[petsc-users] question about the PetscFVLeastSquaresPseudoInverseSVD
Rongliang Chen rongliang.chan at gmail.com
Mon Mar 21 22:10:21 CDT 2016
Hello All,
Can anyone help me to understand the output of
PetscFVLeastSquaresPseudoInverseSVD?
I tested six matrices and the results confused me. The results are
followed and the source codes are attached.
For the cases m>n, the results make sense for me, and for the m<=n
cases, I do not understand the results. For example, for the m=n=3
cases, I think I should get an identity matrix from this function and I
get two difference outputs for the same input matrix.
Best regards,
Rongliang
Initialize the matrix A (is a 3 x 4 matrix):
1.000000 0.000000 0.000000 0.000000
0.000000 1.000000 0.000000 0.000000
0.000000 0.000000 1.000000 0.000000
Initialize the matrix B:
0.000000 0.000000 0.000000 1.000000
The output of the SVD based least square:
Initialize the matrix A (is a 3 x 3 matrix):
0.500000 0.000000 -0.500000
0.500000 -0.707107 0.000000
-0.000000 1.414214 0.000000
Initialize the matrix A (is a 3 x 2 matrix):
1.000000 0.000000
0.000000 1.000000
0.000000 0.000000
1.000000 -0.838728
0.000000 0.000000
-0.000000 1.305169
1.000000 0.000000
0.000000 1.000000
0.000000 0.000000
1.000000 -0.293611
0.000000 0.000000
-0.000000 1.000000
#include <petscts.h>
#include <petscfv.h>
#include <petscdmplex.h>
#include <petscsf.h>
#include <petscblaslapack.h>
#include <petsctime.h>
static char help[] = "Test the SVD function.\n";
#undef __FUNCT__
#define __FUNCT__ "PetscFVLeastSquaresPseudoInverseSVD"
/* Overwrites A. Can handle degenerate problems and m<n. */
PetscErrorCode PetscFVLeastSquaresPseudoInverseSVD(PetscInt m,PetscInt mstride,PetscInt n,PetscScalar *A,PetscScalar *Ainv,PetscScalar *tau,PetscInt worksize,PetscScalar *work)
  PetscBool      debug = PETSC_FALSE;
  PetscScalar   *Brhs, *Aback;
  PetscScalar   *tmpwork;
  PetscReal      rcond;
  PetscInt       i, j, maxmn;
  PetscBLASInt   M, N, lda, ldb, ldwork;
#if !defined(PETSC_USE_COMPLEX)
  PetscBLASInt   nrhs, irank, info;
#endif
  PetscErrorCode ierr;
  PetscMPIInt       rank;
  PetscFunctionBegin;
  ierr = MPI_Comm_rank(PETSC_COMM_WORLD, &rank);CHKERRQ(ierr);
  if (debug) {
    ierr = PetscMalloc1(m*n,&Aback);CHKERRQ(ierr);
    ierr = PetscMemcpy(Aback,A,m*n*sizeof(PetscScalar));CHKERRQ(ierr);
  tmpwork = Ainv;
  Brhs = work;
  maxmn = PetscMax(m,n);
  ierr = PetscPrintf(PETSC_COMM_WORLD,"Initialize the matrix A (is a %d x %d matrix):\n", n, m);
  /* initialize to identity */
  for (j=0; j<n; j++) {
    for (i=0; i<m; i++) {
      if (i == j) {
        A[i + j*m] = 1.0;
      }else{
        A[i + j*m] = 0.0;
      PetscPrintf(PETSC_COMM_WORLD,"%f ", A[i + j*m]);
    PetscPrintf(PETSC_COMM_WORLD,"\n");
  ierr = PetscPrintf(PETSC_COMM_WORLD,"Initialize the matrix B:\n");
  if (rank==2) PetscPrintf(PETSC_COMM_WORLD,"m = %d, n = %d, maxmn = %d\n", m, n, maxmn);
  for (j=0; j<maxmn; j++) {
    for (i=0; i<maxmn; i++) {
      if (i == j) {
        Brhs[i + j*maxmn] = 1.0;
      }else{
        Brhs[i + j*maxmn] = 0.0;
      PetscPrintf(PETSC_COMM_WORLD,"%f ", Brhs[i + j*maxmn]);
  ierr  = PetscBLASIntCast(m,&M);CHKERRQ(ierr);
  ierr  = PetscBLASIntCast(n,&N);CHKERRQ(ierr);
  ierr  = PetscBLASIntCast(mstride,&lda);CHKERRQ(ierr);
  ierr  = PetscBLASIntCast(maxmn,&ldb);CHKERRQ(ierr);
  ierr  = PetscBLASIntCast(worksize,&ldwork);CHKERRQ(ierr);
  rcond = -1;
  ierr  = PetscFPTrapPush(PETSC_FP_TRAP_OFF);CHKERRQ(ierr);
#if defined(PETSC_USE_COMPLEX)
  if (tmpwork && rcond) rcond = 0.0; /* Get rid of compiler warning */
  SETERRQ(PETSC_COMM_SELF, PETSC_ERR_SUP, "I don't think this makes sense for complex numbers");
#else
  nrhs  = M;
  LAPACKgelss_(&M,&N,&nrhs,A,&lda,Brhs,&ldb, (PetscReal *) tau,&rcond,&irank,tmpwork,&ldwork,&info);
  ierr = PetscFPTrapPop();CHKERRQ(ierr);
  ierr = PetscPrintf(PETSC_COMM_WORLD,"The output of the SVD based least square:\n");
  for (i=0; i<n; i++) {
    for (j=0; j<nrhs; j++) {
      Ainv[i*mstride+j] = Brhs[i + j*maxmn];
      PetscPrintf(PETSC_COMM_WORLD,"%f ", Ainv[i*mstride+j]);
    ierr = PetscPrintf(PETSC_COMM_WORLD,"\n");
  PetscFunctionReturn(0);
#endif
#undef __FUNCT__
#define __FUNCT__ "PseudoInverseGetWorkRequired"
PetscErrorCode PseudoInverseGetWorkRequired(PetscInt maxFaces,PetscInt *work)
  PetscInt m,n,nrhs,minwork;
  PetscFunctionBeginUser;
  m       = maxFaces;
  n       = 3;
  nrhs    = maxFaces;
  minwork = 3*PetscMin(m,n) + PetscMax(2*PetscMin(m,n), PetscMax(PetscMax(m,n), nrhs)); /* required by LAPACK */
  *work   = 5*minwork;          /* We can afford to be extra generous */
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc, char **argv)
  PetscInt       maxNumFaces = 4, worksize;
  PetscScalar    *B,*Binv,*work,*tau;
  PetscInt      dim = 3, numFaces = 4;
  PetscInt      usedFaces[6] = {4, 4, 3, 3, 2, 2};
  PetscInt      i;
  ierr = PetscInitialize(&argc, &argv, (char*) 0, help);CHKERRQ(ierr);
  ierr = PseudoInverseGetWorkRequired(maxNumFaces,&worksize);CHKERRQ(ierr);
  PetscPrintf(PETSC_COMM_WORLD, "maxNumFaces = %d, worksize = %d\n", maxNumFaces, worksize);
  ierr = PetscMalloc4(maxNumFaces*dim, &B, worksize, &Binv, worksize, &work, maxNumFaces, &tau);CHKERRQ(ierr);
  for(i=0; i<6; i++){
    PetscPrintf(PETSC_COMM_WORLD, "-----------------------------------\n");
    ierr = PetscFVLeastSquaresPseudoInverseSVD(usedFaces[i],numFaces,dim,B,Binv,tau,worksize,work);CHKERRQ(ierr);
  ierr = PetscFree4(B,Binv,work,tau);CHKERRQ(ierr);
 ierr = PetscFinalize();
  return(0);
