[petsc-users] petsc and slepc incompatibility
Sun May 8 10:12:47 CDT 2016
On Sun, 8 May 2016, Dominic Steinitz wrote:
> Can someone advise me which version of PETSc and SLEPc are compatible? Should
> I try PETSc 3.6.4 and SLEPc 3.6.3 or 3.6.0?
To clarify - if using petsc-3.6 with slepc 3.6 - you should use the
latest patched version for these packages. That would be petsc-3.6.4
with slepc-3.6.3.
There is no realson to use petsc-3.6.0 or 3.6.1 etcc as petsc-3.6.4
privides bug fixes and superseeds them. [similarly with slepc-3.6.0 ..]
Satish
