[petsc-users] MatSetSizes with blocked matrix
Steena Monteiro steena.hpc at gmail.com
Wed Mar 23 19:11:53 CDT 2016
Thanks, Barry. The block size compatibility was a probe to investigate an
error arising when trying to assign unequal numbers of rows across two MPI
ranks.
To re-visit the initial question, what is going wrong when I try to divide
rows unequally across MPI ranks using MatSetSize?
For matrix A with rows=cols=1,139,905 and block size = 2,
rank 0 gets 400000 rows and rank 1, 739905 rows
if (!rank) {
    ierr = MatSetSizes(A, 400000, PETSC_DECIDE,
1139905,1139905);CHKERRQ(ierr);
else {
    ierr = MatSetSizes(A, 739905, PETSC_DECIDE,
MatMult (A,x,y);
Error message:
[1]PETSC ERROR: [0]PETSC ERROR: No support for this operation for this
object type
Cannot change/reset row sizes to 400000 local 1139906 global after
previously setting them to 400000 local 1139905 global
[1]PETSC ERROR: [0]PETSC ERROR: Cannot change/reset row sizes to 739905
local 1139906 global after previously setting them to 739905 local 1139905
global
On 23 March 2016 at 15:46, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   The baij and sbaij MatLoad() do automatically pad the matrix with
> rows/columns of the identity to make it divisible by the block size. This
> is why you are seeing what you are seeing.
>    Barry
> Is this a good idea? Maybe not
> > On Mar 22, 2016, at 8:59 PM, Steena Monteiro <steena.hpc at gmail.com>
> wrote:
> > So, are you saying that
> >   1) You have a matrix with odd total dimension
> >   2) You set the block size of the initial matrix to 2
> >   3) You load the matrix
> > and there is no error? Can you make a simple example with a matrix of
> size 5?
> > I can put in the relevant error checking.
> > Hi Matt,
> > Thank you for the suggestion.
> > I used cage3, a 5x5 matrix from the UFL collection, converted it to
> binary, and tested the code for block sizes 1 through 7. I added  printfs
> inside all the MatMult_SeqBAIJ_*s in baij2.c  and also logged some counts
> (blocked rows and blocks). The counts make sense if the matrix is being
> padded somewhere to accommodate for block sizes that are not completely
> divisible by matrix dimensions.
> > surface86 at monteiro:./rvector-petsctrain-seqbaij -fin cage3.dat
> -matload_block_size 2
> > Inside SeqBAIJ_2
> -matload_block_size 3
> > Inside MatMult_SeqBAIJ_3
> -matload_block_size 7
> > Inside MatMult_SeqBAIJ_7
> > Table for different block sizes listing corresponding number of blocked
> rows and number of blocks inside the rows for cage3.
> > Block size    No. of blocked rows     No. of nnz blocks in each blocked
> row.
> > 1     5       5,3,3,4,4
> > 2     3       3,3,3
> > 3     2       2,2
> > 4     2       2,2
> > 5     1       1
> > 6     1       1
> > 7     1       1
> > I am attaching cage3.dat and cage3.mtx.
> > Thanks,
> > Steena
> >   ierr = MatCreateVecs(A, &x, &y);CHKERRQ(ierr);
> >   ierr =  VecSetRandom(x,NULL); CHKERRQ(ierr);
> >   ierr = VecSet(y,zero); CHKERRQ(ierr);
> >   ierr = MatMult(A,x,y); CHKERRQ(ierr);
> >   ierr = PetscViewerDestroy(&fd);CHKERRQ(ierr);
> >   ierr = MatDestroy(&A);CHKERRQ(ierr);
> >   ierr = VecDestroy(&x);CHKERRQ(ierr);
> >   ierr = VecDestroy(&y);CHKERRQ(ierr);
> > Thanks,
> > Steena
> > On 15 March 2016 at 09:15, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Mar 15, 2016 at 11:04 AM, Steena Monteiro <steena.hpc at gmail.com>
> wrote:
> > I pass a binary, matrix data file at the command line and load it into
> the matrix:
> > PetscInitialize(&argc,&args,(char*)0,help);
> > ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
> > /* converted mtx to dat file*/
> > ierr = PetscOptionsGetString(NULL,"-f",file,PETSC_MAX_PATH_LEN,&flg);
> > CHKERRQ(ierr);
> > if (!flg) SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_USER,"specify matrix dat
> file with -f");
> >  /* Load matrices */
> > ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&fd);CHKERRQ(ierr);
> > ierr =
> > ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
> > ierr = MatSetFromOptions(A);CHKERRQ(ierr);
> > Nothing above loads a matrix. Do you also call MatLoad()?
> >   Matt
> > Thanks,
> > Steena
> > On 15 March 2016 at 08:58, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Mar 15, 2016 at 10:54 AM, Steena Monteiro <steena.hpc at gmail.com>
> wrote:
> > Thank you, Dave.
> > Matt: I understand the inconsistency but MatMult with non divisible
> block sizes (here, 2) does not throw any errors and fail, when MatSetSize
> is commented out. Implying that 1139905 global size does work with block
> size 2.
> > If you comment out MatSetSize(), how does it know what size the Mat is?
> >    Matt
> > On 15 March 2016 at 00:12, Dave May <dave.mayhem23 at gmail.com> wrote:
> > On 15 March 2016 at 04:46, Matthew Knepley <knepley at gmail.com> wrote:
> > On Mon, Mar 14, 2016 at 10:05 PM, Steena Monteiro <steena.hpc at gmail.com>
> wrote:
> > Hello,
> > I am having difficulty getting MatSetSize to work prior to using MatMult.
> > It is inconsistent to have a row/col size that is not divisible by the
> block size.
> > To be honest, I don't think the error message being thrown clearly
> indicates what the actual problem is (hence the email from Steena). What
> about
> > "Cannot change/reset row sizes to 400000 local 1139906 global after
> previously setting them to 400000 local 1139905 global. Local and global
> sizes must be divisible by the block size"
> >   Matt
> > rank 0 gets 400000 rows and rank 1 739905 rows,  like so:
> > /*Matrix setup*/
> > ierr=PetscViewerBinaryOpen(PETSC_COMM_WORLD,file,FILE_MODE_READ,&fd);
> > ierr = MatSetType(A,MATBAIJ);
> > ierr = MatSetBlockSize(A,2);
> > /*Unequal row assignment*/
> >  if (!rank) {
> > else {
> > MatMult (A,x,y);
> > Error message:
> object type
> global
> > -Without messing with row assignment,  MatMult works fine on this matrix
> for block size = 2, presumably because an extra padded row is automatically
> added to facilitate blocking.
> > -The above code snippet works well for block size = 1.
> > Is it possible to do unequal row distribution while using blocking?
> > Thank you for any advice.
> > -Steena
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
> > <cage3.dat><cage3.mtx>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160323/e14b5506/attachment-0001.html>
