t type);
    herr_t (*set_eoa)(H5FD_t *file, H5FD_mem_t type, haddr_t addr);
    haddr_t (*get_eof)(const H5FD_t *file);
    herr_t (*get_handle)(H5FD_t *file, hid_t fapl, void**file_handle);
    herr_t (*read)(H5FD_t *file, H5FD_mem_t type, hid_t dxpl,
                    haddr_t addr, size_t size, void *buffer);
    herr_t (*write)(H5FD_t *file, H5FD_mem_t type, hid_t dxpl,
                     haddr_t addr, size_t size, const void *buffer);
    herr_t (*flush)(H5FD_t *file, hid_t dxpl_id, unsigned closing);
    herr_t (*truncate)(H5FD_t *file, hid_t dxpl_id, hbool_t closing);
    herr_t (*lock)(H5FD_t *file, unsigned char *oid, unsigned lock_type, hbool_t last);
    herr_t (*unlock)(H5FD_t *file, unsigned char *oid, hbool_t last);
    H5FD_mem_t fl_map[H5FD_MEM_NTYPES];
} H5FD_class_t;
typedef struct H5FD_free_t {
    haddr_t addr;
    hsize_t size;
    struct H5FD_free_t *next;
} H5FD_free_t;
struct H5FD_t {
    hid_t driver_id;
    const H5FD_class_t *cls;
    unsigned long feature_flags;
    haddr_t maxaddr;
    haddr_t base_addr;
    hsize_t threshold;
    hsize_t alignment;
typedef enum {
    H5FD_FILE_IMAGE_OP_NO_OP,
    H5FD_FILE_IMAGE_OP_PROPERTY_LIST_SET,
    H5FD_FILE_IMAGE_OP_PROPERTY_LIST_COPY,
    H5FD_FILE_IMAGE_OP_PROPERTY_LIST_GET,
    H5FD_FILE_IMAGE_OP_PROPERTY_LIST_CLOSE,
    H5FD_FILE_IMAGE_OP_FILE_OPEN,
    H5FD_FILE_IMAGE_OP_FILE_RESIZE,
    H5FD_FILE_IMAGE_OP_FILE_CLOSE
} H5FD_file_image_op_t;
typedef struct {
    void *(*image_malloc)(size_t size, H5FD_file_image_op_t file_image_op,
                            void *udata);
    void *(*image_memcpy)(void *dest, const void *src, size_t size,
                            H5FD_file_image_op_t file_image_op, void *udata);
    void *(*image_realloc)(void *ptr, size_t size,
    herr_t (*image_free)(void *ptr, H5FD_file_image_op_t file_image_op,
                          void *udata);
    void *(*udata_copy)(void *udata);
    herr_t (*udata_free)(void *udata);
    void *udata;
} H5FD_file_image_callbacks_t;
extern "C" {
 hid_t H5FDregister(const H5FD_class_t *cls);
 herr_t H5FDunregister(hid_t driver_id);
 H5FD_t *H5FDopen(const char *name, unsigned flags, hid_t fapl_id,
                        haddr_t maxaddr);
 herr_t H5FDclose(H5FD_t *file);
 int H5FDcmp(const H5FD_t *f1, const H5FD_t *f2);
 int H5FDquery(const H5FD_t *f, unsigned long *flags);
 haddr_t H5FDalloc(H5FD_t *file, H5FD_mem_t type, hid_t dxpl_id, hsize_t size);
 herr_t H5FDfree(H5FD_t *file, H5FD_mem_t type, hid_t dxpl_id,
 haddr_t H5FDget_eoa(H5FD_t *file, H5FD_mem_t type);
 herr_t H5FDset_eoa(H5FD_t *file, H5FD_mem_t type, haddr_t eoa);
 haddr_t H5FDget_eof(H5FD_t *file);
 herr_t H5FDget_vfd_handle(H5FD_t *file, hid_t fapl, void**file_handle);
 herr_t H5FDread(H5FD_t *file, H5FD_mem_t type, hid_t dxpl_id,
                       haddr_t addr, size_t size, void *buf );
 herr_t H5FDwrite(H5FD_t *file, H5FD_mem_t type, hid_t dxpl_id,
                        haddr_t addr, size_t size, const void *buf);
 herr_t H5FDflush(H5FD_t *file, hid_t dxpl_id, unsigned closing);
 herr_t H5FDtruncate(H5FD_t *file, hid_t dxpl_id, hbool_t closing);
# 31 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Gpublic.h" 1 3 4
# 43 "/usr/include/H5Gpublic.h" 3 4
extern "C" {
typedef enum H5G_storage_type_t {
    H5G_STORAGE_TYPE_UNKNOWN = -1,
    H5G_STORAGE_TYPE_SYMBOL_TABLE,
    H5G_STORAGE_TYPE_COMPACT,
    H5G_STORAGE_TYPE_DENSE
} H5G_storage_type_t;
typedef struct H5G_info_t {
    H5G_storage_type_t storage_type;
    hsize_t nlinks;
    int64_t max_corder;
    hbool_t mounted;
} H5G_info_t;
# 75 "/usr/include/H5Gpublic.h" 3 4
 hid_t H5Gcreate2(hid_t loc_id, const char *name, hid_t lcpl_id,
    hid_t gcpl_id, hid_t gapl_id);
 hid_t H5Gcreate_anon(hid_t loc_id, hid_t gcpl_id, hid_t gapl_id);
 hid_t H5Gopen2(hid_t loc_id, const char *name, hid_t gapl_id);
 hid_t H5Gget_create_plist(hid_t group_id);
 herr_t H5Gget_info(hid_t loc_id, H5G_info_t *ginfo);
 herr_t H5Gget_info_by_name(hid_t loc_id, const char *name, H5G_info_t *ginfo,
    hid_t lapl_id);
 herr_t H5Gget_info_by_idx(hid_t loc_id, const char *group_name,
    H5_index_t idx_type, H5_iter_order_t order, hsize_t n, H5G_info_t *ginfo,
    hid_t lapl_id);
 herr_t H5Gclose(hid_t group_id);
# 119 "/usr/include/H5Gpublic.h" 3 4
typedef enum H5G_obj_t {
    H5G_UNKNOWN = -1,
    H5G_GROUP,
    H5G_DATASET,
    H5G_TYPE,
    H5G_LINK,
    H5G_UDLINK,
    H5G_RESERVED_5,
    H5G_RESERVED_6,
    H5G_RESERVED_7
} H5G_obj_t;
typedef herr_t (*H5G_iterate_t)(hid_t group, const char *name, void *op_data);
typedef struct H5G_stat_t {
    unsigned long fileno[2];
    unsigned long objno[2];
    unsigned nlink;
    H5G_obj_t type;
    time_t mtime;
    size_t linklen;
    H5O_stat_t ohdr;
} H5G_stat_t;
 hid_t H5Gcreate1(hid_t loc_id, const char *name, size_t size_hint);
 hid_t H5Gopen1(hid_t loc_id, const char *name);
 herr_t H5Glink(hid_t cur_loc_id, H5L_type_t type, const char *cur_name,
 herr_t H5Glink2(hid_t cur_loc_id, const char *cur_name, H5L_type_t type,
    hid_t new_loc_id, const char *new_name);
 herr_t H5Gmove(hid_t src_loc_id, const char *src_name,
    const char *dst_name);
 herr_t H5Gmove2(hid_t src_loc_id, const char *src_name, hid_t dst_loc_id,
 herr_t H5Gunlink(hid_t loc_id, const char *name);
 herr_t H5Gget_linkval(hid_t loc_id, const char *name, size_t size,
    char *buf );
 herr_t H5Gset_comment(hid_t loc_id, const char *name, const char *comment);
 int H5Gget_comment(hid_t loc_id, const char *name, size_t bufsize,
    char *buf);
 herr_t H5Giterate(hid_t loc_id, const char *name, int *idx,
        H5G_iterate_t op, void *op_data);
 herr_t H5Gget_num_objs(hid_t loc_id, hsize_t *num_objs);
 herr_t H5Gget_objinfo(hid_t loc_id, const char *name,
    hbool_t follow_link, H5G_stat_t *statbuf );
 ssize_t H5Gget_objname_by_idx(hid_t loc_id, hsize_t idx, char* name,
    size_t size);
 H5G_obj_t H5Gget_objtype_by_idx(hid_t loc_id, hsize_t idx);
# 32 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5MMpublic.h" 1 3 4
# 36 "/usr/include/H5MMpublic.h" 3 4
typedef void *(*H5MM_allocate_t)(size_t size, void *alloc_info);
typedef void (*H5MM_free_t)(void *mem, void *free_info);
extern "C" {
# 35 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Ppublic.h" 1 3 4
# 36 "/usr/include/H5Ppublic.h" 3 4
# 1 "/usr/include/H5Zpublic.h" 1 3 4
# 33 "/usr/include/H5Zpublic.h" 3 4
typedef int H5Z_filter_t;
# 99 "/usr/include/H5Zpublic.h" 3 4
typedef enum H5Z_SO_scale_type_t {
    H5Z_SO_FLOAT_DSCALE = 0,
    H5Z_SO_FLOAT_ESCALE = 1,
    H5Z_SO_INT = 2
} H5Z_SO_scale_type_t;
typedef enum H5Z_EDC_t {
    H5Z_ERROR_EDC = -1,
    H5Z_DISABLE_EDC = 0,
    H5Z_ENABLE_EDC = 1,
    H5Z_NO_EDC = 2
} H5Z_EDC_t;
typedef enum H5Z_cb_return_t {
    H5Z_CB_ERROR = -1,
    H5Z_CB_FAIL = 0,
    H5Z_CB_CONT = 1,
    H5Z_CB_NO = 2
} H5Z_cb_return_t;
typedef H5Z_cb_return_t (*H5Z_filter_func_t)(H5Z_filter_t filter, void* buf,
                                size_t buf_size, void* op_data);
typedef struct H5Z_cb_t {
    H5Z_filter_func_t func;
    void* op_data;
} H5Z_cb_t;
extern "C" {
# 162 "/usr/include/H5Zpublic.h" 3 4
typedef htri_t (*H5Z_can_apply_func_t)(hid_t dcpl_id, hid_t type_id, hid_t space_id);
# 185 "/usr/include/H5Zpublic.h" 3 4
typedef herr_t (*H5Z_set_local_func_t)(hid_t dcpl_id, hid_t type_id, hid_t space_id);
# 202 "/usr/include/H5Zpublic.h" 3 4
typedef size_t (*H5Z_func_t)(unsigned int flags, size_t cd_nelmts,
        const unsigned int cd_values[], size_t nbytes,
        size_t *buf_size, void **buf);
typedef struct H5Z_class2_t {
    int version;
    H5Z_filter_t id;
    unsigned encoder_present;
    unsigned decoder_present;
    const char *name;
    H5Z_can_apply_func_t can_apply;
    H5Z_set_local_func_t set_local;
    H5Z_func_t filter;
} H5Z_class2_t;
 herr_t H5Zregister(const void *cls);
 herr_t H5Zunregister(H5Z_filter_t id);
 htri_t H5Zfilter_avail(H5Z_filter_t id);
 herr_t H5Zget_filter_info(H5Z_filter_t filter, unsigned int *filter_config_flags);
# 236 "/usr/include/H5Zpublic.h" 3 4
typedef struct H5Z_class1_t {
    H5Z_filter_t id;
    const char *name;
    H5Z_func_t filter;
} H5Z_class1_t;
# 37 "/usr/include/H5Ppublic.h" 2 3 4
# 96 "/usr/include/H5Ppublic.h" 3 4
extern "C" {
# 105 "/usr/include/H5Ppublic.h" 3 4
typedef herr_t (*H5P_cls_create_func_t)(hid_t prop_id, void *create_data);
typedef herr_t (*H5P_cls_copy_func_t)(hid_t new_prop_id, hid_t old_prop_id,
                                      void *copy_data);
typedef herr_t (*H5P_cls_close_func_t)(hid_t prop_id, void *close_data);
typedef herr_t (*H5P_prp_cb1_t)(const char *name, size_t size, void *value);
typedef herr_t (*H5P_prp_cb2_t)(hid_t prop_id, const char *name, size_t size, void *value);
typedef H5P_prp_cb1_t H5P_prp_create_func_t;
typedef H5P_prp_cb2_t H5P_prp_set_func_t;
typedef H5P_prp_cb2_t H5P_prp_get_func_t;
typedef H5P_prp_cb2_t H5P_prp_delete_func_t;
typedef H5P_prp_cb1_t H5P_prp_copy_func_t;
typedef int (*H5P_prp_compare_func_t)(const void *value1, const void *value2, size_t size);
typedef H5P_prp_cb1_t H5P_prp_close_func_t;
typedef herr_t (*H5P_iterate_t)(hid_t id, const char *name, void *iter_data);
typedef enum H5D_mpio_actual_chunk_opt_mode_t {
    H5D_MPIO_NO_CHUNK_OPTIMIZATION = 0,
    H5D_MPIO_LINK_CHUNK,
    H5D_MPIO_MULTI_CHUNK
} H5D_mpio_actual_chunk_opt_mode_t;
typedef enum H5D_mpio_actual_io_mode_t {
# 146 "/usr/include/H5Ppublic.h" 3 4
    H5D_MPIO_NO_COLLECTIVE = 0x0,
    H5D_MPIO_CHUNK_INDEPENDENT = 0x1,
    H5D_MPIO_CHUNK_COLLECTIVE = 0x2,
    H5D_MPIO_CHUNK_MIXED = 0x1 | 0x2,
    H5D_MPIO_CONTIGUOUS_COLLECTIVE = 0x4
} H5D_mpio_actual_io_mode_t;
typedef enum H5D_mpio_no_collective_cause_t {
    H5D_MPIO_COLLECTIVE = 0x00,
    H5D_MPIO_SET_INDEPENDENT = 0x01,
    H5D_MPIO_DATATYPE_CONVERSION = 0x02,
    H5D_MPIO_DATA_TRANSFORMS = 0x04,
    H5D_MPIO_MPI_OPT_TYPES_ENV_VAR_DISABLED = 0x08,
    H5D_MPIO_NOT_SIMPLE_OR_SCALAR_DATASPACES = 0x10,
    H5D_MPIO_NOT_CONTIGUOUS_OR_CHUNKED_DATASET = 0x20,
    H5D_MPIO_FILTERS = 0x40
} H5D_mpio_no_collective_cause_t;
extern hid_t H5P_CLS_ROOT_g;
extern hid_t H5P_CLS_OBJECT_CREATE_g;
extern hid_t H5P_CLS_FILE_CREATE_g;
extern hid_t H5P_CLS_FILE_ACCESS_g;
extern hid_t H5P_CLS_DATASET_CREATE_g;
extern hid_t H5P_CLS_DATASET_ACCESS_g;
extern hid_t H5P_CLS_DATASET_XFER_g;
extern hid_t H5P_CLS_FILE_MOUNT_g;
extern hid_t H5P_CLS_GROUP_CREATE_g;
extern hid_t H5P_CLS_GROUP_ACCESS_g;
extern hid_t H5P_CLS_DATATYPE_CREATE_g;
extern hid_t H5P_CLS_DATATYPE_ACCESS_g;
extern hid_t H5P_CLS_STRING_CREATE_g;
extern hid_t H5P_CLS_ATTRIBUTE_CREATE_g;
extern hid_t H5P_CLS_OBJECT_COPY_g;
extern hid_t H5P_CLS_LINK_CREATE_g;
extern hid_t H5P_CLS_LINK_ACCESS_g;
extern hid_t H5P_LST_FILE_CREATE_g;
extern hid_t H5P_LST_FILE_ACCESS_g;
extern hid_t H5P_LST_DATASET_CREATE_g;
extern hid_t H5P_LST_DATASET_ACCESS_g;
extern hid_t H5P_LST_DATASET_XFER_g;
extern hid_t H5P_LST_FILE_MOUNT_g;
extern hid_t H5P_LST_GROUP_CREATE_g;
extern hid_t H5P_LST_GROUP_ACCESS_g;
extern hid_t H5P_LST_DATATYPE_CREATE_g;
extern hid_t H5P_LST_DATATYPE_ACCESS_g;
extern hid_t H5P_LST_ATTRIBUTE_CREATE_g;
extern hid_t H5P_LST_OBJECT_COPY_g;
extern hid_t H5P_LST_LINK_CREATE_g;
extern hid_t H5P_LST_LINK_ACCESS_g;
 hid_t H5Pcreate_class(hid_t parent, const char *name,
    H5P_cls_create_func_t cls_create, void *create_data,
    H5P_cls_copy_func_t cls_copy, void *copy_data,
    H5P_cls_close_func_t cls_close, void *close_data);
 char *H5Pget_class_name(hid_t pclass_id);
 hid_t H5Pcreate(hid_t cls_id);
 herr_t H5Pregister2(hid_t cls_id, const char *name, size_t size,
    void *def_value, H5P_prp_create_func_t prp_create,
    H5P_prp_set_func_t prp_set, H5P_prp_get_func_t prp_get,
    H5P_prp_delete_func_t prp_del, H5P_prp_copy_func_t prp_copy,
    H5P_prp_compare_func_t prp_cmp, H5P_prp_close_func_t prp_close);
 herr_t H5Pinsert2(hid_t plist_id, const char *name, size_t size,
    void *value, H5P_prp_set_func_t prp_set, H5P_prp_get_func_t prp_get,
    H5P_prp_delete_func_t prp_delete, H5P_prp_copy_func_t prp_copy,
 herr_t H5Pset(hid_t plist_id, const char *name, void *value);
 htri_t H5Pexist(hid_t plist_id, const char *name);
 herr_t H5Pget_size(hid_t id, const char *name, size_t *size);
 herr_t H5Pget_nprops(hid_t id, size_t *nprops);
 hid_t H5Pget_class(hid_t plist_id);
 hid_t H5Pget_class_parent(hid_t pclass_id);
 herr_t H5Pget(hid_t plist_id, const char *name, void * value);
 htri_t H5Pequal(hid_t id1, hid_t id2);
 htri_t H5Pisa_class(hid_t plist_id, hid_t pclass_id);
 int H5Piterate(hid_t id, int *idx, H5P_iterate_t iter_func,
            void *iter_data);
 herr_t H5Pcopy_prop(hid_t dst_id, hid_t src_id, const char *name);
 herr_t H5Premove(hid_t plist_id, const char *name);
 herr_t H5Punregister(hid_t pclass_id, const char *name);
 herr_t H5Pclose_class(hid_t plist_id);
 herr_t H5Pclose(hid_t plist_id);
 hid_t H5Pcopy(hid_t plist_id);
 herr_t H5Pset_attr_phase_change(hid_t plist_id, unsigned max_compact, unsigned min_dense);
 herr_t H5Pget_attr_phase_change(hid_t plist_id, unsigned *max_compact, unsigned *min_dense);
 herr_t H5Pset_attr_creation_order(hid_t plist_id, unsigned crt_order_flags);
 herr_t H5Pget_attr_creation_order(hid_t plist_id, unsigned *crt_order_flags);
 herr_t H5Pset_obj_track_times(hid_t plist_id, hbool_t track_times);
 herr_t H5Pget_obj_track_times(hid_t plist_id, hbool_t *track_times);
 herr_t H5Pmodify_filter(hid_t plist_id, H5Z_filter_t filter,
        const unsigned int cd_values[ ]);
 herr_t H5Pset_filter(hid_t plist_id, H5Z_filter_t filter,
        const unsigned int c_values[]);
 int H5Pget_nfilters(hid_t plist_id);
 H5Z_filter_t H5Pget_filter2(hid_t plist_id, unsigned filter,
       unsigned int *flags ,
       size_t *cd_nelmts ,
       unsigned cd_values[] ,
       size_t namelen, char name[],
       unsigned *filter_config );
 herr_t H5Pget_filter_by_id2(hid_t plist_id, H5Z_filter_t id,
       unsigned int *flags , size_t *cd_nelmts ,
       unsigned cd_values[] , size_t namelen, char name[] ,
 htri_t H5Pall_filters_avail(hid_t plist_id);
 herr_t H5Premove_filter(hid_t plist_id, H5Z_filter_t filter);
 herr_t H5Pset_deflate(hid_t plist_id, unsigned aggression);
 herr_t H5Pset_fletcher32(hid_t plist_id);
 herr_t H5Pget_version(hid_t plist_id, unsigned *boot ,
         unsigned *freelist , unsigned *stab ,
         unsigned *shhdr );
 herr_t H5Pset_userblock(hid_t plist_id, hsize_t size);
 herr_t H5Pget_userblock(hid_t plist_id, hsize_t *size);
 herr_t H5Pset_sizes(hid_t plist_id, size_t sizeof_addr,
       size_t sizeof_size);
 herr_t H5Pget_sizes(hid_t plist_id, size_t *sizeof_addr ,
       size_t *sizeof_size );
 herr_t H5Pset_sym_k(hid_t plist_id, unsigned ik, unsigned lk);
 herr_t H5Pget_sym_k(hid_t plist_id, unsigned *ik , unsigned *lk );
 herr_t H5Pset_istore_k(hid_t plist_id, unsigned ik);
 herr_t H5Pget_istore_k(hid_t plist_id, unsigned *ik );
 herr_t H5Pset_shared_mesg_nindexes(hid_t plist_id, unsigned nindexes);
 herr_t H5Pget_shared_mesg_nindexes(hid_t plist_id, unsigned *nindexes);
 herr_t H5Pset_shared_mesg_index(hid_t plist_id, unsigned index_num, unsigned mesg_type_flags, unsigned min_mesg_size);
 herr_t H5Pget_shared_mesg_index(hid_t plist_id, unsigned index_num, unsigned *mesg_type_flags, unsigned *min_mesg_size);
 herr_t H5Pset_shared_mesg_phase_change(hid_t plist_id, unsigned max_list, unsigned min_btree);
 herr_t H5Pget_shared_mesg_phase_change(hid_t plist_id, unsigned *max_list, unsigned *min_btree);
 herr_t H5Pset_alignment(hid_t fapl_id, hsize_t threshold,
    hsize_t alignment);
 herr_t H5Pget_alignment(hid_t fapl_id, hsize_t *threshold ,
    hsize_t *alignment );
 herr_t H5Pset_driver(hid_t plist_id, hid_t driver_id,
        const void *driver_info);
 hid_t H5Pget_driver(hid_t plist_id);
 void *H5Pget_driver_info(hid_t plist_id);
 herr_t H5Pset_family_offset(hid_t fapl_id, hsize_t offset);
 herr_t H5Pget_family_offset(hid_t fapl_id, hsize_t *offset);
 herr_t H5Pset_multi_type(hid_t fapl_id, H5FD_mem_t type);
 herr_t H5Pget_multi_type(hid_t fapl_id, H5FD_mem_t *type);
 herr_t H5Pset_cache(hid_t plist_id, int mdc_nelmts,
       size_t rdcc_nslots, size_t rdcc_nbytes,
       double rdcc_w0);
 herr_t H5Pget_cache(hid_t plist_id,
       int *mdc_nelmts,
       size_t *rdcc_nslots ,
       size_t *rdcc_nbytes , double *rdcc_w0);
 herr_t H5Pset_mdc_config(hid_t plist_id,
 herr_t H5Pget_mdc_config(hid_t plist_id,
 herr_t H5Pset_gc_references(hid_t fapl_id, unsigned gc_ref);
 herr_t H5Pget_gc_references(hid_t fapl_id, unsigned *gc_ref );
 herr_t H5Pset_fclose_degree(hid_t fapl_id, H5F_close_degree_t degree);
 herr_t H5Pget_fclose_degree(hid_t fapl_id, H5F_close_degree_t *degree);
 herr_t H5Pset_meta_block_size(hid_t fapl_id, hsize_t size);
 herr_t H5Pget_meta_block_size(hid_t fapl_id, hsize_t *size );
 herr_t H5Pset_sieve_buf_size(hid_t fapl_id, size_t size);
 herr_t H5Pget_sieve_buf_size(hid_t fapl_id, size_t *size );
 herr_t H5Pset_small_data_block_size(hid_t fapl_id, hsize_t size);
 herr_t H5Pget_small_data_block_size(hid_t fapl_id, hsize_t *size );
 herr_t H5Pset_libver_bounds(hid_t plist_id, H5F_libver_t low,
    H5F_libver_t high);
 herr_t H5Pget_libver_bounds(hid_t plist_id, H5F_libver_t *low,
    H5F_libver_t *high);
 herr_t H5Pset_elink_file_cache_size(hid_t plist_id, unsigned efc_size);
 herr_t H5Pget_elink_file_cache_size(hid_t plist_id, unsigned *efc_size);
 herr_t H5Pset_file_image(hid_t fapl_id, void *buf_ptr, size_t buf_len);
 herr_t H5Pget_file_image(hid_t fapl_id, void **buf_ptr_ptr, size_t *buf_len_ptr);
 herr_t H5Pset_file_image_callbacks(hid_t fapl_id,
       H5FD_file_image_callbacks_t *callbacks_ptr);
 herr_t H5Pget_file_image_callbacks(hid_t fapl_id,
 herr_t H5Pset_core_write_tracking(hid_t fapl_id, hbool_t is_enabled, size_t page_size);
 herr_t H5Pget_core_write_tracking(hid_t fapl_id, hbool_t *is_enabled, size_t *page_size);
 herr_t H5Pset_layout(hid_t plist_id, H5D_layout_t layout);
 H5D_layout_t H5Pget_layout(hid_t plist_id);
 herr_t H5Pset_chunk(hid_t plist_id, int ndims, const hsize_t dim[ ]);
 int H5Pget_chunk(hid_t plist_id, int max_ndims, hsize_t dim[] );
 herr_t H5Pset_external(hid_t plist_id, const char *name, off_t offset,
          hsize_t size);
 int H5Pget_external_count(hid_t plist_id);
 herr_t H5Pget_external(hid_t plist_id, unsigned idx, size_t name_size,
          char *name , off_t *offset ,
          hsize_t *size );
 herr_t H5Pset_szip(hid_t plist_id, unsigned options_mask, unsigned pixels_per_block);
 herr_t H5Pset_shuffle(hid_t plist_id);
 herr_t H5Pset_nbit(hid_t plist_id);
 herr_t H5Pset_scaleoffset(hid_t plist_id, H5Z_SO_scale_type_t scale_type, int scale_factor);
 herr_t H5Pset_fill_value(hid_t plist_id, hid_t type_id,
     const void *value);
 herr_t H5Pget_fill_value(hid_t plist_id, hid_t type_id,
     void *value );
 herr_t H5Pfill_value_defined(hid_t plist, H5D_fill_value_t *status);
 herr_t H5Pset_alloc_time(hid_t plist_id, H5D_alloc_time_t
 alloc_time);
 herr_t H5Pget_alloc_time(hid_t plist_id, H5D_alloc_time_t
 *alloc_time );
 herr_t H5Pset_fill_time(hid_t plist_id, H5D_fill_time_t fill_time);
 herr_t H5Pget_fill_time(hid_t plist_id, H5D_fill_time_t
 *fill_time );
 herr_t H5Pset_chunk_cache(hid_t dapl_id, size_t rdcc_nslots,
       size_t rdcc_nbytes, double rdcc_w0);
 herr_t H5Pget_chunk_cache(hid_t dapl_id,
       double *rdcc_w0 );
 herr_t H5Pset_data_transform(hid_t plist_id, const char* expression);
 ssize_t H5Pget_data_transform(hid_t plist_id, char* expression , size_t size);
 herr_t H5Pset_buffer(hid_t plist_id, size_t size, void *tconv,
        void *bkg);
 size_t H5Pget_buffer(hid_t plist_id, void **tconv ,
        void **bkg );
 herr_t H5Pset_preserve(hid_t plist_id, hbool_t status);
 int H5Pget_preserve(hid_t plist_id);
 herr_t H5Pset_edc_check(hid_t plist_id, H5Z_EDC_t check);
 H5Z_EDC_t H5Pget_edc_check(hid_t plist_id);
 herr_t H5Pset_filter_callback(hid_t plist_id, H5Z_filter_func_t func,
                                     void* op_data);
 herr_t H5Pset_btree_ratios(hid_t plist_id, double left, double middle,
       double right);
 herr_t H5Pget_btree_ratios(hid_t plist_id, double *left ,
       double *middle ,
       double *right );
 herr_t H5Pset_vlen_mem_manager(hid_t plist_id,
                                       H5MM_allocate_t alloc_func,
                                       void *alloc_info, H5MM_free_t free_func,
                                       void *free_info);
 herr_t H5Pget_vlen_mem_manager(hid_t plist_id,
                                       H5MM_allocate_t *alloc_func,
                                       void **alloc_info,
                                       H5MM_free_t *free_func,
                                       void **free_info);
 herr_t H5Pset_hyper_vector_size(hid_t fapl_id, size_t size);
 herr_t H5Pget_hyper_vector_size(hid_t fapl_id, size_t *size );
 herr_t H5Pset_type_conv_cb(hid_t dxpl_id, H5T_conv_except_func_t op, void* operate_data);
 herr_t H5Pget_type_conv_cb(hid_t dxpl_id, H5T_conv_except_func_t *op, void** operate_data);
 herr_t H5Pset_create_intermediate_group(hid_t plist_id, unsigned crt_intmd);
 herr_t H5Pget_create_intermediate_group(hid_t plist_id, unsigned *crt_intmd );
 herr_t H5Pset_local_heap_size_hint(hid_t plist_id, size_t size_hint);
 herr_t H5Pget_local_heap_size_hint(hid_t plist_id, size_t *size_hint );
 herr_t H5Pset_link_phase_change(hid_t plist_id, unsigned max_compact, unsigned min_dense);
 herr_t H5Pget_link_phase_change(hid_t plist_id, unsigned *max_compact , unsigned *min_dense );
 herr_t H5Pset_est_link_info(hid_t plist_id, unsigned est_num_entries, unsigned est_name_len);
 herr_t H5Pget_est_link_info(hid_t plist_id, unsigned *est_num_entries , unsigned *est_name_len );
 herr_t H5Pset_link_creation_order(hid_t plist_id, unsigned crt_order_flags);
 herr_t H5Pget_link_creation_order(hid_t plist_id, unsigned *crt_order_flags );
 herr_t H5Pset_char_encoding(hid_t plist_id, H5T_cset_t encoding);
 herr_t H5Pget_char_encoding(hid_t plist_id, H5T_cset_t *encoding );
 herr_t H5Pset_nlinks(hid_t plist_id, size_t nlinks);
 herr_t H5Pget_nlinks(hid_t plist_id, size_t *nlinks);
 herr_t H5Pset_elink_prefix(hid_t plist_id, const char *prefix);
 ssize_t H5Pget_elink_prefix(hid_t plist_id, char *prefix, size_t size);
 hid_t H5Pget_elink_fapl(hid_t lapl_id);
 herr_t H5Pset_elink_fapl(hid_t lapl_id, hid_t fapl_id);
 herr_t H5Pset_elink_acc_flags(hid_t lapl_id, unsigned flags);
 herr_t H5Pget_elink_acc_flags(hid_t lapl_id, unsigned *flags);
 herr_t H5Pset_elink_cb(hid_t lapl_id, H5L_elink_traverse_t func, void *op_data);
 herr_t H5Pget_elink_cb(hid_t lapl_id, H5L_elink_traverse_t *func, void **op_data);
 herr_t H5Pset_copy_object(hid_t plist_id, unsigned crt_intmd);
 herr_t H5Pget_copy_object(hid_t plist_id, unsigned *crt_intmd );
 herr_t H5Padd_merge_committed_dtype_path(hid_t plist_id, const char *path);
 herr_t H5Pfree_merge_committed_dtype_paths(hid_t plist_id);
 herr_t H5Pset_mcdt_search_cb(hid_t plist_id, H5O_mcdt_search_cb_t func, void *op_data);
 herr_t H5Pget_mcdt_search_cb(hid_t plist_id, H5O_mcdt_search_cb_t *func, void **op_data);
# 473 "/usr/include/H5Ppublic.h" 3 4
 herr_t H5Pregister1(hid_t cls_id, const char *name, size_t size,
 herr_t H5Pinsert1(hid_t plist_id, const char *name, size_t size,
 H5Z_filter_t H5Pget_filter1(hid_t plist_id, unsigned filter,
    unsigned cd_values[] , size_t namelen, char name[]);
 herr_t H5Pget_filter_by_id1(hid_t plist_id, H5Z_filter_t id,
    unsigned cd_values[] , size_t namelen, char name[] );
# 37 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Rpublic.h" 1 3 4
# 30 "/usr/include/H5Rpublic.h" 3 4
typedef enum {
    H5R_BADTYPE = (-1),
    H5R_OBJECT,
    H5R_DATASET_REGION,
    H5R_MAXTYPE
} H5R_type_t;
# 44 "/usr/include/H5Rpublic.h" 3 4
typedef haddr_t hobj_ref_t;
typedef unsigned char hdset_reg_ref_t[(sizeof(haddr_t)+4)];
extern "C" {
 herr_t H5Rcreate(void *ref, hid_t loc_id, const char *name,
    H5R_type_t ref_type, hid_t space_id);
 hid_t H5Rdereference(hid_t dataset, H5R_type_t ref_type, const void *ref);
 hid_t H5Rget_region(hid_t dataset, H5R_type_t ref_type, const void *ref);
 herr_t H5Rget_obj_type2(hid_t id, H5R_type_t ref_type, const void *_ref,
    H5O_type_t *obj_type);
 ssize_t H5Rget_name(hid_t loc_id, H5R_type_t ref_type, const void *ref,
    char *name , size_t size);
# 83 "/usr/include/H5Rpublic.h" 3 4
 H5G_obj_t H5Rget_obj_type1(hid_t id, H5R_type_t ref_type, const void *_ref);
# 38 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5Spublic.h" 1 3 4
# 34 "/usr/include/H5Spublic.h" 3 4
typedef enum H5S_class_t {
    H5S_NO_CLASS = -1,
    H5S_SCALAR = 0,
    H5S_SIMPLE = 1,
    H5S_NULL = 2
} H5S_class_t;
typedef enum H5S_seloper_t {
    H5S_SELECT_NOOP = -1,
    H5S_SELECT_SET = 0,
    H5S_SELECT_OR,
    H5S_SELECT_AND,
    H5S_SELECT_XOR,
    H5S_SELECT_NOTB,
    H5S_SELECT_NOTA,
    H5S_SELECT_APPEND,
    H5S_SELECT_PREPEND,
    H5S_SELECT_INVALID
} H5S_seloper_t;
typedef enum {
    H5S_SEL_ERROR = -1,
    H5S_SEL_NONE = 0,
    H5S_SEL_POINTS = 1,
    H5S_SEL_HYPERSLABS = 2,
    H5S_SEL_ALL = 3,
    H5S_SEL_N
}H5S_sel_type;
extern "C" {
 hid_t H5Screate(H5S_class_t type);
 hid_t H5Screate_simple(int rank, const hsize_t dims[],
          const hsize_t maxdims[]);
 herr_t H5Sset_extent_simple(hid_t space_id, int rank,
        const hsize_t max[]);
 hid_t H5Scopy(hid_t space_id);
 herr_t H5Sclose(hid_t space_id);
 herr_t H5Sencode(hid_t obj_id, void *buf, size_t *nalloc);
 hid_t H5Sdecode(const void *buf);
 hssize_t H5Sget_simple_extent_npoints(hid_t space_id);
 int H5Sget_simple_extent_ndims(hid_t space_id);
 int H5Sget_simple_extent_dims(hid_t space_id, hsize_t dims[],
          hsize_t maxdims[]);
 htri_t H5Sis_simple(hid_t space_id);
 hssize_t H5Sget_select_npoints(hid_t spaceid);
 herr_t H5Sselect_hyperslab(hid_t space_id, H5S_seloper_t op,
       const hsize_t start[],
       const hsize_t _stride[],
       const hsize_t count[],
       const hsize_t _block[]);
# 128 "/usr/include/H5Spublic.h" 3 4
 herr_t H5Sselect_elements(hid_t space_id, H5S_seloper_t op,
    size_t num_elem, const hsize_t *coord);
 H5S_class_t H5Sget_simple_extent_type(hid_t space_id);
 herr_t H5Sset_extent_none(hid_t space_id);
 herr_t H5Sextent_copy(hid_t dst_id,hid_t src_id);
 htri_t H5Sextent_equal(hid_t sid1, hid_t sid2);
 herr_t H5Sselect_all(hid_t spaceid);
 herr_t H5Sselect_none(hid_t spaceid);
 herr_t H5Soffset_simple(hid_t space_id, const hssize_t *offset);
 htri_t H5Sselect_valid(hid_t spaceid);
 hssize_t H5Sget_select_hyper_nblocks(hid_t spaceid);
 hssize_t H5Sget_select_elem_npoints(hid_t spaceid);
 herr_t H5Sget_select_hyper_blocklist(hid_t spaceid, hsize_t startblock,
    hsize_t numblocks, hsize_t buf[ ]);
 herr_t H5Sget_select_elem_pointlist(hid_t spaceid, hsize_t startpoint,
    hsize_t numpoints, hsize_t buf[ ]);
 herr_t H5Sget_select_bounds(hid_t spaceid, hsize_t start[],
    hsize_t end[]);
 H5S_sel_type H5Sget_select_type(hid_t spaceid);
# 39 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDcore.h" 1 3 4
# 30 "/usr/include/H5FDcore.h" 3 4
extern "C" {
 hid_t H5FD_core_init(void);
 void H5FD_core_term(void);
 herr_t H5Pset_fapl_core(hid_t fapl_id, size_t increment,
    hbool_t backing_store);
 herr_t H5Pget_fapl_core(hid_t fapl_id, size_t *increment ,
    hbool_t *backing_store );
# 44 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDfamily.h" 1 3 4
# 30 "/usr/include/H5FDfamily.h" 3 4
extern "C" {
 hid_t H5FD_family_init(void);
 void H5FD_family_term(void);
 herr_t H5Pset_fapl_family(hid_t fapl_id, hsize_t memb_size,
     hid_t memb_fapl_id);
 herr_t H5Pget_fapl_family(hid_t fapl_id, hsize_t *memb_size ,
     hid_t *memb_fapl_id );
# 45 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDlog.h" 1 3 4
# 60 "/usr/include/H5FDlog.h" 3 4
extern "C" {
 hid_t H5FD_log_init(void);
 void H5FD_log_term(void);
 herr_t H5Pset_fapl_log(hid_t fapl_id, const char *logfile, unsigned long long flags, size_t buf_size);
# 46 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDmpi.h" 1 3 4
# 40 "/usr/include/H5FDmpi.h" 3 4
typedef enum H5FD_mpio_xfer_t {
    H5FD_MPIO_INDEPENDENT = 0,
    H5FD_MPIO_COLLECTIVE
} H5FD_mpio_xfer_t;
typedef enum H5FD_mpio_chunk_opt_t {
    H5FD_MPIO_CHUNK_DEFAULT = 0,
    H5FD_MPIO_CHUNK_ONE_IO,
    H5FD_MPIO_CHUNK_MULTI_IO
} H5FD_mpio_chunk_opt_t;
typedef enum H5FD_mpio_collective_opt_t {
    H5FD_MPIO_COLLECTIVE_IO = 0,
    H5FD_MPIO_INDIVIDUAL_IO
} H5FD_mpio_collective_opt_t;
# 1 "/usr/include/H5FDmpio.h" 1 3 4
# 60 "/usr/include/H5FDmpi.h" 2 3 4
# 47 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDmulti.h" 1 3 4
# 32 "/usr/include/H5FDmulti.h" 3 4
extern "C" {
 hid_t H5FD_multi_init(void);
 void H5FD_multi_term(void);
 herr_t H5Pset_fapl_multi(hid_t fapl_id, const H5FD_mem_t *memb_map,
    const hid_t *memb_fapl, const char * const *memb_name,
    const haddr_t *memb_addr, hbool_t relax);
 herr_t H5Pget_fapl_multi(hid_t fapl_id, H5FD_mem_t *memb_map ,
    hid_t *memb_fapl , char **memb_name ,
    haddr_t *memb_addr , hbool_t *relax );
 herr_t H5Pset_fapl_split(hid_t fapl, const char *meta_ext,
    hid_t meta_plist_id, const char *raw_ext,
    hid_t raw_plist_id);
# 48 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDsec2.h" 1 3 4
# 30 "/usr/include/H5FDsec2.h" 3 4
extern "C" {
 hid_t H5FD_sec2_init(void);
 void H5FD_sec2_term(void);
 herr_t H5Pset_fapl_sec2(hid_t fapl_id);
# 49 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDstdio.h" 1 3 4
# 30 "/usr/include/H5FDstdio.h" 3 4
extern "C" {
 hid_t H5FD_stdio_init(void);
 void H5FD_stdio_term(void);
 herr_t H5Pset_fapl_stdio(hid_t fapl_id);
# 50 "/usr/include/hdf5.h" 2 3 4
# 1 "/usr/include/H5FDdirect.h" 1 3 4
# 54 "/usr/include/hdf5.h" 2 3 4
# 3 "/tmp/petsc-F9l5hH/config.headers/conftest.cc" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['hdf5.h'] in ['/usr/include', '/usr/local/include']
                Popping language Cxx
            Checking for functions [H5Pset_fapl_mpio] in library ['/usr/lib/libhdf5.so', 'libm.a'] []
              Pushing language Cxx
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.libraries -fopenmp -O3      /tmp/petsc-F9l5hH/config.libraries/conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
char H5Pset_fapl_mpio();
static void _check_H5Pset_fapl_mpio() { H5Pset_fapl_mpio(); }
#ifdef __cplusplus
#endif
int main() {
_check_H5Pset_fapl_mpio();;
  return 0;
                      Pushing language CXX
                      Popping language CXX
Executing: mpic++  -o /tmp/petsc-F9l5hH/config.libraries/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.o  -Wl,-rpath,/usr/lib -L/usr/lib -lhdf5 -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
Possible ERROR while running linker: exit code 256
stderr:
/tmp/petsc-F9l5hH/config.libraries/conftest.o: In function `main':
conftest.cc:(.text.startup+0x5): undefined reference to `H5Pset_fapl_mpio'
collect2: error: ld returned 1 exit status
TEST checkSharedLibrary from config.packages.hdf5(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:731)
TESTING: checkSharedLibrary from config.packages.hdf5(config/BuildSystem/config/package.py:731)
  By default we don't care about checking if the library is shared
TEST alternateConfigureLibrary from config.packages.ascem-io(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.ascem-io(config/BuildSystem/config/package.py:735)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.pflotran(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.pflotran(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.netcdf(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.netcdf(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.MOAB(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.MOAB(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.exodusii(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.exodusii(config/BuildSystem/config/package.py:735)
TEST locateCMake from config.packages.cmake(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/cmake.py:33)
TESTING: locateCMake from config.packages.cmake(config/BuildSystem/config/packages/cmake.py:33)
Looking for default CMake executable
Checking for program ./cmake...not found
Checking for program /home/mpovolot/bin/cmake...not found
Checking for program /bin/cmake...found
              Defined make macro "CMAKE" to "/bin/cmake"
Looking for default CTest executable
Checking for program ./ctest...not found
Checking for program /home/mpovolot/bin/ctest...not found
Checking for program /bin/ctest...found
              Defined make macro "CTEST" to "/bin/ctest"
TEST alternateConfigureLibrary from config.packages.alquimia(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.alquimia(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.unittestcpp(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.unittestcpp(config/BuildSystem/config/package.py:735)
TEST configureScalarType from PETSc.options.scalarTypes(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/scalarTypes.py:37)
TESTING: configureScalarType from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:37)
  Choose between real and complex numbers
            Defined "USE_SCALAR_REAL" to "1"
          Scalar type is real
                        All intermediate test results are stored in /tmp/petsc-F9l5hH/PETSc.options.scalarTypes
Executing: mpic++ -c -o /tmp/petsc-F9l5hH/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.libraries -I/tmp/petsc-F9l5hH/PETSc.options.scalarTypes -fopenmp -O3      /tmp/petsc-F9l5hH/PETSc.options.scalarTypes/conftest.cc
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnormal(b);
  return 0;
Executing: mpic++  -o /tmp/petsc-F9l5hH/PETSc.options.scalarTypes/conftest   -fopenmp -O3  /tmp/petsc-F9l5hH/PETSc.options.scalarTypes/conftest.o -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
            Defined "HAVE_ISNORMAL" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnan(b);
  return 0;
            Defined "HAVE_ISNAN" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isinf(b);
  return 0;
            Defined "HAVE_ISINF" to "1"
Possible ERROR while running compiler: exit code 256
stderr:
/tmp/petsc-F9l5hH/PETSc.options.scalarTypes/conftest.cc: In function ‘int main()’:
/tmp/petsc-F9l5hH/PETSc.options.scalarTypes/conftest.cc:6:32: error: ‘_isnan’ was not declared in this scope
 double b = 2.0;int a = _isnan(b);
Source:
#include <float.h>
int main() {
  return 0;
              Compile failed inside link
stderr:
/tmp/petsc-F9l5hH/PETSc.options.scalarTypes/conftest.cc:6:33: error: ‘_finite’ was not declared in this scope
 double b = 2.0;int a = _finite(b);
Source:
#include <float.h>
int main() {
  return 0;
TEST configurePrecision from PETSc.options.scalarTypes(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/PETSc/options/scalarTypes.py:77)
TESTING: configurePrecision from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:77)
  Set the default real number precision for PETSc objects
            Defined "USE_REAL_DOUBLE" to "1"
            Defined make macro "PETSC_SCALAR_SIZE" to "64"
          Precision is double
TEST alternateConfigureLibrary from config.packages.opencl(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.opencl(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.viennacl(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.viennacl(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.fblaslapack(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.fblaslapack(config/BuildSystem/config/package.py:735)
TEST alternateConfigureLibrary from config.packages.f2cblaslapack(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/package.py:735)
TESTING: alternateConfigureLibrary from config.packages.f2cblaslapack(config/BuildSystem/config/package.py:735)
TEST configureLibrary from config.packages.BlasLapack(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/BlasLapack.py:333)
TESTING: configureLibrary from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:333)
Checking for a functional BLAS and LAPACK in User specified BLAS/LAPACK library
TEST checkLib from config.packages.BlasLapack(/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/BlasLapack.py:106)
TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:106)
  Checking for BLAS and LAPACK symbols
                  Checking for functions [ddot_] in library ['1'] ['-L/usr/local/lib', '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/usr/local/lib', '-lgfortran', '-lm', '-lquadmath', '-lm']
                    Pushing language C
Executing: mpicc -c -o /tmp/petsc-F9l5hH/config.libraries/conftest.o -I/tmp/petsc-F9l5hH/config.setCompilers -I/tmp/petsc-F9l5hH/config.compilers -I/tmp/petsc-F9l5hH/config.utilities.closure -I/tmp/petsc-F9l5hH/config.headers -I/tmp/petsc-F9l5hH/config.utilities.cacheDetails -I/tmp/petsc-F9l5hH/config.atomics -I/tmp/petsc-F9l5hH/config.functions -I/tmp/petsc-F9l5hH/config.utilities.featureTestMacros -I/tmp/petsc-F9l5hH/config.utilities.missing -I/tmp/petsc-F9l5hH/config.types -I/tmp/petsc-F9l5hH/config.packages.MPI -I/tmp/petsc-F9l5hH/config.packages.pthread -I/tmp/petsc-F9l5hH/config.packages.valgrind -I/tmp/petsc-F9l5hH/config.libraries    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3  /tmp/petsc-F9l5hH/config.libraries/conftest.c
Successful compile:
Source:
char ddot_();
static void _check_ddot_() { ddot_(); }
int main() {
_check_ddot_();;
  return 0;
                            Pushing language C
                            Popping language C
Executing: mpicc  -o /tmp/petsc-F9l5hH/config.libraries/conftest      -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -O3 /tmp/petsc-F9l5hH/config.libraries/conftest.o  -l1 -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -lmpifort -lgfortran -lm -Wl,-rpath,/usr/local/lib -lgfortran -lm -lquadmath -lm -L/usr/local/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.9.2 -ldl -Wl,-rpath,/usr/local/lib -lmpi -lgcc_s -ldl
stderr:
/bin/ld: cannot find -l1
                    Popping language C
              Checking for no name mangling on BLAS/LAPACK
                  Checking for functions [ddot] in library ['1'] ['-L/usr/local/lib', '-L/usr/lib/gcc/x86_64-redhat-linux/4.9.2', '-lmpifort', '-lgfortran', '-lm', '-Wl,-rpath,/usr/local/lib', '-lgfortran', '-lm', '-lquadmath', '-lm']
                    Pushing language C
Successful compile:
Source:
char ddot();
static void _check_ddot() { ddot(); }
int main() {
_check_ddot();;
  return 0;
                            Pushing language C
                            Popping language C
stderr:
                    Popping language C
              Checking for underscore name mangling on BLAS/LAPACK
                    Pushing language C
Successful compile:
Source:
char ddot_();
int main() {
_check_ddot_();;
  return 0;
                            Pushing language C
                            Popping language C
stderr:
                    Popping language C
              Unknown name mangling in BLAS/LAPACK
**** Configure header /tmp/petsc-F9l5hH/confdefs.h ****
#if !defined(INCLUDED_UNKNOWN)
#define INCLUDED_UNKNOWN
#ifndef IS_COLORING_MAX
#define IS_COLORING_MAX 65535
#endif
#ifndef STDC_HEADERS
#define STDC_HEADERS 1
#endif
#ifndef MPIU_COLORING_VALUE
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#endif
#ifndef PETSC_HAVE_GZIP
#define PETSC_HAVE_GZIP 1
#endif
#ifndef PETSC_HAVE_STRING_H
#define PETSC_HAVE_STRING_H 1
#endif
#ifndef PETSC_HAVE_SYS_TYPES_H
#define PETSC_HAVE_SYS_TYPES_H 1
#endif
#ifndef PETSC_HAVE_ENDIAN_H
#define PETSC_HAVE_ENDIAN_H 1
#endif
#ifndef PETSC_HAVE_SYS_PROCFS_H
#define PETSC_HAVE_SYS_PROCFS_H 1
#endif
#ifndef PETSC_HAVE_DLFCN_H
#define PETSC_HAVE_DLFCN_H 1
#endif
#ifndef PETSC_HAVE_SCHED_H
#define PETSC_HAVE_SCHED_H 1
#endif
#ifndef PETSC_HAVE_STDINT_H
#define PETSC_HAVE_STDINT_H 1
#endif
#ifndef PETSC_HAVE_LINUX_KERNEL_H
#define PETSC_HAVE_LINUX_KERNEL_H 1
#endif
#ifndef PETSC_HAVE_TIME_H
#define PETSC_HAVE_TIME_H 1
#endif
#ifndef PETSC_HAVE_MATH_H
#define PETSC_HAVE_MATH_H 1
#endif
#ifndef PETSC_TIME_WITH_SYS_TIME
#define PETSC_TIME_WITH_SYS_TIME 1
#endif
#ifndef PETSC_HAVE_SYS_PARAM_H
#define PETSC_HAVE_SYS_PARAM_H 1
#endif
#ifndef PETSC_HAVE_PTHREAD_H
#define PETSC_HAVE_PTHREAD_H 1
#endif
#ifndef PETSC_HAVE_UNISTD_H
#define PETSC_HAVE_UNISTD_H 1
#endif
#ifndef PETSC_HAVE_STDLIB_H
#define PETSC_HAVE_STDLIB_H 1
#endif
#ifndef PETSC_HAVE_SYS_WAIT_H
#define PETSC_HAVE_SYS_WAIT_H 1
#endif
#ifndef PETSC_HAVE_SETJMP_H
#define PETSC_HAVE_SETJMP_H 1
#endif
#ifndef PETSC_HAVE_LIMITS_H
#define PETSC_HAVE_LIMITS_H 1
#endif
#ifndef PETSC_HAVE_SYS_UTSNAME_H
#define PETSC_HAVE_SYS_UTSNAME_H 1
#endif
#ifndef PETSC_HAVE_NETINET_IN_H
#define PETSC_HAVE_NETINET_IN_H 1
#endif
#ifndef PETSC_HAVE_SYS_SOCKET_H
#define PETSC_HAVE_SYS_SOCKET_H 1
#endif
#ifndef PETSC_HAVE_FLOAT_H
#define PETSC_HAVE_FLOAT_H 1
#endif
#ifndef PETSC_HAVE_SEARCH_H
#define PETSC_HAVE_SEARCH_H 1
#endif
#ifndef PETSC_HAVE_SYS_RESOURCE_H
#define PETSC_HAVE_SYS_RESOURCE_H 1
#endif
#ifndef PETSC_HAVE_SYS_TIMES_H
#define PETSC_HAVE_SYS_TIMES_H 1
#endif
#ifndef PETSC_HAVE_NETDB_H
#define PETSC_HAVE_NETDB_H 1
#endif
#ifndef PETSC_HAVE_MALLOC_H
#define PETSC_HAVE_MALLOC_H 1
#endif
#ifndef PETSC_HAVE_PWD_H
#define PETSC_HAVE_PWD_H 1
#endif
#ifndef PETSC_HAVE_FCNTL_H
#define PETSC_HAVE_FCNTL_H 1
#endif
#ifndef PETSC_HAVE_STRINGS_H
#define PETSC_HAVE_STRINGS_H 1
#endif
#ifndef PETSC_HAVE_SYS_SYSINFO_H
#define PETSC_HAVE_SYS_SYSINFO_H 1
#endif
#ifndef PETSC_HAVE_SYS_TIME_H
#define PETSC_HAVE_SYS_TIME_H 1
#endif
#ifndef PETSC_USING_F90
#define PETSC_USING_F90 1
#endif
#ifndef PETSC_USING_F2003
#define PETSC_USING_F2003 1
#endif
#ifndef PETSC_HAVE_RTLD_NOW
#define PETSC_HAVE_RTLD_NOW 1
#endif
#ifndef PETSC_HAVE_RTLD_LOCAL
#define PETSC_HAVE_RTLD_LOCAL 1
#endif
#ifndef PETSC_HAVE_RTLD_LAZY
#define PETSC_HAVE_RTLD_LAZY 1
#endif
#ifndef PETSC_C_STATIC_INLINE
#define PETSC_C_STATIC_INLINE static inline
#endif
#ifndef PETSC_HAVE_FORTRAN_UNDERSCORE
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#endif
#ifndef PETSC_HAVE_CXX_NAMESPACE
#define PETSC_HAVE_CXX_NAMESPACE 1
#endif
#ifndef PETSC_HAVE_RTLD_GLOBAL
#define PETSC_HAVE_RTLD_GLOBAL 1
#endif
#ifndef PETSC_C_RESTRICT
#define PETSC_C_RESTRICT  __restrict__
#endif
#ifndef PETSC_CXX_RESTRICT
#define PETSC_CXX_RESTRICT  __restrict__
#endif
#ifndef PETSC_CXX_STATIC_INLINE
#define PETSC_CXX_STATIC_INLINE static inline
#endif
#ifndef PETSC_HAVE_LIBZ
#define PETSC_HAVE_LIBZ 1
#endif
#ifndef PETSC_HAVE_LIBDL
#define PETSC_HAVE_LIBDL 1
#endif
#ifndef PETSC_HAVE_LIBM
#define PETSC_HAVE_LIBM 1
#endif
#ifndef PETSC_HAVE_LIBCRYPTO
#define PETSC_HAVE_LIBCRYPTO 1
#endif
#ifndef PETSC_HAVE_FENV_H
#define PETSC_HAVE_FENV_H 1
#endif
#ifndef PETSC_HAVE_LOG2
#define PETSC_HAVE_LOG2 1
#endif
#ifndef PETSC_HAVE_LIBHDF5
#define PETSC_HAVE_LIBHDF5 1
#endif
#ifndef PETSC_HAVE_ERF
#define PETSC_HAVE_ERF 1
#endif
#ifndef PETSC_HAVE_LIBSSL
#define PETSC_HAVE_LIBSSL 1
#endif
#ifndef PETSC_HAVE_TGAMMA
#define PETSC_HAVE_TGAMMA 1
#endif
#ifndef PETSC_ARCH
#define PETSC_ARCH "linux"
#endif
#ifndef PETSC_USE_SCALAR_REAL
#define PETSC_USE_SCALAR_REAL 1
#endif
#ifndef PETSC_HAVE_ISINF
#define PETSC_HAVE_ISINF 1
#endif
#ifndef PETSC_HAVE_ISNAN
#define PETSC_HAVE_ISNAN 1
#endif
#ifndef PETSC_HAVE_ISNORMAL
#define PETSC_HAVE_ISNORMAL 1
#endif
#ifndef PETSC_USE_REAL_DOUBLE
#define PETSC_USE_REAL_DOUBLE 1
#endif
#ifndef PETSC_SIZEOF_MPI_COMM
#define PETSC_SIZEOF_MPI_COMM 4
#endif
#ifndef PETSC_BITS_PER_BYTE
#define PETSC_BITS_PER_BYTE 8
#endif
#ifndef PETSC_SIZEOF_MPI_FINT
#define PETSC_SIZEOF_MPI_FINT 4
#endif
#ifndef PETSC_USE_VISIBILITY_C
#define PETSC_USE_VISIBILITY_C 1
#endif
#ifndef PETSC_SIZEOF_VOID_P
#define PETSC_SIZEOF_VOID_P 8
#endif
#ifndef PETSC_RETSIGTYPE
#define PETSC_RETSIGTYPE void
#endif
#ifndef PETSC_HAVE_CXX_COMPLEX
#define PETSC_HAVE_CXX_COMPLEX 1
#endif
#ifndef PETSC_SIZEOF_LONG
#define PETSC_SIZEOF_LONG 8
#endif
#ifndef PETSC_USE_FORTRANKIND
#define PETSC_USE_FORTRANKIND 1
#endif
#ifndef PETSC_USE_VISIBILITY_CXX
#define PETSC_USE_VISIBILITY_CXX 1
#endif
#ifndef PETSC_SIZEOF_SIZE_T
#define PETSC_SIZEOF_SIZE_T 8
#endif
#ifndef PETSC_HAVE_SIGINFO_T
#define PETSC_HAVE_SIGINFO_T 1
#endif
#ifndef PETSC_SIZEOF_CHAR
#define PETSC_SIZEOF_CHAR 1
#endif
#ifndef PETSC_SIZEOF_DOUBLE
#define PETSC_SIZEOF_DOUBLE 8
#endif
#ifndef PETSC_SIZEOF_FLOAT
#define PETSC_SIZEOF_FLOAT 4
#endif
#ifndef PETSC_HAVE_C99_COMPLEX
#define PETSC_HAVE_C99_COMPLEX 1
#endif
#ifndef PETSC_SIZEOF_INT
#define PETSC_SIZEOF_INT 4
#endif
#ifndef PETSC_SIZEOF_LONG_LONG
#define PETSC_SIZEOF_LONG_LONG 8
#endif
#ifndef PETSC_SIZEOF_SHORT
#define PETSC_SIZEOF_SHORT 2
#endif
#ifndef PETSC_CLANGUAGE_CXX
#define PETSC_CLANGUAGE_CXX 1
#endif
#ifndef PETSC_HAVE_MPI_F90MODULE
#define PETSC_HAVE_MPI_F90MODULE 1
#endif
#ifndef PETSC_HAVE_MPI_IALLREDUCE
#define PETSC_HAVE_MPI_IALLREDUCE 1
#endif
#ifndef PETSC_HAVE_MPI_REDUCE_SCATTER_BLOCK
#define PETSC_HAVE_MPI_REDUCE_SCATTER_BLOCK 1
#endif
#ifndef PETSC_HAVE_MPI_IN_PLACE
#define PETSC_HAVE_MPI_IN_PLACE 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_C2F
#define PETSC_HAVE_MPI_COMM_C2F 1
#endif
#ifndef PETSC_HAVE_MPI_COMBINER_CONTIGUOUS
#define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
#endif
#ifndef PETSC_HAVE_MPI_INT64_T
#define PETSC_HAVE_MPI_INT64_T 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_GET_EXTENT
#define PETSC_HAVE_MPI_TYPE_GET_EXTENT 1
#endif
#ifndef PETSC_HAVE_MPI_WIN_CREATE
#define PETSC_HAVE_MPI_WIN_CREATE 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_DUP
#define PETSC_HAVE_MPI_TYPE_DUP 1
#endif
#ifndef PETSC_HAVE_MPI_INIT_THREAD
#define PETSC_HAVE_MPI_INIT_THREAD 1
#endif
#ifndef PETSC_HAVE_MPI_LONG_DOUBLE
#define PETSC_HAVE_MPI_LONG_DOUBLE 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_F2C
#define PETSC_HAVE_MPI_COMM_F2C 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_GET_ENVELOPE
#define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
#endif
#define PETSC_HAVE_MPI_REDUCE_SCATTER 1
#endif
#ifndef PETSC_HAVE_MPI_COMBINER_DUP
#define PETSC_HAVE_MPI_COMBINER_DUP 1
#endif
#ifndef PETSC_HAVE_MPICH_NUMVERSION
#define PETSC_HAVE_MPICH_NUMVERSION 30200300
#endif
#ifndef PETSC_HAVE_MPIIO
#define PETSC_HAVE_MPIIO 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_SPAWN
#define PETSC_HAVE_MPI_COMM_SPAWN 1
#endif
#ifndef PETSC_HAVE_MPI_FINT
#define PETSC_HAVE_MPI_FINT 1
#endif
#ifndef PETSC_HAVE_MPI_IBARRIER
#define PETSC_HAVE_MPI_IBARRIER 1
#endif
#ifndef PETSC_HAVE_MPI_ALLTOALLW
#define PETSC_HAVE_MPI_ALLTOALLW 1
#endif
#ifndef PETSC_HAVE_MPI_REDUCE_LOCAL
#define PETSC_HAVE_MPI_REDUCE_LOCAL 1
#endif
#ifndef PETSC_HAVE_MPI_REPLACE
#define PETSC_HAVE_MPI_REPLACE 1
#endif
#ifndef PETSC_HAVE_MPI_EXSCAN
#define PETSC_HAVE_MPI_EXSCAN 1
#endif
#ifndef PETSC_HAVE_MPI_FINALIZED
#define PETSC_HAVE_MPI_FINALIZED 1
#endif
#ifndef PETSC_HAVE_DYNAMIC_LIBRARIES
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#endif
#ifndef PETSC_HAVE_SHARED_LIBRARIES
#define PETSC_HAVE_SHARED_LIBRARIES 1
#endif
#ifndef PETSC_USE_GDB_DEBUGGER
#define PETSC_USE_GDB_DEBUGGER 1
#endif
#ifndef PETSC_USE_ERRORCHECKING
#define PETSC_USE_ERRORCHECKING 1
#endif
#ifndef PETSC_HAVE_STRCASECMP
#define PETSC_HAVE_STRCASECMP 1
#endif
#ifndef PETSC_HAVE_GET_NPROCS
#define PETSC_HAVE_GET_NPROCS 1
#endif
#ifndef PETSC_HAVE_POPEN
#define PETSC_HAVE_POPEN 1
#endif
#ifndef PETSC_HAVE_SIGSET
#define PETSC_HAVE_SIGSET 1
#endif
#ifndef PETSC_HAVE_GETWD
#define PETSC_HAVE_GETWD 1
#endif
#ifndef PETSC_HAVE_VSNPRINTF
#define PETSC_HAVE_VSNPRINTF 1
#endif
#ifndef PETSC_HAVE_TIMES
#define PETSC_HAVE_TIMES 1
#endif
#ifndef PETSC_HAVE_DLSYM
#define PETSC_HAVE_DLSYM 1
#endif
#ifndef PETSC_HAVE_SNPRINTF
#define PETSC_HAVE_SNPRINTF 1
#endif
#ifndef PETSC_HAVE_GETHOSTBYNAME
#define PETSC_HAVE_GETHOSTBYNAME 1
#endif
#ifndef PETSC_HAVE_GETCWD
#define PETSC_HAVE_GETCWD 1
#endif
#ifndef PETSC_HAVE_DLERROR
#define PETSC_HAVE_DLERROR 1
#endif
#ifndef PETSC_HAVE_FORK
#define PETSC_HAVE_FORK 1
#endif
#ifndef PETSC_HAVE_RAND
#define PETSC_HAVE_RAND 1
#endif
#ifndef PETSC_HAVE_GETTIMEOFDAY
#define PETSC_HAVE_GETTIMEOFDAY 1
#endif
#ifndef PETSC_HAVE_DLCLOSE
#define PETSC_HAVE_DLCLOSE 1
#endif
#ifndef PETSC_HAVE_UNAME
#define PETSC_HAVE_UNAME 1
#endif
#ifndef PETSC_HAVE_GETHOSTNAME
#define PETSC_HAVE_GETHOSTNAME 1
#endif
#ifndef PETSC_HAVE_MKSTEMP
#define PETSC_HAVE_MKSTEMP 1
#endif
#ifndef PETSC_HAVE_SIGACTION
#define PETSC_HAVE_SIGACTION 1
#endif
#ifndef PETSC_HAVE_DRAND48
#define PETSC_HAVE_DRAND48 1
#endif
#ifndef PETSC_HAVE_MEMALIGN
#define PETSC_HAVE_MEMALIGN 1
#endif
#ifndef PETSC_HAVE_VA_COPY
#define PETSC_HAVE_VA_COPY 1
#endif
#ifndef PETSC_HAVE_CLOCK
#define PETSC_HAVE_CLOCK 1
#endif
#ifndef PETSC_HAVE_ACCESS
#define PETSC_HAVE_ACCESS 1
#endif
#ifndef PETSC_HAVE_SIGNAL
#define PETSC_HAVE_SIGNAL 1
#endif
#ifndef PETSC_HAVE_USLEEP
#define PETSC_HAVE_USLEEP 1
#endif
#ifndef PETSC_HAVE_GETRUSAGE
#define PETSC_HAVE_GETRUSAGE 1
#endif
#ifndef PETSC_HAVE_VFPRINTF
#define PETSC_HAVE_VFPRINTF 1
#endif
#ifndef PETSC_HAVE_NANOSLEEP
#define PETSC_HAVE_NANOSLEEP 1
#endif
#ifndef PETSC_HAVE_GETDOMAINNAME
#define PETSC_HAVE_GETDOMAINNAME 1
#endif
#define PETSC_HAVE_TIME 1
#endif
#ifndef PETSC_HAVE_LSEEK
#define PETSC_HAVE_LSEEK 1
#endif
#ifndef PETSC_HAVE_SOCKET
#define PETSC_HAVE_SOCKET 1
#endif
#ifndef PETSC_HAVE_SYSINFO
#define PETSC_HAVE_SYSINFO 1
#endif
#ifndef PETSC_HAVE_READLINK
#define PETSC_HAVE_READLINK 1
#endif
#ifndef PETSC_HAVE_REALPATH
#define PETSC_HAVE_REALPATH 1
#endif
#ifndef PETSC_HAVE_DLOPEN
#define PETSC_HAVE_DLOPEN 1
#endif
#ifndef PETSC_HAVE_MEMMOVE
#define PETSC_HAVE_MEMMOVE 1
#endif
#ifndef PETSC_HAVE__GFORTRAN_IARGC
#define PETSC_HAVE__GFORTRAN_IARGC 1
#endif
#ifndef PETSC_SIGNAL_CAST
#define PETSC_SIGNAL_CAST
#endif
#ifndef PETSC_HAVE_SLEEP
#define PETSC_HAVE_SLEEP 1
#endif
#ifndef PETSC_HAVE_VPRINTF
#define PETSC_HAVE_VPRINTF 1
#endif
#ifndef PETSC_HAVE_BZERO
#define PETSC_HAVE_BZERO 1
#endif
#ifndef PETSC_HAVE_GETPAGESIZE
#define PETSC_HAVE_GETPAGESIZE 1
#endif
#ifndef PETSC_WRITE_MEMORY_BARRIER
#define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
#endif
#ifndef PETSC_MEMORY_BARRIER
#define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
#endif
#ifndef PETSC_READ_MEMORY_BARRIER
#define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
#endif
#ifndef PETSC_CPU_RELAX
#define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
#endif
#ifndef PETSC_USE_INFO
#define PETSC_USE_INFO 1
#endif
#ifndef PETSC_Alignx
#define PETSC_Alignx(a,b)
#endif
#ifndef PETSC_USE_BACKWARD_LOOP
#define PETSC_USE_BACKWARD_LOOP 1
#endif
#ifndef PETSC_IS_COLOR_VALUE_TYPE_SIZE
#define PETSC_IS_COLOR_VALUE_TYPE_SIZE PETSC_SIZEOF_SHORT
#endif
#ifndef PETSC_USE_MALLOC_COALESCED
#define PETSC_USE_MALLOC_COALESCED 1
#endif
#define PETSC_IS_COLOR_VALUE_TYPE short
#endif
#ifndef PETSC_USE_CTABLE
#define PETSC_USE_CTABLE 1
#endif
#ifndef PETSC_MEMALIGN
#define PETSC_MEMALIGN 16
#endif
#ifndef PETSC__GNU_SOURCE
#define PETSC__GNU_SOURCE 1
#endif
#ifndef PETSC__BSD_SOURCE
#define PETSC__BSD_SOURCE 1
#endif
#ifndef PETSC__DEFAULT_SOURCE
#define PETSC__DEFAULT_SOURCE 1
#endif
#ifndef PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#endif
#ifndef PETSC_HAVE_GFORTRAN_IARGC
#define PETSC_HAVE_GFORTRAN_IARGC 1
#endif
#ifndef PETSC_LEVEL1_DCACHE_LINESIZE
#define PETSC_LEVEL1_DCACHE_LINESIZE 64
#endif
#ifndef PETSC_LEVEL1_DCACHE_SIZE
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#endif
#ifndef PETSC_LEVEL1_DCACHE_ASSOC
#define PETSC_LEVEL1_DCACHE_ASSOC 8
#endif
#ifndef PETSC_USE_PROC_FOR_SIZE
#define PETSC_USE_PROC_FOR_SIZE 1
#endif
#ifndef PETSC_HAVE_SCHED_CPU_SET_T
#define PETSC_HAVE_SCHED_CPU_SET_T 1
#endif
#ifndef PETSC_HAVE_PTHREAD_BARRIER_T
#define PETSC_HAVE_PTHREAD_BARRIER_T 1
#endif
#ifndef PETSC_HAVE_SYS_SYSCTL_H
#define PETSC_HAVE_SYS_SYSCTL_H 1
#endif
#endif
**** C specific Configure header /tmp/petsc-F9l5hH/conffix.h ****
#if defined(__cplusplus)
extern "C" {
#else
#endif
#endif
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
You set a value for --with-blas-lapack-lib=<lib>, but ['1'] cannot be used
  File "./config/configure.py", line 406, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/framework.py", line 1090, in configure
    self.processChildren()
  File "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/framework.py", line 1079, in processChildren
    self.serialEvaluation(self.childGraph)
  File "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/framework.py", line 1060, in serialEvaluation
    child.configure()
  File "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/BlasLapack.py", line 544, in configure
    self.executeTest(self.configureLibrary)
  File "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/base.py", line 126, in executeTest
    ret = test(*args,**kargs)
  File "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/BlasLapack.py", line 341, in configureLibrary
    for (name, blasLibrary, lapackLibrary, self.useCompatibilityLibs) in self.generateGuesses():
  File "/home/mpovolot/NEMO5/NEMO/libs/petsc/build-real/config/BuildSystem/config/packages/BlasLapack.py", line 181, in generateGuesses
    raise RuntimeError('You set a value for --with-blas-lapack-lib=<lib>, but '+str(self.argDB['with-blas-lapack-lib'])+' cannot be used\n')
Finishing Configure Run at Sun Nov  6 01:52:24 2016
