[petsc-users] makefile for compiling multiple sources
Fri Mar 18 10:04:17 CDT 2016
On Fri, Mar 18, 2016 at 9:49 AM, Matthew Overholt <overholt at capesim.com>
wrote:
> Hi,
> I’m just getting started with PETSc and have been able to configure and
> run the examples, but as I’m starting to put together a more substantial
> code with multiple source files I haven’t been able to find or create a
> makefile which works and follows PETSc guidelines.
> I’ve configured and am building with the Intel compilers and MKL for blas
> & lapack, as per the installation example, and with the C++ language.
Use this:
CFLAGS     =
CPPFLAGS   =
LIBFILES   =
TARGET     = femex1
OBJFILES   = femex1.o shapes.o
CLEANFILES = $(TARGET)
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
all: $(TARGET)
$(TARGET) : $(OBJFILES)
       ${CLINKER} -o $(TARGET) $(OBJFILES) ${PETSC_KSP_LIB}
and do not mess around with putting in header file dependencies yourself,
use https://ccache.samba.org/
    Matt
> Here’s my makefile --------------------------------------
> # makefile for femex1 - PETSc/kde/ex1.c adapted for FEA
> # Usage: make all
> #        make clean
> # PETSc was configured using the Intel Compilers, MKL, and C++
> CFLAGS        =
> CPPFLAGS     =
> CLFLAGS      =
> LIBFILES      = ${PETSC_KSP_LIB}
> TARGET        = femex1
> OBJFILES = femex1.o \
>            shapes.o
> all: $(TARGET)
> $(TARGET) : $(OBJFILES) $(LIBFILES)
>        ${CLINKER} -o $(TARGET) $(OBJFILES) $(LIBFILES)
> # femex1.cpp has 'main' and PETSc calls
> femex1.o: femex1.cpp lists.h shapes.h  chkopts
>        ${PETSC_CXXCOMPILE} femex1.cpp
> # shapes.cpp does not have any PETSc calls
> shapes.o: shapes.cpp shapes.h
>        icpc -c shapes.cpp
> And here’s the result ------------------------------------
> [Matt at HPCL1 mycode]$ make all
> /opt/petsc/petsc-3.6.3/linux-gnu-intel/bin/mpicxx -c -wd1572 -g  -fPIC
> -I/opt/petsc/petsc-3.6.3/include
> -I/opt/petsc/petsc-3.6.3/linux-gnu-intel/include      femex1.cpp
> icpc -c shapes.cpp
> make: *** No rule to make target
> `-Wl,-rpath,/opt/petsc/petsc-3.6.3/linux-gnu-intel/lib', needed by
> `femex1'.  Stop.
> So it compiles the two sources, but then fails on the linking step.
> Thanks in advance.
> Matt Overholt
> CapeSym, Inc.
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=oa-2115-d> This
> email is safe. www.avast.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160318/9706c7ae/attachment-0001.html>
