[petsc-users] re. AIJ preallocation man page
Karl Rupp rupp at iue.tuwien.ac.at
Mon May 23 06:39:14 CDT 2016
Hi Marco,
 > I'm struggling with this statement:
> "It is recommended that you call both of the above preallocation
> routines [MatSeqAIJSetPreallocation and MatMPIAIJSetPreallocation] for
> simplicity."
> (source: https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATAIJ.html
> I saw that, even on a single-processor communicator,
> MatMPIAIJSetPreallocation works fine (at least, it gives no errors,
> but I don't know about efficiency drops).
> What's the effect of the recommended double preallocation?
It allows you to quickly switch between a serial run and a parallel run.
If something doesn't work as expected, it's much easier to debug (if
possible) on a single rank, hence MatSeqAIJSetPreallocation. However,
ultimately you are looking for parallel runs, for which you need
MatMPIAIJSetPreallocation. Changing your code back and forth is
non-productive, hence it's recommended to call both and you get full
flexibility :-)
Best regards,
Karli
