[petsc-users] Inconsistent data
Bikash Kanungo bikash at umich.edu
Tue Nov 1 23:09:33 CDT 2016
I'm trying to perform several KSPSolve in sequence. After several
successful runs I get the following error:
[4]PETSC ERROR: Petsc has generated inconsistent data
[4]PETSC ERROR: No more room in array, limit 256
 recompile src/sys/objects/destroy.c with larger value for MAXREGDESOBJS
[7]PETSC ERROR: #1 PetscObjectRegisterDestroy() line 228 in
/home/bikash/fem_dft_softwares/petsc/petsc-3.6.3/src/sys/objects/destroy.c
[7]PETSC ERROR: #2 PetscViewerASCIIGetStdout() line 45 in
/home/bikash/fem_dft_softwares/petsc/petsc-3.6.3/src/sys/classes/viewer/impls/ascii/vcreatea.c
[2]PETSC ERROR: #3 PETSC_VIEWER_STDOUT_() line 81 in
/home/bikash/fem_dft_softwares/petsc/petsc-3.6.3/src/sys/classes/viewer/impls/ascii/vcreatea.c\
[3]PETSC ERROR: #4 PetscObjectRegisterDestroy() line 228 in
[3]PETSC ERROR: #5 PetscViewerASCIIGetStdout() line 45 in
[4]PETSC ERROR: #6 PETSC_VIEWER_STDOUT_() line 81 in
[5]PETSC ERROR: #7 PetscObjectRegisterDestroy() line 228 in
[5]PETSC ERROR: #8 PetscViewerASCIIGetStdout() line 45 in
[5]PETSC ERROR: #9 PCView() line 1695 in
/home/bikash/fem_dft_softwares/petsc/petsc-3.6.3/src/ksp/pc/interface/precon.c
[5]PETSC ERROR: #10 KSPView() line 211 in
/home/bikash/fem_dft_softwares/petsc/petsc-3.6.3/src/ksp/ksp/interface/itcreate.c
I tried to be destroy the ksp object after each solve but to no avail. Can
you provide some input on what might be causing the abort?
Bikash
Bikash S. Kanungo
PhD Student
Computational Materials Physics Group
Mechanical Engineering
University of Michigan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161102/173589d0/attachment.html>
